[mapguide-commits] r6690 - trunk/MgDev/Server/src/Common/Manager
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 23 22:29:49 EDT 2012
Author: hubu
Date: 2012-05-23 19:29:48 -0700 (Wed, 23 May 2012)
New Revision: 6690
   trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
   trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
Submit on behalf of Andy Zhang
Implement ticket #1998: Fdo Connection Manager enhancement.
Ticket: http://trac.osgeo.org/mapguide/ticket/1998
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp	2012-05-23 16:57:57 UTC (rev 6689)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp	2012-05-24 02:29:48 UTC (rev 6690)
@@ -239,26 +239,35 @@
     // Try to acquire a connection. We will either get a connection or exhaust the re-try logic
     providerInfo = TryAcquireFdoConnection(provider);
+    bool reuseOnly = false;
+    ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, NULL));
     if(providerInfo)
-        ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex, NULL));
+        // If current connections count is equal to the pool size of the provider, we cannot create new connection.
+        // But if it is a PerCommandThreaded/MultiThreaded provider, we can reuse existing connections.
+        reuseOnly = (providerInfo->GetCurrentConnections() == providerInfo->GetPoolSize());
         if(m_bFdoConnectionPoolEnabled)
             // Search the cache for an FDO connection matching this resourceIdentifier
             // The content and long transaction name must also match, as the information may change
-            pFdoConnection = FindFdoConnection(resourceIdentifier);
+            pFdoConnection = FindFdoConnection(resourceIdentifier, reuseOnly);
+    if (providerInfo && ((NULL == pFdoConnection && !reuseOnly) || (NULL != pFdoConnection)))
+        STRING longTransactionName = (STRING)featureSource->GetLongTransaction();
+        // Update the long transaction name to any active one for the current request
+        MgLongTransactionManager::GetLongTransactionName(resourceIdentifier, longTransactionName);
         if(NULL == pFdoConnection)
             // Parse XML and get properties
             STRING configDocumentName = (STRING)featureSource->GetConfigurationDocument();
-            STRING longTransactionName = (STRING)featureSource->GetLongTransaction();
-            // Update the long transaction name to any active one for the current request
-            MgLongTransactionManager::GetLongTransactionName(resourceIdentifier, longTransactionName);
             // Create a new connection
             pFdoConnection = m_connManager->CreateConnection(provider.c_str());
@@ -294,6 +303,11 @@
                                resourceIdentifier->ToString(),
+        else
+            // Need to activate long transaction again for some providers.
+            ActivateLongTransaction(pFdoConnection, longTransactionName);
         #ifdef _DEBUG_FDOCONNECTION_MANAGER
         ShowProviderInfoCache();
@@ -369,16 +383,24 @@
     providerInfo = TryAcquireFdoConnection(providerNoVersion);
     if(providerInfo)
             // Search the cache for an FDO connection matching this provider/connection string
-            pFdoConnection = FindFdoConnection(providerNoVersion, updatedConnectionString);
+            pFdoConnection = FindFdoConnection(providerNoVersion, updatedConnectionString, reuseOnly);
             // Create a new connection and add it to the cache
@@ -586,7 +608,7 @@
-FdoIConnection* MgFdoConnectionManager::FindFdoConnection(MgResourceIdentifier* resourceIdentifier)
+FdoIConnection* MgFdoConnectionManager::FindFdoConnection(MgResourceIdentifier* resourceIdentifier, bool reuseOnly)
     CHECKNULL(resourceIdentifier, L"MgFdoConnectionManager.FindFdoConnection");
@@ -619,7 +641,8 @@
     pFdoConnection = SearchFdoConnectionCache(provider,
-                                              ltName);
+                                              ltName,
+                                              reuseOnly);
