[mapguide-commits] r7498 - trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun May 19 14:50:21 PDT 2013
Author: jng
Date: 2013-05-19 14:50:21 -0700 (Sun, 19 May 2013)
New Revision: 7498
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
#2269: This submission adds large file upload support for the SetResourceData operation in the HttpServerConnection. For files under 50MB, we use the old code path, otherwise we use a specialized code path that streams the file upload from a temp file source instead of funnelling into a temporary MemoryStream (obvious cause of OutOfMemoryException objects being thrown for SetResourceData calls with really large files)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2013-05-17 13:48:43 UTC (rev 7497)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2013-05-19 21:50:21 UTC (rev 7498)
@@ -45,6 +45,7 @@
 using System.Drawing;
 using OSGeo.MapGuide.ObjectModels.FeatureSource;
 using OSGeo.MapGuide.MaestroAPI.SchemaOverrides;
+using System.Diagnostics;
 namespace OSGeo.MapGuide.MaestroAPI
@@ -455,51 +456,175 @@
 		public override void SetResourceData(string resourceid, string dataname, ResourceDataType datatype, System.IO.Stream stream, Utility.StreamCopyProgressDelegate callback)
+            //Protect against session expired
+            if (this.m_autoRestartSession && m_username != null && m_password != null)
+                this.DownloadData(m_reqBuilder.GetSiteVersion());
-#if DEBUG_LASTMESSAGE
-			using (System.IO.Stream s = System.IO.File.Open("lastSaveData.bin", System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
-				Utility.CopyStream(stream, s);
-#endif
-			if (stream.CanSeek)
-				stream.Position = 0;
+            //Use the old code path if stream is under 50MB (implying seekable too)
+            if (stream.CanSeek && stream.Length < 50 * 1024 * 1024)
+    #if DEBUG_LASTMESSAGE
+			    using (System.IO.Stream s = System.IO.File.Open("lastSaveData.bin", System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+				    Utility.CopyStream(stream, s);
+    #endif
+                    if (stream.CanSeek)
+                        stream.Position = 0;
-			System.IO.MemoryStream outStream = new System.IO.MemoryStream();
-			try
-#endif
-				System.Net.WebRequest req = m_reqBuilder.SetResourceData(resourceid, dataname, datatype, outStream, stream, callback);
-                req.Credentials = _cred;
-				outStream.Position = 0;
-				//Protect against session expired
-				if (this.m_autoRestartSession && m_username != null && m_password != null)
-					this.DownloadData(m_reqBuilder.GetSiteVersion());
+                    System.IO.MemoryStream outStream = new System.IO.MemoryStream();
+			    try
+    #endif
+                    System.Net.WebRequest req = m_reqBuilder.SetResourceData(resourceid, dataname, datatype, outStream, stream, callback);
+                    req.Credentials = _cred;
+                    outStream.Position = 0;
-				//TODO: We need a progress bar for the upload....
-				req.Timeout = 1000 * 60 * 15;
-				using(System.IO.Stream rs = req.GetRequestStream())
-					Utility.CopyStream(outStream, rs);
-					rs.Flush();
-				using (System.IO.Stream resp = req.GetResponse().GetResponseStream())
-					//Do nothing... there is no return value
-			catch
-				using (System.IO.Stream s = System.IO.File.OpenWrite("lastPost.txt"))
-					Utility.CopyStream(outStream, s);
+                    //TODO: We need a progress bar for the upload....
+                    req.Timeout = 1000 * 60 * 15;
+                    using (System.IO.Stream rs = req.GetRequestStream())
+                        Utility.CopyStream(outStream, rs);
+                        rs.Flush();
+                    using (System.IO.Stream resp = req.GetResponse().GetResponseStream())
+                        //Do nothing... there is no return value
+			    catch
+				    using (System.IO.Stream s = System.IO.File.OpenWrite("lastPost.txt"))
+					    Utility.CopyStream(outStream, s);
-				throw;
-#endif
+				    throw;
+    #endif
+            else
+                //Dump to temp file
+                string tmp = Path.GetTempFileName();
+                try
+                    using (var fw = File.OpenWrite(tmp))
+                        Utility.CopyStream(stream, fw);
+                    var fi = new FileInfo(tmp);
+                    NameValueCollection nvc = m_reqBuilder.SetResourceDataParams(resourceid, dataname, datatype);
+                    nvc.Add("DATALENGTH", fi.Length.ToString());
+                    HttpUploadFile(m_reqBuilder.HostURI, tmp, "DATA", "application/octet-stream", nvc, callback);
+                finally
+                    if (File.Exists(tmp))
+                        try
