[mapguide-commits] r7249 -	trunk/MgDev/Common/Geometry/CoordinateSystem
    svn_mapguide at osgeo.org
    Sat Dec  8 06:46:23 PST 2012
Author: jng
Date: 2012-12-08 06:46:22 -0800 (Sat, 08 Dec 2012)
New Revision: 7249
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h
#2097: More API commentary for MgGeometry.
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -652,7 +652,7 @@
     /// \brief
-    /// Gets the projection code of this coordinate system
+    /// Gets the projection code of this coordinate system (see MgCoordinateSystemProjectionCode)
     /// \return
     /// The projection code of this coordinate system
@@ -664,7 +664,7 @@
     /// Sets the projection code for this coordinate system
     /// \param prjType (int)
-    /// The projection code
+    /// The projection code (see MgCoordinateSystemProjectionCode)
     virtual void SetProjectionCode(INT32  prjType)=0;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -22,14 +22,71 @@
 class MgCoordinateSystemDatum;
 class MgCoordinateSystemEllipsoid;
+/// \brief
+/// A mathematical comparator used to detemerine equality between
+/// two different coordinate systems, datums or ellipsoids
 class MgCoordinateSystemMathComparator : public MgGuardDisposable
     DECLARE_CLASSNAME(MgCoordinateSystemMathComparator)
 PUBLISHED_API:
+    /// \brief
+    /// Determines if the two given definitions are the same
+    /// \param pDefinition1 (MgGuardDisposable)
+    /// The first definition to compare
+    /// \param pDefinition2 (MgGuardDisposable)
+    /// The second definiton to compare
+    /// \return
+    /// true if both definitions are the same. false otherwise
     virtual bool Same(MgGuardDisposable *pDefinition1, MgGuardDisposable *pDefinition2)=0;
+    /// \brief
+    /// Determines if the two given ellipsoids are the same
+    /// \param pDefinition1 (MgCoordinateSystemEllipsoid)
+    /// \param pDefinition2 (MgCoordinateSystemEllipsoid)
+    /// \return
     virtual bool SameEllipsoid(MgCoordinateSystemEllipsoid *pDefinition1, MgCoordinateSystemEllipsoid *pDefinition2)=0;
+    /// \brief
+    /// Determines if the two given datums are the same
+    /// \param pDefinition1 (MgCoordinateSystemDatum)
+    /// \param pDefinition2 (MgCoordinateSystemDatum)
+    /// \return
     virtual bool SameDatum(MgCoordinateSystemDatum *pDefinition1, MgCoordinateSystemDatum *pDefinition2)=0;
+    /// \brief
+    /// Determines if the two given coordinate system are the same
+    /// \param pDefinition1 (MgCoordinateSystem)
+    /// \param pDefinition2 (MgCoordinateSystem)
+    /// \return
     virtual bool SameCoordinateSystem(MgCoordinateSystem *pDefinition1, MgCoordinateSystem *pDefinition2)=0;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -23,6 +23,7 @@
+/// \brief
 /// This object carries most, if not all, intelligence specific to the MGRS
 /// (Military Grid Reference System) grid standard.  It can be used at two
 /// distinct levels, depending upon how it is manufactured.
@@ -44,64 +45,64 @@
 PUBLISHED_API:
     // section that reads/writes MGRS coordinates
-    /// /brief
+    /// \brief
     /// Converts a geographic coordinate to MGRS string form.
-    /// /param dLongitude
+    /// \param dLongitude (double)
     /// Longitude of the geographic position to be converted, in degrees
     /// relative to Greenwich.  Use negative value for west longitude.
-    /// /param dLatitude
+    /// \param dLatitude (double)
     /// Latitude of the geographic position to be converted, in degrees.
     /// Use negative value for south latitude.
-    /// /param nPrecision
+    /// \param nPrecision (int)
     /// A value between zero and five, indicates the precision of the
     /// numeric portion of the returned MGRS designation.
