[mapguide-commits] r6114 - in
	trunk/Tools/Maestro/Maestro.AddIn.Local: . Services UI
    svn_mapguide at osgeo.org
    Mon Sep  5 07:41:03 EDT 2011
Author: jng
Date: 2011-09-05 04:41:03 -0700 (Mon, 05 Sep 2011)
New Revision: 6114
Added:
   trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.Designer.cs
   trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.cs
   trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.resx
   trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj
   trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgFoundation.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgGeometry.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsCommon.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsQueryEngine.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsResource.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfModel.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfParser.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgPlatformBase.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgRenderers.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/MgStylization.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
   trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs
   trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.Designer.cs
   trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs
   trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.resx
Update mg-desktop binaries (revision babc6614c9). Replace existing map preview window to use the new map viewer component
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj
--- trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj	2011-09-05 07:37:53 UTC (rev 6113)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/Maestro.AddIn.Local.csproj	2011-09-05 11:41:03 UTC (rev 6114)
@@ -34,6 +34,11 @@
     <Reference Include="OSGeo.MapGuide.Desktop, Version=2.4.0.0, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=x86">
       <Private>False</Private>
     </Reference>
+    <Reference Include="OSGeo.MapGuide.Viewer, Version=1.0.0.0, Culture=neutral, processorArchitecture=MSIL">
+      <SpecificVersion>False</SpecificVersion>
+      <HintPath>.\OSGeo.MapGuide.Viewer.dll</HintPath>
+      <Private>False</Private>
+    </Reference>
     <Reference Include="System" />
     <Reference Include="System.Data" />
     <Reference Include="System.Drawing" />
@@ -61,6 +66,12 @@
     <Compile Include="UI\MapPreviewWindow.Designer.cs">
       <DependentUpon>MapPreviewWindow.cs</DependentUpon>
     </Compile>
+    <Compile Include="UI\ZoomScaleDialog.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="UI\ZoomScaleDialog.Designer.cs">
+      <DependentUpon>ZoomScaleDialog.cs</DependentUpon>
+    </Compile>
   </ItemGroup>
   <ItemGroup>
     <ProjectReference Include="..\Maestro.Base\Maestro.Base.csproj">
@@ -287,6 +298,9 @@
     <None Include="Resources\arrow-225.png" />
     <None Include="Resources\arrow-135.png" />
     <None Include="Resources\arrow-045.png" />
+    <Content Include="OSGeo.MapGuide.Viewer.dll">
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </Content>
     <Content Include="xerces-c_3_1mg.dll">
     </Content>
@@ -988,6 +1002,9 @@
     <EmbeddedResource Include="UI\MapPreviewWindow.resx">
     </EmbeddedResource>
+    <EmbeddedResource Include="UI\ZoomScaleDialog.resx">
+    </EmbeddedResource>
   </ItemGroup>
   <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
   <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
(Binary files differ)
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgFoundation.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGeometry.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsCommon.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsQueryEngine.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgGwsResource.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfModel.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgMdfParser.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgPlatformBase.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgRenderers.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgStylization.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
Added: trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs	2011-09-05 07:37:53 UTC (rev 6113)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs	2011-09-05 11:41:03 UTC (rev 6114)
@@ -26,7 +26,6 @@
 using OSGeo.MapGuide.ObjectModels.Common;
 using OSGeo.MapGuide.MaestroAPI;
 using OSGeo.MapGuide;
-using Maestro.AddIn.Local.UI;
 using OSGeo.MapGuide.ObjectModels.WatermarkDefinition;
 using OSGeo.MapGuide.ObjectModels.LayerDefinition;
@@ -81,9 +80,13 @@
             var mapResId = new MgResourceIdentifier("Session:" + edSvc.SessionID + "//" + Guid.NewGuid() + "." + res.ResourceType.ToString());
             edSvc.ResourceService.SetResourceXmlData(mapResId.ToString(), ResourceTypeRegistry.Serialize(mapDef));
-            MgdMap map = new MgdMap(mapResId);
+            //MgdMap map = new MgdMap(mapResId);
-            var diag = new MapPreviewWindow(map, conn);
+            //var diag = new MapPreviewWindow(map, conn);
+            //diag.ShowDialog();
+            var diag = new UI.MapPreviewWindow(conn);
+            diag.Init(mapResId);
             diag.ShowDialog();
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.Designer.cs	2011-09-05 07:37:53 UTC (rev 6113)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.Designer.cs	2011-09-05 11:41:03 UTC (rev 6114)
@@ -28,323 +28,177 @@
         /// </summary>
         private void InitializeComponent()
-            this.splitContainer1 = new System.Windows.Forms.SplitContainer();
-            this.mapImage = new System.Windows.Forms.PictureBox();
-            this.panel1 = new System.Windows.Forms.Panel();
-            this.groupBox1 = new System.Windows.Forms.GroupBox();
-            this.btnZoomScale = new System.Windows.Forms.Button();
-            this.label1 = new System.Windows.Forms.Label();
-            this.numScale = new System.Windows.Forms.NumericUpDown();
-            this.btnLowerRight = new System.Windows.Forms.Button();
-            this.btnLowerLeft = new System.Windows.Forms.Button();
-            this.btnUpperLeft = new System.Windows.Forms.Button();
-            this.btnUpperRight = new System.Windows.Forms.Button();
-            this.btnClearSelect = new System.Windows.Forms.Button();
-            this.chkSelectFeatures = new System.Windows.Forms.CheckBox();
-            this.btnZoomExtents = new System.Windows.Forms.Button();
-            this.btnZoomOut = new System.Windows.Forms.Button();
-            this.btnZoomIn = new System.Windows.Forms.Button();