+                            File.Delete(tmp);
+                            Debug.WriteLine("Deleted: " + tmp);
+                        catch { }
+        //Source: http://stackoverflow.com/questions/566462/upload-files-with-httpwebrequest-multipart-form-data
+        private void HttpUploadFile(string url, string file, string paramName, string contentType, NameValueCollection nvc, Utility.StreamCopyProgressDelegate callback)
+            Debug.WriteLine(string.Format("Uploading {0} to {1}", file, url));
+            string boundary = "---------------------------" + DateTime.Now.Ticks.ToString("x");
+            string formdataTemplate = "Content-Disposition: form-data; name=\"{0}\"\r\n\r\n{1}";
+            string headerTemplate = "Content-Disposition: form-data; name=\"{0}\"; filename=\"{1}\"\r\nContent-Type: {2}\r\n\r\n";
+            byte[] boundarybytes = System.Text.Encoding.ASCII.GetBytes("\r\n--" + boundary + "\r\n");
+            byte[] trailer = System.Text.Encoding.ASCII.GetBytes("\r\n--" + boundary + "--\r\n");
+            HttpWebRequest wr = (HttpWebRequest)WebRequest.Create(url);
+            wr.ContentType = "multipart/form-data; boundary=" + boundary;
+            wr.Method = "POST";
+            //DO NOT BUFFER. Otherwise this will still OOM on really large files
+            wr.AllowWriteStreamBuffering = false;
+            wr.KeepAlive = true;
+            wr.Credentials = _cred;
+            //Pre-compute request body size
+                long contentLength = 0L;
+                foreach (string key in nvc.Keys)
+                    string formitem = string.Format(formdataTemplate, key, nvc[key]);
+                    byte[] formitembytes = System.Text.Encoding.ASCII.GetBytes(formitem);
+                    contentLength += formitembytes.Length;
+                    contentLength += boundarybytes.Length;
+                string header = string.Format(headerTemplate, paramName, file, contentType);
+                byte[] headerbytes = System.Text.Encoding.ASCII.GetBytes(header);
+                contentLength += headerbytes.Length;
+                var fi = new FileInfo(file);
+                contentLength += fi.Length;
+                contentLength += trailer.Length;
+                wr.ContentLength = contentLength;
+            using (Stream rs = wr.GetRequestStream())
+                    rs.Write(boundarybytes, 0, boundarybytes.Length);
+                    rs.Write(formitembytes, 0, formitembytes.Length);
+                rs.Write(headerbytes, 0, headerbytes.Length);
+                FileStream fileStream = new FileStream(file, FileMode.Open, FileAccess.Read);
+                byte[] buffer = new byte[4096];
+                int bytesRead = 0;
+                while ((bytesRead = fileStream.Read(buffer, 0, buffer.Length)) != 0)
+                    rs.Write(buffer, 0, bytesRead);
+                Utility.CopyStream(fileStream, rs, callback, 1024);
+                fileStream.Close();
+                rs.Write(trailer, 0, trailer.Length);
+                rs.Close();
+                WebResponse wresp = null;
+                try
+                    wresp = wr.GetResponse();
+                    Stream stream2 = wresp.GetResponseStream();
+                    StreamReader reader2 = new StreamReader(stream2);
+                    Debug.WriteLine(string.Format("File uploaded, server response is: {0}", reader2.ReadToEnd()));
+                catch (Exception ex)
+                    Debug.WriteLine("Error uploading file", ex);
+                    if (wresp != null)
+                        wresp.Close();
+                        wresp = null;
+                finally
+                    wr = null;
         public override void SetResourceXmlData(string resourceid, System.IO.Stream content, System.IO.Stream header)
             bool exists = ResourceExists(resourceid);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs	2013-05-17 13:48:43 UTC (rev 7497)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/RequestBuilder.cs	2013-05-19 21:50:21 UTC (rev 7498)
@@ -26,29 +26,29 @@
-	/// <summary>
-	/// Collection class for building web requests to the MapGuide Server
-	/// </summary>
-	internal class RequestBuilder
+    /// <summary>
+    /// Collection class for building web requests to the MapGuide Server
+    /// </summary>
+    internal class RequestBuilder
         private string m_userAgent = "MapGuide Maestro API";
-		private string m_hosturi;
-		private string m_sessionID = null;
-		private string m_locale = null;
+        private string m_hosturi;
+        private string m_sessionID = null;
+        private string m_locale = null;
-		internal RequestBuilder(Uri hosturi, string locale, string sessionid, bool bIncludeSessionIdInRequests)
