[mapguide-commits] r8158 - in trunk/MgDev/BuildTools/WebTools/IMake: . Win32
svn_mapguide at osgeo.org
Mon May 26 03:26:38 PDT 2014
Author: jng
Date: 2014-05-26 03:26:38 -0700 (Mon, 26 May 2014)
New Revision: 8158
Added:
trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj
Removed:
trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcproj
trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp
trunk/MgDev/BuildTools/WebTools/IMake/IMake.sln
trunk/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
IMake update:
- Upgrade to VS 2012
- Escape potential XML entities in the source API documentation when emitting .net XML API documentation
Modified: trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp
--- trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp 2014-05-26 08:45:32 UTC (rev 8157)
+++ trunk/MgDev/BuildTools/WebTools/IMake/IMake.cpp 2014-05-26 10:26:38 UTC (rev 8158)
@@ -12,7 +12,7 @@
java
-static char version[] = "1.2";
+static char version[] = "1.2.1";
static string module;
static string customPath;
@@ -540,6 +540,24 @@
return str.length() > 3; //A "///" does not count
+bool stringReplace(string& str, const string& find, const string& replace)
+ size_t start_pos = str.find(find);
+ if(start_pos == string::npos)
+ return false;
+ str.replace(start_pos, find.length(), replace);
+ return true;
+void xmlEscapeString(string& str)
+ stringReplace(str, "&", "&");
+ stringReplace(str, "'", "'");
+ stringReplace(str, "\"", """);
+ stringReplace(str, "<", "<");
+ stringReplace(str, ">", ">");
string linkifyCSharpDocFragment(const string& str)
// Explode the fragment into a space delimited list.
@@ -555,6 +573,7 @@
//interfere with doxygen directive translation
if (item == "\\link" || item == "\\endlink")
continue;
+ xmlEscapeString(item);
elems.push_back(item);
Modified: trunk/MgDev/BuildTools/WebTools/IMake/IMake.sln
--- trunk/MgDev/BuildTools/WebTools/IMake/IMake.sln 2014-05-26 08:45:32 UTC (rev 8157)
+++ trunk/MgDev/BuildTools/WebTools/IMake/IMake.sln 2014-05-26 10:26:38 UTC (rev 8158)
@@ -1,6 +1,6 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IMake", "IMake.vcproj", "{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio Express 2012 for Windows Desktop
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "IMake", "IMake.vcxproj", "{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Deleted: trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcproj
--- trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcproj 2014-05-26 08:45:32 UTC (rev 8157)
+++ trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcproj 2014-05-26 10:26:38 UTC (rev 8158)
@@ -1,211 +0,0 @@
-<?xml version="1.0" encoding="Windows-1252"?>
-<VisualStudioProject
- ProjectType="Visual C++"
- Version="9.00"
- Name="IMake"
- ProjectGUID="{B601F04C-0D42-4AFC-A092-B31185E2EA8C}"
- Keyword="Win32Proj"
- TargetFrameworkVersion="131072"
- <Platforms>
- <Platform
- Name="Win32"
- </Platforms>
- <ToolFiles>
- </ToolFiles>
- <Configurations>
- <Configuration
- Name="Debug|Win32"
- OutputDirectory="Win32"
- IntermediateDirectory="Debug"
- ConfigurationType="1"
- CharacterSet="2"
- <Tool
- Name="VCPreBuildEventTool"
- <Tool
- Name="VCCustomBuildTool"
- <Tool
- Name="VCXMLDataGeneratorTool"
- <Tool
- Name="VCWebServiceProxyGeneratorTool"
- <Tool
- Name="VCMIDLTool"
- <Tool
- Name="VCCLCompilerTool"
- Optimization="0"
- PreprocessorDefinitions="WIN32;_DEBUG;_CONSOLE"
- MinimalRebuild="true"
- BasicRuntimeChecks="3"
- RuntimeLibrary="1"
- UsePrecompiledHeader="2"
- WarningLevel="3"
- Detect64BitPortabilityProblems="false"
- DebugInformationFormat="3"
- <Tool
- Name="VCManagedResourceCompilerTool"
- <Tool
- Name="VCResourceCompilerTool"
- <Tool
- Name="VCPreLinkEventTool"
- <Tool
- Name="VCLinkerTool"
- OutputFile="$(OutDir)\IMake.exe"
- LinkIncremental="2"
- GenerateDebugInformation="true"
- ProgramDatabaseFile="$(OutDir)\IMake.pdb"
- SubSystem="1"
- RandomizedBaseAddress="1"
- DataExecutionPrevention="0"
- TargetMachine="1"
- <Tool
- Name="VCALinkTool"
- <Tool
- Name="VCManifestTool"
- <Tool
- Name="VCXDCMakeTool"
- <Tool
- Name="VCBscMakeTool"
- <Tool
- Name="VCFxCopTool"
- <Tool
- Name="VCAppVerifierTool"
- <Tool
- Name="VCPostBuildEventTool"
- </Configuration>
- <Configuration
- Name="Release|Win32"
