[mapguide-commits] r6688 - in trunk/Tools/Maestro/Maestro.Editors: Common Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 23 07:58:26 EDT 2012
Author: jng
Date: 2012-05-23 04:58:25 -0700 (Wed, 23 May 2012)
New Revision: 6688
   trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
#1979: Use the same BusyWaitDialog to perform resource data uploads/downloads
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs	2012-05-22 17:53:41 UTC (rev 6687)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs	2012-05-23 11:58:25 UTC (rev 6688)
@@ -174,41 +174,47 @@
                 open.Multiselect = true;
                 if (open.ShowDialog() == DialogResult.OK)
-                    using (new WaitCursor(this))
+                    try
-                        try
+                        foreach (var fileName in open.FileNames)
-                            foreach (var fileName in open.FileNames)
-                                UploadFile(fileName);
-                                var handler = this.ResourceDataUploaded;
-                                if (handler != null)
-                                    handler(Path.GetFileName(fileName), fileName);
+                            UploadFile(fileName);
-                        catch (Exception ex)
-                            MessageBox.Show(NestedExceptionMessageProcessor.GetFullMessage(ex), Properties.Resources.TitleError, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                    catch (Exception ex)
+                        MessageBox.Show(NestedExceptionMessageProcessor.GetFullMessage(ex), Properties.Resources.TitleError, MessageBoxButtons.OK, MessageBoxIcon.Error);
+        private void DoFileUpload(string fileName)
+            using (var fs = new FileStream(fileName, FileMode.Open))
+                //_edSvc.AddResourceData(Path.GetFileName(open.FileName), ResourceDataType.File, fs);
+                IResource res = _edSvc.GetEditedResource();
+                res.SetResourceData(Path.GetFileName(fileName), ResourceDataType.File, fs);
         /// <summary>
         /// Uploads the file.
         /// </summary>
         /// <param name="fileName">Name of the file.</param>
         public void UploadFile(string fileName)
-            using (var fs = new FileStream(fileName, FileMode.Open))
+            //TODO: Obviously support progress
+            BusyWaitDelegate method = () => { DoFileUpload(fileName); return null; };
+            BusyWaitDialog.Run(Properties.Resources.TextUploading, method, (obj) =>
-                //_edSvc.AddResourceData(Path.GetFileName(open.FileName), ResourceDataType.File, fs);
-                IResource res = _edSvc.GetEditedResource();
-                res.SetResourceData(Path.GetFileName(fileName), ResourceDataType.File, fs);
                 LoadResourceData();
                 OnDataListChanged();
+                var handler = this.ResourceDataUploaded;
+                if (handler != null)
+                    handler(Path.GetFileName(fileName), fileName);
         private void OnDataListChanged()
@@ -260,19 +266,24 @@
                     save.FileName = item.Name;
                     if (save.ShowDialog() == DialogResult.OK)
+                        var fn = save.FileName;
                         try
-                                //var stream = _edSvc.GetResourceData(item.Name);
                                 var stream = res.GetResourceData(item.Name);
-                                using (var fs = File.OpenWrite(save.FileName))
+                                using (var fs = File.OpenWrite(fn))
                                     Utility.CopyStream(stream, fs);
-                            MessageBox.Show(string.Format(Properties.Resources.FileDownloaded, save.FileName));
+                                return null;
+                            BusyWaitDialog.Run(Properties.Resources.TextDownloading, method, (obj) =>
+                                MessageBox.Show(string.Format(Properties.Resources.FileDownloaded, fn));
@@ -387,7 +398,6 @@
         private void lstDataFiles_DragDrop(object sender, DragEventArgs e)
             Array a = e.Data.GetData(DataFormats.FileDrop) as Array;
-            bool refresh = false;
             if (a != null && a.Length > 0)
                 for (int i = 0; i < a.Length; i++)
@@ -395,21 +405,11 @@
                     string file = a.GetValue(i).ToString();
                     try
-                        using (var fs = new FileStream(file, FileMode.Open))
-                            res.SetResourceData(Path.GetFileName(file), ResourceDataType.File, fs);
-                            refresh = true;
+                        UploadFile(file);
                     catch { }
-            if (refresh)
-                LoadResourceData();
-                OnDataListChanged();
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2012-05-22 17:53:41 UTC (rev 6687)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2012-05-23 11:58:25 UTC (rev 6688)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:4.0.30319.239
+//     Runtime Version:4.0.30319.225
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -3200,6 +3200,24 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Downloading.
+        /// </summary>
+        internal static string TextDownloading {
+            get {
+                return ResourceManager.GetString("TextDownloading", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to Uploading.
+        /// </summary>
+        internal static string TextUploading {
+            get {
+                return ResourceManager.GetString("TextUploading", resourceCulture);
         internal static System.Drawing.Bitmap tick {
             get {
                 object obj = ResourceManager.GetObject("tick", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2012-05-22 17:53:41 UTC (rev 6687)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2012-05-23 11:58:25 UTC (rev 6688)
@@ -112,86 +112,265 @@
     <value>2.0</value>
   </resheader>
   <resheader name="reader">
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <resheader name="writer">
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
-  <data name="scissors-blue" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\scissors-blue.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="scissors-blue" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACRUlEQVQ4T6VSS2gTURS9mSyD
+        QRGtRlOxkM+gdcAQiIImMQYbE2tIqqVmJUHcWPCDkj4k/q2gYBcuahYuhIpWorgQsSqEqhUpmE1WQQrR
+        QsBo1m7M8543HQ0ibhw43LnnN2+GISkl/Q8ok8lQNpvdxzBSqRRFo1EKBoPk9/vJ7XariR08dPjgRw4P
+        VmQ+nxdAMpk0/lUA3fIipwpweTweUa1WZS6XE5FIxPjbCcBDhw9+5H4V8L3h9XpFrVaTfDQRCASM7lfA
+        Dh46fPD/WYDd8Pl8ol6vy0QiIdho4BtgYgcP3Qr/LvDtJ9KzRKs3qRJ+smg0GjIcDguXyzWEiR28CsMH
+        P+fMVxi8Q5S5R3RgmihyHkWGruui2WzKeDw+U6lUJHbwSocPfs51Fzho6EGacYkxSeFiuW/30flWqyWd
+        gzfnKTVZVrypp7nA0V3goPTdse3F17NnyovfxmfanWsv2vJ46Y2077nexj0AHjp88HOBwzzB3tLBUOHl
+        O5g8R6Y+2AduvLr87Iu0x8YrjAlMtTPfM1Kau/r8q4QfObMgNnGrO3z28Sep7bwwq4UvDmu7rpCavIO3
+        SsSjz9+RMwtC556y2IFYfLIotdDYW22bGNG2HCbbxhhhqp35wsMFVXL6/scfyJkFm0dv7zg21cQpbFtP
+        vbd5hw/ZnL3mL7p0YVc864XphQ78yJkFy9xR6h8tMeaod+AkM/34uxkbGOsY6xl9DJ31E8oHP+esX9nF
+        ooW1fN/DWMlYznAuYQXPVYw1XV4XCn4Cnzlvq0a0CiQAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="ColorCountError" xml:space="preserve">
     <value>Failed to read {0} color(s) in line {1}</value>
-    <comment>An error message that is displayed if the expected color count does not match the actual count</comment>
   </data>
   <data name="InvokeUrlNoMapDefined" xml:space="preserve">
     <value>Cannot get layers. No map definition specified</value>
   </data>
-  <data name="minus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\minus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="minus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACC0lEQVQ4T6WSP2gTYRjGP5JA
+        EyhNc0M8SotbAxU7pNDsNRA6hLQIpXiVzi0d3RVEaAUXBwexYgT7T9EKcfHfWQlSJJfmUFAhZOgJRocM
+        yh1ZjtfnCXq0pY2DgR+8933v87v3u3xKRNT/0AnfV0o9ABtgU6mBLaWWwBoo/4H1EvfYw15mmD0qyD+O
+        xcxaJuP8mJtzfy0u+j8XFvzvhuHujY873IMgf5Ig/7S/32oahvdtfl4cwzgE177Oznrb8bgFQf7QBEWO
+        Fo2a+zMz3pfpaflUKBzL56kpqRcK3npPj8lMcIS7ON+7dNqxJyfl/cREV/ZyOXk1MuIwEwhuK7X+IZdz
+        zUxG/vI8nZbtVErWBgflXjIpdzStA+tSKuUyEwhu4Wvj7f6LsTFpt9vSaDSkWq2KbdtSr9el2WxKq9Xq
+        UEwk5NHQkM9MILiJByub9Z8ND0utVpNKpXJsmIItCJ7ous9MILiBcd6MjroljLiBhm6UKNA0l5lAsMKL
+        k0zu7+B8r9HwL4qxmMNMILiGv+R6OGzu6Lq3iyl2ITmJl/G4txIKmcwEgqu4lpdxOZYjEausaZ4NiQ3J
+        Ud4ivBwOW+xlJhCgVqfBeWxcgn01GnXKfX3ux0TCJ6y5xj32sJe/g4IInk+BMwNKncsqdeWCUg8v4ksT
+        1lzjHnrOAh1EDgpCWOgFSYC+rvBF7A1R8BuYvt7nXvKiFAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="SelectLayer" xml:space="preserve">
     <value>Select Layer</value>
   </data>
-  <data name="map--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\map--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="map--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5ElEQVQ4T53STUzTZwDH8ecy
+        E52e57yZnRaiWRZdCPHgYdHDhtMwdkA0MQ0UeauA0A55UQSRYJEgL4KCQIq2EMGmCgEE5K0DLGwoXUFR
+        wLYgEtm0BSQi3z1PYrKYeDA+yef2+/6T////iNDMzGAp8jME/5qRIURIerqWzziqk4Q4lJoatS4fUNeX
+        RtNQDn1jxTgn63BMtmF6OEb2oAdDj5eEVi9xNi/RjV7UXnWSEAf0+ui19XWudabQPmlk0FPOkKucxZVO
+        /vZNYJ7zk2H3ctYJaQ6ItnpRe9VJQvyUlBSz+u4d5a0J3Hado/NpIa0jRp77brGwbGfgnxny70+R9whO
+        P4BYmxu1V50kxH6dLm5lbY1iWwwVbYnU3kvFOpxL12ghD8ZrGZxoxuxykWWfJqVrBl3LDGqvOkmIH2Ni
+        4v1v33LxZhRmxymsY2cxdZ/iD/dlphYtvFzuoMPZgWXuNcYn6yS2T6P2qpOE2KvVnni1uorxeiQmu576
+        kXSutidz98lFhmcrmX3VxLCrQb7KNJXuVQxdU6i96iQh9mg0iYtv3lBQpaWmO5m6QQOld3TcGT/Pvaki
+        nC9qcYxV4vY7aF2Y53TPY9RedZIQgUePJi2srFBYGk1+dQQXzBGUNMdR1nyCqrsG6nuzsDtLcTysoW20
+        hWONT2ka96E6SYhdYWHJ88vLFBfGYbIaqOk4yQVLBJbhNKzObPlrC2jsz8Hz701eLPXwS/UEh80efkip
+        uPF9QpkQ34WG6meXlijJ12GpT6f2dgrnTRpMA3oa/sxAc93GvqJuDl4ZIOSqg59Lhyjzws4z/Z4dOX+F
+        i2+Dg1M9fj8lefFcyo/HeCmKvEoNeXUajA1agrJtFLnlBZIX6cjo/5LG4Zvfex1ia1DQmXn5VZ/5fB8V
+        axplb073BwL7YWvEjdmvY1vCxcbt249/GRCQ+6m2/HZ5TtkUGFa8efdhoc4m6Stp26fYcKCs6ot9uZHv
+        O/EfeeONT9E6bWgAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="layer--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layer--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layer--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHUlEQVQ4T6XSXUhTcRjH8Qel
+        QrwJDZWlUhBR2ZzpbV7UZQRGIERhrRdXahhS1lVedRFEKdVyg1XUaiCczVmbL80CG2svzgtHuMxUTp7T
+        2nbmNs2yq9P/d1xkXtigwYf/nvF8z84ZI1mW6X9QzTUXlDN1zPEsYRcNUfXVV3DEP5UYiKV/BqPp5cB6
+        sINdNGhpX/sQNERTy6N8fMmVDeyiQUtVVwbhZCT5wzsb/TaUDeyiQUuaywOgFRPfPZ8ii/3ZwC4atKRu
+        c8JpduvusLDgWG2cT9k8H6SnrtDXB46xL129AeEW+KYSFjRoqeLSSzg7E10aCfHpPhibSXIsMlr9wh3O
+        N3db4f3DHY4/Q4OW9rS+gMaPkcU3LLS9nYibewPiXc4rdHE+RadyYl75rNMdlixo0NKui3Y4PyEsDA+H
+        ok/Yt963+v5yj82K/Y6G90VWTezQ6zM8GrS0s9kGTcHpeafNLxiY7gy8Xz13F/doYufm2+UyriaJpvCG
+        lmjHBQ5aPJOS3R4QTb+xxzAB5lruRLjYXBmH+rhOLrNUJ3MN23gyFRhpe2MPtLJf1tkXFB8rRjNnZi55
+        qJYORI7Ka5F+c5A2leymrafMuucj04PsL9r/blJyrHWY04rlhqoU7P1cK6v0lencm6U8Necbib0K8tV1
+        Bwvr9W1bjpmuryeno1RUzVbIOR2qOTRocYE8pohR/VPTxkek2zBOOFeavF/hwGWQJJEHwAAAAABJRU5E
+        rkJggg==
+</value>
   </data>
-  <data name="application--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABq0lEQVQ4T6XQz0vacRzH8Tda
+        gwjD7dAhdvLiYS3Bk7H1pcCLB0EFD8ODEKFzW8EY26EgunToTwhEBJkIMnEI4vSq5tBoQrIFwkCYX1BM
+        QUER5dXn3Y9TlH3bGx68P9/vlyd8v18CQP+DnE6nTngjeBTiRkcOh8OVz+dPq9Uqzs7+oFKpoFz+hVKp
+        hEKhAPEMuRz7Kc7HODoqo1j8jVQqe8ot2Ww2XyaTQTqdFjdTSCaTSCQSiMfjiMViiEajiEQiCIfDCIVC
+        CAaDCAQC8Pv9UKvVHv4Er/gHjxpuyW63vx2PxxiNRopwwy1ZrdZ3w+EQg8FAEW64JYvF8qHf76PX6ynC
+        DbdkNpu3ut0u2u22ItxwS5Ikfex0Omg2mxO5s+9hSK6CNzfckslk+tRqtVCv1yda+i5h4/wzeHPDLRmN
+        xi+NRgO1Wu1Orh8evIy+vuRsXp0N3yQ83X5eIL1ev8OvL8vynQxfX2FNdtwyffDsH2k0Gq9Wq92/z9T6
+        3Ilqd05mi7UV3JxV7tk4iZkR5oWFifZmywt/X4DEvm64feAsTxFtPjkk33TpcvO1mAsmbJya11eQ2wAA
+        AABJRU5ErkJggg==
+</value>
   </data>
-  <data name="image" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\image.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6XTT0iTYRzA8efk
+        Jbp0EOpQFy9drIMXVyhaEbWsjBUxTCmQOf8wojcYMWcmZKM/tsoKCXSXVtiqJdlaRmVeKjH7Y5pKUNvK
+        zD+DuS3X5rfnWaeObi98eZ8Xns/z4zm8AhDZlBVWg8X+pqYymSnDysQ+m61GnpTRo6zYY7WaU0tL6M7B
+        5vNQchG2XYbiNii6ALuugbETKl1w8iF0D4F7EJRRVug1rS6RSmG+BZY7YJebLj2HEw+g5dG/tVPW3Aue
+        YZj8Be9DoIyyYrvF0hBPJmnpGeD2YAj/KDz+JJPv4SD45PqehD0f4MUEjPyAr3OgjLJiS22tJZJIUNx8
+        mB2OOpz+Pt7JCWrjhJw2Pk36OzAPX2YgGIa5KCijrCiqrj46v7jI6kObWF+vR2er4JTHRWf/M3wfJxn6
+        NsvoVJSAhGkck9P/gDLKisKqqmMz8Tirdh8gt9zIWuMRNtZrFGqNbLWfYa/jChXtXZhdHqx3n9D+coTe
+        sTDKKCsKjMbjU7EYBaYOdA1dlGhu9HYvB88+xdTxGmv3GI6+ENffhLn5+TfeYAqfvFraSCs2GAzW7wsL
+        /x2ws/E+hlY/lc4BzDfeornHsXuDtPpnaeuPcvVVEmWUFetKS+0/5X0CkciyUkZZsSIvr2Zlfv7pTFJW
+        yCdHlitbs8yUycn6b/wLvnCph/venGUAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="PropEnumNoValues" xml:space="preserve">
     <value>Could not find possible values for enumerable property</value>
   </data>
   <data name="DataReadError" xml:space="preserve">
     <value>Unable to read data from the selected column: {0}</value>
-    <comment>An error message that is displayed when the column read fails</comment>
   </data>
-  <data name="icon_invokeurl_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_invokeurl_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_invokeurl_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIU4ANrf46y7zJ6rvLXLss/Z4cXQ2rPD1M3Fo8fR2rjHwK/BtbTJsb3TtcLXt8TOzsDL
+        ycTDpbrQtL7UtrnNs7DCtMHWt6m9rqm9rcHL1LHDtrDDtLPIsb7MxMDVtrLEtbHHsLbMs6u8xK/CtK++
+        q6y/ssDWtrrPtLjPtLrRtLzRtLvStb/VtqS1s7nJw8jSz63AtbzQtMDWt7bMsrvRtcHXt7zStcDMz7zR
+        tQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA4ACwAAAAAEAAQ
+        AAAIuQBx4MAQoKDBgwUxCAxgoKHDhgAMRBSwEKHFABRxBCDAsaNHjhk3AhhJsmSBjCFaZLCQgQOEAzAP
+        ADiJ4wGJBQMq3FjgwYVJihomDAAwoEGDCR5eyjyZYEGDoUQr0FjAgeRJBTBKQCUaI8UImDMFXOiwYivR
+        DhasClBgQsJWBhIivChAl+kGBlBn1GCwgYWAv38daBgwNAIKFQNE2EDAmHFNCh9AnJDxgcIDgZgxO0ig
+        4IKCBA4yYw4IADs=
+</value>
   </data>
   <data name="MoreThanLabel" xml:space="preserve">
     <value>More than {0}</value>
-    <comment>The label used for the highest value in the graduated theme set</comment>
   </data>
-  <data name="icon_selectpolygon_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_selectpolygon_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_selectpolygon_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIMLAM3Jzs6lqZ+svcTM083Cx828wdbcyMvSxsTEy8LKxM3DxwAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIbwAXCFxQIIDBgwcHCixIAIDDhwAC
+        KGQIEaLEhQEaVnRI4CLFjQA6FhCYcaMABBFHkgQp4CQAhQFYHhAwACZLAzNrrjRpACfNnQ8bCujps2bM
+        oBKHJmjZcgFCgwoWCFg6oKpOhQNbXsWK9SfXr2ADAgA7
+</value>
   </data>
-  <data name="tick-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\tick-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="tick-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC5UlEQVQ4T12Q60uTYRiHHzIZ
+        HlssW6Em62BQikPE0cyJg6W20h0cgc2gxMAYfVACFbEDJkIRnb4IrukyM1kuJhqK6NJEreHUPDWXEydK
+        +g/47dd7Pw1jPXC93Nz377rf531ZSUkJ0+l0zGAwMKPRyEpLSxNMJpNKgE5FCKpVNKMMZckhlz9CC0TC
+        MLempqZ2ampqfmdnB1tbWxyqJycn56urq2spIywQ/b9ApNfrr9pstg4S2mbtuDNxDznDWg7V1NvcDMJq
+        tXZQVlgg4jcoLi4m8oSBPRAIQDdyA+pvRph+3cb1oIVT6q9E/rSBz/z+VbS2ttrJIZdptVqpxWJpWF8P
+        oHioDJfnymDwVUD7wxyG/uctXJq5xjMrKyuoqqpqIJcVFhaqR0dHFp6Pv4bq61UUCQvyJnVhZA1rQOfd
+        715ccBfh2ZeX6OtzLZDLNBqNma5l7q9EgfCG9H4VskcKIB/Mx5nebCR1pmNjYwPBYBDb29s451LyrMfz
+        HeQytVpt8Xq9yPiYA43HhL29PSS+T4O4QwbxGxnW1tb4Avq5YqsMiT1pPDs+Pg5ymUqluuvxeJD2QQFH
+        wIXFxUXs7u4i/m1KmBxvT0FsdzKOOE7zrNvtBrlMqVTe9HpnYXKU4+RQJl/g8/nC5LiuE4j+lMg53Cvj
+        Wbd7DOQyhUJR0NPjWH78+SlSHOchdoRfO7YnGaLBY/tIu0+haeAJbDb7MrksKyvruF5vbJ6ZWcDFTg0k
+        Lhlincn8m6OdiTg4lrDPIWcSz0xPz0Kn0zeTy+RyOcvIyChsbHzkmJtbhaJNhbj2o4gclCBi4i9Ux7Yn
+        8JnX60NDw0MHOeQyqVTKZDJZVGpqqrmu7oFzaWkTLQMvcMVqgLhJwqGaektLQdTV3XdSlhxy6RwQiBaJ
+        REkSiaRcqcx91dXl8vt8u8LP/Af1aEYZIZtMTshlEUIhEUgVyIyMjFRHRUVVxsTE1Au0hKinHs0oI3A2
+        5ET8AeUdBAROQKmSAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="ColorPicker" xml:space="preserve">
     <value>Color Picker ...</value>
   </data>
-  <data name="icon_printablepage_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_printablepage_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_printablepage_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZsAO7y9pKaptzi6LC5xtra4P39/f///6qrsqmqsdbX26+xuN/j6O/v8qurs9HT3ff4
+        +f7+/qmrsr6/xvj4+bi4vaqrs8TFzqyrs7q9wb/CyL2+w+zs7bW2vO3v8dLT3rW2vcHEzLu7wOrs7cPG
+        zfP09crM0/X298/R2sTGyre2vP39/qystNva3sbGycbHy7q9wuLk6fr6+8bJ0eHj6LGxt6mrsejp7Pv7
+        +8/Q0bu9w7i4vry8wtrc4N3g5s/Q0vT198PDy729wtvc4e3t77CxuNzd4vz8/M/R27q9xb6+xvb3+L7A
+        w7S0vuDg5ayut/Lz9NXV1ubn7N7g5czMz+Tl59vc38DBxMXGydTW3M7R27Cvt7i5v/z8+87O0fn5+vLz
+        9fr7+6yttLi5wMHCx8PEzaiqsdXV2Ozs8aqqscTFyNfX29LT1////wAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AABsACwAAAAAEAAQAAAI1gDZCBQ4oKDBggMTshlgoGHDAQACKPSxREcQABgBQBQgkQ0OK1OGFDBzJeNG
+        jim6bDBQ4EaBHSYDyAwAhQOEAmC8KKHSIqOAnxI1oIgxwcQXAiEyYuQo8MMEAlAJMBHzwmfHMVATaFVQ
+        BMaWpRIjjACSAIkCBSWSFKhCAwDHBj24SMigAAuDMz86sNDiNsAKB1JUSHjygAeGAzkQpAGK4IiDKCRA
+        1EDgYYYIIjMDlMlygoEMJ00gGCnw4AKFBajZNDgQoQKCMEJsuDhgQY1ChWgOkFmjMCAAOw==
+</value>
   </data>
-  <data name="application--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABpElEQVQ4T6XQTUgCQRjG8QEh
+        iBK8VNAxAukWHsKTJy8Wkit56ItOfRJRBF2iLtE5kCAiEUMSwRJBENGOaYb2sdCSgZeMlBRRUFBEeZo3
+        ggoK3HrhB7uz/IfZYQDYfzCLxdLHjXNzMlHTx8xm82Q0Gr1PpVJ4fExCkiSI4h0SiQRisRj4N0Qi5Io/
+        X+PyUkQ8/oBg8OKeWmYymRbD4TBCoRBfDCIQCMDv98Pn88Hr9cLj8cDtdsPlcsHpdMLhcMBut8Nms0Gh
+        UMzRL8zzO/jTUMsEQVhoNptoNBqyUEMtMxqNS/V6HbVaTRZqqGUGg2G5Wq2iUqnIQg21TK/Xr5TLZRSL
+        RVmooZbpdLq1UqmEfD7fkp3zV5zd5kANtUyr1a4XCgVkMpmWTJ48gZzevIJaptFoNnK5HNLp9I82PEmY
+        D6VvDl6AsaMHDE5su5lard6k42ez2R8N78VhfQaWJGBa/LSeBPpX/S9MqVTOq1Sq3d90jWzd9swcZ7/S
+        RgB6Vw2N7zM+7Vw319sK5YRTJJ2CdfajpT1aG8XAKGsTbIfcVIfJ+h69AbnIrwah7HLvAAAAAElFTkSu
+        QmCC
+</value>
   </data>
   <data name="NotAFolder" xml:space="preserve">
     <value>Not a folder: {0}</value>
   </data>
-  <data name="icon_refreshmap_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_refreshmap_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_refreshmap_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIYAAAAAAP////38/f7+//39/vz8/evr7Nzd4M7P0s3O0bGzuOvs7n6Ej32DjnyCjH6E
+        js3Q1c3P0szO0ers77K4wLG3v6+1vYaasLC3v6+2vq61vK+2vczQ1Ors7unr7fb3+N7f4Kqtrpienqes
+        rKisrKqtramsrN3f38TGxvT19d/g4Kesq6isq6qtrMPGxcTGxdzf3c7Sz7a9t0J2QlqAWneNd3uOe4KU
+        gpSllJmomaOyo6WzpdHi0dHh0cXUxdbk1snWyd3p3dvn26avpqOso97p3tHc0a22rdPd0+Ls4uXu5cTK
+        xMHHwenr6f7+/v39/fz8/O7u7v///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABSACwAAAAAEAAQAAAI8AAxZKiwAYPBCgYvSFm4EEOBhyYKEIBSAAMEhQwxPHlSwIQAjhULcMAoxUIE
+        BBFKJEiAAAEGBgweMLRQAAGBFQQeFjjQoYPMhRUiSIgwooAAJwNSDBhgIGPOAiEkDlhio6oMhhkKqECx
+        4gWIADYCiLVBA2gBFwRIEEAxNYcSJTaQ5JCSgQQLEytYtIgypImRJDaMGKGhoQCKAi2guBhwI8gOGzJ2
+        FKmBgcCJFyNcgHByQ4gOJjZ0CKlBocDGERudHAECJGwTIDRKd/AgYsKCDzBw+Aj7A8cMDA4aPAjuQIGB
+        GETC8uhhg6Fz5zOq2pgREAA7
+</value>
   </data>
-  <data name="folder_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\folder-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="folder_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABLUlEQVQ4T6XUvUoDQRSG4a/K
+        JVh4EXsPVl6FVQrBykJEQZEkrIn/GBSMEIQIoogiFinEFIKgxoiCiGBABTG66MrihpC47B7nExt1txhT
+        PMWZM285AxFBO1BOI1IlA0NJRDDYMo4rqSh+EIjbbErNcaRqWdJ1EohRrMv3/TiOTJjibkvgbP7AM+ts
+        4svvHWfu2eIwhYxvr4v3VPjDVxdrZVNu94dCscVBAlOetSqth3yoD7UL472uCVuUxjDbelyRxt2SFjZs
+        sTeCbOM+J+5NVgsbtigOY7FeXRDnakYLG7bYHUTu/XpO7Iu0FjZssTWAvHM5KS+VpBY2bLHRj8Lb+bg8
+        H49qYcMWy73YcdRgnya1sGGLvm7MT/eg9B9s1WtATOlQOjWxibX1lPkNfAJSiLGOr2CqXQAAAABJRU5E
+        rkJggg==
+</value>
   </data>
-  <data name="block" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\block.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="block" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB80lEQVQ4T4WSUUhTURjH//fV
+        hwgiRBnSi8xxG0qlBZZtajK0xir30MCQYI/51AQzFEXSUQ8JiiAqiGLMh0HhQ4U1aNBDHoiIZbYpRKWE
+        DaHe/Tzf8d7rdu/ACz8+/ud83++ce7nQWrqhjb0/Ip4OavH0VgmCRX1yjogAbSRlZ7Xh5c7/zrV9MuEs
+        +1btvUrQ7euCNvC6kJz/1S6dX9604Cx7cra+wxukADyr8kLrfWGSvbKyQ3XPv1twlvvZgh7o45EjgZK4
+        dGg9CWbjUvIHnV34asGZ1419+GZ0hJdRLFCSSg+06Pz6uUSO3HOfLTjzugS+aY8atgTvgIBEmETqQts8
+        4F1ct1CCyFTGN+W2hi3BGyC53XE9vx/rJWbhXh+FQ/2Kmmt39iq6DtEfXP3dmYAoIKA+4oo8/V99G/3B
+        GQfDtyDGRCsl8tEi4l/8+dAikkqQlIK/3ib6CZeDR0GIxx+baXLjJnE14dw+A6EES1Lwq7qBsqhwEGuH
+        GP7QROOZG8TVhHPrhCGYk4Itl5cyOO3gfhvEYLqRnn4KEFcTzpefGIJJKchV1dK3U9UOon6I/tRFdXWu
+        JpwvDBmCu8DsQykpxe1GiL639TS61lL0Cpz1mCGQ/0+ZpFxSacN9ohlLJ8MQpZB7s+ojHvPYpWbmA8tY
+        cADrXMqIVYe9mAAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="icon_print" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_print.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_print" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIMAADw8PNjY2GZmZvf396/Azu/v7+jo6P///3Nzczw/ROHh4WptcHZ4fGtzc////wAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwAOACwAAAAAEAAQAAAIjgAdCEQAoKBBAAgEKhQI4IDDhwcQ
+        JFzoAICCixgVIIhI0WLGixs5KgwwoKTJAhJTCmSQoKVLBAMMyDQAQGACiA4TxJxZU8BNnAkElCxQAADL
+        nxBbbiQKQOcAly5L3mSagKjVqwVulmwaoKvXr1oHNIVKtuWBrS4PEFhL4EDarUdxuk2wIEDBiUehMqDo
+        ICAAOw==
+</value>
   </data>
-  <data name="icon_tasks" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_tasks.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_tasks" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIYAAAAAAP////39/vv8/gkiTxAwYzhfl2CW0qG30Pf6/fb5/Pn7/fj6/Ozz+ery+PH2
+        +vX5/OXv9uzz+O/1+djo8trp8tzq897r8+Tv9uPu9efx9+z0+fP4+9bn8djo8d7s9OLu9eXw9urz+Ony
+        9+jx9u71+dXn8Nfo8d3s9Nzr89vq8uDt9OTw9uPv9enz+Ofx9uz0+PH3+vX5+9nq8tjp8eLv9efy9+Xw
+        9erz9+nz9/D3+u/2+fP4+u72+fn8/ff7/Pz+/vv9/f7//v///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABDACwAAAAAEAAQAAAIuQCHCBxIsKBAAwgTKlR48ICBFxBfGDhAkSKBgwUMINiIoIDHjxeHGAhgQEAQ
+        HwxkcNBhYEOOkAaEGBiwsIcBBy9gAjHg44cCDjFKwDCggQVMmgkUwhBhIAIImAsMyODxYEIDFzYM1FgB
+        k4EBHgtDGFjxASYEAw92wMjxAkMLAyhUwORgwCbCGyBWGLBQAeYDAzBwkAiR94OBCh5gTliokMYJmBJG
+        aIiQYcWFFDModDABk4Dnz6A/DwkIADs=
+</value>
   </data>
   <data name="ColHeaderName" xml:space="preserve">
     <value>Name</value>
@@ -199,8 +378,16 @@
   <data name="SelectSpatialContext" xml:space="preserve">
     <value>Select Spatial Context</value>
   </data>
-  <data name="ui_splitter_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\ui-splitter-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="ui_splitter_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABD0lEQVQ4T62TsWqEQBCGxwTS
+        JFZpEq0sAj6ARUrtbFLlBWzkIHCkFwtfJV1eTUVEBBER5+bfc8WzusNb+JiZ3f3/HWWXmJn2sEuMg/cb
+        pGlKWZYt+L5P8zAlHgREwvx6H3Sqg61BFEXa4CiJhjB/lYHehBM1a6HOlw6SJPmS4nAr0KlPiOP4RxKe
+        ponHceRhGLjve+66jtu25aZpuK5rrqqKi6LgPM+5LEuedURhGH4HQfB7K9CpDkRInudd4Lou2ba9gHq7
+        B7rFwLIs/edVNAwD/K24WDdNkxzHORusxoPkz8K78CHiT+EfEbXwJrwIj1qzNTBk4Wm+OK+zAK1BiBpi
+        rOMgNe5zlfe8xLt0cALSyt8vnqRT9gAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="NotSessionBasedId" xml:space="preserve">
     <value>Resource ID must not be session based</value>
@@ -208,65 +395,215 @@
   <data name="SaveResourceFirst" xml:space="preserve">
     <value>Please save this resource first</value>
   </data>
-  <data name="layer" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwElEQVQ4T6XS6ytDcRzH8e8z
+        yTMkUUpJLsntP/AP8ERJuSV3kdwe+QvkkrtaybXUMcPmNilmdjEP7IHNZbScmWNnmLtH8/sclvFAR1av
+        zvme832fXRr5/X76D8pu10Ick8sUyoRdNERZbeuQZzrxrlz73iyC79X8G+xgFw1aymxdgyLh7nXP6XnS
+        yoFdNGgpo2UVit23L4Zz4XFNDuyiQUvpzStQ6vI+60/dD8tyYBcNWkpr0kAZ++g6G3+vDnbgvFPq7eKE
+        1no1pN6/7J03851gPPHOoEFLqY1LUH4mPG1Znb4F2D+75Vg0OmfiuznjRZfE8EVn80yhQUspDYtQcex+
+        2GShcvvQMzlvdvVxBr6XM0p6pCPmj2s9Ops4gwYtJdWroOqQv9/YsArj7F0H5ozf9LM5QLrHHjCLBi0l
+        1iqhxuK40ShN/Agz/AnnwTOuS7PO7uHQoKWEag7q9EeiSmV2KQLY11AA5p/nO3ZRhQYtxVfMQgP7ZTUL
+        FteYZO/zGJiDj+wedtGgpZDoZIotmayc3nKssr/o8u6RqP4NdrCLBi1e4WFpuTkR+YNNkQWKDjmwiwYt
+        HhDKRDExf4Qm9B0h5nPvHST9+wAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="gear--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\gear--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="gear--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeklEQVQ4T6WQUUhTURzGz9zm
+        GNMxJSasHFEbKzZDNmhbESNLRnMPc9pzDCKR6ikaFC1EKBEsCvWhslBovtSL4lNmgskV3IVtbrikpWts
+        Tgx6k9CXf+e7d4VGPXXhx/nz/b/v29lhRMT+BykcCARYMBhknZ2dLBwOS2d3d7eX01PFu38HLzLgQEEo
+        FDrDjb38PIxzb2+PdnZ2aL8Gz18LOjo6zkaj0Sfb29sUiUTuctP1zc0yAczQsIMH3gM38Pv9jHOzUChQ
+        IrFM5XKJZmZmPpdKJQKY8/m8tIMH3mpG/gter5f5fL4jXV1d99PpFKVSSVpf/0LF4lcJzNCwgwdeZNxu
+        t1zg8Xh8XLgFJibG89lshiYn4zmHwzEKMEPD7pcPmd8FTqczKooJmp//QEtLAq2srFBLy6kBpVLJAGZo
+        2MEDLzIc+QZ2u/3O4uIizc7OEs5MZpVaW539CoWCAczQ9nuQ4cgFVqu13WKx3APDwyMbyWSWpqffJ12u
+        0zGAGdqFt6Fd1fOmcn3MlECGIxeYzWbW3Nx81Ol0DQmCSHNzH2ltrURbWz8kMEM78cZLV7/fJsX4oYy2
+        z8jYy0a5wGg0gn5BSNHU1DtaWBBpZORFYXk5S+BiPLxri7vJMuGiy9+ukfJx4yYPi2ys8ZlU0NDQAC61
+        tbW/TiQ+kc128qnBYHggCBkCNQ8NlfOVMP0JGzWIUgE+lUrFtFptQKfTDWg0mmM4c7kKf9AiqSL1ScWg
+        PqOI6SuO4jliQ3pR4pFevgHynCYOf1bmAmq1+govGgSYJT2mWzVt2In11aXZcf6LQ3r5DfhXw6nj8Jdh
+        pn/SW/uK9ajT7EbtWDXDfgLZQt8vMfwSKAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="NoWidgetEditorIface" xml:space="preserve">
     <value>The specified editor does not implement the required IWidgetEditor interface</value>
   </data>
-  <data name="control" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\control.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="control" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABeklEQVQ4T2P4//8/AyUYRbP9
+        3BcMDvNezgTiGJtZTxkspj5gMO67yaDXfolBo/4UVotQBEGagPgMFMeQbABIAxCfmfn0/38QbTHlfgxJ
+        LgApBuIzHVd+/5/++P9/ENu490YM0V4AKQTiM/Wnv//P2vbx/4Q7f/+D+LptF2OICgOQIiA+U3Xs6//E
+        tS//hy++/7/hzMf/IDH1upMx2GILJRCVyg8xAPGZtC1P/7tMOvffeeJZMM7f8/w/SJygATJ5OxmA+EzA
+        uif/TWbeBOOE3a/+g8Rk83cRdoFY2kYGID5jufn9f9klr/577f30H8QXT98UAzKcoAsE4lcxAPEZxR2/
+        /5vs//0fxBZMWB0DMlg0qJuwAdwRixmA+Izq/v//QTRP5JIYHvd6BlZJHQYQIOgCFi1/BraguWdAmNWu
+        LIZZTBOsEQYIGgBUyMFkVbyIySi5BMg2AGINIFYAYgkgZifGABagQjEgloJqEgHSAkDMA8QsBA0gJ1sD
+        AE2BbRvnALnyAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="images_stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\images-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="images_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6WRXUiTURjHz03o
+        lK0EE1SwL9JCvJj4dZF14S5sMEVJB13YRYiitpjKbt7cuhGxZJDlLoKapkwqxUVRM9YkEwTPhR8QTENE
+        /ID0ItLEhrp/5znqcFim+MKf83J4nv/v/fEyAOw4YSVWK7vR0LD3NIi7ikPGEFZQYrOxIkWpFF+E4H9C
+        MzS7j1ysKK5+zvH86bV/5pUzA5vBIAwWS5UsOCr5hVOH31tbuG4211CBdN4l6x9wFLRwFNs5DA85bj7m
+        uOXguNfN0ebxS7KrS49fGxvQVVebjuTc+WlEkjvaC/EjEMDV8nIzIw9qHe2N/UtOh+5o5uXAsCQ3N2Vh
+        eX0dOWVldYw8qHWs7yz875Mw+WE7Ux/PYHrgPL55z2HSkyTJLq9Pku+atFhcW0O60Whh5EGtt3VX4LRl
+        YO7zJcwPXsbyRDYCK0b8nNFhYShVkq2vvZLscLuxJIpS9HqFkQe15iYmoiAtFfY76ehpyYR/uFT86Uas
+        fDdhdjBbkmvb+yX5Yn6+75RW26hOTq5g5EGtbnuUSDTePlLjXasGX1wxWPiagHFPHHzPToaRL+TlNTPG
+        EkRUjDyo9UltZChtdSo476sw9EaN3tYoOOoj95FPaDRiXzzkQT7zq6sHhmbCyNvrjJEH+RwmNBsi7xaI
+        M0IkfseJvA6Kas+efP0DD+tcAk1PV7wAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="icon_zoomout_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomout_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomout_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZpAJySh3aFlJ6tvO7z9eDPvpubm+ru8LKysqGhoZ2dncvFwOLm6Z+fn+ru8dbc4t/j
+        56ioqNvf5KOjo+bp68rT3Kqqqp6ensnKyufr7tDX38rQ2MPIzre3t62trfL29+7y9brBybjAyMPJzsDK
+        0trf48XL0s3Q0sDBxO3x9Lu8vLy9va62wLm5uf39/ebp7aWlpc3Nzautrs/Pz9Pe49HY39bd4qyyt5+m
+        rtLY3K+vr8nP1NHX3bOzs9PZ4Nvg5czU3K24w83V3crS2uXp7OTo7JycnNDe47e+x+Hl6Ovv8rm7vL7F
+        y6Kkpefq7dff5M/a4M7d48vT3M7W3ujs75+goOTo6/b4+aWmp5qamtXX2NDQ0MrDv7O2uc3S15GSk9Td
+        47rCy7CwsM3e49fZ2qKiora2tqiim/H09t7i5gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABpACwAAAAAEAAQAAAIwADTCEyTIwGWAi+0DFyYhoOECxMGGBhzoALDNGU6GBgw4EOSKS5U8GBIxkAL
+        KygaYBiy4MEBGQPDXBjg4YzKKkjQRDBhUSCDiAKCChXgYAeDgQUGEAnAtGkAGlIsDLTQBEeXlj6cfMkQ
+        RAOCgRCy6NhAIkKNGUagUDjBYiCMAyKWlHDQ44mYEUK+LpQQA8QRMD+iULiBIMUWhhCY2FgBJASXBF7M
