[mapguide-commits] r7497 - in sandbox/jng/createruntimemap:	Common/MapGuideCommon/Resources	Common/MapGuideCommon/Services Common/Schema	Server/src/Services/Mapping Server/src/UnitTesting	Web/src/HttpHandler
    svn_mapguide at osgeo.org
    Fri May 17 06:48:43 PDT 2013
Author: jng
Date: 2013-05-17 06:48:43 -0700 (Fri, 17 May 2013)
New Revision: 7497
Added:
   sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.cpp
   sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.h
   sandbox/jng/createruntimemap/Common/MapGuideCommon/Resources/mapguide_en.res
   sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/MappingService.h
   sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.cpp
   sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.h
   sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd
   sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.cpp
   sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.h
   sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp
   sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.h
   sandbox/jng/createruntimemap/Server/src/UnitTesting/TestMappingService.cpp
   sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.cpp
   sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.h
   sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.cpp
   sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.h
This submission includes the following changes:
 - Derp! Left out OpCreateRuntimeMap.h and OpCreateRuntimeMap.cpp
 - Allow the icon image format to be specified. Default is PNG. PNG, PNG8, JPG and GIF are the allowed formats. This exposed a defect in MgMappingService::GetLegendImage where image format was ignored because MgMappingUtil::DrawFTS was hard-coded for PNG output. This submission fixes that.
 - One last change (hopefully) to the CREATERUNTIMEMAP response format in an effort to eliminate redundancy in the XML content.
   - Promote icon format to the top-level. Since the format is the same for all inline icons, there's no point specifying the same mime type for each inline icon.
   - On the same vein, group all rule elements by into a parent FeatureStyle element (with type specified in inside). This eliminates redundant <GeometryType> elements for multiple rules of a style as we can get that information from its parent
   - Also on the same vein, remove the <ThemeCategory> element. This can be inferred from the rule's position in the parent FeatureStyle element
 - Update unit test to exercise all supported icon image formats.
Modified: sandbox/jng/createruntimemap/Common/MapGuideCommon/Resources/mapguide_en.res
--- sandbox/jng/createruntimemap/Common/MapGuideCommon/Resources/mapguide_en.res	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Common/MapGuideCommon/Resources/mapguide_en.res	2013-05-17 13:48:43 UTC (rev 7497)
@@ -259,6 +259,7 @@
 MgInvalidGeometryTooFewCoordinates                    = The geometry is invalid because it has too few coordinates.
 MgInvalidGeometryType                                 = The geometry type is invalid because it is not recognized.
 MgInvalidHour                                         = The hour is invalid because it must be between 0 and 23.
+MgInvalidImageFormat                                  = Invalid Image Format: %1
 MgInvalidImageSizeTooBig                              = The requested image size exceeds the maximum.
 MgInvalidIpConfigurationForSiteServer                 = The site server (%1) must have the same IP address as this local server (%2).
 MgInvalidIpConfigurationForSupportServer              = The site server (%1) must have a different IP address than this support server (%2).
Modified: sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/MappingService.h
--- sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/MappingService.h	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/MappingService.h	2013-05-17 13:48:43 UTC (rev 7497)
@@ -433,6 +433,8 @@
     /// The desired name of the runtime map
     /// \param sessionId (String/string)
     /// The session ID
+    /// \param iconFormat (String/string)
+    /// The desired image format for icons (from MgImageFormats)
     /// \param iconWidth (int)
     /// The width of each individual inline legend icons. Has no effect if icons was not requested in the response.
