[mapguide-commits] r8157 - in trunk/MgDev/Web/src: DotNetUnmanagedApi/MapGuideCommon MapGuideApi
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 26 01:45:32 PDT 2014
Author: jng
Date: 2014-05-26 01:45:32 -0700 (Mon, 26 May 2014)
New Revision: 8157
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonConstants.xml
   trunk/MgDev/Web/src/MapGuideApi/Constants.xml
#2449: Fix MgImageFormats not exposed to public API.
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonConstants.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonConstants.xml	2014-05-26 07:31:30 UTC (rev 8156)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonConstants.xml	2014-05-26 08:45:32 UTC (rev 8157)
@@ -65,6 +65,7 @@
   <Class name="MgPageUnitsType" />
   <Class name="MgCoordinateSpace" />
   <Class name="MgConfigProperties" />
+  <Class name="MgImageFormats" />
   <Class name="MgMapPlotInstruction" />
   <Class name="MgUnitType" />
   <Class name="MgLogFileType" />
@@ -79,6 +80,7 @@
 <Headers>
   <!-- API -->
+  <Header path="../../../../Common/MapGuideCommon/Services/ImageFormats.h" />
   <Header path="../../../../Common/MapGuideCommon/Services/MappingDefs.h" />
   <Header path="../../../../Common/MapGuideCommon/Services/MapPlotInstruction.h" />
   <Header path="../../../../Common/MapGuideCommon/Services/ServerAdminDefs.h" />
Modified: trunk/MgDev/Web/src/MapGuideApi/Constants.xml
--- trunk/MgDev/Web/src/MapGuideApi/Constants.xml	2014-05-26 07:31:30 UTC (rev 8156)
+++ trunk/MgDev/Web/src/MapGuideApi/Constants.xml	2014-05-26 08:45:32 UTC (rev 8157)
@@ -123,6 +123,7 @@
   <Class name="MgCoordinateSystemGeodeticAnalyticalTransformationMethod" />
   <Class name="MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod" />
   <Class name="MgCoordinateSystemGeodeticTransformGridFileFormat" />
   <Class name="MgPackageStatus" />
@@ -181,6 +182,7 @@
     <Header path="../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h" />
     <Header path="../../../Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h" />
+    <Header path="../../../Common/MapGuideCommon/Services/ImageFormats.h" />
     <Header path="../../../Common/MapGuideCommon/Services/MappingDefs.h" />
     <Header path="../../../Common/MapGuideCommon/Services/MapPlotInstruction.h" />
     <Header path="../../../Common/MapGuideCommon/Services/ServerAdminDefs.h" />
More information about the mapguide-commits mailing list
