[mapguide-commits] r7140 - trunk/MgDev/Doc/viewerapi
svn_mapguide at osgeo.org
Fri Oct 19 08:51:34 PDT 2012
Author: jng
Date: 2012-10-19 08:51:34 -0700 (Fri, 19 Oct 2012)
New Revision: 7140
trunk/MgDev/Doc/viewerapi/index.htm
#1012: Viewer API doc update
Modified: trunk/MgDev/Doc/viewerapi/index.htm
--- trunk/MgDev/Doc/viewerapi/index.htm 2012-10-19 15:51:15 UTC (rev 7139)
+++ trunk/MgDev/Doc/viewerapi/index.htm 2012-10-19 15:51:34 UTC (rev 7140)
@@ -21,6 +21,8 @@
<LI><A href="#legendpalette_getbasegroups">GetBaseGroups</A></LI>
<LI><A href="#legendpalette_getlayer">GetLayer</A></LI>
<LI><A href="#legendpalette_getlayers">GetLayers</A></LI>
+ <LI><A href="#legendpalette_expandlayerinlegend">ExpandLayerInLegend</A></LI>
+ <LI><A href="#legendpalette_expandgroupinlegend">ExpandGroupInLegend</A></LI>
<LI><A href="#legendpalette_internalstatecomplete">InternalStateComplete</A></LI>
<LI><A href="#legendpalette_refresh">Refresh</A></LI>
<LI><A href="#legendpalette_setscale">SetScale</A></LI>
@@ -189,6 +191,38 @@
</P>
</DD>
</DL>
+ <DL>
+ <DT><STRONG><A name="legendpalette_expandlayerinlegend">ExpandLayerInLegend(layerName, expandInLegend)</A></STRONG></DT>
+ <DD>
+ Expands or collapses the specified (themed) layer in the legend
+ <P>
+ <STRONG>Parameters:</STRONG><BR>
+ <CODE>layerName</CODE> - The name of the layer to expand or collapse<BR><BR>
+ <CODE>expandInLegend</CODE> - set to <CODE>true</CODE> to expand this layer; set to <CODE>false</CODE> to collapse it
+ </P>
+ <P>
+ <STRONG>Remarks:</STRONG>
+ This only expands/collapses the layer client-side. To persist these changes (ie. Keep the state after refreshing the legend) you must call a server-side script that updates this map state
+ </P>
+ </DD>
+ </DL>
+ <DL>
+ <DT><STRONG><A name="legendpalette_expandgroupinlegend">ExpandGroupInLegend(groupName, expandInLegend)</A></STRONG></DT>
+ <DD>
+ Expands or collapses the specified layer group in the legend
+ <P>
+ <CODE>groupName</CODE> - The name of the layer group to expand or collapse<BR><BR>
+ <CODE>expandInLegend</CODE> - set to <CODE>true</CODE> to expand this group; set to <CODE>false</CODE> to collapse it
+ </P>
+ <P>
+ This only expands/collapses the group client-side. To persist these changes (ie. Keep the state after refreshing the legend) you must call a server-side script that updates this map state
+ </P>
+ </DD>
+ </DL>
<DL>
<DT><STRONG><A name="legendpalette_internalstatecomplete">InternalStateComplete()</A></STRONG></DT>
More information about the mapguide-commits