-			m_hosturi = hosturi.AbsoluteUri;
-			m_locale = locale;
-			m_sessionID = sessionid;
+        internal RequestBuilder(Uri hosturi, string locale, string sessionid, bool bIncludeSessionIdInRequests)
+            m_hosturi = hosturi.AbsoluteUri;
+            m_locale = locale;
+            m_sessionID = sessionid;
             m_userAgent += " v" + System.Reflection.Assembly.GetExecutingAssembly().GetName().Version.ToString();
             this.IncludeSessionIdInRequestParams = bIncludeSessionIdInRequests;
-		internal RequestBuilder(Uri hosturi, string locale)
-			: this (hosturi, locale, null, false)
+        internal RequestBuilder(Uri hosturi, string locale)
+            : this (hosturi, locale, null, false)
         /// <summary>
         /// Indicates if the session id should be included as the SESSION request parameter. This needs to be set to true if
@@ -57,161 +57,161 @@
         /// </summary>
         internal bool IncludeSessionIdInRequestParams { get; private set; }
-		internal string Locale { get { return m_locale; } }
+        internal string Locale { get { return m_locale; } }
-		internal string CreateSession()
-			NameValueCollection param = new NameValueCollection();
-			param.Add("OPERATION", "CREATESESSION");
-			param.Add("VERSION", "1.0.0");
-			param.Add("FORMAT", "text/xml");
+        internal string CreateSession()
+            NameValueCollection param = new NameValueCollection();
+            param.Add("OPERATION", "CREATESESSION");
+            param.Add("VERSION", "1.0.0");
+            param.Add("FORMAT", "text/xml");
             param.Add("CLIENTAGENT", m_userAgent);
-			if (m_locale != null)
-				param.Add("LOCALE", m_locale);
-			return m_hosturi + "?" + EncodeParameters(param);
+            if (m_locale != null)
+                param.Add("LOCALE", m_locale);
+            return m_hosturi + "?" + EncodeParameters(param);
-		internal string GetSiteVersion()
-			param.Add("OPERATION", "GETSITEVERSION");
-			param.Add("SESSION", m_sessionID);
+        internal string GetSiteVersion()
+            param.Add("OPERATION", "GETSITEVERSION");
+            param.Add("SESSION", m_sessionID);
-		internal string GetFeatureProviders()
-			if (m_sessionID == null)
-				throw new Exception("Connection is not yet logged in");
+        internal string GetFeatureProviders()
+            if (m_sessionID == null)
+                throw new Exception("Connection is not yet logged in");
-			param.Add("OPERATION", "GETFEATUREPROVIDERS");
+            param.Add("OPERATION", "GETFEATUREPROVIDERS");
-		internal string EnumerateResources(string startingpoint, int depth, string type, bool computeChildren)
-			if (type == null)
-				type = "";
+        internal string EnumerateResources(string startingpoint, int depth, string type, bool computeChildren)
+            if (type == null)
+                type = "";
-			param.Add("OPERATION", "ENUMERATERESOURCES");
+            param.Add("OPERATION", "ENUMERATERESOURCES");
-			param.Add("RESOURCEID", startingpoint);
-			param.Add("DEPTH", depth.ToString());
-			param.Add("TYPE", type);
+            param.Add("RESOURCEID", startingpoint);
+            param.Add("DEPTH", depth.ToString());
+            param.Add("TYPE", type);
             param.Add("COMPUTECHILDREN", computeChildren ? "1" : "0");
-		internal string TestConnection(string featuresource)
+        internal string TestConnection(string featuresource)
-			param.Add("OPERATION", "TESTCONNECTION");
+            param.Add("OPERATION", "TESTCONNECTION");
             param.Add("RESOURCEID", featuresource);
-		internal System.Net.WebRequest TestConnectionPost(string providername, NameValueCollection parameters, System.IO.Stream outStream)
+        internal System.Net.WebRequest TestConnectionPost(string providername, NameValueCollection parameters, System.IO.Stream outStream)
-			param.Add("PROVIDER", providername);
-			System.Text.StringBuilder sb = new System.Text.StringBuilder();
-			foreach(string k in parameters)
-				sb.Append(k);
-				sb.Append("=");
-				sb.Append(parameters[k]);
-				sb.Append(";");
-			if (sb.Length != 0)
-				sb.Length = sb.Length - 1;
+            param.Add("PROVIDER", providername);
+            System.Text.StringBuilder sb = new System.Text.StringBuilder();
+            foreach(string k in parameters)
+                sb.Append(k);
+                sb.Append("=");
+                sb.Append(parameters[k]);
+                sb.Append(";");
+            if (sb.Length != 0)
+                sb.Length = sb.Length - 1;
-			//TODO: Figure out how to encode the '%' character...
-			param.Add("CONNECTIONSTRING", sb.ToString());
+            //TODO: Figure out how to encode the '%' character...
