[mapguide-commits] r6952 - branches/2.4/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Fri Aug 24 01:39:07 PDT 2012
Author: jng
Date: 2012-08-24 01:39:06 -0700 (Fri, 24 Aug 2012)
New Revision: 6952
branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj
branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
#2096: Fix layer icon display for layers with various scale ranges and DWF/Raster-based layers
Modified: branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj
--- branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-08-23 15:58:33 UTC (rev 6951)
+++ branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-08-24 08:39:06 UTC (rev 6952)
@@ -29,7 +29,8 @@
<DebugType>pdbonly</DebugType>
<Optimize>true</Optimize>
<OutputPath>bin\Release\</OutputPath>
- <DefineConstants>TRACE</DefineConstants>
+ <DefineConstants>
+ </DefineConstants>
<ErrorReport>prompt</ErrorReport>
<WarningLevel>4</WarningLevel>
<DocumentationFile>bin\Release\OSGeo.MapGuide.Viewer.XML</DocumentationFile>
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-08-23 15:58:33 UTC (rev 6951)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-08-24 08:39:06 UTC (rev 6952)
@@ -152,46 +152,7 @@
String[] typeStyles = new String[] { "PointTypeStyle", "LineTypeStyle", "AreaTypeStyle", "CompositeTypeStyle" };
String[] ruleNames = new String[] { "PointRule", "LineRule", "AreaRule", "CompositeRule" };
- try
- if (layerMeta.Icon == null)
- MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
- _map.ViewScale,
- 16,
- 16,
- "PNG",
- -1,
- -1);
- legendCallCount++;
- if (layerIcon != null)
- try
- byte[] b = new byte[layerIcon.GetLength()];
- layerIcon.Read(b, b.Length);
- using (var ms = new MemoryStream(b))
- layerMeta.Icon = Image.FromStream(ms);
- node.ToolTipText = string.Format(Properties.Resources.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
- finally
- layerIcon.Dispose();
- else
- layerMeta.Icon = Properties.Resources.lc_broken;
- catch
+ node.ToolTipText = string.Format(Properties.Resources.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
if (!layerMeta.HasTheme())
for (int sc = 0; sc < scaleRanges.Count; sc++)
@@ -232,7 +193,7 @@
XmlNodeList rules = ((XmlElement)typeStyle[st]).GetElementsByTagName(ruleNames[geomType]);
if (rules.Count > 1)
- layerMeta.Icon = Properties.Resources.lc_theme;
+ layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_theme);
node.ToolTipText = string.Format(Properties.Resources.ThemedLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName, rules.Count);
if (_legend.ThemeCompressionLimit > 0 && rules.Count > _legend.ThemeCompressionLimit)
@@ -249,6 +210,45 @@
+ else
+ try
+ MgByteReader layerIcon = _provider.GenerateLegendImage(layer.LayerDefinition,
+ _map.ViewScale,
+ 16,
+ 16,
+ "PNG",
+ -1,
+ -1);
+ legendCallCount++;
+ if (layerIcon != null)
+ try
+ byte[] b = new byte[layerIcon.GetLength()];
+ layerIcon.Read(b, b.Length);
+ using (var ms = new MemoryStream(b))
+ layerMeta.SetDefaultIcon(themeCat, Image.FromStream(ms));
+ finally
+ layerIcon.Dispose();
+ else
+ layerMeta.SetDefaultIcon(themeCat, Properties.Resources.lc_broken);
+ catch
@@ -555,6 +555,7 @@
internal void DrawNode(DrawTreeNodeEventArgs e, bool showPlusMinus, Font font)
+ var currentScale = _map.ViewScale;
if (!e.Bounds.IsEmpty && (IsLayerNode(e.Node) || IsThemeLayerNode(e.Node)))
Color backColor, foreColor;
@@ -652,16 +653,30 @@
e.Graphics.DrawImage(icon, e.Node.Bounds.X + selectabilityOffset, e.Node.Bounds.Y);
//Trace.TraceInformation("Painted icon at ({0},{1})", e.Node.Bounds.X, e.Node.Bounds.Y);
- if (layerMeta.Icon != null)
+ Image layerIcon = null;
+ if (layerMeta.IsRaster)
+ layerIcon = Properties.Resources.lc_raster;
+ else if (layerMeta.IsDwf)
+ layerIcon = Properties.Resources.lc_dwf;
+ else
+ layerIcon = layerMeta.GetDefaultIcon(currentScale);
if (layerMeta.DrawSelectabilityIcon)