-            this.btnDown = new System.Windows.Forms.Button();
-            this.btnRight = new System.Windows.Forms.Button();
-            this.btnLeft = new System.Windows.Forms.Button();
-            this.btnUp = new System.Windows.Forms.Button();
-            this.renderWorker = new System.ComponentModel.BackgroundWorker();
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MapPreviewWindow));
             this.statusStrip1 = new System.Windows.Forms.StatusStrip();
             this.lblCoordinates = new System.Windows.Forms.ToolStripStatusLabel();
             this.lblFeaturesSelected = new System.Windows.Forms.ToolStripStatusLabel();
+            this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
+            this.lblSelectedFeatures = new System.Windows.Forms.ToolStripStatusLabel();
+            this.lblMapSize = new System.Windows.Forms.ToolStripStatusLabel();
+            this.splitContainer1 = new System.Windows.Forms.SplitContainer();
+            this.splitContainer2 = new System.Windows.Forms.SplitContainer();
+            this.legend = new MapViewer.MgLegend();
+            this.propertyPane = new MapViewer.MgPropertyPane();
+            this.viewer = new MapViewer.MgMapViewer();
+            this.toolbar = new MapViewer.MgDefaultToolbar();
+            this.toolStripButton1 = new System.Windows.Forms.ToolStripButton();
+            this.statusStrip1.SuspendLayout();
             this.splitContainer1.Panel1.SuspendLayout();
             this.splitContainer1.Panel2.SuspendLayout();
             this.splitContainer1.SuspendLayout();
-            ((System.ComponentModel.ISupportInitialize)(this.mapImage)).BeginInit();
-            this.panel1.SuspendLayout();
-            this.groupBox1.SuspendLayout();
-            ((System.ComponentModel.ISupportInitialize)(this.numScale)).BeginInit();
-            this.statusStrip1.SuspendLayout();
+            this.splitContainer2.Panel1.SuspendLayout();
+            this.splitContainer2.Panel2.SuspendLayout();
+            this.splitContainer2.SuspendLayout();
+            this.toolbar.SuspendLayout();
             this.SuspendLayout();
-            // splitContainer1
+            // statusStrip1
-            this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
-            this.splitContainer1.FixedPanel = System.Windows.Forms.FixedPanel.Panel2;
-            this.splitContainer1.Location = new System.Drawing.Point(0, 0);
-            this.splitContainer1.Name = "splitContainer1";
+            this.statusStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+            this.lblCoordinates,
+            this.lblFeaturesSelected,
+            this.lblScale,
+            this.lblSelectedFeatures,
+            this.lblMapSize});
+            this.statusStrip1.Location = new System.Drawing.Point(0, 465);
+            this.statusStrip1.Name = "statusStrip1";
+            this.statusStrip1.Size = new System.Drawing.Size(674, 22);
+            this.statusStrip1.TabIndex = 1;
+            this.statusStrip1.Text = "statusStrip1";
-            // splitContainer1.Panel1
+            // lblCoordinates
-            this.splitContainer1.Panel1.Controls.Add(this.mapImage);
+            this.lblCoordinates.Name = "lblCoordinates";
+            this.lblCoordinates.Size = new System.Drawing.Size(0, 17);
+            this.lblCoordinates.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
-            // splitContainer1.Panel2
+            // lblFeaturesSelected
-            this.splitContainer1.Panel2.Controls.Add(this.panel1);
-            this.splitContainer1.Size = new System.Drawing.Size(674, 465);
-            this.splitContainer1.SplitterDistance = 549;
-            this.splitContainer1.TabIndex = 0;
+            this.lblFeaturesSelected.Name = "lblFeaturesSelected";
+            this.lblFeaturesSelected.Size = new System.Drawing.Size(659, 17);
+            this.lblFeaturesSelected.Spring = true;
-            // mapImage
+            // lblScale
-            this.mapImage.Dock = System.Windows.Forms.DockStyle.Fill;
-            this.mapImage.Location = new System.Drawing.Point(0, 0);
-            this.mapImage.Name = "mapImage";
-            this.mapImage.Size = new System.Drawing.Size(549, 465);
-            this.mapImage.TabIndex = 0;
-            this.mapImage.TabStop = false;
-            this.mapImage.MouseMove += new System.Windows.Forms.MouseEventHandler(this.mapImage_MouseMove);
-            this.mapImage.MouseClick += new System.Windows.Forms.MouseEventHandler(this.mapImage_MouseClick);
+            this.lblScale.Name = "lblScale";
+            this.lblScale.Size = new System.Drawing.Size(0, 17);
-            // panel1
+            // lblSelectedFeatures
-            this.panel1.Controls.Add(this.groupBox1);
-            this.panel1.Dock = System.Windows.Forms.DockStyle.Fill;
-            this.panel1.Location = new System.Drawing.Point(0, 0);
-            this.panel1.Name = "panel1";
-            this.panel1.Size = new System.Drawing.Size(121, 465);
-            this.panel1.TabIndex = 0;
+            this.lblSelectedFeatures.Name = "lblSelectedFeatures";
+            this.lblSelectedFeatures.Size = new System.Drawing.Size(0, 17);
-            // groupBox1
+            // lblMapSize
-            this.groupBox1.Controls.Add(this.btnZoomScale);
-            this.groupBox1.Controls.Add(this.label1);
-            this.groupBox1.Controls.Add(this.numScale);
-            this.groupBox1.Controls.Add(this.btnLowerRight);
-            this.groupBox1.Controls.Add(this.btnLowerLeft);
-            this.groupBox1.Controls.Add(this.btnUpperLeft);
-            this.groupBox1.Controls.Add(this.btnUpperRight);
-            this.groupBox1.Controls.Add(this.btnClearSelect);
-            this.groupBox1.Controls.Add(this.chkSelectFeatures);
-            this.groupBox1.Controls.Add(this.btnZoomExtents);
-            this.groupBox1.Controls.Add(this.btnZoomOut);
-            this.groupBox1.Controls.Add(this.btnZoomIn);
-            this.groupBox1.Controls.Add(this.btnDown);
-            this.groupBox1.Controls.Add(this.btnRight);
-            this.groupBox1.Controls.Add(this.btnLeft);
-            this.groupBox1.Controls.Add(this.btnUp);
-            this.groupBox1.Location = new System.Drawing.Point(4, 4);
-            this.groupBox1.Name = "groupBox1";
-            this.groupBox1.Size = new System.Drawing.Size(112, 336);
-            this.groupBox1.TabIndex = 0;
-            this.groupBox1.TabStop = false;
-            this.groupBox1.Text = "Controls";
+            this.lblMapSize.Name = "lblMapSize";
+            this.lblMapSize.Size = new System.Drawing.Size(0, 17);
-            // btnZoomScale
+            // splitContainer1
-            this.btnZoomScale.Location = new System.Drawing.Point(22, 295);
