[mapguide-commits] r6143 - in trunk/Tools/Maestro: Maestro
Properties
svn_mapguide at osgeo.org
Wed Sep 21 11:40:59 EDT 2011
Author: jng
Date: 2011-09-21 08:40:59 -0700 (Wed, 21 Sep 2011)
New Revision: 6143
trunk/Tools/Maestro/Maestro/changelog.txt
trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
Prepare new beta 2 release
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2011-09-21 14:34:54 UTC (rev 6142)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2011-09-21 15:40:59 UTC (rev 6143)
@@ -3,6 +3,7 @@
- Support for non-transactional package loading w/ ability to retry failed operations
- Style editor support for FDO expressions in color properties
+ - If an broken Layer Definition is opened, the user is now given a chance to repair it by selecting a valid feature source
- Fix: assorted issues introduced by the new multi-site support.
- Updated mg-desktop binaries for Local Connection mode.
@@ -13,7 +14,7 @@
- New Local Connection mode, backed by the new mg-desktop library (http://mg-desktop.googlecode.com). This feature is Windows only
- MgCooker updated to support Local Connections
- Support drag/drop creation of Drawing Sources from DWF files
- - Resource Previewing is now an connection provider defined function
+ - Resource Previewing is now a connection provider defined function
- API: ResourceMigrator now applies any downgrades if required
- API: Each connection provider is now responsible for creating coordinate transformers. Local and LocalNative connections return a MgCoordinateSystem-wrapped transformer.
- Fix: SizeContext values not saved
Modified: trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-09-21 14:34:54 UTC (rev 6142)
+++ trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-09-21 15:40:59 UTC (rev 6143)
@@ -35,5 +35,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("4.0.0.6138")]
-[assembly: AssemblyFileVersion("4.0.0.6138")]
+[assembly: AssemblyVersion("4.0.0.6143")]
+[assembly: AssemblyFileVersion("4.0.0.6143")]
More information about the mapguide-commits
