[mapguide-commits] r6113 - in trunk/MgDev:
	Common/MapGuideCommon/Services Common/MdfParser
	Server/src/Services/Profiling Server/src/Services/Rendering
    svn_mapguide at osgeo.org
    Mon Sep  5 03:37:53 EDT 2011
Author: liuar
Date: 2011-09-05 00:37:53 -0700 (Mon, 05 Sep 2011)
New Revision: 6113
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
   trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h
   trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
   trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp
   trunk/MgDev/Server/src/Services/Profiling/ServerProfilingService.cpp
   trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp
   trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp
   trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp
   trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
   trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
The RFC 110 Profiling Service (VII).
Implement the ProfileRenderMap API in Server.
1. Add a new internal used API for RenderingService to accept the profile result parameter
2. Inject profile code into ServerRenderingService.
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.cpp	2011-09-05 07:37:53 UTC (rev 6113)
@@ -849,10 +849,10 @@
     MgCommand cmd;
     cmd.ExecuteCommand(m_connProp,                                      // Connection
                         MgCommand::knObject,                            // Return type expected
-                        MgRenderingServiceOpId::RenderDynamicOverlay,   // Command Code
+                        MgRenderingServiceOpId::RenderDynamicOverlay2,  // Command Code
                         4,                                              // No of arguments
                         Rendering_Service,                              // Service Id
-                        BUILD_VERSION(2,1,0),                           // Operation version
+                        BUILD_VERSION(2,4,0),                           // Operation version
                         MgCommand::knObject, map,                       // Argument#1
                         MgCommand::knObject, selection,                 // Argument#2
                         MgCommand::knObject, options,                   // Argument#3
@@ -863,3 +863,78 @@
     return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
+/// \brief
+/// Renders the specified MgMap with specified parameters.
+/// Profile result will be recorded.
+/// \param map
+/// Input
+/// map object containing current state of map.
+/// \param selection
+/// Input
+/// map feature selection. Specifies the selected features on the map
+/// \param center
+/// Input
+/// map center point. Specifies the center point for the map
+/// \param scale
+/// Input
+/// map scale. Specifies the scale for the map
+/// \param width
+/// Input
+/// image width. Specifies the image width in pixels
+/// \param height
+/// Input
+/// image height. Specifies the image height in pixels
+/// \param backgroundColor
+/// Input
+/// background color. Specifies the map background color
+/// \param format
+/// Input
+/// image format. Defines the format of the resulting image
+/// \param bKeepSelection
+/// Input
+/// true if you want to keep the selection
+/// \param profileRenderMapResult
+/// Input&Output
+/// profile result of rendering map
+/// \return
+/// A byte reader containing the rendered image
+MgByteReader* MgProxyRenderingService::RenderMap(
+    MgMap* map,
+    MgSelection* selection,
+    MgCoordinate* center,
+    double scale,
+    INT32 width,
+    INT32 height,
+    MgColor* backgroundColor,
+    CREFSTRING format,
+    bool bKeepSelection,
+    ProfileRenderMapResult* profileRenderMapResult)
+    MgCommand cmd;
+    cmd.ExecuteCommand(m_connProp,                                      // Connection
+                        MgCommand::knObject,                            // Return type expected
+                        MgRenderingServiceOpId::RenderMap5,             // Command Code
+                        10,                                             // No of arguments
+                        Rendering_Service,                              // Service Id
+                        MgCommand::knObject, map,                       // Argument#1
+                        MgCommand::knObject, selection,                 // Argument#2
+                        MgCommand::knObject, center,                    // Argument#3
+                        MgCommand::knDouble, scale,                     // Argument#4
+                        MgCommand::knInt32, width,                      // Argument#5
+                        MgCommand::knInt32, height,                     // Argument#6
+                        MgCommand::knObject, backgroundColor,           // Argument#7
+                        MgCommand::knString, &format,                   // Argument#8
+                        MgCommand::knInt8, (INT8)bKeepSelection,        // Argument#9
+                        MgCommand::knObject, profileRenderMapResult,    // Argument#10
+                        MgCommand::knNone);                             // End of arguments
+    SetWarning(cmd.GetWarningObject());
+    return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyRenderingService.h	2011-09-05 07:37:53 UTC (rev 6113)
@@ -618,6 +618,57 @@
         MgRenderingOptions* options,
         ProfileRenderMapResult* profileRenderMapResult);
+    /// \brief
+    /// Renders the specified MgMap with specified parameters.