-            this.btnZoomScale.Name = "btnZoomScale";
-            this.btnZoomScale.Size = new System.Drawing.Size(66, 23);
-            this.btnZoomScale.TabIndex = 17;
-            this.btnZoomScale.Text = "Zoom";
-            this.btnZoomScale.UseVisualStyleBackColor = true;
-            this.btnZoomScale.Click += new System.EventHandler(this.btnZoomScale_Click);
+            this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.splitContainer1.Location = new System.Drawing.Point(0, 25);
+            this.splitContainer1.Name = "splitContainer1";
-            // label1
+            // splitContainer1.Panel1
-            this.label1.AutoSize = true;
-            this.label1.Location = new System.Drawing.Point(19, 252);
-            this.label1.Name = "label1";
-            this.label1.Size = new System.Drawing.Size(71, 13);
-            this.label1.TabIndex = 16;
-            this.label1.Text = "Current Scale";
+            this.splitContainer1.Panel1.Controls.Add(this.splitContainer2);
-            // numScale
+            // splitContainer1.Panel2
-            this.numScale.Location = new System.Drawing.Point(22, 268);
-            this.numScale.Maximum = new decimal(new int[] {
-            99999,
-            0,
-            0,
-            0});
-            this.numScale.Minimum = new decimal(new int[] {
-            1,
-            0,
-            0,
-            0});
-            this.numScale.Name = "numScale";
-            this.numScale.Size = new System.Drawing.Size(66, 20);
-            this.numScale.TabIndex = 15;
-            this.numScale.Value = new decimal(new int[] {
-            1,
-            0,
-            0,
-            0});
+            this.splitContainer1.Panel2.Controls.Add(this.viewer);
+            this.splitContainer1.Size = new System.Drawing.Size(674, 440);
+            this.splitContainer1.SplitterDistance = 224;
+            this.splitContainer1.TabIndex = 2;
-            // btnLowerRight
+            // splitContainer2
-            this.btnLowerRight.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow_315;
-            this.btnLowerRight.Location = new System.Drawing.Point(75, 93);
-            this.btnLowerRight.Name = "btnLowerRight";
-            this.btnLowerRight.Size = new System.Drawing.Size(30, 30);
-            this.btnLowerRight.TabIndex = 14;
-            this.btnLowerRight.UseVisualStyleBackColor = true;
-            this.btnLowerRight.Click += new System.EventHandler(this.btnLowerRight_Click);
+            this.splitContainer2.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.splitContainer2.Location = new System.Drawing.Point(0, 0);
+            this.splitContainer2.Name = "splitContainer2";
+            this.splitContainer2.Orientation = System.Windows.Forms.Orientation.Horizontal;
-            // btnLowerLeft
+            // splitContainer2.Panel1
-            this.btnLowerLeft.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow_225;
-            this.btnLowerLeft.Location = new System.Drawing.Point(6, 93);
-            this.btnLowerLeft.Name = "btnLowerLeft";
-            this.btnLowerLeft.Size = new System.Drawing.Size(30, 30);
-            this.btnLowerLeft.TabIndex = 13;
-            this.btnLowerLeft.UseVisualStyleBackColor = true;
-            this.btnLowerLeft.Click += new System.EventHandler(this.btnLowerLeft_Click);
+            this.splitContainer2.Panel1.Controls.Add(this.legend);
-            // btnUpperLeft
+            // splitContainer2.Panel2
-            this.btnUpperLeft.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow_135;
-            this.btnUpperLeft.Location = new System.Drawing.Point(6, 20);
-            this.btnUpperLeft.Name = "btnUpperLeft";
-            this.btnUpperLeft.Size = new System.Drawing.Size(30, 30);
-            this.btnUpperLeft.TabIndex = 12;
-            this.btnUpperLeft.UseVisualStyleBackColor = true;
-            this.btnUpperLeft.Click += new System.EventHandler(this.btnUpperLeft_Click);
+            this.splitContainer2.Panel2.Controls.Add(this.propertyPane);
+            this.splitContainer2.Size = new System.Drawing.Size(224, 440);
+            this.splitContainer2.SplitterDistance = 223;
+            this.splitContainer2.TabIndex = 0;
-            // btnUpperRight
+            // legend
-            this.btnUpperRight.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow_045;
-            this.btnUpperRight.Location = new System.Drawing.Point(74, 20);
-            this.btnUpperRight.Name = "btnUpperRight";
-            this.btnUpperRight.Size = new System.Drawing.Size(30, 30);
-            this.btnUpperRight.TabIndex = 11;
-            this.btnUpperRight.UseVisualStyleBackColor = true;
-            this.btnUpperRight.Click += new System.EventHandler(this.btnUpperRight_Click);
+            this.legend.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.legend.Location = new System.Drawing.Point(0, 0);
+            this.legend.Name = "legend";
+            this.legend.Size = new System.Drawing.Size(224, 223);
+            this.legend.TabIndex = 0;
-            // btnClearSelect
+            // propertyPane
-            this.btnClearSelect.Image = global::Maestro.AddIn.Local.Properties.Resources.icon_clearselect;
-            this.btnClearSelect.Location = new System.Drawing.Point(58, 183);
-            this.btnClearSelect.Name = "btnClearSelect";
-            this.btnClearSelect.Size = new System.Drawing.Size(30, 30);
-            this.btnClearSelect.TabIndex = 8;
-            this.btnClearSelect.UseVisualStyleBackColor = true;
-            this.btnClearSelect.Click += new System.EventHandler(this.btnClearSelect_Click);
+            this.propertyPane.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.propertyPane.Location = new System.Drawing.Point(0, 0);
+            this.propertyPane.Name = "propertyPane";
+            this.propertyPane.Size = new System.Drawing.Size(224, 213);
+            this.propertyPane.TabIndex = 1;
-            // chkSelectFeatures
+            // viewer
-            this.chkSelectFeatures.AutoSize = true;
-            this.chkSelectFeatures.Location = new System.Drawing.Point(22, 219);
-            this.chkSelectFeatures.Name = "chkSelectFeatures";
-            this.chkSelectFeatures.Size = new System.Drawing.Size(56, 17);
-            this.chkSelectFeatures.TabIndex = 7;
-            this.chkSelectFeatures.Text = "Select";
-            this.chkSelectFeatures.UseVisualStyleBackColor = true;
+            this.viewer.ActiveTool = MapViewer.MapActiveTool.None;
+            this.viewer.Cursor = System.Windows.Forms.Cursors.Default;
+            this.viewer.Dock = System.Windows.Forms.DockStyle.Fill;
+            this.viewer.FeatureTooltipsEnabled = false;
