[mapguide-commits] r6144 - in trunk/MgDev: Common/MdfModel Common/MdfParser Common/Schema Server/src/Services/Mapping Server/src/Services/Rendering
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Sep 21 21:57:08 EDT 2011
Author: liuar
Date: 2011-09-21 18:57:08 -0700 (Wed, 21 Sep 2011)
New Revision: 6144
   trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.cpp
   trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.h
   trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.cpp
   trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.h
   trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp
   trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd
   trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
   trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
   trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
The RFC 110 Profiling Service (IX).
1. Refactoring the RenderMapInternal method in ServerRenderingService.
2. Replace CS wkt with user friendly CS code to describe the coordinate system of map and layer.
3. Fix the incorrect render dynamic overlay end tag.
Modified: trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.cpp
--- trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.cpp	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.cpp	2011-09-22 01:57:08 UTC (rev 6144)
@@ -124,7 +124,7 @@
 // PURPOSE: Accessor method for the CoordinateSystem property.
-// RETURNS: The coordinate system as WKT used by the layer.
+// RETURNS: The coordinate system code used by the layer.
 const MdfString& ProfileRenderLayerResult::GetCoordinateSystem() const
@@ -135,7 +135,7 @@
 // PURPOSE: Accessor method to the CoordinateSystem property.
 // PARAMETERS:
 //      Input:
-//          pstrCoordinateSystem - The coordinate system as WKT used by the layer.
+//          pstrCoordinateSystem - The coordinate system code used by the layer.
 void ProfileRenderLayerResult::SetCoordinateSystem(const MdfString& pstrCoordinateSystem)
Modified: trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.h
--- trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.h	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Common/MdfModel/ProfileRenderLayerResult.h	2011-09-22 01:57:08 UTC (rev 6144)
@@ -60,7 +60,7 @@
         void SetFeatureClassName(const MdfString& pstrFeatureClassName);
         // Property: CoordinateSystem
-        // The coordinate system as WKT used by the layer.
+        // The coordinate system code used by the layer.
         const MdfString& GetCoordinateSystem() const;
         void SetCoordinateSystem(const MdfString& pstrCoordinateSystem);
Modified: trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.cpp
--- trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.cpp	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.cpp	2011-09-22 01:57:08 UTC (rev 6144)
@@ -73,7 +73,7 @@
-// RETURNS: The coordinate system as WKT used by the map.
+// RETURNS: The coordinate system code used by the map.
 const MdfString& ProfileRenderMapResult::GetCoordinateSystem() const
@@ -84,7 +84,7 @@
 // PARAMETERS:
 //      Input:
-//          pstrCoordinateSystem - The coordinate system as WKT used by the map.
+//          pstrCoordinateSystem - The coordinate system code used by the map.
 void ProfileRenderMapResult::SetCoordinateSystem(const MdfString& pstrCoordinateSystem)
Modified: trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.h
--- trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.h	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Common/MdfModel/ProfileRenderMapResult.h	2011-09-22 01:57:08 UTC (rev 6144)
@@ -51,7 +51,7 @@
         void SetResourceId(const MdfString& pstrResourceId);
-        // The coordinate system as WKT used by the map.
+        // The coordinate system code used by the map.
Modified: trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp
--- trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Common/MdfParser/IOProfileRenderMapResult.cpp	2011-09-22 01:57:08 UTC (rev 6144)
@@ -158,7 +158,7 @@
     IOUnknown::Write(fd, profileRenderMapResult->GetUnknownXml(), version, tab);
     tab.dectab();
-    if (ProfileResult::ProfileRenderMap)
+    if (ProfileResult::ProfileRenderMap == type)
         fd << tab.tab() << endStr(sProfileRenderMapResult) << std::endl;
     else //ProfileResult::ProfileRenderDynamicOverlay
         fd << tab.tab() << endStr(sProfileRenderDynamicOverlayResult) << std::endl;
Modified: trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd
--- trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd	2011-09-22 01:57:08 UTC (rev 6144)
@@ -40,7 +40,7 @@
       </xs:element>
       <xs:element name="CoordinateSystem" type="xs:string">
         <xs:annotation>
-          <xs:documentation>The coordinate system as WKT used by the map.</xs:documentation>
+          <xs:documentation>The coordinate system code used by the map.</xs:documentation>
         </xs:annotation>
       </xs:element>
       <xs:element name="Extents" type="Box2DType">
@@ -195,7 +195,7 @@
       </xs:element>
         <xs:annotation>
-          <xs:documentation>The coordinate system as WKT used by the layer.</xs:documentation>
+          <xs:documentation>The coordinate system code used by the layer.</xs:documentation>
         </xs:annotation>
       </xs:element>
       <xs:element name="ScaleRange" type="ScaleRangeType">
Modified: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp	2011-09-22 01:57:08 UTC (rev 6144)
@@ -837,13 +837,13 @@
                 pPRLResult->SetFeatureClassName(mapLayer->GetFeatureClassName());
-                STRING layerCSWkt = L"";
+                STRING layerCsCode = L"";
                 if(NULL != TCForProfile)
                     Ptr<MgCoordinateSystem> layerCS = TCForProfile->GetCoordSys();
-                    layerCSWkt = csFactory->ConvertCoordinateSystemCodeToWkt(layerCS->GetCsCode());
+                    layerCsCode = layerCS->GetCsCode();
-                pPRLResult->SetCoordinateSystem(layerCSWkt);
