[mapguide-commits] r8104 - trunk/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat May 3 02:45:23 PDT 2014
Author: jng
Date: 2014-05-03 02:45:23 -0700 (Sat, 03 May 2014)
New Revision: 8104
   trunk/MgDev/prepare_webtier_components.bat
Merge r8103 from 2.6 branch
Modified: trunk/MgDev/prepare_webtier_components.bat
--- trunk/MgDev/prepare_webtier_components.bat	2014-05-03 09:33:50 UTC (rev 8103)
+++ trunk/MgDev/prepare_webtier_components.bat	2014-05-03 09:45:23 UTC (rev 8104)
@@ -3,27 +3,54 @@
 SET HTTPD_VER=2.4.9
 SET PHP_VER=5.5.11
 pushd Oem\LinuxApt
-if exist httpd-%HTTPD_VER% (
-    echo httpd already unpacked. Nothing to do here.
-    goto check_php
+:check_httpd
+if not exist httpd-%HTTPD_VER% goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\httpd.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_config.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\ap_config.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_log.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_protocol.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_main.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\util_script.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\http_core.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\apr_strings.h goto unpack_httpd
+if not exist httpd-%HTTPD_VER%\include\apr_tables.h goto unpack_httpd
+goto check_php
 :unpack_httpd
 if not exist httpd-%HTTPD_VER%.tar "%SEVENZ%" x httpd-%HTTPD_VER%.tar.bz2
-if not exist httpd-%HTTPD_VER% "%SEVENZ%" x httpd-%HTTPD_VER%.tar
+"%SEVENZ%" x -y httpd-%HTTPD_VER%.tar
 :check_php
-if exist php-%PHP_VER% (
-    echo PHP already unpacked. Nothing to do here
-    goto patch_php_headers
+rem *sigh* there is not a 100% reliable way to nuke a directory in windows from the cmd line to make way
+rem for a new MapGuide build, meaning we could have empty PHP directories from a previous build that would
+rem pass the previous iteration of this check to determine if PHP needs to be unpacked. So check for the specific
+rem headers that we know we are going to be using and if a single one of these headers cannot be found then
+rem do the archive unpacking
+if not exist php-%PHP_VER% goto unpack_php
+if not exist php-%PHP_VER%\ext goto unpack_php
+if not exist php-%PHP_VER%\ext\standard goto unpack_php
+if not exist php-%PHP_VER%\ext\standard\info.h goto unpack_php
+if not exist php-%PHP_VER%\main goto unpack_php
+if not exist php-%PHP_VER%\main\php.h goto unpack_php
+if not exist php-%PHP_VER%\main\php_ini.h goto unpack_php
+if not exist php-%PHP_VER%\main\config.w32.h goto unpack_php
+if not exist php-%PHP_VER%\main\win95nt.h goto unpack_php
+if not exist php-%PHP_VER%\TSRM goto unpack_php
+if not exist php-%PHP_VER%\TSRM\readdir.h goto unpack_php
+if not exist php-%PHP_VER%\Zend goto unpack_php
+if not exist php-%PHP_VER%\Zend\zend.h goto unpack_php
+if not exist php-%PHP_VER%\Zend\zend_exceptions.h goto unpack_php
+if not exist php-%PHP_VER%\Zend\zend_API.h goto unpack_php
+goto patch_php_headers
 :unpack_php
 if not exist php-%PHP_VER%.tar "%SEVENZ%" x php-%PHP_VER%.tar.bz2
-if not exist php-%PHP_VER% "%SEVENZ%" x php-%PHP_VER%.tar
+"%SEVENZ%" x -y php-%PHP_VER%.tar
 :patch_php_headers
 echo Patching PHP headers
-copy /Y ..\php\main\*.h php-%PHP_VER%\main
-copy /Y ..\php\TSRM\*.h php-%PHP_VER%\TSRM
+copy /Y ..\php\main\*.h php-%PHP_VER%\main\
+copy /Y ..\php\TSRM\*.h php-%PHP_VER%\TSRM\
 :patch_httpd_headers
 echo Patching HTTPD headers
-copy /Y ..\httpd\include\*.h httpd-%HTTPD_VER%\include
+copy /Y ..\httpd\include\*.h httpd-%HTTPD_VER%\include\
 :done
 popd
More information about the mapguide-commits mailing list
