[mapguide-commits] r5850 - in trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb: . Tasks
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 24 13:58:50 EDT 2011
Author: jng
Date: 2011-05-24 10:58:50 -0700 (Tue, 24 May 2011)
New Revision: 5850
Added:
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.designer.cs
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.designer.cs
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx
   trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx
#1676: Update the web sample with examples for toggling group/layer visibility
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj	2011-05-24 17:42:07 UTC (rev 5849)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj	2011-05-24 17:58:50 UTC (rev 5850)
@@ -85,6 +85,8 @@
     <Content Include="Global.asax" />
     <Content Include="readme.txt" />
     <Content Include="Tasks\AddTracksLayer.aspx" />
+    <Content Include="Tasks\ToggleGroupVisibility.aspx" />
+    <Content Include="Tasks\ToggleLayerVisibility.aspx" />
     <Content Include="Tasks\ToggleParcelsLayer.aspx" />
     <Content Include="Tasks\Home.aspx" />
     <Content Include="Web.config" />
@@ -108,6 +110,20 @@
     <Compile Include="Tasks\AddTracksLayer.aspx.designer.cs">
       <DependentUpon>AddTracksLayer.aspx</DependentUpon>
     </Compile>
+    <Compile Include="Tasks\ToggleGroupVisibility.aspx.cs">
+      <DependentUpon>ToggleGroupVisibility.aspx</DependentUpon>
+      <SubType>ASPXCodeBehind</SubType>
+    </Compile>
+    <Compile Include="Tasks\ToggleGroupVisibility.aspx.designer.cs">
+    </Compile>
+    <Compile Include="Tasks\ToggleLayerVisibility.aspx.cs">
+      <DependentUpon>ToggleLayerVisibility.aspx</DependentUpon>
+    </Compile>
+    <Compile Include="Tasks\ToggleLayerVisibility.aspx.designer.cs">
+    </Compile>
     <Compile Include="Tasks\ToggleParcelsLayer.aspx.cs">
       <DependentUpon>ToggleParcelsLayer.aspx</DependentUpon>
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx	2011-05-24 17:42:07 UTC (rev 5849)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx	2011-05-24 17:58:50 UTC (rev 5850)
@@ -11,7 +11,7 @@
     <div>
         <asp:Label ID="lblMessage" runat="server"></asp:Label>
         <br />
-        <a href="javascript:history.go(-1)">Go back</a>
+        <a href="Home.aspx">Go back</a>
         <br />
         <div id="debug" runat="server">
         </div>
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx	2011-05-24 17:42:07 UTC (rev 5849)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx	2011-05-24 17:58:50 UTC (rev 5850)
@@ -7,13 +7,16 @@
     <title>Home</title>
     <script type="text/javascript">
-        function Go(url)
+        function Go(url, extraParams)
             var map = parent.parent.GetMapFrame();
             url += "?SESSION=" + map.GetSessionId();
             url += "&MAPNAME=" + map.GetMapName();
+            if (extraParams)
+                url += "&" + extraParams;
             window.location = url;
@@ -24,8 +27,10 @@
     <p>Samples</p>
     <ul>
-        <li><a href="#" onclick="Go('ToggleParcelsLayer.aspx')">Toggle Parcels Layer</a></li>
-        <li><a href="#" onclick="Go('AddTracksLayer.aspx')">Add Tracks Layer</a></li>
+        <li><a href="#" onclick="Go('ToggleParcelsLayer.aspx',null)">Add/Remove Parcels Layer</a></li>
+        <li><a href="#" onclick="Go('AddTracksLayer.aspx',null)">Add Tracks Layer</a></li>
+        <li><a href="#" onclick="Go('ToggleGroupVisibility.aspx','GROUPNAME=Base Map')">Toggle "Base Map" Group</a></li>
+        <li><a href="#" onclick="Go('ToggleLayerVisibility.aspx','LAYERNAME=Parcels')">Toggle "Parcels" Layer</a></li>
     </ul>
 </body>
 </html>
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx	2011-05-24 17:58:50 UTC (rev 5850)
@@ -0,0 +1,21 @@
+<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="ToggleGroupVisibility.aspx.cs" Inherits="SamplesWeb.Tasks.ToggleGroupVisibility" %>
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" >
+<head runat="server">
+    <title>Untitled Page</title>
+</head>
+<body>
+    <form id="form1" runat="server">
+    <div>
+        <asp:Label ID="lblMessage" runat="server"></asp:Label>
+        <br />
+        <br />
+        <div id="debug" runat="server">
+        </div>
+    </div>
+    </form>
+</body>
+</html>
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.cs	2011-05-24 17:58:50 UTC (rev 5850)
@@ -0,0 +1,53 @@
+using System;
+using System.Collections;
+using System.Configuration;
+using System.Data;
+using System.Web;
+using System.Web.Security;
+using System.Web.UI;
+using System.Web.UI.HtmlControls;
+using System.Web.UI.WebControls;