+                pPRLResult->SetCoordinateSystem(layerCsCode);
                 ScaleRange* pScaleRange = new ScaleRange();
                 pScaleRange->SetMinScale(minScale_Profile);
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp	2011-09-22 01:57:08 UTC (rev 6144)
@@ -394,12 +394,11 @@
     if(NULL != pPRMResult)
-        Ptr<MgResourceIdentifier> mapResId = map->GetResourceId();
+        Ptr<MgResourceIdentifier> mapResId = map->GetMapDefinition();
         pPRMResult->SetResourceId(mapResId ? mapResId->ToString() : L"");
         pPRMResult->SetScale(scale);
         pPRMResult->SetExtents(Box2D(extent.minx, extent.miny, extent.maxx, extent.maxy));
         pPRMResult->SetLayerCount(layers->GetCount());
-        pPRMResult->SetCoordinateSystem(map->GetMapSRS());
     // call the internal helper API to do all the stylization overhead work
@@ -703,13 +702,12 @@
         pPRMResult->SetExtents(Box2D(b.minx, b.miny, b.maxx, b.maxy));
         Ptr<MgLayerCollection> layers = map->GetLayers();
@@ -972,341 +970,32 @@
         INT32 behavior = options->GetBehavior();
         if (behavior & MgRenderingOptions::RenderLayers)    // this is for tiles so observer colormaps
-            ProfileRenderLayersResult* pPRLsResult = NULL; // pointer points to Profile Render Layers Result
-            if(NULL != pPRMResult)
-                pPRLsResult = new ProfileRenderLayersResult();
-                pPRMResult->AdoptProfileRenderLayersResult(pPRLsResult);
-                // Set the start time of stylizing layers
-                pPRLsResult->SetRenderTime(MgTimerUtil::GetTime());
-            MgMappingUtil::StylizeLayers(m_svcResource, m_svcFeature, m_svcDrawing, m_pCSFactory, map,
-                                         tempLayers, NULL, &ds, dr, dstCs, expandExtents, false, scale,
-                                         false, hasColorMap(format), pPRLsResult);
-                pPRLsResult = pPRMResult->GetProfileRenderLayersResult();
-                // Calculate the time spent on stylizing layers
-                double stylizeLayersTime = MgTimerUtil::GetTime() - pPRLsResult->GetRenderTime();
-                pPRLsResult->SetRenderTime(stylizeLayersTime);
+            RenderLayers(map, tempLayers, &ds, dr, dstCs, expandExtents, scale, format, pPRMResult);
         // now we need to stylize the selection on top (this is not for tiles!)
         if (selection && (behavior & MgRenderingOptions::RenderSelection))
-            ProfileRenderSelectionResult* pPRSResult = NULL; // pointer points to Profile Render Selection Result
-                pPRSResult = new ProfileRenderSelectionResult();
-                pPRMResult->AdoptProfileRenderSelectionResult(pPRSResult);
-                // Set the start time of stylizing selected layers
-                pPRSResult->SetRenderTime(MgTimerUtil::GetTime());
-            Ptr<MgReadOnlyLayerCollection> selLayers = selection->GetLayers();
-            #ifdef _DEBUG
-            printf("MgServerRenderingService::RenderMapInternal() - Layers:%d  Selection Layers:%d\n", tempLayers.p? tempLayers->GetCount() : 0, selLayers.p? selLayers->GetCount() : 0);
-            #endif
-            if (selLayers.p && selLayers->GetCount() > 0)
-                // tell the renderer to override draw styles with the ones
-                // we use for selection
-                MgColor *selectionColor = options->GetSelectionColor();
-                if (selectionColor == NULL)
-                    dr->SetRenderSelectionMode(true);
-                else
-                    dr->SetRenderSelectionMode(true,
-                        selectionColor->GetRed() << 24 |
-                        selectionColor->GetGreen() << 16 |
-                        selectionColor->GetBlue() << 8 |
-                        selectionColor->GetAlpha());
-                SAFE_RELEASE(selectionColor);
-                // prepare a collection of temporary MgLayers which have the right
-                // FDO filters that will fetch only the selected features from FDO
-                Ptr<MgReadOnlyLayerCollection> modLayers = new MgReadOnlyLayerCollection();
-                Ptr<MgStringCollection> overrideFilters = new MgStringCollection();
-                for (int s=0; s<selLayers->GetCount(); s++)
-                    Ptr<MgLayerBase> selLayer = selLayers->GetItem(s);
-                    // generate a filter for the selected features
-                    Ptr<MgStringCollection> filters = selection->GenerateFilters(
-                    selLayer, selLayer->GetFeatureClassName(), m_renderSelectionBatchSize);
-                    INT32 numFilter = (NULL == filters)? 0 : filters->GetCount();
-                    for (INT32 i = 0; i < numFilter; ++i)
-                        overrideFilters->Add(filters->GetItem(i));
-                        modLayers->Add(selLayer);
-                    modLayers, overrideFilters, &ds, dr, dstCs, false, false, scale, (behavior & MgRenderingOptions::KeepSelection) != 0,false,pPRSResult);
-                // Set selection mode to false to avoid affecting following code
-                dr->SetRenderSelectionMode(false);
-                pPRSResult = pPRMResult->GetProfileRenderSelectionResult();
-                // Calculate the time spent on stylizing selected layers
-                double stylizeSelectionTime = MgTimerUtil::GetTime() - pPRSResult->GetRenderTime();
-                pPRSResult->SetRenderTime(stylizeSelectionTime);
+            RenderSelection(map, selection, tempLayers, options, &ds, dr, dstCs, scale, behavior, pPRMResult);
         if (renderWatermark && (behavior & MgRenderingOptions::RenderLayers) && map->GetWatermarkUsage() != 0)
-            // Rendering watermark only when:
-            //      1. rendering layers
-            //      2. not set renderWatermark to false (not render tile)
-            //      3. Map's watermark usage is not 0, which means watermark usage is WMS and / or Viewer.
