[mapguide-commits] r7791 - in trunk/MgDev/Doc/samples: . ol2samples ol2samples/assets ol2samples/assets/theme ol2samples/assets/theme/default ol2samples/assets/theme/default/img ol2samples/commercial ol2samples/querymap ol2samples/selection ol2samples/tiled ol2samples/untiled
svn_mapguide at osgeo.org
Wed Aug 21 05:56:21 PDT 2013
Author: jng
Date: 2013-08-21 05:56:20 -0700 (Wed, 21 Aug 2013)
New Revision: 7791
Added:
trunk/MgDev/Doc/samples/ol2samples/
trunk/MgDev/Doc/samples/ol2samples/assets/
trunk/MgDev/Doc/samples/ol2samples/assets/OpenLayers.js
trunk/MgDev/Doc/samples/ol2samples/assets/jquery-1.10.2.min.js
trunk/MgDev/Doc/samples/ol2samples/assets/theme/
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.css
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.tidy.css
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.css
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.tidy.css
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/add_point_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/add_point_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/blank.gif
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/close.gif
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/drag-rectangle-off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/drag-rectangle-on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_line_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_line_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_point_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_point_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_polygon_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_polygon_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/editing_tool_bar.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/move_feature_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/move_feature_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/navigation_history.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/overview_replacement.gif
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan-panel-NOALPHA.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan-panel.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/panning-hand-off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/panning-hand-on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/remove_point_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/remove_point_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/ruler.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/save_features_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/save_features_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_next_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_next_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_previous_off.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_previous_on.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/zoom-panel-NOALPHA.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/zoom-panel.png
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.css
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.css
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.tidy.css
trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.tidy.css
trunk/MgDev/Doc/samples/ol2samples/commercial/
trunk/MgDev/Doc/samples/ol2samples/querymap/
trunk/MgDev/Doc/samples/ol2samples/selection/
trunk/MgDev/Doc/samples/ol2samples/tiled/
trunk/MgDev/Doc/samples/ol2samples/tiled/index.html
trunk/MgDev/Doc/samples/ol2samples/untiled/
trunk/MgDev/Doc/samples/ol2samples/untiled/index.html
trunk/MgDev/Doc/samples/samples.html
#2343: Add samples landing page
#2344: Add skeleton OpenLayers samples
Property changes on: trunk/MgDev/Doc/samples/ol2samples
___________________________________________________________________
Added: bugtraq:number
+ true
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets
+ true
Added: trunk/MgDev/Doc/samples/ol2samples/assets/OpenLayers.js
--- trunk/MgDev/Doc/samples/ol2samples/assets/OpenLayers.js (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/OpenLayers.js 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,1443 @@
+ OpenLayers.js -- OpenLayers Map Viewer Library
+ Copyright (c) 2006-2013 by OpenLayers Contributors
+ Published under the 2-clause BSD license.
+ See http://openlayers.org/dev/license.txt for the full text of the license, and http://openlayers.org/dev/authors.txt for full list of contributors.
+ Includes compressed code under the following licenses:
+ (For uncompressed versions of the code used, please see the
+ OpenLayers Github repository: <https://github.com/openlayers/openlayers>)
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ * used to endorse or promote products derived from this software without
+ * specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+var OpenLayers={VERSION_NUMBER:"Release 2.13.1",singleFile:!0,_getScriptLocation:function(){for(var a=/(^|(.*?\/))(OpenLayers[^\/]*?\.js)(\?|$)/,b=document.getElementsByTagName("script"),c,d="",e=0,f=b.length;e<f;e++)if(c=b[e].getAttribute("src"))if(c=c.match(a)){d=c[1];break}return function(){return d}}(),ImgPath:""};OpenLayers.Class=function(){var a=arguments.length,b=arguments[0],c=arguments[a-1],d="function"==typeof c.initialize?c.initialize:function(){b.prototype.initialize.apply(this,arguments)};1<a?(a=[d,b].concat(Array.prototype.slice.call(arguments).slice(1,a-1),c),OpenLayers.inherit.apply(null,a)):d.prototype=c;return d};
+OpenLayers.inherit=function(a,b){var c=function(){};c.prototype=b.prototype;a.prototype=new c;var d,e,c=2;for(d=arguments.length;c<d;c++)e=arguments[c],"function"===typeof e&&(e=e.prototype),OpenLayers.Util.extend(a.prototype,e)};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(a,b){a=a||{};if(b){for(var c in b){var d=b[c];void 0!==d&&(a[c]=d)}"function"==typeof window.Event&&b instanceof window.Event||(!b.hasOwnProperty||!b.hasOwnProperty("toString"))||(a.toString=b.toString)}return a};OpenLayers.String={startsWith:function(a,b){return 0==a.indexOf(b)},contains:function(a,b){return-1!=a.indexOf(b)},trim:function(a){return a.replace(/^\s\s*/,"").replace(/\s\s*$/,"")},camelize:function(a){a=a.split("-");for(var b=a[0],c=1,d=a.length;c<d;c++)var e=a[c],b=b+(e.charAt(0).toUpperCase()+e.substring(1));return b},format:function(a,b,c){b||(b=window);return a.replace(OpenLayers.String.tokenRegEx,function(a,e){for(var f,g=e.split(/\.+/),h=0;h<g.length;h++){0==h&&(f
=b);if(void 0===f)break;
+f=f[g[h]]}"function"==typeof f&&(f=c?f.apply(null,c):f());return"undefined"==typeof f?"undefined":f})},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(a){return OpenLayers.String.numberRegEx.test(a)},numericIf:function(a,b){var c=a;!0===b&&(null!=a&&a.replace)&&(a=a.replace(/^\s*|\s*$/g,""));return OpenLayers.String.isNumeric(a)?parseFloat(a):c}};
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(a,b){var c=0;0<b&&(c=parseFloat(a.toPrecision(b)));return c},format:function(a,b,c,d){b="undefined"!=typeof b?b:0;c="undefined"!=typeof c?c:OpenLayers.Number.thousandsSeparator;d="undefined"!=typeof d?d:OpenLayers.Number.decimalSeparator;null!=b&&(a=parseFloat(a.toFixed(b)));var e=a.toString().split(".");1==e.length&&null==b&&(b=0);a=e[0];if(c)for(var f=/(-?[0-9]+)([0-9]{3})/;f.test(a);)a=a.replace(f,"$1"+c+"$2");
+0==b?b=a:(c=1<e.length?e[1]:"0",null!=b&&(c+=Array(b-c.length+1).join("0")),b=a+d+c);return b},zeroPad:function(a,b,c){for(a=a.toString(c||10);a.length<b;)a="0"+a;return a}};
+OpenLayers.Function={bind:function(a,b){var c=Array.prototype.slice.apply(arguments,[2]);return function(){var d=c.concat(Array.prototype.slice.apply(arguments,[0]));return a.apply(b,d)}},bindAsEventListener:function(a,b){return function(c){return a.call(b,c||window.event)}},False:function(){return!1},True:function(){return!0},Void:function(){}};
+OpenLayers.Array={filter:function(a,b,c){var d=[];if(Array.prototype.filter)d=a.filter(b,c);else{var e=a.length;if("function"!=typeof b)throw new TypeError;for(var f=0;f<e;f++)if(f in a){var g=a[f];b.call(c,g,f,a)&&d.push(g)}}return d}};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(a,b,c,d){OpenLayers.Util.isArray(a)&&(d=a[3],c=a[2],b=a[1],a=a[0]);null!=a&&(this.left=OpenLayers.Util.toFloat(a));null!=b&&(this.bottom=OpenLayers.Util.toFloat(b));null!=c&&(this.right=OpenLayers.Util.toFloat(c));null!=d&&(this.top=OpenLayers.Util.toFloat(d))},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top)},equals:function(a){var b=!1;null!=
+a&&(b=this.left==a.left&&this.right==a.right&&this.top==a.top&&this.bottom==a.bottom);return b},toString:function(){return[this.left,this.bottom,this.right,this.top].join()},toArray:function(a){return!0===a?[this.bottom,this.left,this.top,this.right]:[this.left,this.bottom,this.right,this.top]},toBBOX:function(a,b){null==a&&(a=6);var c=Math.pow(10,a),d=Math.round(this.left*c)/c,e=Math.round(this.bottom*c)/c,f=Math.round(this.right*c)/c,c=Math.round(this.top*c)/c;return!0===b?e+","+d+","+c+","+f:d+
+","+e+","+f+","+c},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])])},getWidth:function(){return this.right-this.left},getHeight:function(){return this.top-this.bottom},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight())},
+getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2)},getCenterLonLat:function(){this.centerLonLat||(this.centerLonLat=new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2));return this.centerLonLat},scale:function(a,b){null==b&&(b=this.getCenterLonLat());var c,d;"OpenLayers.LonLat"==b.CLASS_NAME?(c=b.lon,d=b.lat):(c=b.x,d=b.y);return new OpenLayers.Bounds((this.left-c)*a+c,(this.bottom-d)*a+d,(this.right-c)*a+c,(this.top-d)*a+
+d)},add:function(a,b){if(null==a||null==b)throw new TypeError("Bounds.add cannot receive null values");return new OpenLayers.Bounds(this.left+a,this.bottom+b,this.right+a,this.top+b)},extend:function(a){if(a)switch(a.CLASS_NAME){case "OpenLayers.LonLat":this.extendXY(a.lon,a.lat);break;case "OpenLayers.Geometry.Point":this.extendXY(a.x,a.y);break;case "OpenLayers.Bounds":this.centerLonLat=null;if(null==this.left||a.left<this.left)this.left=a.left;if(null==this.bottom||a.bottom<this.bottom)this.bottom=
+a.bottom;if(null==this.right||a.right>this.right)this.right=a.right;if(null==this.top||a.top>this.top)this.top=a.top}},extendXY:function(a,b){this.centerLonLat=null;if(null==this.left||a<this.left)this.left=a;if(null==this.bottom||b<this.bottom)this.bottom=b;if(null==this.right||a>this.right)this.right=a;if(null==this.top||b>this.top)this.top=b},containsLonLat:function(a,b){"boolean"===typeof b&&(b={inclusive:b});b=b||{};var c=this.contains(a.lon,a.lat,b.inclusive),d=b.worldBounds;d&&!c&&(c=d.getWidth(),
+d=Math.round((a.lon-(d.left+d.right)/2)/c),c=this.containsLonLat({lon:a.lon-d*c,lat:a.lat},{inclusive:b.inclusive}));return c},containsPixel:function(a,b){return this.contains(a.x,a.y,b)},contains:function(a,b,c){null==c&&(c=!0);if(null==a||null==b)return!1;a=OpenLayers.Util.toFloat(a);b=OpenLayers.Util.toFloat(b);var d=!1;return d=c?a>=this.left&&a<=this.right&&b>=this.bottom&&b<=this.top:a>this.left&&a<this.right&&b>this.bottom&&b<this.top},intersectsBounds:function(a,b){"boolean"===typeof b&&(b=
+{inclusive:b});b=b||{};if(b.worldBounds){var c=this.wrapDateLine(b.worldBounds);a=a.wrapDateLine(b.worldBounds)}else c=this;null==b.inclusive&&(b.inclusive=!0);var d=!1,e=c.left==a.right||c.right==a.left||c.top==a.bottom||c.bottom==a.top;if(b.inclusive||!e)var d=a.top>=c.bottom&&a.top<=c.top||c.top>a.bottom&&c.top<a.top,e=a.left>=c.left&&a.left<=c.right||c.left>=a.left&&c.left<=a.right,f=a.right>=c.left&&a.right<=c.right||c.right>=a.left&&c.right<=a.right,d=(a.bottom>=c.bottom&&a.bottom<=c.top||c.bottom>=
+a.bottom&&c.bottom<=a.top||d)&&(e||f);if(b.worldBounds&&!d){var g=b.worldBounds,e=g.getWidth(),f=!g.containsBounds(c),g=!g.containsBounds(a);f&&!g?(a=a.add(-e,0),d=c.intersectsBounds(a,{inclusive:b.inclusive})):g&&!f&&(c=c.add(-e,0),d=a.intersectsBounds(c,{inclusive:b.inclusive}))}return d},containsBounds:function(a,b,c){null==b&&(b=!1);null==c&&(c=!0);var d=this.contains(a.left,a.bottom,c),e=this.contains(a.right,a.bottom,c),f=this.contains(a.left,a.top,c);a=this.contains(a.right,a.top,c);return b?
+d||e||f||a:d&&e&&f&&a},determineQuadrant:function(a){var b="",c=this.getCenterLonLat(),b=b+(a.lat<c.lat?"b":"t");return b+=a.lon<c.lon?"l":"r"},transform:function(a,b){this.centerLonLat=null;var c=OpenLayers.Projection.transform({x:this.left,y:this.bottom},a,b),d=OpenLayers.Projection.transform({x:this.right,y:this.bottom},a,b),e=OpenLayers.Projection.transform({x:this.left,y:this.top},a,b),f=OpenLayers.Projection.transform({x:this.right,y:this.top},a,b);this.left=Math.min(c.x,e.x);this.bottom=Math.min(c.y,
+d.y);this.right=Math.max(d.x,f.x);this.top=Math.max(e.y,f.y);return this},wrapDateLine:function(a,b){b=b||{};var c=b.leftTolerance||0,d=b.rightTolerance||0,e=this.clone();if(a){for(var f=a.getWidth();e.left<a.left&&e.right-d<=a.left;)e=e.add(f,0);for(;e.left+c>=a.right&&e.right>a.right;)e=e.add(-f,0);c=e.left+c;c<a.right&&(c>a.left&&e.right-d>a.right)&&(e=e.add(-f,0))}return e},CLASS_NAME:"OpenLayers.Bounds"});
+OpenLayers.Bounds.fromString=function(a,b){var c=a.split(",");return OpenLayers.Bounds.fromArray(c,b)};OpenLayers.Bounds.fromArray=function(a,b){return!0===b?new OpenLayers.Bounds(a[1],a[0],a[3],a[2]):new OpenLayers.Bounds(a[0],a[1],a[2],a[3])};OpenLayers.Bounds.fromSize=function(a){return new OpenLayers.Bounds(0,a.h,a.w,0)};OpenLayers.Bounds.oppositeQuadrant=function(a){var b;b=""+("t"==a.charAt(0)?"b":"t");return b+="l"==a.charAt(1)?"r":"l"};OpenLayers.Element={visible:function(a){return"none"!=OpenLayers.Util.getElement(a).style.display},toggle:function(){for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]),d=OpenLayers.Element.visible(c)?"none":"";c.style.display=d}},remove:function(a){a=OpenLayers.Util.getElement(a);a.parentNode.removeChild(a)},getHeight:function(a){a=OpenLayers.Util.getElement(a);return a.offsetHeight},hasClass:function(a,b){var c=a.className;return!!c&&RegExp("(^|\\s)"+b+"(\\s|$)").test(c)},
+addClass:function(a,b){OpenLayers.Element.hasClass(a,b)||(a.className+=(a.className?" ":"")+b);return a},removeClass:function(a,b){var c=a.className;c&&(a.className=OpenLayers.String.trim(c.replace(RegExp("(^|\\s+)"+b+"(\\s+|$)")," ")));return a},toggleClass:function(a,b){OpenLayers.Element.hasClass(a,b)?OpenLayers.Element.removeClass(a,b):OpenLayers.Element.addClass(a,b);return a},getStyle:function(a,b){a=OpenLayers.Util.getElement(a);var c=null;if(a&&a.style){c=a.style[OpenLayers.String.camelize(b)];
+c||(document.defaultView&&document.defaultView.getComputedStyle?c=(c=document.defaultView.getComputedStyle(a,null))?c.getPropertyValue(b):null:a.currentStyle&&(c=a.currentStyle[OpenLayers.String.camelize(b)]));var d=["left","top","right","bottom"];window.opera&&(-1!=OpenLayers.Util.indexOf(d,b)&&"static"==OpenLayers.Element.getStyle(a,"position"))&&(c="auto")}return"auto"==c?null:c}};OpenLayers.LonLat=OpenLayers.Class({lon:0,lat:0,initialize:function(a,b){OpenLayers.Util.isArray(a)&&(b=a[1],a=a[0]);this.lon=OpenLayers.Util.toFloat(a);this.lat=OpenLayers.Util.toFloat(b)},toString:function(){return"lon="+this.lon+",lat="+this.lat},toShortString:function(){return this.lon+", "+this.lat},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat)},add:function(a,b){if(null==a||null==b)throw new TypeError("LonLat.add cannot receive null values");return new OpenLayers.LonLat(this.lon+
+OpenLayers.Util.toFloat(a),this.lat+OpenLayers.Util.toFloat(b))},equals:function(a){var b=!1;null!=a&&(b=this.lon==a.lon&&this.lat==a.lat||isNaN(this.lon)&&isNaN(this.lat)&&isNaN(a.lon)&&isNaN(a.lat));return b},transform:function(a,b){var c=OpenLayers.Projection.transform({x:this.lon,y:this.lat},a,b);this.lon=c.x;this.lat=c.y;return this},wrapDateLine:function(a){var b=this.clone();if(a){for(;b.lon<a.left;)b.lon+=a.getWidth();for(;b.lon>a.right;)b.lon-=a.getWidth()}return b},CLASS_NAME:"OpenLayers.LonLat"});
+OpenLayers.LonLat.fromString=function(a){a=a.split(",");return new OpenLayers.LonLat(a[0],a[1])};OpenLayers.LonLat.fromArray=function(a){var b=OpenLayers.Util.isArray(a);return new OpenLayers.LonLat(b&&a[0],b&&a[1])};OpenLayers.Pixel=OpenLayers.Class({x:0,y:0,initialize:function(a,b){this.x=parseFloat(a);this.y=parseFloat(b)},toString:function(){return"x="+this.x+",y="+this.y},clone:function(){return new OpenLayers.Pixel(this.x,this.y)},equals:function(a){var b=!1;null!=a&&(b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y));return b},distanceTo:function(a){return Math.sqrt(Math.pow(this.x-a.x,2)+Math.pow(this.y-a.y,2))},add:function(a,b){if(null==a||null==b)throw new TypeError("Pixel.add cannot receive null values");
+return new OpenLayers.Pixel(this.x+a,this.y+b)},offset:function(a){var b=this.clone();a&&(b=this.add(a.x,a.y));return b},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Size=OpenLayers.Class({w:0,h:0,initialize:function(a,b){this.w=parseFloat(a);this.h=parseFloat(b)},toString:function(){return"w="+this.w+",h="+this.h},clone:function(){return new OpenLayers.Size(this.w,this.h)},equals:function(a){var b=!1;null!=a&&(b=this.w==a.w&&this.h==a.h||isNaN(this.w)&&isNaN(this.h)&&isNaN(a.w)&&isNaN(a.h));return b},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(a){alert(a)},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};
+(function(){for(var a=document.getElementsByTagName("script"),b=0,c=a.length;b<c;++b)if(-1!=a[b].src.indexOf("firebug.js")&&console){OpenLayers.Util.extend(OpenLayers.Console,console);break}})();OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){OpenLayers.Lang.code||OpenLayers.Lang.setCode();return OpenLayers.Lang.code},setCode:function(a){var b;a||(a="msie"==OpenLayers.BROWSER_NAME?navigator.userLanguage:navigator.language);a=a.split("-");a[0]=a[0].toLowerCase();"object"==typeof OpenLayers.Lang[a[0]]&&(b=a[0]);if(a[1]){var c=a[0]+"-"+a[1].toUpperCase();"object"==typeof OpenLayers.Lang[c]&&(b=c)}b||(OpenLayers.Console.warn("Failed to find OpenLayers.Lang."+a.join("-")+" dictionary, falling back to default language"),
+b=OpenLayers.Lang.defaultCode);OpenLayers.Lang.code=b},translate:function(a,b){var c=OpenLayers.Lang[OpenLayers.Lang.getCode()];(c=c&&c[a])||(c=a);b&&(c=OpenLayers.String.format(c,b));return c}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.getElement=function(){for(var a=[],b=0,c=arguments.length;b<c;b++){var d=arguments[b];"string"==typeof d&&(d=document.getElementById(d));if(1==arguments.length)return d;a.push(d)}return a};OpenLayers.Util.isElement=function(a){return!(!a||1!==a.nodeType)};OpenLayers.Util.isArray=function(a){return"[object Array]"===Object.prototype.toString.call(a)};OpenLayers.Util.removeItem=function(a,b){for(var c=a.length-1;0<=c;c--)a[c]==b&&a.splice(c,1);return a};
+OpenLayers.Util.indexOf=function(a,b){if("function"==typeof a.indexOf)return a.indexOf(b);for(var c=0,d=a.length;c<d;c++)if(a[c]==b)return c;return-1};OpenLayers.Util.dotless=/\./g;
+OpenLayers.Util.modifyDOMElement=function(a,b,c,d,e,f,g,h){b&&(a.id=b.replace(OpenLayers.Util.dotless,"_"));c&&(a.style.left=c.x+"px",a.style.top=c.y+"px");d&&(a.style.width=d.w+"px",a.style.height=d.h+"px");e&&(a.style.position=e);f&&(a.style.border=f);g&&(a.style.overflow=g);0<=parseFloat(h)&&1>parseFloat(h)?(a.style.filter="alpha(opacity="+100*h+")",a.style.opacity=h):1==parseFloat(h)&&(a.style.filter="",a.style.opacity="")};
+OpenLayers.Util.createDiv=function(a,b,c,d,e,f,g,h){var k=document.createElement("div");d&&(k.style.backgroundImage="url("+d+")");a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="absolute");OpenLayers.Util.modifyDOMElement(k,a,b,c,e,f,g,h);return k};
+OpenLayers.Util.createImage=function(a,b,c,d,e,f,g,h){var k=document.createElement("img");a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="relative");OpenLayers.Util.modifyDOMElement(k,a,b,c,e,f,null,g);h&&(k.style.display="none",b=function(){k.style.display="";OpenLayers.Event.stopObservingElement(k)},OpenLayers.Event.observe(k,"load",b),OpenLayers.Event.observe(k,"error",b));k.style.alt=a;k.galleryImg="no";d&&(k.src=d);return k};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;
+OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(null==OpenLayers.Util.alphaHackNeeded){var a=navigator.appVersion.split("MSIE"),a=parseFloat(a[1]),b=!1;try{b=!!document.body.filters}catch(c){}OpenLayers.Util.alphaHackNeeded=b&&5.5<=a&&7>a}return OpenLayers.Util.alphaHackNeeded};
+OpenLayers.Util.modifyAlphaImageDiv=function(a,b,c,d,e,f,g,h,k){OpenLayers.Util.modifyDOMElement(a,b,c,d,f,null,null,k);b=a.childNodes[0];e&&(b.src=e);OpenLayers.Util.modifyDOMElement(b,a.id+"_innerImage",null,d,"relative",g);OpenLayers.Util.alphaHack()&&("none"!=a.style.display&&(a.style.display="inline-block"),null==h&&(h="scale"),a.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+b.src+"', sizingMethod='"+h+"')",0<=parseFloat(a.style.opacity)&&1>parseFloat(a.style.opacity)&&
+(a.style.filter+=" alpha(opacity="+100*a.style.opacity+")"),b.style.filter="alpha(opacity=0)")};OpenLayers.Util.createAlphaImageDiv=function(a,b,c,d,e,f,g,h,k){var l=OpenLayers.Util.createDiv();k=OpenLayers.Util.createImage(null,null,null,null,null,null,null,k);k.className="olAlphaImg";l.appendChild(k);OpenLayers.Util.modifyAlphaImageDiv(l,a,b,c,d,e,f,g,h);return l};OpenLayers.Util.upperCaseObject=function(a){var b={},c;for(c in a)b[c.toUpperCase()]=a[c];return b};
+OpenLayers.Util.applyDefaults=function(a,b){a=a||{};var c="function"==typeof window.Event&&b instanceof window.Event,d;for(d in b)if(void 0===a[d]||!c&&b.hasOwnProperty&&b.hasOwnProperty(d)&&!a.hasOwnProperty(d))a[d]=b[d];!c&&(b&&b.hasOwnProperty&&b.hasOwnProperty("toString")&&!a.hasOwnProperty("toString"))&&(a.toString=b.toString);return a};
+OpenLayers.Util.getParameterString=function(a){var b=[],c;for(c in a){var d=a[c];if(null!=d&&"function"!=typeof d){if("object"==typeof d&&d.constructor==Array){for(var e=[],f,g=0,h=d.length;g<h;g++)f=d[g],e.push(encodeURIComponent(null===f||void 0===f?"":f));d=e.join(",")}else d=encodeURIComponent(d);b.push(encodeURIComponent(c)+"="+d)}}return b.join("&")};OpenLayers.Util.urlAppend=function(a,b){var c=a;if(b)var d=(a+" ").split(/[?&]/),c=c+(" "===d.pop()?b:d.length?"&"+b:"?"+b);return c};
+OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||OpenLayers._getScriptLocation()+"img/"};OpenLayers.Util.getImageLocation=function(a){return OpenLayers.Util.getImagesLocation()+a};OpenLayers.Util.Try=function(){for(var a=null,b=0,c=arguments.length;b<c;b++){var d=arguments[b];try{a=d();break}catch(e){}}return a};
+OpenLayers.Util.getXmlNodeValue=function(a){var b=null;OpenLayers.Util.Try(function(){b=a.text;b||(b=a.textContent);b||(b=a.firstChild.nodeValue)},function(){b=a.textContent});return b};OpenLayers.Util.mouseLeft=function(a,b){for(var c=a.relatedTarget?a.relatedTarget:a.toElement;c!=b&&null!=c;)c=c.parentNode;return c!=b};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(a,b){null==b&&(b=OpenLayers.Util.DEFAULT_PRECISION);"number"!==typeof a&&(a=parseFloat(a));return 0===b?a:parseFloat(a.toPrecision(b))};
+OpenLayers.Util.rad=function(a){return a*Math.PI/180};OpenLayers.Util.deg=function(a){return 180*a/Math.PI};OpenLayers.Util.VincentyConstants={a:6378137,b:6356752.3142,f:1/298.257223563};
+OpenLayers.Util.distVincenty=function(a,b){for(var c=OpenLayers.Util.VincentyConstants,d=c.a,e=c.b,c=c.f,f=OpenLayers.Util.rad(b.lon-a.lon),g=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(a.lat))),h=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(b.lat))),k=Math.sin(g),g=Math.cos(g),l=Math.sin(h),h=Math.cos(h),m=f,n=2*Math.PI,p=20;1E-12<Math.abs(m-n)&&0<--p;){var q=Math.sin(m),r=Math.cos(m),s=Math.sqrt(h*q*h*q+(g*l-k*h*r)*(g*l-k*h*r));if(0==s)return 0;var r=k*l+g*h*r,t=Math.atan2(s,r),u=Math.asin(g*h*
+q/s),v=Math.cos(u)*Math.cos(u),q=r-2*k*l/v,w=c/16*v*(4+c*(4-3*v)),n=m,m=f+(1-w)*c*Math.sin(u)*(t+w*s*(q+w*r*(-1+2*q*q)))}if(0==p)return NaN;d=v*(d*d-e*e)/(e*e);c=d/1024*(256+d*(-128+d*(74-47*d)));return(e*(1+d/16384*(4096+d*(-768+d*(320-175*d))))*(t-c*s*(q+c/4*(r*(-1+2*q*q)-c/6*q*(-3+4*s*s)*(-3+4*q*q))))).toFixed(3)/1E3};
+OpenLayers.Util.destinationVincenty=function(a,b,c){var d=OpenLayers.Util,e=d.VincentyConstants,f=e.a,g=e.b,h=e.f,e=a.lon;a=a.lat;var k=d.rad(b);b=Math.sin(k);k=Math.cos(k);a=(1-h)*Math.tan(d.rad(a));var l=1/Math.sqrt(1+a*a),m=a*l,n=Math.atan2(a,k);a=l*b;for(var p=1-a*a,f=p*(f*f-g*g)/(g*g),q=1+f/16384*(4096+f*(-768+f*(320-175*f))),r=f/1024*(256+f*(-128+f*(74-47*f))),f=c/(g*q),s=2*Math.PI;1E-12<Math.abs(f-s);)var t=Math.cos(2*n+f),u=Math.sin(f),v=Math.cos(f),w=r*u*(t+r/4*(v*(-1+2*t*t)-r/6*t*(-3+4*
+u*u)*(-3+4*t*t))),s=f,f=c/(g*q)+w;c=m*u-l*v*k;g=Math.atan2(m*v+l*u*k,(1-h)*Math.sqrt(a*a+c*c));b=Math.atan2(u*b,l*v-m*u*k);k=h/16*p*(4+h*(4-3*p));t=b-(1-k)*h*a*(f+k*u*(t+k*v*(-1+2*t*t)));Math.atan2(a,-c);return new OpenLayers.LonLat(e+d.deg(t),d.deg(g))};
+OpenLayers.Util.getParameters=function(a,b){b=b||{};a=null===a||void 0===a?window.location.href:a;var c="";if(OpenLayers.String.contains(a,"?"))var d=a.indexOf("?")+1,c=OpenLayers.String.contains(a,"#")?a.indexOf("#"):a.length,c=a.substring(d,c);for(var d={},c=c.split(/[&;]/),e=0,f=c.length;e<f;++e){var g=c[e].split("=");if(g[0]){var h=g[0];try{h=decodeURIComponent(h)}catch(k){h=unescape(h)}g=(g[1]||"").replace(/\+/g," ");try{g=decodeURIComponent(g)}catch(l){g=unescape(g)}!1!==b.splitArgs&&(g=g.split(","));
+1==g.length&&(g=g[0]);d[h]=g}}return d};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(a){a=null==a?"id_":a.replace(OpenLayers.Util.dotless,"_");OpenLayers.Util.lastSeqID+=1;return a+OpenLayers.Util.lastSeqID};OpenLayers.INCHES_PER_UNIT={inches:1,ft:12,mi:63360,m:39.37,km:39370,dd:4374754,yd:36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT.degrees=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT.nmi=1852*OpenLayers.INCHES_PER_UNIT.m;
+OpenLayers.METERS_PER_INCH=0.0254000508001016;
+OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{Inch:OpenLayers.INCHES_PER_UNIT.inches,Meter:1/OpenLayers.METERS_PER_INCH,Foot:0.3048006096012192/OpenLayers.METERS_PER_INCH,IFoot:0.3048/OpenLayers.METERS_PER_INCH,ClarkeFoot:0.3047972651151/OpenLayers.METERS_PER_INCH,SearsFoot:0.30479947153867626/OpenLayers.METERS_PER_INCH,GoldCoastFoot:0.3047997101815088/OpenLayers.METERS_PER_INCH,IInch:0.0254/OpenLayers.METERS_PER_INCH,MicroInch:2.54E-5/OpenLayers.METERS_PER_INCH,Mil:2.54E-8/OpenLayers.METERS_PER_INCH,
+Centimeter:0.01/OpenLayers.METERS_PER_INCH,Kilometer:1E3/OpenLayers.METERS_PER_INCH,Yard:0.9144018288036576/OpenLayers.METERS_PER_INCH,SearsYard:0.914398414616029/OpenLayers.METERS_PER_INCH,IndianYard:0.9143985307444408/OpenLayers.METERS_PER_INCH,IndianYd37:0.91439523/OpenLayers.METERS_PER_INCH,IndianYd62:0.9143988/OpenLayers.METERS_PER_INCH,IndianYd75:0.9143985/OpenLayers.METERS_PER_INCH,IndianFoot:0.30479951/OpenLayers.METERS_PER_INCH,IndianFt37:0.30479841/OpenLayers.METERS_PER_INCH,IndianFt62:0.3047996/
+OpenLayers.METERS_PER_INCH,IndianFt75:0.3047995/OpenLayers.METERS_PER_INCH,Mile:1609.3472186944373/OpenLayers.METERS_PER_INCH,IYard:0.9144/OpenLayers.METERS_PER_INCH,IMile:1609.344/OpenLayers.METERS_PER_INCH,NautM:1852/OpenLayers.METERS_PER_INCH,"Lat-66":110943.31648893273/OpenLayers.METERS_PER_INCH,"Lat-83":110946.25736872235/OpenLayers.METERS_PER_INCH,Decimeter:0.1/OpenLayers.METERS_PER_INCH,Millimeter:0.001/OpenLayers.METERS_PER_INCH,Dekameter:10/OpenLayers.METERS_PER_INCH,Decameter:10/OpenLayers.METERS_PER_INCH,
+Hectometer:100/OpenLayers.METERS_PER_INCH,GermanMeter:1.0000135965/OpenLayers.METERS_PER_INCH,CaGrid:0.999738/OpenLayers.METERS_PER_INCH,ClarkeChain:20.1166194976/OpenLayers.METERS_PER_INCH,GunterChain:20.11684023368047/OpenLayers.METERS_PER_INCH,BenoitChain:20.116782494375872/OpenLayers.METERS_PER_INCH,SearsChain:20.11676512155/OpenLayers.METERS_PER_INCH,ClarkeLink:0.201166194976/OpenLayers.METERS_PER_INCH,GunterLink:0.2011684023368047/OpenLayers.METERS_PER_INCH,BenoitLink:0.20116782494375873/OpenLayers.METERS_PER_INCH,
+SearsLink:0.2011676512155/OpenLayers.METERS_PER_INCH,Rod:5.02921005842012/OpenLayers.METERS_PER_INCH,IntnlChain:20.1168/OpenLayers.METERS_PER_INCH,IntnlLink:0.201168/OpenLayers.METERS_PER_INCH,Perch:5.02921005842012/OpenLayers.METERS_PER_INCH,Pole:5.02921005842012/OpenLayers.METERS_PER_INCH,Furlong:201.1684023368046/OpenLayers.METERS_PER_INCH,Rood:3.778266898/OpenLayers.METERS_PER_INCH,CapeFoot:0.3047972615/OpenLayers.METERS_PER_INCH,Brealey:375/OpenLayers.METERS_PER_INCH,ModAmFt:0.304812252984506/
+OpenLayers.METERS_PER_INCH,Fathom:1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":5E4/OpenLayers.METERS_PER_INCH,"150kilometers":15E4/OpenLayers.METERS_PER_INCH});
+OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{mm:OpenLayers.INCHES_PER_UNIT.Meter/1E3,cm:OpenLayers.INCHES_PER_UNIT.Meter/100,dm:100*OpenLayers.INCHES_PER_UNIT.Meter,km:1E3*OpenLayers.INCHES_PER_UNIT.Meter,kmi:OpenLayers.INCHES_PER_UNIT.nmi,fath:OpenLayers.INCHES_PER_UNIT.Fathom,ch:OpenLayers.INCHES_PER_UNIT.IntnlChain,link:OpenLayers.INCHES_PER_UNIT.IntnlLink,"us-in":OpenLayers.INCHES_PER_UNIT.inches,"us-ft":OpenLayers.INCHES_PER_UNIT.Foot,"us-yd":OpenLayers.INCHES_PER_UNIT.Yard,"us-ch":OpenLayers.INCHES_PER_UNIT.GunterChain,
+"us-mi":OpenLayers.INCHES_PER_UNIT.Mile,"ind-yd":OpenLayers.INCHES_PER_UNIT.IndianYd37,"ind-ft":OpenLayers.INCHES_PER_UNIT.IndianFt37,"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(a){return 1<a?1/a:a};OpenLayers.Util.getResolutionFromScale=function(a,b){var c;a&&(null==b&&(b="degrees"),c=1/(OpenLayers.Util.normalizeScale(a)*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH));return c};
+OpenLayers.Util.getScaleFromResolution=function(a,b){null==b&&(b="degrees");return a*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH};
+OpenLayers.Util.pagePosition=function(a){var b=[0,0],c=OpenLayers.Util.getViewportElement();if(!a||a==window||a==c)return b;var d=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&"absolute"==OpenLayers.Element.getStyle(a,"position")&&(""==a.style.top||""==a.style.left),e=null;if(a.getBoundingClientRect)a=a.getBoundingClientRect(),e=window.pageYOffset||c.scrollTop,b[0]=a.left+(window.pageXOffset||c.scrollLeft),b[1]=a.top+e;else if(document.getBoxObjectFor&&!d)a=document.getBoxObjectFor(a),c=document.getBoxObjectFor(c),
+b[0]=a.screenX-c.screenX,b[1]=a.screenY-c.screenY;else{b[0]=a.offsetLeft;b[1]=a.offsetTop;e=a.offsetParent;if(e!=a)for(;e;)b[0]+=e.offsetLeft,b[1]+=e.offsetTop,e=e.offsetParent;c=OpenLayers.BROWSER_NAME;if("opera"==c||"safari"==c&&"absolute"==OpenLayers.Element.getStyle(a,"position"))b[1]-=document.body.offsetTop;for(e=a.offsetParent;e&&e!=document.body;){b[0]-=e.scrollLeft;if("opera"!=c||"TR"!=e.tagName)b[1]-=e.scrollTop;e=e.offsetParent}}return b};
+OpenLayers.Util.getViewportElement=function(){var a=arguments.callee.viewportElement;void 0==a&&(a="msie"==OpenLayers.BROWSER_NAME&&"CSS1Compat"!=document.compatMode?document.body:document.documentElement,arguments.callee.viewportElement=a);return a};
+OpenLayers.Util.isEquivalentUrl=function(a,b,c){c=c||{};OpenLayers.Util.applyDefaults(c,{ignoreCase:!0,ignorePort80:!0,ignoreHash:!0,splitArgs:!1});a=OpenLayers.Util.createUrlObject(a,c);b=OpenLayers.Util.createUrlObject(b,c);for(var d in a)if("args"!==d&&a[d]!=b[d])return!1;for(d in a.args){if(a.args[d]!=b.args[d])return!1;delete b.args[d]}for(d in b.args)return!1;return!0};
+OpenLayers.Util.createUrlObject=function(a,b){b=b||{};if(!/^\w+:\/\//.test(a)){var c=window.location,d=c.port?":"+c.port:"",d=c.protocol+"//"+c.host.split(":").shift()+d;0===a.indexOf("/")?a=d+a:(c=c.pathname.split("/"),c.pop(),a=d+c.join("/")+"/"+a)}b.ignoreCase&&(a=a.toLowerCase());c=document.createElement("a");c.href=a;d={};d.host=c.host.split(":").shift();d.protocol=c.protocol;d.port=b.ignorePort80?"80"==c.port||"0"==c.port?"":c.port:""==c.port||"0"==c.port?"80":c.port;d.hash=b.ignoreHash||"#"===
+c.hash?"":c.hash;var e=c.search;e||(e=a.indexOf("?"),e=-1!=e?a.substr(e):"");d.args=OpenLayers.Util.getParameters(e,{splitArgs:b.splitArgs});d.pathname="/"==c.pathname.charAt(0)?c.pathname:"/"+c.pathname;return d};OpenLayers.Util.removeTail=function(a){var b=null,b=a.indexOf("?"),c=a.indexOf("#");return b=-1==b?-1!=c?a.substr(0,c):a:-1!=c?a.substr(0,Math.min(b,c)):a.substr(0,b)};OpenLayers.IS_GECKO=function(){var a=navigator.userAgent.toLowerCase();return-1==a.indexOf("webkit")&&-1!=a.indexOf("gecko")}();
+OpenLayers.CANVAS_SUPPORTED=function(){var a=document.createElement("canvas");return!(!a.getContext||!a.getContext("2d"))}();OpenLayers.BROWSER_NAME=function(){var a="",b=navigator.userAgent.toLowerCase();-1!=b.indexOf("opera")?a="opera":-1!=b.indexOf("msie")?a="msie":-1!=b.indexOf("safari")?a="safari":-1!=b.indexOf("mozilla")&&(a=-1!=b.indexOf("firefox")?"firefox":"mozilla");return a}();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME};
+OpenLayers.Util.getRenderedDimensions=function(a,b,c){var d,e,f=document.createElement("div");f.style.visibility="hidden";for(var g=c&&c.containerElement?c.containerElement:document.body,h=!1,k=null,l=g;l&&"body"!=l.tagName.toLowerCase();){var m=OpenLayers.Element.getStyle(l,"position");if("absolute"==m){h=!0;break}else if(m&&"static"!=m)break;l=l.parentNode}!h||0!==g.clientHeight&&0!==g.clientWidth||(k=document.createElement("div"),k.style.visibility="hidden",k.style.position="absolute",k.style.overflow=
+"visible",k.style.width=document.body.clientWidth+"px",k.style.height=document.body.clientHeight+"px",k.appendChild(f));f.style.position="absolute";b&&(b.w?(d=b.w,f.style.width=d+"px"):b.h&&(e=b.h,f.style.height=e+"px"));c&&c.displayClass&&(f.className=c.displayClass);b=document.createElement("div");b.innerHTML=a;b.style.overflow="visible";if(b.childNodes)for(a=0,c=b.childNodes.length;a<c;a++)b.childNodes[a].style&&(b.childNodes[a].style.overflow="visible");f.appendChild(b);k?g.appendChild(k):g.appendChild(f);
+d||(d=parseInt(b.scrollWidth),f.style.width=d+"px");e||(e=parseInt(b.scrollHeight));f.removeChild(b);k?(k.removeChild(f),g.removeChild(k)):g.removeChild(f);return new OpenLayers.Size(d,e)};
+OpenLayers.Util.getScrollbarWidth=function(){var a=OpenLayers.Util._scrollbarWidth;if(null==a){var b=null,c=null,b=a=0,b=document.createElement("div");b.style.position="absolute";b.style.top="-1000px";b.style.left="-1000px";b.style.width="100px";b.style.height="50px";b.style.overflow="hidden";c=document.createElement("div");c.style.width="100%";c.style.height="200px";b.appendChild(c);document.body.appendChild(b);a=c.offsetWidth;b.style.overflow="scroll";b=c.offsetWidth;document.body.removeChild(document.body.lastChild);
+OpenLayers.Util._scrollbarWidth=a-b;a=OpenLayers.Util._scrollbarWidth}return a};
+OpenLayers.Util.getFormattedLonLat=function(a,b,c){c||(c="dms");a=(a+540)%360-180;var d=Math.abs(a),e=Math.floor(d),f=d=(d-e)/(1/60),d=Math.floor(d),f=Math.round(10*((f-d)/(1/60))),f=f/10;60<=f&&(f-=60,d+=1,60<=d&&(d-=60,e+=1));10>e&&(e="0"+e);e+="\u00b0";0<=c.indexOf("dm")&&(10>d&&(d="0"+d),e+=d+"'",0<=c.indexOf("dms")&&(10>f&&(f="0"+f),e+=f+'"'));return e="lon"==b?e+(0>a?OpenLayers.i18n("W"):OpenLayers.i18n("E")):e+(0>a?OpenLayers.i18n("S"):OpenLayers.i18n("N"))};OpenLayers.Format=OpenLayers.Class({options:null,externalProjection:null,internalProjection:null,data:null,keepData:!1,initialize:function(a){OpenLayers.Util.extend(this,a);this.options=a},destroy:function(){},read:function(a){throw Error("Read not implemented.");},write:function(a){throw Error("Write not implemented.");},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Format.CSWGetRecords=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetRecords.DEFAULTS);var b=OpenLayers.Format.CSWGetRecords["v"+
a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetRecords version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetRecords.DEFAULTS={version:"2.0.2"};OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:!1,displayClass:"",title:"",autoActivate:!1,active:null,handlerOptions:null,handler:null,eventListeners:null,events:null,initialize:function(a){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);null==this.id&&(this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+
+"_"))},destroy:function(){this.events&&(this.eventListeners&&this.events.un(this.eventListeners),this.events.destroy(),this.events=null);this.eventListeners=null;this.handler&&(this.handler.destroy(),this.handler=null);if(this.handlers){for(var a in this.handlers)this.handlers.hasOwnProperty(a)&&"function"==typeof this.handlers[a].destroy&&this.handlers[a].destroy();this.handlers=null}this.map&&(this.map.removeControl(this),this.map=null);this.div=null},setMap:function(a){this.map=a;this.handler&&
+this.handler.setMap(a)},draw:function(a){null==this.div&&(this.div=OpenLayers.Util.createDiv(this.id),this.div.className=this.displayClass,this.allowSelection||(this.div.className+=" olControlNoSelect",this.div.setAttribute("unselectable","on",0),this.div.onselectstart=OpenLayers.Function.False),""!=this.title&&(this.div.title=this.title));null!=a&&(this.position=a.clone());this.moveTo(this.position);return this.div},moveTo:function(a){null!=a&&null!=this.div&&(this.div.style.left=a.x+"px",this.div.style.top=
+a.y+"px")},activate:function(){if(this.active)return!1;this.handler&&this.handler.activate();this.active=!0;this.map&&OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");this.events.triggerEvent("activate");return!0},deactivate:function(){return this.active?(this.handler&&this.handler.deactivate(),this.active=!1,this.map&&OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active"),this.events.triggerEvent("deactivate"),
+!0):!1},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Event={observers:!1,KEY_SPACE:32,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(a){return a.target||a.srcElement},isSingleTouch:function(a){return a.touches&&1==a.touches.length},isMultiTouch:function(a){return a.touches&&1<a.touches.length},isLeftClick:function(a){return a.which&&1==a.which||a.button&&1==a.button},isRightClick:function(a){return a.which&&3==a.which||a.button&&2==a.button},stop:function(a,
+b){b||OpenLayers.Event.preventDefault(a);a.stopPropagation?a.stopPropagation():a.cancelBubble=!0},preventDefault:function(a){a.preventDefault?a.preventDefault():a.returnValue=!1},findElement:function(a,b){for(var c=OpenLayers.Event.element(a);c.parentNode&&(!c.tagName||c.tagName.toUpperCase()!=b.toUpperCase());)c=c.parentNode;return c},observe:function(a,b,c,d){a=OpenLayers.Util.getElement(a);d=d||!1;"keypress"==b&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.attachEvent)&&(b="keydown");
+this.observers||(this.observers={});if(!a._eventCacheID){var e="eventCacheID_";a.id&&(e=a.id+"_"+e);a._eventCacheID=OpenLayers.Util.createUniqueID(e)}e=a._eventCacheID;this.observers[e]||(this.observers[e]=[]);this.observers[e].push({element:a,name:b,observer:c,useCapture:d});a.addEventListener?a.addEventListener(b,c,d):a.attachEvent&&a.attachEvent("on"+b,c)},stopObservingElement:function(a){a=OpenLayers.Util.getElement(a)._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[a])},
+_removeElementObservers:function(a){if(a)for(var b=a.length-1;0<=b;b--){var c=a[b];OpenLayers.Event.stopObserving.apply(this,[c.element,c.name,c.observer,c.useCapture])}},stopObserving:function(a,b,c,d){d=d||!1;a=OpenLayers.Util.getElement(a);var e=a._eventCacheID;"keypress"==b&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.detachEvent)&&(b="keydown");var f=!1,g=OpenLayers.Event.observers[e];if(g)for(var h=0;!f&&h<g.length;){var k=g[h];if(k.name==b&&k.observer==c&&k.useCapture==d){g.splice(h,
+1);0==g.length&&delete OpenLayers.Event.observers[e];f=!0;break}h++}f&&(a.removeEventListener?a.removeEventListener(b,c,d):a&&a.detachEvent&&a.detachEvent("on"+b,c));return f},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var a in OpenLayers.Event.observers)OpenLayers.Event._removeElementObservers.apply(this,[OpenLayers.Event.observers[a]]);OpenLayers.Event.observers=!1}},CLASS_NAME:"OpenLayers.Event"};
+OpenLayers.Event.observe(window,"unload",OpenLayers.Event.unloadCache,!1);
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:"mouseover mouseout mousedown mouseup mousemove click dblclick rightclick dblrightclick resize focus blur touchstart touchmove touchend keydown".split(" "),listeners:null,object:null,element:null,eventHandler:null,fallThrough:null,includeXY:!1,extensions:null,extensionCount:null,clearMouseListener:null,initialize:function(a,b,c,d,e){OpenLayers.Util.extend(this,e);this.object=a;this.fallThrough=d;this.listeners={};this.extensions={};this.extensionCount=
+{};this._msTouches=[];null!=b&&this.attachToElement(b)},destroy:function(){for(var a in this.extensions)"boolean"!==typeof this.extensions[a]&&this.extensions[a].destroy();this.extensions=null;this.element&&(OpenLayers.Event.stopObservingElement(this.element),this.element.hasScrollEvent&&OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener));this.eventHandler=this.fallThrough=this.object=this.listeners=this.element=null},addEventType:function(a){},attachToElement:function(a){this.element?
+OpenLayers.Event.stopObservingElement(this.element):(this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this),this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this));this.element=a;for(var b=!!window.navigator.msMaxTouchPoints,c,d=0,e=this.BROWSER_EVENTS.length;d<e;d++)c=this.BROWSER_EVENTS[d],OpenLayers.Event.observe(a,c,this.eventHandler),b&&0===c.indexOf("touch")&&this.addMsTouchListener(a,c,this.eventHandler);OpenLayers.Event.observe(a,"dragstart",
+OpenLayers.Event.stop)},on:function(a){for(var b in a)"scope"!=b&&a.hasOwnProperty(b)&&this.register(b,a.scope,a[b])},register:function(a,b,c,d){a in OpenLayers.Events&&!this.extensions[a]&&(this.extensions[a]=new OpenLayers.Events[a](this));if(null!=c){null==b&&(b=this.object);var e=this.listeners[a];e||(e=[],this.listeners[a]=e,this.extensionCount[a]=0);b={obj:b,func:c};d?(e.splice(this.extensionCount[a],0,b),"object"===typeof d&&d.extension&&this.extensionCount[a]++):e.push(b)}},registerPriority:function(a,
+b,c){this.register(a,b,c,!0)},un:function(a){for(var b in a)"scope"!=b&&a.hasOwnProperty(b)&&this.unregister(b,a.scope,a[b])},unregister:function(a,b,c){null==b&&(b=this.object);a=this.listeners[a];if(null!=a)for(var d=0,e=a.length;d<e;d++)if(a[d].obj==b&&a[d].func==c){a.splice(d,1);break}},remove:function(a){null!=this.listeners[a]&&(this.listeners[a]=[])},triggerEvent:function(a,b){var c=this.listeners[a];if(c&&0!=c.length){null==b&&(b={});b.object=this.object;b.element=this.element;b.type||(b.type=
+a);for(var c=c.slice(),d,e=0,f=c.length;e<f&&(d=c[e],d=d.func.apply(d.obj,[b]),void 0==d||!1!=d);e++);this.fallThrough||OpenLayers.Event.stop(b,!0);return d}},handleBrowserEvent:function(a){var b=a.type,c=this.listeners[b];if(c&&0!=c.length){if((c=a.touches)&&c[0]){for(var d=0,e=0,f=c.length,g,h=0;h<f;++h)g=this.getTouchClientXY(c[h]),d+=g.clientX,e+=g.clientY;a.clientX=d/f;a.clientY=e/f}this.includeXY&&(a.xy=this.getMousePosition(a));this.triggerEvent(b,a)}},getTouchClientXY:function(a){var b=window.olMockWin||
+window,c=b.pageXOffset,b=b.pageYOffset,d=a.clientX,e=a.clientY;if(0===a.pageY&&Math.floor(e)>Math.floor(a.pageY)||0===a.pageX&&Math.floor(d)>Math.floor(a.pageX))d-=c,e-=b;else if(e<a.pageY-b||d<a.pageX-c)d=a.pageX-c,e=a.pageY-b;a.olClientX=d;a.olClientY=e;return{clientX:d,clientY:e}},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;this.element.offsets=null},getMousePosition:function(a){this.includeXY?this.element.hasScrollEvent||(OpenLayers.Event.observe(window,"scroll",
+this.clearMouseListener),this.element.hasScrollEvent=!0):this.clearMouseCache();if(!this.element.scrolls){var b=OpenLayers.Util.getViewportElement();this.element.scrolls=[window.pageXOffset||b.scrollLeft,window.pageYOffset||b.scrollTop]}this.element.lefttop||(this.element.lefttop=[document.documentElement.clientLeft||0,document.documentElement.clientTop||0]);this.element.offsets||(this.element.offsets=OpenLayers.Util.pagePosition(this.element));return new OpenLayers.Pixel(a.clientX+this.element.scrolls[0]-
+this.element.offsets[0]-this.element.lefttop[0],a.clientY+this.element.scrolls[1]-this.element.offsets[1]-this.element.lefttop[1])},addMsTouchListener:function(a,b,c){function d(a){c(OpenLayers.Util.applyDefaults({stopPropagation:function(){for(var a=e.length-1;0<=a;--a)e[a].stopPropagation()},preventDefault:function(){for(var a=e.length-1;0<=a;--a)e[a].preventDefault()},type:b},a))}var e=this._msTouches;switch(b){case "touchstart":return this.addMsTouchListenerStart(a,b,d);case "touchend":return this.addMsTouchListenerEnd(a,
+b,d);case "touchmove":return this.addMsTouchListenerMove(a,b,d);default:throw"Unknown touch event type";}},addMsTouchListenerStart:function(a,b,c){var d=this._msTouches;OpenLayers.Event.observe(a,"MSPointerDown",function(a){for(var b=!1,g=0,h=d.length;g<h;++g)if(d[g].pointerId==a.pointerId){b=!0;break}b||d.push(a);a.touches=d.slice();c(a)});OpenLayers.Event.observe(a,"MSPointerUp",function(a){for(var b=0,c=d.length;b<c;++b)if(d[b].pointerId==a.pointerId){d.splice(b,1);break}})},addMsTouchListenerMove:function(a,
+b,c){var d=this._msTouches;OpenLayers.Event.observe(a,"MSPointerMove",function(a){if(a.pointerType!=a.MSPOINTER_TYPE_MOUSE||0!=a.buttons)if(1!=d.length||d[0].pageX!=a.pageX||d[0].pageY!=a.pageY){for(var b=0,g=d.length;b<g;++b)if(d[b].pointerId==a.pointerId){d[b]=a;break}a.touches=d.slice();c(a)}})},addMsTouchListenerEnd:function(a,b,c){var d=this._msTouches;OpenLayers.Event.observe(a,"MSPointerUp",function(a){for(var b=0,g=d.length;b<g;++b)if(d[b].pointerId==a.pointerId){d.splice(b,1);break}a.touches=
+d.slice();c(a)})},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Events.buttonclick=OpenLayers.Class({target:null,events:"mousedown mouseup click dblclick touchstart touchmove touchend keydown".split(" "),startRegEx:/^mousedown|touchstart$/,cancelRegEx:/^touchmove$/,completeRegEx:/^mouseup|touchend$/,initialize:function(a){this.target=a;for(a=this.events.length-1;0<=a;--a)this.target.register(this.events[a],this,this.buttonClick,{extension:!0})},destroy:function(){for(var a=this.events.length-1;0<=a;--a)this.target.unregister(this.events[a],this,this.buttonClick);
+delete this.target},getPressedButton:function(a){var b=3,c;do{if(OpenLayers.Element.hasClass(a,"olButton")){c=a;break}a=a.parentNode}while(0<--b&&a);return c},ignore:function(a){var b=3,c=!1;do{if("a"===a.nodeName.toLowerCase()){c=!0;break}a=a.parentNode}while(0<--b&&a);return c},buttonClick:function(a){var b=!0,c=OpenLayers.Event.element(a);if(c&&(OpenLayers.Event.isLeftClick(a)||!~a.type.indexOf("mouse")))if(c=this.getPressedButton(c)){if("keydown"===a.type)switch(a.keyCode){case OpenLayers.Event.KEY_RETURN:case OpenLayers.Event.KEY_SPACE:this.target.triggerEvent("buttonclick",
+{buttonElement:c}),OpenLayers.Event.stop(a),b=!1}else if(this.startEvt){if(this.completeRegEx.test(a.type)){var b=OpenLayers.Util.pagePosition(c),d=OpenLayers.Util.getViewportElement(),e=window.pageYOffset||d.scrollTop;b[0]-=window.pageXOffset||d.scrollLeft;b[1]-=e;this.target.triggerEvent("buttonclick",{buttonElement:c,buttonXY:{x:this.startEvt.clientX-b[0],y:this.startEvt.clientY-b[1]}})}this.cancelRegEx.test(a.type)&&delete this.startEvt;OpenLayers.Event.stop(a);b=!1}this.startRegEx.test(a.type)&&
+(this.startEvt=a,OpenLayers.Event.stop(a),b=!1)}else b=!this.ignore(OpenLayers.Event.element(a)),delete this.startEvt;return b}});OpenLayers.Util=OpenLayers.Util||{};
+OpenLayers.Util.vendorPrefix=function(){function a(a){return a?a.replace(/([A-Z])/g,function(a){return"-"+a.toLowerCase()}).replace(/^ms-/,"-ms-"):null}function b(a,b){if(void 0===g[b]){var c,e=0,f=d.length,p="undefined"!==typeof a.cssText;for(g[b]=null;e<f;e++)if((c=d[e])?(p||(c=c.toLowerCase()),c=c+b.charAt(0).toUpperCase()+b.slice(1)):c=b,void 0!==a[c]){g[b]=c;break}}return g[b]}function c(a){return b(e,a)}var d=["","O","ms","Moz","Webkit"],e=document.createElement("div").style,f={},g={};return{css:function(b){if(void 0===
+f[b]){var d=b.replace(/(-[\s\S])/g,function(a){return a.charAt(1).toUpperCase()}),d=c(d);f[b]=a(d)}return f[b]},js:b,style:c,cssCache:f,jsCache:g}}();OpenLayers.Animation=function(a){var b=OpenLayers.Util.vendorPrefix.js(a,"requestAnimationFrame"),c=!!b,d=function(){var c=a[b]||function(b,c){a.setTimeout(b,16)};return function(b,d){c.apply(a,[b,d])}}(),e=0,f={};return{isNative:c,requestFrame:d,start:function(a,b,c){b=0<b?b:Number.POSITIVE_INFINITY;var l=++e,m=+new Date;f[l]=function(){f[l]&&+new Date-m<=b?(a(),f[l]&&d(f[l],c)):delete f[l]};d(f[l],c);return l},stop:function(a){delete f[a]}}}(window);OpenLayers.Tween=OpenLayers.Class({easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,minFrameRate:null,startTime:null,animationId:null,playing:!1,initialize:function(a){this.easing=a?a:OpenLayers.Easing.Expo.easeOut},start:function(a,b,c,d){this.playing=!0;this.begin=a;this.finish=b;this.duration=c;this.callbacks=d.callbacks;this.minFrameRate=d.minFrameRate
||30;this.time=0;this.startTime=(new Date).getTime();OpenLayers.Animation.stop(this.animationId);this.animationId=null;
+this.callbacks&&this.callbacks.start&&this.callbacks.start.call(this,this.begin);this.animationId=OpenLayers.Animation.start(OpenLayers.Function.bind(this.play,this))},stop:function(){this.playing&&(this.callbacks&&this.callbacks.done&&this.callbacks.done.call(this,this.finish),OpenLayers.Animation.stop(this.animationId),this.animationId=null,this.playing=!1)},play:function(){var a={},b;for(b in this.begin){var c=this.begin[b],d=this.finish[b];if(null==c||null==d||isNaN(c)||isNaN(d))throw new TypeError("invalid value for Tween");
+a[b]=this.easing.apply(this,[this.time,c,d-c,this.duration])}this.time++;this.callbacks&&this.callbacks.eachStep&&((new Date).getTime()-this.startTime)/this.time<=1E3/this.minFrameRate&&this.callbacks.eachStep.call(this,a);this.time>this.duration&&this.stop()},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(a,b,c,d){return c*a/d+b},easeOut:function(a,b,c,d){return c*a/d+b},easeInOut:function(a,b,c,d){return c*a/d+b},CLASS_NAME:"OpenLayers.Easing.Linear"};
+OpenLayers.Easing.Expo={easeIn:function(a,b,c,d){return 0==a?b:c*Math.pow(2,10*(a/d-1))+b},easeOut:function(a,b,c,d){return a==d?b+c:c*(-Math.pow(2,-10*a/d)+1)+b},easeInOut:function(a,b,c,d){return 0==a?b:a==d?b+c:1>(a/=d/2)?c/2*Math.pow(2,10*(a-1))+b:c/2*(-Math.pow(2,-10*--a)+2)+b},CLASS_NAME:"OpenLayers.Easing.Expo"};
+OpenLayers.Easing.Quad={easeIn:function(a,b,c,d){return c*(a/=d)*a+b},easeOut:function(a,b,c,d){return-c*(a/=d)*(a-2)+b},easeInOut:function(a,b,c,d){return 1>(a/=d/2)?c/2*a*a+b:-c/2*(--a*(a-2)-1)+b},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.projCode=a;"object"==typeof Proj4js&&(this.proj=new Proj4js.Proj(a))},getCode:function(){return this.proj?this.proj.srsCode:this.projCode},getUnits:function(){return this.proj?this.proj.units:null},toString:function(){return this.getCode()},equals:function(a){var b=!1;a&&(a instanceof OpenLayers.Projection||(a=new OpenLayers.Projection(a)),"object"==
+typeof Proj4js&&this.proj.defData&&a.proj.defData?b=this.proj.defData.replace(this.titleRegEx,"")==a.proj.defData.replace(this.titleRegEx,""):a.getCode&&(b=this.getCode(),a=a.getCode(),b=b==a||!!OpenLayers.Projection.transforms[b]&&OpenLayers.Projection.transforms[b][a]===OpenLayers.Projection.nullTransform));return b},destroy:function(){delete this.proj;delete this.projCode},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};
+OpenLayers.Projection.defaults={"EPSG:4326":{units:"degrees",maxExtent:[-180,-90,180,90],yx:!0},"CRS:84":{units:"degrees",maxExtent:[-180,-90,180,90]},"EPSG:900913":{units:"m",maxExtent:[-2.003750834E7,-2.003750834E7,2.003750834E7,2.003750834E7]}};
+OpenLayers.Projection.addTransform=function(a,b,c){if(c===OpenLayers.Projection.nullTransform){var d=OpenLayers.Projection.defaults[a];d&&!OpenLayers.Projection.defaults[b]&&(OpenLayers.Projection.defaults[b]=d)}OpenLayers.Projection.transforms[a]||(OpenLayers.Projection.transforms[a]={});OpenLayers.Projection.transforms[a][b]=c};
+OpenLayers.Projection.transform=function(a,b,c){if(b&&c)if(b instanceof OpenLayers.Projection||(b=new OpenLayers.Projection(b)),c instanceof OpenLayers.Projection||(c=new OpenLayers.Projection(c)),b.proj&&c.proj)a=Proj4js.transform(b.proj,c.proj,a);else{b=b.getCode();c=c.getCode();var d=OpenLayers.Projection.transforms;if(d[b]&&d[b][c])d[b][c](a)}return a};OpenLayers.Projection.nullTransform=function(a){return a};
+(function(){function a(a){a.x=180*a.x/d;a.y=180/Math.PI*(2*Math.atan(Math.exp(a.y/d*Math.PI))-Math.PI/2);return a}function b(a){a.x=a.x*d/180;var b=Math.log(Math.tan((90+a.y)*Math.PI/360))/Math.PI*d;a.y=Math.max(-2.003750834E7,Math.min(b,2.003750834E7));return a}function c(c,d){var e=OpenLayers.Projection.addTransform,f=OpenLayers.Projection.nullTransform,g,p,q,r,s;g=0;for(p=d.length;g<p;++g)for(q=d[g],e(c,q,b),e(q,c,a),s=g+1;s<p;++s)r=d[s],e(q,r,f),e(r,q,f)}var d=2.003750834E7,e=["EPSG:900913","EPSG:3857",
+"EPSG:102113","EPSG:102100"],f=["CRS:84","urn:ogc:def:crs:EPSG:6.6:4326","EPSG:4326"],g;for(g=e.length-1;0<=g;--g)c(e[g],f);for(g=f.length-1;0<=g;--g)c(f[g],e)})();OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1E3},id:null,fractionalZoom:!1,events:null,allOverlays:!1,div:null,dragging:!1,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,options:null,tileSize:null,projection:"EPSG:4326",units:null,resolutions:null,maxResolution:null,minResolution:null,maxScale:null,minScale:null,
+maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:!1,autoUpdateSize:!0,eventListeners:null,panTween:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,zoomTween:null,zoomMethod:OpenLayers.Easing.Quad.easeOut,zoomDuration:20,paddingForPopups:null,layerContainerOriginPx:null,minPx:null,maxPx:null,initialize:function(a,b){1===arguments.length&&"object"===typeof a&&(a=(b=a)&&b.div);this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,
+OpenLayers.Map.TILE_HEIGHT);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+"theme/default/style.css";this.options=OpenLayers.Util.extend({},b);OpenLayers.Util.extend(this,b);OpenLayers.Util.applyDefaults(this,OpenLayers.Projection.defaults[this.projection instanceof OpenLayers.Projection?this.projection.projCode:this.projection]);!this.maxExtent||this.maxExtent instanceof OpenLayers.Bounds||(this.maxExtent=new OpenLayers.Bounds(this.maxExtent));
+!this.minExtent||this.minExtent instanceof OpenLayers.Bounds||(this.minExtent=new OpenLayers.Bounds(this.minExtent));!this.restrictedExtent||this.restrictedExtent instanceof OpenLayers.Bounds||(this.restrictedExtent=new OpenLayers.Bounds(this.restrictedExtent));!this.center||this.center instanceof OpenLayers.LonLat||(this.center=new OpenLayers.LonLat(this.center));this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(a);this.div||(this.div=document.createElement("div"),
+this.div.style.height="1px",this.div.style.width="1px");OpenLayers.Element.addClass(this.div,"olMap");var c=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(c,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);this.events=new OpenLayers.Events(this,this.viewPortDiv,null,this.fallThrough,{includeXY:!0});OpenLayers.TileManager&&null!==
+this.tileManager&&(this.tileManager instanceof OpenLayers.TileManager||(this.tileManager=new OpenLayers.TileManager(this.tileManager)),this.tileManager.addMap(this));c=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(c);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE.Popup-1;this.layerContainerOriginPx={x:0,y:0};this.applyTransform();this.viewPortDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);
+!0===this.autoUpdateSize&&(this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this),OpenLayers.Event.observe(window,"resize",this.updateSizeDestroy));if(this.theme){for(var c=!0,d=document.getElementsByTagName("link"),e=0,f=d.length;e<f;++e)if(OpenLayers.Util.isEquivalentUrl(d.item(e).href,this.theme)){c=!1;break}c&&(c=document.createElement("link"),c.setAttribute("rel","stylesheet"),c.setAttribute("type","text/css"),c.setAttribute("href",this.theme),document.getElementsByTagName("head")[0].appendChild(c))}null==
+this.controls&&(this.controls=[],null!=OpenLayers.Control&&(OpenLayers.Control.Navigation?this.controls.push(new OpenLayers.Control.Navigation):OpenLayers.Control.TouchNavigation&&this.controls.push(new OpenLayers.Control.TouchNavigation),OpenLayers.Control.Zoom?this.controls.push(new OpenLayers.Control.Zoom):OpenLayers.Control.PanZoom&&this.controls.push(new OpenLayers.Control.PanZoom),OpenLayers.Control.ArgParser&&this.controls.push(new OpenLayers.Control.ArgParser),OpenLayers.Control.Attribution&&
+this.controls.push(new OpenLayers.Control.Attribution)));e=0;for(f=this.controls.length;e<f;e++)this.addControlToMap(this.controls[e]);this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,"unload",this.unloadDestroy);b&&b.layers&&(delete this.center,delete this.zoom,this.addLayers(b.layers),b.center&&!this.getCenter()&&this.setCenter(b.center,b.zoom));this.panMethod&&(this.panTween=new OpenLayers.Tween(this.panMethod));this.zoomMethod&&this.applyTransform.transform&&
+(this.zoomTween=new OpenLayers.Tween(this.zoomMethod))},getViewport:function(){return this.viewPortDiv},render:function(a){this.div=OpenLayers.Util.getElement(a);OpenLayers.Element.addClass(this.div,"olMap");this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize()},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy)return!1;this.panTween&&(this.panTween.stop(),this.panTween=null);this.zoomTween&&(this.zoomTween.stop(),
+this.zoomTween=null);OpenLayers.Event.stopObserving(window,"unload",this.unloadDestroy);this.unloadDestroy=null;this.updateSizeDestroy&&OpenLayers.Event.stopObserving(window,"resize",this.updateSizeDestroy);this.paddingForPopups=null;if(null!=this.controls){for(var a=this.controls.length-1;0<=a;--a)this.controls[a].destroy();this.controls=null}if(null!=this.layers){for(a=this.layers.length-1;0<=a;--a)this.layers[a].destroy(!1);this.layers=null}this.viewPortDiv&&this.viewPortDiv.parentNode&&this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);
+this.viewPortDiv=null;this.tileManager&&(this.tileManager.removeMap(this),this.tileManager=null);this.eventListeners&&(this.events.un(this.eventListeners),this.eventListeners=null);this.events.destroy();this.options=this.events=null},setOptions:function(a){var b=this.minPx&&a.restrictedExtent!=this.restrictedExtent;OpenLayers.Util.extend(this,a);b&&this.moveTo(this.getCachedCenter(),this.zoom,{forceZoomChange:!0})},getTileSize:function(){return this.tileSize},getBy:function(a,b,c){var d="function"==
+typeof c.test;return OpenLayers.Array.filter(this[a],function(a){return a[b]==c||d&&c.test(a[b])})},getLayersBy:function(a,b){return this.getBy("layers",a,b)},getLayersByName:function(a){return this.getLayersBy("name",a)},getLayersByClass:function(a){return this.getLayersBy("CLASS_NAME",a)},getControlsBy:function(a,b){return this.getBy("controls",a,b)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",a)},getLayer:function(a){for(var b=null,c=0,d=this.layers.length;c<d;c++){var e=
+this.layers[c];if(e.id==a){b=e;break}}return b},setLayerZIndex:function(a,b){a.setZIndex(this.Z_INDEX_BASE[a.isBaseLayer?"BaseLayer":"Overlay"]+5*b)},resetLayersZIndex:function(){for(var a=0,b=this.layers.length;a<b;a++)this.setLayerZIndex(this.layers[a],a)},addLayer:function(a){for(var b=0,c=this.layers.length;b<c;b++)if(this.layers[b]==a)return!1;if(!1===this.events.triggerEvent("preaddlayer",{layer:a}))return!1;this.allOverlays&&(a.isBaseLayer=!1);a.div.className="olLayerDiv";a.div.style.overflow=
+"";this.setLayerZIndex(a,this.layers.length);a.isFixed?this.viewPortDiv.appendChild(a.div):this.layerContainerDiv.appendChild(a.div);this.layers.push(a);a.setMap(this);a.isBaseLayer||this.allOverlays&&!this.baseLayer?null==this.baseLayer?this.setBaseLayer(a):a.setVisibility(!1):a.redraw();this.events.triggerEvent("addlayer",{layer:a});a.events.triggerEvent("added",{map:this,layer:a});a.afterAdd();return!0},addLayers:function(a){for(var b=0,c=a.length;b<c;b++)this.addLayer(a[b])},removeLayer:function(a,
+b){if(!1!==this.events.triggerEvent("preremovelayer",{layer:a})){null==b&&(b=!0);a.isFixed?this.viewPortDiv.removeChild(a.div):this.layerContainerDiv.removeChild(a.div);OpenLayers.Util.removeItem(this.layers,a);a.removeMap(this);a.map=null;if(this.baseLayer==a&&(this.baseLayer=null,b))for(var c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.isBaseLayer||this.allOverlays){this.setBaseLayer(e);break}}this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:a});a.events.triggerEvent("removed",
+{map:this,layer:a})}},getNumLayers:function(){return this.layers.length},getLayerIndex:function(a){return OpenLayers.Util.indexOf(this.layers,a)},setLayerIndex:function(a,b){var c=this.getLayerIndex(a);0>b?b=0:b>this.layers.length&&(b=this.layers.length);if(c!=b){this.layers.splice(c,1);this.layers.splice(b,0,a);for(var c=0,d=this.layers.length;c<d;c++)this.setLayerZIndex(this.layers[c],c);this.events.triggerEvent("changelayer",{layer:a,property:"order"});this.allOverlays&&(0===b?this.setBaseLayer(a):
+this.baseLayer!==this.layers[0]&&this.setBaseLayer(this.layers[0]))}},raiseLayer:function(a,b){var c=this.getLayerIndex(a)+b;this.setLayerIndex(a,c)},setBaseLayer:function(a){if(a!=this.baseLayer&&-1!=OpenLayers.Util.indexOf(this.layers,a)){var b=this.getCachedCenter(),c=OpenLayers.Util.getResolutionFromScale(this.getScale(),a.units);null==this.baseLayer||this.allOverlays||this.baseLayer.setVisibility(!1);this.baseLayer=a;if(!this.allOverlays||this.baseLayer.visibility)this.baseLayer.setVisibility(!0),
+!1===this.baseLayer.inRange&&this.baseLayer.redraw();null!=b&&(a=this.getZoomForResolution(c||this.resolution,!0),this.setCenter(b,a,!1,!0));this.events.triggerEvent("changebaselayer",{layer:this.baseLayer})}},addControl:function(a,b){this.controls.push(a);this.addControlToMap(a,b)},addControls:function(a,b){for(var c=1===arguments.length?[]:b,d=0,e=a.length;d<e;d++)this.addControl(a[d],c[d]?c[d]:null)},addControlToMap:function(a,b){a.outsideViewport=null!=a.div;this.displayProjection&&!a.displayProjection&&
+(a.displayProjection=this.displayProjection);a.setMap(this);var c=a.draw(b);c&&!a.outsideViewport&&(c.style.zIndex=this.Z_INDEX_BASE.Control+this.controls.length,this.viewPortDiv.appendChild(c));a.autoActivate&&a.activate()},getControl:function(a){for(var b=null,c=0,d=this.controls.length;c<d;c++){var e=this.controls[c];if(e.id==a){b=e;break}}return b},removeControl:function(a){a&&a==this.getControl(a.id)&&(a.div&&a.div.parentNode==this.viewPortDiv&&this.viewPortDiv.removeChild(a.div),OpenLayers.Util.removeItem(this.controls,
+a))},addPopup:function(a,b){if(b)for(var c=this.popups.length-1;0<=c;--c)this.removePopup(this.popups[c]);a.map=this;this.popups.push(a);if(c=a.draw())c.style.zIndex=this.Z_INDEX_BASE.Popup+this.popups.length,this.layerContainerDiv.appendChild(c)},removePopup:function(a){OpenLayers.Util.removeItem(this.popups,a);if(a.div)try{this.layerContainerDiv.removeChild(a.div)}catch(b){}a.map=null},getSize:function(){var a=null;null!=this.size&&(a=this.size.clone());return a},updateSize:function(){var a=this.getCurrentSize();
+if(a&&!isNaN(a.h)&&!isNaN(a.w)){this.events.clearMouseCache();var b=this.getSize();null==b&&(this.size=b=a);if(!a.equals(b)){this.size=a;a=0;for(b=this.layers.length;a<b;a++)this.layers[a].onMapResize();a=this.getCachedCenter();null!=this.baseLayer&&null!=a&&(b=this.getZoom(),this.zoom=null,this.setCenter(a,b))}}this.events.triggerEvent("updatesize")},getCurrentSize:function(){var a=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(0==a.w&&0==a.h||isNaN(a.w)&&isNaN(a.h))a.w=this.div.offsetWidth,
+a.h=this.div.offsetHeight;if(0==a.w&&0==a.h||isNaN(a.w)&&isNaN(a.h))a.w=parseInt(this.div.style.width),a.h=parseInt(this.div.style.height);return a},calculateBounds:function(a,b){var c=null;null==a&&(a=this.getCachedCenter());null==b&&(b=this.getResolution());if(null!=a&&null!=b)var c=this.size.w*b/2,d=this.size.h*b/2,c=new OpenLayers.Bounds(a.lon-c,a.lat-d,a.lon+c,a.lat+d);return c},getCenter:function(){var a=null,b=this.getCachedCenter();b&&(a=b.clone());return a},getCachedCenter:function(){!this.center&&
+this.size&&(this.center=this.getLonLatFromViewPortPx({x:this.size.w/2,y:this.size.h/2}));return this.center},getZoom:function(){return this.zoom},pan:function(a,b,c){c=OpenLayers.Util.applyDefaults(c,{animate:!0,dragging:!1});if(c.dragging)0==a&&0==b||this.moveByPx(a,b);else{var d=this.getViewPortPxFromLonLat(this.getCachedCenter());a=d.add(a,b);if(this.dragging||!a.equals(d))d=this.getLonLatFromViewPortPx(a),c.animate?this.panTo(d):(this.moveTo(d),this.dragging&&(this.dragging=!1,this.events.triggerEvent("moveend")))}},
+panTo:function(a){if(this.panTween&&this.getExtent().scale(this.panRatio).containsLonLat(a)){var b=this.getCachedCenter();if(!a.equals(b)){var b=this.getPixelFromLonLat(b),c=this.getPixelFromLonLat(a),d=0,e=0;this.panTween.start({x:0,y:0},{x:c.x-b.x,y:c.y-b.y},this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(a){this.moveByPx(a.x-d,a.y-e);d=Math.round(a.x);e=Math.round(a.y)},this),done:OpenLayers.Function.bind(function(b){this.moveTo(a);this.dragging=!1;this.events.triggerEvent("moveend")},
+this)}})}}else this.setCenter(a)},setCenter:function(a,b,c,d){this.panTween&&this.panTween.stop();this.zoomTween&&this.zoomTween.stop();this.moveTo(a,b,{dragging:c,forceZoomChange:d})},moveByPx:function(a,b){var c=this.size.w/2,d=this.size.h/2,e=c+a,f=d+b,g=this.baseLayer.wrapDateLine,h=0,k=0;this.restrictedExtent&&(h=c,k=d,g=!1);a=g||e<=this.maxPx.x-h&&e>=this.minPx.x+h?Math.round(a):0;b=f<=this.maxPx.y-k&&f>=this.minPx.y+k?Math.round(b):0;if(a||b){this.dragging||(this.dragging=!0,this.events.triggerEvent("movestart"));
+this.center=null;a&&(this.layerContainerOriginPx.x-=a,this.minPx.x-=a,this.maxPx.x-=a);b&&(this.layerContainerOriginPx.y-=b,this.minPx.y-=b,this.maxPx.y-=b);this.applyTransform();d=0;for(e=this.layers.length;d<e;++d)c=this.layers[d],c.visibility&&(c===this.baseLayer||c.inRange)&&(c.moveByPx(a,b),c.events.triggerEvent("move"));this.events.triggerEvent("move")}},adjustZoom:function(a){if(this.baseLayer&&this.baseLayer.wrapDateLine){var b=this.baseLayer.resolutions,c=this.getMaxExtent().getWidth()/this.size.w;
+if(this.getResolutionForZoom(a)>c)if(this.fractionalZoom)a=this.getZoomForResolution(c);else for(var d=a|0,e=b.length;d<e;++d)if(b[d]<=c){a=d;break}}return a},getMinZoom:function(){return this.adjustZoom(0)},moveTo:function(a,b,c){null==a||a instanceof OpenLayers.LonLat||(a=new OpenLayers.LonLat(a));c||(c={});null!=b&&(b=parseFloat(b),this.fractionalZoom||(b=Math.round(b)));var d=b;b=this.adjustZoom(b);b!==d&&(a=this.getCenter());var d=c.dragging||this.dragging,e=c.forceZoomChange;this.getCachedCenter()||
+this.isValidLonLat(a)||(a=this.maxExtent.getCenterLonLat(),this.center=a.clone());if(null!=this.restrictedExtent){null==a&&(a=this.center);null==b&&(b=this.getZoom());var f=this.getResolutionForZoom(b),f=this.calculateBounds(a,f);if(!this.restrictedExtent.containsBounds(f)){var g=this.restrictedExtent.getCenterLonLat();f.getWidth()>this.restrictedExtent.getWidth()?a=new OpenLayers.LonLat(g.lon,a.lat):f.left<this.restrictedExtent.left?a=a.add(this.restrictedExtent.left-f.left,0):f.right>this.restrictedExtent.right&&
+(a=a.add(this.restrictedExtent.right-f.right,0));f.getHeight()>this.restrictedExtent.getHeight()?a=new OpenLayers.LonLat(a.lon,g.lat):f.bottom<this.restrictedExtent.bottom?a=a.add(0,this.restrictedExtent.bottom-f.bottom):f.top>this.restrictedExtent.top&&(a=a.add(0,this.restrictedExtent.top-f.top))}}e=e||this.isValidZoomLevel(b)&&b!=this.getZoom();f=this.isValidLonLat(a)&&!a.equals(this.center);if(e||f||d){d||this.events.triggerEvent("movestart",{zoomChanged:e});f&&(!e&&this.center&&this.centerLayerContainer(a),
+this.center=a.clone());a=e?this.getResolutionForZoom(b):this.getResolution();if(e||null==this.layerContainerOrigin){this.layerContainerOrigin=this.getCachedCenter();this.layerContainerOriginPx.x=0;this.layerContainerOriginPx.y=0;this.applyTransform();var f=this.getMaxExtent({restricted:!0}),h=f.getCenterLonLat(),g=this.center.lon-h.lon,h=h.lat-this.center.lat,k=Math.round(f.getWidth()/a),l=Math.round(f.getHeight()/a);this.minPx={x:(this.size.w-k)/2-g/a,y:(this.size.h-l)/2-h/a};this.maxPx={x:this.minPx.x+
+Math.round(f.getWidth()/a),y:this.minPx.y+Math.round(f.getHeight()/a)}}e&&(this.zoom=b,this.resolution=a);a=this.getExtent();this.baseLayer.visibility&&(this.baseLayer.moveTo(a,e,c.dragging),c.dragging||this.baseLayer.events.triggerEvent("moveend",{zoomChanged:e}));a=this.baseLayer.getExtent();for(b=this.layers.length-1;0<=b;--b)f=this.layers[b],f===this.baseLayer||f.isBaseLayer||(g=f.calculateInRange(),f.inRange!=g&&((f.inRange=g)||f.display(!1),this.events.triggerEvent("changelayer",{layer:f,property:"visibility"})),
+g&&f.visibility&&(f.moveTo(a,e,c.dragging),c.dragging||f.events.triggerEvent("moveend",{zoomChanged:e})));this.events.triggerEvent("move");d||this.events.triggerEvent("moveend");if(e){b=0;for(c=this.popups.length;b<c;b++)this.popups[b].updatePosition();this.events.triggerEvent("zoomend")}}},centerLayerContainer:function(a){var b=this.getViewPortPxFromLonLat(this.layerContainerOrigin),c=this.getViewPortPxFromLonLat(a);if(null!=b&&null!=c){var d=this.layerContainerOriginPx.x;a=this.layerContainerOriginPx.y;
+var e=Math.round(b.x-c.x),b=Math.round(b.y-c.y);this.applyTransform(this.layerContainerOriginPx.x=e,this.layerContainerOriginPx.y=b);d-=e;a-=b;this.minPx.x-=d;this.maxPx.x-=d;this.minPx.y-=a;this.maxPx.y-=a}},isValidZoomLevel:function(a){return null!=a&&0<=a&&a<this.getNumZoomLevels()},isValidLonLat:function(a){var b=!1;null!=a&&(b=this.getMaxExtent(),b=b.containsLonLat(a,{worldBounds:this.baseLayer.wrapDateLine&&b}));return b},getProjection:function(){var a=this.getProjectionObject();return a?a.getCode():
+null},getProjectionObject:function(){var a=null;null!=this.baseLayer&&(a=this.baseLayer.projection);return a},getMaxResolution:function(){var a=null;null!=this.baseLayer&&(a=this.baseLayer.maxResolution);return a},getMaxExtent:function(a){var b=null;a&&a.restricted&&this.restrictedExtent?b=this.restrictedExtent:null!=this.baseLayer&&(b=this.baseLayer.maxExtent);return b},getNumZoomLevels:function(){var a=null;null!=this.baseLayer&&(a=this.baseLayer.numZoomLevels);return a},getExtent:function(){var a=
+null;null!=this.baseLayer&&(a=this.baseLayer.getExtent());return a},getResolution:function(){var a=null;null!=this.baseLayer?a=this.baseLayer.getResolution():!0===this.allOverlays&&0<this.layers.length&&(a=this.layers[0].getResolution());return a},getUnits:function(){var a=null;null!=this.baseLayer&&(a=this.baseLayer.units);return a},getScale:function(){var a=null;null!=this.baseLayer&&(a=this.getResolution(),a=OpenLayers.Util.getScaleFromResolution(a,this.baseLayer.units));return a},getZoomForExtent:function(a,
+b){var c=null;null!=this.baseLayer&&(c=this.baseLayer.getZoomForExtent(a,b));return c},getResolutionForZoom:function(a){var b=null;this.baseLayer&&(b=this.baseLayer.getResolutionForZoom(a));return b},getZoomForResolution:function(a,b){var c=null;null!=this.baseLayer&&(c=this.baseLayer.getZoomForResolution(a,b));return c},zoomTo:function(a,b){var c=this;if(c.isValidZoomLevel(a))if(c.baseLayer.wrapDateLine&&(a=c.adjustZoom(a)),c.zoomTween){var d=c.getResolution(),e=c.getResolutionForZoom(a),f={scale:1},
+d={scale:d/e};c.zoomTween.playing&&c.zoomTween.duration<3*c.zoomDuration?c.zoomTween.finish={scale:c.zoomTween.finish.scale*d.scale}:(b||(e=c.getSize(),b={x:e.w/2,y:e.h/2}),c.zoomTween.start(f,d,c.zoomDuration,{minFrameRate:50,callbacks:{eachStep:function(a){var d=c.layerContainerOriginPx;a=a.scale;c.applyTransform(d.x+((a-1)*(d.x-b.x)|0),d.y+((a-1)*(d.y-b.y)|0),a)},done:function(a){c.applyTransform();a=c.getResolution()/a.scale;var d=c.getZoomForResolution(a,!0);c.moveTo(c.getZoomTargetCenter(b,
+a),d,!0)}}}))}else f=b?c.getZoomTargetCenter(b,c.getResolutionForZoom(a)):null,c.setCenter(f,a)},zoomIn:function(){this.zoomTo(this.getZoom()+1)},zoomOut:function(){this.zoomTo(this.getZoom()-1)},zoomToExtent:function(a,b){a instanceof OpenLayers.Bounds||(a=new OpenLayers.Bounds(a));var c=a.getCenterLonLat();if(this.baseLayer.wrapDateLine){c=this.getMaxExtent();for(a=a.clone();a.right<a.left;)a.right+=c.getWidth();c=a.getCenterLonLat().wrapDateLine(c)}this.setCenter(c,this.getZoomForExtent(a,b))},
+zoomToMaxExtent:function(a){a=this.getMaxExtent({restricted:a?a.restricted:!0});this.zoomToExtent(a)},zoomToScale:function(a,b){var c=OpenLayers.Util.getResolutionFromScale(a,this.baseLayer.units),d=this.size.w*c/2,c=this.size.h*c/2,e=this.getCachedCenter(),d=new OpenLayers.Bounds(e.lon-d,e.lat-c,e.lon+d,e.lat+c);this.zoomToExtent(d,b)},getLonLatFromViewPortPx:function(a){var b=null;null!=this.baseLayer&&(b=this.baseLayer.getLonLatFromViewPortPx(a));return b},getViewPortPxFromLonLat:function(a){var b=
+null;null!=this.baseLayer&&(b=this.baseLayer.getViewPortPxFromLonLat(a));return b},getZoomTargetCenter:function(a,b){var c=null,d=this.getSize(),e=d.w/2-a.x,d=a.y-d.h/2,f=this.getLonLatFromPixel(a);f&&(c=new OpenLayers.LonLat(f.lon+e*b,f.lat+d*b));return c},getLonLatFromPixel:function(a){return this.getLonLatFromViewPortPx(a)},getPixelFromLonLat:function(a){a=this.getViewPortPxFromLonLat(a);a.x=Math.round(a.x);a.y=Math.round(a.y);return a},getGeodesicPixelSize:function(a){var b=a?this.getLonLatFromPixel(a):
+this.getCachedCenter()||new OpenLayers.LonLat(0,0),c=this.getResolution();a=b.add(-c/2,0);var d=b.add(c/2,0),e=b.add(0,-c/2),b=b.add(0,c/2),c=new OpenLayers.Projection("EPSG:4326"),f=this.getProjectionObject()||c;f.equals(c)||(a.transform(f,c),d.transform(f,c),e.transform(f,c),b.transform(f,c));return new OpenLayers.Size(OpenLayers.Util.distVincenty(a,d),OpenLayers.Util.distVincenty(e,b))},getViewPortPxFromLayerPx:function(a){var b=null;null!=a&&(b=a.add(this.layerContainerOriginPx.x,this.layerContainerOriginPx.y));
+return b},getLayerPxFromViewPortPx:function(a){var b=null;null!=a&&(b=a.add(-this.layerContainerOriginPx.x,-this.layerContainerOriginPx.y),isNaN(b.x)||isNaN(b.y))&&(b=null);return b},getLonLatFromLayerPx:function(a){a=this.getViewPortPxFromLayerPx(a);return this.getLonLatFromViewPortPx(a)},getLayerPxFromLonLat:function(a){a=this.getPixelFromLonLat(a);return this.getLayerPxFromViewPortPx(a)},applyTransform:function(a,b,c){c=c||1;var d=this.layerContainerOriginPx,e=1!==c;a=a||d.x;b=b||d.y;var f=this.layerContainerDiv.style,
+g=this.applyTransform.transform,h=this.applyTransform.template;if(void 0===g&&(g=OpenLayers.Util.vendorPrefix.style("transform"),this.applyTransform.transform=g)){var k=OpenLayers.Element.getStyle(this.viewPortDiv,OpenLayers.Util.vendorPrefix.css("transform"));k&&"none"===k||(h=["translate3d(",",0) ","scale3d(",",1)"],f[g]=[h[0],"0,0",h[1]].join(""));h&&~f[g].indexOf(h[0])||(h=["translate(",") ","scale(",")"]);this.applyTransform.template=h}null===g||"translate3d("!==h[0]&&!0!==e?(f.left=a+"px",f.top=
+b+"px",null!==g&&(f[g]="")):(!0===e&&"translate("===h[0]&&(a-=d.x,b-=d.y,f.left=d.x+"px",f.top=d.y+"px"),f[g]=[h[0],a,"px,",b,"px",h[1],h[2],c,",",c,h[3]].join(""))},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:!1,evt:null,touch:!1,initialize:function(a,b,c){OpenLayers.Util.extend(this,c);this.control=a;this.callbacks=b;(a=this.map||a.map)&&this.setMap(a);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},setMap:function(a){this.map=a},checkModifiers:function(a){return null==this.keyMask?!0:((a.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(a.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(a.altKey?OpenLayers.Handler.MOD_ALT:
+0)|(a.metaKey?OpenLayers.Handler.MOD_META:0))==this.keyMask},activate:function(){if(this.active)return!1;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.register(a[b],this[a[b]]);return this.active=!0},deactivate:function(){if(!this.active)return!1;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.unregister(a[b],this[a[b]]);this.active=this.touch=!1;return!0},startTouch:function(){if(!this.touch){this.touch=!0;
+for(var a="mousedown mouseup mousemove click dblclick mouseout".split(" "),b=0,c=a.length;b<c;b++)this[a[b]]&&this.unregister(a[b],this[a[b]])}},callback:function(a,b){a&&this.callbacks[a]&&this.callbacks[a].apply(this.control,b)},register:function(a,b){this.map.events.registerPriority(a,this,b);this.map.events.registerPriority(a,this,this.setEvent)},unregister:function(a,b){this.map.events.unregister(a,this,b);this.map.events.unregister(a,this,this.setEvent)},setEvent:function(a){this.evt=a;return!0},
+destroy:function(){this.deactivate();this.control=this.map=null},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.MOD_META=8;OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:!0,"double":!1,pixelTolerance:0,dblclickTolerance:13,stopSingle:!1,stopDouble:!1,timerId:null,down:null,last:null,first:null,rightclickTimerId:null,touchstart:function(a){this.startTouch();this.down=this.getEventInfo(a);this.last=this.getEventInfo(a);return!0},touchmove:function(a){this.last=this.getEventInfo(a);return!0},touchend:function(a){this.down&&(a.xy=this.last.xy,a.lastTouches=this.last.touches,this.handleSingle(a),
+this.down=null);return!0},mousedown:function(a){this.down=this.getEventInfo(a);this.last=this.getEventInfo(a);return!0},mouseup:function(a){var b=!0;this.checkModifiers(a)&&(this.control.handleRightClicks&&OpenLayers.Event.isRightClick(a))&&(b=this.rightclick(a));return b},rightclick:function(a){if(this.passesTolerance(a)){if(null!=this.rightclickTimerId)return this.clearTimer(),this.callback("dblrightclick",[a]),!this.stopDouble;a=this["double"]?OpenLayers.Util.extend({},a):this.callback("rightclick",
+[a]);a=OpenLayers.Function.bind(this.delayedRightCall,this,a);this.rightclickTimerId=window.setTimeout(a,this.delay)}return!this.stopSingle},delayedRightCall:function(a){this.rightclickTimerId=null;a&&this.callback("rightclick",[a])},click:function(a){this.last||(this.last=this.getEventInfo(a));this.handleSingle(a);return!this.stopSingle},dblclick:function(a){this.handleDouble(a);return!this.stopDouble},handleDouble:function(a){this.passesDblclickTolerance(a)&&(this["double"]&&this.callback("dblclick",
+[a]),this.clearTimer())},handleSingle:function(a){this.passesTolerance(a)&&(null!=this.timerId?(this.last.touches&&1===this.last.touches.length&&(this["double"]&&OpenLayers.Event.preventDefault(a),this.handleDouble(a)),this.last.touches&&2===this.last.touches.length||this.clearTimer()):(this.first=this.getEventInfo(a),a=this.single?OpenLayers.Util.extend({},a):null,this.queuePotentialClick(a)))},queuePotentialClick:function(a){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,
+this,a),this.delay)},passesTolerance:function(a){var b=!0;if(null!=this.pixelTolerance&&this.down&&this.down.xy&&(b=this.pixelTolerance>=this.down.xy.distanceTo(a.xy))&&this.touch&&this.down.touches.length===this.last.touches.length){a=0;for(var c=this.down.touches.length;a<c;++a)if(this.getTouchDistance(this.down.touches[a],this.last.touches[a])>this.pixelTolerance){b=!1;break}}return b},getTouchDistance:function(a,b){return Math.sqrt(Math.pow(a.clientX-b.clientX,2)+Math.pow(a.clientY-b.clientY,
+2))},passesDblclickTolerance:function(a){a=!0;this.down&&this.first&&(a=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance);return a},clearTimer:function(){null!=this.timerId&&(window.clearTimeout(this.timerId),this.timerId=null);null!=this.rightclickTimerId&&(window.clearTimeout(this.rightclickTimerId),this.rightclickTimerId=null)},delayedCall:function(a){this.timerId=null;a&&this.callback("click",[a])},getEventInfo:function(a){var b;if(a.touches){var c=a.touches.length;b=Array(c);for(var d,
+e=0;e<c;e++)d=a.touches[e],b[e]={clientX:d.olClientX,clientY:d.olClientY}}return{xy:a.xy,touches:b}},deactivate:function(){var a=!1;OpenLayers.Handler.prototype.deactivate.apply(this,arguments)&&(this.clearTimer(),this.last=this.first=this.down=null,a=!0);return a},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:!1,stopDown:!0,dragging:!1,last:null,start:null,lastMoveEvt:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:!1,documentEvents:null,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(!0===this.documentDrag){var d=this;this._docMove=function(a){d.mousemove({xy:{x:a.clientX,y:a.clientY},element:document})};this._docUp=function(a){d.mouseup({xy:{x:a.clientX,y:a.clientY}})}}},
+dragstart:function(a){var b=!0;this.dragging=!1;this.checkModifiers(a)&&(OpenLayers.Event.isLeftClick(a)||OpenLayers.Event.isSingleTouch(a))?(this.started=!0,this.last=this.start=a.xy,OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown"),this.down(a),this.callback("down",[a.xy]),OpenLayers.Event.preventDefault(a),this.oldOnselectstart||(this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True),document.onselectstart=OpenLayers.Function.False,b=!this.stopDown):
+(this.started=!1,this.last=this.start=null);return b},dragmove:function(a){this.lastMoveEvt=a;!this.started||(this.timeoutId||a.xy.x==this.last.x&&a.xy.y==this.last.y)||(!0===this.documentDrag&&this.documentEvents&&(a.element===document?(this.adjustXY(a),this.setEvent(a)):this.removeDocumentEvents()),0<this.interval&&(this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval)),this.dragging=!0,this.move(a),this.callback("move",[a.xy]),this.oldOnselectstart||(this.oldOnselectstart=
+document.onselectstart,document.onselectstart=OpenLayers.Function.False),this.last=a.xy);return!0},dragend:function(a){if(this.started){!0===this.documentDrag&&this.documentEvents&&(this.adjustXY(a),this.removeDocumentEvents());var b=this.start!=this.last;this.dragging=this.started=!1;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(a);this.callback("up",[a.xy]);b&&this.callback("done",[a.xy]);document.onselectstart=this.oldOnselectstart}return!0},down:function(a){},move:function(a){},
+up:function(a){},out:function(a){},mousedown:function(a){return this.dragstart(a)},touchstart:function(a){this.startTouch();return this.dragstart(a)},mousemove:function(a){return this.dragmove(a)},touchmove:function(a){return this.dragmove(a)},removeTimeout:function(){this.timeoutId=null;this.dragging&&this.mousemove(this.lastMoveEvt)},mouseup:function(a){return this.dragend(a)},touchend:function(a){a.xy=this.last;return this.dragend(a)},mouseout:function(a){if(this.started&&OpenLayers.Util.mouseLeft(a,
+this.map.viewPortDiv))if(!0===this.documentDrag)this.addDocumentEvents();else{var b=this.start!=this.last;this.dragging=this.started=!1;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(a);this.callback("out",[]);b&&this.callback("done",[a.xy]);document.onselectstart&&(document.onselectstart=this.oldOnselectstart)}return!0},click:function(a){return this.start==this.last},activate:function(){var a=!1;OpenLayers.Handler.prototype.activate.apply(this,arguments)&&(this.dragging=
+!1,a=!0);return a},deactivate:function(){var a=!1;OpenLayers.Handler.prototype.deactivate.apply(this,arguments)&&(this.dragging=this.started=!1,this.last=this.start=null,a=!0,OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown"));return a},adjustXY:function(a){var b=OpenLayers.Util.pagePosition(this.map.viewPortDiv);a.xy.x-=b[0];a.xy.y-=b[1]},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=!0;OpenLayers.Event.observe(document,"mousemove",
+this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp)},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=!1;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp)},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:{w:180,h:90},layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,autoPan:!1,handlers:null,resolutionFactor:1,maximized:!1,maximizeTitle:"",minimizeTitle:"",initialize:function(a){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[a])},destroy:function(){this.mapDiv&&(this.handlers.click&&this.handlers.click.destroy(),
+this.handlers.drag&&this.handlers.drag.destroy(),this.ovmap&&this.ovmap.viewPortDiv.removeChild(this.extentRectangle),this.extentRectangle=null,this.rectEvents&&(this.rectEvents.destroy(),this.rectEvents=null),this.ovmap&&(this.ovmap.destroy(),this.ovmap=null),this.element.removeChild(this.mapDiv),this.mapDiv=null,this.div.removeChild(this.element),this.element=null,this.maximizeDiv&&(this.div.removeChild(this.maximizeDiv),this.maximizeDiv=null),this.minimizeDiv&&(this.div.removeChild(this.minimizeDiv),
+this.minimizeDiv=null),this.map.events.un({buttonclick:this.onButtonClick,moveend:this.update,changebaselayer:this.baseLayerDraw,scope:this}),OpenLayers.Control.prototype.destroy.apply(this,arguments))},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(0===this.layers.length)if(this.map.baseLayer)this.layers=[this.map.baseLayer.clone()];else return this.map.events.register("changebaselayer",this,this.baseLayerDraw),this.div;this.element=document.createElement("div");this.element.className=
+this.displayClass+"Element";this.element.style.display="none";this.mapDiv=document.createElement("div");this.mapDiv.style.width=this.size.w+"px";this.mapDiv.style.height=this.size.h+"px";this.mapDiv.style.position="relative";this.mapDiv.style.overflow="hidden";this.mapDiv.id=OpenLayers.Util.createUniqueID("overviewMap");this.extentRectangle=document.createElement("div");this.extentRectangle.style.position="absolute";this.extentRectangle.style.zIndex=1E3;this.extentRectangle.className=this.displayClass+
+"ExtentRectangle";this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(this.outsideViewport)this.element.style.display="";else{this.div.className+=" "+this.displayClass+"Container";var a=OpenLayers.Util.getImageLocation("layer-switcher-maximize.png");this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+"MaximizeButton",null,null,a,"absolute");this.maximizeDiv.style.display="none";this.maximizeDiv.className=this.displayClass+"MaximizeButton olButton";this.maximizeTitle&&
+(this.maximizeDiv.title=this.maximizeTitle);this.div.appendChild(this.maximizeDiv);a=OpenLayers.Util.getImageLocation("layer-switcher-minimize.png");this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_minimizeDiv",null,null,a,"absolute");this.minimizeDiv.style.display="none";this.minimizeDiv.className=this.displayClass+"MinimizeButton olButton";this.minimizeTitle&&(this.minimizeDiv.title=this.minimizeTitle);this.div.appendChild(this.minimizeDiv);this.minimizeControl()}this.map.getExtent()&&
+this.update();this.map.events.on({buttonclick:this.onButtonClick,moveend:this.update,scope:this});this.maximized&&this.maximizeControl();return this.div},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw)},rectDrag:function(a){var b=this.handlers.drag.last.x-a.x,c=this.handlers.drag.last.y-a.y;if(0!=b||0!=c){var d=this.rectPxBounds.top,e=this.rectPxBounds.left;a=Math.abs(this.rectPxBounds.getHeight());var f=this.rectPxBounds.getWidth(),c=Math.max(0,
+d-c),c=Math.min(c,this.ovmap.size.h-this.hComp-a),b=Math.max(0,e-b),b=Math.min(b,this.ovmap.size.w-this.wComp-f);this.setRectPxBounds(new OpenLayers.Bounds(b,c+a,b+f,c))}},mapDivClick:function(a){var b=this.rectPxBounds.getCenterPixel(),c=a.xy.x-b.x,d=a.xy.y-b.y,e=this.rectPxBounds.top,f=this.rectPxBounds.left;a=Math.abs(this.rectPxBounds.getHeight());b=this.rectPxBounds.getWidth();d=Math.max(0,e+d);d=Math.min(d,this.ovmap.size.h-a);c=Math.max(0,f+c);c=Math.min(c,this.ovmap.size.w-b);this.setRectPxBounds(new OpenLayers.Bounds(c,
+d+a,c+b,d));this.updateMapToRect()},onButtonClick:function(a){a.buttonElement===this.minimizeDiv?this.minimizeControl():a.buttonElement===this.maximizeDiv&&this.maximizeControl()},maximizeControl:function(a){this.element.style.display="";this.showToggle(!1);null!=a&&OpenLayers.Event.stop(a)},minimizeControl:function(a){this.element.style.display="none";this.showToggle(!0);null!=a&&OpenLayers.Event.stop(a)},showToggle:function(a){this.maximizeDiv&&(this.maximizeDiv.style.display=a?"":"none");this.minimizeDiv&&
+(this.minimizeDiv.style.display=a?"none":"")},update:function(){null==this.ovmap&&this.createMap();!this.autoPan&&this.isSuitableOverview()||this.updateOverview();this.updateRectToMap()},isSuitableOverview:function(){var a=this.map.getExtent(),b=this.map.getMaxExtent(),a=new OpenLayers.Bounds(Math.max(a.left,b.left),Math.max(a.bottom,b.bottom),Math.min(a.right,b.right),Math.min(a.top,b.top));this.ovmap.getProjection()!=this.map.getProjection()&&(a=a.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject()));
+b=this.ovmap.getResolution()/this.map.getResolution();return b>this.minRatio&&b<=this.maxRatio&&this.ovmap.getExtent().containsBounds(a)},updateOverview:function(){var a=this.map.getResolution(),b=this.ovmap.getResolution(),c=b/a;c>this.maxRatio?b=this.minRatio*a:c<=this.minRatio&&(b=this.maxRatio*a);this.ovmap.getProjection()!=this.map.getProjection()?(a=this.map.center.clone(),a.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject())):a=this.map.center;this.ovmap.setCenter(a,
+this.ovmap.getZoomForResolution(b*this.resolutionFactor));this.updateRectToMap()},createMap:function(){var a=OpenLayers.Util.extend({controls:[],maxResolution:"auto",fallThrough:!1},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,a);this.ovmap.viewPortDiv.appendChild(this.extentRectangle);OpenLayers.Event.stopObserving(window,"unload",this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=(this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,
+"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,"border-right-width")))?this.wComp:2;this.hComp=(this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,"border-bottom-width")))?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.mapDivClick},
+{single:!0,"double":!1,stopSingle:!0,stopDouble:!0,pixelTolerance:1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,!0);this.rectEvents.register("mouseover",this,function(a){this.handlers.drag.active||this.map.dragging||this.handlers.drag.activate()});this.rectEvents.register("mouseout",this,function(a){this.handlers.drag.dragging||this.handlers.drag.deactivate()});if(this.ovmap.getProjection()!=this.map.getProjection()){var a=this.map.getProjectionObject().getUnits()||
+this.map.units||this.map.baseLayer.units,b=this.ovmap.getProjectionObject().getUnits()||this.ovmap.units||this.ovmap.baseLayer.units;this.resolutionFactor=a&&b?OpenLayers.INCHES_PER_UNIT[a]/OpenLayers.INCHES_PER_UNIT[b]:1}},updateRectToMap:function(){var a;a=this.ovmap.getProjection()!=this.map.getProjection()?this.map.getExtent().transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject()):this.map.getExtent();(a=this.getRectBoundsFromMapBounds(a))&&this.setRectPxBounds(a)},updateMapToRect:function(){var a=
+this.getMapBoundsFromRectBounds(this.rectPxBounds);this.ovmap.getProjection()!=this.map.getProjection()&&(a=a.transform(this.ovmap.getProjectionObject(),this.map.getProjectionObject()));this.map.panTo(a.getCenterLonLat())},setRectPxBounds:function(a){var b=Math.max(a.top,0),c=Math.max(a.left,0),d=Math.min(a.top+Math.abs(a.getHeight()),this.ovmap.size.h-this.hComp);a=Math.min(a.left+a.getWidth(),this.ovmap.size.w-this.wComp);var e=Math.max(a-c,0),f=Math.max(d-b,0);e<this.minRectSize||f<this.minRectSize?
+(this.extentRectangle.className=this.displayClass+this.minRectDisplayClass,e=c+e/2-this.minRectSize/2,this.extentRectangle.style.top=Math.round(b+f/2-this.minRectSize/2)+"px",this.extentRectangle.style.left=Math.round(e)+"px",this.extentRectangle.style.height=this.minRectSize+"px",this.extentRectangle.style.width=this.minRectSize+"px"):(this.extentRectangle.className=this.displayClass+"ExtentRectangle",this.extentRectangle.style.top=Math.round(b)+"px",this.extentRectangle.style.left=Math.round(c)+
+"px",this.extentRectangle.style.height=Math.round(f)+"px",this.extentRectangle.style.width=Math.round(e)+"px");this.rectPxBounds=new OpenLayers.Bounds(Math.round(c),Math.round(d),Math.round(a),Math.round(b))},getRectBoundsFromMapBounds:function(a){var b=this.getOverviewPxFromLonLat({lon:a.left,lat:a.bottom});a=this.getOverviewPxFromLonLat({lon:a.right,lat:a.top});var c=null;b&&a&&(c=new OpenLayers.Bounds(b.x,b.y,a.x,a.y));return c},getMapBoundsFromRectBounds:function(a){var b=this.getLonLatFromOverviewPx({x:a.left,
+y:a.bottom});a=this.getLonLatFromOverviewPx({x:a.right,y:a.top});return new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat)},getLonLatFromOverviewPx:function(a){var b=this.ovmap.size,c=this.ovmap.getResolution(),d=this.ovmap.getExtent().getCenterLonLat();return{lon:d.lon+(a.x-b.w/2)*c,lat:d.lat-(a.y-b.h/2)*c}},getOverviewPxFromLonLat:function(a){var b=this.ovmap.getResolution(),c=this.ovmap.getExtent();if(c)return{x:Math.round(1/b*(a.lon-c.left)),y:Math.round(1/b*(c.top-a.lat))}},CLASS_NAME:"OpenLayers.Control.OverviewMap"});OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:1,alwaysInRange:null,RESOLUTION_PROPERTIES:"scales resolutions maxScale minScale maxResolution minResolution numZoomLevels maxZoomLevel".split(" "),events:null,map:null,isBaseLayer:!1,alpha:!1,displayInLayerSwitcher:!0,visibility:!0,attribution:null,inRange:!1,imageSize:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minE
xtent:null,maxResolution:null,minResolution:null,
+numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:!1,wrapDateLine:!1,metadata:null,initialize:function(a,b){this.metadata={};b=OpenLayers.Util.extend({},b);null!=this.alwaysInRange&&(b.alwaysInRange=this.alwaysInRange);this.addOptions(b);this.name=a;if(null==this.id&&(this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_"),this.div=OpenLayers.Util.createDiv(this.id),this.div.style.width="100%",this.div.style.height="100%",this.div.dir="ltr",this.events=new OpenLayers.Events(this,
+this.div),this.eventListeners instanceof Object))this.events.on(this.eventListeners)},destroy:function(a){null==a&&(a=!0);null!=this.map&&this.map.removeLayer(this,a);this.options=this.div=this.name=this.map=this.projection=null;this.events&&(this.eventListeners&&this.events.un(this.eventListeners),this.events.destroy());this.events=this.eventListeners=null},clone:function(a){null==a&&(a=new OpenLayers.Layer(this.name,this.getOptions()));OpenLayers.Util.applyDefaults(a,this);a.map=null;return a},
+getOptions:function(){var a={},b;for(b in this.options)a[b]=this[b];return a},setName:function(a){a!=this.name&&(this.name=a,null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"name"}))},addOptions:function(a,b){null==this.options&&(this.options={});a&&("string"==typeof a.projection&&(a.projection=new OpenLayers.Projection(a.projection)),a.projection&&OpenLayers.Util.applyDefaults(a,OpenLayers.Projection.defaults[a.projection.getCode()]),!a.maxExtent||a.maxExtent instanceof
+OpenLayers.Bounds||(a.maxExtent=new OpenLayers.Bounds(a.maxExtent)),!a.minExtent||a.minExtent instanceof OpenLayers.Bounds||(a.minExtent=new OpenLayers.Bounds(a.minExtent)));OpenLayers.Util.extend(this.options,a);OpenLayers.Util.extend(this,a);this.projection&&this.projection.getUnits()&&(this.units=this.projection.getUnits());if(this.map){var c=this.map.getResolution(),d=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]),e;for(e in a)if(a.hasOwnProperty(e)&&0<=OpenLayers.Util.indexOf(d,
+e)){this.initResolutions();b&&this.map.baseLayer===this&&(this.map.setCenter(this.map.getCenter(),this.map.getZoomForResolution(c),!1,!0),this.map.events.triggerEvent("changebaselayer",{layer:this}));break}}},onMapResize:function(){},redraw:function(){var a=!1;if(this.map){this.inRange=this.calculateInRange();var b=this.getExtent();b&&(this.inRange&&this.visibility)&&(this.moveTo(b,!0,!1),this.events.triggerEvent("moveend",{zoomChanged:!0}),a=!0)}return a},moveTo:function(a,b,c){a=this.visibility;
+this.isBaseLayer||(a=a&&this.inRange);this.display(a)},moveByPx:function(a,b){},setMap:function(a){null==this.map&&(this.map=a,this.maxExtent=this.maxExtent||this.map.maxExtent,this.minExtent=this.minExtent||this.map.minExtent,this.projection=this.projection||this.map.projection,"string"==typeof this.projection&&(this.projection=new OpenLayers.Projection(this.projection)),this.units=this.projection.getUnits()||this.units||this.map.units,this.initResolutions(),this.isBaseLayer||(this.inRange=this.calculateInRange(),
+this.div.style.display=this.visibility&&this.inRange?"":"none"),this.setTileSize())},afterAdd:function(){},removeMap:function(a){},getImageSize:function(a){return this.imageSize||this.tileSize},setTileSize:function(a){this.tileSize=a=a?a:this.tileSize?this.tileSize:this.map.getTileSize();this.gutter&&(this.imageSize=new OpenLayers.Size(a.w+2*this.gutter,a.h+2*this.gutter))},getVisibility:function(){return this.visibility},setVisibility:function(a){a!=this.visibility&&(this.visibility=a,this.display(a),
+this.redraw(),null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"}),this.events.triggerEvent("visibilitychanged"))},display:function(a){a!=("none"!=this.div.style.display)&&(this.div.style.display=a&&this.calculateInRange()?"block":"none")},calculateInRange:function(){var a=!1;this.alwaysInRange?a=!0:this.map&&(a=this.map.getResolution(),a=a>=this.minResolution&&a<=this.maxResolution);return a},setIsBaseLayer:function(a){a!=this.isBaseLayer&&(this.isBaseLayer=
+a,null!=this.map&&this.map.events.triggerEvent("changebaselayer",{layer:this}))},initResolutions:function(){var a,b,c,d={},e=!0;a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<b;a++)c=this.RESOLUTION_PROPERTIES[a],d[c]=this.options[c],e&&this.options[c]&&(e=!1);null==this.options.alwaysInRange&&(this.alwaysInRange=e);null==d.resolutions&&(d.resolutions=this.resolutionsFromScales(d.scales));null==d.resolutions&&(d.resolutions=this.calculateResolutions(d));if(null==d.resolutions){a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<
+b;a++)c=this.RESOLUTION_PROPERTIES[a],d[c]=null!=this.options[c]?this.options[c]:this.map[c];null==d.resolutions&&(d.resolutions=this.resolutionsFromScales(d.scales));null==d.resolutions&&(d.resolutions=this.calculateResolutions(d))}var f;this.options.maxResolution&&"auto"!==this.options.maxResolution&&(f=this.options.maxResolution);this.options.minScale&&(f=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units));var g;this.options.minResolution&&"auto"!==this.options.minResolution&&
+(g=this.options.minResolution);this.options.maxScale&&(g=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units));d.resolutions&&(d.resolutions.sort(function(a,b){return b-a}),f||(f=d.resolutions[0]),g||(g=d.resolutions[d.resolutions.length-1]));if(this.resolutions=d.resolutions){b=this.resolutions.length;this.scales=Array(b);for(a=0;a<b;a++)this.scales[a]=OpenLayers.Util.getScaleFromResolution(this.resolutions[a],this.units);this.numZoomLevels=b}if(this.minResolution=g)this.maxScale=
+OpenLayers.Util.getScaleFromResolution(g,this.units);if(this.maxResolution=f)this.minScale=OpenLayers.Util.getScaleFromResolution(f,this.units)},resolutionsFromScales:function(a){if(null!=a){var b,c,d;d=a.length;b=Array(d);for(c=0;c<d;c++)b[c]=OpenLayers.Util.getResolutionFromScale(a[c],this.units);return b}},calculateResolutions:function(a){var b,c,d=a.maxResolution;null!=a.minScale?d=OpenLayers.Util.getResolutionFromScale(a.minScale,this.units):"auto"==d&&null!=this.maxExtent&&(b=this.map.getSize(),
+c=this.maxExtent.getWidth()/b.w,b=this.maxExtent.getHeight()/b.h,d=Math.max(c,b));c=a.minResolution;null!=a.maxScale?c=OpenLayers.Util.getResolutionFromScale(a.maxScale,this.units):"auto"==a.minResolution&&null!=this.minExtent&&(b=this.map.getSize(),c=this.minExtent.getWidth()/b.w,b=this.minExtent.getHeight()/b.h,c=Math.max(c,b));"number"!==typeof d&&("number"!==typeof c&&null!=this.maxExtent)&&(d=this.map.getTileSize(),d=Math.max(this.maxExtent.getWidth()/d.w,this.maxExtent.getHeight()/d.h));b=a.maxZoomLevel;
+a=a.numZoomLevels;"number"===typeof c&&"number"===typeof d&&void 0===a?a=Math.floor(Math.log(d/c)/Math.log(2))+1:void 0===a&&null!=b&&(a=b+1);if(!("number"!==typeof a||0>=a||"number"!==typeof d&&"number"!==typeof c)){b=Array(a);var e=2;"number"==typeof c&&"number"==typeof d&&(e=Math.pow(d/c,1/(a-1)));var f;if("number"===typeof d)for(f=0;f<a;f++)b[f]=d/Math.pow(e,f);else for(f=0;f<a;f++)b[a-1-f]=c*Math.pow(e,f);return b}},getResolution:function(){var a=this.map.getZoom();return this.getResolutionForZoom(a)},
+getExtent:function(){return this.map.calculateBounds()},getZoomForExtent:function(a,b){var c=this.map.getSize(),c=Math.max(a.getWidth()/c.w,a.getHeight()/c.h);return this.getZoomForResolution(c,b)},getDataExtent:function(){},getResolutionForZoom:function(a){a=Math.max(0,Math.min(a,this.resolutions.length-1));if(this.map.fractionalZoom){var b=Math.floor(a),c=Math.ceil(a);a=this.resolutions[b]-(a-b)*(this.resolutions[b]-this.resolutions[c])}else a=this.resolutions[Math.round(a)];return a},getZoomForResolution:function(a,
+b){var c,d;if(this.map.fractionalZoom){var e=0,f=this.resolutions[e],g=this.resolutions[this.resolutions.length-1],h;c=0;for(d=this.resolutions.length;c<d;++c)if(h=this.resolutions[c],h>=a&&(f=h,e=c),h<=a){g=h;break}c=f-g;c=0<c?e+(f-a)/c:e}else{f=Number.POSITIVE_INFINITY;c=0;for(d=this.resolutions.length;c<d;c++)if(b){e=Math.abs(this.resolutions[c]-a);if(e>f)break;f=e}else if(this.resolutions[c]<a)break;c=Math.max(0,c-1)}return c},getLonLatFromViewPortPx:function(a){var b=null,c=this.map;if(null!=
+a&&c.minPx){var b=c.getResolution(),d=c.getMaxExtent({restricted:!0}),b=new OpenLayers.LonLat((a.x-c.minPx.x)*b+d.left,(c.minPx.y-a.y)*b+d.top);this.wrapDateLine&&(b=b.wrapDateLine(this.maxExtent))}return b},getViewPortPxFromLonLat:function(a,b){var c=null;null!=a&&(b=b||this.map.getResolution(),c=this.map.calculateBounds(null,b),c=new OpenLayers.Pixel(1/b*(a.lon-c.left),1/b*(c.top-a.lat)));return c},setOpacity:function(a){if(a!=this.opacity){this.opacity=a;for(var b=this.div.childNodes,c=0,d=b.length;c<
+d;++c){var e=b[c].firstChild||b[c],f=b[c].lastChild;f&&"iframe"===f.nodeName.toLowerCase()&&(e=f.parentNode);OpenLayers.Util.modifyDOMElement(e,null,null,null,null,null,null,a)}null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"})}},getZIndex:function(){return this.div.style.zIndex},setZIndex:function(a){this.div.style.zIndex=a},adjustBounds:function(a){if(this.gutter){var b=this.gutter*this.map.getResolution();a=new OpenLayers.Bounds(a.left-b,a.bottom-b,a.right+
+b,a.top+b)}this.wrapDateLine&&(b={rightTolerance:this.getResolution(),leftTolerance:this.getResolution()},a=a.wrapDateLine(this.maxExtent,b));return a},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var a=null;return a=this.sphericalMercator?this.map.calculateBounds():OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this)},getLonLatFromViewPortPx:function(a){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments)},getViewPortPxFromLonLat:function(a){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments)},initMercatorParameters:function(){this.RESOLUTIONS=[];for(var a=0;a<=this.MAX_ZOOM_LEVEL;++a)this.RESOLUTIONS[a]=
+156543.03390625/Math.pow(2,a);this.units="m";this.projection=this.projection||"EPSG:900913"},forwardMercator:function(){var a=new OpenLayers.Projection("EPSG:4326"),b=new OpenLayers.Projection("EPSG:900913");return function(c,d){var e=OpenLayers.Projection.transform({x:c,y:d},a,b);return new OpenLayers.LonLat(e.x,e.y)}}(),inverseMercator:function(){var a=new OpenLayers.Projection("EPSG:4326"),b=new OpenLayers.Projection("EPSG:900913");return function(c,d){var e=OpenLayers.Projection.transform({x:c,
+y:d},b,a);return new OpenLayers.LonLat(e.x,e.y)}}()};OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:!0,isBaseLayer:!0,isFixed:!0,pane:null,mapObject:null,initialize:function(a,b){OpenLayers.Layer.prototype.initialize.apply(this,arguments);null==this.pane&&(this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane"))},destroy:function(){this.pane=this.mapObject=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},setMap:function(a){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=
+parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";"msie"==OpenLayers.BROWSER_NAME&&(this.pane.style.background="url("+OpenLayers.Util.getImageLocation("blank.gif")+")");this.isFixed?this.map.viewPortDiv.appendChild(this.pane):this.map.layerContainerDiv.appendChild(this.pane);this.loadMapObject();null==this.mapObject&&this.loadWarningMessage()},removeMap:function(a){this.pane&&this.pane.parentNode&&this.pane.parentNode.removeChild(this.pane);
+OpenLayers.Layer.prototype.removeMap.apply(this,arguments)},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var a=this.map.getSize(),b=Math.min(a.w,300),c=Math.min(a.h,200),b=new OpenLayers.Size(b,c),a=(new OpenLayers.Pixel(a.w/2,a.h/2)).add(-b.w/2,-b.h/2),a=OpenLayers.Util.createDiv(this.name+"_warning",a,b,null,null,null,"auto");a.style.padding="7px";a.style.backgroundColor="yellow";a.innerHTML=this.getWarningHTML();this.div.appendChild(a)},getWarningHTML:function(){return""},
+display:function(a){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display},setZIndex:function(a){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1},moveByPx:function(a,b){OpenLayers.Layer.prototype.moveByPx.apply(this,arguments);this.dragPanMapObject?this.dragPanMapObject(a,-b):this.moveTo(this.map.getCachedCenter())},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,
+arguments);if(null!=this.mapObject){var d=this.map.getCenter(),e=this.map.getZoom();if(null!=d){var f=this.getMapObjectCenter(),f=this.getOLLonLatFromMapObjectLonLat(f),g=this.getMapObjectZoom(),g=this.getOLZoomFromMapObjectZoom(g);d.equals(f)&&e==g||(!b&&f&&this.dragPanMapObject&&this.smoothDragPan?(e=this.map.getViewPortPxFromLonLat(f),d=this.map.getViewPortPxFromLonLat(d),this.dragPanMapObject(d.x-e.x,e.y-d.y)):(d=this.getMapObjectLonLatFromOLLonLat(d),e=this.getMapObjectZoomFromOLZoom(e),this.setMapObjectCenter(d,
+e,c)))}}},getLonLatFromViewPortPx:function(a){var b=null;null!=this.mapObject&&null!=this.getMapObjectCenter()&&(a=this.getMapObjectPixelFromOLPixel(a),a=this.getMapObjectLonLatFromMapObjectPixel(a),b=this.getOLLonLatFromMapObjectLonLat(a));return b},getViewPortPxFromLonLat:function(a){var b=null;null!=this.mapObject&&null!=this.getMapObjectCenter()&&(a=this.getMapObjectLonLatFromOLLonLat(a),a=this.getMapObjectPixelFromMapObjectLonLat(a),b=this.getOLPixelFromMapObjectPixel(a));return b},getOLLonLatFromMapObjectLonLat:function(a){var b=
+null;null!=a&&(b=this.getLongitudeFromMapObjectLonLat(a),a=this.getLatitudeFromMapObjectLonLat(a),b=new OpenLayers.LonLat(b,a));return b},getMapObjectLonLatFromOLLonLat:function(a){var b=null;null!=a&&(b=this.getMapObjectLonLatFromLonLat(a.lon,a.lat));return b},getOLPixelFromMapObjectPixel:function(a){var b=null;null!=a&&(b=this.getXFromMapObjectPixel(a),a=this.getYFromMapObjectPixel(a),b=new OpenLayers.Pixel(b,a));return b},getMapObjectPixelFromOLPixel:function(a){var b=null;null!=a&&(b=this.getMapObjectPixelFromXY(a.x,
+a.y));return b},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){for(var a=["minZoomLevel","maxZoomLevel","numZoomLevels"],b=0,c=a.length;b<c;b++){var d=a[b];this[d]=null!=this.options[d]?this.options[d]:this.map[d]}if(null==this.minZoomLevel||this.minZoomLevel<this.MIN_ZOOM_LEVEL)this.minZoomLevel=this.MIN_ZOOM_LEVEL;a=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;b=null==this.options.numZoomLevels&&null!=this.options.maxZoomLevel||null==this.numZoomLevels&&null!=this.maxZoomLevel?