+        EFDAUAmVIgUSXBEIAMDki6A7fwbNUDTpi50DAgA7
+</value>
   </data>
-  <data name="sql-join-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\sql-join-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="sql-join-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADAUlEQVQ4T6WT+0uTURyHXwz6
+        IUgzu1lQUJIilqhBWQRqZlZkaqvUnMIMiw00NS94WUt0DtFlqVPUzOmc2hyjubmL13mZl3LL6dTNrXev
+        c+/mZumWBklg5639Bx54+By+53ye89OBdnd3ob2wpzL2MBT1Qg3FFyAQocTq85S63gyAATtYplBtzMii
+        rzFBuX33AfHOvBKYI3UNyJZA/lmi/4K4fDj2SRFiLmqwmhv5mzru8NZKGcumTCw2zCWQDRtM0dqYzfFb
+        gdh+ibvkRkZkiQwPBKf/CSKJSp976SpzJduq7xhwLLH7HQttUruaUKHntYg25+kd1pXoTJVjVPV90mDd
+        lq6sbw+qjfbum8VDyUDgBl1NHG4m0ZbM7X2OBZbUPg8Ei3mNxsESFjqOzTBItEULkaqAgaBfZ9kSwdbt
+        vrYRmHEhQ3gd8oviw5VsVNsi3lRhAIEmoXSxp0mwoXzLXR8rY1v7ChuQzwE4waZAgVazRpFS7tRqhVyz
+        3uqbxo+DvCI4O0zxxnKTcEOJ0SqxL9zNn+VVfrTJCt6jfAwae03mdYvzRzCD1jOkOjJDonvVqzQ3eJN4
+        qdDZcC5cxlxdquf/mAGlsfJOm+wBZU5IZVtkeU2mHozsmm/T3nd4ds6EsaZKqKVU9Wop3Elj7blnnCTI
+        +7a4ObFAhZZ3WkdzGkyCog9myfM3y/0ZDHiooBkVYeCylStR6aPaeqm+vPyT5nWtWEejdCrpZ1I6IqCL
+        0XKfQNyUJY2OKPMaTaKsemNPcSs6EkOeFYEcT6cb5i49mvxZwdF2FXerKZU9mjLmkL7al9iVcSq57TDk
+        6ZsK+d5ojb2G11jwZAR5yTBNU9stEyQ6/CWMqNYG4xccmdWLA92TxpYPg/q63Japd+dT27Pdw3O9D/rH
+        QNjaBzhy3AsXcRkn54QQTEhoinknlIAaguMVnBMhZJLHw7oMj8eNhR642ky3sJyk/Z5+QVjH2YVcwOaA
+        c3ASpCfgKOAQwNWJO8hjzjPsDlbGOi57/0x7+cpY9y8yIme1LfwcuAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="FiletypeZip" xml:space="preserve">
     <value>Zip files ({0})</value>
-    <comment>The text displayed when browsing for zip files</comment>
   </data>
-  <data name="magnifier" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\magnifier.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="magnifier" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACPklEQVQ4T2Pw8/NjwIYDAwMZ
+        QkJCBENDQx2AOAqIU6G0A0gcJA/Sh1UzSAKoQDEuITlpyuKN3UevPlt//9WX4zcfv926aM22PpA4SB5s
+        gI+PDwb29fUVjIqNT1l38OrCIzdeH3r05tvZJ2+/nQNhEHvHiZtLomMTUkDqGDw9PbFh54nz1/btvvTi
+        wNXHH0/ANMPoa08+nZi+ZMNEoF5nBmdnrDhh2+kHa0AG4MIHLz/ZBNSbwGBnZ4cN5++78nIfTDO6C0D8
+        E7ffHgXqzWewsLDAhlP3nH+4EWQANs0gsVM3nu8A6k1lMDQ0xIY9J89dMX3/1VeH77/8ehrdEGBAnpu3
+        bO1coF5PBicnJwYHBwewN2xtbRlsbGwYzM3NVVzc3KuPXLy37+azzygGPHv//eLlm/d3WNvYlqipqYlg
+        GGBtbS0PNKR47dr1/zU0tdsnTp+79PGLd0fefv557emr90fnLVi8UkNDs1ZQUFBLTk6OAcUAoEYtNzf3
+        mh079vwXFRVrZmFh0QLiMCCuBOJ2KA3ii/Hx8TGgGAB0vkVgYHDbkSNn/isqKvUAFakCMQMuzMXFxcDB
+        wcEA8793QkLKhIsX7/7X0zOYBtRkzMzMzMDIyMjAxMSEgRmQAcgZwEAruXXr1X97e+d5QM0uII2kAA5R
+        UVEXERGRFqDmbKBGfSDWAWINIFYBYnkglgZiMSAWBGIeIAa6nYEViJlAFrFAJaWAtCQQS0D5IkBaCIgF
+        gJgPiLmBmBOI2aB6mIE0IwDSnmBluZcHuwAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="NewFolder" xml:space="preserve">
     <value>New folder</value>
-    <comment>The default name of a new folder</comment>
   </data>
-  <data name="grid" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\grid.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="grid" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAApklEQVQ4T6WTMQrCQBBFZ0+Q
+        NljkrjYpU3oKEUFQhBQpAjZewAt4jXX+kpG/3V8S+PAW/r6dKWI5Z9sTSykhR8+5IeiXh0Nw2UQ4y8yC
+        KwlkZsHNBZFRYHSrFe40gcw8wZMEMrNgdkFkEhjdaoWFJpCZJ1hJIDMLXi6InARGt1rhTRPIXCbYvs+f
+        zGQOweCXH55vQ9AfQtD5ofccGoJ+VwR7fmXc/QGbydmsomqW4QAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="document--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB20lEQVQ4T42SO0hbYRTHz2jo
+        5qBZOgiJgwgl6dAgqCAIBlQqRnBQQTDGoEFuCAbfIkK3Lg5GXLUdOrVD3IVujjo4lYpRkeAj7/fxfy45
+        i4+rH/zg3sv3/3HOuYd8a2skjKyvD4DpN3AMr67S0NISfV1cpMHxTiL5UCeQrVT4rljkm1yOE5kMn6fT
+        /D+VMvl9dMS4FwBOFYjEtNWZSZdKnETw6uGB/yWTfHZ9zaeXl3ySSPBBPM5ycHcGOCVsCgajUSWYgeA2
+        m31Rsr2/z4rT610BJFB/JKLM5splvkf5r0mkEmkHmVnNUZ9hKHN5zCCVz1tKRIDMnOaoNxRSQgUIMoWC
+        pUQGi0xIc9QTDCrzpWqVc5iDlUT+DjLzmqMuv18xyhAUMAcryQ1aRMbQHHVMTirhSq3GRbRhJZE9QSYs
+        OcPlIvoyNqZEqhBIFVaSFFpEJvLdbqefhPN5dFRZqGFRKhA8lfydmuK4y2Vy6Hbzns12gfDxD6JdcnR3
+        0yefT4jKptVQxVPJL4TyExPPiEEiRdBHj4davd5lc1dfkPzx+3kHEiEGFhoaEhsIb0kFODbQ1OzxbKrA
+        lACZiQxWWpJfLHtSxLvclUw9S414aLe1tIQ/tLV9ew9yVzKg8REGvINQesvmrAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="ScaleRange" xml:space="preserve">
     <value>Scale Range</value>
   </data>
-  <data name="table--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\table--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="table--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACLUlEQVQ4T52ST0iTYRzHn0vB
+        qK4h3YQu4aEOFmMYmQ461ASTdRDyojRzltFbzFZrik2DIKJDdik6dAg6BHXokIo61prOVzfX2GROUZes
+        xXRs7/64d/v2/F7aG4MdxAe+vL/fC58vH573ZUa73cBz44AxsA6bzYQDHmJZu9XaW+YFei/QOl9Gy1wJ
+        Fz0yLrj3cN6VR5MzC92sBO10GuemUjg7uYvGiR0QQyxrs1j65HJZKXiahFLgSMh48ruoFNhjWdg2M0qB
+        dT2FweiOUkAMseyyIJgLpZJq0CNKcPgTGFmKY1jcxpA3hsfzW3jk2YDVvY4H39cw6IqCGGLZpYGBWzlZ
+        Vg1G/X+wx3eKKxhU52mfT50nFhZADLFMbzbfzhSLqgEVeFZW4A6FsBSNwhkIYHZ5GV7+bmpxEZOiCCpQ
+        GM6yZpPpTqpQqDKQ+E4hg8pMBpWZCoghljV1d99N5vM1DcTVVdVgLhyuMiCGWKbt6hISuVyVQYrvFDKo
+        zGRA8+hMEs+/BUEMsayxs/N+PJutaeCNRFSDH/xO6A6uvoso+Rjgn5Oz7IzRaPklSVUGSb5TyODh5zUY
+        34Rx5ZVfeVLGY0AHf57uf/GBnTIYrFuZTE0DKmh95sbLTaDvJ3Dd9z9CCDh572uM1el0w3F+oxvpdM30
+        v/eh2TFTFa2L/7FjTtS1C5+Ypr7+5pGGhrH95ti119uUoy09X4hl/Gh4jvOc2E8Ot42/PaQf6f3HaP4C
+        dRjFo//0njYAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="blueprints" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\blueprints.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="blueprints" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACLklEQVQ4T4WSTUhUURTHz8q2
+        BW2azURMJFkQBIEQjqsoaJHmQIuWWREMlZl9qOnCTS6UgoohZ1pUZpPDUFEUVkrqaM2FMiVnkomk6cOQ
+        t3Dec56r0/lfmsfzMdWFH9zLfed/fufyKBhboNpbvzTY/zlH5KzKURUKBbY2NFBlfT1tqaujUoETUtP3
+        gwTVNlnkxNwKnxle5lMvinxyqMiHB/IsxceEwF8DYLA7klfJ3AqPfrV54KPF/TMW3/lg8YG+DGNJ8XFh
+        s9tglXIw+tPaf2+RQ/FFPprI6pATTw2u6U45+MLPlEDQ/adyy+0n3JjIcPfEkg6BCcbZdTWnBILuf5XD
+        0UfcOJjh8HNDj4M32dmTVQJR9fV5oC6mTI7P4tIoq1zVPurc4WF3XJ5RAhE0oNM6UeB4xnJCvMp7o/N8
+        +qXB96VJy2uLt3W9UwIRNKDTNlngsbzNTa8Mvjll6m5u5dobOafB+TGTKzvTSiCCBnTa3xR4MGvxAwEh
+        6FYaB8r7InPyTxg65MK4yYHWlBKIoAGdS28LPP7N5uYRQ3/Yk15apbzn2qxuAMtkzuaNZ0eUQAQN6HSk
+        xeCTpQNi06bTDQ8L5ereaYblw882d6plXn8kqSp824mgAZ0O6ZiQgFIIurmV/c3D1pqDMVWiIniun4g2
+        0YZDVwg6j7/YnPpu6xCMggC3sr9paEoKfB7WyZnWQqfrvckIgQnGwZt4leVbXeBdftG569Yrt3eUPdW/
+        Ab7ReT9BDLTyAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="LayerGroupConvertedToBaseLayerGroup" xml:space="preserve">
     <value>Layer Group ({0}) successfully converted to Base Layer Group ({1})</value>
   </data>
-  <data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="server" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABaUlEQVQ4T42SMWvCUBRGr+LU
+        jqVQujh1dtDFxSVDBhFB9DdokCAigpNDBscundw7+A8cRDAEFKQiySAYXESy+Ceu95Z3H0IerYGTId+5
+        ZwogIjSbzV9arVaNaP9DTXy+BX41Gg2hc71eMUkSI7yR2xFfB+r1Oiicy+WCcRwb4Y08R3wdqFaroOj6
+        vo/r9doIb+R1xdcB27ZB4Z7PZzydTkZ4I88VXwcsywJF73g84n6/N8IbeT3xdaBSqYCiP5/PcbFYGOGN
+        vL74OlAul0ExOBwOGIahEd7IG4ivA6VSCRTD3W6HQRCkmE6nyBt5Q/F1oFAogGK03W5xtVqliKIIeSNv
+        JL4O5PN5UIw3mw0ul0sjvJE3Fl8HstksKGb0G+NfkDcTXwcymQzkcjnmy3VddBwnRfGniLyxwy7f6ADQ
+        Q9UPGj4nkwl6nmeEN3bY5Zv7wAsV2zR8PwK5Hbp/vQ880Yc34v1B2H3mwA1XqPmpzb5U7wAAAABJRU5E
+        rkJggg==
+</value>
   </data>
-  <data name="icon_printablepage" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_printablepage.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_printablepage" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZ+ANbn9xExZEtypa3D3q+xyP///6irvlVgfLfH3E5Sb+/w9vz8/fb2+WBedoGPsO7x
+        9pifyZygqWNohGluipiYpPDy9rW91Kusvm1rgd7e6r3D2X2CpuXq8Ors8r/F24qLnfr5/2lviJKexoCC
+        oe7z93h/jm1ngn2HpW55jE1Sb/37/FFWdEtQbk9Qb9nZ4dvd6naBm0xTb/f5+k1VfPv9/HeDpfLy936B
+        j2xuhnFzh1ldeoSLnYaIlc7Q3YyVsvb3+kpRbVFRc9TZ34yMmJ2iqP78/ZSdxHV6l2Rqgbu90v3//rS+
+        1+zu8/z79+Tn7tjf6ZWdwk9QbH2CmP///tXW6rG2yoiMl3V7kHd4jExSbHZ0i9rZ3mBiirO4zPv7/MjL
+        1LC3yktQbVFQcG15jpqZp295kU1UcObq87SxwqGrxICDqJeeyExRbpmdyllYd8fO4aqrr05Rcmx5mOTn
+        70xTcPz++3V4mLS4xHV4llBQcvz7+amotktSbqGktf///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AAB+ACwAAAAAEAAQAAAI1gD9CBQooKDBggMT+hFQoGFDAQACKIxQAgcWABgBQBwg0Q+RGxRcFNljJeNG
+        jibIbCmwQIYKLSYDyAwAB8kULz9sMPkyJOOAnxKv7GBQocMcAjkyYuQoUIICAlAJcJkwxmdHKVANaD3Q
+        xUOIpRLpnBhhQM6BAz7s1LnTAADHFkua4IFxIE0GKmeeoHHjNkCQNRZAHHFCAgyKBGXY8AAaxgiENxxq
+        ZOHTRoMQHTMDABEB5YWDGUmU6KHxQAwGBKj95EkRIw6LFVV6fEig5oJChVHMbOijMCAAOw==
+</value>
   </data>
   <data name="InfiniteValue" xml:space="preserve">
     <value>infinite</value>
-    <comment>A value that is displayed when the value assigned is infinite</comment>
   </data>
   <data name="RequiredServiceNotSupported" xml:space="preserve">
     <value>This connection does not support required service: </value>
@@ -277,20 +614,60 @@
   <data name="LastUpdated" xml:space="preserve">
     <value>Last Updated: </value>
   </data>
-  <data name="printer" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\printer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="printer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACYklEQVQ4T42SX0hTYRjGX1To
+        omIggdDVLvJi5o0IJjrI5ZgtNuG4KVsodtPZGSNScirHzY2mTIQSDPVK8MKBN6JSyVTUGAkTuqyLBInU
+        iQRZ+OdChz5978nBxJTew+/84/c853zwkbO7mzLUh0J2gXwJdxzBIEldXecgfpmF51c6jdTBATb29/F9
+        b09jJpGAcDyCwgsFkqpSFsrvoyNs7O7i684Ovmxv43MqhdjsLHiEp1hbW/UmRSGmzuMhcjgcVCfLVNvR
+        wXj3j4/xQ3w1u+TN+DgyFFqtAQE9qK/XstrJ6XSSo6mJbG1tvgNR8PPw8EIJ/wkvhx12tcxZQY54sAs8
+        eXl5r/x+P66CHXY5IwpySJKkW6qqhnbEmhVFQSQSQTAYvEAgEEA4HNacra0tdHZ2hjhLNpvNMDg4OLa2
+        tgaXy4X29nbIsozm5mZIUh2qq82orDSirOwerNZHmjM3t4yent4xzlJNTU3V5OTk8urqKsxmswh7YLFY
+        YTRWieD9c5jNDzVnZmYBAwPDy5wlk8nkSiaT60tLSygpKUFDQ6OQ7P/EYqnVHFkcExPv1zlLFRUVz+Lx
+        OGKxGPR6PZzOJ7DbH18KO6Ojo5iamgJnqbS01J9IfMT0dBw+33P09w+jr28I0ehwFiPi/i9ebysWFj5p
+        cJYMBoO6uLiC+fkVuN3u/yJTwFnS6XQt+fn5vUxubm5fSmyY6mgKr9+mMPTuAypfuHG3UYXRO4Jvm5tg
+        J+NzlsTcFNxmCsrLX2qbPmtOTk/BpE9OkBZXdjL+WZY7iK4VFNCN4uKn14uKolfBDruZ+QOvqgI74xfB
+        qAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="InvalidResourceId" xml:space="preserve">
     <value>Not a valid resource identifier</value>
   </data>
-  <data name="document--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACMklEQVQ4T4WSTWgTURDHZ4/V
+        Ww4KhRwCjWgIegjFrVLbSq1djaKYQg/10ENMQxs0JRhSbRu8iBc9eBLUXuJFlFCsi7YiGL/wXrURTGgw
+        aZRQbb423+PMtg+CtPHBD5bH/H/Mmx1wzMwAMzQ7e4a49B86LkxPw/mpKTgXCMD+7m4AvtjCVajV8He5
+        jL+KRUzm85jI5XA1m9WZj0SQ6lyEWQhYotu2GMtVKpih4NrGBsYzGYym0/g5lcLlZBIfqSryodoxwsxh
+        XXDW7xe48yRYLxS2ldwNhVBgVpTrBDBg9/kE48VqFf9Q+ztJuBN+DmXGRQ4GvV7BhEYzyGpaSwkLKDPB
+        uVtdXQAnPB6Bp0SCfKnUUsKDpYxn0WiET5IEcNztFlyu1OtYpDm0kvDfuWK334lJUviDJPXCMadT4K2S
+        oERzaCVZjsXQ2d+vYjCI85L0Bo6Mjgoma40GlukZO0ni8Zf4OBxGjeY00N5+ew5gAA6PjAh8dRJwF9tJ
+        EqtLGHk2iFoqgAc6O18YDIaD94GObXhYcLVBi1Ijwb+SZOIVvl1Q9PCTh314+uLReyabDVxWK0BHTw8c
+        cjgYP29ag7polqR/vMZ3C6c2ww968Vt0EbmWM5zVj1GWYZ+iXNN3tUmy/vMrvn++GX5K4ZUvKvKycS1n
+        xGmjjz17ZfmGEOgS4qMaRMxHMTzXh9+jS8h7UqYOuZYzBGfBQFjbTKbJ3RbLzWboHodO7lqxyMZQ8z3X
+        coazfwEpq4JeDHDvFwAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="PromptDeleteWidgetAndReferences" xml:space="preserve">
     <value>Delete this widget and all references to it?</value>
   </data>
-  <data name="gear" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\gear.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="gear" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHElEQVQ4T6WQT4gScRTHf66K
+        iB30YlEpEcoSaiwjhFMHYWGR1IP/7uEpIjoFQlEdFmIJOhRrpy4t1N538ZRtC5vMgiPoOpIt2WYybot3
+        Cby83nfIYRaCDg18eI/v+36/MyqISPwPRjidTotsNivy+bwoFArGLJVKMnP7D7L1Bi8yyJ4qyOVy19l4
+        h+cFzNlsRtPplKwaPH8tyGQyNyqVyovJZELlcvkhm+4eH48JYIeGGzzwnvqCVColmHvD4ZBUtUnjsU61
+        Wu2rrusEsA8GA+MGD7zImD9BlmWRTCYvFovFJwcHHep02nR09I1Gox8G2KHhBg+8yJgFiUQiycJ9sLHx
+        ZtDrabS5+a4fjUZfAezQcJv7kDELJEmqtFoq7e5+pP19hbrdLsViV9fsdrsA2KHhBg+8yJgFkUjkQaPR
+        oHq9Tpia9pmWlqRVm80mAHZoVg8yZkE4HF4JhUKPwPp69Xu73aPt7Q/tePzaY4AdGm5zHzJmQTAYFIFA
+        4JIkxZ8rSot2dj7R4aFOJye/DLBDww0eeJExC/x+v2BWFaVDW1vvaW+vRdXq62Gz2SOAHRpu8MCLjFng
+        8/kEc3N5eeWtqn6hxcUrL71e71NF0TigEXZouMEDLzJmgeDH4XAIt9ud9ng8ay6X6zJmv/+T/9ARWTV4
+        4MVjLYBylokwceB0Om9x0TOAfa7zjDHn8E5rwQILZxg/c/4f4EXwLqDgN4SU6ia8nlT3AAAAAElFTkSu
+        QmCC
+</value>
   </data>
   <data name="AggregateQuery" xml:space="preserve">
     <value>Aggregate Query</value>
@@ -301,80 +678,300 @@
   <data name="FilterPng" xml:space="preserve">
     <value>Portable Network Graphics (*.png)|*.png</value>
   </data>
-  <data name="icon_zoomin" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZeAEV2qAE0Zm1LJt7s9eqvdrK8xtfk7LOcjF1dXdDc45i101lZWaOmqX+AgF9fX4ep
+        xc7b57GxsY+Rk3JycnyWsWNjZK+vr1xcXMvLy19hY2mGp6urq2SHreXx96C61YGYsnFxcc3a5lpbW3p6
+        enmTsGVlZcfU4GNjY2ZmZnt7e6DP4X5/gIuLi5Kov21+kXplTnF3fJOluFJrhfz9/Wlpaaewuam80brK
+        28PP3bGai5qzzsHP3ZvO4prU5WJjZImetJyvwbvJ2FtcXYCAgIeNkkZJTFlZWsfHx2RkZG5vcJGkuIWF
+        hWdrb+Pv9dLe546QkZuxyYeHh8jV4WNobLnAxez0+dPh63d4eLW8wZKYoVdXV25ublxdXnuFjwAAAAAA
+        AABeACwAAAAAEAAQAAAIsgC9CMQw4oKWBTQiCFy4MEoJBgkGGKDSYAJDgUuuGBgAIAAAKxAkDGF4BImB
+        GVU6AgghBccKCwtTMBjQoYlKEztu1ACx0EECAEBVBrXhYOGCAQGSKlXqAcFCBE6CCgUK5cTCLViAKAmi
+        UgUPBVlYLNzQIMaPFip7PNBR4SIKGB9IqFQgw8eTHBeTTHGhgQOFLlyKvCBw4CKRDCKMCGHipYAAAYQv
+        Sm78OPJkho4hX76YOSAAOw==
+</value>
   </data>
-  <data name="ui_menu" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\ui-menu.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="ui_menu" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABG0lEQVQ4T53OvYqDQBDA8anS
+        iO0VV+YVxCCxt7OyEbnC6hK4T0E4swiGIFgIQQiE+Bq+kVXQRCFIuujcTp7AdeBfbPGbHdhutybvfWIm
+        hGG4wolDFjabzWoYBjydTtj3/ejIkAXf99cEH4+HUGTIgqZp6zzPnxccj0c8HA6YZRnu93tM0xSTJME4
+        jnG322EURcjPRsYYBkGAy+WSwWKxeC6gEV3AP2egKMrkC1RVZeC67sf9fseu64QiQxYcx/m83W7oeR5e
+        r9fRkSELlmV90aNtW6HIkAXTNL+LosApkQXDMH6apsG6roUiQxZ0Xf+tqgpt28ayLEdHhizM53P/crng
+        +XwWigxZkCTpTZblvymRBT4z3gvvVTAys38hdsO4G3bw/gAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="TitleNewFeatureClass" xml:space="preserve">
     <value>New Feature Class</value>
   </data>
-  <data name="icon_help_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_help_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_help_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIezAPLy8o2cqvj4+JKfq8LK0pWirvf395mlsf///8bT36m1wbO+yay4xPHw76q2waKv
+        vKe1wo+cqK+7xvT5+5yotLTAy+rz+LK+yOfr7qWxvJqpt/r8/d/k6Ku3w8fS3pSirrC9ybC8yODq84qT
+        oaezvvn8/bG8yc7V26CsuLa/yJOgrN3i5/L09ff4+Ke1xNzh5cPP25als93j6JWir6y7yfj7/JqnsrzF
+        zu71+fP2+NXb4d7o8crV4JGfrLbCzbC8x8PQ3Pb8/L/GzLG6w8HK0rfDzpGdqZShrsnV4J2qtZ6qtZyo
+        s5SgrLC9ysHIztPg7MHK1dvm8b/L17fAyb7J1L7K1Ky5xtjc4Kizvaa0wcXR3bfF0IyXpY6cqYybp/r9
+        /aSwvLbBzIyZp6u5x6q4xp6ruK25xLvG0ery+Ku3wouVo8XO1qi0wIuUosnV4Z2ruJKhr7bDz7bDzrbC
+        zsrQ1uLq86q0vezz+Jentq+3wbW+x/T3+bTC0J2pttLW2tvg5Z+ruZyntMzX4bTBzbvH0qexuqayvsbR
+        3J+suM/U2cXS3bfE0IyXpuDk6ay1vtXZ3vX3+brG0bS/yq26x5uotcLN2IuWo7S8xtLY3c3Y4uHl6rzI
+        1LW9xPX19Jqns5uns622v+ft8+fs8tnk76e0wbC7yJGeqp6qtsvW4Oz1+IuTo/T7+4+dqs/T2MfU4aGu
+        urO8xbzI06Cvvv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACzACwAAAAAEAAQAAAI/wBnzerUQoDBgwIMKGwgEJKrBIqA
+        8KFBxsWYSRAgEJgFwA2STB7i6NAkY4WkLD/MwCEAIIEgHrFY1EGDQ8SGGw8clEkBQAuqRRxGhXpxQtST
+        PSjAeJoCAMahOTm+YJCFJ9GOCVj6zNADQEolQlDWVDAR40qUGkoo9bgEYFMVKnJAhHjz6M4qOqwodBkC
+        YEukMz4WPMBkYUIrRp9siMkDYFCRMAsYZCiRyo8qCgcKcAEFoEmFCxIUvPrTKNCHzCosOQJgpZSENCQA
+        weKU5EiBAaZG2AFAikEHNoiWIAjiRA0TIxEGFAKgQYEDQ6cOIEAgpM2ACF4GbCQSoLv37wO0CwpsAKC8
+        +fPlBQYEADs=
+</value>
   </data>
-  <data name="icon_panleft" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_panleft.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_panleft" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIeDAJhpZZpqZiJNeNikptelprG+zCBPfSJNdyJOfVJvjMybl9Kgn7ShnSNOeCJPea2f
+        nq6entWjojVkl6CBgB9NfjVjlB5OftOnqDJejp1xbp9wbM6cnbWEgbaGhKh3eJBkYbeKh9CdnM2jpMeU
+        kcCNirqIi9qoqZ5ybdOfodSmptenpbuKhriHg6uWkyNQeq59fNakpciYljZklaB1dCtXhTFhkC1Zid2m
+        qdilpJlxbah2cyBPe////9ioqLCRjtCdmrKiotuop8OWkaZ0c3+hvdmhpMyZlipZhkFiirWgnd2prcGP
+        jvXm6TNfjcmdmtShoMKPjoKVs9KanbmTkrqIiaiOjVFwjNulpZJnZqNwcpd0dE9wkGF8mNimpdimp7GR
+        kvfk6MeVlKyfqcSSkd6rqDVjk9KeoqGEgbyWk5emu36SscSUkjFfj8WUkDdlltOaoDJeirqurqOPjiBM
+        eax/f9Ghn8aUkyBOf9yorNympKJybtKeoMOTkcuYlShYh6R/fpx6eL6KjL6LigAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwQAHCRxIcFCBBAUTCnQhQECDAwcG
+        2fESYEqVggcHitAh5AoAMjPiKBw0oUeAEQMAKPkDQeEZOgQArMEBAI+TLwpzcMgToM2ADjdS+FD4IUwX
+        Fj/e7DFxgYFCDSpgbAiBoggBNAU9xKiTZYmUBWaeRAgihmASLEYUvCghaEwfPmDSWCEIBNAKKCBIUAnE
+        JEoZP1sKthiS4YQeHmqOVKhBA0nCB3K0EDFwp4kEDBZGDuKCAMEcG27gaB7EhsIOBwZkBAQAOw==
+</value>
   </data>
-  <data name="icon_popupscrolldown_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_popupscrolldown_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_popupscrolldown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
+        /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
+        mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
+        /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
+        MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
+        mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
+        /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
+        M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
+        mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
+        /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
+        M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
+        mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
+        /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAIMQAfCBxIsKDBgwgTKlzIUCCChxAj
+        SkTwYKJFig4vQiyoESNHiwknLozY8GHDkygbBgQAOw==
+</value>
   </data>
   <data name="SpecifySecondaryFeatureSource" xml:space="preserve">
     <value>Please specify the secondary feature source</value>
   </data>
-  <data name="globe--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\globe--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="globe--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADYklEQVQ4T32QfUxTZxTGX1td
+        ZgyaLDHoMg1+sAFzkxSVKqYR/IBtBjRZ5nS0cy6KVhNiQIgmfiGFUKgojEFTIGABJ9qNKXUFnPsDUUpp
+        a6VNqVTrFy1YCVDEdBX77NxK4h8mu8kv573nPM/znnsZL/sO4+UaGP/MAOMXPv6QLx/cxC92y4krRMd0
+        lYf63Jx0nD7kI94euIA8RwQNlfHVT8yFt154m2w+/1WHL2gcn/I3Ol95Nze5zdyc070fkKOPmHfS3JJ5
+        7Yn7sn0Uvb4pNNrGoTKN4vZzP+wBwP4vcNYw4uZ0PNK/2yBDO5snba/NbHngKer0oN3jp4AgGq2j0Dh8
+        6Bz2o2dsCj2TwO2XQEGn28PpeZwvQ8vYjPSm5JhjOtuPl+5j/1UX6h0vkXfzGY7//QwX+yfwzwhwQuuE
+        mvq/DwFXnr5G5JHrNs43Y5eaArZXlklqTKMptXZsrutHmrofO5qdEGse4kCLC+l195BarkepJYBjlLZH
+        8wi7SM/5CMZYcpHusHYokFhhxcpSI4RVViSorBBV27C+wgyJxo3crjc41DEJUakJscUGfF1lCnA+ggIS
+        T+uFJ28EN9YOIlKmR1SJEdElJsQoTIiWGyCQmyA6Z8e3mkksym6DQEHhJd1BzkdQwIZTbQlyQ2BJXjeW
+        F/YikgyfTRNFNTK/G2vOObGlcRKLM9vwjQbYrh4OcD6CAjbKfvk8Vzf2adE9RBX3YcVZK2JLrRCct4WI
+        VVgQf96JlfkWJCiHkKQeh6h8YILzERSQovjqI7H6fhyJBMS6iodIUrqQXO1CSs0jbFG5kFjpxOoCM767
+        DohUbsQp7P6IrBtnwjP+oIDUX2ezbcqGqBM93iSlB6l1w9jZ9By7m734+bIXieUDiFfYsaqIfi6d44r7
+        XlcOAl8WWExfyO6mM7bjAmPfNyydKW5uFxRavZLfxnCwxYes1gnkaCcQJzOi7CkgtQFiyzuy+oFlRzt7
+        aQV6wmPoU/KXsp/+bPgkp8uRphock2rGA0daXwWFMuObZdk3pxYc1PnnH2gdCZdq+4RdwAKptnfhob9o
+        A8b4xHwimoWFC9nafXuZpLmW7dN1sIx2fahy71yf5mE7661hPzTcnSu+KKGQ0P08Ys50yMdU/5cP0qpq
+        Zm0t2z3tY/8BOAMvdn6kKfgAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="drive-download" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\drive-download.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="drive-download" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACTklEQVQ4T42OXWhSYRjHH4KK
+        iBNkX9AHWx9QeaQuDpTsZgu7CsRJGjIcqyAFiY0xhm7RFqxTdLPoqtjCm+jCPsCwUhtL86O0nRo2zZy5
+        tXWR3qztYuUkfHqfsSOOsdWRHzz+n9//4YV6ZwFWQXB+xwYxUW5ge2E1D47d/FTh+K0xqLs7LWO79/XP
+        9Y7AvMgym5yTU92B2s5AhQOOEBy9NgJCf4Z4fCe1kLJ6ZlJsfkQZ7cip7qw4cKg7CoevxoDv+yj1vZ/D
+        M4NfkGbKaLfmgf32N7eZ4FtCsoVmUHV/Atl/Sc7JWfaCvW2vQGZPq9988Eoo1Z4o4SVpAQXfPG5zzWH9
+        8C80RH9jjSOYJKe6UylTuPuyFxQXn5p3tfuT2pEybveWcd2zMqqCZdzR5kvSjpxlB060iECcPH8Djlic
+        sPXCE9hsemDeYnUn66KItcOInMWdpIx25JAr90Cn0y2i1+vBaDTCaZMN9p3rh/WNg+aNLa6xDQyaKaMd
+        OeTKvRUHSCBOnbUA39hZQ9As52sd4AwGQxPD+g+a2Au4ygu0Wi0s0RwOh8cTiQTG4zEMBl+j1/sSPR4P
+        4znDzwigy/VinPnNcg8EQQCNRkO0lkolLBaLODv7E/P5Hzg19Q1zuRxjgjGNkpTGTCaP5FKHuosfz/Og
+        Vqs7CoUCut1uFEURe3t7sKvLgXY70cMQ0cJ+sVgayaWO/G1iw06lUtnNnjuZzWYxnf6Mo6MfmPwOI5EI
+        I8qI49DQWxwYeDhJLnUY1AUFQ8VxnEmhUIj/A7nUoe5fouy03kA6Jw4AAAAASUVORK5CYII=
+</value>
   </data>
   <data name="QualitativeName" xml:space="preserve">
     <value>Qualitative</value>
-    <comment>A display name for the Qualitative data type</comment>
   </data>
-  <data name="funnel" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\funnel.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="funnel" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB9klEQVQ4T6WT30uaYRTHj7/w
+        FzLyQnFC4Mgh4hgs9B8QvJH0vxDqJhiDRYMuNsaoi6Cr3bSgaIHMNghrUhmZliwpMXCMGAoyJNzNbnf1
+        3TkvzxtKNoJe+MDzvDznc85zzvsSALoPWnA6nZ6IRCIZm82WISJhinllNBrnnU7nvNfrfRsMBuei0ejL
+        eDw+zefTelJdkOn1euh2u2i1Wmg2mzg9Pcf2dgWFwjdUKt9xcfEL7fYfXF39BcdP3hBIBaVSCfl8Htls
+        FsvLH7CwsITFxfe8/ojNzR3s7x9DVTAoSCaTJIJOp4N6vY5iscjZv3LgJ6yt5Xld5Yp+4vLytyZIpVLX
+        fdMWsVhMBGPSg0ajgXK5jN3dPays5LCxUeDM5zg7a0P1IJRIJIYKiAVj0sRarYbDwxJWVz8jlztAtfoD
+        qolhroD+J+B4EsnUyUkV6+tfsLVVgZrCE66A7iIQyWMZo0xBjfEpV0C3Cvx+P3k8HjKbzRKsP9cCt9tN
+        Pp+PAoEAhUIhCofDgz3ojxomcLlcpONwOMhqtd5JMKuu8K4/WE8w8CH1V2AwGEjxQgR2u31OsvKEBgq9
+        VSCn+B8QnovAYrHMMDduOUxg4lMPGB/zkJk5OmrAZDLNqr28G2G0Tg8TSJpR5hkzzrxm3vB1Umov7x4x
+        2l10wT8uhpNvS0oRDQAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="sort-number" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\sort-number.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="sort-number" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABuElEQVQ4T42TTUsCYRSFJwMJ
+        QWoXCFKEtAhqE/4EN4E7V+nGELUsAyUcUdC9W8Ef4cKtG3+BuJGgtQiCX/iFIn7d7rk5Mg4JCg/nfe89
+        58yIqKiqqiSTyT3S6bSSyWQcTBCKu9GDHBEpyoEChEJsICjjOFiQSCRuuOSZCenZbDa0Xq8JatzBj5y8
+        QTwe97Zare/VakV6lsslaRh38CMnBdFo9HWxWNB8Pj8a+JGTgnA4/IbwdDqlUqlEhUJBznoqlYrMoZjD
+        j5wU+P3+yGw2o/F4LORyud3ZONN28CMnBV6v930ymdBgMBBSqZRovV7fnYvFopy1HfzISYHH4/kYjUbU
+        6/WESCSyO2szaLVapVgsJjv4kZMCt9sdxRPb7TZls1ny+XyiuGvk83kKBAJULpdlBj9yUuByuT77/T7x
+        T3M08CMnBU6n86VWq/10u13qdDo7ms0maejn8MGPnBTY7fZbm80WZL70DIdDajQaBDXu4EdOCviiWCyW
+        Pcxm8x2j4rtCcTd6rFbr359p+zGxnjNXzD3zaDKZnhgVijvzwFwzF8wpcvqCE76fbZeXrLZ/wBxh+PBA
+        KfgFcqFa2BgtJlQAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="SelectWidget" xml:space="preserve">
     <value>Select widget</value>
   </data>
-  <data name="icon_invokeurl" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_invokeurl.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_invokeurl" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIU/AP///0typRExZG+wPtbn963D3maPxcyZALfH3FWHSGupO3ugdqq+r5iymaDfUY/S
+        S1iORF6fN56xxmKWSj14K5jYTqqRCT95LHy6Ql6PT5Gzh4fKSIPCRY/RS2akOShXQp/eUZ7dUIrOSYLH
+        R1V8IHvBRFmPRInISH+og0mCPpfYTp3cUJPVTIDGRojHR1eNRIPDRYjGR0dzh5vbT6DeUHCzP7jOsU+E
+        SVuQRZvbUHGzQIbLSJPVTZq0sWWkOQAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
+        AAAIugB//JAQoKDBgwUlCAxgoKHDhgAMRBSwEKHFABR/BCDAsaNHjhk3AhhJsmSBjDJQZLiQQYOFAzAP
+        ADj5o0EKBQNWnFAwwYZJAQxwYBgAYIADBxgmvJR5coECGkSLhgChQAPJkwlizIhaNIcLEjBnCqBQQQXX
+        ohUuXBWQgAMPrh1YwLhRoG5THw+ibhDxwMMHAYABMzAxgGiLETsGvOiBoHHjmhAi6ChRIwKEBgIzZ2aw
+        IAGFBAsYaM4cEAA7
+</value>
   </data>
-  <data name="disk" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\disk.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="disk" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwklEQVQ4T6XOT0iTcRzH8e+e
+        7e7BgxDixbuXELyKlxQPgiwx/JOa4UE8CR4UFcTUubUJk4nhX6ytRHCCqJvicuEk6KBWZKgVRaIM/IPK
+        YLBPv8+jgwR5VBy8tvH7fd7PJgDkPqTa7FRcdUqvta3t+W1we9E4RarUm+LYenOi/giQuAE33LJhK0/N
+        DnJujkYRTyQQi8cNccMtG7ZSabZT3/rwAc5UfHR+bogbbtmwlQqzjdyfBv/iMBbD3vGxIW64ZcNWyrQu
+        8nz0/Ma++vUf0aghbrhlw1aeaJ00GHH/xO7OEf6cnhrihls2bKVU66ChsGsbga7NW+GWDVsp0dppNOTY
+        Qs/jcXRbx67Fu6S1/l9gw1asWitNLPZ8gb30NSKRNayshK/gGe/eNYXhLPPhQ98O2LCVYq2ZfAsvNuAq
+        f4tgMISW/H7dzMycjme84wM8z6bx/uV3sGErRVoTTQW7P8NdNQW/P6B/ks/n1yXP+ICR+nks27+BDVtJ
+        NaVLjqk4t8DUEGh/9OpwcnIBA7V+ndc7q0ue8QHexhCWbF/BPVu+MpSsTMmuyZPaVYvFYrsO7/73UAqH
+        L1tJUV/SlAd3xCblH+s4aw2T/BzJAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="DeleteCommand" xml:space="preserve">
     <value>Delete Command</value>
   </data>
-  <data name="map--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\map--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="map--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6klEQVQ4T53Rf0zUdRzH8fdq
+        1srNWv2R6eZy8x9Hg9babKRTNmd/FG5l9Idbru2Cw8PjBII7EfAHKjI8ZcJR14DidjQOhniB2ImAml2C
+        h07lPH+gB3IHIpMyTpCJPP186s/Wan63xz7/vJ7f7fv9SMqOHclK2jNI/qyoSGRDYaGRZ3h0p4h8kp+f
+        PqdeUH+2gJbevZztryQ4UE9g4ATuK/3s6YlgOxMlyxfF3BrFdCSK3utOEVlvtZpm5+b4viuPjgE7PREn
+        vSEnE9NdXJ28TsNojCJ/lOIgFATA5I2i97pTRD7KycmYefIEpy+LttA+um6X47tg5+7kUcan/Jz7fYiy
+        82FKb8DOy7CldRi9150i8qHFYp6enaWyNYPvTmTjOpWPt6+E7kvlXL7moud6Ow2hELv9g+R1D2E5PoTe
+        604RWZuRkRl7/JhDzek0BLbj7S/GfXo7vw1/S3jCw/2pTjqDnXhG/8R+a47sjkH0XneKyBqjceuDmRns
+        P6bh9ltpvFBIdUcuJ28dom+khpEHLfSFmtSnDFIzPIOtO4ze604RWWkwZE88esTBWiN1p3Op77FRdczC
+        sWv7ORU+TPCei0B/DcOxAL7xMXaeuYne604ReX/Tppzx6WnKq0yU/ZDKgYZUHO1mvmnfSu1JG42/7MYf
+        rCJwpY6PfZ+z5GgiX/ZmoTtF5L2NG3PHpqaoLDfj9tqo6/yaA55UPH0FeIN71NUe5Mive4n80UxC2wq+
+        mshVZxK6W1ywQuSdlBTryMOHOMoseBoLcbXlsd9twH3OStPFInW1JSQ1riSuOZ6ElndJGU8jvmU18xxv
+        RqT6NacsT07Oj8RiOEozqSjLxF6RTmmNgdJ6A/YmIxU/mXmrehlJo5/+gzheDcjCxMRdY+qv3pmc/Fdf
+        /LyF+LoP/vL2nVUkuFbxfPHrI2Jf4JSXli7dPD8uruT/eG7bK6OLwnHoU3ey7kXRz8vKG8qi/7T5hVpJ
+        m3dJTOr8u5Onl817ThS42NsAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="PromptRepairBrokenFeatureSource" xml:space="preserve">
     <value>The resource id {0} could not be found. You will now be prompted to select the correct feature source</value>
   </data>
-  <data name="icon_popupscrollup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_popupscrollup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_popupscrollup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAILwAfCBxIsKDBgwgTKkSAQOFAhgwd
+        QoSYcOLEgxYtFsyY8SHHjh8/OhxJsqRJkwEBADs=
+</value>
   </data>
-  <data name="icon_plotdwf" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_plotdwf.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_plotdwf" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIe1AP///Vpuov7//f7//////7643ltsoVltoUt+spij2f7+/JGVoZKUo01/s11toLOx
+        2Jaj12d/irWw2IWNmm+3yNTU1I+VoSZZkX99inl0w//9/3CinXCimxlagZSl29Lc6NPc67W0wr7e/7G1
+        wIuKj7y43b643HShh+fw99bt/Xl1wf7+/1pvgJmWyv7+/gZ7NK+1wefm9KOyx/X19QQwM+br7oWLlxpX
+        bMDE0IzA8AFKGVluomR0qWuf0f3+/3CAsLnN2HaGtHaHsuXj8F6SxIOJmfr6+iN1gNri4sjHxIGAjaCs
+        unh+iSBhOfHz9Hmqo4SNnH2Ahoy8rqGlsQhVKxRIcLy421C2m5Pv2rq52Wykm9/k539+j1xtoje7aZik
+        2Jqhp9jY1ltupThYZaiuutLX2VptpJKKwzFglZOLxunw9oWMkiZYlP/9/jVnm52ns3+Cjufx84CHkiZY
+        kk6EvGx8ruzs7X17gOnx9L7x0oWNmHxzw1lvoAJ9Inx1wlxxov79/397ibu53qTM/7/J1fXz9Km6yjtY
+        YLS7y/3//idYktLU0/f7/llupJujpnRzgfb29nCknNrr/RJUapai3IyPnjVITxZbfLG503Kf2tfY2kpu
+        kXhzwtvj5b/H26ewwZel1ihflnl1wNbc7Kmwu4GRujhqjoaMmOnp9MDIy/L3+lhtoa+0x5ek2aCtyHl0
+        xQ9oZn5+iYyUlnKCeQIxB////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAC1ACwAAAAAEAAQAAAI+QBrCRwoUMoGLQ0QPOlEcCAkJBzy
+        pBjUA9YkJwNRtVDBKRIWSSJyEKFCi0WtNGf8tAFUCMgVLxQyIbhBw1KtVwIArBCgIMaJPi+OuGFT5VCt
+        DJoAENCgYAChJjouhUJjKoLAPT4SCSCQpcCsMR020blgZ6AoACUKCGJV5A6JOYrKEAxgxcSnSkyiQJD1
+        iNRAI0ICwJGzxlECUGriTOExsMubBZRSfUmABwUMC0p2DDQwABEZDwBCjDiFwUEjPgPNGHIBAoeeCVBs
+        PNiyiMHAADJGBVpyAIyEGowqtKoz0NOfD1xiHRCjKswPV0MazgiyykCtJKUwNawVEAA7
+</value>
   </data>
   <data name="TooManyRulesWarning" xml:space="preserve">
     <value>You are creating a large number of rules, this will likely result in Maestro becoming unresponsive.