- e.Graphics.DrawImage(layerMeta.Icon, e.Node.Bounds.X + iconOffset, e.Node.Bounds.Y);
+ e.Graphics.DrawImage(layerIcon, e.Node.Bounds.X + iconOffset, e.Node.Bounds.Y);
else
- e.Graphics.DrawImage(layerMeta.Icon, e.Node.Bounds.X + iconOffsetNoSelect, e.Node.Bounds.Y);
+ e.Graphics.DrawImage(layerIcon, e.Node.Bounds.X + iconOffsetNoSelect, e.Node.Bounds.Y);
@@ -815,6 +830,17 @@
return hash;
+ public override bool Equals(object obj)
+ var cat = obj as ThemeCategory;
+ if (cat == null)
+ return false;
+ return this.MaxScale == cat.MaxScale &&
+ this.MinScale == cat.MinScale &&
+ this.GeometryType == cat.GeometryType;
[DebuggerDisplay("Name = {Layer.Name}, Label = {Layer.LegendLabel}")]
@@ -829,6 +855,7 @@
this.WasInitiallySelectable = bInitiallySelectable;
this.LayerDefinitionContent = null;
_themeNodes = new Dictionary<ThemeCategory, List<LayerThemeNodeMetadata>>();
+ _defaultIcons = new Dictionary<ThemeCategory, Image>();
public override string ObjectId
@@ -836,10 +863,63 @@
get { return this.Layer.GetObjectId(); }
- public Image Icon { get; set; }
+ private bool? _isRaster;
- public string IconId { get; set; }
+ public bool IsRaster
+ get
+ if (_isRaster.HasValue)
+ return _isRaster.Value;
+ if (!string.IsNullOrEmpty(this.LayerDefinitionContent))
+ _isRaster = this.LayerDefinitionContent.Contains("<GridLayerDefinition");
+ throw new Exception("Layer metadata not fully initialized"); //Shouldn't get to here
+ private bool? _isDwf;
+ public bool IsDwf
+ get
+ if (_isDwf.HasValue)
+ _isDwf = this.LayerDefinitionContent.Contains("<DrawingLayerDefinition");
+ private Dictionary<ThemeCategory, Image> _defaultIcons;
+ public void SetDefaultIcon(ThemeCategory cat, Image image)
+ _defaultIcons[cat] = image;
+ public Image GetDefaultIcon(double scale)
+ foreach (var cat in _defaultIcons.Keys)
+ if (ScaleIsApplicable(scale, cat))
+ return _defaultIcons[cat];
+ return null;
+ //public Image Icon { get; set; }
internal MgLayerBase Layer { get; private set; }
public bool DrawSelectabilityIcon { get; set; }
@@ -871,7 +951,7 @@
internal bool HasTheme()
- if (_themeNodes.Count == 0)
+ if (_themeNodes.Count == 0 || _defaultIcons.Count == 0)
return false;
foreach (var coll in _themeNodes.Values)
@@ -888,48 +968,54 @@
//Find the applicable scale range(s)
foreach (var cat in _themeNodes.Keys)
- bool bApplicable = false;
+ bool bApplicable = ScaleIsApplicable(scale, cat);
- bool bHasMin = !string.IsNullOrEmpty(cat.MinScale);
- bool bHasMax = !string.IsNullOrEmpty(cat.MaxScale);
+ if (bApplicable)
+ var metadata = _themeNodes[cat];
+ nodes.AddRange(CreateThemeNodes(metadata));
- if (bHasMin)
+ return nodes.ToArray();
+ private static bool ScaleIsApplicable(double scale, ThemeCategory cat)
+ bool bApplicable = false;
+ bool bHasMin = !string.IsNullOrEmpty(cat.MinScale);
+ bool bHasMax = !string.IsNullOrEmpty(cat.MaxScale);
+ if (bHasMin)
+ double minVal = double.Parse(cat.MinScale);
+ if (bHasMax) //bHasMin = true, bHasMax = true
- double minVal = double.Parse(cat.MinScale);
- if (bHasMax) //bHasMin = true, bHasMax = true
- double maxVal = double.Parse(cat.MaxScale);
- if (scale >= minVal && scale < maxVal)
- bApplicable = true;
- else //bHasMin = true, bHasMax = false
- if (scale >= minVal)
+ double maxVal = double.Parse(cat.MaxScale);
+ if (scale >= minVal && scale < maxVal)
+ bApplicable = true;
- else
+ else //bHasMin = true, bHasMax = false
- if (bHasMax) //bHasMin = false, bHasMax = true
- if (scale < maxVal)
- else //bHasMin = false, bHasMax = false
+ if (scale >= minVal)
bApplicable = true;
- if (bApplicable)
+ else
+ if (bHasMax) //bHasMin = false, bHasMax = true
- var metadata = _themeNodes[cat];
- nodes.AddRange(CreateThemeNodes(metadata));
+ if (scale < maxVal)
+ else //bHasMin = false, bHasMax = false
- return nodes.ToArray();
+ return bApplicable;
private IEnumerable<TreeNode> CreateThemeNodes(List<LayerThemeNodeMetadata> metadata)
More information about the mapguide-commits