+            param.Add("CONNECTIONSTRING", sb.ToString());
-			string boundary;
-			System.Net.WebRequest req = PrepareFormContent(outStream, out boundary);
-			EncodeFormParameters(boundary, param, outStream);
-			req.ContentLength = outStream.Length;
-			return req;
+            string boundary;
+            System.Net.WebRequest req = PrepareFormContent(outStream, out boundary);
+            EncodeFormParameters(boundary, param, outStream);
+            req.ContentLength = outStream.Length;
+            return req;
-		internal string TestConnection(string providername, NameValueCollection parameters)
+        internal string TestConnection(string providername, NameValueCollection parameters)
-				sb.Append(k);
-				sb.Append("=");
-				sb.Append(";");
+                sb.Append(k);
+                sb.Append("=");
+                sb.Append(";");
-		internal string SessionID
-			get { return m_sessionID; }
-			set { m_sessionID = value; }
+        internal string SessionID
+            get { return m_sessionID; }
+            set { m_sessionID = value; }
         private string EncodeParameters(NameValueCollection param, bool bAddSessionId)
@@ -228,285 +228,301 @@
             return sb.ToString(0, sb.Length - 1);
-		private string EncodeParameters(NameValueCollection param)
+        private string EncodeParameters(NameValueCollection param)
             return EncodeParameters(param, true);
-		private string EncodeParameter(string name, string value)
-			return System.Web.HttpUtility.UrlEncode(name) + "=" + System.Web.HttpUtility.UrlEncode(value);
+        private string EncodeParameter(string name, string value)
+            return System.Web.HttpUtility.UrlEncode(name) + "=" + System.Web.HttpUtility.UrlEncode(value);
-		public string GetMapDWF(string id)
+        public string GetMapDWF(string id)
-			param.Add("OPERATION", "GETMAP");
+            param.Add("OPERATION", "GETMAP");
-			param.Add("DWFVERSION", "6.01");
-			param.Add("EMAPVERSION", "1.0");
-			param.Add("MAPDEFINITION", id);
+            param.Add("DWFVERSION", "6.01");
+            param.Add("EMAPVERSION", "1.0");
+            param.Add("MAPDEFINITION", id);
-		public string GetResourceContent(string id)
+        public string GetResourceContent(string id)
-			param.Add("OPERATION", "GETRESOURCECONTENT");
+            param.Add("OPERATION", "GETRESOURCECONTENT");
-			param.Add("RESOURCEID", id);
+            param.Add("RESOURCEID", id);
-		public string GetResourceData(string id, string name)
+        public string GetResourceData(string id, string name)
-			param.Add("OPERATION", "GETRESOURCEDATA");
+            param.Add("OPERATION", "GETRESOURCEDATA");
-			param.Add("DATANAME", name);
+            param.Add("DATANAME", name);
-		public string EnumerateResourceData(string id)
+        public string EnumerateResourceData(string id)
-			param.Add("OPERATION", "ENUMERATERESOURCEDATA");
+            param.Add("OPERATION", "ENUMERATERESOURCEDATA");
-		public string DeleteResourceData(string id, string name)
+        public string DeleteResourceData(string id, string name)
-			param.Add("OPERATION", "DELETERESOURCEDATA");
+            param.Add("OPERATION", "DELETERESOURCEDATA");
-		public string GetResourceHeader(string id)
+        public string GetResourceHeader(string id)
-			param.Add("OPERATION", "GETRESOURCEHEADER");
+            param.Add("OPERATION", "GETRESOURCEHEADER");
-		public string SetResource(string id)
+        public string SetResource(string id)
-			param.Add("OPERATION", "SETRESOURCE");
+            param.Add("OPERATION", "SETRESOURCE");
-		private void EncodeFormParameters(string boundary, NameValueCollection param, System.IO.Stream responseStream)
-			foreach(string s in param.Keys)
+        private void EncodeFormParameters(string boundary, NameValueCollection param, System.IO.Stream responseStream)
+            foreach(string s in param.Keys)
                 string val = param[s];
                 if (string.IsNullOrEmpty(val))
                     continue;
                 System.IO.MemoryStream content = new System.IO.MemoryStream(System.Text.Encoding.UTF8.GetBytes(val));
-				AppendFormContent(s, null, boundary, responseStream, content, null);
+                AppendFormContent(s, null, boundary, responseStream, content, null);
-		/// <summary>
-		/// Writes a value/file to a form-multipart HttpRequest stream
-		/// </summary>
-		/// <param name="name">The name of the parameter</param>
-		/// <param name="filename">The name of the file uploaded, set to null if this parameter is not a file</param>
-		/// <param name="boundary">The request boundary string</param>
-		/// <param name="responseStream">The stream to write to</param>
-		/// <param name="dataStream">The stream to read from. When using non-file parameters, use UTF8 encoding</param>
-		private void AppendFormContent(string name, string filename, string boundary, System.IO.Stream responseStream, System.IO.Stream dataStream, Utility.StreamCopyProgressDelegate callback)