     /// \param iconHeight (int)
@@ -452,9 +454,13 @@
     /// \return
     /// Returns an XML-based description of the runtime map
+    /// \exception MgInvalidArgumentException
+    /// \exception MgNullArgumentException
     virtual MgByteReader* CreateRuntimeMap(MgResourceIdentifier* mapDefinition,
                                            CREFSTRING targetMapName,
                                            CREFSTRING sessionId,
+                                           CREFSTRING iconFormat,
                                            INT32 iconWidth,
                                            INT32 iconHeight,
                                            INT32 requestedFeatures,
Modified: sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.cpp
--- sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.cpp	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.cpp	2013-05-17 13:48:43 UTC (rev 7497)
@@ -478,6 +478,7 @@
 MgByteReader* MgProxyMappingService::CreateRuntimeMap(MgResourceIdentifier* mapDefinition,
                                                       INT32 iconWidth,
                                                       INT32 iconHeight,
@@ -488,12 +489,13 @@
     cmd.ExecuteCommand(m_connProp,
                        MgCommand::knObject,
                        MgMappingServiceOpId::CreateRuntimeMap2,
-                       7,
+                       8,
                        Mapping_Service,
                        BUILD_VERSION(2,6,0),
                        MgCommand::knObject,    mapDefinition,
                        MgCommand::knString,    targetMapName,
                        MgCommand::knString,    sessionId,
+                       MgCommand::knString,    iconFormat,
                        MgCommand::knInt32,     iconWidth,
                        MgCommand::knInt32,     iconHeight,
                        MgCommand::knInt32,     requestedFeatures,
Modified: sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.h
--- sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.h	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Common/MapGuideCommon/Services/ProxyMappingService.h	2013-05-17 13:48:43 UTC (rev 7497)
@@ -396,6 +396,8 @@
     /// The session ID
@@ -418,6 +420,7 @@
                                            INT32 iconWidth,
                                            INT32 iconHeight,
Modified: sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd
--- sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Common/Schema/RuntimeMap-2.6.0.xsd	2013-05-17 13:48:43 UTC (rev 7497)
@@ -26,6 +26,11 @@
             <xs:documentation>The map's background color in ARGB hex string format</xs:documentation>
           </xs:annotation>
         </xs:element>
+        <xs:element name="IconMimeType" type="xs:string" minOccurs="0">
+          <xs:annotation>
+            <xs:documentation>The mime type of all inline icons</xs:documentation>
+          </xs:annotation>
+        </xs:element>
         <xs:element name="CoordinateSystem" type="CoordinateSystemType" />
         <xs:element name="Extents" type="Envelope" />
         <xs:element name="Group" type="RuntimeMapGroup" minOccurs="0" maxOccurs="unbounded" />
@@ -208,24 +213,31 @@
           <xs:documentation>The maximum scale of this scale range</xs:documentation>
         </xs:annotation>
       </xs:element>
-      <xs:element name="Rule" type="RuleInfo" minOccurs="0" maxOccurs="unbounded" />
+      <xs:element name="FeatureStyle" type="FeatureStyleInfo" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>The feature style for a given geometry type.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
     </xs:sequence>
   </xs:complexType>
-  <xs:complexType name="RuleInfo">
+  <xs:complexType name="FeatureStyleInfo">
     <xs:annotation>
-      <xs:documentation>Describes a stylization rule in a layer's scale range</xs:documentation>
+      <xs:documentation>Defines the style rules for a given geometry type</xs:documentation>
     </xs:annotation>
     <xs:sequence>
-      <xs:element name="GeometryType" type="xs:integer">
+      <xs:element name="Type" type="xs:integer">
         <xs:annotation>
           <xs:documentation>The geometry type that this rule is applicable to (1=point, 2=line, 3=area, 4=composite)</xs:documentation>
         </xs:annotation>
       </xs:element>
-      <xs:element name="ThemeCategory" type="xs:integer">
-        <xs:annotation>
-          <xs:documentation>The theme category index</xs:documentation>
-        </xs:annotation>
-      </xs:element>
+      <xs:element name="Rule" type="RuleInfo" minOccurs="0" maxOccurs="unbounded" />
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="RuleInfo">
+    <xs:annotation>
