[mapguide-commits] r6165 - in trunk/Tools/Maestro:
	Maestro.Editors/WebLayout Maestro.Shared.UI
    svn_mapguide at osgeo.org
    Wed Oct  5 01:33:17 EDT 2011
Author: jng
Date: 2011-10-04 22:33:17 -0700 (Tue, 04 Oct 2011)
New Revision: 6165
   trunk/Tools/Maestro/Maestro.Editors/WebLayout/CustomCommandPropertyCtrl.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/TextBoxBinder.cs
#1823: Unlock the command property fields. The name field remains read-only because this an internal command name that is referenced by toolbar and menu items and not exposed in the UI
Modified: trunk/Tools/Maestro/Maestro.Editors/WebLayout/CustomCommandPropertyCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/WebLayout/CustomCommandPropertyCtrl.cs	2011-10-04 07:06:14 UTC (rev 6164)
+++ trunk/Tools/Maestro/Maestro.Editors/WebLayout/CustomCommandPropertyCtrl.cs	2011-10-05 05:33:17 UTC (rev 6165)
@@ -80,13 +80,13 @@
             else
                 //Not editable
-                txtTooltip.ReadOnly = true;
-                txtDescription.ReadOnly = true;
-                txtDisabledIcon.ReadOnly = true;
-                txtEnabledIcon.ReadOnly = true;
+                txtTooltip.ReadOnly = false;
+                txtDescription.ReadOnly = false;
+                txtDisabledIcon.ReadOnly = false;
+                txtEnabledIcon.ReadOnly = false;
                 txtName.ReadOnly = true;
-                txtTitle.ReadOnly = true;
+                txtTitle.ReadOnly = false;
                 tabProperties.TabPages.Remove(TAB_ADVANCED);
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/TextBoxBinder.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/TextBoxBinder.cs	2011-10-04 07:06:14 UTC (rev 6164)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/TextBoxBinder.cs	2011-10-05 05:33:17 UTC (rev 6165)
@@ -43,7 +43,10 @@
         public static Binding BindText(TextBoxBase txt, Binding b)
             txt.DataBindings.Add(b);
-            txt.TextChanged += (sender, e) => { b.WriteValue(); };
+            txt.TextChanged += (sender, e) =>
+                b.WriteValue();
             return b;
@@ -58,7 +61,10 @@
         public static Binding BindText(TextBoxBase txt, object dataSource, string dataMember)
             var binding = txt.DataBindings.Add("Text", dataSource, dataMember);
-            txt.TextChanged += (sender, e) => { binding.WriteValue(); };
+                binding.WriteValue();
             return binding;
More information about the mapguide-commits