-			string contenttype;
-			if (filename == null)
-				filename = "";
-				contenttype = "";
-			else
-				filename = " filename=\"" + filename + "\"";
-				contenttype = "\r\nContent-Type: application/octet-stream";
+        /// <summary>
+        /// Writes a value/file to a form-multipart HttpRequest stream
+        /// </summary>
+        /// <param name="name">The name of the parameter</param>
+        /// <param name="filename">The name of the file uploaded, set to null if this parameter is not a file</param>
+        /// <param name="boundary">The request boundary string</param>
+        /// <param name="responseStream">The stream to write to</param>
+        /// <param name="dataStream">The stream to read from. When using non-file parameters, use UTF8 encoding</param>
+        private void AppendFormContent(string name, string filename, string boundary, System.IO.Stream responseStream, System.IO.Stream dataStream, Utility.StreamCopyProgressDelegate callback)
+            string contenttype;
+            if (filename == null)
+                filename = "";
+                contenttype = "";
+            else
+                filename = " filename=\"" + filename + "\"";
+                contenttype = "\r\nContent-Type: application/octet-stream";
-			byte[] headers = System.Text.Encoding.UTF8.GetBytes(string.Concat(new String[] { "Content-Disposition: form-data; name=\"" + name + "\";" + filename , "\"", contenttype, "\r\n\r\n"}));
-			responseStream.Write(headers, 0, headers.Length);
+            byte[] headers = System.Text.Encoding.UTF8.GetBytes(string.Concat(new String[] { "Content-Disposition: form-data; name=\"" + name + "\";" + filename , "\"", contenttype, "\r\n\r\n"}));
+            responseStream.Write(headers, 0, headers.Length);
             Utility.CopyStream(dataStream, responseStream, callback, 0);
-			byte[] footer =  System.Text.Encoding.UTF8.GetBytes("\r\n--" + boundary + "\r\n");
-			responseStream.Write(footer, 0, footer.Length);
+            byte[] footer =  System.Text.Encoding.UTF8.GetBytes("\r\n--" + boundary + "\r\n");
+            responseStream.Write(footer, 0, footer.Length);
-		public System.Net.WebRequest SetResource(string id, System.IO.Stream outStream, System.IO.Stream content, System.IO.Stream header)
+        public System.Net.WebRequest SetResource(string id, System.IO.Stream outStream, System.IO.Stream content, System.IO.Stream header)
-			string boundary;
+            string boundary;
-			if (content != null)
-				AppendFormContent("CONTENT", "content.xml", boundary, outStream, content, null);
-			if (header != null)
-				AppendFormContent("HEADER", "header.xml", boundary, outStream, header, null);
+            if (content != null)
+                AppendFormContent("CONTENT", "content.xml", boundary, outStream, content, null);
+            if (header != null)
+                AppendFormContent("HEADER", "header.xml", boundary, outStream, header, null);
-			return req;
+            return req;
+        internal NameValueCollection SetResourceDataParams(string resourceid, string dataname, ResourceDataType datatype)
+            param.Add("OPERATION", "SETRESOURCEDATA");
+            param.Add("CLIENTAGENT", m_userAgent);
-		public System.Net.WebRequest SetResourceData(string id, string dataname, ResourceDataType datatype, System.IO.Stream outStream, System.IO.Stream content, Utility.StreamCopyProgressDelegate callback)
+            param.Add("RESOURCEID", resourceid);
+            param.Add("DATANAME", dataname);
+            param.Add("DATATYPE", datatype.ToString());
-			param.Add("OPERATION", "SETRESOURCEDATA");
+            return param;
+        public System.Net.WebRequest SetResourceData(string id, string dataname, ResourceDataType datatype, System.IO.Stream outStream, System.IO.Stream content, Utility.StreamCopyProgressDelegate callback)
-			param.Add("DATANAME", dataname);
-			param.Add("DATATYPE", datatype.ToString());
             //This does not appear to be used anywhere in the MG WebTier code
             //anyway, set this if stream supports seeking
             if (content.CanSeek)
-			    param.Add("DATALENGTH", content.Length.ToString());
+                param.Add("DATALENGTH", content.Length.ToString());
-			string boundary;
+            string boundary;
-			AppendFormContent("DATA", "content.bin", boundary, outStream, content, callback);
+            AppendFormContent("DATA", "content.bin", boundary, outStream, content, callback);
-			return req;
+            return req;
-		internal string reqAsUrl(string resourceId, string classname, string filter, string[] columns)
-			param.Add("OPERATION", "SELECTFEATURES");
+        internal string reqAsUrl(string resourceId, string classname, string filter, string[] columns)
+            param.Add("OPERATION", "SELECTFEATURES");
-			param.Add("RESOURCEID", resourceId);
-			param.Add("CLASSNAME", classname);
-			//Using the very standard TAB character for column seperation