+this.maxZoomLevel-this.minZoomLevel+1:this.numZoomLevels;this.numZoomLevels=null!=b?Math.min(b,a):a;this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(null!=this.RESOLUTIONS){a=0;this.resolutions=[];for(b=this.minZoomLevel;b<=this.maxZoomLevel;b++)this.resolutions[a++]=this.RESOLUTIONS[b];this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1]}},getResolution:function(){if(null!=this.resolutions)return OpenLayers.Layer.prototype.getResolution.apply(this,
+arguments);var a=null,b=this.map.getSize(),c=this.getExtent();null!=b&&null!=c&&(a=Math.max(c.getWidth()/b.w,c.getHeight()/b.h));return a},getExtent:function(){var a=this.map.getSize(),b=this.getLonLatFromViewPortPx({x:0,y:0}),a=this.getLonLatFromViewPortPx({x:a.w,y:a.h});return null!=b&&null!=a?new OpenLayers.Bounds(b.lon,a.lat,a.lon,b.lat):null},getZoomForResolution:function(a){if(null!=this.resolutions)return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);var b=OpenLayers.Layer.prototype.getExtent.apply(this,
+[]);return this.getZoomForExtent(b)},getOLZoomFromMapObjectZoom:function(a){var b=null;null!=a&&(b=a-this.minZoomLevel,this.map.baseLayer!==this&&(b=this.map.baseLayer.getZoomForResolution(this.getResolutionForZoom(b))));return b},getMapObjectZoomFromOLZoom:function(a){var b=null;null!=a&&(b=a+this.minZoomLevel,this.map.baseLayer!==this&&(b=this.getZoomForResolution(this.map.baseLayer.getResolutionForZoom(b))));return b},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:21,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5,2.145767211914062E-5,1.072883605957031E-5,5.36441802978515E-6,2.68220901489257E-6,1.341104507446289E-6,6.705522537231445E-7],
+type:null,wrapDateLine:!0,sphericalMercator:!1,version:null,initialize:function(a,b){b=b||{};b.version||(b.version="function"===typeof GMap2?"2":"3");var c=OpenLayers.Layer.Google["v"+b.version.replace(/\./g,"_")];if(c)OpenLayers.Util.applyDefaults(b,c);else throw"Unsupported Google Maps API version: "+b.version;OpenLayers.Util.applyDefaults(b,c.DEFAULTS);b.maxExtent&&(b.maxExtent=b.maxExtent.clone());OpenLayers.Layer.EventPane.prototype.initialize.apply(this,[a,b]);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,
+[a,b]);this.sphericalMercator&&(OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator),this.initMercatorParameters())},clone:function(){return new OpenLayers.Layer.Google(this.name,this.getOptions())},setVisibility:function(a){var b=null==this.opacity?1:this.opacity;OpenLayers.Layer.EventPane.prototype.setVisibility.apply(this,arguments);this.setOpacity(b)},display:function(a){this._dragging||this.setGMapVisibility(a);OpenLayers.Layer.EventPane.prototype.display.apply(this,arguments)},moveTo:function(a,
+b,c){this._dragging=c;OpenLayers.Layer.EventPane.prototype.moveTo.apply(this,arguments);delete this._dragging},setOpacity:function(a){a!==this.opacity&&(null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"}),this.opacity=a);if(this.getVisibility()){var b=this.getMapContainer();OpenLayers.Util.modifyDOMElement(b,null,null,null,null,null,null,a)}},destroy:function(){if(this.map){this.setGMapVisibility(!1);var a=OpenLayers.Layer.Google.cache[this.map.id];a&&1>=a.count&&
+this.removeGMapElements()}OpenLayers.Layer.EventPane.prototype.destroy.apply(this,arguments)},removeGMapElements:function(){var a=OpenLayers.Layer.Google.cache[this.map.id];if(a){var b=this.mapObject&&this.getMapContainer();b&&b.parentNode&&b.parentNode.removeChild(b);(b=a.termsOfUse)&&b.parentNode&&b.parentNode.removeChild(b);(a=a.poweredBy)&&a.parentNode&&a.parentNode.removeChild(a);this.mapObject&&(window.google&&google.maps&&google.maps.event&&google.maps.event.clearListeners)&&google.maps.event.clearListeners(this.mapObject,
+"tilesloaded")}},removeMap:function(a){this.visibility&&this.mapObject&&this.setGMapVisibility(!1);var b=OpenLayers.Layer.Google.cache[a.id];b&&(1>=b.count?(this.removeGMapElements(),delete OpenLayers.Layer.Google.cache[a.id]):--b.count);delete this.termsOfUse;delete this.poweredBy;delete this.mapObject;delete this.dragObject;OpenLayers.Layer.EventPane.prototype.removeMap.apply(this,arguments)},getOLBoundsFromMapObjectBounds:function(a){var b=null;null!=a&&(b=a.getSouthWest(),a=a.getNorthEast(),this.sphericalMercator?
+(b=this.forwardMercator(b.lng(),b.lat()),a=this.forwardMercator(a.lng(),a.lat())):(b=new OpenLayers.LonLat(b.lng(),b.lat()),a=new OpenLayers.LonLat(a.lng(),a.lat())),b=new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat));return b},getWarningHTML:function(){return OpenLayers.i18n("googleWarning")},getMapObjectCenter:function(){return this.mapObject.getCenter()},getMapObjectZoom:function(){return this.mapObject.getZoom()},getLongitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.lng(),
+a.lat()).lon:a.lng()},getLatitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.lng(),a.lat()).lat:a.lat()},getXFromMapObjectPixel:function(a){return a.x},getYFromMapObjectPixel:function(a){return a.y},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Google.cache={};
+OpenLayers.Layer.Google.v2={termsOfUse:null,poweredBy:null,dragObject:null,loadMapObject:function(){this.type||(this.type=G_NORMAL_MAP);var a,b,c,d=OpenLayers.Layer.Google.cache[this.map.id];if(d)a=d.mapObject,b=d.termsOfUse,c=d.poweredBy,++d.count;else{var d=this.map.viewPortDiv,e=document.createElement("div");e.id=this.map.id+"_GMap2Container";e.style.position="absolute";e.style.width="100%";e.style.height="100%";d.appendChild(e);try{a=new GMap2(e),b=e.lastChild,d.appendChild(b),b.style.zIndex=
+"1100",b.style.right="",b.style.bottom="",b.className="olLayerGoogleCopyright",c=e.lastChild,d.appendChild(c),c.style.zIndex="1100",c.style.right="",c.style.bottom="",c.className="olLayerGooglePoweredBy gmnoprint"}catch(f){throw f;}OpenLayers.Layer.Google.cache[this.map.id]={mapObject:a,termsOfUse:b,poweredBy:c,count:1}}this.mapObject=a;this.termsOfUse=b;this.poweredBy=c;-1===OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)&&this.mapObject.addMapType(this.type);"function"==typeof a.getDragObject?
+this.dragObject=a.getDragObject():this.dragPanMapObject=null;!1===this.isBaseLayer&&this.setGMapVisibility("none"!==this.div.style.display)},onMapResize:function(){if(this.visibility&&this.mapObject.isLoaded())this.mapObject.checkResize();else{if(!this._resized)var a=this,b=GEvent.addListener(this.mapObject,"load",function(){GEvent.removeListener(b);delete a._resized;a.mapObject.checkResize();a.moveTo(a.map.getCenter(),a.map.getZoom())});this._resized=!0}},setGMapVisibility:function(a){var b=OpenLayers.Layer.Google.cache[this.map.id];
+if(b){var c=this.mapObject.getContainer();!0===a?(this.mapObject.setMapType(this.type),c.style.display="",this.termsOfUse.style.left="",this.termsOfUse.style.display="",this.poweredBy.style.display="",b.displayed=this.id):(b.displayed===this.id&&delete b.displayed,b.displayed||(c.style.display="none",this.termsOfUse.style.display="none",this.termsOfUse.style.left="-9999px",this.poweredBy.style.display="none"))}},getMapContainer:function(){return this.mapObject.getContainer()},getMapObjectBoundsFromOLBounds:function(a){var b=
+null;null!=a&&(b=this.sphericalMercator?this.inverseMercator(a.bottom,a.left):new OpenLayers.LonLat(a.bottom,a.left),a=this.sphericalMercator?this.inverseMercator(a.top,a.right):new OpenLayers.LonLat(a.top,a.right),b=new GLatLngBounds(new GLatLng(b.lat,b.lon),new GLatLng(a.lat,a.lon)));return b},setMapObjectCenter:function(a,b){this.mapObject.setCenter(a,b)},dragPanMapObject:function(a,b){this.dragObject.moveBy(new GSize(-a,b))},getMapObjectLonLatFromMapObjectPixel:function(a){return this.mapObject.fromContainerPixelToLatLng(a)},
+getMapObjectPixelFromMapObjectLonLat:function(a){return this.mapObject.fromLatLngToContainerPixel(a)},getMapObjectZoomFromMapObjectBounds:function(a){return this.mapObject.getBoundsZoomLevel(a)},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),c=new GLatLng(c.lat,c.lon)):c=new GLatLng(b,a);return c},getMapObjectPixelFromXY:function(a,b){return new GPoint(a,b)}};OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(a){window.ActiveXObject&&(this.xmldom=new ActiveXObject("Microsoft.XMLDOM"));OpenLayers.Format.prototype.initialize.apply(this,[a]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var b in this.namespaces)this.namespaceAlias[this.namespaces[b]]=b},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,
+arguments)},setNamespace:function(a,b){this.namespaces[a]=b;this.namespaceAlias[b]=a},read:function(a){var b=a.indexOf("<");0<b&&(a=a.substring(b));b=OpenLayers.Util.Try(OpenLayers.Function.bind(function(){var b;b=window.ActiveXObject&&!this.xmldom?new ActiveXObject("Microsoft.XMLDOM"):this.xmldom;b.loadXML(a);return b},this),function(){return(new DOMParser).parseFromString(a,"text/xml")},function(){var b=new XMLHttpRequest;b.open("GET","data:text/xml;charset=utf-8,"+encodeURIComponent(a),!1);b.overrideMimeType&&
+b.overrideMimeType("text/xml");b.send(null);return b.responseXML});this.keepData&&(this.data=b);return b},write:function(a){if(this.xmldom)a=a.xml;else{var b=new XMLSerializer;if(1==a.nodeType){var c=document.implementation.createDocument("","",null);c.importNode&&(a=c.importNode(a,!0));c.appendChild(a);a=b.serializeToString(c)}else a=b.serializeToString(a)}return a},createElementNS:function(a,b){return this.xmldom?"string"==typeof a?this.xmldom.createNode(1,b,a):this.xmldom.createNode(1,b,""):document.createElementNS(a,
+b)},createDocumentFragment:function(){return this.xmldom?this.xmldom.createDocumentFragment():document.createDocumentFragment()},createTextNode:function(a){"string"!==typeof a&&(a=String(a));return this.xmldom?this.xmldom.createTextNode(a):document.createTextNode(a)},getElementsByTagNameNS:function(a,b,c){var d=[];if(a.getElementsByTagNameNS)d=a.getElementsByTagNameNS(b,c);else{a=a.getElementsByTagName("*");for(var e,f,g=0,h=a.length;g<h;++g)if(e=a[g],f=e.prefix?e.prefix+":"+c:c,"*"==c||f==e.nodeName)"*"!=
+b&&b!=e.namespaceURI||d.push(e)}return d},getAttributeNodeNS:function(a,b,c){var d=null;if(a.getAttributeNodeNS)d=a.getAttributeNodeNS(b,c);else{a=a.attributes;for(var e,f,g=0,h=a.length;g<h;++g)if(e=a[g],e.namespaceURI==b&&(f=e.prefix?e.prefix+":"+c:c,f==e.nodeName)){d=e;break}}return d},getAttributeNS:function(a,b,c){var d="";if(a.getAttributeNS)d=a.getAttributeNS(b,c)||"";else if(a=this.getAttributeNodeNS(a,b,c))d=a.nodeValue;return d},getChildValue:function(a,b){var c=b||"";if(a)for(var d=a.firstChild;d;d=
+d.nextSibling)switch(d.nodeType){case 3:case 4:c+=d.nodeValue}return c},isSimpleContent:function(a){var b=!0;for(a=a.firstChild;a;a=a.nextSibling)if(1===a.nodeType){b=!1;break}return b},contentType:function(a){var b=!1,c=!1,d=OpenLayers.Format.XML.CONTENT_TYPE.EMPTY;for(a=a.firstChild;a;a=a.nextSibling){switch(a.nodeType){case 1:c=!0;break;case 8:break;default:b=!0}if(c&&b)break}if(c&&b)d=OpenLayers.Format.XML.CONTENT_TYPE.MIXED;else{if(c)return OpenLayers.Format.XML.CONTENT_TYPE.COMPLEX;if(b)return OpenLayers.Format.XML.CONTENT_TYPE.SIMPLE}return d},
+hasAttributeNS:function(a,b,c){var d=!1;return d=a.hasAttributeNS?a.hasAttributeNS(b,c):!!this.getAttributeNodeNS(a,b,c)},setAttributeNS:function(a,b,c,d){if(a.setAttributeNS)a.setAttributeNS(b,c,d);else if(this.xmldom)b?(b=a.ownerDocument.createNode(2,c,b),b.nodeValue=d,a.setAttributeNode(b)):a.setAttribute(c,d);else throw"setAttributeNS not implemented";},createElementNSPlus:function(a,b){b=b||{};var c=b.uri||this.namespaces[b.prefix];c||(c=a.indexOf(":"),c=this.namespaces[a.substring(0,c)]);c||
+(c=this.namespaces[this.defaultPrefix]);c=this.createElementNS(c,a);b.attributes&&this.setAttributes(c,b.attributes);var d=b.value;null!=d&&c.appendChild(this.createTextNode(d));return c},setAttributes:function(a,b){var c,d,e;for(e in b)null!=b[e]&&b[e].toString&&(c=b[e].toString(),d=this.namespaces[e.substring(0,e.indexOf(":"))]||null,this.setAttributeNS(a,d,e,c))},readNode:function(a,b){b||(b={});var c=this.readers[a.namespaceURI?this.namespaceAlias[a.namespaceURI]:this.defaultPrefix];if(c){var d=
+a.localName||a.nodeName.split(":").pop();(c=c[d]||c["*"])&&c.apply(this,[a,b])}return b},readChildNodes:function(a,b){b||(b={});for(var c=a.childNodes,d,e=0,f=c.length;e<f;++e)d=c[e],1==d.nodeType&&this.readNode(d,b);return b},writeNode:function(a,b,c){var d,e=a.indexOf(":");0<e?(d=a.substring(0,e),a=a.substring(e+1)):d=c?this.namespaceAlias[c.namespaceURI]:this.defaultPrefix;b=this.writers[d][a].apply(this,[b]);c&&c.appendChild(b);return b},getChildEl:function(a,b,c){return a&&this.getThisOrNextEl(a.firstChild,
+b,c)},getNextEl:function(a,b,c){return a&&this.getThisOrNextEl(a.nextSibling,b,c)},getThisOrNextEl:function(a,b,c){a:for(;a;a=a.nextSibling)switch(a.nodeType){case 1:if(!(b&&b!==(a.localName||a.nodeName.split(":").pop())||c&&c!==a.namespaceURI))break a;a=null;break a;case 3:if(/^\s*$/.test(a.nodeValue))break;case 4:case 6:case 12:case 10:case 11:a=null;break a}return a||null},lookupNamespaceURI:function(a,b){var c=null;if(a)if(a.lookupNamespaceURI)c=a.lookupNamespaceURI(b);else a:switch(a.nodeType){case 1:if(null!==
+a.namespaceURI&&a.prefix===b){c=a.namespaceURI;break a}if(c=a.attributes.length)for(var d,e=0;e<c;++e)if(d=a.attributes[e],"xmlns"===d.prefix&&d.name==="xmlns:"+b){c=d.value||null;break a}else if("xmlns"===d.name&&null===b){c=d.value||null;break a}c=this.lookupNamespaceURI(a.parentNode,b);break a;case 2:c=this.lookupNamespaceURI(a.ownerElement,b);break a;case 9:c=this.lookupNamespaceURI(a.documentElement,b);break a;case 6:case 12:case 10:case 11:break a;default:c=this.lookupNamespaceURI(a.parentNode,
+b)}return c},getXMLDoc:function(){OpenLayers.Format.XML.document||this.xmldom||(document.implementation&&document.implementation.createDocument?OpenLayers.Format.XML.document=document.implementation.createDocument("","",null):!this.xmldom&&window.ActiveXObject&&(this.xmldom=new ActiveXObject("Microsoft.XMLDOM")));return OpenLayers.Format.XML.document||this.xmldom},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};
+OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Format.XML.document=null;OpenLayers.Format.WFST=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.WFST.DEFAULTS);var b=OpenLayers.Format.WFST["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported WFST version: "+a.version;return new b(a)};OpenLayers.Format.WFST.DEFAULTS={version:"1.0.0"};OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:null,popup:null,initialize:function(a,b,c){this.layer=a;this.lonlat=b;this.data=null!=c?c:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){null!=this.layer&&null!=this.layer.map&&null!=this.popup&&this.layer.map.removePopup(this.popup);null!=this.layer&&null!=this.marker&&this.layer.removeMarker(this.marker);this.data=this.lonlat=this.id=this.layer=null;null!=this.marker&&
+(this.destroyMarker(this.marker),this.marker=null);null!=this.popup&&(this.destroyPopup(this.popup),this.popup=null)},onScreen:function(){var a=!1;null!=this.layer&&null!=this.layer.map&&(a=this.layer.map.getExtent().containsLonLat(this.lonlat));return a},createMarker:function(){null!=this.lonlat&&(this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon));return this.marker},destroyMarker:function(){this.marker.destroy()},createPopup:function(a){null!=this.lonlat&&(this.popup||(this.popup=new (this.popupClass?
+this.popupClass:OpenLayers.Popup.Anchored)(this.id+"_popup",this.lonlat,this.data.popupSize,this.data.popupContentHTML,this.marker?this.marker.icon:null,a)),null!=this.data.overflow&&(this.popup.contentDiv.style.overflow=this.data.overflow),this.popup.feature=this);return this.popup},destroyPopup:function(){this.popup&&(this.popup.feature=null,this.popup.destroy(),this.popup=null)},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:"Unknown",INSERT:"Insert",UPDATE:"Update",DELETE:"Delete"};
+OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",modified:null,initialize:function(a,b,c){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,b]);this.lonlat=null;this.geometry=a?a:null;this.state=null;this.attributes={};b&&(this.attributes=OpenLayers.Util.extend(this.attributes,b));this.style=c?c:null},destroy:function(){this.layer&&(this.layer.removeFeatures(this),this.layer=
+null);this.modified=this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments)},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style)},onScreen:function(a){var b=!1;this.layer&&this.layer.map&&(b=this.layer.map.getExtent(),a?(a=this.geometry.getBounds(),b=b.intersectsBounds(a)):b=b.toGeometry().intersects(this.geometry));return b},getVisibility:function(){return!(this.style&&"none"==this.style.display||!this.layer||
+this.layer&&this.layer.styleMap&&"none"==this.layer.styleMap.createSymbolizer(this,this.renderIntent).display||this.layer&&!this.layer.getVisibility())},createMarker:function(){return null},destroyMarker:function(){},createPopup:function(){return null},atPoint:function(a,b,c){var d=!1;this.geometry&&(d=this.geometry.atPoint(a,b,c));return d},destroyPopup:function(){},move:function(a){if(this.layer&&this.geometry.move){a="OpenLayers.LonLat"==a.CLASS_NAME?this.layer.getViewPortPxFromLonLat(a):a;var b=
+this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat()),c=this.layer.map.getResolution();this.geometry.move(c*(a.x-b.x),c*(b.y-a.y));this.layer.drawFeature(this);return b}},toState:function(a){if(a==OpenLayers.State.UPDATE)switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=a}else if(a==OpenLayers.State.INSERT)switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=a}else if(a==OpenLayers.State.DELETE)switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=
+a}else a==OpenLayers.State.UNKNOWN&&(this.state=a)},CLASS_NAME:"OpenLayers.Feature.Vector"});
+OpenLayers.Feature.Vector.style={"default":{fillColor:"#ee9900",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},select:{fillColor:"blue",fillOpacity:0.4,
+hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},temporary:{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,
+strokeLinecap:"round",strokeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit",fontColor:"#000000",labelAlign:"cm",labelOutlineColor:"white",labelOutlineWidth:3},"delete":{display:"none"}};OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:!1,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:!1,propertyStyles:null,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.rules=[];b&&b.rules&&this.addRules(b.rules);this.setDefaultStyle(a||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){for(var a=0,b=this.rules.length;a<b;a++)this.rules[a].destroy(),
+this.rules[a]=null;this.defaultStyle=this.rules=null},createSymbolizer:function(a){for(var b=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),a),c=this.rules,d,e=[],f=!1,g=0,h=c.length;g<h;g++)d=c[g],d.evaluate(a)&&(d instanceof OpenLayers.Rule&&d.elseFilter?e.push(d):(f=!0,this.applySymbolizer(d,b,a)));if(!1==f&&0<e.length)for(f=!0,g=0,h=e.length;g<h;g++)this.applySymbolizer(e[g],b,a);0<c.length&&!1==f&&(b.display="none");null!=b.label&&"string"!==typeof b.label&&
+(b.label=String(b.label));return b},applySymbolizer:function(a,b,c){var d=c.geometry?this.getSymbolizerPrefix(c.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];a=a.symbolizer[d]||a.symbolizer;!0===this.defaultsPerSymbolizer&&(d=this.defaultStyle,OpenLayers.Util.applyDefaults(a,{pointRadius:d.pointRadius}),!0!==a.stroke&&!0!==a.graphic||OpenLayers.Util.applyDefaults(a,{strokeWidth:d.strokeWidth,strokeColor:d.strokeColor,strokeOpacity:d.strokeOpacity,strokeDashstyle:d.strokeDashstyle,strokeLinecap:d.strokeLinecap}),
+!0!==a.fill&&!0!==a.graphic||OpenLayers.Util.applyDefaults(a,{fillColor:d.fillColor,fillOpacity:d.fillOpacity}),!0===a.graphic&&OpenLayers.Util.applyDefaults(a,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset}));
+return this.createLiterals(OpenLayers.Util.extend(b,a),c)},createLiterals:function(a,b){var c=OpenLayers.Util.extend({},b.attributes||b.data);OpenLayers.Util.extend(c,this.context);for(var d in this.propertyStyles)a[d]=OpenLayers.Style.createLiteral(a[d],c,b,d);return a},findPropertyStyles:function(){var a={};this.addPropertyStyles(a,this.defaultStyle);for(var b=this.rules,c,d,e=0,f=b.length;e<f;e++){c=b[e].symbolizer;for(var g in c)if(d=c[g],"object"==typeof d)this.addPropertyStyles(a,d);else{this.addPropertyStyles(a,
+c);break}}return a},addPropertyStyles:function(a,b){var c,d;for(d in b)c=b[d],"string"==typeof c&&c.match(/\$\{\w+\}/)&&(a[d]=!0);return a},addRules:function(a){Array.prototype.push.apply(this.rules,a);this.propertyStyles=this.findPropertyStyles()},setDefaultStyle:function(a){this.defaultStyle=a;this.propertyStyles=this.findPropertyStyles()},getSymbolizerPrefix:function(a){for(var b=OpenLayers.Style.SYMBOLIZER_PREFIXES,c=0,d=b.length;c<d;c++)if(-1!=a.CLASS_NAME.indexOf(b[c]))return b[c]},clone:function(){var a=
+OpenLayers.Util.extend({},this);if(this.rules){a.rules=[];for(var b=0,c=this.rules.length;b<c;++b)a.rules.push(this.rules[b].clone())}a.context=this.context&&OpenLayers.Util.extend({},this.context);b=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(b,a)},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(a,b,c,d){"string"==typeof a&&-1!=a.indexOf("${")&&(a=OpenLayers.String.format(a,b,[c,d]),a=isNaN(a)||!a?a:parseFloat(a));return a};
+OpenLayers.Style.SYMBOLIZER_PREFIXES=["Point","Line","Polygon","Text","Raster"];OpenLayers.Filter=OpenLayers.Class({initialize:function(a){OpenLayers.Util.extend(this,a)},destroy:function(){},evaluate:function(a){return!0},clone:function(){return null},toString:function(){return OpenLayers.Format&&OpenLayers.Format.CQL?OpenLayers.Format.CQL.prototype.write(this):Object.prototype.toString.call(this)},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,evaluate:function(a){var b=!1;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(a.geometry){var c=this.value;"OpenLayers.Bounds"==this.value.CLASS_NAME&&(c=this.value.toGeometry());a.geometry.intersects(c)&&(b=!0)}break;default:throw Error("evaluate is not implemented for this filter type.");}return b},clone:function(){var a=
+OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(a)},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,type:"FID",initialize:function(a){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[a])},evaluate:function(a){for(var b=0,c=this.fids.length;b<c;b++)if((a.fid||a.id)==this.fids[b])return!0;return!1},clone:function(){var a=new OpenLayers.Filter.FeatureId;OpenLayers.Util.extend(a,this);a.fids=this.fids.slice();return a},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Format.WFST.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/
XMLSchema-instance",wfs:"http://www.opengis.net/wfs",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows"},defaultPrefix:"wfs",version:null,schemaLocations:null,srsName:null,extractAttributes:!0,xy:!0,stateName:null,initialize:function(a){this.stateName={};this.stateName[OpenLayers.State.INSERT]="wfs:Insert";this.stateName[OpenLayers.State.UPDATE]=
+"wfs:Update";this.stateName[OpenLayers.State.DELETE]="wfs:Delete";OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},getSrsName:function(a,b){var c=b&&b.srsName;c||(c=a&&a.layer?a.layer.projection.getCode():this.srsName);return c},read:function(a,b){b=b||{};OpenLayers.Util.applyDefaults(b,{output:"features"});"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var c={};a&&this.readNode(a,c,!0);c.features&&"features"===b.output&&
+(c=c.features);return c},readers:{wfs:{FeatureCollection:function(a,b){b.features=[];this.readChildNodes(a,b)}}},write:function(a,b){var c=this.writeNode("wfs:Transaction",{features:a,options:b}),d=this.schemaLocationAttr();d&&this.setAttributeNS(c,this.namespaces.xsi,"xsi:schemaLocation",d);return OpenLayers.Format.XML.prototype.write.apply(this,[c])},writers:{wfs:{GetFeature:function(a){var b=this.createElementNSPlus("wfs:GetFeature",{attributes:{service:"WFS",version:this.version,handle:a&&a.handle,
+outputFormat:a&&a.outputFormat,maxFeatures:a&&a.maxFeatures,"xsi:schemaLocation":this.schemaLocationAttr(a)}});if("string"==typeof this.featureType)this.writeNode("Query",a,b);else for(var c=0,d=this.featureType.length;c<d;c++)a.featureType=this.featureType[c],this.writeNode("Query",a,b);return b},Transaction:function(a){a=a||{};var b=a.options||{},c=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version,handle:b.handle}}),d,e=a.features;if(e){!0===b.multi&&OpenLayers.Util.extend(this.geometryTypes,
+{"OpenLayers.Geometry.Point":"MultiPoint","OpenLayers.Geometry.LineString":!0===this.multiCurve?"MultiCurve":"MultiLineString","OpenLayers.Geometry.Polygon":!0===this.multiSurface?"MultiSurface":"MultiPolygon"});var f,g;a=0;for(d=e.length;a<d;++a)g=e[a],(f=this.stateName[g.state])&&this.writeNode(f,{feature:g,options:b},c);!0===b.multi&&this.setGeometryTypes()}if(b.nativeElements)for(a=0,d=b.nativeElements.length;a<d;++a)this.writeNode("wfs:Native",b.nativeElements[a],c);return c},Native:function(a){return this.createElementNSPlus("wfs:Native",
+{attributes:{vendorId:a.vendorId,safeToIgnore:a.safeToIgnore},value:a.value})},Insert:function(a){var b=a.feature;a=a.options;a=this.createElementNSPlus("wfs:Insert",{attributes:{handle:a&&a.handle}});this.srsName=this.getSrsName(b);this.writeNode("feature:_typeName",b,a);return a},Update:function(a){var b=a.feature;a=a.options;a=this.createElementNSPlus("wfs:Update",{attributes:{handle:a&&a.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+this.featureType}});this.featureNS&&a.setAttribute("xmlns:"+
+this.featurePrefix,this.featureNS);var c=b.modified;null===this.geometryName||c&&void 0===c.geometry||(this.srsName=this.getSrsName(b),this.writeNode("Property",{name:this.geometryName,value:b.geometry},a));for(var d in b.attributes)void 0===b.attributes[d]||c&&c.attributes&&(!c.attributes||void 0===c.attributes[d])||this.writeNode("Property",{name:d,value:b.attributes[d]},a);this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[b.fid]}),a);return a},Property:function(a){var b=this.createElementNSPlus("wfs:Property");
+this.writeNode("Name",a.name,b);null!==a.value&&this.writeNode("Value",a.value,b);return b},Name:function(a){return this.createElementNSPlus("wfs:Name",{value:a})},Value:function(a){var b;a instanceof OpenLayers.Geometry?(b=this.createElementNSPlus("wfs:Value"),a=this.writeNode("feature:_geometry",a).firstChild,b.appendChild(a)):b=this.createElementNSPlus("wfs:Value",{value:a});return b},Delete:function(a){var b=a.feature;a=a.options;a=this.createElementNSPlus("wfs:Delete",{attributes:{handle:a&&
+a.handle,typeName:(this.featureNS?this.featurePrefix+":":"")+this.featureType}});this.featureNS&&a.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[b.fid]}),a);return a}}},schemaLocationAttr:function(a){a=OpenLayers.Util.extend({featurePrefix:this.featurePrefix,schema:this.schema},a);var b=OpenLayers.Util.extend({},this.schemaLocations);a.schema&&(b[a.featurePrefix]=a.schema);a=[];var c,d;for(d in b)(c=this.namespaces[d])&&
+a.push(c+" "+b[d]);return a.join(" ")||void 0},setFilterProperty:function(a){if(a.filters)for(var b=0,c=a.filters.length;b<c;++b)OpenLayers.Format.WFST.v1.prototype.setFilterProperty.call(this,a.filters[b]);else a instanceof OpenLayers.Filter.Spatial&&!a.property&&(a.property=this.geometryName)},CLASS_NAME:"OpenLayers.Format.WFST.v1"});OpenLayers.Format.OGCExceptionReport=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},defaultPrefix:"ogc",read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b={exceptionReport:null};a.documentElement&&(this.readChildNodes(a,b),null===b.exceptionReport&&(b=(new OpenLayers.Format.OWSCommon).read(a)));return b},readers:{ogc:{ServiceExceptionReport:function(a,
+b){b.exceptionReport={exceptions:[]};this.readChildNodes(a,b.exceptionReport)},ServiceException:function(a,b){var c={code:a.getAttribute("code"),locator:a.getAttribute("locator"),text:this.getChildValue(a)};b.exceptions.push(c)}}},CLASS_NAME:"OpenLayers.Format.OGCExceptionReport"});OpenLayers.Format.XML.VersionedOGC=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:null,version:null,profile:null,allowFallback:!1,name:null,stringifyOutput:!1,parser:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);a=this.CLASS_NAME;this.name=a.substring(a.lastIndexOf(".")+1)},getVersion:function(a,b){var c;a?(c=this.version,c||(c=a.getAttribute("version"),c||(c=this.defaultVersion))):c=b&&b.version||this.version||this.defaultVersion;return c},getParser:function(a){a=
+a||this.defaultVersion;var b=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.VERSION!=a){var c=OpenLayers.Format[this.name]["v"+a.replace(/\./g,"_")+b];if(!c&&(""!==b&&this.allowFallback&&(b="",c=OpenLayers.Format[this.name]["v"+a.replace(/\./g,"_")]),!c))throw"Can't find a "+this.name+" parser for version "+a+b;this.parser=new c(this.options)}return this.parser},write:function(a,b){var c=this.getVersion(null,b);this.parser=this.getParser(c);c=this.parser.write(a,b);return!1===this.stringifyOutput?
+c:OpenLayers.Format.XML.prototype.write.apply(this,[c])},read:function(a,b){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var c=this.getVersion(a.documentElement);this.parser=this.getParser(c);var d=this.parser.read(a,b),e=this.parser.errorProperty||null;null!==e&&void 0===d[e]&&(e=new OpenLayers.Format.OGCExceptionReport,d.error=e.read(a));d.version=c;return d},CLASS_NAME:"OpenLayers.Format.XML.VersionedOGC"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(a){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[a])},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this)},evaluate:function(a){var b,c;switch(this.type){case OpenLayers.Filter.Logical.AND:b=0;for(c=this.filters.length;b<c;b++)if(!1==this.filters[b].evaluate(a))return!1;return!0;case OpenLayers.Filter.Logical.OR:b=0;for(c=this.filters.length;b<
+c;b++)if(!0==this.filters[b].evaluate(a))return!0;return!1;case OpenLayers.Filter.Logical.NOT:return!this.filters[0].evaluate(a)}},clone:function(){for(var a=[],b=0,c=this.filters.length;b<c;++b)a.push(this.filters[b].clone());return new OpenLayers.Filter.Logical({type:this.type,filters:a})},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:!0,lowerBoundary:null,upperBoundary:null,initialize:function(a){OpenLayers.Filter.prototype.initialize.apply(this,[a]);this.type===OpenLayers.Filter.Comparison.LIKE&&void 0===a.matchCase&&(this.matchCase=null)},evaluate:function(a){a instanceof OpenLayers.Feature.Vector&&(a=a.attributes);var b=!1;a=a[this.property];switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:b=this.value;
+b=this.matchCase||"string"!=typeof a||"string"!=typeof b?a==b:a.toUpperCase()==b.toUpperCase();break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:b=this.value;b=this.matchCase||"string"!=typeof a||"string"!=typeof b?a!=b:a.toUpperCase()!=b.toUpperCase();break;case OpenLayers.Filter.Comparison.LESS_THAN:b=a<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:b=a>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:b=a<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:b=
+a>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:b=a>=this.lowerBoundary&&a<=this.upperBoundary;break;case OpenLayers.Filter.Comparison.LIKE:b=RegExp(this.value,"gi").test(a);break;case OpenLayers.Filter.Comparison.IS_NULL:b=null===a}return b},value2regex:function(a,b,c){if("."==a)throw Error("'.' is an unsupported wildCard character for OpenLayers.Filter.Comparison");a=a?a:"*";b=b?b:".";this.value=this.value.replace(RegExp("\\"+(c?c:"!")+"(.|$)","g"),"\\$1");this.value=this.value.replace(RegExp("\\"+
+b,"g"),".");this.value=this.value.replace(RegExp("\\"+a,"g"),".*");this.value=this.value.replace(RegExp("\\\\.\\*","g"),"\\"+a);return this.value=this.value.replace(RegExp("\\\\\\.","g"),"\\"+b)},regex2value:function(){var a=this.value,a=a.replace(/!/g,"!!"),a=a.replace(/(\\)?\\\./g,function(a,c){return c?a:"!."}),a=a.replace(/(\\)?\\\*/g,function(a,c){return c?a:"!*"}),a=a.replace(/\\\\/g,"\\");return a=a.replace(/\.\*/g,"*")},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison,
+this)},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_EQUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Comparison.IS_NULL="NULL";OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Filter.Function=OpenLayers.Class(OpenLayers.Filter,{name:null,params:null,CLASS_NAME:"OpenLayers.Filter.Function"});OpenLayers.Date={dateRegEx:/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))|Z)?$/,toISOString:function(){return"toISOString"in Date.prototype?function(a){return a.toISOString()}:functio
n(a){return isNaN(a.getTime())?"Invalid Date":a.getUTCFullYear()+"-"+OpenLayers.Number.zeroPad(a.getUTCMonth()+1,2)+"-"+OpenLayers.Number.zeroPad(a.getUTCDate(),2)+"T"+OpenLayers.Number.zeroPad(a.getUTCHours(),2)+":"+OpenLayers.Number.zeroPad(a.getUTCMinutes(),
+2)+":"+OpenLayers.Number.zeroPad(a.getUTCSeconds(),2)+"."+OpenLayers.Number.zeroPad(a.getUTCMilliseconds(),3)+"Z"}}(),parse:function(a){var b;if((a=a.match(this.dateRegEx))&&(a[1]||a[7])){b=parseInt(a[1],10)||0;var c=parseInt(a[2],10)-1||0,d=parseInt(a[3],10)||1;b=new Date(Date.UTC(b,c,d));if(c=a[7]){var d=parseInt(a[4],10),e=parseInt(a[5],10),f=parseFloat(a[6]),g=f|0,f=Math.round(1E3*(f-g));b.setUTCHours(d,e,g,f);"Z"!==c&&(c=parseInt(c,10),a=parseInt(a[8],10)||0,a=-1E3*(60*60*c+60*a),b=new Date(b.getTime()+
+a))}}else b=new Date("invalid");return b}};OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){var b={};this.readers.ogc.Filter.apply(this,[a,b]);return b.filter},readers:{ogc:{_expression:function(a){for(var b="",c=a.firstChild;c;c=
+c.nextSibling)switch(c.nodeType){case 1:a=this.readNode(c);a.property?b+="${"+a.property+"}":void 0!==a.value&&(b+=a.value);break;case 3:case 4:b+=c.nodeValue}return b},Filter:function(a,b){var c={fids:[],filters:[]};this.readChildNodes(a,c);0<c.fids.length?b.filter=new OpenLayers.Filter.FeatureId({fids:c.fids}):0<c.filters.length&&(b.filter=c.filters[0])},FeatureId:function(a,b){var c=a.getAttribute("fid");c&&b.fids.push(c)},And:function(a,b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});
+this.readChildNodes(a,c);b.filters.push(c)},Or:function(a,b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(a,c);b.filters.push(c)},Not:function(a,b){var c=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLessThan:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsGreaterThan:function(a,
+b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLessThanOrEqualTo:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsGreaterThanOrEqualTo:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},
+PropertyIsBetween:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(a,c);b.filters.push(c)},Literal:function(a,b){b.value=OpenLayers.String.numericIf(this.getChildValue(a),!0)},PropertyName:function(a,b){b.property=this.getChildValue(a)},LowerBoundary:function(a,b){b.lowerBoundary=OpenLayers.String.numericIf(this.readers.ogc._expression.call(this,a),!0)},UpperBoundary:function(a,b){b.upperBoundary=OpenLayers.String.numericIf(this.readers.ogc._expression.call(this,
+a),!0)},Intersects:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.INTERSECTS)},Within:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.WITHIN)},Contains:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.CONTAINS)},DWithin:function(a,b){this.readSpatial(a,b,OpenLayers.Filter.Spatial.DWITHIN)},Distance:function(a,b){b.distance=parseInt(this.getChildValue(a));b.distanceUnits=a.getAttribute("units")},Function:function(a,b){},PropertyIsNull:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.IS_NULL});
+this.readChildNodes(a,c);b.filters.push(c)}}},readSpatial:function(a,b,c){c=new OpenLayers.Filter.Spatial({type:c});this.readChildNodes(a,c);c.value=c.components[0];delete c.components;b.filters.push(c)},encodeLiteral:function(a){a instanceof Date&&(a=OpenLayers.Date.toISOString(a));return a},writeOgcExpression:function(a,b){a instanceof OpenLayers.Filter.Function?this.writeNode("Function",a,b):this.writeNode("Literal",a,b);return b},write:function(a){return this.writers.ogc.Filter.apply(this,[a])},
+writers:{ogc:{Filter:function(a){var b=this.createElementNSPlus("ogc:Filter");this.writeNode(this.getFilterType(a),a,b);return b},_featureIds:function(a){for(var b=this.createDocumentFragment(),c=0,d=a.fids.length;c<d;++c)this.writeNode("ogc:FeatureId",a.fids[c],b);return b},FeatureId:function(a){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:a}})},And:function(a){for(var b=this.createElementNSPlus("ogc:And"),c,d=0,e=a.filters.length;d<e;++d)c=a.filters[d],this.writeNode(this.getFilterType(c),
+c,b);return b},Or:function(a){for(var b=this.createElementNSPlus("ogc:Or"),c,d=0,e=a.filters.length;d<e;++d)c=a.filters[d],this.writeNode(this.getFilterType(c),c,b);return b},Not:function(a){var b=this.createElementNSPlus("ogc:Not");a=a.filters[0];this.writeNode(this.getFilterType(a),a,b);return b},PropertyIsLessThan:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsGreaterThan:function(a){var b=
+this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsLessThanOrEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsGreaterThanOrEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);
+return b},PropertyIsBetween:function(a){var b=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode("PropertyName",a,b);this.writeNode("LowerBoundary",a,b);this.writeNode("UpperBoundary",a,b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",{value:a.property})},Literal:function(a){return this.createElementNSPlus("ogc:Literal",{value:(this.encodeLiteral||OpenLayers.Format.Filter.v1.prototype.encodeLiteral)(a)})},LowerBoundary:function(a){var b=this.createElementNSPlus("ogc:LowerBoundary");
+this.writeOgcExpression(a.lowerBoundary,b);return b},UpperBoundary:function(a){var b=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode("Literal",a.upperBoundary,b);return b},INTERSECTS:function(a){return this.writeSpatial(a,"Intersects")},WITHIN:function(a){return this.writeSpatial(a,"Within")},CONTAINS:function(a){return this.writeSpatial(a,"Contains")},DWITHIN:function(a){var b=this.writeSpatial(a,"DWithin");this.writeNode("Distance",a,b);return b},Distance:function(a){return this.createElementNSPlus("ogc:Distance",
+{attributes:{units:a.distanceUnits},value:a.distance})},Function:function(a){var b=this.createElementNSPlus("ogc:Function",{attributes:{name:a.name}});a=a.params;for(var c=0,d=a.length;c<d;c++)this.writeOgcExpression(a[c],b);return b},PropertyIsNull:function(a){var b=this.createElementNSPlus("ogc:PropertyIsNull");this.writeNode("PropertyName",a,b);return b}}},getFilterType:function(a){var b=this.filterMap[a.type];if(!b)throw"Filter writing not supported for rule type: "+a.type;return b},filterMap:{"&&":"And",
+"||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike",NULL:"PropertyIsNull",BBOX:"BBOX",DWITHIN:"DWITHIN",WITHIN:"WITHIN",CONTAINS:"CONTAINS",INTERSECTS:"INTERSECTS",FID:"_featureIds"},CLASS_NAME:"OpenLayers.Format.Filter.v1"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){this.bounds=this.id=null},clone:function(){return new OpenLayers.Geometry},setBounds:function(a){a&&(this.bounds=a.clone())},clearBounds:function(){this.bounds=null;this.parent&&this.parent.clearBounds()},extendBounds:function(a){this.getBounds()?this.bounds.extend(a):this.setBounds(a)},getBounds:function(){null==this.bounds&&this.calculateBounds();
+return this.bounds},calculateBounds:function(){},distanceTo:function(a,b){},getVertices:function(a){},atPoint:function(a,b,c){var d=!1;null!=this.getBounds()&&null!=a&&(b=null!=b?b:0,c=null!=c?c:0,d=(new OpenLayers.Bounds(this.bounds.left-b,this.bounds.bottom-c,this.bounds.right+b,this.bounds.top+c)).containsLonLat(a));return d},getLength:function(){return 0},getArea:function(){return 0},getCentroid:function(){return null},toString:function(){return OpenLayers.Format&&OpenLayers.Format.WKT?OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this)):
+Object.prototype.toString.call(this)},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(a){var b;if(OpenLayers.Format&&OpenLayers.Format.WKT){var c=OpenLayers.Geometry.fromWKT.format;c||(c=new OpenLayers.Format.WKT,OpenLayers.Geometry.fromWKT.format=c);a=c.read(a);if(a instanceof OpenLayers.Feature.Vector)b=a.geometry;else if(OpenLayers.Util.isArray(a)){b=a.length;for(var c=Array(b),d=0;d<b;++d)c[d]=a[d].geometry;b=new OpenLayers.Geometry.Collection(c)}}return b};
+OpenLayers.Geometry.segmentsIntersect=function(a,b,c){var d=c&&c.point;c=c&&c.tolerance;var e=!1,f=a.x1-b.x1,g=a.y1-b.y1,h=a.x2-a.x1,k=a.y2-a.y1,l=b.y2-b.y1,m=b.x2-b.x1,n=l*h-m*k,l=m*g-l*f,g=h*g-k*f;0==n?0==l&&0==g&&(e=!0):(f=l/n,n=g/n,0<=f&&(1>=f&&0<=n&&1>=n)&&(d?(h=a.x1+f*h,n=a.y1+f*k,e=new OpenLayers.Geometry.Point(h,n)):e=!0));if(c)if(e){if(d)a:for(a=[a,b],b=0;2>b;++b)for(f=a[b],k=1;3>k;++k)if(h=f["x"+k],n=f["y"+k],d=Math.sqrt(Math.pow(h-e.x,2)+Math.pow(n-e.y,2)),d<c){e.x=h;e.y=n;break a}}else a:for(a=
+[a,b],b=0;2>b;++b)for(h=a[b],n=a[(b+1)%2],k=1;3>k;++k)if(f={x:h["x"+k],y:h["y"+k]},g=OpenLayers.Geometry.distanceToSegment(f,n),g.distance<c){e=d?new OpenLayers.Geometry.Point(f.x,f.y):!0;break a}return e};OpenLayers.Geometry.distanceToSegment=function(a,b){var c=OpenLayers.Geometry.distanceSquaredToSegment(a,b);c.distance=Math.sqrt(c.distance);return c};
+OpenLayers.Geometry.distanceSquaredToSegment=function(a,b){var c=a.x,d=a.y,e=b.x1,f=b.y1,g=b.x2,h=b.y2,k=g-e,l=h-f,m=(k*(c-e)+l*(d-f))/(Math.pow(k,2)+Math.pow(l,2));0>=m||(1<=m?(e=g,f=h):(e+=m*k,f+=m*l));return{distance:Math.pow(e-c,2)+Math.pow(f-d,2),x:e,y:f,along:m}};OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(a,b){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(a);this.y=parseFloat(b)},clone:function(a){null==a&&(a=new OpenLayers.Geometry.Point(this.x,this.y));OpenLayers.Util.applyDefaults(a,this);return a},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y)},distanceTo:function(a,b){var c=!(b&&!1===b.edge)&&b&&b.details,d,e,f,g,h;a instanceof
+OpenLayers.Geometry.Point?(e=this.x,f=this.y,g=a.x,h=a.y,d=Math.sqrt(Math.pow(e-g,2)+Math.pow(f-h,2)),d=c?{x0:e,y0:f,x1:g,y1:h,distance:d}:d):(d=a.distanceTo(this,b),c&&(d={x0:d.x1,y0:d.y1,x1:d.x0,y1:d.y0,distance:d.distance}));return d},equals:function(a){var b=!1;null!=a&&(b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y));return b},toShortString:function(){return this.x+", "+this.y},move:function(a,b){this.x+=a;this.y+=b;this.clearBounds()},rotate:function(a,b){a*=
+Math.PI/180;var c=this.distanceTo(b),d=a+Math.atan2(this.y-b.y,this.x-b.x);this.x=b.x+c*Math.cos(d);this.y=b.y+c*Math.sin(d);this.clearBounds()},getCentroid:function(){return new OpenLayers.Geometry.Point(this.x,this.y)},resize:function(a,b,c){this.x=b.x+a*(void 0==c?1:c)*(this.x-b.x);this.y=b.y+a*(this.y-b.y);this.clearBounds();return this},intersects:function(a){var b=!1;return b="OpenLayers.Geometry.Point"==a.CLASS_NAME?this.equals(a):a.intersects(this)},transform:function(a,b){a&&b&&(OpenLayers.Projection.transform(this,
+a,b),this.bounds=null);return this},getVertices:function(a){return[this]},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(a){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];null!=a&&this.addComponents(a)},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments)},clone:function(){for(var a=eval("new "+this.CLASS_NAME+"()"),b=0,c=this.components.length;b<c;b++)a.addComponent(this.components[b].clone());
+OpenLayers.Util.applyDefaults(a,this);return a},getComponentsString:function(){for(var a=[],b=0,c=this.components.length;b<c;b++)a.push(this.components[b].toShortString());return a.join(",")},calculateBounds:function(){this.bounds=null;var a=new OpenLayers.Bounds,b=this.components;if(b)for(var c=0,d=b.length;c<d;c++)a.extend(b[c].getBounds());null!=a.left&&(null!=a.bottom&&null!=a.right&&null!=a.top)&&this.setBounds(a)},addComponents:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=0,c=a.length;b<
+c;b++)this.addComponent(a[b])},addComponent:function(a,b){var c=!1;if(a&&(null==this.componentTypes||-1<OpenLayers.Util.indexOf(this.componentTypes,a.CLASS_NAME))){if(null!=b&&b<this.components.length){var c=this.components.slice(0,b),d=this.components.slice(b,this.components.length);c.push(a);this.components=c.concat(d)}else this.components.push(a);a.parent=this;this.clearBounds();c=!0}return c},removeComponents:function(a){var b=!1;OpenLayers.Util.isArray(a)||(a=[a]);for(var c=a.length-1;0<=c;--c)b=
+this.removeComponent(a[c])||b;return b},removeComponent:function(a){OpenLayers.Util.removeItem(this.components,a);this.clearBounds();return!0},getLength:function(){for(var a=0,b=0,c=this.components.length;b<c;b++)a+=this.components[b].getLength();return a},getArea:function(){for(var a=0,b=0,c=this.components.length;b<c;b++)a+=this.components[b].getArea();return a},getGeodesicArea:function(a){for(var b=0,c=0,d=this.components.length;c<d;c++)b+=this.components[c].getGeodesicArea(a);return b},getCentroid:function(a){if(!a)return this.components.length&&
+this.components[0].getCentroid();a=this.components.length;if(!a)return!1;for(var b=[],c=[],d=0,e=Number.MAX_VALUE,f,g=0;g<a;++g){f=this.components[g];var h=f.getArea();f=f.getCentroid(!0);isNaN(h)||(isNaN(f.x)||isNaN(f.y))||(b.push(h),d+=h,e=h<e&&0<h?h:e,c.push(f))}a=b.length;if(0===d){for(g=0;g<a;++g)b[g]=1;d=b.length}else{for(g=0;g<a;++g)b[g]/=e;d/=e}for(var k=e=0,g=0;g<a;++g)f=c[g],h=b[g],e+=f.x*h,k+=f.y*h;return new OpenLayers.Geometry.Point(e/d,k/d)},getGeodesicLength:function(a){for(var b=0,
+c=0,d=this.components.length;c<d;c++)b+=this.components[c].getGeodesicLength(a);return b},move:function(a,b){for(var c=0,d=this.components.length;c<d;c++)this.components[c].move(a,b)},rotate:function(a,b){for(var c=0,d=this.components.length;c<d;++c)this.components[c].rotate(a,b)},resize:function(a,b,c){for(var d=0;d<this.components.length;++d)this.components[d].resize(a,b,c);return this},distanceTo:function(a,b){for(var c=!(b&&!1===b.edge)&&b&&b.details,d,e,f,g=Number.POSITIVE_INFINITY,h=0,k=this.components.length;h<
+k&&!(d=this.components[h].distanceTo(a,b),f=c?d.distance:d,f<g&&(g=f,e=d,0==g));++h);return e},equals:function(a){var b=!0;if(a&&a.CLASS_NAME&&this.CLASS_NAME==a.CLASS_NAME)if(OpenLayers.Util.isArray(a.components)&&a.components.length==this.components.length)for(var c=0,d=this.components.length;c<d;++c){if(!this.components[c].equals(a.components[c])){b=!1;break}}else b=!1;else b=!1;return b},transform:function(a,b){if(a&&b){for(var c=0,d=this.components.length;c<d;c++)this.components[c].transform(a,
+b);this.bounds=null}return this},intersects:function(a){for(var b=!1,c=0,d=this.components.length;c<d&&!(b=a.intersects(this.components[c]));++c);return b},getVertices:function(a){for(var b=[],c=0,d=this.components.length;c<d;++c)Array.prototype.push.apply(b,this.components[c].getVertices(a));return b},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],addPoint:function(a,b){this.addComponent(a,b)},removePoint:function(a){this.removeComponent(a)},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],getLength:function(){var a=0;if(this.components&&1<this.components.length)for(var b=1,c=this.components.length;b<c;b++)a+=this.components[b-1].distanceTo(this.components[b]);return a},getGeodesicLength:function(a){var b=this;if(a){var c=new OpenLayers.
Projection("EPSG:4326");c.equals(a)||(b=this.clone().transform(a,c))}a=0;if(b.components&&1<b.components.length)for(var d,e=1,f=b.components.length;e<
+f;e++)c=b.components[e-1],d=b.components[e],a+=OpenLayers.Util.distVincenty({lon:c.x,lat:c.y},{lon:d.x,lat:d.y});return 1E3*a},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{removeComponent:function(a){var b=this.components&&2<this.components.length;b&&OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);return b},intersects:function(a){var b=!1,c=a.CLASS_NAME;if("OpenLayers.Geometry.LineString"==c||"OpenLayers.Geometry.LinearRing"==c||"OpenLayers.Geometry.Point"==c){var d=this.getSortedSegments();a="OpenLayers.Geometry.Point"==c?[{x1:a.x,y1:a.y,x2:a.x,y2:a.y}]:a.getSortedSegments();
+var e,f,g,h,k,l,m,n=0,p=d.length;a:for(;n<p;++n){c=d[n];e=c.x1;f=c.x2;g=c.y1;h=c.y2;var q=0,r=a.length;for(;q<r;++q){k=a[q];if(k.x1>f)break;if(!(k.x2<e||(l=k.y1,m=k.y2,Math.min(l,m)>Math.max(g,h)||Math.max(l,m)<Math.min(g,h)||!OpenLayers.Geometry.segmentsIntersect(c,k)))){b=!0;break a}}}}else b=a.intersects(this);return b},getSortedSegments:function(){for(var a=this.components.length-1,b=Array(a),c,d,e=0;e<a;++e)c=this.components[e],d=this.components[e+1],b[e]=c.x<d.x?{x1:c.x,y1:c.y,x2:d.x,y2:d.y}:
+{x1:d.x,y1:d.y,x2:c.x,y2:c.y};return b.sort(function(a,b){return a.x1-b.x1})},splitWithSegment:function(a,b){for(var c=!(b&&!1===b.edge),d=b&&b.tolerance,e=[],f=this.getVertices(),g=[],h=[],k=!1,l,m,n,p={point:!0,tolerance:d},q=null,r=0,s=f.length-2;r<=s;++r)if(d=f[r],g.push(d.clone()),l=f[r+1],m={x1:d.x,y1:d.y,x2:l.x,y2:l.y},m=OpenLayers.Geometry.segmentsIntersect(a,m,p),m instanceof OpenLayers.Geometry.Point&&((n=m.x===a.x1&&m.y===a.y1||m.x===a.x2&&m.y===a.y2||m.equals(d)||m.equals(l)?!0:!1)||c))m.equals(h[h.length-
+1])||h.push(m.clone()),0===r&&m.equals(d)||m.equals(l)||(k=!0,m.equals(d)||g.push(m),e.push(new OpenLayers.Geometry.LineString(g)),g=[m.clone()]);k&&(g.push(l.clone()),e.push(new OpenLayers.Geometry.LineString(g)));if(0<h.length)var t=a.x1<a.x2?1:-1,u=a.y1<a.y2?1:-1,q={lines:e,points:h.sort(function(a,b){return t*a.x-t*b.x||u*a.y-u*b.y})};return q},split:function(a,b){var c=null,d=b&&b.mutual,e,f,g,h;if(a instanceof OpenLayers.Geometry.LineString){var k=this.getVertices(),l,m,n,p,q,r=[];g=[];for(var s=
+0,t=k.length-2;s<=t;++s){l=k[s];m=k[s+1];n={x1:l.x,y1:l.y,x2:m.x,y2:m.y};h=h||[a];d&&r.push(l.clone());for(var u=0;u<h.length;++u)if(p=h[u].splitWithSegment(n,b))if(q=p.lines,0<q.length&&(q.unshift(u,1),Array.prototype.splice.apply(h,q),u+=q.length-2),d)for(var v=0,w=p.points.length;v<w;++v)q=p.points[v],q.equals(l)||(r.push(q),g.push(new OpenLayers.Geometry.LineString(r)),r=q.equals(m)?[]:[q.clone()])}d&&(0<g.length&&0<r.length)&&(r.push(m.clone()),g.push(new OpenLayers.Geometry.LineString(r)))}else c=
+a.splitWith(this,b);h&&1<h.length?f=!0:h=[];g&&1<g.length?e=!0:g=[];if(f||e)c=d?[g,h]:h;return c},splitWith:function(a,b){return a.split(this,b)},getVertices:function(a){return!0===a?[this.components[0],this.components[this.components.length-1]]:!1===a?this.components.slice(1,this.components.length-1):this.components.slice()},distanceTo:function(a,b){var c=!(b&&!1===b.edge)&&b&&b.details,d,e={},f=Number.POSITIVE_INFINITY;if(a instanceof OpenLayers.Geometry.Point){for(var g=this.getSortedSegments(),
+h=a.x,k=a.y,l,m=0,n=g.length;m<n;++m)if(l=g[m],d=OpenLayers.Geometry.distanceToSegment(a,l),d.distance<f){if(f=d.distance,e=d,0===f)break}else if(l.x2>h&&(k>l.y1&&k<l.y2||k<l.y1&&k>l.y2))break;e=c?{distance:e.distance,x0:e.x,y0:e.y,x1:h,y1:k}:e.distance}else if(a instanceof OpenLayers.Geometry.LineString){var g=this.getSortedSegments(),h=a.getSortedSegments(),p,q,r=h.length,s={point:!0},m=0,n=g.length;a:for(;m<n;++m){k=g[m];l=k.x1;q=k.y1;for(var t=0;t<r;++t)if(d=h[t],p=OpenLayers.Geometry.segmentsIntersect(k,
+d,s)){f=0;e={distance:0,x0:p.x,y0:p.y,x1:p.x,y1:p.y};break a}else d=OpenLayers.Geometry.distanceToSegment({x:l,y:q},d),d.distance<f&&(f=d.distance,e={distance:f,x0:l,y0:q,x1:d.x,y1:d.y})}c||(e=e.distance);0!==f&&k&&(d=a.distanceTo(new OpenLayers.Geometry.Point(k.x2,k.y2),b),m=c?d.distance:d,m<f&&(e=c?{distance:f,x0:d.x1,y0:d.y1,x1:d.x0,y1:d.y0}:m))}else e=a.distanceTo(this,b),c&&(e={distance:e.distance,x0:e.x1,y0:e.y1,x1:e.x0,y1:e.y0});return e},simplify:function(a){if(this&&null!==this){var b=this.getVertices();
+if(3>b.length)return this;var c=function(a,b,d,k){for(var l=0,m=0,n=b,p;n<d;n++){p=a[b];var q=a[d],r=a[n],r=Math.abs(0.5*(p.x*q.y+q.x*r.y+r.x*p.y-q.x*p.y-r.x*q.y-p.x*r.y));p=Math.sqrt(Math.pow(p.x-q.x,2)+Math.pow(p.y-q.y,2));p=2*(r/p);p>l&&(l=p,m=n)}l>k&&m!=b&&(e.push(m),c(a,b,m,k),c(a,m,d,k))},d=b.length-1,e=[];e.push(0);for(e.push(d);b[0].equals(b[d]);)d--,e.push(d);c(b,0,d,a);a=[];e.sort(function(a,b){return a-b});for(d=0;d<e.length;d++)a.push(b[e[d]]);return new OpenLayers.Geometry.LineString(a)}return this},
+CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],split:function(a,b){for(var c=null,d=b&&b.mutual,e,f,g,h,k=[],l=[a],m=0,n=this.components.length;m<n;++m){f=this.components[m];g=!1;for(var p=0;p<l.length;++p)if(e=f.split(l[p],b)){if(d){g=e[0];for(var q=0,r=g.length;q<r;++q)0===q&&k.length?k[k.length-1].addComponent(g[q]):k.push(new OpenLayers.Geometry.MultiLineString([g[q]]));g=!0;e=e[1]}if(e.length){e.unshift(p,
+1);Array.prototype.splice.apply(l,e);break}}g||(k.length?k[k.length-1].addComponent(f.clone()):k=[new OpenLayers.Geometry.MultiLineString(f.clone())])}k&&1<k.length?g=!0:k=[];l&&1<l.length?h=!0:l=[];if(g||h)c=d?[k,l]:l;return c},splitWith:function(a,b){var c=null,d=b&&b.mutual,e,f,g,h,k,l;if(a instanceof OpenLayers.Geometry.LineString){l=[];k=[a];for(var m=0,n=this.components.length;m<n;++m){g=!1;f=this.components[m];for(var p=0;p<k.length;++p)if(e=k[p].split(f,b)){d&&(g=e[0],g.length&&(g.unshift(p,
+1),Array.prototype.splice.apply(k,g),p+=g.length-2),e=e[1],0===e.length&&(e=[f.clone()]));g=0;for(var q=e.length;g<q;++g)0===g&&l.length?l[l.length-1].addComponent(e[g]):l.push(new OpenLayers.Geometry.MultiLineString([e[g]]));g=!0}g||(l.length?l[l.length-1].addComponent(f.clone()):l=[new OpenLayers.Geometry.MultiLineString([f.clone()])])}}else c=a.split(this);k&&1<k.length?h=!0:k=[];l&&1<l.length?g=!0:l=[];if(h||g)c=d?[k,l]:l;return c},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],addComponent:function(a,b){var c=!1,d=this.components.pop();null==b&&a.equals(d)||(c=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments));OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[this.components[0]]);return c},removeComponent:function(a){var b=this.components&&3<this.components.length;b&&(this.components.pop(),OpenLayers.G
+arguments),OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[this.components[0]]));return b},move:function(a,b){for(var c=0,d=this.components.length;c<d-1;c++)this.components[c].move(a,b)},rotate:function(a,b){for(var c=0,d=this.components.length;c<d-1;++c)this.components[c].rotate(a,b)},resize:function(a,b,c){for(var d=0,e=this.components.length;d<e-1;++d)this.components[d].resize(a,b,c);return this},transform:function(a,b){if(a&&b){for(var c=0,d=this.components.length;c<d-1;c++)this.components[c].transform(a,
+b);this.bounds=null}return this},getCentroid:function(){if(this.components){var a=this.components.length;if(0<a&&2>=a)return this.components[0].clone();if(2<a){var b=0,c=0,d=this.components[0].x,e=this.components[0].y,f=-1*this.getArea();if(0!=f){for(var g=0;g<a-1;g++)var h=this.components[g],k=this.components[g+1],b=b+(h.x+k.x-2*d)*((h.x-d)*(k.y-e)-(k.x-d)*(h.y-e)),c=c+(h.y+k.y-2*e)*((h.x-d)*(k.y-e)-(k.x-d)*(h.y-e));b=d+b/(6*f);a=e+c/(6*f)}else{for(g=0;g<a-1;g++)b+=this.components[g].x,c+=this.components[g].y;
+b/=a-1;a=c/(a-1)}return new OpenLayers.Geometry.Point(b,a)}return null}},getArea:function(){var a=0;if(this.components&&2<this.components.length){for(var b=a=0,c=this.components.length;b<c-1;b++)var d=this.components[b],e=this.components[b+1],a=a+(d.x+e.x)*(e.y-d.y);a=-a/2}return a},getGeodesicArea:function(a){var b=this;if(a){var c=new OpenLayers.Projection("EPSG:4326");c.equals(a)||(b=this.clone().transform(a,c))}a=0;c=b.components&&b.components.length;if(2<c){for(var d,e,f=0;f<c-1;f++)d=b.components[f],
+e=b.components[f+1],a+=OpenLayers.Util.rad(e.x-d.x)*(2+Math.sin(OpenLayers.Util.rad(d.y))+Math.sin(OpenLayers.Util.rad(e.y)));a=40680631590769*a/2}return a},containsPoint:function(a){var b=OpenLayers.Number.limitSigDigs,c=b(a.x,14);a=b(a.y,14);for(var d=this.components.length-1,e,f,g,h,k,l=0,m=0;m<d;++m)if(e=this.components[m],g=b(e.x,14),e=b(e.y,14),f=this.components[m+1],h=b(f.x,14),f=b(f.y,14),e==f){if(a==e&&(g<=h&&c>=g&&c<=h||g>=h&&c<=g&&c>=h)){l=-1;break}}else{k=b((a-f)*((h-g)/(f-e))+h,14);if(k==
+c&&(e<f&&a>=e&&a<=f||e>f&&a<=e&&a>=f)){l=-1;break}k<=c||g!=h&&(k<Math.min(g,h)||k>Math.max(g,h))||(e<f&&a>=e&&a<f||e>f&&a<e&&a>=f)&&++l}return-1==l?1:!!(l&1)},intersects:function(a){var b=!1;if("OpenLayers.Geometry.Point"==a.CLASS_NAME)b=this.containsPoint(a);else if("OpenLayers.Geometry.LineString"==a.CLASS_NAME)b=a.intersects(this);else if("OpenLayers.Geometry.LinearRing"==a.CLASS_NAME)b=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[a]);else for(var c=0,d=a.components.length;c<
+d&&!(b=a.components[c].intersects(this));++c);return b},getVertices:function(a){return!0===a?[]:this.components.slice(0,this.components.length-1)},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],getArea:function(){var a=0;if(this.components&&0<this.components.length)for(var a=a+Math.abs(this.components[0].getArea()),b=1,c=this.components.length;b<c;b++)a-=Math.abs(this.components[b].getArea());return a},getGeodesicArea:function(a){var b=0;if(this.components&&0<this.components.length)for(var b=b+Math.abs(this.components[0].getGeodesicArea(a)),c=1,d=this.components.length;c<
+d;c++)b-=Math.abs(this.components[c].getGeodesicArea(a));return b},containsPoint:function(a){var b=this.components.length,c=!1;if(0<b&&(c=this.components[0].containsPoint(a),1!==c&&c&&1<b))for(var d,e=1;e<b;++e)if(d=this.components[e].containsPoint(a)){c=1===d?1:!1;break}return c},intersects:function(a){var b=!1,c,d;if("OpenLayers.Geometry.Point"==a.CLASS_NAME)b=this.containsPoint(a);else if("OpenLayers.Geometry.LineString"==a.CLASS_NAME||"OpenLayers.Geometry.LinearRing"==a.CLASS_NAME){c=0;for(d=
+this.components.length;c<d&&!(b=a.intersects(this.components[c]));++c);if(!b)for(c=0,d=a.components.length;c<d&&!(b=this.containsPoint(a.components[c]));++c);}else for(c=0,d=a.components.length;c<d&&!(b=this.intersects(a.components[c]));++c);if(!b&&"OpenLayers.Geometry.Polygon"==a.CLASS_NAME){var e=this.components[0];c=0;for(d=e.components.length;c<d&&!(b=a.containsPoint(e.components[c]));++c);}return b},distanceTo:function(a,b){return b&&!1===b.edge&&this.intersects(a)?0:OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,
+[a,b])},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(a,b,c,d){var e=Math.PI*(1/c-0.5);d&&(e+=d/180*Math.PI);for(var f,g=[],h=0;h<c;++h)f=e+2*h*Math.PI/c,d=a.x+b*Math.cos(f),f=a.y+b*Math.sin(f),g.push(new OpenLayers.Geometry.Point(d,f));a=new OpenLayers.Geometry.LinearRing(g);return new OpenLayers.Geometry.Polygon([a])};OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:!0,xy:!0,initialize:function(a){this.regExes={trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g};OpenLayers
.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a=this.getElementsByTagNameNS(a.documentElement,this.gmlns,this.featureName);for(var b=[],c=0;c<a.length;c++){var d=this.parseFeature(a[c]);d&&b.push(d)}return b},parseFeature:function(a){for(var b="MultiPolygon Polygon MultiLineString LineString MultiPoint Point Envelope".split(" "),c,d,e,f=0;f<b.length;++f)if(c=b[f],d=this.getElementsByTagNameNS(a,this.gmlns,c),0<d.length){if(e=this.parseGeometry[c.toLowerCase()])e=e.apply(this,
+[d[0]]),this.internalProjection&&this.externalProjection&&e.transform(this.externalProjection,this.internalProjection);else throw new TypeError("Unsupported geometry type: "+c);break}var g;c=this.getElementsByTagNameNS(a,this.gmlns,"Box");for(f=0;f<c.length;++f)b=c[f],d=this.parseGeometry.box.apply(this,[b]),b=b.parentNode,"boundedBy"===(b.localName||b.nodeName.split(":").pop())?g=d:e=d.toGeometry();var h;this.extractAttributes&&(h=this.parseAttributes(a));h=new OpenLayers.Feature.Vector(e,h);h.bounds=
+g;h.gml={featureType:a.firstChild.nodeName.split(":")[1],featureNS:a.firstChild.namespaceURI,featureNSPrefix:a.firstChild.prefix};a=a.firstChild;for(var k;a&&(1!=a.nodeType||!(k=a.getAttribute("fid")||a.getAttribute("id")));)a=a.nextSibling;h.fid=k;return h},parseGeometry:{point:function(a){var b,c;c=[];b=this.getElementsByTagNameNS(a,this.gmlns,"pos");0<b.length&&(c=b[0].firstChild.nodeValue,c=c.replace(this.regExes.trimSpace,""),c=c.split(this.regExes.splitSpace));0==c.length&&(b=this.getElementsByTagNameNS(a,
+this.gmlns,"coordinates"),0<b.length&&(c=b[0].firstChild.nodeValue,c=c.replace(this.regExes.removeSpace,""),c=c.split(",")));0==c.length&&(b=this.getElementsByTagNameNS(a,this.gmlns,"coord"),0<b.length&&(a=this.getElementsByTagNameNS(b[0],this.gmlns,"X"),b=this.getElementsByTagNameNS(b[0],this.gmlns,"Y"),0<a.length&&0<b.length&&(c=[a[0].firstChild.nodeValue,b[0].firstChild.nodeValue])));2==c.length&&(c[2]=null);return this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],
+c[0],c[2])},multipoint:function(a){a=this.getElementsByTagNameNS(a,this.gmlns,"Point");var b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.point.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiPoint(b)},linestring:function(a,b){var c,d;d=[];var e=[];c=this.getElementsByTagNameNS(a,this.gmlns,"posList");if(0<c.length){d=this.getChildValue(c[0]);d=d.replace(this.regExes.trimSpace,"");d=d.split(this.regExes.splitSpace);var f=parseInt(c[0].getAttribute("dimension")),
+g,h,k;for(c=0;c<d.length/f;++c)g=c*f,h=d[g],k=d[g+1],g=2==f?null:d[g+2],this.xy?e.push(new OpenLayers.Geometry.Point(h,k,g)):e.push(new OpenLayers.Geometry.Point(k,h,g))}if(0==d.length&&(c=this.getElementsByTagNameNS(a,this.gmlns,"coordinates"),0<c.length))for(d=this.getChildValue(c[0]),d=d.replace(this.regExes.trimSpace,""),d=d.replace(this.regExes.trimComma,","),f=d.split(this.regExes.splitSpace),c=0;c<f.length;++c)d=f[c].split(","),2==d.length&&(d[2]=null),this.xy?e.push(new OpenLayers.Geometry.Point(d[0],
+d[1],d[2])):e.push(new OpenLayers.Geometry.Point(d[1],d[0],d[2]));d=null;0!=e.length&&(d=b?new OpenLayers.Geometry.LinearRing(e):new OpenLayers.Geometry.LineString(e));return d},multilinestring:function(a){a=this.getElementsByTagNameNS(a,this.gmlns,"LineString");var b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.linestring.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiLineString(b)},polygon:function(a){a=this.getElementsByTagNameNS(a,this.gmlns,"LinearRing");
+var b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.linestring.apply(this,[a[d],!0]))&&b.push(c);return new OpenLayers.Geometry.Polygon(b)},multipolygon:function(a){a=this.getElementsByTagNameNS(a,this.gmlns,"Polygon");var b=[];if(0<a.length)for(var c,d=0;d<a.length;++d)(c=this.parseGeometry.polygon.apply(this,[a[d]]))&&b.push(c);return new OpenLayers.Geometry.MultiPolygon(b)},envelope:function(a){var b=[],c,d,e=this.getElementsByTagNameNS(a,this.gmlns,"lowerCorner");if(0<e.length){c=
+[];0<e.length&&(c=e[0].firstChild.nodeValue,c=c.replace(this.regExes.trimSpace,""),c=c.split(this.regExes.splitSpace));2==c.length&&(c[2]=null);var f=this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2])}a=this.getElementsByTagNameNS(a,this.gmlns,"upperCorner");if(0<a.length){c=[];0<a.length&&(c=a[0].firstChild.nodeValue,c=c.replace(this.regExes.trimSpace,""),c=c.split(this.regExes.splitSpace));2==c.length&&(c[2]=null);var g=this.xy?new OpenLayers.Geometry.Point(c[0],
+c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2])}f&&g&&(b.push(new OpenLayers.Geometry.Point(f.x,f.y)),b.push(new OpenLayers.Geometry.Point(g.x,f.y)),b.push(new OpenLayers.Geometry.Point(g.x,g.y)),b.push(new OpenLayers.Geometry.Point(f.x,g.y)),b.push(new OpenLayers.Geometry.Point(f.x,f.y)),b=new OpenLayers.Geometry.LinearRing(b),d=new OpenLayers.Geometry.Polygon([b]));return d},box:function(a){var b=this.getElementsByTagNameNS(a,this.gmlns,"coordinates"),c=a=null;0<b.length&&(b=b[0].firstChild.nodeValue,
+b=b.split(" "),2==b.length&&(a=b[0].split(","),c=b[1].split(",")));if(null!==a&&null!==c)return new OpenLayers.Bounds(parseFloat(a[0]),parseFloat(a[1]),parseFloat(c[0]),parseFloat(c[1]))}},parseAttributes:function(a){var b={};a=a.firstChild;for(var c,d,e;a;){if(1==a.nodeType){a=a.childNodes;for(c=0;c<a.length;++c)if(d=a[c],1==d.nodeType)if(e=d.childNodes,1==e.length){if(e=e[0],3==e.nodeType||4==e.nodeType)d=d.prefix?d.nodeName.split(":")[1]:d.nodeName,e=e.nodeValue.replace(this.regExes.trimSpace,
+""),b[d]=e}else b[d.nodeName.split(":").pop()]=null;break}a=a.nextSibling}return b},write:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName),c=0;c<a.length;c++)b.appendChild(this.createFeatureXML(a[c]));return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFeatureXML:function(a){var b=this.buildGeometryNode(a.geometry),c=this.createElementNS(this.featureNS,this.featurePrefix+":"+this.geometryName);c.appendChild(b);
+var b=this.createElementNS(this.gmlns,"gml:"+this.featureName),d=this.createElementNS(this.featureNS,this.featurePrefix+":"+this.layerName);d.setAttribute("fid",a.fid||a.id);d.appendChild(c);for(var e in a.attributes){var c=this.createTextNode(a.attributes[e]),f=e.substring(e.lastIndexOf(":")+1),f=this.createElementNS(this.featureNS,this.featurePrefix+":"+f);f.appendChild(c);d.appendChild(f)}b.appendChild(d);return b},buildGeometryNode:function(a){this.externalProjection&&this.internalProjection&&
+(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));var b=a.CLASS_NAME,b=b.substring(b.lastIndexOf(".")+1);return this.buildGeometry[b.toLowerCase()].apply(this,[a])},buildGeometry:{point:function(a){var b=this.createElementNS(this.gmlns,"gml:Point");b.appendChild(this.buildCoordinatesNode(a));return b},multipoint:function(a){var b=this.createElementNS(this.gmlns,"gml:MultiPoint");a=a.components;for(var c,d,e=0;e<a.length;e++)c=this.createElementNS(this.gmlns,"gml:pointMember"),
+d=this.buildGeometry.point.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);return b},linestring:function(a){var b=this.createElementNS(this.gmlns,"gml:LineString");b.appendChild(this.buildCoordinatesNode(a));return b},multilinestring:function(a){var b=this.createElementNS(this.gmlns,"gml:MultiLineString");a=a.components;for(var c,d,e=0;e<a.length;++e)c=this.createElementNS(this.gmlns,"gml:lineStringMember"),d=this.buildGeometry.linestring.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);
+return b},linearring:function(a){var b=this.createElementNS(this.gmlns,"gml:LinearRing");b.appendChild(this.buildCoordinatesNode(a));return b},polygon:function(a){var b=this.createElementNS(this.gmlns,"gml:Polygon");a=a.components;for(var c,d,e=0;e<a.length;++e)c=0==e?"outerBoundaryIs":"innerBoundaryIs",c=this.createElementNS(this.gmlns,"gml:"+c),d=this.buildGeometry.linearring.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);return b},multipolygon:function(a){var b=this.createElementNS(this.gmlns,
+"gml:MultiPolygon");a=a.components;for(var c,d,e=0;e<a.length;++e)c=this.createElementNS(this.gmlns,"gml:polygonMember"),d=this.buildGeometry.polygon.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);return b},bounds:function(a){var b=this.createElementNS(this.gmlns,"gml:Box");b.appendChild(this.buildCoordinatesNode(a));return b}},buildCoordinatesNode:function(a){var b=this.createElementNS(this.gmlns,"gml:coordinates");b.setAttribute("decimal",".");b.setAttribute("cs",",");b.setAttribute("ts",
+" ");var c=[];if(a instanceof OpenLayers.Bounds)c.push(a.left+","+a.bottom),c.push(a.right+","+a.top);else{a=a.components?a.components:[a];for(var d=0;d<a.length;d++)c.push(a[d].x+","+a[d].y)}c=this.createTextNode(c.join(" "));b.appendChild(c);return b},CLASS_NAME:"OpenLayers.Format.GML"});OpenLayers.Format.GML||(OpenLayers.Format.GML={});
+OpenLayers.Format.GML.Base=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs"},defaultPrefix:"gml",schemaLocation:null,featureType:null,featureNS:null,geometryName:"geometry",extractAttributes:!0,srsName:null,xy:!0,geometryTypes:null,singleFeatureType:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g,featureMember:/^(.*:)?featureMembers?$/},
+initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.setGeometryTypes();a&&a.featureNS&&this.setNamespace("feature",a.featureNS);this.singleFeatureType=!a||"string"===typeof a.featureType},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b=[];this.readNode(a,{features:b},!0);if(0==b.length){var c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMember");if(c.length){a=
+0;for(var d=c.length;a<d;++a)this.readNode(c[a],{features:b},!0)}else c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMembers"),c.length&&this.readNode(c[0],{features:b},!0)}return b},readNode:function(a,b,c){!0===c&&!0===this.autoConfig&&(this.featureType=null,delete this.namespaceAlias[this.featureNS],delete this.namespaces.feature,this.featureNS=null);this.featureNS||(a.prefix in this.namespaces||a.parentNode.namespaceURI!=this.namespaces.gml||!this.regExes.featureMember.test(a.parentNode.nodeName))||
+(this.featureType=a.nodeName.split(":").pop(),this.setNamespace("feature",a.namespaceURI),this.featureNS=a.namespaceURI,this.autoConfig=!0);return OpenLayers.Format.XML.prototype.readNode.apply(this,[a,b])},readers:{gml:{_inherit:function(a,b,c){},featureMember:function(a,b){this.readChildNodes(a,b)},featureMembers:function(a,b){this.readChildNodes(a,b)},name:function(a,b){b.name=this.getChildValue(a)},boundedBy:function(a,b){var c={};this.readChildNodes(a,c);c.components&&0<c.components.length&&
+(b.bounds=c.components[0])},Point:function(a,b){var c={points:[]};this.readChildNodes(a,c);b.components||(b.components=[]);b.components.push(c.points[0])},coordinates:function(a,b){for(var c=this.getChildValue(a).replace(this.regExes.trimSpace,""),c=c.replace(this.regExes.trimComma,","),c=c.split(this.regExes.splitSpace),d,e=c.length,f=Array(e),g=0;g<e;++g)d=c[g].split(","),f[g]=this.xy?new OpenLayers.Geometry.Point(d[0],d[1],d[2]):new OpenLayers.Geometry.Point(d[1],d[0],d[2]);b.points=f},coord:function(a,
+b){var c={};this.readChildNodes(a,c);b.points||(b.points=[]);b.points.push(new OpenLayers.Geometry.Point(c.x,c.y,c.z))},X:function(a,b){b.x=this.getChildValue(a)},Y:function(a,b){b.y=this.getChildValue(a)},Z:function(a,b){b.z=this.getChildValue(a)},MultiPoint:function(a,b){var c={components:[]};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiPoint(c.components)]},pointMember:function(a,b){this.readChildNodes(a,b)},LineString:function(a,
+b){var c={};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);b.components||(b.components=[]);b.components.push(new OpenLayers.Geometry.LineString(c.points))},MultiLineString:function(a,b){var c={components:[]};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiLineString(c.components)]},lineStringMember:function(a,b){this.readChildNodes(a,b)},Polygon:function(a,b){var c={outer:null,inner:[]};this.readers.gml._inherit.apply(this,
+[a,c,b]);this.readChildNodes(a,c);c.inner.unshift(c.outer);b.components||(b.components=[]);b.components.push(new OpenLayers.Geometry.Polygon(c.inner))},LinearRing:function(a,b){var c={};this.readers.gml._inherit.apply(this,[a,c]);this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.LinearRing(c.points)]},MultiPolygon:function(a,b){var c={components:[]};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.MultiPolygon(c.components)]},
+polygonMember:function(a,b){this.readChildNodes(a,b)},GeometryCollection:function(a,b){var c={components:[]};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);b.components=[new OpenLayers.Geometry.Collection(c.components)]},geometryMember:function(a,b){this.readChildNodes(a,b)}},feature:{"*":function(a,b){var c,d=a.localName||a.nodeName.split(":").pop();b.features?this.singleFeatureType||-1===OpenLayers.Util.indexOf(this.featureType,d)?d===this.featureType&&(c="_typeName"):c=
+"_typeName":0==a.childNodes.length||1==a.childNodes.length&&3==a.firstChild.nodeType?this.extractAttributes&&(c="_attribute"):c="_geometry";c&&this.readers.feature[c].apply(this,[a,b])},_typeName:function(a,b){var c={components:[],attributes:{}};this.readChildNodes(a,c);c.name&&(c.attributes.name=c.name);var d=new OpenLayers.Feature.Vector(c.components[0],c.attributes);this.singleFeatureType||(d.type=a.nodeName.split(":").pop(),d.namespace=a.namespaceURI);var e=a.getAttribute("fid")||this.getAttributeNS(a,
+this.namespaces.gml,"id");e&&(d.fid=e);this.internalProjection&&(this.externalProjection&&d.geometry)&&d.geometry.transform(this.externalProjection,this.internalProjection);c.bounds&&(d.bounds=c.bounds);b.features.push(d)},_geometry:function(a,b){this.geometryName||(this.geometryName=a.nodeName.split(":").pop());this.readChildNodes(a,b)},_attribute:function(a,b){var c=a.localName||a.nodeName.split(":").pop(),d=this.getChildValue(a);b.attributes[c]=d}},wfs:{FeatureCollection:function(a,b){this.readChildNodes(a,
+b)}}},write:function(a){var b;b=OpenLayers.Util.isArray(a)?"featureMembers":"featureMember";a=this.writeNode("gml:"+b,a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:{featureMember:function(a){var b=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",a,b);return b},MultiPoint:function(a){var b=this.createElementNSPlus("gml:MultiPoint");a=a.components||[a];
+for(var c=0,d=a.length;c<d;++c)this.writeNode("pointMember",a[c],b);return b},pointMember:function(a){var b=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",a,b);return b},MultiLineString:function(a){var b=this.createElementNSPlus("gml:MultiLineString");a=a.components||[a];for(var c=0,d=a.length;c<d;++c)this.writeNode("lineStringMember",a[c],b);return b},lineStringMember:function(a){var b=this.createElementNSPlus("gml:lineStringMember");this.writeNode("LineString",a,b);return b},
+MultiPolygon:function(a){var b=this.createElementNSPlus("gml:MultiPolygon");a=a.components||[a];for(var c=0,d=a.length;c<d;++c)this.writeNode("polygonMember",a[c],b);return b},polygonMember:function(a){var b=this.createElementNSPlus("gml:polygonMember");this.writeNode("Polygon",a,b);return b},GeometryCollection:function(a){for(var b=this.createElementNSPlus("gml:GeometryCollection"),c=0,d=a.components.length;c<d;++c)this.writeNode("geometryMember",a.components[c],b);return b},geometryMember:function(a){var b=
+this.createElementNSPlus("gml:geometryMember");a=this.writeNode("feature:_geometry",a);b.appendChild(a.firstChild);return b}},feature:{_typeName:function(a){var b=this.createElementNSPlus("feature:"+this.featureType,{attributes:{fid:a.fid}});a.geometry&&this.writeNode("feature:_geometry",a.geometry,b);for(var c in a.attributes){var d=a.attributes[c];null!=d&&this.writeNode("feature:_attribute",{name:c,value:d},b)}return b},_geometry:function(a){this.externalProjection&&this.internalProjection&&(a=
+a.clone().transform(this.internalProjection,this.externalProjection));var b=this.createElementNSPlus("feature:"+this.geometryName);a=this.writeNode("gml:"+this.geometryTypes[a.CLASS_NAME],a,b);this.srsName&&a.setAttribute("srsName",this.srsName);return b},_attribute:function(a){return this.createElementNSPlus("feature:"+a.name,{value:a.value})}},wfs:{FeatureCollection:function(a){for(var b=this.createElementNSPlus("wfs:FeatureCollection"),c=0,d=a.length;c<d;++c)this.writeNode("gml:featureMember",
+a[c],b);return b}}},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":"LineString","OpenLayers.Geometry.MultiLineString":"MultiLineString","OpenLayers.Geometry.Polygon":"Polygon","OpenLayers.Geometry.MultiPolygon":"MultiPolygon","OpenLayers.Geometry.Collection":"GeometryCollection"}},CLASS_NAME:"OpenLayers.Format.GML.Base"});OpenLayers.Format.GML.v3=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlsfProfile/1.0.0/gmlsf.xsd",curve:!1,multiCurve:!0,surface:!1,multiSurface:!0,initialize:function(a){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[a])},readers:{gml:OpenLayers.Util.applyDefaults({_inherit:function(a,b,c){if(a=parseInt(a.getAttribute("srsDimension"),10)||c&&c.srsDimension)b.srsDimension=a},featureMembers:function(a,
+b){this.readChildNodes(a,b)},Curve:function(a,b){var c={points:[]};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);b.components||(b.components=[]);b.components.push(new OpenLayers.Geometry.LineString(c.points))},segments:function(a,b){this.readChildNodes(a,b)},LineStringSegment:function(a,b){var c={};this.readChildNodes(a,c);c.points&&Array.prototype.push.apply(b.points,c.points)},pos:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(this.regExes.splitSpace),
+c=this.xy?new OpenLayers.Geometry.Point(c[0],c[1],c[2]):new OpenLayers.Geometry.Point(c[1],c[0],c[2]);b.points=[c]},posList:function(a,b){for(var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(this.regExes.splitSpace),d=b.srsDimension||parseInt(a.getAttribute("srsDimension")||a.getAttribute("dimension"),10)||2,e,f,g,h=Array(c.length/d),k=0,l=c.length;k<l;k+=d)e=c[k],f=c[k+1],g=2==d?void 0:c[k+2],h[k/d]=this.xy?new OpenLayers.Geometry.Point(e,f,g):new OpenLayers.Geometry.Point(f,
+e,g);b.points=h},Surface:function(a,b){this.readChildNodes(a,b)},patches:function(a,b){this.readChildNodes(a,b)},PolygonPatch:function(a,b){this.readers.gml.Polygon.apply(this,[a,b])},exterior:function(a,b){var c={};this.readChildNodes(a,c);b.outer=c.components[0]},interior:function(a,b){var c={};this.readChildNodes(a,c);b.inner.push(c.components[0])},MultiCurve:function(a,b){var c={components:[]};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);0<c.components.length&&(b.components=
+[new OpenLayers.Geometry.MultiLineString(c.components)])},curveMember:function(a,b){this.readChildNodes(a,b)},MultiSurface:function(a,b){var c={components:[]};this.readers.gml._inherit.apply(this,[a,c,b]);this.readChildNodes(a,c);0<c.components.length&&(b.components=[new OpenLayers.Geometry.MultiPolygon(c.components)])},surfaceMember:function(a,b){this.readChildNodes(a,b)},surfaceMembers:function(a,b){this.readChildNodes(a,b)},pointMembers:function(a,b){this.readChildNodes(a,b)},lineStringMembers:function(a,
+b){this.readChildNodes(a,b)},polygonMembers:function(a,b){this.readChildNodes(a,b)},geometryMembers:function(a,b){this.readChildNodes(a,b)},Envelope:function(a,b){var c={points:Array(2)};this.readChildNodes(a,c);b.components||(b.components=[]);var d=c.points[0],c=c.points[1];b.components.push(new OpenLayers.Bounds(d.x,d.y,c.x,c.y))},lowerCorner:function(a,b){var c={};this.readers.gml.pos.apply(this,[a,c]);b.points[0]=c.points[0]},upperCorner:function(a,b){var c={};this.readers.gml.pos.apply(this,
+[a,c]);b.points[1]=c.points[0]}},OpenLayers.Format.GML.Base.prototype.readers.gml),feature:OpenLayers.Format.GML.Base.prototype.readers.feature,wfs:OpenLayers.Format.GML.Base.prototype.readers.wfs},write:function(a){var b;b=OpenLayers.Util.isArray(a)?"featureMembers":"featureMember";a=this.writeNode("gml:"+b,a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:OpenLayers.Util.applyDefaults({featureMembers:function(a){for(var b=
+this.createElementNSPlus("gml:featureMembers"),c=0,d=a.length;c<d;++c)this.writeNode("feature:_typeName",a[c],b);return b},Point:function(a){var b=this.createElementNSPlus("gml:Point");this.writeNode("pos",a,b);return b},pos:function(a){return this.createElementNSPlus("gml:pos",{value:this.xy?a.x+" "+a.y:a.y+" "+a.x})},LineString:function(a){var b=this.createElementNSPlus("gml:LineString");this.writeNode("posList",a.components,b);return b},Curve:function(a){var b=this.createElementNSPlus("gml:Curve");
+this.writeNode("segments",a,b);return b},segments:function(a){var b=this.createElementNSPlus("gml:segments");this.writeNode("LineStringSegment",a,b);return b},LineStringSegment:function(a){var b=this.createElementNSPlus("gml:LineStringSegment");this.writeNode("posList",a.components,b);return b},posList:function(a){for(var b=a.length,c=Array(b),d,e=0;e<b;++e)d=a[e],c[e]=this.xy?d.x+" "+d.y:d.y+" "+d.x;return this.createElementNSPlus("gml:posList",{value:c.join(" ")})},Surface:function(a){var b=this.createElementNSPlus("gml:Surface");
+this.writeNode("patches",a,b);return b},patches:function(a){var b=this.createElementNSPlus("gml:patches");this.writeNode("PolygonPatch",a,b);return b},PolygonPatch:function(a){var b=this.createElementNSPlus("gml:PolygonPatch",{attributes:{interpolation:"planar"}});this.writeNode("exterior",a.components[0],b);for(var c=1,d=a.components.length;c<d;++c)this.writeNode("interior",a.components[c],b);return b},Polygon:function(a){var b=this.createElementNSPlus("gml:Polygon");this.writeNode("exterior",a.components[0],
+b);for(var c=1,d=a.components.length;c<d;++c)this.writeNode("interior",a.components[c],b);return b},exterior:function(a){var b=this.createElementNSPlus("gml:exterior");this.writeNode("LinearRing",a,b);return b},interior:function(a){var b=this.createElementNSPlus("gml:interior");this.writeNode("LinearRing",a,b);return b},LinearRing:function(a){var b=this.createElementNSPlus("gml:LinearRing");this.writeNode("posList",a.components,b);return b},MultiCurve:function(a){var b=this.createElementNSPlus("gml:MultiCurve");
+a=a.components||[a];for(var c=0,d=a.length;c<d;++c)this.writeNode("curveMember",a[c],b);return b},curveMember:function(a){var b=this.createElementNSPlus("gml:curveMember");this.curve?this.writeNode("Curve",a,b):this.writeNode("LineString",a,b);return b},MultiSurface:function(a){var b=this.createElementNSPlus("gml:MultiSurface");a=a.components||[a];for(var c=0,d=a.length;c<d;++c)this.writeNode("surfaceMember",a[c],b);return b},surfaceMember:function(a){var b=this.createElementNSPlus("gml:surfaceMember");
+this.surface?this.writeNode("Surface",a,b):this.writeNode("Polygon",a,b);return b},Envelope:function(a){var b=this.createElementNSPlus("gml:Envelope");this.writeNode("lowerCorner",a,b);this.writeNode("upperCorner",a,b);this.srsName&&b.setAttribute("srsName",this.srsName);return b},lowerCorner:function(a){return this.createElementNSPlus("gml:lowerCorner",{value:this.xy?a.left+" "+a.bottom:a.bottom+" "+a.left})},upperCorner:function(a){return this.createElementNSPlus("gml:upperCorner",{value:this.xy?
+a.right+" "+a.top:a.top+" "+a.right})}},OpenLayers.Format.GML.Base.prototype.writers.gml),feature:OpenLayers.Format.GML.Base.prototype.writers.feature,wfs:OpenLayers.Format.GML.Base.prototype.writers.wfs},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":!0===this.curve?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":!1===this.multiCurve?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":!0===
+this.surface?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":!1===this.multiSurface?"MultiPolygon":"MultiSurface","OpenLayers.Geometry.Collection":"GeometryCollection"}},CLASS_NAME:"OpenLayers.Format.GML.v3"});OpenLayers.Format.Filter.v1_1_0=OpenLayers.Class(OpenLayers.Format.GML.v3,OpenLayers.Format.Filter.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.1.0/filter.xsd",initialize:function(a){OpenLayers.Format.GML.v3.prototype.initialize.apply(this,[a])},readers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a,b){var c=a.getAttribute("matchCase"),c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,matchCase:!("false"===c||"0"===c)});this.readChildNodes(a,
+c);b.filters.push(c)},PropertyIsNotEqualTo:function(a,b){var c=a.getAttribute("matchCase"),c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO,matchCase:!("false"===c||"0"===c)});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLike:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(a,c);var d=a.getAttribute("wildCard"),e=a.getAttribute("singleChar"),f=a.getAttribute("escapeChar");c.value2regex(d,e,
+f);b.filters.push(c)}},OpenLayers.Format.Filter.v1.prototype.readers.ogc),gml:OpenLayers.Format.GML.v3.prototype.readers.gml,feature:OpenLayers.Format.GML.v3.prototype.readers.feature},writers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsEqualTo",{attributes:{matchCase:a.matchCase}});this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsNotEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsNotEqualTo",
+{attributes:{matchCase:a.matchCase}});this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsLike:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{matchCase:a.matchCase,wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.regex2value(),b);return b},BBOX:function(a){var b=this.createElementNSPlus("ogc:BBOX");a.property&&this.writeNode("PropertyName",a,b);var c=this.writeNode("gml:Envelope",
+a.value);a.projection&&c.setAttribute("srsName",a.projection);b.appendChild(c);return b},SortBy:function(a){for(var b=this.createElementNSPlus("ogc:SortBy"),c=0,d=a.length;c<d;c++)this.writeNode("ogc:SortProperty",a[c],b);return b},SortProperty:function(a){var b=this.createElementNSPlus("ogc:SortProperty");this.writeNode("ogc:PropertyName",a,b);this.writeNode("ogc:SortOrder","DESC"==a.order?"DESC":"ASC",b);return b},SortOrder:function(a){return this.createElementNSPlus("ogc:SortOrder",{value:a})}},
+OpenLayers.Format.Filter.v1.prototype.writers.ogc),gml:OpenLayers.Format.GML.v3.prototype.writers.gml,feature:OpenLayers.Format.GML.v3.prototype.writers.feature},writeSpatial:function(a,b){var c=this.createElementNSPlus("ogc:"+b);this.writeNode("PropertyName",a,c);if(a.value instanceof OpenLayers.Filter.Function)this.writeNode("Function",a.value,c);else{var d;d=a.value instanceof OpenLayers.Geometry?this.writeNode("feature:_geometry",a.value).firstChild:this.writeNode("gml:Envelope",a.value);a.projection&&
+d.setAttribute("srsName",a.projection);c.appendChild(d)}return c},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});OpenLayers.Format.OWSCommon=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",getVersion:function(a,b){var c=this.version;if(!c){var d=a.getAttribute("xmlns:ows");d&&"1.1"===d.substring(d.lastIndexOf("/")+1)&&(c="1.1.0");c||(c=this.defaultVersion)}return c},CLASS_NAME:"OpenLayers.Format.OWSCommon"});OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},read:function(a,b){OpenLayers.Util.applyDefaults(b,this.options);var c={};this.readChildNodes(a,c);return c},readers:{ows:{Exception:function(a,b){var c={code:a.getAttribute("exceptionCode"),locator:a.getAttribute("locator"),texts:[]};b.exceptions.push(c);this.readChildNodes(a,c)},ExceptionText:function(a,b){var c=this.getChildValue(a);b.texts.push(c)},
+ServiceIdentification:function(a,b){b.serviceIdentification={};this.readChildNodes(a,b.serviceIdentification)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b["abstract"]=this.getChildValue(a)},Keywords:function(a,b){b.keywords={};this.readChildNodes(a,b.keywords)},Keyword:function(a,b){b[this.getChildValue(a)]=!0},ServiceType:function(a,b){b.serviceType={codeSpace:a.getAttribute("codeSpace"),value:this.getChildValue(a)}},ServiceTypeVersion:function(a,b){b.serviceTypeVersion=
+this.getChildValue(a)},Fees:function(a,b){b.fees=this.getChildValue(a)},AccessConstraints:function(a,b){b.accessConstraints=this.getChildValue(a)},ServiceProvider:function(a,b){b.serviceProvider={};this.readChildNodes(a,b.serviceProvider)},ProviderName:function(a,b){b.providerName=this.getChildValue(a)},ProviderSite:function(a,b){b.providerSite=this.getAttributeNS(a,this.namespaces.xlink,"href")},ServiceContact:function(a,b){b.serviceContact={};this.readChildNodes(a,b.serviceContact)},IndividualName:function(a,
+b){b.individualName=this.getChildValue(a)},PositionName:function(a,b){b.positionName=this.getChildValue(a)},ContactInfo:function(a,b){b.contactInfo={};this.readChildNodes(a,b.contactInfo)},Phone:function(a,b){b.phone={};this.readChildNodes(a,b.phone)},Voice:function(a,b){b.voice=this.getChildValue(a)},Address:function(a,b){b.address={};this.readChildNodes(a,b.address)},DeliveryPoint:function(a,b){b.deliveryPoint=this.getChildValue(a)},City:function(a,b){b.city=this.getChildValue(a)},AdministrativeArea:function(a,
+b){b.administrativeArea=this.getChildValue(a)},PostalCode:function(a,b){b.postalCode=this.getChildValue(a)},Country:function(a,b){b.country=this.getChildValue(a)},ElectronicMailAddress:function(a,b){b.electronicMailAddress=this.getChildValue(a)},Role:function(a,b){b.role=this.getChildValue(a)},OperationsMetadata:function(a,b){b.operationsMetadata={};this.readChildNodes(a,b.operationsMetadata)},Operation:function(a,b){var c=a.getAttribute("name");b[c]={};this.readChildNodes(a,b[c])},DCP:function(a,
+b){b.dcp={};this.readChildNodes(a,b.dcp)},HTTP:function(a,b){b.http={};this.readChildNodes(a,b.http)},Get:function(a,b){b.get||(b.get=[]);var c={url:this.getAttributeNS(a,this.namespaces.xlink,"href")};this.readChildNodes(a,c);b.get.push(c)},Post:function(a,b){b.post||(b.post=[]);var c={url:this.getAttributeNS(a,this.namespaces.xlink,"href")};this.readChildNodes(a,c);b.post.push(c)},Parameter:function(a,b){b.parameters||(b.parameters={});var c=a.getAttribute("name");b.parameters[c]={};this.readChildNodes(a,
+b.parameters[c])},Constraint:function(a,b){b.constraints||(b.constraints={});var c=a.getAttribute("name");b.constraints[c]={};this.readChildNodes(a,b.constraints[c])},Value:function(a,b){b[this.getChildValue(a)]=!0},OutputFormat:function(a,b){b.formats.push({value:this.getChildValue(a)});this.readChildNodes(a,b)},WGS84BoundingBox:function(a,b){var c={};c.crs=a.getAttribute("crs");b.BoundingBox?b.BoundingBox.push(c):(b.projection=c.crs,c=b);this.readChildNodes(a,c)},BoundingBox:function(a,b){this.readers.ows.WGS84BoundingBox.apply(this,
+[a,b])},LowerCorner:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,""),c=c.replace(this.regExes.trimComma,","),c=c.split(this.regExes.splitSpace);b.left=c[0];b.bottom=c[1]},UpperCorner:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,""),c=c.replace(this.regExes.trimComma,","),c=c.split(this.regExes.splitSpace);b.right=c[0];b.top=c[1];b.bounds=new OpenLayers.Bounds(b.left,b.bottom,b.right,b.top);delete b.left;delete b.bottom;delete b.right;delete b.top},
+Language:function(a,b){b.language=this.getChildValue(a)}}},writers:{ows:{BoundingBox:function(a,b){var c=this.createElementNSPlus(b||"ows:BoundingBox",{attributes:{crs:a.projection}});this.writeNode("ows:LowerCorner",a,c);this.writeNode("ows:UpperCorner",a,c);return c},LowerCorner:function(a){return this.createElementNSPlus("ows:LowerCorner",{value:a.bounds.left+" "+a.bounds.bottom})},UpperCorner:function(a){return this.createElementNSPlus("ows:UpperCorner",{value:a.bounds.right+" "+a.bounds.top})},
+Identifier:function(a){return this.createElementNSPlus("ows:Identifier",{value:a})},Title:function(a){return this.createElementNSPlus("ows:Title",{value:a})},Abstract:function(a){return this.createElementNSPlus("ows:Abstract",{value:a})},OutputFormat:function(a){return this.createElementNSPlus("ows:OutputFormat",{value:a})}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink"},readers:{ows:OpenLayers.Util.applyDefaults({ExceptionReport:function(a,b){b.success=!1;b.exceptionReport={version:a.getAttribute("version"),language:a.getAttribute("language"),exceptions:[]};this.readChildNodes(a,b.exceptionReport)}},OpenLayers.Format.OWSCommon.v1.prototype.readers.ows)},writers:{ows:OpenLayers.Format.OWSCommon.v1.prototype.writers.ows},
+CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_0_0"});OpenLayers.Format.WFST.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFST.v1,{version:"1.1.0",schemaLocations:{wfs:"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},initialize:function(a){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[a]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[a])},readNode:function(a,b,c){return OpenLayers.Format.GML.v3.prototype.readNode.apply(this,arguments)},readers:{wfs:OpenLayers.Util.applyDefaults({FeatureCollection:function(a,
+b){b.numberOfFeatures=parseInt(a.getAttribute("numberOfFeatures"));OpenLayers.Format.WFST.v1.prototype.readers.wfs.FeatureCollection.apply(this,arguments)},TransactionResponse:function(a,b){b.insertIds=[];b.success=!1;this.readChildNodes(a,b)},TransactionSummary:function(a,b){b.success=!0},InsertResults:function(a,b){this.readChildNodes(a,b)},Feature:function(a,b){var c={fids:[]};this.readChildNodes(a,c);b.insertIds.push(c.fids[0])}},OpenLayers.Format.WFST.v1.prototype.readers.wfs),gml:OpenLayers.Format.GML.v3.prototype.readers.gml,
+feature:OpenLayers.Format.GML.v3.prototype.readers.feature,ogc:OpenLayers.Format.Filter.v1_1_0.prototype.readers.ogc,ows:OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows},writers:{wfs:OpenLayers.Util.applyDefaults({GetFeature:function(a){var b=OpenLayers.Format.WFST.v1.prototype.writers.wfs.GetFeature.apply(this,arguments);a&&this.setAttributes(b,{resultType:a.resultType,startIndex:a.startIndex,count:a.count});return b},Query:function(a){a=OpenLayers.Util.extend({featureNS:this.featureNS,
+featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},a);var b=a.featurePrefix,c=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(b?b+":":"")+a.featureType,srsName:a.srsName}});a.featureNS&&c.setAttribute("xmlns:"+b,a.featureNS);if(a.propertyNames)for(var b=0,d=a.propertyNames.length;b<d;b++)this.writeNode("wfs:PropertyName",{property:a.propertyNames[b]},c);a.filter&&(OpenLayers.Format.WFST.v1_1_0.prototype.setFilterProperty.call(this,a.filter),this.writeNode("ogc:Filter",
+a.filter,c));return c},PropertyName:function(a){return this.createElementNSPlus("wfs:PropertyName",{value:a.property})}},OpenLayers.Format.WFST.v1.prototype.writers.wfs),gml:OpenLayers.Format.GML.v3.prototype.writers.gml,feature:OpenLayers.Format.GML.v3.prototype.writers.feature,ogc:OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:!0,defaultFilter:null,initialize:function(a){a=a||{};OpenLayers.Util.extend(this,a);this.options=a},mergeWithDefaultFilter:function(a){return a&&this.defaultFilter?new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,a]}):a||this.defaultFilter||void 0},destroy:function(){this.format=this.options=null},read:function(a){a=a||{};a.filter=this.mergeWithDefaultFilter(a.filter)},create:function(){},
+update:function(){},"delete":function(){},commit:function(){},abort:function(a){},createCallback:function(a,b,c){return OpenLayers.Function.bind(function(){a.apply(this,[b,c])},this)},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:!0,features:null,data:null,reqFeatures:null,priv:null,error:null,initialize:function(a){OpenLayers.Util.extend(this,a)},success:function(){return 0<this.code},CLASS_NAME:"OpenLayers.Protocol.Response"});
+OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:" ",space:" ",newline:"\n",level:0,pretty:!1,nativeJSON:function(){return!(!window.JSON||"function"!=typeof JSON.parse||"function"!=typeof JSON.stringify)}(),read:function(a,b){var c;if(this.nativeJSON)c=JSON.parse(a,b);else try{if(/^[\],:{}\s]*$/.test(a.replace(/\\["\\\/bfnrtu]/g,"@").replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,"]").replace(/(?:^|:|,)(?:\s*\[)+/g,""))&&(c=eval("("+a+")"),"function"===
+typeof b)){var d=function(a,c){if(c&&"object"===typeof c)for(var e in c)c.hasOwnProperty(e)&&(c[e]=d(e,c[e]));return b(a,c)};c=d("",c)}}catch(e){}this.keepData&&(this.data=c);return c},write:function(a,b){this.pretty=!!b;var c=null,d=typeof a;if(this.serialize[d])try{c=!this.pretty&&this.nativeJSON?JSON.stringify(a):this.serialize[d].apply(this,[a])}catch(e){OpenLayers.Console.error("Trouble serializing: "+e)}return c},writeIndent:function(){var a=[];if(this.pretty)for(var b=0;b<this.level;++b)a.push(this.indent);
+return a.join("")},writeNewline:function(){return this.pretty?this.newline:""},writeSpace:function(){return this.pretty?this.space:""},serialize:{object:function(a){if(null==a)return"null";if(a.constructor==Date)return this.serialize.date.apply(this,[a]);if(a.constructor==Array)return this.serialize.array.apply(this,[a]);var b=["{"];this.level+=1;var c,d,e,f=!1;for(c in a)a.hasOwnProperty(c)&&(d=OpenLayers.Format.JSON.prototype.write.apply(this,[c,this.pretty]),e=OpenLayers.Format.JSON.prototype.write.apply(this,
+[a[c],this.pretty]),null!=d&&null!=e&&(f&&b.push(","),b.push(this.writeNewline(),this.writeIndent(),d,":",this.writeSpace(),e),f=!0));this.level-=1;b.push(this.writeNewline(),this.writeIndent(),"}");return b.join("")},array:function(a){var b,c=["["];this.level+=1;for(var d=0,e=a.length;d<e;++d)b=OpenLayers.Format.JSON.prototype.write.apply(this,[a[d],this.pretty]),null!=b&&(0<d&&c.push(","),c.push(this.writeNewline(),this.writeIndent(),b));this.level-=1;c.push(this.writeNewline(),this.writeIndent(),
+"]");return c.join("")},string:function(a){var b={"\b":"\\b","\t":"\\t","\n":"\\n","\f":"\\f","\r":"\\r",'"':'\\"',"\\":"\\\\"};return/["\\\x00-\x1f]/.test(a)?'"'+a.replace(/([\x00-\x1f\\"])/g,function(a,d){var e=b[d];if(e)return e;e=d.charCodeAt();return"\\u00"+Math.floor(e/16).toString(16)+(e%16).toString(16)})+'"':'"'+a+'"'},number:function(a){return isFinite(a)?String(a):"null"},"boolean":function(a){return String(a)},date:function(a){function b(a){return 10>a?"0"+a:a}return'"'+a.getFullYear()+
+"-"+b(a.getMonth()+1)+"-"+b(a.getDate())+"T"+b(a.getHours())+":"+b(a.getMinutes())+":"+b(a.getSeconds())+'"'}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:!1,read:function(a,b,c){b=b?b:"FeatureCollection";var d=null,e=null,e="string"==typeof a?OpenLayers.Format.JSON.prototype.read.apply(this,[a,c]):a;if(!e)OpenLayers.Console.error("Bad JSON: "+a);else if("string"!=typeof e.type)OpenLayers.Console.error("Bad GeoJSON - no type: "+a);else if(this.isValidType(e,b))switch(b){case "Geometry":try{d=this.parseGeometry(e)}catch(f){OpenLayers.Console.error(f)}break;case "Feature":try{d=
+this.parseFeature(e),d.type="Feature"}catch(g){OpenLayers.Console.error(g)}break;case "FeatureCollection":switch(d=[],e.type){case "Feature":try{d.push(this.parseFeature(e))}catch(h){d=null,OpenLayers.Console.error(h)}break;case "FeatureCollection":a=0;for(b=e.features.length;a<b;++a)try{d.push(this.parseFeature(e.features[a]))}catch(k){d=null,OpenLayers.Console.error(k)}break;default:try{var l=this.parseGeometry(e);d.push(new OpenLayers.Feature.Vector(l))}catch(m){d=null,OpenLayers.Console.error(m)}}}return d},
+isValidType:function(a,b){var c=!1;switch(b){case "Geometry":-1==OpenLayers.Util.indexOf("Point MultiPoint LineString MultiLineString Polygon MultiPolygon Box GeometryCollection".split(" "),a.type)?OpenLayers.Console.error("Unsupported geometry type: "+a.type):c=!0;break;case "FeatureCollection":c=!0;break;default:a.type==b?c=!0:OpenLayers.Console.error("Cannot convert types from "+a.type+" to "+b)}return c},parseFeature:function(a){var b,c,d;c=a.properties?a.properties:{};d=a.geometry&&a.geometry.bbox||
+a.bbox;try{b=this.parseGeometry(a.geometry)}catch(e){throw e;}b=new OpenLayers.Feature.Vector(b,c);d&&(b.bounds=OpenLayers.Bounds.fromArray(d));a.id&&(b.fid=a.id);return b},parseGeometry:function(a){if(null==a)return null;var b,c=!1;if("GeometryCollection"==a.type){if(!OpenLayers.Util.isArray(a.geometries))throw"GeometryCollection must have geometries array: "+a;b=a.geometries.length;for(var c=Array(b),d=0;d<b;++d)c[d]=this.parseGeometry.apply(this,[a.geometries[d]]);b=new OpenLayers.Geometry.Collection(c);
+c=!0}else{if(!OpenLayers.Util.isArray(a.coordinates))throw"Geometry must have coordinates array: "+a;if(!this.parseCoords[a.type.toLowerCase()])throw"Unsupported geometry type: "+a.type;try{b=this.parseCoords[a.type.toLowerCase()].apply(this,[a.coordinates])}catch(e){throw e;}}this.internalProjection&&(this.externalProjection&&!c)&&b.transform(this.externalProjection,this.internalProjection);return b},parseCoords:{point:function(a){if(!1==this.ignoreExtraDims&&2!=a.length)throw"Only 2D points are supported: "+
+a;return new OpenLayers.Geometry.Point(a[0],a[1])},multipoint:function(a){for(var b=[],c=null,d=0,e=a.length;d<e;++d){try{c=this.parseCoords.point.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.MultiPoint(b)},linestring:function(a){for(var b=[],c=null,d=0,e=a.length;d<e;++d){try{c=this.parseCoords.point.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.LineString(b)},multilinestring:function(a){for(var b=[],c=null,d=0,e=a.length;d<e;++d){try{c=
+this.parseCoords.linestring.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.MultiLineString(b)},polygon:function(a){for(var b=[],c,d,e=0,f=a.length;e<f;++e){try{d=this.parseCoords.linestring.apply(this,[a[e]])}catch(g){throw g;}c=new OpenLayers.Geometry.LinearRing(d.components);b.push(c)}return new OpenLayers.Geometry.Polygon(b)},multipolygon:function(a){for(var b=[],c=null,d=0,e=a.length;d<e;++d){try{c=this.parseCoords.polygon.apply(this,[a[d]])}catch(f){throw f;}b.push(c)}return new OpenLayers.Geometry.MultiPolygon(b)},
+box:function(a){if(2!=a.length)throw"GeoJSON box coordinates must have 2 elements";return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(a[0][0],a[0][1]),new OpenLayers.Geometry.Point(a[1][0],a[0][1]),new OpenLayers.Geometry.Point(a[1][0],a[1][1]),new OpenLayers.Geometry.Point(a[0][0],a[1][1]),new OpenLayers.Geometry.Point(a[0][0],a[0][1])])])}},write:function(a,b){var c={type:null};if(OpenLayers.Util.isArray(a)){c.type="FeatureCollection";var d=
+a.length;c.features=Array(d);for(var e=0;e<d;++e){var f=a[e];if(!f instanceof OpenLayers.Feature.Vector)throw"FeatureCollection only supports collections of features: "+f;c.features[e]=this.extract.feature.apply(this,[f])}}else 0==a.CLASS_NAME.indexOf("OpenLayers.Geometry")?c=this.extract.geometry.apply(this,[a]):a instanceof OpenLayers.Feature.Vector&&(c=this.extract.feature.apply(this,[a]),a.layer&&a.layer.projection&&(c.crs=this.createCRSObject(a)));return OpenLayers.Format.JSON.prototype.write.apply(this,
+[c,b])},createCRSObject:function(a){a=a.layer.projection.toString();var b={};a.match(/epsg:/i)&&(a=parseInt(a.substring(a.indexOf(":")+1)),b=4326==a?{type:"name",properties:{name:"urn:ogc:def:crs:OGC:1.3:CRS84"}}:{type:"name",properties:{name:"EPSG:"+a}});return b},extract:{feature:function(a){var b=this.extract.geometry.apply(this,[a.geometry]),b={type:"Feature",properties:a.attributes,geometry:b};null!=a.fid&&(b.id=a.fid);return b},geometry:function(a){if(null==a)return null;this.internalProjection&&
+this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));var b=a.CLASS_NAME.split(".")[2];a=this.extract[b.toLowerCase()].apply(this,[a]);return"Collection"==b?{type:"GeometryCollection",geometries:a}:{type:b,coordinates:a}},point:function(a){return[a.x,a.y]},multipoint:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.point.apply(this,[a.components[c]]));return b},linestring:function(a){for(var b=[],c=0,d=a.components.length;c<
+d;++c)b.push(this.extract.point.apply(this,[a.components[c]]));return b},multilinestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.linestring.apply(this,[a.components[c]]));return b},polygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.linestring.apply(this,[a.components[c]]));return b},multipolygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.polygon.apply(this,[a.components[c]]));return b},collection:function(a){for(var b=
+a.components.length,c=Array(b),d=0;d<b;++d)c[d]=this.extract.geometry.apply(this,[a.components[d]]);return c}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Protocol.Script=OpenLayers.Class(OpenLayers.Protocol,{url:null,params:null,callback:null,callbackTemplate:"OpenLayers.Protocol.Script.registry.${id}",callbackKey:"callback",callbackPrefix:"",scope:null,format:null,pendingRequests:null,srsInBBOX:!1,initialize:function(a){a=a||{};this.params={};this.pendingRequests={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);this.format||(this.format=new OpenLayers.Format.GeoJSON);if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var b=
+new OpenLayers.Format.QueryStringFilter({srsInBBOX:this.srsInBBOX});this.filterToParams=function(a,d){return b.write(a,d)}}},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,arguments);a=OpenLayers.Util.applyDefaults(a,this.options);a.params=OpenLayers.Util.applyDefaults(a.params,this.options.params);a.filter&&this.filterToParams&&(a.params=this.filterToParams(a.filter,a.params));var b=new OpenLayers.Protocol.Response({requestType:"read"}),c=this.createRequest(a.url,a.params,OpenLayers.Function.bind(function(c){b.data=
+c;this.handleRead(b,a)},this));b.priv=c;return b},createRequest:function(a,b,c){c=OpenLayers.Protocol.Script.register(c);var d=OpenLayers.String.format(this.callbackTemplate,{id:c});b=OpenLayers.Util.extend({},b);b[this.callbackKey]=this.callbackPrefix+d;a=OpenLayers.Util.urlAppend(a,OpenLayers.Util.getParameterString(b));b=document.createElement("script");b.type="text/javascript";b.src=a;b.id="OpenLayers_Protocol_Script_"+c;this.pendingRequests[b.id]=b;document.getElementsByTagName("head")[0].appendChild(b);
+return b},destroyRequest:function(a){OpenLayers.Protocol.Script.unregister(a.id.split("_").pop());delete this.pendingRequests[a.id];a.parentNode&&a.parentNode.removeChild(a)},handleRead:function(a,b){this.handleResponse(a,b)},handleResponse:function(a,b){b.callback&&(a.data?(a.features=this.parseFeatures(a.data),a.code=OpenLayers.Protocol.Response.SUCCESS):a.code=OpenLayers.Protocol.Response.FAILURE,this.destroyRequest(a.priv),b.callback.call(b.scope,a))},parseFeatures:function(a){return this.format.read(a)},
+abort:function(a){if(a)this.destroyRequest(a.priv);else for(var b in this.pendingRequests)this.destroyRequest(this.pendingRequests[b])},destroy:function(){this.abort();delete this.params;delete this.format;OpenLayers.Protocol.prototype.destroy.apply(this)},CLASS_NAME:"OpenLayers.Protocol.Script"});(function(){var a=OpenLayers.Protocol.Script,b=0;a.registry={};a.register=function(c){var d="c"+ ++b;a.registry[d]=function(){c.apply(this,arguments)};return d};a.unregister=function(b){delete a.registry[b]}})();OpenLayers.Format.EncodedPolyline=OpenLayers.Class(OpenLayers.Format,{geometryType:"linestring",initialize:function(a){OpenLayers.Format.prototype.initialize.apply(this,[a])},read:function(a){var b;if("linestring"==this.geometryType)b=OpenLayers.Geometry.LineString;else if("linearring"==this.geometryType)b=OpenLayers.Geometry.LinearRing;else if("multipoint"==this.geometryType)b=OpenLayers.Geometry.MultiPoint;else if("point"!=this.geometryType&&"polygon"!=this.geometryType)r
eturn null;a=this.decodeDeltas(a,
+2);for(var c=a.length,d=[],e=0;e+1<c;){var f=a[e++],g=a[e++];d.push(new OpenLayers.Geometry.Point(g,f))}return"point"==this.geometryType?new OpenLayers.Feature.Vector(d[0]):"polygon"==this.geometryType?new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(d)])):new OpenLayers.Feature.Vector(new b(d))},decode:function(a,b,c){a=this.decodeDeltas(a,b,c||1E5);c=a.length;for(var d=[],e=0;e+(b-1)<c;){for(var f=[],g=0;g<b;++g)f.push(a[e++]);d.push(f)}return d},
+write:function(a){a=(a.constructor==Array?a[0]:a).geometry;var b=a.CLASS_NAME.split(".")[2].toLowerCase();if("point"==b)a=Array(a);else if("linestring"==b||"linearring"==b||"multipoint"==b)a=a.components;else if("polygon"==b)a=a.components[0].components;else return null;for(var b=[],c=a.length,d=0;d<c;++d){var e=a[d];b.push(e.y);b.push(e.x)}return this.encodeDeltas(b,2)},encode:function(a,b,c){c=c||1E5;for(var d=[],e=a.length,f=0;f<e;++f)for(var g=a[f],h=0;h<b;++h)d.push(g[h]);return this.encodeDeltas(d,
+b,c)},encodeDeltas:function(a,b,c){var d,e=Array(b);for(d=0;d<b;++d)e[d]=0;for(var f=a.length,g=0;g<f;)for(d=0;d<b;++d,++g){var h=a[g],k=h-e[d];e[d]=h;a[g]=k}return this.encodeFloats(a,c||1E5)},decodeDeltas:function(a,b,c){var d,e=Array(b);for(d=0;d<b;++d)e[d]=0;a=this.decodeFloats(a,c||1E5);c=a.length;for(var f=0;f<c;)for(d=0;d<b;++d,++f)e[d]+=a[f],a[f]=e[d];return a},encodeFloats:function(a,b){for(var c=b||1E5,d=a.length,e=0;e<d;++e)a[e]=Math.round(a[e]*c);return this.encodeSignedIntegers(a)},decodeFloats:function(a,
+b){for(var c=b||1E5,d=this.decodeSignedIntegers(a),e=d.length,f=0;f<e;++f)d[f]/=c;return d},encodeSignedIntegers:function(a){for(var b=a.length,c=0;c<b;++c){var d=a[c],e=d<<1;0>d&&(e=~e);a[c]=e}return this.encodeUnsignedIntegers(a)},decodeSignedIntegers:function(a){a=this.decodeUnsignedIntegers(a);for(var b=a.length,c=0;c<b;++c){var d=a[c];a[c]=d&1?~(d>>1):d>>1}return a},encodeUnsignedIntegers:function(a){for(var b="",c=a.length,d=0;d<c;++d)b+=this.encodeUnsignedInteger(a[d]);return b},decodeUnsignedIntegers:function(a){for(var b=
+[],c=0,d=0,e=a.length,f=0;f<e;++f){var g=a.charCodeAt(f)-63,c=c|(g&31)<<d;32>g?(b.push(c),d=c=0):d+=5}return b},encodeFloat:function(a,b){a=Math.round(a*(b||1E5));return this.encodeSignedInteger(a)},decodeFloat:function(a,b){return this.decodeSignedInteger(a)/(b||1E5)},encodeSignedInteger:function(a){var b=a<<1;0>a&&(b=~b);return this.encodeUnsignedInteger(b)},decodeSignedInteger:function(a){a=this.decodeUnsignedInteger(a);return a&1?~(a>>1):a>>1},encodeUnsignedInteger:function(a){for(var b,c="";32<=
+a;)b=(32|a&31)+63,c+=String.fromCharCode(b),a>>=5;return c+=String.fromCharCode(a+63)},decodeUnsignedInteger:function(a){for(var b=0,c=0,d=a.length,e=0;e<d;++e){var f=a.charCodeAt(e)-63,b=b|(f&31)<<c;if(32>f)break;c+=5}return b},CLASS_NAME:"OpenLayers.Format.EncodedPolyline"});OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:!0,defaultControl:null,saveState:!1,allowDepress:!1,activeState:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.controls=[];this.activeState={}},destroy:function(){this.map&&this.map.events.unregister("buttonclick",this,this.onButtonClick);OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var a,b=this.controls.length-1;0<=b;b--)a=this.controls[b],a.events&&
+a.events.un({activate:this.iconOn,deactivate:this.iconOff}),a.panel_div=null;this.activeState=null},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){for(var a,b=0,c=this.controls.length;b<c;b++)a=this.controls[b],(a===this.defaultControl||this.saveState&&this.activeState[a.id])&&a.activate();!0===this.saveState&&(this.defaultControl=null);this.redraw();return!0}return!1},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){for(var a,
+b=0,c=this.controls.length;b<c;b++)a=this.controls[b],this.activeState[a.id]=a.deactivate();this.redraw();return!0}return!1},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.outsideViewport?(this.events.attachToElement(this.div),this.events.register("buttonclick",this,this.onButtonClick)):this.map.events.register("buttonclick",this,this.onButtonClick);this.addControlsToMap(this.controls);return this.div},redraw:function(){for(var a=this.div.childNodes.length-1;0<=a;a--)this.div.removeChild(this.div.childNodes[a]);
+this.div.innerHTML="";if(this.active)for(var a=0,b=this.controls.length;a<b;a++)this.div.appendChild(this.controls[a].panel_div)},activateControl:function(a){if(!this.active)return!1;if(a.type==OpenLayers.Control.TYPE_BUTTON)a.trigger();else if(a.type==OpenLayers.Control.TYPE_TOGGLE)a.active?a.deactivate():a.activate();else if(this.allowDepress&&a.active)a.deactivate();else{for(var b,c=0,d=this.controls.length;c<d;c++)b=this.controls[c],b==a||b.type!==OpenLayers.Control.TYPE_TOOL&&null!=b.type||b.deactivate();
+a.activate()}},addControls:function(a){OpenLayers.Util.isArray(a)||(a=[a]);this.controls=this.controls.concat(a);for(var b=0,c=a.length;b<c;b++){var d=a[b],e=this.createControlMarkup(d);OpenLayers.Element.addClass(e,d.displayClass+"ItemInactive");OpenLayers.Element.addClass(e,"olButton");""==d.title||e.title||(e.title=d.title);d.panel_div=e}this.map&&(this.addControlsToMap(a),this.redraw())},createControlMarkup:function(a){return document.createElement("div")},addControlsToMap:function(a){for(var b,
+c=0,d=a.length;c<d;c++)b=a[c],!0===b.autoActivate?(b.autoActivate=!1,this.map.addControl(b),b.autoActivate=!0):(this.map.addControl(b),b.deactivate()),b.events.on({activate:this.iconOn,deactivate:this.iconOff})},iconOn:function(){var a=this.panel_div;a.className=a.className.replace(RegExp("\\b("+this.displayClass+"Item)Inactive\\b"),"$1Active")},iconOff:function(){var a=this.panel_div;a.className=a.className.replace(RegExp("\\b("+this.displayClass+"Item)Active\\b"),"$1Inactive")},onButtonClick:function(a){var b=
+this.controls;a=a.buttonElement;for(var c=b.length-1;0<=c;--c)if(b[c].panel_div===a){this.activateControl(b[c]);break}},getControlsBy:function(a,b){var c="function"==typeof b.test;return OpenLayers.Array.filter(this.controls,function(d){return d[a]==b||c&&b.test(d[a])})},getControlsByName:function(a){return this.getControlsBy("name",a)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",a)},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Control.ZoomIn=OpenLayers.Class(OpenLayers.Control.Button,{trigger:function(){this.map&&this.map.zoomIn()},CLASS_NAME:"OpenLayers.Control.ZoomIn"});OpenLayers.Control.ZoomOut=OpenLayers.Class(OpenLayers.Control.Button,{trigger:function(){this.map&&this.map.zoomOut()},CLASS_NAME:"OpenLayers.Control.ZoomOut"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(Op
enLayers.Control.Button,{trigger:function(){this.map&&this.map.zoomToMaxExtent()},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Control.ZoomPanel=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(a){OpenLayers.Control.Panel.prototype.initialize.apply(this,[a]);this.addControls([new OpenLayers.Control.ZoomIn,new OpenLayers.Control.ZoomToMaxExtent,new OpenLayers.Control.ZoomOut])},CLASS_NAME:"OpenLayers.Control.ZoomPanel"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:!1,initialize:function(a,b,c,d){OpenLayers.Layer.prototype.initialize.apply(this,[a,d]);this.url=b;this.params||(this.params=OpenLayers.Util.extend({},c))},destroy:function(){this.params=this.url=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions()));
+return a=OpenLayers.Layer.prototype.clone.apply(this,[a])},setUrl:function(a){this.url=a},mergeNewParams:function(a){this.params=OpenLayers.Util.extend(this.params,a);a=this.redraw();null!=this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});return a},redraw:function(a){return a?this.mergeNewParams({_olSalt:Math.random()}):OpenLayers.Layer.prototype.redraw.apply(this,[])},selectUrl:function(a,b){for(var c=1,d=0,e=a.length;d<e;d++)c*=a.charCodeAt(d)*this.URL_HASH_FACTOR,
+c-=Math.floor(c);return b[Math.floor(c*b.length)]},getFullRequestString:function(a,b){var c=b||this.url,d=OpenLayers.Util.extend({},this.params),d=OpenLayers.Util.extend(d,a),e=OpenLayers.Util.getParameterString(d);OpenLayers.Util.isArray(c)&&(c=this.selectUrl(e,c));var e=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c)),f;for(f in d)f.toUpperCase()in e&&delete d[f];e=OpenLayers.Util.getParameterString(d);return OpenLayers.Util.urlAppend(c,e)},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Tile=OpenLayers.Class({events:null,eventListeners:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:!1,initialize:function(a,b,c,d,e,f){this.layer=a;this.position=b.clone();this.setBounds(c);this.url=d;e&&(this.size=e.clone());this.id=OpenLayers.Util.createUniqueID("Tile_");OpenLayers.Util.extend(this,f);this.events=new OpenLayers.Events(this);if(this.eventListeners instanceof Object)this.events.on(this.eventListeners)},unload:function()
{this.isLoading&&(this.isLoading=
+!1,this.events.triggerEvent("unload"))},destroy:function(){this.position=this.size=this.bounds=this.layer=null;this.eventListeners&&this.events.un(this.eventListeners);this.events.destroy();this.events=this.eventListeners=null},draw:function(a){a||this.clear();var b=this.shouldDraw();b&&(!a&&!1===this.events.triggerEvent("beforedraw"))&&(b=null);return b},shouldDraw:function(){var a=!1,b=this.layer.maxExtent;if(b){var c=this.layer.map,c=c.baseLayer.wrapDateLine&&c.getMaxExtent();this.bounds.intersectsBounds(b,
+{inclusive:!1,worldBounds:c})&&(a=!0)}return a||this.layer.displayOutsideMaxExtent},setBounds:function(a){a=a.clone();if(this.layer.map.baseLayer.wrapDateLine){var b=this.layer.map.getMaxExtent(),c=this.layer.map.getResolution();a=a.wrapDateLine(b,{leftTolerance:c,rightTolerance:c})}this.bounds=a},moveTo:function(a,b,c){null==c&&(c=!0);this.setBounds(a);this.position=b.clone();c&&this.draw()},clear:function(a){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,imageReloadAttempts:null,layerAlphaHack:null,asyncRequestId:null,maxGetUrlLength:null,canvasContext:null,crossOriginKeyword:null,initialize:function(a,b,c,d,e,f){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=d;this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();if(null!=this.maxGetUrlLength||this.layer.gutter||this.layerAlphaHack)this.frame=document.createElement("div"),this.frame.style.position=
+"absolute",this.frame.style.overflow="hidden";null!=this.maxGetUrlLength&&OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame)},destroy:function(){this.imgDiv&&(this.clear(),this.frame=this.imgDiv=null);this.asyncRequestId=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments)},draw:function(){var a=OpenLayers.Tile.prototype.draw.apply(this,arguments);a?(this.layer!=this.layer.map.baseLayer&&this.layer.reproject&&(this.bounds=this.getBoundsFromBaseLayer(this.position)),this.isLoading?this._loadEvent=
+"reload":(this.isLoading=!0,this._loadEvent="loadstart"),this.renderTile(),this.positionTile()):!1===a&&this.unload();return a},renderTile:function(){if(this.layer.async){var a=this.asyncRequestId=(this.asyncRequestId||0)+1;this.layer.getURLasync(this.bounds,function(b){a==this.asyncRequestId&&(this.url=b,this.initImage())},this)}else this.url=this.layer.getURL(this.bounds),this.initImage()},positionTile:function(){var a=this.getTile().style,b=this.frame?this.size:this.layer.getImageSize(this.bounds),
+c=1;this.layer instanceof OpenLayers.Layer.Grid&&(c=this.layer.getServerResolution()/this.layer.map.getResolution());a.left=this.position.x+"px";a.top=this.position.y+"px";a.width=Math.round(c*b.w)+"px";a.height=Math.round(c*b.h)+"px"},clear:function(){OpenLayers.Tile.prototype.clear.apply(this,arguments);var a=this.imgDiv;if(a){var b=this.getTile();b.parentNode===this.layer.div&&this.layer.div.removeChild(b);this.setImgSrc();!0===this.layerAlphaHack&&(a.style.filter="");OpenLayers.Element.removeClass(a,
+"olImageLoadError")}this.canvasContext=null},getImage:function(){if(!this.imgDiv){this.imgDiv=OpenLayers.Tile.Image.IMAGE.cloneNode(!1);var a=this.imgDiv.style;if(this.frame){var b=0,c=0;this.layer.gutter&&(b=100*(this.layer.gutter/this.layer.tileSize.w),c=100*(this.layer.gutter/this.layer.tileSize.h));a.left=-b+"%";a.top=-c+"%";a.width=2*b+100+"%";a.height=2*c+100+"%"}a.visibility="hidden";a.opacity=0;1>this.layer.opacity&&(a.filter="alpha(opacity="+100*this.layer.opacity+")");a.position="absolute";
+this.layerAlphaHack&&(a.paddingTop=a.height,a.height="0",a.width="100%");this.frame&&this.frame.appendChild(this.imgDiv)}return this.imgDiv},setImage:function(a){this.imgDiv=a},initImage:function(){if(this.url||this.imgDiv){this.events.triggerEvent("beforeload");this.layer.div.appendChild(this.getTile());this.events.triggerEvent(this._loadEvent);var a=this.getImage(),b=a.getAttribute("src")||"";this.url&&OpenLayers.Util.isEquivalentUrl(b,this.url)?this._loadTimeout=window.setTimeout(OpenLayers.Function.bind(this.onImageLoad,
+this),0):(this.stopLoading(),this.crossOriginKeyword&&a.removeAttribute("crossorigin"),OpenLayers.Event.observe(a,"load",OpenLayers.Function.bind(this.onImageLoad,this)),OpenLayers.Event.observe(a,"error",OpenLayers.Function.bind(this.onImageError,this)),this.imageReloadAttempts=0,this.setImgSrc(this.url))}else this.isLoading=!1},setImgSrc:function(a){var b=this.imgDiv;a?(b.style.visibility="hidden",b.style.opacity=0,this.crossOriginKeyword&&("data:"!==a.substr(0,5)?b.setAttribute("crossorigin",this.crossOriginKeyword):
+b.removeAttribute("crossorigin")),b.src=a):(this.stopLoading(),this.imgDiv=null,b.parentNode&&b.parentNode.removeChild(b))},getTile:function(){return this.frame?this.frame:this.getImage()},createBackBuffer:function(){if(this.imgDiv&&!this.isLoading){var a;this.frame?(a=this.frame.cloneNode(!1),a.appendChild(this.imgDiv)):a=this.imgDiv;this.imgDiv=null;return a}},onImageLoad:function(){var a=this.imgDiv;this.stopLoading();a.style.visibility="inherit";a.style.opacity=this.layer.opacity;this.isLoading=
+!1;this.canvasContext=null;this.events.triggerEvent("loadend");!0===this.layerAlphaHack&&(a.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+a.src+"', sizingMethod='scale')")},onImageError:function(){var a=this.imgDiv;null!=a.src&&(this.imageReloadAttempts++,this.imageReloadAttempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS?this.setImgSrc(this.layer.getURL(this.bounds)):(OpenLayers.Element.addClass(a,"olImageLoadError"),this.events.triggerEvent("loaderror"),this.onImageLoad()))},stopLoading:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);
+window.clearTimeout(this._loadTimeout);delete this._loadTimeout},getCanvasContext:function(){if(OpenLayers.CANVAS_SUPPORTED&&this.imgDiv&&!this.isLoading){if(!this.canvasContext){var a=document.createElement("canvas");a.width=this.size.w;a.height=this.size.h;this.canvasContext=a.getContext("2d");this.canvasContext.drawImage(this.imgDiv,0,0)}return this.canvasContext}},CLASS_NAME:"OpenLayers.Tile.Image"});
+OpenLayers.Tile.Image.IMAGE=function(){var a=new Image;a.className="olTileImage";a.galleryImg="no";return a}();OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,tileClass:OpenLayers.Tile.Image,grid:null,singleTile:!1,ratio:1.5,buffer:0,transitionEffect:"resize",numLoadingTiles:0,serverResolutions:null,loading:!1,backBuffer:null,gridResolution:null,backBufferResolution:null,backBufferLonLat:null,backBufferTimerId:null,removeBackBufferDelay:null,className:null,gridLayout:null,rowSign:null,transitionendEvents:["transitionend",
+"webkitTransitionEnd","otransitionend","oTransitionEnd"],initialize:function(a,b,c,d){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.grid=[];this._removeBackBuffer=OpenLayers.Function.bind(this.removeBackBuffer,this);this.initProperties();this.rowSign="t"===this.tileOriginCorner.substr(0,1)?1:-1},initProperties:function(){void 0===this.options.removeBackBufferDelay&&(this.removeBackBufferDelay=this.singleTile?0:2500);void 0===this.options.className&&(this.className=this.singleTile?