+    /// Profile result will be recorded.
+    /// \param map
+    /// Input
+    /// map object containing current state of map.
+    /// \param selection
+    /// Input
+    /// map feature selection. Specifies the selected features on the map
+    /// \param center
+    /// Input
+    /// map center point. Specifies the center point for the map
+    /// \param scale
+    /// Input
+    /// map scale. Specifies the scale for the map
+    /// \param width
+    /// Input
+    /// image width. Specifies the image width in pixels
+    /// \param height
+    /// Input
+    /// image height. Specifies the image height in pixels
+    /// \param backgroundColor
+    /// Input
+    /// background color. Specifies the map background color
+    /// \param format
+    /// Input
+    /// image format. Defines the format of the resulting image
+    /// \param bKeepSelection
+    /// Input
+    /// true if you want to keep the selection
+    /// \param profileRenderMapResult
+    /// Input&Output
+    /// profile result of rendering map
+    /// \return
+    /// A byte reader containing the rendered image
+    virtual MgByteReader* RenderMap(
+        MgMap* map,
+        double scale,
+        INT32 width,
+        INT32 height,
+        ProfileRenderMapResult* profileRenderMapResult);
 protected:
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingDefs.h	2011-09-05 07:37:53 UTC (rev 6113)
@@ -37,6 +37,8 @@
     static const int RenderDynamicOverlay       = 0x1111E909;
     static const int QueryFeatureProperties     = 0x1111E90A;
     static const int RenderMap4                 = 0x1111E90B;
+    static const int RenderDynamicOverlay2      = 0x1111E90C;
+    static const int RenderMap5                 = 0x1111E90D;
 /// \endcond
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h	2011-09-05 07:37:53 UTC (rev 6113)
@@ -617,6 +617,57 @@
         ProfileRenderMapResult* profileRenderMapResult) = 0;
+    /// \brief
+    /// \param map
+    /// Input
+    /// Input
+    /// \param center
+    /// Input
+    /// \param scale
+    /// Input
+    /// \param width
+    /// Input
+    /// \param height
+    /// Input
+    /// Input
+    /// \param format
+    /// Input
+    /// Input
+    /// Input&Output
+    /// \return
+        MgMap* map,
+        double scale,
+        INT32 width,
+        INT32 height,
+        ProfileRenderMapResult* profileRenderMapResult) = 0;
 protected:
Modified: trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp
--- trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp	2011-09-05 07:37:53 UTC (rev 6113)
@@ -85,7 +85,7 @@
 void IOProfileRenderMapResult::Write(MdfStream& fd, ProfileRenderMapResult* profileRenderMapResult, Version* version, MgTab& tab)
     ProfileResult::ProfileResultType type = profileRenderMapResult->GetProfileResultType();
-    if (ProfileResult::ProfileRenderMap)
+    if (ProfileResult::ProfileRenderMap == type)
         fd << tab.tab() << startStr(sProfileRenderMapResult) << std::endl;
     else //ProfileResult::ProfileRenderDynamicOverlay
         fd << tab.tab() << startStr(sProfileRenderDynamicOverlayResult) << std::endl;
Modified: trunk/MgDev/Server/src/Services/Profiling/ServerProfilingService.cpp
--- trunk/MgDev/Server/src/Services/Profiling/ServerProfilingService.cpp	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Server/src/Services/Profiling/ServerProfilingService.cpp	2011-09-05 07:37:53 UTC (rev 6113)
@@ -58,14 +58,13 @@
     MG_TRY()
-    // selection is an optional and nullable parameter
-    if (NULL == map || NULL == options)
+    if (NULL == map)
         throw new MgNullArgumentException(L"MgServerProfilingService.ProfileRenderDynamicOverlay", __LINE__, __WFILE__, NULL, L"", NULL);
     auto_ptr<ProfileRenderMapResult> pPRMResult; // a pointer points to Profile Render Map Result
     pPRMResult.reset(new ProfileRenderMapResult());