 Do you want to continue?</value>
-    <comment>A warning message that is displayed if the user has selected options that will generate a very large number of rules</comment>
   </data>
   <data name="FiniteDisplayScales" xml:space="preserve">
     <value>Finite Display Scales</value>
   </data>
-  <data name="ruler" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\ruler.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="ruler" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3UlEQVQ4T2PYn8jCsD+JheFA
+        EksGEHdDcQZIbG0EM0gcJw3SywAiQIqAdM/fm8v+/7qy8D+IjU8jzGCwAfsSWTJBGpaFMF98sLnh/9dT
+        0//vTWQ5AxJbE8E8Bx8N0suwPZZlyu9ri/9fnej+/8fFef8/n5gKZ9/fWAcWw0aD9ID0MgBtmf92f8//
+        baUm/+9tqP3/8eik/6dbrP4/29aMF4P0gPQyzAtgap7lx7QRyLn/9fSM/+8P9YMk7oPECGGQXgagIjCe
+        5MY0787aqv8gkzdHM88AiU30ZMSLQWoYloYwM2yIAuPZIOe/2tP5H8QGic30xW8I2IBOeyYYXnhzZdn/
+        FzvbwH4DYlD4MMzAYwjYgJVhzDC8COR8UOABxRYhiTNM98HuErABjZaMMLz0+tKi/0+AaWFZKNNSIGaA
+        YS0xRgZ0oCrMyOCrDhRfHMwEwytfAZ3/CBiVQLGVMHFNUUzNKIaJsTEwVBgxgvDqK4vy/z9YV/1/rj/T
+        eiBm0CCkGWYSyDkTPBn3vAa64NmWxv8gNkiMWCAPVGiUasywsM2Z4TgIA9nzgGLKQCwHxBJALAzEfEDM
+        CcSsQAwMPQQQADIloRikWAyIRYBYCIj5gZgHiLmAmB2qmRlIw50HAIdyTYaOb/frAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="document-copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document-copy.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document-copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB70lEQVQ4T42SPUubYRSGz+Kg
+        IphFqCAFY4YiWboIUkyLhZjQWhULWVwcNJUgRqpECWazP6DkF9S2UkTqoAjBqnF3dOtQBC1YNOb7+/Tc
+        Dz3yECvkgQteeN735lz3eWlybY3exmKvhZkH6JuIRmlsZQXvGUYnh8nf30aurhYiXArBXLXK18Ui/87n
+        +TyT4V/pNO8kk4w7wWUHaOCg10MmWXiXLZf5TzbLF6kU/7y64rPLS/68t8c4uBdcOoEGvIlEiF4tLYG5
+        XKXCN7mcCUmcnvLXoyNejcfveBEMfv+neKdkAkbCYRAqiMJtoWBCtk9OuBklE/AyFALzJQnISgcI2Rb3
+        ZpRMwPPZWbBQrtU4Lz0gZOv4mG0l7eXjxgYrLp8vKhA9m54Gi9V6nYvSA0K2Dg/ZVmosFxuCNvRpYGoK
+        vK9JQEU0EPLt4IBtJS1XJzmXoqENfXoaCIDluqyrKhoI2Uwk2FbScnUS/CvQhj65x8dBBPuuyxQI+bK/
+        z7aSlquT3JRKDG3oU6vDQT0eT8z8MQgRPu3usq2k5eokaekJ2tDHedzudIY73O4PSp/X+8NW0nJ1EqwY
+        2tDH6RQeCd3KE79/3VbScnWSvBQN7d6hIRPQeDoblaCDTlAstlOSZ7wjHzr+F3BPydbTZ2jLx71/Ad5i
+        gsnRJ2HiAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="FilterSqlite" xml:space="preserve">
     <value>SQLite files|*.sqlite;*.db;*.sdx;*.slt</value>
@@ -384,18 +981,20 @@
   </data>
   <data name="InvalidRestorePathError" xml:space="preserve">
     <value>An error occured while validating the restore path: {0}\nIt should have the format: \"Libray://folder/folder/\".</value>
-    <comment>A message that is displayed when the restore path does not validate</comment>
   </data>
   <data name="NoFolderSelected" xml:space="preserve">
     <value>You have not selected a starting folder, do you want to back up the entire site?</value>
-    <comment>A message that is displayed when the user has not selected a folder to create  a folder from</comment>
   </data>
-  <data name="icon_measure_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_measure_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_measure_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIMPAKufkcu/pqqomunkwKKdkdXIq5Whrtbh5YyZpZy+1J6Zj42Zp5y/1I2appy+1f//
+        /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAPACwAAAAAEAAQAAAIWAAfCBxIsKDBgwgTDkyQYMGDAwce
+        RoT4gOECBwwQPDBgYGNHjg8wIhjZQCFJhShTqhRYgEDLly5jwhwggKbNmjhvBlAQoCdPnz139gRAtKjR
+        owBWKl06MCAAOw==
+</value>
   </data>
   <data name="DeleteConfirmation" xml:space="preserve">
     <value>Do you want to remove the selected item?</value>
-    <comment>A confirmation message displayed when deleting a resource</comment>
   </data>
   <data name="ErrorLoadingWmsConfig" xml:space="preserve">
     <value>Error loading WMS configuration document: {0}. A default document will be created</value>
@@ -403,20 +1002,65 @@
   <data name="SymbolGraphicsImagePlaceholder" xml:space="preserve">
     <value>&lt;image&gt;</value>
   </data>
-  <data name="ui-separator" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\ui-separator.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="ui-separator" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAKklEQVQ4T2P4//8/AyWYIs0g
+        i0cNoEYYMDExVVCCR2OBGrFASUYaHHkBAGwz1S9OnHZ7AAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="database--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\database--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="database--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACQUlEQVQ4T5WST2iSYRzHn5qK
+        Hhq1oMLLoINsbC4wki6CXUZ/NsHES0SnGhTrFJIDDy47OnaoLd6pzbk5nU77N6evUzcyK927IQt0NMrt
+        jd7I/hBdOn573rEO5qL5wIeHh9/v+4Xny5eYzWayQy+9+/aIuLut+yMmBoOhr1qtolKpoFQqYW3tDdLp
+        V5ibyyGVWkU+v4Fy+TME4Rfo7g2j0UhEagwEQUCxWKTCNFg2icnJCFzuMKYDCSTYApa5d9jifzZgMBXB
+        GDXwB+cRT75GgdvAJv+jEYNZMJ4ZTAVjmE++RJ5bR4X/9k+Dk/39/c9cLhcYhsHw8DBsNhusVivsdjuc
+        TifEmcViidMMtLtm8HeIqUwOT+YXEU/nkC0Usbb+HpvC171/wecP48G4H95QFE8XMsitFLHBf2zAYDqE
+        0fFJjIfCeJxawIuVFbzl+QYMAiGMeCfwMDyDR6kEeuOX0RHTQTnUllUPaEn7bU1ND/4bYqvvBK5+t0Di
+        PVomE4cJ8bQQYjKZtunp6alrYmopi0g8gQvRS1AFTqF95jTMX/ogHz22RcUccbcwRKvVku7ubqLX66/V
+        NpGFLxjEPZ8HrWNdOPPpYh1k5CBHxKNSqYharb6+u4EbOuYsjo92QTWmQSevg/TuIZ44mzky1MyIegXl
+        iFKpvFXXg6XnmE3MIboYA7ucQdt9DZSVDjRZD3wQNTtaQpMgnQqF4qZcLh+USqWDEolE5A7FQd8OmUzm
+        oDNH03nZ6r4rMmH/OSkraigtvwEKQSNnrT8HPgAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="UnitsKb" xml:space="preserve">
     <value>KB</value>
   </data>
-  <data name="icon_popupscrollup" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_popupscrollup.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_popupscrollup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAILwAfCBxIsKDBgwgTKvzxQ+FAhgwd
+</value>
   </data>
-  <data name="icon_panright_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_panright_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_panright_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
+        2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
+        s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
+        vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
+        18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
+        yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
+        AABuACwAAAAAEAAQAAAIvwDdCBxIcOAABgUTAli40IibFwEIpACT0M1BNz2gcIAgwIIWNRXd1FhAgMQD
+        AWvOBKl4wkQAAQZ4CNjSpU1FH2iqENjwQEgSCTEqzmgRQAmFCgkWSAhRcUyAJSUo/NgRIE3BI1EQ3JhQ
+        AUECHUUg0CAI4kmDBjhUyDAAw0AGNgMIehiCYoIXFl+IABETwUyZgk6sHDjARMoFDRGwXMmScAqGMC4U
+        jBDhYAWXkG7IFCjQhEoOG5jdICnwoYMCBwEBADs=
+</value>
   </data>
   <data name="NoSchemasInFeatureSource" xml:space="preserve">
     <value>Feature Source has no schemas</value>
@@ -426,7 +1070,6 @@
   </data>
   <data name="EmptyText" xml:space="preserve">
     <value>None</value>
-    <comment>The text used for rendering examples with no text data</comment>
   </data>
   <data name="TestConnectionNoErrors" xml:space="preserve">
     <value>Provider reported no errors</value>
@@ -443,22 +1086,60 @@
   <data name="FileDownloaded" xml:space="preserve">
     <value>File Downloaded to {0}</value>
   </data>
-  <data name="layer-shape-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layer-shape-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layer-shape-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T6WS2y/CYRjHH4uN
+        ZbRSU8sqM1FSsdEF5sKFzYXIoTJuwozKMcw9rurSDS64YWbOZ/+C/ynf5+33tn5lDvPbPr/v8x6e7/u8
+        B+rceu8CcUUJmscZTZPW6qHiTx9Mk2HykLLZLFHH5lsCwQcr4Hae9rUnalt5IPfyvcAxtk/G7gipDPyp
+        1wBIKkpQgUwuNGATV/KOmhYuyTx9kquAJ/s2XsJABzhWJX9l0Jq4JUYYeNefmUHg4lU9q4+iXE6UyC3I
+        ClQGnARsYALJWjn51wa8IoOEPjAKAyvQIO4BKdZvKygY1CD2gTCIgW2+HValzf0+HKJGtYVCd7lHPmlM
+        6gU7rGiXQxvAOOhvid8QIw7RFIiK+5VGnKwYiEm8WkG72rl0PQUczYtXOQP58YtjM34oDCdKA3toT8Sc
+        BLwgWGJQ8l6LOqosbvGAgAHMNc5fqCv4yYDHa/0hssXOBuyz57uscgtlGNOAClAJtKAG6IAe1AETqAdm
+        y8xphm9HUbHunwwMI5nhuvDRgTFyPCQq4N9/+ATdd0wu3kGkzgAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="color" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\color.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="color" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC3klEQVQ4T6XSa0hTYRgH8Cdd
+        yyCCBDWLWRARdsE+VhRllCH0LWEYFSZ2wTJ0kIhm0dzy0rIbCGGOXKkLNU1y3nNU1vCSudlxK0bBlpk5
+        5Ciabu78e/TDTAj60Ic/L+dw/r/zPu85BID+JwvlisdEA8+IPuYTWRIpbOAQKe07g7X2cHmZXb6mzC7b
+        rh2kWGU/HQ8TSEM2qiUztS50lwI3KdZxLdQwWnamf+al0SO9Nfukjle+GUOTZzSppN8RmmMQqCD270AD
+        HXZUK1pmP1eJsD4BjFeBPBWg4jX3MVDajdl7VtGxvqrFRvWHl+zgSQ1FWntWm2Y8jybhLgYsXGxUA3od
+        oHsAaBqAy128fsGM+vukdZXF1ErmyMAIejOlCe4E15xUCkxmAK4iwKYHOqqBmhag/ANQ/BXIFDGX54ew
+        3+0ykiUtABRaqP7TVOEvN7IwjuuYm+PyeDPg7AZ6HUDbGPwGLyZuAN94cx+Sp37pyFIfAM69JrvVXyJ1
+        4RJsKIQLTzEJC/yzbkgj05juA4brAOE28C4d6Dzvl1LptT0AHOokZ7O/QKpEGhoZeMPAIAPD+IkfIjD0
+        nosMNDFgZEB/wi8doU5nAIhqpXbtRIq3iHdwh0cohwHNDHRjDL0MtDFQYQTu8wjaVODCwQnvRmptDwDL
+        Kih711CMmMFABnJRhEro0YNqBmom+AwH+Axr+Aw1QNIpIHrDkBhEddkBgNSkkJvkwlHxpDeFR1DxCGr0
+        QgcPdAxorPwVeYSkQmDfMdErW24SiB4qFoF0Iqok5coXEe4D41d8iahFCvpwkYGLDJxlIPE5sDd33Bei
+        eOEmqlYS3V38lblOFM1JD1bK9NGCoksl7h5t9sb7RqR4j0/a0zHqjcrqEmUxeoHkKi5vXags7oBIxtcR
+        nG20aUUcnd5yizQJZsrPdFJOvpMSNWbalnyLQjbH8TM7OGs5sj+BIL6xihPOWfePzL9o/tmgeeA3KbNy
+        RaQn6HMAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="NoTypesSelected" xml:space="preserve">
     <value>You must select at least one type</value>
-    <comment>A message that is displayed when the user has not selected any resource types</comment>
   </data>
   <data name="ContentFileMissing" xml:space="preserve">
     <value>The content file does not exist</value>
-    <comment>A message displayed when the user selects a non-existing file</comment>
   </data>
-  <data name="gear--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\gear--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="gear--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACfklEQVQ4T6WQXUhTcRjG/7Yt
+        GWbozexrI0qRUMPOwG11MbDEmov8uojQZFBIq66kgVERgogglG1hEJRSGdRNihG0TFA7ws6JnX2YmsuW
+        bTq8l8ibt/9zjpZCdNOBH+/L8z7PwzmHERH7H9Swy+Vibreb1dXVsfr6enU2NjY6OK3rODbf4EUGbCmo
+        ra09yo2X+NyLuba2Rqurq7RZg+evBTU1Ncd8Pt/dlZUV8ng817np8tJSmgB2aLjBA++WN6iurmacq8lk
+        kiQpROl0ikZGRuZTqRQB7IlEQr3BA+96RvsEh8PBnE7nvoaGhluRiEKKEqaFhS+0uPhNBTs03OCBFxmb
+        zaYV2O12JxfawMBAfyIej9Hg4LOZ0tLS+wA7NNw2fMj8LhAEwSfLEo2NvaepKZGi0SiVlR3u0ul0DGCH
+        hhs88CLD0d6gpKSkfXJykoLBIGHGYp+ovFzoyMrKYgA7tM0eZDhaQVFRUVVhYeEN4PcHvobDcRoefhe2
+        WituAuzQcKu49lw60nz7JTIcrcBisTCz2bxfEKw9oijT6OgEzc2lKJP5oYIdGm72bilj6/0cs/kXmviH
+        aQUmkwl0iKJCQ0NvaXxcpkDgYTIUipP3sULHe6Sfbn+ETt75SKcDUepLE/GwXNapNKkF+fn54FRlZdVT
+        SZql4uJDvXl5eZ2iGKMT3VN07zuRd5qoOfKHtlmig+0TslqAR6/XM6PR6MrJyenKzs4+gDkzs0wX+0Jk
+        ahlYLmh9FVPnhRfz9g9Eu7yv5d1X3mhvgDyngMN/K7MCg8HQwou6AfYNPfds/3TuuSeRnU2D53mJ9g/4
+        s42zg2Pi7PkX2888eGRw93rWM+wXiN3yhzE1UjYAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="OdbcDriverExcel64" xml:space="preserve">
     <value>{Microsoft Excel Driver (*.xls, *.xlsx, *.xlsm, *.xlsb)}</value>
@@ -466,8 +1147,20 @@
   <data name="ParameterOverrideExists" xml:space="preserve">
     <value>Parameter Override already specified</value>
   </data>
-  <data name="layer--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layer--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layer--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB+ElEQVQ4T6XSzU/TcBzH8e/N
+        TA8QNcSIAZGHiISgGP8BLx7Bg8GYOEQCKBAIAeHk1QtRiI8QlviALiwpY8jGgyMkuIw9MA7sQEEE09g6
+        azu3ggie5u9TR5w7kBqWvNJ+u++765ZRIpGg/aDzXW7IYSqYawZhFw1Reec7qAysRie+ab9CsrYT3At2
+        sIsGLZ27MwXX5fjOvKBsuY3ALhq0dLZjEsyR2Lbvk/xjygjsokFLZe0TcEOK/vR+jGyOG4FdNGiptM0F
+        NezRPby44Uy1KMTt3mX1lTv89alz4UvvSFDsBv9q1IoGLZW0jkHturw1Gxa0UVhYj3Es6h8OiA84/+f7
+        Ot9fHl55jQYtnWl5C3UfIpszLLS/X1IGR4LSQ84n9nJ+XY9+xPznWo+HV61o0NLpZgc0LIkb09Nh+SX7
+        1MfD/n88YvMu/T12AxsatFTUaIfbobXvLntA7GOeJeE8dcZ1ffYsKxyahgtVRAW3OGjyrqgOR1Cy7GJf
+        wwKYbZcq+aHsXMXG4MidzI8NHMwUrET9lFdngxb2y7pGQ9Jz3XzymJwHTuSq22ZzIl0fUYgOHCum7OrB
+        +jeza5PsLzo+t6I60724XCV15xXEdacKtXs5+VqXKUO4iSdgr8OHSisuHrnypO3oVctdI7CLBi1uYGKy
+        mOP/CY3pN4OVZi86RL5AAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Infinity" xml:space="preserve">
     <value>Infinity</value>
@@ -477,26 +1170,71 @@
   </data>
   <data name="UnknownResourceTypes" xml:space="preserve">
     <value>Unknown types</value>
-    <comment>The list entry that represents unknown resource types</comment>
   </data>
-  <data name="icon_zoomin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomin_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUhALK8xpKYoa+vr7Gxsaurq9jY2LnAxcfHx7W8waq1wOns79bW1rOcjNDc4+Tk5PHz
+        9am80YGYsuzs7MzOz/n5+dfk7PHx8cLK0tPh68fU4ImetOz0+cjV4dLe56Omqfz9/cvLywAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAhACwAAAAAEAAQ
+        AAAIrgBDCAxhgIDBAQUGKgxxYMACCQ8sOECAYCFDBAoeAAgAQIGEAwYWDrDwgQKACB0VOAg5EMGCDRQ0
+        Bkig0sGCigIFSACQAMBGCD4BdBAwkMADDQECREi6NEADojkV8PQZAEJPAE9bFmgwoUICjhUwNABxYOAC
+        AwsmcPiJIUOBASIRXDgAgWOBBAIOTBA5wIDfCwYEeEBo8YAAAQQEwA3BgEFCi5AJOIYceTLlhZIDAgA7
+</value>
   </data>
-  <data name="icon_panright" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_panright.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_panright" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwQAHCRxIcGCCAgUTHjjQQIAAF4Ps
+        eAkwpUrCQQcHidAh5AoAMjPiXBw0oUeAEQMAKPkD4eIZOgQArMEBAI+TLxdzcMgToM2ADjdS+Lj4IUwX
+        Fj/e7DFxgcFFDSpgbAiBoggBNAU9xKiTZYmUBWaeRAgihmASLEYUvCghaEwfPmDSWCEIBNAKKCBIUAnE
+</value>
   </data>
   <data name="PackageCreationFailedError" xml:space="preserve">
     <value>Failed to create package, error message: {0}</value>
-    <comment>A message displayed when the package creation fails</comment>
   </data>
-  <data name="icon_home" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_home.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_home" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZZAFJ5osvLxjZHVTdPa6C9zcOlRMjl9pa65GqZz3CLpPb4+f///329mg2RUJy1yE91
+        n9jb52B+l0ZSayApMSw/UV6LvjZRbsDQ4GmtmY3F6ujs8j9cfOfcvmOSx2+cz2uYyomou1Foe02Mg6eo
+        w3Wdy5ahrI634Y203OXp7m+QtYSt2jyScFeBr9K1f16Mv+3x9eXl4rOMMN7p+jNLZlmGuo2cq+Ho8Iiw
+        23qk1mGelW+lndnh7IGPm2uaz157k9a0MGWJs12KvKWlo1+Mvqy7yR4iJUdXYzRObT6UctTf6xgoOFVv
+        huLLgOny/XiXuKKALLTI19rY05mmtHGBkaO50fP0+E51n6S1xU98rP///wAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AABZACwAAAAAEAAQAAAI3QCzCBQY4AGVFwViSBjIMEtBEg82jPghIUBDhwgOHOhBI6KECBYHBkBgQIWH
+        DgBcWFFiBCRBkjcqHEBQAcCMGlMogBxp4IRMAEMAHJGyQMYVChR8GDBhAAeCIAAslFiwoIkGAQInADgA
+        4AOAATwWZMAy4KrABBYmcB0QAkWGJwUG7MCaJYEBCwMmLIGywEmBKAMu0E2gAEALDg4UVElRoEjgwToc
+        JEiQ2AaQAkweZyHAoMGKHCASJ2FRoIAAARgIZIHAuQESEQqICBggBMZmhqw7C2jAIPVF3ASCXwwIADs=
+</value>
   </data>
   <data name="QuestionResetFsOverrideList" xml:space="preserve">
     <value>Reset Feature Source override list?</value>
   </data>
-  <data name="icon_restorecenter_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_restorecenter_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_restorecenter_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUtAKq7y5+svcbS2MPQ1tTc4MvW29DZ3sTR17nH0tDZ3crV2tLa38fT2dHa3snU2tPb
+        387X3MzW29Xd4MjU2dbd4dXc4MXS18nV2sfT2LjH0sXS2NLa3rzJ1LbF0cjT2dfd4c/Y3c3X3NTb4LbF
+        0LvJ1LXF0M7Y3c/Z3dLb38bT2MzX3LrH07vJ0wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAtACwAAAAAEAAQ
+        AAAIxAABCBxIsGALAAQkUJBA4EGDBBAKXGAgAMBBCQE4fAhAYEGCABFWBKh4kAKHACQ4LjAQAEFLkgAq
+        fGARgCMKli09wKxQs6bDEz1HWgTwgAABEQ82GDARooADBhqGNliwYEMDAyAiKpiQwsLQBAkMGEgAIkQE
+        BQ4wCDgwFEJQFQUUBGV7sEAElwHiOqjZ4cCAoRdcZgjgYAKDAB0CjPh70EOADBMCMFAb4ECJAIwBCNi8
+        WYOFA34HiB5asPTAFqhTq16NOiAAOw==
+</value>
   </data>
   <data name="ResourceDoesntExist" xml:space="preserve">
     <value>Resource doesn't exist</value>
@@ -504,45 +1242,161 @@
   <data name="SelectProperty" xml:space="preserve">
     <value>Select Property</value>
   </data>
-  <data name="marker" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\marker.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="marker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T4WSP0iCURTF75Og
+        oWwp+gNurQ0tzq6igyBokkOUhAkqiOZQkyCCW0stQkUukkMUjbUEQpRRS1s0BI6SGoqVdrvH/KQanh/8
+        ON85977jg09iZjKoKEXCpBATDoVCX+GRD3aNM38CWZgT9usOx20nm23wzg5D4ZFj/vsH8f6/INFwue45
+        leKvZHIAPHIpSGgLXpTKd9Lpt24iwYVAgFe93p7CI8dcW/CkVLGbyXQ7sRgvOZ1st9t7Co8cc23Bo1IH
+        rXi8+hmNcs7jYYfN1lN45JhrC+6UCj5brXcfcuX3cHgAPHLMtQUlpaZKJtNpbWOj3g6F2AAeOebagiv5
+        zhdKrZbn58vtSIRb6+sMhUeOubbgnIiEsTOik4rbXW2urTEUHjnm2oKiLIBjouVLi+WhKZ8QCm/MtAV5
+        OdzHfERUaqysMFQyM/LtYTeQOW0KuR+u634/Q+GR49HeoL9DMXnZI7qp+XwMhTeeYQUmWRwXpnfl4Kv8
+        laHiZ4UJYWRYwYgszQgLQaItHIaKXxQswuj/gm+HNTFEuMVJpAAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="icon_tasks_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_tasks_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_tasks_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQAAAAAAP////39/vz8/fv7/Pr6+/n5+vj4+fb2936EjuDi5YyTnM7T2bG3vvf4+fb3
+        +PX29/T19vP09fb4+PT29v3+/vz9/fr7+/n6+vj5+ff4+P7+/v39/fz8/Pv7+////yH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIogA/CBxIsKDABggTKlR4kEGDDBAzNGBAkWKCgwsaKNio
+        YIHHjxc/NAjQYMOGChw6dCDQ4IKBkCNLLrzQAEMGmBsaoByw8kKBhzcP5uSgsACGhxpgCmigkoCHCzYb
+        aJgAk2iHhRInPIBpoYHTAgYyHHDQ4AEEmFdpIjwwtQEECjBZGoU49UEDChFgelioMELeg2AhOpiA4K1f
+        CTATKF7MePGHgAA7
+</value>
   </data>
-  <data name="gear--exclamation" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\gear--exclamation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="gear--exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACv0lEQVQ4T6WQbUhTYRTHn9sm
+        IhbolwWlEqaYTEO2SGcfFiu1ph/UbZ8MxC+9EEUQjQwTkkyioMIFpWIpawVGoUyDTTfTeVfe5e5eTJfT
+        llxfNoiSWIUUp+dsLhT61oUf53DO///n3IcAAPkfYma1Wk2qqqpITU0Nqa2tjVWtVqugnNpAsXmHWvQg
+        WwKqq6tLqfAMrbuxrq+vQzQahc0z1PwzoLKy8pBer78biUSgoaHhChWdXV5eAgR7nOEONajdckFFRQWh
+        nAuFQsBxk7C0JIDZbJ4TBAEQ7IPBYGyHGtRueOK/oFAoiFKpzNBoNM0eDw8874aFhXlYXPwUA3uc4Q41
+        qEVPcXFxPKCkpERJBxeRnp7HQb/fBybTk5mCgoL7CPY4w11Ch56/ATKZTO9ycWC328DpZMHr9UJh4f42
+        kUhEEOw9zuvAWVQwYb0MqEUPJX6BVCptdDgcYLVaAavP9x6KimQtDMMQRC6TtrpHNfA10gsTQ8fAMW4D
+        9FDiAbm5uWU5OTlNSHu74aPb7YeBgWG3XH7wKvLCpPcHPefhV7QP3ljKhZMnJEb0UOIBWVlZJDMzc49M
+        Jr/Nsi4YGRmHQECA1dUfsLLyDdz2OviyfAd0Oh2EF5p/2kwik6OPEVPiARKJBGlhWR76+y0wNuYCg6Ez
+        NDnphwl7B0zZtb/XhCYgVL4yexoGjXuF0WfMEfvTjYD09HRCOa5SlRk5bhby8vLvpaWltbKsD2wvdTA7
+        Vfd9xlcOg+ZL4OUPwzu2dG3YyDyw9NIHwgvwE4vFJCUlRZ2amtqWnJycjZXnzOB8dRRCARXMT8tjF2Cd
+        nz4Ar5/vcA51M6WJADFd7qTQZyVyJCkpqf7aBZGHH82OhufyIfxhH0Q/N8YqEnBmhPsfMl2JgG3UtJ0i
+        oexK0NlKOiiuzXTdIFx3G3n76CZhe28Rwx+y4Aflu5kbswAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="icon_zoomout" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomout.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomout" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZ6AG1LJgE0ZkV2qN7s9bK8xuqvdtfk7LOcjH+AgLrK25i1019fX6OmqdDc41lZWV1d
+        XcnV4XF3fJrU5Xp6emVlZbHE2Y6QkY+Rk7DE2ZGkuLvJ2MjV4VlZWmZmZlpbW8PP3XmTsLHN3rGai5ux
+        yYWFhajN32NobG5vcOz0+a+vr6ewuYGYstzq9LW8weXx993r9WSHraDP4VxcXJ641IeHh3uFj5qzzn6a
+        uF9hY6rK3YepxarA19bk7ouLi5230rnAxdLe56m80ZKYodjm8M3a5nplTnt7e3Jyctfl7/z9/dLg6tPh
+        65m108HP3aurq5vO4mlpabvM3M7b58fHx1xdXoCAgG5ubometKy/zoeNkkZJTGdrb1tcXczZ5cfU4MvL
+        y7GxsXFxcae+12NjZJOluLHJ25yvwcva5lJrhePv9ZKov9He6aHE28PQ3WJjZGRkZKC61WNjY2mGp21+
+        kaS2x3d4eH5/gHyWsaW911dXVwAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AAB6ACwAAAAAEAAQAAAIxgD1CPwyQUYeB1DACFy4kAYFBg0GGPiB4AhDgSTqGBgw4MWQJVIuVGE45Y2B
+        JChYIFFCZMMHOykWGmEwwEUaHmu6eGmSQEWYhQsiChhKVACGIAsWOhhwJoDTpwHEwHmw8AEQLHQgtIkS
+        IgeeGSPiLLTSwkwGDQnKlIjxRIGQHgudICBzRU2FHWwk6LAx5mKHCCtA3PDBRAEaNxZEXDxhYo4cGHdq
+        UNFSpMCBi1lweODAZYseAgAAWL5I+nPo0aUZghad+uLqgAA7
+</value>
   </data>
   <data name="ExtendedClassTooltip" xml:space="preserve">
     <value>Extended class based on: {0}</value>
   </data>
   <data name="GenericError" xml:space="preserve">
     <value>An error occured: {0}</value>
-    <comment>An error message that is displayed when an unexpected error occurs</comment>
   </data>
-  <data name="icon_pan" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_pan.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_pan" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUAAAAAALe7woCEiVNYYTtBSuHi5Keqr2hsc9HT1uzt7pSYnHB3g8fJyrG0t////19k
+        a97e342QlURKUqCjp7/Bw290en+Diaqvt5Sbp1lZWUxMTZCUnMzMzKOosri7vNbX13F1e+Xm55KWmWZq
+        cZyfolRUVL3AxIaKj660u76/wKastd7e5s/R08PFxnR5f5SUpdbW3sXOzn6FkpmcoKKlqJScrbS4v5SU
+        lIWLlf///wAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwA5ACwAAAAAEAAQ
+        AAAIyABzCBxIUCCAgggHZgCQIWHBhgcbJmhxAoQLBR4+5ADAsSOAAxVEFKCgYAaICQxKbMzR8IGDECwg
+        JHAAwQEIFhoYCnzQQqYDDgUcyHAwgcJBgQcEeGAQVAYLBwwckOAwMEQEAgZaPOUgMwGECg0IfiBw4cOH
+        EAnSJkgxQGCCEQ8GEPDAVW2CEG1zzJiRlkaFFi1g2M0r4YAIDyYSB7BRIK0BAgNTWCAwA8UFFR06INhA
+        gEVBFgRwYBi9YQEBjQhBS5BAoDUEggEBADs=
+</value>
   </data>
-  <data name="icon_search_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_search_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_search_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIYAAAAAAP///+np6q+xtc3O0JeboqKlqqSnrKOmq5OXncXJz5SZn7q/xaOnrKSqsMLH
+        zOLn7Ont8e3w8/n6+/j5+vf4+fb3+OLj5NfY2Zieo52jqLS7wOLo7PH09pKan9rf4unu8ebr7quzt9rg
+        4/D09unt7/P19qCnqvT3+PP29+rt7pqipPD09e7y8+nt7ufr7MrS07W8vOLn55Sgn5qlpK62tcrS0c/W
+        1dvh4Obr6pKfnO7y8aSuq7/JxtXc2p+qprfBvbW/u73Gws3U0cHKxaa0rKe1rMbPyZ6uo6q3rpSmmJCj
+        k5Ollqe1qaq3rKOxpISYhYOXhIeaiJSllZ23nZu1m5ixmJKqkoSahICVgH6Tfpu0m5aulo6ljo2kjYmf
+        iYGWgYKWgoCUgHuOe6O4o6C1oJ+0n52xnZiomLrJurO/s8rUysfRx8XOxcnRycjPyMTLxOLo4uLn4uHm
+        4eDl4OHl4ePm4+Ll4uHk4eDj4N7h3vv8+/r7+vv7+////wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AAB+ACwAAAAAEAAQAAAI6gD9CBRAYECCBAMICBDIUCCGAydiBAHyQAMCDA39YMjAw0kTGSVCwKCxAOPA
+        Az/QoDniQkKEEUVEGFjoh8CKKU92oOggAQQEI0o8EBA4oAaOHChSkHDJgQkUHQMEJhAy5EULFhMoVDCR
+        J8+dC1I/3CDiQwIFKmjTph2gwIYWMUksVEkTZ0+cNFWqbCHgoEcYLWPsWJGzhswaOVYSC2jAAAmUKHq4
+        9CnDxUwfLpg1FtiwRAqeK3XYnGEz54pphwg8zFDRRQ2dPnT4uPHShSHBARe+6Nb9Zk+bLxkFYhlOHM4e
+        LMH9gFm+PAvzgAA7
+</value>
   </data>
-  <data name="icon_viewoptions" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_viewoptions.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_viewoptions" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIYAAAAAAP////7+//39/vv8/gkiTxAwYzhfl4KSqYGRqHuNpnyOp32Pp3+QqICRqLfC
+        0WCW0q++zqy8za29zbHAz7TC0LPBz/n7/fj6/Ory+PH2+vX5/ODs9OXv9uzz+PD2+u/1+djo8tvq89rp
+        8tzq897r8+Tv9uPu9efx9+z0+fP4+9bn8djo8d7s9OLu9eXw9uny9+jx9u71+dXn8Nfo8d3s9Nzr89vq
+        8t7s8+Dt9OTw9uPv9efx9uz0+PH3+vX5+9nq8tjp8eLv9dvr8unz9/D3+vP4+u72+fn8/ff7/Pz+/vv9
+        /f3+/qbQrqfQrnS0fKzSsXS1e3W1e6zTsHe2fHm3fXu5fgB3AP7//v///wAAAAAAAAAAAAAAAAAAAAAA
+        AABZACwAAAAAEAAQAAAIywCzCBxIsGCWAwgTKlyIEILDhxAhFjhgoKLFixcnBhAwYAkSDD9UiCwiIwWR
+        iViYEECS5IeRDzCPpMjAY6ISj1OuqPAho2ePDCh0TCRwBcqVKj4QJFjqoEEHFxMvWDmqAcSDClgtUBCS
+        YyLIKiR7EEFB9sWJHC0mblChwckVIjxMyN2Ro8aNiSquNLkSBQWDBYAV4CAxYqIGKlekxHgRYYJjCSJG
+        sJgIoscTFB1OcKjBeciIIDQmeoCB+WwJG6iBhFgxY2KB17Bjyw4IADs=
+</value>
   </data>
-  <data name="icon_zoomselect" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomselect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZvAISChAEBAXBJJai7zsfb8Nrn9M/a5Nnm81tgZNDh8sXa77jH16jR4+fu9dDh8brT
+        7erv89jm8uzw9ODq9Ku0vNHh8mRrcvT3+aStttri6oOGiJqbncrc7oaKjZ+fn9Di6JSVl67C1a6yt5u2
+        0F5cWsjd5IiOlM3U2Tg3N398ezAvLujjjKCnr5u83uXq73V5fnh3d+nv9OLaid/s76/N6pyzy9fn65mi
+        rLCurXahzJDO1tfb3+Do8dDg8UdKTb7L2EpMTFhYWZy20K22v6jG5KWqsaq8z+7sj7C/z6amp6C50uLr
+        9evw9aTF52RgX250esjQ2ISAf2xtb7S3u+Tr8WBocMPT43yQo7vU7cbb7+Hr9JGRkt7m7YSFiL7H0cza
+        6IWUo7bBzeqxd6uvs6uoqOLs9c7X31xbXbe/x+fs8evv84SHi8vY5XyPoq7L5wAAAAAAAAAAAAAAAAAA
+        AABvACwAAAAAEAAQAAAIwgABvBFIcOCbgwgTJsQRxUkKMgkFBpj4xsMULz/CFNmiMMCRNxugcEkTg8cX
+        JGsOSlyRRAQENRcaTIjAAQwIhAFkwDghIQMVLQd6KKhxxuBEEi6YsLFSoIKCB0RQKJSyo0GZAgmyMKAh
+        xIfBNwFMjFlywAEBBjqaXHmCcwaaLmYSEMDSIoeSKhSM2njDQsONEG5GtLGAIGGADyXeDOkQRAWQFxgQ
+        CBAjECxFAwuMLDDwZoAAAQpDI/RcsHToAaJTvwkIADs=
+</value>
   </data>
   <data name="FailEnumDataStores" xml:space="preserve">
     <value>Failed to enumerate data stores. Reason: {0}</value>
   </data>
-  <data name="drive-upload" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\drive-upload.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="drive-upload" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACS0lEQVQ4T42OX2iScRSGD3QR
+        C4QwiBH9WV3U0qLIiyyoNuyiG1FBRwwsRqtR4BZFuQXNbiRydNMgmEFrxC5WBJbZZvbH0pVuXwyJFBW1
+        DWpaQYsIzVGn3yv7bGOw+n08cL5znvdwiObeirpdtKGlj3b2xEnbm6V9Nz5SQ/+n/QA1epjBgVt9qw60
+        0roj12nzxQjVXxr/u8D94ZAIShVELS+AAxcZZCs/MvKC3dcyCEi9ud98NfmLUaOHC+QFcmbRgh2udxCl
+        nsQsd4Z/cEfgOzvGi4weZksu2OIYgyBdfvuTnbES2/yf2TKQ4uP3p7jlXpYxgzP/atpkf1ll4/kXfXXn
+        gpJMx5NpNt6M8/wenPmZBQuESOvPPKW1pwNUe8o3ah0pFBtvZ4uo0cMMzoIFe45dIbC31UXbbYO0xjZC
+        K4/eAbcO+r9F6u9+iYi6Hz3M4MCVc2QwGCqYTCayWCykazpJNU0DoH1rYNalfFB2oUYPMzhw5dyiBRAa
+        zW20zOBuqH3MxuU+NqJGD7OlFijMZnOzoO0fNIsLFNUL9Ho9zWENhUKpWCzG0WiEg8FnPDz8iL1er+Ch
+        wC94zkNDvpTwrXKONBoN6XQ60F4ul7lUKvHMzFfO56d5cvI9ZzIZQVYwxZKU4GQyz3CRQbby1Go1abXa
+        s4VCgT0eDzudTnY4urmrq5PtdtAtcPIJ8UUiCYaLjPxqRLFapVJdEOfm0uk0JxJxnph4I+TXHA6HBaOC
+        KAcCr9jtHszBRUaALCkF2xQKxWGlUun8H+Aig+wfdPytZLAK/bMAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="application-search-result" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application-search-result.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application-search-result" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACjUlEQVQ4T5XST0iacRgH8J/W
+        IBFGtEteOtRBL7u4SycbImRYw8IGrR3Nav9gDrbDTpHBW5c22A6NatHB0TKSFbWSTpqtJmOyUMM2h2j+
+        yVI0fE2MZ8/zshdcu2wvfPDnw+/5vs9Pf8xkMjFRb29vM+pDln9A+5pZT09PtX6v17sfDochEAiA3+8H
+        n+8z7OzsgMfjhe3tT+D1foHd3X1YX/fsY28/MxqN1YZdLhdsbGzA2toarK6ugtPphKWlJVhYWAC73Q7z
+        8/MwNzcHMzMzUFNTY2E4RrVB+I8HewdZd3d3taFCoQDpdBpOTk7g7OwMyuUyVCqVv1xcXAD2DjGDwSDo
+        7OxkXV1d9w4PDyGbzQLP84JisSgolUp/oGDaz9rb2wV6vb7FarWOpVKpc5vNtqVSqV4RWmcymfN8Pi9M
+        JKLwjo6OB0yn04lMPp/vG8dxm7fuWLi9YGxxLxRbNN4dHKcaHQmDhOkIHRV7HzGNRiO6j28vtrW1Tbx1
+        Be3vPNEV4nCHHVSj3yUajcLx8bEgl8sB9j5mra2toofJZLKI5xp1eL6/D8Tym2Tra2yFavF4HEKhEBwd
+        HQloIux9wtRqtagPL0xgampqeYR7OfIjkf34M5lzTbx4baPawcGBcLFoCkITYe9TplAoWGNjI9FMT097
+        IpEIPzs767BYLM8IrYPBIO92u4H+oUQiIaBjKJXK56y2tpbhjVKbzebl09NTmJyc3MXbGMaReUJrrVb7
+        pr6+fuyyhoYGMwXcxGYnNQ8MDDjxuw4No9HfaH29rq5OIpfLWTUMZBTAUTOGfMBJbkilUnaZRCJh4oN7
+        mEwmE4KEACz0Y8g4ft7GTSrUgpqQAl1DV5EMXUFSMYhCKOAXo8sWCvVAT3EAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="SpatialContextsFound" xml:space="preserve">
     <value>{0} spatial contexts found</value>
@@ -553,8 +1407,26 @@
   <data name="OperationCancelled" xml:space="preserve">
     <value>Operation Cancelled</value>
   </data>
-  <data name="globe--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\globe--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="globe--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADSklEQVQ4T4WRbUxTVxzGD+1M
+        JGYuMSFmiyMOQQuaiDUqGwsRGG+aoCRkKpHOlymKi2SZQkKmbAxtKC8FtUoDErRQFalhzhpe3PaBqZRC
+        G7RNKavWKbRAJZQi2lXWZ/9zxU9+8Ca/PPee//M859x7mejYfSYqMjLxL38zsfyfhWLF6FfiCpeCaCO6
+        51UhrPM5+bif57JKvmXCjVBQal9OQ/Wmhqdm+V/PPVqrz3/T7gsOTM/5WxwvPSlal5nPue9tAc++KSg0
+        LP+oxNxe8NtT13XbFPp9c2ixTqPeNIV7E37YAoDtX6DaOOniPu4XckJBnj5UlN/VWND+yF3e40aX208F
+        QbRYpqCz+9Az7kefdw59s8C9F8DpHpeb+4Vcnp6xkN3atJjiDus314Zx6KYTl+wvUPrHCE78PoIrQzP4
+        cxI4qXdAQ+s3xoC2Z68Rdfy2ledCcjRUkHXhjOyiaSq90YaUpiFs0wxhR6sDubrHONzuxO6mB8g8a4By
+        MIBiatune4Ic8vMcwRhLK+/4Xj8WSFRZsFY5gLg6C+LrLUhosOJLlRkynQtFd//Dd92zSFCaEFthxJY6
+        U4DnCCpI/NkQV3InmNw4iqhTBkgqBxBdaUJMlQnRCiOkChMSamzI1s3i02OdkFZReWVvkOcIKtj8U2e8
+        whj4rLQXkfJ+RFFg1TwS0qiyXmyscSC1ZRbhBZ3YqgOyNOMBniOoIPnUudVFHd6V5Q8gqXiINdUWxCot
+        kNZaBWKrBrGp1oG1ZYOIV48hrQ1IVj3y8hxBBelVGUtyNcPrySQlvlA9RpLaibQGJ9IvPkFqvROJFxzY
+        cNqMr29DYNnhG8OrN+ZnZEemUkHm+VC2Xd0sOdnnSVK7kdk0jl3aCexp9WD/dY+g8qRcqMLXoEGynjT6
+        dc2isEltiMikZUzN2I7LjO1sjvggt7VLKrd4ZFe9ONLuww+3ZlConxFUGbkOr2Syd6hjrJ+OQNfSGHqV
+        sgi299fmZYV37dvqR735uunA8Vsvg1yPxO98dTRshf/o4o8nfxQveEifrp9TJpyAMTERRkSzD5fGsc8P
+        HmCy1kZ2sKOb5XUZBOXPfJ3PGaPdWFg45fg/4JeIWDRf8gnp++CbcT/Psf8BxLcXab+EC34AAAAASUVO
+        RK5CYII=
+</value>
   </data>
   <data name="FdoConnectionStringComponentNotFound" xml:space="preserve">
     <value>The component "{0}" could not be found in the specified FDO connection string</value>
@@ -564,11 +1436,9 @@
   </data>
   <data name="OutputFileMissing" xml:space="preserve">
     <value>You must enter a full path to the output file</value>
-    <comment>A message that is displayed when the user has not entered an output file</comment>
   </data>
   <data name="FontPreviewError" xml:space="preserve">
     <value>Cannot Preview Font "{0}"</value>
-    <comment>An error message that is displayed when the rendering fails, using the specified font</comment>
   </data>
   <data name="OdbcCannotInferDriver" xml:space="preserve">
     <value>Could not infer ODBC driver from file name: {0}</value>
@@ -579,51 +1449,141 @@
   <data name="UnitsMs" xml:space="preserve">
     <value>ms</value>
   </data>
-  <data name="icon_zoomprev" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomprev.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomprev" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZ7AHBJJai7zuqxd9nFsxc5ZrjH11tgZOnv9CpGdRc2bGV7kpu20IiOlKm1w6u0vKqx
+        wSJEcd7m7UdhgaTF59ri6hgzakFagqC50tfb3xU3Z5yzy1xbXXyQo6q8z7bBza6ytz9Sfc/O1IaKjYSA