-            WatermarkInstanceCollection watermarkInstances;   //Watermark list to render
-            WatermarkInstanceCollection tempWatermarkInstances;    //Used to reverse list
-            auto_ptr<WatermarkInstance> tempInstance;
-            // Get watermark instance in map
-            Ptr<MgResourceIdentifier> mapId = map->GetMapDefinition();
-            if (mapId.p)
-                auto_ptr<MapDefinition> mdef(MgMapBase::GetMapDefinition(m_svcResource, mapId));
-                WatermarkInstanceCollection* mapWatermarks = mdef->GetWatermarks();
-                for (int i=mapWatermarks->GetCount()-1; i>=0; i--)
-                    tempWatermarkInstances.Adopt(mapWatermarks->OrphanAt(i));
-                for (int i=tempWatermarkInstances.GetCount()-1; i>=0; i--)
-                    tempInstance.reset(tempWatermarkInstances.OrphanAt(i));
-                    if (!tempInstance.get())
-                        continue;
-                    if (((map->GetWatermarkUsage() & MgMap::Viewer) != 0
-                        && (tempInstance->GetUsage() & WatermarkInstance::Viewer) == 0)
-                        || ((map->GetWatermarkUsage() & MgMap::WMS) != 0
-                        && (tempInstance->GetUsage() & WatermarkInstance::WMS) == 0))
-                        continue;
-                    bool alreadyInList = false;
-                    for (int j=watermarkInstances.GetCount()-1; j >=0; j--)
-                        if (tempInstance->Equals(watermarkInstances.GetAt(j)))
-                            alreadyInList = true;
-                            break;
-                    if (!alreadyInList)
-                        watermarkInstances.Adopt(tempInstance.release());
-            // Get watermark instance in layer
-            const int layerCount = tempLayers->GetCount();
-            auto_ptr<LayerDefinition> ldf;
-            for (int i=0; i<layerCount; ++i)
-                Ptr<MgLayerBase> mapLayer(tempLayers->GetItem(i));
-                // the layer resource content should be set during stylization if visible
-                if (mapLayer->GetLayerResourceContent() == L"")
-                    continue;
-                ldf.reset(MgLayerBase::GetLayerDefinition(mapLayer->GetLayerResourceContent()));
-                WatermarkInstanceCollection* layerWatermarks = ldf->GetWatermarks();
-                for (int j=layerWatermarks->GetCount()-1; j>=0; j--)
-                    tempWatermarkInstances.Adopt(layerWatermarks->OrphanAt(j));
-                for (int j=tempWatermarkInstances.GetCount()-1; j>=0; j--)
-                    tempInstance.reset(tempWatermarkInstances.OrphanAt(j));
-                        continue;
-                        continue;
-                    for (int k=watermarkInstances.GetCount()-1; k>=0; k--)
-                        if (tempInstance->Equals(watermarkInstances.GetAt(k)))
-                            break;
-            assert(tempWatermarkInstances.GetCount() == 0);
-            MgStringCollection watermarkIds;            // ID list of loaded watermark definition
-            MgStringCollection watermarkDefinitions;    // Loaded watermark definition
-            MgStringCollection failLoadedIds;           // ID list of failed in loading resource
-            if(0 != watermarkInstances.GetCount())
-                ProfileRenderWatermarksResult* pPRWsResult = NULL; // pointer points to Profile Render Watermarks Result
-                    pPRWsResult = new ProfileRenderWatermarksResult();
-                    pPRMResult->AdoptProfileRenderWatermarksResult(pPRWsResult);
-                    // Set the start time of stylizing watermarks
-                    pPRWsResult->SetRenderTime(MgTimerUtil::GetTime());
-                for (int i=watermarkInstances.GetCount()-1; i>=0; i--)
-                    WatermarkInstance* instance = watermarkInstances.GetAt(i);
-                    STRING resourceId = instance->GetResourceId();
-                    WatermarkDefinition* wdef = NULL;
-                    MG_TRY()
-                        for(int j = 0; j < watermarkIds.GetCount(); j++)
-                            if(resourceId == watermarkIds.GetItem(j))
-                                wdef = MgWatermark::GetWatermarkDefinition(watermarkDefinitions.GetItem(j));
-                                break;
-                        if(NULL != pPRWsResult)
-                            ProfileRenderWatermarkResult* pPRWResult = new ProfileRenderWatermarkResult(); // pointer points to Render Watermark Result
-                            pPRWResult->SetRenderTime(MgTimerUtil::GetTime());
-                            ProfileRenderWatermarkResultCollection* pPRWResultColl = pPRWsResult->GetProfileRenderWatermarkResults();
-                            pPRWResultColl->Adopt(pPRWResult);
-                        if(wdef == NULL)
-                            Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resourceId);
-                            Ptr<MgByteReader> reader = m_svcResource->GetResourceContent(resId);
-                            STRING content = reader->ToString();
-                            watermarkIds.Add(resourceId);
-                            watermarkDefinitions.Add(content);
-                            wdef = MgWatermark::GetWatermarkDefinition(content);