+"olLayerGridSingleTile":"olLayerGrid")},setMap:function(a){OpenLayers.Layer.HTTPRequest.prototype.setMap.call(this,a);OpenLayers.Element.addClass(this.div,this.className)},removeMap:function(a){this.removeBackBuffer()},destroy:function(){this.removeBackBuffer();this.clearGrid();this.tileSize=this.grid=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments)},clearGrid:function(){if(this.grid){for(var a=0,b=this.grid.length;a<b;a++)for(var c=this.grid[a],d=0,e=c.length;d<e;d++)this.destroyTile(c[d]);
+this.grid=[];this.gridLayout=this.gridResolution=null}},addOptions:function(a,b){var c=void 0!==a.singleTile&&a.singleTile!==this.singleTile;OpenLayers.Layer.HTTPRequest.prototype.addOptions.apply(this,arguments);this.map&&c&&(this.initProperties(),this.clearGrid(),this.tileSize=this.options.tileSize,this.setTileSize(),this.moveTo(null,!0))},clone:function(a){null==a&&(a=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions()));a=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,
+[a]);null!=this.tileSize&&(a.tileSize=this.tileSize.clone());a.grid=[];a.gridResolution=null;a.backBuffer=null;a.backBufferTimerId=null;a.loading=!1;a.numLoadingTiles=0;return a},moveTo:function(a,b,c){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);a=a||this.map.getExtent();if(null!=a){var d=!this.grid.length||b,e=this.getTilesBounds(),f=this.map.getResolution();this.getServerResolution(f);if(this.singleTile){if(d||!c&&!e.containsBounds(a))b&&"resize"!==this.transitionEffect&&
+this.removeBackBuffer(),b&&"resize"!==this.transitionEffect||this.applyBackBuffer(f),this.initSingleTile(a)}else(d=d||!e.intersectsBounds(a,{worldBounds:this.map.baseLayer.wrapDateLine&&this.map.getMaxExtent()}))?(!b||"resize"!==this.transitionEffect&&this.gridResolution!==f||this.applyBackBuffer(f),this.initGriddedTiles(a)):this.moveGriddedTiles()}},getTileData:function(a){var b=null,c=a.lon,d=a.lat,e=this.grid.length;if(this.map&&e){var f=this.map.getResolution();a=this.tileSize.w;var g=this.tileSize.h,
+h=this.grid[0][0].bounds,k=h.left,h=h.top;if(c<k&&this.map.baseLayer.wrapDateLine)var l=this.map.getMaxExtent().getWidth(),m=Math.ceil((k-c)/l),c=c+l*m;c=(c-k)/(f*a);d=(h-d)/(f*g);f=Math.floor(c);k=Math.floor(d);0<=k&&k<e&&(e=this.grid[k][f])&&(b={tile:e,i:Math.floor((c-f)*a),j:Math.floor((d-k)*g)})}return b},destroyTile:function(a){this.removeTileMonitoringHooks(a);a.destroy()},getServerResolution:function(a){var b=Number.POSITIVE_INFINITY;a=a||this.map.getResolution();if(this.serverResolutions&&
+-1===OpenLayers.Util.indexOf(this.serverResolutions,a)){var c,d,e,f;for(c=this.serverResolutions.length-1;0<=c;c--){e=this.serverResolutions[c];d=Math.abs(e-a);if(d>b)break;b=d;f=e}a=f}return a},getServerZoom:function(){var a=this.getServerResolution();return this.serverResolutions?OpenLayers.Util.indexOf(this.serverResolutions,a):this.map.getZoomForResolution(a)+(this.zoomOffset||0)},applyBackBuffer:function(a){null!==this.backBufferTimerId&&this.removeBackBuffer();var b=this.backBuffer;if(!b){b=
+this.createBackBuffer();if(!b)return;a===this.gridResolution?this.div.insertBefore(b,this.div.firstChild):this.map.baseLayer.div.parentNode.insertBefore(b,this.map.baseLayer.div);this.backBuffer=b;var c=this.grid[0][0].bounds;this.backBufferLonLat={lon:c.left,lat:c.top};this.backBufferResolution=this.gridResolution}for(var c=this.backBufferResolution/a,d=b.childNodes,e,f=d.length-1;0<=f;--f)e=d[f],e.style.top=(c*e._i*e._h|0)+"px",e.style.left=(c*e._j*e._w|0)+"px",e.style.width=Math.round(c*e._w)+
+"px",e.style.height=Math.round(c*e._h)+"px";a=this.getViewPortPxFromLonLat(this.backBufferLonLat,a);c=this.map.layerContainerOriginPx.y;b.style.left=Math.round(a.x-this.map.layerContainerOriginPx.x)+"px";b.style.top=Math.round(a.y-c)+"px"},createBackBuffer:function(){var a;if(0<this.grid.length){a=document.createElement("div");a.id=this.div.id+"_bb";a.className="olBackBuffer";a.style.position="absolute";var b=this.map;a.style.zIndex="resize"===this.transitionEffect?this.getZIndex()-1:b.Z_INDEX_BASE.BaseLayer-
+(b.getNumLayers()-b.getLayerIndex(this));for(var b=0,c=this.grid.length;b<c;b++)for(var d=0,e=this.grid[b].length;d<e;d++){var f=this.grid[b][d],g=this.grid[b][d].createBackBuffer();g&&(g._i=b,g._j=d,g._w=f.size.w,g._h=f.size.h,g.id=f.id+"_bb",a.appendChild(g))}}return a},removeBackBuffer:function(){if(this._transitionElement){for(var a=this.transitionendEvents.length-1;0<=a;--a)OpenLayers.Event.stopObserving(this._transitionElement,this.transitionendEvents[a],this._removeBackBuffer);delete this._transitionElement}this.backBuffer&&
+(this.backBuffer.parentNode&&this.backBuffer.parentNode.removeChild(this.backBuffer),this.backBufferResolution=this.backBuffer=null,null!==this.backBufferTimerId&&(window.clearTimeout(this.backBufferTimerId),this.backBufferTimerId=null))},moveByPx:function(a,b){this.singleTile||this.moveGriddedTiles()},setTileSize:function(a){this.singleTile&&(a=this.map.getSize(),a.h=parseInt(a.h*this.ratio,10),a.w=parseInt(a.w*this.ratio,10));OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[a])},getTilesBounds:function(){var a=
+null,b=this.grid.length;if(b)var a=this.grid[b-1][0].bounds,b=this.grid[0].length*a.getWidth(),c=this.grid.length*a.getHeight(),a=new OpenLayers.Bounds(a.left,a.bottom,a.left+b,a.bottom+c);return a},initSingleTile:function(a){this.events.triggerEvent("retile");var b=a.getCenterLonLat(),c=a.getWidth()*this.ratio;a=a.getHeight()*this.ratio;b=new OpenLayers.Bounds(b.lon-c/2,b.lat-a/2,b.lon+c/2,b.lat+a/2);c=this.map.getLayerPxFromLonLat({lon:b.left,lat:b.top});this.grid.length||(this.grid[0]=[]);(a=this.grid[0][0])?
+a.moveTo(b,c):(a=this.addTile(b,c),this.addTileMonitoringHooks(a),a.draw(),this.grid[0][0]=a);this.removeExcessTiles(1,1);this.gridResolution=this.getServerResolution()},calculateGridLayout:function(a,b,c){var d=c*this.tileSize.w;c*=this.tileSize.h;var e=Math.floor((a.left-b.lon)/d)-this.buffer,f=this.rowSign;a=Math[~f?"floor":"ceil"](f*(b.lat-a.top+c)/c)-this.buffer*f;return{tilelon:d,tilelat:c,startcol:e,startrow:a}},getTileOrigin:function(){var a=this.tileOrigin;if(!a)var a=this.getMaxExtent(),
+b={tl:["left","top"],tr:["right","top"],bl:["left","bottom"],br:["right","bottom"]}[this.tileOriginCorner],a=new OpenLayers.LonLat(a[b[0]],a[b[1]]);return a},getTileBoundsForGridIndex:function(a,b){var c=this.getTileOrigin(),d=this.gridLayout,e=d.tilelon,f=d.tilelat,g=d.startcol,d=d.startrow,h=this.rowSign;return new OpenLayers.Bounds(c.lon+(g+b)*e,c.lat-(d+a*h)*f*h,c.lon+(g+b+1)*e,c.lat-(d+(a-1)*h)*f*h)},initGriddedTiles:function(a){this.events.triggerEvent("retile");var b=this.map.getSize(),c=this.getTileOrigin(),
+d=this.map.getResolution(),e=this.getServerResolution(),f=d/e,d=this.tileSize.w/f,f=this.tileSize.h/f,g=Math.ceil(b.h/f)+2*this.buffer+1,b=Math.ceil(b.w/d)+2*this.buffer+1;this.gridLayout=e=this.calculateGridLayout(a,c,e);var c=e.tilelon,h=e.tilelat,e=this.map.layerContainerOriginPx.x,k=this.map.layerContainerOriginPx.y,l=this.getTileBoundsForGridIndex(0,0),m=this.map.getViewPortPxFromLonLat(new OpenLayers.LonLat(l.left,l.top));m.x=Math.round(m.x)-e;m.y=Math.round(m.y)-k;var e=[],k=this.map.getCenter(),
+n=0;do{var p=this.grid[n];p||(p=[],this.grid.push(p));var q=0;do{var l=this.getTileBoundsForGridIndex(n,q),r=m.clone();r.x+=q*Math.round(d);r.y+=n*Math.round(f);var s=p[q];s?s.moveTo(l,r,!1):(s=this.addTile(l,r),this.addTileMonitoringHooks(s),p.push(s));r=l.getCenterLonLat();e.push({tile:s,distance:Math.pow(r.lon-k.lon,2)+Math.pow(r.lat-k.lat,2)});q+=1}while(l.right<=a.right+c*this.buffer||q<b);n+=1}while(l.bottom>=a.bottom-h*this.buffer||n<g);this.removeExcessTiles(n,q);this.gridResolution=d=this.getServerResolution();
+e.sort(function(a,b){return a.distance-b.distance});a=0;for(d=e.length;a<d;++a)e[a].tile.draw()},getMaxExtent:function(){return this.maxExtent},addTile:function(a,b){var c=new this.tileClass(this,b,a,null,this.tileSize,this.tileOptions);this.events.triggerEvent("addtile",{tile:c});return c},addTileMonitoringHooks:function(a){a.onLoadStart=function(){!1===this.loading&&(this.loading=!0,this.events.triggerEvent("loadstart"));this.events.triggerEvent("tileloadstart",{tile:a});this.numLoadingTiles++;
+!this.singleTile&&(this.backBuffer&&this.gridResolution===this.backBufferResolution)&&OpenLayers.Element.addClass(a.getTile(),"olTileReplacing")};a.onLoadEnd=function(b){this.numLoadingTiles--;b="unload"===b.type;this.events.triggerEvent("tileloaded",{tile:a,aborted:b});if(!this.singleTile&&!b&&this.backBuffer&&this.gridResolution===this.backBufferResolution){var c=a.getTile();if("none"===OpenLayers.Element.getStyle(c,"display")){var d=document.getElementById(a.id+"_bb");d&&d.parentNode.removeChild(d)}OpenLayers.Element.removeClass(c,
+"olTileReplacing")}if(0===this.numLoadingTiles){if(this.backBuffer)if(0===this.backBuffer.childNodes.length)this.removeBackBuffer();else{this._transitionElement=b?this.div.lastChild:a.imgDiv;b=this.transitionendEvents;for(c=b.length-1;0<=c;--c)OpenLayers.Event.observe(this._transitionElement,b[c],this._removeBackBuffer);this.backBufferTimerId=window.setTimeout(this._removeBackBuffer,this.removeBackBufferDelay)}this.loading=!1;this.events.triggerEvent("loadend")}};a.onLoadError=function(){this.events.triggerEvent("tileerror",
+{tile:a})};a.events.on({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,loaderror:a.onLoadError,scope:this})},removeTileMonitoringHooks:function(a){a.unload();a.events.un({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,loaderror:a.onLoadError,scope:this})},moveGriddedTiles:function(){for(var a=this.buffer+1;;){var b=this.grid[0][0],c=b.position.x+this.map.layerContainerOriginPx.x,b=b.position.y+this.map.layerContainerOriginPx.y,d=this.getServerResolution()/this.map.getResolution(),
+d={w:Math.round(this.tileSize.w*d),h:Math.round(this.tileSize.h*d)};if(c>-d.w*(a-1))this.shiftColumn(!0,d);else if(c<-d.w*a)this.shiftColumn(!1,d);else if(b>-d.h*(a-1))this.shiftRow(!0,d);else if(b<-d.h*a)this.shiftRow(!1,d);else break}},shiftRow:function(a,b){var c=this.grid,d=a?0:c.length-1,e=a?-1:1;this.gridLayout.startrow+=e*this.rowSign;for(var f=c[d],g=c[a?"pop":"shift"](),h=0,k=g.length;h<k;h++){var l=g[h],m=f[h].position.clone();m.y+=b.h*e;l.moveTo(this.getTileBoundsForGridIndex(d,h),m)}c[a?
+"unshift":"push"](g)},shiftColumn:function(a,b){var c=this.grid,d=a?0:c[0].length-1,e=a?-1:1;this.gridLayout.startcol+=e;for(var f=0,g=c.length;f<g;f++){var h=c[f],k=h[d].position.clone(),l=h[a?"pop":"shift"]();k.x+=b.w*e;l.moveTo(this.getTileBoundsForGridIndex(f,d),k);h[a?"unshift":"push"](l)}},removeExcessTiles:function(a,b){for(var c,d;this.grid.length>a;){var e=this.grid.pop();c=0;for(d=e.length;c<d;c++){var f=e[c];this.destroyTile(f)}}c=0;for(d=this.grid.length;c<d;c++)for(;this.grid[c].length>
+b;)e=this.grid[c],f=e.pop(),this.destroyTile(f)},onMapResize:function(){this.singleTile&&(this.clearGrid(),this.setTileSize())},getTileBounds:function(a){var b=this.maxExtent,c=this.getResolution(),d=c*this.tileSize.w,c=c*this.tileSize.h,e=this.getLonLatFromViewPortPx(a);a=b.left+d*Math.floor((e.lon-b.left)/d);b=b.bottom+c*Math.floor((e.lat-b.bottom)/c);return new OpenLayers.Bounds(a,b,a+d,b+c)},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:"antialiasing blockout font fontcolor fontsize fontstyle glowing interval outline printmode shadow transparency".split(" "),request:null,response:null,initialize:function(a){this.request=new OpenLayers.Format.ArcXML.Request;this.response=new OpenLayers.Format.ArcXML.Response;if(a)if("feature"==a.requesttype){this.request.get_image=null;var b=this.request.get_feature.query;this.addCoordSys(b.featurecoordsys,a.featureCoordSys);
+this.addCoordSys(b.filtercoordsys,a.filterCoordSys);a.polygon?(b.isspatial=!0,b.spatialfilter.polygon=a.polygon):a.envelope&&(b.isspatial=!0,b.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0},this.parseEnvelope(b.spatialfilter.envelope,a.envelope))}else"image"==a.requesttype?(this.request.get_feature=null,b=this.request.get_image.properties,this.parseEnvelope(b.envelope,a.envelope),this.addLayers(b.layerlist,a.layers),this.addImageSize(b.imagesize,a.tileSize),this.addCoordSys(b.featurecoordsys,
+a.featureCoordSys),this.addCoordSys(b.filtercoordsys,a.filterCoordSys)):this.request=null;OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},parseEnvelope:function(a,b){b&&4==b.length&&(a.minx=b[0],a.miny=b[1],a.maxx=b[2],a.maxy=b[3])},addLayers:function(a,b){for(var c=0,d=b.length;c<d;c++)a.push(b[c])},addImageSize:function(a,b){null!==b&&(a.width=b.w,a.height=b.h,a.printwidth=b.w,a.printheight=b.h)},addCoordSys:function(a,b){"string"==typeof b?(a.id=parseInt(b),a.string=b):"object"==typeof b&&
+null!==b.proj&&(a.id=b.proj.srsProjNumber,a.string=b.proj.srsCode)},iserror:function(a){var b=null;a?(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]),a=a.documentElement.getElementsByTagName("ERROR"),b=null!==a&&0<a.length):b=""!==this.response.error;return b},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=null;a&&a.documentElement&&(b="ARCXML"==a.documentElement.nodeName?a.documentElement:a.documentElement.getElementsByTagName("ARCXML")[0]);
+if(!b||"parsererror"===b.firstChild.nodeName){var c,d;try{c=a.firstChild.nodeValue,d=a.firstChild.childNodes[1].firstChild.nodeValue}catch(e){}throw{message:"Error parsing the ArcXML request",error:c,source:d};}return this.parseResponse(b)},write:function(a){a||(a=this.request);var b=this.createElementNS("","ARCXML");b.setAttribute("version","1.1");var c=this.createElementNS("","REQUEST");if(null!=a.get_image){var d=this.createElementNS("","GET_IMAGE");c.appendChild(d);var e=this.createElementNS("",
+"PROPERTIES");d.appendChild(e);a=a.get_image.properties;null!=a.featurecoordsys&&(d=this.createElementNS("","FEATURECOORDSYS"),e.appendChild(d),0===a.featurecoordsys.id?d.setAttribute("string",a.featurecoordsys.string):d.setAttribute("id",a.featurecoordsys.id));null!=a.filtercoordsys&&(d=this.createElementNS("","FILTERCOORDSYS"),e.appendChild(d),0===a.filtercoordsys.id?d.setAttribute("string",a.filtercoordsys.string):d.setAttribute("id",a.filtercoordsys.id));null!=a.envelope&&(d=this.createElementNS("",
+"ENVELOPE"),e.appendChild(d),d.setAttribute("minx",a.envelope.minx),d.setAttribute("miny",a.envelope.miny),d.setAttribute("maxx",a.envelope.maxx),d.setAttribute("maxy",a.envelope.maxy));d=this.createElementNS("","IMAGESIZE");e.appendChild(d);d.setAttribute("height",a.imagesize.height);d.setAttribute("width",a.imagesize.width);if(a.imagesize.height!=a.imagesize.printheight||a.imagesize.width!=a.imagesize.printwidth)d.setAttribute("printheight",a.imagesize.printheight),d.setArrtibute("printwidth",a.imagesize.printwidth);
+null!=a.background&&(d=this.createElementNS("","BACKGROUND"),e.appendChild(d),d.setAttribute("color",a.background.color.r+","+a.background.color.g+","+a.background.color.b),null!==a.background.transcolor&&d.setAttribute("transcolor",a.background.transcolor.r+","+a.background.transcolor.g+","+a.background.transcolor.b));if(null!=a.layerlist&&0<a.layerlist.length)for(d=this.createElementNS("","LAYERLIST"),e.appendChild(d),e=0;e<a.layerlist.length;e++){var f=this.createElementNS("","LAYERDEF");d.appendChild(f);
+f.setAttribute("id",a.layerlist[e].id);f.setAttribute("visible",a.layerlist[e].visible);if("object"==typeof a.layerlist[e].query){var g=a.layerlist[e].query;if(0>g.where.length)continue;var h=null,h="boolean"==typeof g.spatialfilter&&g.spatialfilter?this.createElementNS("","SPATIALQUERY"):this.createElementNS("","QUERY");h.setAttribute("where",g.where);"number"==typeof g.accuracy&&0<g.accuracy&&h.setAttribute("accuracy",g.accuracy);"number"==typeof g.featurelimit&&2E3>g.featurelimit&&h.setAttribute("featurelimit",
+g.featurelimit);"string"==typeof g.subfields&&"#ALL#"!=g.subfields&&h.setAttribute("subfields",g.subfields);"string"==typeof g.joinexpression&&0<g.joinexpression.length&&h.setAttribute("joinexpression",g.joinexpression);"string"==typeof g.jointables&&0<g.jointables.length&&h.setAttribute("jointables",g.jointables);f.appendChild(h)}"object"==typeof a.layerlist[e].renderer&&this.addRenderer(f,a.layerlist[e].renderer)}}else null!=a.get_feature&&(d=this.createElementNS("","GET_FEATURES"),d.setAttribute("outputmode",
+"newxml"),d.setAttribute("checkesc","true"),a.get_feature.geometry?d.setAttribute("geometry",a.get_feature.geometry):d.setAttribute("geometry","false"),a.get_feature.compact&&d.setAttribute("compact",a.get_feature.compact),"number"==a.get_feature.featurelimit&&d.setAttribute("featurelimit",a.get_feature.featurelimit),d.setAttribute("globalenvelope","true"),c.appendChild(d),null!=a.get_feature.layer&&0<a.get_feature.layer.length&&(e=this.createElementNS("","LAYER"),e.setAttribute("id",a.get_feature.layer),
+d.appendChild(e)),a=a.get_feature.query,null!=a&&(e=null,e=a.isspatial?this.createElementNS("","SPATIALQUERY"):this.createElementNS("","QUERY"),d.appendChild(e),"number"==typeof a.accuracy&&e.setAttribute("accuracy",a.accuracy),null!=a.featurecoordsys&&(d=this.createElementNS("","FEATURECOORDSYS"),0==a.featurecoordsys.id?d.setAttribute("string",a.featurecoordsys.string):d.setAttribute("id",a.featurecoordsys.id),e.appendChild(d)),null!=a.filtercoordsys&&(d=this.createElementNS("","FILTERCOORDSYS"),
+0===a.filtercoordsys.id?d.setAttribute("string",a.filtercoordsys.string):d.setAttribute("id",a.filtercoordsys.id),e.appendChild(d)),0<a.buffer&&(d=this.createElementNS("","BUFFER"),d.setAttribute("distance",a.buffer),e.appendChild(d)),a.isspatial&&(d=this.createElementNS("","SPATIALFILTER"),d.setAttribute("relation",a.spatialfilter.relation),e.appendChild(d),a.spatialfilter.envelope?(f=this.createElementNS("","ENVELOPE"),f.setAttribute("minx",a.spatialfilter.envelope.minx),f.setAttribute("miny",a.spatialfilter.envelope.miny),
+f.setAttribute("maxx",a.spatialfilter.envelope.maxx),f.setAttribute("maxy",a.spatialfilter.envelope.maxy),d.appendChild(f)):"object"==typeof a.spatialfilter.polygon&&d.appendChild(this.writePolygonGeometry(a.spatialfilter.polygon))),null!=a.where&&0<a.where.length&&e.setAttribute("where",a.where)));b.appendChild(c);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},addGroupRenderer:function(a,b){var c=this.createElementNS("","GROUPRENDERER");a.appendChild(c);for(var d=0;d<b.length;d++)this.addRenderer(c,
+b[d])},addRenderer:function(a,b){if(OpenLayers.Util.isArray(b))this.addGroupRenderer(a,b);else{var c=this.createElementNS("",b.type.toUpperCase()+"RENDERER");a.appendChild(c);"VALUEMAPRENDERER"==c.tagName?this.addValueMapRenderer(c,b):"VALUEMAPLABELRENDERER"==c.tagName?this.addValueMapLabelRenderer(c,b):"SIMPLELABELRENDERER"==c.tagName?this.addSimpleLabelRenderer(c,b):"SCALEDEPENDENTRENDERER"==c.tagName&&this.addScaleDependentRenderer(c,b)}},addScaleDependentRenderer:function(a,b){"string"!=typeof b.lower&&
+"number"!=typeof b.lower||a.setAttribute("lower",b.lower);"string"!=typeof b.upper&&"number"!=typeof b.upper||a.setAttribute("upper",b.upper);this.addRenderer(a,b.renderer)},addValueMapLabelRenderer:function(a,b){a.setAttribute("lookupfield",b.lookupfield);a.setAttribute("labelfield",b.labelfield);if("object"==typeof b.exacts)for(var c=0,d=b.exacts.length;c<d;c++){var e=b.exacts[c],f=this.createElementNS("","EXACT");"string"==typeof e.value&&f.setAttribute("value",e.value);"string"==typeof e.label&&
+f.setAttribute("label",e.label);"string"==typeof e.method&&f.setAttribute("method",e.method);a.appendChild(f);if("object"==typeof e.symbol){var g=null;"text"==e.symbol.type&&(g=this.createElementNS("","TEXTSYMBOL"));if(null!=g){for(var h=this.fontStyleKeys,k=0,l=h.length;k<l;k++){var m=h[k];e.symbol[m]&&g.setAttribute(m,e.symbol[m])}f.appendChild(g)}}}},addValueMapRenderer:function(a,b){a.setAttribute("lookupfield",b.lookupfield);if("object"==typeof b.ranges)for(var c=0,d=b.ranges.length;c<d;c++){var e=
+b.ranges[c],f=this.createElementNS("","RANGE");f.setAttribute("lower",e.lower);f.setAttribute("upper",e.upper);a.appendChild(f);if("object"==typeof e.symbol){var g=null;"simplepolygon"==e.symbol.type&&(g=this.createElementNS("","SIMPLEPOLYGONSYMBOL"));null!=g&&("string"==typeof e.symbol.boundarycolor&&g.setAttribute("boundarycolor",e.symbol.boundarycolor),"string"==typeof e.symbol.fillcolor&&g.setAttribute("fillcolor",e.symbol.fillcolor),"number"==typeof e.symbol.filltransparency&&g.setAttribute("filltransparency",
+e.symbol.filltransparency),f.appendChild(g))}}else if("object"==typeof b.exacts)for(c=0,d=b.exacts.length;c<d;c++)e=b.exacts[c],f=this.createElementNS("","EXACT"),"string"==typeof e.value&&f.setAttribute("value",e.value),"string"==typeof e.label&&f.setAttribute("label",e.label),"string"==typeof e.method&&f.setAttribute("method",e.method),a.appendChild(f),"object"==typeof e.symbol&&(g=null,"simplemarker"==e.symbol.type&&(g=this.createElementNS("","SIMPLEMARKERSYMBOL")),null!=g&&("string"==typeof e.symbol.antialiasing&&
+g.setAttribute("antialiasing",e.symbol.antialiasing),"string"==typeof e.symbol.color&&g.setAttribute("color",e.symbol.color),"string"==typeof e.symbol.outline&&g.setAttribute("outline",e.symbol.outline),"string"==typeof e.symbol.overlap&&g.setAttribute("overlap",e.symbol.overlap),"string"==typeof e.symbol.shadow&&g.setAttribute("shadow",e.symbol.shadow),"number"==typeof e.symbol.transparency&&g.setAttribute("transparency",e.symbol.transparency),"string"==typeof e.symbol.usecentroid&&g.setAttribute("usecentroid",
+e.symbol.usecentroid),"number"==typeof e.symbol.width&&g.setAttribute("width",e.symbol.width),f.appendChild(g)))},addSimpleLabelRenderer:function(a,b){a.setAttribute("field",b.field);for(var c="featureweight howmanylabels labelbufferratio labelpriorities labelweight linelabelposition rotationalangles".split(" "),d=0,e=c.length;d<e;d++){var f=c[d];b[f]&&a.setAttribute(f,b[f])}if("text"==b.symbol.type){var g=b.symbol,h=this.createElementNS("","TEXTSYMBOL");a.appendChild(h);c=this.fontStyleKeys;d=0;
+for(e=c.length;d<e;d++)f=c[d],g[f]&&h.setAttribute(f,b[f])}},writePolygonGeometry:function(a){if(!(a instanceof OpenLayers.Geometry.Polygon))throw{message:"Cannot write polygon geometry to ArcXML with an "+a.CLASS_NAME+" object.",geometry:a};for(var b=this.createElementNS("","POLYGON"),c=0,d=a.components.length;c<d;c++){for(var e=a.components[c],f=this.createElementNS("","RING"),g=0,h=e.components.length;g<h;g++){var k=e.components[g],l=this.createElementNS("","POINT");l.setAttribute("x",k.x);l.setAttribute("y",
+k.y);f.appendChild(l)}b.appendChild(f)}return b},parseResponse:function(a){"string"==typeof a&&(a=(new OpenLayers.Format.XML).read(a));var b=new OpenLayers.Format.ArcXML.Response,c=a.getElementsByTagName("ERROR");if(null!=c&&0<c.length)b.error=this.getChildValue(c,"Unknown error.");else{c=a.getElementsByTagName("RESPONSE");if(null==c||0==c.length)return b.error="No RESPONSE tag found in ArcXML response.",b;var d=c[0].firstChild.nodeName;"#text"==d&&(d=c[0].firstChild.nextSibling.nodeName);if("IMAGE"==
+d)c=a.getElementsByTagName("ENVELOPE"),a=a.getElementsByTagName("OUTPUT"),null==c||0==c.length?b.error="No ENVELOPE tag found in ArcXML response.":null==a||0==a.length?b.error="No OUTPUT tag found in ArcXML response.":(c=this.parseAttributes(c[0]),d=this.parseAttributes(a[0]),b.image="string"==typeof d.type?{envelope:c,output:{type:d.type,data:this.getChildValue(a[0])}}:{envelope:c,output:d});else if("FEATURES"==d){if(a=c[0].getElementsByTagName("FEATURES"),c=a[0].getElementsByTagName("FEATURECOUNT"),
+b.features.featurecount=c[0].getAttribute("count"),0<b.features.featurecount)for(c=a[0].getElementsByTagName("ENVELOPE"),b.features.envelope=this.parseAttributes(c[0],"number"),a=a[0].getElementsByTagName("FEATURE"),c=0;c<a.length;c++){for(var d=new OpenLayers.Feature.Vector,e=a[c].getElementsByTagName("FIELD"),f=0;f<e.length;f++){var g=e[f].getAttribute("name"),h=e[f].getAttribute("value");d.attributes[g]=h}e=a[c].getElementsByTagName("POLYGON");if(0<e.length){e=e[0].getElementsByTagName("RING");
+f=[];for(g=0;g<e.length;g++){h=[];h.push(this.parsePointGeometry(e[g]));for(var k=e[g].getElementsByTagName("HOLE"),l=0;l<k.length;l++)h.push(this.parsePointGeometry(k[l]));f.push(new OpenLayers.Geometry.Polygon(h))}d.geometry=1==f.length?f[0]:new OpenLayers.Geometry.MultiPolygon(f)}b.features.feature.push(d)}}else b.error="Unidentified response type."}return b},parseAttributes:function(a,b){for(var c={},d=0;d<a.attributes.length;d++)c[a.attributes[d].nodeName]="number"==b?parseFloat(a.attributes[d].nodeValue):
+a.attributes[d].nodeValue;return c},parsePointGeometry:function(a){var b=[],c=a.getElementsByTagName("COORDS");if(0<c.length)for(a=this.getChildValue(c[0]),a=a.split(/;/),c=0;c<a.length;c++){var d=a[c].split(/ /);b.push(new OpenLayers.Geometry.Point(d[0],d[1]))}else if(a=a.getElementsByTagName("POINT"),0<a.length)for(c=0;c<a.length;c++)b.push(new OpenLayers.Geometry.Point(parseFloat(a[c].getAttribute("x")),parseFloat(a[c].getAttribute("y"))));return new OpenLayers.Geometry.LinearRing(b)},CLASS_NAME:"OpenLayers.Format.ArcXML"});
+OpenLayers.Format.ArcXML.Request=OpenLayers.Class({initialize:function(a){return OpenLayers.Util.extend(this,{get_image:{properties:{background:null,draw:!0,envelope:{minx:0,miny:0,maxx:0,maxy:0},featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},imagesize:{height:0,width:0,dpi:96,printheight:0,printwidth:0,scalesymbols:!1},layerlist:[],output:{baseurl:"",legendbaseurl:"",legendname:"",legendpath:"",
+legendurl:"",name:"",path:"",type:"jpg",url:""}}},get_feature:{layer:"",query:{isspatial:!1,featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},buffer:0,where:"",spatialfilter:{relation:"envelope_intersection",envelope:null}}},environment:{separators:{cs:" ",ts:";"}},layer:[],workspaces:[]})},CLASS_NAME:"OpenLayers.Format.ArcXML.Request"});
+OpenLayers.Format.ArcXML.Response=OpenLayers.Class({initialize:function(a){return OpenLayers.Util.extend(this,{image:{envelope:null,output:""},features:{featurecount:0,envelope:null,feature:[]},error:""})},CLASS_NAME:"OpenLayers.Format.ArcXML.Response"});(function(){function a(){this._object=f&&!k?new f:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[]}function b(){return new a}function c(a){b.onreadystatechange&&b.onreadystatechange.apply(a);a.dispatchEvent({type:"readystatechange",bubbles:!1,cancelable:!1,timeStamp:new Date+0})}function d(a){try{a.responseText=a._object.responseText}catch(b){}try{var c;var d=a._object,e=d.responseXML,f=d.responseText;h&&(f&&e&&!e.documentElement&&d.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/))&&
+(e=new window.ActiveXObject("Microsoft.XMLDOM"),e.async=!1,e.validateOnParse=!1,e.loadXML(f));c=e&&(h&&0!=e.parseError||!e.documentElement||e.documentElement&&"parsererror"==e.documentElement.tagName)?null:e;a.responseXML=c}catch(g){}try{a.status=a._object.status}catch(k){}try{a.statusText=a._object.statusText}catch(u){}}function e(a){a._object.onreadystatechange=new window.Function}var f=window.XMLHttpRequest,g=!!window.controllers,h=window.document.all&&!window.opera,k=h&&window.navigator.userAgent.match(/MSIE 7.0/);
+b.prototype=a.prototype;g&&f.wrapped&&(b.wrapped=f.wrapped);b.UNSENT=0;b.OPENED=1;b.HEADERS_RECEIVED=2;b.LOADING=3;b.DONE=4;b.prototype.readyState=b.UNSENT;b.prototype.responseText="";b.prototype.responseXML=null;b.prototype.status=0;b.prototype.statusText="";b.prototype.priority="NORMAL";b.prototype.onreadystatechange=null;b.onreadystatechange=null;b.onopen=null;b.onsend=null;b.onabort=null;b.prototype.open=function(a,f,k,p,q){delete this._headers;3>arguments.length&&(k=!0);this._async=k;var r=this,
+s=this.readyState,t;h&&k&&(t=function(){s!=b.DONE&&(e(r),r.abort())},window.attachEvent("onunload",t));b.onopen&&b.onopen.apply(this,arguments);4<arguments.length?this._object.open(a,f,k,p,q):3<arguments.length?this._object.open(a,f,k,p):this._object.open(a,f,k);this.readyState=b.OPENED;c(this);this._object.onreadystatechange=function(){if(!g||k)r.readyState=r._object.readyState,d(r),r._aborted?r.readyState=b.UNSENT:(r.readyState==b.DONE&&(delete r._data,e(r),h&&k&&window.detachEvent("onunload",t)),
+s!=r.readyState&&c(r),s=r.readyState)}};b.prototype.send=function(a){b.onsend&&b.onsend.apply(this,arguments);arguments.length||(a=null);a&&a.nodeType&&(a=window.XMLSerializer?(new window.XMLSerializer).serializeToString(a):a.xml,this._headers["Content-Type"]||this._object.setRequestHeader("Content-Type","application/xml"));this._data=a;a:if(this._object.send(this._data),g&&!this._async)for(this.readyState=b.OPENED,d(this);this.readyState<b.DONE;)if(this.readyState++,c(this),this._aborted)break a};
+b.prototype.abort=function(){b.onabort&&b.onabort.apply(this,arguments);this.readyState>b.UNSENT&&(this._aborted=!0);this._object.abort();e(this);this.readyState=b.UNSENT;delete this._data};b.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders()};b.prototype.getResponseHeader=function(a){return this._object.getResponseHeader(a)};b.prototype.setRequestHeader=function(a,b){this._headers||(this._headers={});this._headers[a]=b;return this._object.setRequestHeader(a,b)};
+b.prototype.addEventListener=function(a,b,c){for(var d=0,e;e=this._listeners[d];d++)if(e[0]==a&&e[1]==b&&e[2]==c)return;this._listeners.push([a,b,c])};b.prototype.removeEventListener=function(a,b,c){for(var d=0,e;(e=this._listeners[d])&&(e[0]!=a||e[1]!=b||e[2]!=c);d++);e&&this._listeners.splice(d,1)};b.prototype.dispatchEvent=function(a){a={type:a.type,target:this,currentTarget:this,eventPhase:2,bubbles:a.bubbles,cancelable:a.cancelable,timeStamp:a.timeStamp,stopPropagation:function(){},preventDefault:function(){},
+initEvent:function(){}};"readystatechange"==a.type&&this.onreadystatechange&&(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,[a]);for(var b=0,c;c=this._listeners[b];b++)c[0]!=a.type||c[2]||(c[1].handleEvent||c[1]).apply(this,[a])};b.prototype.toString=function(){return"[object XMLHttpRequest]"};b.toString=function(){return"[XMLHttpRequest]"};window.Function.prototype.apply||(window.Function.prototype.apply=function(a,b){b||(b=[]);a.__func=this;a.__func(b[0],b[1],b[2],b[3],
+b[4]);delete a.__func});OpenLayers.Request||(OpenLayers.Request={});OpenLayers.Request.XMLHttpRequest=b})();OpenLayers.ProxyHost="";OpenLayers.Request||(OpenLayers.Request={});
+OpenLayers.Util.extend(OpenLayers.Request,{DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:!0,user:void 0,password:void 0,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this),makeSameOrigin:function(a,b){var c=0!==a.indexOf("http"),d=!c&&a.match(this.URL_SPLIT_REGEX);if(d){var e=window.location,c=d[1]==e.protocol&&d[3]==
+e.hostname,d=d[4],e=e.port;if(80!=d&&""!=d||"80"!=e&&""!=e)c=c&&d==e}c||b&&(a="function"==typeof b?b(a):b+encodeURIComponent(a));return a},issue:function(a){var b=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});a=a||{};a.headers=a.headers||{};a=OpenLayers.Util.applyDefaults(a,b);a.headers=OpenLayers.Util.applyDefaults(a.headers,b.headers);var b=!1,c;for(c in a.headers)a.headers.hasOwnProperty(c)&&"x-requested-with"===c.toLowerCase()&&(b=!0);!1===b&&(a.headers["X-Requested-With"]=
+"XMLHttpRequest");var d=new OpenLayers.Request.XMLHttpRequest,e=OpenLayers.Util.urlAppend(a.url,OpenLayers.Util.getParameterString(a.params||{})),e=OpenLayers.Request.makeSameOrigin(e,a.proxy);d.open(a.method,e,a.async,a.user,a.password);for(var f in a.headers)d.setRequestHeader(f,a.headers[f]);var g=this.events,h=this;d.onreadystatechange=function(){d.readyState==OpenLayers.Request.XMLHttpRequest.DONE&&!1!==g.triggerEvent("complete",{request:d,config:a,requestUrl:e})&&h.runCallbacks({request:d,config:a,
+requestUrl:e})};!1===a.async?d.send(a.data):window.setTimeout(function(){0!==d.readyState&&d.send(a.data)},0);return d},runCallbacks:function(a){var b=a.request,c=a.config,d=c.scope?OpenLayers.Function.bind(c.callback,c.scope):c.callback,e;c.success&&(e=c.scope?OpenLayers.Function.bind(c.success,c.scope):c.success);var f;c.failure&&(f=c.scope?OpenLayers.Function.bind(c.failure,c.scope):c.failure);"file:"==OpenLayers.Util.createUrlObject(c.url).protocol&&b.responseText&&(b.status=200);d(b);if(!b.status||
+200<=b.status&&300>b.status)this.events.triggerEvent("success",a),e&&e(b);b.status&&(200>b.status||300<=b.status)&&(this.events.triggerEvent("failure",a),f&&f(b))},GET:function(a){a=OpenLayers.Util.extend(a,{method:"GET"});return OpenLayers.Request.issue(a)},POST:function(a){a=OpenLayers.Util.extend(a,{method:"POST"});a.headers=a.headers?a.headers:{};"CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(a.headers)||(a.headers["Content-Type"]="application/xml");return OpenLayers.Request.issue(a)},PUT:function(a){a=
+OpenLayers.Util.extend(a,{method:"PUT"});a.headers=a.headers?a.headers:{};"CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(a.headers)||(a.headers["Content-Type"]="application/xml");return OpenLayers.Request.issue(a)},DELETE:function(a){a=OpenLayers.Util.extend(a,{method:"DELETE"});return OpenLayers.Request.issue(a)},HEAD:function(a){a=OpenLayers.Util.extend(a,{method:"HEAD"});return OpenLayers.Request.issue(a)},OPTIONS:function(a){a=OpenLayers.Util.extend(a,{method:"OPTIONS"});return OpenLayers.Request.issue(a)}});OpenLayers.Layer.ArcIMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{ClientVersion:"9.2",ServiceName:""},featureCoordSys:"4326",filterCoordSys:"4326",layers:null,async:!0,name:"ArcIMS",isBaseLayer:!0,DEFAULT_OPTIONS:{tileSize:new OpenLayers.Size(512,512),featureCoordSys:"4326",filterCoordSys:"4326",layers:null,isBaseLayer:!0,async:!0,name:"ArcIMS"},initialize:function(a,b,c){this.tileSize=new OpenLayers.Size(512,512);this.params=OpenLayers.Util.applyDefa
ults({ServiceName:c.serviceName},
+this.DEFAULT_PARAMS);this.options=OpenLayers.Util.applyDefaults(c,this.DEFAULT_OPTIONS);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,this.params,c]);this.transparent&&(this.isBaseLayer||(this.isBaseLayer=!1),"image/jpeg"==this.format&&(this.format=OpenLayers.Util.alphaHack()?"image/gif":"image/png"));null===this.options.layers&&(this.options.layers=[])},getURL:function(a){var b="";a=this.adjustBounds(a);a=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",
+envelope:a.toArray(),tileSize:this.tileSize}));a=new OpenLayers.Request.POST({url:this.getFullRequestString(),data:a.write(),async:!1});null!=a&&(b=a.responseXML,b&&b.documentElement||(b=a.responseText),b=(new OpenLayers.Format.ArcXML).read(b),b=this.getUrlOrImage(b.image.output));return b},getURLasync:function(a,b,c){a=this.adjustBounds(a);a=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:a.toArray(),tileSize:this.tileSize}));OpenLayers.Request.POST({url:this.getFullRequestString(),
+async:!0,data:a.write(),callback:function(a){var e=a.responseXML;e&&e.documentElement||(e=a.responseText);a=(new OpenLayers.Format.ArcXML).read(e);b.call(c,this.getUrlOrImage(a.image.output))},scope:this})},getUrlOrImage:function(a){var b="";a.url?b=a.url:a.data&&(b="data:image/"+a.type+";base64,"+a.data);return b},setLayerQuery:function(a,b){for(var c=0;c<this.options.layers.length;c++)if(a==this.options.layers[c].id){this.options.layers[c].query=b;return}this.options.layers.push({id:a,visible:!0,
+query:b})},getFeatureInfo:function(a,b,c){var d=c.buffer||1,e=c.callback||function(){},f=c.scope||window,g={};OpenLayers.Util.extend(g,this.options);g.requesttype="feature";a instanceof OpenLayers.LonLat?(g.polygon=null,g.envelope=[a.lon-d,a.lat-d,a.lon+d,a.lat+d]):a instanceof OpenLayers.Geometry.Polygon&&(g.envelope=null,g.polygon=a);var h=new OpenLayers.Format.ArcXML(g);OpenLayers.Util.extend(h.request.get_feature,c);h.request.get_feature.layer=b.id;"number"==typeof b.query.accuracy?h.request.get_feature.query.accuracy=
+b.query.accuracy:(a=this.map.getCenter(),c=this.map.getViewPortPxFromLonLat(a),c.x++,c=this.map.getLonLatFromPixel(c),h.request.get_feature.query.accuracy=c.lon-a.lon);h.request.get_feature.query.where=b.query.where;h.request.get_feature.query.spatialfilter.relation="area_intersection";OpenLayers.Request.POST({url:this.getFullRequestString({CustomService:"Query"}),data:h.write(),callback:function(a){a=h.parseResponse(a.responseText);h.iserror()?e.call(f,null):e.call(f,a.features)}})},clone:function(a){null==
+a&&(a=new OpenLayers.Layer.ArcIMS(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,buttons:null,position:null,initialize:function(a){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.map&&this.map.events.unregister("buttonclick",this,this.onButtonClick);this.removeButtons();this.position=this.buttons=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},
+setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register("buttonclick",this,this.onButtonClick)},draw:function(a){OpenLayers.Control.prototype.draw.apply(this,arguments);a=this.position;this.buttons=[];var b={w:18,h:18},c=new OpenLayers.Pixel(a.x+b.w/2,a.y);this._addButton("panup","north-mini.png",c,b);a.y=c.y+b.h;this._addButton("panleft","west-mini.png",a,b);this._addButton("panright","east-mini.png",a.add(b.w,0),b);this._addButton("pandown","south-mini.png",
+c.add(0,2*b.h),b);this._addButton("zoomin","zoom-plus-mini.png",c.add(0,3*b.h+5),b);this._addButton("zoomworld","zoom-world-mini.png",c.add(0,4*b.h+5),b);this._addButton("zoomout","zoom-minus-mini.png",c.add(0,5*b.h+5),b);return this.div},_addButton:function(a,b,c,d){b=OpenLayers.Util.getImageLocation(b);c=OpenLayers.Util.createAlphaImageDiv(this.id+"_"+a,c,d,b,"absolute");c.style.cursor="pointer";this.div.appendChild(c);c.action=a;c.className="olButton";this.buttons.push(c);return c},_removeButton:function(a){this.div.removeChild(a);
+OpenLayers.Util.removeItem(this.buttons,a)},removeButtons:function(){for(var a=this.buttons.length-1;0<=a;--a)this._removeButton(this.buttons[a])},onButtonClick:function(a){switch(a.buttonElement.action){case "panup":this.map.pan(0,-this.getSlideFactor("h"));break;case "pandown":this.map.pan(0,this.getSlideFactor("h"));break;case "panleft":this.map.pan(-this.getSlideFactor("w"),0);break;case "panright":this.map.pan(this.getSlideFactor("w"),0);break;case "zoomin":this.map.zoomIn();break;case "zoomout":this.map.zoomOut();
+break;case "zoomworld":this.map.zoomToMaxExtent()}},getSlideFactor:function(a){return this.slideRatio?this.map.getSize()[a]*this.slideRatio:this.slideFactor},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoombarDiv:null,zoomWorldIcon:!1,panIcons:!0,forceFixedZoomLevel:!1,mouseDragStart:null,deltaY:null,zoomStart:null,destroy:function(){this._removeZoomBar();this.map.events.un({changebaselayer:this.redraw,updatesize:this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);delete this.mouseDragStart;delete this.zoomStart},setMap:function(a){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,
+arguments);this.map.events.on({changebaselayer:this.redraw,updatesize:this.redraw,scope:this})},redraw:function(){null!=this.div&&(this.removeButtons(),this._removeZoomBar());this.draw()},draw:function(a){OpenLayers.Control.prototype.draw.apply(this,arguments);a=this.position.clone();this.buttons=[];var b={w:18,h:18};if(this.panIcons){var c=new OpenLayers.Pixel(a.x+b.w/2,a.y),d=b.w;this.zoomWorldIcon&&(c=new OpenLayers.Pixel(a.x+b.w,a.y));this._addButton("panup","north-mini.png",c,b);a.y=c.y+b.h;
+this._addButton("panleft","west-mini.png",a,b);this.zoomWorldIcon&&(this._addButton("zoomworld","zoom-world-mini.png",a.add(b.w,0),b),d*=2);this._addButton("panright","east-mini.png",a.add(d,0),b);this._addButton("pandown","south-mini.png",c.add(0,2*b.h),b);this._addButton("zoomin","zoom-plus-mini.png",c.add(0,3*b.h+5),b);c=this._addZoomBar(c.add(0,4*b.h+5));this._addButton("zoomout","zoom-minus-mini.png",c,b)}else this._addButton("zoomin","zoom-plus-mini.png",a,b),c=this._addZoomBar(a.add(0,b.h)),
+this._addButton("zoomout","zoom-minus-mini.png",c,b),this.zoomWorldIcon&&(c=c.add(0,b.h+3),this._addButton("zoomworld","zoom-world-mini.png",c,b));return this.div},_addZoomBar:function(a){var b=OpenLayers.Util.getImageLocation("slider.png"),c=this.id+"_"+this.map.id,d=this.map.getMinZoom(),e=this.map.getNumZoomLevels()-1-this.map.getZoom(),e=OpenLayers.Util.createAlphaImageDiv(c,a.add(-1,e*this.zoomStopHeight),{w:20,h:9},b,"absolute");e.style.cursor="move";this.slider=e;this.sliderEvents=new OpenLayers.Events(this,
+e,null,!0,{includeXY:!0});this.sliderEvents.on({touchstart:this.zoomBarDown,touchmove:this.zoomBarDrag,touchend:this.zoomBarUp,mousedown:this.zoomBarDown,mousemove:this.zoomBarDrag,mouseup:this.zoomBarUp});var f={w:this.zoomStopWidth,h:this.zoomStopHeight*(this.map.getNumZoomLevels()-d)},b=OpenLayers.Util.getImageLocation("zoombar.png"),c=null;OpenLayers.Util.alphaHack()?(c=this.id+"_"+this.map.id,c=OpenLayers.Util.createAlphaImageDiv(c,a,{w:f.w,h:this.zoomStopHeight},b,"absolute",null,"crop"),c.style.height=
+f.h+"px"):c=OpenLayers.Util.createDiv("OpenLayers_Control_PanZoomBar_Zoombar"+this.map.id,a,f,b);c.style.cursor="pointer";c.className="olButton";this.zoombarDiv=c;this.div.appendChild(c);this.startTop=parseInt(c.style.top);this.div.appendChild(e);this.map.events.register("zoomend",this,this.moveZoomBar);return a=a.add(0,this.zoomStopHeight*(this.map.getNumZoomLevels()-d))},_removeZoomBar:function(){this.sliderEvents.un({touchstart:this.zoomBarDown,touchmove:this.zoomBarDrag,touchend:this.zoomBarUp,
+mousedown:this.zoomBarDown,mousemove:this.zoomBarDrag,mouseup:this.zoomBarUp});this.sliderEvents.destroy();this.div.removeChild(this.zoombarDiv);this.zoombarDiv=null;this.div.removeChild(this.slider);this.slider=null;this.map.events.unregister("zoomend",this,this.moveZoomBar)},onButtonClick:function(a){OpenLayers.Control.PanZoom.prototype.onButtonClick.apply(this,arguments);if(a.buttonElement===this.zoombarDiv){var b=a.buttonXY.y/this.zoomStopHeight;if(this.forceFixedZoomLevel||!this.map.fractionalZoom)b=
+Math.floor(b);b=this.map.getNumZoomLevels()-1-b;b=Math.min(Math.max(b,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(b)}},passEventToSlider:function(a){this.sliderEvents.handleBrowserEvent(a)},zoomBarDown:function(a){if(OpenLayers.Event.isLeftClick(a)||OpenLayers.Event.isSingleTouch(a))this.map.events.on({touchmove:this.passEventToSlider,mousemove:this.passEventToSlider,mouseup:this.passEventToSlider,scope:this}),this.mouseDragStart=a.xy.clone(),this.zoomStart=a.xy.clone(),this.div.style.cursor=
+"move",this.zoombarDiv.offsets=null,OpenLayers.Event.stop(a)},zoomBarDrag:function(a){if(null!=this.mouseDragStart){var b=this.mouseDragStart.y-a.xy.y,c=OpenLayers.Util.pagePosition(this.zoombarDiv);0<a.clientY-c[1]&&a.clientY-c[1]<parseInt(this.zoombarDiv.style.height)-2&&(b=parseInt(this.slider.style.top)-b,this.slider.style.top=b+"px",this.mouseDragStart=a.xy.clone());this.deltaY=this.zoomStart.y-a.xy.y;OpenLayers.Event.stop(a)}},zoomBarUp:function(a){if((OpenLayers.Event.isLeftClick(a)||"touchend"===
+a.type)&&this.mouseDragStart){this.div.style.cursor="";this.map.events.un({touchmove:this.passEventToSlider,mouseup:this.passEventToSlider,mousemove:this.passEventToSlider,scope:this});var b=this.map.zoom;!this.forceFixedZoomLevel&&this.map.fractionalZoom?(b+=this.deltaY/this.zoomStopHeight,b=Math.min(Math.max(b,0),this.map.getNumZoomLevels()-1)):(b+=this.deltaY/this.zoomStopHeight,b=Math.max(Math.round(b),0));this.map.zoomTo(b);this.zoomStart=this.mouseDragStart=null;this.deltaY=0;OpenLayers.Event.stop(a)}},
+moveZoomBar:function(){var a=(this.map.getNumZoomLevels()-1-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=a+"px"},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wfs:"http://www.opengis.net/wfs",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",ows:"http://www.opengis.net/ows"},errorProperty:"featureTypeList",defaultPrefix:"wfs",read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,b);return b},readers:{wfs:{WFS_Capabilities:function(a,
+b){this.readChildNodes(a,b)},FeatureTypeList:function(a,b){b.featureTypeList={featureTypes:[]};this.readChildNodes(a,b.featureTypeList)},FeatureType:function(a,b){var c={};this.readChildNodes(a,c);b.featureTypes.push(c)},Name:function(a,b){var c=this.getChildValue(a);c&&(c=c.split(":"),b.name=c.pop(),0<c.length&&(b.featureNS=this.lookupNamespaceURI(a,c[0])))},Title:function(a,b){var c=this.getChildValue(a);c&&(b.title=c)},Abstract:function(a,b){var c=this.getChildValue(a);c&&(b["abstract"]=c)}}},
+CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1"});OpenLayers.Format.WFSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},readers:{wfs:OpenLayers.Util.applyDefaults({DefaultSRS:function(a,b){var c=this.getChildValue(a);c&&(b.srs=c)}},OpenLayers.Format.WFSCapabilities.v1.prototype.readers.wfs),ows:OpenLayers.Format.OWSCommon.v1.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_1_0"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:!0,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(a,b,c,d,e){this.url=b;this.maxExtent=this.extent=c;this.size=d;OpenLayers.Layer.prototype.initialize.apply(this,[a,e]);this.aspectRatio=this.extent.getHeight()/this.size.h/(this.extent.getWidth()/this.size.w)},destroy:function(){this.tile&&(this.removeTileMonitoringHooks(this.tile),this.tile.destroy(),this.tile=n
ull);OpenLayers.Layer.prototype.destroy.apply(this,
+arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.getOptions()));return a=OpenLayers.Layer.prototype.clone.apply(this,[a])},setMap:function(a){null==this.options.maxResolution&&(this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w);OpenLayers.Layer.prototype.setMap.apply(this,arguments)},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var d=null==this.tile;if(b||d){this.setTileSize();
+var e=this.map.getLayerPxFromLonLat({lon:this.extent.left,lat:this.extent.top});d?(this.tile=new OpenLayers.Tile.Image(this,e,this.extent,null,this.tileSize),this.addTileMonitoringHooks(this.tile)):(this.tile.size=this.tileSize.clone(),this.tile.position=e.clone());this.tile.draw()}},setTileSize:function(){var a=this.extent.getWidth()/this.map.getResolution(),b=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(a,b)},addTileMonitoringHooks:function(a){a.onLoadStart=
+function(){this.events.triggerEvent("loadstart")};a.events.register("loadstart",this,a.onLoadStart);a.onLoadEnd=function(){this.events.triggerEvent("loadend")};a.events.register("loadend",this,a.onLoadEnd);a.events.register("unload",this,a.onLoadEnd)},removeTileMonitoringHooks:function(a){a.unload();a.events.un({loadstart:a.onLoadStart,loadend:a.onLoadEnd,unload:a.onLoadEnd,scope:this})},setUrl:function(a){this.url=a;this.tile.draw()},getURL:function(a){return this.url},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:!0,autoDestroy:!0,initialize:function(a){OpenLayers.Util.extend(this,a);this.options=a;this.active=!1},destroy:function(){this.deactivate();this.options=this.layer=null},setLayer:function(a){this.layer=a},activate:function(){return this.active?!1:this.active=!0},deactivate:function(){return this.active?(this.active=!1,!0):!1},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Save=O
penLayers.Class(OpenLayers.Strategy,{events:null,auto:!1,timer:null,initialize:function(a){OpenLayers.Strategy.prototype.initialize.apply(this,[a]);this.events=new OpenLayers.Events(this)},activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);if(a&&this.auto)if("number"===typeof this.auto)this.timer=window.setInterval(OpenLayers.Function.bind(this.save,this),1E3*this.auto);else this.layer.events.on({featureadded:this.triggerSave,afterfeaturemodified:this.triggerSave,
+scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&this.auto&&("number"===typeof this.auto?window.clearInterval(this.timer):this.layer.events.un({featureadded:this.triggerSave,afterfeaturemodified:this.triggerSave,scope:this}));return a},triggerSave:function(a){var b=a.feature;b.state!==OpenLayers.State.INSERT&&b.state!==OpenLayers.State.UPDATE&&b.state!==OpenLayers.State.DELETE||this.save([a.feature])},save:function(a){a||(a=this.layer.features);
+this.events.triggerEvent("start",{features:a});var b=this.layer.projection,c=this.layer.map.getProjectionObject();if(!c.equals(b)){for(var d=a.length,e=Array(d),f,g,h=0;h<d;++h)f=a[h],g=f.clone(),g.fid=f.fid,g.state=f.state,f.url&&(g.url=f.url),g._original=f,g.geometry.transform(c,b),e[h]=g;a=e}this.layer.protocol.commit(a,{callback:this.onCommit,scope:this})},onCommit:function(a){var b={response:a};if(a.success()){for(var c=a.reqFeatures,d,e=[],f=a.insertIds||[],g=0,h=0,k=c.length;h<k;++h)if(d=c[h],
+d=d._original||d,a=d.state)a==OpenLayers.State.DELETE?e.push(d):a==OpenLayers.State.INSERT&&(d.fid=f[g],++g),d.state=null;0<e.length&&this.layer.destroyFeatures(e);this.events.triggerEvent("success",b)}else this.events.triggerEvent("fail",b)},CLASS_NAME:"OpenLayers.Strategy.Save"});OpenLayers.Events.featureclick=OpenLayers.Class({cache:null,map:null,provides:["featureclick","nofeatureclick","featureover","featureout"],initialize:function(a){this.target=a;if(a.object instanceof OpenLayers.Map)this.setMap(a.object);else if(a.object instanceof OpenLayers.Layer.Vector)a.object.map?this.setMap(a.object.map):a.object.events.register("added",this,function(b){this.setMap(a.object.map)});else throw"Listeners for '"+this.provides.join("', '")+"' events can only be registered for OpenLayers.Layer.Vector or OpenLayers.Map instances";
+for(var b=this.provides.length-1;0<=b;--b)a.extensions[this.provides[b]]=!0},setMap:function(a){this.map=a;this.cache={};a.events.register("mousedown",this,this.start,{extension:!0});a.events.register("mouseup",this,this.onClick,{extension:!0});a.events.register("touchstart",this,this.start,{extension:!0});a.events.register("touchmove",this,this.cancel,{extension:!0});a.events.register("touchend",this,this.onClick,{extension:!0});a.events.register("mousemove",this,this.onMousemove,{extension:!0})},
+start:function(a){this.startEvt=a},cancel:function(a){delete this.startEvt},onClick:function(a){if(this.startEvt&&("touchend"===a.type||OpenLayers.Event.isLeftClick(a))){a=this.getFeatures(this.startEvt);delete this.startEvt;for(var b,c,d={},e=0,f=a.length;e<f&&(b=a[e],c=b.layer,d[c.id]=!0,b=this.triggerEvent("featureclick",{feature:b}),!1!==b);++e);e=0;for(f=this.map.layers.length;e<f;++e)c=this.map.layers[e],c instanceof OpenLayers.Layer.Vector&&!d[c.id]&&this.triggerEvent("nofeatureclick",{layer:c})}},
+onMousemove:function(a){delete this.startEvt;var b=this.getFeatures(a),c={};a=[];for(var d,e=0,f=b.length;e<f;++e)d=b[e],c[d.id]=d,this.cache[d.id]||a.push(d);var b=[],g;for(g in this.cache)d=this.cache[g],d.layer&&d.layer.map?c[d.id]||b.push(d):delete this.cache[g];e=0;for(f=a.length;e<f&&(d=a[e],this.cache[d.id]=d,g=this.triggerEvent("featureover",{feature:d}),!1!==g);++e);e=0;for(f=b.length;e<f&&(d=b[e],delete this.cache[d.id],g=this.triggerEvent("featureout",{feature:d}),!1!==g);++e);},triggerEvent:function(a,
+b){var c=b.feature?b.feature.layer:b.layer,d=this.target.object;if(d instanceof OpenLayers.Map||d===c)return this.target.triggerEvent(a,b)},getFeatures:function(a){var b=a.clientX,c=a.clientY,d=[],e=[],f=[],g,h,k,l;for(l=this.map.layers.length-1;0<=l;--l)if(g=this.map.layers[l],"none"!==g.div.style.display)if(g.renderer instanceof OpenLayers.Renderer.Elements){if(g instanceof OpenLayers.Layer.Vector)for(h=document.elementFromPoint(b,c);h&&h._featureId;)(k=g.getFeatureById(h._featureId))?(d.push(k),
+h.style.display="none",e.push(h),h=document.elementFromPoint(b,c)):h=!1;f.push(g);g.div.style.display="none"}else g.renderer instanceof OpenLayers.Renderer.Canvas&&(k=g.renderer.getFeatureIdFromEvent(a))&&(d.push(k),f.push(g));l=0;for(a=e.length;l<a;++l)e[l].style.display="";for(l=f.length-1;0<=l;--l)f[l].div.style.display="block";return d},destroy:function(){for(var a=this.provides.length-1;0<=a;--a)delete this.target.extensions[this.provides[a]];this.map.events.un({mousemove:this.onMousemove,mousedown:this.start,
+mouseup:this.onClick,touchstart:this.start,touchmove:this.cancel,touchend:this.onClick,scope:this});delete this.cache;delete this.map;delete this.target}});OpenLayers.Events.nofeatureclick=OpenLayers.Events.featureclick;OpenLayers.Events.featureover=OpenLayers.Events.featureclick;OpenLayers.Events.featureout=OpenLayers.Events.featureclick;OpenLayers.Format.GPX=OpenLayers.Class(OpenLayers.Format.XML,{defaultDesc:"No description available",extractWaypoints:!0,extractTracks:!0,extractRoutes:!0,extractAttributes:!0,namespaces:{gpx:"http://www.topografix.com/GPX/1/1",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd",creator:"OpenLayers",initialize:function(a){this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,
+[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=[];if(this.extractTracks)for(var c=a.getElementsByTagName("trk"),d=0,e=c.length;d<e;d++){var f={};this.extractAttributes&&(f=this.parseAttributes(c[d]));for(var g=this.getElementsByTagNameNS(c[d],c[d].namespaceURI,"trkseg"),h=0,k=g.length;h<k;h++){var l=this.extractSegment(g[h],"trkpt");b.push(new OpenLayers.Feature.Vector(l,f))}}if(this.extractRoutes)for(e=a.getElementsByTagName("rte"),c=0,d=
+e.length;c<d;c++)f={},this.extractAttributes&&(f=this.parseAttributes(e[c])),g=this.extractSegment(e[c],"rtept"),b.push(new OpenLayers.Feature.Vector(g,f));if(this.extractWaypoints)for(a=a.getElementsByTagName("wpt"),c=0,e=a.length;c<e;c++)f={},this.extractAttributes&&(f=this.parseAttributes(a[c])),d=new OpenLayers.Geometry.Point(a[c].getAttribute("lon"),a[c].getAttribute("lat")),b.push(new OpenLayers.Feature.Vector(d,f));if(this.internalProjection&&this.externalProjection)for(f=0,a=b.length;f<a;f++)b[f].geometry.transform(this.externalProjection,
+this.internalProjection);return b},extractSegment:function(a,b){for(var c=this.getElementsByTagNameNS(a,a.namespaceURI,b),d=[],e=0,f=c.length;e<f;e++)d.push(new OpenLayers.Geometry.Point(c[e].getAttribute("lon"),c[e].getAttribute("lat")));return new OpenLayers.Geometry.LineString(d)},parseAttributes:function(a){var b={};a=a.firstChild;for(var c,d;a;)1==a.nodeType&&a.firstChild&&(c=a.firstChild,3==c.nodeType||4==c.nodeType)&&(d=a.prefix?a.nodeName.split(":")[1]:a.nodeName,"trkseg"!=d&&"rtept"!=d&&
+(b[d]=c.nodeValue)),a=a.nextSibling;return b},write:function(a,b){a=OpenLayers.Util.isArray(a)?a:[a];var c=this.createElementNS(this.namespaces.gpx,"gpx");c.setAttribute("version","1.1");c.setAttribute("creator",this.creator);this.setAttributes(c,{"xsi:schemaLocation":this.schemaLocation});b&&"object"==typeof b&&c.appendChild(this.buildMetadataNode(b));for(var d=0,e=a.length;d<e;d++)c.appendChild(this.buildFeatureNode(a[d]));return OpenLayers.Format.XML.prototype.write.apply(this,[c])},buildMetadataNode:function(a){for(var b=
+["name","desc","author"],c=this.createElementNS(this.namespaces.gpx,"metadata"),d=0;d<b.length;d++){var e=b[d];if(a[e]){var f=this.createElementNS(this.namespaces.gpx,e);f.appendChild(this.createTextNode(a[e]));c.appendChild(f)}}return c},buildFeatureNode:function(a){var b=a.geometry,b=b.clone();this.internalProjection&&this.externalProjection&&b.transform(this.internalProjection,this.externalProjection);if("OpenLayers.Geometry.Point"==b.CLASS_NAME){var c=this.buildWptNode(b);this.appendAttributesNode(c,
+a);return c}c=this.createElementNS(this.namespaces.gpx,"trk");this.appendAttributesNode(c,a);a=this.buildTrkSegNode(b);a=OpenLayers.Util.isArray(a)?a:[a];for(var b=0,d=a.length;b<d;b++)c.appendChild(a[b]);return c},buildTrkSegNode:function(a){var b,c,d,e;if("OpenLayers.Geometry.LineString"==a.CLASS_NAME||"OpenLayers.Geometry.LinearRing"==a.CLASS_NAME){b=this.createElementNS(this.namespaces.gpx,"trkseg");c=0;for(d=a.components.length;c<d;c++)e=a.components[c],b.appendChild(this.buildTrkPtNode(e));
+return b}b=[];c=0;for(d=a.components.length;c<d;c++)b.push(this.buildTrkSegNode(a.components[c]));return b},buildTrkPtNode:function(a){var b=this.createElementNS(this.namespaces.gpx,"trkpt");b.setAttribute("lon",a.x);b.setAttribute("lat",a.y);return b},buildWptNode:function(a){var b=this.createElementNS(this.namespaces.gpx,"wpt");b.setAttribute("lon",a.x);b.setAttribute("lat",a.y);return b},appendAttributesNode:function(a,b){var c=this.createElementNS(this.namespaces.gpx,"name");c.appendChild(this.createTextNode(b.attributes.name||
+b.id));a.appendChild(c);c=this.createElementNS(this.namespaces.gpx,"desc");c.appendChild(this.createTextNode(b.attributes.description||this.defaultDesc));a.appendChild(c)},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Format.WMSDescribeLayer=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.1",CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer"});OpenLayers.Format.WMSDescribeLayer.v1_1_1=OpenLayers.Class(OpenLayers.Format.WMSDescribeLayer,{initialize:function(a){OpenLayers.Format.WMSDescribeLayer.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));for(var b=a.documentElement.childNodes,c={layerDescriptions:[]},d,e,f=0;f<b.length;++f)if(d=b[f],e=d.nodeName,"LayerDescription"==e){e=d.getAttribute("name");var g="",h="",k="";d.getAttribute("owsType")?(g=d.getAttribute("owsType"),
+h=d.getAttribute("owsURL")):""!=d.getAttribute("wfs")?(g="WFS",h=d.getAttribute("wfs")):""!=d.getAttribute("wcs")&&(g="WCS",h=d.getAttribute("wcs"));d=d.getElementsByTagName("Query");0<d.length&&((k=d[0].getAttribute("typeName"))||(k=d[0].getAttribute("typename")));d={layerName:e,owsType:g,owsURL:h,typeName:k};c.layerDescriptions.push(d);c.length=c.layerDescriptions.length;c[c.length-1]=d}else if("ServiceException"==e)return{error:(new OpenLayers.Format.OGCExceptionReport).read(a)};return c},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer.v1_1_1"});
+OpenLayers.Format.WMSDescribeLayer.v1_1_0=OpenLayers.Format.WMSDescribeLayer.v1_1_1;OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,sphericalMercator:!1,zoomOffset:0,serverResolutions:null,initialize:function(a,b,c){if(c&&c.sphericalMercator||this.sphericalMercator)c=OpenLayers.Util.extend({projection:"EPSG:900913",numZoomLevels:19},c);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a||this.name,b||this.url,{},c])},clone:function(a){null==a&&(a=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,
+[a])},getURL:function(a){a=this.getXYZ(a);var b=this.url;OpenLayers.Util.isArray(b)&&(b=this.selectUrl(""+a.x+a.y+a.z,b));return OpenLayers.String.format(b,a)},getXYZ:function(a){var b=this.getServerResolution(),c=Math.round((a.left-this.maxExtent.left)/(b*this.tileSize.w));a=Math.round((this.maxExtent.top-a.top)/(b*this.tileSize.h));b=this.getServerZoom();if(this.wrapDateLine)var d=Math.pow(2,b),c=(c%d+d)%d;return{x:c,y:a,z:b}},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,
+arguments);this.tileOrigin||(this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom))},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",url:["http://a.tile.openstreetmap.org/${z}/${x}/${y}.png","http://b.tile.openstreetmap.org/${z}/${x}/${y}.png","http://c.tile.openstreetmap.org/${z}/${x}/${y}.png"],attribution:"© <a href='http://www.openstreetmap.org/copyright'>OpenStreetMap</a> contributors",sphericalMercator:!0,wrapDateLine:!0,tileOptions:null,initialize:function(a,b,c){OpenLayers.Layer.XYZ.prototype.initialize.apply(this,arguments);this.tileOptions=
+OpenLayers.Util.extend({crossOriginKeyword:"anonymous"},this.options&&this.options.tileOptions)},clone:function(a){null==a&&(a=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:!1,size:null,resolution:null,map:null,featureDx:0,initialize:function(a,b){this.container=OpenLayers.Util.getElement(a);OpenLayers.Util.extend(this,b)},destroy:function(){this.map=this.resolution=this.size=this.extent=this.container=null},supported:function(){return!1},setExtent:function(a,b){this.extent=a.clone();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){var c=a.getWidth()/this.map.getExtent().getWidth();
+a=a.scale(1/c);this.extent=a.wrapDateLine(this.map.getMaxExtent()).scale(c)}b&&(this.resolution=null);return!0},setSize:function(a){this.size=a.clone();this.resolution=null},getResolution:function(){return this.resolution=this.resolution||this.map.getResolution()},drawFeature:function(a,b){null==b&&(b=a.style);if(a.geometry){var c=a.geometry.getBounds();if(c){var d;this.map.baseLayer&&this.map.baseLayer.wrapDateLine&&(d=this.map.getMaxExtent());c.intersectsBounds(this.extent,{worldBounds:d})?this.calculateFeatureDx(c,
+d):b={display:"none"};c=this.drawGeometry(a.geometry,b,a.id);if("none"!=b.display&&b.label&&!1!==c){d=a.geometry.getCentroid();if(b.labelXOffset||b.labelYOffset){var e=isNaN(b.labelXOffset)?0:b.labelXOffset,f=isNaN(b.labelYOffset)?0:b.labelYOffset,g=this.getResolution();d.move(e*g,f*g)}this.drawText(a.id,b,d)}else this.removeText(a.id);return c}}},calculateFeatureDx:function(a,b){this.featureDx=0;if(b){var c=b.getWidth();this.featureDx=Math.round(((a.left+a.right)/2-(this.extent.left+this.extent.right)/
+2)/c)*c}},drawGeometry:function(a,b,c){},drawText:function(a,b,c){},removeText:function(a){},clear:function(){},getFeatureIdFromEvent:function(a){},eraseFeatures:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=0,c=a.length;b<c;++b){var d=a[b];this.eraseGeometry(d.geometry,d.id);this.removeText(d.id)}},eraseGeometry:function(a,b){},moveRoot:function(a){},getRenderLayerId:function(){return this.container.id},applyDefaultSymbolizer:function(a){var b=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);
+!1===a.stroke&&(delete b.strokeWidth,delete b.strokeColor);!1===a.fill&&delete b.fillColor;OpenLayers.Util.extend(b,a);return b},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0,labelAlign:"cm"};
+OpenLayers.Renderer.symbol={star:[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],cross:[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],x:[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],square:[0,0,0,1,1,1,1,0,0,0],triangle:[0,10,10,10,5,0,0,10]};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:!0,hitOverflow:0,canvas:null,features:null,pendingRedraw:!1,cachedSymbolBounds:{},initialize:function(a,b){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};this.hitDetection&&(this.hitCanvas=document.createElement("canvas"),this.hitContext=this.hitCanvas.getContext("2d"))},
+setExtent:function(){OpenLayers.Renderer.prototype.setExtent.apply(this,arguments);return!1},eraseGeometry:function(a,b){this.eraseFeatures(this.features[b][0])},supported:function(){return OpenLayers.CANVAS_SUPPORTED},setSize:function(a){this.size=a.clone();var b=this.root;b.style.width=a.w+"px";b.style.height=a.h+"px";b.width=a.w;b.height=a.h;this.resolution=null;this.hitDetection&&(b=this.hitCanvas,b.style.width=a.w+"px",b.style.height=a.h+"px",b.width=a.w,b.height=a.h)},drawFeature:function(a,
+b){var c;if(a.geometry){b=this.applyDefaultSymbolizer(b||a.style);c=a.geometry.getBounds();var d;this.map.baseLayer&&this.map.baseLayer.wrapDateLine&&(d=this.map.getMaxExtent());d=c&&c.intersectsBounds(this.extent,{worldBounds:d});(c="none"!==b.display&&!!c&&d)?this.features[a.id]=[a,b]:delete this.features[a.id];this.pendingRedraw=!0}this.pendingRedraw&&!this.locked&&(this.redraw(),this.pendingRedraw=!1);return c},drawGeometry:function(a,b,c){var d=a.CLASS_NAME;if("OpenLayers.Geometry.Collection"==
+d||"OpenLayers.Geometry.MultiPoint"==d||"OpenLayers.Geometry.MultiLineString"==d||"OpenLayers.Geometry.MultiPolygon"==d)for(d=0;d<a.components.length;d++)this.drawGeometry(a.components[d],b,c);else switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":this.drawPoint(a,b,c);break;case "OpenLayers.Geometry.LineString":this.drawLineString(a,b,c);break;case "OpenLayers.Geometry.LinearRing":this.drawLinearRing(a,b,c);break;case "OpenLayers.Geometry.Polygon":this.drawPolygon(a,b,c)}},drawExternalGraphic:function(a,
+b,c){var d=new Image,e=b.title||b.graphicTitle;e&&(d.title=e);var f=b.graphicWidth||b.graphicHeight,g=b.graphicHeight||b.graphicWidth,f=f?f:2*b.pointRadius,g=g?g:2*b.pointRadius,h=void 0!=b.graphicXOffset?b.graphicXOffset:-(0.5*f),k=void 0!=b.graphicYOffset?b.graphicYOffset:-(0.5*g),l=b.graphicOpacity||b.fillOpacity;d.onload=OpenLayers.Function.bind(function(){if(this.features[c]){var b=this.getLocalXY(a),e=b[0],b=b[1];if(!isNaN(e)&&!isNaN(b)){var e=e+h|0,b=b+k|0,p=this.canvas;p.globalAlpha=l;var q=
+OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);p.drawImage(d,e*q,b*q,f*q,g*q);this.hitDetection&&(this.setHitContextStyle("fill",c),this.hitContext.fillRect(e,b,f,g))}}},this);d.src=b.externalGraphic},drawNamedSymbol:function(a,b,c){var d,e,f,g;f=Math.PI/180;var h=OpenLayers.Renderer.symbol[b.graphicName];if(!h)throw Error(b.graphicName+" is not a valid symbol name");
+if(!(!h.length||2>h.length||(a=this.getLocalXY(a),e=a[0],g=a[1],isNaN(e)||isNaN(g)))){this.canvas.lineCap="round";this.canvas.lineJoin="round";this.hitDetection&&(this.hitContext.lineCap="round",this.hitContext.lineJoin="round");if(b.graphicName in this.cachedSymbolBounds)d=this.cachedSymbolBounds[b.graphicName];else{d=new OpenLayers.Bounds;for(a=0;a<h.length;a+=2)d.extend(new OpenLayers.LonLat(h[a],h[a+1]));this.cachedSymbolBounds[b.graphicName]=d}this.canvas.save();this.hitDetection&&this.hitContext.save();
+this.canvas.translate(e,g);this.hitDetection&&this.hitContext.translate(e,g);a=f*b.rotation;isNaN(a)||(this.canvas.rotate(a),this.hitDetection&&this.hitContext.rotate(a));f=2*b.pointRadius/Math.max(d.getWidth(),d.getHeight());this.canvas.scale(f,f);this.hitDetection&&this.hitContext.scale(f,f);a=d.getCenterLonLat().lon;d=d.getCenterLonLat().lat;this.canvas.translate(-a,-d);this.hitDetection&&this.hitContext.translate(-a,-d);g=b.strokeWidth;b.strokeWidth=g/f;if(!1!==b.fill){this.setCanvasStyle("fill",
+b);this.canvas.beginPath();for(a=0;a<h.length;a+=2)d=h[a],e=h[a+1],0==a&&this.canvas.moveTo(d,e),this.canvas.lineTo(d,e);this.canvas.closePath();this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",c,b);this.hitContext.beginPath();for(a=0;a<h.length;a+=2)d=h[a],e=h[a+1],0==a&&this.canvas.moveTo(d,e),this.hitContext.lineTo(d,e);this.hitContext.closePath();this.hitContext.fill()}}if(!1!==b.stroke){this.setCanvasStyle("stroke",b);this.canvas.beginPath();for(a=0;a<h.length;a+=2)d=h[a],
+e=h[a+1],0==a&&this.canvas.moveTo(d,e),this.canvas.lineTo(d,e);this.canvas.closePath();this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",c,b,f);this.hitContext.beginPath();for(a=0;a<h.length;a+=2)d=h[a],e=h[a+1],0==a&&this.hitContext.moveTo(d,e),this.hitContext.lineTo(d,e);this.hitContext.closePath();this.hitContext.stroke()}}b.strokeWidth=g;this.canvas.restore();this.hitDetection&&this.hitContext.restore();this.setCanvasStyle("reset")}},setCanvasStyle:function(a,b){"fill"===
+a?(this.canvas.globalAlpha=b.fillOpacity,this.canvas.fillStyle=b.fillColor):"stroke"===a?(this.canvas.globalAlpha=b.strokeOpacity,this.canvas.strokeStyle=b.strokeColor,this.canvas.lineWidth=b.strokeWidth):(this.canvas.globalAlpha=0,this.canvas.lineWidth=1)},featureIdToHex:function(a){a=Number(a.split("_").pop())+1;16777216<=a&&(this.hitOverflow=a-16777215,a=a%16777216+1);a="000000"+a.toString(16);var b=a.length;return a="#"+a.substring(b-6,b)},setHitContextStyle:function(a,b,c,d){b=this.featureIdToHex(b);
+"fill"==a?(this.hitContext.globalAlpha=1,this.hitContext.fillStyle=b):"stroke"==a?(this.hitContext.globalAlpha=1,this.hitContext.strokeStyle=b,"undefined"===typeof d?this.hitContext.lineWidth=c.strokeWidth+2:isNaN(d)||(this.hitContext.lineWidth=c.strokeWidth+2/d)):(this.hitContext.globalAlpha=0,this.hitContext.lineWidth=1)},drawPoint:function(a,b,c){if(!1!==b.graphic)if(b.externalGraphic)this.drawExternalGraphic(a,b,c);else if(b.graphicName&&"circle"!=b.graphicName)this.drawNamedSymbol(a,b,c);else{var d=
+this.getLocalXY(a);a=d[0];d=d[1];if(!isNaN(a)&&!isNaN(d)){var e=2*Math.PI,f=b.pointRadius;!1!==b.fill&&(this.setCanvasStyle("fill",b),this.canvas.beginPath(),this.canvas.arc(a,d,f,0,e,!0),this.canvas.fill(),this.hitDetection&&(this.setHitContextStyle("fill",c,b),this.hitContext.beginPath(),this.hitContext.arc(a,d,f,0,e,!0),this.hitContext.fill()));!1!==b.stroke&&(this.setCanvasStyle("stroke",b),this.canvas.beginPath(),this.canvas.arc(a,d,f,0,e,!0),this.canvas.stroke(),this.hitDetection&&(this.setHitContextStyle("stroke",
+c,b),this.hitContext.beginPath(),this.hitContext.arc(a,d,f,0,e,!0),this.hitContext.stroke()),this.setCanvasStyle("reset"))}}},drawLineString:function(a,b,c){b=OpenLayers.Util.applyDefaults({fill:!1},b);this.drawLinearRing(a,b,c)},drawLinearRing:function(a,b,c){!1!==b.fill&&(this.setCanvasStyle("fill",b),this.renderPath(this.canvas,a,b,c,"fill"),this.hitDetection&&(this.setHitContextStyle("fill",c,b),this.renderPath(this.hitContext,a,b,c,"fill")));!1!==b.stroke&&(this.setCanvasStyle("stroke",b),this.renderPath(this.canvas,
+a,b,c,"stroke"),this.hitDetection&&(this.setHitContextStyle("stroke",c,b),this.renderPath(this.hitContext,a,b,c,"stroke")));this.setCanvasStyle("reset")},renderPath:function(a,b,c,d,e){b=b.components;c=b.length;a.beginPath();d=this.getLocalXY(b[0]);var f=d[1];if(!isNaN(d[0])&&!isNaN(f)){a.moveTo(d[0],d[1]);for(d=1;d<c;++d)f=this.getLocalXY(b[d]),a.lineTo(f[0],f[1]);"fill"===e?a.fill():a.stroke()}},drawPolygon:function(a,b,c){a=a.components;var d=a.length;this.drawLinearRing(a[0],b,c);for(var e=1;e<
+d;++e)this.canvas.globalCompositeOperation="destination-out",this.hitDetection&&(this.hitContext.globalCompositeOperation="destination-out"),this.drawLinearRing(a[e],OpenLayers.Util.applyDefaults({stroke:!1,fillOpacity:1},b),c),this.canvas.globalCompositeOperation="source-over",this.hitDetection&&(this.hitContext.globalCompositeOperation="source-over"),this.drawLinearRing(a[e],OpenLayers.Util.applyDefaults({fill:!1},b),c)},drawText:function(a,b){var c=this.getLocalXY(a);this.setCanvasStyle("reset");
+this.canvas.fillStyle=b.fontColor;this.canvas.globalAlpha=b.fontOpacity||1;var d=[b.fontStyle?b.fontStyle:"normal","normal",b.fontWeight?b.fontWeight:"normal",b.fontSize?b.fontSize:"1em",b.fontFamily?b.fontFamily:"sans-serif"].join(" "),e=b.label.split("\n"),f=e.length;if(this.canvas.fillText){this.canvas.font=d;this.canvas.textAlign=OpenLayers.Renderer.Canvas.LABEL_ALIGN[b.labelAlign[0]]||"center";this.canvas.textBaseline=OpenLayers.Renderer.Canvas.LABEL_ALIGN[b.labelAlign[1]]||"middle";var g=OpenLayers.Renderer.Canvas.LABEL_FACTOR[b.labelAlign[1]];
+null==g&&(g=-0.5);d=this.canvas.measureText("Mg").height||this.canvas.measureText("xx").width;c[1]+=d*g*(f-1);for(g=0;g<f;g++)b.labelOutlineWidth&&(this.canvas.save(),this.canvas.globalAlpha=b.labelOutlineOpacity||b.fontOpacity||1,this.canvas.strokeStyle=b.labelOutlineColor,this.canvas.lineWidth=b.labelOutlineWidth,this.canvas.strokeText(e[g],c[0],c[1]+d*g+1),this.canvas.restore()),this.canvas.fillText(e[g],c[0],c[1]+d*g)}else if(this.canvas.mozDrawText){this.canvas.mozTextStyle=d;var h=OpenLayers.Renderer.Canvas.LABEL_FACTOR[b.labelAlign[0]];
+null==h&&(h=-0.5);g=OpenLayers.Renderer.Canvas.LABEL_FACTOR[b.labelAlign[1]];null==g&&(g=-0.5);d=this.canvas.mozMeasureText("xx");c[1]+=d*(1+g*f);for(g=0;g<f;g++){var k=c[0]+h*this.canvas.mozMeasureText(e[g]),l=c[1]+g*d;this.canvas.translate(k,l);this.canvas.mozDrawText(e[g]);this.canvas.translate(-k,-l)}}this.setCanvasStyle("reset")},getLocalXY:function(a){var b=this.getResolution(),c=this.extent;return[(a.x-this.featureDx)/b+-c.left/b,c.top/b-a.y/b]},clear:function(){var a=this.root.height,b=this.root.width;
+this.canvas.clearRect(0,0,b,a);this.features={};this.hitDetection&&this.hitContext.clearRect(0,0,b,a)},getFeatureIdFromEvent:function(a){var b;if(this.hitDetection&&"none"!==this.root.style.display&&!this.map.dragging&&(a=a.xy,a=this.hitContext.getImageData(a.x|0,a.y|0,1,1).data,255===a[3]&&(a=a[2]+256*(a[1]+256*a[0])))){a="OpenLayers_Feature_Vector_"+(a-1+this.hitOverflow);try{b=this.features[a][0]}catch(c){}}return b},eraseFeatures:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=0;b<a.length;++b)delete this.features[a[b].id];
+this.redraw()},redraw:function(){if(!this.locked){var a=this.root.height,b=this.root.width;this.canvas.clearRect(0,0,b,a);this.hitDetection&&this.hitContext.clearRect(0,0,b,a);var a=[],c,d,e=this.map.baseLayer&&this.map.baseLayer.wrapDateLine&&this.map.getMaxExtent(),f;for(f in this.features)this.features.hasOwnProperty(f)&&(b=this.features[f][0],c=b.geometry,this.calculateFeatureDx(c.getBounds(),e),d=this.features[f][1],this.drawGeometry(c,d,b.id),d.label&&a.push([b,d]));b=0;for(c=a.length;b<c;++b)f=
+a[b],this.drawText(f[0].geometry.getCentroid(),f[1])}},CLASS_NAME:"OpenLayers.Renderer.Canvas"});OpenLayers.Renderer.Canvas.LABEL_ALIGN={l:"left",r:"right",t:"top",b:"bottom"};OpenLayers.Renderer.Canvas.LABEL_FACTOR={l:0,r:-1,t:0,b:-1};OpenLayers.Renderer.Canvas.drawImageScaleFactor=null;OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:!1,interestingTagsExclude:null,areaTags:null,initialize:function(a){var b={interestingTagsExclude:"source source_ref source:ref history attribution created_by".split(" "),areaTags:"area building leisure tourism ruins historic landuse military natural sport".split(" ")},b=OpenLayers.Util.extend(b,a),c={};for(a=0;a<b.interestingTagsExclude.length;a++)c[b.interestingTagsExclude[a]]=!0;b.interestingTagsExclude=c;c={};for(a=0;a<b.areaTags.length;a++)c[b.areaTags[a]]=
+!0;b.areaTags=c;this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[b])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=this.getNodes(a),c=this.getWays(a);a=Array(c.length);for(var d=0;d<c.length;d++){for(var e=Array(c[d].nodes.length),f=this.isWayArea(c[d])?1:0,g=0;g<c[d].nodes.length;g++){var h=b[c[d].nodes[g]],k=new OpenLayers.Geometry.Point(h.lon,h.lat);k.osm_id=parseInt(c[d].nodes[g]);
+e[g]=k;h.used=!0}h=null;h=f?new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(e)):new OpenLayers.Geometry.LineString(e);this.internalProjection&&this.externalProjection&&h.transform(this.externalProjection,this.internalProjection);e=new OpenLayers.Feature.Vector(h,c[d].tags);e.osm_id=parseInt(c[d].id);e.fid="way."+e.osm_id;a[d]=e}for(var l in b){h=b[l];if(!h.used||this.checkTags){c=null;if(this.checkTags){c=this.getTags(h.node,!0);if(h.used&&!c[1])continue;c=c[0]}else c=this.getTags(h.node);
+e=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(h.lon,h.lat),c);this.internalProjection&&this.externalProjection&&e.geometry.transform(this.externalProjection,this.internalProjection);e.osm_id=parseInt(l);e.fid="node."+e.osm_id;a.push(e)}h.node=null}return a},getNodes:function(a){a=a.getElementsByTagName("node");for(var b={},c=0;c<a.length;c++){var d=a[c],e=d.getAttribute("id");b[e]={lat:d.getAttribute("lat"),lon:d.getAttribute("lon"),node:d}}return b},getWays:function(a){a=a.getElementsByTagName("way");
+for(var b=[],c=0;c<a.length;c++){var d=a[c],e={id:d.getAttribute("id")};e.tags=this.getTags(d);d=d.getElementsByTagName("nd");e.nodes=Array(d.length);for(var f=0;f<d.length;f++)e.nodes[f]=d[f].getAttribute("ref");b.push(e)}return b},getTags:function(a,b){for(var c=a.getElementsByTagName("tag"),d={},e=!1,f=0;f<c.length;f++){var g=c[f].getAttribute("k");d[g]=c[f].getAttribute("v");b&&(this.interestingTagsExclude[g]||(e=!0))}return b?[d,e]:d},isWayArea:function(a){var b=!1,c=!1;a.nodes[0]==a.nodes[a.nodes.length-
+1]&&(b=!0);if(this.checkTags)for(var d in a.tags)if(this.areaTags[d]){c=!0;break}return b&&(this.checkTags?c:!0)},write:function(a){OpenLayers.Util.isArray(a)||(a=[a]);this.osm_id=1;this.created_nodes={};var b=this.createElementNS(null,"osm");b.setAttribute("version","0.5");b.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var c=a.length-1;0<=c;c--)for(var d=this.createFeatureNodes(a[c]),e=0;e<d.length;e++)b.appendChild(d[e]);return OpenLayers.Format.XML.prototype.write.apply(this,
+[b])},createFeatureNodes:function(a){var b=[],c=a.geometry.CLASS_NAME,c=c.substring(c.lastIndexOf(".")+1),c=c.toLowerCase();(c=this.createXML[c])&&(b=c.apply(this,[a]));return b},createXML:{point:function(a){var b=null,c=a.geometry?a.geometry:a;this.internalProjection&&this.externalProjection&&(c=c.clone(),c.transform(this.internalProjection,this.externalProjection));var d=!1;a.osm_id?(b=a.osm_id,this.created_nodes[b]&&(d=!0)):(b=-this.osm_id,this.osm_id++);var e=d?this.created_nodes[b]:this.createElementNS(null,
+"node");this.created_nodes[b]=e;e.setAttribute("id",b);e.setAttribute("lon",c.x);e.setAttribute("lat",c.y);a.attributes&&this.serializeTags(a,e);this.setState(a,e);return d?[]:[e]},linestring:function(a){var b,c=[],d=a.geometry;a.osm_id?b=a.osm_id:(b=-this.osm_id,this.osm_id++);var e=this.createElementNS(null,"way");e.setAttribute("id",b);for(b=0;b<d.components.length;b++){var f=this.createXML.point.apply(this,[d.components[b]]);if(f.length){var f=f[0],g=f.getAttribute("id");c.push(f)}else g=d.components[b].osm_id,
+f=this.created_nodes[g];this.setState(a,f);f=this.createElementNS(null,"nd");f.setAttribute("ref",g);e.appendChild(f)}this.serializeTags(a,e);c.push(e);return c},polygon:function(a){var b=OpenLayers.Util.extend({area:"yes"},a.attributes),b=new OpenLayers.Feature.Vector(a.geometry.components[0],b);b.osm_id=a.osm_id;return this.createXML.linestring.apply(this,[b])}},serializeTags:function(a,b){for(var c in a.attributes){var d=this.createElementNS(null,"tag");d.setAttribute("k",c);d.setAttribute("v",
+a.attributes[c]);b.appendChild(d)}},setState:function(a,b){if(a.state){var c=null;switch(a.state){case OpenLayers.State.UPDATE:case OpenLayers.State.DELETE:c="delete"}c&&b.setAttribute("action",c)}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,observeElement:null,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this)},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments)},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,
+arguments)){this.observeElement=this.observeElement||document;for(var a=0,b=this.KEY_EVENTS.length;a<b;a++)OpenLayers.Event.observe(this.observeElement,this.KEY_EVENTS[a],this.eventListener);return!0}return!1},deactivate:function(){var a=!1;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var a=0,b=this.KEY_EVENTS.length;a<b;a++)OpenLayers.Event.stopObserving(this.observeElement,this.KEY_EVENTS[a],this.eventListener);a=!0}return a},handleKeyEvent:function(a){this.checkModifiers(a)&&
+this.callback(a.type,[a])},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{documentDrag:!1,geometryTypes:null,clickout:!0,toggle:!0,standalone:!1,layer:null,feature:null,vertex:null,vertices:null,virtualVertices:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,createVertices:!0,modified:!1,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(a,b){b=b||{};this.layer=a;this.vertices=
+[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,b.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[b]);OpenLayers.Util.isArray(this.deleteCodes)||(this.deleteCodes=[this.deleteCodes]);var c={documentDrag:this.documentDrag,stopDown:!1};this.handlers=
+{keyboard:new OpenLayers.Handler.Keyboard(this,{keydown:this.handleKeypress}),drag:new OpenLayers.Handler.Drag(this,{down:function(a){this.vertex=null;(a=this.layer.getFeatureFromEvent(this.handlers.drag.evt))?this.dragStart(a):this.clickout&&(this._unselect=this.feature)},move:function(a){delete this._unselect;this.vertex&&this.dragVertex(this.vertex,a)},up:function(){this.handlers.drag.stopDown=!1;this._unselect&&(this.unselectFeature(this._unselect),delete this._unselect)},done:function(a){this.vertex&&
+this.dragComplete(this.vertex)}},c)}},destroy:function(){this.map&&this.map.events.un({removelayer:this.handleMapEvents,changelayer:this.handleMapEvents,scope:this});this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[])},activate:function(){this.moveLayerToTop();this.map.events.on({removelayer:this.handleMapEvents,changelayer:this.handleMapEvents,scope:this});return this.handlers.keyboard.activate()&&this.handlers.drag.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments)},
+deactivate:function(){var a=!1;OpenLayers.Control.prototype.deactivate.apply(this,arguments)&&(this.moveLayerBack(),this.map.events.un({removelayer:this.handleMapEvents,changelayer:this.handleMapEvents,scope:this}),this.layer.removeFeatures(this.vertices,{silent:!0}),this.layer.removeFeatures(this.virtualVertices,{silent:!0}),this.vertices=[],this.handlers.drag.deactivate(),this.handlers.keyboard.deactivate(),(a=this.feature)&&(a.geometry&&a.layer)&&this.unselectFeature(a),a=!0);return a},beforeSelectFeature:function(a){return this.layer.events.triggerEvent("beforefeaturemodified",
+{feature:a})},selectFeature:function(a){if(!(this.feature===a||this.geometryTypes&&-1==OpenLayers.Util.indexOf(this.geometryTypes,a.geometry.CLASS_NAME))){!1!==this.beforeSelectFeature(a)&&(this.feature&&this.unselectFeature(this.feature),this.feature=a,this.layer.selectedFeatures.push(a),this.layer.drawFeature(a,"select"),this.modified=!1,this.resetVertices(),this.onModificationStart(this.feature));var b=a.modified;!a.geometry||b&&b.geometry||(this._originalGeometry=a.geometry.clone())}},unselectFeature:function(a){this.layer.removeFeatures(this.vertices,
+{silent:!0});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:!0});this.virtualVertices=[];this.dragHandle&&(this.layer.destroyFeatures([this.dragHandle],{silent:!0}),delete this.dragHandle);this.radiusHandle&&(this.layer.destroyFeatures([this.radiusHandle],{silent:!0}),delete this.radiusHandle);this.layer.drawFeature(this.feature,"default");this.feature=null;OpenLayers.Util.removeItem(this.layer.selectedFeatures,a);this.onModificationEnd(a);this.layer.events.triggerEvent("afterfeaturemodified",
+{feature:a,modified:this.modified});this.modified=!1},dragStart:function(a){var b="OpenLayers.Geometry.Point"==a.geometry.CLASS_NAME;this.standalone||(a._sketch||!b)&&a._sketch||(this.toggle&&this.feature===a&&(this._unselect=a),this.selectFeature(a));if(a._sketch||b)this.vertex=a,this.handlers.drag.stopDown=!0},dragVertex:function(a,b){var c=this.map.getLonLatFromViewPortPx(b),d=a.geometry;d.move(c.lon-d.x,c.lat-d.y);this.modified=!0;"OpenLayers.Geometry.Point"==this.feature.geometry.CLASS_NAME?
