[mapguide-commits] r7139 - trunk/MgDev/Web/src/viewerfiles
    svn_mapguide at osgeo.org
    Fri Oct 19 08:51:15 PDT 2012
Author: jng
Date: 2012-10-19 08:51:15 -0700 (Fri, 19 Oct 2012)
New Revision: 7139
   trunk/MgDev/Web/src/viewerfiles/legendctrl.templ
   trunk/MgDev/Web/src/viewerfiles/legendui.templ
#1012: Add an AJAX Viewer API to Expand and Collapse layer and group nodes in the legend. These expanded/collapsed states are only client-side, for these states to be persistent (ie. stay the same after legend refresh) the calling application must invoke a server-side script that calls SetExpandInLegend() on the appropriate MgLayer and MgLayerGroup objects. This has been remarked in the updated Viewer API documentation (coming after this)
Modified: trunk/MgDev/Web/src/viewerfiles/legendctrl.templ
--- trunk/MgDev/Web/src/viewerfiles/legendctrl.templ	2012-10-19 15:01:03 UTC (rev 7138)
+++ trunk/MgDev/Web/src/viewerfiles/legendctrl.templ	2012-10-19 15:51:15 UTC (rev 7139)
@@ -42,6 +42,16 @@
     return thisFrame.legendUiFrame.GetBaseGroups(onlyVisible,scale);
+function ExpandLayerInLegend(layerName, expandInLegend)
+    return thisFrame.legendUiFrame.ExpandLayerInLegend(layerName, expandInLegend);
+function ExpandGroupInLegend(groupName, expandInLegend)
+    return thisFrame.legendUiFrame.ExpandGroupInLegend(groupName, expandInLegend);
 // private functions -----------------------------------------------
 function IsUiReady()
Modified: trunk/MgDev/Web/src/viewerfiles/legendui.templ
--- trunk/MgDev/Web/src/viewerfiles/legendui.templ	2012-10-19 15:01:03 UTC (rev 7138)
+++ trunk/MgDev/Web/src/viewerfiles/legendui.templ	2012-10-19 15:51:15 UTC (rev 7139)
@@ -1222,12 +1222,98 @@
 function SetShowInvisibleLayers(isInvisibleLayersVisible)
-  showInvisibleLayers = isInvisibleLayersVisible;
-  GetMainFrame().Refresh();
+    showInvisibleLayers = isInvisibleLayersVisible;
+    GetMainFrame().Refresh();
+    if (tree == null) return;
+    var nodeLayer = FindLayerByName(tree,layerName);
+    if (nodeLayer != null)
+            if (expandInLegend)
+                 Expand(nodeLayer);
+            else
+                 Collapse(nodeLayer);
+    if (tree == null)
+        return;
+    var nodeGroup = FindGroupByName(tree, groupName);
+    if (nodeGroup != null)
+        ExpandAllGroupParentInLegend(expandInLegend,nodeGroup);
+function FindGroupByName(nodes, groupName)
+    for (var i=0; i < nodes.length; i++)
+        var node = nodes[i];
+        if (node.type == 0)// only group
+            if (node.name.toLowerCase() == groupName.toLowerCase())
+                return node;
+            if (node.children != null)
+                var child = FindGroupByName(node.children, groupName.toLowerCase());
+                if (child != null)
+                    return child;
+    return null;
+function FindLayerByName(nodes, layerName)
+        if (node.type == 1)// only layer
+            if (node.name.toLowerCase() == layerName.toLowerCase())
+                return node;
+        else (node.type == 0) // only group
+                var child = FindLayerByName(node.children, layerName.toLowerCase());
+                    return child;
+    return null;
+// if expandInLegend==true => node group and all parents of this group are expanded
+// if expandInLegend==false => only node group is collapsed
+function ExpandAllGroupParentInLegend(expandInLegend,node)
+        Expand(node);
+        if (node.parent!= null)
+            ExpandAllGroupParentInLegend(expandInLegend,node.parent);
+    else Collapse(node);
+function GetGroupByLayer(layerName)
+    if (tree == null) return null;
+    if ((nodeLayer != null) && (nodeLayer.parent != null))
+        return nodeLayer.parent;
+    return null;
 </script>
 </head>
 <body id="legendUi" onload="InitDocument()" leftmargin=3 topmargin=3 rightmargin=3 bottommargin=3 marginwidth=3 marginheight=3>
     <div id="Tree"></div>
More information about the mapguide-commits