-    // Start to profile the RenderDynamicOverlay process
+    // Start to profile the ProfileRenderDynamicOverlay process
     double renderMapStart = MgTimerUtil::GetTime();
     m_svcRendering->RenderDynamicOverlay(map, selection, options, pPRMResult.get());
     double renderMapEnd = MgTimerUtil::GetTime();
@@ -97,17 +96,32 @@
                                                   bool bKeepSelection)
     Ptr<MgByteReader> ret;
+    MG_TRY()
-    //MG_TRY()
-    //MapProfileResult* mapProfileResult = new MapProfileResult();
-    //m_svcRendering->SetProfileResult(mapProfileResult);
-    //ret = m_svcRendering->RenderMap(map,selection,center,scale,width,height,backgroundColor,format,bKeepSelection);
-    //Version mapProfileResultVersion23(2, 3, 0); // MapGuide 2012
-    //MdfParser::SAX2Parser parser;
-    //parser.WriteToFile("c:\\map.xml",mapProfileResult,&mapProfileResultVersion23);
-    //MG_CATCH_AND_THROW(L"MgServerProfilingService.ProfileRenderMap")
+    if (NULL == map)
+        throw new MgNullArgumentException(L"MgServerProfilingService.ProfileRenderMap", __LINE__, __WFILE__, NULL, L"", NULL);
+    auto_ptr<ProfileRenderMapResult> pPRMResult; // a pointer points to Profile Render Map Result
+    pPRMResult.reset(new ProfileRenderMapResult());
+    // Start to profile the ProfileRenderMap process
+    double renderMapStart = MgTimerUtil::GetTime();
+    m_svcRendering->RenderMap(map, selection, center, scale, width, height, backgroundColor, format, bKeepSelection, pPRMResult.get());
+    double renderMapEnd = MgTimerUtil::GetTime();
+    pPRMResult->SetRenderTime(renderMapEnd - renderMapStart);
+    pPRMResult->SetProfileResultType(ProfileResult::ProfileRenderMap);
+    // Serialize the ProfileRenderMapResult to xml
+    MdfParser::SAX2Parser parser;
+    auto_ptr<Version> version;
+    version.reset(new Version(2,4,0));
+    string content = parser.SerializeToXML(pPRMResult.get(),version.get());
+    ret = new MgByteReader(MgUtil::MultiByteToWideChar(content), MgMimeType::Xml);
+    MG_CATCH_AND_THROW(L"MgServerProfilingService.ProfileRenderMap")
     return ret.Detach();
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp	2011-09-05 07:37:53 UTC (rev 6113)
@@ -105,6 +105,7 @@
         auto_ptr<ProfileRenderMapResult> pProfileRenderMapResult;
         pProfileRenderMapResult.reset((ProfileRenderMapResult*)m_stream->GetObject());
         BeginExecution();
         MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp	2011-09-05 07:37:53 UTC (rev 6113)
@@ -245,6 +245,69 @@
         EndExecution(byteReader);
+    else if (10 == m_packet.m_NumArguments)
+        Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
+        Ptr<MgResourceIdentifier> resource = map->GetResourceId();
+        map->SetDelayedLoadResourceService(m_resourceService);
+        Ptr<MgSelection> selection = (MgSelection*)m_stream->GetObject();
+        if(selection)
+            selection->SetMap(map);
+        Ptr<MgCoordinate> center = (MgCoordinate*)m_stream->GetObject();
+        double scale = 0.0;
+        m_stream->GetDouble(scale);
+        INT32 width = 0;
+        m_stream->GetInt32(width);
+        INT32 height = 0;
+        m_stream->GetInt32(height);
+        Ptr<MgColor> color = (MgColor*)m_stream->GetObject();
+        STRING format;
+        m_stream->GetString(format);
+        bool bKeepSelection = false;
+        m_stream->GetBoolean(bKeepSelection);
+        auto_ptr<ProfileRenderMapResult> pProfileRenderMapResult;
+        pProfileRenderMapResult.reset((ProfileRenderMapResult*)m_stream->GetObject());
+        BeginExecution();
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
+        MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgSelection");
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgCoordinate");
+        MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(scale);
+        MG_LOG_OPERATION_MESSAGE_ADD_INT32(width);