+        f2RgX+fs8a7C1Y6XqImXpLrT7WRrchIzaYWUo5qbneLr9Tg3N77L2PT3+auoqOzw9Kamp6jG5JSpvsrc
+        7s/a5MXa75SVl7e/x250esfS2L7H0UdKTZmirJKfsuXq75y20ISHi2BocNnm8+rv82xtb6a80auvs0Ze
+        gBMzYmZ+odDh8n6QrjhWfM3U2ThUe+Tr8bS3uxY3ajAvLnV5fn98e3ahzJ6quEpMTDBQeZ+fn3CCohg4
+        Z15cWlhYWWd7kxg5b8LQ3aSttoSFiMjQ2P///+fu9SJAcnyPooOGiBY1bM7X37Cura22v5iktBU1aIBq
+        V3qSsCtGdWh8lnh3d6CnrxI0ZM7OzgAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AAB7ACwAAAAAEAAQAAAIvAD3CHwzggQWGXFQaBHIUGAXKj5geOCyog6IJQ33tDgTocQBBG2aENkj5gRD
+        Gh+OoIlBh4mFGyx07FHA8E6UGRSmqMljI4eGDXueMAQjJASUKgTGJElR48WeBgyRYEjz4EuFBBAkDPmR
+        kYESF0akyMlgZwIHHhl3mHHjpAcBL1kuFHGQcQ8eNkBMBFmwRoUBPXX3wBERxsqWK2UMABAwIHCBDgVw
+        7AkAYHHjwA0pW8acubIAzp3ngM5MZk9AADs=
+</value>
   </data>
-  <data name="databases-relation" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\databases-relation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="databases-relation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACD0lEQVQ4T42SvW8ScRzGb+B9
+        0oSBl8EAIWGAOLIhgyMkLCxOJgaNbwlDBzGVsz3BPwAxosH42qiHl1LbhuRsKJQ3y3bm0pqI9dQj7VWM
+        k+vj3UktR7DyS57ll3ue3+f73JeIx+PEFDorf3NzkqYxE5FI5LwkSej1euB5HrXaJlZWWlhf5zB1QL/f
+        R7fbBcuyePFyEQ+KJZSYNTVgIpp8r2CrDygE4wH3izRohgUxjsRxXyGKvxCNRi/FYjFCOW63O5RIJN4U
+        CgXk83mQJIlUKgWKokCMIzWaPD4LP9UAn8+n+E9mb2dpTQcb71BerYKtdQ4DDpA2Whx2hIEaoJipbIb+
+        /mMAzQivGNx79BwLi0sgxpFyuRySyWTF6/WemcvconcH+0iTZFUTQDO4+/gJnpWZYQcjSF1uGzuiBDJD
+        0d/29zBLpqsej+fc0R2MIK21O/ggfIEg7eJ6+kZVp9OdCoVCCU0HjTaYSgXL9bfDDkaQ2HYTW8InXEvP
+        qman00n4/f6LmhFKr3HnaREPlxb+3UEwGDxttVoJk8lE2O32GS1BC6XKMsr1yrCDEaTG+01six8RDocv
+        uFwu5TeeMJvNV4xG45xMdCBKr9dTBoOB+rMHI0irHRacwCMQCFy22WxKwDFZdlmOiVI3sXGIVOea4MUt
+        OByOGdlwXF3Fo84Q6y+SPPO8xWKZl7GvKlv8P/9vysUMoJZl8vEAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="ValidateOutputfileError" xml:space="preserve">
     <value>An error occured while validating the output file path: {0}</value>
-    <comment>A message that is displayed to the user when the output path is invalid</comment>
   </data>
   <data name="FsPreview_DataPropertyNodeTooltip" xml:space="preserve">
     <value>Name: {0}{8}Description: {1}{8}Data Type: {2}{8}Nullable: {3}{8}Read Only: {4}{8}Length: {5}{8}Precision: {6}{8}Scale: {7}</value>
   </data>
-  <data name="arrow-return-180" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-return-180.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-return-180" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAClUlEQVQ4T6XSe0hTcRQH8IPm
+        Y1ZWPnK2yqt/NMpHPqMkUaNCqn8iMYSbZGFhSMtCS6RBD4VmDxqVjCywP9QwLa5GPkK9PVDHtVrlkx6z
+        1WbhH5kSE7d7OnduK8T6p8GHc36/e8733j8GiAj/A1JvjTmk3f6qI8I/6OkZR9Q0z6TcNENy5ScAqXES
+        rhkRL4+I87pE9+VvbdYCfsqytXqMp510R8CmG6MugvaDiJoBm9uFfhu6lL+eQbV+Gku7rVjS+3Myreoz
+        T7sMbNC+d9ElXX0n/E2q7qMhp+mbqfjplF3VPom5zeNmmlW7A+gAiVdGIFbT7yD1f4q/OKiIqxjQZN+z
+        mApavmNhx4SVzhwo1b2w9owAUedfOvqocy9Yoos82we05A6Jo9DosleKpIo3hpyGUcxrtiDt6EF+5CGs
+        VLVBxEke1pzuYSlEcAKmqAtWFT52iDj1RHquiCnrM+yoM+Kuu0akud8B4cVdLIUIWqMdpRp2osO9LAUw
+        RZ0KutdsrBw0RdeYcXPdFyududkvONrK0lcIpUM2zOqeRqmfK7yEN0RdHzIp70/Y5fU/MLJy2EwzagjJ
+        b84gQq5BRK8HM7iuw4479SJu6xEx5bmIibzdcRfWZkP/Jhv6cTO4unZ8Uq5q5enlDAQcaMggwnY9/ac5
+        xCWPEBXtiKFE3oa4nAS1Iga2iBjcOGWVa4ctgflNfODBxvTgwxzAsv314L+vjl3M1gpJz2YXpX4eerrj
+        iJrmGXopLEzMBpDFZoFPTCb47b3DyrKqBWUnolR9t5SCd/Seefmsz4S5P0+6kC1IPnbIa3eVIKHzCqdQ
+        qiEkiCwli4gv8SIeriBvagJImEdCnsoj+XgN9QlO8VRjiJIwRO4MklH1/AWgVvXWOcn9vQAAAABJRU5E
+        rkJggg==
+</value>
   </data>
-  <data name="arrow-curve-180-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-curve-180-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-curve-180-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACGElEQVQ4T2P4//8/AyWYIs0g
+        ixk0G88wGHRdZTCbdJfBeuYTBvt5Lz2AeKbd3BcMIGzYcx2OQeq0m88xqNUcZ1CpPALGqAbMeOwBNOQM
+        FDOYTLhNggET73gAXXFm5tP//0G0cd9NFM0gl+B0gX7nFQ+gJFhz9/U//0FsJHwayN4GxL1AdaYYXtBo
+        OO0BDIcz0x///1+078v/qmPf/jed+/G/8eyP/w1nfvyvP/39f/mRzz+TN798Y9V/5TJQbSUwDLjgYaBU
+        fujM5Pt//2dseY+CEze8/h+y/PF/z3m3/jvPuPrfcdql/17zb/wx7T57F6inUqFkP4N80V4GBpn8XR7S
+        eTvPdF379T9t07v/6Ts+/g/b+eG/w6Y3/63Xv/5vvvbVf8PVr/5rr3j5X2XJi/+aS5//ka86fFkqd4ep
+        ZPY2BgagZgbR1A0eIinrz+Sc+fVfZ++f/yA2DIumbTwrlrf9okTlweuSbeceCC948VF4+oPXQPleIGZg
+        4DOPZeD3bmbgi1nuwRu97IzR4f//QbRgwmoGoaS1DPyxK1iAWBCINYDYHSjXy5uz/SyQ3gbEDHDALK7J
+        wGZf4cERMv8MCDOLaSAkkVhsukEgdVXIahiB8qxAzAXEAsyG8SHM1sULgWwVINYEYj0gNgJiY2QMVAOy
+        XgFkNsgAZqghHECaG4j5gVgIiEWBWByIJYFYCgsWoDwzUZKVQXoB+7/02cSOHsEAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="icon_refreshmap" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_refreshmap.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_refreshmap" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIYAAAAAAP////vz//79//fy//fz/vfz//38//bz//j2//b0/vf2/ff2//T0//T0/vb2
+        //r6//z8//39/vb3/fb3/PT2/HyIqPT2+3mIqXyJpgcgUgcgUAggUAkgT0lafXmJqnqJqHmIpcTK1vL2
+        /gchTgcgTd/j6nmKpjNgobnM5zBhoTBgoDBgnzFhoGuOvZerxi5hny9ioDBioDFjoS9hnDFjnzBinWqP
+        u7XN67jN5y9jmy9hmjBim7XO57PN5t/q9PL4/am1uEhgZKa4u6W3uqm5ukdhYkhiY0hiYURiYEViYEZj
+        YTNPTUdhXkViXkliX0hhXs/W1XOJhHKKhHGJg3KKgnGJgXGKfIGijJy+pFGFWGKWZzByNWiaaQBVAAda
+        BxJ1Ehx1HCSHJCeHJ1P3UlP4U0jQSGD5YFHRUTR2NXT2dHX2dWjUaD9/P2nTaX74fm/Ub4v9i5P+k8DV
+        wL/Uv373ff///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AAB2ACwAAAAAEAAQAAAI9gBlwGihQwYLGTVkKLTDkOEKCg0QQBnx4EKDGC5kNLQTY8IEB0gMLGhwscEN
+        jQxpgLCA4ciJExYsxNCgoUNDHgosPHDywIHPFz162GSo4kOIDEkaCIBwwMSBAyIaykjgQIEQBw8idPHC
+        VUtDGw2KSHFyJcgALwHScmU4o4KVB0seTNEaRo4cL3DC2LGxpIkRJ02eREkzh00cL2zceNlRYIqDJ0Co
+        HPhSZ4wXLWPeeJHBgEgVJVSGSPiiRswWL2LWeEFBwKMSjxLaoEGDlg5t1jl8MMGR4kcWMGbQngHjJQaJ
+        DR1KcCjhQQQWLmjLkPGysTpDrtgDAgA7
+</value>
   </data>
   <data name="SequentialName" xml:space="preserve">
     <value>Sequential</value>
-    <comment>A display name for the Sequential data type</comment>
   </data>
   <data name="PromptDeleteCommand" xml:space="preserve">
     <value>This command is referenced in the following menus: {0}. Do you want to delete this command and all menu items referencing it?</value>
   </data>
   <data name="InsertionPointYError" xml:space="preserve">
     <value>You have entered a non-numeric value in the Reference Y field. Due to a bug in MapGuide, this will likely give an error when saving.</value>
-    <comment>An error message that is displayed if the user attempts to use an expression as the InsertionPointY value (caused by an xsd bug in MapGuide)</comment>
   </data>
   <data name="FieldRequired" xml:space="preserve">
     <value>This field is required: {0}</value>
   </data>
-  <data name="icon_copy_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_copy_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_copy_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIeMAEF1pURzq0Rzqezx9URzp0JyokJxp0F1p0J0p0B0pkN1pkZwoEZ2pERvokd2runz
+        9eDo6sHZ3ebw8ev19ufy+D5xqPv69vr4+0Z3otDi5J/Byvv7+d3p6fD28j93qENwqfj8/fn9/EFzqObu
+        8T90qL3U3MTb4z50o/r5/kBxqd3o6kVzpEVwp9Pk6/z1/PXz+NTh59nn6Pj3/UVyrb3N50J0qT9zo/r7
+        9sDY2OTs77zV2Uhyrvf89ery9aXH0LXS1uPr7qfH0src5srd5ENvrKHGzkRypkN0r0BzorfL1pnDz7bT
+        293r7L7V297o56zK0sne46PD0O3x9EdyqajI06THzerv8+jt8KrP2Ofx8sDS3rPK0J3CyEVyq6fFz6TC
+        zbrV4LnQ2LrT2Eh0ocXY3rDN05/EykJ1rrrR193m7aLCzcTY36LDzENwp8rb46rL0t/p6KrE0eDu78Tc
+        4KHBzMbb3tXj5rLP1z93quvy+EV0rLPQ1sHY3qLEza7G0KrI0ElyqKDCzKC+ycHU2z12rdzn66nD0EVu
+        pER0pNbg6T1xoaHCx////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACMACwAAAAAEAAQAAAInwAZCRxIsCAjQ4ISKhSEUFBBQRsu
+        uLDg4sWLK1cSEjTkIqKFDlKuQIAgiORAQRYaKkTI0iEjQRc4UqRoUaTGgyk3eHwR0qZJQS5gRgQZciRD
+        hS4MobjxAqRIJxASSU0Y1MIFoiOdSJ0q6IWhDRY7ABG51Y2bli6kSLGSVetWl117QnCiFUYiMong8nwq
+        FQYMN3byCjya0A9hwzcNKmYUEAA7
+</value>
   </data>
-  <data name="script--arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\script--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="script--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACA0lEQVQ4T43TT0iTYRzA8d/o
+        DylIsEOUOyS85qGZhxXULsGG0kCrQ60uG3aIZ7iNZIZ/VuhFbSQIug5dUrpK4KGIIII0iQi3WtFCR6XD
+        3jne+Ta3uSG67dfvCZ7q9ODhA+/h9+X9Pc/LCx39/cBdCgbh6tCQlbC9ujI4WP8n5i4ODFhfLi4+q1Sr
+        WK5UpPKl0satyck79NLjcCEQEFihXMZMoSCV29nB8OzsY0dPTyN/MZzv6hKYurWFy+m0FJ+hhtn8fmjt
+        7gY409kpsGQ+j19UVYrPUMNEByedToGt0fpfUykpPkMNEx00tLcL7Cett0RHkOEz1DDRwRG7XWDrxSJ+
+        0zQpPkMNEx3UWa0Cy5RKmNR1KT5DDRMdHLRYBPZrextTm5tSw3M6Kp7x6Yab98HkHgYwNDcLnjx94w26
+        JBn3jIqnxz4mzz744WoJfQaApibBV9zdxRyt+L+7T1fQObX817XpBD5UESmOnBqNuQBMJgBF4QJaLofp
+        bBY1OkaGnnXapiMcxfAaojeO6P70z+0lRCW4EAEwGnlsvuzzPXkVjeJ8LIbv4nH8kEhgfHUVPY/eo21k
+        Du2j89h67w22hRbw3FvEo97nkWP+Fy4wGI1ms8Mxoel6tko/khQinvDOFOquT32vtfd56AIOgaGmpmWf
+        ooT26oCt9/V+y40+iunscPg3qfGIS2EPRjUAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="ColumnHasNoValidDataError" xml:space="preserve">
     <value>The selected column had no non-null values and cannot be used.</value>
-    <comment>An error message that is displayed if the user selects a column with no valid data</comment>
   </data>
   <data name="SaveResource" xml:space="preserve">
     <value>Save Resource</value>
@@ -631,59 +1591,171 @@
   <data name="CoordinateTransformationFailed" xml:space="preserve">
     <value>Failed to transform coordinates: {0}</value>
   </data>
-  <data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="cross" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABfUlEQVQ4T6WTu0vDUBTGz1+g
+        VBtB1KBgdSsUNFvHQoZChw4upWoRupYO7a6giw66KCj4wgciuAiKg5M4XcFBUHAVBxdXcfD4fTGJqaZT
+        hx+353yPezNUVFU6oaMwL/YKDkXkCJyIuMDw5LzvE6cx87eAIaPNpvIEbqTA0z5qtVBrKfCN5qvR0Id8
+        Xj/rdcXOAJYQ81apeNpLqRRovy/YxXOAuwPje7Wq146jr+WyciaPhYK3u8vlvB29zISfwAGCbEHYhOG5
+        WNSLdFpvs1m9ymR027L02LaVGj30xhbAIBswrMN4nkrpXiLhcZBMKnfU6PlXsIjlElgBqzCtwXyGW08R
+        DuCOGj30MhN+QlCw/GMwlwjGQY2edgUUzA3CAZzb7NyWF8zjOcDcIxzAeQG3kTiNmfATbAxTMNYRekIJ
+        T87D2JM4jZmwAL8HwdiEyNw0wpMis5hHwRAYACOOyAw1ejCPMxMt6MKiF/T79OHsAd2AWgJYET3JfVjQ
+        yd/5G8s+qAWdGU8YAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="PropertyTooltip" xml:space="preserve">
     <value>Property: {0}
 Type: {1}</value>
-    <comment>The tooltip displayed in the text editor when the cursor is over a property</comment>
   </data>
   <data name="UnitsSeconds" xml:space="preserve">
     <value>s</value>
   </data>
-  <data name="icon_help" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_help.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_help" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIfIAOXl5QA5cw4/cnaYt/////Hy8UJyoUl4pjVtoQs8bhRGeDVqn+Xi3hBPjkBwnhJH
+        elF/q/Dx8FWHtVaFtWCPvVd5nxRIePDw8AApYCdWhEdskRFCc16CptHt/0+DtgA5a53K9wU5bFaJuTRq
+        n0p4qUp6qVqItiBZjWeXwkVzorbK3FF+rPPy8Q9CdwAhYCRUiBhVjTZllW+gzzlqlrDV+0luk3Wo3Xyt
+        2TpqmTxrnFOBq26h05WswEBwnE1wl3Om1ZKtxc3p/+P2/zFsqOP4/43B802HvwdDfj5qkjx4sXONqG+W
+        wBBBc7LI3j5tm3KVt5aovPP7/xtMffT//yJUg2eMryRTf4Cs1xFNham7zEBvoGSTwFl+omGRw3ik0WeU
+        wFJ2m09/qej//3Wn2rLE1fPz8hxMfRxMfAAkXB5QhShZixJFdwU9ciVWjSVXh7nM4FiGsypbjISv2VZ7
+        n1iGsQw+b+fv+liNu7fJ3VyApQ1CclSDrwQ8cEF1qXSn1DJik2GNuVGBr8jp/63D1Tx0rHiRrB1Pfe/w
+        7z90qHao2aSzx8rX5SFRgvD9/5+30B9PgeT9/z1lioiy2/P08itflO3r6CFQgqHQ+3CeyQAkXWiZySxd
+        kOXj3lWJuwAuZhtQgrLF2QU5a3ut3oKu2DRkkgAuaYqiu+Pv97PV+c7z/yRfmyRXjMfl/wAza+78/3yf
+        wO/y80l7rkRrkOTr78Xa8Ut5p0d6rythlTxrmwpBduXv+Z2uv6zT+Fx7mQAnYPT08kt6q3em1iRVg5qx
+        yGCNvBBIesPe9jl0rP///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAADIACwAAAAAEAAQAAAI/wCRIasEq0CBMr8msSgQ4cIhTgLt
+        2BjjZ4eRJMeGEOqDAMEAZABE3ZAUTISjN01A6RhRK8WRAQASybmyZRYqVh1oRKlyq8eqPAB+jOqkAoQx
+        MkBoFdEV588nDgBkeJlwasoiVQ148BKC5MUDLgA0YaKw5NUeYFiyXHKVIU2uCgC6oPgiIVaJE4qCQDLF
+        hgofMADuEAMEZwWlYYKIQCn1yFArHwA8mKADwQCpRql2uWBkRoGnGgBsBQpzANemQXgsFZOyhgkGDQAQ
+        kTjgYEabOb2EtbAgoA4aWQAWGNCCQ40VAmIK+dqQIJSASABg5HASw80ZAgSUZNIT4oOAj08CiA8fT17A
+        d4EMAKhfz169wIAAOw==
+</value>
   </data>
   <data name="WidgetUpdated" xml:space="preserve">
     <value>Widget updated</value>
   </data>
-  <data name="icon_back_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_back_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_back_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQfAIaKkNjZ27a4vNbe4szS2dvh5M7U29LY39DW3c3T2vP198nP1s/V3MbM09Xb39vf
+        5PDy9PL09t3h5tjc4cbN097i58jO1dTa4crQ19re48TK0dbb3/Lz9d3i5svR2P///yH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIeAA/CBxIsKDBDwIOHhQAQGFBAQoaOhQI8YJEhwIiHDgA
+        QIDHjwwpcmCAAEGFDhIeZJiwwQGAAAAgEEhgoGYCAhgsNNAw4OUHAAU8ECAwoKjRoj5hFliwAIDTp08D
+        CFRK4WWAq1ivDlTqc+IHmF29wpTqdSrZshMDAgA7
+</value>
   </data>
   <data name="FileCopyError" xml:space="preserve">
     <value>An error occured while copying file: {0}</value>
-    <comment>A message displayed when a file copy fails</comment>
   </data>
-  <data name="layers-stack-arrange" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layers-stack-arrange.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layers-stack-arrange" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACuElEQVQ4T4WQb0gTYRzHnze9
+        it5ERC/KIOkvUpggRC8qKggiiqQXWWH+CSvMtNIoonrRP6LAwoSiCYqmc61tOp2bzm06N4fTuXm67c7d
+        ttttt+223ea2eiFxPY8xuUTs4MPdc8/n+/vec6D4YhMoejgkJA+uz0NK/wNy8kDVq9g/Aw43ai7osKjc
+        x2Y13mhmcC3QHnKQKxyw3AxftnxSLzjeyF3GtfjQj+tVtrCMjGTUhQ3qa8sDLr/wg1zz5EIc80az0QUm
+        HVyNJ5wJjbti1Ltelw4PpZWH7qvKQOVLtgQOISH8etQ3xZZ6dIkIDgc/E2Njc4FU38F7A+Wg9AlFKsaS
+        XK4Zo1IcbP4FG7I5CCb9Uz7K/a5+TS/BIPWo026w+5KKgjplJTh3F+PReZRTIbPDn6KNLpadJrms1ZNY
+        FOIOLmaRC4PUgzabwerhZAdqe2+AY+VGHp1HZqFNMEjpsEjEQiQyZjyeEjJLpTLIhUN9tSKrHu5J99XI
+        q0FhyQCPziMe95ssRJxSzzCR0Xk2PeSIcCobk1BOMfG+qVB8zBlLIdfkjntvfrboR52sdPct6W2w54wU
+        fZaiXU8aDfOst8voDykmg8nvE3RMyAgWTSIXOmRFs9kA7z/yqyU1YNcpCfwsTvZxwG2AQfyr1hP4ZvQv
+        SsyBZA/C9Jfh2UgaubCZrhNN2kTDhHL79Y4qkH9agaZ2Pxc7tNIJmmgdIZ0tgwTdrMIZIRIzFUNuu84z
+        t6O8U7nlUkvdpuKyIrD/rJYfnAl3PO22a1q1HlJsChBd4xS+GvhPKOSuNAOwDQCwEf5EK6+xh8Xve51t
+        jzumdY1tVlODALRGfNG4Z5Gba96weSfMw+vIFYJs6mZYtT3c0z/NdK0F2kMOcmEkf7k5dxWcFF09XhH0
+        nagM8+uBnL1H396Bua0rYfjwB5D4p3X4gwOzAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="UpdatingConfiguration" xml:space="preserve">
     <value>Updating Configuration Document</value>
   </data>
-  <data name="database_share" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\database-share.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="database_share" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACqklEQVQ4T5WSa0iTURjHz6oP
+        Db8EpfghDLpRKH5RhBXJGIE52VzNVaybEGibFZZ9UNIuGDgIxRRzF3NL1FDx0tzm5iWdl3nZ61Rkajd1
+        inOogRJlkPDvvAMTh4Ed+MF5Xt73d97n/xwik8lIACJap+wC9j0S+DERi8UpS0tLmJ6ehtvtBsOMwmzu
+        hdU6hL6+SfrMi4WFnxCJREqJRLKzwOv1wuVyob29HSaTBbqyWhgqjGg29WJg8CNmPav/K6iBvqIJRnM3
+        +ocmMOP5tiXg8xO2tUFbiFIoFM1arRZqtRoqlQqZmZnIzs7270tLS5GRkdFCW4jxtxASEhMoCMhgBKYW
+        O0y2HnQ5hjHi/ozZheWtPyAkfJuEDTEwA62+GrrKGtRbrOh2Mvjkmd8uYCWbo9xJoNFXQVv1DnUtZnQ5
+        BzE1N/NvQXLiuV1lIBQKYxISEghd4cMsUqk0lcUgP2gbe6OEU6uEqyEfTocdzbYONLbaYOu3Y2DChSnv
+        V/D5/FSBQEBIenoRJJKH2NjYgNFoBL7U+Pk9WYn51jy0qpJQnnsbakMxqqz1aGM6MT43gcjIyLQs4WFC
+        4uPTwONdh8/nQ3V1NdZdOqz1Ff3lB6PBVH0WGp/Go+r1Ixhr82EpkKNQxHV0JO9Tkujoy4iISPRfXY1G
+        g+8DJRgtT4O94BraVDKMGe5h+cNL/KLit/fPgCm7g1V6AFs3yffqSFycAlFRMiwuLiI0NPT5K2nw+GDJ
+        jRXP+ydgNCmw5Eqgv8uDNjUanflyzBtz1nvyLrgbFMe69Bf3XKEhnlhjCQoKyuNyuQ/OhpGbj2NJXeGl
+        Q+OOwqsrPksuNmHr4qTgkRcCTsn5oxye+BSHnQIJo5ymRFCOU05SoqjoFit6xifMJjmxpDb2CKH3lxyg
+        7Kdw/gAsOxzv+3rD2AAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="Separator" xml:space="preserve">
     <value>Separator</value>
   </data>
-  <data name="icon_panup_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_panup_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_panup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AABuACwAAAAAEAAQAAAIxADdCBxIcKCRgggHMgDAQOCLAARSgEE4AMAANz2gcIAgwIIWNQUBCKyxgACJ
+        BwLWnAlCUKSbEyYCCDDAQ8CWLm0GunTjA00VAhseCEkiIUbCGS0CKKFQIcECCSESjgmwpASFHzsCpCl4
+        JAqCGxMqIEigowgEGgRBPGnQAIcKGQZgGMjA5uJAD0NQTPDC4gsRIGIimClT0ImVAweYSLmgIQKWK1kQ
+        TsEQxoWCESIcrOCSUCCZAgWaUMlho7NAJAU+dFDgICAAOw==
+</value>
   </data>
   <data name="InvalidConnection" xml:space="preserve">
     <value>This is not a valid connection: {0}</value>
   </data>
-  <data name="folder--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\folder--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="folder--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDUlEQVQ4T43OXUjTYRTH8XNh
+        gRJDd7Gk2yICZSu8C8K8qJsuIiG66E0rFkJXUZG4lK2xaavVYuKWbikT7U1p9EIks6JXdWbQC5GhlKYb
+        0/VvLnOp+3Ue6dlFqz8d+HAGO9+HPw3UEwnheqpk5v9UKTvqt5NkwfcgkOhWxzfcWGRHfTaSrPh2A+mp
+        TlXihhur7OiZlSTbYvwqFqLtqsQNNzbZ0ZPTJDUsxDowP9GmStxw0yA7emQmyTEfCSA15lMlbrhxyI56
+        60hypr74MTvqUfUz0gZunL21RCFGPacyXD8+NSM57P6n1LgfIw9N4MbFSu6b+IF7NRnu2ZEmJN5f+Cvx
+        38dQNTuJxXQa3LlFS7sduWR05lKpV/N2wy09Knq2QHnjyJL8cBFDXVUQe2ZuDneqqYnx+LS0/LKWCv0F
+        sUPx4zB0FWH6lT1L4p0T4WtGiD2hKAieoEuMp0Xr5UfChZ78qZ0xIwyd65bsu1mK2KAlQ3l9Bi86DkDs
+        4WgU3cfIx3ga88Nlk+X4k6F1LaL9dRlf+aueBvZD7LK+NK4fpVbGc07jpbOa8Er7injx503Qe9Ys2du+
+        EZHnpoz4SytCzbsgtv5uEoEjdKWmXDxAlMd0uto8ZdVoEda7VmN6wJxFGbIheH4bxG48SLcrNtOO3y1p
+        +Udxwfacx7rDy2ZKjDmTjj30QE3VVmoRDdP+AgqRc9vLR4PDAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="arrow-curve" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-curve.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-curve" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACE0lEQVQ4T2P4//8/AyWYIs0g
+        ixlUKo+AsVrNcQbt5nMMBl1XGQx7rsOx3dwXDCBsP+/lTCD2sJ75hMFs0l2wOs3GM4QNMJlwmwGkCYjP
+        gPGMxx4kGQByjXHfTZCtZ6Y+/PcfRJtNvOOB0wX6nVdMgZK9QLwNiE8D8RkYrj/943/39d//QXygOg90
+        L3ABBSptJ129nL3nzZu6099+Np//+b/x7I//dae+/68+/u1/4d5P/zO2vP9ff/r7f6DaMxoNpz0Y5Iv2
+        MiiU7GdQKj9U6Tnr+t2aE9/+lB789j9j+/v/Yaue/Pecd+u/84yr/x2mXARj5+lX/nvMufk/fcfr/0A9
+        Zxgks7cxSOXuMDVoOnq57PDnPxl7vvz32fbhv+2G12Bsvf71f4t1r/6brnn1X2v5y/8Ki57/t9709r90
+        3s4zMvm7PBhEUtaDcG/k8ruvw9c//WjYd+6BUs3B65L5Oy6Kpm88C5Q7A8fb/v6X2fn3P4gvmrrBA2gI
+        AwNv9DIQ3qaYt/kskO7lj13hDsQaQCwIxCxCSWsZBBNWg9ScEdrx/z+I5otZ7sHv3czALq3HwMAspsHA
+        ETL/DJt9RRWbbhADNgBTA1XnwSyuiaJMmNm6eDFQxBgLNgCK6QCxOlDNImaD2HAgWxiIeYGYHYiZQSZx
+        AbE4EEthwRJAMTEgFgFiAahGkHqQZhYgZqI8M1GSlUF6AcIC84BckOgRAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="FsPreview_ClassNodeTooltip" xml:space="preserve">
     <value>Name: {0}{3}Description: {1}{3}Geometry Property: {2}</value>
   </data>
-  <data name="folder--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\folder--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="folder--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3klEQVQ4T43SS0hUYRjG8Wfd
+        SlwEZbTOiBZJy6A2bdyUmzZhWRAIrSIiccpmmkZtYMqYUvNCMjJOacZAihhjF7qpUwZFRIYilcygTqdp
+        vIyXeXpf8TuLmA4e+PEe+N7/x1kcjNYBKl6HCuHepArTYaQWhofzUTLd60x2pPGYDsM+GF7+7mFutsuR
+        7kjjNR1ee2H41lL3uZrsdKQ70vhMh5dXYdSvzoS5Mt3hSHekqTcdnrth+FcSIWa/tznSHWn8psNQDYxA
+        9mc7FyabHC0nOihNYOgyEBN4csnWsDjVwsx48L+yP9o58cxFaRpEyaBLLhiotgUXJhqZ/nIzLz37FqsS
+        F7mWy1G6oLZ4dADoq1rXmPl6i9Ynf156Nvawkjr/LC1R97VDl+jZCUQv4G76c4BzH2rz0rP4gzPUOW1Z
+        1H0BhIFmuSQeKcBs/+4d7Cvevu5F2X7OvPPYrI/X+TZ8ijrHk0n2nkebAJokXiwv578iu7YxOVJj+yVf
+        9ip0gjoPDefYfQ73BCA/YvMVueRaAVJ3iosYlFB1H9nHxBuXLfXey1jLMerc259h6Cwi1WVygTxbxNbb
+        p/HYGvNxbtSdl55Fb5RSp+6ePIijGy0K5WVP5WG0+o/j6Wborjai8C+upHqE/vhN6AAAAABJRU5ErkJg
+        gg==
+</value>
   </data>
   <data name="ExportNoCustomCommandsSelected" xml:space="preserve">
     <value>No custom commands selected. Nothing to export</value>
@@ -691,62 +1763,135 @@
   <data name="TooMuchDataWarning" xml:space="preserve">
     <value>The selected column contains more than {0} different values.
 The calculated averages only accounts for the first {0} distinct values.</value>
-    <comment>A warning message that is displayed if the dataset is too large</comment>
   </data>
-  <data name="control-stop-square" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\control-stop-square.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="control-stop-square" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABcUlEQVQ4T8XTO0hCYRjG8Q8M
+        6YKE2RC1VRANQVNDQi65RVC0hDQEBS2F4FBQSy2BQxdrUOg6mDWEBJZJUdBSw1cEZYNh2AUywgiHEBSf
+        3ldQ+ChJcGj4cc6B/3nOtxwBQBSjqJf5w5mBjtWoMK29uYgsgIv77KkzN0bXC5PLEWD+Pq2YC6WR5XgA
+        uONeGWhzhAWR9rsUJs8Tec3eJMEd98pAqz0oiJy5SmA0EM8Z8cUwuPuKgZ0nWDwRWI/fwR33ykDztBRE
+        Tl18YXgvhn73I7qctzAvXqJzQeZYPCFwx70yUD9+Joi0nn7A7AzCtHT9q153CNxxrwzUjQUEkT2+KFpW
+        wnmZtp/BHffKQPWQVxDZ7o+jxhPLq8n7Ce64VwZ0li1BZONRClpvMq8qXxLcca8MlPatCyIbTgBDANAf
+        ApV+QEcqDoByUrZPz3TlTmuaUAeEEBqN0bah6XbJPxltm9SXKCfgAaIntQUw/Bj417/xG49phw+gF0Mn
+        AAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="ColumnValueError" xml:space="preserve">
     <value>An error occured while reading column values: {0}</value>
-    <comment>An error message that is displayed when the column values could not be read</comment>
   </data>
   <data name="RepositoryWipeWarning" xml:space="preserve">
     <value>You have selected to restore the package at the root.
 You have also selected to delete the target before restoring.
 This will result in the entire repository being deleted and replaced with this package.
 Are you absolutely sure that is what you want?</value>
-    <comment>A confirmation message displayed to the user, when creating a package that will completely wipe a repository</comment>
   </data>
-  <data name="icon_viewoptions_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_viewoptions_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_viewoptions_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUAAAAAAP////39/vv7/Pr6+/n5+vj4+fb299DR1M/Q0+bn6eXm6OPk5n6Ejs3P0oyT
+        nM7T2bG3vs/R087Q0vf4+fb3+PX29/T19vP09ebn6OXm5+Tl5uPl5vb4+PT29v3+/vz9/fr7+/n6+vj5
+        +ff4+Pb3987Uz8/W0M7Vz4qgitHX0dDW0OLm4uTn5P7+/v39/fz8/Pv7+////wAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAyACwAAAAAEAAQ
+        AAAItgBlCBxIsKCMCAgTKlyIEILDhxAhNojwoKLFixcnBgjgwsWHFzBCwhgQIkQBjR0/hhzAsqSIERNT
+        tkgxsmQIAi9hRnCRYuaKAQgkCJWQYASJiQJUpPgZQ0GGpws0kOgwEeTPmwVGaB1BoUOFiSBGskiR1YDZ
+        rhUsTISRYiyKERPiTnBQwoKHiQNOpHg7YgOHvwzsXpgYg4AJrRQqKE7r4cLgCASycu1wwILlxhcwTGzA
+        ubPnzwEBADs=
+</value>
   </data>
-  <data name="icon_invokescript" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_invokescript.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_invokescript" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIU6AEtypf///9bn92+wPq3D3hExZKq+r3ugdmupO1WHSD14K7fH3Jiymb7M37HMxlmP
+        RFeLTVyTSVuQRY/SS6DfUZjYTl6fN1iORJ6xxny6Qn+og4jHR5vbTzJpMpvbUIjGR3Gad4/RS4nISHvB
+        RIrOSXCzP5/eUaDeUJ7dUJPVTYfKSIbLSIDGRnWPsoLHR2WkOT95LD11Pp3cUJPVTIPCRZ6+rIPDRWak
+        OZfYTnGzQAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA6ACwAAAAAEAAQ
+        AAAIuAB1CNSBAYDBgwgxDNRhsEGAhxADNACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjgQAwYEDQ4y
+        ohzIQAKCATJEIIhQA+NMHQYkZBgQYAAFChkixPx5AMEJokVRmECgQcDPBB84QC3qYQMEqyl1KKiAY2vR
+        CgoItAibgEaKrSFm2OhQoMACgQdeTICqgsSEGyAW3BVo4MEAoixcrBjwwMBCgQwuWMgxooSFCwweD1yZ
+        QEGCA441BwQAOw==
+</value>
   </data>
-  <data name="applications_stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\applications-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="applications_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABc0lEQVQ4T5WSMWvCQBiGv8Ut
+        pZMIxcVMri4ZI4hjBhUdikvpYKmLS5cu/Qv5Bw4OdXCRokYQHKoGETooLhldgw5ZxMm399kkikZJAw+5
+        cHdv7uU5IvdJp9NULBZ9SqWSLHgUVK7AczJFo1E63VwoFMilbJrm0rIsLBZzzGYzTCYmxuMpptM5DON7
+        KdaVz/96+M7lcszrYDBAv99Hp9NBu91Gq9VCs9lEo9FAvV5HJBKpXASIYxEjgl72+z1uwWuu9s7n85+G
+        YaDb7foMh0OsVitst1vsdjtomlY9BITtPRr9oNfrYb1ew3EcZDKZmnfc0L11XYdt29hsNlAU5e0Q8J/e
+        qqp+JRKJDyYejz/zZt93mN7ZbPZdXJ0Hl3vuf9N3UO9UKuXdPwrl+7y36E7JZPIvJIzv896xWIwYSZKI
+        2CU7ZbdB8NxF72MBInbJTtltEJ5vWZZPtx3H7JKdstsgfN9Ed4EJwuWT5/XaW6yputouMn4B8esdOkQY
+        S3EAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="PromptUseOffice2010Drivers" xml:space="preserve">
     <value>Use Office 2010 Drivers? (these are 64-bit compatible)</value>
   </data>
-  <data name="icon_buffer_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_buffer_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_buffer_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQAAIyJk6y5xWibx7PN4423x/D1+cXHx3Ghy6PC3ZW9x4Gr0LXHx57Bx5S1xb3Hx7a/
+        xqDCx////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBBwARACwAAAAAEAAQAAAIiQAjFEBwQMGAAhESKlw4IIGDBQkEKCwwQIFBhAoWBABg
+        gIDECAISLICIIEJGACg7ChBAwACAAA4ORGjoMqWBmygBLFAgkGVNjj8NJBig0GfOnCoRFsWJ1OPChAKY
+        cmzwcWHIoBGfFriKNOvTAQywVl2oQOxThWUfcPR6diaEmxDGnh1Y8GDbhAEBADs=
+</value>
   </data>
-  <data name="icon_pandown_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_pandown_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_pandown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AABuACwAAAAAEAAQAAAIwQDdCBxIkCCAgggNCnwRgEAKMAndHOwBhQMEARa0qCk4AMCAGgsIkHggYM2Z
+        IAQZAGBwwkQAAQZ4CNjSpQ1BIwJ9oKlCYMMDIUkkxEg4o0UAJRQqJFggIUTCMQGWlKDwY0eANAWPREFw
+        Y0IFBAl0FIFAgyCIJw0a4FAhwwAMAxnYDCDoYQiKCV5YfCECREwEM2UKOrFy4AATKRc0RMByJQvCKRjC
+        uFAwQoSDFVwiuiFToEATKjlsaHaDpMCHDgocBAQAOw==
+</value>
   </data>
   <data name="TransparentName" xml:space="preserve">
     <value>Transparent</value>
   </data>
   <data name="NoColumnValuesError" xml:space="preserve">
     <value>No values found in selected column</value>
-    <comment>A message displayed when the column has no values</comment>
   </data>
   <data name="InvalidRecordCountError" xml:space="preserve">
     <value>Invalid record count in line {0}</value>
-    <comment>An error message that is displayed if the file has an invalid error count</comment>
   </data>
   <data name="NoRestorePathWarning" xml:space="preserve">
     <value>You have selected to restore the package at another location, but not entered one.
 This will cause the package to be restored a the root of the resource tree.
 Are you sure this is what you want?</value>
-    <comment>A message displayed when the user has not entered a restore path</comment>
   </data>
-  <data name="cross-script" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\cross-script.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="cross-script" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACFElEQVQ4T6WTT0iTcRjHn3D6
+        5nJbr+2dZo3Ci0KE6EC9rpNEl52yS4HFhKyItJIKCwnBlVYUFh0a2b95yYJRHdYunYJJZBZEeogxhJAu
+        ecnSt88zt5cF0WWDz37P832e5/v7A6/Yti3lUNawbpw3SIjIlEgXZArcfII2CXfhHjwE+nZRH4JnEHUM
+        tAiZ3wMD9nJf39pMe3tO8/slBg9ERhNVVe/QXz8S2QsbHIM4jRBlp8zbjo7ct54eO9vdvTIdCHziBKEp
+        rzeebm5eoJ6kb4duiEH+9Pk/NdBj3qF5QiQGmZlw+PvnSGT1ZVNTNt3SkkV7jlm99v7PQK7TMIbROCap
+        1tYfqVBo5XZ19Ry5XANdlb9OcAmhyLCINcIjJRoaFpONjT/HDWM27vd/HausnKUmF2CwgHOFonCewpDI
+        jceWlUsHg6sxw5i7KHIY7ektt3ue9cW5fxmcRFROi/ROeDzzmbo6e9Lny51FYkh06AzGMZfrI+tIP/mp
+        0kc8RnKc1z3Bvd9b1q83prlMnMTUVGM9oQ6gDcMresM641whSgJX4253bqG21h6sqPjQy0NG0Iu/ToKj
+        632XYfSIiMsxqKdwiN2/mObadE3NEvGVrSXDpWHbem9/l0ibY4C2ncLBA5jsF0kFRPag7QRC8YEHNoMF
+        24IinbtF9pUaeCn4QTdWdFAHNsFGMAqr5tprwhbHoJzP+Q95lHpGrVHH8wAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="icon_clearselect" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_clearselect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_clearselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZXAAEBAYSChPn6+b2/vvrond3Th9bm63CrvN7Vh6+8mOCnnLK8mnJ+jOzNYuTfi627
+        nIeZk3l+jvX28+LaiamMOSE7NSwuLMfd47SVnNDi6O7sj2ZdZIBoKdfn67TA0O/swv3///vKwd+zDV+y
+        qu3Zh395RpiimK26xaiouLC9xcjd5JRCL7m/0sytJvP19vL09qyuq4GCmd/s7/Lv+s/i6HV+hHk/Odet
+        EXqChdjMhURNV/vok+nljbuRAamDAfz8+6+9os3h5zU7L/n6+ujjjJ6iorS8yOLdisDZ4J+dlnpaWa3B
+        xY53O/nonIiSmbO/yrqAfbTAy914aNuvDUBeXLePAclWRv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABXACwAAAAAEAAQAAAIoACvCBxIcOCTBR8CXFHIcOHAEwl2NChIMcqDJjdaKATAkaPDFEAITKlCQSAA
+        DTwcABDowQQJET2YJNlI5AiClQxYzCjhg8MACSYnFMgBwAgKEEsOCIHxw2FHADowKIAwgkoRARQFxggh
+        ZUUFHEMGKrzSMQIUKzZquKAIQIaBIBY2KHHyouDGDjQurBybFUAGFUhWZnVI1iPhwYgJNlycNSAAOw==
+</value>
   </data>
   <data name="ExportNoCommandsSelected" xml:space="preserve">
     <value>No commands selected. Nothing to export</value>
@@ -756,43 +1901,100 @@
   </data>
   <data name="FiletypeMGP" xml:space="preserve">
     <value>MapGuide Packages ({0})</value>
-    <comment>The text displayed when browsing for MGP files</comment>
   </data>
   <data name="SymbolTypeNotSupported" xml:space="preserve">
     <value>Only symbols of type "Mark" and "Font" are currently supported</value>
-    <comment>A message that is displayed when the user attempts to modify an item with an unsupported type</comment>
   </data>
   <data name="FdoConnectionStatus" xml:space="preserve">
     <value>FDO Connection Status: {0}</value>
   </data>
-  <data name="clipboard-paste" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\clipboard-paste.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="clipboard-paste" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACc0lEQVQ4T43SW0hUURQG4PWS
+        0JsIFUQ9lWMTFo63RqXRLKoRDMbMcbyMWtqY5qBOjsEEFmlRJAaTlJRdTLtn+ZBBL4EE9rBDu0AlIURZ
+        D4VQjo3j7W+v0+xT+tSBj7M5Z6+ftdc5dC6diLVn/HXIaozIzc3NkVxhOfzs3z2qTisOB3TIDYKdMNFw
+        12H3l5GRD2C85mfqvbx36AF+GRAm3rfvRV9NKgYHX2Fo6B1GRz9reM3P+N1bfynkfqHq6OxmUsTrtiJc
+        L4nFRftaXCtej5v74nC7Ih7dpRtwuSAGPWUb8bK1ALJGqDpqTSVFDJ9x4NnRbDz2ZGguNNjQ1ujQnW8q
+        Q2eLC83bl72pLbSQ25FGdNqsEy9O5eGpb6fO7yvGr7k5/JyexvepKYwFAugbGECtPeWjzeeLzvZ6iU4m
+        6cTzZhueeLfqWr35mJyZwfjkJL5NTODT+Dh6+vvBlyyukgx0PIEUwe0/qrNoeGDHqrIRnJ3Fj2BQD/F3
+        d0OJtlqPUFMcKYLbv38gWRvkpfxoNJRkIiSPEAiFFoRwJ2Oyq23V1W7yxZIi+uvTcaVwHTodBo3HmYkZ