-			//  ... nice if your data has "," or ";" in the column names :)
-			if (columns != null)
-				param.Add("PROPERTIES", string.Join("\t", columns));
+            param.Add("RESOURCEID", resourceId);
+            param.Add("CLASSNAME", classname);
+            //Using the very standard TAB character for column seperation
+            //  ... nice if your data has "," or ";" in the column names :)
+            if (columns != null)
+                param.Add("PROPERTIES", string.Join("\t", columns));
-			//param.Add("COMPUTED_ALIASES", computed_aliases);
-			//param.Add("COMPUTED_PROPERTIES", computed_properties);
-			if (filter != null)
-				param.Add("FILTER", filter);
+            //param.Add("COMPUTED_ALIASES", computed_aliases);
+            //param.Add("COMPUTED_PROPERTIES", computed_properties);
+            if (filter != null)
+                param.Add("FILTER", filter);
         public string ExecuteSqlQuery(string featureSourceID, string sql)
@@ -525,27 +541,27 @@
-		public System.Net.WebRequest SelectFeatures(bool aggregate, string resourceId, string classname, string filter, string[] columns, NameValueCollection computedProperties, System.IO.Stream outStream)
-			if (aggregate)
+        public System.Net.WebRequest SelectFeatures(bool aggregate, string resourceId, string classname, string filter, string[] columns, NameValueCollection computedProperties, System.IO.Stream outStream)
+            if (aggregate)
                 param.Add("OPERATION", "SELECTAGGREGATES");
             else
             if (computedProperties != null && computedProperties.Count > 0)
@@ -561,45 +577,45 @@
                 param.Add("COMPUTED_ALIASES", string.Join("\t", keys.ToArray()));
                 param.Add("COMPUTED_PROPERTIES", string.Join("\t", values.ToArray()));
-			string boundary;
+            string boundary;
-			return req;
+            return req;
-		private System.Net.WebRequest PrepareFormContent(System.IO.Stream outStream, out string boundary)
-			System.Net.WebRequest req = System.Net.WebRequest.Create(m_hosturi);
-			boundary = "---------------------" + DateTime.Now.Ticks.ToString("x");
-			byte[] initialBound = System.Text.Encoding.UTF8.GetBytes(string.Concat("--", boundary, "\r\n"));
-			req.ContentType = "multipart/form-data; boundary=" + boundary;
-			req.Timeout = 20 * 1000;
-			req.Method = "POST";
-			outStream.Write(initialBound, 0, initialBound.Length);
-			return req;
+        private System.Net.WebRequest PrepareFormContent(System.IO.Stream outStream, out string boundary)
+            System.Net.WebRequest req = System.Net.WebRequest.Create(m_hosturi);
+            boundary = "---------------------" + DateTime.Now.Ticks.ToString("x");
+            byte[] initialBound = System.Text.Encoding.UTF8.GetBytes(string.Concat("--", boundary, "\r\n"));
+            req.ContentType = "multipart/form-data; boundary=" + boundary;
+            req.Timeout = 20 * 1000;
+            req.Method = "POST";
+            outStream.Write(initialBound, 0, initialBound.Length);
+            return req;
-		public string DescribeSchema(string resourceId, string schema)
-			param.Add("OPERATION", "DESCRIBEFEATURESCHEMA");
+        public string DescribeSchema(string resourceId, string schema)
+            param.Add("OPERATION", "DESCRIBEFEATURESCHEMA");
-			param.Add("SCHEMA", schema);
+            param.Add("SCHEMA", schema);
         public string DescribeSchema(string resourceID)
@@ -617,260 +633,260 @@
-		public string GetProviderCapabilities(string provider)
-			param.Add("OPERATION", "GETPROVIDERCAPABILITIES");
+        public string GetProviderCapabilities(string provider)
+            param.Add("OPERATION", "GETPROVIDERCAPABILITIES");
-			param.Add("PROVIDER", provider);
+            param.Add("PROVIDER", provider);
-		public string EnumerateCategories()
-			param.Add("OPERATION", "CS.ENUMERATECATEGORIES");
+        public string EnumerateCategories()
+            param.Add("OPERATION", "CS.ENUMERATECATEGORIES");
-		public string EnumerateCoordinateSystems(string category)
-			param.Add("OPERATION", "CS.ENUMERATECOORDINATESYSTEMS");
+        public string EnumerateCoordinateSystems(string category)
+            param.Add("OPERATION", "CS.ENUMERATECOORDINATESYSTEMS");
-			param.Add("CSCATEGORY", category);
+            param.Add("CSCATEGORY", category);
-		public string ConvertWktToCoordinateSystemCode(string wkt)
-			param.Add("OPERATION", "CS.CONVERTWKTTOCOORDINATESYSTEMCODE");
+        public string ConvertWktToCoordinateSystemCode(string wkt)
+            param.Add("OPERATION", "CS.CONVERTWKTTOCOORDINATESYSTEMCODE");
-			param.Add("CSWKT", wkt);
+            param.Add("CSWKT", wkt);
-		public string ConvertCoordinateSystemCodeToWkt(string code)
-			param.Add("OPERATION", "CS.CONVERTCOORDINATESYSTEMCODETOWKT");
+        public string ConvertCoordinateSystemCodeToWkt(string code)
+            param.Add("OPERATION", "CS.CONVERTCOORDINATESYSTEMCODETOWKT");
-			param.Add("CSCODE", code);