-    /// /returns
+    /// \return
     /// The MGRs representation for the given point.
     virtual STRING ConvertFromLonLat(double dLongitude, double dLatitude, INT32 nPrecision)=0;
-    /// /brief
+    /// \brief
-    /// /param pLonLat
+    /// \param pLonLat (String/string)
     /// The geographic position to be converted.  X coordinate is the longitude
     /// in degrees relative to Greenwich, negative indicating west longitude.
     /// Y coordinate is latitude in degrees, negative indicating south latitude.
-    /// /returns
+    /// \return
     virtual STRING ConvertFromLonLat(MgCoordinate* pLonLat, INT32 nPrecision)=0;
-    /// /brief
+    /// \brief
     /// Converts an MGRS string to geographic coordinates.
-    /// /param sMgrs
+    /// \param sMgrs (String/string)
     /// The MGRS string to be converted.
-    /// /returns
+    /// \return
     /// The geographic coordinates of the location identified by the provided
     /// MGRS string (center of the grid sqaure).
     virtual MgCoordinate* ConvertToLonLat(CREFSTRING sMgrs)=0;
-    /// /brief
+    /// \brief
-    /// /param sMgrs
-    /// /param grdSqrPosition
+    /// \param grdSqrPosition (int)
     /// A value from the MgCoordinateSystemMgrsGridSquarePosition enumeration
     /// which indicates the position within the grid sqaure referenced by
     /// the sMgrs argumjent which is to be returned.
-    /// /returns
+    /// \return
     /// MGRS string.
     virtual MgCoordinate* ConvertToLonLat(CREFSTRING sMgrs, INT32 grdSqrPosition)=0;
-    /// /brief
+    /// \brief
     /// Returns a value as defined by the MgCoordinateSystemMgrsLetteringScheme
     /// object indicating which lettering scheme is currently active.
-    /// /returns
+    /// \return
     /// Either MgCoordinateSystemMgrsLetteringScheme::Normal or
     /// MgCoordinateSystemMgrsLetteringScheme::Alternative
     virtual INT8 GetLetteringScheme()=0;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -29,15 +29,55 @@
 class MG_GEOMETRY_API MgCoordinateSystemMgrsGridLevel
 PUBLISHED_API:
+    /// \brief
+    /// None
     static const INT32 MgrsNone    =  0;
+    /// \brief
+    /// UTM
     static const INT32 MgrsUtm     =  1;
+    /// \brief
+    /// UPS
     static const INT32 MgrsUps     =  2;
+    /// \brief
+    /// 100km
     static const INT32 Mgrs100Km   =  3;
+    /// \brief
+    /// 10km
     static const INT32 Mgrs10Km    =  4;
+    /// \brief
+    /// 1km
     static const INT32 Mgrs1Km     =  5;
+    /// \brief
+    /// 100m
     static const INT32 Mgrs100m    =  6;
+    /// \brief
+    /// 10m
     static const INT32 Mgrs10m     =  7;
+    /// \brief
+    /// 1m
     static const INT32 Mgrs1m      =  8;
+    /// \brief
+    /// Unknown
     static const INT32 MgrsUnknown = 99;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -19,64 +19,63 @@
 #define _MGCOORDINATESYSTEMMGRSGRIDSQUAREPOSITION_H_
-///<summary>
+/// \brief
 /// MgCoordinateSystemMgrsGridSquarePosition defines enumerated values used to
 /// specify the the location desired relative to the subject MGRS grid sqaure
 /// when evaluating an MGRS string.
 /// Note that the values used in this enumeration match those used by the
-// CS-MAP interface.
-///</summary>
+/// CS-MAP interface.
 class MG_GEOMETRY_API MgCoordinateSystemMgrsGridSquarePosition
     // MENTOR_MAINTENANCE --> These enumeration values are assumed to be the
     // same as those used by CS-MAP.
 PUBLISHED_API:
-    ///<summary>
+    /// \brief
     /// Specifies the grid square position is not set as yet.
-    ///</summary>
     static const INT32 None = 0;
-    ///<summary>
+    /// \brief
     /// Specifies the center of the grid square; the default previous to this
     /// revision (Dec 2009).
-    ///</summary>
     static const INT32 Center = 1;
-    ///<summary>
+    /// \brief
     /// Specifies the southwest corner of the MGRS grid square.