+        MG_LOG_OPERATION_MESSAGE_ADD_INT32(height);
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgColor");
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(format.c_str());
+        MG_LOG_OPERATION_MESSAGE_ADD_BOOL(bKeepSelection);
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"ProfileRenderMapResult");
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+        Validate();
+        Ptr<MgByteReader> byteReader =
+            m_service->RenderMap(map, selection, center, scale, width, height, color, format, bKeepSelection, pProfileRenderMapResult.get());
+        EndExecution(byteReader);
     else
Modified: trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp
--- trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Server/src/Services/Rendering/RenderingOperationFactory.cpp	2011-09-05 07:37:53 UTC (rev 6113)
@@ -85,6 +85,17 @@
                 L"MgRenderingOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
         break;
+    case MgRenderingServiceOpId::RenderDynamicOverlay2:
+        switch (VERSION_NO_PHASE(operationVersion))
+        case VERSION_SUPPORTED(2,4):
+            handler.reset(new MgOpRenderDynamicOverlay());
+            break;
+        default:
+            throw new MgInvalidOperationVersionException(
+                L"MgRenderingOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
+        break;
     case MgRenderingServiceOpId::RenderMap1:
@@ -135,6 +146,18 @@
         break;
+    case MgRenderingServiceOpId::RenderMap5:
+            handler.reset(new MgOpRenderMap());
+            break;
+        default:
+        break;
     case MgRenderingServiceOpId::QueryFeatures:
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2011-09-05 07:37:53 UTC (rev 6113)
@@ -606,7 +606,7 @@
-// default arguments bClip = false
+// default arguments bClip = false  pProfileRenderMapResult = NULL
 MgByteReader* MgServerRenderingService::RenderMap(MgMap* map,
@@ -620,6 +620,21 @@
     return RenderMap(map, selection, center, scale, width, height, backgroundColor, format, bKeepSelection, false);
+MgByteReader* MgServerRenderingService::RenderMap(MgMap* map,
+                                                  double scale,
+                                                  INT32 width,
+                                                  INT32 height,
+                                                  ProfileRenderMapResult* pPRMResult)
+    return RenderMap(map, selection, center, scale, width, height, backgroundColor, format, bKeepSelection, false, pPRMResult);
 // render map around center point in given scale
@@ -634,7 +649,8 @@
                                                   CREFSTRING format,
-                                                  bool bClip)
+                                                  bool bClip,
@@ -685,8 +701,19 @@
     // initialize the appropriate map renderer
     auto_ptr<SE_Renderer> dr(CreateRenderer(width, height, bgcolor, bClip));
+    if(NULL != pPRMResult)
+        Ptr<MgResourceIdentifier> mapResId = map->GetResourceId();
+        pPRMResult->SetResourceId(mapResId ? mapResId->ToString() : L"");
+        pPRMResult->SetScale(scale);
+        pPRMResult->SetExtents(Box2D(b.minx, b.miny, b.maxx, b.maxy));
+        Ptr<MgLayerCollection> layers = map->GetLayers();
+        pPRMResult->SetLayerCount(layers->GetCount());
+        pPRMResult->SetCoordinateSystem(map->GetMapSRS());
     // call the internal helper API to do all the stylization overhead work
-    ret = RenderMapInternal(map, selection, NULL, dr.get(), width, height, width, height, format, scale, b, false, bKeepSelection, true);
+    ret = RenderMapInternal(map, selection, NULL, dr.get(), width, height, width, height, format, scale, b, false, bKeepSelection, true, pPRMResult);
     MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderMap")
@@ -859,7 +886,7 @@