-                        assert(wdef != NULL);
-                        if (instance->GetPositionOverride())
-                            wdef->AdoptPosition(instance->OrphanPositionOverride());
-                        if (instance->GetAppearanceOverride())
-                            wdef->AdoptAppearance(instance->OrphanAppearanceOverride());
-                        ds.StylizeWatermark(dr, wdef, drawWidth, drawHeight, saveWidth, saveHeight);
-                            ProfileRenderWatermarkResult* pPRWResult = pPRWResultColl->GetAt(pPRWResultColl->GetCount()-1); // TODO: check index
-                            // Calculate the time spent on stylizing watermark
-                            double stylizeWatermarkTime = MgTimerUtil::GetTime() - pPRWResult->GetRenderTime();
-                            pPRWResult->SetRenderTime(stylizeWatermarkTime);
-                            pPRWResult->SetResourceId(resourceId);
-                            WatermarkPosition* position = wdef->GetPosition();
-                            if(NULL != dynamic_cast<XYWatermarkPosition*>(position))
-                                pPRWResult->SetPositionType(L"XY");
-                            else // No other position types
-                                pPRWResult->SetPositionType(L"Tile");
-                    MG_CATCH(L"MgServerRenderingService.RenderMapInternal")
-                    if(mgException.p)
-                        // Do not do anything if fail in resource loading and has logged error.
-                        bool isExceptionLogged = false;
-                        if(wdef == NULL) // Fail in resource loading
-                            for(int i = 0; i < failLoadedIds.GetCount(); i++)
-                                if(resourceId == failLoadedIds.GetItem(i))
-                                    isExceptionLogged = true;
-                                    break;
-                        if(!isExceptionLogged)
-                            // TODO: Eventually this should be used to indicate visually to the client what
-                            //       layer failed in addition to logging the error.
-                            MgServerManager* serverManager = MgServerManager::GetInstance();
-                            STRING locale = (NULL == serverManager)? MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
-                            MG_LOG_EXCEPTION_ENTRY(mgException->GetExceptionMessage(locale).c_str(), mgException->GetStackTrace(locale).c_str());
-    #if defined(_DEBUG) || defined(_DEBUG_PNG8)
-                            STRING details = mgException->GetDetails(locale);
-                            wstring err = L"\n %t Error during stylization of watermark:";
-                            err += instance->GetName();
-                            err += L"\n";
-                            err += L"Details: ";
-                            err += details;
-                            err += L"\n";
-                            ACE_DEBUG( (LM_DEBUG, err.c_str()) );
-    #endif
-                            if(wdef == NULL)            // Failed in resource loading
-                                failLoadedIds.Add(resourceId);
-                    // Calculate the time spent on stylizing watermarks
-                    double stylizeRenderWatermarksTime = MgTimerUtil::GetTime() - pPRWsResult->GetRenderTime();
-                    pPRWsResult->SetRenderTime(stylizeRenderWatermarksTime);
+            RenderWatermarks(map,tempLayers,&ds, dr,drawWidth, drawHeight, saveWidth, saveHeight, pPRMResult);
+        if(NULL != dstCs)
+            pPRMResult->SetCoordinateSystem(dstCs->GetCsCode());
         ProfileRenderLabelsResult* pPRLablesResult = new ProfileRenderLabelsResult(); // pointer points to Render Labels Result
         // Set the start time of stylizing labels
@@ -1327,101 +1016,9 @@
     MG_THROW()  // to skip a faulty tile we need to rethrow the exception which could be thrown in StylizeLayers
-    // draw a border around the tile - used for debugging
-    RS_LineStroke ls;
-    ls.color() = RS_Color(128, 128, 128, 64);
-    LineBuffer lb(5);
-    double mcsMinX = b.minx;
-    double mcsMaxX = b.maxx;
-    double mcsMinY = b.miny;
-    double mcsMaxY = b.maxy;
-    double incX = (mcsMaxX - mcsMinX) / saveWidth  / 10.0;
-    double incY = (mcsMaxY - mcsMinY) / saveHeight / 10.0;
-    lb.MoveTo(mcsMinX + incX, mcsMinY + incY);
-    lb.LineTo(mcsMaxX - incX, mcsMinY + incY);
-    lb.LineTo(mcsMaxX - incX, mcsMaxY - incY);
-    lb.LineTo(mcsMinX + incX, mcsMaxY - incY);
-    lb.LineTo(mcsMinX + incX, mcsMinY + incY);
-    dr->ProcessPolyline(&lb, ls);
+    Ptr<MgByteReader> ret = CreateImage(map, dr, saveWidth, saveHeight, format, pPRMResult);
-        // Set the start time of creating map image
-        pPRMResult->SetCreateImageTime(MgTimerUtil::GetTime());
-    Ptr<MgByteReader> ret;
-    // get a byte representation of the image
-    auto_ptr<RS_ByteData> data;
-    try
-        // call the image renderer to create the image
-        if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
-            /// RFC60 code to correct colormaps by UV
-            // We examine the expressions collected from xml definitions of all layers.