-    ///</summary>
     static const INT32 SouthWest = 2;
-    ///<summary>
+    /// \brief
     /// Specifies the midpoint of the western edge of the MGRS grid square.
-    ///</summary>
     static const INT32 West = 3;
-    ///<summary>
+    /// \brief
     /// Specifies the northwest corner of the MGRS grid square.
-    ///</summary>
     static const INT32 NorthWest = 4;
-    ///<summary>
+    /// \brief
     /// Specifies the midpoint of the northern edge of the MGRS grid square.
-    ///</summary>
     static const INT32 North = 5;
-    ///<summary>
+    /// \brief
-    ///</summary>
     static const INT32 NorthEast = 6;
-    ///<summary>
+    /// \brief
     /// Specifies the midpoint of the eastern edge of the MGRS grid square.
-    ///</summary>
     static const INT32 East = 7;
-    ///<summary>
+    /// \brief
     /// Specifies the southeast corner of the MGRS grid square.
-    ///</summary>
     static const INT32 SouthEast = 8;
-    ///<summary>
+    /// \brief
     /// Specifies the midpoint of the southern edge of the MGRS grid square.
-    ///</summary>
     static const INT32 South = 9;
-    ///<summary>
+    /// \brief
     /// Specifies an error return value, end of table, or other abnormal situation.
-    ///</summary>
     static const INT32 Unknown = 10;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -31,13 +31,13 @@
 PUBLISHED_API:
     /// \brief
+    /// Normal
     static const INT8 Normal = 0;
     /// \brief
+    /// Alternative
     static const INT8 Alternative = 1;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -24,82 +24,370 @@
 /// \brief
+/// Defines coordinate system projection codes
 class MG_GEOMETRY_API MgCoordinateSystemProjectionCode
 PUBLISHED_API:
-    static const INT32 Alber = 4;           // Albers Equal Area Conic Projection
-    static const INT32 Azede = 59;          // Azimuthal Equi-Distant; Elevated ellipsoid.
-    static const INT32 Azmea = 11;          // Lambert Azimuthal Equal Area Projection
-    static const INT32 Azmed = 7;           // Lambert Azimuthal Equidistant Projection
-    static const INT32 Bipolar = 31;        // Bipolar Oblique Conformal Conic Projection
-    static const INT32 Bonne = 24;          // Bonne Pseudoconical Projection
-    static const INT32 Cassini = 22;        // Cassini Projection
-    static const INT32 Eckert4 = 25;        // Ekert Pseudocylindrical Projection; Number IV
-    static const INT32 Eckert6 = 26;        // Ekert Pseudocylindrical Projection; Number VI
-    static const INT32 Edcnc = 12;          // Equidistant Conic Projection; aka Simple Conic
-    static const INT32 Edcyl = 20;          // Equidistant Cylindrical Projection (Spherical only)
-    static const INT32 GaussK = 46;         // Gauss-Kruger: Transverse Mercator without scale reduction parameter.
-    static const INT32 Gnomonic = 19;       // Gnomonic Projection
-    static const INT32 Goode = 28;          // Goode Homolosine Projection
-    static const INT32 Hom1uv = 1281;       // Unrectified Hotine Oblique Mercator Projection; Sngl Point Form
-    static const INT32 Hom1xy = 1282;       // Rectified Hotine Oblique Mercator Projection; Single Point Form
-    static const INT32 Hom2uv = 1283;       // Unrectified Hotine Oblique Mercator Projection; Two Point Form
-    static const INT32 Hom2xy = 1284;       // Rectified Hotine Oblique Mercator Projection; Two Point Form
-    static const INT32 Krovak = 47;         // Czech Krovak; original.
-    static const INT32 Krvk95 = 51;         // Czech Krovak; includes 1995 adjustment.
-    static const INT32 LL = 1;              // Null Projection; produces/processes Latitude & Longitude
-    static const INT32 Lm1sp = 36;          // Single standard parallel variation of the Lambert Conformal Conic.
-    static const INT32 Lm2sp = 37;          // Double standard parallel variation of the Lambert Conformal Conic.
