[mapguide-commits] r8103 - branches/2.6/MgDev
svn_mapguide at osgeo.org
Sat May 3 02:33:50 PDT 2014
Author: jng
Date: 2014-05-03 02:33:50 -0700 (Sat, 03 May 2014)
New Revision: 8103
branches/2.6/MgDev/prepare_webtier_components.bat
Make prepare_webtier_components.bat more resilient in light of Windows' woeful inability to delete a directory with 100% reliability from the command-line meaning empty httpd and php directories that are left behind will slip pass the check in the previous iteration of this script that determines if we need to re-extract the PHP and httpd tarballs
Modified: branches/2.6/MgDev/prepare_webtier_components.bat
--- branches/2.6/MgDev/prepare_webtier_components.bat 2014-05-03 08:38:10 UTC (rev 8102)
+++ branches/2.6/MgDev/prepare_webtier_components.bat 2014-05-03 09:33:50 UTC (rev 8103)
@@ -3,27 +3,54 @@
SET HTTPD_VER=2.4.9
SET PHP_VER=5.5.11
pushd Oem\LinuxApt
-if exist httpd-%HTTPD_VER% (
- echo httpd already unpacked. Nothing to do here.
- goto check_php
+:check_httpd
+if not exist httpd-%HTTPD_VER% goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\httpd.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_config.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\ap_config.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_log.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_protocol.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_main.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\util_script.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_core.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\apr_strings.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\apr_tables.h goto unpack_httpd
+goto check_php
:unpack_httpd
if not exist httpd-%HTTPD_VER%.tar "%SEVENZ%" x httpd-%HTTPD_VER%.tar.bz2
-if not exist httpd-%HTTPD_VER% "%SEVENZ%" x httpd-%HTTPD_VER%.tar
+"%SEVENZ%" x -y httpd-%HTTPD_VER%.tar
:check_php
-if exist php-%PHP_VER% (
- echo PHP already unpacked. Nothing to do here
- goto patch_php_headers
+rem *sigh* there is not a 100% reliable way to nuke a directory in windows from the cmd line to make way
+rem for a new MapGuide build, meaning we could have empty PHP directories from a previous build that would
+rem pass the previous iteration of this check to determine if PHP needs to be unpacked. So check for the specific
+rem headers that we know we are going to be using and if a single one of these headers cannot be found then
+rem do the archive unpacking
+if not exist php-%PHP_VER% goto unpack_php
+if not exist php-%PHP_VER%\ext goto unpack_php
+if not exist php-%PHP_VER%\ext\standard goto unpack_php
+if not exist php-%PHP_VER%\ext\standard\info.h goto unpack_php
+if not exist php-%PHP_VER%\main goto unpack_php
+if not exist php-%PHP_VER%\main\php.h goto unpack_php
+if not exist php-%PHP_VER%\main\php_ini.h goto unpack_php
+if not exist php-%PHP_VER%\main\config.w32.h goto unpack_php
+if not exist php-%PHP_VER%\main\win95nt.h goto unpack_php
+if not exist php-%PHP_VER%\TSRM goto unpack_php
+if not exist php-%PHP_VER%\TSRM\readdir.h goto unpack_php
+if not exist php-%PHP_VER%\Zend goto unpack_php
+if not exist php-%PHP_VER%\Zend\zend.h goto unpack_php
+if not exist php-%PHP_VER%\Zend\zend_exceptions.h goto unpack_php
+if not exist php-%PHP_VER%\Zend\zend_API.h goto unpack_php
+goto patch_php_headers
:unpack_php
if not exist php-%PHP_VER%.tar "%SEVENZ%" x php-%PHP_VER%.tar.bz2
-if not exist php-%PHP_VER% "%SEVENZ%" x php-%PHP_VER%.tar
+"%SEVENZ%" x -y php-%PHP_VER%.tar
:patch_php_headers
echo Patching PHP headers
-copy /Y ..\php\main\*.h php-%PHP_VER%\main
-copy /Y ..\php\TSRM\*.h php-%PHP_VER%\TSRM
+copy /Y ..\php\main\*.h php-%PHP_VER%\main\
+copy /Y ..\php\TSRM\*.h php-%PHP_VER%\TSRM\
:patch_httpd_headers
echo Patching HTTPD headers
-copy /Y ..\httpd\include\*.h httpd-%HTTPD_VER%\include
+copy /Y ..\httpd\include\*.h httpd-%HTTPD_VER%\include\
:done
popd
More information about the mapguide-commits