+            this.viewer.Location = new System.Drawing.Point(0, 0);
+            this.viewer.Name = "viewer";
+            this.viewer.Size = new System.Drawing.Size(446, 440);
+            this.viewer.TabIndex = 0;
+            this.viewer.Text = "mgMapViewer1";
+            this.viewer.ZoomInFactor = 0.75;
+            this.viewer.ZoomOutFactor = 1.35;
-            // btnZoomExtents
+            // toolbar
-            this.btnZoomExtents.Image = global::Maestro.AddIn.Local.Properties.Resources.magnifier_zoom_fit;
-            this.btnZoomExtents.Location = new System.Drawing.Point(22, 183);
-            this.btnZoomExtents.Name = "btnZoomExtents";
-            this.btnZoomExtents.Size = new System.Drawing.Size(30, 30);
-            this.btnZoomExtents.TabIndex = 6;
-            this.btnZoomExtents.UseVisualStyleBackColor = true;
-            this.btnZoomExtents.Click += new System.EventHandler(this.btnZoomExtents_Click);
+            this.toolbar.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+            this.toolStripButton1});
+            this.toolbar.Location = new System.Drawing.Point(0, 0);
+            this.toolbar.Name = "toolbar";
+            this.toolbar.Size = new System.Drawing.Size(674, 25);
+            this.toolbar.TabIndex = 3;
+            this.toolbar.Text = "mgDefaultToolbar1";
+            this.toolbar.Viewer = null;
-            // btnZoomOut
+            // toolStripButton1
-            this.btnZoomOut.Image = global::Maestro.AddIn.Local.Properties.Resources.magnifier_zoom_out;
-            this.btnZoomOut.Location = new System.Drawing.Point(58, 147);
-            this.btnZoomOut.Name = "btnZoomOut";
-            this.btnZoomOut.Size = new System.Drawing.Size(30, 30);
-            this.btnZoomOut.TabIndex = 5;
-            this.btnZoomOut.UseVisualStyleBackColor = true;
-            this.btnZoomOut.Click += new System.EventHandler(this.btnZoomOut_Click);
+            this.toolStripButton1.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton1.Image")));
+            this.toolStripButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.toolStripButton1.Name = "toolStripButton1";
+            this.toolStripButton1.Size = new System.Drawing.Size(106, 22);
+            this.toolStripButton1.Text = "Zoom To Scale";
+            this.toolStripButton1.Click += new System.EventHandler(this.toolStripButton1_Click);
-            // btnZoomIn
-            this.btnZoomIn.Image = global::Maestro.AddIn.Local.Properties.Resources.magnifier_zoom_in;
-            this.btnZoomIn.Location = new System.Drawing.Point(22, 147);
-            this.btnZoomIn.Name = "btnZoomIn";
-            this.btnZoomIn.Size = new System.Drawing.Size(30, 30);
-            this.btnZoomIn.TabIndex = 4;
-            this.btnZoomIn.UseVisualStyleBackColor = true;
-            this.btnZoomIn.Click += new System.EventHandler(this.btnZoomIn_Click);
-            // btnDown
-            this.btnDown.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow_270;
-            this.btnDown.Location = new System.Drawing.Point(40, 93);
-            this.btnDown.Name = "btnDown";
-            this.btnDown.Size = new System.Drawing.Size(30, 30);
-            this.btnDown.TabIndex = 3;
-            this.btnDown.UseVisualStyleBackColor = true;
-            this.btnDown.Click += new System.EventHandler(this.btnDown_Click);
-            // btnRight
-            this.btnRight.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow;
-            this.btnRight.Location = new System.Drawing.Point(74, 57);
-            this.btnRight.Name = "btnRight";
-            this.btnRight.Size = new System.Drawing.Size(30, 30);
-            this.btnRight.TabIndex = 2;
-            this.btnRight.UseVisualStyleBackColor = true;
-            this.btnRight.Click += new System.EventHandler(this.btnRight_Click);
-            // btnLeft
-            this.btnLeft.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow_180;
-            this.btnLeft.Location = new System.Drawing.Point(6, 57);
-            this.btnLeft.Name = "btnLeft";
-            this.btnLeft.Size = new System.Drawing.Size(30, 30);
-            this.btnLeft.TabIndex = 1;
-            this.btnLeft.UseVisualStyleBackColor = true;
-            this.btnLeft.Click += new System.EventHandler(this.btnLeft_Click);
-            // btnUp
-            this.btnUp.Image = global::Maestro.AddIn.Local.Properties.Resources.arrow_090;
-            this.btnUp.Location = new System.Drawing.Point(40, 20);
-            this.btnUp.Name = "btnUp";
-            this.btnUp.Size = new System.Drawing.Size(30, 30);
-            this.btnUp.TabIndex = 0;
-            this.btnUp.UseVisualStyleBackColor = true;
-            this.btnUp.Click += new System.EventHandler(this.btnUp_Click);
-            // renderWorker
-            this.renderWorker.DoWork += new System.ComponentModel.DoWorkEventHandler(this.renderWorker_DoWork);
-            this.renderWorker.RunWorkerCompleted += new System.ComponentModel.RunWorkerCompletedEventHandler(this.renderWorker_RunWorkerCompleted);
-            this.renderWorker.ProgressChanged += new System.ComponentModel.ProgressChangedEventHandler(this.renderWorker_ProgressChanged);
-            // statusStrip1
-            this.statusStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
-            this.lblCoordinates,
-            this.lblFeaturesSelected});
-            this.statusStrip1.Location = new System.Drawing.Point(0, 465);
-            this.statusStrip1.Name = "statusStrip1";
-            this.statusStrip1.Size = new System.Drawing.Size(674, 22);
-            this.statusStrip1.TabIndex = 1;
-            this.statusStrip1.Text = "statusStrip1";
-            // lblCoordinates
-            this.lblCoordinates.Name = "lblCoordinates";
-            this.lblCoordinates.Size = new System.Drawing.Size(659, 17);
-            this.lblCoordinates.Spring = true;
-            this.lblCoordinates.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
-            // lblFeaturesSelected
-            this.lblFeaturesSelected.Name = "lblFeaturesSelected";
-            this.lblFeaturesSelected.Size = new System.Drawing.Size(0, 17);
             // MapPreviewWindow
             this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
             this.ClientSize = new System.Drawing.Size(674, 487);
             this.Controls.Add(this.splitContainer1);
+            this.Controls.Add(this.toolbar);
             this.Controls.Add(this.statusStrip1);
             this.Name = "MapPreviewWindow";
             this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
             this.Text = "Map Preview";
+            this.statusStrip1.ResumeLayout(false);
+            this.statusStrip1.PerformLayout();
             this.splitContainer1.Panel1.ResumeLayout(false);
