[mapguide-commits] r7792 - in trunk/MgDev/Doc/samples/ol2samples: assets tiled untiled
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Aug 21 07:00:54 PDT 2013
Author: jng
Date: 2013-08-21 07:00:54 -0700 (Wed, 21 Aug 2013)
New Revision: 7792
Added:
   trunk/MgDev/Doc/samples/ol2samples/assets/legend.js
   trunk/MgDev/Doc/samples/ol2samples/tiled/index.html
   trunk/MgDev/Doc/samples/ol2samples/untiled/index.html
#2344:
 - Update css of tiled sample.
 - Refactor out the legend functionality into its own js file.
Added: trunk/MgDev/Doc/samples/ol2samples/assets/legend.js
--- trunk/MgDev/Doc/samples/ol2samples/assets/legend.js	                        (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/assets/legend.js	2013-08-21 14:00:54 UTC (rev 7792)
@@ -0,0 +1,191 @@
+//A simple legend to toggle MapGuide Layer visbility for a OpenLayers.Layer.MapGuide instance
+//NOTE: Only tested with the Sheboygan dataset. Probably doesn't handle all corner cases that can be possible with a MapGuide Map Definition
+//Requires: OpenLayers, jQuery
+function Legend(options)
+    var rtMapInfo = options.runtimeMap;
+    var legendSelector = options.legendSelector;
+    this.map = options.map;
+    this.mgLayer = options.mgLayerOL;
+    this.debug = false;
+    this.stdIconRoot = options.stdIconRoot || "../../stdicons";
+    this.rootEl = $(legendSelector);
+    var _self = this;
+    this.map.events.register("zoomend", this, OpenLayers.Function.bind(this.update, this));
+    var groupElMap = {};
+    if (rtMapInfo.RuntimeMap.Group) {
+        var remainingGroups = {};
+        //1st pass, un-parented groups
+        for (var i = 0; i < rtMapInfo.RuntimeMap.Group.length; i++) {
+            var group = rtMapInfo.RuntimeMap.Group[i];
+            if (group.ParentId) {
+                remainingGroups[group.ObjectId[0]] = group;
+                continue;
+            var el = this.createGroupElement(group);
+            groupElMap[group.ObjectId[0]] = el;
+            this.rootEl.append(el);
+        //2nd pass, parented groups
+        var itemCount = 0;
+        for (var objId in remainingGroups) {
+            itemCount++;
+        //Whittle down
+        while(itemCount > 0) {
+            var removeIds = [];
+                var group = remainingGroups[objId];
+                //Do we have a parent?
+                if (typeof(groupElMap[group.ParentId[0]]) != 'undefined') {
+                    groupElMap[group.ParentId[0]].find("ul.groupChildren").append(el);
+                    removeIds.push(group.ObjectId[0]);
+            for (var i = 0; i < removeIds.length; i++) {
+                delete remainingGroups[removeIds[i]];
+            itemCount = 0;
+                itemCount++;
+    if (rtMapInfo.RuntimeMap.Layer) {
+        for (var i = 0; i < rtMapInfo.RuntimeMap.Layer.length; i++) {
+            var layer = rtMapInfo.RuntimeMap.Layer[i];
+            var els = this.createLayerElements(layer);
+            for (var j = 0; j < els.length; j++) {
+                if (layer.ParentId) {
+                    groupElMap[layer.ParentId[0]].find("ul.groupChildren").append(els[j]);
+                } else {
+                    this.rootEl.append(els[j]);
+    $("input.group-checkbox", this.rootEl).change(function() {
+        var bShow = $(this).is(":checked");
+        var objId = $(this).val();
+        _self.showGroup(objId, bShow);
+    $("input.layer-checkbox", this.rootEl).change(function() {
+        _self.showLayer(objId, bShow);
+    this.req = {
+        showgroups: null,
+        showlayers: null,
+        hidegroups: null,
+        hidelayers: null
+Legend.prototype.resetRequest = function() {
+    this.req.showgroups = null;
+    this.req.showlayers = null;
+    this.req.hidegroups = null;
+    this.req.hidelayers = null;
+Legend.prototype.showGroup = function(groupId, bShow) {
+    this.resetRequest();
+    if (bShow)
+        this.req.showgroups = groupId;
+    else
+        this.req.hidegroups = groupId;
+    this.mgLayer.mergeNewParams(this.req);
+Legend.prototype.showLayer = function(layerId, bShow) {
+    if (bShow)
+        this.req.showlayers = layerId;
+    else
+        this.req.hidelayers = layerId;
+Legend.prototype.update = function() {
+    var scale = this.map.getScale();
+    var nodes = $("li.layer-node");
+    nodes.each(function(i, e) {
+        var el = $(e);
+        var min = el.attr("data-layer-min-scale");
+        var max = el.attr("data-layer-max-scale");
+        if (scale >= min && scale < max) {
+            if (el.is(":hidden"))
+                el.show();
+        } else {
+            if (el.is(":visible"))
+                el.hide();
+Legend.prototype.createGroupElement = function(group) {