+        GRCUM1gcwjOxVFTUUaORFPGg2oyrRUZdXfEWzM3PIySPsTiEB2t2Oj1UbyBF9MqALtm+4i7MwLwc2Kzs
+        YnFIQAbE2+1e2r2SyL1GI3qrNmk/i1KZl6ZNnEO4Ez4Oz4QHOyXvMVlZPuJr1woi1+o/AbfKTboaWzzy
+        raYFHFkmJBlXfY00mVqiEhPLuX6ptHxPJImHB1O0r3CvMgl3XYm6O/sTwPi3ZryXa8K1FCUXsclL6MaO
+        CBL/g/dyjRT1G7y5F+bDPK+HAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="MissingColumnError" xml:space="preserve">
     <value>Missing column "{0}"</value>
-    <comment>An error message that is displayed if the file is missing a required column</comment>
   </data>
   <data name="OverwriteDisplayScales" xml:space="preserve">
     <value>Overwrite the current display scales?</value>
   </data>
   <data name="PackageBuildError" xml:space="preserve">
     <value>An error occured while building package: {0}</value>
   </data>
-  <data name="cross-circle-frame" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\cross-circle-frame.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="cross-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACw0lEQVQ4T22SXUhTYRjHXxI5
+        LG+UmWNSiAoLvFBJRZhswZHZUNyHU7tRU7ILZXThbpwM+7gQL6OMWiLTE4gfS01DJDJnq6a1dtxaR3Nz
+        ExVZBl504+XT+7wcQaMHfjsPz/P/vTsvHGI2m4nFYiENDQ3EZrORxsbGS01NTXoK1m0Z7PW4wwxm0UGX
+        /cgHcHSpczgcvWtra5GjoyM4PDxkYB8IBCI9PT29mKEHcP8ewFmt1nqPxzOGwveJCfjscMAyzzOwj9DZ
+        wcE+jIyMjGGWHsCxNzCZTMh1uhCSySSsdnSAaDTCL/r8093NSLW3Q6imhu3i8Ri43W4BHXRJXV2dym63
+        u3Z3k/CurRV+2myAlWhuPgfOfphMLLO1tQVdXV0udInRaORXVt5HPw6/gC/V1Uw+rW8GAyBny6/Tgd/9
+        HBYW5qPoEoPB0IKvtdjZCZLZDNOFhSx/cnICqVQKEokExGIx2NnZgeGsLFgsLmbZYPAroEt4nreLogiv
+        KiogUlsLSzQwqlRCKBSCcDgMkiTRe8fBQ2WBMpOXx7J+vx/QJXq9/m4wGITJsjJYr6qCmexs8NLgWXlv
+        b4/NkNdqNcv6fD5Al2i12g5R3ICZtluwWlQES/+RT78F3L1RqVjW5/sA6JLKysobU1PezbePn8JcQcG5
+        f56jAoIf0vHxMWM6NxeWHg2BxyNsokvKy8vVVqttIBSKwqTJAkJODrvzIhU3ZLBHWaDXw8z6+gZYLNYB
+        dElpaSkpKSkx9vc/9IbDMXhZWw9DmZnwiUpRGexxhjtR3AaX64EXHXSJSqUi+fn5Co1G0+J03p+VpANY
+        fjYKws1WGFTnMrDHmSTtg9N5bxaz6KCLdYFykeO4y0qlslWr1T0ZH5+Pb2//hrPgDHeYodkr6MguSaON
+        kqKhXEtPT+cVCsWdjIyMPsqgTB/OcIcZylXZSfsLjyUbBUyIGBQAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="PreviewRecordCount" xml:space="preserve">
     <value>{0} results found</value>
   </data>
-  <data name="icon_fitwindow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_fitwindow.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_fitwindow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZlAEJyokd1qBU2aPLyl/PzoPj4yvT0rJi2zPn9/O729/L4+PT1rLnS2eny8+fx87zV
+        26jB1bnT2vr62rHN1e/29/v86cLY3/f7+9Hj5vb2uq7L1N/r7q3L1OPu8PX6+vT1q7TQ2KrJ0qnC1Zm3
+        zObx8/z86ev09Pj8+7/W3PH4+Pz76bbQ2LHO1bXP1+Xw8erz9O319cDY3cHY3vL5+PT5+brT2rTP18fd
+        4bbR2Nrp7KjH0OTv8arI0szg5LjS2dHi5vb3u9bl6d7r7b7W3OLt8Or09ejy8+z19fT6+qnB1bLO1afG
+        0PPzn8Ta36vJ0ubw8r3V3OTv8Pb6+tXl6f399q3K07rU2q7L08jd4rLN1cPa373W3Oz19tro66XFz/f8
+        +/D398zf5MLY3rXQ1+v09QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABlACwAAAAAEAAQAAAI0QABCBxIsGAZAAgQnJAyAwyXBk+ICOkSBMBBBBc8KKAAI4DHjxgsAviCZOOR
+        BgEWEBgwQEAPkTQUJDBhxIWIAAZWCrghMkUCMg52JAlQIMMCJgK0iExQxEEUCAEqSCgg4IMAFCJfeIRa
+        gooKASMECKghkgROohIqCDggZogVHCI7BCCwAAjVAxa2RFihROSGAAMIGFgrA0qEMVk0iMwBOPDgBwxA
+        sODgROSUAGIzM2gx4UoIHSJ/hMHSJMYDHzYmVOGxxIvIgrAHlplNu7bt2QEBADs=
+</value>
   </data>
-  <data name="icon_pan_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_pan_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_pan_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQAAGtra7/Dy6Smq5KWm9bW1o2Rlri6veTl5q6wtPDx8czMzMPFx5mZmdzd3q6zuqir
+        r/f3+Lu9v52gpcbK0a+yttjZ262trcLGzre7w7u/xba4vP///wAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBBwAbACwAAAAAEAAQAAAIlQA3CBxIUCCAgggHSgAgIWHBhgcbQmgQAQGFBRUObADA
+        sSOABwgWECCwYAEFBQcYbNzQUMDIly8REGDAUKBLmCMxEFBA4KDABwZg6nzJc2CCDAV44hwpk+CBAktf
+        NtwA4YEACVCjTi05UoHMpVMHPBAZdWSBgRU0FLjQVYHbBQU0Oi2QYcKECwEcxE34dMCAAoATEAwIADs=
+</value>
   </data>
-  <data name="sql-join" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\sql-join.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="sql-join" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXklEQVQ4T6WTW0jTYRjGPwy6
+        CHLZKsjALhYVkkhJtJvqoiN0EUGSXaQX0oIEc4oNR+ga2kRUxJ106lquaOps03by72GosZzhVonWdJuu
+        nZxa2WhBV+t7ZEL3G/z4Xp73+b27+pNkMknSIS0Zf0zyq6zkdPUIOfOYYRUIRrmUm5S7qfccfcH/GRdd
+        OHB3DuRcr5+81+cIKgIbf2wb8b+u0U8xzQ3J9COAGRl26KBLD+TsHGBdEdtLFoK/9N82ExOr6wnGE42P
+        FLW+E84HtqwAMzLs0EEXDj3AInl883nt1IpiZT0x6l37baWlsWf6z9KesWU1MoAZGXboIIMDl+SWDxd9
+        CcVNiyn8sYT9Wp1N5Pb/NI7Px7reOEMtFlek86LQXGtyRaQvpwMNg85Qs8Oz2QuXnCgz8OjVyY+rWwbw
+        NRxnjvF0NVZXVKlkvHXA4o4qOPd1Naa5SIeC8dYqRrYzFVzCeTBQPOf/YXR6v+ut7rVu42xYya0yiPsd
+        AWWbeUkEMCMbeB+UbWeWJdHgTFAOlxwtfX213bSoGvoQ7m4e9og7GF8TTzbVJuydlclsy40AMzLsmoY8
+        T+U2b6NI526FS46UaNmnyvorX9h90pa3HolYvyDSTPg6z1YMSNTj3h6AGRl26KCb+7CPD5fszb9Fsi4L
+        Th7nvaoWaJzt6gmfUj8T1DT0u1WcUm09wIzsOd2hgy4cuPjtohzYnZ1XwLokKGbflley73Q9YRcqKzIv
+        lBcCOvOR7ac7dNCFk3JJBh32pIJs+h6mHKTso2SmyKLvodQOHchwMtL/mNL5lOH+A5i6WIwCDkE+AAAA
+        AElFTkSuQmCC
+</value>
   </data>
   <data name="UnknownQueryMode" xml:space="preserve">
     <value>Unknown query mode</value>
@@ -802,7 +2004,6 @@
   </data>
   <data name="FiletypeAll" xml:space="preserve">
     <value>All files ({0})</value>
-    <comment>The text displayed when browsing for all file types</comment>
   </data>
   <data name="NoActiveDataFile" xml:space="preserve">
     <value>No active resource data file selected</value>
@@ -813,45 +2014,186 @@
   <data name="TitleQuestion" xml:space="preserve">
     <value>Question</value>
   </data>
-  <data name="map--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\map--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="map--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACt0lEQVQ4T52ROU8TUACA32bQ
+        H6BxI+qgJqjEwRgHBhMHxcQoCwNLxSJYiiC0QcALRQIFIodURYW0hoKglSuAnGIVbL2g1gMFpAWRiCKF
+        QkA+34txMg76ki9v+b53iohTp8IlR/6D8EMZGUIcTE/X8h9DdRIhDqSmxizLBaw9adzpO0/PQBHuQSvO
+        wRYs/QNk9noxdvs43uxDV+cjttaH8lUnEWK/wRC7tLzMjfYUWgdN9HrN9HnMTAXaeTXzhspxPxkOH+fc
+        kOaEWLsP5atOIsTepKS4hR8/MDcfp95zgfYPBTQ/NfFp5i6Tcw4efx0h58kQ2W/h9Es4VjeK8lUnEWKP
+        Xq8LLC1RVBfHlZZEKjpTsbuy6HhRwMvXFfS+aaTS4+GsY5iUjhH0TSMoX3USIXbHxcX7FxfJr4mh0nkS
+        +8A5LF0neTRaytCUjS9zbbS527CNf8f0fpnE1mGUrzqJEGFabcL0wgKmW0ewOAxUPU3nWmsy99/n4xor
+        Y2z6Di5PtbzKMGWjCxg7hlC+6iRC7NJoEqfm58m7rqW8Kxlrr5GSBj0Nry/SOXQJ9+cKnANljPqdNE9O
+        cLr7HcpXnUSIHVFRSZOBAAUlseTcjCa3MpriRh2XGxO4ft9I1YOzONwlOPvLaXnRROGj5yhfdRIhtkdG
+        Jk/MzVFUoMNiN1LedoJcWzQ2Vxp2d6b82jxqH57H+62Gz7Pd1LraUb7q4kNChNgaEWEYm52lOEePrSqd
+        ivoULlo0WB4bqH6WIb82C+u+UO5uCaZ+23pqNq2T8zauBgV5bwlhFhvDw1O9fj/F2fEU5sRjKowhu0xD
+        tlWDqVpL4T0d5g1rCERF/UGpEE6xZufOMxPyVT/OzPyV24cPUyR3/U1xaCgnVqwYy1QnCAoOPrpq8+as
+        f0V1YeLXWClZLVn7DyhfdeInSrd8PdhgSYgAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="icon_zoomnext" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomnext.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomnext" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZ4AHBJJai7zuqxd9nFs1tgZLjH1xc5Zs/a5CtGdezw9Bg5bypGdWV7khY1bKu0vNjm
+        8oOGiKqxwcfb8GBocEFagpKfshI0ZKa80cza6JGRkoSHi622v2d7k8LQ3aSttmh8lre/x67L567C1a6y
+        t36QrjhUe5y20ODo8auvsz9SfSJAcoSFiBIzacvY5YSAfzAvLjg3N2xtb3V5fnCCov///6amp3h3d5Sp
+        vhg4Z+rv82RgXzBQeaCnr5qbnV5cWpmirEdhgdDh8hc2bEdKTevw9cXa76m1w+Xq79Dg8crc7oaKjRU1
+        aLC/z56quGRrcr7L2KTF52Z+oVxbXcjQ2OLr9RY3aoiOlEpMTIWUoxgzaqC50tri6s3U2YBqV9nm8yJE
+        cZiktMfS2Ofu9RMzYlhYWc/O1KuoqJyzy7bBzXqSsH98e6q8z9fb3xU3ZzhWfG50enyPoomXpJSVl6Wq
+        sY6XqM7X30ZegHyQowAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AAB4ACwAAAAAEAAQAAAItADx4GkSB4wLHWrMCFy40E4KBCx2PEEzJwNDgXQ49JgSpcGCExiYaLjIoMaI
+        HDQojEnzIAkWOQxJ2OCSYMsNCyqQFDkjhaERH0eItLigwEAVN2VgXIzBRgyQL0Ky4IhgYshFKyioePnQ
+        ZkkJKHfeXASxok4QCTMMhNEywcFFPDwg/BARogIcJwTeCtyghMyLKzI8EAAgYMDbAwXWFDiAJwAAwob1
+        MnQMWfLkxwIsX+6ieXKHgAA7
+</value>
   </data>
-  <data name="icon_zoomprev_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomprev_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomprev_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZpAK2km+XXyfX29+Xn6ZWdqJScqNPa4JqirsHCwq6vsLm+xNfY2dfZ29vg5cTGx6Oq
+        tMbJzZObpq2trJWcqqSkpcPJ0J2ksODj5ZKapszNzc/Pz87Q0vL197u8vezt7rW2tru7u7GztaiuuLe5
+        upWcqZScqefp6u/y9ZWdqb69veLp78LHy9ni6tfd4snLz5aWltbW1tbX2NLS0pafrMC/v9fZ3c7T2MzQ
+        1K2trfr7+8PExcLHzMXQ2vX2+MTJ0Ofn6N3g45WdqqSkpOHk5+fs8aurq+jt8fT19tTT0+jq7JOcqbm/
+        yLe9wrq1sOvv86CosqertsfKzb3Byc7R1fP09Z6ksLi9w6qwuP///5ubm9Xb4bCvr8nKytHU19rb3Pb3
+        +KOrtPDy9Nri6amvt8LDxPP19rO1ttPZ3+7w8gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AABpACwAAAAAEAAQAAAIqgDTCIRBY0sKJFOidBHIUKAGLxeGAHmipAqUMQ3TZBgQ5ogAC0GWkEljxQVD
+        GQsEYMlRIYIIIxC4pGHCEISJL2jKHMBgg8gZHGl8MJRA5QeYEgRmtFAhJkvGDx561EBBYsKBKwYoZHQQ
+        g8OJBwUKKGCxY0TGNAiSOBlAQAoPLSEYnEW7ocENAyvMJJgrUEeRF0I6pEkAIADfswAKH86Y2PBiho0f
+        Q24iOWNAADs=
+</value>
   </data>
-  <data name="icon_home_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_home_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_home_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZYAOTk47K8xp6iptXc4KGnrtHJsdTd58HN2r3Eyunw9P////r7+9LZ3Za3p7rF0rG6
+        xcbWzZGTlaGor7a+xKeqsOPn6+3u8Zqfo7zNyKattdHf6PT19rzAxPb4+9fc4rvG0tnd4PLz9fn5+sG5
+        pNbW3dDb5d3Wyc3X4sPGydHR0dDZ47fGxLK9yb7Lyb3I1qi9tdXZ3Y+Tl8rR1sHM2si+p8/S1cHM2MPL
+        07jD0KaqrbzFz+7w8p+lq7C2vPP09evr6q2yt+3q48DI0bbBzKm+tvf4+czW4Y+QkbC6xKCmrsXP2tXN
+        rPH0+LW8wq69u7rF0c3Q0srN0ePey/Hx8N3i5uzv8sfR3sPO2////wAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABYACwAAAAAEAAQAAAI3QCxCBQI4IGHIgVoUBjIEEtBJQ8ykFhCAUBDhwcMGJiBIyKFCRYHAjiQwMgV
+        FwEcIImRAyRBkiccGDjgIACPKBwugByZQIXMAB8CJKmhgAmMCxeaJCiRwMqBJwEkQFGgoMMGAQIjBDAQ
+        wEYAAigUaGBB4KpABBIicCUAxIeGEQUI7MCKBUECCQQi9KCi4EaBHwQq0EWwIICJIAwWiBBS4EjgwS0Y
+        IECQOISOAlIeYxkAocGLFTISVxlSoIAAARgGYLHAuQERJwtACCCQYspmhqw7C2gAIfVF3AOCXwwIADs=
+</value>
   </data>
-  <data name="arrow-270" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-270.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-270" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T6WPT0hUYRTFPyYH
+        QkkJMpgBNSYEiRY2SiAyFvhnUy0Cy4GeQpS6UDeaiQ4oucqVQiKOWIumRdMgWlHSX7UYXXhdCLpSU2FM
+        Z1NYDI4gc7p3cOS9N86qD35c7jnnO+97CoD6H+KXrzzdMXD1WdjLkA6vOZP4aLzANbJlhgY3gP6VGJ6s
+        A+yTOWMoKBnaVCaob/kAnrkoHi8dgD0yZwwFF3oXVPHAih56tBBFy4c/6JnfA3uk9yVvKMhr+6ryPUFV
+        2LeUgDxzETS8+YWu2QhYp4QnOcknFZxrn1LnO78raWeofWYXNb51NL4NQXbRxZdcygIxHR0zKr8rSHfH
+        1lAxQKj1r0J20cU/tiC39YuXW0mPO/ADZYOLuOVfg9mTvOEX7M2Tmq3pPTUHd3F9YhvXxn/C9WIThSOr
+        KPVtoDIQQsWrEKrfhSE5yRsKWFTZ9RPamfvjdPvbX+T6wkmUT/6G+JKTfFIBmyqrzq9l1r6ksul9ZAYi
+        R1z6GIXo4ksuqeDU5Tsq3elWGVXdKsPt09JrnlPBVAyW1zE4Pscgu+jiW20XlRzDC+LK4bGcLVBproea
+        9eYo2T8BMmUXXX+OK7ByIIdxMkUW570HlhvDJFP2Qxw8T6Z6wQk2shgbY0/BadbT9AX/ADWhA8f0EOn9
+        AAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="AlternateNameMissing" xml:space="preserve">
     <value>You must enter a alternate name, or remove the checkmark</value>
-    <comment>A message displayed when the user has not entered an alternate name for a resource</comment>
   </data>
-  <data name="arrow-090" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-090.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-090" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB1klEQVQ4T6WQTyjkYRzG32ax
+        WlK7xvhzsNnNxko7RYkiBzkoBwfZWtMmm4ucJIuTPeHCblgkB8q/SRPbYvewbStcvnsQ7QEzWOYgcVAT
+        iXn2faZ+mjEzqH3r09v3eZ73eX/vTwFQ/4Pv8MsPv5W1c0Pl9myp/P49VTjkVsUjh9Ua4c6ZOn3mmDcu
+        DVfAQzLoBrhrqu9f0LfLsHzeB9pWz9H/F+Ccr/W7v6B7kyHp2/Oi4dvpNR+dV6Ceq/2wT3jVsU5TPrmu
+        UDd3EkTXnwvQZy7oH2S2C0Xp3rpE64oHLcse1C8co2psB28mXKh17OKt3YnmpSMwx3zAT3zRtjKY3ros
+        /tTMOFHSI7BNbeOmx3xAgQ6o5++XfDxr/qWeNv6Q13YXinrXUDnlBGfqRob5kAVpTT9Vcv08kbIZN6xD
+        2yidPgBn6vRZErJA36LM7xwGkjd7gtSxQ+Q4jqF1MTzmggriC2tVtLVSxdkmDST96xni7B6kfdG7bVIM
+        LyIpS3EFPMGn6PXAkqkeVY0SsSx6YZr14smCF5yp0zdWyAKapoQMFVkxLJbvQOw88HgR4Ezdf4UqeKgD
+        TOWYChrHTeUDco2eqWuyNTHhnhChDbMm5RYStRflX/AP4Mv/7H+tMgIAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="globe--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\globe--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="globe--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADV0lEQVQ4T3WPf1DTdRzG327K
+        5WnY4RWnZ51pU0AvuXUlanJNVDDvILs8y5MpWaDmxWkCd96pSQgxmGBGOgc7ajBtuo7MdfxQ+wM1xmAT
+        227MpjOSTVwEDLG1cI/vz+KuP7y+d697Pt/353me7/tLkn0/k6TIStLPfiVp2W9PSVX9q6UVPhVzjmmb
+        UFV0Lu7ZJ/zRHPPvQRQUu+fypWZpbZ+97MofAYMzGDrvDka6R8ZDjZ6HgTUGn13cC9+TBYWWuTMO2Zvy
+        f+jznXUNoSs4jkbnCLS2IVy7H4IrDLj+Bo5aB33CJ2H/fxvkmadKdrXq8ptu+cvb/Wj1h7gggkbHEEzu
+        INoHQugcHkfnGHDtAVDa7vMLv0Tk8sxEk7YY0pP2Nzu3fnsTO8578bX7AYov38WBS3dxuncUPw0CB80e
+        6Hn+3T3g3O//QFbwo1PkJm3Wc8GGE18o62xDGToX1tT3Ikvfi01GD7JNt7GzyYst9TeQedyCqp4w9nPb
+        +6Y72Mx+kWOIKL28eY/5XlhR48CSqm6knHRghdaB1FonXq+xQ2nyoejqI+xuG0NqlQ3JFVa8edIWFjmG
+        CxSHLSmHLkbSdP2QHbEgobIbiZU2JKltSFRZIVfZkFrtwjumMTy/rwVyNZdXdkREjuGCNz5tWaGyhl8s
+        7sBLZV2QcWDhBAmsspIOvFbtwdrGMbyQ34L1JmCDfiAscgwXpB35clFR8/CC8htIqPgFi486kFzlgPyY
+        M0qyugdLj3mwpKQHM7U5iDWuxizdtpDIMVyQoV4Xl62/+Qqb5MzymttYpfEivdaLjLo7WKv1QnHCg1dL
+        7Yg7k4YP/ixAzKnkECk/Xkd7s7gg86up9JamIeFgZ2CVxo/M+gG8Z7iPbcYAtp8NRHV+/Q7M0C5HvEGB
+        jYFc0HHZINXNtFFtnIZo0zdE7zbMm5xtbJWXOQLKM8P4qCmITy6MotA8GtXntCuh8L/9BFTzTBevwE98
+        Ev9KyTzK+b5hTuFVd5a2f3iXaSRccOFhROic6py/pnz+cohKZYOL+1aCKmO7oqhjeQMiKfMsk0hPx6fQ
+        stwPSWnUUW5zG+W1WqIq3sX8wHTXbO8i0OHp12n+ZCmXRL8vYaZNlMxm/X92xugob8p12h2jncjRY8Vf
+        HJIr03vAAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="icon_selectwithin_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_selectwithin_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_selectwithin_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUsAOjs8K+6x5ScqICAgLSun+zs1uPhzs3Q0ujn0ebr7ebl0O3x8uru8O7u2OLj0aet
+        svj48Onu79rbzd3ezre8u/7+/vHx4cTHy/H09efm0LW6usXIxOXjz7e8vrC2verq0/b27LG2t+Pp6+Xk
+        z+7u2qKpsvv79+DdzPDv3fPz5LzBxtjazf///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAsACwAAAAAEAAQ
+        AAAIlQBZCBxIsCCLAAgTKlyIEIDDhxAhNhxAcYCAiA8nfkCgQMBFjBMzjDAgoMJHiQEADOBg4IQAExAE
+        EJhJAMDEigJApEAhgGPNhhAFWCBRoIAAAz9TqqQooEEBCSEeyLSZcgCGBREEOKBglCZVlQsYJBDQQcCK
+        DQcyVhUrogSACxoKeFDrsOJDARNOAsV4QIAKtQwDIwwIADs=
+</value>
   </data>
-  <data name="icon_selectradius" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_selectradius.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_selectradius" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQZAM2vsxU2aKi0ws2TlvLyl86Ym82Xm85ucM5hY85sbs81Ns9GR82rr8bMjs8cHM5c
+        Xs8xMaOuhqiXpKiAjc5YWs8bG6lYZM6Bg889PgAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBAAAZACwAAAAAEAAQAAAIjAAzCCyAQIEDCBQKCFy48MCCBAMYDEiA4QBDgQceGADA
+        kaOBBxYXFliwsWNHAwsUCkSQwKTLCwgWQhjgEkAACQAGQFjogEHNADcZVFiogKbLAA0CTFCwkOVPAkkt
+        iCR5lADUAAIaajQZwOrVrBgfRhzQNQJQoAwJGlQQwKyAt2AvCgQaVy5DrHbz2g0IADs=
+</value>
   </data>
-  <data name="application-export" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application-export.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application-export" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzklEQVQ4T6WTO2hiURCGB+0M
+        go0YtrwKaqlphKCVhQ/EB1qE9Ek2CYElsFvErRZ7KytBEAtBsFDBqK2P5MpmIckiaCGIKCqi+MAHyuyZ
+        W66Fhgx85zTzDWd+OICI8BnA5/NxjDPGxYFQL+f1eoEAj8dzXi6X3xuNBtZqNXx7e8WXl9/4/PyEpVIZ
+        i8UKu3msVP4gz//Fx8fiOzkMcgFcLtfXQqGAuVwOs9ksZjIZTKVSmEwmMZFIYDwex1gshtFoFCORCIbD
+        YRSLxRcikQgIWuGSZfChIodBLoDb7b7abre42Wz2wvM85vN5ZE+/cjqdYLFYABwOx/V6vcblcrkXWo3K
+        brff2Gw2nclkArBarbeLxQJns9kO/X4f6/U6C7Ek5EJ59Ho9YQiTvxmNxhMwm8130+kUR6PRDpPJBOfz
+        Oa5WK6Q1/y+dTvcDaNJ4PMbBYLBDs9nEarWK6XRaSD8YDGK73RbmcBz3U6VSGcBgMNwPh0PsdDp7CQQC
+        giyXy38pFIpTNgRAr9d/p11brdZeQqEQ+v1+1Gg0D0qlErRaLYBarX6g53e73YOgXnIY5AJIpdJLmUwW
+        +AjkSCQSIKjoPGZ8ORDqPRJMqs98ZXL/Ad8QklT8D+CBAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="icon_select_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_select_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_select_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZYAM3Q1fn58aKpsqKps/Dw56GosrzBxsLGyK6xtujp68jM0fT19bS4vuvs7KWstvn5
+        8Lq/xs7R1bm+xLm+weXm1ri9wO7u6Nzc3q+0uu/v6vHy8OHi5LO4wNPX2/j37v///+rq3cnM0uzt7KWr
+        te3u3dDSycPHyM7S0evs6dfY2dHU2fz89+jo4fr68LS5vqCnsbzAx6OptMLGxPf3+Pv79qOqtfHy8qyx
+        urK3v/P09MzO0Ojp6ra7wP7+/Ofn6Obo4NXZ3vv7893e36Cnsu3u5/T05ezt777Bx+fn1vr68/39+rzB
+        yNrb3PDx7qKptLK3vdDS1/v79drc4dXX3Pj47P39+cXIzNHUz////wAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABYACwAAAAAEAAQAAAIiwCxCBxIsCDBIUsMKsTiQEqHhQVrzDCiAuJAJzk+7FBgEUsMG0p6iABgcYCG
+        KjRWoCC5cECTKEkCBCESYWGBDAEeeGDx40QIhQUstCBABcOIGwwUCiBwwEURE0dSCFE6AYeEKyA4LFj4
+        AgYTKwZIyICycEMDLAkQlKDwxEdHHTyQVLjQEQsQCFMKBgQAOw==
+</value>
   </data>
-  <data name="question" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\question.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="question" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeUlEQVQ4T6WPbUhTYRTHH+9U
+        IvVbllsQC99yTdSYJtbULHJOsKFpzT7obNNFRaKJhVDfNAuCAgvKFRQRFFb41iau1iLMWiyDam4ZE0nI
+        2GDu9m1yOufWvCpEH3rgxz33nPP/3ecyAGD/gxCWKIeYJHuESXKsiC1FkjtmRG4go3+g2ijMaId2MUPZ
+        tQJNUqF9aI952ttyKRBqv8ZH2vr4SHNvIFTS7PHSDAWavwk0ycUOZ8vFQNjU8wN0bZ5VmHoWoKl7IbxB
+        /dyJAs2aGwxKk/Ktw8bu72F9lx+0Jz7g7Vaf05e9QLP6c3PhRNXTYYlyUCr+guKxabdhyld35gtUtX6C
+        iuNTcOXOR4FR57xg6h/wC7OaDi/sODTpk2BmWcBlPrTUnZ1ZLD/mhihlxjewU++AjgtOcLlc0Nk7Dmn7
+        ByBT+wQK9C8WKSMK0u/b9F0zkX3NLihtmoS8g3bIrByB+nY7uN1TcO/RBGRUDEKGdlgA5xEOM6Ig9e5Y
+        bef00q6G16CsdoBC9wy2VdnA5/MJZFWNCb0oObXOJQ4zokB++1aZ6X04V/8Wcg6LZB0YB2Jlj2qF7lWY
+        w4wo2HLTnF5unyk8Og35jR6BXP07CAaDAlRH+/SUqa1fOcyIgs3Xpeu29lsLDV6+yDwPRS3fQNXweVlA
+        NfWIvCMePl7eb+UwIwpkfYxLuapNSLNMFDTN8iWnQlCM5NW7BagmVI1+fn2qZYJ2OcwsCxiemPg0FpNg
+        qIxP7h2Xq62zBYY5vrT15xJBNfVoRju0S2elIBbfNyHbGSffy2JrzrO4kw9YXNvL32BNPZoxlo2kILEr
+        BRw2EpGNiOwf0IdolyPBL48SEnGn6e/kAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="InvalidFeatureSourceNoClasses" xml:space="preserve">
     <value>Feature Source ({0}) has no usable feature classes. Choose a different feature source</value>
@@ -862,79 +2204,249 @@
   <data name="FindReplaceNothing" xml:space="preserve">
     <value>Nothing to replace</value>
   </data>
-  <data name="icon_plotdwf_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_plotdwf_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_plotdwf_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIecAP7+/rW6x9PW48TD1uHg6ba6x////8HBxMTFyMC/wrK+y/r6+v39/cTD173JyMLG
+        0fT09/P09d3d5qGprPX3+MPFxtXW2dLT1vj4+JOjqcXFxujo6OLk5+Dl58TFyba7x8fIy7a6xuDi4+Li
+        4drb3cHG0Onp6cLP29vb3u7w8ODg6LG2utjc4IeSk+Tx6dTr5dLV4urq6palqp2ho6ezwL69vrTBz8TD
+        1ebu9rvI1Lq+vKSvvdzm89XY3r+/wtLV2PX3+dTX3tHQ3Ymbj+Lk6b/KxOvt8PD1+bS5xvz9/aGvvPX3
+        98LOzLa6yJ+suuvr66CsurzKyM7Q0OHf6NHT1uzu8sTGyb3KyMrKztLX5M3L2b2+wdbY3O3u8sTGyODg
+        6cbIyNrb4Le9v8rLzrq+y5GunKvMuNna3eHi5fDx8qayu7u7vpShq/Py9fX19ZKop8LU2Jmps+nq67TN
+        x5eosPn6++/1+bO/zKCsu/T398XR36Goqp+rutbX2r/AwdHe6tPW5O3v787M2sfL1fz8/K22v/X199ze
+        4t3c5rW6xr/Dz/n5+c7Q0cnKzdze5MTGyoaSiJenndPW4o+ul+Df6MDAxL3BzcHDxcvX1Jyws8XD142g
+        lv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACcACwAAAAAEAAQAAAI8QA5CRwoEJODKHcUMElBcOCCQA5c
+        2OFx4k0GDAMNCRkw4MqLIzj+5NgEaQUnQVoGAACwqMMcM3D0KJDRYganBitXMoBQZFKZTDTwsNlz8wkA
+        AwAYAOAQaQgdJTvUiBGoKacBFQR0TIhTyIYTNwNvACBA4EsYDzU08IEih2AASlO4gNjiBwaYNX0GEioR
+        4MClClIESKKQ5wKZgQWojAEkQoCAJUDONDoQADGAQxayAEBBAkGCEAESDQzAAkAVNF6sPEIgIc0GLKN7
+        dEnwIwAjRBGSmBBgaSCRD0Yq+QjQpE4MRUHaNFzwAEkBTiMGOWrIKSAAOw==
+</value>
   </data>
   <data name="FilterAll" xml:space="preserve">
     <value>All File Types (*.*)|*.*</value>
   </data>
-  <data name="icon_copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_copy.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACMACwAAAAAEAAQAAAI3AAZCRxIsCAjBwASAGiAAQGLAyQY
+        FBQQYoOMDg8gcMgQoYINgjNuWHgxYYSKFiZKLKBxYmANFAgVMnQIkUEBgQouULSIUSNHjwJFgAg5suTJ
+        lCtbenDxkseALExi1GmChtChMQUIDMiZpweQQkJw/EjyxJASPAYoCJVyxUmiOVr2YKlihg6iFBKWWsmR
+        BgoZMFv8BNEgCNCKD1rlwIGxRseSN3G8fOESQGDaGDDcDApzh0qfIhoCKRKI184QPmLK/PERhY2aRWcE
+        HibSZsqOLgH0HBEQAIkRg8AHBgQAOw==
+</value>
   </data>
   <data name="Confirm" xml:space="preserve">
     <value>Confirm</value>
   </data>
-  <data name="gear--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\gear--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="gear--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACkElEQVQ4T6WPUUjTURTG799N
+        zNnD9GGJpcRQJOZMNtCtGTPNxG0POn3oLUYPUREEwcCsMCmEiMpcTxW6UiNWgTYLNNNs/MVttOlGJi1b
+        son4nA58Od3vvyUTeuvCj3P4zne+ey8jIvY/SMsWi4XZbDbW3t7O7Ha7VDs7O42ccxmM2TN4sQP2BLS1
+        tR3jxvO8HkTd2dmhra0tytbg+WeA1Wo1OZ3OB5ubm+RwOK5y08X19SQB9NAwgwfePS9oaWlhnEvxeJwC
+        AT8lkwnyer3fE4kEAfSxWEyawQNvZif9BaPRyMxm86GOjo4bi4thCodDtLr6g9bWfkmgh4YZPPBiZ0EQ
+        0gEGg8HMhSvA7R6KRaMRGh0dWa6qqnoE0EPD7K8PO7sBOp3OGQwGaGbmI83Pi7S0tERabXWfTCZjAD00
+        zOD5MjRIMwpFVBSEBukFGo2my+fz0dTUFKFGIl+ppkbXK/AnAvTQMPN4POTu7ibq6aExQfgkBVRUVDSX
+        l5dfAwMDrp+hUJTGxz+E9Pra6wC9pHlubptMJm8qlaKmkpJXg4ydkgLKyspYaWnpYZ1Of1cUgzQ9/ZlW
+        VhK0sZGSQD/93kXvRo5Tar2L1Gr1vaKiouonjB8EqFQq0CuKYRobm6S5uSC5XI/jfn+UwMSbO9sTw/XS
+        sru/lmprlM94ADutUKQDCgsLQWtjY/NwIPCNKiuP9CuVytuiGKHZyafk6pHHsPz8oYFO1he/hjezkw7A
+        kcvlLD8/31JQUNCXl5enRg0t+GjyZZN08/0uYb7u6L4X8MC7ezIBUA5wNBw9yM3NPeNolfno9wrdupyz
+        fKKOXcjMtLwW404pJBOQw9v9HBWnJAs6axXe2hsEW5aGi+DFDvsDd0bcBZIplukAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="icon_ctxarrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_ctxarrow.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_ctxarrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhBAAIAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
+        /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
+        mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
+        /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
+        MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
+        mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
+        /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
+        M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
+        mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
+        /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
+        M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
+        mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
+        /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAABAAIAAAIFAABPBgIQOCDggIRKlR40KDBBwEB
+        ADs=
+</value>
   </data>
   <data name="InvalidResourceIdFolder" xml:space="preserve">
     <value>Must be valid resource id. Cannot be a folder</value>
   </data>
-  <data name="icon_measure" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_measure.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_measure" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQSAHFCCr2NKldCE9ajLmddJf7nWp3M3BJEd005EQGM5AGK4wGN4QEzZgGK5QE1ZwI0
+        ZQE0awE1Zf///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBAAASACwAAAAAEAAQAAAIWgAlCBxIsKDBgwgTDlSQAIIEAwYeRoQogSGEBgsiSDhw
+        YGNHjhIwRnjAwIFCkiYVqlzJUsIAAS9jwpwpswABmzhv6swZAEGAnz6B/uz5E4DRo0iTAmjJtOnAgAA7
+</value>
   </data>
   <data name="FilenameValidationError" xml:space="preserve">
     <value>Failed to validate the filenames: {0}</value>
-    <comment>A message displayed when the user enters an invalid filename</comment>
   </data>
-  <data name="table" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\table.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="table" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABzUlEQVQ4T52RzUtiUQDF71ba
+        R7RrGW5aVIQUNVPQYjCIwU2LNg3ZjMwUSViPzGKmmf6oiigcs+zZF5FSFn3iGJbo8yOfnrnnwXskuMkL
+        B8598Dv8uE+4AgGnzGSDcYrPfr8bDR6yYlRRpqpyYCgCDO5X8XGvgg9hHf2hV/QFi+jdycOxraFnK4vu
+        zQy6Nl7Quf4MMmTFiM/3Ta9WjYG1NIyB1ZSOX//KxkDgPg//bc4YUK4zmE88GwNkyIpPXq+nVKlYBl9U
+        DavHKfw8TGJFfcRy5B5L+3dYDN9ACV1j4e8V5oMJkCErhqenvxd03TL4ffyEV3lngmdnVt86OrL6+sEB
+        yJAVQx7Pj1y5bBlwIByPI3R+jsNEAjunp9g+OUFEftuMRrGhquCAwUhWDLjdM5lSqcZAk3eGBmangdk5
+        QIas6J2YmE0Xi3UN1MtLy2AvFqsxIENW9IyPe1OFQo1BRt4ZGpidBmanARmyonNsbC6Zz9c1iFxcWAa7
+        8k3evgEZsqLD5fI9aFqNQVreGRqYnQZmpwEZsqLd6VTucrm6Bhww/wIH3hqQIStaHI6VpHzRm2z2XSFD
+        Vtja2r422e1/GglZIY9Nplmm9Z0hY/sP0fXQjui6fQYAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="ExtentsTransformationFailed" xml:space="preserve">
     <value>Could not transform extent of layer {0} to the map definition's coordinate system. Extents ignored</value>
   </data>
-  <data name="icon_selectpolygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_selectpolygon.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_selectpolygon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIMLAM2qrs8YGBU2aKi0ws2OkfLyl851eMbMjqiToKOuhs6QkwAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIbwAXCFxgIIDBgwcHCixIAIDDhwAC
+        KGQIEaLEhQEaVnRI4CLFjQA6GhCYcaMABBFHkgQp4CQAhQFYHhAwACbLAjNrrjRZACfNnQ8bCujps2bM
+        oBKHJmjZcgFCgwoWCFg6oKpOhQNbXsWK9SfXr2ADAgA7
+</value>
   </data>
-  <data name="icon_pandown" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_pandown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_pandown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIeDAJhpZZpqZiJNeNikptelprG+zCBPfSJNdyJOfVJvjMybl9Kgn7ShnSNOeCJPea2f
+        nq6entWjojVkl6CBgB9NfjVjlB5OftOnqDJejp1xbp9wbM6cnbWEgbaGhKh3eJBkYbeKh9CdnM2jpMeU
+        kcCNirqIi9qoqZ5ybdOfodSmptenpbuKhriHg6uWkyNQeq59fNakpciYljZklaB1dCtXhTFhkC1Zid2m
+        qdilpJlxbah2cyBPe////9ioqLCRjtCdmrKiotuop8OWkaZ0c3+hvdmhpMyZlipZhkFiirWgnd2prcGP
+        jvXm6TNfjcmdmtShoMKPjoKVs9KanbmTkrqIiaiOjVFwjNulpZJnZqNwcpd0dE9wkGF8mNimpdimp7GR
+        kvfk6MeVlKyfqcSSkd6rqDVjk9KeoqGEgbyWk5emu36SscSUkjFfj8WUkDdlltOaoDJeirqurqOPjiBM
+        eax/f9Ghn8aUkyBOf9yorNympKJybtKeoMOTkcuYlShYh6R/fpx6eL6KjL6LigAAAAAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIwgAHCRxIkOCBgggNCrTjJcCUKgkH
+        NRgkQoeQKwDIzIhTMIGABBN6BBgxAICSPxAIFhBQ4AwdAgDW4ACAx8kXgi4E5uCQJ0CbAR1upPCR8EOY
+        Lix+vNlj4gKDhBpUwNgQAkURAmgKeohRJ8sSKQvMPIkQRAzBJFiMKHhRQtCYPnzApLFCEAigFVBAkKAS
+        iEmUMn62FGwxJMMJPTzUHKlQgwYShA/kaCFi4E4TCRgsRBzEBQGCOTbcwNk8iA2FHQ4MyAgIADs=
+</value>
   </data>
-  <data name="icon_selectwithin" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_selectwithin.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_selectwithin" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUwAMnY6Ud1qBU2aAEBAYBoKfLyl+Tfi97Vh+nljZeirOLaicjd5Pf3vPX2s+Ldimp9
+        hv7+/vr62lZsif397ENccrvDjs3h54qYhWZ7etjMhdXZkt3Th+jjjMfd48nPjvX0qvPznGp/evn50Nbm
+        6zVReNfn67/GjfPzou7sj9/s73CBl150eMDZ4M/i6NDi6IGPoP///wAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAwACwAAAAAEAAQ
+        AAAIlgBhCBxIsCCMAAgTKlyIEIDDhxAhNhxAcYCAiA8nokBgQMBFjBM5ODggAMJHiQEADFCwIYOACREE
+        EJhJAMDEigJEMPgggGPNhhAFNDhRoICAAz9TqqQoAEQBEysoyLSZckCKERYEaAhhlCZVlSVadBDwQECF
+        CwkyVnWxgAUJAC8wFJCg1mHFhwI8nASKMYEAFWoZCkYYEAA7
+</value>
   </data>
-  <data name="icon_panup" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_panup.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_panup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACDACwAAAAAEAAQAAAIxAAHCRxIcKCLgggHFhBQQKAdLwGm
+        VEGYQECCQSJ0CLkCgMyMOAUbCJzQI8CIAQCU/IFA8IDAM3QIAFiDAwAeJ18GuhSYg0OeAG0GdLiRwkfC
+        D2G6sPjxZo+JCwwSalABY0MIFEUIoCnoIUadLEukLDDzJEIQMQSTYDGi4EUJQWP68AGTxgpBIIBWQAFB
+        gkogJlHK+NlSsMWQDCf08FBzpEINGkgQPpCjhYiBO00kYLCQUCAXBAjm2HADp7NANhR2ODAgIyAAOw==
+</value>
   </data>
   <data name="BaseLayerGroup" xml:space="preserve">
     <value>Base Layer Group</value>
   </data>
-  <data name="icon_print_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_print_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_print_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIIAAJmZmdra2rS2uLe5u7W1vbq6uv///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        BwAGACwAAAAAEAAQAAAIYgANCBQAoKBBAAUEKhQIIIDDhwEKJFxooCFEhwUiUrR4MaNGhRcfShwpcMDB
+        ggMuAmAYkqPDlQRbCoAIwKTLlwgfFsR58KXOmyp/hqT586TRokAN6rTZEsDMggJKGh1A0UBAADs=
+</value>
   </data>
   <data name="FilterXml" xml:space="preserve">
     <value>XML Files (.xml)|*.xml</value>
   </data>
   <data name="HeaderFileMissing" xml:space="preserve">
     <value>The header file does not exist</value>
-    <comment>A message displayed when the user selects a non-existing file</comment>
   </data>
-  <data name="icon_search" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_search.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_search" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIcAAAAAAP///4CLnpWeriI3WjRJazVKbDRJajVKazdMbcHGziI8ZC1Ne0hadq+3wyA8
+        XyZDZEVzpVmDs1WBrTxtnNvu/ydNbo7I+aLV/6TW/43J95rQ+4O32rLg/9nt++Dy/xxGYC9VbabY97Ph
+        /dHo9+X1/zRriH/A4L/q/8Dq/8Ps/ylTZLrW4srx/73p98/1/6/h6Wayup7W3Kzf5EyDhiZnYEJ9dmm1
+        q63h2h1jWFKmlXK7q4DEtcHu5BtiUY/OvjRyXUeWeVKegi1sU225mESVbFSpeCiLUCeKTanLtRyBOC6O
+        SWCxeBF3JqvQsg1yHRB1ICmKNy6OPAVoDCSFLKbKqQRlCQRkCBJ1GBZ5GxZ5HKXJp6THpgNiBgNhBQCq
+        AAClAACkAACdAACUAACLAACKAACAAAB/AAB1AABrAABiAABhAABWAAFdAgJeAw+jDw+bDw+aDw+RDzi5
+        ODi4ODicOF/CX1+2X2azZmGqYWasZmGkYaDdoKDaoKDUoKDToKDQoKPCo/D68PD58O/37/D38PP58///
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACHACwAAAAAEAAQAAAI6gAPCVQgoAEBAg0EKBDIUOCABCFo
+        FAkywQKCAQ0PDYAAREoUGSI2xKjxAOPABEO0ZGECowOGE0hMHFh4SMAKLFR6vFAxIoOGI01ACBDYwMYP
+        HC9apHB5AYoVHw0EEhBCZIYLFCU+VCCxhUsSB1I57DDCo8OHL2jTpm0g4UYbN0s8gKHDRxCfOWDAhBHA
+        QIeXNmyciOlj542dPmISKzAQQcmVLoHGDIIzJs6gMZg1LqDwZEoVMn/uyLnjp4xphwVA5GBhpg6gQoAI
+        4TljhiHBBg7Q6Natx1AeNBkFphlOfI+hNMEPqVm+fA3zgAA7
