[mapguide-commits] r8614 - in branches/2.6/MgDev: . BuildTools/WebTools/IMake BuildTools/WebTools/IMake/Win32 Common/MdfParser Desktop Desktop/DesktopUnmanagedApi/DotNet Doc/samples/phpsamples Doc/samples/phpsamples/common Doc/samples/phpsamples/modifying_maps_and_layers Server/src/UnitTesting Web/src/mapviewernet
svn_mapguide at osgeo.org
Thu Apr 2 04:40:10 PDT 2015
Author: jng
Date: 2015-04-02 04:40:10 -0700 (Thu, 02 Apr 2015)
New Revision: 8614
Added:
branches/2.6/MgDev/Doc/samples/phpsamples/common/LayerDefinition-1.3.0.xsd
branches/2.6/MgDev/Doc/samples/phpsamples/common/PlatformCommon-1.0.0.xsd
branches/2.6/MgDev/Doc/samples/phpsamples/common/SymbolDefinition-1.1.0.xsd
branches/2.6/MgDev/
branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp
branches/2.6/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
branches/2.6/MgDev/Common/MdfParser/FSDSAX2Parser.cpp
branches/2.6/MgDev/Common/MdfParser/SAX2Parser.cpp
branches/2.6/MgDev/Desktop/
branches/2.6/MgDev/Desktop/DesktopUnmanagedApi/DotNet/SignMapGuideApi.exe
branches/2.6/MgDev/Desktop/DesktopUnmanagedApi/DotNet/SignMapGuideApi.pdb
branches/2.6/MgDev/Doc/samples/phpsamples/common/common.php
branches/2.6/MgDev/Doc/samples/phpsamples/index.php
branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php
branches/2.6/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
branches/2.6/MgDev/Web/src/mapviewernet/selectwithin.aspx
Merged revision(s) 8444, 8518-8519, 8568, 8588-8589, 8595 from trunk/MgDev:
Fix #2501 In basic web layout, Select Within will select all features in map when user restricts the results to an invisible layer
After the fix, the features will be selected in the layer in which the user restrict the selection, no matter visible and invisible.
#2531: Fix unit test failures on Coordinate System test suite. The issue is that the MgFileUtil::CreateDirectory() is non-recursive, meaning if any parent part of the path doesn't exist, the whole call fails and derails the test case as a result. The fix is to create this directory recursively.
#2531: Missed a part.
#2523: Don't hard-code include paths for PHP developer's guide samples. The samples are expected to be installed from a known location relative to the www root, so discover the expected paths based on this setup. For convenience, include the required schema files for code that validates some layer definitions. Also fix a PHP deprecation warning.
This submission updates IMake to skip over invalid \exception declarations. Wrapper APIs know nothing about std::bad_alloc or any other non-MapGuide exceptions, so such declaration should be skipped over when writing the respective .net and Java API documentation.
Update SignMapGuideApi.exe with build from r8587
Add missing calls to XMLString::release() in 2 places using XMLString::transcode().
Property changes on: branches/2.6/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8423,8433,8439,8443
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8423,8433,8439,8443-8444,8518-8519,8568,8588-8589,8595
Modified: branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp
--- branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/BuildTools/WebTools/IMake/IMake.cpp 2015-04-02 11:40:10 UTC (rev 8614)
@@ -12,7 +12,7 @@
java
-static char version[] = "1.2.3";
+static char version[] = "1.2.4";
static char EXTERNAL_API_DOCUMENTATION[] = "(NOTE: This API is not officially supported and may be subject to removal in a future release without warning. Use with caution.)";
static string module;
@@ -1076,20 +1076,32 @@
eelems.push_back(eitem);
- csharpDoc.append("///<exception cref=\"");
- csharpDoc.append(nspace);
- csharpDoc.append(".");
- if (eelems.size() > 1) {
- csharpDoc.append(eelems[0]);
- csharpDoc.append("\">");
- for (int j = 1; j < eelems.size(); j++) {
- csharpDoc.append(" ");
- csharpDoc.append(eelems[j]);
+ if (eelems.size() > 0)
+ //Skip anything that is not of the form:
+ //\exception MgExceptionType Description of cases when the exception is thrown
+ //So the first token must start with "Mg"
+ std::string t("Mg");
+ if (eelems[0].compare(0, t.length(), t) == 0)
+ csharpDoc.append("///<exception cref=\"");
+ csharpDoc.append(nspace);
+ csharpDoc.append(".");
+ if (eelems.size() > 1) {
+ csharpDoc.append(eelems[0]);
+ csharpDoc.append("\">");
+ for (int j = 1; j < eelems.size(); j++) {
+ csharpDoc.append(" ");
+ csharpDoc.append(eelems[j]);
+ csharpDoc.append("</exception>\n");
+ else {
+ csharpDoc.append("\"></exception>\n");
- csharpDoc.append("</exception>\n");
- } else {
- csharpDoc.append("\"></exception>\n");
Modified: branches/2.6/MgDev/BuildTools/WebTools/IMake/Win32/IMake.exe
(Binary files differ)
Modified: branches/2.6/MgDev/Common/MdfParser/FSDSAX2Parser.cpp
--- branches/2.6/MgDev/Common/MdfParser/FSDSAX2Parser.cpp 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Common/MdfParser/FSDSAX2Parser.cpp 2015-04-02 11:40:10 UTC (rev 8614)
@@ -74,7 +74,9 @@
void FSDSAX2Parser::error(const SAXException& exc)
- m_strParserError = toMdfString(XMLString::transcode(exc.getMessage()));
+ char* str = XMLString::transcode(exc.getMessage());
+ m_strParserError = toMdfString(str);
+ XMLString::release(&str);
Modified: branches/2.6/MgDev/Common/MdfParser/SAX2Parser.cpp
--- branches/2.6/MgDev/Common/MdfParser/SAX2Parser.cpp 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Common/MdfParser/SAX2Parser.cpp 2015-04-02 11:40:10 UTC (rev 8614)
@@ -122,7 +122,9 @@
void SAX2Parser::error(const SAXException& exc)
Property changes on: branches/2.6/MgDev/Desktop
- /branches/2.4/MgDev/Desktop:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006,7152
/branches/2.5/MgDev/Desktop:7511
/sandbox/jng/createruntimemap/Desktop:7486-7555
/sandbox/rfc94/Desktop:5099-5163
+ /branches/2.4/MgDev/Desktop:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006,7152
/trunk/MgDev/Desktop:8588-8589,8595
Modified: branches/2.6/MgDev/Desktop/DesktopUnmanagedApi/DotNet/SignMapGuideApi.exe
Modified: branches/2.6/MgDev/Desktop/DesktopUnmanagedApi/DotNet/SignMapGuideApi.pdb
