[mapguide-commits] r6689 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 23 12:57:58 EDT 2012
Author: jng
Date: 2012-05-23 09:57:57 -0700 (Wed, 23 May 2012)
New Revision: 6689
   trunk/Tools/Maestro/Maestro/changelog.txt
Update changelog.txt
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt	2012-05-23 11:58:25 UTC (rev 6688)
+++ trunk/Tools/Maestro/Maestro/changelog.txt	2012-05-23 16:57:57 UTC (rev 6689)
@@ -1,6 +1,12 @@
 5.0 Beta 2
  - MgCooker tiling classes now part of the MaestroAPI
+ - Fix: Potentially long running tasks are now done on background threads with busy dialogs
+ - Fix: Non-working expression buttons for some color pickers
+ - Fix: Watermarks not showing up as a resource type in Create Package dialog
+ - Fix: HttpServerConnection no longer re-creates MapGuide session on any exception thrown, only ones relating to session expiry.
+ - Fix: Avoid using full schema walks wherever possible. Will improve performance on large data stores.
+ - Fix: Broken Server Status Monitor
  - Fix: Some MgCooker command line arguments were being ignored
  - Fix: Raise signficantly the maximum allowed "Meters per unit" value in MgCooker.
  - Fix: Dragging and dropping onto a layer in the Map Definition editor will add the layer to that layer's parent group instead of the root
More information about the mapguide-commits mailing list