             this.splitContainer1.Panel2.ResumeLayout(false);
             this.splitContainer1.ResumeLayout(false);
-            ((System.ComponentModel.ISupportInitialize)(this.mapImage)).EndInit();
-            this.panel1.ResumeLayout(false);
-            this.groupBox1.ResumeLayout(false);
-            this.groupBox1.PerformLayout();
-            ((System.ComponentModel.ISupportInitialize)(this.numScale)).EndInit();
-            this.statusStrip1.ResumeLayout(false);
-            this.statusStrip1.PerformLayout();
+            this.splitContainer2.Panel1.ResumeLayout(false);
+            this.splitContainer2.Panel2.ResumeLayout(false);
+            this.splitContainer2.ResumeLayout(false);
+            this.toolbar.ResumeLayout(false);
+            this.toolbar.PerformLayout();
             this.ResumeLayout(false);
             this.PerformLayout();
@@ -352,29 +206,18 @@
         #endregion
-        private System.Windows.Forms.SplitContainer splitContainer1;
-        private System.Windows.Forms.PictureBox mapImage;
-        private System.Windows.Forms.Panel panel1;
-        private System.Windows.Forms.GroupBox groupBox1;
-        private System.Windows.Forms.Button btnDown;
-        private System.Windows.Forms.Button btnRight;
-        private System.Windows.Forms.Button btnLeft;
-        private System.Windows.Forms.Button btnUp;
-        private System.Windows.Forms.Button btnZoomOut;
-        private System.Windows.Forms.Button btnZoomIn;
-        private System.Windows.Forms.Button btnZoomExtents;
-        private System.ComponentModel.BackgroundWorker renderWorker;
-        private System.Windows.Forms.CheckBox chkSelectFeatures;
-        private System.Windows.Forms.Button btnClearSelect;
-        private System.Windows.Forms.Button btnLowerRight;
-        private System.Windows.Forms.Button btnLowerLeft;
-        private System.Windows.Forms.Button btnUpperLeft;
-        private System.Windows.Forms.Button btnUpperRight;
-        private System.Windows.Forms.Label label1;
-        private System.Windows.Forms.NumericUpDown numScale;
-        private System.Windows.Forms.Button btnZoomScale;
         private System.Windows.Forms.StatusStrip statusStrip1;
         private System.Windows.Forms.ToolStripStatusLabel lblCoordinates;
         private System.Windows.Forms.ToolStripStatusLabel lblFeaturesSelected;
+        private System.Windows.Forms.ToolStripStatusLabel lblScale;
+        private System.Windows.Forms.ToolStripStatusLabel lblSelectedFeatures;
+        private System.Windows.Forms.ToolStripStatusLabel lblMapSize;
+        private System.Windows.Forms.SplitContainer splitContainer1;
+        private System.Windows.Forms.SplitContainer splitContainer2;
+        private MapViewer.MgLegend legend;
+        private MapViewer.MgPropertyPane propertyPane;
+        private MapViewer.MgMapViewer viewer;
+        private MapViewer.MgDefaultToolbar toolbar;
+        private System.Windows.Forms.ToolStripButton toolStripButton1;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs	2011-09-05 07:37:53 UTC (rev 6113)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs	2011-09-05 11:41:03 UTC (rev 6114)
@@ -30,578 +30,69 @@
 using OSGeo.MapGuide.ObjectModels;
+using MapViewer;
+using ICSharpCode.Core;
 namespace Maestro.AddIn.Local.UI
-    public partial class MapPreviewWindow : Form
+    public partial class MapPreviewWindow : Form, IMapStatusBar
-        private MgdMap _map;
-        private MgRenderingService _renderSvc;
-        private MgCoordinateSystem _mapCs;
-        private MgdSelection _selection;
-        private MgRenderingOptions _layerRenderOpts;
-        private MgMeasure _mapMeasure;
-        private MgWktReaderWriter _wktRW;
-        private MgAgfReaderWriter _agfRW;
-        private MgGeometryFactory _geomFact;
+        private IServerConnection _conn;
-        private Color _mapBgColor;
-        public MapPreviewWindow(MgdMap map, IServerConnection conn)
+        public MapPreviewWindow(IServerConnection conn)
             InitializeComponent();
-            _map = map;
-            var fact = new MgCoordinateSystemFactory();
-            _mapCs = fact.Create(_map.GetMapSRS());
-            _mapMeasure = _mapCs.GetMeasure();
-            _wktRW = new MgWktReaderWriter();
-            _agfRW = new MgAgfReaderWriter();
-            _geomFact = new MgGeometryFactory();
-            this.Disposed += new EventHandler(OnDisposed);
+            _conn = conn;
-            Init(_map, conn);
+            new MapViewerController(viewer, legend, this, propertyPane, toolbar);
+            this.Disposed += OnDisposed;
-        void OnDisposed(object sender, EventArgs e)
-            if (_renderSvc != null)
-                _renderSvc.Dispose();
-                _renderSvc = null;
+        private MgdMap _map;
-            if (_selection != null)
-                _selection.Dispose();
-                _selection = null;
-            if (_mapMeasure != null)
-                _mapMeasure.Dispose();
-                _mapMeasure = null;
-            if (_mapCs != null)
-                _mapCs.Dispose();
-                _mapCs = null;
-            if (_wktRW != null)
-                _wktRW.Dispose();
-                _wktRW = null;
-            if (_agfRW != null)
-                _agfRW.Dispose();
-                _agfRW = null;
-            if (_geomFact != null)
-                _geomFact.Dispose();
-                _geomFact = null;
-        private double _orgX1;
-        private double _orgX2;
-        private double _orgY1;
-        private double _orgY2;
-        private double _extX1;
-        private double _extX2;
-        private double _extY1;
-        private double _extY2;
-        private bool _init = false;
-#if DEBUG
-        private MgdLayer _debugLayer;
-#endif
-        public void Init(MgdMap map, IServerConnection conn)
+        public void Init(MgResourceIdentifier mapResId)
-            numScale.Maximum = int.MaxValue;
-            _init = false;
-            _renderSvc = MgServiceFactory.CreateRenderingService();
-            _layerRenderOpts = new MgRenderingOptions(MgImageFormats.Png, 7, new MgColor(0, 0, 255));
-            _map = map;
-            var bgColor = _map.GetBackgroundColor();
-            if (bgColor.Length == 8 || bgColor.Length == 6)
-                _mapBgColor = ColorTranslator.FromHtml("#" + bgColor);
-                mapImage.BackColor = _mapBgColor;
-            _map.SetDisplaySize(mapImage.Width, mapImage.Height);
-            _selection = new MgdSelection(_map);
-            var env = _map.GetMapExtent();
-            var ll = env.LowerLeftCoordinate;
-            var ur = env.UpperRightCoordinate;
-            _extX1 = _orgX1 = ll.X;
