[mapguide-commits] r8448 - trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org
Fri Nov 14 01:48:43 PST 2014
Author: jng
Date: 2014-11-14 01:48:43 -0800 (Fri, 14 Nov 2014)
New Revision: 8448
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs
tab -> space cleanup
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs 2014-11-14 07:16:17 UTC (rev 8447)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs 2014-11-14 09:48:43 UTC (rev 8448)
@@ -25,16 +25,16 @@
namespace OSGeo.MapGuide.MaestroAPI
using CoordinateSystem;
- /// <summary>
- /// Interface to MapGuide coordinate system functions.
- /// Only works with server > 1.2, since the coordinate mapping is not avalible through Http on older versions
- /// </summary>
+ /// <summary>
+ /// Interface to MapGuide coordinate system functions.
+ /// Only works with server > 1.2, since the coordinate mapping is not avalible through Http on older versions
+ /// </summary>
public class HttpCoordinateSystemDefinition : CoordinateSystem.CoordinateSystemDefinitionBase
internal HttpCoordinateSystemDefinition() : base() { }
internal HttpCoordinateSystemDefinition(CoordinateSystemCategory parent, XmlNode topnode) : base(parent)
foreach (XmlNode node in topnode.ChildNodes)
switch (node["Name"].InnerText.ToLower())
@@ -65,6 +65,6 @@
break;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs 2014-11-14 07:16:17 UTC (rev 8447)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs 2014-11-14 09:48:43 UTC (rev 8448)
@@ -28,81 +28,81 @@
public class HttpCoordinateSystemCatalog : CoordinateSystemCatalog
private HttpServerConnection m_con;
- private RequestBuilder m_req;
- private CoordinateSystemCategory[] m_categories;
- private string m_coordLib = null;
+ private RequestBuilder m_req;
+ private CoordinateSystemCategory[] m_categories;
+ private string m_coordLib = null;
internal HttpCoordinateSystemCatalog(HttpServerConnection con, RequestBuilder req)
- m_con = con;
- m_req = req;
+ m_con = con;
+ m_req = req;
- internal HttpServerConnection Connection { get { return m_con; } }
- internal RequestBuilder RequestBuilder { get { return m_req; } }
+ internal HttpServerConnection Connection { get { return m_con; } }
+ internal RequestBuilder RequestBuilder { get { return m_req; } }
public override CoordinateSystemCategory[] Categories
- get
- if (m_categories == null)
- string req = m_req.EnumerateCategories();
- XmlDocument doc = new XmlDocument();
- doc.Load(m_con.OpenRead(req));
- XmlNodeList lst = doc.SelectNodes("StringCollection/Item");
+ get
+ if (m_categories == null)
+ string req = m_req.EnumerateCategories();
+ XmlDocument doc = new XmlDocument();
+ doc.Load(m_con.OpenRead(req));
+ XmlNodeList lst = doc.SelectNodes("StringCollection/Item");
CoordinateSystemCategory[] data = new CoordinateSystemCategory[lst.Count];
- for(int i = 0; i < lst.Count; i++)
- data[i] = new HttpCoordinateSystemCategory(this, lst[i].InnerText);
- m_categories = data;
+ for(int i = 0; i < lst.Count; i++)
+ data[i] = new HttpCoordinateSystemCategory(this, lst[i].InnerText);
+ m_categories = data;
- return m_categories;
+ return m_categories;
public override string LibraryName
- get
- if (m_coordLib == null)
- string req = m_req.GetBaseLibrary();
- m_coordLib = System.Text.Encoding.UTF8.GetString(m_con.DownloadData(req));
- return m_coordLib;
+ get
+ if (m_coordLib == null)
+ string req = m_req.GetBaseLibrary();
+ m_coordLib = System.Text.Encoding.UTF8.GetString(m_con.DownloadData(req));
+ return m_coordLib;
public override bool IsValid(string wkt)
- string req = m_req.IsValidCoordSys(wkt);
- return System.Text.Encoding.UTF8.GetString(m_con.DownloadData(req)).ToLower().Trim().Equals("true");
+ string req = m_req.IsValidCoordSys(wkt);
+ return System.Text.Encoding.UTF8.GetString(m_con.DownloadData(req)).ToLower().Trim().Equals("true");
public override string ConvertWktToCoordinateSystemCode(string wkt)
- string req = m_req.ConvertWktToCoordinateSystemCode(wkt);
+ string req = m_req.ConvertWktToCoordinateSystemCode(wkt);
return System.Text.Encoding.UTF8.GetString(m_con.DownloadData(req)).Trim('\0');
public override string ConvertCoordinateSystemCodeToWkt(string coordcode)
- string req = m_req.ConvertCoordinateSystemCodeToWkt(coordcode);
+ string req = m_req.ConvertCoordinateSystemCodeToWkt(coordcode);
public override string ConvertWktToEpsgCode(string wkt)
- string req = m_req.ConvertWktToEpsgCode(wkt);
+ string req = m_req.ConvertWktToEpsgCode(wkt);
public override string ConvertEpsgCodeToWkt(string epsg)
- string req = m_req.ConvertEpsgCodeToWkt(epsg);
+ string req = m_req.ConvertEpsgCodeToWkt(epsg);
public override bool IsLoaded { get { return m_categories != null; } }
More information about the mapguide-commits