     MG_FDOCONNECTION_MANAGER_CATCH_AND_THROW(L"MgFdoConnectionManager.FindFdoConnection")
@@ -627,7 +650,7 @@
-FdoIConnection* MgFdoConnectionManager::FindFdoConnection(CREFSTRING provider, CREFSTRING connectionString)
+FdoIConnection* MgFdoConnectionManager::FindFdoConnection(CREFSTRING provider, CREFSTRING connectionString, bool reuseOnly)
     FdoPtr<FdoIConnection> pFdoConnection;
@@ -636,7 +659,7 @@
     STRING providerNoVersion = UpdateProviderName(provider);
     STRING ltName = L"";
-    pFdoConnection = SearchFdoConnectionCache(providerNoVersion, connectionString, ltName);
+    pFdoConnection = SearchFdoConnectionCache(providerNoVersion, connectionString, ltName, reuseOnly);
@@ -644,7 +667,7 @@
-FdoIConnection* MgFdoConnectionManager::SearchFdoConnectionCache(CREFSTRING provider, CREFSTRING key, CREFSTRING ltName)
+FdoIConnection* MgFdoConnectionManager::SearchFdoConnectionCache(CREFSTRING provider, CREFSTRING key, CREFSTRING ltName, bool reuseOnly)
@@ -684,9 +707,12 @@
                                 INT32 useLimit = providerInfo->GetUseLimit();
                                 if (useLimit == -1 || pFdoConnectionCacheEntry->nUseTotal <= useLimit)
+                                    // If the provider is a PerCommandThreaded/MultiThreaded provider, reuse existing
+                                    // connection only when reuseOnly is true (current connections count == pool size).
                                     if((!pFdoConnectionCacheEntry->bInUse) ||
-                                       (providerInfo->GetThreadModel() == FdoThreadCapability_PerCommandThreaded) ||
-                                       (providerInfo->GetThreadModel() == FdoThreadCapability_MultiThreaded))
+                                       (reuseOnly &&
+                                       ((providerInfo->GetThreadModel() == FdoThreadCapability_PerCommandThreaded) ||
+                                       (providerInfo->GetThreadModel() == FdoThreadCapability_MultiThreaded))))
                                         // It is not in use or the provider is a PerCommandThreaded/MultiThreaded provider so claim it
                                         pFdoConnectionCacheEntry->lastUsed = ACE_OS::gettimeofday();
@@ -1405,7 +1431,10 @@
         if(providerInfo)
             // Check to see if all connections are in use
-            if(providerInfo->GetCurrentConnections() == providerInfo->GetPoolSize())
+            // If it is a PerCommandThreaded/MultiThreaded provider, the existing connections can be reused.
+            if(providerInfo->GetCurrentConnections() == providerInfo->GetPoolSize() &&
+                ((providerInfo->GetThreadModel() != FdoThreadCapability_PerCommandThreaded) &&
+                (providerInfo->GetThreadModel() != FdoThreadCapability_MultiThreaded)))
                 // All connections are in use
                 providerInfo = NULL;
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h	2012-05-23 16:57:57 UTC (rev 6689)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h	2012-05-24 02:29:48 UTC (rev 6690)
@@ -244,9 +244,9 @@
     // Constructor
     MgFdoConnectionManager();
-    FdoIConnection* FindFdoConnection(MgResourceIdentifier* resourceIdentifier);
-    FdoIConnection* FindFdoConnection(CREFSTRING provider, CREFSTRING connectionString);
-    FdoIConnection* SearchFdoConnectionCache(CREFSTRING provider, CREFSTRING key, CREFSTRING ltName);
+    FdoIConnection* FindFdoConnection(MgResourceIdentifier* resourceIdentifier, bool reuseOnly = false);
+    FdoIConnection* FindFdoConnection(CREFSTRING provider, CREFSTRING connectionString, bool reuseOnly = false);
+    FdoIConnection* SearchFdoConnectionCache(CREFSTRING provider, CREFSTRING key, CREFSTRING ltName, bool reuseOnly = false);
     void CacheFdoConnection(FdoIConnection* pFdoConnection, CREFSTRING provider, CREFSTRING key, CREFSTRING ltName);
     bool UpdateFdoConnectionCache(CREFSTRING provider);
More information about the mapguide-commits mailing list