+this.layer.events.triggerEvent("vertexmodified",{vertex:a.geometry,feature:this.feature,pixel:b}):(a._index?(a.geometry.parent.addComponent(a.geometry,a._index),delete a._index,OpenLayers.Util.removeItem(this.virtualVertices,a),this.vertices.push(a)):a==this.dragHandle?(this.layer.removeFeatures(this.vertices,{silent:!0}),this.vertices=[],this.radiusHandle&&(this.layer.destroyFeatures([this.radiusHandle],{silent:!0}),this.radiusHandle=null)):a!==this.radiusHandle&&this.layer.events.triggerEvent("vertexmodified",
+{vertex:a.geometry,feature:this.feature,pixel:b}),0<this.virtualVertices.length&&(this.layer.destroyFeatures(this.virtualVertices,{silent:!0}),this.virtualVertices=[]),this.layer.drawFeature(this.feature,this.standalone?void 0:"select"));this.layer.drawFeature(a)},dragComplete:function(a){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature})},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&
+this.feature.state!=OpenLayers.State.DELETE&&(this.feature.state=OpenLayers.State.UPDATE,this.modified&&this._originalGeometry)){var a=this.feature;a.modified=OpenLayers.Util.extend(a.modified,{geometry:this._originalGeometry});delete this._originalGeometry}},resetVertices:function(){0<this.vertices.length&&(this.layer.removeFeatures(this.vertices,{silent:!0}),this.vertices=[]);0<this.virtualVertices.length&&(this.layer.removeFeatures(this.virtualVertices,{silent:!0}),this.virtualVertices=[]);this.dragHandle&&
+(this.layer.destroyFeatures([this.dragHandle],{silent:!0}),this.dragHandle=null);this.radiusHandle&&(this.layer.destroyFeatures([this.radiusHandle],{silent:!0}),this.radiusHandle=null);this.feature&&"OpenLayers.Geometry.Point"!=this.feature.geometry.CLASS_NAME&&(this.mode&OpenLayers.Control.ModifyFeature.DRAG&&this.collectDragHandle(),this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE)&&this.collectRadiusHandle(),this.mode&OpenLayers.Control.ModifyFeature.RESHAPE&&
+(this.mode&OpenLayers.Control.ModifyFeature.RESIZE||this.collectVertices()))},handleKeypress:function(a){var b=a.keyCode;this.feature&&-1!=OpenLayers.Util.indexOf(this.deleteCodes,b)&&(b=this.layer.getFeatureFromEvent(this.handlers.drag.evt))&&(-1!=OpenLayers.Util.indexOf(this.vertices,b)&&!this.handlers.drag.dragging&&b.geometry.parent)&&(b.geometry.parent.removeComponent(b.geometry),this.layer.events.triggerEvent("vertexremoved",{vertex:b.geometry,feature:this.feature,pixel:a.xy}),this.layer.drawFeature(this.feature,
+this.standalone?void 0:"select"),this.modified=!0,this.resetVertices(),this.setFeatureState(),this.onModification(this.feature),this.layer.events.triggerEvent("featuremodified",{feature:this.feature}))},collectVertices:function(){function a(c){var d,e,f;if("OpenLayers.Geometry.Point"==c.CLASS_NAME)e=new OpenLayers.Feature.Vector(c),e._sketch=!0,e.renderIntent=b.vertexRenderIntent,b.vertices.push(e);else{f=c.components.length;"OpenLayers.Geometry.LinearRing"==c.CLASS_NAME&&(f-=1);for(d=0;d<f;++d)e=
+c.components[d],"OpenLayers.Geometry.Point"==e.CLASS_NAME?(e=new OpenLayers.Feature.Vector(e),e._sketch=!0,e.renderIntent=b.vertexRenderIntent,b.vertices.push(e)):a(e);if(b.createVertices&&"OpenLayers.Geometry.MultiPoint"!=c.CLASS_NAME)for(d=0,f=c.components.length;d<f-1;++d){e=c.components[d];var g=c.components[d+1];"OpenLayers.Geometry.Point"==e.CLASS_NAME&&"OpenLayers.Geometry.Point"==g.CLASS_NAME&&(e=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point((e.x+g.x)/2,(e.y+g.y)/2),null,b.virtualStyle),
+e.geometry.parent=c,e._index=d+1,e._sketch=!0,b.virtualVertices.push(e))}}}this.vertices=[];this.virtualVertices=[];var b=this;a.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:!0});this.layer.addFeatures(this.vertices,{silent:!0})},collectDragHandle:function(){var a=this.feature.geometry,b=a.getBounds().getCenterLonLat(),b=new OpenLayers.Geometry.Point(b.lon,b.lat),c=new OpenLayers.Feature.Vector(b);b.move=function(b,c){OpenLayers.Geometry.Point.prototype.move.call(this,
+b,c);a.move(b,c)};c._sketch=!0;this.dragHandle=c;this.dragHandle.renderIntent=this.vertexRenderIntent;this.layer.addFeatures([this.dragHandle],{silent:!0})},collectRadiusHandle:function(){var a=this.feature.geometry,b=a.getBounds(),c=b.getCenterLonLat(),d=new OpenLayers.Geometry.Point(c.lon,c.lat),b=new OpenLayers.Geometry.Point(b.right,b.bottom),c=new OpenLayers.Feature.Vector(b),e=this.mode&OpenLayers.Control.ModifyFeature.RESIZE,f=this.mode&OpenLayers.Control.ModifyFeature.RESHAPE,g=this.mode&
+OpenLayers.Control.ModifyFeature.ROTATE;b.move=function(b,c){OpenLayers.Geometry.Point.prototype.move.call(this,b,c);var l=this.x-d.x,m=this.y-d.y,n=l-b,p=m-c;if(g){var q=Math.atan2(p,n),q=Math.atan2(m,l)-q,q=q*(180/Math.PI);a.rotate(q,d)}if(e){var r;f?(m/=p,r=l/n/m):(n=Math.sqrt(n*n+p*p),m=Math.sqrt(l*l+m*m)/n);a.resize(m,d,r)}};c._sketch=!0;this.radiusHandle=c;this.radiusHandle.renderIntent=this.vertexRenderIntent;this.layer.addFeatures([this.radiusHandle],{silent:!0})},setMap:function(a){this.handlers.drag.setMap(a);
+OpenLayers.Control.prototype.setMap.apply(this,arguments)},handleMapEvents:function(a){"removelayer"!=a.type&&"order"!=a.property||this.moveLayerToTop()},moveLayerToTop:function(){var a=Math.max(this.map.Z_INDEX_BASE.Feature-1,this.layer.getZIndex())+1;this.layer.setZIndex(a)},moveLayerBack:function(){var a=this.layer.getZIndex()-1;a>=this.map.Z_INDEX_BASE.Feature?this.layer.setZIndex(a):this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer))},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});
+OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Layer.Bing=OpenLayers.Class(OpenLayers.Layer.XYZ,{key:null,serverResolutions:[156543.03390625,78271.516953125,39135.7584765625,19567.87923828125,9783.939619140625,4891.9698095703125,2445.9849047851562,1222.9924523925781,611.4962261962891,305.74811309814453,152.87405654907226,76.43702827453613,38.218514137268066,19.109257068634033,9.554628534317017,4.777314267158508,2.388657133579254,1.194328566789627,0.5971642833948135,0.29858214169740677,0.14929107084870338,0.07464553542435169],attributionTemplate:'<span class="olBingAttribution ${type}"><div><a target="_blank" href="http://www.bing.com/maps/"><img src="${logo}" /></a></div>${copyrights}<a style="white-space: nowrap" target="_blank" href="http://www.microsoft.com/maps/product/terms.html">Terms of Use</a></span>',
+metadata:null,protocolRegex:/^http:/i,type:"Road",culture:"en-US",metadataParams:null,tileOptions:null,protocol:~window.location.href.indexOf("http")?"":"http:",initialize:function(a){a=OpenLayers.Util.applyDefaults({sphericalMercator:!0},a);OpenLayers.Layer.XYZ.prototype.initialize.apply(this,[a.name||"Bing "+(a.type||this.type),null,a]);this.tileOptions=OpenLayers.Util.extend({crossOriginKeyword:"anonymous"},this.options.tileOptions);this.loadMetadata()},loadMetadata:function(){this._callbackId=
+"_callback_"+this.id.replace(/\./g,"_");window[this._callbackId]=OpenLayers.Function.bind(OpenLayers.Layer.Bing.processMetadata,this);var a=OpenLayers.Util.applyDefaults({key:this.key,jsonp:this._callbackId,include:"ImageryProviders"},this.metadataParams),a=this.protocol+"//dev.virtualearth.net/REST/v1/Imagery/Metadata/"+this.type+"?"+OpenLayers.Util.getParameterString(a),b=document.createElement("script");b.type="text/javascript";b.src=a;b.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(b)},
+initLayer:function(){var a=this.metadata.resourceSets[0].resources[0],b=a.imageUrl.replace("{quadkey}","${quadkey}"),b=b.replace("{culture}",this.culture),b=b.replace(this.protocolRegex,this.protocol);this.url=[];for(var c=0;c<a.imageUrlSubdomains.length;++c)this.url.push(b.replace("{subdomain}",a.imageUrlSubdomains[c]));this.addOptions({maxResolution:Math.min(this.serverResolutions[a.zoomMin],this.maxResolution||Number.POSITIVE_INFINITY),numZoomLevels:Math.min(a.zoomMax+1-a.zoomMin,this.numZoomLevels)},
+!0);this.isBaseLayer||this.redraw();this.updateAttribution()},getURL:function(a){if(this.url){var b=this.getXYZ(a);a=b.x;for(var c=b.y,b=b.z,d=[],e=b;0<e;--e){var f="0",g=1<<e-1;0!=(a&g)&&f++;0!=(c&g)&&(f++,f++);d.push(f)}d=d.join("");a=this.selectUrl(""+a+c+b,this.url);return OpenLayers.String.format(a,{quadkey:d})}},updateAttribution:function(){var a=this.metadata;if(a.resourceSets&&this.map&&this.map.center){var b=a.resourceSets[0].resources[0],c=this.map.getExtent().transform(this.map.getProjectionObject(),
+new OpenLayers.Projection("EPSG:4326")),d=b.imageryProviders||[],e=OpenLayers.Util.indexOf(this.serverResolutions,this.getServerResolution()),b="",f,g,h,k,l,m,n;g=0;for(h=d.length;g<h;++g)for(f=d[g],k=0,l=f.coverageAreas.length;k<l;++k)n=f.coverageAreas[k],m=OpenLayers.Bounds.fromArray(n.bbox,!0),c.intersectsBounds(m)&&(e<=n.zoomMax&&e>=n.zoomMin)&&(b+=f.attribution+" ");a=a.brandLogoUri.replace(this.protocolRegex,this.protocol);this.attribution=OpenLayers.String.format(this.attributionTemplate,{type:this.type.toLowerCase(),
+logo:a,copyrights:b});this.map&&this.map.events.triggerEvent("changelayer",{layer:this,property:"attribution"})}},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.updateAttribution)},clone:function(a){null==a&&(a=new OpenLayers.Layer.Bing(this.options));return a=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},destroy:function(){this.map&&this.map.events.unregister("moveend",this,this.updateAttribution);OpenLayers.Layer.XYZ.prototype.destroy.apply(this,
+arguments)},CLASS_NAME:"OpenLayers.Layer.Bing"});OpenLayers.Layer.Bing.processMetadata=function(a){this.metadata=a;this.initLayer();a=document.getElementById(this._callbackId);a.parentNode.removeChild(a);window[this._callbackId]=void 0;delete this._callbackId};OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:!0,initialize:function(a,b){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),select:new OpenLayers.Style(OpenLayers.Feature.Vector.style.select),temporary:new OpenLayers.Style(OpenLayers.Feature.Vector.style.temporary),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(a instanceof OpenLayers.Style)this.styles["default"]=a,this.styles.select=a,this.styles.temporary=a,this.styles["delete"]=
+a;else if("object"==typeof a)for(var c in a)if(a[c]instanceof OpenLayers.Style)this.styles[c]=a[c];else if("object"==typeof a[c])this.styles[c]=new OpenLayers.Style(a[c]);else{this.styles["default"]=new OpenLayers.Style(a);this.styles.select=new OpenLayers.Style(a);this.styles.temporary=new OpenLayers.Style(a);this.styles["delete"]=new OpenLayers.Style(a);break}OpenLayers.Util.extend(this,b)},destroy:function(){for(var a in this.styles)this.styles[a].destroy();this.styles=null},createSymbolizer:function(a,
+b){a||(a=new OpenLayers.Feature.Vector);this.styles[b]||(b="default");a.renderIntent=b;var c={};this.extendDefault&&"default"!=b&&(c=this.styles["default"].createSymbolizer(a));return OpenLayers.Util.extend(c,this.styles[b].createSymbolizer(a))},addUniqueValueRules:function(a,b,c,d){var e=[],f;for(f in c)e.push(new OpenLayers.Rule({symbolizer:c[f],context:d,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:b,value:f})}));this.styles[a].addRules(e)},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:!1,isFixed:!1,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:!0,style:null,styleMap:null,strategies:null,protocol:null,renderers:["SVG","VML","Canvas"],renderer:null,rendererOptions:null,geometryType:null,drawn:!1,ratio:1,initialize:function(a,b){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.renderer&&this.renderer.supported()||t
his.assignRenderer();this.renderer&&this.renderer.supported()||
+(this.renderer=null,this.displayError());this.styleMap||(this.styleMap=new OpenLayers.StyleMap);this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies)for(var c=0,d=this.strategies.length;c<d;c++)this.strategies[c].setLayer(this)},destroy:function(){if(this.strategies){var a,b,c;b=0;for(c=this.strategies.length;b<c;b++)a=this.strategies[b],a.autoDestroy&&a.destroy();this.strategies=null}this.protocol&&(this.protocol.autoDestroy&&this.protocol.destroy(),this.protocol=
+null);this.destroyFeatures();this.unrenderedFeatures=this.selectedFeatures=this.features=null;this.renderer&&this.renderer.destroy();this.drawn=this.geometryType=this.renderer=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.Vector(this.name,this.getOptions()));a=OpenLayers.Layer.prototype.clone.apply(this,[a]);for(var b=this.features,c=b.length,d=Array(c),e=0;e<c;++e)d[e]=b[e].clone();a.features=d;return a},refresh:function(a){this.calculateInRange()&&
+this.visibility&&this.events.triggerEvent("refresh",a)},assignRenderer:function(){for(var a=0,b=this.renderers.length;a<b;a++){var c=this.renderers[a];if((c="function"==typeof c?c:OpenLayers.Renderer[c])&&c.prototype.supported()){this.renderer=new c(this.div,this.rendererOptions);break}}},displayError:function(){this.reportError&&OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{renderers:this.renderers.join("\n")}))},setMap:function(a){OpenLayers.Layer.prototype.setMap.apply(this,
+arguments);if(this.renderer){this.renderer.map=this.map;var b=this.map.getSize();b.w*=this.ratio;b.h*=this.ratio;this.renderer.setSize(b)}else this.map.removeLayer(this)},afterAdd:function(){if(this.strategies){var a,b,c;b=0;for(c=this.strategies.length;b<c;b++)a=this.strategies[b],a.autoActivate&&a.activate()}},removeMap:function(a){this.drawn=!1;if(this.strategies){var b,c;b=0;for(c=this.strategies.length;b<c;b++)a=this.strategies[b],a.autoActivate&&a.deactivate()}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,
+arguments);var a=this.map.getSize();a.w*=this.ratio;a.h*=this.ratio;this.renderer.setSize(a)},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var d=!0;if(!c){this.renderer.root.style.visibility="hidden";var d=this.map.getSize(),e=d.w,d=d.h,e=e/2*this.ratio-e/2,d=d/2*this.ratio-d/2,e=e+this.map.layerContainerOriginPx.x,e=-Math.round(e),d=d+this.map.layerContainerOriginPx.y,d=-Math.round(d);this.div.style.left=e+"px";this.div.style.top=d+"px";e=this.map.getExtent().scale(this.ratio);
+d=this.renderer.setExtent(e,b);this.renderer.root.style.visibility="visible";!0===OpenLayers.IS_GECKO&&(this.div.scrollLeft=this.div.scrollLeft);if(!b&&d)for(var f in this.unrenderedFeatures)e=this.unrenderedFeatures[f],this.drawFeature(e)}if(!this.drawn||b||!d)for(this.drawn=!0,f=0,d=this.features.length;f<d;f++)this.renderer.locked=f!==d-1,e=this.features[f],this.drawFeature(e)},display:function(a){OpenLayers.Layer.prototype.display.apply(this,arguments);var b=this.div.style.display;b!=this.renderer.root.style.display&&
+(this.renderer.root.style.display=b)},addFeatures:function(a,b){OpenLayers.Util.isArray(a)||(a=[a]);var c=!b||!b.silent;if(c){var d={features:a};if(!1===this.events.triggerEvent("beforefeaturesadded",d))return;a=d.features}for(var d=[],e=0,f=a.length;e<f;e++){this.renderer.locked=e!=a.length-1?!0:!1;var g=a[e];if(this.geometryType&&!(g.geometry instanceof this.geometryType))throw new TypeError("addFeatures: component should be an "+this.geometryType.prototype.CLASS_NAME);g.layer=this;!g.style&&this.style&&
+(g.style=OpenLayers.Util.extend({},this.style));if(c){if(!1===this.events.triggerEvent("beforefeatureadded",{feature:g}))continue;this.preFeatureInsert(g)}d.push(g);this.features.push(g);this.drawFeature(g);c&&(this.events.triggerEvent("featureadded",{feature:g}),this.onFeatureInsert(g))}c&&this.events.triggerEvent("featuresadded",{features:d})},removeFeatures:function(a,b){if(a&&0!==a.length){if(a===this.features)return this.removeAllFeatures(b);OpenLayers.Util.isArray(a)||(a=[a]);a===this.selectedFeatures&&
+(a=a.slice());var c=!b||!b.silent;c&&this.events.triggerEvent("beforefeaturesremoved",{features:a});for(var d=a.length-1;0<=d;d--){this.renderer.locked=0!=d&&a[d-1].geometry?!0:!1;var e=a[d];delete this.unrenderedFeatures[e.id];c&&this.events.triggerEvent("beforefeatureremoved",{feature:e});this.features=OpenLayers.Util.removeItem(this.features,e);e.layer=null;e.geometry&&this.renderer.eraseFeatures(e);-1!=OpenLayers.Util.indexOf(this.selectedFeatures,e)&&OpenLayers.Util.removeItem(this.selectedFeatures,
+e);c&&this.events.triggerEvent("featureremoved",{feature:e})}c&&this.events.triggerEvent("featuresremoved",{features:a})}},removeAllFeatures:function(a){a=!a||!a.silent;var b=this.features;a&&this.events.triggerEvent("beforefeaturesremoved",{features:b});for(var c,d=b.length-1;0<=d;d--)c=b[d],a&&this.events.triggerEvent("beforefeatureremoved",{feature:c}),c.layer=null,a&&this.events.triggerEvent("featureremoved",{feature:c});this.renderer.clear();this.features=[];this.unrenderedFeatures={};this.selectedFeatures=
+[];a&&this.events.triggerEvent("featuresremoved",{features:b})},destroyFeatures:function(a,b){void 0==a&&(a=this.features);if(a){this.removeFeatures(a,b);for(var c=a.length-1;0<=c;c--)a[c].destroy()}},drawFeature:function(a,b){if(this.drawn){if("object"!=typeof b){b||a.state!==OpenLayers.State.DELETE||(b="delete");var c=b||a.renderIntent;(b=a.style||this.style)||(b=this.styleMap.createSymbolizer(a,c))}c=this.renderer.drawFeature(a,b);!1===c||null===c?this.unrenderedFeatures[a.id]=a:delete this.unrenderedFeatures[a.id]}},
+eraseFeatures:function(a){this.renderer.eraseFeatures(a)},getFeatureFromEvent:function(a){if(!this.renderer)throw Error("getFeatureFromEvent called on layer with no renderer. This usually means you destroyed a layer, but not some handler which is associated with it.");var b=null;(a=this.renderer.getFeatureIdFromEvent(a))&&(b="string"===typeof a?this.getFeatureById(a):a);return b},getFeatureBy:function(a,b){for(var c=null,d=0,e=this.features.length;d<e;++d)if(this.features[d][a]==b){c=this.features[d];
+break}return c},getFeatureById:function(a){return this.getFeatureBy("id",a)},getFeatureByFid:function(a){return this.getFeatureBy("fid",a)},getFeaturesByAttribute:function(a,b){var c,d,e=this.features.length,f=[];for(c=0;c<e;c++)(d=this.features[c])&&d.attributes&&d.attributes[a]===b&&f.push(d);return f},onFeatureInsert:function(a){},preFeatureInsert:function(a){},getDataExtent:function(){var a=null,b=this.features;if(b&&0<b.length)for(var c=null,d=0,e=b.length;d<e;d++)if(c=b[d].geometry)null===a&&
+(a=new OpenLayers.Bounds),a.extend(c.getBounds());return a},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.PointGrid=OpenLayers.Class(OpenLayers.Layer.Vector,{dx:null,dy:null,ratio:1.5,maxFeatures:250,rotation:0,origin:null,gridBounds:null,initialize:function(a){a=a||{};OpenLayers.Layer.Vector.prototype.initialize.apply(this,[a.name,a])},setMap:function(a){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);a.events.register("moveend",this,this.onMoveEnd)},removeMap:function(a){a.events.unregister("moveend",this,this.onMoveEnd);OpenLayers.Layer.Vector.prototype.removeMap.apply(this,
+arguments)},setRatio:function(a){this.ratio=a;this.updateGrid(!0)},setMaxFeatures:function(a){this.maxFeatures=a;this.updateGrid(!0)},setSpacing:function(a,b){this.dx=a;this.dy=b||a;this.updateGrid(!0)},setOrigin:function(a){this.origin=a;this.updateGrid(!0)},getOrigin:function(){this.origin||(this.origin=this.map.getExtent().getCenterLonLat());return this.origin},setRotation:function(a){this.rotation=a;this.updateGrid(!0)},onMoveEnd:function(){this.updateGrid()},getViewBounds:function(){var a=this.map.getExtent();
+if(this.rotation){var b=this.getOrigin(),b=new OpenLayers.Geometry.Point(b.lon,b.lat),a=a.toGeometry();a.rotate(-this.rotation,b);a=a.getBounds()}return a},updateGrid:function(a){if(a||this.invalidBounds()){var b=this.getViewBounds(),c=this.getOrigin();a=new OpenLayers.Geometry.Point(c.lon,c.lat);var d=b.getWidth(),e=b.getHeight(),f=d/e,g=Math.sqrt(this.dx*this.dy*this.maxFeatures/f),d=Math.min(d*this.ratio,g*f),e=Math.min(e*this.ratio,g),b=b.getCenterLonLat();this.gridBounds=new OpenLayers.Bounds(b.lon-
+d/2,b.lat-e/2,b.lon+d/2,b.lat+e/2);for(var b=Math.floor(e/this.dy),d=Math.floor(d/this.dx),e=c.lon+this.dx*Math.ceil((this.gridBounds.left-c.lon)/this.dx),c=c.lat+this.dy*Math.ceil((this.gridBounds.bottom-c.lat)/this.dy),g=Array(b*d),h,k=0;k<d;++k)for(var f=e+k*this.dx,l=0;l<b;++l)h=c+l*this.dy,h=new OpenLayers.Geometry.Point(f,h),this.rotation&&h.rotate(this.rotation,a),g[k*b+l]=new OpenLayers.Feature.Vector(h);this.destroyFeatures(this.features,{silent:!0});this.addFeatures(g,{silent:!0})}},invalidBounds:function(){return!this.gridBounds||
+!this.gridBounds.containsBounds(this.getViewBounds())},CLASS_NAME:"OpenLayers.Layer.PointGrid"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,interval:0,maxDelta:Number.POSITIVE_INFINITY,delta:0,cumulative:!0,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this)},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null},onWheelEvent:function(a){if(this.map&&this.checkModifiers(a)){for(var b=
+!1,c=!1,d=!1,e=OpenLayers.Event.element(a);null!=e&&!d&&!b;){if(!b)try{var f,b=(f=e.currentStyle?e.currentStyle.overflow:document.defaultView.getComputedStyle(e,null).getPropertyValue("overflow"))&&"auto"==f||"scroll"==f}catch(g){}if(!c&&(c=OpenLayers.Element.hasClass(e,"olScrollable"),!c))for(var d=0,h=this.map.layers.length;d<h;d++){var k=this.map.layers[d];if(e==k.div||e==k.pane){c=!0;break}}d=e==this.map.div;e=e.parentNode}if(!b&&d){if(c)if(b=0,a.wheelDelta?(b=a.wheelDelta,0===b%160&&(b*=0.75),
+b/=120):a.detail&&(b=-(a.detail/Math.abs(a.detail))),this.delta+=b,window.clearTimeout(this._timeoutId),this.interval&&Math.abs(this.delta)<this.maxDelta){var l=OpenLayers.Util.extend({},a);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(l)},this),this.interval)}else this.wheelZoom(a);OpenLayers.Event.stop(a)}}},wheelZoom:function(a){var b=this.delta;this.delta=0;b&&(a.xy=this.map.events.getMousePosition(a),0>b?this.callback("down",[a,this.cumulative?Math.max(-this.maxDelta,
+b):-1]):this.callback("up",[a,this.cumulative?Math.min(this.maxDelta,b):1]))},activate:function(a){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var b=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",b);OpenLayers.Event.observe(window,"mousewheel",b);OpenLayers.Event.observe(document,"mousewheel",b);return!0}return!1},deactivate:function(a){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var b=this.wheelListener;OpenLayers.Event.stopObserving(window,
+"DOMMouseScroll",b);OpenLayers.Event.stopObserving(window,"mousewheel",b);OpenLayers.Event.stopObserving(document,"mousewheel",b);return!0}return!1},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Symbolizer=OpenLayers.Class({zIndex:0,initialize:function(a){OpenLayers.Util.extend(this,a)},clone:function(){return new (eval(this.CLASS_NAME))(OpenLayers.Util.extend({},this))},CLASS_NAME:"OpenLayers.Symbolizer"});OpenLayers.Symbolizer.Raster=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Raster"});OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:!1,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(a){this.symbolizer={};OpenLayers.Util.extend(this,a);this.symbolizers&&delete this.symbolizer;this.id=OpenLayers.Util.createUniqueID(this.CLASS_
NAME+"_")},destroy:function(){for(var a in this.symbolizer)this.symbolizer[a]=null;this.symbolizer=null;delete this.symbolizers},evaluate:function(a){var b=
+this.getContext(a),c=!0;if(this.minScaleDenominator||this.maxScaleDenominator)var d=a.layer.map.getScale();this.minScaleDenominator&&(c=d>=OpenLayers.Style.createLiteral(this.minScaleDenominator,b));c&&this.maxScaleDenominator&&(c=d<OpenLayers.Style.createLiteral(this.maxScaleDenominator,b));c&&this.filter&&(c="OpenLayers.Filter.FeatureId"==this.filter.CLASS_NAME?this.filter.evaluate(a):this.filter.evaluate(b));return c},getContext:function(a){var b=this.context;b||(b=a.attributes||a.data);"function"==
+typeof this.context&&(b=this.context(a));return b},clone:function(){var a=OpenLayers.Util.extend({},this);if(this.symbolizers){var b=this.symbolizers.length;a.symbolizers=Array(b);for(var c=0;c<b;++c)a.symbolizers[c]=this.symbolizers[c].clone()}else{a.symbolizer={};for(var d in this.symbolizer)b=this.symbolizer[d],c=typeof b,"object"===c?a.symbolizer[d]=OpenLayers.Util.extend({},b):"string"===c&&(a.symbolizer[d]=b)}a.filter=this.filter&&this.filter.clone();a.context=this.context&&OpenLayers.Util.extend({},
+this.context);return new OpenLayers.Rule(a)},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{profile:null,defaultVersion:"1.0.0",stringifyOutput:!0,namedLayersAsArray:!1,CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Symbolizer.Polygon=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Polygon"});OpenLayers.Format.GML.v2=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd",initialize:function(a){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[a])},readers:{gml:OpenLayers.Util.applyDefaults({outerBoundaryIs:function(a,b){var c={};this.readChildNodes(a,c);b.outer=c.components[0]},innerBoundaryIs:function(a,b){var c={};this.readChildNodes(a,c);b.inner.push(c.components[0])},Box:function(a,b){var c=
+{};this.readChildNodes(a,c);b.components||(b.components=[]);var d=c.points[0],c=c.points[1];b.components.push(new OpenLayers.Bounds(d.x,d.y,c.x,c.y))}},OpenLayers.Format.GML.Base.prototype.readers.gml),feature:OpenLayers.Format.GML.Base.prototype.readers.feature,wfs:OpenLayers.Format.GML.Base.prototype.readers.wfs},write:function(a){var b;b=OpenLayers.Util.isArray(a)?"wfs:FeatureCollection":"gml:featureMember";a=this.writeNode(b,a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);
+return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{gml:OpenLayers.Util.applyDefaults({Point:function(a){var b=this.createElementNSPlus("gml:Point");this.writeNode("coordinates",[a],b);return b},coordinates:function(a){for(var b=a.length,c=Array(b),d,e=0;e<b;++e)d=a[e],c[e]=this.xy?d.x+","+d.y:d.y+","+d.x,void 0!=d.z&&(c[e]+=","+d.z);return this.createElementNSPlus("gml:coordinates",{attributes:{decimal:".",cs:",",ts:" "},value:1==b?c[0]:c.join(" ")})},LineString:function(a){var b=
+this.createElementNSPlus("gml:LineString");this.writeNode("coordinates",a.components,b);return b},Polygon:function(a){var b=this.createElementNSPlus("gml:Polygon");this.writeNode("outerBoundaryIs",a.components[0],b);for(var c=1;c<a.components.length;++c)this.writeNode("innerBoundaryIs",a.components[c],b);return b},outerBoundaryIs:function(a){var b=this.createElementNSPlus("gml:outerBoundaryIs");this.writeNode("LinearRing",a,b);return b},innerBoundaryIs:function(a){var b=this.createElementNSPlus("gml:innerBoundaryIs");
+this.writeNode("LinearRing",a,b);return b},LinearRing:function(a){var b=this.createElementNSPlus("gml:LinearRing");this.writeNode("coordinates",a.components,b);return b},Box:function(a){var b=this.createElementNSPlus("gml:Box");this.writeNode("coordinates",[{x:a.left,y:a.bottom},{x:a.right,y:a.top}],b);this.srsName&&b.setAttribute("srsName",this.srsName);return b}},OpenLayers.Format.GML.Base.prototype.writers.gml),feature:OpenLayers.Format.GML.Base.prototype.writers.feature,wfs:OpenLayers.Format.GML.Base.prototype.writers.wfs},
+CLASS_NAME:"OpenLayers.Format.GML.v2"});OpenLayers.Format.Filter.v1_0_0=OpenLayers.Class(OpenLayers.Format.GML.v2,OpenLayers.Format.Filter.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.0.0/filter.xsd",initialize:function(a){OpenLayers.Format.GML.v2.prototype.initialize.apply(this,[a])},readers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsNotEqualTo:function(a,
+b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(a,c);b.filters.push(c)},PropertyIsLike:function(a,b){var c=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(a,c);var d=a.getAttribute("wildCard"),e=a.getAttribute("singleChar"),f=a.getAttribute("escape");c.value2regex(d,e,f);b.filters.push(c)}},OpenLayers.Format.Filter.v1.prototype.readers.ogc),gml:OpenLayers.Format.GML.v2.prototype.readers.gml,
+feature:OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{ogc:OpenLayers.Util.applyDefaults({PropertyIsEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsNotEqualTo:function(a){var b=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode("PropertyName",a,b);this.writeOgcExpression(a.value,b);return b},PropertyIsLike:function(a){var b=this.createElementNSPlus("ogc:PropertyIsLike",
+{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode("PropertyName",a,b);this.writeNode("Literal",a.regex2value(),b);return b},BBOX:function(a){var b=this.createElementNSPlus("ogc:BBOX");a.property&&this.writeNode("PropertyName",a,b);var c=this.writeNode("gml:Box",a.value,b);a.projection&&c.setAttribute("srsName",a.projection);return b}},OpenLayers.Format.Filter.v1.prototype.writers.ogc),gml:OpenLayers.Format.GML.v2.prototype.writers.gml,feature:OpenLayers.Format.GML.v2.prototype.writers.feature},
+writeSpatial:function(a,b){var c=this.createElementNSPlus("ogc:"+b);this.writeNode("PropertyName",a,c);if(a.value instanceof OpenLayers.Filter.Function)this.writeNode("Function",a.value,c);else{var d;d=a.value instanceof OpenLayers.Geometry?this.writeNode("feature:_geometry",a.value).firstChild:this.writeNode("gml:Box",a.value);a.projection&&d.setAttribute("srsName",a.projection);c.appendChild(d)}return c},CLASS_NAME:"OpenLayers.Format.Filter.v1_0_0"});OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:!1,schemaLocations:{wfs:"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(a){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[a]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[a])},readNode:function(a,b,c){return OpenLayers.Format.GML.v2.prototype.readNode.apply(this,arguments)},readers:{wfs:OpenLayers.Util.applyDefaults({WFS_Transact
ionResponse:function(a,
+b){b.insertIds=[];b.success=!1;this.readChildNodes(a,b)},InsertResult:function(a,b){var c={fids:[]};this.readChildNodes(a,c);b.insertIds=b.insertIds.concat(c.fids)},TransactionResult:function(a,b){this.readChildNodes(a,b)},Status:function(a,b){this.readChildNodes(a,b)},SUCCESS:function(a,b){b.success=!0}},OpenLayers.Format.WFST.v1.prototype.readers.wfs),gml:OpenLayers.Format.GML.v2.prototype.readers.gml,feature:OpenLayers.Format.GML.v2.prototype.readers.feature,ogc:OpenLayers.Format.Filter.v1_0_0.prototype.readers.ogc},
+writers:{wfs:OpenLayers.Util.applyDefaults({Query:function(a){a=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},a);var b=a.featurePrefix,c=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(b?b+":":"")+a.featureType}});a.srsNameInQuery&&a.srsName&&c.setAttribute("srsName",a.srsName);a.featureNS&&c.setAttribute("xmlns:"+b,a.featureNS);if(a.propertyNames)for(var b=0,d=a.propertyNames.length;b<
+d;b++)this.writeNode("ogc:PropertyName",{property:a.propertyNames[b]},c);a.filter&&(this.setFilterProperty(a.filter),this.writeNode("ogc:Filter",a.filter,c));return c}},OpenLayers.Format.WFST.v1.prototype.writers.wfs),gml:OpenLayers.Format.GML.v2.prototype.writers.gml,feature:OpenLayers.Format.GML.v2.prototype.writers.feature,ogc:OpenLayers.Format.Filter.v1_0_0.prototype.writers.ogc},CLASS_NAME:"OpenLayers.Format.WFST.v1_0_0"});OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(a){this.compare=a?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.clear()},insert:function(a){this.exists(a)&&this.remove(a);var b=a.id;this.determineZIndex(a);for(var c=-1,d=this.order.length,e;1<d-c;)e=parseInt((c+d)/2),0<this.compare(this,a,OpenLayers.Util.getElement(this.order[e]))?c=e:d=e;this.order.splice(d,
+0,b);this.indices[b]=this.getZIndex(a);return this.getNextElement(d)},remove:function(a){a=a.id;var b=OpenLayers.Util.indexOf(this.order,a);0<=b&&(this.order.splice(b,1),delete this.indices[a],this.maxZIndex=0<this.order.length?this.indices[this.order[this.order.length-1]]:0)},clear:function(){this.order=[];this.indices={};this.maxZIndex=0},exists:function(a){return null!=this.indices[a.id]},getZIndex:function(a){return a._style.graphicZIndex},determineZIndex:function(a){var b=a._style.graphicZIndex;
+null==b?(b=this.maxZIndex,a._style.graphicZIndex=b):b>this.maxZIndex&&(this.maxZIndex=b)},getNextElement:function(a){a+=1;if(a<this.order.length){var b=OpenLayers.Util.getElement(this.order[a]);void 0==b&&(b=this.getNextElement(a));return b}return null},CLASS_NAME:"OpenLayers.ElementsIndexer"});
+OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(a,b,c){b=a.getZIndex(b);var d=0;c&&(a=a.getZIndex(c),d=b-a);return d},Z_ORDER_DRAWING_ORDER:function(a,b,c){a=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(a,b,c);c&&0==a&&(a=1);return a},Z_ORDER_Y_ORDER:function(a,b,c){a=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(a,b,c);c&&0===a&&(b=c._boundsBottom-b._boundsBottom,a=0===b?1:b);return a}};
+OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,xOffset:0,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",LABEL_OUTLINE_SUFFIX:"_outline",initialize:function(a,b){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);
+this.root.appendChild(this.textRoot);this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);b&&(b.zIndexing||b.yOrdering)&&(this.indexer=new OpenLayers.ElementsIndexer(b.yOrdering))},destroy:function(){this.clear();this.xmlns=this.root=this.rendererRoot=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments)},clear:function(){var a,b=this.vectorRoot;if(b)for(;a=b.firstChild;)b.removeChild(a);if(b=this.textRoot)for(;a=b.firstChild;)b.removeChild(a);this.indexer&&
+this.indexer.clear()},setExtent:function(a,b){var c=OpenLayers.Renderer.prototype.setExtent.apply(this,arguments),d=this.getResolution();if(this.map.baseLayer&&this.map.baseLayer.wrapDateLine){var e,f=a.getWidth()/this.map.getExtent().getWidth();a=a.scale(1/f);f=this.map.getMaxExtent();f.right>a.left&&f.right<a.right?e=!0:f.left>a.left&&f.left<a.right&&(e=!1);if(e!==this.rightOfDateLine||b)c=!1,this.xOffset=!0===e?f.getWidth()/d:0;this.rightOfDateLine=e}return c},getNodeType:function(a,b){},drawGeometry:function(a,
+b,c){var d=a.CLASS_NAME,e=!0;if("OpenLayers.Geometry.Collection"==d||"OpenLayers.Geometry.MultiPoint"==d||"OpenLayers.Geometry.MultiLineString"==d||"OpenLayers.Geometry.MultiPolygon"==d){for(var d=0,f=a.components.length;d<f;d++)e=this.drawGeometry(a.components[d],b,c)&&e;return e}d=e=!1;"none"!=b.display&&(b.backgroundGraphic?this.redrawBackgroundNode(a.id,a,b,c):d=!0,e=this.redrawNode(a.id,a,b,c));!1==e&&(b=document.getElementById(a.id))&&(b._style.backgroundGraphic&&(d=!0),b.parentNode.removeChild(b));
+d&&(b=document.getElementById(a.id+this.BACKGROUND_ID_SUFFIX))&&b.parentNode.removeChild(b);return e},redrawNode:function(a,b,c,d){c=this.applyDefaultSymbolizer(c);a=this.nodeFactory(a,this.getNodeType(b,c));a._featureId=d;a._boundsBottom=b.getBounds().bottom;a._geometryClass=b.CLASS_NAME;a._style=c;b=this.drawGeometryNode(a,b,c);if(!1===b)return!1;a=b.node;this.indexer?(c=this.indexer.insert(a))?this.vectorRoot.insertBefore(a,c):this.vectorRoot.appendChild(a):a.parentNode!==this.vectorRoot&&this.vectorRoot.appendChild(a);
+this.postDraw(a);return b.complete},redrawBackgroundNode:function(a,b,c,d){c=OpenLayers.Util.extend({},c);c.externalGraphic=c.backgroundGraphic;c.graphicXOffset=c.backgroundXOffset;c.graphicYOffset=c.backgroundYOffset;c.graphicZIndex=c.backgroundGraphicZIndex;c.graphicWidth=c.backgroundWidth||c.graphicWidth;c.graphicHeight=c.backgroundHeight||c.graphicHeight;c.backgroundGraphic=null;c.backgroundXOffset=null;c.backgroundYOffset=null;c.backgroundGraphicZIndex=null;return this.redrawNode(a+this.BACKGROUND_ID_SUFFIX,
+b,c,null)},drawGeometryNode:function(a,b,c){c=c||a._style;var d={isFilled:void 0===c.fill?!0:c.fill,isStroked:void 0===c.stroke?!!c.strokeWidth:c.stroke},e;switch(b.CLASS_NAME){case "OpenLayers.Geometry.Point":!1===c.graphic&&(d.isFilled=!1,d.isStroked=!1);e=this.drawPoint(a,b);break;case "OpenLayers.Geometry.LineString":d.isFilled=!1;e=this.drawLineString(a,b);break;case "OpenLayers.Geometry.LinearRing":e=this.drawLinearRing(a,b);break;case "OpenLayers.Geometry.Polygon":e=this.drawPolygon(a,b);break;
+case "OpenLayers.Geometry.Rectangle":e=this.drawRectangle(a,b)}a._options=d;return!1!=e?{node:this.setStyle(a,c,d,b),complete:e}:!1},postDraw:function(a){},drawPoint:function(a,b){},drawLineString:function(a,b){},drawLinearRing:function(a,b){},drawPolygon:function(a,b){},drawRectangle:function(a,b){},drawCircle:function(a,b){},removeText:function(a){var b=document.getElementById(a+this.LABEL_ID_SUFFIX);b&&this.textRoot.removeChild(b);(a=document.getElementById(a+this.LABEL_OUTLINE_SUFFIX))&&this.textRoot.removeChild(a)},
+getFeatureIdFromEvent:function(a){var b=a.target,c=b&&b.correspondingUseElement;return(c?c:b||a.srcElement)._featureId},eraseGeometry:function(a,b){if("OpenLayers.Geometry.MultiPoint"==a.CLASS_NAME||"OpenLayers.Geometry.MultiLineString"==a.CLASS_NAME||"OpenLayers.Geometry.MultiPolygon"==a.CLASS_NAME||"OpenLayers.Geometry.Collection"==a.CLASS_NAME)for(var c=0,d=a.components.length;c<d;c++)this.eraseGeometry(a.components[c],b);else(c=OpenLayers.Util.getElement(a.id))&&c.parentNode&&(c.geometry&&(c.geometry.destroy(),
+c.geometry=null),c.parentNode.removeChild(c),this.indexer&&this.indexer.remove(c),c._style.backgroundGraphic&&(c=OpenLayers.Util.getElement(a.id+this.BACKGROUND_ID_SUFFIX))&&c.parentNode&&c.parentNode.removeChild(c))},nodeFactory:function(a,b){var c=OpenLayers.Util.getElement(a);c?this.nodeTypeCompare(c,b)||(c.parentNode.removeChild(c),c=this.nodeFactory(a,b)):c=this.createNode(b,a);return c},nodeTypeCompare:function(a,b){},createNode:function(a,b){},moveRoot:function(a){var b=this.root;a.root.parentNode==
+this.rendererRoot&&(b=a.root);b.parentNode.removeChild(b);a.rendererRoot.appendChild(b)},getRenderLayerId:function(){return this.root.parentNode.parentNode.id},isComplexSymbol:function(a){return"circle"!=a&&!!a},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,getParameters:function(a){a=a||window.location.href;var b=OpenLayers.Util.getParameters(a),c=a.indexOf("#");0<c&&(a="?"+a.substring(c+1,a.length),OpenLayers.Util.extend(b,OpenLayers.Util.getParameters(a)));return b},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var b=0,c=this.map.controls.length;b<c;b++){var d=this.map.controls[b];if(d!=this&&
+"OpenLayers.Control.ArgParser"==d.CLASS_NAME){d.displayProjection!=this.displayProjection&&(this.displayProjection=d.displayProjection);break}}b==this.map.controls.length&&(b=this.getParameters(),b.layers&&(this.layers=b.layers,this.map.events.register("addlayer",this,this.configureLayers),this.configureLayers()),b.lat&&b.lon&&(this.center=new OpenLayers.LonLat(parseFloat(b.lon),parseFloat(b.lat)),b.zoom&&(this.zoom=parseFloat(b.zoom)),this.map.events.register("changebaselayer",this,this.setCenter),
+this.setCenter()))},setCenter:function(){this.map.baseLayer&&(this.map.events.unregister("changebaselayer",this,this.setCenter),this.displayProjection&&this.center.transform(this.displayProjection,this.map.getProjectionObject()),this.map.setCenter(this.center,this.zoom))},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister("addlayer",this,this.configureLayers);for(var a=0,b=this.layers.length;a<b;a++){var c=this.map.layers[a],d=this.layers.charAt(a);
+"B"==d?this.map.setBaseLayer(c):"T"!=d&&"F"!=d||c.setVisibility("T"==d)}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{argParserClass:OpenLayers.Control.ArgParser,element:null,anchor:!1,base:"",displayProjection:null,initialize:function(a,b,c){null===a||"object"!=typeof a||OpenLayers.Util.isElement(a)?(OpenLayers.Control.prototype.initialize.apply(this,[c]),this.element=OpenLayers.Util.getElement(a),this.base=b||document.location.href):(this.base=document.location.href,OpenLayers.Control.prototype.initialize.apply(this,[a]),null!=this.element&&(this.element=
+OpenLayers.Util.getElement(this.element)))},destroy:function(){this.element&&this.element.parentNode==this.div&&(this.div.removeChild(this.element),this.element=null);this.map&&this.map.events.unregister("moveend",this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments)},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var b=0,c=this.map.controls.length;b<c;b++){var d=this.map.controls[b];if(d.CLASS_NAME==this.argParserClass.CLASS_NAME){d.displayProjection!=
+this.displayProjection&&(this.displayProjection=d.displayProjection);break}}b==this.map.controls.length&&this.map.addControl(new this.argParserClass({displayProjection:this.displayProjection}))},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.element||this.anchor||(this.element=document.createElement("a"),this.element.innerHTML=OpenLayers.i18n("Permalink"),this.element.href="",this.div.appendChild(this.element));this.map.events.on({moveend:this.updateLink,changelayer:this.updateLink,
+changebaselayer:this.updateLink,scope:this});this.updateLink();return this.div},updateLink:function(){var a=this.anchor?"#":"?",b=this.base,c=null;-1!=b.indexOf("#")&&!1==this.anchor&&(c=b.substring(b.indexOf("#"),b.length));-1!=b.indexOf(a)&&(b=b.substring(0,b.indexOf(a)));b=b.split("#")[0]+a+OpenLayers.Util.getParameterString(this.createParams());c&&(b+=c);this.anchor&&!this.element?window.location.href=b:this.element.href=b},createParams:function(a,b,c){a=a||this.map.getCenter();var d=OpenLayers.Util.getParameters(this.base);
+if(a)for(d.zoom=b||this.map.getZoom(),b=a.lat,a=a.lon,this.displayProjection&&(b=OpenLayers.Projection.transform({x:a,y:b},this.map.getProjectionObject(),this.displayProjection),a=b.x,b=b.y),d.lat=Math.round(1E5*b)/1E5,d.lon=Math.round(1E5*a)/1E5,c=c||this.map.layers,d.layers="",a=0,b=c.length;a<b;a++){var e=c[a];d.layers=e.isBaseLayer?d.layers+(e==this.map.baseLayer?"B":"0"):d.layers+(e.getVisibility()?"T":"F")}return d},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:!0,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(a,b,c){var d=[];d.push(a,b,{},c);OpenLayers.Layer.Grid.prototype.initialize.apply(this,d)},clone:function(a){null==a&&(a=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){a=this.adjustBounds(a);var b=this.getServerResolution()
+c=Math.round((a.left-this.tileOrigin.lon)/(b*this.tileSize.w));a=Math.round((a.bottom-this.tileOrigin.lat)/(b*this.tileSize.h));b=this.getServerZoom();c=this.serviceVersion+"/"+this.layername+"/"+b+"/"+c+"/"+a+"."+this.type;a=this.url;OpenLayers.Util.isArray(a)&&(a=this.selectUrl(c,a));return a+c},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.tileOrigin||(this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom))},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Format.WCSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",CLASS_NAME:"OpenLayers.Format.WCSCapabilities"});OpenLayers.Format.WCSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:/^\s*|\s*$/g,splitSpace:/\s+/},defaultPrefix:"wcs",read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,
b);return b},CLASS_NAME:"OpenLayers.Format.WCSCapabilities.v1"});OpenLayers.Format.WCSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.WCSCapabilities.v1,{namespaces:{wcs:"http://www.opengis.net/wcs",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",ows:"http://www.opengis.net/ows"},errorProperty:"service",readers:{wcs:{WCS_Capabilities:function(a,b){this.readChildNodes(a,b)},Service:function(a,b){b.service={};this.readChildNodes(a,b.service)},name:function(a,b){b.name=this.getChildValue(a)},label:function(a,b){b.label=
+this.getChildValue(a)},keywords:function(a,b){b.keywords=[];this.readChildNodes(a,b.keywords)},keyword:function(a,b){b.push(this.getChildValue(a))},responsibleParty:function(a,b){b.responsibleParty={};this.readChildNodes(a,b.responsibleParty)},individualName:function(a,b){b.individualName=this.getChildValue(a)},organisationName:function(a,b){b.organisationName=this.getChildValue(a)},positionName:function(a,b){b.positionName=this.getChildValue(a)},contactInfo:function(a,b){b.contactInfo={};this.readChildNodes(a,
+b.contactInfo)},phone:function(a,b){b.phone={};this.readChildNodes(a,b.phone)},voice:function(a,b){b.voice=this.getChildValue(a)},facsimile:function(a,b){b.facsimile=this.getChildValue(a)},address:function(a,b){b.address={};this.readChildNodes(a,b.address)},deliveryPoint:function(a,b){b.deliveryPoint=this.getChildValue(a)},city:function(a,b){b.city=this.getChildValue(a)},postalCode:function(a,b){b.postalCode=this.getChildValue(a)},country:function(a,b){b.country=this.getChildValue(a)},electronicMailAddress:function(a,
+b){b.electronicMailAddress=this.getChildValue(a)},fees:function(a,b){b.fees=this.getChildValue(a)},accessConstraints:function(a,b){b.accessConstraints=this.getChildValue(a)},ContentMetadata:function(a,b){b.contentMetadata=[];this.readChildNodes(a,b.contentMetadata)},CoverageOfferingBrief:function(a,b){var c={};this.readChildNodes(a,c);b.push(c)},name:function(a,b){b.name=this.getChildValue(a)},label:function(a,b){b.label=this.getChildValue(a)},lonLatEnvelope:function(a,b){var c=this.getElementsByTagNameNS(a,
+"http://www.opengis.net/gml","pos");if(2==c.length){var d={},e={};OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[c[0],d]);OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[c[1],e]);b.lonLatEnvelope={};b.lonLatEnvelope.srsName=a.getAttribute("srsName");b.lonLatEnvelope.min=d.points[0];b.lonLatEnvelope.max=e.points[0]}}}},CLASS_NAME:"OpenLayers.Format.WCSCapabilities.v1_0_0"});OpenLayers.Strategy.Fixed=OpenLayers.Class(OpenLayers.Strategy,{preload:!1,activate:function(){var a=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(a)if(this.layer.events.on({refresh:this.load,scope:this}),!0==this.layer.visibility||this.preload)this.load();else this.layer.events.on({visibilitychanged:this.load,scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&this.layer.events.un({refresh:this.load,visibilitychanged:this.load,
+scope:this});return a},load:function(a){var b=this.layer;b.events.triggerEvent("loadstart",{filter:b.filter});b.protocol.read(OpenLayers.Util.applyDefaults({callback:this.merge,filter:b.filter,scope:this},a));b.events.un({visibilitychanged:this.load,scope:this})},merge:function(a){var b=this.layer;b.destroyFeatures();var c=a.features;if(c&&0<c.length){var d=b.projection,e=b.map.getProjectionObject();if(!e.equals(d))for(var f,g=0,h=c.length;g<h;++g)(f=c[g].geometry)&&f.transform(d,e);b.addFeatures(c)}b.events.triggerEvent("loadend",
+{response:a})},CLASS_NAME:"OpenLayers.Strategy.Fixed"});OpenLayers.Control.Zoom=OpenLayers.Class(OpenLayers.Control,{zoomInText:"+",zoomInId:"olZoomInLink",zoomOutText:"\u2212",zoomOutId:"olZoomOutLink",draw:function(){var a=OpenLayers.Control.prototype.draw.apply(this),b=this.getOrCreateLinks(a),c=b.zoomIn,b=b.zoomOut,d=this.map.events;b.parentNode!==a&&(d=this.events,d.attachToElement(b.parentNode));d.register("buttonclick",this,this.onZoomClick);this.zoomInLink=c;this.zoomOutLink=b;return a},getOrCreateLinks:function(a){var b=document.getElementById(this.zoomInId),
+c=document.getElementById(this.zoomOutId);b||(b=document.createElement("a"),b.href="#zoomIn",b.appendChild(document.createTextNode(this.zoomInText)),b.className="olControlZoomIn",a.appendChild(b));OpenLayers.Element.addClass(b,"olButton");c||(c=document.createElement("a"),c.href="#zoomOut",c.appendChild(document.createTextNode(this.zoomOutText)),c.className="olControlZoomOut",a.appendChild(c));OpenLayers.Element.addClass(c,"olButton");return{zoomIn:b,zoomOut:c}},onZoomClick:function(a){a=a.buttonElement;
+a===this.zoomInLink?this.map.zoomIn():a===this.zoomOutLink&&this.map.zoomOut()},destroy:function(){this.map&&this.map.events.unregister("buttonclick",this,this.onZoomClick);delete this.zoomInLink;delete this.zoomOutLink;OpenLayers.Control.prototype.destroy.apply(this)},CLASS_NAME:"OpenLayers.Control.Zoom"});OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,styleFrom:null,addNodes:function(a,b){if(2>a.length)throw Error("At least two point features have to be added to create a line from");for(var c=Array(a.length-1),d,e,f,g=0,h=a.length;g<h;g++){d=a[g];f=d.geometry;if(!f)f=d.lonlat,f=new OpenLayers.Geometry.Point(f.lon,f.lat);else if("OpenLayers.Geometry.Point"!=f.CLASS_NAME)throw new TypeError("Only features with point geometries are supported.");if(0<g){d=null!=this.dataFrom?
+a[g+this.dataFrom].data||a[g+this.dataFrom].attributes:null;var k=null!=this.styleFrom?a[g+this.styleFrom].style:null;e=new OpenLayers.Geometry.LineString([e,f]);c[g-1]=new OpenLayers.Feature.Vector(e,d,k)}e=f}this.addFeatures(c,b)},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.SOURCE_NODE=-1;OpenLayers.Layer.PointTrack.TARGET_NODE=0;OpenLayers.Layer.PointTrack.dataFrom={SOURCE_NODE:-1,TARGET_NODE:0};OpenLayers.Protocol.WFS=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Protocol.WFS.DEFAULTS);var b=OpenLayers.Protocol.WFS["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported WFS version: "+a.version;return new b(a)};
+OpenLayers.Protocol.WFS.fromWMSLayer=function(a,b){var c,d;c=a.params.LAYERS;c=(OpenLayers.Util.isArray(c)?c[0]:c).split(":");1<c.length&&(d=c[0]);c=c.pop();d={url:a.url,featureType:c,featurePrefix:d,srsName:a.projection&&a.projection.getCode()||a.map&&a.map.getProjectionObject().getCode(),version:"1.1.0"};return new OpenLayers.Protocol.WFS(OpenLayers.Util.applyDefaults(b,d))};OpenLayers.Protocol.WFS.DEFAULTS={version:"1.0.0"};OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:!1,markers:null,drawn:!1,initialize:function(a,b){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[]},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},setOpacity:function(a){if(a!=this.opacity){this.opacity=a;a=0;for(var b=this.markers.length;a<b;a++)this.markers[a].setOpacity(this.opacity)}},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,
+arguments);if(b||!this.drawn){for(var d=0,e=this.markers.length;d<e;d++)this.drawMarker(this.markers[d]);this.drawn=!0}},addMarker:function(a){this.markers.push(a);1>this.opacity&&a.setOpacity(this.opacity);this.map&&this.map.getExtent()&&(a.map=this.map,this.drawMarker(a))},removeMarker:function(a){this.markers&&this.markers.length&&(OpenLayers.Util.removeItem(this.markers,a),a.erase())},clearMarkers:function(){if(null!=this.markers)for(;0<this.markers.length;)this.removeMarker(this.markers[0])},
+drawMarker:function(a){var b=this.map.getLayerPxFromLonLat(a.lonlat);null==b?a.display(!1):a.isDrawn()?a.icon&&a.icon.moveTo(b):(a=a.draw(b),this.div.appendChild(a))},getDataExtent:function(){var a=null;if(this.markers&&0<this.markers.length)for(var a=new OpenLayers.Bounds,b=0,c=this.markers.length;b<c;b++)a.extend(this.markers[b].lonlat);return a},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Control.Pan=OpenLayers.Class(OpenLayers.Control.Button,{slideFactor:50,slideRatio:null,direction:null,initialize:function(a,b){this.direction=a;this.CLASS_NAME+=this.direction;OpenLayers.Control.prototype.initialize.apply(this,[b])},trigger:function(){if(this.map){var a=OpenLayers.Function.bind(function(a){return this.slideRatio?this.map.getSize()[a]*this.slideRatio:this.slideFactor},this);switch(this.direction){case OpenLayers.Control.Pan.NORTH:this.map.pan(0,-a("h"));break;case OpenLayers.Control.Pan.SOUTH:this.map.pan(0,
+a("h"));break;case OpenLayers.Control.Pan.WEST:this.map.pan(-a("w"),0);break;case OpenLayers.Control.Pan.EAST:this.map.pan(a("w"),0)}}},CLASS_NAME:"OpenLayers.Control.Pan"});OpenLayers.Control.Pan.NORTH="North";OpenLayers.Control.Pan.SOUTH="South";OpenLayers.Control.Pan.EAST="East";OpenLayers.Control.Pan.WEST="West";OpenLayers.Format.CSWGetDomain=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Format.CSWGetDomain.DEFAULTS);var b=OpenLayers.Format.CSWGetDomain["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSWGetDomain version: "+a.version;return new b(a)};OpenLayers.Format.CSWGetDomain.DEFAULTS={version:"2.0.2"};OpenLayers.Format.CSWGetDomain.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-
discovery.xsd",PropertyName:null,ParameterName:null,read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==
+a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,b);return b},readers:{csw:{GetDomainResponse:function(a,b){this.readChildNodes(a,b)},DomainValues:function(a,b){OpenLayers.Util.isArray(b.DomainValues)||(b.DomainValues=[]);for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;this.readChildNodes(a,d);b.DomainValues.push(d)},PropertyName:function(a,b){b.PropertyName=this.getChildValue(a)},ParameterName:function(a,b){b.ParameterName=this.getChildValue(a)},ListOfValues:function(a,
+b){OpenLayers.Util.isArray(b.ListOfValues)||(b.ListOfValues=[]);this.readChildNodes(a,b.ListOfValues)},Value:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.push({Value:d})},ConceptualScheme:function(a,b){b.ConceptualScheme={};this.readChildNodes(a,b.ConceptualScheme)},Name:function(a,b){b.Name=this.getChildValue(a)},Document:function(a,b){b.Document=this.getChildValue(a)},Authority:function(a,b){b.Authority=this.getChildValue(a)},
+RangeOfValues:function(a,b){b.RangeOfValues={};this.readChildNodes(a,b.RangeOfValues)},MinValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MinValue=d},MaxValue:function(a,b){for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]=c[e].nodeValue;d.value=this.getChildValue(a);b.MaxValue=d}}},write:function(a){a=this.writeNode("csw:GetDomain",a);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{csw:{GetDomain:function(a){var b=
+this.createElementNSPlus("csw:GetDomain",{attributes:{service:"CSW",version:this.version}});a.PropertyName||this.PropertyName?this.writeNode("csw:PropertyName",a.PropertyName||this.PropertyName,b):(a.ParameterName||this.ParameterName)&&this.writeNode("csw:ParameterName",a.ParameterName||this.ParameterName,b);this.readChildNodes(b,a);return b},PropertyName:function(a){return this.createElementNSPlus("csw:PropertyName",{value:a})},ParameterName:function(a){return this.createElementNSPlus("csw:ParameterName",
+{value:a})}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{read:function(a){return(new OpenLayers.Format.ArcXML).read(a).features.feature}});OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{DEFAULTS:{tolerance:10,node:!0,edge:!0,vertex:!0},greedy:!0,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.options=a||{};this.options.layer&&this.setLayer(this.options.layer);a=OpenLayers.Util.extend({},this.options.defaults);this.defaults=OpenLayers.Util.applyDefaults(a,this.DEFAULTS);this.setTargets(this.options.targets);
+0===this.targets.length&&this.layer&&this.addTargetLayer(this.layer);this.geoToleranceCache={}},setLayer:function(a){this.active?(this.deactivate(),this.layer=a,this.activate()):this.layer=a},setTargets:function(a){this.targets=[];if(a&&a.length)for(var b,c=0,d=a.length;c<d;++c)b=a[c],b instanceof OpenLayers.Layer.Vector?this.addTargetLayer(b):this.addTarget(b)},addTargetLayer:function(a){this.addTarget({layer:a})},addTarget:function(a){a=OpenLayers.Util.applyDefaults(a,this.defaults);a.nodeTolerance=
+a.nodeTolerance||a.tolerance;a.vertexTolerance=a.vertexTolerance||a.tolerance;a.edgeTolerance=a.edgeTolerance||a.tolerance;this.targets.push(a)},removeTargetLayer:function(a){for(var b,c=this.targets.length-1;0<=c;--c)b=this.targets[c],b.layer===a&&this.removeTarget(b)},removeTarget:function(a){return OpenLayers.Util.removeItem(this.targets,a)},activate:function(){var a=OpenLayers.Control.prototype.activate.call(this);if(a&&this.layer&&this.layer.events)this.layer.events.on({sketchstarted:this.onSketchModified,
+sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});return a},deactivate:function(){var a=OpenLayers.Control.prototype.deactivate.call(this);a&&this.layer&&this.layer.events&&this.layer.events.un({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});this.point=this.feature=null;return a},onSketchModified:function(a){this.feature=a.feature;this.considerSnapping(a.vertex,a.vertex)},onVertexModified:function(a){this.feature=
+a.feature;var b=this.layer.map.getLonLatFromViewPortPx(a.pixel);this.considerSnapping(a.vertex,new OpenLayers.Geometry.Point(b.lon,b.lat))},considerSnapping:function(a,b){for(var c={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY,x:null,y:null},d=!1,e,f,g=0,h=this.targets.length;g<h;++g)if(f=this.targets[g],e=this.testTarget(f,b))if(this.greedy){c=e;c.target=f;d=!0;break}else if(e.rank<c.rank||e.rank===c.rank&&e.dist<c.dist)c=e,c.target=f,d=!0;d&&(!1!==this.events.triggerEvent("beforesnap",
+{point:a,x:c.x,y:c.y,distance:c.dist,layer:c.target.layer,snapType:this.precedence[c.rank]})?(a.x=c.x,a.y=c.y,this.point=a,this.events.triggerEvent("snap",{point:a,snapType:this.precedence[c.rank],layer:c.target.layer,distance:c.dist})):d=!1);this.point&&!d&&(a.x=b.x,a.y=b.y,this.point=null,this.events.triggerEvent("unsnap",{point:a}))},testTarget:function(a,b){var c=this.layer.map.getResolution();if("minResolution"in a&&c<a.minResolution||"maxResolution"in a&&c>=a.maxResolution)return null;for(var c=
+{node:this.getGeoTolerance(a.nodeTolerance,c),vertex:this.getGeoTolerance(a.vertexTolerance,c),edge:this.getGeoTolerance(a.edgeTolerance,c)},d=Math.max(c.node,c.vertex,c.edge),e={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY},f=!1,g=a.layer.features,h,k,l,m,n,p,q=this.precedence.length,r=new OpenLayers.LonLat(b.x,b.y),s=0,t=g.length;s<t;++s)if(h=g[s],h!==this.feature&&(!h._sketch&&h.state!==OpenLayers.State.DELETE&&(!a.filter||a.filter.evaluate(h)))&&h.atPoint(r,d,d))for(var u=0,v=Math.min(e.rank+
+1,q);u<v;++u)if(k=this.precedence[u],a[k])if("edge"===k){if(l=h.geometry.distanceTo(b,{details:!0}),n=l.distance,n<=c[k]&&n<e.dist){e={rank:u,dist:n,x:l.x0,y:l.y0};f=!0;break}}else{l=h.geometry.getVertices("node"===k);p=!1;for(var w=0,x=l.length;w<x;++w)m=l[w],n=m.distanceTo(b),n<=c[k]&&(u<e.rank||u===e.rank&&n<e.dist)&&(e={rank:u,dist:n,x:m.x,y:m.y},p=f=!0);if(p)break}return f?e:null},getGeoTolerance:function(a,b){b!==this.resolution&&(this.resolution=b,this.geoToleranceCache={});var c=this.geoToleranceCache[a];
+void 0===c&&(c=a*b,this.geoToleranceCache[a]=c);return c},destroy:function(){this.active&&this.deactivate();delete this.layer;delete this.targets;OpenLayers.Control.prototype.destroy.call(this)},CLASS_NAME:"OpenLayers.Control.Snapping"});OpenLayers.Format.OWSCommon.v1_1_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.1",xlink:"http://www.w3.org/1999/xlink"},readers:{ows:OpenLayers.Util.applyDefaults({ExceptionReport:function(a,b){b.exceptionReport={version:a.getAttribute("version"),language:a.getAttribute("xml:lang"),exceptions:[]};this.readChildNodes(a,b.exceptionReport)},AllowedValues:function(a,b){b.allowedValues={};this.readChildNodes(a,b.allowedValues)},AnyValue:function(a,b){b.anyValue=
+!0},DataType:function(a,b){b.dataType=this.getChildValue(a)},Range:function(a,b){b.range={};this.readChildNodes(a,b.range)},MinimumValue:function(a,b){b.minValue=this.getChildValue(a)},MaximumValue:function(a,b){b.maxValue=this.getChildValue(a)},Identifier:function(a,b){b.identifier=this.getChildValue(a)},SupportedCRS:function(a,b){b.supportedCRS=this.getChildValue(a)}},OpenLayers.Format.OWSCommon.v1.prototype.readers.ows)},writers:{ows:OpenLayers.Util.applyDefaults({Range:function(a){var b=this.createElementNSPlus("ows:Range",
+{attributes:{"ows:rangeClosure":a.closure}});this.writeNode("ows:MinimumValue",a.minValue,b);this.writeNode("ows:MaximumValue",a.maxValue,b);return b},MinimumValue:function(a){return this.createElementNSPlus("ows:MinimumValue",{value:a})},MaximumValue:function(a){return this.createElementNSPlus("ows:MaximumValue",{value:a})},Value:function(a){return this.createElementNSPlus("ows:Value",{value:a})}},OpenLayers.Format.OWSCommon.v1.prototype.writers.ows)},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.WCSGetCoverage=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wcs:"http://www.opengis.net/wcs/1.1",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},VERSION:"1.1.2",schemaLocation:"http://www.opengis.net/wcs/1.1 http://schemas.opengis.net/wcs/1.1/wcsGetCoverage.xsd",write:function(a){a=this.writ
eNode("wcs:GetCoverage",
+a);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},writers:{wcs:{GetCoverage:function(a){var b=this.createElementNSPlus("wcs:GetCoverage",{attributes:{version:a.version||this.VERSION,service:"WCS"}});this.writeNode("ows:Identifier",a.identifier,b);this.writeNode("wcs:DomainSubset",a.domainSubset,b);this.writeNode("wcs:Output",a.output,b);return b},DomainSubset:function(a){var b=this.createElementNSPlus("wcs:DomainSubset",
+{});this.writeNode("ows:BoundingBox",a.boundingBox,b);a.temporalSubset&&this.writeNode("wcs:TemporalSubset",a.temporalSubset,b);return b},TemporalSubset:function(a){for(var b=this.createElementNSPlus("wcs:TemporalSubset",{}),c=0,d=a.timePeriods.length;c<d;++c)this.writeNode("wcs:TimePeriod",a.timePeriods[c],b);return b},TimePeriod:function(a){var b=this.createElementNSPlus("wcs:TimePeriod",{});this.writeNode("wcs:BeginPosition",a.begin,b);this.writeNode("wcs:EndPosition",a.end,b);a.resolution&&this.writeNode("wcs:TimeResolution",
+a.resolution,b);return b},BeginPosition:function(a){return this.createElementNSPlus("wcs:BeginPosition",{value:a})},EndPosition:function(a){return this.createElementNSPlus("wcs:EndPosition",{value:a})},TimeResolution:function(a){return this.createElementNSPlus("wcs:TimeResolution",{value:a})},Output:function(a){var b=this.createElementNSPlus("wcs:Output",{attributes:{format:a.format,store:a.store}});a.gridCRS&&this.writeNode("wcs:GridCRS",a.gridCRS,b);return b},GridCRS:function(a){var b=this.createElementNSPlus("wcs:GridCRS",
+{});this.writeNode("wcs:GridBaseCRS",a.baseCRS,b);a.type&&this.writeNode("wcs:GridType",a.type,b);a.origin&&this.writeNode("wcs:GridOrigin",a.origin,b);this.writeNode("wcs:GridOffsets",a.offsets,b);a.CS&&this.writeNode("wcs:GridCS",a.CS,b);return b},GridBaseCRS:function(a){return this.createElementNSPlus("wcs:GridBaseCRS",{value:a})},GridOrigin:function(a){return this.createElementNSPlus("wcs:GridOrigin",{value:a})},GridType:function(a){return this.createElementNSPlus("wcs:GridType",{value:a})},GridOffsets:function(a){return this.createElementNSPlus("wcs:GridOffsets",
+{value:a})},GridCS:function(a){return this.createElementNSPlus("wcs:GridCS",{value:a})}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},CLASS_NAME:"OpenLayers.Format.WCSGetCoverage"});OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{kml:"http://www.opengis.net/kml/2.2",gx:"http://www.google.com/kml/ext/2.2"},kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date,extractAttributes:!0,kvpAttributes:!1,extractStyles:!1,extractTracks:!1,trackAttributes:null,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(a){this.regExes=
+{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g,kmlColor:/(\w{2})(\w{2})(\w{2})(\w{2})/,kmlIconPalette:/root:\/\/icons\/palette-(\d+)(\.\w+)/,straightBracket:/\$\[(.*?)\]/g};this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){this.features=[];this.styles={};this.fetched={};return this.parseData(a,{depth:0,styleBaseUrl:this.styleBaseUrl})},parseData:function(a,b){"string"==typeof a&&
+(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));for(var c=["Link","NetworkLink","Style","StyleMap","Placemark"],d=0,e=c.length;d<e;++d){var f=c[d],g=this.getElementsByTagNameNS(a,"*",f);if(0!=g.length)switch(f.toLowerCase()){case "link":case "networklink":this.parseLinks(g,b);break;case "style":this.extractStyles&&this.parseStyles(g,b);break;case "stylemap":this.extractStyles&&this.parseStyleMaps(g,b);break;case "placemark":this.parseFeatures(g,b)}}return this.features},parseLinks:function(a,
+b){if(b.depth>=this.maxDepth)return!1;var c=OpenLayers.Util.extend({},b);c.depth++;for(var d=0,e=a.length;d<e;d++){var f=this.parseProperty(a[d],"*","href");f&&!this.fetched[f]&&(this.fetched[f]=!0,(f=this.fetchLink(f))&&this.parseData(f,c))}},fetchLink:function(a){if(a=OpenLayers.Request.GET({url:a,async:!1}))return a.responseText},parseStyles:function(a,b){for(var c=0,d=a.length;c<d;c++){var e=this.parseStyle(a[c]);e&&(this.styles[(b.styleBaseUrl||"")+"#"+e.id]=e)}},parseKmlColor:function(a){var b=
+null;a&&(a=a.match(this.regExes.kmlColor))&&(b={color:"#"+a[4]+a[3]+a[2],opacity:parseInt(a[1],16)/255});return b},parseStyle:function(a){for(var b={},c=["LineStyle","PolyStyle","IconStyle","BalloonStyle","LabelStyle"],d,e,f=0,g=c.length;f<g;++f)if(d=c[f],e=this.getElementsByTagNameNS(a,"*",d)[0])switch(d.toLowerCase()){case "linestyle":d=this.parseProperty(e,"*","color");if(d=this.parseKmlColor(d))b.strokeColor=d.color,b.strokeOpacity=d.opacity;(d=this.parseProperty(e,"*","width"))&&(b.strokeWidth=
+d);break;case "polystyle":d=this.parseProperty(e,"*","color");if(d=this.parseKmlColor(d))b.fillOpacity=d.opacity,b.fillColor=d.color;"0"==this.parseProperty(e,"*","fill")&&(b.fillColor="none");"0"==this.parseProperty(e,"*","outline")&&(b.strokeWidth="0");break;case "iconstyle":var h=parseFloat(this.parseProperty(e,"*","scale")||1);d=32*h;var k=32*h,l=this.getElementsByTagNameNS(e,"*","Icon")[0];if(l){var m=this.parseProperty(l,"*","href");if(m){var n=this.parseProperty(l,"*","w"),p=this.parseProperty(l,
+"*","h");!OpenLayers.String.startsWith(m,"http://maps.google.com/mapfiles/kml")||(n||p)||(p=n=64,h/=2);n=n||p;p=p||n;n&&(d=parseInt(n)*h);p&&(k=parseInt(p)*h);if(p=m.match(this.regExes.kmlIconPalette))n=p[1],p=p[2],m=this.parseProperty(l,"*","x"),l=this.parseProperty(l,"*","y"),m="http://maps.google.com/mapfiles/kml/pal"+n+"/icon"+(8*(l?7-l/32:7)+(m?m/32:0))+p;b.graphicOpacity=1;b.externalGraphic=m}}if(e=this.getElementsByTagNameNS(e,"*","hotSpot")[0])m=parseFloat(e.getAttribute("x")),l=parseFloat(e.getAttribute("y")),
+n=e.getAttribute("xunits"),"pixels"==n?b.graphicXOffset=-m*h:"insetPixels"==n?b.graphicXOffset=-d+m*h:"fraction"==n&&(b.graphicXOffset=-d*m),e=e.getAttribute("yunits"),"pixels"==e?b.graphicYOffset=-k+l*h+1:"insetPixels"==e?b.graphicYOffset=-(l*h)+1:"fraction"==e&&(b.graphicYOffset=-k*(1-l)+1);b.graphicWidth=d;b.graphicHeight=k;break;case "balloonstyle":(e=OpenLayers.Util.getXmlNodeValue(e))&&(b.balloonStyle=e.replace(this.regExes.straightBracket,"${$1}"));break;case "labelstyle":if(d=this.parseProperty(e,
+"*","color"),d=this.parseKmlColor(d))b.fontColor=d.color,b.fontOpacity=d.opacity}!b.strokeColor&&b.fillColor&&(b.strokeColor=b.fillColor);(a=a.getAttribute("id"))&&b&&(b.id=a);return b},parseStyleMaps:function(a,b){for(var c=0,d=a.length;c<d;c++)for(var e=a[c],f=this.getElementsByTagNameNS(e,"*","Pair"),e=e.getAttribute("id"),g=0,h=f.length;g<h;g++){var k=f[g],l=this.parseProperty(k,"*","key");(k=this.parseProperty(k,"*","styleUrl"))&&"normal"==l&&(this.styles[(b.styleBaseUrl||"")+"#"+e]=this.styles[(b.styleBaseUrl||
+"")+k])}},parseFeatures:function(a,b){for(var c=[],d=0,e=a.length;d<e;d++){var f=a[d],g=this.parseFeature.apply(this,[f]);if(g){this.extractStyles&&(g.attributes&&g.attributes.styleUrl)&&(g.style=this.getStyle(g.attributes.styleUrl,b));if(this.extractStyles){var h=this.getElementsByTagNameNS(f,"*","Style")[0];h&&(h=this.parseStyle(h))&&(g.style=OpenLayers.Util.extend(g.style,h))}this.extractTracks?(f=this.getElementsByTagNameNS(f,this.namespaces.gx,"Track"))&&0<f.length&&(g={features:[],feature:g},
+this.readNode(f[0],g),0<g.features.length&&c.push.apply(c,g.features)):c.push(g)}else throw"Bad Placemark: "+d;}this.features=this.features.concat(c)},readers:{kml:{when:function(a,b){b.whens.push(OpenLayers.Date.parse(this.getChildValue(a)))},_trackPointAttribute:function(a,b){var c=a.nodeName.split(":").pop();b.attributes[c].push(this.getChildValue(a))}},gx:{Track:function(a,b){var c={whens:[],points:[],angles:[]};if(this.trackAttributes){var d;c.attributes={};for(var e=0,f=this.trackAttributes.length;e<
+f;++e)d=this.trackAttributes[e],c.attributes[d]=[],d in this.readers.kml||(this.readers.kml[d]=this.readers.kml._trackPointAttribute)}this.readChildNodes(a,c);if(c.whens.length!==c.points.length)throw Error("gx:Track with unequal number of when ("+c.whens.length+") and gx:coord ("+c.points.length+") elements.");var g=0<c.angles.length;if(g&&c.whens.length!==c.angles.length)throw Error("gx:Track with unequal number of when ("+c.whens.length+") and gx:angles ("+c.angles.length+") elements.");for(var h,
+e=0,f=c.whens.length;e<f;++e){h=b.feature.clone();h.fid=b.feature.fid||b.feature.id;d=c.points[e];h.geometry=d;"z"in d&&(h.attributes.altitude=d.z);this.internalProjection&&this.externalProjection&&h.geometry.transform(this.externalProjection,this.internalProjection);if(this.trackAttributes)for(var k=0,l=this.trackAttributes.length;k<l;++k)d=this.trackAttributes[k],h.attributes[d]=c.attributes[d][e];h.attributes.when=c.whens[e];h.attributes.trackId=b.feature.id;g&&(d=c.angles[e],h.attributes.heading=
+parseFloat(d[0]),h.attributes.tilt=parseFloat(d[1]),h.attributes.roll=parseFloat(d[2]));b.features.push(h)}},coord:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(/\s+/),d=new OpenLayers.Geometry.Point(c[0],c[1]);2<c.length&&(d.z=parseFloat(c[2]));b.points.push(d)},angles:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"").split(/\s+/);b.angles.push(c)}}},parseFeature:function(a){for(var b=["MultiGeometry","Polygon","LineString","Point"],
+c,d,e,f=0,g=b.length;f<g;++f)if(c=b[f],this.internalns=a.namespaceURI?a.namespaceURI:this.kmlns,d=this.getElementsByTagNameNS(a,this.internalns,c),0<d.length){if(b=this.parseGeometry[c.toLowerCase()])e=b.apply(this,[d[0]]),this.internalProjection&&this.externalProjection&&e.transform(this.externalProjection,this.internalProjection);else throw new TypeError("Unsupported geometry type: "+c);break}var h;this.extractAttributes&&(h=this.parseAttributes(a));c=new OpenLayers.Feature.Vector(e,h);a=a.getAttribute("id")||
+a.getAttribute("name");null!=a&&(c.fid=a);return c},getStyle:function(a,b){var c=OpenLayers.Util.removeTail(a),d=OpenLayers.Util.extend({},b);d.depth++;d.styleBaseUrl=c;!this.styles[a]&&!OpenLayers.String.startsWith(a,"#")&&d.depth<=this.maxDepth&&!this.fetched[c]&&(c=this.fetchLink(c))&&this.parseData(c,d);return OpenLayers.Util.extend({},this.styles[a])},parseGeometry:{point:function(a){var b=this.getElementsByTagNameNS(a,this.internalns,"coordinates");a=[];if(0<b.length){var c=b[0].firstChild.nodeValue,
+c=c.replace(this.regExes.removeSpace,"");a=c.split(",")}b=null;if(1<a.length)2==a.length&&(a[2]=null),b=new OpenLayers.Geometry.Point(a[0],a[1],a[2]);else throw"Bad coordinate string: "+c;return b},linestring:function(a,b){var c=this.getElementsByTagNameNS(a,this.internalns,"coordinates"),d=null;if(0<c.length){for(var c=this.getChildValue(c[0]),c=c.replace(this.regExes.trimSpace,""),c=c.replace(this.regExes.trimComma,","),d=c.split(this.regExes.splitSpace),e=d.length,f=Array(e),g,h,k=0;k<e;++k)if(g=
+d[k].split(","),h=g.length,1<h)2==g.length&&(g[2]=null),f[k]=new OpenLayers.Geometry.Point(g[0],g[1],g[2]);else throw"Bad LineString point coordinates: "+d[k];if(e)d=b?new OpenLayers.Geometry.LinearRing(f):new OpenLayers.Geometry.LineString(f);else throw"Bad LineString coordinates: "+c;}return d},polygon:function(a){a=this.getElementsByTagNameNS(a,this.internalns,"LinearRing");var b=a.length,c=Array(b);if(0<b)for(var d=0,e=a.length;d<e;++d)if(b=this.parseGeometry.linestring.apply(this,[a[d],!0]))c[d]=
+b;else throw"Bad LinearRing geometry: "+d;return new OpenLayers.Geometry.Polygon(c)},multigeometry:function(a){for(var b,c=[],d=a.childNodes,e=0,f=d.length;e<f;++e)a=d[e],1==a.nodeType&&(b=a.prefix?a.nodeName.split(":")[1]:a.nodeName,(b=this.parseGeometry[b.toLowerCase()])&&c.push(b.apply(this,[a])));return new OpenLayers.Geometry.Collection(c)}},parseAttributes:function(a){var b={},c=a.getElementsByTagName("ExtendedData");c.length&&(b=this.parseExtendedData(c[0]));var d,e,f;a=a.childNodes;for(var c=
+0,g=a.length;c<g;++c)if(d=a[c],1==d.nodeType&&(e=d.childNodes,1<=e.length&&3>=e.length)){switch(e.length){case 1:f=e[0];break;case 2:f=e[0];e=e[1];f=3==f.nodeType||4==f.nodeType?f:e;break;default:f=e[1]}if(3==f.nodeType||4==f.nodeType)if(d=d.prefix?d.nodeName.split(":")[1]:d.nodeName,f=OpenLayers.Util.getXmlNodeValue(f))f=f.replace(this.regExes.trimSpace,""),b[d]=f}return b},parseExtendedData:function(a){var b={},c,d,e,f,g=a.getElementsByTagName("Data");c=0;for(d=g.length;c<d;c++){e=g[c];f=e.getAttribute("name");
+var h={},k=e.getElementsByTagName("value");k.length&&(h.value=this.getChildValue(k[0]));this.kvpAttributes?b[f]=h.value:(e=e.getElementsByTagName("displayName"),e.length&&(h.displayName=this.getChildValue(e[0])),b[f]=h)}a=a.getElementsByTagName("SimpleData");c=0;for(d=a.length;c<d;c++)h={},e=a[c],f=e.getAttribute("name"),h.value=this.getChildValue(e),this.kvpAttributes?b[f]=h.value:(h.displayName=f,b[f]=h);return b},parseProperty:function(a,b,c){var d;a=this.getElementsByTagNameNS(a,b,c);try{d=OpenLayers.Util.getXmlNodeValue(a[0])}catch(e){d=
+null}return d},write:function(a){OpenLayers.Util.isArray(a)||(a=[a]);for(var b=this.createElementNS(this.kmlns,"kml"),c=this.createFolderXML(),d=0,e=a.length;d<e;++d)c.appendChild(this.createPlacemarkXML(a[d]));b.appendChild(c);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFolderXML:function(){var a=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var b=this.createElementNS(this.kmlns,"name"),c=this.createTextNode(this.foldersName);b.appendChild(c);a.appendChild(b)}this.foldersDesc&&
+(b=this.createElementNS(this.kmlns,"description"),c=this.createTextNode(this.foldersDesc),b.appendChild(c),a.appendChild(b));return a},createPlacemarkXML:function(a){var b=this.createElementNS(this.kmlns,"name"),c=a.style&&a.style.label?a.style.label:a.id;b.appendChild(this.createTextNode(a.attributes.name||c));var d=this.createElementNS(this.kmlns,"description");d.appendChild(this.createTextNode(a.attributes.description||this.placemarksDesc));c=this.createElementNS(this.kmlns,"Placemark");null!=
+a.fid&&c.setAttribute("id",a.fid);c.appendChild(b);c.appendChild(d);b=this.buildGeometryNode(a.geometry);c.appendChild(b);a.attributes&&(a=this.buildExtendedData(a.attributes))&&c.appendChild(a);return c},buildGeometryNode:function(a){var b=a.CLASS_NAME,b=b.substring(b.lastIndexOf(".")+1),b=this.buildGeometry[b.toLowerCase()],c=null;b&&(c=b.apply(this,[a]));return c},buildGeometry:{point:function(a){var b=this.createElementNS(this.kmlns,"Point");b.appendChild(this.buildCoordinatesNode(a));return b},
+multipoint:function(a){return this.buildGeometry.collection.apply(this,[a])},linestring:function(a){var b=this.createElementNS(this.kmlns,"LineString");b.appendChild(this.buildCoordinatesNode(a));return b},multilinestring:function(a){return this.buildGeometry.collection.apply(this,[a])},linearring:function(a){var b=this.createElementNS(this.kmlns,"LinearRing");b.appendChild(this.buildCoordinatesNode(a));return b},polygon:function(a){var b=this.createElementNS(this.kmlns,"Polygon");a=a.components;
+for(var c,d,e=0,f=a.length;e<f;++e)c=0==e?"outerBoundaryIs":"innerBoundaryIs",c=this.createElementNS(this.kmlns,c),d=this.buildGeometry.linearring.apply(this,[a[e]]),c.appendChild(d),b.appendChild(c);return b},multipolygon:function(a){return this.buildGeometry.collection.apply(this,[a])},collection:function(a){for(var b=this.createElementNS(this.kmlns,"MultiGeometry"),c,d=0,e=a.components.length;d<e;++d)(c=this.buildGeometryNode.apply(this,[a.components[d]]))&&b.appendChild(c);return b}},buildCoordinatesNode:function(a){var b=
+this.createElementNS(this.kmlns,"coordinates"),c;if(c=a.components){for(var d=c.length,e=Array(d),f=0;f<d;++f)a=c[f],e[f]=this.buildCoordinates(a);c=e.join(" ")}else c=this.buildCoordinates(a);c=this.createTextNode(c);b.appendChild(c);return b},buildCoordinates:function(a){this.internalProjection&&this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));return a.x+","+a.y},buildExtendedData:function(a){var b=this.createElementNS(this.kmlns,"ExtendedData"),
+c;for(c in a)if(a[c]&&"name"!=c&&"description"!=c&&"styleUrl"!=c){var d=this.createElementNS(this.kmlns,"Data");d.setAttribute("name",c);var e=this.createElementNS(this.kmlns,"value");if("object"==typeof a[c]){if(a[c].value&&e.appendChild(this.createTextNode(a[c].value)),a[c].displayName){var f=this.createElementNS(this.kmlns,"displayName");f.appendChild(this.getXMLDoc().createCDATASection(a[c].displayName));d.appendChild(f)}}else e.appendChild(this.createTextNode(a[c]));d.appendChild(e);b.appendChild(d)}return this.isSimpleContent(b)?
+null:b},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Format.WMSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.1",profile:null,CLASS_NAME:"OpenLayers.Format.WMSCapabilities"});OpenLayers.Format.WMSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wms:"http://www.opengis.net/wms",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"wms",read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=a;a&&9==a.nodeType&&(a=a.documentElement);var c={};this.readNode(a,c);void 0===c.service&&(a=new OpenLayers.Format.OGCExceptionReport,c.error=a.read(b));return c},readers:{wms:{Service:function(a,
+b){b.service={};this.readChildNodes(a,b.service)},Name:function(a,b){b.name=this.getChildValue(a)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b["abstract"]=this.getChildValue(a)},BoundingBox:function(a,b){var c={};c.bbox=[parseFloat(a.getAttribute("minx")),parseFloat(a.getAttribute("miny")),parseFloat(a.getAttribute("maxx")),parseFloat(a.getAttribute("maxy"))];var d={x:parseFloat(a.getAttribute("resx")),y:parseFloat(a.getAttribute("resy"))};isNaN(d.x)&&isNaN(d.y)||(c.res=
+d);return c},OnlineResource:function(a,b){b.href=this.getAttributeNS(a,this.namespaces.xlink,"href")},ContactInformation:function(a,b){b.contactInformation={};this.readChildNodes(a,b.contactInformation)},ContactPersonPrimary:function(a,b){b.personPrimary={};this.readChildNodes(a,b.personPrimary)},ContactPerson:function(a,b){b.person=this.getChildValue(a)},ContactOrganization:function(a,b){b.organization=this.getChildValue(a)},ContactPosition:function(a,b){b.position=this.getChildValue(a)},ContactAddress:function(a,
+b){b.contactAddress={};this.readChildNodes(a,b.contactAddress)},AddressType:function(a,b){b.type=this.getChildValue(a)},Address:function(a,b){b.address=this.getChildValue(a)},City:function(a,b){b.city=this.getChildValue(a)},StateOrProvince:function(a,b){b.stateOrProvince=this.getChildValue(a)},PostCode:function(a,b){b.postcode=this.getChildValue(a)},Country:function(a,b){b.country=this.getChildValue(a)},ContactVoiceTelephone:function(a,b){b.phone=this.getChildValue(a)},ContactFacsimileTelephone:function(a,
+b){b.fax=this.getChildValue(a)},ContactElectronicMailAddress:function(a,b){b.email=this.getChildValue(a)},Fees:function(a,b){var c=this.getChildValue(a);c&&"none"!=c.toLowerCase()&&(b.fees=c)},AccessConstraints:function(a,b){var c=this.getChildValue(a);c&&"none"!=c.toLowerCase()&&(b.accessConstraints=c)},Capability:function(a,b){b.capability={nestedLayers:[],layers:[]};this.readChildNodes(a,b.capability)},Request:function(a,b){b.request={};this.readChildNodes(a,b.request)},GetCapabilities:function(a,
+b){b.getcapabilities={formats:[]};this.readChildNodes(a,b.getcapabilities)},Format:function(a,b){OpenLayers.Util.isArray(b.formats)?b.formats.push(this.getChildValue(a)):b.format=this.getChildValue(a)},DCPType:function(a,b){this.readChildNodes(a,b)},HTTP:function(a,b){this.readChildNodes(a,b)},Get:function(a,b){b.get={};this.readChildNodes(a,b.get);b.href||(b.href=b.get.href)},Post:function(a,b){b.post={};this.readChildNodes(a,b.post);b.href||(b.href=b.get.href)},GetMap:function(a,b){b.getmap={formats:[]};
+this.readChildNodes(a,b.getmap)},GetFeatureInfo:function(a,b){b.getfeatureinfo={formats:[]};this.readChildNodes(a,b.getfeatureinfo)},Exception:function(a,b){b.exception={formats:[]};this.readChildNodes(a,b.exception)},Layer:function(a,b){var c,d;b.capability?(d=b.capability,c=b):d=b;var e=a.getAttributeNode("queryable"),f=e&&e.specified?a.getAttribute("queryable"):null,g=(e=a.getAttributeNode("cascaded"))&&e.specified?a.getAttribute("cascaded"):null,e=(e=a.getAttributeNode("opaque"))&&e.specified?
+a.getAttribute("opaque"):null,h=a.getAttribute("noSubsets"),k=a.getAttribute("fixedWidth"),l=a.getAttribute("fixedHeight"),m=c||{},n=OpenLayers.Util.extend;c={nestedLayers:[],styles:c?[].concat(c.styles):[],srs:c?n({},m.srs):{},metadataURLs:[],bbox:c?n({},m.bbox):{},llbbox:m.llbbox,dimensions:c?n({},m.dimensions):{},authorityURLs:c?n({},m.authorityURLs):{},identifiers:{},keywords:[],queryable:f&&""!==f?"1"===f||"true"===f:m.queryable||!1,cascaded:null!==g?parseInt(g):m.cascaded||0,opaque:e?"1"===
+e||"true"===e:m.opaque||!1,noSubsets:null!==h?"1"===h||"true"===h:m.noSubsets||!1,fixedWidth:null!=k?parseInt(k):m.fixedWidth||0,fixedHeight:null!=l?parseInt(l):m.fixedHeight||0,minScale:m.minScale,maxScale:m.maxScale,attribution:m.attribution};b.nestedLayers.push(c);c.capability=d;this.readChildNodes(a,c);delete c.capability;c.name&&(f=c.name.split(":"),g=d.request,e=g.getfeatureinfo,0<f.length&&(c.prefix=f[0]),d.layers.push(c),void 0===c.formats&&(c.formats=g.getmap.formats),void 0===c.infoFormats&&
+e&&(c.infoFormats=e.formats))},Attribution:function(a,b){b.attribution={};this.readChildNodes(a,b.attribution)},LogoURL:function(a,b){b.logo={width:a.getAttribute("width"),height:a.getAttribute("height")};this.readChildNodes(a,b.logo)},Style:function(a,b){var c={};b.styles.push(c);this.readChildNodes(a,c)},LegendURL:function(a,b){var c={width:a.getAttribute("width"),height:a.getAttribute("height")};b.legend=c;this.readChildNodes(a,c)},MetadataURL:function(a,b){var c={type:a.getAttribute("type")};
+b.metadataURLs.push(c);this.readChildNodes(a,c)},DataURL:function(a,b){b.dataURL={};this.readChildNodes(a,b.dataURL)},FeatureListURL:function(a,b){b.featureListURL={};this.readChildNodes(a,b.featureListURL)},AuthorityURL:function(a,b){var c=a.getAttribute("name"),d={};this.readChildNodes(a,d);b.authorityURLs[c]=d.href},Identifier:function(a,b){var c=a.getAttribute("authority");b.identifiers[c]=this.getChildValue(a)},KeywordList:function(a,b){this.readChildNodes(a,b)},SRS:function(a,b){b.srs[this.getChildValue(a)]=
+!0}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{wms:OpenLayers.Util.applyDefaults({WMT_MS_Capabilities:function(a,b){this.readChildNodes(a,b)},Keyword:function(a,b){b.keywords&&b.keywords.push(this.getChildValue(a))},DescribeLayer:function(a,b){b.describelayer={formats:[]};this.readChildNodes(a,b.describelayer)},GetLegendGraphic:function(a,b){b.getlegendgraphic={formats:[]};this.readChildNodes(a,b.getlegendgraphic)},GetStyles:function(a,b){b.getstyles=
+{formats:[]};this.readChildNodes(a,b.getstyles)},PutStyles:function(a,b){b.putstyles={formats:[]};this.readChildNodes(a,b.putstyles)},UserDefinedSymbolization:function(a,b){var c={supportSLD:1==parseInt(a.getAttribute("SupportSLD")),userLayer:1==parseInt(a.getAttribute("UserLayer")),userStyle:1==parseInt(a.getAttribute("UserStyle")),remoteWFS:1==parseInt(a.getAttribute("RemoteWFS"))};b.userSymbols=c},LatLonBoundingBox:function(a,b){b.llbbox=[parseFloat(a.getAttribute("minx")),parseFloat(a.getAttribute("miny")),
+parseFloat(a.getAttribute("maxx")),parseFloat(a.getAttribute("maxy"))]},BoundingBox:function(a,b){var c=OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms.BoundingBox.apply(this,[a,b]);c.srs=a.getAttribute("SRS");b.bbox[c.srs]=c},ScaleHint:function(a,b){var c=a.getAttribute("min"),d=a.getAttribute("max"),e=Math.pow(2,0.5),f=OpenLayers.INCHES_PER_UNIT.m;0!=c&&(b.maxScale=parseFloat((c/e*f*OpenLayers.DOTS_PER_INCH).toPrecision(13)));d!=Number.POSITIVE_INFINITY&&(b.minScale=parseFloat((d/e*f*
+OpenLayers.DOTS_PER_INCH).toPrecision(13)))},Dimension:function(a,b){var c={name:a.getAttribute("name").toLowerCase(),units:a.getAttribute("units"),unitsymbol:a.getAttribute("unitSymbol")};b.dimensions[c.name]=c},Extent:function(a,b){var c=a.getAttribute("name").toLowerCase();if(c in b.dimensions){c=b.dimensions[c];c.nearestVal="1"===a.getAttribute("nearestValue");c.multipleVal="1"===a.getAttribute("multipleValues");c.current="1"===a.getAttribute("current");c["default"]=a.getAttribute("default")||
+"";var d=this.getChildValue(a);c.values=d.split(",")}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});OpenLayers.Format.WMSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.0",readers:{wms:OpenLayers.Util.applyDefaults({SRS:function(a,b){for(var c=this.getChildValue(a).split(/ +/),d=0,e=c.length;d<e;d++)b.srs[c[d]]=!0}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_0"});OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a]);a.format||(this.format=OpenLayers.Format.WFST(OpenLayers.Util.extend({version:this.version,featureType:this.featureTy
pe,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,
+srsName:this.srsName,schema:this.schema},this.formatOptions)));!a.geometryName&&1<parseFloat(this.format.version)&&this.setGeometryName(null)},destroy:function(){this.options&&!this.options.format&&this.format.destroy();this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,arguments);a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,this.options||{});var b=new OpenLayers.Protocol.Response({requestType:"read"}),
+c=OpenLayers.Format.XML.prototype.write.apply(this.format,[this.format.writeNode("wfs:GetFeature",a)]);b.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleRead,b,a),params:a.params,headers:a.headers,data:c});return b},setFeatureType:function(a){this.featureType=a;this.format.featureType=a},setGeometryName:function(a){this.geometryName=a;this.format.geometryName=a},handleRead:function(a,b){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);if(b.callback){var c=
+a.priv;200<=c.status&&300>c.status?(c=this.parseResponse(c,b.readOptions))&&!1!==c.success?(b.readOptions&&"object"==b.readOptions.output?OpenLayers.Util.extend(a,c):a.features=c,a.code=OpenLayers.Protocol.Response.SUCCESS):(a.code=OpenLayers.Protocol.Response.FAILURE,a.error=c):a.code=OpenLayers.Protocol.Response.FAILURE;b.callback.call(b.scope,a)}},parseResponse:function(a,b){var c=a.responseXML;c&&c.documentElement||(c=a.responseText);if(!c||0>=c.length)return null;c=null!==this.readFormat?this.readFormat.read(c):
+this.format.read(c,b);if(!this.featureNS){var d=this.readFormat||this.format;this.featureNS=d.featureNS;d.autoConfig=!1;this.geometryName||this.setGeometryName(d.geometryName)}return c},commit:function(a,b){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);var c=new OpenLayers.Protocol.Response({requestType:"commit",reqFeatures:a});c.priv=OpenLayers.Request.POST({url:b.url,headers:b.headers,data:this.format.write(a,b),callback:this.createCallback(this.handleCommit,c,b)});
+return c},handleCommit:function(a,b){if(b.callback){var c=a.priv,d=c.responseXML;d&&d.documentElement||(d=c.responseText);c=this.format.read(d)||{};a.insertIds=c.insertIds||[];c.success?a.code=OpenLayers.Protocol.Response.SUCCESS:(a.code=OpenLayers.Protocol.Response.FAILURE,a.error=c);b.callback.call(b.scope,a)}},filterDelete:function(a,b){b=OpenLayers.Util.extend({},b);OpenLayers.Util.applyDefaults(b,this.options);new OpenLayers.Protocol.Response({requestType:"commit"});var c=this.format.createElementNSPlus("wfs:Transaction",
+{attributes:{service:"WFS",version:this.version}}),d=this.format.createElementNSPlus("wfs:Delete",{attributes:{typeName:(b.featureNS?this.featurePrefix+":":"")+b.featureType}});b.featureNS&&d.setAttribute("xmlns:"+this.featurePrefix,b.featureNS);var e=this.format.writeNode("ogc:Filter",a);d.appendChild(e);c.appendChild(d);c=OpenLayers.Format.XML.prototype.write.apply(this.format,[c]);return OpenLayers.Request.POST({url:this.url,callback:b.callback||function(){},data:c})},abort:function(a){a&&a.priv.abort()},
+CLASS_NAME:"OpenLayers.Protocol.WFS.v1"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{click:{"in":"click",out:"clickout"},mousemove:{"in":"over",out:"out"},dblclick:{"in":"dblclick",out:null},mousedown:{"in":null,out:null},mouseup:{"in":null,out:null},touchstart:{"in":"click",out:"clickout"}},feature:null,lastFeature:null,down:null,up:null,clickTolerance:4,geometryTypes:null,stopClick:!0,stopDown:!0,stopUp:!1,initialize:function(a,b,c,d){OpenLayers.Handler.prototype.initialize.apply(this,[a,c,d]);this.layer=
+b},touchstart:function(a){this.startTouch();return OpenLayers.Event.isMultiTouch(a)?!0:this.mousedown(a)},touchmove:function(a){OpenLayers.Event.preventDefault(a)},mousedown:function(a){if(OpenLayers.Event.isLeftClick(a)||OpenLayers.Event.isSingleTouch(a))this.down=a.xy;return this.handle(a)?!this.stopDown:!0},mouseup:function(a){this.up=a.xy;return this.handle(a)?!this.stopUp:!0},click:function(a){return this.handle(a)?!this.stopClick:!0},mousemove:function(a){if(!this.callbacks.over&&!this.callbacks.out)return!0;
+this.handle(a);return!0},dblclick:function(a){return!this.handle(a)},geometryTypeMatches:function(a){return null==this.geometryTypes||-1<OpenLayers.Util.indexOf(this.geometryTypes,a.geometry.CLASS_NAME)},handle:function(a){this.feature&&!this.feature.layer&&(this.feature=null);var b=a.type,c=!1,d=!!this.feature,e="click"==b||"dblclick"==b||"touchstart"==b;(this.feature=this.layer.getFeatureFromEvent(a))&&!this.feature.layer&&(this.feature=null);this.lastFeature&&!this.lastFeature.layer&&(this.lastFeature=
+null);this.feature?("touchstart"===b&&OpenLayers.Event.preventDefault(a),a=this.feature!=this.lastFeature,this.geometryTypeMatches(this.feature)?(d&&a?(this.lastFeature&&this.triggerCallback(b,"out",[this.lastFeature]),this.triggerCallback(b,"in",[this.feature])):d&&!e||this.triggerCallback(b,"in",[this.feature]),this.lastFeature=this.feature,c=!0):(this.lastFeature&&(d&&a||e)&&this.triggerCallback(b,"out",[this.lastFeature]),this.feature=null)):this.lastFeature&&(d||e)&&this.triggerCallback(b,"out",
+[this.lastFeature]);return c},triggerCallback:function(a,b,c){if(b=this.EVENTMAP[a][b])"click"==a&&this.up&&this.down?(Math.sqrt(Math.pow(this.up.x-this.down.x,2)+Math.pow(this.up.y-this.down.y,2))<=this.clickTolerance&&this.callback(b,c),this.up=this.down=null):this.callback(b,c)},activate:function(){var a=!1;OpenLayers.Handler.prototype.activate.apply(this,arguments)&&(this.moveLayerToTop(),this.map.events.on({removelayer:this.handleMapEvents,changelayer:this.handleMapEvents,scope:this}),a=!0);
+return a},deactivate:function(){var a=!1;OpenLayers.Handler.prototype.deactivate.apply(this,arguments)&&(this.moveLayerBack(),this.up=this.down=this.lastFeature=this.feature=null,this.map.events.un({removelayer:this.handleMapEvents,changelayer:this.handleMapEvents,scope:this}),a=!0);return a},handleMapEvents:function(a){"removelayer"!=a.type&&"order"!=a.property||this.moveLayerToTop()},moveLayerToTop:function(){var a=Math.max(this.map.Z_INDEX_BASE.Feature-1,this.layer.getZIndex())+1;this.layer.setZIndex(a)},
+moveLayerBack:function(){var a=this.layer.getZIndex()-1;a>=this.map.Z_INDEX_BASE.Feature?this.layer.setZIndex(a):this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer))},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:!1,layers:null,display:function(){},getFeatureFromEvent:function(a){for(var b=this.layers,c,d=0;d<b.length;d++)if(c=b[d].getFeatureFromEvent(a))return c},setMap:function(a){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();a.events.register("changelayer",this,this.handleChangeLayer)},removeMap:function(a){a.events.unregister("changelayer",this,this.handleChangeLayer);
+this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments)},collectRoots:function(){for(var a,b=0;b<this.map.layers.length;++b)a=this.map.layers[b],-1!=OpenLayers.Util.indexOf(this.layers,a)&&a.renderer.moveRoot(this.renderer)},resetRoots:function(){for(var a,b=0;b<this.layers.length;++b)a=this.layers[b],this.renderer&&a.renderer.getRenderLayerId()==this.id&&this.renderer.moveRoot(a.renderer)},handleChangeLayer:function(a){var b=a.layer;"order"==a.property&&-1!=OpenLayers.Util.indexOf(this.layers,
+b)&&(this.resetRoots(),this.collectRoots())},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:!1,clickout:!0,toggle:!1,hover:!1,highlightOnly:!1,box:!1,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);null===this.scope&&(this.scope=this);this.initLayer(a);var c=
+{click:this.clickFeature,clickout:this.clickoutFeature};this.hover&&(c.over=this.overFeature,c.out=this.outFeature);this.callbacks=OpenLayers.Util.extend(c,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};this.box&&(this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"}))},initLayer:function(a){OpenLayers.Util.isArray(a)?(this.layers=a,this.layer=
+new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:a})):this.layer=a},destroy:function(){this.active&&this.layers&&this.map.removeLayer(this.layer);OpenLayers.Control.prototype.destroy.apply(this,arguments);this.layers&&this.layer.destroy()},activate:function(){this.active||(this.layers&&this.map.addLayer(this.layer),this.handlers.feature.activate(),this.box&&this.handlers.box&&this.handlers.box.activate());return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.active&&
+(this.handlers.feature.deactivate(),this.handlers.box&&this.handlers.box.deactivate(),this.layers&&this.map.removeLayer(this.layer));return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},unselectAll:function(a){var b=this.layers||[this.layer],c,d,e,f;for(e=0;e<b.length;++e)if(c=b[e],f=0,null!=c.selectedFeatures)for(;c.selectedFeatures.length>f;)d=c.selectedFeatures[f],a&&a.except==d?++f:this.unselect(d)},clickFeature:function(a){this.hover||(-1<OpenLayers.Util.indexOf(a.layer.selectedFeatures,
+a)?this.toggleSelect()?this.unselect(a):this.multipleSelect()||this.unselectAll({except:a}):(this.multipleSelect()||this.unselectAll({except:a}),this.select(a)))},multipleSelect:function(){return this.multiple||this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]},toggleSelect:function(){return this.toggle||this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]},clickoutFeature:function(a){!this.hover&&this.clickout&&this.unselectAll()},overFeature:function(a){var b=
+a.layer;this.hover&&(this.highlightOnly?this.highlight(a):-1==OpenLayers.Util.indexOf(b.selectedFeatures,a)&&this.select(a))},outFeature:function(a){if(this.hover)if(this.highlightOnly){if(a._lastHighlighter==this.id)if(a._prevHighlighter&&a._prevHighlighter!=this.id){delete a._lastHighlighter;var b=this.map.getControl(a._prevHighlighter);b&&b.highlight(a)}else this.unhighlight(a)}else this.unselect(a)},highlight:function(a){var b=a.layer;!1!==this.events.triggerEvent("beforefeaturehighlighted",{feature:a})&&
+(a._prevHighlighter=a._lastHighlighter,a._lastHighlighter=this.id,b.drawFeature(a,this.selectStyle||this.renderIntent),this.events.triggerEvent("featurehighlighted",{feature:a}))},unhighlight:function(a){var b=a.layer;void 0==a._prevHighlighter?delete a._lastHighlighter:(a._prevHighlighter!=this.id&&(a._lastHighlighter=a._prevHighlighter),delete a._prevHighlighter);b.drawFeature(a,a.style||a.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:a})},select:function(a){var b=
+this.onBeforeSelect.call(this.scope,a),c=a.layer;!1!==b&&(b=c.events.triggerEvent("beforefeatureselected",{feature:a}),!1!==b&&(c.selectedFeatures.push(a),this.highlight(a),this.handlers.feature.lastFeature||(this.handlers.feature.lastFeature=c.selectedFeatures[0]),c.events.triggerEvent("featureselected",{feature:a}),this.onSelect.call(this.scope,a)))},unselect:function(a){var b=a.layer;this.unhighlight(a);OpenLayers.Util.removeItem(b.selectedFeatures,a);b.events.triggerEvent("featureunselected",
+{feature:a});this.onUnselect.call(this.scope,a)},selectBox:function(a){if(a instanceof OpenLayers.Bounds){var b=this.map.getLonLatFromPixel({x:a.left,y:a.bottom});a=this.map.getLonLatFromPixel({x:a.right,y:a.top});b=new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat);this.multipleSelect()||this.unselectAll();a=this.multiple;this.multiple=!0;var c=this.layers||[this.layer];this.events.triggerEvent("boxselectionstart",{layers:c});for(var d,e=0;e<c.length;++e){d=c[e];for(var f=0,g=d.features.length;f<g;++f){var h=
+d.features[f];h.getVisibility()&&(null==this.geometryTypes||-1<OpenLayers.Util.indexOf(this.geometryTypes,h.geometry.CLASS_NAME))&&b.toGeometry().intersects(h.geometry)&&-1==OpenLayers.Util.indexOf(d.selectedFeatures,h)&&this.select(h)}}this.multiple=a;this.events.triggerEvent("boxselectionend",{layers:c})}},setMap:function(a){this.handlers.feature.setMap(a);this.box&&this.handlers.box.setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},setLayer:function(a){var b=this.active;this.unselectAll();
+this.deactivate();this.layers&&(this.layer.destroy(),this.layers=null);this.initLayer(a);this.handlers.feature.layer=this.layer;b&&this.activate()},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:!1,citeCompliant:!1,mouseDown:!1,stoppedDown:null,lastDown:null,lastUp:null,persist:!1,stopDown:!1,stopUp:!1,layerOptions:null,pixelTolerance:5,lastTouchPx:null,initialize:function(a,b,c){c&&c.layerOptions&&c.layerOptions.styleMap||(this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style["default"],{}));OpenLayers.Handler.prototype.initialize.apply(this,arguments)},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,
+arguments))return!1;var a=OpenLayers.Util.extend({displayInLayerSwitcher:!1,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,a);this.map.addLayer(this.layer);return!0},createFeature:function(a){a=this.layer.getLonLatFromViewPortPx(a);a=new OpenLayers.Geometry.Point(a.lon,a.lat);this.point=new OpenLayers.Feature.Vector(a);this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();
+this.layer.addFeatures([this.point],{silent:!0})},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments))return!1;this.cancel();null!=this.layer.map&&(this.destroyFeature(!0),this.layer.destroy(!1));this.layer=null;return!0},destroyFeature:function(a){!this.layer||!a&&this.persist||this.layer.destroyFeatures();this.point=null},destroyPersistedFeature:function(){var a=this.layer;a&&1<a.features.length&&this.layer.features[0].destroy()},finalize:function(a){this.mouseDown=
+!1;this.lastTouchPx=this.lastUp=this.lastDown=null;this.callback(a?"cancel":"done",[this.geometryClone()]);this.destroyFeature(a)},cancel:function(){this.finalize(!0)},click:function(a){OpenLayers.Event.stop(a);return!1},dblclick:function(a){OpenLayers.Event.stop(a);return!1},modifyFeature:function(a){this.point||this.createFeature(a);a=this.layer.getLonLatFromViewPortPx(a);this.point.geometry.x=a.lon;this.point.geometry.y=a.lat;this.callback("modify",[this.point.geometry,this.point,!1]);this.point.geometry.clearBounds();
+this.drawFeature()},drawFeature:function(){this.layer.drawFeature(this.point,this.style)},getGeometry:function(){var a=this.point&&this.point.geometry;a&&this.multi&&(a=new OpenLayers.Geometry.MultiPoint([a]));return a},geometryClone:function(){var a=this.getGeometry();return a&&a.clone()},mousedown:function(a){return this.down(a)},touchstart:function(a){this.startTouch();this.lastTouchPx=a.xy;return this.down(a)},mousemove:function(a){return this.move(a)},touchmove:function(a){this.lastTouchPx=a.xy;
+return this.move(a)},mouseup:function(a){return this.up(a)},touchend:function(a){a.xy=this.lastTouchPx;return this.up(a)},down:function(a){this.mouseDown=!0;this.lastDown=a.xy;this.touch||this.modifyFeature(a.xy);this.stoppedDown=this.stopDown;return!this.stopDown},move:function(a){this.touch||this.mouseDown&&!this.stoppedDown||this.modifyFeature(a.xy);return!0},up:function(a){this.mouseDown=!1;this.stoppedDown=this.stopDown;if(!this.checkModifiers(a)||this.lastUp&&this.lastUp.equals(a.xy)||!this.lastDown||
+!this.passesTolerance(this.lastDown,a.xy,this.pixelTolerance))return!0;this.touch&&this.modifyFeature(a.xy);this.persist&&this.destroyPersistedFeature();this.lastUp=a.xy;this.finalize();return!this.stopUp},mouseout:function(a){OpenLayers.Util.mouseLeft(a,this.map.viewPortDiv)&&(this.stoppedDown=this.stopDown,this.mouseDown=!1)},passesTolerance:function(a,b,c){var d=!0;null!=c&&a&&b&&a.distanceTo(b)>c&&(d=!1);return d},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,maxVertices:null,doubleTouchTolerance:20,freehand:!1,freehandToggle:"shiftKey",timerId:null,redoStack:null,createFeature:function(a){a=this.layer.getLonLatFromViewPortPx(a);a=new OpenLayers.Geometry.Point(a.lon,a.lat);this.point=new OpenLayers.Feature.Vector(a);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);
+this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:!0})},destroyFeature:function(a){OpenLayers.Handler.Point.prototype.destroyFeature.call(this,a);this.line=null},destroyPersistedFeature:function(){var a=this.layer;a&&2<a.features.length&&this.layer.features[0].destroy()},removePoint:function(){this.point&&this.layer.removeFeatures([this.point])},addPoint:function(a){this.layer.removeFeatures([this.point]);a=this.layer.getLonLatFromViewPortPx(a);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(a.lon,
+a.lat));this.line.geometry.addComponent(this.point.geometry,this.line.geometry.components.length);this.layer.addFeatures([this.point]);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();delete this.redoStack},insertXY:function(a,b){this.line.geometry.addComponent(new OpenLayers.Geometry.Point(a,b),this.getCurrentPointIndex());this.drawFeature();delete this.redoStack},insertDeltaXY:function(a,b){var c=this.getCurrentPointIndex()-
+1,c=this.line.geometry.components[c];!c||(isNaN(c.x)||isNaN(c.y))||this.insertXY(c.x+a,c.y+b)},insertDirectionLength:function(a,b){a*=Math.PI/180;var c=b*Math.cos(a),d=b*Math.sin(a);this.insertDeltaXY(c,d)},insertDeflectionLength:function(a,b){var c=this.getCurrentPointIndex()-1;if(0<c){var d=this.line.geometry.components[c],c=this.line.geometry.components[c-1],d=Math.atan2(d.y-c.y,d.x-c.x);this.insertDirectionLength(180*d/Math.PI+a,b)}},getCurrentPointIndex:function(){return this.line.geometry.components.length-
+1},undo:function(){var a=this.line.geometry,b=a.components,c=this.getCurrentPointIndex()-1,d=b[c],e=a.removeComponent(d);e&&(this.touch&&0<c&&(b=a.components,a=b[c-1],c=this.getCurrentPointIndex(),b=b[c],b.x=a.x,b.y=a.y),this.redoStack||(this.redoStack=[]),this.redoStack.push(d),this.drawFeature());return e},redo:function(){var a=this.redoStack&&this.redoStack.pop();a&&(this.line.geometry.addComponent(a,this.getCurrentPointIndex()),this.drawFeature());return!!a},freehandMode:function(a){return this.freehandToggle&&
+a[this.freehandToggle]?!this.freehand:this.freehand},modifyFeature:function(a,b){this.line||this.createFeature(a);var c=this.layer.getLonLatFromViewPortPx(a);this.point.geometry.x=c.lon;this.point.geometry.y=c.lat;this.callback("modify",[this.point.geometry,this.getSketch(),b]);this.point.geometry.clearBounds();this.drawFeature()},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style)},getSketch:function(){return this.line},getGeometry:function(){var a=
+this.line&&this.line.geometry;a&&this.multi&&(a=new OpenLayers.Geometry.MultiLineString([a]));return a},touchstart:function(a){if(this.timerId&&this.passesTolerance(this.lastTouchPx,a.xy,this.doubleTouchTolerance))return this.finishGeometry(),window.clearTimeout(this.timerId),this.timerId=null,!1;this.timerId&&(window.clearTimeout(this.timerId),this.timerId=null);this.timerId=window.setTimeout(OpenLayers.Function.bind(function(){this.timerId=null},this),300);return OpenLayers.Handler.Point.prototype.touchstart.call(this,
+a)},down:function(a){var b=this.stopDown;this.freehandMode(a)&&(b=!0,this.touch&&(this.modifyFeature(a.xy,!!this.lastUp),OpenLayers.Event.stop(a)));this.touch||this.lastDown&&this.passesTolerance(this.lastDown,a.xy,this.pixelTolerance)||this.modifyFeature(a.xy,!!this.lastUp);this.mouseDown=!0;this.lastDown=a.xy;this.stoppedDown=b;return!b},move:function(a){if(this.stoppedDown&&this.freehandMode(a))return this.persist&&this.destroyPersistedFeature(),this.maxVertices&&this.line&&this.line.geometry.components.length===
+this.maxVertices?(this.removePoint(),this.finalize()):this.addPoint(a.xy),!1;this.touch||this.mouseDown&&!this.stoppedDown||this.modifyFeature(a.xy,!!this.lastUp);return!0},up:function(a){!this.mouseDown||this.lastUp&&this.lastUp.equals(a.xy)||(this.stoppedDown&&this.freehandMode(a)?(this.persist&&this.destroyPersistedFeature(),this.removePoint(),this.finalize()):this.passesTolerance(this.lastDown,a.xy,this.pixelTolerance)&&(this.touch&&this.modifyFeature(a.xy),null==this.lastUp&&this.persist&&this.destroyPersistedFeature(),
+this.addPoint(a.xy),this.lastUp=a.xy,this.line.geometry.components.length===this.maxVertices+1&&this.finishGeometry()));this.stoppedDown=this.stopDown;this.mouseDown=!1;return!this.stopUp},finishGeometry:function(){this.line.geometry.removeComponent(this.line.geometry.components[this.line.geometry.components.length-1]);this.removePoint();this.finalize()},dblclick:function(a){this.freehandMode(a)||this.finishGeometry();return!1},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Spherical=OpenLayers.Spherical||{};OpenLayers.Spherical.DEFAULT_RADIUS=6378137;OpenLayers.Spherical.computeDistanceBetween=function(a,b,c){c=c||OpenLayers.Spherical.DEFAULT_RADIUS;var d=Math.sin(Math.PI*(b.lon-a.lon)/360),e=Math.sin(Math.PI*(b.lat-a.lat)/360);a=e*e+d*d*Math.cos(Math.PI*a.lat/180)*Math.cos(Math.PI*b.lat/180);return 2*c*Math.atan2(Math.sqrt(a),Math.sqrt(1-a))};
+OpenLayers.Spherical.computeHeading=function(a,b){var c=Math.sin(Math.PI*(a.lon-b.lon)/180)*Math.cos(Math.PI*b.lat/180),d=Math.cos(Math.PI*a.lat/180)*Math.sin(Math.PI*b.lat/180)-Math.sin(Math.PI*a.lat/180)*Math.cos(Math.PI*b.lat/180)*Math.cos(Math.PI*(a.lon-b.lon)/180);return 180*Math.atan2(c,d)/Math.PI};OpenLayers.Control.CacheWrite=OpenLayers.Class(OpenLayers.Control,{layers:null,imageFormat:"image/png",quotaRegEx:/quota/i,setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);var b,c=this.layers||a.layers;for(b=c.length-1;0<=b;--b)this.addLayer({layer:c[b]});if(!this.layers)a.events.on({addlayer:this.addLayer,removeLayer:this.removeLayer,scope:this})},addLayer:function(a){a.layer.events.on({tileloadstart:this.makeSameOrigin,tileloaded:this.onTileLoaded,scope:this})},removeLayer:function(a){a.layer.events.un({tileloadstart:this.makeSameOrigin,
+tileloaded:this.onTileLoaded,scope:this})},makeSameOrigin:function(a){if(this.active&&(a=a.tile,a instanceof OpenLayers.Tile.Image&&!a.crossOriginKeyword&&"data:"!==a.url.substr(0,5))){var b=OpenLayers.Request.makeSameOrigin(a.url,OpenLayers.ProxyHost);OpenLayers.Control.CacheWrite.urlMap[b]=a.url;a.url=b}},onTileLoaded:function(a){this.active&&(!a.aborted&&a.tile instanceof OpenLayers.Tile.Image&&"data:"!==a.tile.url.substr(0,5))&&(this.cache({tile:a.tile}),delete OpenLayers.Control.CacheWrite.urlMap[a.tile.url])},
+cache:function(a){if(window.localStorage){a=a.tile;try{var b=a.getCanvasContext();b&&window.localStorage.setItem("olCache_"+(OpenLayers.Control.CacheWrite.urlMap[a.url]||a.url),b.canvas.toDataURL(this.imageFormat))}catch(c){(b=c.name||c.message)&&this.quotaRegEx.test(b)?this.events.triggerEvent("cachefull",{tile:a}):OpenLayers.Console.error(c.toString())}}},destroy:function(){if(this.layers||this.map){var a,b=this.layers||this.map.layers;for(a=b.length-1;0<=a;--a)this.removeLayer({layer:b[a]})}this.map&&
+this.map.events.un({addlayer:this.addLayer,removeLayer:this.removeLayer,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.CacheWrite"});OpenLayers.Control.CacheWrite.clearCache=function(){if(window.localStorage){var a,b;for(a=window.localStorage.length-1;0<=a;--a)b=window.localStorage.key(a),"olCache_"===b.substr(0,8)&&window.localStorage.removeItem(b)}};OpenLayers.Control.CacheWrite.urlMap={};OpenLayers.Format.Context=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{layerOptions:null,layerParams:null,read:function(a,b){var c=OpenLayers.Format.XML.VersionedOGC.prototype.read.apply(this,arguments);if(b&&b.map)if(this.context=c,b.map instanceof OpenLayers.Map)c=this.mergeContextToMap(c,b.map);else{var d=b.map;if(OpenLayers.Util.isElement(d)||"string"==typeof d)d={div:d};c=this.contextToMap(c,d)}return c},getLayerFromContext:function(a){var b,c,d={queryable:a.queryable,visibility:a.visibility,
+maxExtent:a.maxExtent,metadata:OpenLayers.Util.applyDefaults(a.metadata,{styles:a.styles,formats:a.formats,"abstract":a["abstract"],dataURL:a.dataURL}),numZoomLevels:a.numZoomLevels,units:a.units,isBaseLayer:a.isBaseLayer,opacity:a.opacity,displayInLayerSwitcher:a.displayInLayerSwitcher,singleTile:a.singleTile,tileSize:a.tileSize?new OpenLayers.Size(a.tileSize.width,a.tileSize.height):void 0,minScale:a.minScale||a.maxScaleDenominator,maxScale:a.maxScale||a.minScaleDenominator,srs:a.srs,dimensions:a.dimensions,
+metadataURL:a.metadataURL};this.layerOptions&&OpenLayers.Util.applyDefaults(d,this.layerOptions);var e={layers:a.name,transparent:a.transparent,version:a.version};if(a.formats&&0<a.formats.length)for(e.format=a.formats[0].value,b=0,c=a.formats.length;b<c;b++){var f=a.formats[b];if(!0==f.current){e.format=f.value;break}}if(a.styles&&0<a.styles.length)for(b=0,c=a.styles.length;b<c;b++)if(f=a.styles[b],!0==f.current){f.href?e.sld=f.href:f.body?e.sld_body=f.body:e.styles=f.name;break}this.layerParams&&
+OpenLayers.Util.applyDefaults(e,this.layerParams);b=null;c=a.service;c==OpenLayers.Format.Context.serviceTypes.WFS?(d.strategies=[new OpenLayers.Strategy.BBOX],d.protocol=new OpenLayers.Protocol.WFS({url:a.url,featurePrefix:a.name.split(":")[0],featureType:a.name.split(":").pop()}),b=new OpenLayers.Layer.Vector(a.title||a.name,d)):c==OpenLayers.Format.Context.serviceTypes.KML?(d.strategies=[new OpenLayers.Strategy.Fixed],d.protocol=new OpenLayers.Protocol.HTTP({url:a.url,format:new OpenLayers.Format.KML}),
+b=new OpenLayers.Layer.Vector(a.title||a.name,d)):c==OpenLayers.Format.Context.serviceTypes.GML?(d.strategies=[new OpenLayers.Strategy.Fixed],d.protocol=new OpenLayers.Protocol.HTTP({url:a.url,format:new OpenLayers.Format.GML}),b=new OpenLayers.Layer.Vector(a.title||a.name,d)):a.features?(b=new OpenLayers.Layer.Vector(a.title||a.name,d),b.addFeatures(a.features)):!0!==a.categoryLayer&&(b=new OpenLayers.Layer.WMS(a.title||a.name,a.url,e,d));return b},getLayersFromContext:function(a){for(var b=[],c=
+0,d=a.length;c<d;c++){var e=this.getLayerFromContext(a[c]);null!==e&&b.push(e)}return b},contextToMap:function(a,b){b=OpenLayers.Util.applyDefaults({maxExtent:a.maxExtent,projection:a.projection,units:a.units},b);b.maxExtent&&(b.maxResolution=b.maxExtent.getWidth()/OpenLayers.Map.TILE_WIDTH);b.metadata={contactInformation:a.contactInformation,"abstract":a["abstract"],keywords:a.keywords,logo:a.logo,descriptionURL:a.descriptionURL};var c=new OpenLayers.Map(b);c.addLayers(this.getLayersFromContext(a.layersContext));
+c.setCenter(a.bounds.getCenterLonLat(),c.getZoomForExtent(a.bounds,!0));return c},mergeContextToMap:function(a,b){b.addLayers(this.getLayersFromContext(a.layersContext));return b},write:function(a,b){a=this.toContext(a);return OpenLayers.Format.XML.VersionedOGC.prototype.write.apply(this,arguments)},CLASS_NAME:"OpenLayers.Format.Context"});
+OpenLayers.Format.Context.serviceTypes={WMS:"urn:ogc:serviceType:WMS",WFS:"urn:ogc:serviceType:WFS",WCS:"urn:ogc:serviceType:WCS",GML:"urn:ogc:serviceType:GML",SLD:"urn:ogc:serviceType:SLD",FES:"urn:ogc:serviceType:FES",KML:"urn:ogc:serviceType:KML"};OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",layerToContext:function(a){var b=this.getParser(),c={queryable:a.queryable,visibility:a.visibility,name:a.params.LAYERS,title:a.name,"abstract":a.metadata["abstract"],dataURL:a.metadata.dataURL,metadataURL:a.metadataURL,server:{version:a.params.VERSION,url:a.url},maxExtent:a.maxExtent,transparent:a.params.TRANSPARENT,numZoomLevels:a.numZoomLevels,units:a.units,isBaseLayer:a.isBaseLayer,opacity:1==a.opacity?void 0:
+a.opacity,displayInLayerSwitcher:a.displayInLayerSwitcher,singleTile:a.singleTile,tileSize:a.singleTile||!a.tileSize?void 0:{width:a.tileSize.w,height:a.tileSize.h},minScale:a.options.resolutions||a.options.scales||a.options.maxResolution||a.options.minScale?a.minScale:void 0,maxScale:a.options.resolutions||a.options.scales||a.options.minResolution||a.options.maxScale?a.maxScale:void 0,formats:[],styles:[],srs:a.srs,dimensions:a.dimensions};a.metadata.servertitle&&(c.server.title=a.metadata.servertitle);
+if(a.metadata.formats&&0<a.metadata.formats.length)for(var d=0,e=a.metadata.formats.length;d<e;d++){var f=a.metadata.formats[d];c.formats.push({value:f.value,current:f.value==a.params.FORMAT})}else c.formats.push({value:a.params.FORMAT,current:!0});if(a.metadata.styles&&0<a.metadata.styles.length)for(d=0,e=a.metadata.styles.length;d<e;d++)b=a.metadata.styles[d],b.current=b.href==a.params.SLD||b.body==a.params.SLD_BODY||b.name==a.params.STYLES?!0:!1,c.styles.push(b);else c.styles.push({href:a.params.SLD,
+body:a.params.SLD_BODY,name:a.params.STYLES||b.defaultStyleName,title:b.defaultStyleTitle,current:!0});return c},toContext:function(a){var b={},c=a.layers;if("OpenLayers.Map"==a.CLASS_NAME){var d=a.metadata||{};b.size=a.getSize();b.bounds=a.getExtent();b.projection=a.projection;b.title=a.title;b.keywords=d.keywords;b["abstract"]=d["abstract"];b.logo=d.logo;b.descriptionURL=d.descriptionURL;b.contactInformation=d.contactInformation;b.maxExtent=a.maxExtent}else OpenLayers.Util.applyDefaults(b,a),void 0!=
+b.layers&&delete b.layers;void 0==b.layersContext&&(b.layersContext=[]);if(void 0!=c&&OpenLayers.Util.isArray(c))for(a=0,d=c.length;a<d;a++){var e=c[a];e instanceof OpenLayers.Layer.WMS&&b.layersContext.push(this.layerToContext(e))}return b},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(a){var b=null;if(null==a)b=this.namespaces[this.defaultPrefix];else for(b in this.namespaces)if(this.namespaces[b]==a)break;return b},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",
+defaultStyleTitle:"Default",initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a=a.documentElement;this.rootPrefix=a.prefix;var b={version:a.getAttribute("version")};this.runChildNodes(b,a);return b},runChildNodes:function(a,b){for(var c=b.childNodes,d,e,f,g=0,h=c.length;g<h;++g)d=c[g],1==d.nodeType&&(e=this.getNamespacePrefix(d.namespaceURI),f=d.nodeName.split(":").pop(),
+(e=this["read_"+e+"_"+f])&&e.apply(this,[a,d]))},read_wmc_General:function(a,b){this.runChildNodes(a,b)},read_wmc_BoundingBox:function(a,b){a.projection=b.getAttribute("SRS");a.bounds=new OpenLayers.Bounds(b.getAttribute("minx"),b.getAttribute("miny"),b.getAttribute("maxx"),b.getAttribute("maxy"))},read_wmc_LayerList:function(a,b){a.layersContext=[];this.runChildNodes(a,b)},read_wmc_Layer:function(a,b){var c={visibility:"1"!=b.getAttribute("hidden"),queryable:"1"==b.getAttribute("queryable"),formats:[],
+styles:[],metadata:{}};this.runChildNodes(c,b);a.layersContext.push(c)},read_wmc_Extension:function(a,b){this.runChildNodes(a,b)},read_ol_units:function(a,b){a.units=this.getChildValue(b)},read_ol_maxExtent:function(a,b){var c=new OpenLayers.Bounds(b.getAttribute("minx"),b.getAttribute("miny"),b.getAttribute("maxx"),b.getAttribute("maxy"));a.maxExtent=c},read_ol_transparent:function(a,b){a.transparent=this.getChildValue(b)},read_ol_numZoomLevels:function(a,b){a.numZoomLevels=parseInt(this.getChildValue(b))},
+read_ol_opacity:function(a,b){a.opacity=parseFloat(this.getChildValue(b))},read_ol_singleTile:function(a,b){a.singleTile="true"==this.getChildValue(b)},read_ol_tileSize:function(a,b){var c={width:b.getAttribute("width"),height:b.getAttribute("height")};a.tileSize=c},read_ol_isBaseLayer:function(a,b){a.isBaseLayer="true"==this.getChildValue(b)},read_ol_displayInLayerSwitcher:function(a,b){a.displayInLayerSwitcher="true"==this.getChildValue(b)},read_wmc_Server:function(a,b){a.version=b.getAttribute("version");
+a.url=this.getOnlineResource_href(b);a.metadata.servertitle=b.getAttribute("title")},read_wmc_FormatList:function(a,b){this.runChildNodes(a,b)},read_wmc_Format:function(a,b){var c={value:this.getChildValue(b)};"1"==b.getAttribute("current")&&(c.current=!0);a.formats.push(c)},read_wmc_StyleList:function(a,b){this.runChildNodes(a,b)},read_wmc_Style:function(a,b){var c={};this.runChildNodes(c,b);"1"==b.getAttribute("current")&&(c.current=!0);a.styles.push(c)},read_wmc_SLD:function(a,b){this.runChildNodes(a,
+b)},read_sld_StyledLayerDescriptor:function(a,b){var c=OpenLayers.Format.XML.prototype.write.apply(this,[b]);a.body=c},read_sld_FeatureTypeStyle:function(a,b){var c=OpenLayers.Format.XML.prototype.write.apply(this,[b]);a.body=c},read_wmc_OnlineResource:function(a,b){a.href=this.getAttributeNS(b,this.namespaces.xlink,"href")},read_wmc_Name:function(a,b){var c=this.getChildValue(b);c&&(a.name=c)},read_wmc_Title:function(a,b){var c=this.getChildValue(b);c&&(a.title=c)},read_wmc_MetadataURL:function(a,
+b){a.metadataURL=this.getOnlineResource_href(b)},read_wmc_KeywordList:function(a,b){a.keywords=[];this.runChildNodes(a.keywords,b)},read_wmc_Keyword:function(a,b){a.push(this.getChildValue(b))},read_wmc_Abstract:function(a,b){var c=this.getChildValue(b);c&&(a["abstract"]=c)},read_wmc_LogoURL:function(a,b){a.logo={width:b.getAttribute("width"),height:b.getAttribute("height"),format:b.getAttribute("format"),href:this.getOnlineResource_href(b)}},read_wmc_DescriptionURL:function(a,b){a.descriptionURL=
+this.getOnlineResource_href(b)},read_wmc_ContactInformation:function(a,b){var c={};this.runChildNodes(c,b);a.contactInformation=c},read_wmc_ContactPersonPrimary:function(a,b){var c={};this.runChildNodes(c,b);a.personPrimary=c},read_wmc_ContactPerson:function(a,b){var c=this.getChildValue(b);c&&(a.person=c)},read_wmc_ContactOrganization:function(a,b){var c=this.getChildValue(b);c&&(a.organization=c)},read_wmc_ContactPosition:function(a,b){var c=this.getChildValue(b);c&&(a.position=c)},read_wmc_ContactAddress:function(a,
+b){var c={};this.runChildNodes(c,b);a.contactAddress=c},read_wmc_AddressType:function(a,b){var c=this.getChildValue(b);c&&(a.type=c)},read_wmc_Address:function(a,b){var c=this.getChildValue(b);c&&(a.address=c)},read_wmc_City:function(a,b){var c=this.getChildValue(b);c&&(a.city=c)},read_wmc_StateOrProvince:function(a,b){var c=this.getChildValue(b);c&&(a.stateOrProvince=c)},read_wmc_PostCode:function(a,b){var c=this.getChildValue(b);c&&(a.postcode=c)},read_wmc_Country:function(a,b){var c=this.getChildValue(b);
+c&&(a.country=c)},read_wmc_ContactVoiceTelephone:function(a,b){var c=this.getChildValue(b);c&&(a.phone=c)},read_wmc_ContactFacsimileTelephone:function(a,b){var c=this.getChildValue(b);c&&(a.fax=c)},read_wmc_ContactElectronicMailAddress:function(a,b){var c=this.getChildValue(b);c&&(a.email=c)},read_wmc_DataURL:function(a,b){a.dataURL=this.getOnlineResource_href(b)},read_wmc_LegendURL:function(a,b){var c={width:b.getAttribute("width"),height:b.getAttribute("height"),format:b.getAttribute("format"),
+href:this.getOnlineResource_href(b)};a.legend=c},read_wmc_DimensionList:function(a,b){a.dimensions={};this.runChildNodes(a.dimensions,b)},read_wmc_Dimension:function(a,b){var c={name:b.getAttribute("name").toLowerCase(),units:b.getAttribute("units")||"",unitSymbol:b.getAttribute("unitSymbol")||"",userValue:b.getAttribute("userValue")||"",nearestValue:"1"===b.getAttribute("nearestValue"),multipleValues:"1"===b.getAttribute("multipleValues"),current:"1"===b.getAttribute("current"),"default":b.getAttribute("default")||
+""},d=this.getChildValue(b);c.values=d.split(",");a[c.name]=c},write:function(a,b){var c=this.createElementDefaultNS("ViewContext");this.setAttributes(c,{version:this.VERSION,id:b&&"string"==typeof b.id?b.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(c,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);c.appendChild(this.write_wmc_General(a));c.appendChild(this.write_wmc_LayerList(a));return OpenLayers.Format.XML.prototype.write.apply(this,[c])},createElementDefaultNS:function(a,
+b,c){a=this.createElementNS(this.namespaces[this.defaultPrefix],a);b&&a.appendChild(this.createTextNode(b));c&&this.setAttributes(a,c);return a},setAttributes:function(a,b){var c,d;for(d in b)c=b[d].toString(),c.match(/[A-Z]/)?this.setAttributeNS(a,null,d,c):a.setAttribute(d,c)},write_wmc_General:function(a){var b=this.createElementDefaultNS("General");a.size&&b.appendChild(this.createElementDefaultNS("Window",null,{width:a.size.w,height:a.size.h}));var c=a.bounds;b.appendChild(this.createElementDefaultNS("BoundingBox",
+null,{minx:c.left.toPrecision(18),miny:c.bottom.toPrecision(18),maxx:c.right.toPrecision(18),maxy:c.top.toPrecision(18),SRS:a.projection}));b.appendChild(this.createElementDefaultNS("Title",a.title));a.keywords&&b.appendChild(this.write_wmc_KeywordList(a.keywords));a["abstract"]&&b.appendChild(this.createElementDefaultNS("Abstract",a["abstract"]));a.logo&&b.appendChild(this.write_wmc_URLType("LogoURL",a.logo.href,a.logo));a.descriptionURL&&b.appendChild(this.write_wmc_URLType("DescriptionURL",a.descriptionURL));
+a.contactInformation&&b.appendChild(this.write_wmc_ContactInformation(a.contactInformation));b.appendChild(this.write_ol_MapExtension(a));return b},write_wmc_KeywordList:function(a){for(var b=this.createElementDefaultNS("KeywordList"),c=0,d=a.length;c<d;c++)b.appendChild(this.createElementDefaultNS("Keyword",a[c]));return b},write_wmc_ContactInformation:function(a){var b=this.createElementDefaultNS("ContactInformation");a.personPrimary&&b.appendChild(this.write_wmc_ContactPersonPrimary(a.personPrimary));
+a.position&&b.appendChild(this.createElementDefaultNS("ContactPosition",a.position));a.contactAddress&&b.appendChild(this.write_wmc_ContactAddress(a.contactAddress));a.phone&&b.appendChild(this.createElementDefaultNS("ContactVoiceTelephone",a.phone));a.fax&&b.appendChild(this.createElementDefaultNS("ContactFacsimileTelephone",a.fax));a.email&&b.appendChild(this.createElementDefaultNS("ContactElectronicMailAddress",a.email));return b},write_wmc_ContactPersonPrimary:function(a){var b=this.createElementDefaultNS("ContactPersonPrimary");
+a.person&&b.appendChild(this.createElementDefaultNS("ContactPerson",a.person));a.organization&&b.appendChild(this.createElementDefaultNS("ContactOrganization",a.organization));return b},write_wmc_ContactAddress:function(a){var b=this.createElementDefaultNS("ContactAddress");a.type&&b.appendChild(this.createElementDefaultNS("AddressType",a.type));a.address&&b.appendChild(this.createElementDefaultNS("Address",a.address));a.city&&b.appendChild(this.createElementDefaultNS("City",a.city));a.stateOrProvince&&
+b.appendChild(this.createElementDefaultNS("StateOrProvince",a.stateOrProvince));a.postcode&&b.appendChild(this.createElementDefaultNS("PostCode",a.postcode));a.country&&b.appendChild(this.createElementDefaultNS("Country",a.country));return b},write_ol_MapExtension:function(a){var b=this.createElementDefaultNS("Extension");if(a=a.maxExtent){var c=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(c,{minx:a.left.toPrecision(18),miny:a.bottom.toPrecision(18),maxx:a.right.toPrecision(18),
+maxy:a.top.toPrecision(18)});b.appendChild(c)}return b},write_wmc_LayerList:function(a){for(var b=this.createElementDefaultNS("LayerList"),c=0,d=a.layersContext.length;c<d;++c)b.appendChild(this.write_wmc_Layer(a.layersContext[c]));return b},write_wmc_Layer:function(a){var b=this.createElementDefaultNS("Layer",null,{queryable:a.queryable?"1":"0",hidden:a.visibility?"0":"1"});b.appendChild(this.write_wmc_Server(a));b.appendChild(this.createElementDefaultNS("Name",a.name));b.appendChild(this.createElementDefaultNS("Title",
+a.title));a["abstract"]&&b.appendChild(this.createElementDefaultNS("Abstract",a["abstract"]));a.dataURL&&b.appendChild(this.write_wmc_URLType("DataURL",a.dataURL));a.metadataURL&&b.appendChild(this.write_wmc_URLType("MetadataURL",a.metadataURL));return b},write_wmc_LayerExtension:function(a){var b=this.createElementDefaultNS("Extension"),c=a.maxExtent,d=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(d,{minx:c.left.toPrecision(18),miny:c.bottom.toPrecision(18),maxx:c.right.toPrecision(18),
+maxy:c.top.toPrecision(18)});b.appendChild(d);a.tileSize&&!a.singleTile&&(c=this.createElementNS(this.namespaces.ol,"ol:tileSize"),this.setAttributes(c,a.tileSize),b.appendChild(c));for(var c="transparent numZoomLevels units isBaseLayer opacity displayInLayerSwitcher singleTile".split(" "),e=0,f=c.length;e<f;++e)(d=this.createOLPropertyNode(a,c[e]))&&b.appendChild(d);return b},createOLPropertyNode:function(a,b){var c=null;null!=a[b]&&(c=this.createElementNS(this.namespaces.ol,"ol:"+b),c.appendChild(this.createTextNode(a[b].toString())));
+return c},write_wmc_Server:function(a){a=a.server;var b=this.createElementDefaultNS("Server"),c={service:"OGC:WMS",version:a.version};a.title&&(c.title=a.title);this.setAttributes(b,c);b.appendChild(this.write_wmc_OnlineResource(a.url));return b},write_wmc_URLType:function(a,b,c){a=this.createElementDefaultNS(a);a.appendChild(this.write_wmc_OnlineResource(b));if(c){b=["width","height","format"];for(var d=0;d<b.length;d++)b[d]in c&&a.setAttribute(b[d],c[b[d]])}return a},write_wmc_DimensionList:function(a){var b=
+this.createElementDefaultNS("DimensionList"),c;for(c in a.dimensions){var d={},e=a.dimensions[c],f;for(f in e)d[f]="boolean"==typeof e[f]?Number(e[f]):e[f];e="";d.values&&(e=d.values.join(","),delete d.values);b.appendChild(this.createElementDefaultNS("Dimension",e,d))}return b},write_wmc_FormatList:function(a){for(var b=this.createElementDefaultNS("FormatList"),c=0,d=a.formats.length;c<d;c++){var e=a.formats[c];b.appendChild(this.createElementDefaultNS("Format",e.value,e.current&&!0==e.current?{current:"1"}:
+null))}return b},write_wmc_StyleList:function(a){var b=this.createElementDefaultNS("StyleList");if((a=a.styles)&&OpenLayers.Util.isArray(a))for(var c,d=0,e=a.length;d<e;d++){var f=a[d],g=this.createElementDefaultNS("Style",null,f.current&&!0==f.current?{current:"1"}:null);f.href?(c=this.createElementDefaultNS("SLD"),f.name&&c.appendChild(this.createElementDefaultNS("Name",f.name)),f.title&&c.appendChild(this.createElementDefaultNS("Title",f.title)),f.legend&&c.appendChild(this.write_wmc_URLType("LegendURL",
+f.legend.href,f.legend)),f=this.write_wmc_OnlineResource(f.href),c.appendChild(f),g.appendChild(c)):f.body?(c=this.createElementDefaultNS("SLD"),f.name&&c.appendChild(this.createElementDefaultNS("Name",f.name)),f.title&&c.appendChild(this.createElementDefaultNS("Title",f.title)),f.legend&&c.appendChild(this.write_wmc_URLType("LegendURL",f.legend.href,f.legend)),f=OpenLayers.Format.XML.prototype.read.apply(this,[f.body]).documentElement,c.ownerDocument&&c.ownerDocument.importNode&&(f=c.ownerDocument.importNode(f,
+!0)),c.appendChild(f),g.appendChild(c)):(g.appendChild(this.createElementDefaultNS("Name",f.name)),g.appendChild(this.createElementDefaultNS("Title",f.title)),f["abstract"]&&g.appendChild(this.createElementDefaultNS("Abstract",f["abstract"])),f.legend&&g.appendChild(this.write_wmc_URLType("LegendURL",f.legend.href,f.legend)));b.appendChild(g)}return b},write_wmc_OnlineResource:function(a){var b=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(b,this.namespaces.xlink,"xlink:type",
+"simple");this.setAttributeNS(b,this.namespaces.xlink,"xlink:href",a);return b},getOnlineResource_href:function(a){var b={};a=a.getElementsByTagName("OnlineResource");0<a.length&&this.read_wmc_OnlineResource(b,a[0]);return b.href},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Control.PanPanel=OpenLayers.Class(OpenLayers.Control.Panel,{slideFactor:50,slideRatio:null,initialize:function(a){OpenLayers.Control.Panel.prototype.initialize.apply(this,[a]);a={slideFactor:this.slideFactor,slideRatio:this.slideRatio};this.addControls([new OpenLayers.Control.Pan(OpenLayers.Control.Pan.NORTH,a),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.SOUTH,a),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.EAST,a),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.WEST,a)])},
+CLASS_NAME:"OpenLayers.Control.PanPanel"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",template:"${layers}",destroy:function(){this.map.events.un({removelayer:this.updateAttribution,addlayer:this.updateAttribution,changelayer:this.updateAttribution,changebaselayer:this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({changebaselayer:this.updateAttribution,changelayer:this.updateAttribution,
+addlayer:this.updateAttribution,removelayer:this.updateAttribution,scope:this});this.updateAttribution();return this.div},updateAttribution:function(){var a=[];if(this.map&&this.map.layers){for(var b=0,c=this.map.layers.length;b<c;b++){var d=this.map.layers[b];d.attribution&&d.getVisibility()&&-1===OpenLayers.Util.indexOf(a,d.attribution)&&a.push(d.attribution)}this.div.innerHTML=OpenLayers.String.format(this.template,{layers:a.join(this.separator)})}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Kinetic=OpenLayers.Class({threshold:0,deceleration:0.0035,nbPoints:100,delay:200,points:void 0,timerId:void 0,initialize:function(a){OpenLayers.Util.extend(this,a)},begin:function(){OpenLayers.Animation.stop(this.timerId);this.timerId=void 0;this.points=[]},update:function(a){this.points.unshift({xy:a,tick:(new Date).getTime()});this.points.length>this.nbPoints&&this.points.pop()},end:function(a){for(var b,c=(new Date).getTime(),d=0,e=this.points.length,f;d<e;d++){f=this
.points[d];if(c-
+f.tick>this.delay)break;b=f}if(b&&(d=(new Date).getTime()-b.tick,c=Math.sqrt(Math.pow(a.x-b.xy.x,2)+Math.pow(a.y-b.xy.y,2)),d=c/d,!(0==d||d<this.threshold)))return c=Math.asin((a.y-b.xy.y)/c),b.xy.x<=a.x&&(c=Math.PI-c),{speed:d,theta:c}},move:function(a,b){var c=a.speed,d=Math.cos(a.theta),e=-Math.sin(a.theta),f=(new Date).getTime(),g=0,h=0;this.timerId=OpenLayers.Animation.start(OpenLayers.Function.bind(function(){if(null!=this.timerId){var a=(new Date).getTime()-f,l=-this.deceleration*Math.pow(a,
+2)/2+c*a,m=l*d,l=l*e,n,p;n=!1;0>=-this.deceleration*a+c&&(OpenLayers.Animation.stop(this.timerId),this.timerId=null,n=!0);a=m-g;p=l-h;g=m;h=l;b(a,p,n)}},this))},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Format.WPSExecute=OpenLayers.Class(OpenLayers.Format.XML,OpenLayers.Format.Filter.v1_1_0,{namespaces:{ows:"http://www.opengis.net/ows/1.1",gml:"http://www.opengis.net/gml",wps:"http://www.opengis.net/wps/1.0.0",wfs:"http://www.opengis.net/wfs",ogc:"http://www.opengis.net/ogc",wcs:"http://www.opengis.net/wcs",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},VERSION:"1.0.0",
+schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",schemaLocationAttr:function(a){},write:function(a){var b;window.ActiveXObject?this.xmldom=b=new ActiveXObject("Microsoft.XMLDOM"):b=document.implementation.createDocument("","",null);a=this.writeNode("wps:Execute",a,b);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[a])},read:function(a){"string"==typeof a&&(a=
+OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,b);return b},writers:{wps:{Execute:function(a){var b=this.createElementNSPlus("wps:Execute",{attributes:{version:this.VERSION,service:"WPS"}});this.writeNode("ows:Identifier",a.identifier,b);this.writeNode("wps:DataInputs",a.dataInputs,b);this.writeNode("wps:ResponseForm",a.responseForm,b);return b},ResponseForm:function(a){var b=this.createElementNSPlus("wps:ResponseForm",{});a.rawDataOutput&&
+this.writeNode("wps:RawDataOutput",a.rawDataOutput,b);a.responseDocument&&this.writeNode("wps:ResponseDocument",a.responseDocument,b);return b},ResponseDocument:function(a){var b=this.createElementNSPlus("wps:ResponseDocument",{attributes:{storeExecuteResponse:a.storeExecuteResponse,lineage:a.lineage,status:a.status}});if(a.outputs)for(var c=0,d=a.outputs.length;c<d;c++)this.writeNode("wps:Output",a.outputs[c],b);return b},Output:function(a){var b=this.createElementNSPlus("wps:Output",{attributes:{asReference:a.asReference,
+mimeType:a.mimeType,encoding:a.encoding,schema:a.schema}});this.writeNode("ows:Identifier",a.identifier,b);this.writeNode("ows:Title",a.title,b);this.writeNode("ows:Abstract",a["abstract"],b);return b},RawDataOutput:function(a){var b=this.createElementNSPlus("wps:RawDataOutput",{attributes:{mimeType:a.mimeType,encoding:a.encoding,schema:a.schema}});this.writeNode("ows:Identifier",a.identifier,b);return b},DataInputs:function(a){for(var b=this.createElementNSPlus("wps:DataInputs",{}),c=0,d=a.length;c<
+d;++c)this.writeNode("wps:Input",a[c],b);return b},Input:function(a){var b=this.createElementNSPlus("wps:Input",{});this.writeNode("ows:Identifier",a.identifier,b);a.title&&this.writeNode("ows:Title",a.title,b);a.data&&this.writeNode("wps:Data",a.data,b);a.reference&&this.writeNode("wps:Reference",a.reference,b);a.boundingBoxData&&this.writeNode("wps:BoundingBoxData",a.boundingBoxData,b);return b},Data:function(a){var b=this.createElementNSPlus("wps:Data",{});a.literalData?this.writeNode("wps:LiteralData",
+a.literalData,b):a.complexData?this.writeNode("wps:ComplexData",a.complexData,b):a.boundingBoxData&&this.writeNode("ows:BoundingBox",a.boundingBoxData,b);return b},LiteralData:function(a){return this.createElementNSPlus("wps:LiteralData",{attributes:{uom:a.uom},value:a.value})},ComplexData:function(a){var b=this.createElementNSPlus("wps:ComplexData",{attributes:{mimeType:a.mimeType,encoding:a.encoding,schema:a.schema}}),c=a.value;"string"===typeof c?b.appendChild(this.getXMLDoc().createCDATASection(a.value)):
+b.appendChild(c);return b},Reference:function(a){var b=this.createElementNSPlus("wps:Reference",{attributes:{mimeType:a.mimeType,"xlink:href":a.href,method:a.method,encoding:a.encoding,schema:a.schema}});a.body&&this.writeNode("wps:Body",a.body,b);return b},BoundingBoxData:function(a,b){this.writers.ows.BoundingBox.apply(this,[a,b,"wps:BoundingBoxData"])},Body:function(a){var b=this.createElementNSPlus("wps:Body",{});a.wcs?this.writeNode("wcs:GetCoverage",a.wcs,b):a.wfs?(this.featureType=a.wfs.featureType,
+this.version=a.wfs.version,this.writeNode("wfs:GetFeature",a.wfs,b)):this.writeNode("wps:Execute",a,b);return b}},wcs:OpenLayers.Format.WCSGetCoverage.prototype.writers.wcs,wfs:OpenLayers.Format.WFST.v1_1_0.prototype.writers.wfs,ogc:OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc,ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows},readers:{wps:{ExecuteResponse:function(a,b){b.executeResponse={lang:a.getAttribute("lang"),statusLocation:a.getAttribute("statusLocation"),serviceInstance:a.getAttribute("serviceInstance"),
+service:a.getAttribute("service")};this.readChildNodes(a,b.executeResponse)},Process:function(a,b){b.process={};this.readChildNodes(a,b.process)},Status:function(a,b){b.status={creationTime:a.getAttribute("creationTime")};this.readChildNodes(a,b.status)},ProcessSucceeded:function(a,b){b.processSucceeded=!0},ProcessOutputs:function(a,b){b.processOutputs=[];this.readChildNodes(a,b.processOutputs)},Output:function(a,b){var c={};this.readChildNodes(a,c);b.push(c)},Reference:function(a,b){b.reference=
+{href:a.getAttribute("href"),mimeType:a.getAttribute("mimeType"),encoding:a.getAttribute("encoding"),schema:a.getAttribute("schema")}},Data:function(a,b){b.data={};this.readChildNodes(a,b)},LiteralData:function(a,b){b.literalData={dataType:a.getAttribute("dataType"),uom:a.getAttribute("uom"),value:this.getChildValue(a)}},ComplexData:function(a,b){b.complexData={mimeType:a.getAttribute("mimeType"),schema:a.getAttribute("schema"),encoding:a.getAttribute("encoding"),value:""};if(this.isSimpleContent(a)){var c;
+for(c=a.firstChild;c;c=c.nextSibling)switch(c.nodeType){case 3:case 4:b.complexData.value+=c.nodeValue}}else for(c=a.firstChild;c;c=c.nextSibling)1==c.nodeType&&(b.complexData.value=c)},BoundingBox:function(a,b){b.boundingBoxData={dimensions:a.getAttribute("dimensions"),crs:a.getAttribute("crs")};this.readChildNodes(a,b.boundingBoxData)}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WPSExecute"});OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:!0,initialize:function(a,b,c){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[a,c]);this.location=b;this.features=[]},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null},loadRSS:function(){this.loaded||(this.events.triggerEvent("loadstart"),OpenLayers.Request.GET({url:this.location,
+success:this.parseData,scope:this}),this.loaded=!0)},moveTo:function(a,b,c){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);this.visibility&&!this.loaded&&this.loadRSS()},parseData:function(a){var b=a.responseXML;b&&b.documentElement||(b=OpenLayers.Format.XML.prototype.read(a.responseText));if(this.useFeedTitle){a=null;try{a=b.getElementsByTagNameNS("*","title")[0].firstChild.nodeValue}catch(c){a=b.getElementsByTagName("title")[0].firstChild.nodeValue}a&&this.setName(a)}a={};OpenLayers.Util.extend(a,
+this.formatOptions);this.map&&!this.projection.equals(this.map.getProjectionObject())&&(a.externalProjection=this.projection,a.internalProjection=this.map.getProjectionObject());b=(new OpenLayers.Format.GeoRSS(a)).read(b);a=0;for(var d=b.length;a<d;a++){var e={},f=b[a];if(f.geometry){var g=f.attributes.title?f.attributes.title:"Untitled",h=f.attributes.description?f.attributes.description:"No description.",k=f.attributes.link?f.attributes.link:"",f=f.geometry.getBounds().getCenterLonLat();e.icon=
+null==this.icon?OpenLayers.Marker.defaultIcon():this.icon.clone();e.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(g||h){e.title=g;e.description=h;var l='<div class="olLayerGeoRSSClose">[x]</div>',l=l+'<div class="olLayerGeoRSSTitle">';k&&(l+='<a class="link" href="'+k+'" target="_blank">');l+=g;k&&(l+="</a>");l+="</div>";l+='<div style="" class="olLayerGeoRSSDescription">';l+=h;l+="</div>";e.popupContentHTML=l}f=new OpenLayers.Feature(this,f,e);this.features.push(f);
+e=f.createMarker();e.events.register("click",f,this.markerClick);this.addMarker(e)}}this.events.triggerEvent("loadend")},markerClick:function(a){var b=this==this.layer.selectedFeature;this.layer.selectedFeature=b?null:this;for(var c=0,d=this.layer.map.popups.length;c<d;c++)this.layer.map.removePopup(this.layer.map.popups[c]);b||(b=this.createPopup(),OpenLayers.Event.observe(b.div,"click",OpenLayers.Function.bind(function(){for(var a=0,b=this.layer.map.popups.length;a<b;a++)this.layer.map.removePopup(this.layer.map.popups[a])},
+this)),this.layer.map.addPopup(b));OpenLayers.Event.stop(a)},clearFeatures:function(){if(null!=this.features)for(;0<this.features.length;){var a=this.features[0];OpenLayers.Util.removeItem(this.features,a);a.destroy()}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Symbolizer.Point=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Point"});OpenLayers.Symbolizer.Line=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Line"});OpenLayers.Symbolizer.Text=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(a){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments)},CLASS_NAME:"OpenLayers.Symbolizer.Text"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://ww
w.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,multipleSymbolizers:!1,featureTypeCounter:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,strokeDashstyle:"solid",pointRadius:3,
+graphicName:"square"},read:function(a,b){b=OpenLayers.Util.applyDefaults(b,this.options);var c={namedLayers:!0===b.namedLayersAsArray?[]:{}};this.readChildNodes(a,c);return c},readers:OpenLayers.Util.applyDefaults({sld:{StyledLayerDescriptor:function(a,b){b.version=a.getAttribute("version");this.readChildNodes(a,b)},Name:function(a,b){b.name=this.getChildValue(a)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b.description=this.getChildValue(a)},NamedLayer:function(a,b){var c=
+{userStyles:[],namedStyles:[]};this.readChildNodes(a,c);for(var d=0,e=c.userStyles.length;d<e;++d)c.userStyles[d].layerName=c.name;OpenLayers.Util.isArray(b.namedLayers)?b.namedLayers.push(c):b.namedLayers[c.name]=c},NamedStyle:function(a,b){b.namedStyles.push(this.getChildName(a.firstChild))},UserStyle:function(a,b){var c={defaultsPerSymbolizer:!0,rules:[]};this.featureTypeCounter=-1;this.readChildNodes(a,c);this.multipleSymbolizers?(delete c.defaultsPerSymbolizer,c=new OpenLayers.Style2(c)):c=new OpenLayers.Style(this.defaultSymbolizer,
+c);b.userStyles.push(c)},IsDefault:function(a,b){"1"==this.getChildValue(a)&&(b.isDefault=!0)},FeatureTypeStyle:function(a,b){++this.featureTypeCounter;var c={rules:this.multipleSymbolizers?b.rules:[]};this.readChildNodes(a,c);this.multipleSymbolizers||(b.rules=c.rules)},Rule:function(a,b){var c;this.multipleSymbolizers&&(c={symbolizers:[]});c=new OpenLayers.Rule(c);this.readChildNodes(a,c);b.rules.push(c)},ElseFilter:function(a,b){b.elseFilter=!0},MinScaleDenominator:function(a,b){b.minScaleDenominator=
+parseFloat(this.getChildValue(a))},MaxScaleDenominator:function(a,b){b.maxScaleDenominator=parseFloat(this.getChildValue(a))},TextSymbolizer:function(a,b){var c={};this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Text(c))):b.symbolizer.Text=OpenLayers.Util.applyDefaults(c,b.symbolizer.Text)},LabelPlacement:function(a,b){this.readChildNodes(a,b)},PointPlacement:function(a,b){var c={};this.readChildNodes(a,c);c.labelRotation=
+c.rotation;delete c.rotation;var d,e=b.labelAnchorPointX,f=b.labelAnchorPointY;e<=1/3?d="l":e>1/3&&e<2/3?d="c":e>=2/3&&(d="r");f<=1/3?d+="b":f>1/3&&f<2/3?d+="m":f>=2/3&&(d+="t");c.labelAlign=d;OpenLayers.Util.applyDefaults(b,c)},AnchorPoint:function(a,b){this.readChildNodes(a,b)},AnchorPointX:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.labelAnchorPointX=c)},AnchorPointY:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.labelAnchorPointY=c)},Displacement:function(a,
+b){this.readChildNodes(a,b)},DisplacementX:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.labelXOffset=c)},DisplacementY:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.labelYOffset=c)},LinePlacement:function(a,b){this.readChildNodes(a,b)},PerpendicularOffset:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.labelPerpendicularOffset=c)},Label:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.label=c)},Font:function(a,b){this.readChildNodes(a,
+b)},Halo:function(a,b){var c={};this.readChildNodes(a,c);b.haloRadius=c.haloRadius;b.haloColor=c.fillColor;b.haloOpacity=c.fillOpacity},Radius:function(a,b){var c=this.readers.ogc._expression.call(this,a);null!=c&&(b.haloRadius=c)},RasterSymbolizer:function(a,b){var c={};this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Raster(c))):b.symbolizer.Raster=OpenLayers.Util.applyDefaults(c,b.symbolizer.Raster)},Geometry:function(a,
+b){b.geometry={};this.readChildNodes(a,b.geometry)},ColorMap:function(a,b){b.colorMap=[];this.readChildNodes(a,b.colorMap)},ColorMapEntry:function(a,b){var c=a.getAttribute("quantity"),d=a.getAttribute("opacity");b.push({color:a.getAttribute("color"),quantity:null!==c?parseFloat(c):void 0,label:a.getAttribute("label")||void 0,opacity:null!==d?parseFloat(d):void 0})},LineSymbolizer:function(a,b){var c={};this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Line(c))):
+b.symbolizer.Line=OpenLayers.Util.applyDefaults(c,b.symbolizer.Line)},PolygonSymbolizer:function(a,b){var c={fill:!1,stroke:!1};this.multipleSymbolizers||(c=b.symbolizer.Polygon||c);this.readChildNodes(a,c);this.multipleSymbolizers?(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Polygon(c))):b.symbolizer.Polygon=c},PointSymbolizer:function(a,b){var c={fill:!1,stroke:!1,graphic:!1};this.multipleSymbolizers||(c=b.symbolizer.Point||c);this.readChildNodes(a,c);this.multipleSymbolizers?