+      <xs:documentation>Describes a stylization rule in a layer's scale range</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
       <xs:element name="LegendLabel" type="xs:string">
         <xs:annotation>
           <xs:documentation>The legend label for this rule</xs:documentation>
@@ -236,30 +248,13 @@
           <xs:documentation>The FDO filter that features must match in order for them to be stylized using this particular rule</xs:documentation>
         </xs:annotation>
       </xs:element>
-      <xs:element name="Icon" type="IconInfo" minOccurs="0">
+      <xs:element name="Icon" type="xs:string" minOccurs="0">
         <xs:annotation>
-          <xs:documentation>Defines the icon for this rule</xs:documentation>
+          <xs:documentation>Defines the icon for this rule. The icon's image content is in base64 format</xs:documentation>
         </xs:annotation>
       </xs:element>
     </xs:sequence>
   </xs:complexType>
-  <xs:complexType name="IconInfo">
-    <xs:annotation>
-      <xs:documentation>Describes a layer legend icon</xs:documentation>
-    </xs:annotation>
-    <xs:sequence>
-      <xs:element name="MimeType" type="xs:string">
-        <xs:annotation>
-          <xs:documentation>The icon's mime type</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-      <xs:element name="Content" type="xs:string">
-        <xs:annotation>
-          <xs:documentation>The icon's image content (in base64 format)</xs:documentation>
-        </xs:annotation>
-      </xs:element>
-    </xs:sequence>
-  </xs:complexType>
   <xs:complexType name="Envelope">
     <xs:annotation>
       <xs:documentation>Specifies an envelope (a rectangle) using two corner points.</xs:documentation>
Modified: sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.cpp
--- sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.cpp	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.cpp	2013-05-17 13:48:43 UTC (rev 7497)
@@ -1201,7 +1201,8 @@
                                      MdfModel::FeatureTypeStyle* fts,
                                      INT32 imgWidth,
                                      INT32 imgHeight,
-                                     INT32 themeCategory)
+                                     INT32 themeCategory,
+                                     CREFSTRING format)
     if (!fts)
         return NULL;
@@ -1219,9 +1220,6 @@
     // draw the preview
     StylizationUtil::DrawStylePreview(imgWidth, imgHeight, themeCategory, fts, &er, &se_sman);
-    // TODO: use user-specified format
-    RS_String format = L"PNG";
     auto_ptr<RS_ByteData> data;
     data.reset(er.Save(format, imgWidth, imgHeight));
@@ -1229,8 +1227,14 @@
         // put this into a byte source
         Ptr<MgByteSource> bs = new MgByteSource(data->GetBytes(), data->GetNumBytes());
-        bs->SetMimeType(MgMimeType::Png);
+        if (format == MgImageFormats::Gif)
+            bs->SetMimeType(MgMimeType::Gif);
+        else if (format == MgImageFormats::Jpeg)
+            bs->SetMimeType(MgMimeType::Jpeg);
+        else if (format == MgImageFormats::Png || format == MgImageFormats::Png8)
+            bs->SetMimeType(MgMimeType::Png);
         return bs->GetReader();
Modified: sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.h
--- sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.h	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Server/src/Services/Mapping/MappingUtil.h	2013-05-17 13:48:43 UTC (rev 7497)
@@ -86,7 +86,7 @@
     static MdfModel::MapDefinition* GetMapDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId);
-    static MgByteReader* DrawFTS(MgResourceService* svcResource, MdfModel::FeatureTypeStyle* fts, INT32 imgWidth, INT32 imgHeight, INT32 themeCategory);
+    static MgByteReader* DrawFTS(MgResourceService* svcResource, MdfModel::FeatureTypeStyle* fts, INT32 imgWidth, INT32 imgHeight, INT32 themeCategory, CREFSTRING format = L"PNG");
     static double ComputeStylizationOffset(MgMap* map, MdfModel::VectorScaleRange* scaleRange, double scale);
     static MgEnvelope* TransformExtent(MgEnvelope* extent, MgCoordinateSystemTransform* xform);
Added: sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.cpp
--- sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.cpp	                        (rev 0)
+++ sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.cpp	2013-05-17 13:48:43 UTC (rev 7497)
@@ -0,0 +1,162 @@
+//  Copyright (C) 2004-2013 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#include "ServerMappingServiceDefs.h"
+#include "OpCreateRuntimeMap.h"
+/// <summary>
+/// Constructs the object.
+/// </summary>
+MgOpCreateRuntimeMap::MgOpCreateRuntimeMap()
+/// <summary>
+/// Destructs the object.
+/// </summary>
+MgOpCreateRuntimeMap::~MgOpCreateRuntimeMap()
+/// <summary>
+/// Executes the operation.