Copied: branches/2.6/MgDev/Doc/samples/phpsamples/common/LayerDefinition-1.3.0.xsd (from rev 8568, trunk/MgDev/Doc/samples/phpsamples/common/LayerDefinition-1.3.0.xsd)
--- branches/2.6/MgDev/Doc/samples/phpsamples/common/LayerDefinition-1.3.0.xsd (rev 0)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/common/LayerDefinition-1.3.0.xsd 2015-04-02 11:40:10 UTC (rev 8614)
@@ -0,0 +1,1236 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="1.3.0">
+ <xs:include schemaLocation="SymbolDefinition-1.1.0.xsd"/>
+ <xs:include schemaLocation="PlatformCommon-1.0.0.xsd"/>
+ <xs:element name="LayerDefinition">
+ <xs:annotation>
+ <xs:documentation>The specification of the data source and stylization for a layer.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:complexContent>
+ <xs:extension base="LayerDefinitionType">
+ <xs:attribute name="version" type="xs:string" use="required" fixed="1.3.0"/>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="LayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the definition of a map layer.</xs:documentation>
+ </xs:annotation>
+ <xs:choice>
+ <xs:element name="DrawingLayerDefinition" type="DrawingLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer with a drawing (i.e., DWF) data source.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VectorLayerDefinition" type="VectorLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer with a vector data source; and stylization specification for the datum's geometry types.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GridLayerDefinition" type="GridLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer with a raster or grid data source.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Common types for all layer types ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="BaseLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>Specifies common properties for all layer types.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ResourceId" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Link to the drawing data source.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Opacity" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Opacity at which to display the rendered data.</xs:documentation>
+ </xs:annotation>
+ <xs:simpleType>
+ <xs:restriction base="xs:double">
+ <xs:minInclusive value="0.0"/>
+ <xs:maxInclusive value="1.0"/>
+ </xs:restriction>
+ </xs:simpleType>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Drawing layer ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="DrawingLayerDefinitionType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:extension base="BaseLayerDefinitionType">
+ <xs:sequence>
+ <xs:element name="Sheet" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The sheet of the DWF to use.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerFilter" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The layers to show from the specified sheet. Show all layers if this is not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MinScale" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The zoomed in part of the scale range. Defaults to 0 if not specified. Inclusive.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaxScale" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The zoomed out part of the scale range. Defaults to the application's maximum value if not specified. Exclusive.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Vector layer ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="VectorLayerDefinitionType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FeatureName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Either a feature class or named extension.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FeatureNameType" type="FeatureNameType"/>
+ <xs:element name="Filter" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A boolean FDO expression that specifies which features to return. No filter means pass all features through.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PropertyMapping" type="NameStringPairType" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Specifies which properties to expose to the user and its corresponding friendly name.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Geometry" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Specifies the geometry property that should be used to get the geometries.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Url" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>An optional URL associated with each feature. This is a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ToolTip" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The text to put into the tooltip for displayed features. This is a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VectorScaleRange" type="VectorScaleRangeType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>The stylization to be applied to the features for a given scale range.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="FeatureNameType">
+ <xs:annotation>
+ <xs:documentation>Enumeration describing whether the features are coming from a feature class or named extension</xs:documentation>
+ </xs:annotation>
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="FeatureClass"/>
+ <xs:enumeration value="NamedExtension"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="VectorScaleRangeType">
+ <xs:annotation>
+ <xs:documentation>The stylization to be applied to the vector features for a given scale range.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:choice minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Note that where there is no style specified for a particular geometry type a default styling should be used.</xs:documentation>
+ </xs:annotation>
+ <xs:element name="AreaTypeStyle" type="AreaTypeStyleType">
+ <xs:annotation>
+ <xs:documentation>Style specification of a polygon geometry type.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineTypeStyle" type="LineTypeStyleType">
+ <xs:annotation>
+ <xs:documentation>Style specification of a line geometry type.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PointTypeStyle" type="PointTypeStyleType">