-            _extY2 = _orgY2 = ll.Y;
-            _extX2 = _orgX2 = ur.X;
-            _extY1 = _orgY1 = ur.Y;
-            if ((_orgX1 - _orgX2) == 0 || (_orgY1 - _orgY2) == 0)
-                _extX1 = _orgX1 = -.1;
-                _extY2 = _orgX2 = .1;
-                _extX2 = _orgY1 = -.1;
-                _extY1 = _orgY2 = .1;
-            double scale = CalculateScale(Math.Abs(_orgX2 - _orgX1), Math.Abs(_orgY2 - _orgY1), this.Width, this.Height);
-            numScale.Value = Convert.ToDecimal(scale);
-            _map.SetViewCenterXY(_extX1 + (_extX2 - _extX1) / 2, _extY2 + (_extY1 - _extY2) / 2);
-            _map.SetViewScale(scale);
-#if DEBUG
-            CreateDebugFeatureSource(conn);
-#endif
-            _init = true;
+            _map = new MgdMap(mapResId);
+            viewer.Init(_map);
+            viewer.RefreshMap();
-#if DEBUG
-        private void CreateDebugFeatureSource(IServerConnection conn)
+        void OnDisposed(object sender, EventArgs e)
-            var id = new MgDataPropertyDefinition("ID");
-            id.DataType = MgPropertyType.Int32;
-            id.Nullable = false;
-            id.SetAutoGeneration(true);
-            var geom = new MgGeometricPropertyDefinition("Geometry");
-            geom.GeometryTypes = MgFeatureGeometricType.Point;
-            geom.SpatialContextAssociation = "MapCs";
-            var cls = new MgClassDefinition();
-            cls.Name = "Debug";
-            var props = cls.GetProperties();
-            props.Add(id);
-            props.Add(geom);
-            var idProps = cls.GetIdentityProperties();
-            idProps.Add(id);
-            cls.DefaultGeometryPropertyName = "Geometry";
-            var schema = new MgFeatureSchema("Default", "Default schema");
-            var classes = schema.GetClasses();
-            classes.Add(cls);
-            var debugFsId = new MgResourceIdentifier("Session:" + conn.SessionID + "//Debug" + Guid.NewGuid().ToString() + ".FeatureSource");
-            var createSdf = new MgCreateSdfParams("MapCs", _map.GetMapSRS(), schema);
-            var featureSvc = MgServiceFactory.CreateFeatureService();
-            var resSvc = MgServiceFactory.CreateResourceService();
-            featureSvc.CreateFeatureSource(debugFsId, createSdf);
-            //We use a v1.0.0 Layer Definition so that a default composite style is not created
-            //A composite style would override every other basic geometry style
-            var ldf = ObjectFactory.CreateDefaultLayer(conn, LayerType.Vector, new Version(1, 0, 0));
-            var vl = ((IVectorLayerDefinition)ldf.SubLayer);
-            vl.FeatureName = "Default:Debug";
-            vl.ResourceId = debugFsId.ToString();
-            vl.Geometry = "Geometry";
-            var vsrs = new List<IVectorScaleRange>(vl.VectorScaleRange);
-            var rules = new List<IPointRule>(vsrs[0].PointStyle.Rules);
-            rules[0].Label = ldf.CreateDefaultTextSymbol();
-            rules[0].Label.SetForegroundColor(Color.Red);
-            rules[0].Label.BackgroundStyle = BackgroundStyleType.Ghosted;
-            rules[0].Label.Text = "Concat(X(Geometry),',',Y(Geometry))";
-            var debugLayerId = new MgResourceIdentifier("Session:" + conn.SessionID + "//" + debugFsId.Name + ".LayerDefinition");
-            ldf.ResourceID = debugLayerId.ToString();
-            conn.ResourceService.SaveResource(ldf);
-            _debugLayer = new MgdLayer(debugLayerId, resSvc);
-            _debugLayer.SetVisible(true);
-            _debugLayer.SetDisplayInLegend(true);
-            var mapLayers = _map.GetLayers();
-            mapLayers.Insert(0, _debugLayer);
-            UpdateCenterDebugPoint();
-        private MgPropertyCollection _debugCenter;
-        private void UpdateCenterDebugPoint()
-            if (_debugCenter == null)
-                _debugCenter = new MgPropertyCollection();
-            var center = _wktRW.Read("POINT (" + _map.ViewCenter.Coordinate.X + " " + _map.ViewCenter.Coordinate.Y + ")");
-            var agf = _agfRW.Write(center);
-            if (!_debugCenter.Contains("Geometry"))
+            if (_map != null)
-                MgGeometryProperty geom = new MgGeometryProperty("Geometry", agf);
-                _debugCenter.Add(geom);
+                _map.Dispose();
+                _map = null;
-            else
-                MgGeometryProperty geom = (MgGeometryProperty)_debugCenter.GetItem("Geometry");
-                geom.SetValue(agf);
-            int deleted = _debugLayer.DeleteFeatures("");
-            Trace.TraceInformation("Deleted {0} debug points", deleted);
-            var reader = _debugLayer.InsertFeatures(_debugCenter);
-            int inserted = 0;
-            while (reader.ReadNext())
-                inserted++;
-            reader.Close();
-            Trace.TraceInformation("Added {0} debug points", inserted);
-            _debugLayer.ForceRefresh();
-#endif
-        private double CalculateScale(double mcsW, double mcsH, int devW, int devH)
+        public void SetCursorPositionMessage(string message)
-            var mpu = _map.GetMetersPerUnit();
-            var mpp = 0.0254 / _map.DisplayDpi;
-            if (devH * mcsW > devW * mcsH)
-                return mcsW * mpu / (devW * mpp); //width-limited
-            else
-                return mcsH * mpu / (devH * mpp); //height-limited
+            lblCoordinates.Text = message;
-        protected override void OnLoad(EventArgs e)
+        public void SetFeatureSelectedMessage(string message)
-            base.OnLoad(e);
-            ZoomExtents();
+            lblFeaturesSelected.Text = message;
-        protected override void OnResize(EventArgs e)
+        public void SetMapScaleMessage(string message)
-            if (!_init)
-                return;
-            base.OnResize(e);
-            RefreshMap();
+            lblScale.Text = message;
-        class RenderWorkArgs
+        public void SetMapSizeMessage(string message)
-            public MgRenderingOptions RenderingOptions { get; set; }
+            lblMapSize.Text = message;
-        class RenderResult
+        private void toolStripButton1_Click(object sender, EventArgs e)
-            public Image Image { get; set; }
-            public Image Overlay { get; set; }
-        public void RefreshMap()
-            if (renderWorker.IsBusy)
-                return;
-            if (mapImage.Image != null)
+            var diag = new ZoomScaleDialog();
+            if (diag.ShowDialog() == DialogResult.OK)
-                mapImage.Image.Dispose();
-                mapImage.Image = null;
+                viewer.ZoomToScale(diag.Value);
-            renderWorker.RunWorkerAsync(new RenderWorkArgs() { RenderingOptions = _layerRenderOpts });