+</value>
   </data>
   <data name="ConfirmDeleteResourceData" xml:space="preserve">
     <value>Are you sure you want to delete this resource data?</value>
   </data>
-  <data name="globe--pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\globe--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="globe--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAADRElEQVQ4T4WPe0iTURjGz7ag
+        IqIIKrALFV1MC8UoZ3bRNLcuaEV0I82otIwaUSldNdOG84bV1Llp5dTKS3nJ0HWjLMvMSbWhW7ZVeMm+
+        wjkr15A9nfMl0X8d+PF+57zP72EjwmPPiTCumYjOvyMi+cdRIkVXsCi1W0Epp9wbngr+ne4XHMoj+Z6e
+        fhaB4HajQBBA/hYkmmbQEpWv5lOr/OlXrsRod1Sb7K6W/iFHccdPbnVJdyvbL4xRBsjE4tNISECVQPD4
+        T0Fs04xx8a2VsppP3WVtfXhlH0KxsR9qfR8avzjQ5gTafgE5j6o4r72KN4ODgwhxc8u4QkgIEUbXjhbG
+        6Apkle97Uhp6oOtx0AIXig19qDDZ0dDrwEvbEBo/PsHdmvUY7D6BSSt26sdPc1+iIfQIdpZIPE7WGXfd
+        NGN/tRXXTN+R+LATZx504nr7AB59A7JqbqK8TMrL6txA+MmSLMwT7NDSgo05FyPy9X3SgjasvtqOMG07
+        tpZ2ILzCggOVVsRpC3EpexkvZ2QuR3ReIXbQPPMo9CdIUuqO1H52BioN8MpsgTjXAH+1ASs0Rqy/WI3c
+        /GBeVmSsRGiyEt6pzVibq3cyj0ILAs81iePvu4IKujAnuQnuaS2Yn6aHR7oe4aeigO8mxJ/3RaSmBtOO
+        1cMnnZanvXAxj0ILAhLq/RXNzpmJLzBb/gpzFHrMG4ZusSkyGBL5LYQU/8B0WT3WVQAbtb1O5lFoJCj5
+        smdcnW1uyhu4p77FggwDvDMN8Mky8ninv4ZvVge8kl7DX/UZknIgSPnexjwKLZCmr5kQrjUvoiEfylKl
+        BatUVkg0VkjzPyBEbUVgTgcWX2jFlrvgmXrglpl5RJJKC0KzR5MNqiL3sy+5VaoehF7txfaSL4gs5bCn
+        jOMnu0uzzDjcCATnmTmW573QbFqwtZCQbUWzRoSX6nzkBi7ihg0HK+04emcAsbUD/GT37ZpObL5u4UZG
+        lulYnvcY/JnsQf9K0iyyu6poauwzU5i6yxZT0e88fueni012n3K0wcT2fI7l/zki+j2RMp+MnSwmflH7
+        SERpAYmqu0eidU38ZHf2zvaEMJvlmccfIWXM8KMbnf+DySzPPPIbH8MN9etvR7oAAAAASUVORK5CYII=
+</value>
   </data>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="MgCooker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
+        YQUAAAAJcEhZcwAADsIAAA7CARUoSoAAAAHrSURBVDhPhZLtS1NhGMb9T/rQx6ACyUVDyQjDaKAGQYOB
         Ew2K9ilifrA+LDAMablFb1IM03DbMXMwj4O15VZ5iPly2Go0yzCzF0iwr4OdX3seOxK1owcunofzPPfv
         vq77nLo6i2d44j0Xb8elgk90rO7VfN80dB13coLmyUFalCMcHjvJ+fBnHkdLu4Psty5wKhZgz9022tUw
         9oiHpuQy+1IG7umNnQGdfkV2bA4fq3ZtpCP+EI9u4NAM6mMJDkaDuPoj1pCGgUt/LDfiSYV4sFzGm6/g
@@ -945,35 +2457,80 @@
         WFv7wcxM6j8JZ9++bzL/aISV/Ja7mnNYqmY07YouQubg/l1NwG/XLb2y/7oFegAAAABJRU5ErkJggg==
 </value>
   </data>
-  <data name="icon_restorecenter" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_restorecenter.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_restorecenter" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZdAEJyohU2aKTFzsfc4bLO1eHt7+729rDN1d7r7b/X3drp68nd4ur09Nno6uTw8Xuf
+        veXw8dno69ro67HN1efy8+nz9KrJ0YqpxbbR2KbGz+/2973V3K7L03+hv/P5+cLZ3tfm6bPP1qnI0dfn
+        6qjH0dbm6rPO1cDY3c/h5r3V27fS2bHO1avK0eHt7uHu73yfvnOZuMvf46vK0rXR2Ov09NPk6Mzg47jS
+        2YCiwNLk53+iv8jd4nOauejx84enw8/h5a3L07nT2nygvs/g5Nfn6cDY3u719rnS2XCYt8PZ3rTP1q/M
+        1LnT2ejy88Ta4ODt7rLO1m+Yt7zV24enxMXa4K/N1H6hv/P5+N7s7tXk6LbR17rT2s7g5QAAAAAAAAAA
+        AABdACwAAAAAEAAQAAAI0gABCBxIsGAXAAwMaDDAAAKCESgGJFBxAMBBAwEuXAlAoUCDAAtwBCBgEYCG
+        CwGmBKhQQEEAHQGEmChpxIOPABxdRMD54gjJgzRw4nSApYTQABNKQmhSoYeDJxJy2KCyYUaVkggKFGiB
+        QEKWIQOKBAkBpCSRBgoigKjBZceHFFoOyCj542iMAUmOiig5YEEHnE5ObMDJw0KGkgmsBHgQQMoWDAFg
+        BEAioOSNxUwCYFByIICFKAEqH1xBgACUCUs4sCCRQYDrkgVjD+xCu7bt27QDAgA7
+</value>
   </data>
   <data name="SelectPackageFile" xml:space="preserve">
     <value>Select the package file to edit</value>
-    <comment>The title of the dialog that the is used to pick the package file to edit</comment>
   </data>
-  <data name="map" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\map.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="map" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACnklEQVQ4T52RSU9TUQBGu1V/
+        gMYdS8PGhQtDXLgwcWEwMYYNCzYNFMFSBqENswwCgUIjg6KCgMVQELAyyVQGsVBskakWFASEgoWIYssU
+        huO7L/4A8SVf8hbnnLx3ryIoLS1QWth/LBBQKG6npKiklxM/fz2F4lZiYvixpNcOJdM8ms3QdAnOuVrs
+        c10Yp6bJsq2gG3QT0+lG3eImosmN4IUnf8FNrTbi8PiY55YEuuf02FbKGXWVs7lr4ZN3lro1H6lWN5lO
+        SLZDhNmN4IUnB27ExUXuHx1R3hlDq+sBlq8GOsf0fPe+ZmPHysjPJfI/LJD3GdIn4W7LMoIXnhy4rtGo
+        dw8PKWmJ5ElXLDX9iZgdOfRNGJicqcE2206dy0WGdZGEviU0HUsIXnhy4FpkZJTv4ICixnDq7EmYpzMx
+        DiQxvPyYhU0TP3Z66XX2Ylr7jX7+mNjuRQQvPDlwVaWK3trfR/8yDKNVS/1YCs+64+mZL8KxWsHqVjMO
+        V4P0K4tULO+j61tA8MKTA1eUytjNvT0KK1VUD8RTa9NR1qahbSaX/oWHONdrsE9XsOyz07nhIX3wC4IX
+        nhy4HBISt7G7i6EsgvyqUArqQiltV/OoPZrKHh317zKwOsuwT1XTNdFB8fA4gheeHLgUHBzv2dmhxKDG
+        aNZR3XuPAlMoJkcyZmeWdLWFNL3PZuVXI+vbgzQ5LAheeHLgYlCQdnV7m9J8Dab6FGpaE8g1KjGOaGn4
+        mCpdbQ4vLMlMearweFsYHH+F4IUnBy4EBiau+HyU5kVRnB+FvjicvAolebVK9A0qit+oefpWOpu+NLps
+        ekbGKxG88OTAuYCA+x7pVL95vf88wQtPDpzy87tzxt8/56QTnhyQntPSzko7f4IJ/rQI/AE63awC7yrB
+        bwAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="WarningMapExtentCalculation" xml:space="preserve">
     <value>Could not transform extents of one or more layers in this Map Definition. These extents have not been factored into the computed result.</value>
   </data>
-  <data name="icon_fitwindow_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_fitwindow_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_fitwindow_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUzAKq7y6u8zZ+svdbd4dfcztje4tbcyNfcy9Pb39Tc4NXc4MbS2MTR19ne3cTP2MjU
+        2djd1cDM1srV2sfT2MfT2cnU2tfe4dXd4cnV2sjT2dDZ3svW28/Y3dfd0cXS2M3X3NTb4M7Y3Nje2dLa
+        38XR19Ha3sXS19ne4NfcytLa3srV28PQ18PQ1sDN1szW29Pb4Nfd4dfczcrW2wAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAzACwAAAAAEAAQ
+        AAAIuwABCBxIsOAMAAUSWhgwQEECBCNKaOAA4KBChgoCaNwYoiLChQ0TBCBwwIABAR88whhwwSECByNL
+        CtjgkaUCEC8DQOhAAIUAGR4vJMAJs4EICAJiCMDgUWSAoicaCGghQMADjy9G6hQhNYIEDA8oeEQQ4ACB
+        DkgjqABLYYHHFAEMmBXgtcKDCQs8eNQQVy4BARUytPXAwCOHAFUTZ8BrgkHhgyE+uNggITBeEgxWsPBY
+        sPPAGaBDix4NOiAAOw==
+</value>
   </data>
   <data name="InvalidColumnNameError" xml:space="preserve">
     <value>Invalid column name</value>
-    <comment>An error message that is displayed when the column selected does not exist</comment>
   </data>
-  <data name="arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T2P4//8/AyUYrFmv
+        /RKDfsdlOLaf+4IBhh3mvZwJxDE2s54yWEx9wGDcdxOsXqP+FFgvVgOMe28wgDRA8RkgDcIxRBsAco1R
+        z3WwjUB8ZsaT//9BtMWU+zFEuQDmHcOuqyAnn+m8+uf/lAf//oPYQNfFYHhBt+3iTKDgGVy48eyP/0X7
+        vvzvvfnnP0gNUH0MShgAOUBbfv2vPfntf82Jb/+rj38F46pjX/9XHv36v2DPp/8ZW96DcfP5H/9B6tXr
+        TsbAA1Gp/NAZkIa0Te/gOGHdq//BSx7+95x947/LtMv/HSdfAGMQO2PHi/8gPXADZPJ2nmk8+/1/2aEv
+        /wsPfP4fvePdf88NL/67rnv+33nts/+mSx//15z3EIx9t77+D1Ivm78L4QLx9E0zxdI2nsGFVbd+/8+3
+        +ut/o13f/4PUANXHAA1BpAOgIINIynoMLJy8jkEgftUZoZ3//8vt+f8fxBZMWB0DUo9iALdxJAOXUQQG
+        5o5YzADEZyR2/f8Ponkil8TwuNczsErqMIAAPAzAPCyASVSDgS1o7hkQZrUri2EW00RRhWwAE1CGD4hl
+        gFgLiI1hmMmqeBmTUXIJlK8NpGWBmB+ImZENYAQKsEMNEQXSUjiwGFQzB5BmghtASXYGADrJ+mn64PZ5
+        AAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="FilterShp" xml:space="preserve">
     <value>ESRI Shape File (*.shp)|*.shp</value>
   </data>
   <data name="QuestionAddItemToFlyout" xml:space="preserve">
     <value>Add this item to the flyout? Clicking "No" will add it before the flyout</value>
-    <comment>A question to confirm whether dropping a menu item on a flyout will add it to the flyout or before the flyout</comment>
   </data>
   <data name="XmlEditorCursorTemplate" xml:space="preserve">
     <value>Line {0}, Column {1}</value>
@@ -984,8 +2541,18 @@
   <data name="SelectFolder" xml:space="preserve">
     <value>Select Folder</value>
   </data>
-  <data name="application--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABbklEQVQ4T6XUsUsCYRzG8ZdT
+        BwdBl4ZGFycRnJycXBwEFYTiwFErIgihpamhqX9BRBBMEOTgSEShKfVCowSlBCchDxRRUDgR5en9jRUG
+        b77wgZf33i+878EdA8D2wWKxmJM75hKCqHGyaDQqNxqN7mAwQL//gV6vh07nDe12G5qmgT9DvU6e+fwF
+        zWYHrdY7KpWnLrUsHA6f1mo1VKtVvlhBuVyGqqpQFAWlUgnFYhGFQgH5fB65XA7ZbBaZTAbpdBomkylB
+        V0jyd/CvQS2LRCIn2+0Wm81GCDXUslAodLZer7FarYRQQy0LBoPnhmFguVwKoYZaFggELhaLBWazmRBq
+        qGV+v/9yPp9jMpkIoYZa5vP5UtPpFKPRSAg11DKv13s1Ho8xHA53epRlqG73Nw8eD24cDo25XK5rOr6u
+        6zvd881GPP7LncXyyWw2W9Jut9/+RTabX1OSpP90JEkK48PKHXCHgqix7vUp02/gC8LYywg0EW0TAAAA
+        AElFTkSuQmCC
+</value>
   </data>
   <data name="InlineSymbolDefinition" xml:space="preserve">
     <value>Inline Symbol Definition</value>
@@ -999,11 +2566,39 @@
   <data name="NewLayer" xml:space="preserve">
     <value>New Layer</value>
   </data>
-  <data name="arrow-circle-135" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-circle-135.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-circle-135" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC1UlEQVQ4T6WSfSxVcRjHf93K
+        HxSNCKNkSGSpKyOMpfVi3aympVvRIhZXhWV3RSuypZmYl1WrvC1RrveX0UVKpXZ0N1Ot3MQurisvYbc7
+        pp6e56j+sP5o62yfne/zfJ/f93d+5xwGAOx/YNuylDyeeQPM5/YQ8707ssrvnkaEpCPtCIeUIBL0LGmG
+        ZmkNbbw4wNY/Xy2NkE+VpHTPKbKUP6YQQK2NbJlW+ReoFRgg+ntAbr/FzvzB0Oy+75mpirm6ZG72HTKF
+        AIE9QA92FQ51e+b2i/48gTDjA3O78VHPK/eTf1bvfExix0zm2ebJmn2Fqma3zN52hEOtjJVP6pI6ZgBn
+        wDuvT4FrLPkjuKb1EBZHyof2S1snYiKr1FlYX9ty/W0AhROoxdjjous0OpyB0Gq1CmsJH+CU3EXYS5o0
+        QadlgxLvjB6pc8qbrZuuKtjGKxwfQJtgT7wj571SUjUE8W1jWlzzgA9wSHzJHC6+sEl4Mu4bcv+zn/2F
+        50Jb6VNmc76NrYtvZdaxcuaEQRuSOhl6XESFCnAWSPMBNLA2ruUWDnOLoT75VuceM2uE/BMYEN2kAdJ8
+        gEV0A8GFNIzCoUo1T4R8HKhnKWk8Zh5Vz1aHVzKLqHqxe9prZWDZIASVDWjRXzgCmQi3t3oM3IqH4WDj
+        BFCN5BiflDGj0IfMJKxCTL3AymGdV+kICNO7VFgvvETD46UE5103DXuaZ8CudAJIu6R0KKlPkN5dM6pz
+        Lv8KHrVTYBwuUxiFlC18Rv3DRQQX8GwW6O7aqAO7Wh041OvAXT7LQ9q84husr9GBYZis2yC4WLTyaMnC
+        rywwdWTLD9zhfpGqF1zc5pL+SrVZ9kVr3jgP+jXzsKJAozW41KlCT7HMJ0EkMHNkdPEBeFkJtscXCYSn
+        4lALl5g5+Qs8zlwWBGQ/EohudvGQxh55OOOEmCJLfwcYYmGCrEEs/wFabIAIKOAngC8O+qdBFeoAAAAA
+        SUVORK5CYII=
+</value>
   </data>
-  <data name="document_task" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document-task.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document_task" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACBklEQVQ4T42SPWhTYRSGz1rc
+        FH+WgpWkYBFFOhgcLAiCARXFCB26dKhtaENJCA2ttgUXBQcRRxEcWhAdxCWLReMF6RIIgg4OIkZTSwnR
+        5v//9H0vOYL0Sr3wcHMv3/PmnHOPhJaWhNxYXr4Mbu6B7/riolxbWJCr8/Muwhc9Jivttv5qNHSrWtVc
+        uazZUkm/FYsurxxHcW4S+P8K4EOPqVKzqXmIP7e39Ws+r583N/XTxoZ+zOV0NZlUXjg7Bfx/KriSSEiP
+        cBkBhUrFM+TRyooa/mDwNhAil+JxY7raaulvlP+vEFbCduBMmycXo1FjpoYZOD8cN+RtNqXDz4/taocB
+        cGbMkwuRiBGpI+D0s6P6MHPfvbMS/uvLVErfZDL6Ym3NHSyciHlyPhw2ZpudjlYxh5Or/Vqs1Tzb4deB
+        M2uenJuYMKItBNQxB4aU63XPkC0Ew4maJ2fHx41Yu9vV95gBQ5zv7/T40yO7QrgncGLmyZmxMSPeQcDg
+        k4P6IH3PvbOSL4WCvk6n9UM2q8n1dS3iHZy4eTI8OmrMdbEobbThe3xAGxioVztcNjhz5olvZEROhUIk
+        wU3rogqGcB5eIRW0x7N06LpXfyAgg8HgLXdX9wjhsvEsHbv68OPQ4UDgjgW4IYAz4WBZDT8x96SBZ56l
+        A+jKfnCib2Agtm9o6O7/wLN06O4ALt15PeGOvdAAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="WidgetNameExists" xml:space="preserve">
     <value>A widget named {0} already exists</value>
@@ -1011,41 +2606,101 @@
   <data name="CustomCommandsImported" xml:space="preserve">
     <value>{0} custom commands imported from {1}. The following commands had to be renamed to prevent clashes: {2}</value>
   </data>
-  <data name="icon_zoom_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoom_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoom_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZfAHaFlJ2Sh9HW3Ojt8uDPvuPp79Tg5fP19uzw9O3x9OLo7t3l7PP1956foLa2t52d
+        nZ2dnM/R0tPU1ZKSk6SmqPX2987P0NHT1vDz9eDl6b29veTn6dzg5KqsreTo7KKkpsbZ26enqNba3e/y
+        9b+/wJubm7zEy4eHh7rH09Lc5tbY2tfg6M/OzvHz9sXHysvMzsrKypKTk9vd4LGwsKymoP///4KCgra8
+        wvDy87q7vdTZ3cvO0MvT28XFxeDj5a2trczT2+zw8+jp6uPl5tTd5uTo683V3Le4ucjKzLa8wcLDw7q/
+        w/T2983X4evt76GgoOTq7/n6+u/x9K2vsNjh6dTa4LSzs8vR2fHz9ba3uO3v8c/S1PH09szLy/L09QAA
+        AABfACwAAAAAEAAQAAAIqwC/CGRh5cmMLgITAkj4pYcEGRxEvNDAcKFAJT60eDkgxYOOLF8AiBQJI8KB
+        GlEYjAgCZQkJgRZ/DKngBAsGBAMUXHkAUyAEHEyKZEiQcwGREwy/hBDCgAvRAgaoAJlgYiSAHBZa4IQK
+        IsWNDklVONgwoMCCJiiMfNiS9AsSBy6qrOCRhEKDtgIvHClhI8aUHQ0CEMDbVkAAwYSTGkacOOHiwY0F
+        GqYR2bHAgAA7
+</value>
   </data>
   <data name="UnmanagedBrowserMultiSelectionNotAllowed" xml:space="preserve">
     <value>Multiple selection is not allowed when SelectFoldersOnly is set to true</value>
   </data>
-  <data name="sql-join-right" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\sql-join-right.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="sql-join-right" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC50lEQVQ4T2P4//8/AyWYIs0g
+        ixn0i7czGJbuZDAq28VnXL7bAoj9gTgSRHvUXghMbnu9MKXtzX0g/gWl5yW1vNKIrH7I4FdwFW6AnEfL
+        wdiVxx5Pe/j6247Xn36eW7j95ZGougfvY5oeXG5f8vr82gNfHs3e9OFO7axXz6NrHz6PqLofBDOA37Vp
+        f/zVxx/XPHrzdd+DV193Hb709kRA0aVPfctfPVqw/cOVpJ676xfv+nh12Z5P15bv/XSjd9mru775l557
+        ZJ3XYNAt3Gq7+ND9afdffd1958WX7UAD9mS1nbuf3XH9xdLdn66BcMuSZ0crZj/eBzTg+pJdH6+AxLI7
+        bjy3ijkwj0Erb1PE9SeftlyD4nsvv+43Ct3ysWvJ0+sT17450r7s1e6eVa8OhTVf29S98vW+pkUvtwHF
+        djXPf3xBx2/TfQb17PVpQJsPXnjwYT0I33j6aZeK++o/ncteHqqe+2wTCPesen3Au+ri+p6Vrw/CxDqX
+        vzyi4rb6F4Ny+uq4s/febTh55+2a7edfzNlw6ul0de/1H0un3DtVMefpZhBuW/biYHDD5a1Am/fDxEqn
+        3j+p5LL2PoN88nK3SVuuzdp4+umcnk03m2bsutvll3/4Vkjp+UfV855tB+HCaff3Z/Tf3lM7//nOsllP
+        N4PEQksvPFD33DGPQTp+sZBO9qqihfvvTu7dfLO9ac3Vhp7Vt1aahJ34nN/34HLTomdHA+subgfSh4pn
+        PAa5aHte38PzRiEnn+sFHNNg4NUPZBB0KVdXS1taWr7g5KR5++5OX3Pi8YKiydf3WsZe++SUdfVWdt/9
+        M21LXxwvnfb0VGzdw4fWsTdfaDkvCpLUSmMAAWYgFmGT1DHmdyqLEw6ZWiQcPrtGOHR6oYRDXZZlxLnV
+        DknPHjgmP//lkPT0oXnIsdXiKiFuID1QvQxMQAYXVEAKSEsCsSgQCwAxHxQLAmkxqBxIDUgzSA8T5ZmJ
+        kqwM0gsAucRqK8NQIioAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="SQLQuery" xml:space="preserve">
     <value>SQL Query</value>
   </data>
   <data name="InvalidFieldCountError" xml:space="preserve">
     <value>Invalid field count in line {0}</value>
-    <comment>An error message that is displayed if the file has an invalid field count</comment>
   </data>
   <data name="PromptName" xml:space="preserve">
     <value>Enter the name</value>
   </data>
-  <data name="layers-stack-arrange-back" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layers-stack-arrange-back.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layers-stack-arrange-back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC20lEQVQ4T4WQa0hTYRjHz5c+
+        RV+iog9dIOmKFGYEfakgiyAkQfqQIeYNK8TEvGDYBbpgUFEjB1oLTGXOtebmdG5q25w7c21ubi53OdvZ
+        dnY7u29uK4Tg7X1XyhCpF36cc3if/+/Pc7DDZa+x4o6pHDVPw1jts0h53fMoCQH/gUSz62EkONuJYxVd
+        FClQJhPuSFbqCmcmNwPdoRk0my/YByVXS1q0oEfiMHWPWuc24+24XS420HwylJGU3jWDdcHJdmmZzBwe
+        Hcdp4Apnw45g2r8RJ50JqKxR6qXQKrMH0qJz1XM5Qa4ZCpioubVvETAlzjhjggjl0zftpKXGEGWH4kcc
+        s/K7NzVWVD4BsLVmrSNmRs0aSxTA5p+wIbsGEUz/UFkjmZ5JRxAGqc4ho8LoTgoOXeYBrKhNUon2ES0E
+        1CZPyif+FgB6MpHVOeMr+dj8K9kXfEsQBqnWfoNC50zwD5RwAXbinrgK7cPX+HAYpIS4H2iIeEZtj6Xy
+        WaJSmSdccwBK3U0snRze8QouCgB2vGWiGu3DUXlwDRGjeEofmF2OpKdMoYTYEIyLFoKxsYVATGmJph6w
+        TQHcFnPd6tXIZy0R3tErMwArbBbVon0+yck5xXLExRJ7gEDrT36e90Xz+WoOJzsGFv1whqx5p1bA55ei
+        ch3AjjUJ69E+jAmbAgbtzDH36oDM+4ur9iZHEPgfppdC6Y4BQxg2+5pZWgODQ0fP3CBI7EjjaAO0DT/m
+        mGZ48z7iw5THxRB4Vt/wKZAPW0aDim4D6BWGwal6PThf43cXXmBVYgdv8+5MLtKDD4eN0o8zTpKDewm2
+        irJvBP4TCjWzpgnRnpuDdRiG7YZsxQoauI1SI815JbT03x/Uy9r7dXhbHugb0Se1Le2tHhLtuMZs3na6
+        qnjL9v0wDw+yvZfahBIjPTKuD7I3A92hmb/NBbnmtYNsyLrzOqvrX6CZrYWll2Bu13oYvvwGlvytQyev
+        aMIAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="icon_buffer" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_buffer.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_buffer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQAAEZCU1KTygpgs6jS54Sv2XuSpTJ6wL/e65jI40mOyObv92Wfz7LX6Iy+3hlquKXM
+        4rjb6leVykqUxY2bqK7V6JzK5Gih0FuazVCSybzd6sTh66TQ5mme0f///wAAAAAAACH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBBwAdACwAAAAAEAAQAAAIoQA7KODgwAABBR0SKlxIIAKCBhEEKFRAwIBBhAYaFACw
+        IYHEDgIiNIDIoUNGACgHeBSQYACAAhUcdCBwwWXKAThRAmhgQCBLCjopAEVJ4QIBhQIwDNUJgAIGAQiR
+        MmDAlMHThQkFTNVp9eNCAQEg6IQQwGtCBWAz6MxQFuvMBQd0Hojo1uQDnRro1jXwYAKAvGaxErAA4YGF
+        wFgHFjxYN2FAADs=
+</value>
   </data>
-  <data name="icon_zoomrect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomrect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomrect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZWAI2aptjb4q2km+vv8+/y9efs8eXXyfX29/b3+PX2+PL199Pa4Nrl6a6vsMHCwujt
+        8ujr7uHk5+Pp76SkpLu7u/T19ufp6qSkpfH09vP09fr7+9fY2aurq8LHzO7x9Ozt7tbX2NPU1sC/v8nK
+        ypubm+Xn6c/Pz9LS0t3g49ri6cLHy/Dy9N3k6/Hz9dXd5czNzcjIyL69vdvg5cPExbO1ttDf4ejq7Nni
+        6paWltrb3Nvf4+js787Q0uXp7ezw9NTT08bJzfP19ujt8bu8vfL09uzu8LGzteLp79PZ38TGx62tre7w
+        8t7l7MLDxK2trODj5be5usXQ2tXb4bCvr9bW1rW2tgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABWACwAAAAAEAAQAAAIqwCtABhIsGDBAAIDKFzIUCEAhA+tSJxIMaFAK1RETInxo6JFKyZyPImAIgSM
+        ihFflFhR4UCLHTqaUHx4YsOBIhoSYPAgBMiIiQ8pWECwJAgRAgMKIFECNICTDAgg9CDgo8CRFCSaVvmQ
+        QAHSAgyYLLhwMAkIrwMeMKhxowOUhlYc2EgrwUUUKUY8SnTAQwaLBSpoNNArcQYHHBOGWGkgwABhjwIa
+        P64Y2bGVgAA7
+</value>
   </data>
   <data name="DivergingName" xml:space="preserve">
     <value>Diverging</value>
-    <comment>A display name for the Diverging data type</comment>
   </data>
   <data name="AllResourceTypes" xml:space="preserve">
     <value>All types</value>
-    <comment>The list entry that represents all resource types</comment>
   </data>
   <data name="SelectSymbolLibraryFirst" xml:space="preserve">
     <value>Please specify the symbol library first</value>
@@ -1056,8 +2711,16 @@
   <data name="OdbcDriverAccess64" xml:space="preserve">
     <value>{Microsoft Access Driver (*.mdb, *.accdb)}</value>
   </data>
-  <data name="icon_forward" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_forward.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_forward" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUmAHGFoxQ1Z5TY9bS/z7nD0r7Y8sPd97nT7bjS7IG16sHb9cPe+IO57nCk2YK27HWp
+        3sLc9nir4cTe+Xer4Hqv5L3X8nKn3G6j2HGm23+z6XGl2rrU7oS578Hc9r3X8XOn3b7Y86Kvw7/Z9Haq
+        332x58Te+P///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAmACwAAAAAEAAQ
+        AAAIeABNCBxIsKDBgQAOKgQQQKFBACAaOkRYQIBEgQAyatRYYYJFhBJKLDAAQYGIAh5GfPhoAoABDgwc
+        JMhAgkKEBxgufATQQYDPnz4tNLAYgkCAo0iRbtBgcQABgQOiSh0A4EDTpw4BIAjgdGJLrlgnAujq1QTZ
+        sgoDAgA7
+</value>
   </data>
   <data name="InvokeUrlCmdDescription" xml:space="preserve">
     <value>Invoke URL command</value>
@@ -1065,74 +2728,1893 @@
   <data name="EditWatermarkInstance" xml:space="preserve">
     <value>Edit Watermark Instance</value>
   </data>
-  <data name="ColorBrewer" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\ColorBrewer.csv;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+  <data name="ColorBrewer" xml:space="preserve">
+    <value>"ColorName","NumOfColors","Type","CritVal","ColorNum","ColorLetter","R","G","B","SchemeType"
+"Accent",3,"qual",,1,"A",127,201,127,"Qualitative"
+,,,,2,"B",190,174,212,
+,,,,3,"C",253,192,134,
+"Accent",4,"qual",,1,"A",127,201,127,
+,,,,4,"D",255,255,153,
+"Accent",5,"qual",,1,"A",127,201,127,
+,,,,5,"E",56,108,176,
+"Accent",6,"qual",,1,"A",127,201,127,
+,,,,6,"F",240,2,127,
+"Accent",7,"qual",,1,"A",127,201,127,
+,,,,7,"G",191,91,23,
+"Accent",8,"qual",,1,"A",127,201,127,
+,,,,8,"H",102,102,102,
+"Blues",3,"seq",,1,"C",222,235,247,"Sequential"
+,,,,2,"F",158,202,225,
+,,,,3,"I",49,130,189,
+"Blues",4,"seq",,1,"B",239,243,255,
+,,,,2,"E",189,215,231,
+,,,,3,"G",107,174,214,
+,,,,4,"J",33,113,181,
+"Blues",5,"seq",,1,"B",239,243,255,
+,,,,4,"I",49,130,189,
+,,,,5,"K",8,81,156,
+"Blues",6,"seq",,1,"B",239,243,255,
+,,,,2,"D",198,219,239,
+,,,,3,"F",158,202,225,
+,,,,4,"G",107,174,214,
+,,,,5,"I",49,130,189,
+,,,,6,"K",8,81,156,
+"Blues",7,"seq",,1,"B",239,243,255,
+,,,,5,"H",66,146,198,
+,,,,6,"J",33,113,181,
+,,,,7,"L",8,69,148,
+"Blues",8,"seq",,1,"A",247,251,255,
+,,,,2,"C",222,235,247,
+,,,,3,"D",198,219,239,
+,,,,4,"F",158,202,225,
+,,,,5,"G",107,174,214,
+,,,,6,"H",66,146,198,
+,,,,7,"J",33,113,181,
+,,,,8,"L",8,69,148,
+"Blues",9,"seq",,1,"A",247,251,255,
+,,,,8,"K",8,81,156,
+,,,,9,"M",8,48,107,
+"BrBG",3,"div",2,1,"E",216,179,101,"Diverging"
+,,,,2,"H",245,245,245,
+,,,,3,"K",90,180,172,
+"BrBG",4,"div","2,5",1,"C",166,97,26,
+,,,,2,"F",223,194,125,
+,,,,3,"J",128,205,193,
+,,,,4,"M",1,133,113,
+"BrBG",5,"div",3,1,"C",166,97,26,
+,,,,3,"H",245,245,245,
+,,,,4,"J",128,205,193,
+,,,,5,"M",1,133,113,
+"BrBG",6,"div","3,5",1,"B",140,81,10,
+,,,,2,"E",216,179,101,
+,,,,3,"G",246,232,195,
+,,,,4,"I",199,234,229,
+,,,,5,"K",90,180,172,
+,,,,6,"N",1,102,94,
+"BrBG",7,"div",4,1,"B",140,81,10,
+,,,,4,"H",245,245,245,
+,,,,5,"I",199,234,229,
+,,,,6,"K",90,180,172,
+,,,,7,"N",1,102,94,
+"BrBG",8,"div","4,5",1,"B",140,81,10,
+,,,,2,"D",191,129,45,
+,,,,3,"F",223,194,125,
+,,,,4,"G",246,232,195,
+,,,,6,"J",128,205,193,
+,,,,7,"L",53,151,143,
+,,,,8,"N",1,102,94,
+"BrBG",9,"div",5,1,"B",140,81,10,
+,,,,5,"H",245,245,245,
+,,,,6,"I",199,234,229,
+,,,,7,"J",128,205,193,
+,,,,8,"L",53,151,143,
+,,,,9,"N",1,102,94,
+"BrBG",10,"div","5,5",1,"A",84,48,5,
+,,,,2,"B",140,81,10,
+,,,,3,"D",191,129,45,
+,,,,4,"F",223,194,125,
+,,,,5,"G",246,232,195,
+,,,,10,"O",0,60,48,
+"BrBG",11,"div",6,1,"A",84,48,5,
+,,,,6,"H",245,245,245,
+,,,,7,"I",199,234,229,
+,,,,8,"J",128,205,193,
+,,,,9,"L",53,151,143,
+,,,,10,"N",1,102,94,
+,,,,11,"O",0,60,48,
+"BuGn",3,"seq",,1,"C",229,245,249,"Sequential"
+,,,,2,"F",153,216,201,
+,,,,3,"I",44,162,95,
+"BuGn",4,"seq",,1,"B",237,248,251,
+,,,,2,"E",178,226,226,
+,,,,3,"G",102,194,164,
+,,,,4,"J",35,139,69,
+"BuGn",5,"seq",,1,"B",237,248,251,
+,,,,4,"I",44,162,95,
+,,,,5,"K",0,109,44,
+"BuGn",6,"seq",,1,"B",237,248,251,
+,,,,2,"D",204,236,230,
+,,,,3,"F",153,216,201,
+,,,,4,"G",102,194,164,
+,,,,5,"I",44,162,95,
+,,,,6,"K",0,109,44,
+"BuGn",7,"seq",,1,"B",237,248,251,
+,,,,5,"H",65,174,118,
+,,,,6,"J",35,139,69,
+,,,,7,"L",0,88,36,
+"BuGn",8,"seq",,1,"A",247,252,253,
+,,,,2,"C",229,245,249,
+,,,,3,"D",204,236,230,
+,,,,4,"F",153,216,201,
+,,,,5,"G",102,194,164,
+,,,,6,"H",65,174,118,
+,,,,7,"J",35,139,69,
+,,,,8,"L",0,88,36,
+"BuGn",9,"seq",,1,"A",247,252,253,
+,,,,8,"K",0,109,44,
+,,,,9,"M",0,68,27,
+"BuPu",3,"seq",,1,"C",224,236,244,"Sequential"
+,,,,2,"F",158,188,218,
+,,,,3,"I",136,86,167,
+"BuPu",4,"seq",,1,"B",237,248,251,
+,,,,2,"E",179,205,227,
+,,,,3,"G",140,150,198,
+,,,,4,"J",136,65,157,
+"BuPu",5,"seq",,1,"B",237,248,251,
+,,,,4,"I",136,86,167,
+,,,,5,"K",129,15,124,
+"BuPu",6,"seq",,1,"B",237,248,251,
+,,,,2,"D",191,211,230,
+,,,,3,"F",158,188,218,
+,,,,4,"G",140,150,198,
+,,,,5,"I",136,86,167,
+,,,,6,"K",129,15,124,
+"BuPu",7,"seq",,1,"B",237,248,251,
+,,,,5,"H",140,107,177,
+,,,,6,"J",136,65,157,
+,,,,7,"L",110,1,107,
+"BuPu",8,"seq",,1,"A",247,252,253,
+,,,,2,"C",224,236,244,
+,,,,3,"D",191,211,230,
+,,,,4,"F",158,188,218,
+,,,,5,"G",140,150,198,
+,,,,6,"H",140,107,177,
+,,,,7,"J",136,65,157,
+,,,,8,"L",110,1,107,
+"BuPu",9,"seq",,1,"A",247,252,253,
+,,,,8,"K",129,15,124,
+,,,,9,"M",77,0,75,
+"Dark2",3,"qual",,1,"A",27,158,119,"Qualitative"
+,,,,2,"B",217,95,2,
+,,,,3,"C",117,112,179,
+"Dark2",4,"qual",,1,"A",27,158,119,
+,,,,4,"D",231,41,138,
+"Dark2",5,"qual",,1,"A",27,158,119,
+,,,,5,"E",102,166,30,
+"Dark2",6,"qual",,1,"A",27,158,119,
+,,,,6,"F",230,171,2,
+"Dark2",7,"qual",,1,"A",27,158,119,
+,,,,7,"G",166,118,29,
+"Dark2",8,"qual",,1,"A",27,158,119,
+"GnBu",3,"seq",,1,"C",224,243,219,"Sequential"
+,,,,2,"F",168,221,181,
+,,,,3,"I",67,162,202,
+"GnBu",4,"seq",,1,"B",240,249,232,
+,,,,2,"E",186,228,188,
+,,,,3,"G",123,204,196,
+,,,,4,"J",43,140,190,
+"GnBu",5,"seq",,1,"B",240,249,232,
+,,,,4,"I",67,162,202,
+,,,,5,"K",8,104,172,
+"GnBu",6,"seq",,1,"B",240,249,232,
+,,,,2,"D",204,235,197,
+,,,,3,"F",168,221,181,
+,,,,4,"G",123,204,196,
+,,,,5,"I",67,162,202,
+,,,,6,"K",8,104,172,
+"GnBu",7,"seq",,1,"B",240,249,232,
+,,,,5,"H",78,179,211,
+,,,,6,"J",43,140,190,
+,,,,7,"L",8,88,158,
+"GnBu",8,"seq",,1,"A",247,252,240,
+,,,,2,"C",224,243,219,
+,,,,3,"D",204,235,197,
+,,,,4,"F",168,221,181,
+,,,,5,"G",123,204,196,
+,,,,6,"H",78,179,211,
+,,,,7,"J",43,140,190,
+,,,,8,"L",8,88,158,
+"GnBu",9,"seq",,1,"A",247,252,240,
+,,,,8,"K",8,104,172,
+,,,,9,"M",8,64,129,
+"Greens",3,"seq",,1,"C",229,245,224,"Sequential"
+,,,,2,"F",161,217,155,
+,,,,3,"I",49,163,84,
+"Greens",4,"seq",,1,"B",237,248,233,
+,,,,2,"E",186,228,179,
+,,,,3,"G",116,196,118,
+"Greens",5,"seq",,1,"B",237,248,233,
+,,,,4,"I",49,163,84,
+"Greens",6,"seq",,1,"B",237,248,233,
+,,,,2,"D",199,233,192,
+,,,,3,"F",161,217,155,
+,,,,4,"G",116,196,118,
+,,,,5,"I",49,163,84,
+"Greens",7,"seq",,1,"B",237,248,233,
+,,,,5,"H",65,171,93,
+,,,,7,"L",0,90,50,
+"Greens",8,"seq",,1,"A",247,252,245,
+,,,,2,"C",229,245,224,
+,,,,3,"D",199,233,192,
+,,,,4,"F",161,217,155,
+,,,,5,"G",116,196,118,
+,,,,6,"H",65,171,93,
+,,,,8,"L",0,90,50,
+"Greens",9,"seq",,1,"A",247,252,245,
+,,,,9,"M",0,68,27,
+"Greys",3,"seq",,1,"C",240,240,240,"Sequential"
+,,,,2,"F",189,189,189,
+,,,,3,"I",99,99,99,
+"Greys",4,"seq",,1,"B",247,247,247,
+,,,,2,"E",204,204,204,
+,,,,3,"G",150,150,150,
+,,,,4,"J",82,82,82,
+"Greys",5,"seq",,1,"B",247,247,247,
+,,,,4,"I",99,99,99,
+,,,,5,"K",37,37,37,
+"Greys",6,"seq",,1,"B",247,247,247,
+,,,,2,"D",217,217,217,
+,,,,3,"F",189,189,189,
+,,,,4,"G",150,150,150,
+,,,,5,"I",99,99,99,
+,,,,6,"K",37,37,37,
+"Greys",7,"seq",,1,"B",247,247,247,
+,,,,5,"H",115,115,115,
+,,,,6,"J",82,82,82,
+,,,,7,"L",37,37,37,
+"Greys",8,"seq",,1,"A",255,255,255,
+,,,,2,"C",240,240,240,
+,,,,3,"D",217,217,217,
+,,,,4,"F",189,189,189,
+,,,,5,"G",150,150,150,
+,,,,6,"H",115,115,115,
+,,,,7,"J",82,82,82,
+,,,,8,"L",37,37,37,
+"Greys",9,"seq",,1,"A",255,255,255,
+,,,,8,"K",37,37,37,
+,,,,9,"M",0,0,0,
+"Oranges",3,"seq",,1,"C",254,230,206,"Sequential"
+,,,,2,"F",253,174,107,
+,,,,3,"I",230,85,13,
+"Oranges",4,"seq",,1,"B",254,237,222,
+,,,,2,"E",253,190,133,
+,,,,3,"G",253,141,60,
+,,,,4,"J",217,71,1,
+"Oranges",5,"seq",,1,"B",254,237,222,
+,,,,4,"I",230,85,13,
+,,,,5,"K",166,54,3,
+"Oranges",6,"seq",,1,"B",254,237,222,
+,,,,2,"D",253,208,162,
+,,,,3,"F",253,174,107,
+,,,,4,"G",253,141,60,
+,,,,5,"I",230,85,13,
+,,,,6,"K",166,54,3,
+"Oranges",7,"seq",,1,"B",254,237,222,
+,,,,5,"H",241,105,19,
+,,,,6,"J",217,72,1,
+,,,,7,"L",140,45,4,
+"Oranges",8,"seq",,1,"A",255,245,235,
+,,,,2,"C",254,230,206,
+,,,,3,"D",253,208,162,
+,,,,4,"F",253,174,107,
+,,,,5,"G",253,141,60,
+,,,,6,"H",241,105,19,
+,,,,7,"J",217,72,1,
+,,,,8,"L",140,45,4,
+"Oranges",9,"seq",,1,"A",255,245,235,
+,,,,8,"K",166,54,3,
+,,,,9,"M",127,39,4,
+"OrRd",3,"seq",,1,"C",254,232,200,"Sequential"
+,,,,2,"F",253,187,132,
+,,,,3,"I",227,74,51,
+"OrRd",4,"seq",,1,"B",254,240,217,
+,,,,2,"E",253,204,138,
+,,,,3,"G",252,141,89,
+,,,,4,"J",215,48,31,
+"OrRd",5,"seq",,1,"B",254,240,217,
+,,,,4,"I",227,74,51,
+,,,,5,"K",179,0,0,
+"OrRd",6,"seq",,1,"B",254,240,217,
+,,,,2,"D",253,212,158,
+,,,,3,"F",253,187,132,
+,,,,4,"G",252,141,89,
+,,,,5,"I",227,74,51,
+,,,,6,"K",179,0,0,
+"OrRd",7,"seq",,1,"B",254,240,217,
+,,,,5,"H",239,101,72,
+,,,,6,"J",215,48,31,
+,,,,7,"L",153,0,0,
+"OrRd",8,"seq",,1,"A",255,247,236,
+,,,,2,"C",254,232,200,
+,,,,3,"D",253,212,158,
+,,,,4,"F",253,187,132,
+,,,,5,"G",252,141,89,
+,,,,6,"H",239,101,72,
+,,,,7,"J",215,48,31,
+,,,,8,"L",153,0,0,
+"OrRd",9,"seq",,1,"A",255,247,236,
+,,,,8,"K",179,0,0,
+,,,,9,"M",127,0,0,
+"Paired",3,"qual",,1,"A",166,206,227,"Qualitative"
+,,,,2,"B",31,120,180,
+,,,,3,"C",178,223,138,
+"Paired",4,"qual",,1,"A",166,206,227,
+,,,,4,"D",51,160,44,
+"Paired",5,"qual",,1,"A",166,206,227,
+,,,,5,"E",251,154,153,
+"Paired",6,"qual",,1,"A",166,206,227,
+,,,,6,"F",227,26,28,
+"Paired",7,"qual",,1,"A",166,206,227,
+,,,,7,"G",253,191,111,
+"Paired",8,"qual",,1,"A",166,206,227,
+,,,,8,"H",255,127,0,
+"Paired",9,"qual",,1,"A",166,206,227,
+,,,,9,"I",202,178,214,
+"Paired",10,"qual",,1,"A",166,206,227,
+,,,,10,"J",106,61,154,
+"Paired",11,"qual",,1,"A",166,206,227,
+,,,,11,"K",255,255,153,
+"Paired",12,"qual",,1,"A",166,206,227,
+,,,,12,"L",177,89,40,
+"Pastel1",3,"qual",,1,"A",251,180,174,"Qualitative"
+,,,,2,"B",179,205,227,
+,,,,3,"C",204,235,197,
+"Pastel1",4,"qual",,1,"A",251,180,174,
+,,,,4,"D",222,203,228,
+"Pastel1",5,"qual",,1,"A",251,180,174,
+,,,,5,"E",254,217,166,
+"Pastel1",6,"qual",,1,"A",251,180,174,
+,,,,6,"F",255,255,204,
+"Pastel1",7,"qual",,1,"A",251,180,174,
+,,,,7,"G",229,216,189,
+"Pastel1",8,"qual",,1,"A",251,180,174,
+,,,,8,"H",253,218,236,
+"Pastel1",9,"qual",,1,"A",251,180,174,
+,,,,9,"I",242,242,242,
+"Pastel2",3,"qual",,1,"A",179,226,205,"Qualitative"
+,,,,2,"B",253,205,172,
+,,,,3,"C",203,213,232,
+"Pastel2",4,"qual",,1,"A",179,226,205,
+,,,,4,"D",244,202,228,
+"Pastel2",5,"qual",,1,"A",179,226,205,
+,,,,5,"E",230,245,201,
+"Pastel2",6,"qual",,1,"A",179,226,205,
+,,,,6,"F",255,242,174,
+"Pastel2",7,"qual",,1,"A",179,226,205,
+,,,,7,"G",241,226,204,
+"Pastel2",8,"qual",,1,"A",179,226,205,
+,,,,8,"H",204,204,204,
+"PiYG",3,"div",2,1,"E",233,163,201,"Diverging"
+,,,,2,"H",247,247,247,
+,,,,3,"K",161,215,106,
+"PiYG",4,"div","2,5",1,"C",208,28,139,
+,,,,2,"F",241,182,218,
+,,,,3,"J",184,225,134,
+,,,,4,"M",77,172,38,
+"PiYG",5,"div",3,1,"C",208,28,139,
+,,,,3,"H",247,247,247,
+,,,,4,"J",184,225,134,
+,,,,5,"M",77,172,38,
+"PiYG",6,"div","3,5",1,"B",197,27,125,
+,,,,2,"E",233,163,201,
+,,,,3,"G",253,224,239,
+,,,,4,"I",230,245,208,
+,,,,5,"K",161,215,106,
+,,,,6,"N",77,146,33,
+"PiYG",7,"div",4,1,"B",197,27,125,
+,,,,4,"H",247,247,247,
+,,,,5,"I",230,245,208,
+,,,,6,"K",161,215,106,
+,,,,7,"N",77,146,33,
+"PiYG",8,"div","4,5",1,"B",197,27,125,
+,,,,2,"D",222,119,174,
+,,,,3,"F",241,182,218,
+,,,,4,"G",253,224,239,
+,,,,6,"J",184,225,134,
+,,,,7,"L",127,188,65,
+,,,,8,"N",77,146,33,
+"PiYG",9,"div",5,1,"B",197,27,125,
+,,,,5,"H",247,247,247,
+,,,,6,"I",230,245,208,
+,,,,7,"J",184,225,134,
+,,,,8,"L",127,188,65,
+,,,,9,"N",77,146,33,
+"PiYG",10,"div","5,5",1,"A",142,1,82,
+,,,,2,"B",197,27,125,
+,,,,3,"D",222,119,174,
+,,,,4,"F",241,182,218,
+,,,,5,"G",253,224,239,
+,,,,10,"O",39,100,25,
+"PiYG",11,"div",6,1,"A",142,1,82,
+,,,,6,"H",247,247,247,
+,,,,7,"I",230,245,208,
+,,,,8,"J",184,225,134,
+,,,,9,"L",127,188,65,