-    static const INT32 Lmblg = 38;          // Belgian variation of the Lambert Conformal Conic Projection.
-    static const INT32 Lmtan = 8;           // Lambert Tangential Conformal Conic Projection
-    static const INT32 Miller = 13;         // Miller Cylindrical Projection
-    static const INT32 Mndotl = 41;         // Minnesota DOT variation of the Lambert Conformal Conic.
-    static const INT32 Mndott = 42;         // Minnesota DOT variation of the Transverse Mercator projection.
-    static const INT32 Modpc = 10;          // Lallemand IMW Modified Polyconic Projection
-    static const INT32 Mollweid = 27;       // Mollweide Projection
-    static const INT32 Mrcat = 6;           // Mercator Cylindrical Projection
-    static const INT32 MrcatK = 49;         // Standard Mercator with a scale reduction factor instead of a standard parallel.
-    static const INT32 Mstero = 15;         // Modified Sterographic Projection
-    static const INT32 Neacyl = 29;         // Normal Aspect; Equal Area Cylindrical Projection
-    static const INT32 Nerth = 55;          // Non-georeferenced coordinate system.  Named Non-Earth by Map Info.
-    static const INT32 Nzealand = 16;       // New Zealand National Grid
-    static const INT32 OblqM = 5;         // Oblique Mercator (obsolete)
-    static const INT32 Obqcyl = 56;         // Oblique Cylindrical; a generalized version of the Swiss projection; specifically for Hungary
-    static const INT32 Ortho = 18;          // Orthographic Projection
-    static const INT32 Ostn02 = 60;         // The Transverse Mercator with specific parameters; with the OSTN02 grid shift tacked on.  This is a combination of a projection and a datum shift
-    static const INT32 Ostn97 = 58;         // The Transverse Mercator with specific parameters; with the OSTN97 grid shoft tacked on.  This is a combination of a projection and a datum shift
-    static const INT32 Ostro = 34;          // Oblique Sterographic
-    static const INT32 Plycn = 9;           // Hassler American Polyconic Projection
-    static const INT32 Pstro = 33;          // Polar sterographic
-    static const INT32 Pstrosl = 53;        // Polar sterographic with standard latitude
-    static const INT32 Rskew = 1285;        // cs_PRJCOD_RSKEW
-    static const INT32 Rskewc = 1286;       // cs_PRJCOD_RSKEWC
-    static const INT32 Rskewo = 1287;       // cs_PRJCOD_RSKEWO - Rectified Skew Orthomorphic; Skew Azimuth at Rectified Origin
-    static const INT32 Robinson = 23;       // Robinson Cylindrical Projection
-    static const INT32 Sinus = 17;          // Sinusoidal Projection; Optionally Interrupted
-    static const INT32 Sotrm = 43;          // South Oriented variation of the Transverse Mercator Projection.
-    static const INT32 Sstro = 35;          // Synder's Oblique Sterographic
-    static const INT32 Swiss = 32;          // "Swiss" Projection
-    static const INT32 Sys34 = 57;          // Combination of Transverse Mercator and a polynomial expansion used in Denmark
-    static const INT32 Sys34_99 = 61;       // Combination of Transverse Mercator and polynomial expansion used in Denmark.  Polynominals are of the 1999 vintage.
-    static const INT32 Teacyl = 30;         // Transverse Aspect; Equal Area Cylindrical Projection
-    static const INT32 Tm = 3;              // Transverse Mercator or Gauss Kruger Projection
-    static const INT32 Trmeraf = 54;        // Transverse Mercator with affiine post-processor.
-    static const INT32 Trmrkrg = 62;        // Transverse Mercator using Kruger Formulation
-    static const INT32 Trmrs = 45;          // Transverse Mercator per J. P. Snyder.
-    static const INT32 Vdgrntn = 21;        // Van Der Grinten Projection
-    static const INT32 Wccsl = 39;          // Wisconsin County Coord System variation; Lambert Conformal Conic
-    static const INT32 Wccst = 40;          // Wisconsin County Coord System variation; Transverse Mercator projection
-    static const INT32 Utm = 44;            // The UTM direct variation of the Transverse Mercator projection
-    static const INT32 Winkl = 63;          // Winkel-Tripel; variable standard latitude
-    static const INT32 Nrthsrt = 64;        // Nerth with scale and rotation
-    static const INT32 Lmbrtaf = 65;        // Lambert Conformal Conic with affine post-processor.