+    return $("<li><input type='checkbox' class='group-checkbox' value='" + group.ObjectId[0] + "' " + ((group.Visible[0] == "true") ? "checked='checked'" : "") + " /><img src='" + this.stdIconRoot + "/lc_group.gif' /> " + group.LegendLabel[0] + "<ul class='groupChildren'></ul></li>");
+Legend.prototype.getIconUri = function(iconBase64) {
+    return "data:" + gMimeType + ";base64," + iconBase64;
+Legend.prototype.createLayerElements = function(layer) {
+    var icon = "legend-layer.png";
+    var label = layer.LegendLabel ? layer.LegendLabel[0] : "";
+    var text = label;
+    var childHtml = "";
+    //This is using the first scale range and the first geometry type. To do this proper you'd find the matching scale range
+    //based on the current map's view scale. Then dynamically, toggle item visibility when the map scale
+    //changes
+    var els = [];
+    if (layer.ScaleRange) {
+        for (var i = 0; i < layer.ScaleRange.length; i++) {
+            var scaleRange = layer.ScaleRange[i];
+            if (scaleRange.FeatureStyle) {
+                if (this.debug)
+                    text = label + " (" + scaleRange.MinScale[0] + " - " + scaleRange.MaxScale[0] + ")";
+                var fts = scaleRange.FeatureStyle[0];
+                var ruleCount = fts.Rule.length;
+                if (ruleCount > 1) {
+                    icon = this.stdIconRoot + "/lc_theme.gif";
+                    childHtml = "<ul>";
+                    //Test compression
+                    var bCompressed = false;
+                    if (ruleCount > 3) {
+                        bCompressed = !(fts.Rule[1].Icon);
+                    if (bCompressed) {
+                        childHtml += "<li><img src='" + this.getIconUri(fts.Rule[0].Icon[0]) + "' /> " + (fts.Rule[0].LegendLabel ? fts.Rule[0].LegendLabel[0] : "") + "</li>";
+                        childHtml += "<li>... (" + (ruleCount - 2) + " other theme rules)</li>";
+                        childHtml += "<li><img src='" + this.getIconUri(fts.Rule[ruleCount-1].Icon[0]) + "' /> " + (fts.Rule[ruleCount-1].LegendLabel ? fts.Rule[ruleCount-1].LegendLabel[0] : "") + "</li>";
+                    } else {
+                        for (var i = 0; i < ruleCount; i++) {
+                            var rule = fts.Rule[i];
+                            childHtml += "<li><img src='" + this.getIconUri(rule.Icon[0]) + "' /> " + (rule.LegendLabel ? rule.LegendLabel[0] : "") + "</li>";
+                    childHtml += "</ul>";
+                } else {
+                    icon = this.getIconUri(fts.Rule[0].Icon[0]);
+                els.push($("<li class='layer-node' data-layer-min-scale='" + scaleRange.MinScale[0] + "' data-layer-max-scale='" + scaleRange.MaxScale[0] + "'><input type='checkbox' class='layer-checkbox' value='" + layer.ObjectId[0] + "' " + ((layer.Visible[0] == "true") ? "checked='checked'" : "") + " /><img src='" + icon + "' /> " + text + childHtml + "</li>"));
+    return els;
\ No newline at end of file
Modified: trunk/MgDev/Doc/samples/ol2samples/tiled/index.html
--- trunk/MgDev/Doc/samples/ol2samples/tiled/index.html	2013-08-21 12:56:20 UTC (rev 7791)
+++ trunk/MgDev/Doc/samples/ol2samples/tiled/index.html	2013-08-21 14:00:54 UTC (rev 7792)
@@ -1,20 +1,26 @@
 <html>
     <head>
-        <title>CreateRuntimeMap Example</title>
-        <link rel="stylesheet" href="http://openlayers.org/api/2.13-rc3/theme/default/style.css" />
+        <title>Basic Sheboygan tiled map example</title>
+        <link rel="stylesheet" href="../assets/theme/default/style.css" />
         <style type="text/css">
+            body { font-family: Verdana; font-size: 0.9em; }
             #error { color: red; }
             #wrap { width: 900; }
             #map { width: 650; height: 500; float: right; }
             #layers { width: 250; height: 500; overflow: auto; display: block-inline; float: left; }
             #rootList { list-style-type: none; margin-left: -20px; }
             #rootList li { list-style-type: none; }
+            .olControlMousePosition { background: #ffff66; font-size: 0.6em !important; padding: 2px; }
+            #layers { background: #6699FF; color: white; }
+            #layers .baseLayersDiv { font-size: 0.7em; }
         </style>
-        <script type="text/javascript" src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
-        <script type="text/javascript" src="http://openlayers.org/api/2.13-rc3/OpenLayers.js"></script>
+        <script type="text/javascript" src="../assets/jquery-1.10.2.min.js"></script>
+        <script type="text/javascript" src="../assets/OpenLayers.js"></script>
         <script type="text/javascript">
-        var mapAgentUrl = "../mapagent/mapagent.fcgi";
+        //This sample is assumed to be hosted at http://servername/mapguide/ol2samples/tiled/index.html
+        var mapAgentUrl = "../../mapagent/mapagent.fcgi";
         //Various features you can include in the CREATERUNTIMEMAP response.