+            param.Add("CSCODE", code);
-		public string ConvertWktToEpsgCode(string wkt)
-			param.Add("OPERATION", "CS.CONVERTWKTTOEPSGCODE");
+        public string ConvertWktToEpsgCode(string wkt)
+            param.Add("OPERATION", "CS.CONVERTWKTTOEPSGCODE");
-		public string ConvertEpsgCodeToWkt(string code)
-			param.Add("OPERATION", "CS.CONVERTEPSGCODETOWKT");
+        public string ConvertEpsgCodeToWkt(string code)
+            param.Add("OPERATION", "CS.CONVERTEPSGCODETOWKT");
-		public string GetBaseLibrary()
-			param.Add("OPERATION", "CS.GETBASELIBRARY");
+        public string GetBaseLibrary()
+            param.Add("OPERATION", "CS.GETBASELIBRARY");
-		public string IsValidCoordSys(string wkt)
-			param.Add("OPERATION", "CS.ISVALID");
+        public string IsValidCoordSys(string wkt)
+            param.Add("OPERATION", "CS.ISVALID");
-		public string DeleteResource(string resourceid)
-			param.Add("OPERATION", "DELETERESOURCE");
+        public string DeleteResource(string resourceid)
+            param.Add("OPERATION", "DELETERESOURCE");
-			param.Add("RESOURCEID", resourceid);
-		public string MoveResource(string source, string target, bool overwrite)
-			param.Add("OPERATION", "MOVERESOURCE");
+        public string MoveResource(string source, string target, bool overwrite)
+            param.Add("OPERATION", "MOVERESOURCE");
-			param.Add("SOURCE", source);
-			param.Add("DESTINATION", target);
-			param.Add("OVERWRITE", overwrite ? "1" : "0");
+            param.Add("SOURCE", source);
+            param.Add("DESTINATION", target);
+            param.Add("OVERWRITE", overwrite ? "1" : "0");
-		public string CopyResource(string source, string target, bool overwrite)
-			param.Add("OPERATION", "COPYRESOURCE");
+        public string CopyResource(string source, string target, bool overwrite)
+            param.Add("OPERATION", "COPYRESOURCE");
-		public string EnumerateResourceReferences(string resourceid)
-			param.Add("OPERATION", "ENUMERATERESOURCEREFERENCES");
+        public string EnumerateResourceReferences(string resourceid)
+            param.Add("OPERATION", "ENUMERATERESOURCEREFERENCES");
-		public System.Net.WebRequest GetMapImage(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups, System.IO.Stream outStream)
-			param.Add("OPERATION", "GETMAPIMAGE");
-			param.Add("MAPNAME", mapname);
+        public System.Net.WebRequest GetMapImage(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups, System.IO.Stream outStream)
+            param.Add("OPERATION", "GETMAPIMAGE");
+            param.Add("MAPNAME", mapname);
-			if (format != null && format.Length != 0)
-				param.Add("FORMAT", format);
+            if (format != null && format.Length != 0)
+                param.Add("FORMAT", format);
-			if (selectionXml != null && selectionXml.Length != 0)
-				param.Add("SELECTION", selectionXml);
-			param.Add("SETVIEWCENTERX", Utility.SerializeDigit(centerX));
-			param.Add("SETVIEWCENTERY", Utility.SerializeDigit(centerY));
-			param.Add("SETVIEWSCALE", Utility.SerializeDigit(scale));
-			param.Add("SETDISPLAYDPI", dpi.ToString());
-			param.Add("SETDISPLAYWIDTH", width.ToString());
-			param.Add("SETDISPLAYHEIGHT", height.ToString());
+            if (selectionXml != null && selectionXml.Length != 0)
+                param.Add("SELECTION", selectionXml);
+            param.Add("SETVIEWCENTERX", Utility.SerializeDigit(centerX));
+            param.Add("SETVIEWCENTERY", Utility.SerializeDigit(centerY));
+            param.Add("SETVIEWSCALE", Utility.SerializeDigit(scale));
+            param.Add("SETDISPLAYDPI", dpi.ToString());
+            param.Add("SETDISPLAYWIDTH", width.ToString());
+            param.Add("SETDISPLAYHEIGHT", height.ToString());
-			if (showlayers != null && showlayers.Length > 0)
-				param.Add("SHOWLAYERS", string.Join(",", showlayers));
-			if (hidelayers != null && hidelayers.Length > 0)
-				param.Add("HIDELAYERS", string.Join(",", hidelayers));
-			if (showgroups != null && showgroups.Length > 0)
-				param.Add("SHOWGROUPS", string.Join(",", showgroups));
-			if (hidegroups != null && hidegroups.Length > 0)
-				param.Add("HIDEGROUPS", string.Join(",", hidegroups));
+            if (showlayers != null && showlayers.Length > 0)
+                param.Add("SHOWLAYERS", string.Join(",", showlayers));
+            if (hidelayers != null && hidelayers.Length > 0)
+                param.Add("HIDELAYERS", string.Join(",", hidelayers));
+            if (showgroups != null && showgroups.Length > 0)
+                param.Add("SHOWGROUPS", string.Join(",", showgroups));
+            if (hidegroups != null && hidegroups.Length > 0)
+                param.Add("HIDEGROUPS", string.Join(",", hidegroups));
             param.Add("CLIP", clip ? "1" : "0");
-			//TODO: Find out if this actually works...
-			//param.Add("REFRESHLAYERS", ...)
+            //TODO: Find out if this actually works...
+            //param.Add("REFRESHLAYERS", ...)