- IntermediateDirectory="Release"
- CharacterSet="2"
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- Name="VCMIDLTool"
- <Tool
- PreprocessorDefinitions="WIN32;NDEBUG;_CONSOLE"
- RuntimeLibrary="0"
- WarningLevel="3"
- <Tool
- <Tool
- <Tool
- <Tool
- LinkIncremental="1"
- SubSystem="1"
- OptimizeReferences="2"
- EnableCOMDATFolding="2"
- TargetMachine="1"
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- </Configuration>
- </Configurations>
- <References>
- </References>
- <Files>
- <File
- RelativePath=".\IMake.cpp"
- </File>
- <File
- RelativePath=".\SimpleXmlParser.cpp"
- </File>
- <File
- RelativePath=".\SimpleXmlParser.h"
- </File>
- <File
- RelativePath=".\stdafx.cpp"
- <FileConfiguration
- <Tool
- UsePrecompiledHeader="1"
- </FileConfiguration>
- <Tool
- </File>
- <File
- RelativePath=".\stdafx.h"
- </File>
- </Files>
- <Globals>
- </Globals>
-</VisualStudioProject>
Added: trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj
--- trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj (rev 0)
+++ trunk/MgDev/BuildTools/WebTools/IMake/IMake.vcxproj 2014-05-26 10:26:38 UTC (rev 8158)
@@ -0,0 +1,106 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup Label="ProjectConfigurations">
+ <ProjectConfiguration Include="Debug|Win32">
+ <Configuration>Debug</Configuration>
+ <Platform>Win32</Platform>
+ </ProjectConfiguration>
+ <ProjectConfiguration Include="Release|Win32">
+ <Configuration>Release</Configuration>
+ </ItemGroup>
+ <PropertyGroup Label="Globals">
+ <ProjectGuid>{B601F04C-0D42-4AFC-A092-B31185E2EA8C}</ProjectGuid>
+ <Keyword>Win32Proj</Keyword>
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+ <ConfigurationType>Application</ConfigurationType>
+ <PlatformToolset>v110</PlatformToolset>
+ <CharacterSet>MultiByte</CharacterSet>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+ <ImportGroup Label="ExtensionSettings">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+ <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+ </ImportGroup>
+ <PropertyGroup Label="UserMacros" />
+ <PropertyGroup>
+ <_ProjectFileVersion>11.0.61030.0</_ProjectFileVersion>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <OutDir>Win32\</OutDir>
+ <IntDir>Debug\</IntDir>
+ <LinkIncremental>true</LinkIncremental>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <IntDir>Release\</IntDir>
+ <LinkIncremental>false</LinkIncremental>
+ </PropertyGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <ClCompile>
+ <Optimization>Disabled</Optimization>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <MinimalRebuild>true</MinimalRebuild>
+ <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
+ <RuntimeLibrary>MultiThreadedDebug</RuntimeLibrary>
+ <PrecompiledHeader>Use</PrecompiledHeader>
+ <WarningLevel>Level3</WarningLevel>
+ <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
+ </ClCompile>
+ <Link>
+ <OutputFile>$(OutDir)IMake.exe</OutputFile>
+ <GenerateDebugInformation>true</GenerateDebugInformation>
+ <ProgramDatabaseFile>$(OutDir)IMake.pdb</ProgramDatabaseFile>
+ <SubSystem>Console</SubSystem>
+ <RandomizedBaseAddress>false</RandomizedBaseAddress>
+ <DataExecutionPrevention />
+ <TargetMachine>MachineX86</TargetMachine>
+ </Link>
+ </ItemDefinitionGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <ClCompile>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <RuntimeLibrary>MultiThreaded</RuntimeLibrary>
+ </ClCompile>
+ <Link>
+ <OptimizeReferences>true</OptimizeReferences>
+ <EnableCOMDATFolding>true</EnableCOMDATFolding>
+ </Link>
+ <ItemGroup>
+ <ClCompile Include="IMake.cpp" />
+ <ClCompile Include="SimpleXmlParser.cpp" />
+ <ClCompile Include="stdafx.cpp">
+ <PrecompiledHeader Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Create</PrecompiledHeader>
+ <PrecompiledHeader Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Create</PrecompiledHeader>
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="SimpleXmlParser.h" />
+ <ClInclude Include="stdafx.h" />
+ </ItemGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+ <ImportGroup Label="ExtensionTargets">
+ </ImportGroup>
+</Project>
\ No newline at end of file
Modified: trunk/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
(Binary files differ)
More information about the mapguide-commits