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpCreateRuntimeMap::Execute()
+    ACE_DEBUG((LM_DEBUG, ACE_TEXT("  (%t) MgOpCreateRuntimeMap::Execute()\n")));
+    MG_LOG_OPERATION_MESSAGE(L"CreateRuntimeMap");
+    MG_TRY()
+    MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+    ACE_ASSERT(m_stream != NULL);
+    if (8 == m_packet.m_NumArguments)
+        STRING targetMapName;
+        STRING sessionId;
+        STRING iconFormat;
+        INT32 iconWidth, iconHeight, requestedFeatures, iconsPerScaleRange;
+        Ptr<MgResourceIdentifier> mapDefinition = (MgResourceIdentifier*)m_stream->GetObject();
+        m_stream->GetString(targetMapName);
+        m_stream->GetString(sessionId);
+        m_stream->GetString(iconFormat);
+        m_stream->GetInt32(iconWidth);
+        m_stream->GetInt32(iconHeight);
+        m_stream->GetInt32(requestedFeatures);
+        m_stream->GetInt32(iconsPerScaleRange);
+        BeginExecution();
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == mapDefinition) ? L"MgResourceIdentifier" : mapDefinition->ToString().c_str());
+        MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(targetMapName);
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(sessionId);
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(iconFormat);
+        MG_LOG_OPERATION_MESSAGE_ADD_INT32(iconWidth);
+        MG_LOG_OPERATION_MESSAGE_ADD_INT32(iconHeight);
+        MG_LOG_OPERATION_MESSAGE_ADD_INT32(requestedFeatures);
+        MG_LOG_OPERATION_MESSAGE_ADD_INT32(iconsPerScaleRange);
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+        Validate();
+        Ptr<MgByteReader> byteReader =
+            m_service->CreateRuntimeMap(mapDefinition, targetMapName, sessionId, iconFormat, iconWidth, iconHeight, requestedFeatures, iconsPerScaleRange);
+        EndExecution(byteReader);
+    else if (4 == m_packet.m_NumArguments)
+        STRING sessionId;
+        INT32 requestedFeatures, iconsPerScaleRange;
+        BeginExecution();
+        Validate();
+            m_service->CreateRuntimeMap(mapDefinition, sessionId, requestedFeatures, iconsPerScaleRange);
+    else
+    if (!m_argsRead)
+        throw new MgOperationProcessingException(L"MgOpCreateRuntimeMap.Execute",
+            __LINE__, __WFILE__, NULL, L"", NULL);
+    // Successful operation
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+    MG_CATCH(L"MgOpCreateRuntimeMap.Execute")
+    if (mgException != NULL)
+        // Failed operation
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+    // Add access log entry for operation
+    MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
+    MG_THROW()
Added: sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.h
--- sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.h	                        (rev 0)
+++ sandbox/jng/createruntimemap/Server/src/Services/Mapping/OpCreateRuntimeMap.h	2013-05-17 13:48:43 UTC (rev 7497)
@@ -0,0 +1,31 @@
+#ifndef MG_OP_CREATE_RUNTIME_MAP_H
+#define MG_OP_CREATE_RUNTIME_MAP_H
+class MgOpCreateRuntimeMap : public MgMappingOperation
+    public:
+        MgOpCreateRuntimeMap();
+        virtual ~MgOpCreateRuntimeMap();
+    public:
+        virtual void Execute();
+#endif
\ No newline at end of file
Modified: sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp
--- sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.cpp	2013-05-17 13:48:43 UTC (rev 7497)
@@ -1690,7 +1690,7 @@
             if (fts)
-                byteReader = MgMappingUtil::DrawFTS(m_svcResource, fts, imgWidth, imgHeight, themeCategory);
+                byteReader = MgMappingUtil::DrawFTS(m_svcResource, fts, imgWidth, imgHeight, themeCategory, format);
             else
                 //return the fixed array
@@ -1869,20 +1869,30 @@
     CHECKNULL(mapDefinition, L"MgServerMappingService.CreateRuntimeMap");
     STRING mapName = mapDefinition->GetName();