-			string boundary;
+            string boundary;
-			return req;
+            return req;
         public System.Net.WebRequest GetMapImage(string mapname, string format, string selectionXml, double x1, double y1, double x2, double y2, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups, System.IO.Stream outStream)
@@ -914,48 +930,48 @@
         public string BuildRequest(NameValueCollection param)
-		public string GetMapImageUrl(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups)
+        public string GetMapImageUrl(string mapname, string format, string selectionXml, double centerX, double centerY, double scale, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups)
         public string GetMapImageUrl(string mapname, string format, string selectionXml, double x1, double y1, double x2, double y2, int dpi, int width, int height, bool clip, string[] showlayers, string[] hidelayers, string[] showgroups, string[] hidegroups)
@@ -994,31 +1010,31 @@
-		public System.Net.WebRequest QueryMapFeatures(string mapname, bool persist, string geometry, System.IO.Stream outStream, QueryMapFeaturesLayerAttributes attributes)
-			param.Add("OPERATION", "QUERYMAPFEATURES");
-			param.Add("PERSIST", persist ? "1" : "0");
-			param.Add("GEOMETRY", geometry);
-			param.Add("SELECTIONVARIANT", "INTERSECTS");
-			param.Add("MAXFEATURES", "-1");
-			param.Add("LAYERATTRIBUTEFILTER", ((int)attributes).ToString());
+        public System.Net.WebRequest QueryMapFeatures(string mapname, bool persist, string geometry, System.IO.Stream outStream, QueryMapFeaturesLayerAttributes attributes)
+            param.Add("OPERATION", "QUERYMAPFEATURES");
+            param.Add("PERSIST", persist ? "1" : "0");
+            param.Add("GEOMETRY", geometry);
+            param.Add("SELECTIONVARIANT", "INTERSECTS");
+            param.Add("MAXFEATURES", "-1");
+            param.Add("LAYERATTRIBUTEFILTER", ((int)attributes).ToString());
-			string boundary;
+            string boundary;
-			return req;
+            return req;
         internal System.Net.WebRequest QueryMapFeatures(string runtimeMapName, int maxFeatures, string wkt, bool persist, string selectionVariant, Services.QueryMapOptions extraOptions, System.IO.Stream outStream)
@@ -1053,113 +1069,113 @@
             return req;
-		public string EnumerateApplicationTemplates()
-			param.Add("OPERATION", "ENUMERATEAPPLICATIONTEMPLATES");
+        public string EnumerateApplicationTemplates()
+            param.Add("OPERATION", "ENUMERATEAPPLICATIONTEMPLATES");
-		public string EnumerateApplicationWidgets()
-			param.Add("OPERATION", "ENUMERATEAPPLICATIONWIDGETS");
+        public string EnumerateApplicationWidgets()
+            param.Add("OPERATION", "ENUMERATEAPPLICATIONWIDGETS");
-		public string EnumerateApplicationContainers()
-			param.Add("OPERATION", "ENUMERATEAPPLICATIONCONTAINERS");
+        public string EnumerateApplicationContainers()
+            param.Add("OPERATION", "ENUMERATEAPPLICATIONCONTAINERS");
-		public string GetSpatialContextInfo(string resourceID, bool activeOnly)
-			param.Add("OPERATION", "GETSPATIALCONTEXTS");
-			param.Add("RESOURCEID", resourceID);
-			param.Add("ACTIVEONLY", activeOnly ? "1" : "0");
+        public string GetSpatialContextInfo(string resourceID, bool activeOnly)
+            param.Add("OPERATION", "GETSPATIALCONTEXTS");
+            param.Add("RESOURCEID", resourceID);
+            param.Add("ACTIVEONLY", activeOnly ? "1" : "0");
-		public string HostURI { get { return m_hosturi; } }
+        public string HostURI { get { return m_hosturi; } }
-		public string GetIdentityProperties(string resourceID, string schema, string classname)
-			param.Add("OPERATION", "GETIDENTITYPROPERTIES");
+        public string GetIdentityProperties(string resourceID, string schema, string classname)
+            param.Add("OPERATION", "GETIDENTITYPROPERTIES");
-		public string EnumerateUnmanagedData(string startpath, string filter, bool recursive, UnmanagedDataTypes type)
-			param.Add("OPERATION", "ENUMERATEUNMANAGEDDATA");
+        public string EnumerateUnmanagedData(string startpath, string filter, bool recursive, UnmanagedDataTypes type)
+            param.Add("OPERATION", "ENUMERATEUNMANAGEDDATA");
             if (startpath != null)
-				param.Add("PATH", startpath);
-			param.Add("RECURSIVE", recursive ? "1" : "0");
-			if (type == UnmanagedDataTypes.Files)
-				param.Add("Type", "Files");
-			else if (type == UnmanagedDataTypes.Folders)
-				param.Add("Type", "Folders");
-			else
-				param.Add("Type", "Both");
+                param.Add("PATH", startpath);
+            param.Add("RECURSIVE", recursive ? "1" : "0");
+            if (type == UnmanagedDataTypes.Files)
+                param.Add("Type", "Files");
+            else if (type == UnmanagedDataTypes.Folders)
+                param.Add("Type", "Folders");
+            else
+                param.Add("Type", "Both");
         public string EnumerateUsers(string group)
More information about the mapguide-commits mailing list