+(c.zIndex=this.featureTypeCounter,b.symbolizers.push(new OpenLayers.Symbolizer.Point(c))):b.symbolizer.Point=c},Stroke:function(a,b){b.stroke=!0;this.readChildNodes(a,b)},Fill:function(a,b){b.fill=!0;this.readChildNodes(a,b)},CssParameter:function(a,b){var c=a.getAttribute("name"),d=this.cssMap[c];b.label&&("fill"===c?d="fontColor":"fill-opacity"===c&&(d="fontOpacity"));d&&(c=this.readers.ogc._expression.call(this,a))&&(b[d]=c)},Graphic:function(a,b){b.graphic=!0;var c={};this.readChildNodes(a,c);
+for(var d="stroke strokeColor strokeWidth strokeOpacity strokeLinecap fill fillColor fillOpacity graphicName rotation graphicFormat".split(" "),e,f,g=0,h=d.length;g<h;++g)e=d[g],f=c[e],void 0!=f&&(b[e]=f);void 0!=c.opacity&&(b.graphicOpacity=c.opacity);void 0!=c.size&&(isNaN(c.size/2)?b.graphicWidth=c.size:b.pointRadius=c.size/2);void 0!=c.href&&(b.externalGraphic=c.href);void 0!=c.rotation&&(b.rotation=c.rotation)},ExternalGraphic:function(a,b){this.readChildNodes(a,b)},Mark:function(a,b){this.readChildNodes(a,
+b)},WellKnownName:function(a,b){b.graphicName=this.getChildValue(a)},Opacity:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.opacity=c)},Size:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.size=c)},Rotation:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.rotation=c)},OnlineResource:function(a,b){b.href=this.getAttributeNS(a,this.namespaces.xlink,"href")},Format:function(a,b){b.graphicFormat=this.getChildValue(a)}}},OpenLayers.Format.Filter.v1_0_0.prototype.readers),
+cssMap:{stroke:"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","stroke-dasharray":"strokeDashstyle",fill:"fillColor","fill-opacity":"fillOpacity","font-family":"fontFamily","font-size":"fontSize","font-weight":"fontWeight","font-style":"fontStyle"},getCssProperty:function(a){var b=null,c;for(c in this.cssMap)if(this.cssMap[c]==a){b=c;break}return b},getGraphicFormat:function(a){var b,c;for(c in this.graphicFormats)if(this.graphicFormats[c].test(a)){b=
+c;break}return b||this.defaultGraphicFormat},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(a){return this.writers.sld.StyledLayerDescriptor.apply(this,[a])},writers:OpenLayers.Util.applyDefaults({sld:{_OGCExpression:function(a,b){var c=this.createElementNSPlus(a),d="string"==typeof b?b.split("${"):[b];c.appendChild(this.createTextNode(d[0]));for(var e,f,g=1,h=d.length;g<h;g++)e=d[g],f=e.indexOf("}"),0<f?(this.writeNode("ogc:PropertyName",
+{property:e.substring(0,f)},c),c.appendChild(this.createTextNode(e.substring(++f)))):c.appendChild(this.createTextNode("${"+e));return c},StyledLayerDescriptor:function(a){var b=this.createElementNSPlus("sld:StyledLayerDescriptor",{attributes:{version:this.VERSION,"xsi:schemaLocation":this.schemaLocation}});b.setAttribute("xmlns:ogc",this.namespaces.ogc);b.setAttribute("xmlns:gml",this.namespaces.gml);a.name&&this.writeNode("Name",a.name,b);a.title&&this.writeNode("Title",a.title,b);a.description&&
+this.writeNode("Abstract",a.description,b);if(OpenLayers.Util.isArray(a.namedLayers))for(var c=0,d=a.namedLayers.length;c<d;++c)this.writeNode("NamedLayer",a.namedLayers[c],b);else for(c in a.namedLayers)this.writeNode("NamedLayer",a.namedLayers[c],b);return b},Name:function(a){return this.createElementNSPlus("sld:Name",{value:a})},Title:function(a){return this.createElementNSPlus("sld:Title",{value:a})},Abstract:function(a){return this.createElementNSPlus("sld:Abstract",{value:a})},NamedLayer:function(a){var b=
+this.createElementNSPlus("sld:NamedLayer");this.writeNode("Name",a.name,b);if(a.namedStyles)for(var c=0,d=a.namedStyles.length;c<d;++c)this.writeNode("NamedStyle",a.namedStyles[c],b);if(a.userStyles)for(c=0,d=a.userStyles.length;c<d;++c)this.writeNode("UserStyle",a.userStyles[c],b);return b},NamedStyle:function(a){var b=this.createElementNSPlus("sld:NamedStyle");this.writeNode("Name",a,b);return b},UserStyle:function(a){var b=this.createElementNSPlus("sld:UserStyle");a.name&&this.writeNode("Name",
+a.name,b);a.title&&this.writeNode("Title",a.title,b);a.description&&this.writeNode("Abstract",a.description,b);a.isDefault&&this.writeNode("IsDefault",a.isDefault,b);if(this.multipleSymbolizers&&a.rules){for(var c={0:[]},d=[0],e,f,g,h,k,l=0,m=a.rules.length;l<m;++l)if(e=a.rules[l],e.symbolizers){f={};for(var n=0,p=e.symbolizers.length;n<p;++n)g=e.symbolizers[n],h=g.zIndex,h in f||(k=e.clone(),k.symbolizers=[],f[h]=k),f[h].symbolizers.push(g.clone());for(h in f)h in c||(d.push(h),c[h]=[]),c[h].push(f[h])}else c[0].push(e.clone());
+d.sort();l=0;for(m=d.length;l<m;++l)e=c[d[l]],0<e.length&&(k=a.clone(),k.rules=c[d[l]],this.writeNode("FeatureTypeStyle",k,b))}else this.writeNode("FeatureTypeStyle",a,b);return b},IsDefault:function(a){return this.createElementNSPlus("sld:IsDefault",{value:a?"1":"0"})},FeatureTypeStyle:function(a){for(var b=this.createElementNSPlus("sld:FeatureTypeStyle"),c=0,d=a.rules.length;c<d;++c)this.writeNode("Rule",a.rules[c],b);return b},Rule:function(a){var b=this.createElementNSPlus("sld:Rule");a.name&&
+this.writeNode("Name",a.name,b);a.title&&this.writeNode("Title",a.title,b);a.description&&this.writeNode("Abstract",a.description,b);a.elseFilter?this.writeNode("ElseFilter",null,b):a.filter&&this.writeNode("ogc:Filter",a.filter,b);void 0!=a.minScaleDenominator&&this.writeNode("MinScaleDenominator",a.minScaleDenominator,b);void 0!=a.maxScaleDenominator&&this.writeNode("MaxScaleDenominator",a.maxScaleDenominator,b);var c,d;if(this.multipleSymbolizers&&a.symbolizers)for(var e=0,f=a.symbolizers.length;e<
+f;++e)d=a.symbolizers[e],c=d.CLASS_NAME.split(".").pop(),this.writeNode(c+"Symbolizer",d,b);else for(var f=OpenLayers.Style.SYMBOLIZER_PREFIXES,e=0,g=f.length;e<g;++e)c=f[e],(d=a.symbolizer[c])&&this.writeNode(c+"Symbolizer",d,b);return b},ElseFilter:function(){return this.createElementNSPlus("sld:ElseFilter")},MinScaleDenominator:function(a){return this.createElementNSPlus("sld:MinScaleDenominator",{value:a})},MaxScaleDenominator:function(a){return this.createElementNSPlus("sld:MaxScaleDenominator",
+{value:a})},LineSymbolizer:function(a){var b=this.createElementNSPlus("sld:LineSymbolizer");this.writeNode("Stroke",a,b);return b},Stroke:function(a){var b=this.createElementNSPlus("sld:Stroke");void 0!=a.strokeColor&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeColor"},b);void 0!=a.strokeOpacity&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeOpacity"},b);void 0!=a.strokeWidth&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeWidth"},b);void 0!=a.strokeDashstyle&&"solid"!==
+a.strokeDashstyle&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeDashstyle"},b);void 0!=a.strokeLinecap&&this.writeNode("CssParameter",{symbolizer:a,key:"strokeLinecap"},b);return b},CssParameter:function(a){return this.createElementNSPlus("sld:CssParameter",{attributes:{name:this.getCssProperty(a.key)},value:a.symbolizer[a.key]})},TextSymbolizer:function(a){var b=this.createElementNSPlus("sld:TextSymbolizer");null!=a.label&&this.writeNode("Label",a.label,b);null==a.fontFamily&&null==a.fontSize&&
+null==a.fontWeight&&null==a.fontStyle||this.writeNode("Font",a,b);null==a.labelAnchorPointX&&null==a.labelAnchorPointY&&null==a.labelAlign&&null==a.labelXOffset&&null==a.labelYOffset&&null==a.labelRotation&&null==a.labelPerpendicularOffset||this.writeNode("LabelPlacement",a,b);null==a.haloRadius&&null==a.haloColor&&null==a.haloOpacity||this.writeNode("Halo",a,b);null==a.fontColor&&null==a.fontOpacity||this.writeNode("Fill",{fillColor:a.fontColor,fillOpacity:a.fontOpacity},b);return b},LabelPlacement:function(a){var b=
+this.createElementNSPlus("sld:LabelPlacement");null==a.labelAnchorPointX&&null==a.labelAnchorPointY&&null==a.labelAlign&&null==a.labelXOffset&&null==a.labelYOffset&&null==a.labelRotation||null!=a.labelPerpendicularOffset||this.writeNode("PointPlacement",a,b);null!=a.labelPerpendicularOffset&&this.writeNode("LinePlacement",a,b);return b},LinePlacement:function(a){var b=this.createElementNSPlus("sld:LinePlacement");this.writeNode("PerpendicularOffset",a.labelPerpendicularOffset,b);return b},PerpendicularOffset:function(a){return this.createElementNSPlus("sld:PerpendicularOffset",
+{value:a})},PointPlacement:function(a){var b=this.createElementNSPlus("sld:PointPlacement");null==a.labelAnchorPointX&&null==a.labelAnchorPointY&&null==a.labelAlign||this.writeNode("AnchorPoint",a,b);null==a.labelXOffset&&null==a.labelYOffset||this.writeNode("Displacement",a,b);null!=a.labelRotation&&this.writeNode("Rotation",a.labelRotation,b);return b},AnchorPoint:function(a){var b=this.createElementNSPlus("sld:AnchorPoint"),c=a.labelAnchorPointX,d=a.labelAnchorPointY;null!=c&&this.writeNode("AnchorPointX",
+c,b);null!=d&&this.writeNode("AnchorPointY",d,b);if(null==c&&null==d){var e=a.labelAlign.substr(0,1);a=a.labelAlign.substr(1,1);"l"===e?c=0:"c"===e?c=0.5:"r"===e&&(c=1);"b"===a?d=0:"m"===a?d=0.5:"t"===a&&(d=1);this.writeNode("AnchorPointX",c,b);this.writeNode("AnchorPointY",d,b)}return b},AnchorPointX:function(a){return this.createElementNSPlus("sld:AnchorPointX",{value:a})},AnchorPointY:function(a){return this.createElementNSPlus("sld:AnchorPointY",{value:a})},Displacement:function(a){var b=this.createElementNSPlus("sld:Displacement");
+null!=a.labelXOffset&&this.writeNode("DisplacementX",a.labelXOffset,b);null!=a.labelYOffset&&this.writeNode("DisplacementY",a.labelYOffset,b);return b},DisplacementX:function(a){return this.createElementNSPlus("sld:DisplacementX",{value:a})},DisplacementY:function(a){return this.createElementNSPlus("sld:DisplacementY",{value:a})},Font:function(a){var b=this.createElementNSPlus("sld:Font");a.fontFamily&&this.writeNode("CssParameter",{symbolizer:a,key:"fontFamily"},b);a.fontSize&&this.writeNode("CssParameter",
+{symbolizer:a,key:"fontSize"},b);a.fontWeight&&this.writeNode("CssParameter",{symbolizer:a,key:"fontWeight"},b);a.fontStyle&&this.writeNode("CssParameter",{symbolizer:a,key:"fontStyle"},b);return b},Label:function(a){return this.writers.sld._OGCExpression.call(this,"sld:Label",a)},Halo:function(a){var b=this.createElementNSPlus("sld:Halo");a.haloRadius&&this.writeNode("Radius",a.haloRadius,b);(a.haloColor||a.haloOpacity)&&this.writeNode("Fill",{fillColor:a.haloColor,fillOpacity:a.haloOpacity},b);
+return b},Radius:function(a){return this.createElementNSPlus("sld:Radius",{value:a})},RasterSymbolizer:function(a){var b=this.createElementNSPlus("sld:RasterSymbolizer");a.geometry&&this.writeNode("Geometry",a.geometry,b);a.opacity&&this.writeNode("Opacity",a.opacity,b);a.colorMap&&this.writeNode("ColorMap",a.colorMap,b);return b},Geometry:function(a){var b=this.createElementNSPlus("sld:Geometry");a.property&&this.writeNode("ogc:PropertyName",a,b);return b},ColorMap:function(a){for(var b=this.createElementNSPlus("sld:ColorMap"),
+c=0,d=a.length;c<d;++c)this.writeNode("ColorMapEntry",a[c],b);return b},ColorMapEntry:function(a){var b=this.createElementNSPlus("sld:ColorMapEntry");b.setAttribute("color",a.color);void 0!==a.opacity&&b.setAttribute("opacity",parseFloat(a.opacity));void 0!==a.quantity&&b.setAttribute("quantity",parseFloat(a.quantity));void 0!==a.label&&b.setAttribute("label",a.label);return b},PolygonSymbolizer:function(a){var b=this.createElementNSPlus("sld:PolygonSymbolizer");!1!==a.fill&&this.writeNode("Fill",
+a,b);!1!==a.stroke&&this.writeNode("Stroke",a,b);return b},Fill:function(a){var b=this.createElementNSPlus("sld:Fill");a.fillColor&&this.writeNode("CssParameter",{symbolizer:a,key:"fillColor"},b);null!=a.fillOpacity&&this.writeNode("CssParameter",{symbolizer:a,key:"fillOpacity"},b);return b},PointSymbolizer:function(a){var b=this.createElementNSPlus("sld:PointSymbolizer");this.writeNode("Graphic",a,b);return b},Graphic:function(a){var b=this.createElementNSPlus("sld:Graphic");void 0!=a.externalGraphic?
+this.writeNode("ExternalGraphic",a,b):this.writeNode("Mark",a,b);void 0!=a.graphicOpacity&&this.writeNode("Opacity",a.graphicOpacity,b);void 0!=a.pointRadius?this.writeNode("Size",2*a.pointRadius,b):void 0!=a.graphicWidth&&this.writeNode("Size",a.graphicWidth,b);void 0!=a.rotation&&this.writeNode("Rotation",a.rotation,b);return b},ExternalGraphic:function(a){var b=this.createElementNSPlus("sld:ExternalGraphic");this.writeNode("OnlineResource",a.externalGraphic,b);a=a.graphicFormat||this.getGraphicFormat(a.externalGraphic);
+this.writeNode("Format",a,b);return b},Mark:function(a){var b=this.createElementNSPlus("sld:Mark");a.graphicName&&this.writeNode("WellKnownName",a.graphicName,b);!1!==a.fill&&this.writeNode("Fill",a,b);!1!==a.stroke&&this.writeNode("Stroke",a,b);return b},WellKnownName:function(a){return this.createElementNSPlus("sld:WellKnownName",{value:a})},Opacity:function(a){return this.createElementNSPlus("sld:Opacity",{value:a})},Size:function(a){return this.writers.sld._OGCExpression.call(this,"sld:Size",
+a)},Rotation:function(a){return this.createElementNSPlus("sld:Rotation",{value:a})},OnlineResource:function(a){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":a}})},Format:function(a){return this.createElementNSPlus("sld:Format",{value:a})}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",format:"image/jpeg"},isBaseLayer:!0,encodeBBOX:!1,noMagic:!1,yx:{},initialize:function(a,b,c,d){var e=[];c=OpenLayers.Util.upperCaseObject(c);1.3<=parseFloat(c.VERSION)&&!c.EXCEPTIONS&&(c.EXCEPTIONS="INIMAGE");e.push(a,b,c,d);OpenLayers.Layer.Grid.prototype.initialize.apply(this,e);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));
+!this.noMagic&&(this.params.TRANSPARENT&&"true"==this.params.TRANSPARENT.toString().toLowerCase())&&(null!=d&&d.isBaseLayer||(this.isBaseLayer=!1),"image/jpeg"==this.params.FORMAT&&(this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png"))},clone:function(a){null==a&&(a=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},reverseAxisOrder:function(){var a=this.projection.getCode();return 1.3<=parseFloat(this.params.VERSION)&&
+!!(this.yx[a]||OpenLayers.Projection.defaults[a]&&OpenLayers.Projection.defaults[a].yx)},getURL:function(a){a=this.adjustBounds(a);var b=this.getImageSize(),c={},d=this.reverseAxisOrder();c.BBOX=this.encodeBBOX?a.toBBOX(null,d):a.toArray(d);c.WIDTH=b.w;c.HEIGHT=b.h;return this.getFullRequestString(c)},mergeNewParams:function(a){a=[OpenLayers.Util.upperCaseObject(a)];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,a)},getFullRequestString:function(a,b){var c=this.map.getProjectionObject(),
+c=this.projection&&this.projection.equals(c)?this.projection.getCode():c.getCode(),c="none"==c?null:c;1.3<=parseFloat(this.params.VERSION)?this.params.CRS=c:this.params.SRS=c;"boolean"==typeof this.params.TRANSPARENT&&(a.TRANSPARENT=this.params.TRANSPARENT?"TRUE":"FALSE");return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments)},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,DEFAULT_PARAMS:{i:"jpeg",map:""},initialize:function(a,b,c,d){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS)},getURL:function(a){a=this.adjustBounds(a);var b=this.map.getResolution(),c=Math.round(1E4*this.map.getScale())/1E4,d=Math.round(a.left/b);a=-Math.round(a.top/b);return this.getFullRequestString({t:a,l:d,s:c})},calculateGridLayout:function(a,
+b,c){b=c*this.tileSize.w;c*=this.tileSize.h;return{tilelon:b,tilelat:c,startcol:Math.floor(a.left/b)-this.buffer,startrow:Math.floor(a.top/c)+this.buffer}},getTileBoundsForGridIndex:function(a,b){this.getTileOrigin();var c=this.gridLayout,d=c.tilelon,e=c.tilelat,f=(c.startcol+b)*d,c=(c.startrow-a)*e;return new OpenLayers.Bounds(f,c,f+d,c+e)},clone:function(a){null==a&&(a=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.getOptions()));a=OpenLayers.Layer.Grid.prototype.clone.apply(this,
+[a]);null!=this.tileSize&&(a.tileSize=this.tileSize.clone());a.grid=[];return a},getTileBounds:function(a){var b=this.getResolution(),c=b*this.tileSize.w,b=b*this.tileSize.h,d=this.getLonLatFromViewPortPx(a);a=c*Math.floor(d.lon/c);d=b*Math.floor(d.lat/b);return new OpenLayers.Bounds(a,d,a+c,d+b)},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(a){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[a])},read_sld_MinScaleDenominator:function(a,b){var c=parseFloat(this.getChildValue(b));0<c&&(a.maxScale=c)},read_sld_MaxScaleDenominator:function(a,b){a.minScale=parseFloat(this.getChildValue(b))},read_wmc_SRS:function(a,b){"srs"in
+a||(a.srs={});a.srs[this.getChildValue(b)]=!0},write_wmc_Layer:function(a){var b=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[a]);if(a.maxScale){var c=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");c.appendChild(this.createTextNode(a.maxScale.toPrecision(16)));b.appendChild(c)}a.minScale&&(c=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator"),c.appendChild(this.createTextNode(a.minScale.toPrecision(16))),b.appendChild(c));if(a.srs)for(var d in a.srs)b.appendChild(this.createElementDefaultNS("SRS",
+d));b.appendChild(this.write_wmc_FormatList(a));b.appendChild(this.write_wmc_StyleList(a));a.dimensions&&b.appendChild(this.write_wmc_DimensionList(a));b.appendChild(this.write_wmc_LayerExtension(a));return b},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Format.XLS=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.1.0",stringifyOutput:!0,CLASS_NAME:"OpenLayers.Format.XLS"});OpenLayers.Format.XLS.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xls:"http://www.opengis.net/xls",gml:"http://www.opengis.net/gml",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},xy:!0,defaultPrefix:"xls",schemaLocation:null,read:function(a,b){OpenLayers.Util.applyDefaults(b,this.options);var c={};this.readChildNodes(a,c);return c},readers:{xls:{XLS:function(a,b){b.version=a.getAttribute("version");
+this.readChildNodes(a,b)},Response:function(a,b){this.readChildNodes(a,b)},GeocodeResponse:function(a,b){b.responseLists=[];this.readChildNodes(a,b)},GeocodeResponseList:function(a,b){var c={features:[],numberOfGeocodedAddresses:parseInt(a.getAttribute("numberOfGeocodedAddresses"))};b.responseLists.push(c);this.readChildNodes(a,c)},GeocodedAddress:function(a,b){var c=new OpenLayers.Feature.Vector;b.features.push(c);this.readChildNodes(a,c);c.geometry=c.components[0]},GeocodeMatchCode:function(a,b){b.attributes.matchCode=
+{accuracy:parseFloat(a.getAttribute("accuracy")),matchType:a.getAttribute("matchType")}},Address:function(a,b){var c={countryCode:a.getAttribute("countryCode"),addressee:a.getAttribute("addressee"),street:[],place:[]};b.attributes.address=c;this.readChildNodes(a,c)},freeFormAddress:function(a,b){b.freeFormAddress=this.getChildValue(a)},StreetAddress:function(a,b){this.readChildNodes(a,b)},Building:function(a,b){b.building={number:a.getAttribute("number"),subdivision:a.getAttribute("subdivision"),
+buildingName:a.getAttribute("buildingName")}},Street:function(a,b){b.street.push(this.getChildValue(a))},Place:function(a,b){b.place[a.getAttribute("type")]=this.getChildValue(a)},PostalCode:function(a,b){b.postalCode=this.getChildValue(a)}},gml:OpenLayers.Format.GML.v3.prototype.readers.gml},write:function(a){return this.writers.xls.XLS.apply(this,[a])},writers:{xls:{XLS:function(a){var b=this.createElementNSPlus("xls:XLS",{attributes:{version:this.VERSION,"xsi:schemaLocation":this.schemaLocation}});
+this.writeNode("RequestHeader",a.header,b);this.writeNode("Request",a,b);return b},RequestHeader:function(a){return this.createElementNSPlus("xls:RequestHeader")},Request:function(a){var b=this.createElementNSPlus("xls:Request",{attributes:{methodName:"GeocodeRequest",requestID:a.requestID||"",version:this.VERSION}});this.writeNode("GeocodeRequest",a.addresses,b);return b},GeocodeRequest:function(a){for(var b=this.createElementNSPlus("xls:GeocodeRequest"),c=0,d=a.length;c<d;c++)this.writeNode("Address",
+a[c],b);return b},Address:function(a){var b=this.createElementNSPlus("xls:Address",{attributes:{countryCode:a.countryCode}});a.freeFormAddress?this.writeNode("freeFormAddress",a.freeFormAddress,b):(a.street&&this.writeNode("StreetAddress",a,b),a.municipality&&this.writeNode("Municipality",a.municipality,b),a.countrySubdivision&&this.writeNode("CountrySubdivision",a.countrySubdivision,b),a.postalCode&&this.writeNode("PostalCode",a.postalCode,b));return b},freeFormAddress:function(a){return this.createElementNSPlus("freeFormAddress",
+{value:a})},StreetAddress:function(a){var b=this.createElementNSPlus("xls:StreetAddress");a.building&&this.writeNode(b,"Building",a.building);a=a.street;OpenLayers.Util.isArray(a)||(a=[a]);for(var c=0,d=a.length;c<d;c++)this.writeNode("Street",a[c],b);return b},Building:function(a){return this.createElementNSPlus("xls:Building",{attributes:{number:a.number,subdivision:a.subdivision,buildingName:a.buildingName}})},Street:function(a){return this.createElementNSPlus("xls:Street",{value:a})},Municipality:function(a){return this.createElementNSPlus("xls:Place",
+{attributes:{type:"Municipality"},value:a})},CountrySubdivision:function(a){return this.createElementNSPlus("xls:Place",{attributes:{type:"CountrySubdivision"},value:a})},PostalCode:function(a){return this.createElementNSPlus("xls:PostalCode",{value:a})}}},CLASS_NAME:"OpenLayers.Format.XLS.v1"});OpenLayers.Format.XLS.v1_1_0=OpenLayers.Class(OpenLayers.Format.XLS.v1,{VERSION:"1.1",schemaLocation:"http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd",CLASS_NAME:"OpenLayers.Format.XLS.v1_1_0"});OpenLayers.Format.XLS.v1_1=OpenLayers.Format.XLS.v1_1_0;OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15E3,translationParameters:null,symbolMetrics:null,initialize:function(a){this.supported()&&(OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments),this.translationParameters={x:0,y:0},this.symbolMetrics={})},supported:functio
n(){return document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#SVG",
+"1.1")||document.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#BasicStructure","1.1"))},inValidRange:function(a,b,c){a+=c?0:this.translationParameters.x;b+=c?0:this.translationParameters.y;return a>=-this.MAX_PIXEL&&a<=this.MAX_PIXEL&&b>=-this.MAX_PIXEL&&b<=this.MAX_PIXEL},setExtent:function(a,b){var c=OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments),d=this.getResolution(),e=-a.left/d,d=a.top/d;if(b)return this.left=e,this.top=d,this.rendererRoot.setAttributeNS(null,
+"viewBox","0 0 "+this.size.w+" "+this.size.h),this.translate(this.xOffset,0),!0;(e=this.translate(e-this.left+this.xOffset,d-this.top))||this.setExtent(a,!0);return c&&e},translate:function(a,b){if(this.inValidRange(a,b,!0)){var c="";if(a||b)c="translate("+a+","+b+")";this.root.setAttributeNS(null,"transform",c);this.translationParameters={x:a,y:b};return!0}return!1},setSize:function(a){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);
+this.rendererRoot.setAttributeNS(null,"height",this.size.h)},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"image":this.isComplexSymbol(b.graphicName)?"svg":"circle";break;case "OpenLayers.Geometry.Rectangle":c="rect";break;case "OpenLayers.Geometry.LineString":c="polyline";break;case "OpenLayers.Geometry.LinearRing":c="polygon";break;case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":c="path"}return c},setStyle:function(a,
+b,c){b=b||a._style;c=c||a._options;var d=b.title||b.graphicTitle;if(d){a.setAttributeNS(null,"title",d);var e=a.getElementsByTagName("title");0<e.length?e[0].firstChild.textContent=d:(e=this.nodeFactory(null,"title"),e.textContent=d,a.appendChild(e))}var e=parseFloat(a.getAttributeNS(null,"r")),d=1,f;if("OpenLayers.Geometry.Point"==a._geometryClass&&e){a.style.visibility="";if(!1===b.graphic)a.style.visibility="hidden";else if(b.externalGraphic){f=this.getPosition(a);b.graphicWidth&&b.graphicHeight&&
+a.setAttributeNS(null,"preserveAspectRatio","none");var e=b.graphicWidth||b.graphicHeight,g=b.graphicHeight||b.graphicWidth,e=e?e:2*b.pointRadius,g=g?g:2*b.pointRadius,h=void 0!=b.graphicYOffset?b.graphicYOffset:-(0.5*g),k=b.graphicOpacity||b.fillOpacity;a.setAttributeNS(null,"x",(f.x+(void 0!=b.graphicXOffset?b.graphicXOffset:-(0.5*e))).toFixed());a.setAttributeNS(null,"y",(f.y+h).toFixed());a.setAttributeNS(null,"width",e);a.setAttributeNS(null,"height",g);a.setAttributeNS(this.xlinkns,"xlink:href",
+b.externalGraphic);a.setAttributeNS(null,"style","opacity: "+k);a.onclick=OpenLayers.Event.preventDefault}else if(this.isComplexSymbol(b.graphicName)){var e=3*b.pointRadius,g=2*e,l=this.importSymbol(b.graphicName);f=this.getPosition(a);d=3*this.symbolMetrics[l.id][0]/g;h=a.parentNode;k=a.nextSibling;h&&h.removeChild(a);a.firstChild&&a.removeChild(a.firstChild);a.appendChild(l.firstChild.cloneNode(!0));a.setAttributeNS(null,"viewBox",l.getAttributeNS(null,"viewBox"));a.setAttributeNS(null,"width",
+g);a.setAttributeNS(null,"height",g);a.setAttributeNS(null,"x",f.x-e);a.setAttributeNS(null,"y",f.y-e);k?h.insertBefore(a,k):h&&h.appendChild(a)}else a.setAttributeNS(null,"r",b.pointRadius);e=b.rotation;void 0===e&&void 0===a._rotation||!f||(a._rotation=e,e|=0,"svg"!==a.nodeName?a.setAttributeNS(null,"transform","rotate("+e+" "+f.x+" "+f.y+")"):(f=this.symbolMetrics[l.id],a.firstChild.setAttributeNS(null,"transform","rotate("+e+" "+f[1]+" "+f[2]+")")))}c.isFilled?(a.setAttributeNS(null,"fill",b.fillColor),
+a.setAttributeNS(null,"fill-opacity",b.fillOpacity)):a.setAttributeNS(null,"fill","none");c.isStroked?(a.setAttributeNS(null,"stroke",b.strokeColor),a.setAttributeNS(null,"stroke-opacity",b.strokeOpacity),a.setAttributeNS(null,"stroke-width",b.strokeWidth*d),a.setAttributeNS(null,"stroke-linecap",b.strokeLinecap||"round"),a.setAttributeNS(null,"stroke-linejoin","round"),b.strokeDashstyle&&a.setAttributeNS(null,"stroke-dasharray",this.dashStyle(b,d))):a.setAttributeNS(null,"stroke","none");b.pointerEvents&&
+a.setAttributeNS(null,"pointer-events",b.pointerEvents);null!=b.cursor&&a.setAttributeNS(null,"cursor",b.cursor);return a},dashStyle:function(a,b){var c=a.strokeWidth*b,d=a.strokeDashstyle;switch(d){case "solid":return"none";case "dot":return[1,4*c].join();case "dash":return[4*c,4*c].join();case "dashdot":return[4*c,4*c,1,4*c].join();case "longdash":return[8*c,4*c].join();case "longdashdot":return[8*c,4*c,1,4*c].join();default:return OpenLayers.String.trim(d).replace(/\s+/g,",")}},createNode:function(a,
+b){var c=document.createElementNS(this.xmlns,a);b&&c.setAttributeNS(null,"id",b);return c},nodeTypeCompare:function(a,b){return b==a.nodeName},createRenderRoot:function(){var a=this.nodeFactory(this.container.id+"_svgRoot","svg");a.style.display="block";return a},createRoot:function(a){return this.nodeFactory(this.container.id+a,"g")},createDefs:function(){var a=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(a);return a},drawPoint:function(a,b){return this.drawCircle(a,
+b,1)},drawCircle:function(a,b,c){var d=this.getResolution(),e=(b.x-this.featureDx)/d+this.left;b=this.top-b.y/d;return this.inValidRange(e,b)?(a.setAttributeNS(null,"cx",e),a.setAttributeNS(null,"cy",b),a.setAttributeNS(null,"r",c),a):!1},drawLineString:function(a,b){var c=this.getComponentsString(b.components);return c.path?(a.setAttributeNS(null,"points",c.path),c.complete?a:null):!1},drawLinearRing:function(a,b){var c=this.getComponentsString(b.components);return c.path?(a.setAttributeNS(null,
+"points",c.path),c.complete?a:null):!1},drawPolygon:function(a,b){for(var c="",d=!0,e=!0,f,g,h=0,k=b.components.length;h<k;h++)c+=" M",f=this.getComponentsString(b.components[h].components," "),(g=f.path)?(c+=" "+g,e=f.complete&&e):d=!1;return d?(a.setAttributeNS(null,"d",c+" z"),a.setAttributeNS(null,"fill-rule","evenodd"),e?a:null):!1},drawRectangle:function(a,b){var c=this.getResolution(),d=(b.x-this.featureDx)/c+this.left,e=this.top-b.y/c;return this.inValidRange(d,e)?(a.setAttributeNS(null,"x",
+d),a.setAttributeNS(null,"y",e),a.setAttributeNS(null,"width",b.width/c),a.setAttributeNS(null,"height",b.height/c),a):!1},drawText:function(a,b,c){var d=!!b.labelOutlineWidth;if(d){var e=OpenLayers.Util.extend({},b);e.fontColor=e.labelOutlineColor;e.fontStrokeColor=e.labelOutlineColor;e.fontStrokeWidth=b.labelOutlineWidth;b.labelOutlineOpacity&&(e.fontOpacity=b.labelOutlineOpacity);delete e.labelOutlineWidth;this.drawText(a,e,c)}var f=this.getResolution(),e=(c.x-this.featureDx)/f+this.left,g=c.y/
+f-this.top,d=d?this.LABEL_OUTLINE_SUFFIX:this.LABEL_ID_SUFFIX,f=this.nodeFactory(a+d,"text");f.setAttributeNS(null,"x",e);f.setAttributeNS(null,"y",-g);b.fontColor&&f.setAttributeNS(null,"fill",b.fontColor);b.fontStrokeColor&&f.setAttributeNS(null,"stroke",b.fontStrokeColor);b.fontStrokeWidth&&f.setAttributeNS(null,"stroke-width",b.fontStrokeWidth);b.fontOpacity&&f.setAttributeNS(null,"opacity",b.fontOpacity);b.fontFamily&&f.setAttributeNS(null,"font-family",b.fontFamily);b.fontSize&&f.setAttributeNS(null,
+"font-size",b.fontSize);b.fontWeight&&f.setAttributeNS(null,"font-weight",b.fontWeight);b.fontStyle&&f.setAttributeNS(null,"font-style",b.fontStyle);!0===b.labelSelect?(f.setAttributeNS(null,"pointer-events","visible"),f._featureId=a):f.setAttributeNS(null,"pointer-events","none");g=b.labelAlign||OpenLayers.Renderer.defaultSymbolizer.labelAlign;f.setAttributeNS(null,"text-anchor",OpenLayers.Renderer.SVG.LABEL_ALIGN[g[0]]||"middle");!0===OpenLayers.IS_GECKO&&f.setAttributeNS(null,"dominant-baseline",
+OpenLayers.Renderer.SVG.LABEL_ALIGN[g[1]]||"central");for(var h=b.label.split("\n"),k=h.length;f.childNodes.length>k;)f.removeChild(f.lastChild);for(var l=0;l<k;l++){var m=this.nodeFactory(a+d+"_tspan_"+l,"tspan");!0===b.labelSelect&&(m._featureId=a,m._geometry=c,m._geometryClass=c.CLASS_NAME);!1===OpenLayers.IS_GECKO&&m.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG.LABEL_VSHIFT[g[1]]||"-35%");m.setAttribute("x",e);if(0==l){var n=OpenLayers.Renderer.SVG.LABEL_VFACTOR[g[1]];null==n&&
+(n=-0.5);m.setAttribute("dy",n*(k-1)+"em")}else m.setAttribute("dy","1em");m.textContent=""===h[l]?" ":h[l];m.parentNode||f.appendChild(m)}f.parentNode||this.textRoot.appendChild(f)},getComponentsString:function(a,b){for(var c=[],d=!0,e=a.length,f=[],g,h=0;h<e;h++)g=a[h],c.push(g),(g=this.getShortString(g))?f.push(g):(0<h&&this.getShortString(a[h-1])&&f.push(this.clipLine(a[h],a[h-1])),h<e-1&&this.getShortString(a[h+1])&&f.push(this.clipLine(a[h],a[h+1])),d=!1);return{path:f.join(b||","),complete:d}},
+clipLine:function(a,b){if(b.equals(a))return"";var c=this.getResolution(),d=this.MAX_PIXEL-this.translationParameters.x,e=this.MAX_PIXEL-this.translationParameters.y,f=(b.x-this.featureDx)/c+this.left,g=this.top-b.y/c,h=(a.x-this.featureDx)/c+this.left,c=this.top-a.y/c,k;if(h<-d||h>d)k=(c-g)/(h-f),h=0>h?-d:d,c=g+(h-f)*k;if(c<-e||c>e)k=(h-f)/(c-g),c=0>c?-e:e,h=f+(c-g)*k;return h+","+c},getShortString:function(a){var b=this.getResolution(),c=(a.x-this.featureDx)/b+this.left;a=this.top-a.y/b;return this.inValidRange(c,
+a)?c+","+a:!1},getPosition:function(a){return{x:parseFloat(a.getAttributeNS(null,"cx")),y:parseFloat(a.getAttributeNS(null,"cy"))}},importSymbol:function(a){this.defs||(this.defs=this.createDefs());var b=this.container.id+"-"+a,c=document.getElementById(b);if(null!=c)return c;var d=OpenLayers.Renderer.symbol[a];if(!d)throw Error(a+" is not a valid symbol name");a=this.nodeFactory(b,"symbol");var e=this.nodeFactory(null,"polygon");a.appendChild(e);for(var c=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,
+0,0),f=[],g,h,k=0;k<d.length;k+=2)g=d[k],h=d[k+1],c.left=Math.min(c.left,g),c.bottom=Math.min(c.bottom,h),c.right=Math.max(c.right,g),c.top=Math.max(c.top,h),f.push(g,",",h);e.setAttributeNS(null,"points",f.join(" "));d=c.getWidth();e=c.getHeight();a.setAttributeNS(null,"viewBox",[c.left-d,c.bottom-e,3*d,3*e].join(" "));this.symbolMetrics[b]=[Math.max(d,e),c.getCenterLonLat().lon,c.getCenterLonLat().lat];this.defs.appendChild(a);return a},getFeatureIdFromEvent:function(a){var b=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,
+arguments);b||(b=a.target,b=b.parentNode&&b!=this.rendererRoot?b.parentNode._featureId:void 0);return b},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={l:"start",r:"end",b:"bottom",t:"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={t:"-70%",b:"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={t:0,b:-1};OpenLayers.Renderer.SVG.preventDefault=function(a){OpenLayers.Event.preventDefault(a)};OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Format.OWSContext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getVersion:function(a,b){var c=OpenLayers.Format.XML.VersionedOGC.prototype.getVersion.apply(this,arguments);"0.3.0"===c&&(c=this.defaultVersion);return c},toContext:function(a){var b={};"OpenLayers.Map"==a.CLASS_NAME&&(b.bounds=a.getExtent(
),b.maxExtent=a.maxExtent,b.projection=a.projection,b.size=a.getSize(),b.layers=a.layers);return b},CLASS_NAME:"OpenLayers.Format.OWSContext"});OpenLayers.Format.OWSContext.v0_3_1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",
+defaultPrefix:"owc",extractAttributes:!0,xy:!0,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:"vector",geometryName:"geometry",nestingLayerLookup:null,initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this)},setNestingPath:function(a){if(a.layersContext)for(var b=0,c=a.layersContext.length;b<c;b++){var d=
+a.layersContext[b],e=[],f=a.title||"";a.metadata&&a.metadata.nestingPath&&(e=a.metadata.nestingPath.slice());""!=f&&e.push(f);d.metadata.nestingPath=e;d.layersContext&&this.setNestingPath(d)}},decomposeNestingPath:function(a){var b=[];if(OpenLayers.Util.isArray(a)){for(a=a.slice();0<a.length;)b.push(a.slice()),a.pop();b.reverse()}return b},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,
+b);this.setNestingPath({layersContext:b.layersContext});a=[];this.processLayer(a,b);delete b.layersContext;b.layersContext=a;return b},processLayer:function(a,b){if(b.layersContext)for(var c=0,d=b.layersContext.length;c<d;c++){var e=b.layersContext[c];a.push(e);e.layersContext&&this.processLayer(a,e)}},write:function(a,b){this.nestingLayerLookup={};b=b||{};OpenLayers.Util.applyDefaults(b,a);var c=this.writeNode("OWSContext",b);this.nestingLayerLookup=null;this.setAttributeNS(c,this.namespaces.xsi,
+"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[c])},readers:{kml:{Document:function(a,b){b.features=(new OpenLayers.Format.KML({kmlns:this.namespaces.kml,extractStyles:!0})).read(a)}},owc:{OWSContext:function(a,b){this.readChildNodes(a,b)},General:function(a,b){this.readChildNodes(a,b)},ResourceList:function(a,b){this.readChildNodes(a,b)},Layer:function(a,b){var c={metadata:{},visibility:"1"!=a.getAttribute("hidden"),queryable:"1"==a.getAttribute("queryable"),
+opacity:null!=a.getAttribute("opacity")?parseFloat(a.getAttribute("opacity")):null,name:a.getAttribute("name"),categoryLayer:null==a.getAttribute("name"),formats:[],styles:[]};b.layersContext||(b.layersContext=[]);b.layersContext.push(c);this.readChildNodes(a,c)},InlineGeometry:function(a,b){b.features=[];var c=this.getElementsByTagNameNS(a,this.namespaces.gml,"featureMember"),d;1<=c.length&&(d=c[0]);d&&d.firstChild&&(c=d.firstChild.nextSibling?d.firstChild.nextSibling:d.firstChild,this.setNamespace("feature",
+c.namespaceURI),this.featureType=c.localName||c.nodeName.split(":").pop(),this.readChildNodes(a,b))},Server:function(a,b){if(!b.service&&!b.version||b.service!=OpenLayers.Format.Context.serviceTypes.WMS)b.service=a.getAttribute("service"),b.version=a.getAttribute("version"),this.readChildNodes(a,b)},Name:function(a,b){b.name=this.getChildValue(a);this.readChildNodes(a,b)},Title:function(a,b){b.title=this.getChildValue(a);this.readChildNodes(a,b)},StyleList:function(a,b){this.readChildNodes(a,b.styles)},
+Style:function(a,b){var c={};b.push(c);this.readChildNodes(a,c)},LegendURL:function(a,b){var c={};b.legend=c;this.readChildNodes(a,c)},OnlineResource:function(a,b){b.url=this.getAttributeNS(a,this.namespaces.xlink,"href");this.readChildNodes(a,b)}},ows:OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows,gml:OpenLayers.Format.GML.v2.prototype.readers.gml,sld:OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld,feature:OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{owc:{OWSContext:function(a){var b=
+this.createElementNSPlus("OWSContext",{attributes:{version:this.VERSION,id:a.id||OpenLayers.Util.createUniqueID("OpenLayers_OWSContext_")}});this.writeNode("General",a,b);this.writeNode("ResourceList",a,b);return b},General:function(a){var b=this.createElementNSPlus("General");this.writeNode("ows:BoundingBox",a,b);this.writeNode("ows:Title",a.title||"OpenLayers OWSContext",b);return b},ResourceList:function(a){for(var b=this.createElementNSPlus("ResourceList"),c=0,d=a.layers.length;c<d;c++){var e=
+a.layers[c],f=this.decomposeNestingPath(e.metadata.nestingPath);this.writeNode("_Layer",{layer:e,subPaths:f},b)}return b},Server:function(a){var b=this.createElementNSPlus("Server",{attributes:{version:a.version,service:a.service}});this.writeNode("OnlineResource",a,b);return b},OnlineResource:function(a){return this.createElementNSPlus("OnlineResource",{attributes:{"xlink:href":a.url}})},InlineGeometry:function(a){var b=this.createElementNSPlus("InlineGeometry"),c=a.getDataExtent();null!==c&&this.writeNode("gml:boundedBy",
+c,b);for(var c=0,d=a.features.length;c<d;c++)this.writeNode("gml:featureMember",a.features[c],b);return b},StyleList:function(a){for(var b=this.createElementNSPlus("StyleList"),c=0,d=a.length;c<d;c++)this.writeNode("Style",a[c],b);return b},Style:function(a){var b=this.createElementNSPlus("Style");this.writeNode("Name",a,b);this.writeNode("Title",a,b);a.legend&&this.writeNode("LegendURL",a,b);return b},Name:function(a){return this.createElementNSPlus("Name",{value:a.name})},Title:function(a){return this.createElementNSPlus("Title",
+{value:a.title})},LegendURL:function(a){var b=this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",a.legend,b);return b},_WMS:function(a){var b=this.createElementNSPlus("Layer",{attributes:{name:a.params.LAYERS,queryable:a.queryable?"1":"0",hidden:a.visibility?"0":"1",opacity:a.hasOwnProperty("opacity")?a.opacity:null}});this.writeNode("ows:Title",a.name,b);this.writeNode("ows:OutputFormat",a.params.FORMAT,b);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,
+version:a.params.VERSION,url:a.url},b);a.metadata.styles&&0<a.metadata.styles.length&&this.writeNode("StyleList",a.metadata.styles,b);return b},_Layer:function(a){var b,c,d;b=a.layer;c=a.subPaths;d=null;0<c.length?(b=c[0].join("/"),c=b.lastIndexOf("/"),d=this.nestingLayerLookup[b],c=0<c?b.substring(c+1,b.length):b,d||(d=this.createElementNSPlus("Layer"),this.writeNode("ows:Title",c,d),this.nestingLayerLookup[b]=d),a.subPaths.shift(),this.writeNode("_Layer",a,d)):(b instanceof OpenLayers.Layer.WMS?
+d=this.writeNode("_WMS",b):b instanceof OpenLayers.Layer.Vector&&(b.protocol instanceof OpenLayers.Protocol.WFS.v1?d=this.writeNode("_WFS",b):b.protocol instanceof OpenLayers.Protocol.HTTP?b.protocol.format instanceof OpenLayers.Format.GML?(b.protocol.format.version="2.1.2",d=this.writeNode("_GML",b)):b.protocol.format instanceof OpenLayers.Format.KML&&(b.protocol.format.version="2.2",d=this.writeNode("_KML",b)):(this.setNamespace("feature",this.featureNS),d=this.writeNode("_InlineGeometry",b))),
+b.options.maxScale&&this.writeNode("sld:MinScaleDenominator",b.options.maxScale,d),b.options.minScale&&this.writeNode("sld:MaxScaleDenominator",b.options.minScale,d),this.nestingLayerLookup[b.name]=d);return d},_WFS:function(a){var b=this.createElementNSPlus("Layer",{attributes:{name:a.protocol.featurePrefix+":"+a.protocol.featureType,hidden:a.visibility?"0":"1"}});this.writeNode("ows:Title",a.name,b);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WFS,version:a.protocol.version,
+url:a.protocol.url},b);return b},_InlineGeometry:function(a){var b=this.createElementNSPlus("Layer",{attributes:{name:this.featureType,hidden:a.visibility?"0":"1"}});this.writeNode("ows:Title",a.name,b);this.writeNode("InlineGeometry",a,b);return b},_GML:function(a){var b=this.createElementNSPlus("Layer");this.writeNode("ows:Title",a.name,b);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.GML,url:a.protocol.url,version:a.protocol.format.version},b);return b},_KML:function(a){var b=
+this.createElementNSPlus("Layer");this.writeNode("ows:Title",a.name,b);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.KML,version:a.protocol.format.version,url:a.protocol.url},b);return b}},gml:OpenLayers.Util.applyDefaults({boundedBy:function(a){var b=this.createElementNSPlus("gml:boundedBy");this.writeNode("gml:Box",a,b);return b}},OpenLayers.Format.GML.v2.prototype.writers.gml),ows:OpenLayers.Format.OWSCommon.v1_0_0.prototype.writers.ows,sld:OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld,
+feature:OpenLayers.Format.GML.v2.prototype.writers.feature},CLASS_NAME:"OpenLayers.Format.OWSContext.v0_3_1"});OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,contentSize:null,size:null,contentHTML:null,backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:!1,minSize:null,maxSize:null,displayClass:"olPopup",contentDisplayClass:"olPopupContent",padding:0,disableFirefoxOverflowHack:!1,fixPadding:function(){"number"==typeof this.padding&&(this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding))},panMapIfOutOfView:!1,
+keepInMap:!1,closeOnMove:!1,map:null,initialize:function(a,b,c,d,e,f){null==a&&(a=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_"));this.id=a;this.lonlat=b;this.contentSize=null!=c?c:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);null!=d&&(this.contentHTML=d);this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className=this.displayClass;
+this.groupDiv=OpenLayers.Util.createDiv(this.id+"_GroupDiv",null,null,null,"relative",null,"hidden");a=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(a,null,this.contentSize.clone(),null,"relative");this.contentDiv.className=this.contentDisplayClass;this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);e&&this.addCloseBox(f);this.registerEvents()},destroy:function(){this.border=this.opacity=this.backgroundColor=this.contentHTML=this.size=this.lonlat=this.id=
+null;this.closeOnMove&&this.map&&this.map.events.unregister("movestart",this,this.hide);this.events.destroy();this.events=null;this.closeDiv&&(OpenLayers.Event.stopObservingElement(this.closeDiv),this.groupDiv.removeChild(this.closeDiv));this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;null!=this.map&&this.map.removePopup(this);this.panMapIfOutOfView=this.padding=this.maxSize=this.minSize=this.autoSize=this.div=this.map=null},draw:function(a){null==a&&null!=this.lonlat&&null!=
+this.map&&(a=this.map.getLayerPxFromLonLat(this.lonlat));this.closeOnMove&&this.map.events.register("movestart",this,this.hide);this.disableFirefoxOverflowHack||"firefox"!=OpenLayers.BROWSER_NAME||(this.map.events.register("movestart",this,function(){var a=document.defaultView.getComputedStyle(this.contentDiv,null).getPropertyValue("overflow");"hidden"!=a&&(this.contentDiv._oldOverflow=a,this.contentDiv.style.overflow="hidden")}),this.map.events.register("moveend",this,function(){var a=this.contentDiv._oldOverflow;
+a&&(this.contentDiv.style.overflow=a,this.contentDiv._oldOverflow=null)}));this.moveTo(a);this.autoSize||this.size||this.setSize(this.contentSize);this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();this.panMapIfOutOfView&&this.panIntoView();return this.div},updatePosition:function(){if(this.lonlat&&this.map){var a=this.map.getLayerPxFromLonLat(this.lonlat);a&&this.moveTo(a)}},moveTo:function(a){null!=a&&null!=this.div&&(this.div.style.left=a.x+"px",this.div.style.top=
+a.y+"px")},visible:function(){return OpenLayers.Element.visible(this.div)},toggle:function(){this.visible()?this.hide():this.show()},show:function(){this.div.style.display="";this.panMapIfOutOfView&&this.panIntoView()},hide:function(){this.div.style.display="none"},setSize:function(a){this.size=a.clone();var b=this.getContentDivPadding(),c=b.left+b.right,d=b.top+b.bottom;this.fixPadding();c+=this.padding.left+this.padding.right;d+=this.padding.top+this.padding.bottom;if(this.closeDiv)var e=parseInt(this.closeDiv.style.width),
+c=c+(e+b.right);this.size.w+=c;this.size.h+=d;"msie"==OpenLayers.BROWSER_NAME&&(this.contentSize.w+=b.left+b.right,this.contentSize.h+=b.bottom+b.top);null!=this.div&&(this.div.style.width=this.size.w+"px",this.div.style.height=this.size.h+"px");null!=this.contentDiv&&(this.contentDiv.style.width=a.w+"px",this.contentDiv.style.height=a.h+"px")},updateSize:function(){var a="<div class='"+this.contentDisplayClass+"'>"+this.contentDiv.innerHTML+"</div>",b=this.map?this.map.div:document.body,c=OpenLayers.Util.getRenderedDimensions(a,
+null,{displayClass:this.displayClass,containerElement:b}),d=this.getSafeContentSize(c),e=null;d.equals(c)?e=c:(c={w:d.w<c.w?d.w:null,h:d.h<c.h?d.h:null},c.w&&c.h?e=d:(a=OpenLayers.Util.getRenderedDimensions(a,c,{displayClass:this.contentDisplayClass,containerElement:b}),"hidden"!=OpenLayers.Element.getStyle(this.contentDiv,"overflow")&&a.equals(d)&&(d=OpenLayers.Util.getScrollbarWidth(),c.w?a.h+=d:a.w+=d),e=this.getSafeContentSize(a)));this.setSize(e)},setBackgroundColor:function(a){void 0!=a&&(this.backgroundColor=
+a);null!=this.div&&(this.div.style.backgroundColor=this.backgroundColor)},setOpacity:function(a){void 0!=a&&(this.opacity=a);null!=this.div&&(this.div.style.opacity=this.opacity,this.div.style.filter="alpha(opacity="+100*this.opacity+")")},setBorder:function(a){void 0!=a&&(this.border=a);null!=this.div&&(this.div.style.border=this.border)},setContentHTML:function(a){null!=a&&(this.contentHTML=a);null!=this.contentDiv&&(null!=this.contentHTML&&this.contentHTML!=this.contentDiv.innerHTML)&&(this.contentDiv.innerHTML=
+this.contentHTML,this.autoSize&&(this.registerImageListeners(),this.updateSize()))},registerImageListeners:function(){for(var a=function(){null!==this.popup.id&&(this.popup.updateSize(),this.popup.visible()&&this.popup.panMapIfOutOfView&&this.popup.panIntoView(),OpenLayers.Event.stopObserving(this.img,"load",this.img._onImgLoad))},b=this.contentDiv.getElementsByTagName("img"),c=0,d=b.length;c<d;c++){var e=b[c];if(0==e.width||0==e.height)e._onImgLoad=OpenLayers.Function.bind(a,{popup:this,img:e}),
+OpenLayers.Event.observe(e,"load",e._onImgLoad)}},getSafeContentSize:function(a){a=a.clone();var b=this.getContentDivPadding(),c=b.left+b.right,d=b.top+b.bottom;this.fixPadding();c+=this.padding.left+this.padding.right;d+=this.padding.top+this.padding.bottom;if(this.closeDiv)var e=parseInt(this.closeDiv.style.width),c=c+(e+b.right);this.minSize&&(a.w=Math.max(a.w,this.minSize.w-c),a.h=Math.max(a.h,this.minSize.h-d));this.maxSize&&(a.w=Math.min(a.w,this.maxSize.w-c),a.h=Math.min(a.h,this.maxSize.h-
+d));if(this.map&&this.map.size){e=b=0;if(this.keepInMap&&!this.panMapIfOutOfView)switch(e=this.map.getPixelFromLonLat(this.lonlat),this.relativePosition){case "tr":b=e.x;e=this.map.size.h-e.y;break;case "tl":b=this.map.size.w-e.x;e=this.map.size.h-e.y;break;case "bl":b=this.map.size.w-e.x;e=e.y;break;case "br":b=e.x;e=e.y;break;default:b=e.x,e=this.map.size.h-e.y}d=this.map.size.h-this.map.paddingForPopups.top-this.map.paddingForPopups.bottom-d-e;a.w=Math.min(a.w,this.map.size.w-this.map.paddingForPopups.left-
+this.map.paddingForPopups.right-c-b);a.h=Math.min(a.h,d)}return a},getContentDivPadding:function(){var a=this._contentDivPadding;a||(null==this.div.parentNode&&(this.div.style.display="none",document.body.appendChild(this.div)),this._contentDivPadding=a=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,
+"padding-top")),this.div.parentNode==document.body&&(document.body.removeChild(this.div),this.div.style.display=""));return a},addCloseBox:function(a){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,{w:17,h:17});this.closeDiv.className="olPopupCloseBox";var b=this.getContentDivPadding();this.closeDiv.style.right=b.right+"px";this.closeDiv.style.top=b.top+"px";this.groupDiv.appendChild(this.closeDiv);a=a||function(a){this.hide();OpenLayers.Event.stop(a)};OpenLayers.Event.observe(this.closeDiv,
+"touchend",OpenLayers.Function.bindAsEventListener(a,this));OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(a,this))},panIntoView:function(){var a=this.map.getSize(),b=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top))),c=b.clone();b.x<this.map.paddingForPopups.left?c.x=this.map.paddingForPopups.left:b.x+this.size.w>a.w-this.map.paddingForPopups.right&&(c.x=a.w-this.map.paddingForPopups.right-this.size.w);
+b.y<this.map.paddingForPopups.top?c.y=this.map.paddingForPopups.top:b.y+this.size.h>a.h-this.map.paddingForPopups.bottom&&(c.y=a.h-this.map.paddingForPopups.bottom-this.size.h);this.map.pan(b.x-c.x,b.y-c.y)},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,!0);this.events.on({mousedown:this.onmousedown,mousemove:this.onmousemove,mouseup:this.onmouseup,click:this.onclick,mouseout:this.onmouseout,dblclick:this.ondblclick,touchstart:function(a){OpenLayers.Event.stop(a,!0)},
+scope:this})},onmousedown:function(a){this.mousedown=!0;OpenLayers.Event.stop(a,!0)},onmousemove:function(a){this.mousedown&&OpenLayers.Event.stop(a,!0)},onmouseup:function(a){this.mousedown&&(this.mousedown=!1,OpenLayers.Event.stop(a,!0))},onclick:function(a){OpenLayers.Event.stop(a,!0)},onmouseout:function(a){this.mousedown=!1},ondblclick:function(a){OpenLayers.Event.stop(a,!0)},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";
+OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geodesic:!1,draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.eTop||(this.eTop=document.createElement("div"),this.eTop.className=this.displayClass+"Top",this.div.appendChild(this.eTop),this.eTop.style.visibility=""==this.topOutUnits||""==this.topInUnits?"hidden":"visible",this.eBottom=document.createElement("div"),
+this.eBottom.className=this.displayClass+"Bottom",this.div.appendChild(this.eBottom),this.eBottom.style.visibility=""==this.bottomOutUnits||""==this.bottomInUnits?"hidden":"visible");this.map.events.register("moveend",this,this.update);this.update();return this.div},getBarLen:function(a){var b=parseInt(Math.log(a)/Math.log(10)),b=Math.pow(10,b);a=parseInt(a/b);return(5<a?5:2<a?2:1)*b},update:function(){var a=this.map.getResolution();if(a){var b=this.map.getUnits(),c=OpenLayers.INCHES_PER_UNIT,d=this.maxWidth*
+a*c[b],e=1;!0===this.geodesic&&(e=(this.map.getGeodesicPixelSize().w||1E-6)*this.maxWidth/(d/c.km),d*=e);var f,g;1E5<d?(f=this.topOutUnits,g=this.bottomOutUnits):(f=this.topInUnits,g=this.bottomInUnits);var h=d/c[f],k=d/c[g],d=this.getBarLen(h),l=this.getBarLen(k),h=d/c[b]*c[f],k=l/c[b]*c[g],b=h/a/e,a=k/a/e;"visible"==this.eBottom.style.visibility&&(this.eBottom.style.width=Math.round(a)+"px",this.eBottom.innerHTML=l+" "+g);"visible"==this.eTop.style.visibility&&(this.eTop.style.width=Math.round(b)+
+"px",this.eTop.innerHTML=d+" "+f)}},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(a,b,c,d){this.url=a;this.size=b||{w:20,h:20};this.offset=c||{x:-(this.size.w/2),y:-(this.size.h/2)};this.calculateOffset=d;a=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(a)},destroy:function(){this.erase();OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML="";this.imageDiv=null},clone:function(){return new OpenLayers.Icon(this.url,
+this.size,this.offset,this.calculateOffset)},setSize:function(a){null!=a&&(this.size=a);this.draw()},setUrl:function(a){null!=a&&(this.url=a);this.draw()},draw:function(a){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(a);return this.imageDiv},erase:function(){null!=this.imageDiv&&null!=this.imageDiv.parentNode&&OpenLayers.Element.remove(this.imageDiv)},setOpacity:function(a){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,null,null,
+null,null,null,a)},moveTo:function(a){null!=a&&(this.px=a);null!=this.imageDiv&&(null==this.px?this.display(!1):(this.calculateOffset&&(this.offset=this.calculateOffset(this.size)),OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,{x:this.px.x+this.offset.x,y:this.px.y+this.offset.y})))},display:function(a){this.imageDiv.style.display=a?"":"none"},isDrawn:function(){return this.imageDiv&&this.imageDiv.parentNode&&11!=this.imageDiv.parentNode.nodeType},CLASS_NAME:"OpenLayers.Icon"});OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(a,b){this.lonlat=a;var c=b?b:OpenLayers.Marker.defaultIcon();null==this.icon?this.icon=c:(this.icon.url=c.url,this.icon.size=c.size,this.icon.offset=c.offset,this.icon.calculateOffset=c.calculateOffset);this.events=new OpenLayers.Events(this,this.icon.imageDiv)},destroy:function(){this.erase();this.map=null;this.events.destroy();this.events=null;null!=this.icon&&(this.icon.destroy(),this.icon=nu
ll)},
+draw:function(a){return this.icon.draw(a)},erase:function(){null!=this.icon&&this.icon.erase()},moveTo:function(a){null!=a&&null!=this.icon&&this.icon.moveTo(a);this.lonlat=this.map.getLonLatFromLayerPx(a)},isDrawn:function(){return this.icon&&this.icon.isDrawn()},onScreen:function(){var a=!1;this.map&&(a=this.map.getExtent().containsLonLat(this.lonlat));return a},inflate:function(a){this.icon&&this.icon.setSize({w:this.icon.size.w*a,h:this.icon.size.h*a})},setOpacity:function(a){this.icon.setOpacity(a)},
+setUrl:function(a){this.icon.setUrl(a)},display:function(a){this.icon.display(a)},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){return new OpenLayers.Icon(OpenLayers.Util.getImageLocation("marker.png"),{w:21,h:25},{x:-10.5,y:-25})};OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,format:"image/png",serverResolutions:null,initialize:function(a,b,c,d){this.layername=c;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,{},d]);this.extension=this.format.split("/")[1].toLowerCase();this.extension="jpg"==this.extension?"jpeg":this.extension},clone:function(a){null==a&&(a=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,
+[a])},getURL:function(a){var b=this.getServerResolution(),c=this.maxExtent,d=this.tileSize,e=Math.round((a.left-c.left)/(b*d.w));a=Math.round((a.bottom-c.bottom)/(b*d.h));b=null!=this.serverResolutions?OpenLayers.Util.indexOf(this.serverResolutions,b):this.map.getZoom();e=[this.layername,OpenLayers.Number.zeroPad(b,2),OpenLayers.Number.zeroPad(parseInt(e/1E6),3),OpenLayers.Number.zeroPad(parseInt(e/1E3)%1E3,3),OpenLayers.Number.zeroPad(parseInt(e)%1E3,3),OpenLayers.Number.zeroPad(parseInt(a/1E6),
+3),OpenLayers.Number.zeroPad(parseInt(a/1E3)%1E3,3),OpenLayers.Number.zeroPad(parseInt(a)%1E3,3)+"."+this.extension].join("/");b=this.url;OpenLayers.Util.isArray(b)&&(b=this.selectUrl(e,b));b="/"==b.charAt(b.length-1)?b:b+"/";return b+e},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Strategy.Paging=OpenLayers.Class(OpenLayers.Strategy,{features:null,length:10,num:null,paging:!1,activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);if(a)this.layer.events.on({beforefeaturesadded:this.cacheFeatures,scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&(this.clearCache(),this.layer.events.un({beforefeaturesadded:this.cacheFeatures,scope:this}));return a},cacheFeatures:function(a){this.paging||(this.clearCache(),
+this.features=a.features,this.pageNext(a))},clearCache:function(){if(this.features)for(var a=0;a<this.features.length;++a)this.features[a].destroy();this.num=this.features=null},pageCount:function(){return Math.ceil((this.features?this.features.length:0)/this.length)},pageNum:function(){return this.num},pageLength:function(a){a&&0<a&&(this.length=a);return this.length},pageNext:function(a){var b=!1;this.features&&(null===this.num&&(this.num=-1),b=this.page((this.num+1)*this.length,a));return b},pagePrevious:function(){var a=
+!1;this.features&&(null===this.num&&(this.num=this.pageCount()),a=this.page((this.num-1)*this.length));return a},page:function(a,b){var c=!1;if(this.features&&0<=a&&a<this.features.length){var d=Math.floor(a/this.length);d!=this.num&&(this.paging=!0,c=this.features.slice(a,a+this.length),this.layer.removeFeatures(this.layer.features),this.num=d,b&&b.features?b.features=c:this.layer.addFeatures(c),this.paging=!1,c=!0)}return c},CLASS_NAME:"OpenLayers.Strategy.Paging"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(a,b){},onDrag:function(a,b){},onComplete:function(a,b){},onEnter:function(a){},onLeave:function(a){},documentDrag:!1,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.layer=a;this.handlers={drag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,
+up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})}},clickFeature:function(a){this.handlers.feature.touch&&(!this.over&&this.overFeature(a))&&(this.handlers.drag.dragstart(this.handlers.feature.evt),this.handlers.drag.stopDown=
+!1)},clickoutFeature:function(a){this.handlers.feature.touch&&this.over&&(this.outFeature(a),this.handlers.drag.stopDown=!0)},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[])},activate:function(){return this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=!1;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,
+this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},overFeature:function(a){var b=!1;this.handlers.drag.dragging?this.over=this.feature.id==a.id?!0:!1:(this.feature=a,this.handlers.drag.activate(),this.over=b=!0,OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over"),this.onEnter(a));return b},downFeature:function(a){this.lastPixel=a;this.onStart(this.feature,a)},moveFeature:function(a){var b=this.map.getResolution();this.feature.geometry.move(b*
+(a.x-this.lastPixel.x),b*(this.lastPixel.y-a.y));this.layer.drawFeature(this.feature);this.lastPixel=a;this.onDrag(this.feature,a)},upFeature:function(a){this.over||this.handlers.drag.deactivate()},doneDragging:function(a){this.onComplete(this.feature,a)},outFeature:function(a){this.handlers.drag.dragging?this.feature.id==a.id&&(this.over=!1):(this.over=!1,this.handlers.drag.deactivate(),OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over"),this.onLeave(a),this.feature=null)},
+cancel:function(){this.handlers.drag.deactivate();this.over=!1},setMap:function(a){this.handlers.drag.setMap(a);this.handlers.feature.setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,layer:null,preserveAspectRatio:!1,rotate:!0,feature:null,renderIntent:"temporary",rotationHandleSymbolizer:null,box:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,irregular:!1,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.layer=a;this.rotationHandleSymbolizer||(this.rotationHandleSymbolizer={stroke:!1,pointRadius:10,fillOpacity:0,
+cursor:"pointer"});this.createBox();this.createControl()},activate:function(){var a=!1;OpenLayers.Control.prototype.activate.apply(this,arguments)&&(this.dragControl.activate(),this.layer.addFeatures([this.box]),this.rotate&&this.layer.addFeatures(this.rotationHandles),this.layer.addFeatures(this.handles),a=!0);return a},deactivate:function(){var a=!1;OpenLayers.Control.prototype.deactivate.apply(this,arguments)&&(this.layer.removeFeatures(this.handles),this.rotate&&this.layer.removeFeatures(this.rotationHandles),
+this.layer.removeFeatures([this.box]),this.dragControl.deactivate(),a=!0);return a},setMap:function(a){this.dragControl.setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},setFeature:function(a,b){b=OpenLayers.Util.applyDefaults(b,{rotation:0,scale:1,ratio:1});var c=this.rotation,d=this.center;OpenLayers.Util.extend(this,b);if(!1!==this.events.triggerEvent("beforesetfeature",{feature:a})){this.feature=a;this.activate();this._setfeature=!0;var e=this.feature.geometry.getBounds();this.box.move(e.getCenterLonLat());
+this.box.geometry.rotate(-c,d);this._angle=0;this.rotation?(c=a.geometry.clone(),c.rotate(-this.rotation,this.center),c=new OpenLayers.Feature.Vector(c.getBounds().toGeometry()),c.geometry.rotate(this.rotation,this.center),this.box.geometry.rotate(this.rotation,this.center),this.box.move(c.geometry.getBounds().getCenterLonLat()),c=c.geometry.components[0].components[0].getBounds().getCenterLonLat()):c=new OpenLayers.LonLat(e.left,e.bottom);this.handles[0].move(c);delete this._setfeature;this.events.triggerEvent("setfeature",
+{feature:a})}},unsetFeature:function(){this.active?this.deactivate():(this.feature=null,this.rotation=0,this.ratio=this.scale=1)},createBox:function(){var a=this;this.center=new OpenLayers.Geometry.Point(0,0);this.box=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-1,-1),new OpenLayers.Geometry.Point(0,-1),new OpenLayers.Geometry.Point(1,-1),new OpenLayers.Geometry.Point(1,0),new OpenLayers.Geometry.Point(1,1),new OpenLayers.Geometry.Point(0,1),new OpenLayers.Geometry.Point(-1,
+1),new OpenLayers.Geometry.Point(-1,0),new OpenLayers.Geometry.Point(-1,-1)]),null,"string"==typeof this.renderIntent?null:this.renderIntent);this.box.geometry.move=function(b,c){a._moving=!0;OpenLayers.Geometry.LineString.prototype.move.apply(this,arguments);a.center.move(b,c);delete a._moving};for(var b=function(a,b){OpenLayers.Geometry.Point.prototype.move.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.move(a,b);this._handle.geometry.move(a,b)},c=function(a,b,c){OpenLayers.Geometry.Point.prototype.resize.apply(this,
+arguments);this._rotationHandle&&this._rotationHandle.geometry.resize(a,b,c);this._handle.geometry.resize(a,b,c)},d=function(a,b){OpenLayers.Geometry.Point.prototype.rotate.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.rotate(a,b);this._handle.geometry.rotate(a,b)},e=function(b,c){var d=this.x,e=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,b,c);if(!a._moving){var f=a.dragControl.handlers.drag.evt,g=!(!a._setfeature&&a.preserveAspectRatio)&&!(f&&f.shiftKey),
+h=new OpenLayers.Geometry.Point(d,e),f=a.center;this.rotate(-a.rotation,f);h.rotate(-a.rotation,f);var k=this.x-f.x,l=this.y-f.y,m=k-(this.x-h.x),n=l-(this.y-h.y);a.irregular&&!a._setfeature&&(k-=(this.x-h.x)/2,l-=(this.y-h.y)/2);this.x=d;this.y=e;h=1;g?(l=1E-5>Math.abs(n)?1:l/n,h=(1E-5>Math.abs(m)?1:k/m)/l):(m=Math.sqrt(m*m+n*n),l=Math.sqrt(k*k+l*l)/m);a._moving=!0;a.box.geometry.rotate(-a.rotation,f);delete a._moving;a.box.geometry.resize(l,f,h);a.box.geometry.rotate(a.rotation,f);a.transformFeature({scale:l,
+ratio:h});a.irregular&&!a._setfeature&&(k=f.clone(),k.x+=1E-5>Math.abs(d-f.x)?0:this.x-d,k.y+=1E-5>Math.abs(e-f.y)?0:this.y-e,a.box.geometry.move(this.x-d,this.y-e),a.transformFeature({center:k}))}},f=function(b,c){var d=this.x,e=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,b,c);if(!a._moving){var f=a.dragControl.handlers.drag.evt,f=f&&f.shiftKey?45:1,g=a.center,h=this.x-g.x,k=this.y-g.y;this.x=d;this.y=e;d=Math.atan2(k-c,h-b);d=Math.atan2(k,h)-d;d*=180/Math.PI;a._angle=(a._angle+d)%
+360;d=a.rotation%f;if(Math.abs(a._angle)>=f||0!==d)d=Math.round(a._angle/f)*f-d,a._angle=0,a.box.geometry.rotate(d,g),a.transformFeature({rotation:d})}},g=Array(8),h=Array(4),k,l,m,n="sw s se e ne n nw w".split(" "),p=0;8>p;++p)k=this.box.geometry.components[p],l=new OpenLayers.Feature.Vector(k.clone(),{role:n[p]+"-resize"},"string"==typeof this.renderIntent?null:this.renderIntent),0==p%2&&(m=new OpenLayers.Feature.Vector(k.clone(),{role:n[p]+"-rotate"},"string"==typeof this.rotationHandleSymbolizer?
+null:this.rotationHandleSymbolizer),m.geometry.move=f,k._rotationHandle=m,h[p/2]=m),k.move=b,k.resize=c,k.rotate=d,l.geometry.move=e,k._handle=l,g[p]=l;this.rotationHandles=h;this.handles=g},createControl:function(){var a=this;this.dragControl=new OpenLayers.Control.DragFeature(this.layer,{documentDrag:!0,moveFeature:function(b){this.feature===a.feature&&(this.feature=a.box);OpenLayers.Control.DragFeature.prototype.moveFeature.apply(this,arguments)},onDrag:function(b,c){b===a.box&&a.transformFeature({center:a.center})},
+onStart:function(b,c){var d=!a.geometryTypes||-1!==OpenLayers.Util.indexOf(a.geometryTypes,b.geometry.CLASS_NAME),e=OpenLayers.Util.indexOf(a.handles,b),e=e+OpenLayers.Util.indexOf(a.rotationHandles,b);b!==a.feature&&(b!==a.box&&-2==e&&d)&&a.setFeature(b)},onComplete:function(b,c){a.events.triggerEvent("transformcomplete",{feature:a.feature})}})},drawHandles:function(){for(var a=this.layer,b=0;8>b;++b)this.rotate&&0===b%2&&a.drawFeature(this.rotationHandles[b/2],this.rotationHandleSymbolizer),a.drawFeature(this.handles[b],
+this.renderIntent)},transformFeature:function(a){if(!this._setfeature){this.scale*=a.scale||1;this.ratio*=a.ratio||1;var b=this.rotation;this.rotation=(this.rotation+(a.rotation||0))%360;if(!1!==this.events.triggerEvent("beforetransform",a)){var c=this.feature,d=c.geometry,e=this.center;d.rotate(-b,e);a.scale||a.ratio?d.resize(a.scale,e,a.ratio):a.center&&c.move(a.center.getBounds().getCenterLonLat());d.rotate(this.rotation,e);this.layer.drawFeature(c);c.toState(OpenLayers.State.UPDATE);this.events.triggerEvent("transform",
+a)}}this.layer.drawFeature(this.box,this.renderIntent);this.drawHandles()},destroy:function(){for(var a,b=0;8>b;++b)a=this.box.geometry.components[b],a._handle.destroy(),a._handle=null,a._rotationHandle&&a._rotationHandle.destroy(),a._rotationHandle=null;this.rotationHandles=this.rotationHandleSymbolizer=this.handles=this.feature=this.center=null;this.box.destroy();this.layer=this.box=null;this.dragControl.destroy();this.dragControl=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},
+CLASS_NAME:"OpenLayers.Control.TransformFeature"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:"olHandlerBoxZoomBox",boxOffsets:null,initialize:function(a,b,c){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask})},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.dragHandler&&(this.dragHandler.destroy(),this.dragHandler=
+null)},setMap:function(a){OpenLayers.Handler.prototype.setMap.apply(this,arguments);this.dragHandler&&this.dragHandler.setMap(a)},startBox:function(a){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv("zoomBox",{x:-9999,y:-9999});this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE.Popup-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.viewPortDiv,"olDrawBox")},moveBox:function(a){var b=this.dragHandler.start.x,
+c=this.dragHandler.start.y,d=Math.abs(b-a.x),e=Math.abs(c-a.y),f=this.getBoxOffsets();this.zoomBox.style.width=d+f.width+1+"px";this.zoomBox.style.height=e+f.height+1+"px";this.zoomBox.style.left=(a.x<b?b-d-f.left:b-f.left)+"px";this.zoomBox.style.top=(a.y<c?c-e-f.top:c-f.top)+"px"},endBox:function(a){var b;if(5<Math.abs(this.dragHandler.start.x-a.x)||5<Math.abs(this.dragHandler.start.y-a.y)){var c=this.dragHandler.start;b=Math.min(c.y,a.y);var d=Math.max(c.y,a.y),e=Math.min(c.x,a.x);a=Math.max(c.x,
+a.x);b=new OpenLayers.Bounds(e,d,a,b)}else b=this.dragHandler.start.clone();this.removeBox();this.callback("done",[b])},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.boxOffsets=this.zoomBox=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox")},activate:function(){return OpenLayers.Handler.prototype.activate.apply(this,arguments)?(this.dragHandler.activate(),!0):!1},deactivate:function(){return OpenLayers.Handler.prototype.deactivate.apply(this,arguments)?
+(this.dragHandler.deactivate()&&this.zoomBox&&this.removeBox(),!0):!1},getBoxOffsets:function(){if(!this.boxOffsets){var a=document.createElement("div");a.style.position="absolute";a.style.border="1px solid black";a.style.width="3px";document.body.appendChild(a);var b=3==a.clientWidth;document.body.removeChild(a);var a=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width")),c=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width")),d=parseInt(OpenLayers.Element.getStyle(this.zoomBox,
+"border-top-width")),e=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:a,right:c,top:d,bottom:e,width:!1===b?a+c:0,height:!1===b?d+e:0}}return this.boxOffsets},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:!1,keyMask:null,alwaysZoom:!1,zoomOnClick:!0,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask})},zoomBox:function(a){if(a instanceof OpenLayers.Bounds){var b,c=a.getCenterPixel();if(this.out){b=Math.min(this.map.size.h/(a.bottom-a.top),this.map.size.w/(a.right-a.left));var d=this.map.getExtent(),e=this.map.getLonLatFromPixel(c),f=e.lon-d.getWidth()/
+2*b;a=e.lon+d.getWidth()/2*b;var g=e.lat-d.getHeight()/2*b;b=e.lat+d.getHeight()/2*b;b=new OpenLayers.Bounds(f,g,a,b)}else f=this.map.getLonLatFromPixel({x:a.left,y:a.bottom}),a=this.map.getLonLatFromPixel({x:a.right,y:a.top}),b=new OpenLayers.Bounds(f.lon,f.lat,a.lon,a.lat);f=this.map.getZoom();g=this.map.getSize();a=g.w/2;g=g.h/2;b=this.map.getZoomForExtent(b);d=this.map.getResolution();e=this.map.getResolutionForZoom(b);d==e?this.map.setCenter(this.map.getLonLatFromPixel(c)):this.map.zoomTo(b,
+{x:(d*c.x-e*a)/(d-e),y:(d*c.y-e*g)/(d-e)});f==this.map.getZoom()&&!0==this.alwaysZoom&&this.map.zoomTo(f+(this.out?-1:1))}else this.zoomOnClick&&(this.out?this.map.zoomTo(this.map.getZoom()-1,a):this.map.zoomTo(this.map.getZoom()+1,a))},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:!1,interval:0,documentDrag:!1,kinetic:null,enableKinetic:!0,kineticInterval:10,draw:function(){if(this.enableKinetic&&OpenLayers.Kinetic){var a={interval:this.kineticInterval};"object"===typeof this.enableKinetic&&(a=OpenLayers.Util.extend(a,this.enableKinetic));this.kinetic=new OpenLayers.Kinetic(a)}this.handler=new OpenLayers.Handler.Drag(this,{move:this.panMap,done:this.panMapDone,down:this.panMapStart},
+{interval:this.interval,documentDrag:this.documentDrag})},panMapStart:function(){this.kinetic&&this.kinetic.begin()},panMap:function(a){this.kinetic&&this.kinetic.update(a);this.panned=!0;this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:!0,animate:!1})},panMapDone:function(a){if(this.panned){var b=null;this.kinetic&&(b=this.kinetic.end(a));this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:!!b,animate:!1});if(b){var c=this;this.kinetic.move(b,function(a,b,
+f){c.map.pan(a,b,{dragging:!f,animate:!1})})}this.panned=!1}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:!1,zoomBox:null,zoomBoxEnabled:!0,zoomWheelEnabled:!0,mouseWheelOptions:null,handleRightClicks:!1,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:!0,initialize:function(a){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.deactivate();this.dragPan&&this.dragPan.destroy();this.dragPan=null;
+this.zoomBox&&this.zoomBox.destroy();this.zoomBox=null;this.pinchZoom&&this.pinchZoom.destroy();this.pinchZoom=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){this.dragPan.activate();this.zoomWheelEnabled&&this.handlers.wheel.activate();this.handlers.click.activate();this.zoomBoxEnabled&&this.zoomBox.activate();this.pinchZoom&&this.pinchZoom.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.pinchZoom&&this.pinchZoom.deactivate();
+this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},draw:function(){this.handleRightClicks&&(this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False);this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.defaultClick,dblclick:this.defaultDblClick,dblrightclick:this.defaultDblRightClick},{"double":!0,stopDouble:!0});this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,
+documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{up:this.wheelUp,down:this.wheelDown},OpenLayers.Util.extend(this.map.fractionalZoom?{}:{cumulative:!1,interval:50,maxDelta:6},this.mouseWheelOptions));OpenLayers.Control.PinchZoom&&(this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},
+this.pinchZoomOptions)))},defaultClick:function(a){a.lastTouches&&2==a.lastTouches.length&&this.map.zoomOut()},defaultDblClick:function(a){this.map.zoomTo(this.map.zoom+1,a.xy)},defaultDblRightClick:function(a){this.map.zoomTo(this.map.zoom-1,a.xy)},wheelChange:function(a,b){this.map.fractionalZoom||(b=Math.round(b));var c=this.map.getZoom(),d;d=Math.max(c+b,0);d=Math.min(d,this.map.getNumZoomLevels());d!==c&&this.map.zoomTo(d,a.xy)},wheelUp:function(a,b){this.wheelChange(a,b||1)},wheelDown:function(a,
+b){this.wheelChange(a,b||-1)},disableZoomBox:function(){this.zoomBoxEnabled=!1;this.zoomBox.deactivate()},enableZoomBox:function(){this.zoomBoxEnabled=!0;this.active&&this.zoomBox.activate()},disableZoomWheel:function(){this.zoomWheelEnabled=!1;this.handlers.wheel.deactivate()},enableZoomWheel:function(){this.zoomWheelEnabled=!0;this.active&&this.handlers.wheel.activate()},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,multi:!1,featureAdded:function(){},initialize:function(a,b,c){OpenLayers.Control.prototype.initialize.apply(this,[c]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(a,b){this.layer.events.triggerEvent("sketchmodified",{vertex:a,feature:b})},create:function(a,b){this.layer.events.triggerEvent("sketchstarted",{vertex:a,feature:b})}},this.callbacks);this.layer=a;this.handlerOptions=
+this.handlerOptions||{};this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{renderers:a.renderers,rendererOptions:a.rendererOptions});"multi"in this.handlerOptions||(this.handlerOptions.multi=this.multi);if(a=this.layer.styleMap&&this.layer.styleMap.styles.temporary)this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":a})});this.handler=new b(this,this.callbacks,this.handlerOptions)},
+drawFeature:function(a){a=new OpenLayers.Feature.Vector(a);!1!==this.layer.events.triggerEvent("sketchcomplete",{feature:a})&&(a.state=OpenLayers.State.INSERT,this.layer.addFeatures([a]),this.featureAdded(a),this.events.triggerEvent("featureadded",{feature:a}))},insertXY:function(a,b){this.handler&&this.handler.line&&this.handler.insertXY(a,b)},insertDeltaXY:function(a,b){this.handler&&this.handler.line&&this.handler.insertDeltaXY(a,b)},insertDirectionLength:function(a,b){this.handler&&this.handler.line&&
+this.handler.insertDirectionLength(a,b)},insertDeflectionLength:function(a,b){this.handler&&this.handler.line&&this.handler.insertDeflectionLength(a,b)},undo:function(){return this.handler.undo&&this.handler.undo()},redo:function(){return this.handler.redo&&this.handler.redo()},finishSketch:function(){this.handler.finishGeometry()},cancel:function(){this.handler.cancel()},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:!1,polygon:null,createFeature:function(a){a=this.layer.getLonLatFromViewPortPx(a);a=new OpenLayers.Geometry.Point(a.lon,a.lat);this.point=new OpenLayers.Feature.Vector(a);this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,
+this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:!0})},addPoint:function(a){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier])for(var b=this.point.geometry,c=this.control.layer.features,d,e=c.length-1;0<=e;--e)if(d=c[e].geometry,(d instanceof OpenLayers.Geometry.Polygon||d instanceof OpenLayers.Geometry.MultiPolygon)&&d.intersects(b)){b=c[e];this.control.layer.removeFeatures([b],{silent:!0});this.control.layer.events.registerPriority("sketchcomplete",
+this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);b.geometry.addComponent(this.line.geometry);this.polygon=b;this.drawingHole=!0;break}OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments)},getCurrentPointIndex:function(){return this.line.geometry.components.length-2},enforceTopology:function(a){a=a.vertex;var b=this.line.geometry.components;this.polygon.geometry.intersects(a)||(b=b[b.length-3],a.x=b.x,a.y=b.y)},finishGeometry:function(){this.line.geometry.removeComponent(this.line.geometry.components[this.line.geometry.components.length-
+2]);this.removePoint();this.finalize()},finalizeInteriorRing:function(){var a=this.line.geometry,b=0!==a.getArea();if(b){for(var c=this.polygon.geometry.components,d=c.length-2;0<=d;--d)if(a.intersects(c[d])){b=!1;break}if(b)a:for(d=c.length-2;0<d;--d)for(var e=c[d].components,f=0,g=e.length;f<g;++f)if(a.containsPoint(e[f])){b=!1;break a}}b?this.polygon.state!==OpenLayers.State.INSERT&&(this.polygon.state=OpenLayers.State.UPDATE):this.polygon.geometry.removeComponent(a);this.restoreFeature();return!1},
+cancel:function(){this.drawingHole&&(this.polygon.geometry.removeComponent(this.line.geometry),this.restoreFeature(!0));return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments)},restoreFeature:function(a){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:!0});this.control.layer.addFeatures([this.polygon],{silent:!0});this.drawingHole=
+!1;a||this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon})},destroyFeature:function(a){OpenLayers.Handler.Path.prototype.destroyFeature.call(this,a);this.polygon=null},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style)},getSketch:function(){return this.polygon},getGeometry:function(){var a=this.polygon&&this.polygon.geometry;a&&this.multi&&(a=new OpenLayers.Geometry.MultiPolygon([a]));return a},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{citeCompliant:!1,initialize:function(a,b){OpenLayers.Control.Panel.prototype.initialize.apply(this,[b]);this.addControls([new OpenLayers.Control.Navigation]);var c=[new OpenLayers.Control.DrawFeature(a,OpenLayers.Handler.Point,{displayClass:"olControlDrawFeaturePoint",handlerOptions:{citeCompliant:this.citeCompliant}}),new OpenLayers.Control.DrawFeature(a,OpenLayers.Handler.Pa
th,{displayClass:"olControlDrawFeaturePath",handlerOptions:{citeCompliant:this.citeCompliant}}),
+new OpenLayers.Control.DrawFeature(a,OpenLayers.Handler.Polygon,{displayClass:"olControlDrawFeaturePolygon",handlerOptions:{citeCompliant:this.citeCompliant}})];this.addControls(c)},draw:function(){var a=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);null===this.defaultControl&&(this.defaultControl=this.controls[0]);return a},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Strategy.BBOX=OpenLayers.Class(OpenLayers.Strategy,{bounds:null,resolution:null,ratio:2,resFactor:null,response:null,activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);a&&(this.layer.events.on({moveend:this.update,refresh:this.update,visibilitychanged:this.update,scope:this}),this.update());return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&this.layer.events.un({moveend:this.update,refresh:this.update,visibilitychanged:this.update,
+scope:this});return a},update:function(a){var b=this.getMapBounds();null!==b&&(a&&a.force||this.layer.visibility&&this.layer.calculateInRange()&&this.invalidBounds(b))&&(this.calculateBounds(b),this.resolution=this.layer.map.getResolution(),this.triggerRead(a))},getMapBounds:function(){if(null===this.layer.map)return null;var a=this.layer.map.getExtent();a&&!this.layer.projection.equals(this.layer.map.getProjectionObject())&&(a=a.clone().transform(this.layer.map.getProjectionObject(),this.layer.projection));
+return a},invalidBounds:function(a){a||(a=this.getMapBounds());a=!this.bounds||!this.bounds.containsBounds(a);!a&&this.resFactor&&(a=this.resolution/this.layer.map.getResolution(),a=a>=this.resFactor||a<=1/this.resFactor);return a},calculateBounds:function(a){a||(a=this.getMapBounds());var b=a.getCenterLonLat(),c=a.getWidth()*this.ratio;a=a.getHeight()*this.ratio;this.bounds=new OpenLayers.Bounds(b.lon-c/2,b.lat-a/2,b.lon+c/2,b.lat+a/2)},triggerRead:function(a){!this.response||a&&!0===a.noAbort||
+(this.layer.protocol.abort(this.response),this.layer.events.triggerEvent("loadend"));var b={filter:this.createFilter()};this.layer.events.triggerEvent("loadstart",b);this.response=this.layer.protocol.read(OpenLayers.Util.applyDefaults({filter:b.filter,callback:this.merge,scope:this},a))},createFilter:function(){var a=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});this.layer.filter&&(a=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,
+filters:[this.layer.filter,a]}));return a},merge:function(a){this.layer.destroyFeatures();if(a.success()){var b=a.features;if(b&&0<b.length){var c=this.layer.projection,d=this.layer.map.getProjectionObject();if(!d.equals(c))for(var e,f=0,g=b.length;f<g;++f)(e=b[f].geometry)&&e.transform(c,d);this.layer.addFeatures(b)}}else this.bounds=null;this.response=null;this.layer.events.triggerEvent("loadend",{response:a})},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:!0,lzd:null,zoomLevels:null,initialize:function(a,b,c,d,e,f){this.lzd=c;this.zoomLevels=d;c=[];c.push(a,b,e,f);OpenLayers.Layer.Grid.prototype.initialize.apply(this,c);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS)},getZoom:function(){var a=this.map.getZoom();this.map.getMaxExtent();return a-=Math.log(this.maxResolution/(this.lzd/512))/Math.log(2)},getURL:function(a){a=this.adjustBounds(a);
+var b=this.getZoom(),c=this.map.getMaxExtent(),d=this.lzd/Math.pow(2,this.getZoom()),e=Math.floor((a.left-c.left)/d);a=Math.floor((a.bottom-c.bottom)/d);return this.map.getResolution()<=this.lzd/512&&this.getZoom()<=this.zoomLevels?this.getFullRequestString({L:b,X:e,Y:a}):OpenLayers.Util.getImageLocation("blank.gif")},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Protocol.CSW=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Protocol.CSW.DEFAULTS);var b=OpenLayers.Protocol.CSW["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported CSW version: "+a.version;return new b(a)};OpenLayers.Protocol.CSW.DEFAULTS={version:"2.0.2"};OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",yx:{"urn:ogc:def:crs:EPSG::4326":!0},createLayer:function(a,b){if(!("layer"in b))throw Error("Missing property 'layer' in configuration.");for(var c=a.contents,d,e=0,f=c.layers.length;e<f;++e)if(c.layers[e].identifier===b.layer){d=
c.layers[e];break}if(!d)throw Error("Layer not found");var g=b.format;!g&&(d.formats&&d.formats.length)&&(g=d.formats[0]);var h;b.matrixSet?h=c.tileMatrixSets[b.matrixSet]:
+1<=d.tileMatrixSetLinks.length&&(h=c.tileMatrixSets[d.tileMatrixSetLinks[0].tileMatrixSet]);if(!h)throw Error("matrixSet not found");for(var k,e=0,f=d.styles.length;e<f&&(k=d.styles[e],!k.isDefault);++e);c=b.requestEncoding;if(!c&&(c="KVP",a.operationsMetadata.GetTile.dcp.http)){var l=a.operationsMetadata.GetTile.dcp.http;l.get[0].constraints&&(l=l.get[0].constraints.GetEncoding.allowedValues,l.KVP||!l.REST&&!l.RESTful||(c="REST"))}var l=[],m=b.params||{};delete b.params;for(var n=0,p=d.dimensions.length;n<
+p;n++){var q=d.dimensions[n];l.push(q.identifier);m.hasOwnProperty(q.identifier)||(m[q.identifier]=q["default"])}var n=b.projection||h.supportedCRS.replace(/urn:ogc:def:crs:(\w+):(.*:)?(\w+)$/,"$1:$3"),p=b.units||("EPSG:4326"===n?"degrees":"m"),q=[],r;for(r in h.matrixIds)h.matrixIds.hasOwnProperty(r)&&q.push(2.8E-4*h.matrixIds[r].scaleDenominator/OpenLayers.METERS_PER_INCH/OpenLayers.INCHES_PER_UNIT[p]);if("REST"===c&&d.resourceUrls){r=[];for(var f=0,s=d.resourceUrls.length;f<s;++f)e=d.resourceUrls[f],
+e.format===g&&"tile"===e.resourceType&&r.push(e.template)}else{s=a.operationsMetadata.GetTile.dcp.http.get;r=[];for(var t,e=0,f=s.length;e<f;e++)t=s[e].constraints,(!t||t&&t.GetEncoding.allowedValues[c])&&r.push(s[e].url)}return new OpenLayers.Layer.WMTS(OpenLayers.Util.applyDefaults(b,{url:r,requestEncoding:c,name:d.title,style:k.identifier,format:g,matrixIds:h.matrixIds,matrixSet:h.identifier,projection:n,units:p,resolutions:!1===b.isBaseLayer?void 0:q,serverResolutions:q,tileFullExtent:h.bounds,
+dimensions:l,params:m}))},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities"});OpenLayers.Layer.Google.v3={DEFAULTS:{sphericalMercator:!0,projection:"EPSG:900913"},animationEnabled:!0,loadMapObject:function(){this.type||(this.type=google.maps.MapTypeId.ROADMAP);var a,b=OpenLayers.Layer.Google.cache[this.map.id];b?(a=b.mapObject,++b.count):(a=this.map.getCenter(),b=document.createElement("div"),b.className="olForeignContainer",b.style.width="100%",b.style.height="100%",a=new google.maps.Map(b,{center:a?new google.maps.LatLng(a.lat,a.lon):new google.maps.LatLng(0,0),zoom:this.map.getZoom()||
+0,mapTypeId:this.type,disableDefaultUI:!0,keyboardShortcuts:!1,draggable:!1,disableDoubleClickZoom:!0,scrollwheel:!1,streetViewControl:!1}),b=document.createElement("div"),b.style.width="100%",b.style.height="100%",a.controls[google.maps.ControlPosition.TOP_LEFT].push(b),b={googleControl:b,mapObject:a,count:1},OpenLayers.Layer.Google.cache[this.map.id]=b);this.mapObject=a;this.setGMapVisibility(this.visibility)},onMapResize:function(){this.visibility&&google.maps.event.trigger(this.mapObject,"resize")},
+setGMapVisibility:function(a){var b=OpenLayers.Layer.Google.cache[this.map.id],c=this.map;if(b){for(var d=this.type,e=c.layers,f,g=e.length-1;0<=g;--g)if(f=e[g],f instanceof OpenLayers.Layer.Google&&!0===f.visibility&&!0===f.inRange){d=f.type;a=!0;break}e=this.mapObject.getDiv();if(!0===a){if(e.parentNode!==c.div)if(b.rendered)c.div.appendChild(e),b.googleControl.appendChild(c.viewPortDiv),google.maps.event.trigger(this.mapObject,"resize");else{var h=this;google.maps.event.addListenerOnce(this.mapObject,
+"tilesloaded",function(){b.rendered=!0;h.setGMapVisibility(h.getVisibility());h.moveTo(h.map.getCenter())})}this.mapObject.setMapTypeId(d)}else b.googleControl.hasChildNodes()&&(c.div.appendChild(c.viewPortDiv),c.div.removeChild(e))}},getMapContainer:function(){return this.mapObject.getDiv()},getMapObjectBoundsFromOLBounds:function(a){var b=null;null!=a&&(b=this.sphericalMercator?this.inverseMercator(a.bottom,a.left):new OpenLayers.LonLat(a.bottom,a.left),a=this.sphericalMercator?this.inverseMercator(a.top,
+a.right):new OpenLayers.LonLat(a.top,a.right),b=new google.maps.LatLngBounds(new google.maps.LatLng(b.lat,b.lon),new google.maps.LatLng(a.lat,a.lon)));return b},getMapObjectLonLatFromMapObjectPixel:function(a){var b=this.map.getSize(),c=this.getLongitudeFromMapObjectLonLat(this.mapObject.center),d=this.getLatitudeFromMapObjectLonLat(this.mapObject.center),e=this.map.getResolution();a=new OpenLayers.LonLat(c+(a.x-b.w/2)*e,d-(a.y-b.h/2)*e);this.wrapDateLine&&(a=a.wrapDateLine(this.maxExtent));return this.getMapObjectLonLatFromLonLat(a.lon,
+a.lat)},getMapObjectPixelFromMapObjectLonLat:function(a){var b=this.getLongitudeFromMapObjectLonLat(a);a=this.getLatitudeFromMapObjectLonLat(a);var c=this.map.getResolution(),d=this.map.getExtent();return this.getMapObjectPixelFromXY(1/c*(b-d.left),1/c*(d.top-a))},setMapObjectCenter:function(a,b){if(!1===this.animationEnabled&&b!=this.mapObject.zoom){var c=this.getMapContainer();google.maps.event.addListenerOnce(this.mapObject,"idle",function(){c.style.visibility=""});c.style.visibility="hidden"}this.mapObject.setOptions({center:a,
+zoom:b})},getMapObjectZoomFromMapObjectBounds:function(a){return this.mapObject.getBoundsZoomLevel(a)},getMapObjectLonLatFromLonLat:function(a,b){var c;this.sphericalMercator?(c=this.inverseMercator(a,b),c=new google.maps.LatLng(c.lat,c.lon)):c=new google.maps.LatLng(b,a);return c},getMapObjectPixelFromXY:function(a,b){return new google.maps.Point(a,b)}};OpenLayers.Format.WPSDescribeProcess=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{wps:"http://www.opengis.net/wps/1.0.0",ows:"http://www.opengis.net/ows/1.1",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd",defaultPrefix:"wps",regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,
+[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,b);return b},readers:{wps:{ProcessDescriptions:function(a,b){b.processDescriptions={};this.readChildNodes(a,b.processDescriptions)},ProcessDescription:function(a,b){var c={processVersion:this.getAttributeNS(a,this.namespaces.wps,"processVersion"),statusSupported:"true"===a.getAttribute("statusSupported"),storeSupported:"true"===a.getAttribute("storeSupported")};this.readChildNodes(a,c);b[c.identifier]=c},DataInputs:function(a,
+b){b.dataInputs=[];this.readChildNodes(a,b.dataInputs)},ProcessOutputs:function(a,b){b.processOutputs=[];this.readChildNodes(a,b.processOutputs)},Output:function(a,b){var c={};this.readChildNodes(a,c);b.push(c)},ComplexOutput:function(a,b){b.complexOutput={};this.readChildNodes(a,b.complexOutput)},LiteralOutput:function(a,b){b.literalOutput={};this.readChildNodes(a,b.literalOutput)},Input:function(a,b){var c={maxOccurs:parseInt(a.getAttribute("maxOccurs")),minOccurs:parseInt(a.getAttribute("minOccurs"))};
+this.readChildNodes(a,c);b.push(c)},BoundingBoxData:function(a,b){b.boundingBoxData={};this.readChildNodes(a,b.boundingBoxData)},CRS:function(a,b){b.CRSs||(b.CRSs={});b.CRSs[this.getChildValue(a)]=!0},LiteralData:function(a,b){b.literalData={};this.readChildNodes(a,b.literalData)},ComplexData:function(a,b){b.complexData={};this.readChildNodes(a,b.complexData)},Default:function(a,b){b["default"]={};this.readChildNodes(a,b["default"])},Supported:function(a,b){b.supported={};this.readChildNodes(a,b.supported)},
+Format:function(a,b){var c={};this.readChildNodes(a,c);b.formats||(b.formats={});b.formats[c.mimeType]=!0},MimeType:function(a,b){b.mimeType=this.getChildValue(a)}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WPSDescribeProcess"});OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(a){this.regExes={typeStr:/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,spaces:/\s+/,parenComma:/\)\s*,\s*\(/,doubleParenComma:/\)\s*\)\s*,\s*\(\s*\(/,trimParens:/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[a])},read:function(a){var b,c;a=a.replace(/[\n\r]/g," ");if(c=this.regExes.typeStr.exec(a))if(a=c[1].toLowerCase(),c=c[2],this.parse[a]&&(b=this.parse[a].apply(this,[c])),this.internalProjection&&this.externalProjection)if(b&&
+"OpenLayers.Feature.Vector"==b.CLASS_NAME)b.geometry.transform(this.externalProjection,this.internalProjection);else if(b&&"geometrycollection"!=a&&"object"==typeof b)for(a=0,c=b.length;a<c;a++)b[a].geometry.transform(this.externalProjection,this.internalProjection);return b},write:function(a){var b,c;a.constructor==Array?c=!0:(a=[a],c=!1);var d=[];c&&d.push("GEOMETRYCOLLECTION(");for(var e=0,f=a.length;e<f;++e)c&&0<e&&d.push(","),b=a[e].geometry,d.push(this.extractGeometry(b));c&&d.push(")");return d.join("")},
+extractGeometry:function(a){var b=a.CLASS_NAME.split(".")[2].toLowerCase();if(!this.extract[b])return null;this.internalProjection&&this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));return("collection"==b?"GEOMETRYCOLLECTION":b.toUpperCase())+"("+this.extract[b].apply(this,[a])+")"},extract:{point:function(a){return a.x+" "+a.y},multipoint:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.point.apply(this,[a.components[c]])+
+")");return b.join(",")},linestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extract.point.apply(this,[a.components[c]]));return b.join(",")},multilinestring:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.linestring.apply(this,[a.components[c]])+")");return b.join(",")},polygon:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.linestring.apply(this,[a.components[c]])+")");return b.join(",")},multipolygon:function(a){for(var b=
+[],c=0,d=a.components.length;c<d;++c)b.push("("+this.extract.polygon.apply(this,[a.components[c]])+")");return b.join(",")},collection:function(a){for(var b=[],c=0,d=a.components.length;c<d;++c)b.push(this.extractGeometry.apply(this,[a.components[c]]));return b.join(",")}},parse:{point:function(a){a=OpenLayers.String.trim(a).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(a[0],a[1]))},multipoint:function(a){for(var b=OpenLayers.String.trim(a).split(","),
+c=[],d=0,e=b.length;d<e;++d)a=b[d].replace(this.regExes.trimParens,"$1"),c.push(this.parse.point.apply(this,[a]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(c))},linestring:function(a){a=OpenLayers.String.trim(a).split(",");for(var b=[],c=0,d=a.length;c<d;++c)b.push(this.parse.point.apply(this,[a[c]]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(b))},multilinestring:function(a){for(var b=OpenLayers.String.trim(a).split(this.regExes.parenComma),
+c=[],d=0,e=b.length;d<e;++d)a=b[d].replace(this.regExes.trimParens,"$1"),c.push(this.parse.linestring.apply(this,[a]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(c))},polygon:function(a){var b;a=OpenLayers.String.trim(a).split(this.regExes.parenComma);for(var c=[],d=0,e=a.length;d<e;++d)b=a[d].replace(this.regExes.trimParens,"$1"),b=this.parse.linestring.apply(this,[b]).geometry,b=new OpenLayers.Geometry.LinearRing(b.components),c.push(b);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(c))},
+multipolygon:function(a){for(var b=OpenLayers.String.trim(a).split(this.regExes.doubleParenComma),c=[],d=0,e=b.length;d<e;++d)a=b[d].replace(this.regExes.trimParens,"$1"),c.push(this.parse.polygon.apply(this,[a]).geometry);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(c))},geometrycollection:function(a){a=a.replace(/,\s*([A-Za-z])/g,"|$1");a=OpenLayers.String.trim(a).split("|");for(var b=[],c=0,d=a.length;c<d;++c)b.push(OpenLayers.Format.WKT.prototype.read.apply(this,[a[c]]));
+return b}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.WPSProcess=OpenLayers.Class({client:null,server:null,identifier:null,description:null,localWPS:"http://geoserver/wps",formats:null,chained:0,executeCallbacks:null,initialize:function(a){OpenLayers.Util.extend(this,a);this.executeCallbacks=[];this.formats={"application/wkt":new OpenLayers.Format.WKT,"application/json":new OpenLayers.Format.GeoJSON}},describe:function(a){a=a||{};if(!this.description)this.client.describeProcess(this.server,this.identifier,function(b){this.description||this.parseDescription(b);
+a.callback&&a.callback.call(a.scope,this.description)},this);else if(a.callback){var b=this.description;window.setTimeout(function(){a.callback.call(a.scope,b)},0)}},configure:function(a){this.describe({callback:function(){var b=this.description,c=a.inputs,d,e,f;e=0;for(f=b.dataInputs.length;e<f;++e)d=b.dataInputs[e],this.setInputData(d,c[d.identifier]);a.callback&&a.callback.call(a.scope)},scope:this});return this},execute:function(a){this.configure({inputs:a.inputs,callback:function(){var b=this,
+c=this.getOutputIndex(b.description.processOutputs,a.output);b.setResponseForm({outputIndex:c});(function e(){OpenLayers.Util.removeItem(b.executeCallbacks,e);0!==b.chained?b.executeCallbacks.push(e):OpenLayers.Request.POST({url:b.client.servers[b.server].url,data:(new OpenLayers.Format.WPSExecute).write(b.description),success:function(e){var g=b.findMimeType(b.description.processOutputs[c].complexOutput.supported.formats);e=b.formats[g].read(e.responseText);e instanceof OpenLayers.Feature.Vector&&
+(e=[e]);a.success&&(g={},g[a.output||"result"]=e,a.success.call(a.scope,g))},scope:b})})()},scope:this})},output:function(a){return new OpenLayers.WPSProcess.ChainLink({process:this,output:a})},parseDescription:function(a){a=this.client.servers[this.server];this.description=(new OpenLayers.Format.WPSDescribeProcess).read(a.processDescription[this.identifier]).processDescriptions[this.identifier]},setInputData:function(a,b){delete a.data;delete a.reference;if(b instanceof OpenLayers.WPSProcess.ChainLink)++this.chained,
+a.reference={method:"POST",href:b.process.server===this.server?this.localWPS:this.client.servers[b.process.server].url},b.process.describe({callback:function(){--this.chained;this.chainProcess(a,b)},scope:this});else{a.data={};var c=a.complexData;c?(c=this.findMimeType(c.supported.formats),a.data.complexData={mimeType:c,value:this.formats[c].write(this.toFeatures(b))}):a.data.literalData={value:b}}},setResponseForm:function(a){a=a||{};var b=this.description.processOutputs[a.outputIndex||0];this.description.responseForm=
+{rawDataOutput:{identifier:b.identifier,mimeType:this.findMimeType(b.complexOutput.supported.formats,a.supportedFormats)}}},getOutputIndex:function(a,b){var c;if(b)for(var d=a.length-1;0<=d;--d){if(a[d].identifier===b){c=d;break}}else c=0;return c},chainProcess:function(a,b){var c=this.getOutputIndex(b.process.description.processOutputs,b.output);a.reference.mimeType=this.findMimeType(a.complexData.supported.formats,b.process.description.processOutputs[c].complexOutput.supported.formats);var d={};
+d[a.reference.mimeType]=!0;b.process.setResponseForm({outputIndex:c,supportedFormats:d});for(a.reference.body=b.process.description;0<this.executeCallbacks.length;)this.executeCallbacks[0]()},toFeatures:function(a){var b=OpenLayers.Util.isArray(a);b||(a=[a]);for(var c=Array(a.length),d,e=0,f=a.length;e<f;++e)d=a[e],c[e]=d instanceof OpenLayers.Feature.Vector?d:new OpenLayers.Feature.Vector(d);return b?c:c[0]},findMimeType:function(a,b){b=b||this.formats;for(var c in a)if(c in b)return c},CLASS_NAME:"OpenLayers.WPSProcess"});
+OpenLayers.WPSProcess.ChainLink=OpenLayers.Class({process:null,output:null,initialize:function(a){OpenLayers.Util.extend(this,a)},CLASS_NAME:"OpenLayers.WPSProcess.ChainLink"});OpenLayers.WPSClient=OpenLayers.Class({servers:null,version:"1.0.0",lazy:!1,events:null,initialize:function(a){OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this);this.servers={};for(var b in a.servers)this.servers[b]="string"==typeof a.servers[b]?{url:a.servers[b],version:this.version,processDescription:{}}:a.servers[b]},execute:function(a){this.getProcess(a.server,a.process).execute({inputs:a.inputs,success:a.success,scope:a.scope})},getProcess:function(a,b){var c=new OpenLayers.WPSProcess({client:this,
+server:a,identifier:b});this.lazy||c.describe();return c},describeProcess:function(a,b,c,d){var e=this.servers[a];e.processDescription[b]?window.setTimeout(function(){c.call(d,e.processDescription[b])},0):b in e.processDescription?this.events.register("describeprocess",this,function g(a){a.identifier===b&&(this.events.unregister("describeprocess",this,g),c.call(d,a.raw))}):(e.processDescription[b]=null,OpenLayers.Request.GET({url:e.url,params:{SERVICE:"WPS",VERSION:e.version,REQUEST:"DescribeProcess",
+IDENTIFIER:b},success:function(a){e.processDescription[b]=a.responseText;this.events.triggerEvent("describeprocess",{identifier:b,raw:a.responseText})},scope:this}))},destroy:function(){this.events.destroy();this.servers=this.events=null},CLASS_NAME:"OpenLayers.WPSClient"});OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",gmd:"http://www.isotc211.org/2005/gmd",geonet:"http://www.fao.org/geonetwork",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",
+requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,b);return b},
+readers:{csw:{GetRecordsResponse:function(a,b){b.records=[];this.readChildNodes(a,b);var c=this.getAttributeNS(a,"","version");""!=c&&(b.version=c)},RequestId:function(a,b){b.RequestId=this.getChildValue(a)},SearchStatus:function(a,b){b.SearchStatus={};var c=this.getAttributeNS(a,"","timestamp");""!=c&&(b.SearchStatus.timestamp=c)},SearchResults:function(a,b){this.readChildNodes(a,b);for(var c=a.attributes,d={},e=0,f=c.length;e<f;++e)d[c[e].name]="numberOfRecordsMatched"==c[e].name||"numberOfRecordsReturned"==
+c[e].name||"nextRecord"==c[e].name?parseInt(c[e].nodeValue):c[e].nodeValue;b.SearchResults=d},SummaryRecord:function(a,b){var c={type:"SummaryRecord"};this.readChildNodes(a,c);b.records.push(c)},BriefRecord:function(a,b){var c={type:"BriefRecord"};this.readChildNodes(a,c);b.records.push(c)},DCMIRecord:function(a,b){var c={type:"DCMIRecord"};this.readChildNodes(a,c);b.records.push(c)},Record:function(a,b){var c={type:"Record"};this.readChildNodes(a,c);b.records.push(c)},"*":function(a,b){var c=a.localName||
+a.nodeName.split(":").pop();b[c]=this.getChildValue(a)}},geonet:{info:function(a,b){var c={};this.readChildNodes(a,c);b.gninfo=c}},dc:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();OpenLayers.Util.isArray(b[c])||(b[c]=[]);for(var d={},e=a.attributes,f=0,g=e.length;f<g;++f)d[e[f].name]=e[f].nodeValue;d.value=this.getChildValue(a);""!=d.value&&b[c].push(d)}},dct:{"*":function(a,b){var c=a.localName||a.nodeName.split(":").pop();OpenLayers.Util.isArray(b[c])||(b[c]=[]);b[c].push(this.getChildValue(a))}},
+ows:OpenLayers.Util.applyDefaults({BoundingBox:function(a,b){b.bounds&&(b.BoundingBox=[{crs:b.projection,value:[b.bounds.left,b.bounds.bottom,b.bounds.right,b.bounds.top]}],delete b.projection,delete b.bounds);OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows.BoundingBox.apply(this,arguments)}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows)},write:function(a){a=this.writeNode("csw:GetRecords",a);a.setAttribute("xmlns:gmd",this.namespaces.gmd);return OpenLayers.Format.XML.prototype.write.apply(this,
+[a])},writers:{csw:{GetRecords:function(a){a||(a={});var b=this.createElementNSPlus("csw:GetRecords",{attributes:{service:"CSW",version:this.version,requestId:a.requestId||this.requestId,resultType:a.resultType||this.resultType,outputFormat:a.outputFormat||this.outputFormat,outputSchema:a.outputSchema||this.outputSchema,startPosition:a.startPosition||this.startPosition,maxRecords:a.maxRecords||this.maxRecords}});(a.DistributedSearch||this.DistributedSearch)&&this.writeNode("csw:DistributedSearch",
+a.DistributedSearch||this.DistributedSearch,b);var c=a.ResponseHandler||this.ResponseHandler;if(OpenLayers.Util.isArray(c)&&0<c.length)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ResponseHandler",c[d],b);this.writeNode("Query",a.Query||this.Query,b);return b},DistributedSearch:function(a){return this.createElementNSPlus("csw:DistributedSearch",{attributes:{hopCount:a.hopCount}})},ResponseHandler:function(a){return this.createElementNSPlus("csw:ResponseHandler",{value:a.value})},Query:function(a){a||
+(a={});var b=this.createElementNSPlus("csw:Query",{attributes:{typeNames:a.typeNames||"csw:Record"}}),c=a.ElementName;if(OpenLayers.Util.isArray(c)&&0<c.length)for(var d=0,e=c.length;d<e;d++)this.writeNode("csw:ElementName",c[d],b);else this.writeNode("csw:ElementSetName",a.ElementSetName||{value:"summary"},b);a.Constraint&&this.writeNode("csw:Constraint",a.Constraint,b);a.SortBy&&this.writeNode("ogc:SortBy",a.SortBy,b);return b},ElementName:function(a){return this.createElementNSPlus("csw:ElementName",
+{value:a.value})},ElementSetName:function(a){return this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:a.typeNames},value:a.value})},Constraint:function(a){var b=this.createElementNSPlus("csw:Constraint",{attributes:{version:a.version}});if(a.Filter){var c=new OpenLayers.Format.Filter({version:a.version});b.appendChild(c.write(a.Filter))}else a.CqlText&&(a=this.createElementNSPlus("CqlText",{value:a.CqlText.value}),b.appendChild(a));return b}},ogc:OpenLayers.Format.Filter.v1_1_0.prototype.writers.ogc},
+CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});/*
+ Apache 2
+ Contains portions of Rico <http://openrico.org/>
+ Copyright 2005 Sabre Airline Solutions
+ Licensed under the Apache License, Version 2.0 (the "License"); you
+ may not use this file except in compliance with the License. You
+ may obtain a copy of the License at
+ http://www.apache.org/licenses/LICENSE-2.0
+ Unless required by applicable law or agreed to in writing, software
+ distributed under the License is distributed on an "AS IS" BASIS,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+ implied. See the License for the specific language governing
+ permissions and limitations under the License.
+OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(a,b,c){this.bounds=a;this.div=OpenLayers.Util.createDiv();this.div.style.overflow="hidden";this.events=new OpenLayers.Events(this,this.div);this.setBorder(b,c)},destroy:function(){this.div=this.bounds=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments)},setBorder:function(a,b){a||(a="red");b||(b=2);this.div.style.border=b+"px solid "+a},draw:function(a,b){OpenLayers.Util.modifyDOMElement(this.div,
+null,a,b);return this.div},onScreen:function(){var a=!1;this.map&&(a=this.map.getExtent().containsBounds(this.bounds,!0,!0));return a},display:function(a){this.div.style.display=a?"":"none"},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{defaultStyle:null,extractStyles:!0,initialize:function(a){a=a||{};!1!==a.extractStyles&&(a.defaultStyle={externalGraphic:OpenLayers.Util.getImageLocation("marker.png"),graphicWidth:21,graphicHeight:25,graphicXOffset:-10.5,graphicYOffset:-12.5});OpenLayers.Format.prototype.initialize.apply(this,[a])},read:function(a){a=a.split("\n");for(var b,c=[],d=0;d<a.length-1;d++){var e=a[d].replace(/^\s*/,"").replace(/\s*$/,"");if("#"!=e.charAt(0))if(b){for(var e=
+e.split("\t"),f=new OpenLayers.Geometry.Point(0,0),g={},h=this.defaultStyle?OpenLayers.Util.applyDefaults({},this.defaultStyle):null,k=!1,l=0;l<e.length;l++)if(e[l])if("point"==b[l])k=e[l].split(","),f.y=parseFloat(k[0]),f.x=parseFloat(k[1]),k=!0;else if("lat"==b[l])f.y=parseFloat(e[l]),k=!0;else if("lon"==b[l])f.x=parseFloat(e[l]),k=!0;else if("title"==b[l])g.title=e[l];else if("image"==b[l]||"icon"==b[l]&&h)h.externalGraphic=e[l];else if("iconSize"==b[l]&&h){var m=e[l].split(",");h.graphicWidth=
+parseFloat(m[0]);h.graphicHeight=parseFloat(m[1])}else"iconOffset"==b[l]&&h?(m=e[l].split(","),h.graphicXOffset=parseFloat(m[0]),h.graphicYOffset=parseFloat(m[1])):"description"==b[l]?g.description=e[l]:"overflow"==b[l]?g.overflow=e[l]:g[b[l]]=e[l];k&&(this.internalProjection&&this.externalProjection&&f.transform(this.externalProjection,this.internalProjection),e=new OpenLayers.Feature.Vector(f,g,h),c.push(e))}else b=e.split("\t")}return c},CLASS_NAME:"OpenLayers.Format.Text"});OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(a,b){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=[]},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null},loadText:function(){this.loaded||null==this.location||(this.events.triggerEvent("loadstart"),OpenLayers.Request.GET({url:this.location,
+success:this.parseData,failure:function(a){this.events.triggerEvent("loadend")},scope:this}),this.loaded=!0)},moveTo:function(a,b,c){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);this.visibility&&!this.loaded&&this.loadText()},parseData:function(a){a=a.responseText;var b={};OpenLayers.Util.extend(b,this.formatOptions);this.map&&!this.projection.equals(this.map.getProjectionObject())&&(b.externalProjection=this.projection,b.internalProjection=this.map.getProjectionObject());a=(new OpenLayers.Format.Text(b)).read(a);
+for(var b=0,c=a.length;b<c;b++){var d={},e=a[b],f,g,h;f=new OpenLayers.LonLat(e.geometry.x,e.geometry.y);e.style.graphicWidth&&e.style.graphicHeight&&(g=new OpenLayers.Size(e.style.graphicWidth,e.style.graphicHeight));void 0!==e.style.graphicXOffset&&void 0!==e.style.graphicYOffset&&(h=new OpenLayers.Pixel(e.style.graphicXOffset,e.style.graphicYOffset));null!=e.style.externalGraphic?d.icon=new OpenLayers.Icon(e.style.externalGraphic,g,h):(d.icon=OpenLayers.Marker.defaultIcon(),null!=g&&d.icon.setSize(g));
+null!=e.attributes.title&&null!=e.attributes.description&&(d.popupContentHTML="<h2>"+e.attributes.title+"</h2><p>"+e.attributes.description+"</p>");d.overflow=e.attributes.overflow||"auto";d=new OpenLayers.Feature(this,f,d);this.features.push(d);f=d.createMarker();null!=e.attributes.title&&null!=e.attributes.description&&f.events.register("click",d,this.markerClick);this.addMarker(f)}this.events.triggerEvent("loadend")},markerClick:function(a){var b=this==this.layer.selectedFeature;this.layer.selectedFeature=
+b?null:this;for(var c=0,d=this.layer.map.popups.length;c<d;c++)this.layer.map.removePopup(this.layer.map.popups[c]);b||this.layer.map.addPopup(this.createPopup());OpenLayers.Event.stop(a)},clearFeatures:function(){if(null!=this.features)for(;0<this.features.length;){var a=this.features[0];OpenLayers.Util.removeItem(this.features,a);a.destroy()}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:"shiftKey",layerOptions:null,persist:!1,irregular:!1,citeCompliant:!1,angle:null,fixedRadius:!1,feature:null,layer:null,origin:null,initialize:function(a,b,c){c&&c.layerOptions&&c.layerOptions.styleMap||(this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style["default"],{}));OpenLayers.Handler.Drag.prototype.initialize.apply(this,[a,b,c]);this.options=c?c:{}},setOptions:function(a){OpenLayers.Util.extend(this.options,
+a);OpenLayers.Util.extend(this,a)},activate:function(){var a=!1;OpenLayers.Handler.Drag.prototype.activate.apply(this,arguments)&&(a=OpenLayers.Util.extend({displayInLayerSwitcher:!1,calculateInRange:OpenLayers.Function.True,wrapDateLine:this.citeCompliant},this.layerOptions),this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,a),this.map.addLayer(this.layer),a=!0);return a},deactivate:function(){var a=!1;OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)&&(this.dragging&&this.cancel(),
+null!=this.layer.map&&(this.layer.destroy(!1),this.feature&&this.feature.destroy()),this.feature=this.layer=null,a=!0);return a},down:function(a){this.fixedRadius=!!this.radius;a=this.layer.getLonLatFromViewPortPx(a.xy);this.origin=new OpenLayers.Geometry.Point(a.lon,a.lat);if(!this.fixedRadius||this.irregular)this.radius=this.map.getResolution();this.persist&&this.clear();this.feature=new OpenLayers.Feature.Vector;this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],
+{silent:!0});this.layer.drawFeature(this.feature,this.style)},move:function(a){var b=this.layer.getLonLatFromViewPortPx(a.xy),b=new OpenLayers.Geometry.Point(b.lon,b.lat);this.irregular?(a=Math.sqrt(2)*Math.abs(b.y-this.origin.y)/2,this.radius=Math.max(this.map.getResolution()/2,a)):this.fixedRadius?this.origin=b:(this.calculateAngle(b,a),this.radius=Math.max(this.map.getResolution()/2,b.distanceTo(this.origin)));this.modifyGeometry();if(this.irregular){a=b.x-this.origin.x;var b=b.y-this.origin.y,
+c;c=0==b?a/(this.radius*Math.sqrt(2)):a/b;this.feature.geometry.resize(1,this.origin,c);this.feature.geometry.move(a/2,b/2)}this.layer.drawFeature(this.feature,this.style)},up:function(a){this.finalize();this.start==this.last&&this.callback("done",[a.xy])},out:function(a){this.finalize()},createGeometry:function(){this.angle=Math.PI*(1/this.sides-0.5);this.snapAngle&&(this.angle+=this.snapAngle*(Math.PI/180));this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,
+this.sides,this.snapAngle)},modifyGeometry:function(){var a,b,c=this.feature.geometry.components[0];c.components.length!=this.sides+1&&(this.createGeometry(),c=this.feature.geometry.components[0]);for(var d=0;d<this.sides;++d)b=c.components[d],a=this.angle+2*d*Math.PI/this.sides,b.x=this.origin.x+this.radius*Math.cos(a),b.y=this.origin.y+this.radius*Math.sin(a),b.clearBounds()},calculateAngle:function(a,b){var c=Math.atan2(a.y-this.origin.y,a.x-this.origin.x);if(this.snapAngle&&this.snapToggle&&!b[this.snapToggle]){var d=
+Math.PI/180*this.snapAngle;this.angle=Math.round(c/d)*d}else this.angle=c},cancel:function(){this.callback("cancel",null);this.finalize()},finalize:function(){this.origin=null;this.radius=this.options.radius},clear:function(){this.layer&&(this.layer.renderer.clear(),this.layer.destroyFeatures())},callback:function(a,b){this.callbacks[a]&&this.callbacks[a].apply(this.control,[this.feature.geometry.clone()]);this.persist||"done"!=a&&"cancel"!=a||this.clear()},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{clearOnDeactivate:!1,layers:null,callbacks:null,selectionSymbolizer:{Polygon:{fillColor:"#FF0000",stroke:!1},Line:{strokeColor:"#FF0000",strokeWidth:2},Point:{graphicName:"square",fillColor:"#FF0000",pointRadius:5}},layerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.callbacks=OpenLayers.Util.extend({done:this.selec
t,click:this.select},this.callbacks);
+this.handlerOptions=this.handlerOptions||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:!1,tileOptions:{maxGetUrlLength:2048}});this.sketchStyle&&(this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":this.sketchStyle})}));this.handler=new a(this,this.callbacks,this.handlerOptions)},destroy:function(){for(var a in this.layerCache)delete this.layerCache[a];for(a in this.wfsCache)delete this.wfsCache[a];
+OpenLayers.Control.prototype.destroy.apply(this,arguments)},coupleLayerVisiblity:function(a){this.setVisibility(a.object.getVisibility())},createSelectionLayer:function(a){var b;if(this.layerCache[a.id])b=this.layerCache[a.id];else{b=new OpenLayers.Layer.WMS(a.name,a.url,a.params,OpenLayers.Util.applyDefaults(this.layerOptions,a.getOptions()));this.layerCache[a.id]=b;if(!1===this.layerOptions.displayInLayerSwitcher)a.events.on({visibilitychanged:this.coupleLayerVisiblity,scope:b});this.map.addLayer(b)}return b},
+createSLD:function(a,b,c){for(var d={version:"1.0.0",namedLayers:{}},e=(""+a.params.LAYERS).split(","),f=0,g=e.length;f<g;f++){var h=e[f];d.namedLayers[h]={name:h,userStyles:[]};var k=this.selectionSymbolizer,l=c[f];0<=l.type.indexOf("Polygon")?k={Polygon:this.selectionSymbolizer.Polygon}:0<=l.type.indexOf("LineString")?k={Line:this.selectionSymbolizer.Line}:0<=l.type.indexOf("Point")&&(k={Point:this.selectionSymbolizer.Point});d.namedLayers[h].userStyles.push({name:"default",rules:[new OpenLayers.Rule({symbolizer:k,
+filter:b[f],maxScaleDenominator:a.options.minScale})]})}return(new OpenLayers.Format.SLD({srsName:this.map.getProjection()})).write(d)},parseDescribeLayer:function(a){var b=new OpenLayers.Format.WMSDescribeLayer,c=a.responseXML;c&&c.documentElement||(c=a.responseText);a=b.read(c);for(var b=[],c=null,d=0,e=a.length;d<e;d++)"WFS"==a[d].owsType&&(b.push(a[d].typeName),c=a[d].owsURL);OpenLayers.Request.GET({url:c,params:{SERVICE:"WFS",TYPENAME:b.toString(),REQUEST:"DescribeFeatureType",VERSION:"1.0.0"},
+callback:function(a){var b=new OpenLayers.Format.WFSDescribeFeatureType,c=a.responseXML;c&&c.documentElement||(c=a.responseText);a=b.read(c);this.control.wfsCache[this.layer.id]=a;this.control._queue&&this.control.applySelection()},scope:this})},getGeometryAttributes:function(a){var b=[];a=this.wfsCache[a.id];for(var c=0,d=a.featureTypes.length;c<d;c++)for(var e=a.featureTypes[c].properties,f=0,g=e.length;f<g;f++){var h=e[f],k=h.type;(0<=k.indexOf("LineString")||0<=k.indexOf("GeometryAssociationType")||
+0<=k.indexOf("GeometryPropertyType")||0<=k.indexOf("Point")||0<=k.indexOf("Polygon"))&&b.push(h)}return b},activate:function(){var a=OpenLayers.Control.prototype.activate.call(this);if(a)for(var b=0,c=this.layers.length;b<c;b++){var d=this.layers[b];d&&!this.wfsCache[d.id]&&OpenLayers.Request.GET({url:d.url,params:{SERVICE:"WMS",VERSION:d.params.VERSION,LAYERS:d.params.LAYERS,REQUEST:"DescribeLayer"},callback:this.parseDescribeLayer,scope:{layer:d,control:this}})}return a},deactivate:function(){var a=
+OpenLayers.Control.prototype.deactivate.call(this);if(a)for(var b=0,c=this.layers.length;b<c;b++){var d=this.layers[b];if(d&&!0===this.clearOnDeactivate){var e=this.layerCache,f=e[d.id];f&&(d.events.un({visibilitychanged:this.coupleLayerVisiblity,scope:f}),f.destroy(),delete e[d.id])}}return a},setLayers:function(a){this.active?(this.deactivate(),this.layers=a,this.activate()):this.layers=a},createFilter:function(a,b){var c=null;this.handler instanceof OpenLayers.Handler.RegularPolygon?c=!0===this.handler.irregular?
+new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:a.name,value:b.getBounds()}):new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):this.handler instanceof OpenLayers.Handler.Polygon?c=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):this.handler instanceof OpenLayers.Handler.Path?c=0<=a.type.indexOf("Point")?new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,
+property:a.name,distance:0.01*this.map.getExtent().getWidth(),distanceUnits:this.map.getUnits(),value:b}):new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):this.handler instanceof OpenLayers.Handler.Click&&(c=0<=a.type.indexOf("Polygon")?new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:a.name,value:b}):new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:a.name,distance:0.01*this.map.getExtent().getWidth(),
+distanceUnits:this.map.getUnits(),value:b}));return c},select:function(a){this._queue=function(){for(var b=0,c=this.layers.length;b<c;b++){for(var d=this.layers[b],e=this.getGeometryAttributes(d),f=[],g=0,h=e.length;g<h;g++){var k=e[g];if(null!==k){if(!(a instanceof OpenLayers.Geometry)){var l=this.map.getLonLatFromPixel(a.xy);a=new OpenLayers.Geometry.Point(l.lon,l.lat)}k=this.createFilter(k,a);null!==k&&f.push(k)}}g=this.createSelectionLayer(d);this.events.triggerEvent("selected",{layer:d,filters:f});
+d=this.createSLD(d,f,e);g.mergeNewParams({SLD_BODY:d});delete this._queue}};this.applySelection()},applySelection:function(){for(var a=!0,b=0,c=this.layers.length;b<c;b++)if(!this.wfsCache[this.layers[b].id]){a=!1;break}a&&this._queue.call(this)},CLASS_NAME:"OpenLayers.Control.SLDSelect"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,geodesic:!1,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);this.element=OpenLayers.Util.getElement(a)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.element||(this.element=document.createElement("div"),this.div.appendChild(this.element));this.map.events.register("moveend",this,this.updateScale);this.updateScale();return this.div},updateScale:function(){var a;
+if(!0===this.geodesic){if(!this.map.getUnits())return;a=OpenLayers.INCHES_PER_UNIT;a=(this.map.getGeodesicPixelSize().w||1E-6)*a.km*OpenLayers.DOTS_PER_INCH}else a=this.map.getScale();a&&(a=9500<=a&&95E4>=a?Math.round(a/1E3)+"K":95E4<=a?Math.round(a/1E6)+"M":Math.round(a),this.element.innerHTML=OpenLayers.i18n("Scale = 1 : ${scaleDenom}",{scaleDenom:a}))},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,useHttpTile:!1,singleTile:!1,useOverlay:!1,useAsyncOverlay:!0,TILE_PARAMS:{operation:"GETTILEIMAGE",version:"1.2.0"},SINGLE_TILE_PARAMS:{operation:"GETMAPIMAGE",format:"PNG",locale:"en",clip:"1",version:"1.0.0"},OVERLAY_PARAMS:{operation:"GETDYNAMICMAPOVERLAYIMAGE",format:"PNG",locale:"en",clip:"1",version:"2.0.0"},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:"png",querystring:null},defaultSize:new OpenLayers.Size(300,
+300),tileOriginCorner:"tl",initialize:function(a,b,c,d){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(null==d||null==d.isBaseLayer)this.isBaseLayer="true"!=this.transparent&&!0!=this.transparent;d&&null!=d.useOverlay&&(this.useOverlay=d.useOverlay);this.singleTile?this.useOverlay?(OpenLayers.Util.applyDefaults(this.params,this.OVERLAY_PARAMS),this.useAsyncOverlay||(this.params.version="1.0.0")):OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS):(this.useHttpTile?
+OpenLayers.Util.applyDefaults(this.params,this.FOLDER_PARAMS):OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS),this.setTileSize(this.defaultSize))},clone:function(a){null==a&&(a=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){var b;b=a.getCenterLonLat();var c=this.map.getSize();this.singleTile?(a={setdisplaydpi:OpenLayers.DOTS_PER_INCH,setdisplayheight:c.h*this.ratio,setdisplaywidth:c.w*
+this.ratio,setviewcenterx:b.lon,setviewcentery:b.lat,setviewscale:this.map.getScale()},this.useOverlay&&!this.useAsyncOverlay&&(b={},b=OpenLayers.Util.extend(b,a),b.operation="GETVISIBLEMAPEXTENT",b.version="1.0.0",b.session=this.params.session,b.mapName=this.params.mapName,b.format="text/xml",b=this.getFullRequestString(b),OpenLayers.Request.GET({url:b,async:!1})),b=this.getFullRequestString(a)):(c=this.map.getResolution(),b=Math.floor((a.left-this.maxExtent.left)/c),b=Math.round(b/this.tileSize.w),
+a=Math.floor((this.maxExtent.top-a.top)/c),a=Math.round(a/this.tileSize.h),b=this.useHttpTile?this.getImageFilePath({tilecol:b,tilerow:a,scaleindex:this.resolutions.length-this.map.zoom-1}):this.getFullRequestString({tilecol:b,tilerow:a,scaleindex:this.resolutions.length-this.map.zoom-1}));return b},getFullRequestString:function(a,b){var c=null==b?this.url:b;"object"==typeof c&&(c=c[Math.floor(Math.random()*c.length)]);var d=c,e=OpenLayers.Util.extend({},this.params),e=OpenLayers.Util.extend(e,a),
+f=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c)),g;for(g in e)g.toUpperCase()in f&&delete e[g];e=OpenLayers.Util.getParameterString(e);e=e.replace(/,/g,"+");""!=e&&(f=c.charAt(c.length-1),d="&"==f||"?"==f?d+e:-1==c.indexOf("?")?d+("?"+e):d+("&"+e));return d},getImageFilePath:function(a,b){var c=null==b?this.url:b;"object"==typeof c&&(c=c[Math.floor(Math.random()*c.length)]);var d="",e="";0>a.tilerow&&(d="-");d=0==a.tilerow?d+"0":d+Math.floor(Math.abs(a.tilerow/this.params.tileRowsPerFolder))*
+this.params.tileRowsPerFolder;0>a.tilecol&&(e="-");e=0==a.tilecol?e+"0":e+Math.floor(Math.abs(a.tilecol/this.params.tileColumnsPerFolder))*this.params.tileColumnsPerFolder;d="/S"+Math.floor(a.scaleindex)+"/"+this.params.basemaplayergroupname+"/R"+d+"/C"+e+"/"+a.tilerow%this.params.tileRowsPerFolder+"_"+a.tilecol%this.params.tileColumnsPerFolder+"."+this.params.format;this.params.querystring&&(d+="?"+this.params.querystring);return c+d},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{callbacks:null,displaySystem:"metric",geodesic:!1,displaySystemUnits:{geographic:["dd"],english:["mi","ft","in"],metric:["km","m"]},partialDelay:300,delayedTrigger:null,persist:!1,immediate:!1,initialize:function(a,b){OpenLayers.Control.prototype.initialize.apply(this,[b]);var c={done:this.measureComplete,point:this.measurePartial};this.immediate&&(c.modify=this.measureImmediate);this.callbacks=OpenLayers.Util.extend(c,this.callbacks);
+this.handlerOptions=OpenLayers.Util.extend({persist:this.persist},this.handlerOptions);this.handler=new a(this,this.callbacks,this.handlerOptions)},deactivate:function(){this.cancelDelay();return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},cancel:function(){this.cancelDelay();this.handler.cancel()},setImmediate:function(a){(this.immediate=a)?this.callbacks.modify=this.measureImmediate:delete this.callbacks.modify},updateHandler:function(a,b){var c=this.active;c&&this.deactivate();
+this.handler=new a(this,this.callbacks,b);c&&this.activate()},measureComplete:function(a){this.cancelDelay();this.measure(a,"measure")},measurePartial:function(a,b){this.cancelDelay();b=b.clone();this.handler.freehandMode(this.handler.evt)?this.measure(b,"measurepartial"):this.delayedTrigger=window.setTimeout(OpenLayers.Function.bind(function(){this.delayedTrigger=null;this.measure(b,"measurepartial")},this),this.partialDelay)},measureImmediate:function(a,b,c){c&&!this.handler.freehandMode(this.handler.evt)&&
+(this.cancelDelay(),this.measure(b.geometry,"measurepartial"))},cancelDelay:function(){null!==this.delayedTrigger&&(window.clearTimeout(this.delayedTrigger),this.delayedTrigger=null)},measure:function(a,b){var c,d;-1<a.CLASS_NAME.indexOf("LineString")?(c=this.getBestLength(a),d=1):(c=this.getBestArea(a),d=2);this.events.triggerEvent(b,{measure:c[0],units:c[1],order:d,geometry:a})},getBestArea:function(a){for(var b=this.displaySystemUnits[this.displaySystem],c,d,e=0,f=b.length;e<f&&!(c=b[e],d=this.getArea(a,
+c),1<d);++e);return[d,c]},getArea:function(a,b){var c,d;this.geodesic?(c=a.getGeodesicArea(this.map.getProjectionObject()),d="m"):(c=a.getArea(),d=this.map.getUnits());var e=OpenLayers.INCHES_PER_UNIT[b];e&&(c*=Math.pow(OpenLayers.INCHES_PER_UNIT[d]/e,2));return c},getBestLength:function(a){for(var b=this.displaySystemUnits[this.displaySystem],c,d,e=0,f=b.length;e<f&&!(c=b[e],d=this.getLength(a,c),1<d);++e);return[d,c]},getLength:function(a,b){var c,d;this.geodesic?(c=a.getGeodesicLength(this.map.getProjectionObject()),
+d="m"):(c=a.getLength(),d=this.map.getUnits());var e=OpenLayers.INCHES_PER_UNIT[b];e&&(c*=OpenLayers.INCHES_PER_UNIT[d]/e);return c},CLASS_NAME:"OpenLayers.Control.Measure"});OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(a){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[a])},read_wmc_SRS:function(a,b){var c=this.getChildValue(b);"object"!=typeof a.projections&&(a.projections={});for(var c=c.split(/ +/),d=0,e=c.length;d<e;d++)a.projections[c[d]]=!0},write_wmc_Layer:function(a){var b=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,
+[a]);if(a.srs){var c=[],d;for(d in a.srs)c.push(d);b.appendChild(this.createElementDefaultNS("SRS",c.join(" ")))}b.appendChild(this.write_wmc_FormatList(a));b.appendChild(this.write_wmc_StyleList(a));a.dimensions&&b.appendChild(this.write_wmc_DimensionList(a));b.appendChild(this.write_wmc_LayerExtension(a))},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,keepInMap:!0,anchor:null,initialize:function(a,b,c,d,e,f,g){OpenLayers.Popup.prototype.initialize.apply(this,[a,b,c,d,f,g]);this.anchor=null!=e?e:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)}},destroy:function(){this.relativePosition=this.anchor=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments)},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments)},
+moveTo:function(a){var b=this.relativePosition;this.relativePosition=this.calculateRelativePosition(a);OpenLayers.Popup.prototype.moveTo.call(this,this.calculateNewPx(a));this.relativePosition!=b&&this.updateRelativePosition()},setSize:function(a){OpenLayers.Popup.prototype.setSize.apply(this,arguments);if(this.lonlat&&this.map){var b=this.map.getLayerPxFromLonLat(this.lonlat);this.moveTo(b)}},calculateRelativePosition:function(a){a=this.map.getLonLatFromLayerPx(a);a=this.map.getExtent().determineQuadrant(a);
+return OpenLayers.Bounds.oppositeQuadrant(a)},updateRelativePosition:function(){},calculateNewPx:function(a){a=a.offset(this.anchor.offset);var b=this.size||this.contentSize,c="t"==this.relativePosition.charAt(0);a.y+=c?-b.h:this.anchor.size.h;c="l"==this.relativePosition.charAt(1);a.x+=c?-b.w:this.anchor.size.w;return a},CLASS_NAME:"OpenLayers.Popup.Anchored"});OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:!1,positionBlocks:null,blocks:null,fixedRelativePosition:!1,initialize:function(a,b,c,d,e,f,g){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);this.fixedRelativePosition&&(this.updateRelativePosition(),this.calculateRelativePosition=function(a){return this.relativePosition});this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;f&&(this.closeDiv.style.zIndex=
+1);this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%"},destroy:function(){this.isAlphaImage=this.imageSize=this.imageSrc=null;this.fixedRelativePosition=!1;this.positionBlocks=null;for(var a=0;a<this.blocks.length;a++){var b=this.blocks[a];b.image&&b.div.removeChild(b.image);b.image=null;b.div&&this.groupDiv.removeChild(b.div);b.div=null}this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,
+arguments)},setBackgroundColor:function(a){},setBorder:function(){},setOpacity:function(a){},setSize:function(a){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks()},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var a=this.getContentDivPadding();this.closeDiv.style.right=a.right+this.padding.right+"px";this.closeDiv.style.top=a.top+this.padding.top+"px"}this.updateBlocks()},calculateNewPx:function(a){var b=
+OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);return b=b.offset(this.positionBlocks[this.relativePosition].offset)},createBlocks:function(){this.blocks=[];var a=null,b;for(b in this.positionBlocks){a=b;break}a=this.positionBlocks[a];for(b=0;b<a.blocks.length;b++){var c={};this.blocks.push(c);c.div=OpenLayers.Util.createDiv(this.id+"_FrameDecorationDiv_"+b,null,null,null,"absolute",null,"hidden",null);c.image=(this.isAlphaImage?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage)(this.id+
+"_FrameDecorationImg_"+b,null,this.imageSize,this.imageSrc,"absolute",null,null,null);c.div.appendChild(c.image);this.groupDiv.appendChild(c.div)}},updateBlocks:function(){this.blocks||this.createBlocks();if(this.size&&this.relativePosition){for(var a=this.positionBlocks[this.relativePosition],b=0;b<a.blocks.length;b++){var c=a.blocks[b],d=this.blocks[b],e=c.anchor.left,f=c.anchor.bottom,g=c.anchor.right,h=c.anchor.top,k=isNaN(c.size.w)?this.size.w-(g+e):c.size.w,l=isNaN(c.size.h)?this.size.h-(f+
+h):c.size.h;d.div.style.width=(0>k?0:k)+"px";d.div.style.height=(0>l?0:l)+"px";d.div.style.left=null!=e?e+"px":"";d.div.style.bottom=null!=f?f+"px":"";d.div.style.right=null!=g?g+"px":"";d.div.style.top=null!=h?h+"px":"";d.image.style.left=c.position.x+"px";d.image.style.top=c.position.y+"px"}this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px"}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:!0,panMapIfOutOfView:!0,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:!1,fixedRelativePosition:!1,positionBlocks:{tl:{offset:new OpenLayers.Pixel(44,0),padding:new OpenLayers.Bounds(8,40,8,9),blocks:[{size:new OpenLayers.Size("auto","auto"),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,
+50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-688)}]},tr:{offset:new OpenLayers.Pixel(-45,0),padding:new OpenLayers.Bounds(8,40,8,9),blocks:[{size:new OpenLayers.Size("auto",
+"auto"),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,
+0,null,null),position:new OpenLayers.Pixel(-215,-687)}]},bl:{offset:new OpenLayers.Pixel(45,0),padding:new OpenLayers.Bounds(8,9,8,40),blocks:[{size:new OpenLayers.Size("auto","auto"),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size("auto",21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,
+21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},br:{offset:new OpenLayers.Pixel(-44,0),padding:new OpenLayers.Bounds(8,9,8,40),blocks:[{size:new OpenLayers.Size("auto","auto"),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,"auto"),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,
+0)},{size:new OpenLayers.Size("auto",21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(a,b,c,d,e,f,g){this.imageSrc=OpenLayers.Util.getImageLocation("cloud-popup-relative.png");
+OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Tile.Image.IFrame={useIFrame:null,blankImageUrl:"data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAQAIBRAA7",draw:function(){if(OpenLayers.Tile.Image.prototype.shouldDraw.call(this)){var a=this.layer.getURL(this.bounds),b=this.useIFrame;this.useIFrame=null!==this.maxGetUrlLength&&!this.layer.async&&a.length>this.maxGetUrlLength;a=b&&!this.useIFrame;b=!b&&this.useIFrame;if(a||b)this.imgDiv&&this.imgDiv.parentNode===this.frame&&this.frame.removeChild(this.imgDiv),this.imgDiv=
+null,a&&this.frame.removeChild(this.frame.firstChild)}return OpenLayers.Tile.Image.prototype.draw.apply(this,arguments)},getImage:function(){if(!0===this.useIFrame){if(!this.frame.childNodes.length){var a=document.createElement("div"),b=a.style;b.position="absolute";b.width="100%";b.height="100%";b.zIndex=1;b.backgroundImage="url("+this.blankImageUrl+")";this.frame.appendChild(a)}a=this.id+"_iFrame";9>parseFloat(navigator.appVersion.split("MSIE")[1])?(b=document.createElement('<iframe name="'+a+'">'),
+b.style.backgroundColor="#FFFFFF",b.style.filter="chroma(color=#FFFFFF)"):(b=document.createElement("iframe"),b.style.backgroundColor="transparent",b.name=a);b.scrolling="no";b.marginWidth="0px";b.marginHeight="0px";b.frameBorder="0";b.style.position="absolute";b.style.width="100%";b.style.height="100%";1>this.layer.opacity&&OpenLayers.Util.modifyDOMElement(b,null,null,null,null,null,null,this.layer.opacity);this.frame.appendChild(b);return this.imgDiv=b}return OpenLayers.Tile.Image.prototype.getImage.apply(this,
+arguments)},createRequestForm:function(){var a=document.createElement("form");a.method="POST";var b=this.layer.params._OLSALT,b=(b?b+"_":"")+this.bounds.toBBOX();a.action=OpenLayers.Util.urlAppend(this.layer.url,b);a.target=this.id+"_iFrame";this.layer.getImageSize();var b=OpenLayers.Util.getParameters(this.url),c,d;for(d in b)c=document.createElement("input"),c.type="hidden",c.name=d,c.value=b[d],a.appendChild(c);return a},setImgSrc:function(a){if(!0===this.useIFrame)if(a){var b=this.createRequestForm();
+this.frame.appendChild(b);b.submit();this.frame.removeChild(b)}else this.imgDiv.parentNode===this.frame&&(this.frame.removeChild(this.imgDiv),this.imgDiv=null);else OpenLayers.Tile.Image.prototype.setImgSrc.apply(this,arguments)},onImageLoad:function(){OpenLayers.Tile.Image.prototype.onImageLoad.apply(this,arguments);!0===this.useIFrame&&(this.imgDiv.style.opacity=1,this.frame.style.opacity=this.layer.opacity)},createBackBuffer:function(){var a;!1===this.useIFrame&&(a=OpenLayers.Tile.Image.prototype.createBackBuffer.call(this));
+return a}};OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});OpenLayers.Format.SOSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.SOSCapabilities,{namespaces:{ows:"http://www.opengis.net/ows/1.1",sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.options=a},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,
+[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,b);return b},readers:{gml:OpenLayers.Util.applyDefaults({name:function(a,b){b.name=this.getChildValue(a)},TimePeriod:function(a,b){b.timePeriod={};this.readChildNodes(a,b.timePeriod)},beginPosition:function(a,b){b.beginPosition=this.getChildValue(a)},endPosition:function(a,b){b.endPosition=this.getChildValue(a)}},OpenLayers.Format.GML.v3.prototype.readers.gml),sos:{Capabilities:function(a,b){this.readChildNodes(a,b)},Contents:function(a,
+b){b.contents={};this.readChildNodes(a,b.contents)},ObservationOfferingList:function(a,b){b.offeringList={};this.readChildNodes(a,b.offeringList)},ObservationOffering:function(a,b){var c=this.getAttributeNS(a,this.namespaces.gml,"id");b[c]={procedures:[],observedProperties:[],featureOfInterestIds:[],responseFormats:[],resultModels:[],responseModes:[]};this.readChildNodes(a,b[c])},time:function(a,b){b.time={};this.readChildNodes(a,b.time)},procedure:function(a,b){b.procedures.push(this.getAttributeNS(a,
+this.namespaces.xlink,"href"))},observedProperty:function(a,b){b.observedProperties.push(this.getAttributeNS(a,this.namespaces.xlink,"href"))},featureOfInterest:function(a,b){b.featureOfInterestIds.push(this.getAttributeNS(a,this.namespaces.xlink,"href"))},responseFormat:function(a,b){b.responseFormats.push(this.getChildValue(a))},resultModel:function(a,b){b.resultModels.push(this.getChildValue(a))},responseMode:function(a,b){b.responseModes.push(this.getChildValue(a))}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},
+CLASS_NAME:"OpenLayers.Format.SOSCapabilities.v1_0_0"});OpenLayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:!1,stopDown:!1,pinching:!1,last:null,start:null,touchstart:function(a){var b=!0;this.pinching=!1;if(OpenLayers.Event.isMultiTouch(a))this.started=!0,this.last=this.start={distance:this.getDistance(a.touches),delta:0,scale:1},this.callback("start",[a,this.start]),b=!this.stopDown;else{if(this.started)return!1;this.started=!1;this.last=this.start=null}OpenLayers.Event.preventDefault(a);return b},touchmove:function(a){if(this.started&&
+OpenLayers.Event.isMultiTouch(a)){this.pinching=!0;var b=this.getPinchData(a);this.callback("move",[a,b]);this.last=b;OpenLayers.Event.stop(a)}else if(this.started)return!1;return!0},touchend:function(a){return this.started&&!OpenLayers.Event.isMultiTouch(a)?(this.pinching=this.started=!1,this.callback("done",[a,this.start,this.last]),this.last=this.start=null,!1):!0},activate:function(){var a=!1;OpenLayers.Handler.prototype.activate.apply(this,arguments)&&(this.pinching=!1,a=!0);return a},deactivate:function(){var a=
+!1;OpenLayers.Handler.prototype.deactivate.apply(this,arguments)&&(this.pinching=this.started=!1,this.last=this.start=null,a=!0);return a},getDistance:function(a){var b=a[0];a=a[1];return Math.sqrt(Math.pow(b.olClientX-a.olClientX,2)+Math.pow(b.olClientY-a.olClientY,2))},getPinchData:function(a){a=this.getDistance(a.touches);return{distance:a,delta:this.last.distance-a,scale:a/this.start.distance}},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(a){OpenLayers.Control.Panel.prototype.initialize.apply(this,[a]);this.addControls([new OpenLayers.Control.Navigation,new OpenLayers.Control.ZoomBox])},draw:function(){var a=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);null===this.defaultControl&&(this.defaultControl=this.controls[0]);return a},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:!1,interval:0,timer:null,
activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);a&&(!0===this.layer.visibility&&this.start(),this.layer.events.on({visibilitychanged:this.reset,scope:this}));return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&(this.stop(),this.layer.events.un({visibilitychanged:this.reset,scope:this}));return a},reset:function(){!0===this.layer.visibility?
+this.start():this.stop()},start:function(){this.interval&&("number"===typeof this.interval&&0<this.interval)&&(this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval))},refresh:function(){this.layer&&(this.layer.refresh&&"function"==typeof this.layer.refresh)&&this.layer.refresh({force:this.force})},stop:function(){null!==this.timer&&(window.clearInterval(this.timer),this.timer=null)},CLASS_NAME:"OpenLayers.Strategy.Refresh"});OpenLayers.Layer.ArcGIS93Rest=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{format:"png"},isBaseLayer:!0,initialize:function(a,b,c,d){var e=[];c=OpenLayers.Util.upperCaseObject(c);e.push(a,b,c,d);OpenLayers.Layer.Grid.prototype.initialize.apply(this,e);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));this.params.TRANSPARENT&&"true"==this.params.TRANSPARENT.toString().toLowerCase()&&(null!=d&&d.isBaseLayer||(this.isBaseLayer=!1),"jpg"==this.params.FORMAT&&
+(this.params.FORMAT=OpenLayers.Util.alphaHack()?"gif":"png"))},clone:function(a){null==a&&(a=new OpenLayers.Layer.ArcGIS93Rest(this.name,this.url,this.params,this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){a=this.adjustBounds(a);var b=this.projection.getCode().split(":"),b=b[b.length-1],c=this.getImageSize();a={BBOX:a.toBBOX(),SIZE:c.w+","+c.h,F:"image",BBOXSR:b,IMAGESR:b};if(this.layerDefs){var b=[],d;for(d in this.layerDefs)this.layerDefs.hasOwnProperty(d)&&
+this.layerDefs[d]&&(b.push(d),b.push(":"),b.push(this.layerDefs[d]),b.push(";"));0<b.length&&(a.LAYERDEFS=b.join(""))}return this.getFullRequestString(a)},setLayerFilter:function(a,b){this.layerDefs||(this.layerDefs={});b?this.layerDefs[a]=b:delete this.layerDefs[a]},clearLayerFilter:function(a){a?delete this.layerDefs[a]:delete this.layerDefs},mergeNewParams:function(a){a=[OpenLayers.Util.upperCaseObject(a)];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,a)},CLASS_NAME:"OpenLayers.Layer.ArcGIS93Rest"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:!1,px:null,timerId:null,mousemove:function(a){this.passesTolerance(a.xy)&&(this.clearTimer(),this.callback("move",[a]),this.px=a.xy,a=OpenLayers.Util.extend({},a),this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,a),this.delay));return!this.stopMove},mouseout:function(a){OpenLayers.Util.mouseLeft(a,this.map.viewPortDiv)&&(this.clea
rTimer(),this.callback("move",[a]));return!0},
+passesTolerance:function(a){var b=!0;this.pixelTolerance&&this.px&&Math.sqrt(Math.pow(this.px.x-a.x,2)+Math.pow(this.px.y-a.y,2))<this.pixelTolerance&&(b=!1);return b},clearTimer:function(){null!=this.timerId&&(window.clearTimeout(this.timerId),this.timerId=null)},delayedCall:function(a){this.callback("pause",[a])},deactivate:function(){var a=!1;OpenLayers.Handler.prototype.deactivate.apply(this,arguments)&&(this.clearTimer(),a=!0);return a},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Control.GetFeature=OpenLayers.Class(OpenLayers.Control,{protocol:null,multipleKey:null,toggleKey:null,modifiers:null,multiple:!1,click:!0,single:!0,clickout:!0,toggle:!1,clickTolerance:5,hover:!1,box:!1,maxFeatures:10,features:null,hoverFeature:null,handlers:null,hoverResponse:null,filterType:OpenLayers.Filter.Spatial.BBOX,initialize:function(a){a.handlerOptions=a.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[a]);this.features={};this.handlers={};this.click&&(thi
s.handlers.click=
+new OpenLayers.Handler.Click(this,{click:this.selectClick},this.handlerOptions.click||{}));this.box&&(this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},OpenLayers.Util.extend(this.handlerOptions.box,{boxDivClassName:"olHandlerBoxSelectFeature"})));this.hover&&(this.handlers.hover=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.selectHover},OpenLayers.Util.extend(this.handlerOptions.hover,{delay:250,pixelTolerance:2})))},activate:function(){if(!this.active)for(var a in this.handlers)this.handlers[a].activate();
+return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){if(this.active)for(var a in this.handlers)this.handlers[a].deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},selectClick:function(a){var b=this.pixelToBounds(a.xy);this.setModifiers(a);this.request(b,{single:this.single})},selectBox:function(a){var b;if(a instanceof OpenLayers.Bounds)b=this.map.getLonLatFromPixel({x:a.left,y:a.bottom}),a=this.map.getLonLatFromPixel({x:a.right,
+y:a.top}),b=new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat);else{if(this.click)return;b=this.pixelToBounds(a)}this.setModifiers(this.handlers.box.dragHandler.evt);this.request(b)},selectHover:function(a){a=this.pixelToBounds(a.xy);this.request(a,{single:!0,hover:!0})},cancelHover:function(){this.hoverResponse&&(this.protocol.abort(this.hoverResponse),this.hoverResponse=null,OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait"))},request:function(a,b){b=b||{};var c=new OpenLayers.Filter.Spatial({type:this.filterType,
+value:a});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");c=this.protocol.read({maxFeatures:!0==b.single?this.maxFeatures:void 0,filter:c,callback:function(c){c.success()&&(c.features.length?!0==b.single?this.selectBestFeature(c.features,a.getCenterLonLat(),b):this.select(c.features):b.hover?this.hoverSelect():(this.events.triggerEvent("clickout"),this.clickout&&this.unselectAll()));OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait")},scope:this});!0==b.hover&&(this.hoverResponse=
+c)},selectBestFeature:function(a,b,c){c=c||{};if(a.length){b=new OpenLayers.Geometry.Point(b.lon,b.lat);for(var d,e,f,g=Number.MAX_VALUE,h=0;h<a.length&&!(d=a[h],d.geometry&&(f=b.distanceTo(d.geometry,{edge:!1}),f<g&&(g=f,e=d,0==g)));++h);!0==c.hover?this.hoverSelect(e):this.select(e||a)}},setModifiers:function(a){this.modifiers={multiple:this.multiple||this.multipleKey&&a[this.multipleKey],toggle:this.toggle||this.toggleKey&&a[this.toggleKey]}},select:function(a){this.modifiers.multiple||this.modifiers.toggle||
+this.unselectAll();OpenLayers.Util.isArray(a)||(a=[a]);var b=this.events.triggerEvent("beforefeaturesselected",{features:a});if(!1!==b){for(var c=[],d,e=0,f=a.length;e<f;++e)d=a[e],this.features[d.fid||d.id]?this.modifiers.toggle&&this.unselect(this.features[d.fid||d.id]):(b=this.events.triggerEvent("beforefeatureselected",{feature:d}),!1!==b&&(this.features[d.fid||d.id]=d,c.push(d),this.events.triggerEvent("featureselected",{feature:d})));this.events.triggerEvent("featuresselected",{features:c})}},
+hoverSelect:function(a){var b=a?a.fid||a.id:null,c=this.hoverFeature?this.hoverFeature.fid||this.hoverFeature.id:null;c&&c!=b&&(this.events.triggerEvent("outfeature",{feature:this.hoverFeature}),this.hoverFeature=null);b&&b!=c&&(this.events.triggerEvent("hoverfeature",{feature:a}),this.hoverFeature=a)},unselect:function(a){delete this.features[a.fid||a.id];this.events.triggerEvent("featureunselected",{feature:a})},unselectAll:function(){for(var a in this.features)this.unselect(this.features[a])},
+setMap:function(a){for(var b in this.handlers)this.handlers[b].setMap(a);OpenLayers.Control.prototype.setMap.apply(this,arguments)},pixelToBounds:function(a){var b=a.add(-this.clickTolerance/2,this.clickTolerance/2);a=a.add(this.clickTolerance/2,-this.clickTolerance/2);b=this.map.getLonLatFromPixel(b);a=this.map.getLonLatFromPixel(a);return new OpenLayers.Bounds(b.lon,b.lat,a.lon,a.lat)},CLASS_NAME:"OpenLayers.Control.GetFeature"});OpenLayers.Format.QueryStringFilter=function(){function a(a){a=a.replace(/%/g,"\\%");a=a.replace(/\\\\\.(\*)?/g,function(a,b){return b?a:"\\\\_"});a=a.replace(/\\\\\.\*/g,"\\\\%");a=a.replace(/(\\)?\.(\*)?/g,function(a,b,c){return b||c?a:"_"});a=a.replace(/(\\)?\.\*/g,function(a,b){return b?a:"%"});a=a.replace(/\\\./g,".");return a=a.replace(/(\\)?\\\*/g,function(a,b){return b?a:"*"})}var b={};b[OpenLayers.Filter.Comparison.EQUAL_TO]="eq";b[OpenLayers.Filter.Comparison.NOT_EQUAL_TO]="ne";b[OpenLayers.Filter.Comparison.LESS_THAN]=
+"lt";b[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO]="lte";b[OpenLayers.Filter.Comparison.GREATER_THAN]="gt";b[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO]="gte";b[OpenLayers.Filter.Comparison.LIKE]="ilike";return OpenLayers.Class(OpenLayers.Format,{wildcarded:!1,srsInBBOX:!1,write:function(c,d){d=d||{};var e=c.CLASS_NAME,e=e.substring(e.lastIndexOf(".")+1);switch(e){case "Spatial":switch(c.type){case OpenLayers.Filter.Spatial.BBOX:d.bbox=c.value.toArray();this.srsInBBOX&&c.projection&&
+d.bbox.push(c.projection.getCode());break;case OpenLayers.Filter.Spatial.DWITHIN:d.tolerance=c.distance;case OpenLayers.Filter.Spatial.WITHIN:d.lon=c.value.x;d.lat=c.value.y;break;default:OpenLayers.Console.warn("Unknown spatial filter type "+c.type)}break;case "Comparison":e=b[c.type];if(void 0!==e){var f=c.value;c.type==OpenLayers.Filter.Comparison.LIKE&&(f=a(f),this.wildcarded&&(f="%"+f+"%"));d[c.property+"__"+e]=f;d.queryable=d.queryable||[];d.queryable.push(c.property)}else OpenLayers.Console.warn("Unknown comparison filter type "+
+c.type);break;case "Logical":if(c.type===OpenLayers.Filter.Logical.AND)for(e=0,f=c.filters.length;e<f;e++)d=this.write(c.filters[e],d);else OpenLayers.Console.warn("Unsupported logical filter type "+c.type);break;default:OpenLayers.Console.warn("Unknown filter type "+e)}return d},CLASS_NAME:"OpenLayers.Format.QueryStringFilter"})}();OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,element:null,prefix:"",separator:", ",suffix:"",numDigits:5,granularity:10,emptyString:null,lastXy:null,displayProjection:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){return OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.map.events.register("mousemove",this,this.redraw),this.map.events.register("mouseout",this,this.reset),
+this.redraw(),!0):!1},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments)?(this.map.events.unregister("mousemove",this,this.redraw),this.map.events.unregister("mouseout",this,this.reset),this.element.innerHTML="",!0):!1},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.element||(this.div.left="",this.div.top="",this.element=this.div);return this.div},redraw:function(a){var b;if(null==a)this.reset();else if(null==this.lastXy||Math.abs(a.xy.x-
+this.lastXy.x)>this.granularity||Math.abs(a.xy.y-this.lastXy.y)>this.granularity)this.lastXy=a.xy;else if(b=this.map.getLonLatFromPixel(a.xy))this.displayProjection&&b.transform(this.map.getProjectionObject(),this.displayProjection),this.lastXy=a.xy,a=this.formatOutput(b),a!=this.element.innerHTML&&(this.element.innerHTML=a)},reset:function(a){null!=this.emptyString&&(this.element.innerHTML=this.emptyString)},formatOutput:function(a){var b=parseInt(this.numDigits);return this.prefix+a.lon.toFixed(b)+
+this.separator+a.lat.toFixed(b)+this.suffix},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{geolocation:null,available:"geolocation"in navigator,bind:!0,watch:!1,geolocationOptions:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){this.available&&!this.geolocation&&(this.geolocation=navigator.geolocation);return this.geolocation?OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.watch?this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,
+this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions):this.getCurrentLocation(),!0):!1:(this.events.triggerEvent("locationuncapable"),!1)},deactivate:function(){this.active&&null!==this.watchId&&this.geolocation.clearWatch(this.watchId);return OpenLayers.Control.prototype.deactivate.apply(this,arguments)},geolocate:function(a){var b=(new OpenLayers.LonLat(a.coords.longitude,a.coords.latitude)).transform(new OpenLayers.Projection("EPSG:4326"),this.map.getProjectionObject());this.bind&&
+this.map.setCenter(b);this.events.triggerEvent("locationupdated",{position:a,point:new OpenLayers.Geometry.Point(b.lon,b.lat)})},getCurrentLocation:function(){if(!this.active||this.watch)return!1;this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);return!0},failure:function(a){this.events.triggerEvent("locationfailed",{error:a})},CLASS_NAME:"OpenLayers.Control.Geolocate"});OpenLayers.Tile.UTFGrid=OpenLayers.Class(OpenLayers.Tile,{url:null,utfgridResolution:2,json:null,format:null,destroy:function(){this.clear();OpenLayers.Tile.prototype.destroy.apply(this,arguments)},draw:function(){var a=OpenLayers.Tile.prototype.draw.apply(this,arguments);if(a)if(this.isLoading?(this.abortLoading(),this.events.triggerEvent("reload")):(this.isLoading=!0,this.events.triggerEvent("loadstart")),this.url=this.layer.getURL(this.bounds),this.layer.useJSONP){var b=new OpenLayers.Protocol.Script({url:
this.url,
+callback:function(a){this.isLoading=!1;this.events.triggerEvent("loadend");this.json=a.data},scope:this});b.read();this.request=b}else this.request=OpenLayers.Request.GET({url:this.url,callback:function(a){this.isLoading=!1;this.events.triggerEvent("loadend");200===a.status&&this.parseData(a.responseText)},scope:this});else this.unload();return a},abortLoading:function(){this.request&&(this.request.abort(),delete this.request);this.isLoading=!1},getFeatureInfo:function(a,b){var c=null;if(this.json){var d=
+this.getFeatureId(a,b);null!==d&&(c={id:d,data:this.json.data[d]})}return c},getFeatureId:function(a,b){var c=null;if(this.json){var d=this.utfgridResolution,d=this.json.grid[Math.floor(b/d)].charCodeAt(Math.floor(a/d)),d=this.indexFromCharCode(d),e=this.json.keys;!isNaN(d)&&d in e&&(c=e[d])}return c},indexFromCharCode:function(a){93<=a&&a--;35<=a&&a--;return a-32},parseData:function(a){this.format||(this.format=new OpenLayers.Format.JSON);this.json=this.format.read(a)},clear:function(){this.json=
+null},CLASS_NAME:"OpenLayers.Tile.UTFGrid"});OpenLayers.Protocol.HTTP=OpenLayers.Class(OpenLayers.Protocol,{url:null,headers:null,params:null,callback:null,scope:null,readWithPOST:!1,updateWithPOST:!1,deleteWithPOST:!1,wildcarded:!1,srsInBBOX:!1,initialize:function(a){a=a||{};this.params={};this.headers={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var b=new OpenLayers.Format.QueryStringFilter({wildcarded:this.wildcarded,srsInBBOX:this.srsInBBOX});this.filterToParams=
+function(a,d){return b.write(a,d)}}},destroy:function(){this.headers=this.params=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){OpenLayers.Protocol.prototype.read.apply(this,arguments);a=a||{};a.params=OpenLayers.Util.applyDefaults(a.params,this.options.params);a=OpenLayers.Util.applyDefaults(a,this.options);a.filter&&this.filterToParams&&(a.params=this.filterToParams(a.filter,a.params));var b=void 0!==a.readWithPOST?a.readWithPOST:this.readWithPOST,c=new OpenLayers.Protocol.Response({requestType:"read"});
+b?(b=a.headers||{},b["Content-Type"]="application/x-www-form-urlencoded",c.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleRead,c,a),data:OpenLayers.Util.getParameterString(a.params),headers:b})):c.priv=OpenLayers.Request.GET({url:a.url,callback:this.createCallback(this.handleRead,c,a),params:a.params,headers:a.headers});return c},handleRead:function(a,b){this.handleResponse(a,b)},create:function(a,b){b=OpenLayers.Util.applyDefaults(b,this.options);var c=new OpenLayers.Protocol.Response({reqFeatures:a,
+requestType:"create"});c.priv=OpenLayers.Request.POST({url:b.url,callback:this.createCallback(this.handleCreate,c,b),headers:b.headers,data:this.format.write(a)});return c},handleCreate:function(a,b){this.handleResponse(a,b)},update:function(a,b){b=b||{};var c=b.url||a.url||this.options.url+"/"+a.fid;b=OpenLayers.Util.applyDefaults(b,this.options);var d=new OpenLayers.Protocol.Response({reqFeatures:a,requestType:"update"});d.priv=OpenLayers.Request[this.updateWithPOST?"POST":"PUT"]({url:c,callback:this.createCallback(this.handleUpdate,
+d,b),headers:b.headers,data:this.format.write(a)});return d},handleUpdate:function(a,b){this.handleResponse(a,b)},"delete":function(a,b){b=b||{};var c=b.url||a.url||this.options.url+"/"+a.fid;b=OpenLayers.Util.applyDefaults(b,this.options);var d=new OpenLayers.Protocol.Response({reqFeatures:a,requestType:"delete"}),e=this.deleteWithPOST?"POST":"DELETE",c={url:c,callback:this.createCallback(this.handleDelete,d,b),headers:b.headers};this.deleteWithPOST&&(c.data=this.format.write(a));d.priv=OpenLayers.Request[e](c);
+return d},handleDelete:function(a,b){this.handleResponse(a,b)},handleResponse:function(a,b){var c=a.priv;b.callback&&(200<=c.status&&300>c.status?("delete"!=a.requestType&&(a.features=this.parseFeatures(c)),a.code=OpenLayers.Protocol.Response.SUCCESS):a.code=OpenLayers.Protocol.Response.FAILURE,b.callback.call(b.scope,a))},parseFeatures:function(a){var b=a.responseXML;b&&b.documentElement||(b=a.responseText);return!b||0>=b.length?null:this.format.read(b)},commit:function(a,b){function c(a){for(var b=
+a.features?a.features.length:0,c=Array(b),e=0;e<b;++e)c[e]=a.features[e].fid;r.insertIds=c;d.apply(this,[a])}function d(a){this.callUserCallback(a,b);q=q&&a.success();f++;f>=p&&b.callback&&(r.code=q?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE,b.callback.apply(b.scope,[r]))}b=OpenLayers.Util.applyDefaults(b,this.options);var e=[],f=0,g={};g[OpenLayers.State.INSERT]=[];g[OpenLayers.State.UPDATE]=[];g[OpenLayers.State.DELETE]=[];for(var h,k,l=[],m=0,n=a.length;m<n;++m)if(h=
+a[m],k=g[h.state])k.push(h),l.push(h);var p=(0<g[OpenLayers.State.INSERT].length?1:0)+g[OpenLayers.State.UPDATE].length+g[OpenLayers.State.DELETE].length,q=!0,r=new OpenLayers.Protocol.Response({reqFeatures:l});h=g[OpenLayers.State.INSERT];0<h.length&&e.push(this.create(h,OpenLayers.Util.applyDefaults({callback:c,scope:this},b.create)));h=g[OpenLayers.State.UPDATE];for(m=h.length-1;0<=m;--m)e.push(this.update(h[m],OpenLayers.Util.applyDefaults({callback:d,scope:this},b.update)));h=g[OpenLayers.State.DELETE];
+for(m=h.length-1;0<=m;--m)e.push(this["delete"](h[m],OpenLayers.Util.applyDefaults({callback:d,scope:this},b["delete"])));return e},abort:function(a){a&&a.priv.abort()},callUserCallback:function(a,b){var c=b[a.requestType];c&&c.callback&&c.callback.call(c.scope,a)},CLASS_NAME:"OpenLayers.Protocol.HTTP"});OpenLayers.Strategy.Cluster=OpenLayers.Class(OpenLayers.Strategy,{distance:20,threshold:null,features:null,clusters:null,clustering:!1,resolution:null,activate:function(){var a=OpenLayers.Strategy.prototype.activate.call(this);if(a)this.layer.events.on({beforefeaturesadded:this.cacheFeatures,featuresremoved:this.clearCache,moveend:this.cluster,scope:this});return a},deactivate:function(){var a=OpenLayers.Strategy.prototype.deactivate.call(this);a&&(this.clearCache(),this.layer.events.un({beforefeaturesadded:this.cacheFeatures,
+featuresremoved:this.clearCache,moveend:this.cluster,scope:this}));return a},cacheFeatures:function(a){var b=!0;this.clustering||(this.clearCache(),this.features=a.features,this.cluster(),b=!1);return b},clearCache:function(){this.clustering||(this.features=null)},cluster:function(a){if((!a||a.zoomChanged)&&this.features&&(a=this.layer.map.getResolution(),a!=this.resolution||!this.clustersExist())){this.resolution=a;a=[];for(var b,c,d,e=0;e<this.features.length;++e)if(b=this.features[e],b.geometry){c=
+!1;for(var f=a.length-1;0<=f;--f)if(d=a[f],this.shouldCluster(d,b)){this.addToCluster(d,b);c=!0;break}c||a.push(this.createCluster(this.features[e]))}this.clustering=!0;this.layer.removeAllFeatures();this.clustering=!1;if(0<a.length){if(1<this.threshold)for(b=a.slice(),a=[],e=0,d=b.length;e<d;++e)c=b[e],c.attributes.count<this.threshold?Array.prototype.push.apply(a,c.cluster):a.push(c);this.clustering=!0;this.layer.addFeatures(a);this.clustering=!1}this.clusters=a}},clustersExist:function(){var a=
+!1;if(this.clusters&&0<this.clusters.length&&this.clusters.length==this.layer.features.length)for(var a=!0,b=0;b<this.clusters.length;++b)if(this.clusters[b]!=this.layer.features[b]){a=!1;break}return a},shouldCluster:function(a,b){var c=a.geometry.getBounds().getCenterLonLat(),d=b.geometry.getBounds().getCenterLonLat();return Math.sqrt(Math.pow(c.lon-d.lon,2)+Math.pow(c.lat-d.lat,2))/this.resolution<=this.distance},addToCluster:function(a,b){a.cluster.push(b);a.attributes.count+=1},createCluster:function(a){var b=
+a.geometry.getBounds().getCenterLonLat(),b=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(b.lon,b.lat),{count:1});b.cluster=[a];return b},CLASS_NAME:"OpenLayers.Strategy.Cluster"});OpenLayers.Strategy.Filter=OpenLayers.Class(OpenLayers.Strategy,{filter:null,cache:null,caching:!1,activate:function(){var a=OpenLayers.Strategy.prototype.activate.apply(this,arguments);a&&(this.cache=[],this.layer.events.on({beforefeaturesadded:this.handleAdd,beforefeaturesremoved:this.handleRemove,scope:this}));return a},deactivate:function(){this.cache=null;this.layer&&this.layer.events&&this.layer.events.un({beforefeaturesadded:this.handleAdd,beforefeaturesremoved:this.handleRemove,scope:this});
+return OpenLayers.Strategy.prototype.deactivate.apply(this,arguments)},handleAdd:function(a){if(!this.caching&&this.filter){var b=a.features;a.features=[];for(var c,d=0,e=b.length;d<e;++d)c=b[d],this.filter.evaluate(c)?a.features.push(c):this.cache.push(c)}},handleRemove:function(a){this.caching||(this.cache=[])},setFilter:function(a){this.filter=a;a=this.cache;this.cache=[];this.handleAdd({features:this.layer.features});0<this.cache.length&&(this.caching=!0,this.layer.removeFeatures(this.cache.slice()),
+this.caching=!1);0<a.length&&(a={features:a},this.handleAdd(a),0<a.features.length&&(this.caching=!0,this.layer.addFeatures(a.features),this.caching=!1))},CLASS_NAME:"OpenLayers.Strategy.Filter"});OpenLayers.Protocol.SOS=function(a){a=OpenLayers.Util.applyDefaults(a,OpenLayers.Protocol.SOS.DEFAULTS);var b=OpenLayers.Protocol.SOS["v"+a.version.replace(/\./g,"_")];if(!b)throw"Unsupported SOS version: "+a.version;return new b(a)};OpenLayers.Protocol.SOS.DEFAULTS={version:"1.0.0"};OpenLayers.Format.WFSDescribeFeatureType=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:/^\s*|\s*$/g},namespaces:{xsd:"http://www.w3.org/2001/XMLSchema"},readers:{xsd:{schema:function(a,b){var c=[],d={},e,f;this.readChildNodes(a,{complexTypes:c,customTypes:d});var g=a.attributes,h,k;e=0;for(f=g.length;e<f;++e)h=g[e],k=h.name,0===k.indexOf("xmlns")?this.setNamespace(k.split(":")[1]||"",h.value):b[k]=h.value;b.featureTypes=c;b.targetPrefix=this.namespaceAlias[b.targetNamespace];e=0;for(f=
+c.length;e<f;++e)g=c[e],h=d[g.typeName],d[g.typeName]&&(g.typeName=h.name)},complexType:function(a,b){var c={typeName:a.getAttribute("name")};this.readChildNodes(a,c);b.complexTypes.push(c)},complexContent:function(a,b){this.readChildNodes(a,b)},extension:function(a,b){this.readChildNodes(a,b)},sequence:function(a,b){var c={elements:[]};this.readChildNodes(a,c);b.properties=c.elements},element:function(a,b){var c;if(b.elements){var d={};c=a.attributes;for(var e,f=0,g=c.length;f<g;++f)e=c[f],d[e.name]=
+e.value;c=d.type;c||(c={},this.readChildNodes(a,c),d.restriction=c,d.type=c.base);d.localType=(c.base||c).split(":").pop();b.elements.push(d);this.readChildNodes(a,d)}b.complexTypes&&(c=a.getAttribute("type"),d=c.split(":").pop(),b.customTypes[d]={name:a.getAttribute("name"),type:c})},annotation:function(a,b){b.annotation={};this.readChildNodes(a,b.annotation)},appinfo:function(a,b){b.appinfo||(b.appinfo=[]);b.appinfo.push(this.getChildValue(a))},documentation:function(a,b){b.documentation||(b.documentation=
+[]);var c=this.getChildValue(a);b.documentation.push({lang:a.getAttribute("xml:lang"),textContent:c.replace(this.regExes.trimSpace,"")})},simpleType:function(a,b){this.readChildNodes(a,b)},restriction:function(a,b){b.base=a.getAttribute("base");this.readRestriction(a,b)}}},readRestriction:function(a,b){for(var c=a.childNodes,d,e,f=0,g=c.length;f<g;++f)d=c[f],1==d.nodeType&&(e=d.nodeName.split(":").pop(),d=d.getAttribute("value"),b[e]?("string"==typeof b[e]&&(b[e]=[b[e]]),b[e].push(d)):b[e]=d)},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};if("ExceptionReport"===a.nodeName.split(":").pop()){var c=new OpenLayers.Format.OGCExceptionReport;b.error=c.read(a)}else this.readNode(a,b);return b},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:!1,createGeometryFromItem:function(a){var b=this.getElementsByTagNameNS(a,this.georssns,"point"),c=this.getElementsByTagNameNS(a,this.geons,"lat"),d=this.getElementsByTagNameNS(a,
+this.geons,"long"),e=this.getElementsByTagNameNS(a,this.georssns,"line"),f=this.getElementsByTagNameNS(a,this.georssns,"polygon"),g=this.getElementsByTagNameNS(a,this.georssns,"where");a=this.getElementsByTagNameNS(a,this.georssns,"box");if(0<b.length||0<c.length&&0<d.length){0<b.length?(c=OpenLayers.String.trim(b[0].firstChild.nodeValue).split(/\s+/),2!=c.length&&(c=OpenLayers.String.trim(b[0].firstChild.nodeValue).split(/\s*,\s*/))):c=[parseFloat(c[0].firstChild.nodeValue),parseFloat(d[0].firstChild.nodeValue)];
+var h=new OpenLayers.Geometry.Point(c[1],c[0])}else if(0<e.length){c=OpenLayers.String.trim(this.getChildValue(e[0])).split(/\s+/);d=[];e=0;for(f=c.length;e<f;e+=2)b=new OpenLayers.Geometry.Point(c[e+1],c[e]),d.push(b);h=new OpenLayers.Geometry.LineString(d)}else if(0<f.length){c=OpenLayers.String.trim(this.getChildValue(f[0])).split(/\s+/);d=[];e=0;for(f=c.length;e<f;e+=2)b=new OpenLayers.Geometry.Point(c[e+1],c[e]),d.push(b);h=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(d)])}else 0<
+g.length?(this.gmlParser||(this.gmlParser=new OpenLayers.Format.GML({xy:this.xy})),h=this.gmlParser.parseFeature(g[0]).geometry):0<a.length&&(c=OpenLayers.String.trim(a[0].firstChild.nodeValue).split(/\s+/),d=[],3<c.length&&(b=new OpenLayers.Geometry.Point(c[1],c[0]),d.push(b),b=new OpenLayers.Geometry.Point(c[1],c[2]),d.push(b),b=new OpenLayers.Geometry.Point(c[3],c[2]),d.push(b),b=new OpenLayers.Geometry.Point(c[3],c[0]),d.push(b),b=new OpenLayers.Geometry.Point(c[1],c[0]),d.push(b)),h=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(d)]));
+h&&(this.internalProjection&&this.externalProjection)&&h.transform(this.externalProjection,this.internalProjection);return h},createFeatureFromItem:function(a){var b=this.createGeometryFromItem(a),c=this._getChildValue(a,"*","title",this.featureTitle),d=this._getChildValue(a,"*","description",this._getChildValue(a,"*","content",this._getChildValue(a,"*","summary",this.featureDescription))),e=this._getChildValue(a,"*","link");if(!e)try{e=this.getElementsByTagNameNS(a,"*","link")[0].getAttribute("href")}catch(f){e=
+null}a=this._getChildValue(a,"*","id",null);b=new OpenLayers.Feature.Vector(b,{title:c,description:d,link:e});b.fid=a;return b},_getChildValue:function(a,b,c,d){return(a=this.getElementsByTagNameNS(a,b,c))&&a[0]&&a[0].firstChild&&a[0].firstChild.nodeValue?this.getChildValue(a[0]):void 0==d?"":d},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=null,b=this.getElementsByTagNameNS(a,"*","item");0==b.length&&(b=this.getElementsByTagNameNS(a,"*","entry"));
+a=b.length;for(var c=Array(a),d=0;d<a;d++)c[d]=this.createFeatureFromItem(b[d]);return c},write:function(a){var b;if(OpenLayers.Util.isArray(a)){b=this.createElementNS(this.rssns,"rss");for(var c=0,d=a.length;c<d;c++)b.appendChild(this.createFeatureXML(a[c]))}else b=this.createFeatureXML(a);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFeatureXML:function(a){var b=this.buildGeometryNode(a.geometry),c=this.createElementNS(this.rssns,"item"),d=this.createElementNS(this.rssns,"title");
+d.appendChild(this.createTextNode(a.attributes.title?a.attributes.title:""));var e=this.createElementNS(this.rssns,"description");e.appendChild(this.createTextNode(a.attributes.description?a.attributes.description:""));c.appendChild(d);c.appendChild(e);a.attributes.link&&(d=this.createElementNS(this.rssns,"link"),d.appendChild(this.createTextNode(a.attributes.link)),c.appendChild(d));for(var f in a.attributes)"link"!=f&&("title"!=f&&"description"!=f)&&(d=this.createTextNode(a.attributes[f]),e=f,-1!=
+f.search(":")&&(e=f.split(":")[1]),e=this.createElementNS(this.featureNS,"feature:"+e),e.appendChild(d),c.appendChild(e));c.appendChild(b);return c},buildGeometryNode:function(a){this.internalProjection&&this.externalProjection&&(a=a.clone(),a.transform(this.internalProjection,this.externalProjection));var b;if("OpenLayers.Geometry.Polygon"==a.CLASS_NAME)b=this.createElementNS(this.georssns,"georss:polygon"),b.appendChild(this.buildCoordinatesNode(a.components[0]));else if("OpenLayers.Geometry.LineString"==
+a.CLASS_NAME)b=this.createElementNS(this.georssns,"georss:line"),b.appendChild(this.buildCoordinatesNode(a));else if("OpenLayers.Geometry.Point"==a.CLASS_NAME)b=this.createElementNS(this.georssns,"georss:point"),b.appendChild(this.buildCoordinatesNode(a));else throw"Couldn't parse "+a.CLASS_NAME;return b},buildCoordinatesNode:function(a){var b=null;a.components&&(b=a.components);if(b){a=b.length;for(var c=Array(a),d=0;d<a;d++)c[d]=b[d].y+" "+b[d].x;b=c.join(" ")}else b=a.y+" "+a.x;return this.createTextNode(b)},
+CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.WPSCapabilities=OpenLayers.Class(OpenLayers.Format.XML.VersionedOGC,{defaultVersion:"1.0.0",CLASS_NAME:"OpenLayers.Format.WPSCapabilities"});OpenLayers.Format.WPSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows/1.1",wps:"http://www.opengis.net/wps/1.0.0",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a])},read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);
+var b={};this.readNode(a,b);return b},readers:{wps:{Capabilities:function(a,b){this.readChildNodes(a,b)},ProcessOfferings:function(a,b){b.processOfferings={};this.readChildNodes(a,b.processOfferings)},Process:function(a,b){var c={processVersion:this.getAttributeNS(a,this.namespaces.wps,"processVersion")};this.readChildNodes(a,c);b[c.identifier]=c},Languages:function(a,b){b.languages=[];this.readChildNodes(a,b.languages)},Default:function(a,b){var c={isDefault:!0};this.readChildNodes(a,c);b.push(c)},
+Supported:function(a,b){var c={};this.readChildNodes(a,c);b.push(c)}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WPSCapabilities.v1_0_0"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,pinchOrigin:null,currentCenter:null,autoActivate:!0,preserveCenter:!1,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions)},pinchStart:function(a,b){var c=this.preserveCenter?this.map.getPixelFromLonLat(this.map.getCenter()):a.xy;this.currentCenter=
+this.pinchOrigin=c},pinchMove:function(a,b){var c=b.scale,d=this.map.layerContainerOriginPx,e=this.pinchOrigin,f=this.preserveCenter?this.map.getPixelFromLonLat(this.map.getCenter()):a.xy,g=Math.round(d.x+f.x-e.x+(c-1)*(d.x-e.x)),d=Math.round(d.y+f.y-e.y+(c-1)*(d.y-e.y));this.map.applyTransform(g,d,c);this.currentCenter=f},pinchDone:function(a,b,c){this.map.applyTransform();a=this.map.getZoomForResolution(this.map.getResolution()/c.scale,!0);if(a!==this.map.getZoom()||!this.currentCenter.equals(this.pinchOrigin)){b=
+this.map.getResolutionForZoom(a);c=this.map.getLonLatFromPixel(this.pinchOrigin);var d=this.currentCenter,e=this.map.getSize();c.lon+=b*(e.w/2-d.x);c.lat-=b*(e.h/2-d.y);this.map.div.clientWidth=this.map.div.clientWidth;this.map.setCenter(c,a)}},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,clickHandlerOptions:null,documentDrag:!1,autoActivate:!0,initialize:function(a){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.deactivate();this.dragPan&&this.dragPan.destroy();this.dragPan=null;this.pinchZoom&&(this.pinchZoom.destroy(),delete this.pinchZoom);OpenLayers.Control.prototype.destroy.apply(this,
+arguments)},activate:function(){return OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.dragPan.activate(),this.handlers.click.activate(),this.pinchZoom.activate(),!0):!1},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments)?(this.dragPan.deactivate(),this.handlers.click.deactivate(),this.pinchZoom.deactivate(),!0):!1},draw:function(){var a={click:this.defaultClick,dblclick:this.defaultDblClick},b=OpenLayers.Util.extend({"double":!0,stopDouble:!0,
+pixelTolerance:2},this.clickHandlerOptions);this.handlers.click=new OpenLayers.Handler.Click(this,a,b);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions))},defaultClick:function(a){a.lastTouches&&2==a.lastTouches.length&&this.map.zoomOut()},defaultDblClick:function(a){this.map.zoomTo(this.map.zoom+
+1,a.xy)},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});OpenLayers.Console.warn("OpenLayers.Rico is deprecated");OpenLayers.Rico=OpenLayers.Rico||{};
+OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(a,b,c){this.rgb={r:a,g:b,b:c}},setRed:function(a){this.rgb.r=a},setGreen:function(a){this.rgb.g=a},setBlue:function(a){this.rgb.b=a},setHue:function(a){var b=this.asHSB();b.h=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},setSaturation:function(a){var b=this.asHSB();b.s=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},setBrightness:function(a){var b=this.asHSB();b.b=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},
+darken:function(a){var b=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,Math.max(b.b-a,0))},brighten:function(a){var b=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,Math.min(b.b+a,1))},blend:function(a){this.rgb.r=Math.floor((this.rgb.r+a.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+a.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+a.rgb.b)/2)},isBright:function(){this.asHSB();return 0.5<this.asHSB().b},isDark:function(){return!this.isBright()},asRGB:function(){return"rgb("+
+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")"},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart()},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b)},toString:function(){return this.asHex()}});
+OpenLayers.Rico.Color.createFromHex=function(a){if(4==a.length){var b=a;a="#";for(var c=1;4>c;c++)a+=b.charAt(c)+b.charAt(c)}0==a.indexOf("#")&&(a=a.substring(1));b=a.substring(0,2);c=a.substring(2,4);a=a.substring(4,6);return new OpenLayers.Rico.Color(parseInt(b,16),parseInt(c,16),parseInt(a,16))};
+OpenLayers.Rico.Color.createColorFromBackground=function(a){var b=OpenLayers.Element.getStyle(OpenLayers.Util.getElement(a),"backgroundColor");return"transparent"==b&&a.parentNode?OpenLayers.Rico.Color.createColorFromBackground(a.parentNode):null==b?new OpenLayers.Rico.Color(255,255,255):0==b.indexOf("rgb(")?(a=b.substring(4,b.length-1).split(","),new OpenLayers.Rico.Color(parseInt(a[0]),parseInt(a[1]),parseInt(a[2]))):0==b.indexOf("#")?OpenLayers.Rico.Color.createFromHex(b):new OpenLayers.Rico.Color(255,
+255,255)};
+OpenLayers.Rico.Color.HSBtoRGB=function(a,b,c){var d=0,e=0,f=0;if(0==b)f=e=d=parseInt(255*c+0.5);else{a=6*(a-Math.floor(a));var g=a-Math.floor(a),h=c*(1-b),k=c*(1-b*g);b=c*(1-b*(1-g));switch(parseInt(a)){case 0:d=255*c+0.5;e=255*b+0.5;f=255*h+0.5;break;case 1:d=255*k+0.5;e=255*c+0.5;f=255*h+0.5;break;case 2:d=255*h+0.5;e=255*c+0.5;f=255*b+0.5;break;case 3:d=255*h+0.5;e=255*k+0.5;f=255*c+0.5;break;case 4:d=255*b+0.5;e=255*h+0.5;f=255*c+0.5;break;case 5:d=255*c+0.5,e=255*h+0.5,f=255*k+0.5}}return{r:parseInt(d),g:parseInt(e),
+b:parseInt(f)}};OpenLayers.Rico.Color.RGBtoHSB=function(a,b,c){var d,e=a>b?a:b;c>e&&(e=c);var f=a<b?a:b;c<f&&(f=c);d=0!=e?(e-f)/e:0;if(0==d)a=0;else{var g=(e-a)/(e-f),h=(e-b)/(e-f);c=(e-c)/(e-f);a=(a==e?c-h:b==e?2+g-c:4+h-g)/6;0>a&&(a+=1)}return{h:a,s:d,b:e/255}};OpenLayers.Style2=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:!1,rules:null,initialize:function(a){OpenLayers.Util.extend(this,a);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){for(var a=0,b=this.rules.length;a<b;a++)this.rules[a].destroy();delete this.rules},clone:function(){var a=OpenLayers.Util.extend({},this);if(this.rules){a.rules=[];for(var b=0,c=this.rules.length;b<c;++b)a.rules.push(this.rules[b].clone())}return new OpenLayers.Style2(a)},
+CLASS_NAME:"OpenLayers.Style2"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(a,b){OpenLayers.Format.GML.prototype.initialize.apply(this,[a]);this.layer=b;this.layer.featureNS&&(this.featureNS=this.layer.featureNS);this.layer.options.geometry_column&&(this.geometryName=this.layer.options.geometry_column);this.layer.options.typename&&(this.featureName=this.layer.options.typename)},write:function(a){var b=this.createElementNS(this.wfsns,
+"wfs:Transaction");b.setAttribute("version","1.0.0");b.setAttribute("service","WFS");for(var c=0;c<a.length;c++)switch(a[c].state){case OpenLayers.State.INSERT:b.appendChild(this.insert(a[c]));break;case OpenLayers.State.UPDATE:b.appendChild(this.update(a[c]));break;case OpenLayers.State.DELETE:b.appendChild(this.remove(a[c]))}return OpenLayers.Format.XML.prototype.write.apply(this,[b])},createFeatureXML:function(a){var b=this.buildGeometryNode(a.geometry),c=this.createElementNS(this.featureNS,"feature:"+
+this.geometryName);c.appendChild(b);b=this.createElementNS(this.featureNS,"feature:"+this.featureName);b.appendChild(c);for(var d in a.attributes){var c=this.createTextNode(a.attributes[d]),e=d;-1!=d.search(":")&&(e=d.split(":")[1]);e=this.createElementNS(this.featureNS,"feature:"+e);e.appendChild(c);b.appendChild(e)}return b},insert:function(a){var b=this.createElementNS(this.wfsns,"wfs:Insert");b.appendChild(this.createFeatureXML(a));return b},update:function(a){a.fid||OpenLayers.Console.userError(OpenLayers.i18n("noFID"));
+var b=this.createElementNS(this.wfsns,"wfs:Update");b.setAttribute("typeName",this.featurePrefix+":"+this.featureName);b.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var c=this.createElementNS(this.wfsns,"wfs:Property"),d=this.createElementNS(this.wfsns,"wfs:Name"),e=this.createTextNode(this.geometryName);d.appendChild(e);c.appendChild(d);d=this.createElementNS(this.wfsns,"wfs:Value");e=this.buildGeometryNode(a.geometry);a.layer&&e.setAttribute("srsName",a.layer.projection.getCode());
+d.appendChild(e);c.appendChild(d);b.appendChild(c);for(var f in a.attributes)c=this.createElementNS(this.wfsns,"wfs:Property"),d=this.createElementNS(this.wfsns,"wfs:Name"),d.appendChild(this.createTextNode(f)),c.appendChild(d),d=this.createElementNS(this.wfsns,"wfs:Value"),d.appendChild(this.createTextNode(a.attributes[f])),c.appendChild(d),b.appendChild(c);c=this.createElementNS(this.ogcns,"ogc:Filter");f=this.createElementNS(this.ogcns,"ogc:FeatureId");f.setAttribute("fid",a.fid);c.appendChild(f);
+b.appendChild(c);return b},remove:function(a){if(!a.fid)return OpenLayers.Console.userError(OpenLayers.i18n("noFID")),!1;var b=this.createElementNS(this.wfsns,"wfs:Delete");b.setAttribute("typeName",this.featurePrefix+":"+this.featureName);b.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var c=this.createElementNS(this.ogcns,"ogc:Filter"),d=this.createElementNS(this.ogcns,"ogc:FeatureId");d.setAttribute("fid",a.fid);c.appendChild(d);b.appendChild(c);return b},destroy:function(){this.layer=
+null},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Format.SLD.v1_0_0_GeoServer=OpenLayers.Class(OpenLayers.Format.SLD.v1_0_0,{version:"1.0.0",profile:"GeoServer",readers:OpenLayers.Util.applyDefaults({sld:OpenLayers.Util.applyDefaults({Priority:function(a,b){var c=this.readers.ogc._expression.call(this,a);c&&(b.priority=c)},VendorOption:function(a,b){b.vendorOptions||(b.vendorOptions={});b.vendorOptions[a.getAttribute("name")]=this.getChildValue(a)},TextSymbolizer:function(a,b){OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld.TextSymbolizer.apply(this,
+arguments);var c=this.multipleSymbolizers?b.symbolizers[b.symbolizers.length-1]:b.symbolizer.Text;void 0===c.graphic&&(c.graphic=!1)}},OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld)},OpenLayers.Format.SLD.v1_0_0.prototype.readers),writers:OpenLayers.Util.applyDefaults({sld:OpenLayers.Util.applyDefaults({Priority:function(a){return this.writers.sld._OGCExpression.call(this,"sld:Priority",a)},VendorOption:function(a){return this.createElementNSPlus("sld:VendorOption",{attributes:{name:a.name},
+value:a.value})},TextSymbolizer:function(a){var b=OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld.TextSymbolizer.apply(this,arguments);!1!==a.graphic&&(a.externalGraphic||a.graphicName)&&this.writeNode("Graphic",a,b);"priority"in a&&this.writeNode("Priority",a.priority,b);return this.addVendorOptions(b,a)},PointSymbolizer:function(a){var b=OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld.PointSymbolizer.apply(this,arguments);return this.addVendorOptions(b,a)},LineSymbolizer:function(a){var b=
+OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld.LineSymbolizer.apply(this,arguments);return this.addVendorOptions(b,a)},PolygonSymbolizer:function(a){var b=OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld.PolygonSymbolizer.apply(this,arguments);return this.addVendorOptions(b,a)}},OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld)},OpenLayers.Format.SLD.v1_0_0.prototype.writers),addVendorOptions:function(a,b){if(b.vendorOptions)for(var c in b.vendorOptions)this.writeNode("VendorOption",{name:c,
+value:b.vendorOptions[c]},a);return a},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0_GeoServer"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{drawMarker:function(a){var b=this.map.getLayerPxFromLonLat({lon:a.bounds.left,lat:a.bounds.top}),c=this.map.getLayerPxFromLonLat({lon:a.bounds.right,lat:a.bounds.bottom});null==c||null==b?a.display(!1):(b=a.draw(b,{w:Math.max(1,c.x-b.x),h:Math.max(1,c.y-b.y)}),a.drawn||(this.div.appendChild(b),a.drawn=!0))},removeMarker:function(a){OpenLayers.Util.removeItem(this.markers,a);null!=a.div&&a.div.parentNode==this.div&&this.div.removeChild(a.div)},
+CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Format.WFSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{readers:{wfs:OpenLayers.Util.applyDefaults({Service:function(a,b){b.service={};this.readChildNodes(a,b.service)},Fees:function(a,b){var c=this.getChildValue(a);c&&"none"!=c.toLowerCase()&&(b.fees=c)},AccessConstraints:function(a,b){var c=this.getChildValue(a);c&&"none"!=c.toLowerCase()&&(b.accessConstraints=c)},OnlineResource:function(a,b){var c=this.getChildValue(a);c&&"none"!=c.toLowerCase()&&(b.onlineResource=
+c)},Keywords:function(a,b){var c=this.getChildValue(a);c&&"none"!=c.toLowerCase()&&(b.keywords=c.split(", "))},Capability:function(a,b){b.capability={};this.readChildNodes(a,b.capability)},Request:function(a,b){b.request={};this.readChildNodes(a,b.request)},GetFeature:function(a,b){b.getfeature={href:{},formats:[]};this.readChildNodes(a,b.getfeature)},ResultFormat:function(a,b){for(var c=a.childNodes,d,e=0;e<c.length;e++)d=c[e],1==d.nodeType&&b.formats.push(d.nodeName)},DCPType:function(a,b){this.readChildNodes(a,
+b)},HTTP:function(a,b){this.readChildNodes(a,b.href)},Get:function(a,b){b.get=a.getAttribute("onlineResource")},Post:function(a,b){b.post=a.getAttribute("onlineResource")},SRS:function(a,b){var c=this.getChildValue(a);c&&(b.srs=c)}},OpenLayers.Format.WFSCapabilities.v1.prototype.readers.wfs)},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_0_0"});OpenLayers.Format.WMSCapabilities.v1_3=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{wms:OpenLayers.Util.applyDefaults({WMS_Capabilities:function(a,b){this.readChildNodes(a,b)},LayerLimit:function(a,b){b.layerLimit=parseInt(this.getChildValue(a))},MaxWidth:function(a,b){b.maxWidth=parseInt(this.getChildValue(a))},MaxHeight:function(a,b){b.maxHeight=parseInt(this.getChildValue(a))},BoundingBox:function(a,b){var c=OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms.BoundingBox.apply(this,
+[a,b]);c.srs=a.getAttribute("CRS");b.bbox[c.srs]=c},CRS:function(a,b){this.readers.wms.SRS.apply(this,[a,b])},EX_GeographicBoundingBox:function(a,b){b.llbbox=[];this.readChildNodes(a,b.llbbox)},westBoundLongitude:function(a,b){b[0]=this.getChildValue(a)},eastBoundLongitude:function(a,b){b[2]=this.getChildValue(a)},southBoundLatitude:function(a,b){b[1]=this.getChildValue(a)},northBoundLatitude:function(a,b){b[3]=this.getChildValue(a)},MinScaleDenominator:function(a,b){b.maxScale=parseFloat(this.getChildValue(a)).toPrecision(16)},
+MaxScaleDenominator:function(a,b){b.minScale=parseFloat(this.getChildValue(a)).toPrecision(16)},Dimension:function(a,b){var c={name:a.getAttribute("name").toLowerCase(),units:a.getAttribute("units"),unitsymbol:a.getAttribute("unitSymbol"),nearestVal:"1"===a.getAttribute("nearestValue"),multipleVal:"1"===a.getAttribute("multipleValues"),"default":a.getAttribute("default")||"",current:"1"===a.getAttribute("current"),values:this.getChildValue(a).split(",")};b.dimensions[c.name]=c},Keyword:function(a,
+b){var c={value:this.getChildValue(a),vocabulary:a.getAttribute("vocabulary")};b.keywords&&b.keywords.push(c)}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers.wms),sld:{UserDefinedSymbolization:function(a,b){this.readers.wms.UserDefinedSymbolization.apply(this,[a,b]);b.userSymbols.inlineFeature=1==parseInt(a.getAttribute("InlineFeature"));b.userSymbols.remoteWCS=1==parseInt(a.getAttribute("RemoteWCS"))},DescribeLayer:function(a,b){this.readers.wms.DescribeLayer.apply(this,[a,b])},GetLegendGraphic:function(a,
+b){this.readers.wms.GetLegendGraphic.apply(this,[a,b])}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3"});OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{size:null,isBaseLayer:!0,standardTileSize:256,tileOriginCorner:"tl",numberOfTiers:0,tileCountUpToTier:null,tierSizeInTiles:null,tierImageSize:null,initialize:function(a,b,c,d){this.initializeZoomify(c);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a,b,c,{},d])},initializeZoomify:function(a){var b=a.clone();this.size=a.clone();a=new OpenLayers.Size(Math.ceil(b.w/this.standardTileSize),Math.ceil(b.h/this.standardTileSize));this.tierSizeInTiles=
+[a];for(this.tierImageSize=[b];b.w>this.standardTileSize||b.h>this.standardTileSize;)b=new OpenLayers.Size(Math.floor(b.w/2),Math.floor(b.h/2)),a=new OpenLayers.Size(Math.ceil(b.w/this.standardTileSize),Math.ceil(b.h/this.standardTileSize)),this.tierSizeInTiles.push(a),this.tierImageSize.push(b);this.tierSizeInTiles.reverse();this.tierImageSize.reverse();this.numberOfTiers=this.tierSizeInTiles.length;b=[1];this.tileCountUpToTier=[0];for(a=1;a<this.numberOfTiers;a++)b.unshift(Math.pow(2,a)),this.tileCountUpToTier.push(this.tierSizeInTiles[a-
+1].w*this.tierSizeInTiles[a-1].h+this.tileCountUpToTier[a-1]);this.serverResolutions||(this.serverResolutions=b)},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);this.tileCountUpToTier.length=0;this.tierSizeInTiles.length=0;this.tierImageSize.length=0},clone:function(a){null==a&&(a=new OpenLayers.Layer.Zoomify(this.name,this.url,this.size,this.options));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){a=this.adjustBounds(a);var b=
+this.getServerResolution(),c=Math.round((a.left-this.tileOrigin.lon)/(b*this.tileSize.w));a=Math.round((this.tileOrigin.lat-a.top)/(b*this.tileSize.h));b=this.getZoomForResolution(b);c="TileGroup"+Math.floor((c+a*this.tierSizeInTiles[b].w+this.tileCountUpToTier[b])/256)+"/"+b+"-"+c+"-"+a+".jpg";b=this.url;OpenLayers.Util.isArray(b)&&(b=this.selectUrl(c,b));return b+c},getImageSize:function(){if(0<arguments.length){var a=this.adjustBounds(arguments[0]),b=this.getServerResolution(),c=Math.round((a.left-
+this.tileOrigin.lon)/(b*this.tileSize.w)),a=Math.round((this.tileOrigin.lat-a.top)/(b*this.tileSize.h)),b=this.getZoomForResolution(b),d=this.standardTileSize,e=this.standardTileSize;c==this.tierSizeInTiles[b].w-1&&(d=this.tierImageSize[b].w%this.standardTileSize);a==this.tierSizeInTiles[b].h-1&&(e=this.tierImageSize[b].h%this.standardTileSize);return new OpenLayers.Size(d,e)}return this.tileSize},setMap:function(a){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,
+this.map.maxExtent.top)},CLASS_NAME:"OpenLayers.Layer.Zoomify"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(a,b,c,d){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(null==d||null==d.isBaseLayer)this.isBaseLayer="true"!=this.params.transparent&&!0!=this.params.transparent},clone:function(a){null==a&&(a=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.getOptions()));
+return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getURL:function(a){a=this.adjustBounds(a);a=[a.left,a.bottom,a.right,a.top];var b=this.getImageSize();return this.getFullRequestString({mapext:a,imgext:a,map_size:[b.w,b.h],imgx:b.w/2,imgy:b.h/2,imgxy:[b.w,b.h]})},getFullRequestString:function(a,b){var c=null==b?this.url:b,d=OpenLayers.Util.extend({},this.params),d=OpenLayers.Util.extend(d,a),e=OpenLayers.Util.getParameterString(d);OpenLayers.Util.isArray(c)&&(c=this.selectUrl(e,c));
+var e=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(c)),f;for(f in d)f.toUpperCase()in e&&delete d[f];e=OpenLayers.Util.getParameterString(d);d=c;e=e.replace(/,/g,"+");""!=e&&(f=c.charAt(c.length-1),d="&"==f||"?"==f?d+e:-1==c.indexOf("?")?d+("?"+e):d+("&"+e));return d},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",symbolCache:{},offset:null,initialize:function(a){if(this.supported()){if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);for(var b=document.createStyleSheet(),c="shape rect oval fill stroke imagedata group textbox".split(" "),d=0,e=c.length;d<e;d++)b.addRule("olv\\:"+c[d],"behavior: url(#default#VML); position: absolute; display: inline-block;")}OpenLayers.Renderer.Elements.prototype.initialize.apply(this,
+arguments)}},supported:function(){return!!document.namespaces},setExtent:function(a,b){var c=OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments),d=this.getResolution(),e=a.left/d|0,d=a.top/d-this.size.h|0;b||!this.offset?(this.offset={x:e,y:d},d=e=0):(e-=this.offset.x,d-=this.offset.y);this.root.coordorigin=e-this.xOffset+" "+d;for(var e=[this.root,this.vectorRoot,this.textRoot],f=0,g=e.length;f<g;++f)d=e[f],d.coordsize=this.size.w+" "+this.size.h;this.root.style.flip="y";return c},
+setSize:function(a){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);for(var b=[this.rendererRoot,this.root,this.vectorRoot,this.textRoot],c=this.size.w+"px",d=this.size.h+"px",e,f=0,g=b.length;f<g;++f)e=b[f],e.style.width=c,e.style.height=d},getNodeType:function(a,b){var c=null;switch(a.CLASS_NAME){case "OpenLayers.Geometry.Point":c=b.externalGraphic?"olv:rect":this.isComplexSymbol(b.graphicName)?"olv:shape":"olv:oval";break;case "OpenLayers.Geometry.Rectangle":c="olv:rect";break;case "OpenLayers.Geometry.LineString":case "OpenLayers.Geometry.LinearRing":case "OpenLayers.Geometry.Polygon":case "OpenLayers.Geometry.Curve":c=
+"olv:shape"}return c},setStyle:function(a,b,c,d){b=b||a._style;c=c||a._options;var e=b.fillColor,f=b.title||b.graphicTitle;f&&(a.title=f);if("OpenLayers.Geometry.Point"===a._geometryClass)if(b.externalGraphic){c.isFilled=!0;var e=b.graphicWidth||b.graphicHeight,f=b.graphicHeight||b.graphicWidth,e=e?e:2*b.pointRadius,f=f?f:2*b.pointRadius,g=this.getResolution(),h=void 0!=b.graphicXOffset?b.graphicXOffset:-(0.5*e),k=void 0!=b.graphicYOffset?b.graphicYOffset:-(0.5*f);a.style.left=((d.x-this.featureDx)/
+g-this.offset.x+h|0)+"px";a.style.top=(d.y/g-this.offset.y-(k+f)|0)+"px";a.style.width=e+"px";a.style.height=f+"px";a.style.flip="y";e="none";c.isStroked=!1}else this.isComplexSymbol(b.graphicName)?(f=this.importSymbol(b.graphicName),a.path=f.path,a.coordorigin=f.left+","+f.bottom,f=f.size,a.coordsize=f+","+f,this.drawCircle(a,d,b.pointRadius),a.style.flip="y"):this.drawCircle(a,d,b.pointRadius);c.isFilled?a.fillcolor=e:a.filled="false";d=a.getElementsByTagName("fill");d=0==d.length?null:d[0];c.isFilled?
+(d||(d=this.createNode("olv:fill",a.id+"_fill")),d.opacity=b.fillOpacity,"OpenLayers.Geometry.Point"===a._geometryClass&&b.externalGraphic&&(b.graphicOpacity&&(d.opacity=b.graphicOpacity),d.src=b.externalGraphic,d.type="frame",b.graphicWidth&&b.graphicHeight||(d.aspect="atmost")),d.parentNode!=a&&a.appendChild(d)):d&&a.removeChild(d);e=b.rotation;if(void 0!==e||void 0!==a._rotation)a._rotation=e,b.externalGraphic?(this.graphicRotate(a,h,k,b),d.opacity=0):"OpenLayers.Geometry.Point"===a._geometryClass&&
+(a.style.rotation=e||0);h=a.getElementsByTagName("stroke");h=0==h.length?null:h[0];c.isStroked?(h||(h=this.createNode("olv:stroke",a.id+"_stroke"),a.appendChild(h)),h.on=!0,h.color=b.strokeColor,h.weight=b.strokeWidth+"px",h.opacity=b.strokeOpacity,h.endcap="butt"==b.strokeLinecap?"flat":b.strokeLinecap||"round",b.strokeDashstyle&&(h.dashstyle=this.dashStyle(b))):(a.stroked=!1,h&&(h.on=!1));"inherit"!=b.cursor&&null!=b.cursor&&(a.style.cursor=b.cursor);return a},graphicRotate:function(a,b,c,d){d=
+d||a._style;var e=d.rotation||0,f,g;if(d.graphicWidth&&d.graphicHeight){g=Math.max(d.graphicWidth,d.graphicHeight);f=d.graphicWidth/d.graphicHeight;var h=Math.round(d.graphicWidth||g*f),k=Math.round(d.graphicHeight||g);a.style.width=h+"px";a.style.height=k+"px";var l=document.getElementById(a.id+"_image");l||(l=this.createNode("olv:imagedata",a.id+"_image"),a.appendChild(l));l.style.width=h+"px";l.style.height=k+"px";l.src=d.externalGraphic;l.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='', sizingMethod='scale')";
+l=e*Math.PI/180;e=Math.sin(l);l=Math.cos(l);e="progid:DXImageTransform.Microsoft.Matrix(M11="+l+",M12="+-e+",M21="+e+",M22="+l+",SizingMethod='auto expand')\n";(l=d.graphicOpacity||d.fillOpacity)&&1!=l&&(e+="progid:DXImageTransform.Microsoft.BasicImage(opacity="+l+")\n");a.style.filter=e;e=new OpenLayers.Geometry.Point(-b,-c);h=(new OpenLayers.Bounds(0,0,h,k)).toGeometry();h.rotate(d.rotation,e);h=h.getBounds();a.style.left=Math.round(parseInt(a.style.left)+h.left)+"px";a.style.top=Math.round(parseInt(a.style.top)-
+h.bottom)+"px"}else{var m=new Image;m.onreadystatechange=OpenLayers.Function.bind(function(){if("complete"==m.readyState||"interactive"==m.readyState)f=m.width/m.height,g=Math.max(2*d.pointRadius,d.graphicWidth||0,d.graphicHeight||0),b*=f,d.graphicWidth=g*f,d.graphicHeight=g,this.graphicRotate(a,b,c,d)},this);m.src=d.externalGraphic}},postDraw:function(a){a.style.visibility="visible";var b=a._style.fillColor,c=a._style.strokeColor;"none"==b&&a.fillcolor!=b&&(a.fillcolor=b);"none"==c&&a.strokecolor!=
+c&&(a.strokecolor=c)},setNodeDimension:function(a,b){var c=b.getBounds();if(c){var d=this.getResolution(),c=new OpenLayers.Bounds((c.left-this.featureDx)/d-this.offset.x|0,c.bottom/d-this.offset.y|0,(c.right-this.featureDx)/d-this.offset.x|0,c.top/d-this.offset.y|0);a.style.left=c.left+"px";a.style.top=c.top+"px";a.style.width=c.getWidth()+"px";a.style.height=c.getHeight()+"px";a.coordorigin=c.left+" "+c.top;a.coordsize=c.getWidth()+" "+c.getHeight()}},dashStyle:function(a){a=a.strokeDashstyle;switch(a){case "solid":case "dot":case "dash":case "dashdot":case "longdash":case "longdashdot":return a;
+default:return a=a.split(/[ ,]/),2==a.length?1*a[0]>=2*a[1]?"longdash":1==a[0]||1==a[1]?"dot":"dash":4==a.length?1*a[0]>=2*a[1]?"longdashdot":"dashdot":"solid"}},createNode:function(a,b){var c=document.createElement(a);b&&(c.id=b);c.unselectable="on";c.onselectstart=OpenLayers.Function.False;return c},nodeTypeCompare:function(a,b){var c=b,d=c.indexOf(":");-1!=d&&(c=c.substr(d+1));var e=a.nodeName,d=e.indexOf(":");-1!=d&&(e=e.substr(d+1));return c==e},createRenderRoot:function(){return this.nodeFactory(this.container.id+
+"_vmlRoot","div")},createRoot:function(a){return this.nodeFactory(this.container.id+a,"olv:group")},drawPoint:function(a,b){return this.drawCircle(a,b,1)},drawCircle:function(a,b,c){if(!isNaN(b.x)&&!isNaN(b.y)){var d=this.getResolution();a.style.left=((b.x-this.featureDx)/d-this.offset.x|0)-c+"px";a.style.top=(b.y/d-this.offset.y|0)-c+"px";b=2*c;a.style.width=b+"px";a.style.height=b+"px";return a}return!1},drawLineString:function(a,b){return this.drawLine(a,b,!1)},drawLinearRing:function(a,b){return this.drawLine(a,
+b,!0)},drawLine:function(a,b,c){this.setNodeDimension(a,b);for(var d=this.getResolution(),e=b.components.length,f=Array(e),g,h,k=0;k<e;k++)g=b.components[k],h=(g.x-this.featureDx)/d-this.offset.x|0,g=g.y/d-this.offset.y|0,f[k]=" "+h+","+g+" l ";b=c?" x e":" e";a.path="m"+f.join("")+b;return a},drawPolygon:function(a,b){this.setNodeDimension(a,b);var c=this.getResolution(),d=[],e,f,g,h,k,l,m,n,p,q;e=0;for(f=b.components.length;e<f;e++){d.push("m");g=b.components[e].components;h=0===e;l=k=null;m=0;
+for(n=g.length;m<n;m++)p=g[m],q=(p.x-this.featureDx)/c-this.offset.x|0,p=p.y/c-this.offset.y|0,q=" "+q+","+p,d.push(q),0==m&&d.push(" l"),h||(k?k!=q&&(l?l!=q&&(h=!0):l=q):k=q);d.push(h?" x ":" ")}d.push("e");a.path=d.join("");return a},drawRectangle:function(a,b){var c=this.getResolution();a.style.left=((b.x-this.featureDx)/c-this.offset.x|0)+"px";a.style.top=(b.y/c-this.offset.y|0)+"px";a.style.width=(b.width/c|0)+"px";a.style.height=(b.height/c|0)+"px";return a},drawText:function(a,b,c){var d=this.nodeFactory(a+
+this.LABEL_ID_SUFFIX,"olv:rect"),e=this.nodeFactory(a+this.LABEL_ID_SUFFIX+"_textbox","olv:textbox"),f=this.getResolution();d.style.left=((c.x-this.featureDx)/f-this.offset.x|0)+"px";d.style.top=(c.y/f-this.offset.y|0)+"px";d.style.flip="y";e.innerText=b.label;"inherit"!=b.cursor&&null!=b.cursor&&(e.style.cursor=b.cursor);b.fontColor&&(e.style.color=b.fontColor);b.fontOpacity&&(e.style.filter="alpha(opacity="+100*b.fontOpacity+")");b.fontFamily&&(e.style.fontFamily=b.fontFamily);b.fontSize&&(e.style.fontSize=
+b.fontSize);b.fontWeight&&(e.style.fontWeight=b.fontWeight);b.fontStyle&&(e.style.fontStyle=b.fontStyle);!0===b.labelSelect&&(d._featureId=a,e._featureId=a,e._geometry=c,e._geometryClass=c.CLASS_NAME);e.style.whiteSpace="nowrap";e.inset="1px,0px,0px,0px";d.parentNode||(d.appendChild(e),this.textRoot.appendChild(d));b=b.labelAlign||"cm";1==b.length&&(b+="m");a=e.clientWidth*OpenLayers.Renderer.VML.LABEL_SHIFT[b.substr(0,1)];e=e.clientHeight*OpenLayers.Renderer.VML.LABEL_SHIFT[b.substr(1,1)];d.style.left=
+parseInt(d.style.left)-a-1+"px";d.style.top=parseInt(d.style.top)+e+"px"},moveRoot:function(a){var b=this.map.getLayer(a.container.id);b instanceof OpenLayers.Layer.Vector.RootContainer&&(b=this.map.getLayer(this.container.id));b&&b.renderer.clear();OpenLayers.Renderer.Elements.prototype.moveRoot.apply(this,arguments);b&&b.redraw()},importSymbol:function(a){var b=this.container.id+"-"+a,c=this.symbolCache[b];if(c)return c;c=OpenLayers.Renderer.symbol[a];if(!c)throw Error(a+" is not a valid symbol name");
+a=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);for(var d=["m"],e=0;e<c.length;e+=2){var f=c[e],g=c[e+1];a.left=Math.min(a.left,f);a.bottom=Math.min(a.bottom,g);a.right=Math.max(a.right,f);a.top=Math.max(a.top,g);d.push(f);d.push(g);0==e&&d.push("l")}d.push("x e");c=d.join(" ");d=(a.getWidth()-a.getHeight())/2;0<d?(a.bottom-=d,a.top+=d):(a.left+=d,a.right-=d);c={path:c,size:a.getWidth(),left:a.left,bottom:a.bottom};return this.symbolCache[b]=c},CLASS_NAME:"OpenLayers.Renderer.VML"});
+OpenLayers.Renderer.VML.LABEL_SHIFT={l:0,c:0.5,r:1,t:0,m:0.5,b:1};OpenLayers.Control.CacheRead=OpenLayers.Class(OpenLayers.Control,{fetchEvent:"tileloadstart",layers:null,autoActivate:!0,setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);var b,c=this.layers||a.layers;for(b=c.length-1;0<=b;--b)this.addLayer({layer:c[b]});if(!this.layers)a.events.on({addlayer:this.addLayer,removeLayer:this.removeLayer,scope:this})},addLayer:function(a){a.layer.events.register(this.fetchEvent,this,this.fetch)},removeLayer:function(a){a.layer.events.unregister(this.fetchEvent,
+this,this.fetch)},fetch:function(a){if(this.active&&window.localStorage&&a.tile instanceof OpenLayers.Tile.Image){var b=a.tile,c=b.url;!b.layer.crossOriginKeyword&&(OpenLayers.ProxyHost&&0===c.indexOf(OpenLayers.ProxyHost))&&(c=OpenLayers.Control.CacheWrite.urlMap[c]);if(c=window.localStorage.getItem("olCache_"+c))b.url=c,"tileerror"===a.type&&b.setImgSrc(c)}},destroy:function(){if(this.layers||this.map){var a,b=this.layers||this.map.layers;for(a=b.length-1;0<=a;--a)this.removeLayer({layer:b[a]})}this.map&&
+this.map.events.un({addlayer:this.addLayer,removeLayer:this.removeLayer,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},CLASS_NAME:"OpenLayers.Control.CacheRead"});OpenLayers.Protocol.WFS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFS.v1_0_0"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:"_layer",featureIdentifier:"_feature",regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},gmlFormat:null,read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));var b=a.documentElement;if(b){var c=this["read_"+b.nodeName];a=c?c.call(this,b):(new OpenLayers.Format.GML(this.options?this.options:{})).read(a)}return a},read_msGMLOutput:function(a){var b=
+[];if(a=this.getSiblingNodesByTagCriteria(a,this.layerIdentifier))for(var c=0,d=a.length;c<d;++c){var e=a[c],f=e.nodeName;e.prefix&&(f=f.split(":")[1]);f=f.replace(this.layerIdentifier,"");if(e=this.getSiblingNodesByTagCriteria(e,this.featureIdentifier))for(var g=0;g<e.length;g++){var h=e[g],k=this.parseGeometry(h),h=this.parseAttributes(h),h=new OpenLayers.Feature.Vector(k.geometry,h,null);h.bounds=k.bounds;h.type=f;b.push(h)}}return b},read_FeatureInfoResponse:function(a){var b=[];a=this.getElementsByTagNameNS(a,
+"*","FIELDS");for(var c=0,d=a.length;c<d;c++){var e=a[c],f={},g,h=e.attributes.length;if(0<h)for(g=0;g<h;g++){var k=e.attributes[g];f[k.nodeName]=k.nodeValue}else for(e=e.childNodes,g=0,h=e.length;g<h;++g)k=e[g],3!=k.nodeType&&(f[k.getAttribute("name")]=k.getAttribute("value"));b.push(new OpenLayers.Feature.Vector(null,f,null))}return b},getSiblingNodesByTagCriteria:function(a,b){var c=[],d,e,f,g;if(a&&a.hasChildNodes()){d=a.childNodes;f=d.length;for(var h=0;h<f;h++){for(g=d[h];g&&1!=g.nodeType;)g=
+g.nextSibling,h++;e=g?g.nodeName:"";0<e.length&&-1<e.indexOf(b)?c.push(g):(e=this.getSiblingNodesByTagCriteria(g,b),0<e.length&&(0==c.length?c=e:c.push(e)))}}return c},parseAttributes:function(a){var b={};if(1==a.nodeType){a=a.childNodes;for(var c=a.length,d=0;d<c;++d){var e=a[d];if(1==e.nodeType){var f=e.childNodes,e=e.prefix?e.nodeName.split(":")[1]:e.nodeName;0==f.length?b[e]=null:1==f.length&&(f=f[0],3==f.nodeType||4==f.nodeType)&&(f=f.nodeValue.replace(this.regExes.trimSpace,""),b[e]=f)}}}return b},
+parseGeometry:function(a){this.gmlFormat||(this.gmlFormat=new OpenLayers.Format.GML);a=this.gmlFormat.parseFeature(a);var b,c=null;a&&(b=a.geometry&&a.geometry.clone(),c=a.bounds&&a.bounds.clone(),a.destroy());return{geometry:b,bounds:c}},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Control.WMTSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:!1,requestEncoding:"KVP",drillDown:!1,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:!0,infoFormat:"text/html",vendorParams:{},format:null,formatOptions:null,handler:null,hoverRequest:null,pending:0,initialize:function(a){a=a||{};a.handlerOptions=a.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[a]);this.format||(this.format=new OpenLayers.Format.WMSGetFeatureInfo(a.formatOptions));
+!0===this.drillDown&&(this.hover=!1);this.hover?this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250})):(a={},a[this.clickCallback]=this.getInfoForClick,this.handler=new OpenLayers.Handler.Click(this,a,this.handlerOptions.click||{}))},getInfoForClick:function(a){this.request(a.xy,{})},getInfoForHover:function(a){this.request(a.xy,{hover:!0})},cancelHover:function(){this.hoverRequest&&(--this.pending,
+0>=this.pending&&(OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait"),this.pending=0),this.hoverRequest.abort(),this.hoverRequest=null)},findLayers:function(){for(var a=this.layers||this.map.layers,b=[],c,d=a.length-1;0<=d&&(c=a[d],!(c instanceof OpenLayers.Layer.WMTS)||(c.requestEncoding!==this.requestEncoding||this.queryVisible&&!c.getVisibility())||(b.push(c),this.drillDown&&!this.hover));--d);return b},buildRequestOptions:function(a,b){var c=this.map.getLonLatFromPixel(b),d=a.getURL(new OpenLayers.Bounds(c.lon,
+c.lat,c.lon,c.lat)),d=OpenLayers.Util.getParameters(d),c=a.getTileInfo(c);OpenLayers.Util.extend(d,{service:"WMTS",version:a.version,request:"GetFeatureInfo",infoFormat:this.infoFormat,i:c.i,j:c.j});OpenLayers.Util.applyDefaults(d,this.vendorParams);return{url:OpenLayers.Util.isArray(a.url)?a.url[0]:a.url,params:OpenLayers.Util.upperCaseObject(d),callback:function(c){this.handleResponse(b,c,a)},scope:this}},request:function(a,b){b=b||{};var c=this.findLayers();if(0<c.length){for(var d,e,f=0,g=c.length;f<
+g;f++)e=c[f],d=this.events.triggerEvent("beforegetfeatureinfo",{xy:a,layer:e}),!1!==d&&(++this.pending,d=this.buildRequestOptions(e,a),d=OpenLayers.Request.GET(d),!0===b.hover&&(this.hoverRequest=d));0<this.pending&&OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait")}},handleResponse:function(a,b,c){--this.pending;0>=this.pending&&(OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait"),this.pending=0);if(b.status&&(200>b.status||300<=b.status))this.events.triggerEvent("exception",
+{xy:a,request:b,layer:c});else{var d=b.responseXML;d&&d.documentElement||(d=b.responseText);var e,f;try{e=this.format.read(d)}catch(g){f=!0,this.events.triggerEvent("exception",{xy:a,request:b,error:g,layer:c})}f||this.events.triggerEvent("getfeatureinfo",{text:b.responseText,features:e,request:b,xy:a,layer:c})}},CLASS_NAME:"OpenLayers.Control.WMTSGetFeatureInfo"});OpenLayers.Protocol.CSW.v2_0_2=OpenLayers.Class(OpenLayers.Protocol,{formatOptions:null,initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a]);a.format||(this.format=new OpenLayers.Format.CSWGetRecords.v2_0_2(OpenLayers.Util.extend({},this.formatOptions)))},destroy:function(){this.options&&!this.options.format&&this.format.destroy();this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefaults(a,
+this.options||{});var b=new OpenLayers.Protocol.Response({requestType:"read"}),c=this.format.write(a.params||a);b.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleRead,b,a),params:a.params,headers:a.headers,data:c});return b},handleRead:function(a,b){if(b.callback){var c=a.priv;200<=c.status&&300>c.status?(a.data=this.parseData(c),a.code=OpenLayers.Protocol.Response.SUCCESS):a.code=OpenLayers.Protocol.Response.FAILURE;b.callback.call(b.scope,a)}},parseData:function(a){var b=
+a.responseXML;b&&b.documentElement||(b=a.responseText);return!b||0>=b.length?null:this.format.read(b)},CLASS_NAME:"OpenLayers.Protocol.CSW.v2_0_2"});OpenLayers.Format.WCSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WCSCapabilities.v1,{namespaces:{wcs:"http://www.opengis.net/wcs/1.1",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",ows:"http://www.opengis.net/ows/1.1"},errorProperty:"operationsMetadata",readers:{wcs:OpenLayers.Util.applyDefaults({Capabilities:function(a,b){this.readChildNodes(a,b)},Contents:function(a,b){b.contentMetadata=[];this.readChildNodes(a,b.contentMetadata)},CoverageSummary:function(a,
+b){var c={};this.readChildNodes(a,c);b.push(c)},Identifier:function(a,b){b.identifier=this.getChildValue(a)},Title:function(a,b){b.title=this.getChildValue(a)},Abstract:function(a,b){b["abstract"]=this.getChildValue(a)},SupportedCRS:function(a,b){var c=this.getChildValue(a);c&&(b.supportedCRS||(b.supportedCRS=[]),b.supportedCRS.push(c))},SupportedFormat:function(a,b){var c=this.getChildValue(a);c&&(b.supportedFormat||(b.supportedFormat=[]),b.supportedFormat.push(c))}},OpenLayers.Format.WCSCapabilities.v1.prototype.readers.wcs),
+ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WCSCapabilities.v1_1_0"});OpenLayers.Control.Graticule=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,intervals:[45,30,20,10,5,2,1,0.5,0.2,0.1,0.05,0.01,0.005,0.002,0.001],displayInLayerSwitcher:!0,visible:!0,numPoints:50,targetSize:200,layerName:null,labelled:!0,labelFormat:"dm",lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},labelSymbolizer:{},gratLayer:null,initialize:function(a){a=a||{};a.layerName=a.layerName||OpenLayers.i18n("Graticule");OpenLayers.Control.prototype.initialize.apply(this,[a]);
+this.labelSymbolizer.stroke=!1;this.labelSymbolizer.fill=!1;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}"},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);this.gratLayer&&(this.gratLayer.destroy(),this.gratLayer=null)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.gratLayer){var a=new OpenLayers.Style({},
+{rules:[new OpenLayers.Rule({symbolizer:{Point:this.labelSymbolizer,Line:this.lineSymbolizer}})]});this.gratLayer=new OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({"default":a}),visibility:this.visible,displayInLayerSwitcher:this.displayInLayerSwitcher})}return this.div},activate:function(){return OpenLayers.Control.prototype.activate.apply(this,arguments)?(this.map.addLayer(this.gratLayer),this.map.events.register("moveend",this,this.update),this.update(),!0):!1},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,
+arguments)?(this.map.events.unregister("moveend",this,this.update),this.map.removeLayer(this.gratLayer),!0):!1},update:function(){var a=this.map.getExtent();if(a){this.gratLayer.destroyFeatures();var b=new OpenLayers.Projection("EPSG:4326"),c=this.map.getProjectionObject(),d=this.map.getResolution();c.proj&&"longlat"==c.proj.projName&&(this.numPoints=1);var e=this.map.getCenter(),f=new OpenLayers.Pixel(e.lon,e.lat);OpenLayers.Projection.transform(f,c,b);for(var e=this.targetSize*d,e=e*e,g,d=0;d<this.intervals.length;++d){g=
+this.intervals[d];var h=g/2,k=f.offset({x:-h,y:-h}),h=f.offset({x:h,y:h});OpenLayers.Projection.transform(k,b,c);OpenLayers.Projection.transform(h,b,c);if((k.x-h.x)*(k.x-h.x)+(k.y-h.y)*(k.y-h.y)<=e)break}f.x=Math.floor(f.x/g)*g;f.y=Math.floor(f.y/g)*g;var d=0,e=[f.clone()],h=f.clone(),l;do h=h.offset({x:0,y:g}),l=OpenLayers.Projection.transform(h.clone(),b,c),e.unshift(h);while(a.containsPixel(l)&&1E3>++d);h=f.clone();do h=h.offset({x:0,y:-g}),l=OpenLayers.Projection.transform(h.clone(),b,c),e.push(h);
+while(a.containsPixel(l)&&1E3>++d);d=0;k=[f.clone()];h=f.clone();do h=h.offset({x:-g,y:0}),l=OpenLayers.Projection.transform(h.clone(),b,c),k.unshift(h);while(a.containsPixel(l)&&1E3>++d);h=f.clone();do h=h.offset({x:g,y:0}),l=OpenLayers.Projection.transform(h.clone(),b,c),k.push(h);while(a.containsPixel(l)&&1E3>++d);g=[];for(d=0;d<k.length;++d){l=k[d].x;for(var f=[],m=null,n=Math.min(e[0].y,90),h=Math.max(e[e.length-1].y,-90),p=(n-h)/this.numPoints,n=h,h=0;h<=this.numPoints;++h){var q=new OpenLayers.Geometry.Point(l,
+n);q.transform(b,c);f.push(q);n+=p;q.y>=a.bottom&&!m&&(m=q)}this.labelled&&(m=new OpenLayers.Geometry.Point(m.x,a.bottom),l={value:l,label:this.labelled?OpenLayers.Util.getFormattedLonLat(l,"lon",this.labelFormat):"",labelAlign:"cb",xOffset:0,yOffset:2},this.gratLayer.addFeatures(new OpenLayers.Feature.Vector(m,l)));f=new OpenLayers.Geometry.LineString(f);g.push(new OpenLayers.Feature.Vector(f))}for(h=0;h<e.length;++h)if(n=e[h].y,!(-90>n||90<n)){f=[];d=k[0].x;p=(k[k.length-1].x-d)/this.numPoints;
+l=d;m=null;for(d=0;d<=this.numPoints;++d)q=new OpenLayers.Geometry.Point(l,n),q.transform(b,c),f.push(q),l+=p,q.x<a.right&&(m=q);this.labelled&&(m=new OpenLayers.Geometry.Point(a.right,m.y),l={value:n,label:this.labelled?OpenLayers.Util.getFormattedLonLat(n,"lat",this.labelFormat):"",labelAlign:"rb",xOffset:-2,yOffset:2},this.gratLayer.addFeatures(new OpenLayers.Feature.Vector(m,l)));f=new OpenLayers.Geometry.LineString(f);g.push(new OpenLayers.Feature.Vector(f))}this.gratLayer.addFeatures(g)}},CLASS_NAME:"OpenLayers.Control.Graticule"});OpenLayers.Console.warn("OpenLayers.Rico is deprecated");OpenLayers.Rico=OpenLayers.Rico||{};
+OpenLayers.Rico.Corner={round:function(a,b){a=OpenLayers.Util.getElement(a);this._setOptions(b);var c=this.options.color;"fromElement"==this.options.color&&(c=this._background(a));var d=this.options.bgColor;"fromParent"==this.options.bgColor&&(d=this._background(a.offsetParent));this._roundCornersImpl(a,c,d)},changeColor:function(a,b){a.style.backgroundColor=b;for(var c=a.parentNode.getElementsByTagName("span"),d=0;d<c.length;d++)c[d].style.backgroundColor=b},changeOpacity:function(a,b){var c="alpha(opacity="+
+100*b+")";a.style.opacity=b;a.style.filter=c;for(var d=a.parentNode.getElementsByTagName("span"),e=0;e<d.length;e++)d[e].style.opacity=b,d[e].style.filter=c},reRound:function(a,b){var c=a.parentNode.childNodes[2];a.parentNode.removeChild(a.parentNode.childNodes[0]);a.parentNode.removeChild(c);this.round(a.parentNode,b)},_roundCornersImpl:function(a,b,c){this.options.border&&this._renderBorder(a,c);this._isTopRounded()&&this._roundTopCorners(a,b,c);this._isBottomRounded()&&this._roundBottomCorners(a,
+b,c)},_renderBorder:function(a,b){var c="1px solid "+this._borderColor(b);a.innerHTML="<div "+("style='border-left: "+c+";"+("border-right: "+c)+"'")+">"+a.innerHTML+"</div>"},_roundTopCorners:function(a,b,c){for(var d=this._createCorner(c),e=0;e<this.options.numSlices;e++)d.appendChild(this._createCornerSlice(b,c,e,"top"));a.style.paddingTop=0;a.insertBefore(d,a.firstChild)},_roundBottomCorners:function(a,b,c){for(var d=this._createCorner(c),e=this.options.numSlices-1;0<=e;e--)d.appendChild(this._createCornerSlice(b,
+c,e,"bottom"));a.style.paddingBottom=0;a.appendChild(d)},_createCorner:function(a){var b=document.createElement("div");b.style.backgroundColor=this._isTransparent()?"transparent":a;return b},_createCornerSlice:function(a,b,c,d){var e=document.createElement("span"),f=e.style;f.backgroundColor=a;f.display="block";f.height="1px";f.overflow="hidden";f.fontSize="1px";a=this._borderColor(a,b);this.options.border&&0==c?(f.borderTopStyle="solid",f.borderTopWidth="1px",f.borderLeftWidth="0px",f.borderRightWidth=
+"0px",f.borderBottomWidth="0px",f.height="0px",f.borderColor=a):a&&(f.borderColor=a,f.borderStyle="solid",f.borderWidth="0px 1px");this.options.compact||c!=this.options.numSlices-1||(f.height="2px");this._setMargin(e,c,d);this._setBorder(e,c,d);return e},_setOptions:function(a){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:!0,border:!1,compact:!1};OpenLayers.Util.extend(this.options,a||{});this.options.numSlices=this.options.compact?2:4;this._isTransparent()&&(this.options.blend=
+!1)},_whichSideTop:function(){return this._hasString(this.options.corners,"all","top")||0<=this.options.corners.indexOf("tl")&&0<=this.options.corners.indexOf("tr")?"":0<=this.options.corners.indexOf("tl")?"left":0<=this.options.corners.indexOf("tr")?"right":""},_whichSideBottom:function(){return this._hasString(this.options.corners,"all","bottom")||0<=this.options.corners.indexOf("bl")&&0<=this.options.corners.indexOf("br")?"":0<=this.options.corners.indexOf("bl")?"left":0<=this.options.corners.indexOf("br")?
