[mapguide-commits] r8613 - in branches/2.6/MgDev: . Server/src/Core Web/src/JavaApi Web/src/JavaApiEx Web/src/PhpApi Web/src/schemareport
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Apr 2 04:36:01 PDT 2015
Author: jng
Date: 2015-04-02 04:36:00 -0700 (Thu, 02 Apr 2015)
New Revision: 8613
   branches/2.6/MgDev/
   branches/2.6/MgDev/Server/src/Core/Makefile.am
   branches/2.6/MgDev/Web/src/JavaApi/Makefile.am
   branches/2.6/MgDev/Web/src/JavaApiEx/Makefile.am
   branches/2.6/MgDev/Web/src/PhpApi/Makefile.am
   branches/2.6/MgDev/Web/src/schemareport/displayschema.php
Merged revision(s) 8423, 8433, 8439 from trunk/MgDev:
#309: Ensure /var/lock/mgserver is created in mgserver.sh and mgserverd.sh
#2495: Disable VTA flag when compiling Java and PHP wrappers
#2499: Schema report: ShowFirstClass doesn't work. On behalf of Andy Zhang.
http://trac.osgeo.org/mapguide/ticket/2499
The JS function ShowFirstClass in displayschema.php doesn't work. It is because the element name is "Data_"+schemaName+"_"+className. But ShowFirstClass uses "Data_"+className to get the element.
Property changes on: branches/2.6/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8443
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8423,8433,8439,8443
Modified: branches/2.6/MgDev/Server/src/Core/Makefile.am
--- branches/2.6/MgDev/Server/src/Core/Makefile.am	2015-04-01 15:50:42 UTC (rev 8612)
+++ branches/2.6/MgDev/Server/src/Core/Makefile.am	2015-04-02 11:36:00 UTC (rev 8613)
@@ -435,6 +435,7 @@
 	@echo 'export MENTOR_DICTIONARY_PATH=$(mentor_dict_install_dir)' >> ${prefix}/bin/mgserver.sh
 	@echo 'export LD_LIBRARY_PATH=$(fdodir):"$$LD_LIBRARY_PATH"' >> ${prefix}/bin/mgserver.sh
 	@echo 'export NLSPATH=$(map_fdo_nls):"$$NLSPATH"' >> ${prefix}/bin/mgserver.sh
+	@echo 'mkdir -p /var/lock/mgserver' >> ${prefix}/bin/mgserver.sh
 	@echo 'pushd ${prefix}/bin' >> ${prefix}/bin/mgserver.sh
 	@cp -f ${prefix}/bin/mgserver.sh ${prefix}/bin/mgserverd.sh
 	@echo './mgserver run' >> ${prefix}/bin/mgserver.sh
Modified: branches/2.6/MgDev/Web/src/JavaApi/Makefile.am
--- branches/2.6/MgDev/Web/src/JavaApi/Makefile.am	2015-04-01 15:50:42 UTC (rev 8612)
+++ branches/2.6/MgDev/Web/src/JavaApi/Makefile.am	2015-04-02 11:36:00 UTC (rev 8613)
@@ -30,7 +30,7 @@
 nodist_libMapGuideJavaApi_la_SOURCES = MgApi_wrap.cpp
-AM_CXXFLAGS = @CXXFLAGS@ -fno-strict-aliasing -DJAVA
+AM_CXXFLAGS = @CXXFLAGS@ -fno-strict-aliasing -fno-var-tracking-assignments -DJAVA
 libMapGuideJavaApi_la_LIBADD = \
     -lACE \
Modified: branches/2.6/MgDev/Web/src/JavaApiEx/Makefile.am
--- branches/2.6/MgDev/Web/src/JavaApiEx/Makefile.am	2015-04-01 15:50:42 UTC (rev 8612)
+++ branches/2.6/MgDev/Web/src/JavaApiEx/Makefile.am	2015-04-02 11:36:00 UTC (rev 8613)
@@ -30,7 +30,7 @@
 nodist_libMapGuideJavaApiEx_la_SOURCES = MgApi_wrap.cpp
 libMapGuideJavaApiEx_la_LIBADD = \
     -lACE \
Modified: branches/2.6/MgDev/Web/src/PhpApi/Makefile.am
--- branches/2.6/MgDev/Web/src/PhpApi/Makefile.am	2015-04-01 15:50:42 UTC (rev 8612)
+++ branches/2.6/MgDev/Web/src/PhpApi/Makefile.am	2015-04-02 11:36:00 UTC (rev 8613)
@@ -28,7 +28,7 @@
 nodist_libphp_MapGuideApi_la_SOURCES = MgApi_wrap.cpp
-AM_CXXFLAGS = @CXXFLAGS@ -DPHP -DPHPPROXYAPI_EXPORTS
+AM_CXXFLAGS = @CXXFLAGS@ -fno-var-tracking-assignments -DPHP -DPHPPROXYAPI_EXPORTS
 libphp_MapGuideApi_la_LIBADD = \
     -lACE \
Modified: branches/2.6/MgDev/Web/src/schemareport/displayschema.php
--- branches/2.6/MgDev/Web/src/schemareport/displayschema.php	2015-04-01 15:50:42 UTC (rev 8612)
+++ branches/2.6/MgDev/Web/src/schemareport/displayschema.php	2015-04-02 11:36:00 UTC (rev 8613)
@@ -39,6 +39,7 @@
             $schemaName = $_GET['schemaName'];
             $className = $_GET['className'];
             $viewer = $_GET['viewer'];
+            $firstClass = "";
             try
@@ -58,6 +59,9 @@
                 $resId = new MgResourceIdentifier($resName);
                 $classCollection = $featureSrvc->GetClasses($resId, $schemaName);
+                $qualifiedName = $classCollection->GetItem(0);
+                $pos = strrpos($qualifiedName, ':');
+                $firstSchema = substr($qualifiedName, 0, $pos);
                 $firstClass =  substr(strrchr($classCollection->GetItem(0), ":"), 1);
                 $classNames = new MgStringCollection();
                 $classNames->Add($className);
@@ -162,10 +166,10 @@
         function ShowFirstClass()
-            document.getElementById("Data_"+"<?php echo $firstClass?>").previousSibling.firstChild.src = "./images/collapse_pane.png";
-            document.getElementById("Data_"+"<?php echo $firstClass?>").style.display = 'block';
-            document.getElementById("Geom_"+"<?php echo $firstClass?>").previousSibling.firstChild.src = "./images/collapse_pane.png";
-            document.getElementById("Geom_"+"<?php echo $firstClass?>").style.display = 'block';
+            document.getElementById("Data_"+"<?php echo $firstSchema?>"+"_"+"<?php echo $firstClass?>").previousSibling.firstChild.src = "./images/collapse_pane.png";
+            document.getElementById("Data_"+"<?php echo $firstSchema?>"+"_"+"<?php echo $firstClass?>").style.display = 'block';
+            document.getElementById("Geom_"+"<?php echo $firstSchema?>"+"_"+"<?php echo $firstClass?>").previousSibling.firstChild.src = "./images/collapse_pane.png";
+            document.getElementById("Geom_"+"<?php echo $firstSchema?>"+"_"+"<?php echo $firstClass?>").style.display = 'block';
     </script>
More information about the mapguide-commits mailing list