-        public void Pan(double x, double y, bool refresh)
-            ZoomToView(x, y, _map.ViewScale, refresh);
-        public void ZoomToView(double x, double y, double scale, bool refresh)
-            _map.SetViewCenterXY(x, y);
-#if DEBUG
-            //var mapExt = _map.MapExtent;
-            //var dataExt = _map.DataExtent;
-            //Trace.TraceInformation("Map Extent is ({0},{1} {2},{3})", mapExt.LowerLeftCoordinate.X, mapExt.LowerLeftCoordinate.Y, mapExt.UpperRightCoordinate.X, mapExt.UpperRightCoordinate.Y);
-            //Trace.TraceInformation("Data Extent is ({0},{1} {2},{3})", dataExt.LowerLeftCoordinate.X, dataExt.LowerLeftCoordinate.Y, dataExt.UpperRightCoordinate.X, dataExt.UpperRightCoordinate.Y);
-            Trace.TraceInformation("Center is (" + x + ", " + y + ")");
-#endif
-            //Update current extents
-            double mpu = _map.GetMetersPerUnit();
-            double mpp = 0.0254 / _map.DisplayDpi;
-            var mcsWidth = _map.DisplayWidth * mpp * scale / mpu;
-            var mcsHeight = _map.DisplayHeight * mpp * scale / mpu;
-            _extX1 = x - mcsWidth / 2;
-            _extY1 = y + mcsHeight / 2;
-            _extX2 = x + mcsWidth / 2;
-            _extY2 = y - mcsHeight / 2;
-#if DEBUG
-            Trace.TraceInformation("Current extents is ({0},{1} {2},{3})", _extX1, _extY1, _extX2, _extY2);
-#endif
-            //Then refresh
-            if (refresh)
-                RefreshMap();
-        private void btnLeft_Click(object sender, EventArgs e)
-            PanLeft(true);
-        private void btnUp_Click(object sender, EventArgs e)
-            PanUp(true);
-        private void btnRight_Click(object sender, EventArgs e)
-            PanRight(true);
-        private void btnDown_Click(object sender, EventArgs e)
-            PanDown(true);
-        private void PanLeft(bool refresh)
-            Pan(_extX1 + (_extX2 - _extX1) / 3, _extY2 + (_extY1 - _extY2) / 2, refresh);
-        private void PanUp(bool refresh)
-            Pan(_extX1 + (_extX2 - _extX1) / 2, _extY1 - (_extY1 - _extY2) / 3, refresh);
-        private void PanRight(bool refresh)
-            Pan(_extX2 - (_extX2 - _extX1) / 3, _extY2 + (_extY1 - _extY2) / 2, refresh);
-        private void PanDown(bool refresh)
-            Pan(_extX1 + (_extX2 - _extX1) / 2, _extY2 + (_extY1 - _extY2) / 3, refresh);
-        private void btnZoomIn_Click(object sender, EventArgs e)
-            var scale = _map.ViewScale * 0.8;
-            ZoomToView(_extX1 + (_extX2 - _extX1) / 2, _extY2 + (_extY1 - _extY2) / 2, scale, true);
-            //_map.SetViewScale(_map.ViewScale * 0.8);
-            //RefreshMap();
-        private void btnZoomOut_Click(object sender, EventArgs e)
-            var scale = _map.ViewScale * 1.2;
-            //_map.SetViewScale(_map.ViewScale * 1.2);
-            //RefreshMap();
-        private void btnZoomExtents_Click(object sender, EventArgs e)
-            ZoomExtents();
-        public void ZoomExtents()
-            var scale = CalculateScale((_orgX2 - _orgX1), (_orgY1 - _orgY2), mapImage.Width, mapImage.Height);
-            ZoomToView(_orgX1 + ((_orgX2 - _orgX1) / 2), _orgY2 + ((_orgY1 - _orgY2) / 2), scale, true);
-        private void renderWorker_DoWork(object sender, DoWorkEventArgs e)
-            var args = (RenderWorkArgs)e.Argument;
-            var res = new RenderResult();
-            var br = _renderSvc.RenderDynamicOverlay(_map, _selection, args.RenderingOptions);
-            byte[] b = new byte[br.GetLength()];
-            br.Read(b, b.Length);
-            using (var ms = new MemoryStream(b))
-                res.Image = Image.FromStream(ms);
-            e.Result = res;
-        private void renderWorker_ProgressChanged(object sender, ProgressChangedEventArgs e)
-        private void renderWorker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
-            if (e.Error != null)
-                MessageBox.Show(e.Error.Message, "Error");
-            else
-                var res = (RenderResult)e.Result;
-                //set the image
-                mapImage.Image = res.Image;
-                numScale.Value = Convert.ToDecimal(_map.ViewScale);
-        private void btnClearSelect_Click(object sender, EventArgs e)
-            _selection.Clear();
-            RefreshMap();
-        private void mapImage_MouseClick(object sender, MouseEventArgs e)
-            if (!chkSelectFeatures.Checked)
-                return;
-            var mapPt1 = ScreenToMapUnits(e.X-2, e.Y-2);
-            var mapPt2 = ScreenToMapUnits(e.X+2, e.Y+2);
-            var coord1 = _geomFact.CreateCoordinateXY(mapPt1.X, mapPt1.Y);
-            var coord2 = _geomFact.CreateCoordinateXY(mapPt2.X, mapPt2.Y);
-            var dist = _mapMeasure.GetDistance(coord1, coord2);
-            MgGeometry geom = _wktRW.Read(MakeWktPolygon(mapPt1.X, mapPt1.Y, mapPt2.X, mapPt2.Y));
-            SelectByGeometry(geom);
-        private static string MakeWktPolygon(double x1, double y1, double x2, double y2)
-            return "POLYGON((" + x1 + " " + y1 + ", " + x2 + " " + y1 + ", " + x2 + " " + y2 + ", " + x1 + " " + y2 + ", " + x1 + " " + y1 + "))";
-        private Dictionary<string, string> _layerGeomProps = new Dictionary<string, string>();
-        private void SelectByGeometry(MgGeometry geom)
-            var layers = _map.GetLayers();
-            //Cache geometry properties
-            for (int i = 0; i < layers.GetCount(); i++)
-                var layer = layers.GetItem(i);
-                if (!layer.Selectable || !layer.IsVisible())
-                    continue;
-                var objId = layer.GetObjectId();
-                if (_layerGeomProps.ContainsKey(objId))
-                    continue;
-                var cls = layer.GetClassDefinition();
-                var geomName = cls.DefaultGeometryPropertyName;
-                if (!string.IsNullOrEmpty(geomName))
-                    if (!_layerGeomProps.ContainsKey(objId))
-                        _layerGeomProps[objId] = geomName;
-                    continue;
-                MgFeatureQueryOptions query = new MgFeatureQueryOptions();
-                query.SetSpatialFilter(_layerGeomProps[objId], geom, MgFeatureSpatialOperations.Intersects);
-                MgFeatureReader reader = layer.SelectFeatures(query);
-                _selection.AddFeatures(layer, reader, 0);
-            int total = 0;
-                total += _selection.GetSelectedFeaturesCount(layer, layer.FeatureClassName);
-            lblFeaturesSelected.Text = string.Format("{0} features selected", total);
-            string xml = _selection.ToXml();
-            if (!string.IsNullOrEmpty(xml))
-                RefreshMap();
