[mapguide-commits] r5878 - in branches/2.2/Installer/Support/Web:
x64/Apache2/conf x86/Apache2/conf
svn_mapguide at osgeo.org
Mon May 30 23:33:51 EDT 2011
Author: jng
Date: 2011-05-30 20:33:51 -0700 (Mon, 30 May 2011)
New Revision: 5878
branches/2.2/Installer/Support/Web/x64/Apache2/conf/httpd.conf
branches/2.2/Installer/Support/Web/x86/Apache2/conf/httpd.conf
#1652: The mod_deflate settings were not specified correctly. The httpd.conf template has been updated to properly enable mod_deflate. Also deflate settings were not specified for the text/xml and application/json mime types. With these settings in place, a DESCRIBEFEATURESCHEMA operation that was previously 1.5MB in size is now under 30KB for both XML and JSON response types!
Modified: branches/2.2/Installer/Support/Web/x64/Apache2/conf/httpd.conf
--- branches/2.2/Installer/Support/Web/x64/Apache2/conf/httpd.conf 2011-05-31 02:58:06 UTC (rev 5877)
+++ branches/2.2/Installer/Support/Web/x64/Apache2/conf/httpd.conf 2011-05-31 03:33:51 UTC (rev 5878)
@@ -1011,9 +1011,13 @@
AddHandler cgi-script exe
# Content compression
+ SetOutputFilter DEFLATE
AddType text/javascript js jgz
AddOutputFilterByType DEFLATE text/javascript
AddOutputFilterByType DEFLATE text/html
+ AddOutputFilterByType DEFLATE text/xml
+ AddOutputFilterByType DEFLATE application/json
RewriteEngine on
RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
Modified: branches/2.2/Installer/Support/Web/x86/Apache2/conf/httpd.conf
--- branches/2.2/Installer/Support/Web/x86/Apache2/conf/httpd.conf 2011-05-31 02:58:06 UTC (rev 5877)
+++ branches/2.2/Installer/Support/Web/x86/Apache2/conf/httpd.conf 2011-05-31 03:33:51 UTC (rev 5878)
RewriteEngine on
More information about the mapguide-commits