+using System.Web.UI.WebControls.WebParts;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.MaestroAPI;
+namespace SamplesWeb.Tasks
+    public partial class ToggleGroupVisibility : System.Web.UI.Page
+        protected void Page_Load(object sender, EventArgs e)
+            string agent = ConfigurationManager.AppSettings["MapAgentUrl"];
+            IServerConnection conn = ConnectionProviderRegistry.CreateConnection(
+                "Maestro.Http",
+                "Url", agent,
+                "SessionId", Request.Params["SESSION"]);
+            IMappingService mpSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+            string rtMapId = "Session:" + conn.SessionID + "//" + Request.Params["MAPNAME"] + ".Map";
+            RuntimeMap rtMap = mpSvc.OpenMap(rtMapId);
+            RuntimeMapGroup group = rtMap.GetGroupByName(Request.Params["GROUPNAME"]);
+            if (group != null)
+                group.Visible = !group.Visible;
+                rtMap.Save(); //Always save changes after modifying
+                Page.ClientScript.RegisterStartupScript(
+                    this.GetType(),
+                    "load",
+                    "<script type=\"text/javascript\"> window.onload = function() { parent.parent.Refresh(); } </script>");
+                lblMessage.Text = "Group (" + group.Name + ") visible: " + group.Visible;
+            else
+                lblMessage.Text = "Group (" + group.Name + ") not found!";
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.designer.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleGroupVisibility.aspx.designer.cs	2011-05-24 17:58:50 UTC (rev 5850)
@@ -0,0 +1,43 @@
+// <auto-generated>
+//     This code was generated by a tool.
+//     Runtime Version:2.0.50727.4952
+//     Changes to this file may cause incorrect behavior and will be lost if
+//     the code is regenerated.
+// </auto-generated>
+namespace SamplesWeb.Tasks {
+    public partial class ToggleGroupVisibility {
+        /// <summary>
+        /// form1 control.
+        /// </summary>
+        /// <remarks>
+        /// Auto-generated field.
+        /// To modify move field declaration from designer file to code-behind file.
+        /// </remarks>
+        protected global::System.Web.UI.HtmlControls.HtmlForm form1;
+        /// <summary>
+        /// lblMessage control.
+        /// </summary>
+        /// <remarks>
+        /// </remarks>
+        protected global::System.Web.UI.WebControls.Label lblMessage;
+        /// <summary>
+        /// debug control.
+        /// </summary>
+        /// <remarks>
+        /// </remarks>
+        protected global::System.Web.UI.HtmlControls.HtmlGenericControl debug;
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx	2011-05-24 17:58:50 UTC (rev 5850)
@@ -0,0 +1,21 @@
+<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="ToggleLayerVisibility.aspx.cs" Inherits="SamplesWeb.Tasks.ToggleLayerVisibility" %>
+</head>
+<body>
+    <div>
+        <br />
+        <br />
+        </div>
+    </div>
+    </form>
+</body>
+</html>
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.cs	2011-05-24 17:58:50 UTC (rev 5850)
@@ -0,0 +1,54 @@
+using System;
+using System.Data;
+using System.Web;
+    public partial class ToggleLayerVisibility : System.Web.UI.Page
+                "Maestro.Http",
+                "Url", agent,
+            RuntimeMapLayer layer = rtMap.GetLayerByName(Request.Params["LAYERNAME"]);
+            if (layer != null)
+                layer.Visible = !layer.Visible;
+                    this.GetType(),
+                    "load",
+                lblMessage.Text = "Layer (" + layer.Name + ") visible: " + layer.Visible;
+            else
+                lblMessage.Text = "Layer (" + layer.Name + ") not found!";
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.designer.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleLayerVisibility.aspx.designer.cs	2011-05-24 17:58:50 UTC (rev 5850)
@@ -0,0 +1,43 @@
+    public partial class ToggleLayerVisibility {
+        /// <summary>
+        /// </summary>
+        /// <remarks>
+        /// </remarks>
+        /// <summary>
+        /// </summary>
+        /// <remarks>
+        /// </remarks>
+        /// <summary>
+        /// </summary>
+        /// <remarks>
+        /// </remarks>
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx	2011-05-24 17:42:07 UTC (rev 5849)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ToggleParcelsLayer.aspx	2011-05-24 17:58:50 UTC (rev 5850)
@@ -11,7 +11,7 @@
     <div>
         <br />
         <br />
         </div>
More information about the mapguide-commits mailing list