-    return CreateRuntimeMap(mapDefinition, mapName, sessionId, LEGEND_BITMAP_SIZE, LEGEND_BITMAP_SIZE, requestedFeatures, iconsPerScaleRange);
+    return CreateRuntimeMap(mapDefinition, mapName, sessionId, MgImageFormats::Png, LEGEND_BITMAP_SIZE, LEGEND_BITMAP_SIZE, requestedFeatures, iconsPerScaleRange);
 MgByteReader* MgServerMappingService::CreateRuntimeMap(MgResourceIdentifier* mapDefinition,
                                                        INT32 iconWidth,
                                                        INT32 iconHeight,
                                                        INT32 iconsPerScaleRange)
-    CHECKNULL(mapDefinition, L"MgServerMappingService.CreateRuntimeMap");
+    CHECKARGUMENTNULL(mapDefinition, L"MgServerMappingService.CreateRuntimeMap");
+    LayerDefinitionMap layerDefinitionMap;
+    if (MgImageFormats::Png != iconFormat &&
+        MgImageFormats::Gif != iconFormat &&
+        MgImageFormats::Png8 != iconFormat &&
+        MgImageFormats::Jpeg != iconFormat)
+        MgStringCollection args;
+        args.Add(iconFormat);
+        throw new MgInvalidArgumentException(L"MgServerMappingService.CreateRuntimeMap", __LINE__, __WFILE__, NULL, L"MgInvalidImageFormat", &args);
     Ptr<MgByteReader> byteReader;
-    LayerDefinitionMap layerDefinitionMap;
     MG_SERVER_MAPPING_SERVICE_TRY()
@@ -1933,6 +1943,18 @@
     xml.append("<BackgroundColor>");
     xml.append(MgUtil::WideCharToMultiByte(map->GetBackgroundColor()));
     xml.append("</BackgroundColor>");
+    // ------------------------------ Icon Image Format --------------------------------- //
+    if ((requestedFeatures & REQUEST_LAYER_ICONS) == REQUEST_LAYER_ICONS)
+        xml.append("<IconMimeType>");
+        if (iconFormat == MgImageFormats::Gif)
+            xml.append(MgUtil::WideCharToMultiByte(MgMimeType::Gif));
+        else if (iconFormat == MgImageFormats::Jpeg)
+            xml.append(MgUtil::WideCharToMultiByte(MgMimeType::Jpeg));
+        else if (iconFormat == MgImageFormats::Png || iconFormat == MgImageFormats::Png8)
+            xml.append(MgUtil::WideCharToMultiByte(MgMimeType::Png));
+        xml.append("</IconMimeType>");
     // ------------------------------ Coordinate System --------------------------------- //
     xml.append("<CoordinateSystem>\n");
     xml.append("<Wkt>");
@@ -2020,7 +2042,7 @@
             if (it != layerDefinitionMap.end())
                 layerDef = it->second;
-            CreateLayerItem(requestedFeatures, iconsPerScaleRange, iconWidth, iconHeight, layer, parent, layerDef, xml);
+            CreateLayerItem(requestedFeatures, iconsPerScaleRange, iconFormat, iconWidth, iconHeight, layer, parent, layerDef, xml);
     // ------------------------ Finite Display Scales (if any) ------------------------- //
@@ -2102,7 +2124,7 @@
     MG_SERVER_MAPPING_SERVICE_CATCH_AND_THROW(L"MgServerMappingService.CreateGroupItem")
-void MgServerMappingService::CreateLayerItem(INT32 requestedFeatures, INT32 iconsPerScaleRange, INT32 iconWidth, INT32 iconHeight, MgLayerBase* layer, MgLayerGroup* parent, MdfModel::LayerDefinition* ldf, std::string& xml)
+void MgServerMappingService::CreateLayerItem(INT32 requestedFeatures, INT32 iconsPerScaleRange, CREFSTRING iconFormat, INT32 iconWidth, INT32 iconHeight, MgLayerBase* layer, MgLayerGroup* parent, MdfModel::LayerDefinition* ldf, std::string& xml)
@@ -2221,8 +2243,16 @@
                         geomType = 3;
                     else if (cts)
                         geomType = 4;
-                    INT32 catIndex = 0;
+                    //Geometry type and Theme Category are required so that deferred icon requests can be made
+                    //back to the GetLegendImage(), especially if we exceed the icons-per-scale-range limit
+                    //Geometry type is specified here, theme category is inferred from rule item positioning.
