[mapguide-commits] r8447 - in trunk/Tools/Maestro: MaestroAPITests MaestroAPITests/UserTestData OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Http/Commands
svn_mapguide at osgeo.org
Thu Nov 13 23:16:17 PST 2014
Author: jng
Date: 2014-11-13 23:16:17 -0800 (Thu, 13 Nov 2014)
New Revision: 8447
Removed:
trunk/Tools/Maestro/MaestroAPITests/GeoRestTests.cs
trunk/Tools/Maestro/MaestroAPITests/UserTestData/GeoRestConfig.xml
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Commands/GeoRestCommands.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/GeoRestConnection.cs
#2502: Remove GeoREST related files
Deleted: trunk/Tools/Maestro/MaestroAPITests/GeoRestTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/GeoRestTests.cs 2014-11-14 07:09:50 UTC (rev 8446)
+++ trunk/Tools/Maestro/MaestroAPITests/GeoRestTests.cs 2014-11-14 07:16:17 UTC (rev 8447)
@@ -1,140 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2012, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion
-using System;
-using System.Collections.Generic;
-using System.Text;
-using NUnit.Framework;
-using OSGeo.MapGuide.MaestroAPI.Commands;
-using OSGeo.MapGuide.MaestroAPI.Feature;
-using System.Collections.Specialized;
-using OSGeo.MapGuide.MaestroAPI.Internal;
-namespace MaestroAPITests
- [TestFixture]
- public class GeoRestTests
- [TestFixtureSetUp]
- public void Setup()
- if (TestControl.IgnoreGeoRestTests)
- Assert.Ignore("Skipping GeoRestTests because TestControl.IgnoreGeoRestTests = true");
- [Test]
- public void TestInsert()
- var conn = ConnectionUtil.CreateTestHttpConnectionWithGeoRest();
- var insert = (IInsertFeatures)conn.CreateCommand((int)CommandType.InsertFeature);
- insert.ClassName = "SHP_Schema:Parcels";
- var rec = new MutableRecord();
- insert.RecordToInsert = rec;
- insert.FeatureSourceId = "Library://Samples/Sheboygan/Data/Parcels.FeatureSource";
- var dr = conn.FeatureService.AggregateQueryFeatureSource(
- insert.FeatureSourceId,
- "SHP_Schema:Parcels",
- null,
- new NameValueCollection()
- { "TOTAL", "COUNT(Autogenerated_SDF_ID)" }
- long lBefore = 0L;
- if (dr.ReadNext())
- lBefore = dr.GetInt64("TOTAL");
- dr.Close();
- var wktReader = new FixedWKTReader();
- rec.PutValue("RNAME", new StringValue("Hello World"));
- rec.PutValue("Geometry", new GeometryValue(wktReader.Read("POLYGON ((30 10, 10 20, 20 40, 40 40, 30 10))")));
- var res = insert.Execute();
- Assert.Null(res.Error);
- long lAfter = lBefore;
- dr = conn.FeatureService.AggregateQueryFeatureSource(
- null,
- lAfter = dr.GetInt64("TOTAL");
- dr.Close();
- Assert.AreEqual(lBefore + 1L, lAfter);
- [Test]
- public void TestInsertNotAllowed()
- insert.FeatureSourceId = "Library://Samples/Sheboygan/Data/ParcelsNotAllowed.FeatureSource";
- //This is not allowed
- Assert.IsAssignableFrom<InvalidOperationException>(res.Error);
- [Test]
- public void TestInsertNonConfigured()
- insert.ClassName = "SHP_Schema:Rail";
- insert.FeatureSourceId = "Library://Samples/Sheboygan/Data/Rail.FeatureSource";
- //This is not configured
- [Test]
- public void TestInsertNonConfigured2()
- insert.ClassName = "SHP_Schema:Foobar";
Deleted: trunk/Tools/Maestro/MaestroAPITests/UserTestData/GeoRestConfig.xml
--- trunk/Tools/Maestro/MaestroAPITests/UserTestData/GeoRestConfig.xml 2014-11-14 07:09:50 UTC (rev 8446)
+++ trunk/Tools/Maestro/MaestroAPITests/UserTestData/GeoRestConfig.xml 2014-11-14 07:16:17 UTC (rev 8447)
@@ -1,19 +0,0 @@
-<?xml version="1.0" ?>
-<GeoRestConfiguration>
- <GeoRestFeatureSource>
- <FeatureSource>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</FeatureSource>