-    static const INT32 Sys34_01 = 66;       // Combination of Transverse Mercator and polynomial expansion used in Denmark.  Polynominals are of the 2001 vintage.
-    static const INT32 EdcylE = 67;         // Equidistant Cylindrical Projection, Ellipsoidal or Spherical
-    static const INT32 PlateCarree = 68;    // Inplementation of Plate Carree as a variation of the Equidistant Cylindrical
-    static const INT32 PvMercator = 69;     // Popular Visualization Pseudo Mercator (aka Google Earth)
+    /// \brief
+    /// Albers Equal Area Conic Projection
+    static const INT32 Alber = 4;
+    /// \brief
+    /// Azimuthal Equi-Distant; Elevated ellipsoid.
+    static const INT32 Azede = 59;
+    /// \brief
+    /// Lambert Azimuthal Equal Area Projection
+    static const INT32 Azmea = 11;
+    /// \brief
+    /// Lambert Azimuthal Equidistant Projection
+    static const INT32 Azmed = 7;
+    /// \brief
+    /// Bipolar Oblique Conformal Conic Projection
+    static const INT32 Bipolar = 31;
+    /// \brief
+    /// Bonne Pseudoconical Projection
+    static const INT32 Bonne = 24;
+    /// \brief
+    /// Cassini Projection
+    static const INT32 Cassini = 22;
+    /// \brief
+    /// Ekert Pseudocylindrical Projection; Number IV
+    static const INT32 Eckert4 = 25;
+    /// \brief
+    /// Ekert Pseudocylindrical Projection; Number VI
+    static const INT32 Eckert6 = 26;
+    /// \brief
+    /// Equidistant Conic Projection; aka Simple Conic
+    static const INT32 Edcnc = 12;
+    /// \brief
+    /// Equidistant Cylindrical Projection (Spherical only)
+    static const INT32 Edcyl = 20;
+    /// \brief
+    /// Gauss-Kruger: Transverse Mercator without scale reduction parameter.
+    static const INT32 GaussK = 46;
+    /// \brief
+    /// Gnomonic Projection
+    static const INT32 Gnomonic = 19;
+    /// \brief
+    /// Goode Homolosine Projection
+    static const INT32 Goode = 28;
+    /// \brief
+    /// Unrectified Hotine Oblique Mercator Projection; Sngl Point Form
+    static const INT32 Hom1uv = 1281;
+    /// \brief
+    /// Rectified Hotine Oblique Mercator Projection; Single Point Form
+    static const INT32 Hom1xy = 1282;
+    /// \brief
+    /// Unrectified Hotine Oblique Mercator Projection; Two Point Form
+    static const INT32 Hom2uv = 1283;
+    /// \brief
+    /// Rectified Hotine Oblique Mercator Projection; Two Point Form
+    static const INT32 Hom2xy = 1284;
+    /// \brief
+    /// Czech Krovak; original.
+    static const INT32 Krovak = 47;
+    /// \brief
+    /// Czech Krovak; includes 1995 adjustment.
+    static const INT32 Krvk95 = 51;
+    /// \brief
+    /// Null Projection; produces/processes Latitude & Longitude
+    static const INT32 LL = 1;
+    /// \brief
+    /// Single standard parallel variation of the Lambert Conformal Conic.
+    static const INT32 Lm1sp = 36;
+    /// \brief
+    /// Double standard parallel variation of the Lambert Conformal Conic.
+    static const INT32 Lm2sp = 37;
+    /// \brief
+    /// Belgian variation of the Lambert Conformal Conic Projection.
+    static const INT32 Lmblg = 38;
+    /// \brief
+    /// Lambert Tangential Conformal Conic Projection
+    static const INT32 Lmtan = 8;
+    /// \brief
+    /// Miller Cylindrical Projection
+    static const INT32 Miller = 13;
+    /// \brief
+    /// Minnesota DOT variation of the Lambert Conformal Conic.