+                    xml.append("<FeatureStyle>\n");
+                    xml.append("<Type>");
+                    std::string sGeomType;
+                    MgUtil::Int32ToString(geomType, sGeomType);
+                    xml.append(sGeomType);
+                    xml.append("</Type>\n");
                     MdfModel::RuleCollection* rules = fts->GetRules();
                     for (INT32 r = 0; r < rules->GetCount(); r++)
@@ -2238,18 +2268,6 @@
                         xml.append("<Rule>\n");
-                        //GeometryType and ThemeCategory are required so that deferred icon requests can be made
-                        //back to the GetLegendImage(), especially if we exceed the icons-per-scale-range limit
-                        xml.append("<GeometryType>");
-                        std::string sGeomType;
-                        MgUtil::Int32ToString(geomType, sGeomType);
-                        xml.append(sGeomType);
-                        xml.append("</GeometryType>\n");
-                        xml.append("<ThemeCategory>");
-                        std::string sThemeCat;
-                        MgUtil::Int32ToString(catIndex, sThemeCat);
-                        xml.append(sThemeCat);
-                        xml.append("</ThemeCategory>\n");
                         xml.append("<LegendLabel>");
                         xml.append(MgUtil::WideCharToMultiByte(MgUtil::ReplaceEscapeCharInXml(rule->GetLegendLabel())));
                         xml.append("</LegendLabel>\n");
@@ -2259,23 +2277,17 @@
                         if (bRequestIcon)
                             xml.append("<Icon>");
-                            Ptr<MgByteReader> iconReader = MgMappingUtil::DrawFTS(m_svcResource, fts, iconWidth, iconHeight, catIndex);
-                            xml.append("<MimeType>");
-                            xml.append(MgUtil::WideCharToMultiByte(iconReader->GetMimeType()));
-                            xml.append("</MimeType>\n");
-                            xml.append("<Content>");
+                            Ptr<MgByteReader> iconReader = MgMappingUtil::DrawFTS(m_svcResource, fts, iconWidth, iconHeight, r, iconFormat);
                             Ptr<MgByteSink> sink = new MgByteSink(iconReader);
                             Ptr<MgByte> bytes = sink->ToBuffer();
                             Ptr<MgMemoryStreamHelper> streamHelper = new MgMemoryStreamHelper((INT8*) bytes->Bytes(), bytes->GetLength(), false);
                             std::string b64 = streamHelper->ToBase64();
                             xml.append(b64);
-                            xml.append("</Content>\n");
                             xml.append("</Icon>");
                         xml.append("</Rule>\n");
-                        catIndex++;
+                    xml.append("</FeatureStyle>\n");
                 xml.append("</ScaleRange>\n");
Modified: sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.h
--- sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.h	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Server/src/Services/Mapping/ServerMappingService.h	2013-05-17 13:48:43 UTC (rev 7497)
@@ -124,6 +124,7 @@
                                                INT32 iconWidth,
                                                INT32 iconHeight,
@@ -135,7 +136,7 @@
     private:
         void CreateGroupItem(MgLayerGroup* group, MgLayerGroup* parent, std::string& xml);
-        void CreateLayerItem(INT32 requestedFeatures, INT32 iconsPerScaleRange, INT32 iconWidth, INT32 iconHeight, MgLayerBase* layer, MgLayerGroup* parent, MdfModel::LayerDefinition* ldf, std::string& xml);
+        void CreateLayerItem(INT32 requestedFeatures, INT32 iconsPerScaleRange, CREFSTRING iconFormat, INT32 iconWidth, INT32 iconHeight, MgLayerBase* layer, MgLayerGroup* parent, MdfModel::LayerDefinition* ldf, std::string& xml);
         bool FeatureTypeStyleSupportsGeomType(MdfModel::FeatureTypeStyle* fts, INT32 geomType);
         void MakeUIGraphicsForScaleRange(std::list<RS_UIGraphic>& uiGraphics, std::vector<MgByte*>& uiGraphicSources, MdfModel::VectorScaleRange* sr);
Modified: sandbox/jng/createruntimemap/Server/src/UnitTesting/TestMappingService.cpp
--- sandbox/jng/createruntimemap/Server/src/UnitTesting/TestMappingService.cpp	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Server/src/UnitTesting/TestMappingService.cpp	2013-05-17 13:48:43 UTC (rev 7497)
@@ -257,30 +257,85 @@
         //make a runtime map
         Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+        STRING format = MgImageFormats::Png;
         //call the API
-        Ptr<MgByteReader> rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan1", m_session, 16, 16, 0, 25);
+        Ptr<MgByteReader> rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan1", m_session, format, 16, 16, 0, 25);
         Ptr<MgByteSink> sink = new MgByteSink(rtMap);
         sink->ToFile(L"../UnitTestFiles/RuntimeMapBarebones.xml");
-        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan2", m_session, 16, 16, 1, 25);
+        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan2", m_session, format, 16, 16, 1, 25);
         sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroups.xml");
-        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan3", m_session, 16, 16, (1 | 2), 25);