     MgRenderingOptions options(format, MgRenderingOptions::RenderSelection |
         MgRenderingOptions::RenderLayers | (bKeepSelection? MgRenderingOptions::KeepSelection : 0), NULL);
-    return RenderMapInternal(map, selection, roLayers, dr, drawWidth, drawHeight, saveWidth, saveHeight, scale, b, expandExtents, &options, renderWatermark);
+    return RenderMapInternal(map, selection, roLayers, dr, drawWidth, drawHeight, saveWidth, saveHeight, scale, b, expandExtents, &options, renderWatermark, pPRMResult);
@@ -1051,17 +1078,6 @@
         if (renderWatermark && (behavior & MgRenderingOptions::RenderLayers) && map->GetWatermarkUsage() != 0)
-            ProfileRenderWatermarksResult* pPRWsResult = NULL; // pointer points to Profile Render Watermarks Result
-            if(NULL != pPRMResult)
-                pPRWsResult = new ProfileRenderWatermarksResult();
-                pPRMResult->AdoptProfileRenderWatermarksResult(pPRWsResult);
-                // Set the start time of stylizing watermarks
-                pPRWsResult->SetRenderTime(MgTimerUtil::GetTime());
             // Rendering watermark only when:
             //      1. rendering layers
             //      2. not set renderWatermark to false (not render tile)
@@ -1154,122 +1170,136 @@
             MgStringCollection watermarkDefinitions;    // Loaded watermark definition
             MgStringCollection failLoadedIds;           // ID list of failed in loading resource
-            for (int i=watermarkInstances.GetCount()-1; i>=0; i--)
+            if(0 != watermarkInstances.GetCount())
-                WatermarkInstance* instance = watermarkInstances.GetAt(i);
-                STRING resourceId = instance->GetResourceId();
-                WatermarkDefinition* wdef = NULL;
-                MG_TRY()
-                    for(int j = 0; j < watermarkIds.GetCount(); j++)
-                        if(resourceId == watermarkIds.GetItem(j))
+                ProfileRenderWatermarksResult* pPRWsResult = NULL; // pointer points to Profile Render Watermarks Result
+                    pPRWsResult = new ProfileRenderWatermarksResult();
+                    pPRMResult->AdoptProfileRenderWatermarksResult(pPRWsResult);
+                    // Set the start time of stylizing watermarks
+                    pPRWsResult->SetRenderTime(MgTimerUtil::GetTime());
+                for (int i=watermarkInstances.GetCount()-1; i>=0; i--)
+                    WatermarkInstance* instance = watermarkInstances.GetAt(i);
+                    STRING resourceId = instance->GetResourceId();
+                    WatermarkDefinition* wdef = NULL;
+                    MG_TRY()
+                        for(int j = 0; j < watermarkIds.GetCount(); j++)
-                            wdef = MgWatermark::GetWatermarkDefinition(watermarkDefinitions.GetItem(j));
-                            break;
+                            if(resourceId == watermarkIds.GetItem(j))
+                                wdef = MgWatermark::GetWatermarkDefinition(watermarkDefinitions.GetItem(j));
+                                break;
-                    if(NULL != pPRWsResult)
-                        ProfileRenderWatermarkResult* pPRWResult = new ProfileRenderWatermarkResult(); // pointer points to Render Watermark Result
+                        if(NULL != pPRWsResult)
+                            ProfileRenderWatermarkResult* pPRWResult = new ProfileRenderWatermarkResult(); // pointer points to Render Watermark Result
-                        pPRWResult->SetRenderTime(MgTimerUtil::GetTime());
+                            pPRWResult->SetRenderTime(MgTimerUtil::GetTime());
-                        ProfileRenderWatermarkResultCollection* pPRWResultColl = pPRWsResult->GetProfileRenderWatermarkResults();
-                        pPRWResultColl->Adopt(pPRWResult);