- <FeatureClass>SHP_Schema:Parcels</FeatureClass>
- <UriPart>mgproperty</UriPart>
- <AllowInsert>true</AllowInsert>
- <AllowUpdate>false</AllowUpdate>
- <AllowDelete>false</AllowDelete>
- </GeoRestFeatureSource>
- <FeatureSource>Library://Samples/Sheboygan/Data/ParcelsNotAllowed.FeatureSource</FeatureSource>
- <UriPart>notallowed</UriPart>
- <AllowInsert>false</AllowInsert>
-</GeoRestConfiguration>
\ No newline at end of file
Deleted: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Commands/GeoRestCommands.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Commands/GeoRestCommands.cs 2014-11-14 07:09:50 UTC (rev 8446)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Commands/GeoRestCommands.cs 2014-11-14 07:16:17 UTC (rev 8447)
@@ -1,181 +0,0 @@
-#endregion
-using System;
-using System.Text;
-using System.Xml;
-using System.Net;
-using System.IO;
-using System.Diagnostics;
-namespace OSGeo.MapGuide.MaestroAPI.Http.Commands
- public class GeoRestInsertFeatures : DefaultInsertCommand<HttpServerConnection>
- internal GeoRestInsertFeatures(HttpServerConnection conn) : base(conn) { }
- protected override void ExecuteInternal()
- var gconn = base.ConnImpl.GeoRestConnection;
- if (gconn == null)
- throw new InvalidOperationException("Connection does not have a valid GeoREST url or configuration"); //LOCALIZEME
- if (!gconn.Configuration.IsGeoRestEnabled(this.FeatureSourceId, this.ClassName))
- throw new InvalidOperationException(this.FeatureSourceId + " (" + this.ClassName + ") is not GeoREST configured"); //LOCALIEME
- var fsConf = gconn.Configuration.GetFeatureSource(this.FeatureSourceId, this.ClassName);
- if (!fsConf.AllowInsert)
- throw new InvalidOperationException(this.FeatureSourceId + " (" + this.ClassName + ") is not configured for insert operations"); //LOCALIEME
- //Assemble XML to POST
- XmlDocument doc = new XmlDocument();
- var fs = doc.AppendChild(doc.CreateElement("FeatureSet"));
- var features = fs.AppendChild(doc.CreateElement("Features"));
- var feat = ConvertToFeatureElement(doc);
- features.AppendChild(feat);
- //Build GeoREST insert url
- string insertUrl = gconn.Url;
- if (!insertUrl.EndsWith("/"))
- insertUrl += "/";
- insertUrl += "rest/data/" + fsConf.UriPart + "/.xml";
- HttpWebRequest req = (HttpWebRequest)HttpWebRequest.Create(insertUrl);
- req.Method = "POST";
- req.ContentType = "application/xml; charset=\"UTF-8\"";
- req.Timeout = 10 * 1000;
- using (Stream reqStream = req.GetRequestStream())
- using (StreamWriter sw = new StreamWriter(reqStream))
- doc.Save(sw);
- HttpWebResponse resp = (HttpWebResponse)req.GetResponse();
-#if DEBUG
- using (var sr = new StreamReader(resp.GetResponseStream()))
- Trace.TraceInformation("GeoRest Insert:\n" + sr.ReadToEnd());
-#endif
- private XmlNode ConvertToFeatureElement(XmlDocument doc)
- XmlNode feat = doc.CreateElement("Feature");
- foreach (var propName in this.RecordToInsert.PropertyNames)
- var prop = doc.CreateElement("Property");
- var name = doc.CreateElement("Name");
- name.InnerText = propName;
- prop.AppendChild(name);
- var value = doc.CreateElement("Value");
- prop.AppendChild(value);
- if (!this.RecordToInsert.IsNull(propName))
- var pv = this.RecordToInsert.GetValue(propName);
- value.InnerText = pv.ValueAsString();
- feat.AppendChild(prop);
- return feat;
- public class GeoRestUpdateFeatures : DefaultUpdateCommand<HttpServerConnection>
- public override int ExecuteInternal()
- if (!gconn.Configuration.IsGeoRestEnabled(this.FeatureSourceId))
- throw new InvalidOperationException(this.FeatureSourceId + " is not GeoREST configured"); //LOCALIEME