+        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan3", m_session, format, 16, 16, (1 | 2), 25);
-        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIcons16x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG16x16.xml");
-        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan4", m_session, 16, 16, (1 | 2 | 4), 25);
+        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan4", m_session, format, 16, 16, (1 | 2 | 4), 25);
-        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSource16x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG16x16.xml");
-        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan5", m_session, 32, 32, (1 | 2), 25);
+        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan5", m_session, format, 32, 32, (1 | 2), 25);
-        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIcons32x32.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG32x32.xml");
-        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan6", m_session, 32, 32, (1 | 2 | 4), 25);
+        rtMap = m_svcMapping->CreateRuntimeMap(mdfres, L"UnitTestSheboygan6", m_session, format, 32, 32, (1 | 2 | 4), 25);
-        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSource32x32.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG32x32.xml");
+        format = MgImageFormats::Gif;
+        sink = new MgByteSink(rtMap);
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsGIF16x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceGIF16x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsGIF32x32.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceGIF32x32.xml");
+        format = MgImageFormats::Jpeg;
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsJPEG16x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceJPEG16x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsJPEG32x32.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourceJPEG32x32.xml");
+        format = MgImageFormats::Png8;
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG816x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG816x16.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsPNG832x32.xml");
+        sink->ToFile(L"../UnitTestFiles/RuntimeMapLayersAndGroupsWithIconsAndFeatureSourcePNG832x32.xml");
     catch(MgException* e)
Modified: sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.cpp
--- sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.cpp	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.cpp	2013-05-17 13:48:43 UTC (rev 7497)
@@ -61,8 +61,14 @@
         m_targetMapName = sTargetMapName;
+    m_iconFormat = MgImageFormats::Png;
     m_iconWidth = 16;
     m_iconHeight = 16;
+    STRING sIconFormat = params->GetParameterValue(MgHttpResourceStrings::reqMappingIconFormat);
+    if (!sIconFormat.empty())
+        m_iconFormat = sIconFormat;
     STRING sIconWidth = params->GetParameterValue(MgHttpResourceStrings::reqMappingIconWidth);
     if (!sIconWidth.empty())
@@ -112,7 +118,7 @@
     Ptr<MgMappingService> mappingService = (MgMappingService*)CreateService(MgServiceType::MappingService);
-    byteReader = mappingService->CreateRuntimeMap(mdfId, mapName, sessionId, m_iconWidth, m_iconHeight, m_requestDataMask, m_iconLimitPerScaleRange);
+    byteReader = mappingService->CreateRuntimeMap(mdfId, mapName, sessionId, m_iconFormat, m_iconWidth, m_iconHeight, m_requestDataMask, m_iconLimitPerScaleRange);
     // Convert to requested response format, if necessary
     ProcessFormatConversion(byteReader);
Modified: sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.h
--- sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.h	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpCreateRuntimeMap.h	2013-05-17 13:48:43 UTC (rev 7497)
@@ -63,6 +63,7 @@
 private:
     STRING m_targetMapName;
     STRING m_mapDefinition;
+    STRING m_iconFormat;
     INT32 m_iconWidth;
     INT32 m_iconHeight;
     INT32 m_requestDataMask;
Modified: sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.cpp
--- sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.cpp	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.cpp	2013-05-17 13:48:43 UTC (rev 7497)
@@ -222,6 +222,7 @@
 const STRING MgHttpResourceStrings::reqMappingTargetMapName = L"TARGETMAPNAME";
 const STRING MgHttpResourceStrings::reqMappingIconWidth = L"ICONWIDTH";
 const STRING MgHttpResourceStrings::reqMappingIconHeight = L"ICONHEIGHT";
+const STRING MgHttpResourceStrings::reqMappingIconFormat = L"ICONFORMAT";
 // Predefined Rendering Service Request Parameters
 const STRING MgHttpResourceStrings::reqRenderingMapDefinition = L"MAPDEFINITION";
Modified: sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.h
--- sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.h	2013-05-15 17:57:17 UTC (rev 7496)
+++ sandbox/jng/createruntimemap/Web/src/HttpHandler/HttpResourceStrings.h	2013-05-17 13:48:43 UTC (rev 7497)
@@ -158,6 +158,7 @@
     static const STRING reqMappingTargetMapName;
     static const STRING reqMappingIconWidth;
     static const STRING reqMappingIconHeight;
+    static const STRING reqMappingIconFormat;
     // PREDEFINED RENDERING REQUEST PARAMETERS
     static const STRING reqRenderingMapDefinition;
More information about the mapguide-commits