         var REQ_NONE = 0;                   //Nothing. This the default.
Modified: trunk/MgDev/Doc/samples/ol2samples/untiled/index.html
--- trunk/MgDev/Doc/samples/ol2samples/untiled/index.html	2013-08-21 12:56:20 UTC (rev 7791)
+++ trunk/MgDev/Doc/samples/ol2samples/untiled/index.html	2013-08-21 14:00:54 UTC (rev 7792)
@@ -1,20 +1,24 @@
 <html>
     <head>
+        <title>Basic Sheboygan un-tiled map example with basic legend</title>
             #details { width: 250; height: 500; overflow: auto; display: block-inline; float: left; }
         </style>
+        <script type="text/javascript" src="../assets/legend.js"></script>
+        //This sample is assumed to be hosted at http://servername/mapguide/ol2samples/untiled/index.html
@@ -152,75 +156,19 @@
             mgLayer = new OpenLayers.Layer.MapGuide( "MapGuide (from CREATERUNTIMEMAP)", mapAgentUrl, params, options );
             map.addLayer(mgLayer);
             map.zoomToMaxExtent();
-            var groupElMap = {};
-            if (rtMapInfo.RuntimeMap.Group) {
-                var remainingGroups = {};
-                $("#noLayerStructure").hide();
-                //1st pass, un-parented groups
-                for (var i = 0; i < rtMapInfo.RuntimeMap.Group.length; i++) {
-                    var group = rtMapInfo.RuntimeMap.Group[i];
-                    if (group.ParentId) {
-                        remainingGroups[group.ObjectId[0]] = group;
-                        continue;
-                    var el = createGroupElement(group);
-                    groupElMap[group.ObjectId[0]] = el;
-                    $("#rootList").append(el);
-                //2nd pass, parented groups
-                var itemCount = 0;
-                for (var objId in remainingGroups) {
-                    itemCount++;
-                //Whittle down
-                while(itemCount > 0) {
-                    var removeIds = [];
-                        var group = remainingGroups[objId];
-                        //Do we have a parent?