+"right":""},_borderColor:function(a,b){return"transparent"==a?b:this.options.border?this.options.border:this.options.blend?this._blend(b,a):""},_setMargin:function(a,b,c){b=this._marginSize(b);c="top"==c?this._whichSideTop():this._whichSideBottom();"left"==c?(a.style.marginLeft=b+"px",a.style.marginRight="0px"):"right"==c?(a.style.marginRight=b+"px",a.style.marginLeft="0px"):(a.style.marginLeft=b+"px",a.style.marginRight=b+"px")},_setBorder:function(a,b,c){b=this._borderSize(b);c="top"==c?this._whichSideTop():
+this._whichSideBottom();"left"==c?(a.style.borderLeftWidth=b+"px",a.style.borderRightWidth="0px"):"right"==c?(a.style.borderRightWidth=b+"px",a.style.borderLeftWidth="0px"):(a.style.borderLeftWidth=b+"px",a.style.borderRightWidth=b+"px");!1!=this.options.border&&(a.style.borderLeftWidth=b+"px",a.style.borderRightWidth=b+"px")},_marginSize:function(a){if(this._isTransparent())return 0;var b=[5,3,2,1],c=[3,2,1,0],d=[2,1],e=[1,0];return this.options.compact&&this.options.blend?e[a]:this.options.compact?
+d[a]:this.options.blend?c[a]:b[a]},_borderSize:function(a){var b=[5,3,2,1],c=[2,1,1,1],d=[1,0],e=[0,2,0,0];return this.options.compact&&(this.options.blend||this._isTransparent())?1:this.options.compact?d[a]:this.options.blend?c[a]:this.options.border?e[a]:this._isTransparent()?b[a]:0},_hasString:function(a){for(var b=1;b<arguments.length;b++)if(0<=a.indexOf(arguments[b]))return!0;return!1},_blend:function(a,b){var c=OpenLayers.Rico.Color.createFromHex(a);c.blend(OpenLayers.Rico.Color.createFromHex(b));
+return c},_background:function(a){try{return OpenLayers.Rico.Color.createColorFromBackground(a).asHex()}catch(b){return"#ffffff"}},_isTransparent:function(){return"transparent"==this.options.color},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr")},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br")},_hasSingleTextChild:function(a){return 1==a.childNodes.length&&3==a.childNodes[0].nodeType}};OpenLayers.Control.NavigationHistory=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,previous:null,previousOptions:null,next:null,nextOptions:null,limit:50,autoActivate:!0,clearOnDeactivate:!1,registry:null,nextStack:null,previousStack:null,listeners:null,restoring:!1,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.registry=OpenLayers.Util.extend({moveend:this.getState},this.registry);a={trigger:OpenLayers.Function.bind(this.previousTrigger,
+this),displayClass:this.displayClass+" "+this.displayClass+"Previous"};OpenLayers.Util.extend(a,this.previousOptions);this.previous=new OpenLayers.Control.Button(a);a={trigger:OpenLayers.Function.bind(this.nextTrigger,this),displayClass:this.displayClass+" "+this.displayClass+"Next"};OpenLayers.Util.extend(a,this.nextOptions);this.next=new OpenLayers.Control.Button(a);this.clear()},onPreviousChange:function(a,b){a&&!this.previous.active?this.previous.activate():!a&&this.previous.active&&this.previous.deactivate()},
+onNextChange:function(a,b){a&&!this.next.active?this.next.activate():!a&&this.next.active&&this.next.deactivate()},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.previous.destroy();this.next.destroy();this.deactivate();for(var a in this)this[a]=null},setMap:function(a){this.map=a;this.next.setMap(a);this.previous.setMap(a)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.next.draw();this.previous.draw()},previousTrigger:function(){var a=this.previousStack.shift(),
+b=this.previousStack.shift();void 0!=b?(this.nextStack.unshift(a),this.previousStack.unshift(b),this.restoring=!0,this.restore(b),this.restoring=!1,this.onNextChange(this.nextStack[0],this.nextStack.length),this.onPreviousChange(this.previousStack[1],this.previousStack.length-1)):this.previousStack.unshift(a);return b},nextTrigger:function(){var a=this.nextStack.shift();void 0!=a&&(this.previousStack.unshift(a),this.restoring=!0,this.restore(a),this.restoring=!1,this.onNextChange(this.nextStack[0],
+this.nextStack.length),this.onPreviousChange(this.previousStack[1],this.previousStack.length-1));return a},clear:function(){this.previousStack=[];this.previous.deactivate();this.nextStack=[];this.next.deactivate()},getState:function(){return{center:this.map.getCenter(),resolution:this.map.getResolution(),projection:this.map.getProjectionObject(),units:this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units}},restore:function(a){var b,c;if(this.map.getProjectionObject()==
+a.projection)c=this.map.getZoomForResolution(a.resolution),b=a.center;else{b=a.center.clone();b.transform(a.projection,this.map.getProjectionObject());c=a.units;var d=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units;c=this.map.getZoomForResolution((c&&d?OpenLayers.INCHES_PER_UNIT[c]/OpenLayers.INCHES_PER_UNIT[d]:1)*a.resolution)}this.map.setCenter(b,c)},setListeners:function(){this.listeners={};for(var a in this.registry)this.listeners[a]=OpenLayers.Function.bind(function(){if(!this.restoring){var b=
+this.registry[a].apply(this,arguments);this.previousStack.unshift(b);if(1<this.previousStack.length)this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);this.previousStack.length>this.limit+1&&this.previousStack.pop();0<this.nextStack.length&&(this.nextStack=[],this.onNextChange(null,0))}return!0},this)},activate:function(){var a=!1;if(this.map&&OpenLayers.Control.prototype.activate.apply(this)){null==this.listeners&&this.setListeners();for(var b in this.listeners)this.map.events.register(b,
+this,this.listeners[b]);a=!0;0==this.previousStack.length&&this.initStack()}return a},initStack:function(){this.map.getCenter()&&this.listeners.moveend()},deactivate:function(){var a=!1;if(this.map&&OpenLayers.Control.prototype.deactivate.apply(this)){for(var b in this.listeners)this.map.events.unregister(b,this,this.listeners[b]);this.clearOnDeactivate&&this.clear();a=!0}return a},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});OpenLayers.Layer.UTFGrid=OpenLayers.Class(OpenLayers.Layer.XYZ,{isBaseLayer:!1,projection:new OpenLayers.Projection("EPSG:900913"),useJSONP:!1,tileClass:OpenLayers.Tile.UTFGrid,initialize:function(a){OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a.name,a.url,{},a]);this.tileOptions=OpenLayers.Util.extend({utfgridResolution:this.utfgridResolution},this.tileOptions)},createBackBuffer:function(){},clone:function(a){null==a&&(a=new OpenLayers.Layer.UTFGrid(this.getOptions()));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,
+[a])},getFeatureInfo:function(a){var b=null;(a=this.getTileData(a))&&a.tile&&(b=a.tile.getFeatureInfo(a.i,a.j));return b},getFeatureId:function(a){var b=null;a=this.getTileData(a);a.tile&&(b=a.tile.getFeatureId(a.i,a.j));return b},CLASS_NAME:"OpenLayers.Layer.UTFGrid"});OpenLayers.TileManager=OpenLayers.Class({cacheSize:256,tilesPerFrame:2,frameDelay:16,moveDelay:100,zoomDelay:200,maps:null,tileQueueId:null,tileQueue:null,tileCache:null,tileCacheIndex:null,initialize:function(a){OpenLayers.Util.extend(this,a);this.maps=[];this.tileQueueId={};this.tileQueue={};this.tileCache={};this.tileCacheIndex=[]},addMap:function(a){if(!this._destroyed&&OpenLayers.Layer.Grid){this.maps.push(a);this.tileQueue[a.id]=[];for(var b=0,c=a.layers.length;b<c;++b)this.addLayer({layer:a.layers[b]});
+a.events.on({move:this.move,zoomend:this.zoomEnd,changelayer:this.changeLayer,addlayer:this.addLayer,preremovelayer:this.removeLayer,scope:this})}},removeMap:function(a){if(!this._destroyed&&OpenLayers.Layer.Grid){window.clearTimeout(this.tileQueueId[a.id]);if(a.layers)for(var b=0,c=a.layers.length;b<c;++b)this.removeLayer({layer:a.layers[b]});a.events&&a.events.un({move:this.move,zoomend:this.zoomEnd,changelayer:this.changeLayer,addlayer:this.addLayer,preremovelayer:this.removeLayer,scope:this});
+delete this.tileQueue[a.id];delete this.tileQueueId[a.id];OpenLayers.Util.removeItem(this.maps,a)}},move:function(a){this.updateTimeout(a.object,this.moveDelay,!0)},zoomEnd:function(a){this.updateTimeout(a.object,this.zoomDelay)},changeLayer:function(a){"visibility"!==a.property&&"params"!==a.property||this.updateTimeout(a.object,0)},addLayer:function(a){a=a.layer;if(a instanceof OpenLayers.Layer.Grid){a.events.on({addtile:this.addTile,retile:this.clearTileQueue,scope:this});var b,c,d;for(b=a.grid.length-
+1;0<=b;--b)for(c=a.grid[b].length-1;0<=c;--c)d=a.grid[b][c],this.addTile({tile:d}),d.url&&!d.imgDiv&&this.manageTileCache({object:d})}},removeLayer:function(a){a=a.layer;if(a instanceof OpenLayers.Layer.Grid&&(this.clearTileQueue({object:a}),a.events&&a.events.un({addtile:this.addTile,retile:this.clearTileQueue,scope:this}),a.grid)){var b,c,d;for(b=a.grid.length-1;0<=b;--b)for(c=a.grid[b].length-1;0<=c;--c)d=a.grid[b][c],this.unloadTile({object:d})}},updateTimeout:function(a,b,c){window.clearTimeout(this.tileQueueId[a.id]);
+var d=this.tileQueue[a.id];if(!c||d.length)this.tileQueueId[a.id]=window.setTimeout(OpenLayers.Function.bind(function(){this.drawTilesFromQueue(a);d.length&&this.updateTimeout(a,this.frameDelay)},this),b)},addTile:function(a){if(a.tile instanceof OpenLayers.Tile.Image)a.tile.events.on({beforedraw:this.queueTileDraw,beforeload:this.manageTileCache,loadend:this.addToCache,unload:this.unloadTile,scope:this});else this.removeLayer({layer:a.tile.layer})},unloadTile:function(a){a=a.object;a.events.un({beforedraw:this.queueTileDraw,
+beforeload:this.manageTileCache,loadend:this.addToCache,unload:this.unloadTile,scope:this});OpenLayers.Util.removeItem(this.tileQueue[a.layer.map.id],a)},queueTileDraw:function(a){a=a.object;var b=!1,c=a.layer,d=c.getURL(a.bounds),e=this.tileCache[d];e&&"olTileImage"!==e.className&&(delete this.tileCache[d],OpenLayers.Util.removeItem(this.tileCacheIndex,d),e=null);!c.url||!c.async&&e||(b=this.tileQueue[c.map.id],~OpenLayers.Util.indexOf(b,a)||b.push(a),b=!0);return!b},drawTilesFromQueue:function(a){var b=
+this.tileQueue[a.id],c=this.tilesPerFrame;for(a=a.zoomTween&&a.zoomTween.playing;!a&&b.length&&c;)b.shift().draw(!0),--c},manageTileCache:function(a){a=a.object;var b=this.tileCache[a.url];b&&(b.parentNode&&OpenLayers.Element.hasClass(b.parentNode,"olBackBuffer")&&(b.parentNode.removeChild(b),b.id=null),b.parentNode||(b.style.visibility="hidden",b.style.opacity=0,a.setImage(b),OpenLayers.Util.removeItem(this.tileCacheIndex,a.url),this.tileCacheIndex.push(a.url)))},addToCache:function(a){a=a.object;
+this.tileCache[a.url]||OpenLayers.Element.hasClass(a.imgDiv,"olImageLoadError")||(this.tileCacheIndex.length>=this.cacheSize&&(delete this.tileCache[this.tileCacheIndex[0]],this.tileCacheIndex.shift()),this.tileCache[a.url]=a.imgDiv,this.tileCacheIndex.push(a.url))},clearTileQueue:function(a){a=a.object;for(var b=this.tileQueue[a.map.id],c=b.length-1;0<=c;--c)b[c].layer===a&&b.splice(c,1)},destroy:function(){for(var a=this.maps.length-1;0<=a;--a)this.removeMap(this.maps[a]);this.tileCacheIndex=this.tileCache=
+this.tileQueueId=this.tileQueue=this.maps=null;this._destroyed=!0}});OpenLayers.Layer.ArcGISCache=OpenLayers.Class(OpenLayers.Layer.XYZ,{url:null,tileOrigin:null,tileSize:new OpenLayers.Size(256,256),useArcGISServer:!0,type:"png",useScales:!1,overrideDPI:!1,initialize:function(a,b,c){OpenLayers.Layer.XYZ.prototype.initialize.apply(this,arguments);this.resolutions&&(this.serverResolutions=this.resolutions,this.maxExtent=this.getMaxExtentForResolution(this.resolutions[0]));if(this.layerInfo){var d=this.layerInfo,e=new OpenLayers.Bounds(d.fullExtent.xmin,d.fullExtent.ymin,
+d.fullExtent.xmax,d.fullExtent.ymax);this.projection="EPSG:"+d.spatialReference.wkid;this.sphericalMercator=102100==d.spatialReference.wkid;this.units="esriFeet"==d.units?"ft":"m";if(d.tileInfo){this.tileSize=new OpenLayers.Size(d.tileInfo.width||d.tileInfo.cols,d.tileInfo.height||d.tileInfo.rows);this.tileOrigin=new OpenLayers.LonLat(d.tileInfo.origin.x,d.tileInfo.origin.y);var f=new OpenLayers.Geometry.Point(e.left,e.top),e=new OpenLayers.Geometry.Point(e.right,e.bottom);this.useScales?this.scales=
+[]:this.resolutions=[];this.lods=[];for(var g in d.tileInfo.lods)if(d.tileInfo.lods.hasOwnProperty(g)){var h=d.tileInfo.lods[g];this.useScales?this.scales.push(h.scale):this.resolutions.push(h.resolution);var k=this.getContainingTileCoords(f,h.resolution);h.startTileCol=k.x;h.startTileRow=k.y;k=this.getContainingTileCoords(e,h.resolution);h.endTileCol=k.x;h.endTileRow=k.y;this.lods.push(h)}this.maxExtent=this.calculateMaxExtentWithLOD(this.lods[0]);this.serverResolutions=this.resolutions;this.overrideDPI&&
+d.tileInfo.dpi&&(OpenLayers.DOTS_PER_INCH=d.tileInfo.dpi)}}},getContainingTileCoords:function(a,b){return new OpenLayers.Pixel(Math.max(Math.floor((a.x-this.tileOrigin.lon)/(this.tileSize.w*b)),0),Math.max(Math.floor((this.tileOrigin.lat-a.y)/(this.tileSize.h*b)),0))},calculateMaxExtentWithLOD:function(a){var b=this.tileOrigin.lon+a.startTileCol*this.tileSize.w*a.resolution,c=this.tileOrigin.lat-a.startTileRow*this.tileSize.h*a.resolution;return new OpenLayers.Bounds(b,c-(a.endTileRow-a.startTileRow+
+1)*this.tileSize.h*a.resolution,b+(a.endTileCol-a.startTileCol+1)*this.tileSize.w*a.resolution,c)},calculateMaxExtentWithExtent:function(a,b){var c=new OpenLayers.Geometry.Point(a.left,a.top),d=new OpenLayers.Geometry.Point(a.right,a.bottom),c=this.getContainingTileCoords(c,b),d=this.getContainingTileCoords(d,b);return this.calculateMaxExtentWithLOD({resolution:b,startTileCol:c.x,startTileRow:c.y,endTileCol:d.x,endTileRow:d.y})},getUpperLeftTileCoord:function(a){var b=new OpenLayers.Geometry.Point(this.maxExtent.left,
+this.maxExtent.top);return this.getContainingTileCoords(b,a)},getLowerRightTileCoord:function(a){var b=new OpenLayers.Geometry.Point(this.maxExtent.right,this.maxExtent.bottom);return this.getContainingTileCoords(b,a)},getMaxExtentForResolution:function(a){var b=this.getUpperLeftTileCoord(a),c=this.getLowerRightTileCoord(a),d=this.tileOrigin.lon+b.x*this.tileSize.w*a,e=this.tileOrigin.lat-b.y*this.tileSize.h*a;return new OpenLayers.Bounds(d,e-(c.y-b.y+1)*this.tileSize.h*a,d+(c.x-b.x+1)*this.tileSize.w*
+a,e)},clone:function(a){null==a&&(a=new OpenLayers.Layer.ArcGISCache(this.name,this.url,this.options));return OpenLayers.Layer.XYZ.prototype.clone.apply(this,[a])},initGriddedTiles:function(a){delete this._tileOrigin;OpenLayers.Layer.XYZ.prototype.initGriddedTiles.apply(this,arguments)},getMaxExtent:function(){var a=this.map.getResolution();return this.maxExtent=this.getMaxExtentForResolution(a)},getTileOrigin:function(){if(!this._tileOrigin){var a=this.getMaxExtent();this._tileOrigin=new OpenLayers.LonLat(a.left,
+a.bottom)}return this._tileOrigin},getURL:function(a){var b=this.getResolution(),c=this.tileOrigin.lon+b*this.tileSize.w/2,d=this.tileOrigin.lat-b*this.tileSize.h/2;a=a.getCenterLonLat();c=Math.round(Math.abs((a.lon-c)/(b*this.tileSize.w)));d=Math.round(Math.abs((d-a.lat)/(b*this.tileSize.h)));a=this.map.getZoom();if(this.lods){if(b=this.lods[this.map.getZoom()],c<b.startTileCol||c>b.endTileCol||d<b.startTileRow||d>b.endTileRow)return null}else{var e=this.getUpperLeftTileCoord(b),b=this.getLowerRightTileCoord(b);
+if(c<e.x||c>=b.x||d<e.y||d>=b.y)return null}b=this.url;e=""+c+d+a;OpenLayers.Util.isArray(b)&&(b=this.selectUrl(e,b));this.useArcGISServer?b+="/tile/${z}/${y}/${x}":(c="C"+OpenLayers.Number.zeroPad(c,8,16),d="R"+OpenLayers.Number.zeroPad(d,8,16),a="L"+OpenLayers.Number.zeroPad(a,2,10),b=b+"/${z}/${y}/${x}."+this.type);b=OpenLayers.String.format(b,{x:c,y:d,z:a});return OpenLayers.Util.urlAppend(b,OpenLayers.Util.getParameterString(this.params))},CLASS_NAME:"OpenLayers.Layer.ArcGISCache"});OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:!1,drillDown:!1,maxFeatures:10,clickCallback:"click",output:"features",layers:null,queryVisible:!1,url:null,layerUrls:null,infoFormat:"text/html",vendorParams:{},format:null,formatOptions:null,handler:null,hoverRequest:null,initialize:function(a){a=a||{};a.handlerOptions=a.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[a]);this.format||(this.format=new OpenLayers.Format.WMSGetFeatureInfo(a
.formatOptions));
+!0===this.drillDown&&(this.hover=!1);this.hover?this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250})):(a={},a[this.clickCallback]=this.getInfoForClick,this.handler=new OpenLayers.Handler.Click(this,a,this.handlerOptions.click||{}))},getInfoForClick:function(a){this.events.triggerEvent("beforegetfeatureinfo",{xy:a.xy});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");this.request(a.xy,
+{})},getInfoForHover:function(a){this.events.triggerEvent("beforegetfeatureinfo",{xy:a.xy});this.request(a.xy,{hover:!0})},cancelHover:function(){this.hoverRequest&&(this.hoverRequest.abort(),this.hoverRequest=null)},findLayers:function(){for(var a=this.layers||this.map.layers,b=[],c,d,e=a.length-1;0<=e;--e)c=a[e],c instanceof OpenLayers.Layer.WMS&&(!this.queryVisible||c.getVisibility())&&(d=OpenLayers.Util.isArray(c.url)?c.url[0]:c.url,!1!==this.drillDown||this.url||(this.url=d),(!0===this.drillDown||
+this.urlMatches(d))&&b.push(c));return b},urlMatches:function(a){var b=OpenLayers.Util.isEquivalentUrl(this.url,a);if(!b&&this.layerUrls)for(var c=0,d=this.layerUrls.length;c<d;++c)if(OpenLayers.Util.isEquivalentUrl(this.layerUrls[c],a)){b=!0;break}return b},buildWMSOptions:function(a,b,c,d){for(var e=[],f=[],g=0,h=b.length;g<h;g++)null!=b[g].params.LAYERS&&(e=e.concat(b[g].params.LAYERS),f=f.concat(this.getStyleNames(b[g])));b=b[0];g=this.map.getProjection();(h=b.projection)&&h.equals(this.map.getProjectionObject())&&
+(g=h.getCode());d=OpenLayers.Util.extend({service:"WMS",version:b.params.VERSION,request:"GetFeatureInfo",exceptions:b.params.EXCEPTIONS,bbox:this.map.getExtent().toBBOX(null,b.reverseAxisOrder()),feature_count:this.maxFeatures,height:this.map.getSize().h,width:this.map.getSize().w,format:d,info_format:b.params.INFO_FORMAT||this.infoFormat},1.3<=parseFloat(b.params.VERSION)?{crs:g,i:parseInt(c.x),j:parseInt(c.y)}:{srs:g,x:parseInt(c.x),y:parseInt(c.y)});0!=e.length&&(d=OpenLayers.Util.extend({layers:e,
+query_layers:e,styles:f},d));OpenLayers.Util.applyDefaults(d,this.vendorParams);return{url:a,params:OpenLayers.Util.upperCaseObject(d),callback:function(b){this.handleResponse(c,b,a)},scope:this}},getStyleNames:function(a){return a.params.STYLES?a.params.STYLES:OpenLayers.Util.isArray(a.params.LAYERS)?Array(a.params.LAYERS.length):a.params.LAYERS.replace(/[^,]/g,"")},request:function(a,b){var c=this.findLayers();if(0==c.length)this.events.triggerEvent("nogetfeatureinfo"),OpenLayers.Element.removeClass(this.map.viewPortDiv,
+"olCursorWait");else if(b=b||{},!1===this.drillDown){var c=this.buildWMSOptions(this.url,c,a,c[0].params.FORMAT),d=OpenLayers.Request.GET(c);!0===b.hover&&(this.hoverRequest=d)}else{this._numRequests=this._requestCount=0;this.features=[];for(var d={},e,f=0,g=c.length;f<g;f++){var h=c[f];e=OpenLayers.Util.isArray(h.url)?h.url[0]:h.url;e in d?d[e].push(h):(this._numRequests++,d[e]=[h])}for(e in d)c=d[e],c=this.buildWMSOptions(e,c,a,c[0].params.FORMAT),OpenLayers.Request.GET(c)}},triggerGetFeatureInfo:function(a,
+b,c){this.events.triggerEvent("getfeatureinfo",{text:a.responseText,features:c,request:a,xy:b});OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait")},handleResponse:function(a,b,c){var d=b.responseXML;d&&d.documentElement||(d=b.responseText);d=this.format.read(d);!1===this.drillDown?this.triggerGetFeatureInfo(b,a,d):(this._requestCount++,this._features="object"===this.output?(this._features||[]).concat({url:c,features:d}):(this._features||[]).concat(d),this._requestCount===this._numRequests&&
+(this.triggerGetFeatureInfo(b,a,this._features.concat()),delete this._features,delete this._requestCount,delete this._numRequests))},CLASS_NAME:"OpenLayers.Control.WMSGetFeatureInfo"});OpenLayers.Format.WMSCapabilities.v1_3_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_3,{version:"1.3.0",CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3_0"});OpenLayers.Format.SOSGetFeatureOfInterest=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",sa:"http://www.opengis.net/sampling/1.0",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosAll.xsd",defaultPrefix:"sos",regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={features:[]};this.readNode(a,b);a=[];for(var c=0,d=b.features.length;c<d;c++){var e=b.features[c];this.internalProjection&&(this.externalProjection&&e.components[0])&&e.components[0].transform(this.externalProjection,this.internalProjection);e=new OpenLayers.Feature.Vector(e.components[0],e.attributes);a.push(e)}return a},readers:{sa:{SamplingPoint:function(a,b){if(!b.attributes){var c=
+{attributes:{}};b.features.push(c);b=c}b.attributes.id=this.getAttributeNS(a,this.namespaces.gml,"id");this.readChildNodes(a,b)},position:function(a,b){this.readChildNodes(a,b)}},gml:OpenLayers.Util.applyDefaults({FeatureCollection:function(a,b){this.readChildNodes(a,b)},featureMember:function(a,b){var c={attributes:{}};b.features.push(c);this.readChildNodes(a,c)},name:function(a,b){b.attributes.name=this.getChildValue(a)},pos:function(a,b){this.externalProjection||(this.externalProjection=new OpenLayers.Projection(a.getAttribute("srsName")));
+OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[a,b])}},OpenLayers.Format.GML.v3.prototype.readers.gml)},writers:{sos:{GetFeatureOfInterest:function(a){for(var b=this.createElementNSPlus("GetFeatureOfInterest",{attributes:{version:this.VERSION,service:"SOS","xsi:schemaLocation":this.schemaLocation}}),c=0,d=a.fois.length;c<d;c++)this.writeNode("FeatureOfInterestId",{foi:a.fois[c]},b);return b},FeatureOfInterestId:function(a){return this.createElementNSPlus("FeatureOfInterestId",{value:a.foi})}}},
+CLASS_NAME:"OpenLayers.Format.SOSGetFeatureOfInterest"});OpenLayers.Format.SOSGetObservation=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows",gml:"http://www.opengis.net/gml",sos:"http://www.opengis.net/sos/1.0",ogc:"http://www.opengis.net/ogc",om:"http://www.opengis.net/om/1.0",sa:"http://www.opengis.net/sampling/1.0",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:/^\s*|\s*$/g,removeSpace:/\s*/g,splitSpace:/\s+/,trimComma:/\s*,\s*/g},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",
+defaultPrefix:"sos",read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={measurements:[],observations:[]};this.readNode(a,b);return b},write:function(a){a=this.writeNode("sos:GetObservation",a);a.setAttribute("xmlns:om",this.namespaces.om);a.setAttribute("xmlns:ogc",this.namespaces.ogc);this.setAttributeNS(a,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,
+[a])},readers:{om:{ObservationCollection:function(a,b){b.id=this.getAttributeNS(a,this.namespaces.gml,"id");this.readChildNodes(a,b)},member:function(a,b){this.readChildNodes(a,b)},Measurement:function(a,b){var c={};b.measurements.push(c);this.readChildNodes(a,c)},Observation:function(a,b){var c={};b.observations.push(c);this.readChildNodes(a,c)},samplingTime:function(a,b){var c={};b.samplingTime=c;this.readChildNodes(a,c)},observedProperty:function(a,b){b.observedProperty=this.getAttributeNS(a,this.namespaces.xlink,
+"href");this.readChildNodes(a,b)},procedure:function(a,b){b.procedure=this.getAttributeNS(a,this.namespaces.xlink,"href");this.readChildNodes(a,b)},featureOfInterest:function(a,b){var c={features:[]};b.fois=[];b.fois.push(c);this.readChildNodes(a,c);for(var d=[],e=0,f=c.features.length;e<f;e++){var g=c.features[e];d.push(new OpenLayers.Feature.Vector(g.components[0],g.attributes))}c.features=d},result:function(a,b){var c={};b.result=c;""!==this.getChildValue(a)?(c.value=this.getChildValue(a),c.uom=
+a.getAttribute("uom")):this.readChildNodes(a,c)}},sa:OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.sa,gml:OpenLayers.Util.applyDefaults({TimeInstant:function(a,b){var c={};b.timeInstant=c;this.readChildNodes(a,c)},timePosition:function(a,b){b.timePosition=this.getChildValue(a)}},OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.gml)},writers:{sos:{GetObservation:function(a){var b=this.createElementNSPlus("GetObservation",{attributes:{version:this.VERSION,service:"SOS"}});this.writeNode("offering",
+a,b);a.eventTime&&this.writeNode("eventTime",a,b);for(var c in a.procedures)this.writeNode("procedure",a.procedures[c],b);for(var d in a.observedProperties)this.writeNode("observedProperty",a.observedProperties[d],b);a.foi&&this.writeNode("featureOfInterest",a.foi,b);this.writeNode("responseFormat",a,b);a.resultModel&&this.writeNode("resultModel",a,b);a.responseMode&&this.writeNode("responseMode",a,b);return b},featureOfInterest:function(a){var b=this.createElementNSPlus("featureOfInterest");this.writeNode("ObjectID",
+a.objectId,b);return b},ObjectID:function(a){return this.createElementNSPlus("ObjectID",{value:a})},responseFormat:function(a){return this.createElementNSPlus("responseFormat",{value:a.responseFormat})},procedure:function(a){return this.createElementNSPlus("procedure",{value:a})},offering:function(a){return this.createElementNSPlus("offering",{value:a.offering})},observedProperty:function(a){return this.createElementNSPlus("observedProperty",{value:a})},eventTime:function(a){var b=this.createElementNSPlus("eventTime");
+"latest"===a.eventTime&&this.writeNode("ogc:TM_Equals",a,b);return b},resultModel:function(a){return this.createElementNSPlus("resultModel",{value:a.resultModel})},responseMode:function(a){return this.createElementNSPlus("responseMode",{value:a.responseMode})}},ogc:{TM_Equals:function(a){var b=this.createElementNSPlus("ogc:TM_Equals");this.writeNode("ogc:PropertyName",{property:"urn:ogc:data:time:iso8601"},b);"latest"===a.eventTime&&this.writeNode("gml:TimeInstant",{value:"latest"},b);return b},PropertyName:function(a){return this.createElementNSPlus("ogc:PropertyName",
+{value:a.property})}},gml:{TimeInstant:function(a){var b=this.createElementNSPlus("gml:TimeInstant");this.writeNode("gml:timePosition",a,b);return b},timePosition:function(a){return this.createElementNSPlus("gml:timePosition",{value:a.value})}}},CLASS_NAME:"OpenLayers.Format.SOSGetObservation"});OpenLayers.Control.UTFGrid=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,layers:null,defaultHandlerOptions:{delay:300,pixelTolerance:4,stopMove:!1,single:!0,"double":!1,stopSingle:!1,stopDouble:!1},handlerMode:"click",setHandler:function(a){this.handlerMode=a;this.resetHandler()},resetHandler:function(){this.handler&&(this.handler.deactivate(),this.handler.destroy(),this.handler=null);"hover"==this.handlerMode?this.handler=new OpenLayers.Handler.Hover(this,{pause:this.handleEvent,move:this.reset},
+this.handlerOptions):"click"==this.handlerMode?this.handler=new OpenLayers.Handler.Click(this,{click:this.handleEvent},this.handlerOptions):"move"==this.handlerMode&&(this.handler=new OpenLayers.Handler.Hover(this,{pause:this.handleEvent,move:this.handleEvent},this.handlerOptions));return this.handler?!0:!1},initialize:function(a){a=a||{};a.handlerOptions=a.handlerOptions||this.defaultHandlerOptions;OpenLayers.Control.prototype.initialize.apply(this,[a]);this.resetHandler()},handleEvent:function(a){if(null==
+a)this.reset();else{var b=this.map.getLonLatFromPixel(a.xy);if(b){var c=this.findLayers();if(0<c.length){for(var d={},e,f,g=0,h=c.length;g<h;g++)e=c[g],f=OpenLayers.Util.indexOf(this.map.layers,e),d[f]=e.getFeatureInfo(b);this.callback(d,b,a.xy)}}}},callback:function(a){},reset:function(a){this.callback(null)},findLayers:function(){for(var a=this.layers||this.map.layers,b=[],c,d=a.length-1;0<=d;--d)c=a[d],c instanceof OpenLayers.Layer.UTFGrid&&b.push(c);return b},CLASS_NAME:"OpenLayers.Control.UTFGrid"});OpenLayers.Format.CQL=function(){function a(a){function b(){var a=e.pop();switch(a.type){case "LOGICAL":var c=b(),g=b();return new OpenLayers.Filter.Logical({filters:[g,c],type:f[a.text.toUpperCase()]});case "NOT":return a=b(),new OpenLayers.Filter.Logical({filters:[a],type:OpenLayers.Filter.Logical.NOT});case "BETWEEN":return e.pop(),g=b(),a=b(),c=b(),new OpenLayers.Filter.Comparison({property:c,lowerBoundary:a,upperBoundary:g,type:OpenLayers.Filter.Comparison.BETWEEN});cas
e "COMPARISON":return g=
+b(),c=b(),new OpenLayers.Filter.Comparison({property:c,value:g,type:d[a.text.toUpperCase()]});case "IS_NULL":return c=b(),new OpenLayers.Filter.Comparison({property:c,type:d[a.text.toUpperCase()]});case "VALUE":return(c=a.text.match(/^'(.*)'$/))?c[1].replace(/''/g,"'"):Number(a.text);case "SPATIAL":switch(a.text.toUpperCase()){case "BBOX":var a=b(),c=b(),g=b(),h=b(),k=b();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:k,value:OpenLayers.Bounds.fromArray([h,g,c,
+a])});case "INTERSECTS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:c,value:g});case "WITHIN":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.WITHIN,property:c,value:g});case "CONTAINS":return g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.CONTAINS,property:c,value:g});case "DWITHIN":return a=b(),g=b(),c=b(),new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,value:g,
+property:c,distance:Number(a)})}case "GEOMETRY":return OpenLayers.Geometry.fromWKT(a.text);default:return a.text}}for(var c=[],e=[];a.length;){var g=a.shift();switch(g.type){case "PROPERTY":case "GEOMETRY":case "VALUE":e.push(g);break;case "COMPARISON":case "BETWEEN":case "IS_NULL":case "LOGICAL":for(var k=h[g.type];0<c.length&&h[c[c.length-1].type]<=k;)e.push(c.pop());c.push(g);break;case "SPATIAL":case "NOT":case "LPAREN":c.push(g);break;case "RPAREN":for(;0<c.length&&"LPAREN"!=c[c.length-1].type;)e.push(c.pop());
+c.pop();0<c.length&&"SPATIAL"==c[c.length-1].type&&e.push(c.pop());case "COMMA":case "END":break;default:throw Error("Unknown token type "+g.type);}}for(;0<c.length;)e.push(c.pop());a=b();if(0<e.length){a="Remaining tokens after building AST: \n";for(c=e.length-1;0<=c;c--)a+=e[c].type+": "+e[c].text+"\n";throw Error(a);}return a}var b={PROPERTY:/^[_a-zA-Z]\w*/,COMPARISON:/^(=|<>|<=|<|>=|>|LIKE)/i,IS_NULL:/^IS NULL/i,COMMA:/^,/,LOGICAL:/^(AND|OR)/i,VALUE:/^('([^']|'')*'|\d+(\.\d*)?|\.\d+)/,LPAREN:/^\(/,
+RPAREN:/^\)/,SPATIAL:/^(BBOX|INTERSECTS|DWITHIN|WITHIN|CONTAINS)/i,NOT:/^NOT/i,BETWEEN:/^BETWEEN/i,GEOMETRY:function(a){var b=/^(POINT|LINESTRING|POLYGON|MULTIPOINT|MULTILINESTRING|MULTIPOLYGON|GEOMETRYCOLLECTION)/.exec(a);if(b){var c=a.length,b=a.indexOf("(",b[0].length);if(-1<b)for(var d=1;b<c&&0<d;)switch(b++,a.charAt(b)){case "(":d++;break;case ")":d--}return[a.substr(0,b+1)]}},END:/^$/},c={LPAREN:["GEOMETRY","SPATIAL","PROPERTY","VALUE","LPAREN"],RPAREN:["NOT","LOGICAL","END","RPAREN"],PROPERTY:["COMPARISON",
+"BETWEEN","COMMA","IS_NULL"],BETWEEN:["VALUE"],IS_NULL:["END"],COMPARISON:["VALUE"],COMMA:["GEOMETRY","VALUE","PROPERTY"],VALUE:["LOGICAL","COMMA","RPAREN","END"],SPATIAL:["LPAREN"],LOGICAL:["NOT","VALUE","SPATIAL","PROPERTY","LPAREN"],NOT:["PROPERTY","LPAREN"],GEOMETRY:["COMMA","RPAREN"]},d={"=":OpenLayers.Filter.Comparison.EQUAL_TO,"<>":OpenLayers.Filter.Comparison.NOT_EQUAL_TO,"<":OpenLayers.Filter.Comparison.LESS_THAN,"<=":OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,">":OpenLayers.Filter.Comparison.GREATER_THAN,
+">=":OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,LIKE:OpenLayers.Filter.Comparison.LIKE,BETWEEN:OpenLayers.Filter.Comparison.BETWEEN,"IS NULL":OpenLayers.Filter.Comparison.IS_NULL},e={},f={AND:OpenLayers.Filter.Logical.AND,OR:OpenLayers.Filter.Logical.OR},g={},h={RPAREN:3,LOGICAL:2,COMPARISON:1},k;for(k in d)d.hasOwnProperty(k)&&(e[d[k]]=k);for(k in f)f.hasOwnProperty(k)&&(g[f[k]]=k);return OpenLayers.Class(OpenLayers.Format,{read:function(d){var e=d;d=[];var f,g=["NOT","GEOMETRY","SPATIAL",
+"PROPERTY","LPAREN"];do{a:{f=g;for(var h=void 0,g=void 0,k=f.length,h=0;h<k;h++){var g=f[h],s=b[g]instanceof RegExp?b[g].exec(e):(0,b[g])(e);if(s){f=s[0];e=e.substr(f.length).replace(/^\s*/,"");f={type:g,text:f,remainder:e};break a}}d="ERROR: In parsing: ["+e+"], expected one of: ";for(h=0;h<k;h++)g=f[h],d+="\n "+g+": "+b[g];throw Error(d);}e=f.remainder;g=c[f.type];if("END"!=f.type&&!g)throw Error("No follows list for "+f.type);d.push(f)}while("END"!=f.type);d=a(d);this.keepData&&(this.data=d);
+return d},write:function(a){if(a instanceof OpenLayers.Geometry)return a.toString();switch(a.CLASS_NAME){case "OpenLayers.Filter.Spatial":switch(a.type){case OpenLayers.Filter.Spatial.BBOX:return"BBOX("+a.property+","+a.value.toBBOX()+")";case OpenLayers.Filter.Spatial.DWITHIN:return"DWITHIN("+a.property+", "+this.write(a.value)+", "+a.distance+")";case OpenLayers.Filter.Spatial.WITHIN:return"WITHIN("+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.INTERSECTS:return"INTERSECTS("+
+a.property+", "+this.write(a.value)+")";case OpenLayers.Filter.Spatial.CONTAINS:return"CONTAINS("+a.property+", "+this.write(a.value)+")";default:throw Error("Unknown spatial filter type: "+a.type);}case "OpenLayers.Filter.Logical":if(a.type==OpenLayers.Filter.Logical.NOT)return"NOT ("+this.write(a.filters[0])+")";for(var b="(",c=!0,d=0;d<a.filters.length;d++)c?c=!1:b+=") "+g[a.type]+" (",b+=this.write(a.filters[d]);return b+")";case "OpenLayers.Filter.Comparison":return a.type==OpenLayers.Filter.Comparison.BETWEEN?
+a.property+" BETWEEN "+this.write(a.lowerBoundary)+" AND "+this.write(a.upperBoundary):null!==a.value?a.property+" "+e[a.type]+" "+this.write(a.value):a.property+" "+e[a.type];case void 0:if("string"===typeof a)return"'"+a.replace(/'/g,"''")+"'";if("number"===typeof a)return String(a);default:throw Error("Can't encode: "+a.CLASS_NAME+" "+a);}},CLASS_NAME:"OpenLayers.Format.CQL"})}();OpenLayers.Control.Split=OpenLayers.Class(OpenLayers.Control,{layer:null,source:null,sourceOptions:null,tolerance:null,edge:!0,deferDelete:!1,mutual:!0,targetFilter:null,sourceFilter:null,handler:null,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,[a]);this.options=a||{};this.options.source&&this.setSource(this.options.source)},setSource:function(a){this.active?(this.deactivate(),this.handler&&(this.handler.destroy(),delete this.handler),this.source=a,this.activate()):this.source=
+a},activate:function(){var a=OpenLayers.Control.prototype.activate.call(this);if(a)if(!this.source)this.handler||(this.handler=new OpenLayers.Handler.Path(this,{done:function(a){this.onSketchComplete({feature:new OpenLayers.Feature.Vector(a)})}},{layerOptions:this.sourceOptions})),this.handler.activate();else if(this.source.events)this.source.events.on({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});return a},deactivate:function(){var a=OpenLayers.Control.prototype.deactivate.call(this);
+a&&this.source&&this.source.events&&this.source.events.un({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});return a},onSketchComplete:function(a){this.feature=null;return!this.considerSplit(a.feature)},afterFeatureModified:function(a){a.modified&&"function"===typeof a.feature.geometry.split&&(this.feature=a.feature,this.considerSplit(a.feature))},removeByGeometry:function(a,b){for(var c=0,d=a.length;c<d;++c)if(a[c].geometry===b){a.splice(c,1);break}},
+isEligible:function(a){return a.geometry?a.state!==OpenLayers.State.DELETE&&"function"===typeof a.geometry.split&&this.feature!==a&&(!this.targetFilter||this.targetFilter.evaluate(a.attributes)):!1},considerSplit:function(a){var b=!1,c=!1;if(!this.sourceFilter||this.sourceFilter.evaluate(a.attributes)){for(var d=this.layer&&this.layer.features||[],e,f,g=[],h=[],k=this.layer===this.source&&this.mutual,l={edge:this.edge,tolerance:this.tolerance,mutual:k},m=[a.geometry],n,p,q,r=0,s=d.length;r<s;++r)if(n=
+d[r],this.isEligible(n)){p=[n.geometry];for(var t=0;t<m.length;++t){q=m[t];for(var u=0;u<p.length;++u)if(e=p[u],q.getBounds().intersectsBounds(e.getBounds())&&(e=q.split(e,l)))f=this.events.triggerEvent("beforesplit",{source:a,target:n}),!1!==f&&(k&&(f=e[0],1<f.length&&(f.unshift(t,1),Array.prototype.splice.apply(m,f),t+=f.length-3),e=e[1]),1<e.length&&(e.unshift(u,1),Array.prototype.splice.apply(p,e),u+=e.length-3))}p&&1<p.length&&(this.geomsToFeatures(n,p),this.events.triggerEvent("split",{original:n,
+features:p}),Array.prototype.push.apply(g,p),h.push(n),c=!0)}m&&1<m.length&&(this.geomsToFeatures(a,m),this.events.triggerEvent("split",{original:a,features:m}),Array.prototype.push.apply(g,m),h.push(a),b=!0);if(b||c){if(this.deferDelete){d=[];r=0;for(s=h.length;r<s;++r)c=h[r],c.state===OpenLayers.State.INSERT?d.push(c):(c.state=OpenLayers.State.DELETE,this.layer.drawFeature(c));this.layer.destroyFeatures(d,{silent:!0});r=0;for(s=g.length;r<s;++r)g[r].state=OpenLayers.State.INSERT}else this.layer.destroyFeatures(h,
+{silent:!0});this.layer.addFeatures(g,{silent:!0});this.events.triggerEvent("aftersplit",{source:a,features:g})}}return b},geomsToFeatures:function(a,b){var c=a.clone();delete c.geometry;for(var d,e=0,f=b.length;e<f;++e)d=c.clone(),d.geometry=b[e],d.state=OpenLayers.State.INSERT,b[e]=d},destroy:function(){this.active&&this.deactivate();OpenLayers.Control.prototype.destroy.call(this)},CLASS_NAME:"OpenLayers.Control.Split"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:!0,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,serverResolutions:null,formatSuffixMap:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png",png:"png","image/jpeg":"jpg","image/jpg":"jpg",jpeg:"jpg",jpg:"jpg"},matrix:null,initialize:function(a){var b=
+{url:!0,layer:!0,style:!0,matrixSet:!0},c;for(c in b)if(!(c in a))throw Error("Missing property '"+c+"' in layer configuration.");a.params=OpenLayers.Util.upperCaseObject(a.params);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[a.name,a.url,a.params,a]);this.formatSuffix||(this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop());if(this.matrixIds&&(a=this.matrixIds.length)&&"string"===typeof this.matrixIds[0])for(b=this.matrixIds,this.matrixIds=Array(a),c=0;c<a;++c)this.matrixIds[c]=
+{identifier:b[c]}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments)},updateMatrixProperties:function(){if(this.matrix=this.getMatrix())this.matrix.topLeftCorner&&(this.tileOrigin=this.matrix.topLeftCorner),this.matrix.tileWidth&&this.matrix.tileHeight&&(this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight)),this.tileOrigin||(this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.top)),this.tileFullExtent||(this.tileFullExtent=
+this.maxExtent)},moveTo:function(a,b,c){!b&&this.matrix||this.updateMatrixProperties();return OpenLayers.Layer.Grid.prototype.moveTo.apply(this,arguments)},clone:function(a){null==a&&(a=new OpenLayers.Layer.WMTS(this.options));return a=OpenLayers.Layer.Grid.prototype.clone.apply(this,[a])},getIdentifier:function(){return this.getServerZoom()},getMatrix:function(){var a;if(this.matrixIds&&0!==this.matrixIds.length)if("scaleDenominator"in this.matrixIds[0])for(var b=OpenLayers.METERS_PER_INCH*OpenLayers.INCHES_PER_UNIT[this.units]*
+this.getServerResolution()/2.8E-4,c=Number.POSITIVE_INFINITY,d,e=0,f=this.matrixIds.length;e<f;++e)d=Math.abs(1-this.matrixIds[e].scaleDenominator/b),d<c&&(c=d,a=this.matrixIds[e]);else a=this.matrixIds[this.getIdentifier()];else a={identifier:this.getIdentifier()};return a},getTileInfo:function(a){var b=this.getServerResolution(),c=(a.lon-this.tileOrigin.lon)/(b*this.tileSize.w);a=(this.tileOrigin.lat-a.lat)/(b*this.tileSize.h);var b=Math.floor(c),d=Math.floor(a);return{col:b,row:d,i:Math.floor((c-
+b)*this.tileSize.w),j:Math.floor((a-d)*this.tileSize.h)}},getURL:function(a){a=this.adjustBounds(a);var b="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(a)){a=a.getCenterLonLat();var c=this.getTileInfo(a);a=this.dimensions;var d,b=OpenLayers.Util.isArray(this.url)?this.selectUrl([this.version,this.style,this.matrixSet,this.matrix.identifier,c.row,c.col].join(),this.url):this.url;if("REST"===this.requestEncoding.toUpperCase())if(d=this.params,-1!==b.indexOf("{")){b=b.replace(/\{/g,
+"${");c={style:this.style,Style:this.style,TileMatrixSet:this.matrixSet,TileMatrix:this.matrix.identifier,TileRow:c.row,TileCol:c.col};if(a){var e,f;for(f=a.length-1;0<=f;--f)e=a[f],c[e]=d[e.toUpperCase()]}b=OpenLayers.String.format(b,c)}else{e=this.version+"/"+this.layer+"/"+this.style+"/";if(a)for(f=0;f<a.length;f++)d[a[f]]&&(e=e+d[a[f]]+"/");e=e+this.matrixSet+"/"+this.matrix.identifier+"/"+c.row+"/"+c.col+"."+this.formatSuffix;b.match(/\/$/)||(b+="/");b+=e}else"KVP"===this.requestEncoding.toUpperCase()&&
+(d={SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:c.row,TILECOL:c.col,FORMAT:this.format},b=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[d]))}return b},mergeNewParams:function(a){if("KVP"===this.requestEncoding.toUpperCase())return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(a)])},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Protocol.SOS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol,{fois:null,formatOptions:null,initialize:function(a){OpenLayers.Protocol.prototype.initialize.apply(this,[a]);a.format||(this.format=new OpenLayers.Format.SOSGetFeatureOfInterest(this.formatOptions))},destroy:function(){this.options&&!this.options.format&&this.format.destroy();this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this)},read:function(a){a=OpenLayers.Util.extend({},a);OpenLayers.Util.applyDefault
s(a,this.options||
+{});var b=new OpenLayers.Protocol.Response({requestType:"read"}),c=this.format,c=OpenLayers.Format.XML.prototype.write.apply(c,[c.writeNode("sos:GetFeatureOfInterest",{fois:this.fois})]);b.priv=OpenLayers.Request.POST({url:a.url,callback:this.createCallback(this.handleRead,b,a),data:c});return b},handleRead:function(a,b){if(b.callback){var c=a.priv;200<=c.status&&300>c.status?(a.features=this.parseFeatures(c),a.code=OpenLayers.Protocol.Response.SUCCESS):a.code=OpenLayers.Protocol.Response.FAILURE;
+b.callback.call(b.scope,a)}},parseFeatures:function(a){var b=a.responseXML;b&&b.documentElement||(b=a.responseText);return!b||0>=b.length?null:this.format.read(b)},CLASS_NAME:"OpenLayers.Protocol.SOS.v1_0_0"});OpenLayers.Layer.KaMapCache=OpenLayers.Class(OpenLayers.Layer.KaMap,{IMAGE_EXTENSIONS:{jpeg:"jpg",gif:"gif",png:"png",png8:"png",png24:"png",dithered:"png"},DEFAULT_FORMAT:"jpeg",initialize:function(a,b,c,d){OpenLayers.Layer.KaMap.prototype.initialize.apply(this,arguments);this.extension=this.IMAGE_EXTENSIONS[this.params.i.toLowerCase()||this.DEFAULT_FORMAT]},getURL:function(a){a=this.adjustBounds(a);var b=this.map.getResolution(),c=Math.round(1E4*this.map.getScale())/1E4,d=Math.round(a.left/b);a=
+-Math.round(a.top/b);var b=Math.floor(d/this.tileSize.w/this.params.metaTileSize.w)*this.tileSize.w*this.params.metaTileSize.w,e=Math.floor(a/this.tileSize.h/this.params.metaTileSize.h)*this.tileSize.h*this.params.metaTileSize.h,c=["/",this.params.map,"/",c,"/",this.params.g.replace(/\s/g,"_"),"/def/t",e,"/l",b,"/t",a,"l",d,".",this.extension],d=this.url;OpenLayers.Util.isArray(d)&&(d=this.selectUrl(c.join(""),d));return d+c.join("")},CLASS_NAME:"OpenLayers.Layer.KaMapCache"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(a){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);this.outputFormat&&!this.readFormat&&("gml2"==this.outputFormat.toLowerCase()?this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName}):"json"==this.outputFormat.toLowerCase()&&(this.readFormat=new OpenLayers.Format.GeoJSON))},CLASS_NAME:"OpenLaye
rs.Protocol.WFS.v1_1_0"});OpenLayers.Format.WMSCapabilities.v1_1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.1",readers:{wms:OpenLayers.Util.applyDefaults({SRS:function(a,b){b.srs[this.getChildValue(a)]=!0}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1"});OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1_1,{version:"1.1.1",profile:"WMSC",readers:{wms:OpenLayers.Util.applyDefaults({VendorSpecificCapabilities:function(a,b){b.vendorSpecific={tileSets:[]};this.readChildNodes(a,b.vendorSpecific)},TileSet:function(a,b){var c={srs:{},bbox:{},resolutions:[]};this.readChildNodes(a,c);b.tileSets.push(c)},Resolutions:function(a,b){for(var c=this.getChildValue(a).split(" "),d=0,e=c.length;d<e;d++)""!=c[d]&&b.resolutions.push(parseFloat(c[d]))},
+Width:function(a,b){b.width=parseInt(this.getChildValue(a))},Height:function(a,b){b.height=parseInt(this.getChildValue(a))},Layers:function(a,b){b.layers=this.getChildValue(a)},Styles:function(a,b){b.styles=this.getChildValue(a)}},OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.readers.wms)},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC"});OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:!0,initialize:function(a){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[]},destroy:function(){this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({buttonclick:this.onButtonClick,addlayer:this.redraw,changelayer:this.redraw,
+removelayer:this.redraw,changebaselayer:this.redraw,scope:this});this.events.unregister("buttonclick",this,this.onButtonClick);OpenLayers.Control.prototype.destroy.apply(this,arguments)},setMap:function(a){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({addlayer:this.redraw,changelayer:this.redraw,removelayer:this.redraw,changebaselayer:this.redraw,scope:this});this.outsideViewport?(this.events.attachToElement(this.div),this.events.register("buttonclick",this,this.onButtonClick)):
+this.map.events.register("buttonclick",this,this.onButtonClick)},draw:function(){OpenLayers.Control.prototype.draw.apply(this);this.loadContents();this.outsideViewport||this.minimizeControl();this.redraw();return this.div},onButtonClick:function(a){a=a.buttonElement;a===this.minimizeDiv?this.minimizeControl():a===this.maximizeDiv?this.maximizeControl():a._layerSwitcher===this.id&&(a["for"]&&(a=document.getElementById(a["for"])),a.disabled||("radio"==a.type?(a.checked=!0,this.map.setBaseLayer(this.map.getLayer(a._layer))):
+(a.checked=!a.checked,this.updateMap())))},clearLayersArray:function(a){this[a+"LayersDiv"].innerHTML="";this[a+"Layers"]=[]},checkRedraw:function(){if(!this.layerStates.length||this.map.layers.length!=this.layerStates.length)return!0;for(var a=0,b=this.layerStates.length;a<b;a++){var c=this.layerStates[a],d=this.map.layers[a];if(c.name!=d.name||c.inRange!=d.inRange||c.id!=d.id||c.visibility!=d.visibility)return!0}return!1},redraw:function(){if(!this.checkRedraw())return this.div;this.clearLayersArray("base");
+this.clearLayersArray("data");var a=!1,b=!1,c=this.map.layers.length;this.layerStates=Array(c);for(var d=0;d<c;d++){var e=this.map.layers[d];this.layerStates[d]={name:e.name,visibility:e.visibility,inRange:e.inRange,id:e.id}}var f=this.map.layers.slice();this.ascending||f.reverse();d=0;for(c=f.length;d<c;d++){var e=f[d],g=e.isBaseLayer;if(e.displayInLayerSwitcher){g?b=!0:a=!0;var h=g?e==this.map.baseLayer:e.getVisibility(),k=document.createElement("input"),l=OpenLayers.Util.createUniqueID(this.id+
+"_input_");k.id=l;k.name=g?this.id+"_baseLayers":e.name;k.type=g?"radio":"checkbox";k.value=e.name;k.checked=h;k.defaultChecked=h;k.className="olButton";k._layer=e.id;k._layerSwitcher=this.id;g||e.inRange||(k.disabled=!0);h=document.createElement("label");h["for"]=k.id;OpenLayers.Element.addClass(h,"labelSpan olButton");h._layer=e.id;h._layerSwitcher=this.id;g||e.inRange||(h.style.color="gray");h.innerHTML=e.name;h.style.verticalAlign=g?"bottom":"baseline";l=document.createElement("br");(g?this.baseLayers:
+this.dataLayers).push({layer:e,inputElem:k,labelSpan:h});e=g?this.baseLayersDiv:this.dataLayersDiv;e.appendChild(k);e.appendChild(h);e.appendChild(l)}}this.dataLbl.style.display=a?"":"none";this.baseLbl.style.display=b?"":"none";return this.div},updateMap:function(){for(var a=0,b=this.baseLayers.length;a<b;a++){var c=this.baseLayers[a];c.inputElem.checked&&this.map.setBaseLayer(c.layer,!1)}a=0;for(b=this.dataLayers.length;a<b;a++)c=this.dataLayers[a],c.layer.setVisibility(c.inputElem.checked)},maximizeControl:function(a){this.div.style.width=
+"";this.div.style.height="";this.showControls(!1);null!=a&&OpenLayers.Event.stop(a)},minimizeControl:function(a){this.div.style.width="0px";this.div.style.height="0px";this.showControls(!0);null!=a&&OpenLayers.Event.stop(a)},showControls:function(a){this.maximizeDiv.style.display=a?"":"none";this.minimizeDiv.style.display=a?"none":"";this.layersDiv.style.display=a?"none":""},loadContents:function(){this.layersDiv=document.createElement("div");this.layersDiv.id=this.id+"_layersDiv";OpenLayers.Element.addClass(this.layersDiv,
+"layersDiv");this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("Base Layer");OpenLayers.Element.addClass(this.baseLbl,"baseLbl");this.baseLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.baseLayersDiv,"baseLayersDiv");this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("Overlays");OpenLayers.Element.addClass(this.dataLbl,"dataLbl");this.dataLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.dataLayersDiv,
+"dataLayersDiv");this.ascending?(this.layersDiv.appendChild(this.baseLbl),this.layersDiv.appendChild(this.baseLayersDiv),this.layersDiv.appendChild(this.dataLbl),this.layersDiv.appendChild(this.dataLayersDiv)):(this.layersDiv.appendChild(this.dataLbl),this.layersDiv.appendChild(this.dataLayersDiv),this.layersDiv.appendChild(this.baseLbl),this.layersDiv.appendChild(this.baseLayersDiv));this.div.appendChild(this.layersDiv);var a=OpenLayers.Util.getImageLocation("layer-switcher-maximize.png");this.maximizeDiv=
+OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,null,a,"absolute");OpenLayers.Element.addClass(this.maximizeDiv,"maximizeDiv olButton");this.maximizeDiv.style.display="none";this.div.appendChild(this.maximizeDiv);a=OpenLayers.Util.getImageLocation("layer-switcher-minimize.png");this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,null,a,"absolute");OpenLayers.Element.addClass(this.minimizeDiv,"minimizeDiv olButton");this.minimizeDiv.style.display=
+"none";this.div.appendChild(this.minimizeDiv)},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Format.Atom=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{atom:"http://www.w3.org/2005/Atom",georss:"http://www.georss.org/georss"},feedTitle:"untitled",defaultEntryTitle:"untitled",gmlParser:null,xy:!1,read:function(a){"string"==typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));return this.parseFeatures(a)},write:function(a){var b;if(OpenLayers.Util.isArray(a)){b=this.createElementNSPlus("atom:feed");b.appendChild(this.createElementNSPlus("atom:title",{value:this.feedTitle}));
+for(var c=0,d=a.length;c<d;c++)b.appendChild(this.buildEntryNode(a[c]))}else b=this.buildEntryNode(a);return OpenLayers.Format.XML.prototype.write.apply(this,[b])},buildContentNode:function(a){var b=this.createElementNSPlus("atom:content",{attributes:{type:a.type||null}});if(a.src)b.setAttribute("src",a.src);else if("text"==a.type||null==a.type)b.appendChild(this.createTextNode(a.value));else if("html"==a.type){if("string"!=typeof a.value)throw"HTML content must be in form of an escaped string";b.appendChild(this.createTextNode(a.value))}else"xhtml"==
+a.type?b.appendChild(a.value):"xhtml"==a.type||a.type.match(/(\+|\/)xml$/)?b.appendChild(a.value):b.appendChild(this.createTextNode(a.value));return b},buildEntryNode:function(a){var b=a.attributes,c=b.atom||{},d=this.createElementNSPlus("atom:entry");if(c.authors)for(var e=OpenLayers.Util.isArray(c.authors)?c.authors:[c.authors],f=0,g=e.length;f<g;f++)d.appendChild(this.buildPersonConstructNode("author",e[f]));if(c.categories)for(var e=OpenLayers.Util.isArray(c.categories)?c.categories:[c.categories],
+h,f=0,g=e.length;f<g;f++)h=e[f],d.appendChild(this.createElementNSPlus("atom:category",{attributes:{term:h.term,scheme:h.scheme||null,label:h.label||null}}));c.content&&d.appendChild(this.buildContentNode(c.content));if(c.contributors)for(e=OpenLayers.Util.isArray(c.contributors)?c.contributors:[c.contributors],f=0,g=e.length;f<g;f++)d.appendChild(this.buildPersonConstructNode("contributor",e[f]));a.fid&&d.appendChild(this.createElementNSPlus("atom:id",{value:a.fid}));if(c.links)for(e=OpenLayers.Util.isArray(c.links)?
+c.links:[c.links],f=0,g=e.length;f<g;f++)h=e[f],d.appendChild(this.createElementNSPlus("atom:link",{attributes:{href:h.href,rel:h.rel||null,type:h.type||null,hreflang:h.hreflang||null,title:h.title||null,length:h.length||null}}));c.published&&d.appendChild(this.createElementNSPlus("atom:published",{value:c.published}));c.rights&&d.appendChild(this.createElementNSPlus("atom:rights",{value:c.rights}));(c.summary||b.description)&&d.appendChild(this.createElementNSPlus("atom:summary",{value:c.summary||
+b.description}));d.appendChild(this.createElementNSPlus("atom:title",{value:c.title||b.title||this.defaultEntryTitle}));c.updated&&d.appendChild(this.createElementNSPlus("atom:updated",{value:c.updated}));a.geometry&&(b=this.createElementNSPlus("georss:where"),b.appendChild(this.buildGeometryNode(a.geometry)),d.appendChild(b));return d},initGmlParser:function(){this.gmlParser=new OpenLayers.Format.GML.v3({xy:this.xy,featureNS:"http://example.com#feature",internalProjection:this.internalProjection,
+externalProjection:this.externalProjection})},buildGeometryNode:function(a){this.gmlParser||this.initGmlParser();return this.gmlParser.writeNode("feature:_geometry",a).firstChild},buildPersonConstructNode:function(a,b){var c=["uri","email"],d=this.createElementNSPlus("atom:"+a);d.appendChild(this.createElementNSPlus("atom:name",{value:b.name}));for(var e=0,f=c.length;e<f;e++)b[c[e]]&&d.appendChild(this.createElementNSPlus("atom:"+c[e],{value:b[c[e]]}));return d},getFirstChildValue:function(a,b,c,
+d){return(a=this.getElementsByTagNameNS(a,b,c))&&0<a.length?this.getChildValue(a[0],d):d},parseFeature:function(a){var b={},c=null,d=null,e=null,f=this.namespaces.atom;this.parsePersonConstructs(a,"author",b);d=this.getElementsByTagNameNS(a,f,"category");0<d.length&&(b.categories=[]);for(var g=0,h=d.length;g<h;g++){c={};c.term=d[g].getAttribute("term");if(e=d[g].getAttribute("scheme"))c.scheme=e;if(e=d[g].getAttribute("label"))c.label=e;b.categories.push(c)}d=this.getElementsByTagNameNS(a,f,"content");
+if(0<d.length){c={};if(e=d[0].getAttribute("type"))c.type=e;(e=d[0].getAttribute("src"))?c.src=e:("text"==c.type||"html"==c.type||null==c.type?c.value=this.getFirstChildValue(a,f,"content",null):"xhtml"==c.type||c.type.match(/(\+|\/)xml$/)?c.value=this.getChildEl(d[0]):c.value=this.getFirstChildValue(a,f,"content",null),b.content=c)}this.parsePersonConstructs(a,"contributor",b);b.id=this.getFirstChildValue(a,f,"id",null);d=this.getElementsByTagNameNS(a,f,"link");0<d.length&&(b.links=Array(d.length));
+for(var k=["rel","type","hreflang","title","length"],g=0,h=d.length;g<h;g++){c={};c.href=d[g].getAttribute("href");for(var l=0,m=k.length;l<m;l++)(e=d[g].getAttribute(k[l]))&&(c[k[l]]=e);b.links[g]=c}if(c=this.getFirstChildValue(a,f,"published",null))b.published=c;if(c=this.getFirstChildValue(a,f,"rights",null))b.rights=c;if(c=this.getFirstChildValue(a,f,"summary",null))b.summary=c;b.title=this.getFirstChildValue(a,f,"title",null);b.updated=this.getFirstChildValue(a,f,"updated",null);c={title:b.title,
+description:b.summary,atom:b};a=this.parseLocations(a)[0];a=new OpenLayers.Feature.Vector(a,c);a.fid=b.id;return a},parseFeatures:function(a){var b=[],c=this.getElementsByTagNameNS(a,this.namespaces.atom,"entry");0==c.length&&(c=[a]);a=0;for(var d=c.length;a<d;a++)b.push(this.parseFeature(c[a]));return b},parseLocations:function(a){var b=this.namespaces.georss,c={components:[]},d=this.getElementsByTagNameNS(a,b,"where");if(d&&0<d.length){this.gmlParser||this.initGmlParser();for(var e=0,f=d.length;e<
+f;e++)this.gmlParser.readChildNodes(d[e],c)}c=c.components;if((d=this.getElementsByTagNameNS(a,b,"point"))&&0<d.length)for(e=0,f=d.length;e<f;e++){var g=OpenLayers.String.trim(d[e].firstChild.nodeValue).split(/\s+/);2!=g.length&&(g=OpenLayers.String.trim(d[e].firstChild.nodeValue).split(/\s*,\s*/));c.push(new OpenLayers.Geometry.Point(g[1],g[0]))}var h=this.getElementsByTagNameNS(a,b,"line");if(h&&0<h.length)for(var k,e=0,f=h.length;e<f;e++){d=OpenLayers.String.trim(h[e].firstChild.nodeValue).split(/\s+/);
+k=[];for(var l=0,m=d.length;l<m;l+=2)g=new OpenLayers.Geometry.Point(d[l+1],d[l]),k.push(g);c.push(new OpenLayers.Geometry.LineString(k))}if((a=this.getElementsByTagNameNS(a,b,"polygon"))&&0<a.length)for(e=0,f=a.length;e<f;e++){d=OpenLayers.String.trim(a[e].firstChild.nodeValue).split(/\s+/);k=[];l=0;for(m=d.length;l<m;l+=2)g=new OpenLayers.Geometry.Point(d[l+1],d[l]),k.push(g);c.push(new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(k)]))}if(this.internalProjection&&this.externalProjection)for(e=
+0,f=c.length;e<f;e++)c[e]&&c[e].transform(this.externalProjection,this.internalProjection);return c},parsePersonConstructs:function(a,b,c){var d=[],e=this.namespaces.atom;a=this.getElementsByTagNameNS(a,e,b);for(var f=["uri","email"],g=0,h=a.length;g<h;g++){var k={};k.name=this.getFirstChildValue(a[g],e,"name",null);for(var l=0,m=f.length;l<m;l++){var n=this.getFirstChildValue(a[g],e,f[l],null);n&&(k[f[l]]=n)}d.push(k)}0<d.length&&(c[b+"s"]=d)},CLASS_NAME:"OpenLayers.Format.Atom"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:!0,slideFactor:75,observeElement:null,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{keydown:this.defaultKeyPress},{observeElement:this.observeElement||document})},defaultKeyPress:function(a){var b,c=!0;b=OpenLayers.Event.element(a);if(!b||"INPUT"!=b.tagName&&"TEXTAREA"!=b.tagName&&"SELECT"!=b.tagName){switch(a.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;cas
e OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,
+0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:b=this.map.getSize();this.map.pan(0,-0.75*b.h);break;case 34:b=this.map.getSize();this.map.pan(0,0.75*b.h);break;case 35:b=this.map.getSize();this.map.pan(0.75*b.w,0);break;case 36:b=this.map.getSize();this.map.pan(-0.75*b.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut();
+break;default:c=!1}c&&OpenLayers.Event.stop(a)}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(a){OpenLayers.Format.XML.prototype.initialize.apply(this,[a]);this.options=a;a=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(a,this.yx)},read:function(a){"string"==
+typeof a&&(a=OpenLayers.Format.XML.prototype.read.apply(this,[a]));a&&9==a.nodeType&&(a=a.documentElement);var b={};this.readNode(a,b);b.version=this.version;return b},readers:{wmts:{Capabilities:function(a,b){this.readChildNodes(a,b)},Contents:function(a,b){b.contents={};b.contents.layers=[];b.contents.tileMatrixSets={};this.readChildNodes(a,b.contents)},Layer:function(a,b){var c={styles:[],formats:[],dimensions:[],tileMatrixSetLinks:[],layers:[]};this.readChildNodes(a,c);b.layers.push(c)},Style:function(a,
+b){var c={};c.isDefault="true"===a.getAttribute("isDefault");this.readChildNodes(a,c);b.styles.push(c)},Format:function(a,b){b.formats.push(this.getChildValue(a))},TileMatrixSetLink:function(a,b){var c={};this.readChildNodes(a,c);b.tileMatrixSetLinks.push(c)},TileMatrixSet:function(a,b){if(b.layers){var c={matrixIds:[]};this.readChildNodes(a,c);b.tileMatrixSets[c.identifier]=c}else b.tileMatrixSet=this.getChildValue(a)},TileMatrix:function(a,b){var c={supportedCRS:b.supportedCRS};this.readChildNodes(a,
+c);b.matrixIds.push(c)},ScaleDenominator:function(a,b){b.scaleDenominator=parseFloat(this.getChildValue(a))},TopLeftCorner:function(a,b){var c=this.getChildValue(a).split(" "),d;b.supportedCRS&&(d=b.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2"),d=!!this.yx[d]);b.topLeftCorner=d?new OpenLayers.LonLat(c[1],c[0]):new OpenLayers.LonLat(c[0],c[1])},TileWidth:function(a,b){b.tileWidth=parseInt(this.getChildValue(a))},TileHeight:function(a,b){b.tileHeight=parseInt(this.getChildValue(a))},
+MatrixWidth:function(a,b){b.matrixWidth=parseInt(this.getChildValue(a))},MatrixHeight:function(a,b){b.matrixHeight=parseInt(this.getChildValue(a))},ResourceURL:function(a,b){b.resourceUrl=b.resourceUrl||{};var c=a.getAttribute("resourceType");b.resourceUrls||(b.resourceUrls=[]);c=b.resourceUrl[c]={format:a.getAttribute("format"),template:a.getAttribute("template"),resourceType:c};b.resourceUrls.push(c)},WSDL:function(a,b){b.wsdl={};b.wsdl.href=a.getAttribute("xlink:href")},ServiceMetadataURL:function(a,
+b){b.serviceMetadataUrl={};b.serviceMetadataUrl.href=a.getAttribute("xlink:href")},LegendURL:function(a,b){b.legend={};b.legend.href=a.getAttribute("xlink:href");b.legend.format=a.getAttribute("format")},Dimension:function(a,b){var c={values:[]};this.readChildNodes(a,c);b.dimensions.push(c)},Default:function(a,b){b["default"]=this.getChildValue(a)},Value:function(a,b){b.values.push(this.getChildValue(a))}},ows:OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers.ows},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities.v1_0_0"});
Added: trunk/MgDev/Doc/samples/ol2samples/assets/jquery-1.10.2.min.js
--- trunk/MgDev/Doc/samples/ol2samples/assets/jquery-1.10.2.min.js (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/jquery-1.10.2.min.js 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,6 @@
+/*! jQuery v1.10.2 | (c) 2005, 2013 jQuery Foundation, Inc. | jquery.org/license
+//@ sourceMappingURL=jquery-1.10.2.min.map
+(function(e,t){var n,r,i=typeof t,o=e.location,a=e.document,s=a.documentElement,l=e.jQuery,u=e.$,c={},p=[],f="1.10.2",d=p.concat,h=p.push,g=p.slice,m=p.indexOf,y=c.toString,v=c.hasOwnProperty,b=f.trim,x=function(e,t){return new x.fn.init(e,t,r)},w=/[+-]?(?:\d*\.|)\d+(?:[eE][+-]?\d+|)/.source,T=/\S+/g,C=/^[\s\uFEFF\xA0]+|[\s\uFEFF\xA0]+$/g,N=/^(?:\s*(<[\w\W]+>)[^>]*|#([\w-]*))$/,k=/^<(\w+)\s*\/?>(?:<\/\1>|)$/,E=/^[\],:{}\s]*$/,S=/(?:^|:|,)(?:\s*\[)+/g,A=/\\(?:["\\\/bfnrt]|u[\da-fA-F]{4})/g,j=/"[^"\\\r\n]*"|true|false|null|-?(?:\d+\.|)\d+(?:[eE][+-]?\d+|)/g,D=/^-ms-/,L=/-([\da-z])/gi,H=function(e,t){return t.toUpperCase()},q=function(e){(a.addEventListener||"load"===e.type||"complete"===a.readyState)&&(_(),x.ready())},_=function(){a.addEventListener?(a.removeEventListener("DOMContentLoaded",q,!1),e.removeEventListener("load",q,!1)):(a.detachEvent("onreadystatechange",q),e.detachEvent("onload",q))};x.fn=x.prototype={jquery:f,constructor:x,init:function(e,n,r){var i,o;if(!e)retu
rn this;if("string"==typeof e){if(i="<"===e.charAt(0)&&">"===e.charAt(e.length-1)&&e.length>=3?[null,e,null]:N.exec(e),!i||!i[1]&&n)return!n||n.jquery?(n||r).find(e):this.constructor(n).find(e);if(i[1]){if(n=n instanceof x?n[0]:n,x.merge(this,x.parseHTML(i[1],n&&n.nodeType?n.ownerDocument||n:a,!0)),k.test(i[1])&&x.isPlainObject(n))for(i in n)x.isFunction(this[i])?this[i](n[i]):this.attr(i,n[i]);return this}if(o=a.getElementById(i[2]),o&&o.parentNode){if(o.id!==i[2])return r.find(e);this.length=1,this[0]=o}return this.context=a,this.selector=e,this}return e.nodeType?(this.context=this[0]=e,this.length=1,this):x.isFunction(e)?r.ready(e):(e.selector!==t&&(this.selector=e.selector,this.context=e.context),x.makeArray(e,this))},selector:"",length:0,toArray:function(){return g.call(this)},get:function(e){return null==e?this.toArray():0>e?this[this.length+e]:this[e]},pushStack:function(e){var t=x.merge(this.constructor(),e);return t.prevObject=this,t.context=this.context,t},each:fun
ction(e,t){return x.each(this,e,t)},ready:function(e){return x.ready.promise().done(e),this},slice:function(){return this.pushStack(g.apply(this,arguments))},first:function(){return this.eq(0)},last:function(){return this.eq(-1)},eq:function(e){var t=this.length,n=+e+(0>e?t:0);return this.pushStack(n>=0&&t>n?[this[n]]:[])},map:function(e){return this.pushStack(x.map(this,function(t,n){return e.call(t,n,t)}))},end:function(){return this.prevObject||this.constructor(null)},push:h,sort:[].sort,splice:[].splice},x.fn.init.prototype=x.fn,x.extend=x.fn.extend=function(){var e,n,r,i,o,a,s=arguments[0]||{},l=1,u=arguments.length,c=!1;for("boolean"==typeof s&&(c=s,s=arguments[1]||{},l=2),"object"==typeof s||x.isFunction(s)||(s={}),u===l&&(s=this,--l);u>l;l++)if(null!=(o=arguments[l]))for(i in o)e=s[i],r=o[i],s!==r&&(c&&r&&(x.isPlainObject(r)||(n=x.isArray(r)))?(n?(n=!1,a=e&&x.isArray(e)?e:[]):a=e&&x.isPlainObject(e)?e:{},s[i]=x.extend(c,a,r)):r!==t&&(s[i]=r));return s},x.extend({expa
ndo:"jQuery"+(f+Math.random()).replace(/\D/g,""),noConflict:function(t){return e.$===x&&(e.$=u),t&&e.jQuery===x&&(e.jQuery=l),x},isReady:!1,readyWait:1,holdReady:function(e){e?x.readyWait++:x.ready(!0)},ready:function(e){if(e===!0?!--x.readyWait:!x.isReady){if(!a.body)return setTimeout(x.ready);x.isReady=!0,e!==!0&&--x.readyWait>0||(n.resolveWith(a,[x]),x.fn.trigger&&x(a).trigger("ready").off("ready"))}},isFunction:function(e){return"function"===x.type(e)},isArray:Array.isArray||function(e){return"array"===x.type(e)},isWindow:function(e){return null!=e&&e==e.window},isNumeric:function(e){return!isNaN(parseFloat(e))&&isFinite(e)},type:function(e){return null==e?e+"":"object"==typeof e||"function"==typeof e?c[y.call(e)]||"object":typeof e},isPlainObject:function(e){var n;if(!e||"object"!==x.type(e)||e.nodeType||x.isWindow(e))return!1;try{if(e.constructor&&!v.call(e,"constructor")&&!v.call(e.constructor.prototype,"isPrototypeOf"))return!1}catch(r){return!1}if(x.support.ownLast)
for(n in e)return v.call(e,n);for(n in e);return n===t||v.call(e,n)},isEmptyObject:function(e){var t;for(t in e)return!1;return!0},error:function(e){throw Error(e)},parseHTML:function(e,t,n){if(!e||"string"!=typeof e)return null;"boolean"==typeof t&&(n=t,t=!1),t=t||a;var r=k.exec(e),i=!n&&[];return r?[t.createElement(r[1])]:(r=x.buildFragment([e],t,i),i&&x(i).remove(),x.merge([],r.childNodes))},parseJSON:function(n){return e.JSON&&e.JSON.parse?e.JSON.parse(n):null===n?n:"string"==typeof n&&(n=x.trim(n),n&&E.test(n.replace(A,"@").replace(j,"]").replace(S,"")))?Function("return "+n)():(x.error("Invalid JSON: "+n),t)},parseXML:function(n){var r,i;if(!n||"string"!=typeof n)return null;try{e.DOMParser?(i=new DOMParser,r=i.parseFromString(n,"text/xml")):(r=new ActiveXObject("Microsoft.XMLDOM"),r.async="false",r.loadXML(n))}catch(o){r=t}return r&&r.documentElement&&!r.getElementsByTagName("parsererror").length||x.error("Invalid XML: "+n),r},noop:function(){},globalEval:function(t){
t&&x.trim(t)&&(e.execScript||function(t){e.eval.call(e,t)})(t)},camelCase:function(e){return e.replace(D,"ms-").replace(L,H)},nodeName:function(e,t){return e.nodeName&&e.nodeName.toLowerCase()===t.toLowerCase()},each:function(e,t,n){var r,i=0,o=e.length,a=M(e);if(n){if(a){for(;o>i;i++)if(r=t.apply(e[i],n),r===!1)break}else for(i in e)if(r=t.apply(e[i],n),r===!1)break}else if(a){for(;o>i;i++)if(r=t.call(e[i],i,e[i]),r===!1)break}else for(i in e)if(r=t.call(e[i],i,e[i]),r===!1)break;return e},trim:b&&!b.call("\ufeff\u00a0")?function(e){return null==e?"":b.call(e)}:function(e){return null==e?"":(e+"").replace(C,"")},makeArray:function(e,t){var n=t||[];return null!=e&&(M(Object(e))?x.merge(n,"string"==typeof e?[e]:e):h.call(n,e)),n},inArray:function(e,t,n){var r;if(t){if(m)return m.call(t,e,n);for(r=t.length,n=n?0>n?Math.max(0,r+n):n:0;r>n;n++)if(n in t&&t[n]===e)return n}return-1},merge:function(e,n){var r=n.length,i=e.length,o=0;if("number"==typeof r)for(;r>o;o++)e[i++]=n[o];e
lse while(n[o]!==t)e[i++]=n[o++];return e.length=i,e},grep:function(e,t,n){var r,i=[],o=0,a=e.length;for(n=!!n;a>o;o++)r=!!t(e[o],o),n!==r&&i.push(e[o]);return i},map:function(e,t,n){var r,i=0,o=e.length,a=M(e),s=[];if(a)for(;o>i;i++)r=t(e[i],i,n),null!=r&&(s[s.length]=r);else for(i in e)r=t(e[i],i,n),null!=r&&(s[s.length]=r);return d.apply([],s)},guid:1,proxy:function(e,n){var r,i,o;return"string"==typeof n&&(o=e[n],n=e,e=o),x.isFunction(e)?(r=g.call(arguments,2),i=function(){return e.apply(n||this,r.concat(g.call(arguments)))},i.guid=e.guid=e.guid||x.guid++,i):t},access:function(e,n,r,i,o,a,s){var l=0,u=e.length,c=null==r;if("object"===x.type(r)){o=!0;for(l in r)x.access(e,n,l,r[l],!0,a,s)}else if(i!==t&&(o=!0,x.isFunction(i)||(s=!0),c&&(s?(n.call(e,i),n=null):(c=n,n=function(e,t,n){return c.call(x(e),n)})),n))for(;u>l;l++)n(e[l],r,s?i:i.call(e[l],l,n(e[l],r)));return o?e:c?n.call(e):u?n(e[0],r):a},now:function(){return(new Date).getTime()},swap:function(e,t,n,r){var i,o,a
={};for(o in t)a[o]=e.style[o],e.style[o]=t[o];i=n.apply(e,r||[]);for(o in t)e.style[o]=a[o];return i}}),x.ready.promise=function(t){if(!n)if(n=x.Deferred(),"complete"===a.readyState)setTimeout(x.ready);else if(a.addEventListener)a.addEventListener("DOMContentLoaded",q,!1),e.addEventListener("load",q,!1);else{a.attachEvent("onreadystatechange",q),e.attachEvent("onload",q);var r=!1;try{r=null==e.frameElement&&a.documentElement}catch(i){}r&&r.doScroll&&function o(){if(!x.isReady){try{r.doScroll("left")}catch(e){return setTimeout(o,50)}_(),x.ready()}}()}return n.promise(t)},x.each("Boolean Number String Function Array Date RegExp Object Error".split(" "),function(e,t){c["[object "+t+"]"]=t.toLowerCase()});function M(e){var t=e.length,n=x.type(e);return x.isWindow(e)?!1:1===e.nodeType&&t?!0:"array"===n||"function"!==n&&(0===t||"number"==typeof t&&t>0&&t-1 in e)}r=x(a),function(e,t){var n,r,i,o,a,s,l,u,c,p,f,d,h,g,m,y,v,b="sizzle"+-new Date,w=e.document,T=0,C=0,N=st(),k=st(),E=st
(),S=!1,A=function(e,t){return e===t?(S=!0,0):0},j=typeof t,D=1<<31,L={}.hasOwnProperty,H=[],q=H.pop,_=H.push,M=H.push,O=H.slice,F=H.indexOf||function(e){var t=0,n=this.length;for(;n>t;t++)if(this[t]===e)return t;return-1},B="checked|selected|async|autofocus|autoplay|controls|defer|disabled|hidden|ismap|loop|multiple|open|readonly|required|scoped",P="[\\x20\\t\\r\\n\\f]",R="(?:\\\\.|[\\w-]|[^\\x00-\\xa0])+",W=R.replace("w","w#"),$="\\["+P+"*("+R+")"+P+"*(?:([*^$|!~]?=)"+P+"*(?:(['\"])((?:\\\\.|[^\\\\])*?)\\3|("+W+")|)|)"+P+"*\\]",I=":("+R+")(?:\\(((['\"])((?:\\\\.|[^\\\\])*?)\\3|((?:\\\\.|[^\\\\()[\\]]|"+$.replace(3,8)+")*)|.*)\\)|)",z=RegExp("^"+P+"+|((?:^|[^\\\\])(?:\\\\.)*)"+P+"+$","g"),X=RegExp("^"+P+"*,"+P+"*"),U=RegExp("^"+P+"*([>+~]|"+P+")"+P+"*"),V=RegExp(P+"*[+~]"),Y=RegExp("="+P+"*([^\\]'\"]*)"+P+"*\\]","g"),J=RegExp(I),G=RegExp("^"+W+"$"),Q={ID:RegExp("^#("+R+")"),CLASS:RegExp("^\\.("+R+")"),TAG:RegExp("^("+R.replace("w","w*")+")"),ATTR:RegExp("^"+$),PSEUDO:RegExp
("^"+I),CHILD:RegExp("^:(only|first|last|nth|nth-last)-(child|of-type)(?:\\("+P+"*(even|odd|(([+-]|)(\\d*)n|)"+P+"*(?:([+-]|)"+P+"*(\\d+)|))"+P+"*\\)|)","i"),bool:RegExp("^(?:"+B+")$","i"),needsContext:RegExp("^"+P+"*[>+~]|:(even|odd|eq|gt|lt|nth|first|last)(?:\\("+P+"*((?:-\\d)?\\d*)"+P+"*\\)|)(?=[^-]|$)","i")},K=/^[^{]+\{\s*\[native \w/,Z=/^(?:#([\w-]+)|(\w+)|\.([\w-]+))$/,et=/^(?:input|select|textarea|button)$/i,tt=/^h\d$/i,nt=/'|\\/g,rt=RegExp("\\\\([\\da-f]{1,6}"+P+"?|("+P+")|.)","ig"),it=function(e,t,n){var r="0x"+t-65536;return r!==r||n?t:0>r?String.fromCharCode(r+65536):String.fromCharCode(55296|r>>10,56320|1023&r)};try{M.apply(H=O.call(w.childNodes),w.childNodes),H[w.childNodes.length].nodeType}catch(ot){M={apply:H.length?function(e,t){_.apply(e,O.call(t))}:function(e,t){var n=e.length,r=0;while(e[n++]=t[r++]);e.length=n-1}}}function at(e,t,n,i){var o,a,s,l,u,c,d,m,y,x;if((t?t.ownerDocument||t:w)!==f&&p(t),t=t||f,n=n||[],!e||"string"!=typeof e)return n;if(1!==(l=t.n
odeType)&&9!==l)return[];if(h&&!i){if(o=Z.exec(e))if(s=o[1]){if(9===l){if(a=t.getElementById(s),!a||!a.parentNode)return n;if(a.id===s)return n.push(a),n}else if(t.ownerDocument&&(a=t.ownerDocument.getElementById(s))&&v(t,a)&&a.id===s)return n.push(a),n}else{if(o[2])return M.apply(n,t.getElementsByTagName(e)),n;if((s=o[3])&&r.getElementsByClassName&&t.getElementsByClassName)return M.apply(n,t.getElementsByClassName(s)),n}if(r.qsa&&(!g||!g.test(e))){if(m=d=b,y=t,x=9===l&&e,1===l&&"object"!==t.nodeName.toLowerCase()){c=mt(e),(d=t.getAttribute("id"))?m=d.replace(nt,"\\$&"):t.setAttribute("id",m),m="[id='"+m+"'] ",u=c.length;while(u--)c[u]=m+yt(c[u]);y=V.test(e)&&t.parentNode||t,x=c.join(",")}if(x)try{return M.apply(n,y.querySelectorAll(x)),n}catch(T){}finally{d||t.removeAttribute("id")}}}return kt(e.replace(z,"$1"),t,n,i)}function st(){var e=[];function t(n,r){return e.push(n+=" ")>o.cacheLength&&delete t[e.shift()],t[n]=r}return t}function lt(e){return e[b]=!0,e}function ut(e)
{var t=f.createElement("div");try{return!!e(t)}catch(n){return!1}finally{t.parentNode&&t.parentNode.removeChild(t),t=null}}function ct(e,t){var n=e.split("|"),r=e.length;while(r--)o.attrHandle[n[r]]=t}function pt(e,t){var n=t&&e,r=n&&1===e.nodeType&&1===t.nodeType&&(~t.sourceIndex||D)-(~e.sourceIndex||D);if(r)return r;if(n)while(n=n.nextSibling)if(n===t)return-1;return e?1:-1}function ft(e){return function(t){var n=t.nodeName.toLowerCase();return"input"===n&&t.type===e}}function dt(e){return function(t){var n=t.nodeName.toLowerCase();return("input"===n||"button"===n)&&t.type===e}}function ht(e){return lt(function(t){return t=+t,lt(function(n,r){var i,o=e([],n.length,t),a=o.length;while(a--)n[i=o[a]]&&(n[i]=!(r[i]=n[i]))})})}s=at.isXML=function(e){var t=e&&(e.ownerDocument||e).documentElement;return t?"HTML"!==t.nodeName:!1},r=at.support={},p=at.setDocument=function(e){var n=e?e.ownerDocument||e:w,i=n.defaultView;return n!==f&&9===n.nodeType&&n.documentElement?(f=n,d=n.docume
ntElement,h=!s(n),i&&i.attachEvent&&i!==i.top&&i.attachEvent("onbeforeunload",function(){p()}),r.attributes=ut(function(e){return e.className="i",!e.getAttribute("className")}),r.getElementsByTagName=ut(function(e){return e.appendChild(n.createComment("")),!e.getElementsByTagName("*").length}),r.getElementsByClassName=ut(function(e){return e.innerHTML="<div class='a'></div><div class='a i'></div>",e.firstChild.className="i",2===e.getElementsByClassName("i").length}),r.getById=ut(function(e){return d.appendChild(e).id=b,!n.getElementsByName||!n.getElementsByName(b).length}),r.getById?(o.find.ID=function(e,t){if(typeof t.getElementById!==j&&h){var n=t.getElementById(e);return n&&n.parentNode?[n]:[]}},o.filter.ID=function(e){var t=e.replace(rt,it);return function(e){return e.getAttribute("id")===t}}):(delete o.find.ID,o.filter.ID=function(e){var t=e.replace(rt,it);return function(e){var n=typeof e.getAttributeNode!==j&&e.getAttributeNode("id");return n&&n.value===t}}),o.find.TA
G=r.getElementsByTagName?function(e,n){return typeof n.getElementsByTagName!==j?n.getElementsByTagName(e):t}:function(e,t){var n,r=[],i=0,o=t.getElementsByTagName(e);if("*"===e){while(n=o[i++])1===n.nodeType&&r.push(n);return r}return o},o.find.CLASS=r.getElementsByClassName&&function(e,n){return typeof n.getElementsByClassName!==j&&h?n.getElementsByClassName(e):t},m=[],g=[],(r.qsa=K.test(n.querySelectorAll))&&(ut(function(e){e.innerHTML="<select><option selected=''></option></select>",e.querySelectorAll("[selected]").length||g.push("\\["+P+"*(?:value|"+B+")"),e.querySelectorAll(":checked").length||g.push(":checked")}),ut(function(e){var t=n.createElement("input");t.setAttribute("type","hidden"),e.appendChild(t).setAttribute("t",""),e.querySelectorAll("[t^='']").length&&g.push("[*^$]="+P+"*(?:''|\"\")"),e.querySelectorAll(":enabled").length||g.push(":enabled",":disabled"),e.querySelectorAll("*,:x"),g.push(",.*:")})),(r.matchesSelector=K.test(y=d.webkitMatchesSelector||d.mozM
atchesSelector||d.oMatchesSelector||d.msMatchesSelector))&&ut(function(e){r.disconnectedMatch=y.call(e,"div"),y.call(e,"[s!='']:x"),m.push("!=",I)}),g=g.length&&RegExp(g.join("|")),m=m.length&&RegExp(m.join("|")),v=K.test(d.contains)||d.compareDocumentPosition?function(e,t){var n=9===e.nodeType?e.documentElement:e,r=t&&t.parentNode;return e===r||!(!r||1!==r.nodeType||!(n.contains?n.contains(r):e.compareDocumentPosition&&16&e.compareDocumentPosition(r)))}:function(e,t){if(t)while(t=t.parentNode)if(t===e)return!0;return!1},A=d.compareDocumentPosition?function(e,t){if(e===t)return S=!0,0;var i=t.compareDocumentPosition&&e.compareDocumentPosition&&e.compareDocumentPosition(t);return i?1&i||!r.sortDetached&&t.compareDocumentPosition(e)===i?e===n||v(w,e)?-1:t===n||v(w,t)?1:c?F.call(c,e)-F.call(c,t):0:4&i?-1:1:e.compareDocumentPosition?-1:1}:function(e,t){var r,i=0,o=e.parentNode,a=t.parentNode,s=[e],l=[t];if(e===t)return S=!0,0;if(!o||!a)return e===n?-1:t===n?1:o?-1:a?1:c?F.call(c
,e)-F.call(c,t):0;if(o===a)return pt(e,t);r=e;while(r=r.parentNode)s.unshift(r);r=t;while(r=r.parentNode)l.unshift(r);while(s[i]===l[i])i++;return i?pt(s[i],l[i]):s[i]===w?-1:l[i]===w?1:0},n):f},at.matches=function(e,t){return at(e,null,null,t)},at.matchesSelector=function(e,t){if((e.ownerDocument||e)!==f&&p(e),t=t.replace(Y,"='$1']"),!(!r.matchesSelector||!h||m&&m.test(t)||g&&g.test(t)))try{var n=y.call(e,t);if(n||r.disconnectedMatch||e.document&&11!==e.document.nodeType)return n}catch(i){}return at(t,f,null,[e]).length>0},at.contains=function(e,t){return(e.ownerDocument||e)!==f&&p(e),v(e,t)},at.attr=function(e,n){(e.ownerDocument||e)!==f&&p(e);var i=o.attrHandle[n.toLowerCase()],a=i&&L.call(o.attrHandle,n.toLowerCase())?i(e,n,!h):t;return a===t?r.attributes||!h?e.getAttribute(n):(a=e.getAttributeNode(n))&&a.specified?a.value:null:a},at.error=function(e){throw Error("Syntax error, unrecognized expression: "+e)},at.uniqueSort=function(e){var t,n=[],i=0,o=0;if(S=!r.detectDupl
icates,c=!r.sortStable&&e.slice(0),e.sort(A),S){while(t=e[o++])t===e[o]&&(i=n.push(o));while(i--)e.splice(n[i],1)}return e},a=at.getText=function(e){var t,n="",r=0,i=e.nodeType;if(i){if(1===i||9===i||11===i){if("string"==typeof e.textContent)return e.textContent;for(e=e.firstChild;e;e=e.nextSibling)n+=a(e)}else if(3===i||4===i)return e.nodeValue}else for(;t=e[r];r++)n+=a(t);return n},o=at.selectors={cacheLength:50,createPseudo:lt,match:Q,attrHandle:{},find:{},relative:{">":{dir:"parentNode",first:!0}," ":{dir:"parentNode"},"+":{dir:"previousSibling",first:!0},"~":{dir:"previousSibling"}},preFilter:{ATTR:function(e){return e[1]=e[1].replace(rt,it),e[3]=(e[4]||e[5]||"").replace(rt,it),"~="===e[2]&&(e[3]=" "+e[3]+" "),e.slice(0,4)},CHILD:function(e){return e[1]=e[1].toLowerCase(),"nth"===e[1].slice(0,3)?(e[3]||at.error(e[0]),e[4]=+(e[4]?e[5]+(e[6]||1):2*("even"===e[3]||"odd"===e[3])),e[5]=+(e[7]+e[8]||"odd"===e[3])):e[3]&&at.error(e[0]),e},PSEUDO:function(e){var n,r=!e[5]&&e[2]
;return Q.CHILD.test(e[0])?null:(e[3]&&e[4]!==t?e[2]=e[4]:r&&J.test(r)&&(n=mt(r,!0))&&(n=r.indexOf(")",r.length-n)-r.length)&&(e[0]=e[0].slice(0,n),e[2]=r.slice(0,n)),e.slice(0,3))}},filter:{TAG:function(e){var t=e.replace(rt,it).toLowerCase();return"*"===e?function(){return!0}:function(e){return e.nodeName&&e.nodeName.toLowerCase()===t}},CLASS:function(e){var t=N[e+" "];return t||(t=RegExp("(^|"+P+")"+e+"("+P+"|$)"))&&N(e,function(e){return t.test("string"==typeof e.className&&e.className||typeof e.getAttribute!==j&&e.getAttribute("class")||"")})},ATTR:function(e,t,n){return function(r){var i=at.attr(r,e);return null==i?"!="===t:t?(i+="","="===t?i===n:"!="===t?i!==n:"^="===t?n&&0===i.indexOf(n):"*="===t?n&&i.indexOf(n)>-1:"$="===t?n&&i.slice(-n.length)===n:"~="===t?(" "+i+" ").indexOf(n)>-1:"|="===t?i===n||i.slice(0,n.length+1)===n+"-":!1):!0}},CHILD:function(e,t,n,r,i){var o="nth"!==e.slice(0,3),a="last"!==e.slice(-4),s="of-type"===t;return 1===r&&0===i?function(e){return!
!e.parentNode}:function(t,n,l){var u,c,p,f,d,h,g=o!==a?"nextSibling":"previousSibling",m=t.parentNode,y=s&&t.nodeName.toLowerCase(),v=!l&&!s;if(m){if(o){while(g){p=t;while(p=p[g])if(s?p.nodeName.toLowerCase()===y:1===p.nodeType)return!1;h=g="only"===e&&!h&&"nextSibling"}return!0}if(h=[a?m.firstChild:m.lastChild],a&&v){c=m[b]||(m[b]={}),u=c[e]||[],d=u[0]===T&&u[1],f=u[0]===T&&u[2],p=d&&m.childNodes[d];while(p=++d&&p&&p[g]||(f=d=0)||h.pop())if(1===p.nodeType&&++f&&p===t){c[e]=[T,d,f];break}}else if(v&&(u=(t[b]||(t[b]={}))[e])&&u[0]===T)f=u[1];else while(p=++d&&p&&p[g]||(f=d=0)||h.pop())if((s?p.nodeName.toLowerCase()===y:1===p.nodeType)&&++f&&(v&&((p[b]||(p[b]={}))[e]=[T,f]),p===t))break;return f-=i,f===r||0===f%r&&f/r>=0}}},PSEUDO:function(e,t){var n,r=o.pseudos[e]||o.setFilters[e.toLowerCase()]||at.error("unsupported pseudo: "+e);return r[b]?r(t):r.length>1?(n=[e,e,"",t],o.setFilters.hasOwnProperty(e.toLowerCase())?lt(function(e,n){var i,o=r(e,t),a=o.length;while(a--)i=F.call
(e,o[a]),e[i]=!(n[i]=o[a])}):function(e){return r(e,0,n)}):r}},pseudos:{not:lt(function(e){var t=[],n=[],r=l(e.replace(z,"$1"));return r[b]?lt(function(e,t,n,i){var o,a=r(e,null,i,[]),s=e.length;while(s--)(o=a[s])&&(e[s]=!(t[s]=o))}):function(e,i,o){return t[0]=e,r(t,null,o,n),!n.pop()}}),has:lt(function(e){return function(t){return at(e,t).length>0}}),contains:lt(function(e){return function(t){return(t.textContent||t.innerText||a(t)).indexOf(e)>-1}}),lang:lt(function(e){return G.test(e||"")||at.error("unsupported lang: "+e),e=e.replace(rt,it).toLowerCase(),function(t){var n;do if(n=h?t.lang:t.getAttribute("xml:lang")||t.getAttribute("lang"))return n=n.toLowerCase(),n===e||0===n.indexOf(e+"-");while((t=t.parentNode)&&1===t.nodeType);return!1}}),target:function(t){var n=e.location&&e.location.hash;return n&&n.slice(1)===t.id},root:function(e){return e===d},focus:function(e){return e===f.activeElement&&(!f.hasFocus||f.hasFocus())&&!!(e.type||e.href||~e.tabIndex)},enabled:funct
ion(e){return e.disabled===!1},disabled:function(e){return e.disabled===!0},checked:function(e){var t=e.nodeName.toLowerCase();return"input"===t&&!!e.checked||"option"===t&&!!e.selected},selected:function(e){return e.parentNode&&e.parentNode.selectedIndex,e.selected===!0},empty:function(e){for(e=e.firstChild;e;e=e.nextSibling)if(e.nodeName>"@"||3===e.nodeType||4===e.nodeType)return!1;return!0},parent:function(e){return!o.pseudos.empty(e)},header:function(e){return tt.test(e.nodeName)},input:function(e){return et.test(e.nodeName)},button:function(e){var t=e.nodeName.toLowerCase();return"input"===t&&"button"===e.type||"button"===t},text:function(e){var t;return"input"===e.nodeName.toLowerCase()&&"text"===e.type&&(null==(t=e.getAttribute("type"))||t.toLowerCase()===e.type)},first:ht(function(){return[0]}),last:ht(function(e,t){return[t-1]}),eq:ht(function(e,t,n){return[0>n?n+t:n]}),even:ht(function(e,t){var n=0;for(;t>n;n+=2)e.push(n);return e}),odd:ht(function(e,t){var n=1;for
(;t>n;n+=2)e.push(n);return e}),lt:ht(function(e,t,n){var r=0>n?n+t:n;for(;--r>=0;)e.push(r);return e}),gt:ht(function(e,t,n){var r=0>n?n+t:n;for(;t>++r;)e.push(r);return e})}},o.pseudos.nth=o.pseudos.eq;for(n in{radio:!0,checkbox:!0,file:!0,password:!0,image:!0})o.pseudos[n]=ft(n);for(n in{submit:!0,reset:!0})o.pseudos[n]=dt(n);function gt(){}gt.prototype=o.filters=o.pseudos,o.setFilters=new gt;function mt(e,t){var n,r,i,a,s,l,u,c=k[e+" "];if(c)return t?0:c.slice(0);s=e,l=[],u=o.preFilter;while(s){(!n||(r=X.exec(s)))&&(r&&(s=s.slice(r[0].length)||s),l.push(i=[])),n=!1,(r=U.exec(s))&&(n=r.shift(),i.push({value:n,type:r[0].replace(z," ")}),s=s.slice(n.length));for(a in o.filter)!(r=Q[a].exec(s))||u[a]&&!(r=u[a](r))||(n=r.shift(),i.push({value:n,type:a,matches:r}),s=s.slice(n.length));if(!n)break}return t?s.length:s?at.error(e):k(e,l).slice(0)}function yt(e){var t=0,n=e.length,r="";for(;n>t;t++)r+=e[t].value;return r}function vt(e,t,n){var r=t.dir,o=n&&"parentNode"===r,a=C++;r
eturn t.first?function(t,n,i){while(t=t[r])if(1===t.nodeType||o)return e(t,n,i)}:function(t,n,s){var l,u,c,p=T+" "+a;if(s){while(t=t[r])if((1===t.nodeType||o)&&e(t,n,s))return!0}else while(t=t[r])if(1===t.nodeType||o)if(c=t[b]||(t[b]={}),(u=c[r])&&u[0]===p){if((l=u[1])===!0||l===i)return l===!0}else if(u=c[r]=[p],u[1]=e(t,n,s)||i,u[1]===!0)return!0}}function bt(e){return e.length>1?function(t,n,r){var i=e.length;while(i--)if(!e[i](t,n,r))return!1;return!0}:e[0]}function xt(e,t,n,r,i){var o,a=[],s=0,l=e.length,u=null!=t;for(;l>s;s++)(o=e[s])&&(!n||n(o,r,i))&&(a.push(o),u&&t.push(s));return a}function wt(e,t,n,r,i,o){return r&&!r[b]&&(r=wt(r)),i&&!i[b]&&(i=wt(i,o)),lt(function(o,a,s,l){var u,c,p,f=[],d=[],h=a.length,g=o||Nt(t||"*",s.nodeType?[s]:s,[]),m=!e||!o&&t?g:xt(g,f,e,s,l),y=n?i||(o?e:h||r)?[]:a:m;if(n&&n(m,y,s,l),r){u=xt(y,d),r(u,[],s,l),c=u.length;while(c--)(p=u[c])&&(y[d[c]]=!(m[d[c]]=p))}if(o){if(i||e){if(i){u=[],c=y.length;while(c--)(p=y[c])&&u.push(m[c]=p);i(null,y
=[],u,l)}c=y.length;while(c--)(p=y[c])&&(u=i?F.call(o,p):f[c])>-1&&(o[u]=!(a[u]=p))}}else y=xt(y===a?y.splice(h,y.length):y),i?i(null,a,y,l):M.apply(a,y)})}function Tt(e){var t,n,r,i=e.length,a=o.relative[e[0].type],s=a||o.relative[" "],l=a?1:0,c=vt(function(e){return e===t},s,!0),p=vt(function(e){return F.call(t,e)>-1},s,!0),f=[function(e,n,r){return!a&&(r||n!==u)||((t=n).nodeType?c(e,n,r):p(e,n,r))}];for(;i>l;l++)if(n=o.relative[e[l].type])f=[vt(bt(f),n)];else{if(n=o.filter[e[l].type].apply(null,e[l].matches),n[b]){for(r=++l;i>r;r++)if(o.relative[e[r].type])break;return wt(l>1&&bt(f),l>1&&yt(e.slice(0,l-1).concat({value:" "===e[l-2].type?"*":""})).replace(z,"$1"),n,r>l&&Tt(e.slice(l,r)),i>r&&Tt(e=e.slice(r)),i>r&&yt(e))}f.push(n)}return bt(f)}function Ct(e,t){var n=0,r=t.length>0,a=e.length>0,s=function(s,l,c,p,d){var h,g,m,y=[],v=0,b="0",x=s&&[],w=null!=d,C=u,N=s||a&&o.find.TAG("*",d&&l.parentNode||l),k=T+=null==C?1:Math.random()||.1;for(w&&(u=l!==f&&l,i=n);null!=(h=N[b])
;b++){if(a&&h){g=0;while(m=e[g++])if(m(h,l,c)){p.push(h);break}w&&(T=k,i=++n)}r&&((h=!m&&h)&&v--,s&&x.push(h))}if(v+=b,r&&b!==v){g=0;while(m=t[g++])m(x,y,l,c);if(s){if(v>0)while(b--)x[b]||y[b]||(y[b]=q.call(p));y=xt(y)}M.apply(p,y),w&&!s&&y.length>0&&v+t.length>1&&at.uniqueSort(p)}return w&&(T=k,u=C),x};return r?lt(s):s}l=at.compile=function(e,t){var n,r=[],i=[],o=E[e+" "];if(!o){t||(t=mt(e)),n=t.length;while(n--)o=Tt(t[n]),o[b]?r.push(o):i.push(o);o=E(e,Ct(i,r))}return o};function Nt(e,t,n){var r=0,i=t.length;for(;i>r;r++)at(e,t[r],n);return n}function kt(e,t,n,i){var a,s,u,c,p,f=mt(e);if(!i&&1===f.length){if(s=f[0]=f[0].slice(0),s.length>2&&"ID"===(u=s[0]).type&&r.getById&&9===t.nodeType&&h&&o.relative[s[1].type]){if(t=(o.find.ID(u.matches[0].replace(rt,it),t)||[])[0],!t)return n;e=e.slice(s.shift().value.length)}a=Q.needsContext.test(e)?0:s.length;while(a--){if(u=s[a],o.relative[c=u.type])break;if((p=o.find[c])&&(i=p(u.matches[0].replace(rt,it),V.test(s[0].type)&&t.parent
Node||t))){if(s.splice(a,1),e=i.length&&yt(s),!e)return M.apply(n,i),n;break}}}return l(e,f)(i,t,!h,n,V.test(e)),n}r.sortStable=b.split("").sort(A).join("")===b,r.detectDuplicates=S,p(),r.sortDetached=ut(function(e){return 1&e.compareDocumentPosition(f.createElement("div"))}),ut(function(e){return e.innerHTML="<a href='#'></a>","#"===e.firstChild.getAttribute("href")})||ct("type|href|height|width",function(e,n,r){return r?t:e.getAttribute(n,"type"===n.toLowerCase()?1:2)}),r.attributes&&ut(function(e){return e.innerHTML="<input/>",e.firstChild.setAttribute("value",""),""===e.firstChild.getAttribute("value")})||ct("value",function(e,n,r){return r||"input"!==e.nodeName.toLowerCase()?t:e.defaultValue}),ut(function(e){return null==e.getAttribute("disabled")})||ct(B,function(e,n,r){var i;return r?t:(i=e.getAttributeNode(n))&&i.specified?i.value:e[n]===!0?n.toLowerCase():null}),x.find=at,x.expr=at.selectors,x.expr[":"]=x.expr.pseudos,x.unique=at.uniqueSort,x.text=at.getText,x.isXML
Doc=at.isXML,x.contains=at.contains}(e);var O={};function F(e){var t=O[e]={};return x.each(e.match(T)||[],function(e,n){t[n]=!0}),t}x.Callbacks=function(e){e="string"==typeof e?O[e]||F(e):x.extend({},e);var n,r,i,o,a,s,l=[],u=!e.once&&[],c=function(t){for(r=e.memory&&t,i=!0,a=s||0,s=0,o=l.length,n=!0;l&&o>a;a++)if(l[a].apply(t[0],t[1])===!1&&e.stopOnFalse){r=!1;break}n=!1,l&&(u?u.length&&c(u.shift()):r?l=[]:p.disable())},p={add:function(){if(l){var t=l.length;(function i(t){x.each(t,function(t,n){var r=x.type(n);"function"===r?e.unique&&p.has(n)||l.push(n):n&&n.length&&"string"!==r&&i(n)})})(arguments),n?o=l.length:r&&(s=t,c(r))}return this},remove:function(){return l&&x.each(arguments,function(e,t){var r;while((r=x.inArray(t,l,r))>-1)l.splice(r,1),n&&(o>=r&&o--,a>=r&&a--)}),this},has:function(e){return e?x.inArray(e,l)>-1:!(!l||!l.length)},empty:function(){return l=[],o=0,this},disable:function(){return l=u=r=t,this},disabled:function(){return!l},lock:function(){return u=t,
r||p.disable(),this},locked:function(){return!u},fireWith:function(e,t){return!l||i&&!u||(t=t||[],t=[e,t.slice?t.slice():t],n?u.push(t):c(t)),this},fire:function(){return p.fireWith(this,arguments),this},fired:function(){return!!i}};return p},x.extend({Deferred:function(e){var t=[["resolve","done",x.Callbacks("once memory"),"resolved"],["reject","fail",x.Callbacks("once memory"),"rejected"],["notify","progress",x.Callbacks("memory")]],n="pending",r={state:function(){return n},always:function(){return i.done(arguments).fail(arguments),this},then:function(){var e=arguments;return x.Deferred(function(n){x.each(t,function(t,o){var a=o[0],s=x.isFunction(e[t])&&e[t];i[o[1]](function(){var e=s&&s.apply(this,arguments);e&&x.isFunction(e.promise)?e.promise().done(n.resolve).fail(n.reject).progress(n.notify):n[a+"With"](this===r?n.promise():this,s?[e]:arguments)})}),e=null}).promise()},promise:function(e){return null!=e?x.extend(e,r):r}},i={};return r.pipe=r.then,x.each(t,function(e,o
){var a=o[2],s=o[3];r[o[1]]=a.add,s&&a.add(function(){n=s},t[1^e][2].disable,t[2][2].lock),i[o[0]]=function(){return i[o[0]+"With"](this===i?r:this,arguments),this},i[o[0]+"With"]=a.fireWith}),r.promise(i),e&&e.call(i,i),i},when:function(e){var t=0,n=g.call(arguments),r=n.length,i=1!==r||e&&x.isFunction(e.promise)?r:0,o=1===i?e:x.Deferred(),a=function(e,t,n){return function(r){t[e]=this,n[e]=arguments.length>1?g.call(arguments):r,n===s?o.notifyWith(t,n):--i||o.resolveWith(t,n)}},s,l,u;if(r>1)for(s=Array(r),l=Array(r),u=Array(r);r>t;t++)n[t]&&x.isFunction(n[t].promise)?n[t].promise().done(a(t,u,n)).fail(o.reject).progress(a(t,l,s)):--i;return i||o.resolveWith(u,n),o.promise()}}),x.support=function(t){var n,r,o,s,l,u,c,p,f,d=a.createElement("div");if(d.setAttribute("className","t"),d.innerHTML=" <link/><table></table><a href='/a'>a</a><input type='checkbox'/>",n=d.getElementsByTagName("*")||[],r=d.getElementsByTagName("a")[0],!r||!r.style||!n.length)return t;s=a.createElement
("select"),u=s.appendChild(a.createElement("option")),o=d.getElementsByTagName("input")[0],r.style.cssText="top:1px;float:left;opacity:.5",t.getSetAttribute="t"!==d.className,t.leadingWhitespace=3===d.firstChild.nodeType,t.tbody=!d.getElementsByTagName("tbody").length,t.htmlSerialize=!!d.getElementsByTagName("link").length,t.style=/top/.test(r.getAttribute("style")),t.hrefNormalized="/a"===r.getAttribute("href"),t.opacity=/^0.5/.test(r.style.opacity),t.cssFloat=!!r.style.cssFloat,t.checkOn=!!o.value,t.optSelected=u.selected,t.enctype=!!a.createElement("form").enctype,t.html5Clone="<:nav></:nav>"!==a.createElement("nav").cloneNode(!0).outerHTML,t.inlineBlockNeedsLayout=!1,t.shrinkWrapBlocks=!1,t.pixelPosition=!1,t.deleteExpando=!0,t.noCloneEvent=!0,t.reliableMarginRight=!0,t.boxSizingReliable=!0,o.checked=!0,t.noCloneChecked=o.cloneNode(!0).checked,s.disabled=!0,t.optDisabled=!u.disabled;try{delete d.test}catch(h){t.deleteExpando=!1}o=a.createElement("input"),o.setAttribute("
value",""),t.input=""===o.getAttribute("value"),o.value="t",o.setAttribute("type","radio"),t.radioValue="t"===o.value,o.setAttribute("checked","t"),o.setAttribute("name","t"),l=a.createDocumentFragment(),l.appendChild(o),t.appendChecked=o.checked,t.checkClone=l.cloneNode(!0).cloneNode(!0).lastChild.checked,d.attachEvent&&(d.attachEvent("onclick",function(){t.noCloneEvent=!1}),d.cloneNode(!0).click());for(f in{submit:!0,change:!0,focusin:!0})d.setAttribute(c="on"+f,"t"),t[f+"Bubbles"]=c in e||d.attributes[c].expando===!1;d.style.backgroundClip="content-box",d.cloneNode(!0).style.backgroundClip="",t.clearCloneStyle="content-box"===d.style.backgroundClip;for(f in x(t))break;return t.ownLast="0"!==f,x(function(){var n,r,o,s="padding:0;margin:0;border:0;display:block;box-sizing:content-box;-moz-box-sizing:content-box;-webkit-box-sizing:content-box;",l=a.getElementsByTagName("body")[0];l&&(n=a.createElement("div"),n.style.cssText="border:0;width:0;height:0;position:absolute;top:0;
left:-9999px;margin-top:1px",l.appendChild(n).appendChild(d),d.innerHTML="<table><tr><td></td><td>t</td></tr></table>",o=d.getElementsByTagName("td"),o[0].style.cssText="padding:0;margin:0;border:0;display:none",p=0===o[0].offsetHeight,o[0].style.display="",o[1].style.display="none",t.reliableHiddenOffsets=p&&0===o[0].offsetHeight,d.innerHTML="",d.style.cssText="box-sizing:border-box;-moz-box-sizing:border-box;-webkit-box-sizing:border-box;padding:1px;border:1px;display:block;width:4px;margin-top:1%;position:absolute;top:1%;",x.swap(l,null!=l.style.zoom?{zoom:1}:{},function(){t.boxSizing=4===d.offsetWidth}),e.getComputedStyle&&(t.pixelPosition="1%"!==(e.getComputedStyle(d,null)||{}).top,t.boxSizingReliable="4px"===(e.getComputedStyle(d,null)||{width:"4px"}).width,r=d.appendChild(a.createElement("div")),r.style.cssText=d.style.cssText=s,r.style.marginRight=r.style.width="0",d.style.width="1px",t.reliableMarginRight=!parseFloat((e.getComputedStyle(r,null)||{}).marginRight)),ty
peof d.style.zoom!==i&&(d.innerHTML="",d.style.cssText=s+"width:1px;padding:1px;display:inline;zoom:1",t.inlineBlockNeedsLayout=3===d.offsetWidth,d.style.display="block",d.innerHTML="<div></div>",d.firstChild.style.width="5px",t.shrinkWrapBlocks=3!==d.offsetWidth,t.inlineBlockNeedsLayout&&(l.style.zoom=1)),l.removeChild(n),n=d=o=r=null)}),n=s=l=u=r=o=null,t
+}({});var B=/(?:\{[\s\S]*\}|\[[\s\S]*\])$/,P=/([A-Z])/g;function R(e,n,r,i){if(x.acceptData(e)){var o,a,s=x.expando,l=e.nodeType,u=l?x.cache:e,c=l?e[s]:e[s]&&s;if(c&&u[c]&&(i||u[c].data)||r!==t||"string"!=typeof n)return c||(c=l?e[s]=p.pop()||x.guid++:s),u[c]||(u[c]=l?{}:{toJSON:x.noop}),("object"==typeof n||"function"==typeof n)&&(i?u[c]=x.extend(u[c],n):u[c].data=x.extend(u[c].data,n)),a=u[c],i||(a.data||(a.data={}),a=a.data),r!==t&&(a[x.camelCase(n)]=r),"string"==typeof n?(o=a[n],null==o&&(o=a[x.camelCase(n)])):o=a,o}}function W(e,t,n){if(x.acceptData(e)){var r,i,o=e.nodeType,a=o?x.cache:e,s=o?e[x.expando]:x.expando;if(a[s]){if(t&&(r=n?a[s]:a[s].data)){x.isArray(t)?t=t.concat(x.map(t,x.camelCase)):t in r?t=[t]:(t=x.camelCase(t),t=t in r?[t]:t.split(" ")),i=t.length;while(i--)delete r[t[i]];if(n?!I(r):!x.isEmptyObject(r))return}(n||(delete a[s].data,I(a[s])))&&(o?x.cleanData([e],!0):x.support.deleteExpando||a!=a.window?delete a[s]:a[s]=null)}}}x.extend({cache:{},noData:{ap
plet:!0,embed:!0,object:"clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"},hasData:function(e){return e=e.nodeType?x.cache[e[x.expando]]:e[x.expando],!!e&&!I(e)},data:function(e,t,n){return R(e,t,n)},removeData:function(e,t){return W(e,t)},_data:function(e,t,n){return R(e,t,n,!0)},_removeData:function(e,t){return W(e,t,!0)},acceptData:function(e){if(e.nodeType&&1!==e.nodeType&&9!==e.nodeType)return!1;var t=e.nodeName&&x.noData[e.nodeName.toLowerCase()];return!t||t!==!0&&e.getAttribute("classid")===t}}),x.fn.extend({data:function(e,n){var r,i,o=null,a=0,s=this[0];if(e===t){if(this.length&&(o=x.data(s),1===s.nodeType&&!x._data(s,"parsedAttrs"))){for(r=s.attributes;r.length>a;a++)i=r[a].name,0===i.indexOf("data-")&&(i=x.camelCase(i.slice(5)),$(s,i,o[i]));x._data(s,"parsedAttrs",!0)}return o}return"object"==typeof e?this.each(function(){x.data(this,e)}):arguments.length>1?this.each(function(){x.data(this,e,n)}):s?$(s,e,x.data(s,e)):null},removeData:function(e){return this.each(functi
on(){x.removeData(this,e)})}});function $(e,n,r){if(r===t&&1===e.nodeType){var i="data-"+n.replace(P,"-$1").toLowerCase();if(r=e.getAttribute(i),"string"==typeof r){try{r="true"===r?!0:"false"===r?!1:"null"===r?null:+r+""===r?+r:B.test(r)?x.parseJSON(r):r}catch(o){}x.data(e,n,r)}else r=t}return r}function I(e){var t;for(t in e)if(("data"!==t||!x.isEmptyObject(e[t]))&&"toJSON"!==t)return!1;return!0}x.extend({queue:function(e,n,r){var i;return e?(n=(n||"fx")+"queue",i=x._data(e,n),r&&(!i||x.isArray(r)?i=x._data(e,n,x.makeArray(r)):i.push(r)),i||[]):t},dequeue:function(e,t){t=t||"fx";var n=x.queue(e,t),r=n.length,i=n.shift(),o=x._queueHooks(e,t),a=function(){x.dequeue(e,t)};"inprogress"===i&&(i=n.shift(),r--),i&&("fx"===t&&n.unshift("inprogress"),delete o.stop,i.call(e,a,o)),!r&&o&&o.empty.fire()},_queueHooks:function(e,t){var n=t+"queueHooks";return x._data(e,n)||x._data(e,n,{empty:x.Callbacks("once memory").add(function(){x._removeData(e,t+"queue"),x._removeData(e,n)})})}}),x
.fn.extend({queue:function(e,n){var r=2;return"string"!=typeof e&&(n=e,e="fx",r--),r>arguments.length?x.queue(this[0],e):n===t?this:this.each(function(){var t=x.queue(this,e,n);x._queueHooks(this,e),"fx"===e&&"inprogress"!==t[0]&&x.dequeue(this,e)})},dequeue:function(e){return this.each(function(){x.dequeue(this,e)})},delay:function(e,t){return e=x.fx?x.fx.speeds[e]||e:e,t=t||"fx",this.queue(t,function(t,n){var r=setTimeout(t,e);n.stop=function(){clearTimeout(r)}})},clearQueue:function(e){return this.queue(e||"fx",[])},promise:function(e,n){var r,i=1,o=x.Deferred(),a=this,s=this.length,l=function(){--i||o.resolveWith(a,[a])};"string"!=typeof e&&(n=e,e=t),e=e||"fx";while(s--)r=x._data(a[s],e+"queueHooks"),r&&r.empty&&(i++,r.empty.add(l));return l(),o.promise(n)}});var z,X,U=/[\t\r\n\f]/g,V=/\r/g,Y=/^(?:input|select|textarea|button|object)$/i,J=/^(?:a|area)$/i,G=/^(?:checked|selected)$/i,Q=x.support.getSetAttribute,K=x.support.input;x.fn.extend({attr:function(e,t){return x.acc
ess(this,x.attr,e,t,arguments.length>1)},removeAttr:function(e){return this.each(function(){x.removeAttr(this,e)})},prop:function(e,t){return x.access(this,x.prop,e,t,arguments.length>1)},removeProp:function(e){return e=x.propFix[e]||e,this.each(function(){try{this[e]=t,delete this[e]}catch(n){}})},addClass:function(e){var t,n,r,i,o,a=0,s=this.length,l="string"==typeof e&&e;if(x.isFunction(e))return this.each(function(t){x(this).addClass(e.call(this,t,this.className))});if(l)for(t=(e||"").match(T)||[];s>a;a++)if(n=this[a],r=1===n.nodeType&&(n.className?(" "+n.className+" ").replace(U," "):" ")){o=0;while(i=t[o++])0>r.indexOf(" "+i+" ")&&(r+=i+" ");n.className=x.trim(r)}return this},removeClass:function(e){var t,n,r,i,o,a=0,s=this.length,l=0===arguments.length||"string"==typeof e&&e;if(x.isFunction(e))return this.each(function(t){x(this).removeClass(e.call(this,t,this.className))});if(l)for(t=(e||"").match(T)||[];s>a;a++)if(n=this[a],r=1===n.nodeType&&(n.className?(" "+n.clas
sName+" ").replace(U," "):"")){o=0;while(i=t[o++])while(r.indexOf(" "+i+" ")>=0)r=r.replace(" "+i+" "," ");n.className=e?x.trim(r):""}return this},toggleClass:function(e,t){var n=typeof e;return"boolean"==typeof t&&"string"===n?t?this.addClass(e):this.removeClass(e):x.isFunction(e)?this.each(function(n){x(this).toggleClass(e.call(this,n,this.className,t),t)}):this.each(function(){if("string"===n){var t,r=0,o=x(this),a=e.match(T)||[];while(t=a[r++])o.hasClass(t)?o.removeClass(t):o.addClass(t)}else(n===i||"boolean"===n)&&(this.className&&x._data(this,"__className__",this.className),this.className=this.className||e===!1?"":x._data(this,"__className__")||"")})},hasClass:function(e){var t=" "+e+" ",n=0,r=this.length;for(;r>n;n++)if(1===this[n].nodeType&&(" "+this[n].className+" ").replace(U," ").indexOf(t)>=0)return!0;return!1},val:function(e){var n,r,i,o=this[0];{if(arguments.length)return i=x.isFunction(e),this.each(function(n){var o;1===this.nodeType&&(o=i?e.call(this,n,x(this
).val()):e,null==o?o="":"number"==typeof o?o+="":x.isArray(o)&&(o=x.map(o,function(e){return null==e?"":e+""})),r=x.valHooks[this.type]||x.valHooks[this.nodeName.toLowerCase()],r&&"set"in r&&r.set(this,o,"value")!==t||(this.value=o))});if(o)return r=x.valHooks[o.type]||x.valHooks[o.nodeName.toLowerCase()],r&&"get"in r&&(n=r.get(o,"value"))!==t?n:(n=o.value,"string"==typeof n?n.replace(V,""):null==n?"":n)}}}),x.extend({valHooks:{option:{get:function(e){var t=x.find.attr(e,"value");return null!=t?t:e.text}},select:{get:function(e){var t,n,r=e.options,i=e.selectedIndex,o="select-one"===e.type||0>i,a=o?null:[],s=o?i+1:r.length,l=0>i?s:o?i:0;for(;s>l;l++)if(n=r[l],!(!n.selected&&l!==i||(x.support.optDisabled?n.disabled:null!==n.getAttribute("disabled"))||n.parentNode.disabled&&x.nodeName(n.parentNode,"optgroup"))){if(t=x(n).val(),o)return t;a.push(t)}return a},set:function(e,t){var n,r,i=e.options,o=x.makeArray(t),a=i.length;while(a--)r=i[a],(r.selected=x.inArray(x(r).val(),o)>=0
)&&(n=!0);return n||(e.selectedIndex=-1),o}}},attr:function(e,n,r){var o,a,s=e.nodeType;if(e&&3!==s&&8!==s&&2!==s)return typeof e.getAttribute===i?x.prop(e,n,r):(1===s&&x.isXMLDoc(e)||(n=n.toLowerCase(),o=x.attrHooks[n]||(x.expr.match.bool.test(n)?X:z)),r===t?o&&"get"in o&&null!==(a=o.get(e,n))?a:(a=x.find.attr(e,n),null==a?t:a):null!==r?o&&"set"in o&&(a=o.set(e,r,n))!==t?a:(e.setAttribute(n,r+""),r):(x.removeAttr(e,n),t))},removeAttr:function(e,t){var n,r,i=0,o=t&&t.match(T);if(o&&1===e.nodeType)while(n=o[i++])r=x.propFix[n]||n,x.expr.match.bool.test(n)?K&&Q||!G.test(n)?e[r]=!1:e[x.camelCase("default-"+n)]=e[r]=!1:x.attr(e,n,""),e.removeAttribute(Q?n:r)},attrHooks:{type:{set:function(e,t){if(!x.support.radioValue&&"radio"===t&&x.nodeName(e,"input")){var n=e.value;return e.setAttribute("type",t),n&&(e.value=n),t}}}},propFix:{"for":"htmlFor","class":"className"},prop:function(e,n,r){var i,o,a,s=e.nodeType;if(e&&3!==s&&8!==s&&2!==s)return a=1!==s||!x.isXMLDoc(e),a&&(n=x.propFi
x[n]||n,o=x.propHooks[n]),r!==t?o&&"set"in o&&(i=o.set(e,r,n))!==t?i:e[n]=r:o&&"get"in o&&null!==(i=o.get(e,n))?i:e[n]},propHooks:{tabIndex:{get:function(e){var t=x.find.attr(e,"tabindex");return t?parseInt(t,10):Y.test(e.nodeName)||J.test(e.nodeName)&&e.href?0:-1}}}}),X={set:function(e,t,n){return t===!1?x.removeAttr(e,n):K&&Q||!G.test(n)?e.setAttribute(!Q&&x.propFix[n]||n,n):e[x.camelCase("default-"+n)]=e[n]=!0,n}},x.each(x.expr.match.bool.source.match(/\w+/g),function(e,n){var r=x.expr.attrHandle[n]||x.find.attr;x.expr.attrHandle[n]=K&&Q||!G.test(n)?function(e,n,i){var o=x.expr.attrHandle[n],a=i?t:(x.expr.attrHandle[n]=t)!=r(e,n,i)?n.toLowerCase():null;return x.expr.attrHandle[n]=o,a}:function(e,n,r){return r?t:e[x.camelCase("default-"+n)]?n.toLowerCase():null}}),K&&Q||(x.attrHooks.value={set:function(e,n,r){return x.nodeName(e,"input")?(e.defaultValue=n,t):z&&z.set(e,n,r)}}),Q||(z={set:function(e,n,r){var i=e.getAttributeNode(r);return i||e.setAttributeNode(i=e.ownerDocu
ment.createAttribute(r)),i.value=n+="","value"===r||n===e.getAttribute(r)?n:t}},x.expr.attrHandle.id=x.expr.attrHandle.name=x.expr.attrHandle.coords=function(e,n,r){var i;return r?t:(i=e.getAttributeNode(n))&&""!==i.value?i.value:null},x.valHooks.button={get:function(e,n){var r=e.getAttributeNode(n);return r&&r.specified?r.value:t},set:z.set},x.attrHooks.contenteditable={set:function(e,t,n){z.set(e,""===t?!1:t,n)}},x.each(["width","height"],function(e,n){x.attrHooks[n]={set:function(e,r){return""===r?(e.setAttribute(n,"auto"),r):t}}})),x.support.hrefNormalized||x.each(["href","src"],function(e,t){x.propHooks[t]={get:function(e){return e.getAttribute(t,4)}}}),x.support.style||(x.attrHooks.style={get:function(e){return e.style.cssText||t},set:function(e,t){return e.style.cssText=t+""}}),x.support.optSelected||(x.propHooks.selected={get:function(e){var t=e.parentNode;return t&&(t.selectedIndex,t.parentNode&&t.parentNode.selectedIndex),null}}),x.each(["tabIndex","readOnly","maxL
ength","cellSpacing","cellPadding","rowSpan","colSpan","useMap","frameBorder","contentEditable"],function(){x.propFix[this.toLowerCase()]=this}),x.support.enctype||(x.propFix.enctype="encoding"),x.each(["radio","checkbox"],function(){x.valHooks[this]={set:function(e,n){return x.isArray(n)?e.checked=x.inArray(x(e).val(),n)>=0:t}},x.support.checkOn||(x.valHooks[this].get=function(e){return null===e.getAttribute("value")?"on":e.value})});var Z=/^(?:input|select|textarea)$/i,et=/^key/,tt=/^(?:mouse|contextmenu)|click/,nt=/^(?:focusinfocus|focusoutblur)$/,rt=/^([^.]*)(?:\.(.+)|)$/;function it(){return!0}function ot(){return!1}function at(){try{return a.activeElement}catch(e){}}x.event={global:{},add:function(e,n,r,o,a){var s,l,u,c,p,f,d,h,g,m,y,v=x._data(e);if(v){r.handler&&(c=r,r=c.handler,a=c.selector),r.guid||(r.guid=x.guid++),(l=v.events)||(l=v.events={}),(f=v.handle)||(f=v.handle=function(e){return typeof x===i||e&&x.event.triggered===e.type?t:x.event.dispatch.apply(f.elem,a
rguments)},f.elem=e),n=(n||"").match(T)||[""],u=n.length;while(u--)s=rt.exec(n[u])||[],g=y=s[1],m=(s[2]||"").split(".").sort(),g&&(p=x.event.special[g]||{},g=(a?p.delegateType:p.bindType)||g,p=x.event.special[g]||{},d=x.extend({type:g,origType:y,data:o,handler:r,guid:r.guid,selector:a,needsContext:a&&x.expr.match.needsContext.test(a),namespace:m.join(".")},c),(h=l[g])||(h=l[g]=[],h.delegateCount=0,p.setup&&p.setup.call(e,o,m,f)!==!1||(e.addEventListener?e.addEventListener(g,f,!1):e.attachEvent&&e.attachEvent("on"+g,f))),p.add&&(p.add.call(e,d),d.handler.guid||(d.handler.guid=r.guid)),a?h.splice(h.delegateCount++,0,d):h.push(d),x.event.global[g]=!0);e=null}},remove:function(e,t,n,r,i){var o,a,s,l,u,c,p,f,d,h,g,m=x.hasData(e)&&x._data(e);if(m&&(c=m.events)){t=(t||"").match(T)||[""],u=t.length;while(u--)if(s=rt.exec(t[u])||[],d=g=s[1],h=(s[2]||"").split(".").sort(),d){p=x.event.special[d]||{},d=(r?p.delegateType:p.bindType)||d,f=c[d]||[],s=s[2]&&RegExp("(^|\\.)"+h.join("\\.(?:.