-            // The map object has a list from all color entries found in the most recent
-            // layer stylization.
-            // * TODO - currently they are interpreted as ffffffff 32-bit RGBA string values
-            // * adding expresssions and other interpretations should be done in ParseColorStrings
-            // * the color Palette for the renderer is a vector<RS_Color>
-            if (hasColorMap(format))
-                RS_ColorVector tileColorPalette;
-                MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
-//              printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", tileColorPalette.size());
-                data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, &tileColorPalette));
-            else
-                data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, NULL));
-        else
-            data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
-    catch (exception e)
-        ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in RenderingService ColorPaletteGeneration\n", e.what()));
-        throw e;
-    if (NULL != data.get())
-        // put this into a byte source
-        Ptr<MgByteSource> bs = new MgByteSource(data->GetBytes(), data->GetNumBytes());
-        if (format == MgImageFormats::Gif)
-            bs->SetMimeType(MgMimeType::Gif);
-        else if (format == MgImageFormats::Jpeg)
-            bs->SetMimeType(MgMimeType::Jpeg);
-        else if (format == MgImageFormats::Png || format == MgImageFormats::Png8)
-            bs->SetMimeType(MgMimeType::Png);
-        else if (format == MgImageFormats::Tiff)
-            bs->SetMimeType(MgMimeType::Tiff);
-        ret = bs->GetReader();
-    else
-        throw new MgNullReferenceException(L"MgServerRenderingService.RenderMapInternal", __LINE__, __WFILE__, NULL, L"MgNoDataFromRenderer", NULL);
-        // Calculate the time spent on stylizing labels
-        double createImageTime = MgTimerUtil::GetTime() - pPRMResult->GetCreateImageTime();
-        pPRMResult->SetCreateImageTime(createImageTime);
-        pPRMResult->SetImageFormat(format);
-        pPRMResult->SetRendererType(m_rendererName);
     return ret.Detach();
@@ -1929,3 +1526,465 @@
     return renderer;
+inline void MgServerRenderingService::RenderLayers(MgMap* map,
+                                                   MgReadOnlyLayerCollection* layers,
+                                                   Stylizer* ds,
+                                                   Renderer* dr,
+                                                   MgCoordinateSystem* dstCs,
+                                                   bool expandExtents,
+                                                   double scale,
+                                                   CREFSTRING format,
+                                                   ProfileRenderMapResult* pPRMResult)
+    ProfileRenderLayersResult* pPRLsResult = NULL; // pointer points to Profile Render Layers Result
+    if(NULL != pPRMResult)
+        pPRLsResult = new ProfileRenderLayersResult();
+        pPRMResult->AdoptProfileRenderLayersResult(pPRLsResult);
+        // Set the start time of stylizing layers
+        pPRLsResult->SetRenderTime(MgTimerUtil::GetTime());
+    MgMappingUtil::StylizeLayers(m_svcResource, m_svcFeature, m_svcDrawing, m_pCSFactory, map,
+                                    layers, NULL, ds, dr, dstCs, expandExtents, false, scale,
+                                    false, hasColorMap(format), pPRLsResult);
+        pPRLsResult = pPRMResult->GetProfileRenderLayersResult();
+        // Calculate the time spent on stylizing layers
+        double stylizeLayersTime = MgTimerUtil::GetTime() - pPRLsResult->GetRenderTime();
+        pPRLsResult->SetRenderTime(stylizeLayersTime);
+inline void MgServerRenderingService::RenderSelection(MgMap* map,
+                                                      MgSelection* selection,
+                                                      MgRenderingOptions* options,
+                                                      Stylizer* ds,
+                                                      Renderer* dr,
+                                                      double scale,
+                                                      INT32 behavior,
+    SE_Renderer* renderer = dynamic_cast<SE_Renderer*>(dr);
+    ProfileRenderSelectionResult* pPRSResult = NULL; // pointer points to Profile Render Selection Result
+        pPRSResult = new ProfileRenderSelectionResult();
+        pPRMResult->AdoptProfileRenderSelectionResult(pPRSResult);
+        // Set the start time of stylizing selected layers
+        pPRSResult->SetRenderTime(MgTimerUtil::GetTime());
+    Ptr<MgReadOnlyLayerCollection> selLayers = selection->GetLayers();