+,,,,10,"N",77,146,33,
+,,,,11,"O",39,100,25,
+"PRGn",3,"div",2,1,"E",175,141,195,"Diverging"
+,,,,3,"K",127,191,123,
+"PRGn",4,"div","2,5",1,"C",123,50,148,
+,,,,2,"F",194,165,207,
+,,,,3,"J",166,219,160,
+,,,,4,"M",0,136,55,
+"PRGn",5,"div",3,1,"C",123,50,148,
+,,,,4,"J",166,219,160,
+,,,,5,"M",0,136,55,
+"PRGn",6,"div","3,5",1,"B",118,42,131,
+,,,,2,"E",175,141,195,
+,,,,3,"G",231,212,232,
+,,,,4,"I",217,240,211,
+,,,,5,"K",127,191,123,
+,,,,6,"N",27,120,55,
+"PRGn",7,"div",4,1,"B",118,42,131,
+,,,,5,"I",217,240,211,
+,,,,6,"K",127,191,123,
+,,,,7,"N",27,120,55,
+"PRGn",8,"div","4,5",1,"B",118,42,131,
+,,,,2,"D",153,112,171,
+,,,,3,"F",194,165,207,
+,,,,4,"G",231,212,232,
+,,,,6,"J",166,219,160,
+,,,,7,"L",90,174,97,
+,,,,8,"N",27,120,55,
+"PRGn",9,"div",5,1,"B",118,42,131,
+,,,,6,"I",217,240,211,
+,,,,7,"J",166,219,160,
+,,,,8,"L",90,174,97,
+,,,,9,"N",27,120,55,
+"PRGn",10,"div","5,5",1,"A",64,0,75,
+,,,,2,"B",118,42,131,
+,,,,3,"D",153,112,171,
+,,,,4,"F",194,165,207,
+,,,,5,"G",231,212,232,
+,,,,10,"O",0,68,27,
+"PRGn",11,"div",6,1,"A",64,0,75,
+,,,,7,"I",217,240,211,
+,,,,8,"J",166,219,160,
+,,,,9,"L",90,174,97,
+,,,,10,"N",27,120,55,
+,,,,11,"O",0,68,27,
+"PuBu",3,"seq",,1,"C",236,231,242,"Sequential"
+,,,,2,"F",166,189,219,
+,,,,3,"I",43,140,190,
+"PuBu",4,"seq",,1,"B",241,238,246,
+,,,,2,"E",189,201,225,
+,,,,3,"G",116,169,207,
+,,,,4,"J",5,112,176,
+"PuBu",5,"seq",,1,"B",241,238,246,
+,,,,4,"I",43,140,190,
+,,,,5,"K",4,90,141,
+"PuBu",6,"seq",,1,"B",241,238,246,
+,,,,2,"D",208,209,230,
+,,,,3,"F",166,189,219,
+,,,,4,"G",116,169,207,
+,,,,5,"I",43,140,190,
+,,,,6,"K",4,90,141,
+"PuBu",7,"seq",,1,"B",241,238,246,
+,,,,5,"H",54,144,192,
+,,,,6,"J",5,112,176,
+,,,,7,"L",3,78,123,
+"PuBu",8,"seq",,1,"A",255,247,251,
+,,,,2,"C",236,231,242,
+,,,,3,"D",208,209,230,
+,,,,4,"F",166,189,219,
+,,,,5,"G",116,169,207,
+,,,,6,"H",54,144,192,
+,,,,7,"J",5,112,176,
+,,,,8,"L",3,78,123,
+"PuBu",9,"seq",,1,"A",255,247,251,
+,,,,8,"K",4,90,141,
+,,,,9,"M",2,56,88,
+"PuBuGn",3,"seq",,1,"C",236,226,240,"Sequential"
+,,,,3,"I",28,144,153,
+"PuBuGn",4,"seq",,1,"B",246,239,247,
+,,,,3,"G",103,169,207,
+,,,,4,"J",2,129,138,
+"PuBuGn",5,"seq",,1,"B",246,239,247,
+,,,,4,"I",28,144,153,
+,,,,5,"K",1,108,89,
+"PuBuGn",6,"seq",,1,"B",246,239,247,
+,,,,4,"G",103,169,207,
+,,,,5,"I",28,144,153,
+,,,,6,"K",1,108,89,
+"PuBuGn",7,"seq",,1,"B",246,239,247,
+,,,,6,"J",2,129,138,
+,,,,7,"L",1,100,80,
+"PuBuGn",8,"seq",,1,"A",255,247,251,
+,,,,2,"C",236,226,240,
+,,,,5,"G",103,169,207,
+,,,,7,"J",2,129,138,
+,,,,8,"L",1,100,80,
+"PuBuGn",9,"seq",,1,"A",255,247,251,
+,,,,8,"K",1,108,89,
+,,,,9,"M",1,70,54,
+"PuOr",3,"div",2,1,"E",241,163,64,"Diverging"
+,,,,3,"K",153,142,195,
+"PuOr",4,"div","2,5",1,"C",230,97,1,
+,,,,2,"F",253,184,99,
+,,,,3,"J",178,171,210,
+,,,,4,"M",94,60,153,
+"PuOr",5,"div",3,1,"C",230,97,1,
+,,,,4,"J",178,171,210,
+,,,,5,"M",94,60,153,
+"PuOr",6,"div","3,5",1,"B",179,88,6,
+,,,,2,"E",241,163,64,
+,,,,3,"G",254,224,182,
+,,,,4,"I",216,218,235,
+,,,,5,"K",153,142,195,
+,,,,6,"N",84,39,136,
+"PuOr",7,"div",4,1,"B",179,88,6,
+,,,,5,"I",216,218,235,
+,,,,6,"K",153,142,195,
+,,,,7,"N",84,39,136,
+"PuOr",8,"div","4,5",1,"B",179,88,6,
+,,,,2,"D",224,130,20,
+,,,,3,"F",253,184,99,
+,,,,4,"G",254,224,182,
+,,,,6,"J",178,171,210,
+,,,,7,"L",128,115,172,
+,,,,8,"N",84,39,136,
+"PuOr",9,"div",5,1,"B",179,88,6,
+,,,,6,"I",216,218,235,
+,,,,7,"J",178,171,210,
+,,,,8,"L",128,115,172,
+,,,,9,"N",84,39,136,
+"PuOr",10,"div","5,5",1,"A",127,59,8,
+,,,,2,"B",179,88,6,
+,,,,3,"D",224,130,20,
+,,,,4,"F",253,184,99,
+,,,,5,"G",254,224,182,
+,,,,10,"O",45,0,75,
+"PuOr",11,"div",6,1,"A",127,59,8,
+,,,,7,"I",216,218,235,
+,,,,8,"J",178,171,210,
+,,,,9,"L",128,115,172,
+,,,,10,"N",84,39,136,
+,,,,11,"O",45,0,75,
+"PuRd",3,"seq",,1,"C",231,225,239,"Sequential"
+,,,,2,"F",201,148,199,
+,,,,3,"I",221,28,119,
+"PuRd",4,"seq",,1,"B",241,238,246,
+,,,,2,"E",215,181,216,
+,,,,3,"G",223,101,176,
+,,,,4,"J",206,18,86,
+"PuRd",5,"seq",,1,"B",241,238,246,
+,,,,4,"I",221,28,119,
+,,,,5,"K",152,0,67,
+"PuRd",6,"seq",,1,"B",241,238,246,
+,,,,2,"D",212,185,218,
+,,,,3,"F",201,148,199,
+,,,,4,"G",223,101,176,
+,,,,5,"I",221,28,119,
+,,,,6,"K",152,0,67,
+"PuRd",7,"seq",,1,"B",241,238,246,
+,,,,5,"H",231,41,138,
+,,,,6,"J",206,18,86,
+,,,,7,"L",145,0,63,
+"PuRd",8,"seq",,1,"A",247,244,249,
+,,,,2,"C",231,225,239,
+,,,,3,"D",212,185,218,
+,,,,4,"F",201,148,199,
+,,,,5,"G",223,101,176,
+,,,,6,"H",231,41,138,
+,,,,7,"J",206,18,86,
+,,,,8,"L",145,0,63,
+"PuRd",9,"seq",,1,"A",247,244,249,
+,,,,8,"K",152,0,67,
+,,,,9,"M",103,0,31,
+"Purples",3,"seq",,1,"C",239,237,245,"Sequential"
+,,,,2,"F",188,189,220,
+,,,,3,"I",117,107,177,
+"Purples",4,"seq",,1,"B",242,240,247,
+,,,,2,"E",203,201,226,
+,,,,3,"G",158,154,200,
+,,,,4,"J",106,81,163,
+"Purples",5,"seq",,1,"B",242,240,247,
+,,,,4,"I",117,107,177,
+,,,,5,"K",84,39,143,
+"Purples",6,"seq",,1,"B",242,240,247,
+,,,,2,"D",218,218,235,
+,,,,3,"F",188,189,220,
+,,,,4,"G",158,154,200,
+,,,,5,"I",117,107,177,
+,,,,6,"K",84,39,143,
+"Purples",7,"seq",,1,"B",242,240,247,
+,,,,5,"H",128,125,186,
+,,,,6,"J",106,81,163,
+,,,,7,"L",74,20,134,
+"Purples",8,"seq",,1,"A",252,251,253,
+,,,,2,"C",239,237,245,
+,,,,3,"D",218,218,235,
+,,,,4,"F",188,189,220,
+,,,,5,"G",158,154,200,
+,,,,6,"H",128,125,186,
+,,,,7,"J",106,81,163,
+,,,,8,"L",74,20,134,
+"Purples",9,"seq",,1,"A",252,251,253,
+,,,,8,"K",84,39,143,
+,,,,9,"M",63,0,125,
+"RdBu",3,"div",2,1,"E",239,138,98,"Diverging"
+,,,,3,"K",103,169,207,
+"RdBu",4,"div","2,5",1,"C",202,0,32,
+,,,,2,"F",244,165,130,
+,,,,3,"J",146,197,222,
+,,,,4,"M",5,113,176,
+"RdBu",5,"div",3,1,"C",202,0,32,
+,,,,4,"J",146,197,222,
+,,,,5,"M",5,113,176,
+"RdBu",6,"div","3,5",1,"B",178,24,43,
+,,,,2,"E",239,138,98,
+,,,,3,"G",253,219,199,
+,,,,4,"I",209,229,240,
+,,,,5,"K",103,169,207,
+,,,,6,"N",33,102,172,
+"RdBu",7,"div",4,1,"B",178,24,43,
+,,,,5,"I",209,229,240,
+,,,,6,"K",103,169,207,
+,,,,7,"N",33,102,172,
+"RdBu",8,"div","4,5",1,"B",178,24,43,
+,,,,2,"D",214,96,77,
+,,,,3,"F",244,165,130,
+,,,,4,"G",253,219,199,
+,,,,6,"J",146,197,222,
+,,,,7,"L",67,147,195,
+,,,,8,"N",33,102,172,
+"RdBu",9,"div",5,1,"B",178,24,43,
+,,,,6,"I",209,229,240,
+,,,,7,"J",146,197,222,
+,,,,8,"L",67,147,195,
+,,,,9,"N",33,102,172,
+"RdBu",10,"div","5,5",1,"A",103,0,31,
+,,,,2,"B",178,24,43,
+,,,,3,"D",214,96,77,
+,,,,4,"F",244,165,130,
+,,,,5,"G",253,219,199,
+,,,,10,"O",5,48,97,
+"RdBu",11,"div",6,1,"A",103,0,31,
+,,,,7,"I",209,229,240,
+,,,,8,"J",146,197,222,
+,,,,9,"L",67,147,195,
+,,,,10,"N",33,102,172,
+,,,,11,"O",5,48,97,
+"RdGy",3,"div",2,1,"E",239,138,98,"Diverging"
+,,,,2,"H",255,255,255,
+,,,,3,"K",153,153,153,
+"RdGy",4,"div","2,5",1,"C",202,0,32,
+,,,,3,"J",186,186,186,
+,,,,4,"M",64,64,64,
+"RdGy",5,"div",3,1,"C",202,0,32,
+,,,,3,"H",255,255,255,
+,,,,4,"J",186,186,186,
+,,,,5,"M",64,64,64,
+"RdGy",6,"div","3,5",1,"B",178,24,43,
+,,,,4,"I",224,224,224,
+,,,,5,"K",153,153,153,
+,,,,6,"N",77,77,77,
+"RdGy",7,"div",4,1,"B",178,24,43,
+,,,,4,"H",255,255,255,
+,,,,5,"I",224,224,224,
+,,,,6,"K",153,153,153,
+,,,,7,"N",77,77,77,
+"RdGy",8,"div","4,5",1,"B",178,24,43,
+,,,,6,"J",186,186,186,
+,,,,7,"L",135,135,135,
+,,,,8,"N",77,77,77,
+"RdGy",9,"div",5,1,"B",178,24,43,
+,,,,5,"H",255,255,255,
+,,,,6,"I",224,224,224,
+,,,,7,"J",186,186,186,
+,,,,8,"L",135,135,135,
+,,,,9,"N",77,77,77,
+"RdGy",10,"div","5,5",1,"A",103,0,31,
+,,,,10,"O",26,26,26,
+"RdGy",11,"div",6,1,"A",103,0,31,
+,,,,6,"H",255,255,255,
+,,,,7,"I",224,224,224,
+,,,,8,"J",186,186,186,
+,,,,9,"L",135,135,135,
+,,,,10,"N",77,77,77,
+,,,,11,"O",26,26,26,
+"RdPu",3,"seq",,1,"C",253,224,221,"Sequential"
+,,,,2,"F",250,159,181,
+,,,,3,"I",197,27,138,
+"RdPu",4,"seq",,1,"B",254,235,226,
+,,,,2,"E",251,180,185,
+,,,,3,"G",247,104,161,
+,,,,4,"J",174,1,126,
+"RdPu",5,"seq",,1,"B",254,235,226,
+,,,,4,"I",197,27,138,
+,,,,5,"K",122,1,119,
+"RdPu",6,"seq",,1,"B",254,235,226,
+,,,,2,"D",252,197,192,
+,,,,3,"F",250,159,181,
+,,,,4,"G",247,104,161,
+,,,,5,"I",197,27,138,
+,,,,6,"K",122,1,119,
+"RdPu",7,"seq",,1,"B",254,235,226,
+,,,,5,"H",221,52,151,
+,,,,6,"J",174,1,126,
+,,,,7,"L",122,1,119,
+"RdPu",8,"seq",,1,"A",255,247,243,
+,,,,2,"C",253,224,221,
+,,,,3,"D",252,197,192,
+,,,,4,"F",250,159,181,
+,,,,5,"G",247,104,161,
+,,,,6,"H",221,52,151,
+,,,,7,"J",174,1,126,
+,,,,8,"L",122,1,119,
+"RdPu",9,"seq",,1,"A",255,247,243,
+,,,,8,"K",122,1,119,
+,,,,9,"M",73,0,106,
+"Reds",3,"seq",,1,"C",254,224,210,"Sequential"
+,,,,2,"F",252,146,114,
+,,,,3,"I",222,45,38,
+"Reds",4,"seq",,1,"B",254,229,217,
+,,,,2,"E",252,174,145,
+,,,,3,"G",251,106,74,
+,,,,4,"J",203,24,29,
+"Reds",5,"seq",,1,"B",254,229,217,
+,,,,4,"I",222,45,38,
+,,,,5,"K",165,15,21,
+"Reds",6,"seq",,1,"B",254,229,217,
+,,,,2,"D",252,187,161,
+,,,,3,"F",252,146,114,
+,,,,4,"G",251,106,74,
+,,,,5,"I",222,45,38,
+,,,,6,"K",165,15,21,
+"Reds",7,"seq",,1,"B",254,229,217,
+,,,,5,"H",239,59,44,
+,,,,6,"J",203,24,29,
+,,,,7,"L",153,0,13,
+"Reds",8,"seq",,1,"A",255,245,240,
+,,,,2,"C",254,224,210,
+,,,,3,"D",252,187,161,
+,,,,4,"F",252,146,114,
+,,,,5,"G",251,106,74,
+,,,,6,"H",239,59,44,
+,,,,7,"J",203,24,29,
+,,,,8,"L",153,0,13,
+"Reds",9,"seq",,1,"A",255,245,240,
+,,,,8,"K",165,15,21,
+,,,,9,"M",103,0,13,
+"RdYlBu",3,"div",2,1,"E",252,141,89,"Diverging"
+,,,,2,"H",255,255,191,
+,,,,3,"K",145,191,219,
+"RdYlBu",4,"div","2,5",1,"C",215,25,28,
+,,,,2,"F",253,174,97,
+,,,,3,"J",171,217,233,
+,,,,4,"M",44,123,182,
+"RdYlBu",5,"div",3,1,"C",215,25,28,
+,,,,3,"H",255,255,191,
+,,,,4,"J",171,217,233,
+,,,,5,"M",44,123,182,
+"RdYlBu",6,"div","3,5",1,"B",215,48,39,
+,,,,2,"E",252,141,89,
+,,,,3,"G",254,224,144,
+,,,,4,"I",224,243,248,
+,,,,5,"K",145,191,219,
+,,,,6,"N",69,117,180,
+"RdYlBu",7,"div",4,1,"B",215,48,39,
+,,,,4,"H",255,255,191,
+,,,,5,"I",224,243,248,
+,,,,6,"K",145,191,219,
+,,,,7,"N",69,117,180,
+"RdYlBu",8,"div","4,5",1,"B",215,48,39,
+,,,,2,"D",244,109,67,
+,,,,3,"F",253,174,97,
+,,,,4,"G",254,224,144,
+,,,,6,"J",171,217,233,
+,,,,7,"L",116,173,209,
+,,,,8,"N",69,117,180,
+"RdYlBu",9,"div",5,1,"B",215,48,39,
+,,,,5,"H",255,255,191,
+,,,,6,"I",224,243,248,
+,,,,7,"J",171,217,233,
+,,,,8,"L",116,173,209,
+,,,,9,"N",69,117,180,
+"RdYlBu",10,"div","5,5",1,"A",165,0,38,
+,,,,2,"B",215,48,39,
+,,,,3,"D",244,109,67,
+,,,,4,"F",253,174,97,
+,,,,5,"G",254,224,144,
+,,,,10,"O",49,54,149,
+"RdYlBu",11,"div",6,1,"A",165,0,38,
+,,,,6,"H",255,255,191,
+,,,,7,"I",224,243,248,
+,,,,8,"J",171,217,233,
+,,,,9,"L",116,173,209,
+,,,,10,"N",69,117,180,
+,,,,11,"O",49,54,149,
+"RdYlGn",3,"div",2,1,"E",252,141,89,"Diverging"
+,,,,3,"K",145,207,96,
+"RdYlGn",4,"div","2,5",1,"C",215,25,28,
+,,,,3,"J",166,217,106,
+,,,,4,"M",26,150,65,
+"RdYlGn",5,"div",3,1,"C",215,25,28,
+,,,,4,"J",166,217,106,
+,,,,5,"M",26,150,65,
+"RdYlGn",6,"div","3,5",1,"B",215,48,39,
+,,,,3,"G",254,224,139,
+,,,,4,"I",217,239,139,
+,,,,5,"K",145,207,96,
+,,,,6,"N",26,152,80,
+"RdYlGn",7,"div",4,1,"B",215,48,39,
+,,,,5,"I",217,239,139,
+,,,,6,"K",145,207,96,
+,,,,7,"N",26,152,80,
+"RdYlGn",8,"div","4,5",1,"B",215,48,39,
+,,,,4,"G",254,224,139,
+,,,,6,"J",166,217,106,
+,,,,7,"L",102,189,99,
+,,,,8,"N",26,152,80,
+"RdYlGn",9,"div",5,1,"B",215,48,39,
+,,,,6,"I",217,239,139,
+,,,,7,"J",166,217,106,
+,,,,8,"L",102,189,99,
+,,,,9,"N",26,152,80,
+"RdYlGn",10,"div","5,5",1,"A",165,0,38,
+,,,,5,"G",254,224,139,
+,,,,10,"O",0,104,55,
+"RdYlGn",11,"div",6,1,"A",165,0,38,
+,,,,7,"I",217,239,139,
+,,,,8,"J",166,217,106,
+,,,,9,"L",102,189,99,
+,,,,10,"N",26,152,80,
+,,,,11,"O",0,104,55,
+"Set1",3,"qual",,1,"A",228,26,28,"Qualitative"
+,,,,2,"B",55,126,184,
+,,,,3,"C",77,175,74,
+"Set1",4,"qual",,1,"A",228,26,28,
+,,,,4,"D",152,78,163,
+"Set1",5,"qual",,1,"A",228,26,28,
+,,,,5,"E",255,127,0,
+"Set1",6,"qual",,1,"A",228,26,28,
+,,,,6,"F",255,255,51,
+"Set1",7,"qual",,1,"A",228,26,28,
+,,,,7,"G",166,86,40,
+"Set1",8,"qual",,1,"A",228,26,28,
+,,,,8,"H",247,129,191,
+"Set1",9,"qual",,1,"A",228,26,28,
+,,,,9,"I",153,153,153,
+"Set2",3,"qual",,1,"A",102,194,165,"Qualitative"
+,,,,2,"B",252,141,98,
+,,,,3,"C",141,160,203,
+"Set2",4,"qual",,1,"A",102,194,165,
+,,,,4,"D",231,138,195,
+"Set2",5,"qual",,1,"A",102,194,165,
+,,,,5,"E",166,216,84,
+"Set2",6,"qual",,1,"A",102,194,165,
+,,,,6,"F",255,217,47,
+"Set2",7,"qual",,1,"A",102,194,165,
+,,,,7,"G",229,196,148,
+"Set2",8,"qual",,1,"A",102,194,165,
+,,,,8,"H",179,179,179,
+"Set3",3,"qual",,1,"A",141,211,199,"Qualitative"
+,,,,2,"B",255,255,179,
+,,,,3,"C",190,186,218,
+"Set3",4,"qual",,1,"A",141,211,199,
+,,,,4,"D",251,128,114,
+"Set3",5,"qual",,1,"A",141,211,199,
+,,,,5,"E",128,177,211,
+"Set3",6,"qual",,1,"A",141,211,199,
+,,,,6,"F",253,180,98,
+"Set3",7,"qual",,1,"A",141,211,199,
+,,,,7,"G",179,222,105,
+"Set3",8,"qual",,1,"A",141,211,199,
+,,,,8,"H",252,205,229,
+"Set3",9,"qual",,1,"A",141,211,199,
+,,,,9,"I",217,217,217,
+"Set3",10,"qual",,1,"A",141,211,199,
+,,,,10,"J",188,128,189,
+"Set3",11,"qual",,1,"A",141,211,199,
+,,,,11,"K",204,235,197,
+"Set3",12,"qual",,1,"A",141,211,199,
+,,,,12,"L",255,237,111,
+"Spectral",3,"div",2,1,"E",252,141,89,"Diverging"
+,,,,3,"K",153,213,148,
+"Spectral",4,"div","2,5",1,"C",215,25,28,
+,,,,3,"J",171,221,164,
+,,,,4,"M",43,131,186,
+"Spectral",5,"div",3,1,"C",215,25,28,
+,,,,4,"J",171,221,164,
+,,,,5,"M",43,131,186,
+"Spectral",6,"div","3,5",1,"B",213,62,79,
+,,,,4,"I",230,245,152,
+,,,,5,"K",153,213,148,
+,,,,6,"N",50,136,189,
+"Spectral",7,"div",4,1,"B",213,62,79,
+,,,,5,"I",230,245,152,
+,,,,6,"K",153,213,148,
+,,,,7,"N",50,136,189,
+"Spectral",8,"div","4,5",1,"B",213,62,79,
+,,,,6,"J",171,221,164,
+,,,,7,"L",102,194,165,
+,,,,8,"N",50,136,189,
+"Spectral",9,"div",5,1,"B",213,62,79,
+,,,,6,"I",230,245,152,
+,,,,7,"J",171,221,164,
+,,,,8,"L",102,194,165,
+,,,,9,"N",50,136,189,
+"Spectral",10,"div","5,5",1,"A",158,1,66,
+,,,,2,"B",213,62,79,
+,,,,10,"O",94,79,162,
+"Spectral",11,"div",6,1,"A",158,1,66,
+,,,,7,"I",230,245,152,
+,,,,8,"J",171,221,164,
+,,,,9,"L",102,194,165,
+,,,,10,"N",50,136,189,
+,,,,11,"O",94,79,162,
+"YlGn",3,"seq",,1,"C",247,252,185,"Sequential"
+,,,,2,"F",173,221,142,
+"YlGn",4,"seq",,1,"B",255,255,204,
+,,,,2,"E",194,230,153,
+,,,,3,"G",120,198,121,
+,,,,4,"J",35,132,67,
+"YlGn",5,"seq",,1,"B",255,255,204,
+,,,,5,"K",0,104,55,
+"YlGn",6,"seq",,1,"B",255,255,204,
+,,,,2,"D",217,240,163,
+,,,,3,"F",173,221,142,
+,,,,4,"G",120,198,121,
+,,,,6,"K",0,104,55,
+"YlGn",7,"seq",,1,"B",255,255,204,
+,,,,6,"J",35,132,67,
+,,,,7,"L",0,90,50,
+"YlGn",8,"seq",,1,"A",255,255,229,
+,,,,2,"C",247,252,185,
+,,,,3,"D",217,240,163,
+,,,,4,"F",173,221,142,
+,,,,5,"G",120,198,121,
+,,,,7,"J",35,132,67,
+,,,,8,"L",0,90,50,
+"YlGn",9,"seq",,1,"A",255,255,229,
+,,,,8,"K",0,104,55,
+,,,,9,"M",0,69,41,
+"YlGnBu",3,"seq",,1,"C",237,248,177,"Sequential"
+,,,,2,"F",127,205,187,
+,,,,3,"I",44,127,184,
+"YlGnBu",4,"seq",,1,"B",255,255,204,
+,,,,2,"E",161,218,180,
+,,,,3,"G",65,182,196,
+,,,,4,"J",34,94,168,
+"YlGnBu",5,"seq",,1,"B",255,255,204,
+,,,,4,"I",44,127,184,
+,,,,5,"K",37,52,148,
+"YlGnBu",6,"seq",,1,"B",255,255,204,
+,,,,2,"D",199,233,180,
+,,,,3,"F",127,205,187,
+,,,,4,"G",65,182,196,
+,,,,5,"I",44,127,184,
+,,,,6,"K",37,52,148,
+"YlGnBu",7,"seq",,1,"B",255,255,204,
+,,,,5,"H",29,145,192,
+,,,,6,"J",34,94,168,
+,,,,7,"L",12,44,132,
+"YlGnBu",8,"seq",,1,"A",255,255,217,
+,,,,2,"C",237,248,177,
+,,,,3,"D",199,233,180,
+,,,,4,"F",127,205,187,
+,,,,5,"G",65,182,196,
+,,,,6,"H",29,145,192,
+,,,,7,"J",34,94,168,
+,,,,8,"L",12,44,132,
+"YlGnBu",9,"seq",,1,"A",255,255,217,
+,,,,8,"K",37,52,148,
+,,,,9,"M",8,29,88,
+"YlOrBr",3,"seq",,1,"C",255,247,188,"Sequential"
+,,,,2,"F",254,196,79,
+,,,,3,"I",217,95,14,
+"YlOrBr",4,"seq",,1,"B",255,255,212,
+,,,,2,"E",254,217,142,
+,,,,3,"G",254,153,41,
+,,,,4,"J",204,76,2,
+"YlOrBr",5,"seq",,1,"B",255,255,212,
+,,,,4,"I",217,95,14,
+,,,,5,"K",153,52,4,
+"YlOrBr",6,"seq",,1,"B",255,255,212,
+,,,,2,"D",254,227,145,
+,,,,3,"F",254,196,79,
+,,,,4,"G",254,153,41,
+,,,,5,"I",217,95,14,
+,,,,6,"K",153,52,4,
+"YlOrBr",7,"seq",,1,"B",255,255,212,
+,,,,5,"H",236,112,20,
+,,,,6,"J",204,76,2,
+"YlOrBr",8,"seq",,1,"A",255,255,229,
+,,,,2,"C",255,247,188,
+,,,,3,"D",254,227,145,
+,,,,4,"F",254,196,79,
+,,,,5,"G",254,153,41,
+,,,,6,"H",236,112,20,
+,,,,7,"J",204,76,2,
+"YlOrBr",9,"seq",,1,"A",255,255,229,
+,,,,8,"K",153,52,4,
+,,,,9,"M",102,37,6,
+"YlOrRd",3,"seq",,1,"C",255,237,160,"Sequential"
+,,,,2,"F",254,178,76,
+,,,,3,"I",240,59,32,
+"YlOrRd",4,"seq",,1,"B",255,255,178,
+,,,,2,"E",254,204,92,
+,,,,4,"J",227,26,28,
+"YlOrRd",5,"seq",,1,"B",255,255,178,
+,,,,4,"I",240,59,32,
+,,,,5,"K",189,0,38,
+"YlOrRd",6,"seq",,1,"B",255,255,178,
+,,,,2,"D",254,217,118,
+,,,,3,"F",254,178,76,
+,,,,5,"I",240,59,32,
+,,,,6,"K",189,0,38,
+"YlOrRd",7,"seq",,1,"B",255,255,178,
+,,,,5,"H",252,78,42,
+,,,,6,"J",227,26,28,
+,,,,7,"L",177,0,38,
+"YlOrRd",8,"seq",,1,"A",255,255,204,
+,,,,2,"C",255,237,160,
+,,,,3,"D",254,217,118,
+,,,,4,"F",254,178,76,
+,,,,6,"H",252,78,42,
+,,,,7,"J",227,26,28,
+,,,,8,"L",177,0,38,
+"YlOrRd",9,"seq",,1,"A",255,255,204,
+,,,,8,"K",189,0,38,
+,,,,9,"M",128,0,38,
+"Apache-Style Software License for ColorBrewer software and ColorBrewer Color Schemes",,,,,,,,,
+"Copyright (c) 2002 Cynthia Brewer, Mark Harrower, and The Pennsylvania State University.",,,,,,,,,
+"Licensed under the Apache License, Version 2.0 (the ""License""); you may not use this file except in compliance with the License.",,,,,,,,,
+"You may obtain a copy of the License at",,,,,,,,,
+"       http://www.apache.org/licenses/LICENSE-2.0",,,,,,,,,
+"Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an ""AS IS"" BASIS,",,,,,,,,,
+"WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.",,,,,,,,,
+"See the License for the specific language governing permissions and limitations under the License.",,,,,,,,,
+"Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:",,,,,,,,,
+"1. Redistributions as source code must retain the above copyright notice, this list of conditions and the following disclaimer.",,,,,,,,,
+"2. The end-user documentation included with the redistribution, if any, must include the following acknowledgment:",,,,,,,,,
+"This product includes color specifications and designs developed by Cynthia Brewer (http://colorbrewer.org/).",,,,,,,,,
+"Alternately, this acknowledgment may appear in the software itself, if and wherever such third-party acknowledgments normally appear.",,,,,,,,,
+"4. The name ""ColorBrewer"" must not be used to endorse or promote products derived from this software without prior written permission. ",,,,,,,,,
+"For written permission, please contact Cynthia Brewer at cbrewer at psu.edu.",,,,,,,,,
+"5. Products derived from this software may not be called ""ColorBrewer"", nor may ""ColorBrewer"" appear in their name, without prior written permission of Cynthia Brewer.",,,,,,,,,
+</value>
   </data>
   <data name="CheckGeometryFirst" xml:space="preserve">
     <value>Ensure the Geometry box is checked</value>
   </data>
   <data name="SelectColumnPlaceholder" xml:space="preserve">
     <value>&lt;Select column&gt;</value>
-    <comment>A placeholder message displayed when the user has not yet selected a column</comment>
   </data>
-  <data name="application_browser" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application-browser.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application_browser" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACiklEQVQ4T6WUXUiTURiAT3rl
+        heBNXQTdCGF2E+1qUIwkiwwsleyHfonUrAhCMTAKE7xINCORgnSslqYNZSmJusrQnH9zttraVkNJdLOt
+        uaWbzrH19H1eBF2aLzycc97D8/KeA+cIQGwEkZ+fnypxSqJwnchOqsjLyzttNBqtLpcLp9OBzWbDYvmI
+        yWRiZGQEaY+hIZlRaT7B8LCF8XE7PT0frLIrcnJyig0GA319fVKyh+7ubrq6utDr9XR0dKDT6WhtbaWl
+        pQWtVotGo0GtVtPY2EhiYmKhfIQi6Q7+K2RX5ObmXo7H48RisX8Ir8YwTC1T1h8kX7/Awbafa6O8lvPL
+        0TiyK7Kzs69Eo1EikchfvnnDFHS6uaB3Uz/qp/XLIp3ORSYXY7z6vsLVXh+FXR5kV2RlZV1bWVkhFAqt
+        YZ8LcPL5VyoMs+jsAUyS1Gz7xRNzAKM3gj0K9lVQfw6yufxdm8jMzLy+tLREIBBg3rfAuSYzd3qmuTfo
+        oc8TkQr8ptkaoF3qYPBHhLFgjLEwGEOQeNfxXqhUqhvBYBCfz4fug5Ps+wOcb/vK5c5pnjpDVL6b5fbb
+        WV44luj3w53XLrRSvmMeEkqNA0KpVJb4/X7cbjeXHvZSrLVwSG3ngMbBUa2DEy9dnG2folg/zRnNJ47U
+        j1JniVIuVUso6BwSCoWizOv1MjMzw76SZ5R2z5PRYGVX3QTKx1b2PLGiarSxt2GSc+1ubg7FuWYIo6oz
+        s+m4ekSkpaXdktv3eDwoCh6hrHjDfvUc26tG2VEzQXqNmZ21ZtKrx1FUm1E9sHOsPcy20l7E4dpxkZyc
+        XJSSklIlIzIqTeti98UmIUWSxBaJretEdpI29JTlb+APrpaoVzbDpskAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="NoScalesToGenerate" xml:space="preserve">
     <value>Number of Scales to generate cannot be less than or equal to 0</value>
   </data>
-  <data name="icon_zoomselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZYAMDAwICAgK2km+vv8+/y9fb3+Ofs8fL19/X29/X2+K6vsNPa4MHCwtrl6ejt8sLH
+        y9ri6eLp78jIyMzNzbu8vejr7paWltrb3LW2tru7u9bX2PH09tPZ38/Pz+zw9PP19tHT1dfY2c7Q0uXj
+        z9PU1ufp6q2trcXQ2ufm0MC/v/Hz9d3k6+/v7/L09qSkpL69vdvg5dDf4ejq7MbJzaSkpePp78nKyuzt
+        7rO1tuXn6ejt8fP09dbW1tni6q2trO7w8sPExcTGx+js77Cvr/Dy9Pr7+93g48LHzKurq+rq0+7x9Jub
+        m/T19uXp7dXd5cLDxNXb4eHk59LS0re5urGzteDj5d7l7Nvf4wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AABYACwAAAAAEAAQAAAIrwABYBFIcCCWgwgTJuSRYsgLhQIDSMTS4UKVKEZISFAYIAmLCTmIMEGgQsiV
+        JwcjopASAkGBIgk2KNExwwbCACMylCjw40MLAgMMcDBhUKKPHQUqNCHgwUAECEsUYriR4ABQAw2sLKBh
+        EEuAIBqsDnDQIEaPI1NuHmQgY2wNJyegUEnp9SAIBiJgrFjwAIeChAESAkFiwQUFLAoEdJUYWOFBAYod
+        S8YioKDlyZgdBwQAOw==
+</value>
   </data>
-  <data name="ruler1" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\ruler1.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="ruler1" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB3UlEQVQ4T2PYn8jCsD+JheFA
+        EksGEHdDcQZIbG0EM0gcJw3SywAiQIqAdM/fm8v+/7qy8D+IjU8jzGCwAfsSWTJBGpaFMF98sLnh/9dT
+        0//vTWQ5AxJbE8E8Bx8N0suwPZZlyu9ri/9fnej+/8fFef8/n5gKZ9/fWAcWw0aD9ID0MgBtmf92f8//
+        baUm/+9tqP3/8eik/6dbrP4/29aMF4P0gPQyzAtgap7lx7QRyLn/9fSM/+8P9YMk7oPECGGQXgagIjCe
+        5MY0787aqv8gkzdHM88AiU30ZMSLQWoYloYwM2yIAuPZIOe/2tP5H8QGic30xW8I2IBOeyYYXnhzZdn/
+        FzvbwH4DYlD4MMzAYwjYgJVhzDC8COR8UOABxRYhiTNM98HuErABjZaMMLz0+tKi/0+AaWFZKNNSIGaA
+        YS0xRgZ0oCrMyOCrDhRfHMwEwytfAZ3/CBiVQLGVMHFNUUzNKIaJsTEwVBgxgvDqK4vy/z9YV/1/rj/T
+        eiBm0CCkGWYSyDkTPBn3vAa64NmWxv8gNkiMWCAPVGiUasywsM2Z4TgIA9nzgGLKQCwHxBJALAzEfEDM
+        CcSsQAwMPQQQADIloRikWAyIRYBYCIj5gZgHiLmAmB2qmRlIw50HAIdyTYaOb/frAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="gear--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\gear--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="gear--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACW0lEQVQ4T6WQUUhTYRTHv+s2
+        ZKwHfdmi2pDYWqYLuYPmihhIMpp72OaeejB8ipBeCkaFRUihQQ+FRkUvCbWIKFD2lJlg4wpusOlGJi5b
+        Y5vi+5D2cjr/e13MCHrogx/ncM7//7/f/QQRif9BNQcCAREMBkU4HBaRSESt0WjUy1zaw9u8gxYesC8g
+        FAqdZuFlrodR6/U61Wo1ap5B89eAgYGBM7FY7OHOzg4NDw/fZNFItVohgB4z7KCBdt8N/H6/YK4Ui0VK
+        pZapUilTIpHYKJfLBNAXCgV1Bw20ex7tF7xer/D5fEcGBwdvr6xkKZvN0ObmNyqVfqigxww7aKCFx+Px
+        aAG9vb0+HlwD09MvCvl8juLxV2vd3d2PAXrMsGvo4PkdIMtyLJ1O0cLCJ1paUmh1dZVcrpPjOp1OAPSY
+        YQcNtPAw2g26urpuJJNJmpubI9Rc7gv19MhjkiQJgB6zZg08jBbgcDj67Xb7KJicnPqeyeRpdvZjxu0+
+        dQugxwy7hg4eRguw2WzCarV2yLL7gaKkaX7+M62vl2l7e1cFPWbYQXPWYumYMBrFa8EHAWazGYwpSpZm
+        Zj7Q4mKapqaeF5eX8wTenvP/fOfspDf2Y/T++Al6otNV2ZyOC/FMDWhvbwfn+/r6X6ZSX8np7HzU1tZ2
+        T1Fy/NUcTbS0bO0ODdGfPOUQNQBHr9cLo9EYMJlM462trUdR19a2+EFLdEGvz4xKUu6qJG1dl6SNO2wE
+        dxs3gJ+xMPyswg0MBsNFDroP0DfmXF3MQRt7OER7Az4tzAHGzBz6B/gQtPCIX1/g1Ah/cmufAAAAAElF
+        TkSuQmCC
+</value>
   </data>
   <data name="TooManyValuesError" xml:space="preserve">
     <value>The selected column contains more than {0} different values, and thus cannot be used for theming</value>
-    <comment>An error message that is displayed if the selected column has too many distinct values</comment>
   </data>
   <data name="MoreColorsName" xml:space="preserve">
     <value>More colors...</value>
   </data>
-  <data name="icon_null" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_null.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_null" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIECANji87HH6f///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAACACwAAAAAEAAQ
+        AAAIRAAFCBxIsKDBgwYDKFzIUCHBAAAiSpwY4OHEiwAqDoSIUaJGgRw7ZrQocuTGkiZBovwoIGRHli4x
+        wlz5sKFNhDhzHgwIADs=
+</value>
   </data>
-  <data name="icon_panleft_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_panleft_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_panleft_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
+        2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
+        s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
+        vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
+        18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
+        yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
+        AABuACwAAAAAEAAQAAAIvwDdCBxI0A2DAQUTCjQCoGFDNy8CEEgBpuDBgT2gcIAgwIIWNQrd1FhAgMQD
+        AWvOBFF4wkQAAQZ4CNjSpY1CH2iqENjwQEgSCTEUzmgRQAmFCgkWSAihcEyAJSUo/NgRIE3BI1EQ3JhQ
+        AUECHUUg0CAI4kmDBjhUyDAAw0AGNggHehiCYoIXFl+IABETwUyZgk6sHDjARMoFDRGwXMmScAqGMC4U
+        jBDhYAWXkG7IFCjQhEoOG5jdICnwoYMCBwEBADs=
+</value>
   </data>
   <data name="FsPreview_GeometryPropertyNodeTooltip" xml:space="preserve">
     <value>Name: {0}{7}Description: {1}{7}Geometry Types: {2}{7}Read Only: {3}{7}Has Elevation: {4}{7}Has Measure: {5}{7}Spatial Context: {6}</value>
   </data>
-  <data name="function" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\function.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="function" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABIElEQVQ4T6WTsU4CQRRFdwnE
+        EIkxKBL5BkKjDRQWFljQEwq0pCI2FFT8ABV+gB0dxMrEBAsTowmVxs5f8CvWc/GtWcdZDWGSk3nvvnl3
+        Zmd3gyiKgk0IwjD00UafG4q967Sxr3BMww2cQtXitQx6NM1gL23nWE87wYQFV/81q+4ajBHvHGqJvGum
+        ZdO6vhPUKd6DZj33hc0d03UvU2j6TqCGS1hAyXmEBvmD8X2hvhNcs0i4t95CewK9oVQD7foIA8dA38HS
+        OPvL4ITiC2gONJiHpilW7dwMFH+9hcQYEb9B2bQ+83uiHufSWtKTBnXyZ7j9Yfk7KSCJ1YgNPojFKxzB
+        PhRhF3ZgG/KwBTnIQgbC2KBCcgg6+sHaBpv8yur9BCINtCQt9llRAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="OdbcNoMarkedFile" xml:space="preserve">
     <value>Could not infer ODBC driver. No file specified</value>
   </data>
-  <data name="icon_zoom" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoom.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoom" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZsAAE1Z3BJJai7zuqxd9nFs1tgZNnm88fb8MXa78/a5LjH1+fu9dDh8trn9KjR43yP
+        orrT7erv8+Dq9ISAf622v2Rrcmxtb6Sttqq8z2BocJ+fn4aKjcvY5ZqbnYSHi9jm8pGRkpSVl7S3u83U
+        2f///4SFiHV5fq6yt6Cnr77L2K7L54SdtXh3d1xbXcjQ2Ozw9GRgX5yzy7CurcLQ3efs8eLs9UpMTODo
+        8XahzMbb78rc7s7X39ri6uHr9HyQo6/N6uLr9eXq79Dh8dHh8jAvLrvU7X98e5DO1pmirDg3N97m7auo
+        qKamp5u83sjIx6TF54iOlKu0vJy20IWUo67C1aC50unv9Mza6EdKTV5cWr7H0bC/z4OGiKWqsdDg8YBq
+        V+vw9bbBzauvs7e/x1hYWdfb36jG5OTr8W50evT3+Zu20MPT4wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABsACwAAAAAEAAQAAAIuQDZCJQxAYaRJQITAkjIRoMILSnCdAHhRGHCDi6U0LBy48oWD2wAiBTJ5EQE
+        EmkWSPigY0oIgQvZsBjxgseZHga8IIjRAqbALEHAcFjTYAgCCGaSMGRjocyCGg0Y5HDwQwqWFSMBQBED
+        xICQAw6OPPGBZumYEjsYHCjSBEeVDFGWskHBBQkVFWoeVCggVyCFDWSI2DBxoUCAAQTkJlCAQUECNgIC
+        HE7cl2HkyZUtSx6QWfOXzpZnsAkIADs=
+</value>
   </data>
-  <data name="exclamation" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\exclamation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDklEQVQ4T6XTz2vTYBgH8OcN
+        is6LqAM7cXpxwlAsHnSIiF6ml/0FIlgRhUEOO2g30JPgPCi402C4grP+3rSz/qqpWKtlunXQt7GzrO1W
+        Bk2wdLWDukJdx+P7hKVka0HQwIc8ffL9Jj0kgIjwP4COi6cZTL6ssVnshlfQvCpDHQIDvXXLFL6gxR1c
+        i5/lNNd5gHFDmHjBaoS9rDni2+qpLI6UK4tPyxHfFg/t6mXhq4fVGB9lV7IzXcml/C1cyt/EbEpO0q5e
+        FsaesVW+PGd27t+t/F4YXHY6nUjKhf5lrjQrdG1tHj4PMyspNML6cukerZjpRlmWDcXMZcwmZY2uibxk
+        7UDwMav69IS1R9/vD/36cQMX0p3ocDgMNBe1q8iVlhBlrB348ICZGgKPJHcu3V0ozHaKJ55Du92ONpsN
+        Y+FTqE6cxNhkR4EyotNg9uDdEDP43eyMGmjj+bkuTE11oMpPoHhFDFF+3BBT23HszS5OWbMHvruMNPrv
+        b/DqyfOlROwYxr8dMcxnrxnM33SeihwqKe51XupQF165GLx2sUuRwIHE3PRRnP1+sMr8B9YdzWF/U4I6
+        1IXRAbbHd29jUE8crujT+9DKvMHafSbeWnk7tD5IXXh4G1zqx536/Ewr5lJ7hZaq0s8eJNadOUcD23Xq
+        wmAv9N+5DuP/grr0MUrCJmGb0CTs+AvKNK50pD9EZQJEPplB2AAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="ConfigurationDocumentReset" xml:space="preserve">
     <value>Configuration Document has been reset</value>
   </data>
   <data name="OverwriteResource" xml:space="preserve">
     <value>This resource already exists, continue with save?</value>
-    <comment>Question similar to the standard response of saving to an exisiting file using the regular save file dialog</comment>
   </data>
   <data name="FunctionTooltip" xml:space="preserve">
     <value>Function: {1}({2})
 Description: {3}
 Returns: {0}</value>
-    <comment>The tooltip displayed in the text editor when the cursor is over a function name</comment>
   </data>
-  <data name="icon_clearselect_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_clearselect_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_clearselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZRAICAgMDAwPn5+fz8/Oru8OPhzubr7e3x8vHw5tPIoObY1b6/w9XYz8XJyOjn0bu2
+        p6OmqLe2qcPDyefm0Obl0PH09dfa09XV1bu+wePp6/Dr1tTGxdvd4PXp59/h5d7e3tXV2eDdzOPcwcW7
+        l7Sun8S6l7y+v8DP09/Gwsa/qtzf4fDs2czOzP39/dLIoaOqqr2/wPj4+tnc39XZ0eXjz/j5+bSmpLyo
+        o5WVldrd3+Xkz9XOz7GvsLiwsM7Pz/7+/unk0NDJp/Dr2ZqbmNbY0Orq07nNy5OZmNzf4sXHydzf49TJ
+        oM3Ny9O2sr+1lenu79ne3////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABRACwAAAAAEAAQAAAInwCjCBxIcKAKIggCRFHIcOFAGQw0iChIEcmMFS6CKATAkaPDHBaEJCiRQiCA
+        Ig4oABCohAWQJSMeMNk4QUeBlRg8xIjghMQHASZpFAgBgAOIH1BODLnQwmFHABB2KGhg5IWPARQFSuiA
+        4sYRGFgFKozSccGGJjZMAC0IoMKBJzh49EhSo+DGAwQMrBybFUDeDCuzOiTrcbDgwwQbKs4aEAA7
+</value>
   </data>
   <data name="LoadProcedureVersionExecutionNotSupported" xml:space="preserve">
     <value>This connection does not support executing this type of Load Procedure</value>
@@ -1145,14 +4627,9 @@
   </data>
   <data name="InvalidColorComponent" xml:space="preserve">
     <value>Invalid {0} color component {1} in line {2}</value>
-    <comment>An error message that is displayed if a color component is outside the [0-255] range.
