[mapguide-commits] r6953 - branches/2.4/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Sun Aug 26 19:55:21 PDT 2012
Author: jng
Date: 2012-08-26 19:55:21 -0700 (Sun, 26 Aug 2012)
New Revision: 6953
branches/2.4/MgDev/Desktop/MapViewer/MgLegend.Designer.cs
branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs
branches/2.4/MgDev/Desktop/MapViewer/MgLegend.resx
branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
#2096: mg-desktop - Legend updates
- Create the required TreeNode objects (and the required LayerDefinition loading, icon caching) on a background worker
- Attach relevant layer/group context menus on background worker completion.
- Fix extra GenerateLegendImage calls due to incorrect cache checking logic.
- Add new IsBusy property that indicates whether the MgLegend is currently refreshing itself.
- Implement INotifyPropertyChanged for MgLegend. Broadcast property changes for the following properties:
- IsBusy
- ThemeCompressionLimit
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegend.Designer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegend.Designer.cs 2012-08-24 08:39:06 UTC (rev 6952)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegend.Designer.cs 2012-08-27 02:55:21 UTC (rev 6953)
@@ -31,6 +31,7 @@
this.components = new System.ComponentModel.Container();
this.trvLegend = new System.Windows.Forms.TreeView();
this.imgLegend = new System.Windows.Forms.ImageList(this.components);
+ this.bgLegendUpdate = new System.ComponentModel.BackgroundWorker();
this.SuspendLayout();
// trvLegend
@@ -59,6 +60,11 @@
this.imgLegend.ImageSize = new System.Drawing.Size(16, 16);
this.imgLegend.TransparentColor = System.Drawing.Color.Transparent;
+ // bgLegendUpdate
+ this.bgLegendUpdate.DoWork += new System.ComponentModel.DoWorkEventHandler(this.bgLegendUpdate_DoWork);
+ this.bgLegendUpdate.RunWorkerCompleted += new System.ComponentModel.RunWorkerCompletedEventHandler(this.bgLegendUpdate_RunWorkerCompleted);
// MgLegend
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
@@ -73,5 +79,6 @@
private System.Windows.Forms.TreeView trvLegend;
private System.Windows.Forms.ImageList imgLegend;
+ private System.ComponentModel.BackgroundWorker bgLegendUpdate;
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs 2012-08-24 08:39:06 UTC (rev 6952)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs 2012-08-27 02:55:21 UTC (rev 6953)
@@ -18,7 +18,7 @@
/// <summary>
/// A control that displays and controls visibility of layers in a runtime map
/// </summary>
- public partial class MgLegend : UserControl, IMapLegend, ILegendView
+ public partial class MgLegend : UserControl, IMapLegend, ILegendView, INotifyPropertyChanged
// TODO:
@@ -55,6 +55,8 @@
RefreshLegend();
+ private Stopwatch _legendUpdateStopwatch = new Stopwatch();
/// <summary>
/// Refreshes this component
/// </summary>
@@ -66,22 +68,80 @@
if (_presenter == null)
return;
+ if (IsBusy)
+ return;
ResetTreeView();
trvLegend.BeginUpdate();
+ _legendUpdateStopwatch.Start();
+ this.IsBusy = true;
+ bgLegendUpdate.RunWorkerAsync();
+ //Synchronous version
try
- var sw = new Stopwatch();
- sw.Start();
trvLegend.Nodes.AddRange(_presenter.CreateNodes());
- sw.Stop();
- Trace.TraceInformation("RefreshLegend: Completed in {0}ms", sw.ElapsedMilliseconds);
finally
trvLegend.EndUpdate();
+ private bool _busy = false;
+ [Browsable(false)]
+ public bool IsBusy
+ get { return _busy; }
+ private set
+ if (_busy.Equals(value))
+ return;
+ _busy = value;
+ Trace.TraceInformation("Legend IsBusy: {0}", this.IsBusy);
+ OnPropertyChanged("IsBusy");
+ private void bgLegendUpdate_DoWork(object sender, DoWorkEventArgs e)
+ e.Result = _presenter.CreateNodes();
+ private void bgLegendUpdate_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
+ this.IsBusy = bgLegendUpdate.IsBusy;
+ var nodes = e.Result as TreeNode[];
+ if (nodes != null)
+ //Attach relevant context menus based on attached metadata
+ foreach (var n in nodes)
+ var lm = n.Tag as LegendNodeMetadata;
+ if (lm != null)
+ if (lm.IsGroup)
