[mapguide-commits] r7250 - sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src
svn_mapguide at osgeo.org
Sat Dec 8 06:58:24 PST 2012
Author: jng
Date: 2012-12-08 06:58:22 -0800 (Sat, 08 Dec 2012)
New Revision: 7250
sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java
#9: Fix test harness for linux. Also allow custom webconfig.ini path to be passed in to this test harness
Modified: sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java
--- sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java 2012-12-08 14:46:22 UTC (rev 7249)
+++ sandbox/jng/swig-java/UnitTest/Common/JavaApiExTest/src/MapGuideApiTest.java 2012-12-08 14:58:22 UTC (rev 7250)
@@ -23,7 +23,15 @@
public static void main(String [] args) {
assertFailures = new ArrayList<AssertException>();
- MapGuideJavaApiEx.MgInitializeWebTier("C:\\Program Files\\OSGeo\\MapGuide\\Web\\www\\webconfig.ini");
+ if (args.length == 1) {
+ MapGuideJavaApiEx.MgInitializeWebTier(args[0]);
+ } else {
+ if (System.getProperty("os.name").startsWith("Windows")) {
+ MapGuideJavaApiEx.MgInitializeWebTier("C:\\Program Files\\OSGeo\\MapGuide\\Web\\www\\webconfig.ini");
+ } else {
+ MapGuideJavaApiEx.MgInitializeWebTier("/usr/local/mapguideopensource/webserverextensions/www/webconfig.ini");
MgUserInformation userInfo = new MgUserInformation("Administrator", "admin");
MgSiteConnection siteConn = new MgSiteConnection();
More information about the mapguide-commits