*\\.|)")+"(\\.|$)"),l=o=f.length;while(o--)a=f[o],!i&&g!==a.origType||n&&n.guid!==a.guid||s&&!s.test(a.namespace)||r&&r!==a.selector&&("**"!==r||!a.selector)||(f.splice(o,1),a.selector&&f.delegateCount--,p.remove&&p.remove.call(e,a));l&&!f.length&&(p.teardown&&p.teardown.call(e,h,m.handle)!==!1||x.removeEvent(e,d,m.handle),delete c[d])}else for(d in c)x.event.remove(e,d+t[u],n,r,!0);x.isEmptyObject(c)&&(delete m.handle,x._removeData(e,"events"))}},trigger:function(n,r,i,o){var s,l,u,c,p,f,d,h=[i||a],g=v.call(n,"type")?n.type:n,m=v.call(n,"namespace")?n.namespace.split("."):[];if(u=f=i=i||a,3!==i.nodeType&&8!==i.nodeType&&!nt.test(g+x.event.triggered)&&(g.indexOf(".")>=0&&(m=g.split("."),g=m.shift(),m.sort()),l=0>g.indexOf(":")&&"on"+g,n=n[x.expando]?n:new x.Event(g,"object"==typeof n&&n),n.isTrigger=o?2:3,n.namespace=m.join("."),n.namespace_re=n.namespace?RegExp("(^|\\.)"+m.join("\\.(?:.*\\.|)")+"(\\.|$)"):null,n.result=t,n.target||(n.target=i),r=null==r?[n]:x.makeArray(r,[n
]),p=x.event.special[g]||{},o||!p.trigger||p.trigger.apply(i,r)!==!1)){if(!o&&!p.noBubble&&!x.isWindow(i)){for(c=p.delegateType||g,nt.test(c+g)||(u=u.parentNode);u;u=u.parentNode)h.push(u),f=u;f===(i.ownerDocument||a)&&h.push(f.defaultView||f.parentWindow||e)}d=0;while((u=h[d++])&&!n.isPropagationStopped())n.type=d>1?c:p.bindType||g,s=(x._data(u,"events")||{})[n.type]&&x._data(u,"handle"),s&&s.apply(u,r),s=l&&u[l],s&&x.acceptData(u)&&s.apply&&s.apply(u,r)===!1&&n.preventDefault();if(n.type=g,!o&&!n.isDefaultPrevented()&&(!p._default||p._default.apply(h.pop(),r)===!1)&&x.acceptData(i)&&l&&i[g]&&!x.isWindow(i)){f=i[l],f&&(i[l]=null),x.event.triggered=g;try{i[g]()}catch(y){}x.event.triggered=t,f&&(i[l]=f)}return n.result}},dispatch:function(e){e=x.event.fix(e);var n,r,i,o,a,s=[],l=g.call(arguments),u=(x._data(this,"events")||{})[e.type]||[],c=x.event.special[e.type]||{};if(l[0]=e,e.delegateTarget=this,!c.preDispatch||c.preDispatch.call(this,e)!==!1){s=x.event.handlers.call(this
,e,u),n=0;while((o=s[n++])&&!e.isPropagationStopped()){e.currentTarget=o.elem,a=0;while((i=o.handlers[a++])&&!e.isImmediatePropagationStopped())(!e.namespace_re||e.namespace_re.test(i.namespace))&&(e.handleObj=i,e.data=i.data,r=((x.event.special[i.origType]||{}).handle||i.handler).apply(o.elem,l),r!==t&&(e.result=r)===!1&&(e.preventDefault(),e.stopPropagation()))}return c.postDispatch&&c.postDispatch.call(this,e),e.result}},handlers:function(e,n){var r,i,o,a,s=[],l=n.delegateCount,u=e.target;if(l&&u.nodeType&&(!e.button||"click"!==e.type))for(;u!=this;u=u.parentNode||this)if(1===u.nodeType&&(u.disabled!==!0||"click"!==e.type)){for(o=[],a=0;l>a;a++)i=n[a],r=i.selector+" ",o[r]===t&&(o[r]=i.needsContext?x(r,this).index(u)>=0:x.find(r,this,null,[u]).length),o[r]&&o.push(i);o.length&&s.push({elem:u,handlers:o})}return n.length>l&&s.push({elem:this,handlers:n.slice(l)}),s},fix:function(e){if(e[x.expando])return e;var t,n,r,i=e.type,o=e,s=this.fixHooks[i];s||(this.fixHooks[i]=s=tt
.test(i)?this.mouseHooks:et.test(i)?this.keyHooks:{}),r=s.props?this.props.concat(s.props):this.props,e=new x.Event(o),t=r.length;while(t--)n=r[t],e[n]=o[n];return e.target||(e.target=o.srcElement||a),3===e.target.nodeType&&(e.target=e.target.parentNode),e.metaKey=!!e.metaKey,s.filter?s.filter(e,o):e},props:"altKey bubbles cancelable ctrlKey currentTarget eventPhase metaKey relatedTarget shiftKey target timeStamp view which".split(" "),fixHooks:{},keyHooks:{props:"char charCode key keyCode".split(" "),filter:function(e,t){return null==e.which&&(e.which=null!=t.charCode?t.charCode:t.keyCode),e}},mouseHooks:{props:"button buttons clientX clientY fromElement offsetX offsetY pageX pageY screenX screenY toElement".split(" "),filter:function(e,n){var r,i,o,s=n.button,l=n.fromElement;return null==e.pageX&&null!=n.clientX&&(i=e.target.ownerDocument||a,o=i.documentElement,r=i.body,e.pageX=n.clientX+(o&&o.scrollLeft||r&&r.scrollLeft||0)-(o&&o.clientLeft||r&&r.clientLeft||0),e.pageY=n.
clientY+(o&&o.scrollTop||r&&r.scrollTop||0)-(o&&o.clientTop||r&&r.clientTop||0)),!e.relatedTarget&&l&&(e.relatedTarget=l===e.target?n.toElement:l),e.which||s===t||(e.which=1&s?1:2&s?3:4&s?2:0),e}},special:{load:{noBubble:!0},focus:{trigger:function(){if(this!==at()&&this.focus)try{return this.focus(),!1}catch(e){}},delegateType:"focusin"},blur:{trigger:function(){return this===at()&&this.blur?(this.blur(),!1):t},delegateType:"focusout"},click:{trigger:function(){return x.nodeName(this,"input")&&"checkbox"===this.type&&this.click?(this.click(),!1):t},_default:function(e){return x.nodeName(e.target,"a")}},beforeunload:{postDispatch:function(e){e.result!==t&&(e.originalEvent.returnValue=e.result)}}},simulate:function(e,t,n,r){var i=x.extend(new x.Event,n,{type:e,isSimulated:!0,originalEvent:{}});r?x.event.trigger(i,null,t):x.event.dispatch.call(t,i),i.isDefaultPrevented()&&n.preventDefault()}},x.removeEvent=a.removeEventListener?function(e,t,n){e.removeEventListener&&e.removeEv
entListener(t,n,!1)}:function(e,t,n){var r="on"+t;e.detachEvent&&(typeof e[r]===i&&(e[r]=null),e.detachEvent(r,n))},x.Event=function(e,n){return this instanceof x.Event?(e&&e.type?(this.originalEvent=e,this.type=e.type,this.isDefaultPrevented=e.defaultPrevented||e.returnValue===!1||e.getPreventDefault&&e.getPreventDefault()?it:ot):this.type=e,n&&x.extend(this,n),this.timeStamp=e&&e.timeStamp||x.now(),this[x.expando]=!0,t):new x.Event(e,n)},x.Event.prototype={isDefaultPrevented:ot,isPropagationStopped:ot,isImmediatePropagationStopped:ot,preventDefault:function(){var e=this.originalEvent;this.isDefaultPrevented=it,e&&(e.preventDefault?e.preventDefault():e.returnValue=!1)},stopPropagation:function(){var e=this.originalEvent;this.isPropagationStopped=it,e&&(e.stopPropagation&&e.stopPropagation(),e.cancelBubble=!0)},stopImmediatePropagation:function(){this.isImmediatePropagationStopped=it,this.stopPropagation()}},x.each({mouseenter:"mouseover",mouseleave:"mouseout"},function(e,t)
{x.event.special[e]={delegateType:t,bindType:t,handle:function(e){var n,r=this,i=e.relatedTarget,o=e.handleObj;return(!i||i!==r&&!x.contains(r,i))&&(e.type=o.origType,n=o.handler.apply(this,arguments),e.type=t),n}}}),x.support.submitBubbles||(x.event.special.submit={setup:function(){return x.nodeName(this,"form")?!1:(x.event.add(this,"click._submit keypress._submit",function(e){var n=e.target,r=x.nodeName(n,"input")||x.nodeName(n,"button")?n.form:t;r&&!x._data(r,"submitBubbles")&&(x.event.add(r,"submit._submit",function(e){e._submit_bubble=!0}),x._data(r,"submitBubbles",!0))}),t)},postDispatch:function(e){e._submit_bubble&&(delete e._submit_bubble,this.parentNode&&!e.isTrigger&&x.event.simulate("submit",this.parentNode,e,!0))},teardown:function(){return x.nodeName(this,"form")?!1:(x.event.remove(this,"._submit"),t)}}),x.support.changeBubbles||(x.event.special.change={setup:function(){return Z.test(this.nodeName)?(("checkbox"===this.type||"radio"===this.type)&&(x.event.add(th
is,"propertychange._change",function(e){"checked"===e.originalEvent.propertyName&&(this._just_changed=!0)}),x.event.add(this,"click._change",function(e){this._just_changed&&!e.isTrigger&&(this._just_changed=!1),x.event.simulate("change",this,e,!0)})),!1):(x.event.add(this,"beforeactivate._change",function(e){var t=e.target;Z.test(t.nodeName)&&!x._data(t,"changeBubbles")&&(x.event.add(t,"change._change",function(e){!this.parentNode||e.isSimulated||e.isTrigger||x.event.simulate("change",this.parentNode,e,!0)}),x._data(t,"changeBubbles",!0))}),t)},handle:function(e){var n=e.target;return this!==n||e.isSimulated||e.isTrigger||"radio"!==n.type&&"checkbox"!==n.type?e.handleObj.handler.apply(this,arguments):t},teardown:function(){return x.event.remove(this,"._change"),!Z.test(this.nodeName)}}),x.support.focusinBubbles||x.each({focus:"focusin",blur:"focusout"},function(e,t){var n=0,r=function(e){x.event.simulate(t,e.target,x.event.fix(e),!0)};x.event.special[t]={setup:function(){0==
=n++&&a.addEventListener(e,r,!0)},teardown:function(){0===--n&&a.removeEventListener(e,r,!0)}}}),x.fn.extend({on:function(e,n,r,i,o){var a,s;if("object"==typeof e){"string"!=typeof n&&(r=r||n,n=t);for(a in e)this.on(a,n,r,e[a],o);return this}if(null==r&&null==i?(i=n,r=n=t):null==i&&("string"==typeof n?(i=r,r=t):(i=r,r=n,n=t)),i===!1)i=ot;else if(!i)return this;return 1===o&&(s=i,i=function(e){return x().off(e),s.apply(this,arguments)},i.guid=s.guid||(s.guid=x.guid++)),this.each(function(){x.event.add(this,e,i,r,n)})},one:function(e,t,n,r){return this.on(e,t,n,r,1)},off:function(e,n,r){var i,o;if(e&&e.preventDefault&&e.handleObj)return i=e.handleObj,x(e.delegateTarget).off(i.namespace?i.origType+"."+i.namespace:i.origType,i.selector,i.handler),this;if("object"==typeof e){for(o in e)this.off(o,n,e[o]);return this}return(n===!1||"function"==typeof n)&&(r=n,n=t),r===!1&&(r=ot),this.each(function(){x.event.remove(this,e,r,n)})},trigger:function(e,t){return this.each(function(){x.
event.trigger(e,t,this)})},triggerHandler:function(e,n){var r=this[0];return r?x.event.trigger(e,n,r,!0):t}});var st=/^.[^:#\[\.,]*$/,lt=/^(?:parents|prev(?:Until|All))/,ut=x.expr.match.needsContext,ct={children:!0,contents:!0,next:!0,prev:!0};x.fn.extend({find:function(e){var t,n=[],r=this,i=r.length;if("string"!=typeof e)return this.pushStack(x(e).filter(function(){for(t=0;i>t;t++)if(x.contains(r[t],this))return!0}));for(t=0;i>t;t++)x.find(e,r[t],n);return n=this.pushStack(i>1?x.unique(n):n),n.selector=this.selector?this.selector+" "+e:e,n},has:function(e){var t,n=x(e,this),r=n.length;return this.filter(function(){for(t=0;r>t;t++)if(x.contains(this,n[t]))return!0})},not:function(e){return this.pushStack(ft(this,e||[],!0))},filter:function(e){return this.pushStack(ft(this,e||[],!1))},is:function(e){return!!ft(this,"string"==typeof e&&ut.test(e)?x(e):e||[],!1).length},closest:function(e,t){var n,r=0,i=this.length,o=[],a=ut.test(e)||"string"!=typeof e?x(e,t||this.context):0;f
or(;i>r;r++)for(n=this[r];n&&n!==t;n=n.parentNode)if(11>n.nodeType&&(a?a.index(n)>-1:1===n.nodeType&&x.find.matchesSelector(n,e))){n=o.push(n);break}return this.pushStack(o.length>1?x.unique(o):o)},index:function(e){return e?"string"==typeof e?x.inArray(this[0],x(e)):x.inArray(e.jquery?e[0]:e,this):this[0]&&this[0].parentNode?this.first().prevAll().length:-1},add:function(e,t){var n="string"==typeof e?x(e,t):x.makeArray(e&&e.nodeType?[e]:e),r=x.merge(this.get(),n);return this.pushStack(x.unique(r))},addBack:function(e){return this.add(null==e?this.prevObject:this.prevObject.filter(e))}});function pt(e,t){do e=e[t];while(e&&1!==e.nodeType);return e}x.each({parent:function(e){var t=e.parentNode;return t&&11!==t.nodeType?t:null},parents:function(e){return x.dir(e,"parentNode")},parentsUntil:function(e,t,n){return x.dir(e,"parentNode",n)},next:function(e){return pt(e,"nextSibling")},prev:function(e){return pt(e,"previousSibling")},nextAll:function(e){return x.dir(e,"nextSibling"
)},prevAll:function(e){return x.dir(e,"previousSibling")},nextUntil:function(e,t,n){return x.dir(e,"nextSibling",n)},prevUntil:function(e,t,n){return x.dir(e,"previousSibling",n)},siblings:function(e){return x.sibling((e.parentNode||{}).firstChild,e)},children:function(e){return x.sibling(e.firstChild)},contents:function(e){return x.nodeName(e,"iframe")?e.contentDocument||e.contentWindow.document:x.merge([],e.childNodes)}},function(e,t){x.fn[e]=function(n,r){var i=x.map(this,t,n);return"Until"!==e.slice(-5)&&(r=n),r&&"string"==typeof r&&(i=x.filter(r,i)),this.length>1&&(ct[e]||(i=x.unique(i)),lt.test(e)&&(i=i.reverse())),this.pushStack(i)}}),x.extend({filter:function(e,t,n){var r=t[0];return n&&(e=":not("+e+")"),1===t.length&&1===r.nodeType?x.find.matchesSelector(r,e)?[r]:[]:x.find.matches(e,x.grep(t,function(e){return 1===e.nodeType}))},dir:function(e,n,r){var i=[],o=e[n];while(o&&9!==o.nodeType&&(r===t||1!==o.nodeType||!x(o).is(r)))1===o.nodeType&&i.push(o),o=o[n];return i
},sibling:function(e,t){var n=[];for(;e;e=e.nextSibling)1===e.nodeType&&e!==t&&n.push(e);return n}});function ft(e,t,n){if(x.isFunction(t))return x.grep(e,function(e,r){return!!t.call(e,r,e)!==n});if(t.nodeType)return x.grep(e,function(e){return e===t!==n});if("string"==typeof t){if(st.test(t))return x.filter(t,e,n);t=x.filter(t,e)}return x.grep(e,function(e){return x.inArray(e,t)>=0!==n})}function dt(e){var t=ht.split("|"),n=e.createDocumentFragment();if(n.createElement)while(t.length)n.createElement(t.pop());return n}var ht="abbr|article|aside|audio|bdi|canvas|data|datalist|details|figcaption|figure|footer|header|hgroup|mark|meter|nav|output|progress|section|summary|time|video",gt=/ jQuery\d+="(?:null|\d+)"/g,mt=RegExp("<(?:"+ht+")[\\s/>]","i"),yt=/^\s+/,vt=/<(?!area|br|col|embed|hr|img|input|link|meta|param)(([\w:]+)[^>]*)\/>/gi,bt=/<([\w:]+)/,xt=/<tbody/i,wt=/<|&#?\w+;/,Tt=/<(?:script|style|link)/i,Ct=/^(?:checkbox|radio)$/i,Nt=/checked\s*(?:[^=]|=\s*.checked.)/i,kt=/^$|
\/(?:java|ecma)script/i,Et=/^true\/(.*)/,St=/^\s*<!(?:\[CDATA\[|--)|(?:\]\]|--)>\s*$/g,At={option:[1,"<select multiple='multiple'>","</select>"],legend:[1,"<fieldset>","</fieldset>"],area:[1,"<map>","</map>"],param:[1,"<object>","</object>"],thead:[1,"<table>","</table>"],tr:[2,"<table><tbody>","</tbody></table>"],col:[2,"<table><tbody></tbody><colgroup>","</colgroup></table>"],td:[3,"<table><tbody><tr>","</tr></tbody></table>"],_default:x.support.htmlSerialize?[0,"",""]:[1,"X<div>","</div>"]},jt=dt(a),Dt=jt.appendChild(a.createElement("div"));At.optgroup=At.option,At.tbody=At.tfoot=At.colgroup=At.caption=At.thead,At.th=At.td,x.fn.extend({text:function(e){return x.access(this,function(e){return e===t?x.text(this):this.empty().append((this[0]&&this[0].ownerDocument||a).createTextNode(e))},null,e,arguments.length)},append:function(){return this.domManip(arguments,function(e){if(1===this.nodeType||11===this.nodeType||9===this.nodeType){var t=Lt(this,e);t.appendChild(e)}})},prep
end:function(){return this.domManip(arguments,function(e){if(1===this.nodeType||11===this.nodeType||9===this.nodeType){var t=Lt(this,e);t.insertBefore(e,t.firstChild)}})},before:function(){return this.domManip(arguments,function(e){this.parentNode&&this.parentNode.insertBefore(e,this)})},after:function(){return this.domManip(arguments,function(e){this.parentNode&&this.parentNode.insertBefore(e,this.nextSibling)})},remove:function(e,t){var n,r=e?x.filter(e,this):this,i=0;for(;null!=(n=r[i]);i++)t||1!==n.nodeType||x.cleanData(Ft(n)),n.parentNode&&(t&&x.contains(n.ownerDocument,n)&&_t(Ft(n,"script")),n.parentNode.removeChild(n));return this},empty:function(){var e,t=0;for(;null!=(e=this[t]);t++){1===e.nodeType&&x.cleanData(Ft(e,!1));while(e.firstChild)e.removeChild(e.firstChild);e.options&&x.nodeName(e,"select")&&(e.options.length=0)}return this},clone:function(e,t){return e=null==e?!1:e,t=null==t?e:t,this.map(function(){return x.clone(this,e,t)})},html:function(e){return x.acc
ess(this,function(e){var n=this[0]||{},r=0,i=this.length;if(e===t)return 1===n.nodeType?n.innerHTML.replace(gt,""):t;if(!("string"!=typeof e||Tt.test(e)||!x.support.htmlSerialize&&mt.test(e)||!x.support.leadingWhitespace&&yt.test(e)||At[(bt.exec(e)||["",""])[1].toLowerCase()])){e=e.replace(vt,"<$1></$2>");try{for(;i>r;r++)n=this[r]||{},1===n.nodeType&&(x.cleanData(Ft(n,!1)),n.innerHTML=e);n=0}catch(o){}}n&&this.empty().append(e)},null,e,arguments.length)},replaceWith:function(){var e=x.map(this,function(e){return[e.nextSibling,e.parentNode]}),t=0;return this.domManip(arguments,function(n){var r=e[t++],i=e[t++];i&&(r&&r.parentNode!==i&&(r=this.nextSibling),x(this).remove(),i.insertBefore(n,r))},!0),t?this:this.remove()},detach:function(e){return this.remove(e,!0)},domManip:function(e,t,n){e=d.apply([],e);var r,i,o,a,s,l,u=0,c=this.length,p=this,f=c-1,h=e[0],g=x.isFunction(h);if(g||!(1>=c||"string"!=typeof h||x.support.checkClone)&&Nt.test(h))return this.each(function(r){var i
=p.eq(r);g&&(e[0]=h.call(this,r,i.html())),i.domManip(e,t,n)});if(c&&(l=x.buildFragment(e,this[0].ownerDocument,!1,!n&&this),r=l.firstChild,1===l.childNodes.length&&(l=r),r)){for(a=x.map(Ft(l,"script"),Ht),o=a.length;c>u;u++)i=l,u!==f&&(i=x.clone(i,!0,!0),o&&x.merge(a,Ft(i,"script"))),t.call(this[u],i,u);if(o)for(s=a[a.length-1].ownerDocument,x.map(a,qt),u=0;o>u;u++)i=a[u],kt.test(i.type||"")&&!x._data(i,"globalEval")&&x.contains(s,i)&&(i.src?x._evalUrl(i.src):x.globalEval((i.text||i.textContent||i.innerHTML||"").replace(St,"")));l=r=null}return this}});function Lt(e,t){return x.nodeName(e,"table")&&x.nodeName(1===t.nodeType?t:t.firstChild,"tr")?e.getElementsByTagName("tbody")[0]||e.appendChild(e.ownerDocument.createElement("tbody")):e}function Ht(e){return e.type=(null!==x.find.attr(e,"type"))+"/"+e.type,e}function qt(e){var t=Et.exec(e.type);return t?e.type=t[1]:e.removeAttribute("type"),e}function _t(e,t){var n,r=0;for(;null!=(n=e[r]);r++)x._data(n,"globalEval",!t||x._dat
a(t[r],"globalEval"))}function Mt(e,t){if(1===t.nodeType&&x.hasData(e)){var n,r,i,o=x._data(e),a=x._data(t,o),s=o.events;if(s){delete a.handle,a.events={};for(n in s)for(r=0,i=s[n].length;i>r;r++)x.event.add(t,n,s[n][r])}a.data&&(a.data=x.extend({},a.data))}}function Ot(e,t){var n,r,i;if(1===t.nodeType){if(n=t.nodeName.toLowerCase(),!x.support.noCloneEvent&&t[x.expando]){i=x._data(t);for(r in i.events)x.removeEvent(t,r,i.handle);t.removeAttribute(x.expando)}"script"===n&&t.text!==e.text?(Ht(t).text=e.text,qt(t)):"object"===n?(t.parentNode&&(t.outerHTML=e.outerHTML),x.support.html5Clone&&e.innerHTML&&!x.trim(t.innerHTML)&&(t.innerHTML=e.innerHTML)):"input"===n&&Ct.test(e.type)?(t.defaultChecked=t.checked=e.checked,t.value!==e.value&&(t.value=e.value)):"option"===n?t.defaultSelected=t.selected=e.defaultSelected:("input"===n||"textarea"===n)&&(t.defaultValue=e.defaultValue)}}x.each({appendTo:"append",prependTo:"prepend",insertBefore:"before",insertAfter:"after",replaceAll:"repl
aceWith"},function(e,t){x.fn[e]=function(e){var n,r=0,i=[],o=x(e),a=o.length-1;for(;a>=r;r++)n=r===a?this:this.clone(!0),x(o[r])[t](n),h.apply(i,n.get());return this.pushStack(i)}});function Ft(e,n){var r,o,a=0,s=typeof e.getElementsByTagName!==i?e.getElementsByTagName(n||"*"):typeof e.querySelectorAll!==i?e.querySelectorAll(n||"*"):t;if(!s)for(s=[],r=e.childNodes||e;null!=(o=r[a]);a++)!n||x.nodeName(o,n)?s.push(o):x.merge(s,Ft(o,n));return n===t||n&&x.nodeName(e,n)?x.merge([e],s):s}function Bt(e){Ct.test(e.type)&&(e.defaultChecked=e.checked)}x.extend({clone:function(e,t,n){var r,i,o,a,s,l=x.contains(e.ownerDocument,e);if(x.support.html5Clone||x.isXMLDoc(e)||!mt.test("<"+e.nodeName+">")?o=e.cloneNode(!0):(Dt.innerHTML=e.outerHTML,Dt.removeChild(o=Dt.firstChild)),!(x.support.noCloneEvent&&x.support.noCloneChecked||1!==e.nodeType&&11!==e.nodeType||x.isXMLDoc(e)))for(r=Ft(o),s=Ft(e),a=0;null!=(i=s[a]);++a)r[a]&&Ot(i,r[a]);if(t)if(n)for(s=s||Ft(e),r=r||Ft(o),a=0;null!=(i=s[a]);a
++)Mt(i,r[a]);else Mt(e,o);return r=Ft(o,"script"),r.length>0&&_t(r,!l&&Ft(e,"script")),r=s=i=null,o},buildFragment:function(e,t,n,r){var i,o,a,s,l,u,c,p=e.length,f=dt(t),d=[],h=0;for(;p>h;h++)if(o=e[h],o||0===o)if("object"===x.type(o))x.merge(d,o.nodeType?[o]:o);else if(wt.test(o)){s=s||f.appendChild(t.createElement("div")),l=(bt.exec(o)||["",""])[1].toLowerCase(),c=At[l]||At._default,s.innerHTML=c[1]+o.replace(vt,"<$1></$2>")+c[2],i=c[0];while(i--)s=s.lastChild;if(!x.support.leadingWhitespace&&yt.test(o)&&d.push(t.createTextNode(yt.exec(o)[0])),!x.support.tbody){o="table"!==l||xt.test(o)?"<table>"!==c[1]||xt.test(o)?0:s:s.firstChild,i=o&&o.childNodes.length;while(i--)x.nodeName(u=o.childNodes[i],"tbody")&&!u.childNodes.length&&o.removeChild(u)}x.merge(d,s.childNodes),s.textContent="";while(s.firstChild)s.removeChild(s.firstChild);s=f.lastChild}else d.push(t.createTextNode(o));s&&f.removeChild(s),x.support.appendChecked||x.grep(Ft(d,"input"),Bt),h=0;while(o=d[h++])if((!r||-
1===x.inArray(o,r))&&(a=x.contains(o.ownerDocument,o),s=Ft(f.appendChild(o),"script"),a&&_t(s),n)){i=0;while(o=s[i++])kt.test(o.type||"")&&n.push(o)}return s=null,f},cleanData:function(e,t){var n,r,o,a,s=0,l=x.expando,u=x.cache,c=x.support.deleteExpando,f=x.event.special;for(;null!=(n=e[s]);s++)if((t||x.acceptData(n))&&(o=n[l],a=o&&u[o])){if(a.events)for(r in a.events)f[r]?x.event.remove(n,r):x.removeEvent(n,r,a.handle);
+u[o]&&(delete u[o],c?delete n[l]:typeof n.removeAttribute!==i?n.removeAttribute(l):n[l]=null,p.push(o))}},_evalUrl:function(e){return x.ajax({url:e,type:"GET",dataType:"script",async:!1,global:!1,"throws":!0})}}),x.fn.extend({wrapAll:function(e){if(x.isFunction(e))return this.each(function(t){x(this).wrapAll(e.call(this,t))});if(this[0]){var t=x(e,this[0].ownerDocument).eq(0).clone(!0);this[0].parentNode&&t.insertBefore(this[0]),t.map(function(){var e=this;while(e.firstChild&&1===e.firstChild.nodeType)e=e.firstChild;return e}).append(this)}return this},wrapInner:function(e){return x.isFunction(e)?this.each(function(t){x(this).wrapInner(e.call(this,t))}):this.each(function(){var t=x(this),n=t.contents();n.length?n.wrapAll(e):t.append(e)})},wrap:function(e){var t=x.isFunction(e);return this.each(function(n){x(this).wrapAll(t?e.call(this,n):e)})},unwrap:function(){return this.parent().each(function(){x.nodeName(this,"body")||x(this).replaceWith(this.childNodes)}).end()}});var P
t,Rt,Wt,$t=/alpha\([^)]*\)/i,It=/opacity\s*=\s*([^)]*)/,zt=/^(top|right|bottom|left)$/,Xt=/^(none|table(?!-c[ea]).+)/,Ut=/^margin/,Vt=RegExp("^("+w+")(.*)$","i"),Yt=RegExp("^("+w+")(?!px)[a-z%]+$","i"),Jt=RegExp("^([+-])=("+w+")","i"),Gt={BODY:"block"},Qt={position:"absolute",visibility:"hidden",display:"block"},Kt={letterSpacing:0,fontWeight:400},Zt=["Top","Right","Bottom","Left"],en=["Webkit","O","Moz","ms"];function tn(e,t){if(t in e)return t;var n=t.charAt(0).toUpperCase()+t.slice(1),r=t,i=en.length;while(i--)if(t=en[i]+n,t in e)return t;return r}function nn(e,t){return e=t||e,"none"===x.css(e,"display")||!x.contains(e.ownerDocument,e)}function rn(e,t){var n,r,i,o=[],a=0,s=e.length;for(;s>a;a++)r=e[a],r.style&&(o[a]=x._data(r,"olddisplay"),n=r.style.display,t?(o[a]||"none"!==n||(r.style.display=""),""===r.style.display&&nn(r)&&(o[a]=x._data(r,"olddisplay",ln(r.nodeName)))):o[a]||(i=nn(r),(n&&"none"!==n||!i)&&x._data(r,"olddisplay",i?n:x.css(r,"display"))));for(a=0;s>a;a+
+)r=e[a],r.style&&(t&&"none"!==r.style.display&&""!==r.style.display||(r.style.display=t?o[a]||"":"none"));return e}x.fn.extend({css:function(e,n){return x.access(this,function(e,n,r){var i,o,a={},s=0;if(x.isArray(n)){for(o=Rt(e),i=n.length;i>s;s++)a[n[s]]=x.css(e,n[s],!1,o);return a}return r!==t?x.style(e,n,r):x.css(e,n)},e,n,arguments.length>1)},show:function(){return rn(this,!0)},hide:function(){return rn(this)},toggle:function(e){return"boolean"==typeof e?e?this.show():this.hide():this.each(function(){nn(this)?x(this).show():x(this).hide()})}}),x.extend({cssHooks:{opacity:{get:function(e,t){if(t){var n=Wt(e,"opacity");return""===n?"1":n}}}},cssNumber:{columnCount:!0,fillOpacity:!0,fontWeight:!0,lineHeight:!0,opacity:!0,order:!0,orphans:!0,widows:!0,zIndex:!0,zoom:!0},cssProps:{"float":x.support.cssFloat?"cssFloat":"styleFloat"},style:function(e,n,r,i){if(e&&3!==e.nodeType&&8!==e.nodeType&&e.style){var o,a,s,l=x.camelCase(n),u=e.style;if(n=x.cssProps[l]||(x.cssProps[l]=tn
(u,l)),s=x.cssHooks[n]||x.cssHooks[l],r===t)return s&&"get"in s&&(o=s.get(e,!1,i))!==t?o:u[n];if(a=typeof r,"string"===a&&(o=Jt.exec(r))&&(r=(o[1]+1)*o[2]+parseFloat(x.css(e,n)),a="number"),!(null==r||"number"===a&&isNaN(r)||("number"!==a||x.cssNumber[l]||(r+="px"),x.support.clearCloneStyle||""!==r||0!==n.indexOf("background")||(u[n]="inherit"),s&&"set"in s&&(r=s.set(e,r,i))===t)))try{u[n]=r}catch(c){}}},css:function(e,n,r,i){var o,a,s,l=x.camelCase(n);return n=x.cssProps[l]||(x.cssProps[l]=tn(e.style,l)),s=x.cssHooks[n]||x.cssHooks[l],s&&"get"in s&&(a=s.get(e,!0,r)),a===t&&(a=Wt(e,n,i)),"normal"===a&&n in Kt&&(a=Kt[n]),""===r||r?(o=parseFloat(a),r===!0||x.isNumeric(o)?o||0:a):a}}),e.getComputedStyle?(Rt=function(t){return e.getComputedStyle(t,null)},Wt=function(e,n,r){var i,o,a,s=r||Rt(e),l=s?s.getPropertyValue(n)||s[n]:t,u=e.style;return s&&(""!==l||x.contains(e.ownerDocument,e)||(l=x.style(e,n)),Yt.test(l)&&Ut.test(n)&&(i=u.width,o=u.minWidth,a=u.maxWidth,u.minWidth=u.max
Width=u.width=l,l=s.width,u.width=i,u.minWidth=o,u.maxWidth=a)),l}):a.documentElement.currentStyle&&(Rt=function(e){return e.currentStyle},Wt=function(e,n,r){var i,o,a,s=r||Rt(e),l=s?s[n]:t,u=e.style;return null==l&&u&&u[n]&&(l=u[n]),Yt.test(l)&&!zt.test(n)&&(i=u.left,o=e.runtimeStyle,a=o&&o.left,a&&(o.left=e.currentStyle.left),u.left="fontSize"===n?"1em":l,l=u.pixelLeft+"px",u.left=i,a&&(o.left=a)),""===l?"auto":l});function on(e,t,n){var r=Vt.exec(t);return r?Math.max(0,r[1]-(n||0))+(r[2]||"px"):t}function an(e,t,n,r,i){var o=n===(r?"border":"content")?4:"width"===t?1:0,a=0;for(;4>o;o+=2)"margin"===n&&(a+=x.css(e,n+Zt[o],!0,i)),r?("content"===n&&(a-=x.css(e,"padding"+Zt[o],!0,i)),"margin"!==n&&(a-=x.css(e,"border"+Zt[o]+"Width",!0,i))):(a+=x.css(e,"padding"+Zt[o],!0,i),"padding"!==n&&(a+=x.css(e,"border"+Zt[o]+"Width",!0,i)));return a}function sn(e,t,n){var r=!0,i="width"===t?e.offsetWidth:e.offsetHeight,o=Rt(e),a=x.support.boxSizing&&"border-box"===x.css(e,"boxSizing",!1,
o);if(0>=i||null==i){if(i=Wt(e,t,o),(0>i||null==i)&&(i=e.style[t]),Yt.test(i))return i;r=a&&(x.support.boxSizingReliable||i===e.style[t]),i=parseFloat(i)||0}return i+an(e,t,n||(a?"border":"content"),r,o)+"px"}function ln(e){var t=a,n=Gt[e];return n||(n=un(e,t),"none"!==n&&n||(Pt=(Pt||x("<iframe frameborder='0' width='0' height='0'/>").css("cssText","display:block !important")).appendTo(t.documentElement),t=(Pt[0].contentWindow||Pt[0].contentDocument).document,t.write("<!doctype html><html><body>"),t.close(),n=un(e,t),Pt.detach()),Gt[e]=n),n}function un(e,t){var n=x(t.createElement(e)).appendTo(t.body),r=x.css(n[0],"display");return n.remove(),r}x.each(["height","width"],function(e,n){x.cssHooks[n]={get:function(e,r,i){return r?0===e.offsetWidth&&Xt.test(x.css(e,"display"))?x.swap(e,Qt,function(){return sn(e,n,i)}):sn(e,n,i):t},set:function(e,t,r){var i=r&&Rt(e);return on(e,t,r?an(e,n,r,x.support.boxSizing&&"border-box"===x.css(e,"boxSizing",!1,i),i):0)}}}),x.support.opacity|
|(x.cssHooks.opacity={get:function(e,t){return It.test((t&&e.currentStyle?e.currentStyle.filter:e.style.filter)||"")?.01*parseFloat(RegExp.$1)+"":t?"1":""},set:function(e,t){var n=e.style,r=e.currentStyle,i=x.isNumeric(t)?"alpha(opacity="+100*t+")":"",o=r&&r.filter||n.filter||"";n.zoom=1,(t>=1||""===t)&&""===x.trim(o.replace($t,""))&&n.removeAttribute&&(n.removeAttribute("filter"),""===t||r&&!r.filter)||(n.filter=$t.test(o)?o.replace($t,i):o+" "+i)}}),x(function(){x.support.reliableMarginRight||(x.cssHooks.marginRight={get:function(e,n){return n?x.swap(e,{display:"inline-block"},Wt,[e,"marginRight"]):t}}),!x.support.pixelPosition&&x.fn.position&&x.each(["top","left"],function(e,n){x.cssHooks[n]={get:function(e,r){return r?(r=Wt(e,n),Yt.test(r)?x(e).position()[n]+"px":r):t}}})}),x.expr&&x.expr.filters&&(x.expr.filters.hidden=function(e){return 0>=e.offsetWidth&&0>=e.offsetHeight||!x.support.reliableHiddenOffsets&&"none"===(e.style&&e.style.display||x.css(e,"display"))},x.expr
.filters.visible=function(e){return!x.expr.filters.hidden(e)}),x.each({margin:"",padding:"",border:"Width"},function(e,t){x.cssHooks[e+t]={expand:function(n){var r=0,i={},o="string"==typeof n?n.split(" "):[n];for(;4>r;r++)i[e+Zt[r]+t]=o[r]||o[r-2]||o[0];return i}},Ut.test(e)||(x.cssHooks[e+t].set=on)});var cn=/%20/g,pn=/\[\]$/,fn=/\r?\n/g,dn=/^(?:submit|button|image|reset|file)$/i,hn=/^(?:input|select|textarea|keygen)/i;x.fn.extend({serialize:function(){return x.param(this.serializeArray())},serializeArray:function(){return this.map(function(){var e=x.prop(this,"elements");return e?x.makeArray(e):this}).filter(function(){var e=this.type;return this.name&&!x(this).is(":disabled")&&hn.test(this.nodeName)&&!dn.test(e)&&(this.checked||!Ct.test(e))}).map(function(e,t){var n=x(this).val();return null==n?null:x.isArray(n)?x.map(n,function(e){return{name:t.name,value:e.replace(fn,"\r\n")}}):{name:t.name,value:n.replace(fn,"\r\n")}}).get()}}),x.param=function(e,n){var r,i=[],o=functi
on(e,t){t=x.isFunction(t)?t():null==t?"":t,i[i.length]=encodeURIComponent(e)+"="+encodeURIComponent(t)};if(n===t&&(n=x.ajaxSettings&&x.ajaxSettings.traditional),x.isArray(e)||e.jquery&&!x.isPlainObject(e))x.each(e,function(){o(this.name,this.value)});else for(r in e)gn(r,e[r],n,o);return i.join("&").replace(cn,"+")};function gn(e,t,n,r){var i;if(x.isArray(t))x.each(t,function(t,i){n||pn.test(e)?r(e,i):gn(e+"["+("object"==typeof i?t:"")+"]",i,n,r)});else if(n||"object"!==x.type(t))r(e,t);else for(i in t)gn(e+"["+i+"]",t[i],n,r)}x.each("blur focus focusin focusout load resize scroll unload click dblclick mousedown mouseup mousemove mouseover mouseout mouseenter mouseleave change select submit keydown keypress keyup error contextmenu".split(" "),function(e,t){x.fn[t]=function(e,n){return arguments.length>0?this.on(t,null,e,n):this.trigger(t)}}),x.fn.extend({hover:function(e,t){return this.mouseenter(e).mouseleave(t||e)},bind:function(e,t,n){return this.on(e,null,t,n)},unbind:fu
nction(e,t){return this.off(e,null,t)},delegate:function(e,t,n,r){return this.on(t,e,n,r)},undelegate:function(e,t,n){return 1===arguments.length?this.off(e,"**"):this.off(t,e||"**",n)}});var mn,yn,vn=x.now(),bn=/\?/,xn=/#.*$/,wn=/([?&])_=[^&]*/,Tn=/^(.*?):[ \t]*([^\r\n]*)\r?$/gm,Cn=/^(?:about|app|app-storage|.+-extension|file|res|widget):$/,Nn=/^(?:GET|HEAD)$/,kn=/^\/\//,En=/^([\w.+-]+:)(?:\/\/([^\/?#:]*)(?::(\d+)|)|)/,Sn=x.fn.load,An={},jn={},Dn="*/".concat("*");try{yn=o.href}catch(Ln){yn=a.createElement("a"),yn.href="",yn=yn.href}mn=En.exec(yn.toLowerCase())||[];function Hn(e){return function(t,n){"string"!=typeof t&&(n=t,t="*");var r,i=0,o=t.toLowerCase().match(T)||[];if(x.isFunction(n))while(r=o[i++])"+"===r[0]?(r=r.slice(1)||"*",(e[r]=e[r]||[]).unshift(n)):(e[r]=e[r]||[]).push(n)}}function qn(e,n,r,i){var o={},a=e===jn;function s(l){var u;return o[l]=!0,x.each(e[l]||[],function(e,l){var c=l(n,r,i);return"string"!=typeof c||a||o[c]?a?!(u=c):t:(n.dataTypes.unshift(c),s(c
),!1)}),u}return s(n.dataTypes[0])||!o["*"]&&s("*")}function _n(e,n){var r,i,o=x.ajaxSettings.flatOptions||{};for(i in n)n[i]!==t&&((o[i]?e:r||(r={}))[i]=n[i]);return r&&x.extend(!0,e,r),e}x.fn.load=function(e,n,r){if("string"!=typeof e&&Sn)return Sn.apply(this,arguments);var i,o,a,s=this,l=e.indexOf(" ");return l>=0&&(i=e.slice(l,e.length),e=e.slice(0,l)),x.isFunction(n)?(r=n,n=t):n&&"object"==typeof n&&(a="POST"),s.length>0&&x.ajax({url:e,type:a,dataType:"html",data:n}).done(function(e){o=arguments,s.html(i?x("<div>").append(x.parseHTML(e)).find(i):e)}).complete(r&&function(e,t){s.each(r,o||[e.responseText,t,e])}),this},x.each(["ajaxStart","ajaxStop","ajaxComplete","ajaxError","ajaxSuccess","ajaxSend"],function(e,t){x.fn[t]=function(e){return this.on(t,e)}}),x.extend({active:0,lastModified:{},etag:{},ajaxSettings:{url:yn,type:"GET",isLocal:Cn.test(mn[1]),global:!0,processData:!0,async:!0,contentType:"application/x-www-form-urlencoded; charset=UTF-8",accepts:{"*":Dn,text:"t
ext/plain",html:"text/html",xml:"application/xml, text/xml",json:"application/json, text/javascript"},contents:{xml:/xml/,html:/html/,json:/json/},responseFields:{xml:"responseXML",text:"responseText",json:"responseJSON"},converters:{"* text":String,"text html":!0,"text json":x.parseJSON,"text xml":x.parseXML},flatOptions:{url:!0,context:!0}},ajaxSetup:function(e,t){return t?_n(_n(e,x.ajaxSettings),t):_n(x.ajaxSettings,e)},ajaxPrefilter:Hn(An),ajaxTransport:Hn(jn),ajax:function(e,n){"object"==typeof e&&(n=e,e=t),n=n||{};var r,i,o,a,s,l,u,c,p=x.ajaxSetup({},n),f=p.context||p,d=p.context&&(f.nodeType||f.jquery)?x(f):x.event,h=x.Deferred(),g=x.Callbacks("once memory"),m=p.statusCode||{},y={},v={},b=0,w="canceled",C={readyState:0,getResponseHeader:function(e){var t;if(2===b){if(!c){c={};while(t=Tn.exec(a))c[t[1].toLowerCase()]=t[2]}t=c[e.toLowerCase()]}return null==t?null:t},getAllResponseHeaders:function(){return 2===b?a:null},setRequestHeader:function(e,t){var n=e.toLowerCase(
);return b||(e=v[n]=v[n]||e,y[e]=t),this},overrideMimeType:function(e){return b||(p.mimeType=e),this},statusCode:function(e){var t;if(e)if(2>b)for(t in e)m[t]=[m[t],e[t]];else C.always(e[C.status]);return this},abort:function(e){var t=e||w;return u&&u.abort(t),k(0,t),this}};if(h.promise(C).complete=g.add,C.success=C.done,C.error=C.fail,p.url=((e||p.url||yn)+"").replace(xn,"").replace(kn,mn[1]+"//"),p.type=n.method||n.type||p.method||p.type,p.dataTypes=x.trim(p.dataType||"*").toLowerCase().match(T)||[""],null==p.crossDomain&&(r=En.exec(p.url.toLowerCase()),p.crossDomain=!(!r||r[1]===mn[1]&&r[2]===mn[2]&&(r[3]||("http:"===r[1]?"80":"443"))===(mn[3]||("http:"===mn[1]?"80":"443")))),p.data&&p.processData&&"string"!=typeof p.data&&(p.data=x.param(p.data,p.traditional)),qn(An,p,n,C),2===b)return C;l=p.global,l&&0===x.active++&&x.event.trigger("ajaxStart"),p.type=p.type.toUpperCase(),p.hasContent=!Nn.test(p.type),o=p.url,p.hasContent||(p.data&&(o=p.url+=(bn.test(o)?"&":"?")+p.data,
delete p.data),p.cache===!1&&(p.url=wn.test(o)?o.replace(wn,"$1_="+vn++):o+(bn.test(o)?"&":"?")+"_="+vn++)),p.ifModified&&(x.lastModified[o]&&C.setRequestHeader("If-Modified-Since",x.lastModified[o]),x.etag[o]&&C.setRequestHeader("If-None-Match",x.etag[o])),(p.data&&p.hasContent&&p.contentType!==!1||n.contentType)&&C.setRequestHeader("Content-Type",p.contentType),C.setRequestHeader("Accept",p.dataTypes[0]&&p.accepts[p.dataTypes[0]]?p.accepts[p.dataTypes[0]]+("*"!==p.dataTypes[0]?", "+Dn+"; q=0.01":""):p.accepts["*"]);for(i in p.headers)C.setRequestHeader(i,p.headers[i]);if(p.beforeSend&&(p.beforeSend.call(f,C,p)===!1||2===b))return C.abort();w="abort";for(i in{success:1,error:1,complete:1})C[i](p[i]);if(u=qn(jn,p,n,C)){C.readyState=1,l&&d.trigger("ajaxSend",[C,p]),p.async&&p.timeout>0&&(s=setTimeout(function(){C.abort("timeout")},p.timeout));try{b=1,u.send(y,k)}catch(N){if(!(2>b))throw N;k(-1,N)}}else k(-1,"No Transport");function k(e,n,r,i){var c,y,v,w,T,N=n;2!==b&&(b=2,s&&
clearTimeout(s),u=t,a=i||"",C.readyState=e>0?4:0,c=e>=200&&300>e||304===e,r&&(w=Mn(p,C,r)),w=On(p,w,C,c),c?(p.ifModified&&(T=C.getResponseHeader("Last-Modified"),T&&(x.lastModified[o]=T),T=C.getResponseHeader("etag"),T&&(x.etag[o]=T)),204===e||"HEAD"===p.type?N="nocontent":304===e?N="notmodified":(N=w.state,y=w.data,v=w.error,c=!v)):(v=N,(e||!N)&&(N="error",0>e&&(e=0))),C.status=e,C.statusText=(n||N)+"",c?h.resolveWith(f,[y,N,C]):h.rejectWith(f,[C,N,v]),C.statusCode(m),m=t,l&&d.trigger(c?"ajaxSuccess":"ajaxError",[C,p,c?y:v]),g.fireWith(f,[C,N]),l&&(d.trigger("ajaxComplete",[C,p]),--x.active||x.event.trigger("ajaxStop")))}return C},getJSON:function(e,t,n){return x.get(e,t,n,"json")},getScript:function(e,n){return x.get(e,t,n,"script")}}),x.each(["get","post"],function(e,n){x[n]=function(e,r,i,o){return x.isFunction(r)&&(o=o||i,i=r,r=t),x.ajax({url:e,type:n,dataType:o,data:r,success:i})}});function Mn(e,n,r){var i,o,a,s,l=e.contents,u=e.dataTypes;while("*"===u[0])u.shift(),o=
==t&&(o=e.mimeType||n.getResponseHeader("Content-Type"));if(o)for(s in l)if(l[s]&&l[s].test(o)){u.unshift(s);break}if(u[0]in r)a=u[0];else{for(s in r){if(!u[0]||e.converters[s+" "+u[0]]){a=s;break}i||(i=s)}a=a||i}return a?(a!==u[0]&&u.unshift(a),r[a]):t}function On(e,t,n,r){var i,o,a,s,l,u={},c=e.dataTypes.slice();if(c[1])for(a in e.converters)u[a.toLowerCase()]=e.converters[a];o=c.shift();while(o)if(e.responseFields[o]&&(n[e.responseFields[o]]=t),!l&&r&&e.dataFilter&&(t=e.dataFilter(t,e.dataType)),l=o,o=c.shift())if("*"===o)o=l;else if("*"!==l&&l!==o){if(a=u[l+" "+o]||u["* "+o],!a)for(i in u)if(s=i.split(" "),s[1]===o&&(a=u[l+" "+s[0]]||u["* "+s[0]])){a===!0?a=u[i]:u[i]!==!0&&(o=s[0],c.unshift(s[1]));break}if(a!==!0)if(a&&e["throws"])t=a(t);else try{t=a(t)}catch(p){return{state:"parsererror",error:a?p:"No conversion from "+l+" to "+o}}}return{state:"success",data:t}}x.ajaxSetup({accepts:{script:"text/javascript, application/javascript, application/ecmascript, application/x-
ecmascript"},contents:{script:/(?:java|ecma)script/},converters:{"text script":function(e){return x.globalEval(e),e}}}),x.ajaxPrefilter("script",function(e){e.cache===t&&(e.cache=!1),e.crossDomain&&(e.type="GET",e.global=!1)}),x.ajaxTransport("script",function(e){if(e.crossDomain){var n,r=a.head||x("head")[0]||a.documentElement;return{send:function(t,i){n=a.createElement("script"),n.async=!0,e.scriptCharset&&(n.charset=e.scriptCharset),n.src=e.url,n.onload=n.onreadystatechange=function(e,t){(t||!n.readyState||/loaded|complete/.test(n.readyState))&&(n.onload=n.onreadystatechange=null,n.parentNode&&n.parentNode.removeChild(n),n=null,t||i(200,"success"))},r.insertBefore(n,r.firstChild)},abort:function(){n&&n.onload(t,!0)}}}});var Fn=[],Bn=/(=)\?(?=&|$)|\?\?/;x.ajaxSetup({jsonp:"callback",jsonpCallback:function(){var e=Fn.pop()||x.expando+"_"+vn++;return this[e]=!0,e}}),x.ajaxPrefilter("json jsonp",function(n,r,i){var o,a,s,l=n.jsonp!==!1&&(Bn.test(n.url)?"url":"string"==typeof
n.data&&!(n.contentType||"").indexOf("application/x-www-form-urlencoded")&&Bn.test(n.data)&&"data");return l||"jsonp"===n.dataTypes[0]?(o=n.jsonpCallback=x.isFunction(n.jsonpCallback)?n.jsonpCallback():n.jsonpCallback,l?n[l]=n[l].replace(Bn,"$1"+o):n.jsonp!==!1&&(n.url+=(bn.test(n.url)?"&":"?")+n.jsonp+"="+o),n.converters["script json"]=function(){return s||x.error(o+" was not called"),s[0]},n.dataTypes[0]="json",a=e[o],e[o]=function(){s=arguments},i.always(function(){e[o]=a,n[o]&&(n.jsonpCallback=r.jsonpCallback,Fn.push(o)),s&&x.isFunction(a)&&a(s[0]),s=a=t}),"script"):t});var Pn,Rn,Wn=0,$n=e.ActiveXObject&&function(){var e;for(e in Pn)Pn[e](t,!0)};function In(){try{return new e.XMLHttpRequest}catch(t){}}function zn(){try{return new e.ActiveXObject("Microsoft.XMLHTTP")}catch(t){}}x.ajaxSettings.xhr=e.ActiveXObject?function(){return!this.isLocal&&In()||zn()}:In,Rn=x.ajaxSettings.xhr(),x.support.cors=!!Rn&&"withCredentials"in Rn,Rn=x.support.ajax=!!Rn,Rn&&x.ajaxTransport(func
tion(n){if(!n.crossDomain||x.support.cors){var r;return{send:function(i,o){var a,s,l=n.xhr();if(n.username?l.open(n.type,n.url,n.async,n.username,n.password):l.open(n.type,n.url,n.async),n.xhrFields)for(s in n.xhrFields)l[s]=n.xhrFields[s];n.mimeType&&l.overrideMimeType&&l.overrideMimeType(n.mimeType),n.crossDomain||i["X-Requested-With"]||(i["X-Requested-With"]="XMLHttpRequest");try{for(s in i)l.setRequestHeader(s,i[s])}catch(u){}l.send(n.hasContent&&n.data||null),r=function(e,i){var s,u,c,p;try{if(r&&(i||4===l.readyState))if(r=t,a&&(l.onreadystatechange=x.noop,$n&&delete Pn[a]),i)4!==l.readyState&&l.abort();else{p={},s=l.status,u=l.getAllResponseHeaders(),"string"==typeof l.responseText&&(p.text=l.responseText);try{c=l.statusText}catch(f){c=""}s||!n.isLocal||n.crossDomain?1223===s&&(s=204):s=p.text?200:404}}catch(d){i||o(-1,d)}p&&o(s,c,p,u)},n.async?4===l.readyState?setTimeout(r):(a=++Wn,$n&&(Pn||(Pn={},x(e).unload($n)),Pn[a]=r),l.onreadystatechange=r):r()},abort:function()
{r&&r(t,!0)}}}});var Xn,Un,Vn=/^(?:toggle|show|hide)$/,Yn=RegExp("^(?:([+-])=|)("+w+")([a-z%]*)$","i"),Jn=/queueHooks$/,Gn=[nr],Qn={"*":[function(e,t){var n=this.createTween(e,t),r=n.cur(),i=Yn.exec(t),o=i&&i[3]||(x.cssNumber[e]?"":"px"),a=(x.cssNumber[e]||"px"!==o&&+r)&&Yn.exec(x.css(n.elem,e)),s=1,l=20;if(a&&a[3]!==o){o=o||a[3],i=i||[],a=+r||1;do s=s||".5",a/=s,x.style(n.elem,e,a+o);while(s!==(s=n.cur()/r)&&1!==s&&--l)}return i&&(a=n.start=+a||+r||0,n.unit=o,n.end=i[1]?a+(i[1]+1)*i[2]:+i[2]),n}]};function Kn(){return setTimeout(function(){Xn=t}),Xn=x.now()}function Zn(e,t,n){var r,i=(Qn[t]||[]).concat(Qn["*"]),o=0,a=i.length;for(;a>o;o++)if(r=i[o].call(n,t,e))return r}function er(e,t,n){var r,i,o=0,a=Gn.length,s=x.Deferred().always(function(){delete l.elem}),l=function(){if(i)return!1;var t=Xn||Kn(),n=Math.max(0,u.startTime+u.duration-t),r=n/u.duration||0,o=1-r,a=0,l=u.tweens.length;for(;l>a;a++)u.tweens[a].run(o);return s.notifyWith(e,[u,o,n]),1>o&&l?n:(s.resolveWith(e,[u
]),!1)},u=s.promise({elem:e,props:x.extend({},t),opts:x.extend(!0,{specialEasing:{}},n),originalProperties:t,originalOptions:n,startTime:Xn||Kn(),duration:n.duration,tweens:[],createTween:function(t,n){var r=x.Tween(e,u.opts,t,n,u.opts.specialEasing[t]||u.opts.easing);return u.tweens.push(r),r},stop:function(t){var n=0,r=t?u.tweens.length:0;if(i)return this;for(i=!0;r>n;n++)u.tweens[n].run(1);return t?s.resolveWith(e,[u,t]):s.rejectWith(e,[u,t]),this}}),c=u.props;for(tr(c,u.opts.specialEasing);a>o;o++)if(r=Gn[o].call(u,e,c,u.opts))return r;return x.map(c,Zn,u),x.isFunction(u.opts.start)&&u.opts.start.call(e,u),x.fx.timer(x.extend(l,{elem:e,anim:u,queue:u.opts.queue})),u.progress(u.opts.progress).done(u.opts.done,u.opts.complete).fail(u.opts.fail).always(u.opts.always)}function tr(e,t){var n,r,i,o,a;for(n in e)if(r=x.camelCase(n),i=t[r],o=e[n],x.isArray(o)&&(i=o[1],o=e[n]=o[0]),n!==r&&(e[r]=o,delete e[n]),a=x.cssHooks[r],a&&"expand"in a){o=a.expand(o),delete e[r];for(n in o)n
in e||(e[n]=o[n],t[n]=i)}else t[r]=i}x.Animation=x.extend(er,{tweener:function(e,t){x.isFunction(e)?(t=e,e=["*"]):e=e.split(" ");var n,r=0,i=e.length;for(;i>r;r++)n=e[r],Qn[n]=Qn[n]||[],Qn[n].unshift(t)},prefilter:function(e,t){t?Gn.unshift(e):Gn.push(e)}});function nr(e,t,n){var r,i,o,a,s,l,u=this,c={},p=e.style,f=e.nodeType&&nn(e),d=x._data(e,"fxshow");n.queue||(s=x._queueHooks(e,"fx"),null==s.unqueued&&(s.unqueued=0,l=s.empty.fire,s.empty.fire=function(){s.unqueued||l()}),s.unqueued++,u.always(function(){u.always(function(){s.unqueued--,x.queue(e,"fx").length||s.empty.fire()})})),1===e.nodeType&&("height"in t||"width"in t)&&(n.overflow=[p.overflow,p.overflowX,p.overflowY],"inline"===x.css(e,"display")&&"none"===x.css(e,"float")&&(x.support.inlineBlockNeedsLayout&&"inline"!==ln(e.nodeName)?p.zoom=1:p.display="inline-block")),n.overflow&&(p.overflow="hidden",x.support.shrinkWrapBlocks||u.always(function(){p.overflow=n.overflow[0],p.overflowX=n.overflow[1],p.overflowY=n.ove
rflow[2]}));for(r in t)if(i=t[r],Vn.exec(i)){if(delete t[r],o=o||"toggle"===i,i===(f?"hide":"show"))continue;c[r]=d&&d[r]||x.style(e,r)}if(!x.isEmptyObject(c)){d?"hidden"in d&&(f=d.hidden):d=x._data(e,"fxshow",{}),o&&(d.hidden=!f),f?x(e).show():u.done(function(){x(e).hide()}),u.done(function(){var t;x._removeData(e,"fxshow");for(t in c)x.style(e,t,c[t])});for(r in c)a=Zn(f?d[r]:0,r,u),r in d||(d[r]=a.start,f&&(a.end=a.start,a.start="width"===r||"height"===r?1:0))}}function rr(e,t,n,r,i){return new rr.prototype.init(e,t,n,r,i)}x.Tween=rr,rr.prototype={constructor:rr,init:function(e,t,n,r,i,o){this.elem=e,this.prop=n,this.easing=i||"swing",this.options=t,this.start=this.now=this.cur(),this.end=r,this.unit=o||(x.cssNumber[n]?"":"px")},cur:function(){var e=rr.propHooks[this.prop];return e&&e.get?e.get(this):rr.propHooks._default.get(this)},run:function(e){var t,n=rr.propHooks[this.prop];return this.pos=t=this.options.duration?x.easing[this.easing](e,this.options.duration*e,0,1,t
his.options.duration):e,this.now=(this.end-this.start)*t+this.start,this.options.step&&this.options.step.call(this.elem,this.now,this),n&&n.set?n.set(this):rr.propHooks._default.set(this),this}},rr.prototype.init.prototype=rr.prototype,rr.propHooks={_default:{get:function(e){var t;return null==e.elem[e.prop]||e.elem.style&&null!=e.elem.style[e.prop]?(t=x.css(e.elem,e.prop,""),t&&"auto"!==t?t:0):e.elem[e.prop]},set:function(e){x.fx.step[e.prop]?x.fx.step[e.prop](e):e.elem.style&&(null!=e.elem.style[x.cssProps[e.prop]]||x.cssHooks[e.prop])?x.style(e.elem,e.prop,e.now+e.unit):e.elem[e.prop]=e.now}}},rr.propHooks.scrollTop=rr.propHooks.scrollLeft={set:function(e){e.elem.nodeType&&e.elem.parentNode&&(e.elem[e.prop]=e.now)}},x.each(["toggle","show","hide"],function(e,t){var n=x.fn[t];x.fn[t]=function(e,r,i){return null==e||"boolean"==typeof e?n.apply(this,arguments):this.animate(ir(t,!0),e,r,i)}}),x.fn.extend({fadeTo:function(e,t,n,r){return this.filter(nn).css("opacity",0).show()
.end().animate({opacity:t},e,n,r)},animate:function(e,t,n,r){var i=x.isEmptyObject(e),o=x.speed(t,n,r),a=function(){var t=er(this,x.extend({},e),o);(i||x._data(this,"finish"))&&t.stop(!0)};return a.finish=a,i||o.queue===!1?this.each(a):this.queue(o.queue,a)},stop:function(e,n,r){var i=function(e){var t=e.stop;delete e.stop,t(r)};return"string"!=typeof e&&(r=n,n=e,e=t),n&&e!==!1&&this.queue(e||"fx",[]),this.each(function(){var t=!0,n=null!=e&&e+"queueHooks",o=x.timers,a=x._data(this);if(n)a[n]&&a[n].stop&&i(a[n]);else for(n in a)a[n]&&a[n].stop&&Jn.test(n)&&i(a[n]);for(n=o.length;n--;)o[n].elem!==this||null!=e&&o[n].queue!==e||(o[n].anim.stop(r),t=!1,o.splice(n,1));(t||!r)&&x.dequeue(this,e)})},finish:function(e){return e!==!1&&(e=e||"fx"),this.each(function(){var t,n=x._data(this),r=n[e+"queue"],i=n[e+"queueHooks"],o=x.timers,a=r?r.length:0;for(n.finish=!0,x.queue(this,e,[]),i&&i.stop&&i.stop.call(this,!0),t=o.length;t--;)o[t].elem===this&&o[t].queue===e&&(o[t].anim.stop(!0)
,o.splice(t,1));for(t=0;a>t;t++)r[t]&&r[t].finish&&r[t].finish.call(this);delete n.finish})}});function ir(e,t){var n,r={height:e},i=0;for(t=t?1:0;4>i;i+=2-t)n=Zt[i],r["margin"+n]=r["padding"+n]=e;return t&&(r.opacity=r.width=e),r}x.each({slideDown:ir("show"),slideUp:ir("hide"),slideToggle:ir("toggle"),fadeIn:{opacity:"show"},fadeOut:{opacity:"hide"},fadeToggle:{opacity:"toggle"}},function(e,t){x.fn[e]=function(e,n,r){return this.animate(t,e,n,r)}}),x.speed=function(e,t,n){var r=e&&"object"==typeof e?x.extend({},e):{complete:n||!n&&t||x.isFunction(e)&&e,duration:e,easing:n&&t||t&&!x.isFunction(t)&&t};return r.duration=x.fx.off?0:"number"==typeof r.duration?r.duration:r.duration in x.fx.speeds?x.fx.speeds[r.duration]:x.fx.speeds._default,(null==r.queue||r.queue===!0)&&(r.queue="fx"),r.old=r.complete,r.complete=function(){x.isFunction(r.old)&&r.old.call(this),r.queue&&x.dequeue(this,r.queue)},r},x.easing={linear:function(e){return e},swing:function(e){return.5-Math.cos(e*Math.
PI)/2}},x.timers=[],x.fx=rr.prototype.init,x.fx.tick=function(){var e,n=x.timers,r=0;for(Xn=x.now();n.length>r;r++)e=n[r],e()||n[r]!==e||n.splice(r--,1);n.length||x.fx.stop(),Xn=t},x.fx.timer=function(e){e()&&x.timers.push(e)&&x.fx.start()},x.fx.interval=13,x.fx.start=function(){Un||(Un=setInterval(x.fx.tick,x.fx.interval))},x.fx.stop=function(){clearInterval(Un),Un=null},x.fx.speeds={slow:600,fast:200,_default:400},x.fx.step={},x.expr&&x.expr.filters&&(x.expr.filters.animated=function(e){return x.grep(x.timers,function(t){return e===t.elem}).length}),x.fn.offset=function(e){if(arguments.length)return e===t?this:this.each(function(t){x.offset.setOffset(this,e,t)});var n,r,o={top:0,left:0},a=this[0],s=a&&a.ownerDocument;if(s)return n=s.documentElement,x.contains(n,a)?(typeof a.getBoundingClientRect!==i&&(o=a.getBoundingClientRect()),r=or(s),{top:o.top+(r.pageYOffset||n.scrollTop)-(n.clientTop||0),left:o.left+(r.pageXOffset||n.scrollLeft)-(n.clientLeft||0)}):o},x.offset={setOf
fset:function(e,t,n){var r=x.css(e,"position");"static"===r&&(e.style.position="relative");var i=x(e),o=i.offset(),a=x.css(e,"top"),s=x.css(e,"left"),l=("absolute"===r||"fixed"===r)&&x.inArray("auto",[a,s])>-1,u={},c={},p,f;l?(c=i.position(),p=c.top,f=c.left):(p=parseFloat(a)||0,f=parseFloat(s)||0),x.isFunction(t)&&(t=t.call(e,n,o)),null!=t.top&&(u.top=t.top-o.top+p),null!=t.left&&(u.left=t.left-o.left+f),"using"in t?t.using.call(e,u):i.css(u)}},x.fn.extend({position:function(){if(this[0]){var e,t,n={top:0,left:0},r=this[0];return"fixed"===x.css(r,"position")?t=r.getBoundingClientRect():(e=this.offsetParent(),t=this.offset(),x.nodeName(e[0],"html")||(n=e.offset()),n.top+=x.css(e[0],"borderTopWidth",!0),n.left+=x.css(e[0],"borderLeftWidth",!0)),{top:t.top-n.top-x.css(r,"marginTop",!0),left:t.left-n.left-x.css(r,"marginLeft",!0)}}},offsetParent:function(){return this.map(function(){var e=this.offsetParent||s;while(e&&!x.nodeName(e,"html")&&"static"===x.css(e,"position"))e=e.of
fsetParent;return e||s})}}),x.each({scrollLeft:"pageXOffset",scrollTop:"pageYOffset"},function(e,n){var r=/Y/.test(n);x.fn[e]=function(i){return x.access(this,function(e,i,o){var a=or(e);return o===t?a?n in a?a[n]:a.document.documentElement[i]:e[i]:(a?a.scrollTo(r?x(a).scrollLeft():o,r?o:x(a).scrollTop()):e[i]=o,t)},e,i,arguments.length,null)}});function or(e){return x.isWindow(e)?e:9===e.nodeType?e.defaultView||e.parentWindow:!1}x.each({Height:"height",Width:"width"},function(e,n){x.each({padding:"inner"+e,content:n,"":"outer"+e},function(r,i){x.fn[i]=function(i,o){var a=arguments.length&&(r||"boolean"!=typeof i),s=r||(i===!0||o===!0?"margin":"border");return x.access(this,function(n,r,i){var o;return x.isWindow(n)?n.document.documentElement["client"+e]:9===n.nodeType?(o=n.documentElement,Math.max(n.body["scroll"+e],o["scroll"+e],n.body["offset"+e],o["offset"+e],o["client"+e])):i===t?x.css(n,r,s):x.style(n,r,i,s)},n,a?i:t,a,null)}})}),x.fn.size=function(){return this.length
},x.fn.andSelf=x.fn.addBack,"object"==typeof module&&module&&"object"==typeof module.exports?module.exports=x:(e.jQuery=e.$=x,"function"==typeof define&&define.amd&&define("jquery",[],function(){return x}))})(window);
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme
___________________________________________________________________
Added: bugtraq:number
+ true
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default
+ true
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,9 @@
+.olLayerGoogleCopyright {
+ right: 3px;
+ bottom: 2px;
+ left: auto;
+.olLayerGooglePoweredBy {
+ left: 2px;
+ bottom: 2px;
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.tidy.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.tidy.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/google.tidy.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1 @@
+.olLayerGoogleCopyright{right:3px;bottom:2px;left:auto;}.olLayerGooglePoweredBy{left:2px;bottom:2px;}
\ No newline at end of file
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,10 @@
+.olControlZoomPanel div {
+ background-image: url(img/zoom-panel-NOALPHA.png);
+.olControlPanPanel div {
+ background-image: url(img/pan-panel-NOALPHA.png);
+.olControlEditingToolbar {
+ width: 200px;
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.tidy.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.tidy.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/ie6-style.tidy.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1 @@
+.olControlZoomPanel div{background-image:url(img/zoom-panel-NOALPHA.png);}.olControlPanPanel div{background-image:url(img/pan-panel-NOALPHA.png);}.olControlEditingToolbar{width:200px;}
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img
+ true
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/add_point_off.png
(Binary files differ)
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/add_point_off.png
Added: svn:mime-type
+ application/octet-stream
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/add_point_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/add_point_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/blank.gif
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/blank.gif
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/close.gif
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/close.gif
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/drag-rectangle-off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/drag-rectangle-off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/drag-rectangle-on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/drag-rectangle-on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_line_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_line_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_line_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_line_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_point_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_point_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_point_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_point_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_polygon_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_polygon_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_polygon_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/draw_polygon_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/editing_tool_bar.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/editing_tool_bar.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/move_feature_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/move_feature_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/move_feature_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/move_feature_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/navigation_history.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/navigation_history.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/overview_replacement.gif
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/overview_replacement.gif
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan-panel-NOALPHA.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan-panel-NOALPHA.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan-panel.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan-panel.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/pan_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/panning-hand-off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/panning-hand-off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/panning-hand-on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/panning-hand-on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/remove_point_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/remove_point_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/remove_point_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/remove_point_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/ruler.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/ruler.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/save_features_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/save_features_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/save_features_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/save_features_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_next_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_next_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_next_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_next_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_previous_off.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_previous_off.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_previous_on.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/view_previous_on.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/zoom-panel-NOALPHA.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/zoom-panel-NOALPHA.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/zoom-panel.png
Property changes on: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/img/zoom-panel.png
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,516 @@
+div.olMap {
+ z-index: 0;
+ padding: 0 !important;
+ margin: 0 !important;
+ cursor: default;
+div.olMapViewport {
+ text-align: left;
+ -ms-touch-action: none;
+div.olLayerDiv {
+ -moz-user-select: none;
+ -khtml-user-select: none;
+ left: 2px;
+ bottom: 2px;
+.olLayerGoogleV3.olLayerGoogleCopyright {
+ right: auto !important;
+ left: 2px;
+ bottom: 15px;
+.olLayerGoogleV3.olLayerGooglePoweredBy {
+ bottom: 15px !important;
+/* GMaps should not set styles on its container */
+.olForeignContainer {
+ opacity: 1 !important;
+.olControlAttribution {
+ font-size: smaller;
+ right: 3px;
+ bottom: 4.5em;
+ position: absolute;
+ display: block;
+.olControlScale {
+ right: 3px;
+ bottom: 3em;
+ display: block;
+.olControlScaleLine {
+ display: block;
+ left: 10px;
+ bottom: 15px;
+ font-size: xx-small;
+.olControlScaleLineBottom {
+ border: solid 2px black;
+ border-bottom: none;
+ margin-top:-2px;
+ text-align: center;
+.olControlScaleLineTop {
+ border-top: none;
+.olControlPermalink {
+ right: 3px;
+ bottom: 1.5em;
+ display: block;
+div.olControlMousePosition {
+ bottom: 0;
+ right: 3px;
+ display: block;
+ font-family: Arial;
+.olControlOverviewMapContainer {
+ bottom: 0;
+ right: 0;
+.olControlOverviewMapElement {
+ padding: 10px 18px 10px 10px;
+ background-color: #00008B;
+ -moz-border-radius: 1em 0 0 0;
+.olControlOverviewMapMinimizeButton,
+.olControlOverviewMapMaximizeButton {
+ height: 18px;
+ width: 18px;
+ right: 0;
+ bottom: 80px;
+ cursor: pointer;
+.olControlOverviewMapExtentRectangle {
+ overflow: hidden;
+ background-image: url("img/blank.gif");
+ cursor: move;
+ border: 2px dotted red;
+.olControlOverviewMapRectReplacement {
+ overflow: hidden;
+ cursor: move;
+ background-image: url("img/overview_replacement.gif");
+ background-repeat: no-repeat;
+ background-position: center;
+.olLayerGeoRSSDescription {
+ float:left;
+ width:100%;
+ overflow:auto;
+ font-size:1.0em;
+.olLayerGeoRSSClose {
+ float:right;
+ color:gray;
+ font-size:1.2em;
+ margin-right:6px;
+ font-family:sans-serif;
+.olLayerGeoRSSTitle {
+ float:left;font-size:1.2em;
+.olPopupContent {
+ padding:5px;
+ overflow: auto;
+.olControlNavigationHistory {
+ background-image: url("img/navigation_history.png");
+ width: 24px;
+ height: 24px;
+.olControlNavigationHistoryPreviousItemActive {
+ background-position: 0 0;
+.olControlNavigationHistoryPreviousItemInactive {
+ background-position: 0 -24px;
+.olControlNavigationHistoryNextItemActive {
+ background-position: -24px 0;
+.olControlNavigationHistoryNextItemInactive {
+ background-position: -24px -24px;
+div.olControlSaveFeaturesItemActive {
+ background-image: url(img/save_features_on.png);
+ background-position: 0 1px;
+div.olControlSaveFeaturesItemInactive {
+ background-image: url(img/save_features_off.png);
+.olHandlerBoxZoomBox {
+ border: 2px solid red;
+ background-color: white;
+ opacity: 0.50;
+ font-size: 1px;
+ filter: alpha(opacity=50);
+.olHandlerBoxSelectFeature {
+ border: 2px solid blue;
+ opacity: 0.50;
+ font-size: 1px;
+.olControlPanPanel {
+ top: 10px;
+ left: 5px;
+ background-image: url(img/pan-panel.png);
+ height: 18px;
+ width: 18px;
+ cursor: pointer;
+.olControlPanPanel .olControlPanNorthItemInactive {
+ top: 0;
+ left: 9px;
+.olControlPanPanel .olControlPanSouthItemInactive {
+ top: 36px;
+ left: 9px;
+ background-position: 18px 0;
+.olControlPanPanel .olControlPanWestItemInactive {
+ top: 18px;
+ left: 0;
+ background-position: 0 18px;
+.olControlPanPanel .olControlPanEastItemInactive {
+ top: 18px;
+ left: 18px;
+ background-position: 18px 18px;
+.olControlZoomPanel {
+ top: 71px;
+ left: 14px;
+ background-image: url(img/zoom-panel.png);
+ height: 18px;
+ width: 18px;
+ cursor: pointer;
+.olControlZoomPanel .olControlZoomInItemInactive {
+ top: 0;
+ left: 0;
+.olControlZoomPanel .olControlZoomToMaxExtentItemInactive {
+ top: 18px;
+ left: 0;
+ background-position: 0 -18px;
+.olControlZoomPanel .olControlZoomOutItemInactive {
+ top: 36px;
+ left: 0;
+ * When a potential text is bigger than the image it move the image
+ * with some headers (closes #3154)
+.olControlPanZoomBar div {
+ font-size: 1px;
+.olPopupCloseBox {
+ background: url("img/close.gif") no-repeat;
+ cursor: pointer;
+.olFramedCloudPopupContent {
+ padding: 5px;
+ overflow: auto;
+.olControlNoSelect {
+.olImageLoadError {
+ background-color: pink;
+ opacity: 0.5;
+ filter: alpha(opacity=50); /* IE */
+ * Cursor styles
+.olCursorWait {
+ cursor: wait;
+.olDragDown {
+ cursor: move;
+.olDrawBox {
+ cursor: crosshair;
+.olControlDragFeatureOver {
+ cursor: move;
+.olControlDragFeatureActive.olControlDragFeatureOver.olDragDown {
+ cursor: -moz-grabbing;
+ * Layer switcher
+.olControlLayerSwitcher {
+ top: 25px;
+ right: 0;
+ width: 20em;
+ font-family: sans-serif;
+ font-weight: bold;
+ margin-top: 3px;
+ margin-left: 3px;
+ margin-bottom: 3px;
+ color: white;
+ background-color: transparent;
+.olControlLayerSwitcher .layersDiv {
+ padding-top: 5px;
+ padding-left: 10px;
+ padding-bottom: 5px;
+ padding-right: 10px;
+ background-color: darkblue;
+.olControlLayerSwitcher .layersDiv .baseLbl,
+.olControlLayerSwitcher .layersDiv .dataLbl {
+ margin-top: 3px;
+ margin-left: 3px;
+.olControlLayerSwitcher .layersDiv .baseLayersDiv,
+.olControlLayerSwitcher .layersDiv .dataLayersDiv {
+.olControlLayerSwitcher .maximizeDiv,
+.olControlLayerSwitcher .minimizeDiv {
+ width: 18px;
+ height: 18px;
+ top: 5px;
+ right: 0;
+ cursor: pointer;
+.olBingAttribution {
+ color: #DDD;
+.olBingAttribution.road {
+ color: #333;
+.olGoogleAttribution.hybrid, .olGoogleAttribution.satellite {
+ color: #EEE;
+.olGoogleAttribution {
+ color: #333;
+span.olGoogleAttribution a {
+ color: #77C;
+span.olGoogleAttribution.hybrid a, span.olGoogleAttribution.satellite a {
+ color: #EEE;
+ * Editing and navigation icons.
+ * (using the editing_tool_bar.png sprint image)
+.olControlNavToolbar ,
+ margin: 5px 5px 0 0;
+.olControlNavToolbar div,
+.olControlEditingToolbar div {
+ background-image: url("img/editing_tool_bar.png");
+ margin: 0 0 5px 5px;
+ width: 24px;
+ height: 22px;
+ cursor: pointer
+/* positions */
+ right: 0;
+ top: 0;
+.olControlNavToolbar {
+ top: 295px;
+ left: 9px;
+/* layouts */
+ float: right;
+/* individual controls */
+.olControlNavToolbar .olControlNavigationItemInactive,
+.olControlEditingToolbar .olControlNavigationItemInactive {
+ background-position: -103px -1px;
+.olControlNavToolbar .olControlNavigationItemActive ,
+.olControlEditingToolbar .olControlNavigationItemActive {
+ background-position: -103px -24px;
+.olControlNavToolbar .olControlZoomBoxItemInactive {
+ background-position: -128px -1px;
+.olControlNavToolbar .olControlZoomBoxItemActive {
+ background-position: -128px -24px;
+.olControlEditingToolbar .olControlDrawFeaturePointItemInactive {
+ background-position: -77px -1px;
+.olControlEditingToolbar .olControlDrawFeaturePointItemActive {
+ background-position: -77px -24px;
+.olControlEditingToolbar .olControlDrawFeaturePathItemInactive {
+ background-position: -51px -1px;
+.olControlEditingToolbar .olControlDrawFeaturePathItemActive {
+ background-position: -51px -24px;
+.olControlEditingToolbar .olControlDrawFeaturePolygonItemInactive{
+ background-position: -26px -1px;
+.olControlEditingToolbar .olControlDrawFeaturePolygonItemActive {
+ background-position: -26px -24px;
+div.olControlZoom {
+ top: 8px;
+ left: 8px;
+ background: rgba(255,255,255,0.4);
+ border-radius: 4px;
+ padding: 2px;
+div.olControlZoom a {
+ display: block;
+ margin: 1px;
+ padding: 0;
+ color: white;
+ font-size: 18px;
+ font-family: 'Lucida Grande', Verdana, Geneva, Lucida, Arial, Helvetica, sans-serif;
+ text-decoration: none;
+ height: 22px;
+ width:22px;
+ line-height: 19px;
+ background: #130085; /* fallback for IE - IE6 requires background shorthand*/
+ background: rgba(0, 60, 136, 0.5);
+ filter: alpha(opacity=80);
+div.olControlZoom a:hover {
+ background: #130085; /* fallback for IE */
+ background: rgba(0, 60, 136, 0.7);
+ filter: alpha(opacity=100);
+ at media only screen and (max-width: 600px) {
+ div.olControlZoom a:hover {
+a.olControlZoomIn {
+ border-radius: 4px 4px 0 0;
+a.olControlZoomOut {
+ border-radius: 0 0 4px 4px;
+ * Animations
+.olLayerGrid .olTileImage {
+ -webkit-transition: opacity 0.2s linear;
+ -moz-transition: opacity 0.2s linear;
+ -o-transition: opacity 0.2s linear;
+ transition: opacity 0.2s linear;
+/* Turn on GPU support where available */
+.olTileImage {
+ -webkit-transform: translateZ(0);
+ -moz-transform: translateZ(0);
+ -o-transform: translateZ(0);
+ -ms-transform: translateZ(0);
+ transform: translateZ(0);
+ -webkit-backface-visibility: hidden;
+ -moz-backface-visibility: hidden;
+ -ms-backface-visibility: hidden;
+ backface-visibility: hidden;
+ -webkit-perspective: 1000;
+ -moz-perspective: 1000;
+ -ms-perspective: 1000;
+ perspective: 1000;
+/* when replacing tiles, do not show tile and backbuffer at the same time */
+.olTileReplacing {
+ display: none;
+/* override any max-width image settings (e.g. bootstrap.css) */
+img.olTileImage {
+ max-width: none;
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,70 @@
+ top: 8px;
+ left: 8px;
+ padding: 2px;
+ -webkit-tap-highlight-color: rgba(0, 0, 0, 0);
+ display: block;
+ margin: 1px;
+ padding: 0;
+ color: white;
+ font-size: 28px;
+ height: 32px;
+ width: 32px;
+ line-height: 28px;
+ text-shadow: 0 0 3px rgba(0,0,0,0.8);
+.olTileImage {
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.tidy.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.tidy.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.mobile.tidy.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1 @@
+div.olControlZoom{position:absolute;top:8px;left:8px;background:rgba(255,255,255,0.4);border-radius:4px;padding:2px;}*{-webkit-tap-highlight-color:rgba(0,0,0,0);}div.olControlZoom a{display:block;color:#FFF;font-size:28px;font-family:sans-serif;font-weight:700;text-decoration:none;text-align:center;height:32px;width:32px;line-height:28px;text-shadow:0 0 3px rgba(0,0,0,0.8);background:rgba(0,60,136,0.5);filter:alpha(opacity=80);margin:1px;padding:0;}a.olControlZoomIn{border-radius:4px 4px 0 0;}a.olControlZoomOut{border-radius:0 0 4px 4px;}div.olControlZoom a:hover{background:rgba(0,60,136,0.7);filter:alpha(opacity=100);}div.olMapViewport{-ms-touch-action:none;}.olLayerGrid .olTileImage{-webkit-transition:opacity .2s linear;-moz-transition:opacity .2s linear;-o-transition:opacity .2s linear;transition:opacity .2s linear;}.olTileImage{-webkit-transform:translateZ(0);-moz-transform:translateZ(0);-o-transform:translateZ(0);-ms-transform:translateZ(0);transform:translateZ(0);-webk
it-backface-visibility:hidden;-moz-backface-visibility:hidden;-ms-backface-visibility:hidden;backface-visibility:hidden;-webkit-perspective:1000;-moz-perspective:1000;-ms-perspective:1000;perspective:1000;}@media only screen and max-width 600px{div.olControlZoom a:hover{background:rgba(0,60,136,0.5);}}
Added: trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.tidy.css
--- trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.tidy.css (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/theme/default/style.tidy.css 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1 @@
+div.olMap{z-index:0;cursor:default;margin:0!important;padding:0!important;}div.olMapViewport{text-align:left;-ms-touch-action:none;}.olLayerGoogleCopyright{left:2px;bottom:2px;}.olLayerGoogleV3.olLayerGoogleCopyright{right:auto!important;}.olLayerGooglePoweredBy{left:2px;bottom:15px;}.olLayerGoogleV3.olLayerGooglePoweredBy{bottom:15px!important;}.olForeignContainer{opacity:1!important;}.olControlAttribution{font-size:smaller;right:3px;bottom:4.5em;position:absolute;display:block;}.olControlScale{right:3px;bottom:3em;display:block;position:absolute;font-size:smaller;}.olControlScaleLine{display:block;position:absolute;left:10px;bottom:15px;font-size:xx-small;}.olControlScaleLineBottom{border:solid 2px #000;border-bottom:none;margin-top:-2px;text-align:center;}.olControlScaleLineTop{border:solid 2px #000;border-top:none;text-align:center;}.olControlPermalink{right:3px;bottom:1.5em;display:block;position:absolute;font-size:smaller;}div.olControlMousePosition{bottom:0;right:3px;
display:block;position:absolute;font-family:Arial;font-size:smaller;}.olControlOverviewMapContainer{position:absolute;bottom:0;right:0;}.olControlOverviewMapElement{background-color:#00008B;-moz-border-radius:1em 0 0;padding:10px 18px 10px 10px;}.olControlOverviewMapMinimizeButton,.olControlOverviewMapMaximizeButton{height:18px;width:18px;right:0;bottom:80px;cursor:pointer;}.olControlOverviewMapExtentRectangle{overflow:hidden;background-image:url(img/blank.gif);cursor:move;border:2px dotted red;}.olControlOverviewMapRectReplacement{overflow:hidden;cursor:move;background-image:url(img/overview_replacement.gif);background-repeat:no-repeat;background-position:center;}.olLayerGeoRSSDescription{float:left;width:100%;overflow:auto;font-size:1em;}.olLayerGeoRSSClose{float:right;color:gray;font-size:1.2em;margin-right:6px;font-family:sans-serif;}.olLayerGeoRSSTitle{float:left;font-size:1.2em;}.olControlNavigationHistory{background-image:url(img/navigation_history.png);background-rep
eat:no-repeat;width:24px;height:24px;}.olControlNavigationHistoryPreviousItemActive{background-position:0 0;}.olControlNavigationHistoryPreviousItemInactive{background-position:0 -24px;}.olControlNavigationHistoryNextItemActive{background-position:-24px 0;}.olControlNavigationHistoryNextItemInactive{background-position:-24px -24px;}div.olControlSaveFeaturesItemActive{background-image:url(img/save_features_on.png);background-repeat:no-repeat;background-position:0 1px;}div.olControlSaveFeaturesItemInactive{background-image:url(img/save_features_off.png);background-repeat:no-repeat;background-position:0 1px;}.olHandlerBoxZoomBox{border:2px solid red;position:absolute;background-color:#FFF;opacity:.5;font-size:1px;filter:alpha(opacity=50);}.olHandlerBoxSelectFeature{border:2px solid blue;position:absolute;background-color:#FFF;opacity:.5;font-size:1px;filter:alpha(opacity=50);}.olControlPanPanel{top:10px;left:5px;}.olControlPanPanel div{background-image:url(img/pan-panel.png);he
ight:18px;width:18px;cursor:pointer;position:absolute;}.olControlPanPanel .olControlPanNorthItemInactive{top:0;left:9px;background-position:0 0;}.olControlPanPanel .olControlPanSouthItemInactive{top:36px;left:9px;background-position:18px 0;}.olControlPanPanel .olControlPanWestItemInactive{position:absolute;top:18px;left:0;background-position:0 18px;}.olControlPanPanel .olControlPanEastItemInactive{top:18px;left:18px;background-position:18px 18px;}.olControlZoomPanel{top:71px;left:14px;}.olControlZoomPanel div{background-image:url(img/zoom-panel.png);position:absolute;height:18px;width:18px;cursor:pointer;}.olControlZoomPanel .olControlZoomInItemInactive{top:0;left:0;background-position:0 0;}.olControlZoomPanel .olControlZoomToMaxExtentItemInactive{top:18px;left:0;background-position:0 -18px;}.olControlZoomPanel .olControlZoomOutItemInactive{top:36px;left:0;background-position:0 18px;}.olControlPanZoomBar div{font-size:1px;}.olPopupCloseBox{background:url(img/close.gif) no-re
peat;cursor:pointer;}.olImageLoadError{background-color:#FFC0CB;opacity:.5;filter:alpha(opacity=50);}.olCursorWait{cursor:wait;}.olDrawBox{cursor:crosshair;}.olControlDragFeatureActive.olControlDragFeatureOver.olDragDown{cursor:0;}.olControlLayerSwitcher{position:absolute;top:25px;right:0;width:20em;font-family:sans-serif;font-weight:700;margin-top:3px;margin-left:3px;margin-bottom:3px;font-size:smaller;color:#FFF;background-color:transparent;}.olControlLayerSwitcher .layersDiv{background-color:#00008B;padding:5px 10px;}.olControlLayerSwitcher .layersDiv .baseLbl,.olControlLayerSwitcher .layersDiv .dataLbl{margin-top:3px;margin-left:3px;margin-bottom:3px;}.olControlLayerSwitcher .layersDiv .baseLayersDiv,.olControlLayerSwitcher .layersDiv .dataLayersDiv{padding-left:10px;}.olControlLayerSwitcher .maximizeDiv,.olControlLayerSwitcher .minimizeDiv{width:18px;height:18px;top:5px;right:0;cursor:pointer;}.olBingAttribution{color:#DDD;}span.olGoogleAttribution a{color:#77C;}.olCont
rolNavToolbar,.olControlEditingToolbar{margin:5px 5px 0 0;}.olControlNavToolbar div,.olControlEditingToolbar div{background-image:url(img/editing_tool_bar.png);background-repeat:no-repeat;width:24px;height:22px;cursor:pointer;margin:0 0 5px 5px;}.olControlEditingToolbar{right:0;top:0;}.olControlNavToolbar{top:295px;left:9px;}.olControlEditingToolbar div{float:right;}.olControlNavToolbar .olControlNavigationItemInactive,.olControlEditingToolbar .olControlNavigationItemInactive{background-position:-103px -1px;}.olControlNavToolbar .olControlNavigationItemActive,.olControlEditingToolbar .olControlNavigationItemActive{background-position:-103px -24px;}.olControlNavToolbar .olControlZoomBoxItemInactive{background-position:-128px -1px;}.olControlNavToolbar .olControlZoomBoxItemActive{background-position:-128px -24px;}.olControlEditingToolbar .olControlDrawFeaturePointItemInactive{background-position:-77px -1px;}.olControlEditingToolbar .olControlDrawFeaturePointItemActive{backgrou
nd-position:-77px -24px;}.olControlEditingToolbar .olControlDrawFeaturePathItemInactive{background-position:-51px -1px;}.olControlEditingToolbar .olControlDrawFeaturePathItemActive{background-position:-51px -24px;}.olControlEditingToolbar .olControlDrawFeaturePolygonItemInactive{background-position:-26px -1px;}.olControlEditingToolbar .olControlDrawFeaturePolygonItemActive{background-position:-26px -24px;}div.olControlZoom{position:absolute;top:8px;left:8px;background:rgba(255,255,255,0.4);border-radius:4px;padding:2px;}div.olControlZoom a{display:block;color:#FFF;font-size:18px;font-family:'Lucida Grande', Verdana, Geneva, Lucida, Arial, Helvetica, sans-serif;font-weight:700;text-decoration:none;text-align:center;height:22px;width:22px;line-height:19px;background:rgba(0,60,136,0.5);filter:alpha(opacity=80);margin:1px;padding:0;}div.olControlZoom a:hover{background:rgba(0,60,136,0.7);filter:alpha(opacity=100);}a.olControlZoomIn{border-radius:4px 4px 0 0;}a.olControlZoomOut{b
order-radius:0 0 4px 4px;}.olLayerGrid .olTileImage{-webkit-transition:opacity .2s linear;-moz-transition:opacity .2s linear;-o-transition:opacity .2s linear;transition:opacity .2s linear;}.olTileImage{-webkit-transform:translateZ(0);-moz-transform:translateZ(0);-o-transform:translateZ(0);-ms-transform:translateZ(0);transform:translateZ(0);-webkit-backface-visibility:hidden;-moz-backface-visibility:hidden;-ms-backface-visibility:hidden;backface-visibility:hidden;-webkit-perspective:1000;-moz-perspective:1000;-ms-perspective:1000;perspective:1000;}.olTileReplacing{display:none;}img.olTileImage{max-width:none;}div.olLayerDiv,.olControlNoSelect{-khtml-user-select:none;-moz-user-select:none;}.olPopupContent,.olFramedCloudPopupContent{overflow:auto;padding:5px;}.olDragDown,.olControlDragFeatureOver{cursor:move;}.olBingAttribution.road,.olGoogleAttribution{color:#333;}.olGoogleAttribution.hybrid,.olGoogleAttribution.satellite,span.olGoogleAttribution.hybrid a,span.olGoogleAttribut
ion.satellite a{color:#EEE;}@media only screen and max-width 600px{div.olControlZoom a:hover{background:rgba(0,60,136,0.5);}}
Property changes on: trunk/MgDev/Doc/samples/ol2samples/commercial
+ true
Property changes on: trunk/MgDev/Doc/samples/ol2samples/querymap
+ true
Property changes on: trunk/MgDev/Doc/samples/ol2samples/selection
+ true
Property changes on: trunk/MgDev/Doc/samples/ol2samples/tiled
+ true
Added: trunk/MgDev/Doc/samples/ol2samples/tiled/index.html
--- trunk/MgDev/Doc/samples/ol2samples/tiled/index.html (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/tiled/index.html 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,170 @@
+<html>
+ <head>
+ <title>CreateRuntimeMap Example</title>
+ <link rel="stylesheet" href="http://openlayers.org/api/2.13-rc3/theme/default/style.css" />
+ <style type="text/css">
+ #error { color: red; }
+ #wrap { width: 900; }
+ #map { width: 650; height: 500; float: right; }
+ #layers { width: 250; height: 500; overflow: auto; display: block-inline; float: left; }
+ #rootList { list-style-type: none; margin-left: -20px; }
+ #rootList li { list-style-type: none; }
+ </style>
+ <script type="text/javascript" src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
+ <script type="text/javascript" src="http://openlayers.org/api/2.13-rc3/OpenLayers.js"></script>
+ <script type="text/javascript">
+ var mapAgentUrl = "../mapagent/mapagent.fcgi";
+ //Various features you can include in the CREATERUNTIMEMAP response.
+ var REQ_NONE = 0; //Nothing. This the default.
+ var REQ_LAYER_STRUCTURE = 1; //Information about layers and groups (required for the mask values below to have any effect)
+ var REQ_LAYER_ICONS = 2; //Icons for each layer (has no effect if REQ_LAYER_STRUCTURE is not in the bitmask)
+ var REQ_LAYER_FEATURE_SOURCE = 4; //Feature Source information for each layer (has no effect if REQ_LAYER_STRUCTURE is not in the bitmask)
+ var gMimeType = null;
+ var map = null;
+ $(document).ready(function() {
+ OpenLayers.Control.DragPan.prototype.enableKinetic = false;
+ //Have a play with the bitmask values to see the differences in JSON payload size
+ //and to see how our legend control gracefully handles such situations
+ createMap(REQ_NONE);
+ //createMap(REQ_LAYER_STRUCTURE);
+ //createMap(REQ_LAYER_STRUCTURE | REQ_LAYER_FEATURE_SOURCE | REQ_LAYER_ICONS);
+ function createMap(reqFeatures) {
+ $.getJSON(mapAgentUrl, {
+ "OPERATION": "CREATERUNTIMEMAP",
+ "VERSION": "2.6.0",
+ "MAPDEFINITION": "Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition",
+ "USERNAME": "Anonymous", //Or you can use "SESSION": "<my session id>"
+ "REQUESTEDFEATURES": reqFeatures,
+ //Optional parameters you can specify and/or experiment with
+ //"ICONFORMAT": "GIF", //Uncomment to override desired image format (default: PNG)
+ //"ICONWIDTH": 32, //Uncomment to override desired icon width (default: 16)
+ //"ICONHEIGHT": 32, //Uncomment to override desired icon height (default: 16)
+ //"ICONSPERSCALERANGE": 3, //Uncomment to observe theme compression for themes exceeding this number of rules (default: 25)
+ //"TARGETMAPNAME": "MyRuntimeMapForOpenLayers", //Uncomment if you require a specific map name be given (default: inferred from Map Definition)
+ "FORMAT": "application/json"
+ }, function(data, textStatus, jqXHR) {
+ $("#jsonSize").html(jqXHR.responseText.length);
+ loadMap(data);
+ }).error(function(jqXHR, textStatus, errorThrown) {
+ $("#error").html(jqXHR.responseText);
+ function loadMap(rtMapInfo) {
+ if (rtMapInfo.RuntimeMap.IconMimeType) {
+ gMimeType = rtMapInfo.RuntimeMap.IconMimeType[0];
+ $("#iconFormat").html(gMimeType);
+ var extent = new OpenLayers.Bounds(
+ parseFloat(rtMapInfo.RuntimeMap.Extents[0].LowerLeftCoordinate[0].X[0]),
+ parseFloat(rtMapInfo.RuntimeMap.Extents[0].LowerLeftCoordinate[0].Y[0]),
+ parseFloat(rtMapInfo.RuntimeMap.Extents[0].UpperRightCoordinate[0].X[0]),
+ parseFloat(rtMapInfo.RuntimeMap.Extents[0].UpperRightCoordinate[0].Y[0]));
+ OpenLayers.Control.CustomNavToolbar = OpenLayers.Class(OpenLayers.Control.Panel, {
+ * Constructor: OpenLayers.Control.NavToolbar
+ * Add our two mousedefaults controls.
+ * Parameters:
+ * options - {Object} An optional object whose properties will be used
+ * to extend the control.
+ initialize: function(options) {
+ OpenLayers.Control.Panel.prototype.initialize.apply(this, [options]);
+ this.addControls([
+ new OpenLayers.Control.Navigation(),
+ //Here it come
+ new OpenLayers.Control.ZoomBox({alwaysZoom:true})
+ // To make the custom navtoolbar use the regular navtoolbar style
+ this.displayClass = 'olControlNavToolbar'
+ * Method: draw
+ * calls the default draw, and then activates mouse defaults.
+ draw: function() {
+ var div = OpenLayers.Control.Panel.prototype.draw.apply(this, arguments);
+ this.defaultControl = this.controls[0];
+ return div;
+ var finiteScales = [];
+ if (rtMapInfo.RuntimeMap.FiniteDisplayScale) {
+ for (var i = rtMapInfo.RuntimeMap.FiniteDisplayScale.length - 1; i >= 0; i--) {
+ finiteScales.push(parseFloat(rtMapInfo.RuntimeMap.FiniteDisplayScale[i]));
+ var mapOptions = {
+ theme: null,
+ maxExtent: extent,
+ scales: finiteScales,
+ maxResolution: 'auto',
+ controls: [
+ new OpenLayers.Control.Attribution(),
+ new OpenLayers.Control.Zoom(),
+ new OpenLayers.Control.ScaleLine(),
+ new OpenLayers.Control.MousePosition(),
+ new OpenLayers.Control.LayerSwitcher({ div: $("#layers")[0] }),
+ new OpenLayers.Control.CustomNavToolbar({alwaysZoom:true})
+ if (rtMapInfo.RuntimeMap.CoordinateSystem[0].EpsgCode[0].length > 0) {
+ mapOptions.projection = "EPSG:" + rtMapInfo.RuntimeMap.CoordinateSystem[0].EpsgCode[0];
+ var options = {
+ isBaseLayer: true,
+ transitionEffect: "resize",
+ buffer: 1,
+ useOverlay: true,
+ useAsyncOverlay: true,
+ singleTile: true
+ map = new OpenLayers.Map('map', mapOptions );
+ for (var i = 0; i < rtMapInfo.RuntimeMap.Group.length; i++) {
+ var group = rtMapInfo.RuntimeMap.Group[i];
+ if (group.Type[0] == "2") { //MgLayerGroupType.BaseMap
+ var layer = new OpenLayers.Layer.MapGuide("MapGuide base layer group via CREATERUNTIMEMAP: " + group.Name[0], mapAgentUrl + "?USERNAME=Anonymous", {
+ mapdefinition: rtMapInfo.RuntimeMap.MapDefinition[0],
+ basemaplayergroupname: group.Name[0]
+ singleTile: false
+ map.addLayer(layer);
+ map.zoomToMaxExtent();
+ </script>
+ </head>
+ <body>
+ <p>This map was created from the JSON response of the new CREATERUNTIMEMAP operation</p>
+ <p>No more hard-coding values or needing MapGuide Web Extensions API to provide missing values required by OpenLayers. CREATERUNTIMEMAP gives you all of this information</p>
+ <p>This is all pure OpenLayers and the mapagent. No .net/PHP/Java Web API glue was involved in creating this sample!</p>
+ <div id="error">
+ </div>
+ <div id="wrap">
+ <div id="layers">
+ </div>
+ <div id="map">
+ </div>
+ </div>
+ <div style="clear:both"></div>
+ <p>JSON payload for CREATERUNTIMEMAP is: <span id="jsonSize"></span> characters</p>
+ <p>Icon format is: <span id="iconFormat"></span></p>
+ <p id="mapName"></p>
+ <p id="mgSession"></p>
+ </body>
+</html>
Property changes on: trunk/MgDev/Doc/samples/ol2samples/untiled
+ true
Added: trunk/MgDev/Doc/samples/ol2samples/untiled/index.html
--- trunk/MgDev/Doc/samples/ol2samples/untiled/index.html (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/untiled/index.html 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,342 @@
+<html>
+ <head>
+ <link rel="stylesheet" href="../assets/theme/default/style.css" />
+ #details { width: 250; height: 500; overflow: auto; display: block-inline; float: left; }
+ </style>
+ <script type="text/javascript" src="../assets/jquery-1.10.2.min.js"></script>
+ <script type="text/javascript" src="../assets/OpenLayers.js"></script>
+ var map = null;
+ var mgLayer = null;
+ var sessionId = null;
+ //createMap(REQ_NONE);
+ createMap(REQ_LAYER_STRUCTURE | REQ_LAYER_FEATURE_SOURCE | REQ_LAYER_ICONS);
+ "MAPDEFINITION": "Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition",
+ loadMap(data);
+ * Parameters:
+ //Here it come
+ * Method: draw
+ return div;
+ theme: null,
+ controls: [
+ var options = {
+ buffer: 1,
+ useOverlay: true,
+ singleTile: true
+ var params = {
+ mapname: rtMapInfo.RuntimeMap.Name[0],
+ session: rtMapInfo.RuntimeMap.SessionId[0],
+ selectioncolor: '0xFF000000',
+ behavior: 2
+ sessionId = rtMapInfo.RuntimeMap.SessionId[0];
+ //Adjust the scale assumptions for MapGuide layers
+ //Tiled layers MUST use a DPI value of 96, untiled layers can use a
+ //different DPI value which will be passed to the server as a parameter.
+ //Tiled and untiled layers must adjust the OL INCHES_PER_UNIT values
+ //for any degree-based projections.
+ //You'll still need to do these adjustments manually, but CREATERUNTIMEMAP
+ //now provides the necessary meters-per-unit value for you to do this.
+ var metersPerUnit = parseFloat(rtMapInfo.RuntimeMap.CoordinateSystem[0].MetersPerUnit[0]);
+ var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
+ OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
+ OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
+ OpenLayers.DOTS_PER_INCH = 96;
+ mgLayer = new OpenLayers.Layer.MapGuide( "MapGuide (from CREATERUNTIMEMAP)", mapAgentUrl, params, options );
+ map.addLayer(mgLayer);
+ var groupElMap = {};
+ if (rtMapInfo.RuntimeMap.Group) {
+ var remainingGroups = {};
+ $("#noLayerStructure").hide();
+ //1st pass, un-parented groups
+ if (group.ParentId) {
+ remainingGroups[group.ObjectId[0]] = group;
+ continue;
+ var el = createGroupElement(group);
+ groupElMap[group.ObjectId[0]] = el;
+ $("#rootList").append(el);
+ //2nd pass, parented groups
+ var itemCount = 0;
+ for (var objId in remainingGroups) {
+ itemCount++;
+ //Whittle down
+ while(itemCount > 0) {
+ var removeIds = [];
+ var group = remainingGroups[objId];
+ //Do we have a parent?
+ if (typeof(groupElMap[group.ParentId[0]]) != 'undefined') {
+ groupElMap[group.ParentId[0]].find("ul.groupChildren").append(el);
+ removeIds.push(group.ObjectId[0]);
+ for (var i = 0; i < removeIds.length; i++) {
+ delete remainingGroups[removeIds[i]];
+ itemCount = 0;
+ itemCount++;
+ if (rtMapInfo.RuntimeMap.Layer) {
+ for (var i = 0; i < rtMapInfo.RuntimeMap.Layer.length; i++) {
+ var layer = rtMapInfo.RuntimeMap.Layer[i];
+ var el = createLayerElement(layer);
+ if (layer.ParentId) {
+ groupElMap[layer.ParentId[0]].find("ul.groupChildren").append(el);
+ } else {
+ $("#mapName").html("MapGuide mapname: " + rtMapInfo.RuntimeMap.Name[0]);
+ $("#mgSession").html("MapGuide session ID: " + sessionId);
+ $("div.olMap").css("background-color", "#" + rtMapInfo.RuntimeMap.BackgroundColor[0].substring(2));
+ $("input.group-checkbox").change(function() {
+ var bShow = $(this).is(":checked");
+ var objId = $(this).val();
+ showGroup(objId, bShow);
+ $("input.layer-checkbox").change(function() {
+ showLayer(objId, bShow);
+ startKeepAlive();
+ function startKeepAlive() {
+ var keepAlive = function() {
+ $.get(mapAgentUrl, {
+ "OPERATION": "GETSESSIONTIMEOUT",
+ "VERSION": "1.0.0",
+ "SESSION": sessionId
+ }, function(data, textStatus, jxXHR) {
+ $("#mgSession").html("MapGuide session ID: " + sessionId + " (last checked at: " + (new Date()) + ")");
+ setTimeout(keepAlive, parseInt(data) * 1000);
+ keepAlive();
+ var req = {
+ showgroups: null,
+ showlayers: null,
+ hidegroups: null,
+ hidelayers: null
+ function resetRequest() {
+ req.showgroups = null;
+ req.showlayers = null;
+ req.hidegroups = null;
+ req.hidelayers = null;
+ function showGroup(groupId, bShow) {
+ resetRequest();
+ if (bShow)
+ req.showgroups = groupId;
+ else
+ req.hidegroups = groupId;
+ mgLayer.mergeNewParams(req);
+ function showLayer(layerId, bShow) {
+ resetRequest();
+ if (bShow)
+ req.showlayers = layerId;
+ else
+ req.hidelayers = layerId;
+ function createGroupElement(group) {
+ return $("<li><input type='checkbox' class='group-checkbox' value='" + group.ObjectId[0] + "' " + ((group.Visible[0] == "true") ? "checked='checked'" : "") + " /><img src='../stdicons/lc_group.gif' /> " + group.LegendLabel[0] + "<ul class='groupChildren'></ul></li>");
+ function getIconUri(iconBase64) {
+ return "data:" + gMimeType + ";base64," + iconBase64;
+ function createLayerElement(layer) {
+ var icon = "legend-layer.png";
+ var text = layer.LegendLabel ? layer.LegendLabel[0] : "";
+ var childHtml = "";
+ //This is using the first scale range and the first geometry type. To do this proper you'd find the matching scale range
+ //based on the current map's view scale. Then dynamically, toggle item visibility when the map scale
+ //changes
+ if (layer.ScaleRange) {
+ if (layer.ScaleRange[0].FeatureStyle) {
+ var fts = layer.ScaleRange[0].FeatureStyle[0];
+ var ruleCount = fts.Rule.length;
+ if (ruleCount > 1) {
+ icon = "../stdicons/lc_theme.gif";
+ childHtml = "<ul>";
+ //Test compression
+ var bCompressed = false;
+ if (ruleCount > 3) {
+ bCompressed = !(fts.Rule[1].Icon);
+ if (bCompressed) {
+ childHtml += "<li><img src='" + getIconUri(fts.Rule[0].Icon[0]) + "' /> " + (fts.Rule[0].LegendLabel ? fts.Rule[0].LegendLabel[0] : "") + "</li>";
+ childHtml += "<li>... (" + (ruleCount - 2) + " other theme rules)</li>";
+ childHtml += "<li><img src='" + getIconUri(fts.Rule[ruleCount-1].Icon[0]) + "' /> " + (fts.Rule[ruleCount-1].LegendLabel ? fts.Rule[ruleCount-1].LegendLabel[0] : "") + "</li>";
+ } else {
+ for (var i = 0; i < ruleCount; i++) {
+ var rule = fts.Rule[i];
+ childHtml += "<li><img src='" + getIconUri(rule.Icon[0]) + "' /> " + (rule.LegendLabel ? rule.LegendLabel[0] : "") + "</li>";
+ childHtml += "</ul>";
+ } else {
+ icon = getIconUri(fts.Rule[0].Icon[0]);
+ return $("<li><input type='checkbox' class='layer-checkbox' value='" + layer.ObjectId[0] + "' " + ((layer.Visible[0] == "true") ? "checked='checked'" : "") + " /><img src='" + icon + "' /> " + text + childHtml + "</li>");
+ </script>
+ </head>
+ <body>
+ <div id="error">
+ </div>
+ <div id="wrap">
+ <div id="details">
+ <strong>Layer and Groups</strong>
+ <span id="noLayerStructure">No layer/group structure found. Probably because no additional features were specified in the CREATERUNTIMEMAP request</span>
+ <ul id="rootList">
+ </ul>
+ </div>
+ <div id="map">
+ </div>
+ </div>
+ </body>
+</html>
Added: trunk/MgDev/Doc/samples/samples.html
--- trunk/MgDev/Doc/samples/samples.html (rev 0)
+++ trunk/MgDev/Doc/samples/samples.html 2013-08-21 12:56:20 UTC (rev 7791)
@@ -0,0 +1,43 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <title>MapGuide Samples Landing Page</title>
+ </head>
+ <body>
+ <p>Here you will find an assorted list of samples using</p>
+ <ul>
+ <li>AJAX Viewer</li>
+ <li>MapGuide Web Extensions API</li>
+ <li>OpenLayers integration</li>
+ </ul>
+ <p><strong>NOTE: You should download <a href="http://download.osgeo.org/mapguide/releases/2.0.0/samples/Sheboygan.mgp">Sheboygan Dataset</a> and load this in via the <a href="../mapadmin/login.php">MapGuideSite Administrator</a> before running any of these samples</strong></p>
+ <p><strong>NOTE: Some samples may not be available because you did not choose to install them from the Windows installer. If you did not enable samples when installing MapGuide on Windows, none of these samples below will work</strong></p>
+ <p>Click on a link below to go to that particular sample</p>
+ <p>AJAX Viewer (.net)</p>
+ <ul>
+ <li><a href="dotnetsamples/main.aspx">.net Developer's Guide samples</a></li>
+ <li><a href="dotnetviewersample/ajaxviewersample.aspx">.net Viewer Sample</a></li>
+ <li><a href="dotnetviewersample/ajaxtiledviewersample.aspx">.net Tiled Viewer Sample</a></li>
+ </ul>
+ <p>AJAX Viewer (PHP)</p>
+ <ul>
+ <li><a href="phpsamples/main.php">PHP Developer's Guide samples</a></li>
+ <li><a href="phpviewersample/ajaxviewersample.php">PHP Viewer Sample</a></li>
+ <li><a href="phpviewersample/ajaxtiledviewersample.php">PHP Tiled Viewer Sample</a></li>
+ </ul>
+ <p>AJAX Viewer (Java)</p>
+ <ul>
+ <li><a href="javasamples/main.jsp">Java Developer's Guide samples</a></li>
+ <li><a href="javaviewersample/ajaxviewersample.jsp">Java Viewer Sample</a></li>
+ <li><a href="javaviewersample/ajaxtiledviewersample.jsp">Java Tiled Viewer Sample</a></li>
+ </ul>
+ <p>OpenLayers integration</p>
+ <ul>
+ <li><a href="ol2samples/untiled/index.html">Basic Sheboygan un-tiled map example with basic legend</a></li>
+ <li><a href="ol2samples/tiled/index.html">Basic Sheboygan tiled map example</a></li>
+ <li><a href="ol2samples/mixed/index.html">Basic Sheboygan mixed map (tiled and untiled) example</a></li>
+ <li><a href="ol2samples/querymap/index.html">Sheboygan map with feature selection example</a></li>
+ <li><a href="ol2samples/commercial/index.html">Sheboygan map with Google/OSM layers</a></li>
+ </ul>
+ </body>
+</html>
More information about the mapguide-commits
