[mapguide-commits] r5877 - branches/2.2/MgDev
svn_mapguide at osgeo.org
Mon May 30 22:58:06 EDT 2011
Author: jng
Date: 2011-05-30 19:58:06 -0700 (Mon, 30 May 2011)
New Revision: 5877
branches/2.2/MgDev/build.bat
branches/2.2/MgDev/build64.bat
Fix build.bat not considering CS-Map directory when using the -a=install with a custom -o flag
Modified: branches/2.2/MgDev/build.bat
--- branches/2.2/MgDev/build.bat 2011-05-30 20:06:12 UTC (rev 5876)
+++ branches/2.2/MgDev/build.bat 2011-05-31 02:58:06 UTC (rev 5877)
@@ -154,6 +154,7 @@
if "%2" == "def" SET MG_OUTPUT=%MG_DEFAULT_INSTALLDIR%
SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
+SET MG_OUTPUT_CSMAP=%MG_OUTPUT%\CS-Map
goto next_param
:get_conf
Modified: branches/2.2/MgDev/build64.bat
--- branches/2.2/MgDev/build64.bat 2011-05-30 20:06:12 UTC (rev 5876)
+++ branches/2.2/MgDev/build64.bat 2011-05-31 02:58:06 UTC (rev 5877)
@@ -158,6 +158,7 @@
goto next_param
:get_conf
More information about the mapguide-commits