+    #ifdef _DEBUG
+    printf("MgServerRenderingService::RenderSelection() - Layers:%d  Selection Layers:%d\n", layers? layers->GetCount() : 0, selLayers.p? selLayers->GetCount() : 0);
+    #endif
+    if (selLayers.p && selLayers->GetCount() > 0)
+        // tell the renderer to override draw styles with the ones
+        // we use for selection
+        MgColor *selectionColor = options->GetSelectionColor();
+        if (selectionColor == NULL)
+            renderer->SetRenderSelectionMode(true);
+        else
+            renderer->SetRenderSelectionMode(true,
+                selectionColor->GetRed() << 24 |
+                selectionColor->GetGreen() << 16 |
+                selectionColor->GetBlue() << 8 |
+                selectionColor->GetAlpha());
+        SAFE_RELEASE(selectionColor);
+        // prepare a collection of temporary MgLayers which have the right
+        // FDO filters that will fetch only the selected features from FDO
+        Ptr<MgReadOnlyLayerCollection> modLayers = new MgReadOnlyLayerCollection();
+        Ptr<MgStringCollection> overrideFilters = new MgStringCollection();
+        for (int s=0; s<selLayers->GetCount(); s++)
+            Ptr<MgLayerBase> selLayer = selLayers->GetItem(s);
+            // generate a filter for the selected features
+            Ptr<MgStringCollection> filters = selection->GenerateFilters(
+            selLayer, selLayer->GetFeatureClassName(), m_renderSelectionBatchSize);
+            INT32 numFilter = (NULL == filters)? 0 : filters->GetCount();
+            for (INT32 i = 0; i < numFilter; ++i)
+                overrideFilters->Add(filters->GetItem(i));
+                modLayers->Add(selLayer);
+            modLayers, overrideFilters, ds, renderer, dstCs, false, false, scale, (behavior & MgRenderingOptions::KeepSelection) != 0,false,pPRSResult);
+        // Set selection mode to false to avoid affecting following code
+        renderer->SetRenderSelectionMode(false);
+        pPRSResult = pPRMResult->GetProfileRenderSelectionResult();
+        // Calculate the time spent on stylizing selected layers
+        double stylizeSelectionTime = MgTimerUtil::GetTime() - pPRSResult->GetRenderTime();
+        pPRSResult->SetRenderTime(stylizeSelectionTime);
+inline void MgServerRenderingService::RenderWatermarks(MgMap* map,
+                                                       Stylizer* ds,
+                                                       Renderer* dr,
+                                                       int drawWidth,
+                                                       int drawHeight,
+                                                       INT32 saveWidth,
+                                                       INT32 saveHeight,
+    // Rendering watermark only when:
+    // 1. rendering layers
+    // 2. not set renderWatermark to false (not render tile)
+    // 3. Map's watermark usage is not 0, which means watermark usage is WMS and / or Viewer.
+    WatermarkInstanceCollection watermarkInstances;   //Watermark list to render
+    WatermarkInstanceCollection tempWatermarkInstances;    //Used to reverse list
+    auto_ptr<WatermarkInstance> tempInstance;
+    // Get watermark instance in map
+    Ptr<MgResourceIdentifier> mapId = map->GetMapDefinition();
+    if (mapId.p)
+        auto_ptr<MapDefinition> mdef(MgMapBase::GetMapDefinition(m_svcResource, mapId));
+        WatermarkInstanceCollection* mapWatermarks = mdef->GetWatermarks();
+        for (int i=mapWatermarks->GetCount()-1; i>=0; i--)
+            tempWatermarkInstances.Adopt(mapWatermarks->OrphanAt(i));
+        for (int i=tempWatermarkInstances.GetCount()-1; i>=0; i--)
+            tempInstance.reset(tempWatermarkInstances.OrphanAt(i));
+            if (!tempInstance.get())
+                continue;
+            if (((map->GetWatermarkUsage() & MgMap::Viewer) != 0
+                && (tempInstance->GetUsage() & WatermarkInstance::Viewer) == 0)
+                || ((map->GetWatermarkUsage() & MgMap::WMS) != 0
+                && (tempInstance->GetUsage() & WatermarkInstance::WMS) == 0))
+                continue;
+            bool alreadyInList = false;
+            for (int j=watermarkInstances.GetCount()-1; j >=0; j--)
+                if (tempInstance->Equals(watermarkInstances.GetAt(j)))
+                    alreadyInList = true;
+                    break;
+            if (!alreadyInList)
+                watermarkInstances.Adopt(tempInstance.release());
+    // Get watermark instance in layer
+    const int layerCount = layers->GetCount();
+    auto_ptr<LayerDefinition> ldf;
+    for (int i=0; i<layerCount; ++i)
+        Ptr<MgLayerBase> mapLayer(layers->GetItem(i));
+        // the layer resource content should be set during stylization if visible
