[mapguide-commits] r7526 - branches/maestro-4.0.x/MgCooker
svn_mapguide at osgeo.org
Mon May 27 05:01:53 PDT 2013
Author: jng
Date: 2013-05-27 05:01:53 -0700 (Mon, 27 May 2013)
New Revision: 7526
branches/maestro-4.0.x/MgCooker/Program.cs
#2277: Fix MgCooker command-line ignoring basegroup parameter. Patch by dcreado
Modified: branches/maestro-4.0.x/MgCooker/Program.cs
--- branches/maestro-4.0.x/MgCooker/Program.cs 2013-05-27 12:00:08 UTC (rev 7525)
+++ branches/maestro-4.0.x/MgCooker/Program.cs 2013-05-27 12:01:53 UTC (rev 7526)
@@ -211,21 +211,6 @@
BatchSettings bx = new BatchSettings(connection);
- if (!string.IsNullOrEmpty(basegroups))
- List<string> groups = new List<string>();
- foreach (string s in basegroups.Split(','))
- string f = s;
- if (f.StartsWith("\""))
- f = f.Substring(1);
- if (f.EndsWith("\""))
- f = f.Substring(0, f.Length - 1);
- groups.Add(f);
- bx.SetGroups(groups.ToArray());
int x;
if (!string.IsNullOrEmpty(limitCols) && int.TryParse(limitCols, out x))
@@ -256,6 +241,22 @@
bx.AddMapDefinitions(maps);
+ //basegroups must be set in each mapdefinition
+ if (!string.IsNullOrEmpty(basegroups))
+ List<string> groups = new List<string>();
+ foreach (string s in basegroups.Split(','))
+ string f = s;
+ if (f.StartsWith("\""))
+ f = f.Substring(1);
+ if (f.EndsWith("\""))
+ f = f.Substring(0, f.Length - 1);
+ groups.Add(f);
+ bx.SetGroups(groups.ToArray());
if (!string.IsNullOrEmpty(scaleindex))
List<int> scales = new List<int>();
More information about the mapguide-commits