+                            ProfileRenderWatermarkResultCollection* pPRWResultColl = pPRWsResult->GetProfileRenderWatermarkResults();
+                            pPRWResultColl->Adopt(pPRWResult);
-                    if(wdef == NULL)
-                        Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resourceId);
-                        Ptr<MgByteReader> reader = m_svcResource->GetResourceContent(resId);
-                        STRING content = reader->ToString();
-                        watermarkIds.Add(resourceId);
-                        watermarkDefinitions.Add(content);
-                        wdef = MgWatermark::GetWatermarkDefinition(content);
-                    assert(wdef != NULL);
-                    if (instance->GetPositionOverride())
-                        wdef->AdoptPosition(instance->OrphanPositionOverride());
-                    if (instance->GetAppearanceOverride())
-                        wdef->AdoptAppearance(instance->OrphanAppearanceOverride());
-                    ds.StylizeWatermark(dr, wdef, drawWidth, drawHeight, saveWidth, saveHeight);
+                        if(wdef == NULL)
+                            Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resourceId);
+                            Ptr<MgByteReader> reader = m_svcResource->GetResourceContent(resId);
+                            STRING content = reader->ToString();
+                            watermarkIds.Add(resourceId);
+                            watermarkDefinitions.Add(content);
+                            wdef = MgWatermark::GetWatermarkDefinition(content);
+                        assert(wdef != NULL);
+                        if (instance->GetPositionOverride())
+                            wdef->AdoptPosition(instance->OrphanPositionOverride());
+                        if (instance->GetAppearanceOverride())
+                            wdef->AdoptAppearance(instance->OrphanAppearanceOverride());
+                        ds.StylizeWatermark(dr, wdef, drawWidth, drawHeight, saveWidth, saveHeight);
-                        ProfileRenderWatermarkResult* pPRWResult = pPRWResultColl->GetAt(pPRWResultColl->GetCount()-1); // TODO: check index
+                            ProfileRenderWatermarkResult* pPRWResult = pPRWResultColl->GetAt(pPRWResultColl->GetCount()-1); // TODO: check index
-                        // Calculate the time spent on stylizing watermark
-                        double stylizeWatermarkTime = MgTimerUtil::GetTime() - pPRWResult->GetRenderTime();
-                        pPRWResult->SetRenderTime(stylizeWatermarkTime);
+                            // Calculate the time spent on stylizing watermark
+                            double stylizeWatermarkTime = MgTimerUtil::GetTime() - pPRWResult->GetRenderTime();
+                            pPRWResult->SetRenderTime(stylizeWatermarkTime);
-                        pPRWResult->SetResourceId(resourceId);
+                            pPRWResult->SetResourceId(resourceId);
-                        WatermarkPosition* position = wdef->GetPosition();
-                        if(NULL != dynamic_cast<XYWatermarkPosition*>(position))
-                            pPRWResult->SetPositionType(L"XY");
+                            WatermarkPosition* position = wdef->GetPosition();
+                            if(NULL != dynamic_cast<XYWatermarkPosition*>(position))
+                                pPRWResult->SetPositionType(L"XY");
+                            else // No other position types
+                                pPRWResult->SetPositionType(L"Tile");
-                        else // No other position types
-                            pPRWResult->SetPositionType(L"Tile");
-                MG_CATCH(L"MgServerRenderingService.RenderMapInternal")
-                if(mgException.p)
-                    // Do not do anything if fail in resource loading and has logged error.