-{0} is the color component, eg. R, G or B
-{1} is the value read
-{2} is the line where the error was encountered</comment>
   </data>
   <data name="TooManyIndiviualValuesError" xml:space="preserve">
     <value>The selected column contains more than {0} different values, and thus cannot be used for theming with individual values</value>
   </data>
   <data name="OdbcDriverAccess" xml:space="preserve">
     <value>{Microsoft Access Driver (*.mdb)}</value>
@@ -1163,14 +4640,38 @@
   <data name="NoRasterClasses" xml:space="preserve">
     <value>This feature source has no class definitions with raster properties</value>
   </data>
-  <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="tick" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHElEQVQ4T2P4//8/AyWYIs0g
+        i8EGMEwXZGCYLcTAMAeIQTSIv0iYgWGpCAQvA+IVogwMK0XlGVaJngFiD4blIhC9OA2YCTRkPtAwEIYY
+        JgDUtCHtXfl/IH0GiD1IMYCNYbHIPMNjzk+jHmX/j39Z8BvIP0OsAYwMC4RbFXYY3wu4kfjf+2rML54V
+        cpcYFgr7oBvgAfT/GSD2AIfBZH5Y2GQKr1K54XY+/J/L2dC/AssVrwHDKhloKFIYTBMEaTqT9Kr4L4hm
+        APFBBkwT9OGYK3FZZ5vtb7X15v/4FsjfAspXM8yABDrCBZP4z8Q8zf3lcSHyf8TDzD8MQD4Q57JMFT6t
+        vMXkh+Imo//88+XvA8V6GKYIMDFMFWAAYYQBfXweDL18Z/xvxv9U2mP83+FCwA8QX2qT1mfpHTr/+RfJ
+        PQHy5zH083MADQBrZvDmQDKgl4+BoYPXg6Gd94zxKedvEoc1/2ucsfwvfkjjP/8quVdA8XUMXbwCQAMY
+        GLw4GGAA4QJ3dgaGVC4GhmZuD4Ym7jPSB7S+CJ9V+c+3TfY9YzPPboZWHmkGV6AaNIAwACahwMzAEM7m
+        wVDEfoZrmdgLxjKOI0C+JoMcE4ZmkACyASAVQPcxyAOxLoMxUxpDPNMZBm3GUCBfE4iVgFgKiIFJkoEH
+        iNmAmBHZAEagAMhzwNBhEIcqloSygZmAARhvDLxADPQnWDPQqUgGUJKdAYAsiHz3wn5/AAAAAElFTkSu
+        QmCC
+</value>
   </data>
   <data name="ErrorMapExtentCalculationFailed" xml:space="preserve">
     <value>Could not transform extents of any layer in this Map Definition. You will have to specify the extents manually.</value>
   </data>
-  <data name="document" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABp0lEQVQ4T42SzUoCYRSGz1ba
+        tahVC0FbSNCiRdIiIQgSKooMWrhxUSk6yIgoVhq06QK6BbuANl5A11CLVlGgRUjl//h7es/gCYIa++CB
+        meE8L+c7cyhUKJCwf36+BY4m4NnL52n35IR2cjkbkg9jjluDAX90u/zWbnO52eTnRoOf6nWbm9tbRt0x
+        8P4IkJcx0Uavx1WIL7UaP1ar/PD6yveVCt+Vy3xdKrEc1EaB97uD7WyWxsSaCHhvtX4NuSoWWfEGg2eA
+        BNpMp5V4u9/nT7T/V4h0IteBE1ePNkxTSXQwg3qn4xgiAXAS6tG6YSiGhYCmZTmGyGDhGOrRWiymJHvD
+        IbcxB6cQ+TtwkurR6uGhYvYRYGEOTiFvuCIcUz1aiUSU1GA04i6u4RQiewInpR4th8NKeogA6cIppI4r
+        wkmrR0sHB0pmhEUZIMApRJYNTkY98gQCtBgKCVnZtBG6cAppYUZSK4649pnz+2k+GDy1d3VCiCyb1Iqj
+        x4WHmVm//0ID7BAgM5HBypXkF8uedPEuteIAcWkaLLjc7tSUz3f5H6RWHHG/API/kG3WfDzsAAAAAElF
+        TkSuQmCC
+</value>
   </data>
   <data name="SearchCmdDescription" xml:space="preserve">
     <value>Search Command</value>
@@ -1178,22 +4679,51 @@
   <data name="SpecifyMapForWebLayout" xml:space="preserve">
     <value>Specify a map for this web layout</value>
   </data>
-  <data name="icon_invokescript_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_invokescript_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_invokescript_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUzAKy7zNrf48/Z4bXLssXQ2p6rvMTOzrjHwLDDtLTJsa/Btb3Ttam9rcfR2sDLycLX
+        t8nS277UtrnNs7DCtK/CtrHEtcbS1LPIscHWt8DVtrHHsMHL1LrQtLnJw7bMsrbFwLbMs8DWtrfDz7rR
+        tL/VtrvStbzRtKa5r7jPtLzRtam8ssHXt7zQtMHOzrrPtMDWt7vRtbzStam9rgAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAzACwAAAAAEAAQ
+        AAAItwBnCJyxAYDBgwg3DJxhEEKAhxADQACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjigQgaFDhYy
+        ohzoAEGCARhSJKjQAuPMGQYQSBgQYMCDBxIqxPx5IMEDokUxrEjQQcBPBSxCQC36wgQFqylnMMhAYmvR
+        DAwIiAirwEWErQsicDhRoEADgQcuLIAKI8aCCx8a3BUYdABRDiNKDEBgYKFABxM0gEDhQcMEB44HrlTA
+        QMGBxpkDAgA7
+</value>
   </data>
-  <data name="sql-join-inner" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\sql-join-inner.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="sql-join-inner" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACZ0lEQVQ4T6WTW0jTYRjGPwy6
+        CGrJKrDALooSSaQjdRERnQk6QAeN0gvFIiGZMRdouqRYjC1M3SZmZqnVTjh1Ot3MtTLdFLWRzrb+Oufc
+        Wtsa22xBEKzvkQndb/Dje3ne5/fu6k/i8ThJhqRk/DHJvqsju7n9ZE+ZnrWXZzhIOU/JxXum0noO/J+h
+        gy4cuCsH0k8/NN2QD7ulrsDvvkD0z0T7QGioUOCPAMzIsEMHXXogfeUA60S1MX/aHVEtBGOD8/6Y/tNU
+        2HytgolK1CEXwIwMO3TQhUMPsEgWp+dw6wen1OmPGRjfLx0tDZSIppwl4m++dkPUBjAjww4ddOHAJZl3
+        unJmFqNaW4K5HzHjgVxdRNjmnXmqDg4JXvsN9xtdY/tzdGHthLeu7aPrkdqyKBq2B1/BJTuLO4roVdPn
+        +XAH+OqJ6refUv4VKwKm8ufeLiBSBN4j0457G6R6plLaz1T1Tn5vhEu23VTmjc+FNBbmp0o36WvSjHpk
+        GWc1EW69c/Rek6cbYEamHHHX1/Q4+DW9Dr7a7JbAJVsL3pys1doaO8c8TaIue3WDflZ4gTPiuML7slDe
+        7NUBzMiwE3baH0j6mMf8t5NP4JIt+a3sXcWK0pfG2Tpxt11QrZrmi1WM/NB16xJXsmgFmJEt72gH3czb
+        cg5csjb7Ikk9zsvYUdTO5bVYapsHZ2Uqs7uFK2HeHSlYWAKYkb2gO3TQhQMXv1WUDavTsvaxjpXlsS9J
+        StlXn1WwL8s4aUerbgHMyxndoYMunIRLUuiwJhFspm8aZSNlPWVdglT6bkrs0IEMJyX5jymZTxnuP42L
+        XZ3g33aHAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="PackageReadError" xml:space="preserve">
     <value>Failed to read package. Error message was: {0}</value>
-    <comment>A message displayed when the package could not be read</comment>
   </data>
-  <data name="sql" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\sql.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="sql" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABE0lEQVQ4T82Tv2rCUBjFb+ji
+        IF1KKfgATtJBtFOW6gOIi2hBEAJm8QncpHXxBRwEB0cVRHBx0Uknh76CD+AzpOeEc+EmSJd06IUf5/tz
+        vi83hJgoikwWMg3zwf9gged5PliDqdRAX8Cn8jm0CXhGqtHfAobmDWiDkmLWxmACnkBd9VcOOH7G8YId
+        CNTsSFnrKn6Q58Pp2The8A72oCYDa8ztgnSe6MXX0DWPUuaMe85CN0/0aLbXHyA+aYjad16BufW5cZkL
+        LsaYCjRkrKEZdIE6v0ZD9ap69ISa4ay5grM0gBbAG9iq9g0dqr5UjTNkxQU58AieZeICy5eWF1M9ejnD
+        2V9PHt0DuAH/rjPLn/gnP9MPy8pUmKBE2kMAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="LessThanLabel" xml:space="preserve">
     <value>Less than {0}</value>
-    <comment>The label used for the lowest value in the graduated theme set</comment>
   </data>
   <data name="FsPreview_RasterPropertyNodeTooltip" xml:space="preserve">
     <value>Name: {0}{6}Description: {1}{6}Nullable: {2}{6}Image X Size: {3}{6}Image Y Size: {4}{6}Spatial Context: {5}</value>
@@ -1210,27 +4740,82 @@
   <data name="PreviewQueryElapsed" xml:space="preserve">
     <value>Preview Completed in {0}ms</value>
   </data>
-  <data name="document--plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEklEQVQ4T4WSS0hUYRSAD5NF
+        gyA5mFJRMOBEmJSPRYM43SyChh70mAEXEkw+B73KyNjglBpCtKlNUSAlQdimTQQh2HI2bmbRohatJGtm
+        xAYf834fz7nM2ahzu/BtLv/33f8/9wfH9DQwzpmZm8TAf2i8NzUFd/x+uD05CWdsNgB+UWYwWSjgZjaL
+        66kUhhIJXI3H8XcspvElEEBaN0hYJMARrVZmKJ7LYZTEyPY2rkSj+GttDX+Gw/gjFMKPi4vID60dIiws
+        a4FbPp/gTlBgI5ncN/JqYQEFi93+mAAGbni9wnAqn8ct2n6lCO+Ej0POsHhwzeMRRtI0g1g6rRvhADkj
+        4sFVVRXUDAUSmYxuhAdLjioeXHa7hbFcsYgpmoNehP8OOWPiwcX+fsGTp0CG5qAXWacjkuMRDzpcLmG8
+        UCphlo5RKXJ/eRRblq5g3ctzy+ZZBU496QC40NMjeIsU4F1UirR87cK+jQk8NH/ij+H9UYB5E0B7d7fw
+        sEQXpUCB3ZEHAfry50uEgs5/A3jwzbG/JAfhnWkOGhUFzjscjI9vWol2sTvS+knBrsjdPcDrI0Hg56TV
+        Cqft9kfaXd0n0rukYusHm0bzqg2rntaF4HlNEF7UzLFvJOobrNZZCWgRgmfCg+Uj8S9ue9uJx1fO4gF/
+        bZidsgs0CWg2ms3j1U1Nz/SoctZ+N7iMEcP1w9/YIUw7Q/B728HeTjIAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="WmsLayersUpdated" xml:space="preserve">
     <value>WMS layers updated</value>
   </data>
-  <data name="plus-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\plus-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="plus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACY0lEQVQ4T6WPX0hTcRTHT3eW
+        C93W3dTVlbLdoQbTejCMKDP/lJBs+CewJBnUY3vsvSACDXrpoYfCyig1IxekQWRei4WTscK2NbQ9bLt7
+        GMzXe9nL5XR+V9u1KHroBx/4/s453+/v/AAR4X/QzfDEAfCsCmCaeF4twEx1gJgkQlswHdB7bIbNkkf3
+        /hbgNb+slY6EO2Vfyq8My1e1i4Tvu185vNwhl1OPArx/C/Bag66ob92vDqxfQd83P7Yv9+kw3b92GXvX
+        RlTL7MEoBXh/3WDCIZRPCVJv8pLa8+UCnv08hMc/nKPlNg/TrMZ6Z74Oqbsm90lAHuMLD+2BJqlN7oqc
+        x7ZPPp2Wd92lAKZ/1jtWBrD+basM5DEC7vNTpyP9SutiDzbPn9JpmD2GhUIBs9ksVo3Xo/2BW6fmUSO6
+        Xx1VgDxGwL09oc7IoOZ5fRKLxSJmMhlMJBKYTCYxlUphOp3GXC6H+Xwe+cci1s40aUAeI+CuLdQe7tPE
+        YAvG43GMxWJ/NG9sbCA/KaJz9pAG5DEC7linPO9PKPY5N/LT4iZPxdLLTJfqc6SDLgXIYwSMWQKOaVGu
+        XmpAfpEGGPOisTbpUp16uyecMpDHCLhVKZhu2yTnUqNqD9MWYTIsiPqf9bVJ6zXCtlCncmMWCchjBNys
+        ALhe4S0btUb5kEu1r1LIKhnebME0Yft4QDWNWqJsFshjBACdOhPA4E4vd80smccdsjW0X+HjLo3BNKux
+        HpvRZ+lsDyiju5PwgLCjC7q5GzDMvYARLqTDNKuxHkAzsZco2x7AUaGSqCGEf8AeYrMcC/gB3xr3gK0n
+        sEUAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="ProcessedItem" xml:space="preserve">
     <value>Processed: {0}</value>
   </data>
-  <data name="icon_popupscrolldown" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_popupscrolldown.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_popupscrolldown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
+        /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
+        mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
+        /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
+        MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
+        mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
+        /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
+        M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
+        mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
+        /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
+        M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
+        mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
+        /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAAEAAQAAAIMQAfCBxIsKDBgwgTKlzIUOCPhxAj
+        SvzxYKJFig4vQiyoESNHiwknLozY8GHDkygbBgQAOw==
+</value>
   </data>
   <data name="FolderMissingPrefix" xml:space="preserve">
     <value>The folder must start with \"Library://\", do you want the starting folder to become:\n {0} ?</value>
-    <comment>A message that is displayed when the user has not entered a folder starting with Library://</comment>
   </data>
-  <data name="property" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\property.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="property" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACXUlEQVQ4T5WQUUiTURTHj7bH
+        BF8C6XGEwnoIpg/rIcEY2QhlW86USMjKUoa1LIO0h8AoRRSVolFWkFmuaUaBzW1awkZue+hh1pgJMWiL
+        rbGFC4fM/t1zSfEhaF34cb5zv//vfPe7ZDKZiHGfVEjmmhXV882K/n/BuTdNCpIyc76hinhDMJILPcHK
+        i24ERtuAzxPgPubuQ/zdAFLeEWQCVnBu5oTiyNYAHmI+VkXWhpLaqcYdo/77rch9GoPzlknWxHw/lsYs
+        WJm8iq8zPfgues7xAKWgUdDCXKqrGJy6WBHKfhiVctozLCv3sdmbCE904sv0NSw9OB1/fLTwGRmNxuNe
+        rze4vLwM78t7cPfV4+f723ho3o+Eqxe2K1pZeQjX0HjHr1fd2uRAdcHckK6gifR6favT6YTD4cDdU/vw
+        Y2EQY5YDuHO5Dr31SnwTx+UhXKe6DmP4jAaH9hTaeg7SbjFEXuJZ/FlhzzQemTXgyuvjwiSsLeWIvr4u
+        h7iejiAQCIAdvjNL7V4ig8FwbmNjA7lc7q8E3z6XQ2bHh+Dz+eD3+8GOgF2impqatvX1dZTblMhms+Df
+        4a8Eg0GEw2G5tx3OsiNgl0in05nX1taQyWTygrPsCNgl0mq17aurq1iwtCOVSsHlcsHj8Wyx2W9WzrIj
+        YJeosrLSkk6nkUgk8oKz7AjYJdJoNB3JZBItViAajcLtdsNut8u6/XlxcVG+5yw7AlKpVERqtbozHo8j
+        EonkBWfZKS0tJbnKysq6+PixWCwvOMuOUHcJdlJRUVFbcXHxjf9BOBeELM5PJb8B18GBdzrX/msAAAAA
+        SUVORK5CYII=
+</value>
   </data>
   <data name="SymbolGraphicsTextPlaceholder" xml:space="preserve">
     <value>&lt;text&gt;</value>
@@ -1238,71 +4823,703 @@
   <data name="SelectLayerFirst" xml:space="preserve">
     <value>Please select the layer first</value>
   </data>
-  <data name="application-import" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application-import.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application-import" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABx0lEQVQ4T6XUPWgaYRgH8Afc
+        LIJjySiCOOrkopOCDoKKDiV0jW0phVJoh1BwcXdyUgRxEAQHEYyIuly0EZJKk+LgpPj9gYKC4te/7yMI
+        BQ0Y8sKPO47//+55D+4IAL0Gud3uPY/HoxLeCVdn4qyKXC7XwWWpVHqq1+uo1Wp4fPyDh4d73N39wu1t
+        CZJUFscKyuXfqFT+4uZGehLdS3I4HAcfc7kcstksMpkM0uk0UqkUkskkEokE4vE4YrEYotEoIpEIQqEQ
+        ZDLZFY9+4BXv4kVLdL1ktVrJ6XSyD9vtVoxXQT6fR7vdxmazeRZnuUMmk4ksFgvZ7fZPq9VqPzYvSZLQ
+        6/WwXC5P4ix3yGg0esRNvjLeJ+v3++AnVKtVjEYjzOfzI4vFAjab7TPpdLofpza+Xq/BodlshslkcoSv
+        m83mL6RWq9+rVKqfLBAIgLVaLfCIxWIRjUYDw+HwyHQ6BU9Nosg3IYPB8G08HsPv92O32yEcDu+30Ol0
+        TuIsd0ir1ZJer2ffB4MBgsEgfD4fCoUCms3mszjLHdJoNAfXPGq32z0LZ0X3muRy+Z5CofAqlUr/S3CH
+        /ltycf5WuDgTZ9+86lPm38A/lieNoGpgVUMAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="sum" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\sum.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="sum" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAAtElEQVQ4T2P4//8/AyWYIs0g
+        iweZAYyMjAxA3AjEa3BgkByKq1E4UAM4gXQPEK8HYh2oGMhgEBskRtAAkGKQIROAeAsQ6yEZokusASBD
+        uIB4ChDvBGJ9JENwu4ABCqCKDYD0fiCeATUMZCgYI6cbVA7CACOgwqNAPBemGSQFZIPECRpgAlR0BogX
+        gzTDXAWkYeJ4DeAEKlwPxA9x4A1AcS58XgAZIAzEUjiwKF4DyMlUA58XALSICQGuLQH3AAAAAElFTkSu
+        QmCC
+</value>
   </data>
   <data name="InvalidValueError" xml:space="preserve">
     <value>Invalid value</value>
-    <comment>An error message that is displayed when the entered value is invalid</comment>
   </data>
   <data name="XmlDocIsValid" xml:space="preserve">
     <value>Document is valid</value>
   </data>
-  <data name="icon_zoomnext_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomnext_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomnext_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZqAK2km+XXyefi3uvv85ScqJWdqPb3+OXn6cHCwq6vsJqirpWdqsPJ0Li9w+fs8cTJ
+        0JKapqOrtN3g45Wcqu/y9dPU1sjIyJ6ksNHT1dvg5dHU1/X2+Kurq73BybGztbe5usPExbO1tr69vdPa
+        4O7x9NLS0t3k69TT05OcqZubm6ertpWdqbu7u9PV17q1sLm/yK2trP///8zQ1MLHzM7R1ZObpsTGx6mv
+        t9ni6qCosvX297Cvr/Hz9ejr7qOqtMbJzaSkpKSkpcnKyvL197W2tufp6ru8vdXb4ZaWlujt8ezt7tfd
+        4s7T2Le9wqiuuNvf4+Hk55afrMnLz8LDxPP09dfZ3ejq7Ofn6J2ksOjs787Q0pScqcLHy8C/v62trdbX
+        2MfKzdfY2aqwuO7w8tPZ38zNzejt8pWcqdfZ27m+xAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABqACwAAAAAEAAQAAAIqADVqNEAhkaXHSJOCFy48IaKCyhyQJFQwQJDgVIalDnwYgEWHlmeTLnYpEQY
+        HTGc1GBAIskPIQwfsChiYAwTCAoGOCDj5SIMKgZ6LIlSYEuEKykuElGyQYyCCWdWVBkR5KKNL0MopCFA
+        wAeOGR8uqkFgZYCZDgUOHPGARiwGBFoymJDBJUQCsQtBcEACxEiLBAACCMArFkDgwYQZGhacWHHgxopd
+        QL4YEAA7
+</value>
   </data>
-  <data name="icon_select" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_select.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_select" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZdAOvsxmuAjjRRfpOhtpOitjRQeDVQejtTfDZUdzBMejtXf///1/385///74OTl3WE
+        mu7w81Zhdv384KCuwG+EmZWjtPz72/7+3ISQoeLlyFptkPj5vs3Q1ImYsOPl0ktgg3CBnP/95mp9if//
+        4NfZ3P//zYKTjKWviv3919/inpuovOTo59DU27e6weTn4P//7KGyxzVRfjVQezJNdlRqgoCQl7/Gzm6C
+        n9fd15adp+PmzNfe0P//97C6y2d7ltXb45mppoqZra2yt+rs7v///5mjuOLjrdLauuzvqmN5jjVSdf//
+        9NfavlltiGp/nGB1h9nenmBviLq9wrS4vjRQdzNQelhujqGwnOXp7M/V2KWvwfv60+Ln2v///wAAAAAA
+        AABdACwAAAAAEAAQAAAIjAC7CBxIsCDBBDcMKuyioMeEhQVjQPihAuJAAViIZAlisYuMFUt44BhgsYqL
+        Bgxe7CAA0QCXEBIsjMhQYSEVDxdQbGFyBEgHhQV0LABQgsaBD1EUIgBQ48kGBw+ESFGoJIAVH1eMaBiy
+        cAaIKRgoIDFRZKENEl1YRDgBpQmHjjmSpBDRomMXGE60FAwIADs=
+</value>
   </data>
-  <data name="icon_back" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_back.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUmABQ1Z7S/z3GFo5TY9aXb8YO37oC06oa78oCz6Ya68Y3B96HF64q+9YW58Im99Xer
+        4d7s+6TH7t3r+tvp+H2x54Gz6Xeq4Hyv5Xqu5KvP9ajN85fM7eDu/oK27Z/D6KrO9H+y6YG17Hyv5t/t
+        /XOm3KbK8P///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAmACwAAAAAEAAQ
+        AAAIeQBNCBxIsKBBEwIOHhQAQGFBARwaOhQoYIQCiQ4FQHDAAICAjyAZUpTQIMGBDB80lIiwwMMGAAEA
+        TDDQoYDNEAYoYLBAYgBMEwAIgEBQYYDRo0Z/xiRwQQSAp1ChBhC49AHMAFizYh249OdEEzG9fo059SvV
+        smYnBgQAOw==
+</value>
   </data>
   <data name="BetweenLabel" xml:space="preserve">
     <value>Between {0} and {1}</value>
-    <comment>The label used for all "between" values in the graduated theme set</comment>
   </data>
   <data name="InvokeScriptCmdDescription" xml:space="preserve">
     <value>Invoke Script Command</value>
   </data>
-  <data name="GeometryStyleComboDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\GeometryStyleComboDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+  <data name="GeometryStyleComboDataset" xml:space="preserve">
+    <value>&lt;?xml version="1.0" standalone="yes"?&gt;
+&lt;ComboBoxDataSet&gt;
+	&lt;SymbolMark&gt;
+		&lt;Display&gt;Square&lt;/Display&gt;
+		&lt;Value&gt;Square&lt;/Value&gt;
+	&lt;/SymbolMark&gt;
+		&lt;Display&gt;Circle&lt;/Display&gt;
+		&lt;Value&gt;Circle&lt;/Value&gt;
+		&lt;Display&gt;Triangle&lt;/Display&gt;
+		&lt;Value&gt;Triangle&lt;/Value&gt;
+		&lt;Display&gt;Star&lt;/Display&gt;
+		&lt;Value&gt;Star&lt;/Value&gt;
+		&lt;Display&gt;Cross&lt;/Display&gt;
+		&lt;Value&gt;Cross&lt;/Value&gt;
+		&lt;Display&gt;X - Mark&lt;/Display&gt;
+		&lt;Value&gt;X&lt;/Value&gt;
+		&lt;Display&gt;Font...&lt;/Display&gt;
+		&lt;Value&gt;&lt;/Value&gt;
+		&lt;Display&gt;Symbol...&lt;/Display&gt;
+	&lt;SizeContext&gt;
+		&lt;Display&gt;Device space&lt;/Display&gt;
+		&lt;Value&gt;DeviceUnits&lt;/Value&gt;
+	&lt;/SizeContext&gt;
+		&lt;Display&gt;Map space&lt;/Display&gt;
+		&lt;Value&gt;MappingUnits&lt;/Value&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Points&lt;/Display&gt;
+		&lt;Value&gt;Points&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Inches&lt;/Display&gt;
+		&lt;Value&gt;Inches&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Feet&lt;/Display&gt;
+		&lt;Value&gt;Feet&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Yards&lt;/Display&gt;
+		&lt;Value&gt;Yards&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Millimeters&lt;/Display&gt;
+		&lt;Value&gt;Millimeters&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Centimeters&lt;/Display&gt;
+		&lt;Value&gt;Centimeters&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Meters&lt;/Display&gt;
+		&lt;Value&gt;Meters&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Units&gt;
+		&lt;Display&gt;Kilometers&lt;/Display&gt;
+		&lt;Value&gt;Kilometers&lt;/Value&gt;
+	&lt;/Units&gt;
+	&lt;Rotation&gt;
+		&lt;Display&gt;0 degrees&lt;/Display&gt;
+		&lt;Value&gt;0&lt;/Value&gt;
+	&lt;/Rotation&gt;
+	&lt;Rotation&gt;
+		&lt;Display&gt;30 degrees&lt;/Display&gt;
+		&lt;Value&gt;30&lt;/Value&gt;
+	&lt;/Rotation&gt;
+	&lt;Rotation&gt;
+		&lt;Display&gt;45 degrees&lt;/Display&gt;
+		&lt;Value&gt;45&lt;/Value&gt;
+	&lt;/Rotation&gt;
+	&lt;Rotation&gt;
+		&lt;Display&gt;90 degrees&lt;/Display&gt;
+		&lt;Value&gt;90&lt;/Value&gt;
+	&lt;/Rotation&gt;
+  &lt;Rotation&gt;
+    &lt;Display&gt;Expression...&lt;/Display&gt;
+    &lt;Value&gt;Expression...&lt;/Value&gt;
+  &lt;/Rotation&gt;
+  &lt;BackgroundType&gt;
+    &lt;Display&gt;Ghosted&lt;/Display&gt;
+    &lt;Value&gt;Ghosted&lt;/Value&gt;
+  &lt;/BackgroundType&gt;
+    &lt;Display&gt;Opaque&lt;/Display&gt;
+    &lt;Value&gt;Opaque&lt;/Value&gt;
+    &lt;Display&gt;Transparent&lt;/Display&gt;
+    &lt;Value&gt;Transparent&lt;/Value&gt;
+  &lt;Vertical&gt;
+    &lt;Display&gt;Baseline&lt;/Display&gt;
+    &lt;Value&gt;'Baseline'&lt;/Value&gt;
+  &lt;/Vertical&gt;
+  &lt;Vertical&gt;
+    &lt;Display&gt;Bottom&lt;/Display&gt;
+    &lt;Value&gt;'Bottom'&lt;/Value&gt;
+  &lt;/Vertical&gt;
+  &lt;Vertical&gt;
+    &lt;Display&gt;Capline&lt;/Display&gt;
+    &lt;Value&gt;'Capline'&lt;/Value&gt;
+  &lt;/Vertical&gt;
+  &lt;Vertical&gt;
+    &lt;Display&gt;Halfline&lt;/Display&gt;
+    &lt;Value&gt;'Halfline'&lt;/Value&gt;
+  &lt;/Vertical&gt;
+  &lt;Vertical&gt;
+    &lt;Display&gt;Top&lt;/Display&gt;
+    &lt;Value&gt;'Top'&lt;/Value&gt;
+  &lt;/Vertical&gt;
+  &lt;Vertical&gt;
+  &lt;/Vertical&gt;
+  &lt;Horizontal&gt;
+    &lt;Display&gt;Center&lt;/Display&gt;
+    &lt;Value&gt;'Center'&lt;/Value&gt;
+  &lt;/Horizontal&gt;
+&lt;/ComboBoxDataSet&gt;</value>
   </data>
-  <data name="CommandTypesDataset" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\CommandTypesDataset.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;utf-8</value>
+  <data name="CommandTypesDataset" xml:space="preserve">
+    <value>&lt;?xml version="1.0" encoding="utf-8" ?&gt;
+&lt;!--
+  Note to translators:
+    You can only translate &lt;Label&gt;, &lt;ToolTip&gt; and &lt;Description&gt;
+    If you translate any of the others, the editor won't work!
+--&gt;
+&lt;CommandTypesDataset&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;About&lt;/Command&gt;
+		&lt;Label&gt;About&lt;/Label&gt;
+		&lt;ToolTip&gt;About&lt;/ToolTip&gt;
+		&lt;Action&gt;About&lt;/Action&gt;
+		&lt;Description&gt;Display information about this application&lt;/Description&gt;
+		&lt;Viewers&gt;All&lt;/Viewers&gt;
+		&lt;Type&gt;Built-In&lt;/Type&gt;
+		&lt;EnabledIcon&gt;&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Buffer&lt;/Command&gt;
+		&lt;Label&gt;Buffer&lt;/Label&gt;
+		&lt;ToolTip&gt;Buffer&lt;/ToolTip&gt;
+		&lt;Action&gt;Buffer&lt;/Action&gt;
+		&lt;Description&gt;Create buffers around the selected features&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_buffer.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_buffer_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Clear Selection&lt;/Command&gt;
+		&lt;Label&gt;Clear Selection&lt;/Label&gt;
+		&lt;ToolTip&gt;Clear selection&lt;/ToolTip&gt;
+		&lt;Action&gt;Clear Selection&lt;/Action&gt;
+		&lt;Description&gt;Clear the current selections&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_clearselect.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_clearselect_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Copy Map&lt;/Command&gt;
+		&lt;Label&gt;Copy&lt;/Label&gt;
+		&lt;ToolTip&gt;Copy&lt;/ToolTip&gt;
+		&lt;Action&gt;Copy Map&lt;/Action&gt;
+		&lt;Description&gt;Copy current view of map to clipboard&lt;/Description&gt;
+		&lt;Viewers&gt;DWF&lt;/Viewers&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_copy.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_copy_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Help&lt;/Command&gt;
+		&lt;Label&gt;Help&lt;/Label&gt;
+		&lt;ToolTip&gt;Help&lt;/ToolTip&gt;
+		&lt;Action&gt;Help&lt;/Action&gt;
+		&lt;Description&gt;Launch help for this application&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_help.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_help_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Initial Center and Scale&lt;/Command&gt;
+		&lt;Label&gt;Initial Center and Scale&lt;/Label&gt;
+		&lt;ToolTip&gt;Initial center and scale&lt;/ToolTip&gt;
+		&lt;Action&gt;Restore View&lt;/Action&gt;
+		&lt;Description&gt;Zoom to the initial center and scale of the map&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_restorecenter.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_restorecenter_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Initial Map View&lt;/Command&gt;
+		&lt;Label&gt;Initial Map View&lt;/Label&gt;
+		&lt;ToolTip&gt;Initial map view&lt;/ToolTip&gt;
+		&lt;Action&gt;Fit To Window&lt;/Action&gt;
+		&lt;Description&gt;Fit the initial view of the map to the window&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_fitwindow.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_fitwindow_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Invoke Script&lt;/Command&gt;
+		&lt;Label&gt;Invoke Script&lt;/Label&gt;
+		&lt;ToolTip&gt;Invoke script&lt;/ToolTip&gt;
+		&lt;Action&gt;Invoke Script&lt;/Action&gt;
+		&lt;Description&gt;Invoke a script command&lt;/Description&gt;
+		&lt;Type&gt;Custom&lt;/Type&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_invokescript.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_invokescript_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Invoke URL&lt;/Command&gt;
+		&lt;Label&gt;Invoke URL&lt;/Label&gt;
+		&lt;ToolTip&gt;Invoke a command by accessing a URL&lt;/ToolTip&gt;
+		&lt;Action&gt;Invoke URL&lt;/Action&gt;
+		&lt;Description&gt;Invoke a URL command&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_invokeurl.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_invokeurl_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Measure&lt;/Command&gt;
+		&lt;Label&gt;Measure&lt;/Label&gt;
+		&lt;ToolTip&gt;Measure&lt;/ToolTip&gt;
+		&lt;Action&gt;Measure&lt;/Action&gt;
+		&lt;Description&gt;Measure distances on the map&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_measure.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_measure_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Next View&lt;/Command&gt;
+		&lt;Label&gt;Next View&lt;/Label&gt;
+		&lt;ToolTip&gt;Next View&lt;/ToolTip&gt;
+		&lt;Action&gt;Next View&lt;/Action&gt;
+		&lt;Description&gt;Buffer&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_zoomnext.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_zoomnext_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Pan&lt;/Command&gt;
+		&lt;Label&gt;Pan&lt;/Label&gt;
+		&lt;ToolTip&gt;Pan mode&lt;/ToolTip&gt;
+		&lt;Action&gt;Pan&lt;/Action&gt;
+		&lt;Description&gt;Drag the map to view areas out of range&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_pan.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_pan_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Pan Down&lt;/Command&gt;
+		&lt;Label&gt;Pan Down&lt;/Label&gt;
+		&lt;ToolTip&gt;Pan down&lt;/ToolTip&gt;
+		&lt;Action&gt;Pan Down&lt;/Action&gt;
+		&lt;Description&gt;Pan down by a preset increment&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_pandown.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_pandown_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Pan Left&lt;/Command&gt;
+		&lt;Label&gt;Pan Left&lt;/Label&gt;
+		&lt;ToolTip&gt;Pan left&lt;/ToolTip&gt;
+		&lt;Action&gt;Pan Left&lt;/Action&gt;
+		&lt;Description&gt;Pan left by a preset increment&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_panleft.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_panleft_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Pan Right&lt;/Command&gt;
+		&lt;Label&gt;Pan Right&lt;/Label&gt;
+		&lt;ToolTip&gt;Pan right&lt;/ToolTip&gt;
+		&lt;Action&gt;Pan Right&lt;/Action&gt;
+		&lt;Description&gt;Pan right by a preset increment&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_panright.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_panright_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Pan Up&lt;/Command&gt;
+		&lt;Label&gt;Pan Up&lt;/Label&gt;
+		&lt;ToolTip&gt;Pan up&lt;/ToolTip&gt;
+		&lt;Action&gt;Pan Up&lt;/Action&gt;
+		&lt;Description&gt;Pan up by a preset increment&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_panup.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_panup_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Previous View&lt;/Command&gt;
+		&lt;Label&gt;Previous View&lt;/Label&gt;
+		&lt;ToolTip&gt;Previous view&lt;/ToolTip&gt;
+		&lt;Action&gt;Previous View&lt;/Action&gt;
+		&lt;Description&gt;Go to previous view&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_zoomprev.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_zoomprev_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Print&lt;/Command&gt;
+		&lt;Label&gt;Print&lt;/Label&gt;
+		&lt;ToolTip&gt;Print&lt;/ToolTip&gt;
+		&lt;Action&gt;Print&lt;/Action&gt;
+		&lt;Description&gt;Print with optional layout&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_print.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_print_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Refresh Map&lt;/Command&gt;
+		&lt;Label&gt;Refresh Map&lt;/Label&gt;
+		&lt;ToolTip&gt;Refresh map&lt;/ToolTip&gt;
+		&lt;Action&gt;Refresh&lt;/Action&gt;
+		&lt;Description&gt;Refresh map and reload all layers keeping current center and scale&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_refreshmap.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_refreshmap_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Search&lt;/Command&gt;
+		&lt;Label&gt;Search&lt;/Label&gt;
+		&lt;ToolTip&gt;Search&lt;/ToolTip&gt;
+		&lt;Action&gt;Search&lt;/Action&gt;
+		&lt;Description&gt;Perform a search&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_search.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_search_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Select&lt;/Command&gt;
+		&lt;Label&gt;Select&lt;/Label&gt;
+		&lt;ToolTip&gt;Select mode&lt;/ToolTip&gt;
+		&lt;Action&gt;Select&lt;/Action&gt;
+		&lt;Description&gt;Select features by clicking and dragging&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_select.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_select_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Select Polygon&lt;/Command&gt;
+		&lt;Label&gt;Select Polygon&lt;/Label&gt;
+		&lt;ToolTip&gt;Select polygon&lt;/ToolTip&gt;
+		&lt;Action&gt;Select Polygon&lt;/Action&gt;
+		&lt;Description&gt;Create a polygon to select all features that fall within&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_selectpolygon.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_selectpolygon_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Select Radius&lt;/Command&gt;
+		&lt;Label&gt;Select Radius&lt;/Label&gt;
+		&lt;ToolTip&gt;Select radius&lt;/ToolTip&gt;
+		&lt;Action&gt;Select Radius&lt;/Action&gt;
+		&lt;Description&gt;Click and drag to select all features inside the circle&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_selectradius.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_selectradius_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Select Within&lt;/Command&gt;
+		&lt;Label&gt;Select Within&lt;/Label&gt;
+		&lt;ToolTip&gt;Select within&lt;/ToolTip&gt;
+		&lt;Action&gt;Select Within&lt;/Action&gt;
+		&lt;Description&gt;Select features that fall within currently selected areas&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_selectwithin.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_selectwithin_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;View Options&lt;/Command&gt;
+		&lt;Label&gt;View Options&lt;/Label&gt;
+		&lt;ToolTip&gt;View options&lt;/ToolTip&gt;
+		&lt;Action&gt;View Options&lt;/Action&gt;
+		&lt;Description&gt;View Options&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_viewoptions.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_viewoptions_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Zoom&lt;/Command&gt;
+		&lt;Label&gt;Zoom Dynamic&lt;/Label&gt;
+		&lt;ToolTip&gt;Zoom dynamic&lt;/ToolTip&gt;
+		&lt;Action&gt;Zoom&lt;/Action&gt;
+		&lt;Description&gt;Zoom dynamically by clicking and dragging&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_zoom.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_zoom_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Zoom In&lt;/Command&gt;
+		&lt;Label&gt;Zoom In&lt;/Label&gt;
+		&lt;ToolTip&gt;Zoom in&lt;/ToolTip&gt;
+		&lt;Action&gt;Zoom In&lt;/Action&gt;
+		&lt;Description&gt;Zoom in by a preset increment&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_zoomin.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_zoomin_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Zoom Out&lt;/Command&gt;
+		&lt;Label&gt;Zoom Out&lt;/Label&gt;
+		&lt;ToolTip&gt;Zoom out&lt;/ToolTip&gt;
+		&lt;Action&gt;Zoom Out&lt;/Action&gt;
+		&lt;Description&gt;Zoom out by a preset increment&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_zoomout.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_zoomout_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Zoom Rectangle&lt;/Command&gt;
+		&lt;Label&gt;Zoom Rectangle&lt;/Label&gt;
+		&lt;ToolTip&gt;Zoom to rectangle&lt;/ToolTip&gt;
+		&lt;Action&gt;Zoom Rectangle&lt;/Action&gt;
+		&lt;Description&gt;Zoom in on an area&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_zoomrect.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_zoomrect_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Zoom Selection&lt;/Command&gt;
+		&lt;Label&gt;Zoom Selection&lt;/Label&gt;
+		&lt;ToolTip&gt;Zoom to selection&lt;/ToolTip&gt;
+		&lt;Action&gt;Zoom To Selection&lt;/Action&gt;
+		&lt;Description&gt;Zoom to extents of selected features&lt;/Description&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_zoomselect.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_zoomselect_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+	&lt;Command&gt;
+		&lt;Command&gt;Get Printable Page&lt;/Command&gt;
+		&lt;Label&gt;Printable Page&lt;/Label&gt;
+		&lt;ToolTip&gt;Get printable page&lt;/ToolTip&gt;
+		&lt;Action&gt;Get Printable Page&lt;/Action&gt;
+		&lt;Description&gt;Get printer-friendly page&lt;/Description&gt;
+		&lt;Viewers&gt;AJAX&lt;/Viewers&gt;
+		&lt;EnabledIcon&gt;../stdicons/icon_printablepage.gif&lt;/EnabledIcon&gt;
+		&lt;DisabledIcon&gt;../stdicons/icon_printablepage_disabled.gif&lt;/DisabledIcon&gt;
+	&lt;/Command&gt;
+&lt;/CommandTypesDataset&gt;
+</value>
   </data>
-  <data name="icon_selectradius_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_selectradius_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_selectradius_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQYAM3Lz5+svc3FycTM09bcyM3EyM26v86ssM6wtM26vs23u83KzsvSxs6mqs22us6r
+        r8LKxMTFzM6ussS1vMS/xs6mqc2/w821uQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBAAAYACwAAAAAEAAQAAAIiwAxCBSg4ECDBxcECFy40ACCBAUWFEggwQBDgQYcCADA
+        kaMABxYXCkCwsWPHkQoFKkhgsqUFBQsfFGgJIEAEAAUeLGywgGYAmwsqLDwws2UABgEoHFi40icBpBNE
+        kjRK4GmAAQ01mgxQ1SpWjA8jFuAK4edPhgQNHghQdoDbrxcF/oQbl+HVunjrBgQAOw==
+</value>
   </data>
-  <data name="edit-indent" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\edit-indent.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="edit-indent" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABjElEQVQ4T5XTS0sCURQH8OOm
+        rVmL1E0UGhRWJqGGBUapQZE9NpWQSBBtg4i2EkF9iXa10srHFJHUWNGDgmhTqyjaRASt293+Z3AmXyM0
+        8PPO3Hse98oMCSHIYDCwOCQgWbCHcR8OIAVpyIIEW5zDucpPocC/x/IC3LlWV+oNrClcQ6vkHFzR3wEH
+        qMHquLj5TaqFjS+Kxj/+CjQ7Y8Ts7iVlIbb+KSNI6OH1kgL983li3rlTCi8/MXH+8KOL1zlO+w/cMzkC
+        4RhP+z2zOeqLnMn8rIfXuaFWwB5KELyB4PvO8BG1j6YrdIxlyTl1yM2UHWsFbMEUgWgdTvjtoQyKZWR+
+        Lsfz9pBEXRPH1DN9UrwDCUkStY1I1D15w6qen+cL60qctoNGW4RYvdlLjuAutvcqD0TfRTmedwR2yNjk
+        Ib5030ST1UctrpUKJotPSVSv8gIy3sQ8XMAlXME13MId3MMjkp/hpeYO9L6NkvbFR8C9EUnbNbomEWMt
+        sGBsgDrtCFwAzEVBanC1saTAL88kUjz8yRfZAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="ExpressionItem" xml:space="preserve">
     <value>Expression...</value>
-    <comment>A value displayed in the combobox to activate the expression builder</comment>
   </data>
-  <data name="edit" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\edit.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="edit" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABaElEQVQ4T6WSv07CUBSHWzWO
+        xtE/g08Am5rwDtCGm9w2oBAUW3SC0NAmDaEk3XgRB0PC0IEQFhYWJkYmJwbDwBscz6m2uYqViCf52vR3
+        zv1621wJAKT/EC6WZbmLvPyRLq2NBH3f98HzvJhOpwPtdhtc1wXHcaDVakGz2YR6vQ62bQO+rC8KBrRA
+        1/UVNgYRlmVBo9Gg4TjLZDKrSqUSZqIgIAGGAUKfRASGYUC1Wt3ITdMMM1HQw2CIMEEwLJfLUCqVaJh6
+        kZhm6LknCqKmeB9zzoExRoKxIIhntgkmiqJCNquQYLKLYKooecjl8iSY7iKYqSoHVdVIMNsqkDZrztgN
+        /oNbPC3S/Id+eIY+Lpt1jdGC8zvg/J4GFghlXypJ8IxTr6nU5ZrzBxQYkE5frSlDqBdXkmBZLD5BofAI
+        mlZDzE9qtJPlb4IDbJ4jI+QtAepdIIck+r6DPcyOkBPkLIFTzI+R/UjwDveQHRw0Mf7uAAAAAElFTkSu
+        QmCC
+</value>
   </data>
   <data name="FsMySql" xml:space="preserve">
     <value>MySQL Feature Source</value>
   </data>
-  <data name="icon_forward_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_forward_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_forward_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIQcALa4vIaKkNbe4tjZ29vc3uTn6ufq7ejr7uXo6+Hk58PK0M7V28zT2cHIzs3T2svR
+        2MbN08bM08rQ18jP1cLIz+bp7MTK0cfN1MXL0sPJ0M/R0+Ll6P///wAAAAAAAAAAACH/C05FVFNDQVBF
+        Mi4wAwEBAAAh+QQBAAAcACwAAAAAEAAQAAAIdAA5CBxIsKDBgQAOKgQQQKFBAAgaOkRYQIBEgQAyatRY
+        AIJFhAdCGjBQAUGBAhEsfOQAwMCCBQ4YPJAw4QIGBQ0+thTAsydPBRQsaiAQoKhRoxsyWBxAQOCAp1AH
+        AEiwtKnDqQGYTmSZ1epEAFq3cggrVmFAADs=
+</value>
   </data>
   <data name="FsPostgreSql" xml:space="preserve">
     <value>PostgreSQL/PostGIS Feature Source</value>
   </data>
-  <data name="icon_zoomrect" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_zoomrect.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_zoomrect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZoAAE1Z6e2z3BJJeqxd8Xa71tgZMfb8KjR49Dh8trn9LjH19nm86i7zufu9brT7Zu2
+        0NDg8dHh8tjm8qu0vOzw9Mza6PT3+aSttoOGiGRrcoSAf15cWuLr9a22v97m7Z+fn7e/x1xbXcbb75mi
+        rM7X383U2cjIx3h3d9fb3+Xq73yQo4SHi7S3u67L53ahzKq8z5u83uLs9a6yt+Do8W50epyzy7bBzeTr
+        8cvY5cPT49ri6unv9LvU7b7L2EdKTauoqHyPokpMTMjQ2OHr9FhYWbCurbC/z398e5GRkqC50q/N6tbe
+        56TF52RgX4SFiJDO1oiOlGxtb+rv82BocJy20KWqsXV5fsrc7tDh8aCnr6jG5DAvLq7C1efs8auvs+Dq
+        9JSVl+vw9YWUo77H0Tg3N5qbnaamp4aKjQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AABoACwAAAAAEAAQAAAIuADRABhIsGDBAAIDKFzIUCEAhA/RSJxIMaFANEU0NDnyo6JFNB9YjOlhowoS
+        ExQjlhHiocuOGRWMrEgZwIwMKUssNPgi4YoYMBMfnihBQceNIQsgEKgRImiADSnC4MiRIAIBB1rIOI2C
+        okGMBAhEHFBCxcdBKF44LMBi4MATJipoNAThhAQCAzxguEgyZYLHLBhGcGnxAEiGAh4ldjhDZEsQKxcK
+        CBiQGI2CFwokMhAwuXLFzZ3RBAQAOw==
+</value>
   </data>
   <data name="FindEmptyString" xml:space="preserve">
     <value>Cannot Find an Empty String</value>
   </data>
-  <data name="layers-stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layers-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layers-stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACm0lEQVQ4T4WQ3UtTYRzHn5uu
+        pC7CoouyCwmioiih/oLugroRKgi1F6QQGb0oQqHQTYFdJG1gpaBZOnVN3dqrbTu24xrOHffiXs7Zdjw7
+        287Ldvbizui25xEmxzHqgQ/n7ff9ffkc0DFoBw20weebkLv/Ac20NYbBlQHbLWdYXNrJ12y0KFuagb6h
+        GTSrXLDXDF9q1JZE8M1SzN2M9ybKZSZ4fUqQrZdfWO/tL6g3bySkEC3WRIqXs40kBTmHxwrpUUPMSeaq
+        xkvPzF1owYHm4fkwpbEmi2MmSlAybk/ytoDAkFw1O6IN/9pmK4aLT009+8715nC6UqI4+Q9sqNWhuGoN
+        Nstqa4LbZnfTQ18DWGCnvHxBZXwAkAfyMW5mPUGmknHH8qI/Var5ksVdJbFstfZWH83BIPN8inD5kiX9
+        uf6VRwB5IB+9N4P76RLrDAuil5JkD1moKAmly/LrxW0OLt3pn/C5PKSkO9u31AuQB/LR4gzupYqMleCE
+        tUi+ag/wRTPBST/8nGTczEnuaL78ajaYW49LdO+4F1uL5nVnHuueAOSBfKZdNI5FRHrWnc4tb2TLut9s
+        QYkjLJQHp4ksFsmn7n/wYPD6vb13oQ8gD+QzZopjMEh9/pliv7mZyoKHrcx72HKd1ZAgD34hRNicUU1u
+        EBOrlPFk98xDgDzgtrkRbXBV582Qk45UVGMhM2pznFOyuM4Ubo9i9LQzETnV89XQ2qlRHb7a1QGQh2WL
+        nxme27JPOpIp7TpLzeFpshF7UEgfaAbgBACgBSAPW4DXvjNEp4Zm/I6BKR/ejI+2eEjZfOjoaZiHB3l8
+        ssVXrAF+Hv7x2Wagb2hmzxmA9r3m+jlyrbsD+Ry7M/HyX7R2qlUt529ch7nj+2F48xccaJZr1sn7YAAA
+        AABJRU5ErkJggg==
+</value>
   </data>
   <data name="ConfirmGoogleScaleList" xml:space="preserve">
     <value>Are you sure you want to use a Google-compatible Scale List? This will overwrite your existing scale ranges and will only line up with commercial layers in Fusion if your Map's Coordinate System is WGS84.PseudoMercator</value>
@@ -1406,11 +5623,28 @@
   <data name="Func_URLENCODE_StringValueDescription" xml:space="preserve">
     <value>String to URL encode</value>
   </data>
-  <data name="icon_maptip" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_maptip.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_maptip" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIU/APT19/Dx89HV3PX292tpdYuKld3g5N3g5by9xdnc4c7S2dXY3snO1sbHzJGQmdXY
+        37K1v+Dj5/P09Nba393h5dTX3czN0PP09dfb4M7S2uLk6Nrd4tHW3ImJlGFgbezu8bi7w93h5NTZ3urr
+        7oWGke3u8eXn6svQ2O/x8+rr7enr7c3S2ZSTnMzQ1+3v8dHW2+Hj6Nnd4t7g5c7T2tPX3eHk6NXZ36al
+        rGpodMvQ19nc4s3S2ubo6+3v8EZDUv///yH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
+        AAAIvAB/3MDho6DBgzhuCCQwoOEAFAAifog4gMDACDky7tjIkQGDHBEIZtTIcWOLExkLztixwsPBghAy
+        KFBQUIBNGhUg+CCxkYOAFwIKPrCxYIENED462FhqQ8SDgjES6MAwAYGPAjqyStVRMMQBCgY2WMWqw8AB
+        swVrqK0hY2zWGjBqaChogoddHg18OLh7t+AIvnn33lWRomCPw4ct+GCB2EWPEj5wBAiAuPLhyQESEpBg
+        ufIFCRYFEnyJUGFAADs=
+</value>
   </data>
-  <data name="icon_maptip_disabled" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_maptip_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_maptip_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIUqAO3u8e7v8vHz9cTDyPHz9O3v8fr7+9HQ1eTl6NPT1ujp6+Dh5enr7/f3+PP09dDQ
+        1Pb3+O/w8sC/xfLz9fj4+evs7/f4+evr7PX19+7v8ePk5+/x89TU187P0/n5+u7w8tvb3sPDx/P09vv7
+        /Ors7/Dx8/X29+vt8Pj5+bW0uv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAqACwAAAAAEAAQ
+        AAAIqQBVgAiRoqDBgyFACBwwouEIDw4tOBww0AGJiycyamTAgIQDghcxasxYIWRBjRIOFlygsSCAlwUy
+        LEjRIWMBADcLBvgQYKeGFA8+CBUaoGCJoxsiIEhx4KjTEgUJCBBAoMTSpiWkSi0ooquICVePehVREIOJ
+        syYUpEiAFm3BBm3VskULoUFBFHjxXkjBIS9eCilCePDgt/BgDwkHGCjs14ABigIJqkSoMCAAOw==
+</value>
   </data>
   <data name="SaveMapBeforeTiling" xml:space="preserve">
     <value>You must save this map first before you can run MgCooker</value>
@@ -1424,4 +5658,10 @@
   <data name="BaseLayerGroupConvertedToLayerGroup" xml:space="preserve">
     <value>Base Layer Group ({0}) converted to Regular Group ({1})</value>
   </data>
+  <data name="TextUploading" xml:space="preserve">
+    <value>Uploading</value>
+  </data>
+  <data name="TextDownloading" xml:space="preserve">
+    <value>Downloading</value>
+  </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