+        if (mapLayer->GetLayerResourceContent() == L"")
+            continue;
+        ldf.reset(MgLayerBase::GetLayerDefinition(mapLayer->GetLayerResourceContent()));
+        WatermarkInstanceCollection* layerWatermarks = ldf->GetWatermarks();
+        for (int j=layerWatermarks->GetCount()-1; j>=0; j--)
+            tempWatermarkInstances.Adopt(layerWatermarks->OrphanAt(j));
+        for (int j=tempWatermarkInstances.GetCount()-1; j>=0; j--)
+            tempInstance.reset(tempWatermarkInstances.OrphanAt(j));
+                continue;
+                continue;
+            for (int k=watermarkInstances.GetCount()-1; k>=0; k--)
+                if (tempInstance->Equals(watermarkInstances.GetAt(k)))
+                    break;
+    assert(tempWatermarkInstances.GetCount() == 0);
+    MgStringCollection watermarkIds;            // ID list of loaded watermark definition
+    MgStringCollection watermarkDefinitions;    // Loaded watermark definition
+    MgStringCollection failLoadedIds;           // ID list of failed in loading resource
+    if(0 != watermarkInstances.GetCount())
+        ProfileRenderWatermarksResult* pPRWsResult = NULL; // pointer points to Profile Render Watermarks Result
+            pPRWsResult = new ProfileRenderWatermarksResult();
+            pPRMResult->AdoptProfileRenderWatermarksResult(pPRWsResult);
+            // Set the start time of stylizing watermarks
+            pPRWsResult->SetRenderTime(MgTimerUtil::GetTime());
+        for (int i=watermarkInstances.GetCount()-1; i>=0; i--)
+            WatermarkInstance* instance = watermarkInstances.GetAt(i);
+            STRING resourceId = instance->GetResourceId();
+            WatermarkDefinition* wdef = NULL;
+            MG_TRY()
+                for(int j = 0; j < watermarkIds.GetCount(); j++)
+                    if(resourceId == watermarkIds.GetItem(j))
+                        wdef = MgWatermark::GetWatermarkDefinition(watermarkDefinitions.GetItem(j));
+                        break;
+                if(NULL != pPRWsResult)
+                    ProfileRenderWatermarkResult* pPRWResult = new ProfileRenderWatermarkResult(); // pointer points to Render Watermark Result
+                    pPRWResult->SetRenderTime(MgTimerUtil::GetTime());
+                    ProfileRenderWatermarkResultCollection* pPRWResultColl = pPRWsResult->GetProfileRenderWatermarkResults();
+                    pPRWResultColl->Adopt(pPRWResult);
+                if(wdef == NULL)
+                    Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resourceId);
+                    Ptr<MgByteReader> reader = m_svcResource->GetResourceContent(resId);
+                    STRING content = reader->ToString();
+                    watermarkIds.Add(resourceId);
+                    watermarkDefinitions.Add(content);
+                    wdef = MgWatermark::GetWatermarkDefinition(content);
+                assert(wdef != NULL);
+                if (instance->GetPositionOverride())
+                    wdef->AdoptPosition(instance->OrphanPositionOverride());
+                if (instance->GetAppearanceOverride())
+                    wdef->AdoptAppearance(instance->OrphanAppearanceOverride());
+                ds->StylizeWatermark(dr, wdef, drawWidth, drawHeight, saveWidth, saveHeight);
+                    ProfileRenderWatermarkResult* pPRWResult = pPRWResultColl->GetAt(pPRWResultColl->GetCount()-1); // TODO: check index
+                    // Calculate the time spent on stylizing watermark
+                    double stylizeWatermarkTime = MgTimerUtil::GetTime() - pPRWResult->GetRenderTime();
+                    pPRWResult->SetRenderTime(stylizeWatermarkTime);
+                    pPRWResult->SetResourceId(resourceId);
+                    WatermarkPosition* position = wdef->GetPosition();
+                    if(NULL != dynamic_cast<XYWatermarkPosition*>(position))
+                        pPRWResult->SetPositionType(L"XY");
+                    else // No other position types
+                        pPRWResult->SetPositionType(L"Tile");
+            MG_CATCH(L"MgServerRenderingService.RenderWatermarks")
+            if(mgException.p)
+                // Do not do anything if fail in resource loading and has logged error.
+                bool isExceptionLogged = false;
+                if(wdef == NULL) // Fail in resource loading
+                    for(int i = 0; i < failLoadedIds.GetCount(); i++)
+                        if(resourceId == failLoadedIds.GetItem(i))
+                            isExceptionLogged = true;
+                            break;
+                if(!isExceptionLogged)
+                    // TODO: Eventually this should be used to indicate visually to the client what
+                    //       layer failed in addition to logging the error.