-                    bool isExceptionLogged = false;
-                    if(wdef == NULL) // Fail in resource loading
-                        for(int i = 0; i < failLoadedIds.GetCount(); i++)
-                            if(resourceId == failLoadedIds.GetItem(i))
+                    MG_CATCH(L"MgServerRenderingService.RenderMapInternal")
+                    if(mgException.p)
+                        // Do not do anything if fail in resource loading and has logged error.
+                        bool isExceptionLogged = false;
+                        if(wdef == NULL) // Fail in resource loading
+                            for(int i = 0; i < failLoadedIds.GetCount(); i++)
-                                isExceptionLogged = true;
-                                break;
+                                if(resourceId == failLoadedIds.GetItem(i))
+                                    isExceptionLogged = true;
+                                    break;
-                    if(!isExceptionLogged)
-                        // TODO: Eventually this should be used to indicate visually to the client what
-                        //       layer failed in addition to logging the error.
-                        MgServerManager* serverManager = MgServerManager::GetInstance();
-                        STRING locale = (NULL == serverManager)? MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
-                        MG_LOG_EXCEPTION_ENTRY(mgException->GetExceptionMessage(locale).c_str(), mgException->GetStackTrace(locale).c_str());
+                        if(!isExceptionLogged)
+                            // TODO: Eventually this should be used to indicate visually to the client what
+                            //       layer failed in addition to logging the error.
+                            MgServerManager* serverManager = MgServerManager::GetInstance();
+                            STRING locale = (NULL == serverManager)? MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
+                            MG_LOG_EXCEPTION_ENTRY(mgException->GetExceptionMessage(locale).c_str(), mgException->GetStackTrace(locale).c_str());
-#if defined(_DEBUG) || defined(_DEBUG_PNG8)
-                        STRING details = mgException->GetDetails(locale);
+    #if defined(_DEBUG) || defined(_DEBUG_PNG8)
+                            STRING details = mgException->GetDetails(locale);
-                        wstring err = L"\n %t Error during stylization of watermark:";
-                        err += instance->GetName();
-                        err += L"\n";
-                        err += L"Details: ";
-                        err += details;
-                        err += L"\n";
-                        ACE_DEBUG( (LM_DEBUG, err.c_str()) );
-#endif
-                        if(wdef == NULL)            // Failed in resource loading
-                            failLoadedIds.Add(resourceId);
+                            wstring err = L"\n %t Error during stylization of watermark:";
+                            err += instance->GetName();
+                            err += L"\n";
+                            err += L"Details: ";
+                            err += details;
+                            err += L"\n";
+                            ACE_DEBUG( (LM_DEBUG, err.c_str()) );
+    #endif
+                            if(wdef == NULL)            // Failed in resource loading
+                                failLoadedIds.Add(resourceId);
-                // Calculate the time spent on stylizing watermarks
-                double stylizeRenderWatermarksTime = MgTimerUtil::GetTime() - pPRWsResult->GetRenderTime();
-                pPRWsResult->SetRenderTime(stylizeRenderWatermarksTime);
+                    // Calculate the time spent on stylizing watermarks
+                    double stylizeRenderWatermarksTime = MgTimerUtil::GetTime() - pPRWsResult->GetRenderTime();
+                    pPRWsResult->SetRenderTime(stylizeRenderWatermarksTime);
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h	2011-09-02 06:32:13 UTC (rev 6112)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h	2011-09-05 07:37:53 UTC (rev 6113)
@@ -124,8 +124,20 @@
                                     CREFSTRING format,
-                                    bool bClip);
+                                    ProfileRenderMapResult* pPRMResult);
+    virtual MgByteReader* RenderMap(MgMap* map,
+                                    double scale,
+                                    INT32 width,
+                                    INT32 height,
+                                    bool bClip,
+                                    ProfileRenderMapResult* pPRMResult = NULL);
     virtual MgByteReader* RenderMapLegend(MgMap* map,
                                           INT32 width,
                                           INT32 height,
More information about the mapguide-commits
