[mapguide-commits] r7527 - branches/maestro-4.0.x/Maestro
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 27 05:22:11 PDT 2013
Author: jng
Date: 2013-05-27 05:22:10 -0700 (Mon, 27 May 2013)
New Revision: 7527
   branches/maestro-4.0.x/Maestro/changelog.txt
changelog.txt update
Modified: branches/maestro-4.0.x/Maestro/changelog.txt
--- branches/maestro-4.0.x/Maestro/changelog.txt	2013-05-27 12:01:53 UTC (rev 7526)
+++ branches/maestro-4.0.x/Maestro/changelog.txt	2013-05-27 12:22:10 UTC (rev 7527)
@@ -1,6 +1,9 @@
 4.0.5
  - Support Resampling Method in GDAL Feature Source editor
+ - Fix: MgCooker command-line ignoring basegroup parameter
+ - Fix: Gracefully handle unsupported behaviour for Local Connection when invoking the Resource Properties command
+ - Fix: NullReferenceException when using cut command on an item in the Site Explorer
  - Fix: custom scale indexes passed from command-line ignored by MgCooker
  - Fix: Scale ranges not initialized correctly when creating a RuntimeMap
  - Fix: Group parentage not assigned when creating RuntimeMap
More information about the mapguide-commits mailing list