+ <xs:annotation>
+ <xs:documentation>Style specification of a point geometry type.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CompositeTypeStyle" type="CompositeTypeStyle">
+ <xs:annotation>
+ <xs:documentation>A composite style definition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ <xs:element name="ElevationSettings" type="ElevationSettingsType" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ElevationSettingsType">
+ <xs:sequence>
+ <xs:element name="ZOffset" type="xs:string" minOccurs="0"/>
+ <xs:element name="ZExtrusion" type="xs:string" minOccurs="0"/>
+ <xs:element name="ZOffsetType" type="ElevationTypeType" default="RelativeToGround" minOccurs="0"/>
+ <xs:element name="Unit" type="LengthUnitType" default="Centimeters" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="ElevationTypeType">
+ <xs:annotation>
+ <xs:documentation>The possible interpretations of a z offset value.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="RelativeToGround"/>
+ <xs:enumeration value="Absolute"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="PointTypeStyleType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="DisplayAsText" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Create a text layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AllowOverpost" type="xs:boolean">
+ <xs:annotation>
+ <xs:documentation>Allows labels from any map layer (including the current layer) to obscure features on the current layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PointRule" type="PointRuleType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>One or more PointRules defining the PointTypeStyle.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ShowInLegend" type="xs:boolean" default="true" minOccurs="0"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="PointRuleType">
+ <xs:annotation>
+ <xs:documentation>Style rule for a point geometry type.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LegendLabel" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The label for the Rule to be displayed in the legend.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>A filter for the Rule. This is a boolean FDO expression. Any features that pass this filter are styled using this rule's stylization.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Label" type="TextSymbolType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A label for the Rule.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:choice minOccurs="0">
+ <xs:element name="PointSymbolization2D" type="PointSymbolization2DType"/>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="PointSymbolizationType">
+ <xs:annotation>
+ <xs:documentation>Base point symbolization type.</xs:documentation>
+ </xs:annotation>
+ </xs:complexType>
+ <xs:complexType name="PointSymbolization2DType">
+ <xs:annotation>
+ <xs:documentation>The different types of point geometries.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:element name="Mark" type="MarkSymbolType">
+ <xs:annotation>
+ <xs:documentation>A predefined shape such as a square or circle.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Image" type="ImageSymbolType">
+ <xs:annotation>
+ <xs:documentation>A raster or image symbol. Note that these do not scale well, but sometimes this is all that you have. Supported formats are application specific.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Font" type="FontSymbolType">
+ <xs:annotation>
+ <xs:documentation>A symbol specified using a font character.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="W2D" type="W2DSymbolType">
+ <xs:annotation>
+ <xs:documentation>A vector symbol defined using a W2D stream.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Block" type="BlockSymbolType">
+ <xs:annotation>
+ <xs:documentation>A vector symbol specifed from a block.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="LineTypeStyleType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LineRule" type="LineRuleType" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Rules to define a theme.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="LineRuleType">
+ <xs:annotation>
+ <xs:documentation>Style rule for a line geometry type.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineSymbolization2D" type="StrokeType"/>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="AreaSymbolizationType">
+ <xs:annotation>
+ <xs:documentation>Symbolization characteristics for areas.</xs:documentation>
+ </xs:annotation>
+ </xs:complexType>
+ <xs:complexType name="AreaSymbolizationFillType">
+ <xs:annotation>
+ <xs:documentation>Describes the style of a polygon.</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="AreaSymbolizationType">
+ <xs:sequence>
+ <xs:element name="Fill" type="FillType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The style of the polygon fill.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Stroke" type="StrokeType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The style of the polygon edge.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="AreaTypeStyleType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="AreaRule" type="AreaRuleType" maxOccurs="unbounded">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="AreaRuleType">
+ <xs:annotation>
+ <xs:documentation>Style rule for an area geometry type.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:choice>
+ <xs:element name="AreaSymbolization2D" type="AreaSymbolizationFillType">
+ <xs:annotation>
+ <xs:documentation>The stylization of the polygon geometry.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="StrokeType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the stylization of a line.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="LineStyle" type="xs:string"/>
+ <xs:element name="Thickness" type="xs:string"/>
+ <xs:element name="Color" type="xs:string"/>
+ <xs:element name="Unit" type="LengthUnitType">
+ <xs:annotation>