+    static const INT32 Mndotl = 41;
+    /// \brief
+    /// Minnesota DOT variation of the Transverse Mercator projection.
+    static const INT32 Mndott = 42;
+    /// \brief
+    /// Lallemand IMW Modified Polyconic Projection
+    static const INT32 Modpc = 10;
+    /// \brief
+    /// Mollweide Projection
+    static const INT32 Mollweid = 27;
+    /// \brief
+    /// Mercator Cylindrical Projection
+    static const INT32 Mrcat = 6;
+    /// \brief
+    /// Standard Mercator with a scale reduction factor instead of a standard parallel.
+    static const INT32 MrcatK = 49;
+    /// \brief
+    /// Modified Sterographic Projection
+    static const INT32 Mstero = 15;
+    /// \brief
+    /// Normal Aspect; Equal Area Cylindrical Projection
+    static const INT32 Neacyl = 29;
+    /// \brief
+    /// Non-georeferenced coordinate system.  Named Non-Earth by Map Info.
+    static const INT32 Nerth = 55;
+    /// \brief
+    /// New Zealand National Grid
+    static const INT32 Nzealand = 16;
+    /// \brief
+    /// Oblique Mercator (obsolete)
+    static const INT32 OblqM = 5;
+    /// \brief
+    /// Oblique Cylindrical; a generalized version of the Swiss projection; specifically for Hungary
+    static const INT32 Obqcyl = 56;
+    /// \brief
+    /// Orthographic Projection
+    static const INT32 Ortho = 18;
+    /// \brief
+    /// The Transverse Mercator with specific parameters; with the OSTN02 grid shift tacked on.  This is a combination of a projection and a datum shift
+    static const INT32 Ostn02 = 60;
+    /// \brief
+    /// The Transverse Mercator with specific parameters; with the OSTN97 grid shoft tacked on.  This is a combination of a projection and a datum shift
+    static const INT32 Ostn97 = 58;
+    /// \brief
+    /// Oblique Sterographic
+    static const INT32 Ostro = 34;
+    /// \brief
+    /// Hassler American Polyconic Projection
+    static const INT32 Plycn = 9;
+    /// \brief
+    /// Polar sterographic
+    static const INT32 Pstro = 33;
+    /// \brief
+    /// Polar sterographic with standard latitude
+    static const INT32 Pstrosl = 53;
+    /// \brief
+    /// cs_PRJCOD_RSKEW
+    static const INT32 Rskew = 1285;
+    /// \brief
+    /// cs_PRJCOD_RSKEWC
+    static const INT32 Rskewc = 1286;
+    /// \brief
+    /// cs_PRJCOD_RSKEWO - Rectified Skew Orthomorphic; Skew Azimuth at Rectified Origin
+    static const INT32 Rskewo = 1287;
+    /// \brief
+    /// Robinson Cylindrical Projection
+    static const INT32 Robinson = 23;
+    /// \brief
+    /// Sinusoidal Projection; Optionally Interrupted
+    static const INT32 Sinus = 17;
+    /// \brief
+    /// South Oriented variation of the Transverse Mercator Projection.
+    static const INT32 Sotrm = 43;
+    /// \brief
+    /// Synder's Oblique Sterographic
+    static const INT32 Sstro = 35;
+    /// \brief
+    /// "Swiss" Projection
+    static const INT32 Swiss = 32;
+    /// \brief
+    /// Combination of Transverse Mercator and a polynomial expansion used in Denmark
+    static const INT32 Sys34 = 57;
+    /// \brief
+    /// Combination of Transverse Mercator and polynomial expansion used in Denmark.  Polynominals are of the 1999 vintage.
+    static const INT32 Sys34_99 = 61;
+    /// \brief
+    /// Transverse Aspect; Equal Area Cylindrical Projection
+    static const INT32 Teacyl = 30;
+    /// \brief
+    /// Transverse Mercator or Gauss Kruger Projection
+    static const INT32 Tm = 3;
+    /// \brief
+    /// Transverse Mercator with affiine post-processor.