+                    MgServerManager* serverManager = MgServerManager::GetInstance();
+                    STRING locale = (NULL == serverManager)? MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
+                    MG_LOG_EXCEPTION_ENTRY(mgException->GetExceptionMessage(locale).c_str(), mgException->GetStackTrace(locale).c_str());
+#if defined(_DEBUG) || defined(_DEBUG_PNG8)
+                    STRING details = mgException->GetDetails(locale);
+                    wstring err = L"\n %t Error during stylization of watermark:";
+                    err += instance->GetName();
+                    err += L"\n";
+                    err += L"Details: ";
+                    err += details;
+                    err += L"\n";
+                    ACE_DEBUG( (LM_DEBUG, err.c_str()) );
+#endif
+                    if(wdef == NULL)            // Failed in resource loading
+                        failLoadedIds.Add(resourceId);
+            // Calculate the time spent on stylizing watermarks
+            double stylizeRenderWatermarksTime = MgTimerUtil::GetTime() - pPRWsResult->GetRenderTime();
+            pPRWsResult->SetRenderTime(stylizeRenderWatermarksTime);
+inline MgByteReader* MgServerRenderingService::CreateImage(MgMap* map,
+                                                           Renderer* dr,
+                                                           INT32 saveWidth,
+                                                           INT32 saveHeight,
+        // Set the start time of creating map image
+        pPRMResult->SetCreateImageTime(MgTimerUtil::GetTime());
+    // draw a border around the tile - used for debugging
+    RS_LineStroke ls;
+    ls.color() = RS_Color(128, 128, 128, 64);
+    LineBuffer lb(5);
+    double mcsMinX = b.minx;
+    double mcsMaxX = b.maxx;
+    double mcsMinY = b.miny;
+    double mcsMaxY = b.maxy;
+    double incX = (mcsMaxX - mcsMinX) / saveWidth  / 10.0;
+    double incY = (mcsMaxY - mcsMinY) / saveHeight / 10.0;
+    lb.MoveTo(mcsMinX + incX, mcsMinY + incY);
+    lb.LineTo(mcsMaxX - incX, mcsMinY + incY);
+    lb.LineTo(mcsMaxX - incX, mcsMaxY - incY);
+    lb.LineTo(mcsMinX + incX, mcsMaxY - incY);
+    lb.LineTo(mcsMinX + incX, mcsMinY + incY);
+    dr->ProcessPolyline(&lb, ls);
+    // get a byte representation of the image
+    auto_ptr<RS_ByteData> data;
+    Ptr<MgByteSource> bs;
+    try
+        // call the image renderer to create the image
+        if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
+            /// RFC60 code to correct colormaps by UV
+            // We examine the expressions collected from xml definitions of all layers.
+            // The map object has a list from all color entries found in the most recent
+            // layer stylization.
+            // * TODO - currently they are interpreted as ffffffff 32-bit RGBA string values
+            // * adding expresssions and other interpretations should be done in ParseColorStrings
+            // * the color Palette for the renderer is a vector<RS_Color>
+            if (hasColorMap(format))
+                RS_ColorVector tileColorPalette;
+                MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
+//              printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", tileColorPalette.size());
+                data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, &tileColorPalette));
+            else
+                data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, NULL));
+        else
+            data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
+    catch (exception e)
+        ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in RenderingService ColorPaletteGeneration\n", e.what()));
+        throw e;
+    if (NULL != data.get())
+        // put this into a byte source
+        bs = new MgByteSource(data->GetBytes(), data->GetNumBytes());
+        if (format == MgImageFormats::Gif)
+            bs->SetMimeType(MgMimeType::Gif);
+        else if (format == MgImageFormats::Jpeg)
+            bs->SetMimeType(MgMimeType::Jpeg);
+        else if (format == MgImageFormats::Png || format == MgImageFormats::Png8)
+            bs->SetMimeType(MgMimeType::Png);
+        else if (format == MgImageFormats::Tiff)
+            bs->SetMimeType(MgMimeType::Tiff);
+    else
+        throw new MgNullReferenceException(L"MgServerRenderingService.CreateImage", __LINE__, __WFILE__, NULL, L"MgNoDataFromRenderer", NULL);
+        // Calculate the time spent on stylizing labels
+        double createImageTime = MgTimerUtil::GetTime() - pPRMResult->GetCreateImageTime();
+        pPRMResult->SetCreateImageTime(createImageTime);
+        pPRMResult->SetImageFormat(format);
+        pPRMResult->SetRendererType(m_rendererName);
+    return bs->GetReader();
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h	2011-09-21 15:40:59 UTC (rev 6143)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h	2011-09-22 01:57:08 UTC (rev 6144)
@@ -23,6 +23,7 @@
 class SE_Renderer;
 class FeatureInfoRenderer;
 class MgFeatureInformation;
+class Stylizer;
 namespace MdfModel
@@ -234,6 +235,44 @@
                                 bool localOverposting = false,
                                 double tileExtentOffset = 0.0);
+    void RenderLayers(MgMap* map,
+                      Stylizer* ds,
+                      Renderer* dr,
+                      double scale,
+                      ProfileRenderMapResult* pPRMResult);
+    void RenderSelection(MgMap* map,
+                         Stylizer* ds,
+                         Renderer* dr,
+                         double scale,
+                         INT32 behavior,
+    void RenderWatermarks(MgMap* map,
+                          Stylizer* ds,
+                          Renderer* dr,
+                          int drawWidth,
+                          int drawHeight,
+                          INT32 saveWidth,
+                          INT32 saveHeight,
+    MgByteReader* CreateImage(MgMap* map,
+                              Renderer* dr,
+                              INT32 saveWidth,
+                              INT32 saveHeight,
     // member data
     Ptr<MgFeatureService> m_svcFeature;
     Ptr<MgResourceService> m_svcResource;
More information about the mapguide-commits mailing list