-        public PointF ScreenToMapUnits(double x, double y)
-            return ScreenToMapUnits(x, y, false);
-        private PointF ScreenToMapUnits(double x, double y, bool allowOutsideWindow)
-            if (!allowOutsideWindow)
-                if (x > mapImage.Width - 1) x = mapImage.Width - 1;
-                else if (x < 0) x = 0;
-                if (y > mapImage.Height - 1) y = mapImage.Height - 1;
-                else if (y < 0) y = 0;
-            x = _extX1 + (_extX2 - _extX1) * (x / mapImage.Width);
-            y = _extY1 - (_extY1 - _extY2) * (y / mapImage.Height);
-            return new PointF((float)x, (float)y);
-        private void btnUpperLeft_Click(object sender, EventArgs e)
-            PanUp(false);
-            PanLeft(true);
-        private void btnUpperRight_Click(object sender, EventArgs e)
-            PanUp(false);
-            PanRight(true);
-        private void btnLowerLeft_Click(object sender, EventArgs e)
-            PanDown(false);
-            PanLeft(true);
-        private void btnLowerRight_Click(object sender, EventArgs e)
-            PanDown(false);
-            PanRight(true);
-        private void btnZoomScale_Click(object sender, EventArgs e)
-            var scale = Convert.ToDouble(numScale.Value);
-        private void mapImage_MouseMove(object sender, MouseEventArgs e)
-            var mapPt = ScreenToMapUnits(e.X, e.Y);
-            lblCoordinates.Text = string.Format("X: {0:0.0000000}, Y: {1:0.0000000} ({2})", mapPt.X, mapPt.Y, _mapCs.Units);
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.resx	2011-09-05 07:37:53 UTC (rev 6113)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.resx	2011-09-05 11:41:03 UTC (rev 6114)
@@ -117,10 +117,26 @@
   <resheader name="writer">
     <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-  <metadata name="renderWorker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 17</value>
-  </metadata>
   <metadata name="statusStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>144, 17</value>
   </metadata>
+  <metadata name="toolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>260, 17</value>
+  </metadata>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIISURBVDhPpZP7S1NxGMbPPxKaXVUkMEq8IpKUCoY/hGgI
+        ymqkDYYXcCjDZOANURSjCNGFQUTsl4GXVMxKk62YU4fXQpaIlygHQxBRH8/zwvyaIAYe+HLgnPN8nue9
+        HA3nvDTq63oW/jm13XOwvPTB3DYFY5MH+bXfcN8ygfTSMSSXfESicQDxBqdYHwH29g9w2tnZ3UcguIvN
+        rR3417exuBJE5N1n/wfwLgXEOc38Bc6xNRHb+/y4nm49G0Bnit2zf9H6bkliE/jKuYxrd6oVgDWfjB+K
+        TWeKMyrGEVfowITvD9re/9ABVQrAhh0HHK+ZselMMaN/mvwtDb+aVqkA7HYIwIj3ysfluPTorJnP6Ezx
+        oHsD1s5ZXEktUwCOioB5f1CEPR9+wTG6iuiserTo8dkwng7HT/R+XUPF8xlcTjErAOdMcW6NW8STiwG8
+        7vej8oUPN/PsEv3t8Ao0TZP3T1u8uJRkUgAuSYHtO97oLxmXd5t9Ho8aPTK+GzntqNfrLm2fFoihwYOI
+        xGIF4KjoGBLzY1OrF9k6OOFxnwDC4wxIMX1G0pMhgVyMNyoA13PAtS7OrJk1PrC69LUdQWxuF6IybHrX
+        LRI7JrtZdoDAo1XmbjMyD+tjSXxGcXRmnYg5ttD9QuxDhN0uUgDOmbvNTpPOJaGAo2K36cyaGZvOFIfd
+        KlSA8/zRh9ABIDUG+1JpAAAAAElFTkSuQmCC
+</value>
+  </data>
 </root>
Added: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.Designer.cs	2011-09-05 11:41:03 UTC (rev 6114)
@@ -0,0 +1,102 @@
+namespace Maestro.AddIn.Local.UI
+    partial class ZoomScaleDialog
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.label1 = new System.Windows.Forms.Label();
+            this.btnOK = new System.Windows.Forms.Button();
+            this.btnCancel = new System.Windows.Forms.Button();
+            this.numScale = new System.Windows.Forms.NumericUpDown();
+            ((System.ComponentModel.ISupportInitialize)(this.numScale)).BeginInit();
+            this.SuspendLayout();
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(13, 13);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(64, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "Zoom Scale";
+            // btnOK
+            this.btnOK.Location = new System.Drawing.Point(115, 37);
+            this.btnOK.Name = "btnOK";
+            this.btnOK.Size = new System.Drawing.Size(75, 23);
+            this.btnOK.TabIndex = 2;
+            this.btnOK.Text = "OK";
+            this.btnOK.UseVisualStyleBackColor = true;
+            this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+            // btnCancel
+            this.btnCancel.Location = new System.Drawing.Point(197, 37);
+            this.btnCancel.Name = "btnCancel";
+            this.btnCancel.Size = new System.Drawing.Size(75, 23);
+            this.btnCancel.TabIndex = 3;
+            this.btnCancel.Text = "Cancel";
+            this.btnCancel.UseVisualStyleBackColor = true;
+            this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+            // numScale
+            this.numScale.Location = new System.Drawing.Point(102, 11);
+            this.numScale.Name = "numScale";
+            this.numScale.Size = new System.Drawing.Size(170, 20);
+            this.numScale.TabIndex = 4;
+            // ZoomScaleDialog
+            this.AcceptButton = this.btnOK;
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.CancelButton = this.btnCancel;
+            this.ClientSize = new System.Drawing.Size(284, 72);
+            this.ControlBox = false;
+            this.Controls.Add(this.numScale);
+            this.Controls.Add(this.btnCancel);
+            this.Controls.Add(this.btnOK);
+            this.Controls.Add(this.label1);
+            this.Name = "ZoomScaleDialog";
+            this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+            this.Text = "Zoom Scale";
+            ((System.ComponentModel.ISupportInitialize)(this.numScale)).EndInit();
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.Button btnOK;
+        private System.Windows.Forms.Button btnCancel;
+        private System.Windows.Forms.NumericUpDown numScale;
Added: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.cs	2011-09-05 11:41:03 UTC (rev 6114)
@@ -0,0 +1,54 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+    public partial class ZoomScaleDialog : Form
+        public ZoomScaleDialog()
+            InitializeComponent();
+            numScale.Minimum = Convert.ToDecimal(1.0M);
+            numScale.Maximum = Convert.ToDecimal(int.MaxValue);
+        public double Value
+            get { return Convert.ToDouble(numScale.Value); }
+        private void btnCancel_Click(object sender, EventArgs e)
+            this.DialogResult = DialogResult.Cancel;
+        private void btnOK_Click(object sender, EventArgs e)
+            this.DialogResult = DialogResult.OK;
Added: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ZoomScaleDialog.resx	2011-09-05 11:41:03 UTC (rev 6114)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
More information about the mapguide-commits