+    static const INT32 Trmeraf = 54;
+    /// \brief
+    /// Transverse Mercator using Kruger Formulation
+    static const INT32 Trmrkrg = 62;
+    /// \brief
+    /// Transverse Mercator per J. P. Snyder.
+    static const INT32 Trmrs = 45;
+    /// \brief
+    /// Van Der Grinten Projection
+    static const INT32 Vdgrntn = 21;
+    /// \brief
+    /// Wisconsin County Coord System variation; Lambert Conformal Conic
+    static const INT32 Wccsl = 39;
+    /// \brief
+    /// Wisconsin County Coord System variation; Transverse Mercator projection
+    static const INT32 Wccst = 40;
+    /// \brief
+    /// The UTM direct variation of the Transverse Mercator projection
+    static const INT32 Utm = 44;
+    /// \brief
+    /// Winkel-Tripel; variable standard latitude
+    static const INT32 Winkl = 63;
+    /// \brief
+    /// Nerth with scale and rotation
+    static const INT32 Nrthsrt = 64;
+    /// \brief
+    /// Lambert Conformal Conic with affine post-processor.
+    static const INT32 Lmbrtaf = 65;
+    /// \brief
+    /// Combination of Transverse Mercator and polynomial expansion used in Denmark.  Polynominals are of the 2001 vintage.
+    static const INT32 Sys34_01 = 66;
+    /// \brief
+    /// Equidistant Cylindrical Projection, Ellipsoidal or Spherical
+    static const INT32 EdcylE = 67;
+    /// \brief
+    /// Inplementation of Plate Carree as a variation of the Equidistant Cylindrical
+    static const INT32 PlateCarree = 68;
+    /// \brief
+    /// Popular Visualization Pseudo Mercator (aka Google Earth)
+    static const INT32 PvMercator = 69;
+    /// \brief
+    /// Unknown
     static const INT32 Unknown = 0;
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h	2012-12-08 14:20:55 UTC (rev 7248)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h	2012-12-08 14:46:22 UTC (rev 7249)
@@ -24,20 +24,56 @@
 /// \brief
+/// Defines the type of projection format
 class MG_GEOMETRY_API MgCoordinateSystemProjectionFormatType
 PUBLISHED_API:
-    static const INT32 None = 0;        //none (no formatting)
-    static const INT32 Lng = 57509;     //longitude(cs_FRMT_LNG), azimuth(cs_FRMT_AZM)
-    static const INT32 Lat = 41157;     //latitude (cs_FRMT_LAT)
-    static const INT32 Angd = 32933;    //angular distance (cs_FRMT_ANGD)
-    static const INT32 Coef = 13;       //coefficient (cs_FRMT_COEF)
-    static const INT32 Xxx = 4099;      //coefficient (cs_FRMT_XXX)
-    static const INT32 Yyy = 4099;      //coefficient (cs_FRMT_YYY)
-    static const INT32 Scl = 7;         //coefficient (cs_FRMT_SCL)
-    static const INT32 Rot = 4;         //coefficient (cs_FRMT_ROT)
+    /// \brief
+    /// none (no formatting)
+    static const INT32 None = 0;
+    /// \brief
+    /// longitude(cs_FRMT_LNG), azimuth(cs_FRMT_AZM)
+    static const INT32 Lng = 57509;
+    /// \brief
+    /// latitude (cs_FRMT_LAT)
+    static const INT32 Lat = 41157;
+    /// \brief
+    /// angular distance (cs_FRMT_ANGD)
+    static const INT32 Angd = 32933;
+    /// \brief
+    /// coefficient (cs_FRMT_COEF)
+    static const INT32 Coef = 13;
+    /// \brief
+    /// coefficient (cs_FRMT_XXX)
+    static const INT32 Xxx = 4099;
+    /// \brief
+    /// coefficient (cs_FRMT_YYY)
+    static const INT32 Yyy = 4099;
+    /// \brief
+    /// coefficient (cs_FRMT_SCL)
+    static const INT32 Scl = 7;
+    /// \brief
+    /// coefficient (cs_FRMT_ROT)
+    static const INT32 Rot = 4;
More information about the mapguide-commits