-                        if (typeof(groupElMap[group.ParentId[0]]) != 'undefined') {
-                            groupElMap[group.ParentId[0]].find("ul.groupChildren").append(el);
-                            removeIds.push(group.ObjectId[0]);
-                    for (var i = 0; i < removeIds.length; i++) {
-                        delete remainingGroups[removeIds[i]];
-                    itemCount = 0;
-                        itemCount++;
-            if (rtMapInfo.RuntimeMap.Layer) {
-                for (var i = 0; i < rtMapInfo.RuntimeMap.Layer.length; i++) {
-                    var layer = rtMapInfo.RuntimeMap.Layer[i];
-                    var el = createLayerElement(layer);
-                    if (layer.ParentId) {
-                        groupElMap[layer.ParentId[0]].find("ul.groupChildren").append(el);
-                    } else {
-            $("#mapName").html("MapGuide mapname: " + rtMapInfo.RuntimeMap.Name[0]);
-            $("#mgSession").html("MapGuide session ID: " + sessionId);
-            $("div.olMap").css("background-color", "#" + rtMapInfo.RuntimeMap.BackgroundColor[0].substring(2));
-            $("input.group-checkbox").change(function() {
-                var bShow = $(this).is(":checked");
-                var objId = $(this).val();
-                showGroup(objId, bShow);
-            $("input.layer-checkbox").change(function() {
-                showLayer(objId, bShow);
+            var legend = new Legend({
+                legendSelector: "#rootList",
+                stdIconRoot: "../../stdicons",
+                runtimeMap: rtMapInfo,
+                map: map,
+                mgLayerOL: mgLayer
+            legend.update();
+            $("#mapName").html("MapGuide mapname: " + rtMapInfo.RuntimeMap.Name[0]);
+            $("#mgSession").html("MapGuide session ID: " + sessionId);
+            $("div.olMap").css("background-color", "#" + rtMapInfo.RuntimeMap.BackgroundColor[0].substring(2));
             startKeepAlive();
@@ -238,84 +186,6 @@
             keepAlive();
-        var req = {
-            showgroups: null,
-            showlayers: null,
-            hidegroups: null,
-            hidelayers: null
-        function resetRequest() {
-            req.showgroups = null;
-            req.showlayers = null;
-            req.hidegroups = null;
-            req.hidelayers = null;
-        function showGroup(groupId, bShow) {
-            resetRequest();
-            if (bShow)
-                req.showgroups = groupId;
-            else
-                req.hidegroups = groupId;
-            mgLayer.mergeNewParams(req);
-        function showLayer(layerId, bShow) {
-            resetRequest();
-            if (bShow)
-                req.showlayers = layerId;
-            else
-                req.hidelayers = layerId;
-        function createGroupElement(group) {
-            return $("<li><input type='checkbox' class='group-checkbox' value='" + group.ObjectId[0] + "' " + ((group.Visible[0] == "true") ? "checked='checked'" : "") + " /><img src='../stdicons/lc_group.gif' /> " + group.LegendLabel[0] + "<ul class='groupChildren'></ul></li>");
-        function getIconUri(iconBase64) {
-            return "data:" + gMimeType + ";base64," + iconBase64;
-        function createLayerElement(layer) {
-            var icon = "legend-layer.png";
-            var text = layer.LegendLabel ? layer.LegendLabel[0] : "";
-            var childHtml = "";
-            //This is using the first scale range and the first geometry type. To do this proper you'd find the matching scale range
-            //based on the current map's view scale. Then dynamically, toggle item visibility when the map scale
-            //changes
-            if (layer.ScaleRange) {
-                if (layer.ScaleRange[0].FeatureStyle) {
-                    var fts = layer.ScaleRange[0].FeatureStyle[0];
-                    var ruleCount = fts.Rule.length;
-                    if (ruleCount > 1) {
-                        icon = "../stdicons/lc_theme.gif";
-                        childHtml = "<ul>";
-                        //Test compression
-                        var bCompressed = false;
-                        if (ruleCount > 3) {
-                            bCompressed = !(fts.Rule[1].Icon);
-                        if (bCompressed) {
-                            childHtml += "<li><img src='" + getIconUri(fts.Rule[0].Icon[0]) + "' /> " + (fts.Rule[0].LegendLabel ? fts.Rule[0].LegendLabel[0] : "") + "</li>";
-                            childHtml += "<li>... (" + (ruleCount - 2) + " other theme rules)</li>";
-                            childHtml += "<li><img src='" + getIconUri(fts.Rule[ruleCount-1].Icon[0]) + "' /> " + (fts.Rule[ruleCount-1].LegendLabel ? fts.Rule[ruleCount-1].LegendLabel[0] : "") + "</li>";
-                        } else {
-                            for (var i = 0; i < ruleCount; i++) {
-                                var rule = fts.Rule[i];
-                                childHtml += "<li><img src='" + getIconUri(rule.Icon[0]) + "' /> " + (rule.LegendLabel ? rule.LegendLabel[0] : "") + "</li>";
-                        childHtml += "</ul>";
-                    } else {
-                        icon = getIconUri(fts.Rule[0].Icon[0]);
-            return $("<li><input type='checkbox' class='layer-checkbox' value='" + layer.ObjectId[0] + "' " + ((layer.Visible[0] == "true") ? "checked='checked'" : "") + " /><img src='" + icon + "' /> " + text + childHtml + "</li>");
         </script>
     </head>
     <body>
@@ -327,7 +197,6 @@
         <div id="wrap">
             <div id="details">
                 <strong>Layer and Groups</strong>
-                <span id="noLayerStructure">No layer/group structure found. Probably because no additional features were specified in the CREATERUNTIMEMAP request</span>
                 <ul id="rootList">
                 </ul>
             </div>
More information about the mapguide-commits mailing list