+ n.ContextMenuStrip = this.GroupContextMenu;
+ else
+ var lyrm = n.Tag as LayerNodeMetadata;
+ if (lyrm != null)
+ n.ContextMenuStrip = this.LayerContextMenu;
+ trvLegend.Nodes.AddRange(nodes);
+ trvLegend.EndUpdate();
+ _legendUpdateStopwatch.Stop();
+ Trace.TraceInformation("RefreshLegend: Completed in {0}ms", _legendUpdateStopwatch.ElapsedMilliseconds);
+ _legendUpdateStopwatch.Reset();
private static void ClearNodes(TreeNodeCollection nodes)
foreach (TreeNode node in nodes)
@@ -270,7 +330,14 @@
public int ThemeCompressionLimit
get { return _themeCompressionLimit; }
- set { _themeCompressionLimit = value; }
+ set
+ if (value != _themeCompressionLimit)
+ return;
+ _themeCompressionLimit = value;
+ OnPropertyChanged("ThemeCompressionLimit");
private void OnLayerContextMenuOpening(object sender, CancelEventArgs e)
@@ -344,7 +411,23 @@
public bool ShowTooltips
get { return trvLegend.ShowNodeToolTips; }
- set { trvLegend.ShowNodeToolTips = value; }
+ set
+ if (value != trvLegend.ShowNodeToolTips)
+ return;
+ trvLegend.ShowNodeToolTips = value;
+ OnPropertyChanged("ShowTooltips");
+ public event PropertyChangedEventHandler PropertyChanged;
+ private void OnPropertyChanged(string propertyName)
+ var h = this.PropertyChanged;
+ if (h != null)
+ h(this, new PropertyChangedEventArgs(propertyName));
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegend.resx
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegend.resx 2012-08-24 08:39:06 UTC (rev 6952)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegend.resx 2012-08-27 02:55:21 UTC (rev 6953)
@@ -120,7 +120,7 @@
<metadata name="imgLegend.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
- <metadata name="legendUpdateWorker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="bgLegendUpdate.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>130, 17</value>
</metadata>
</root>
\ No newline at end of file
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-08-24 08:39:06 UTC (rev 6952)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2012-08-27 02:55:21 UTC (rev 6953)
@@ -10,12 +10,12 @@
using Legend.Model;
using System.Xml;
using System.IO;
-using System.Diagnostics;
+ using System.Diagnostics;
interface ILegendView
- ContextMenuStrip LayerContextMenu { get; }
- ContextMenuStrip GroupContextMenu { get; }
+ //ContextMenuStrip LayerContextMenu { get; }
+ //ContextMenuStrip GroupContextMenu { get; }
void AddLegendIcon(string id, Image icon);
int ThemeCompressionLimit { get; }
void OnRequestRefresh();
@@ -92,7 +92,7 @@
node.Name = layer.GetObjectId();
node.Text = layer.GetLegendLabel();
node.Checked = layer.GetVisible();
- node.ContextMenuStrip = _legend.LayerContextMenu;
+ //node.ContextMenuStrip = _legend.LayerContextMenu;
var lt = layer.GetLayerType();
var fsId = layer.GetFeatureSourceId();
@@ -153,7 +153,7 @@
String[] ruleNames = new String[] { "PointRule", "LineRule", "AreaRule", "CompositeRule" };
node.ToolTipText = string.Format(Properties.Resources.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId, layer.FeatureClassName);
- if (!layerMeta.HasTheme())
+ if (!layerMeta.HasTheme() || !layerMeta.HasDefaultIcons())
for (int sc = 0; sc < scaleRanges.Count; sc++)
@@ -210,7 +210,7 @@
- else
+ else if (!layerMeta.HasDefaultIconsAt(_map.ViewScale))
try
@@ -336,7 +336,7 @@
var meta = new GroupNodeMetadata(group);
node.Tag = meta;
_groups[group.GetObjectId()] = meta;
- node.ContextMenuStrip = _legend.GroupContextMenu;
+ //node.ContextMenuStrip = _legend.GroupContextMenu;
return node;
@@ -949,9 +949,14 @@
_themeNodes[category].Add(themeMeta);
+ internal bool HasDefaultIcons()
+ return (_defaultIcons.Count > 0);
internal bool HasTheme()
- if (_themeNodes.Count == 0 || _defaultIcons.Count == 0)
+ if (_themeNodes.Count == 0)
return false;
foreach (var coll in _themeNodes.Values)
@@ -1028,6 +1033,16 @@
yield return node;
+ internal bool HasDefaultIconsAt(double scale)
+ foreach (var cat in _defaultIcons.Keys)
+ if (ScaleIsApplicable(scale, cat))
+ return true;
+ return false;
More information about the mapguide-commits