- var fsConf = gconn.Configuration.GetFeatureSource(this.FeatureSourceId);
- throw new InvalidOperationException(this.FeatureSourceId + " is not configured for insert operations"); //LOCALIEME
- HttpWebRequest req = (HttpWebRequest)HttpWebRequest.Create(gconn.Url);
- req.ContentType = "text/xml";
- Stream reqStream = req.GetRequestStream();
- doc.Save(reqStream);
-#if DEBUG
-#endif
- return 1;
- foreach (var propName in this.ValuesToUpdate.PropertyNames)
- if (!this.ValuesToUpdate.IsNull(propName))
- var pv = this.ValuesToUpdate.GetValue(propName);
- return feat;
- public class GeoRestDeleteFeatures : DefaultDeleteCommand<HttpServerConnection>
- protected override int ExecuteInternal()
- var gconn = base.ConnImpl;
Deleted: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/GeoRestConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/GeoRestConnection.cs 2014-11-14 07:09:50 UTC (rev 8446)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/GeoRestConnection.cs 2014-11-14 07:16:17 UTC (rev 8447)
@@ -1,114 +0,0 @@
-#endregion
-using System;
-using System.Text;
-using System.IO;
-using System.Xml;
- internal class GeoRestConnection
- private string _geoRestUrl;
- private string _configFile;
- private GeoRestFeatureSourceConfiguration _conf;
- public GeoRestFeatureSourceConfiguration Configuration { get { return _conf; } }
- internal GeoRestConnection(string url, string configFile)
- _geoRestUrl = url;
- _configFile = configFile;
- _conf = GeoRestFeatureSourceConfiguration.LoadFrom(configFile);
- public string Url { get { return _geoRestUrl; } }
- public string ConfigPath { get { return _configFile; } }
- internal class GeoRestFeatureSourceConfiguration
- private Dictionary<string, GeoRestFeatureSource> _configuredFeatureSources;
- private GeoRestFeatureSourceConfiguration()
- _configuredFeatureSources = new Dictionary<string, GeoRestFeatureSource>();
- private void PutConfig(string featureSource, string featureClass, GeoRestFeatureSource fs)
- _configuredFeatureSources[featureSource + "|" + featureClass] = fs;
- public bool IsGeoRestEnabled(string featureSource, string featureClass) { return _configuredFeatureSources.ContainsKey(featureSource + "|" + featureClass); }
- public ICollection<string> FeatureSources { get { return _configuredFeatureSources.Keys; } }
- public GeoRestFeatureSource GetFeatureSource(string featureSource, string featureClass) { return _configuredFeatureSources[featureSource + "|" + featureClass]; }
- internal static GeoRestFeatureSourceConfiguration LoadFrom(string configFile)
- var conf = new GeoRestFeatureSourceConfiguration();
- if (!string.IsNullOrEmpty(configFile) && File.Exists(configFile))
- doc.Load(configFile);
- XmlNodeList fsNodes = doc.GetElementsByTagName("GeoRestFeatureSource");
- foreach (XmlNode fsNode in fsNodes)
- var gfs = new GeoRestFeatureSource()
- FeatureSourceId = fsNode["FeatureSource"].InnerText,
- FeatureClass = fsNode["FeatureClass"].InnerText,
- UriPart = fsNode["UriPart"].InnerText,
- AllowInsert = bool.Parse(fsNode["AllowInsert"].InnerText),
- AllowUpdate = bool.Parse(fsNode["AllowUpdate"].InnerText),
- AllowDelete = bool.Parse(fsNode["AllowDelete"].InnerText)
- conf.PutConfig(gfs.FeatureSourceId, gfs.FeatureClass, gfs);
- return conf;
- public class GeoRestFeatureSource
- public string FeatureSourceId { get; set; }
- public string UriPart { get; set; }
- public string FeatureClass { get; set; }
- public bool AllowInsert { get; set; }
- public bool AllowUpdate { get; set; }
- public bool AllowDelete { get; set; }
More information about the mapguide-commits