+ <xs:documentation>Unit of measurement that the thickness is specified in</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeContext" type="SizeContextType">
+ <xs:annotation>
+ <xs:documentation>Whether the sizes are with respect to the earth or the user's display device.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="FillType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the stylization of a polygon's fill.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FillPattern" type="xs:string"/>
+ <xs:element name="ForegroundColor" type="xs:string"/>
+ <xs:element name="BackgroundColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The background color. Not applicable to solid fills.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="BackgroundStyleType">
+ <xs:annotation>
+ <xs:documentation>The possible background styles of a TextSymbol.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Transparent"/>
+ <xs:enumeration value="Opaque"/>
+ <xs:enumeration value="Ghosted"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="SizeContextType">
+ <xs:annotation>
+ <xs:documentation>Whether the sizes are specified as sizes on the earth or on the user's display device.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="MappingUnits"/>
+ <xs:enumeration value="DeviceUnits"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="LengthUnitType">
+ <xs:annotation>
+ <xs:documentation>The measurement units that linear sizes are specified in.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Millimeters"/>
+ <xs:enumeration value="Centimeters"/>
+ <xs:enumeration value="Meters"/>
+ <xs:enumeration value="Kilometers"/>
+ <xs:enumeration value="Inches"/>
+ <xs:enumeration value="Feet"/>
+ <xs:enumeration value="Yards"/>
+ <xs:enumeration value="Miles"/>
+ <xs:enumeration value="Points"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="TextSymbolType">
+ <xs:annotation>
+ <xs:documentation>Encapsulates the text label stylization used to label features, and for FontSymbols.</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="SymbolType">
+ <xs:sequence>
+ <xs:element name="Text" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The text of the TextSymbol. This is a string FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FontName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The font to use.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ForegroundColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The color of the text.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The text background color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="BackgroundStyle" type="BackgroundStyleType">
+ <xs:annotation>
+ <xs:documentation>The background style</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HorizontalAlignment" type="xs:string" default="'Center'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A string FDO expression for the horizontal alignment. Must evaluate to one of the HorizontalAlignmentType enums. Only applicable to text styles.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VerticalAlignment" type="xs:string" default="'Baseline'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A string FDO expression for the vertical alignment. Must evaluate to one of the VerticalAlignmentType enums. Only applicable to text and line styles.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Bold" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies if the label should be in a bold font.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Italic" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies if the font should be italicized.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Underlined" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies if the text should be underlined.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AdvancedPlacement" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Optional element which specifies that a more advanced labeling algorithm should be used with the AJAX viewer.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="ScaleLimit" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The maximum amount any label is allowed to shrink in order to fit into the feature. For example, 0.8 means that the label can shrink until it is 80% of the original size. 1.0 means that the label cannot shrink. If not specified, the application should assume 1.0. If set to 0.0 or less then the advanced placement option is disabled.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="SymbolType">
+ <xs:annotation>
+ <xs:documentation>Defines common properties for all symbols.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The units that the sizes are specified in.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeX" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Width of the symbol. This is a double FDO expression. Does not apply to font symbols.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeY" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Height of the symbol. This is a double FDO expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Rotation" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Amount to rotate the symbol in degrees. This is a double FDO expression. Does not apply to line labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaintainAspect" type="xs:boolean" default="true" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Hint for the UI only. When the user enters a constant size for the width or height, the other dimension should be adjusted accordingly. Does not apply to font symbols or labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionPointX" type="xs:string" default="0.5" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>X offset for the symbol specified in symbol space. Does not apply to labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionPointY" type="xs:double" default="0.5" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Y offset for the symbol specified in symbol space. Does not apply to labels.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="MarkSymbolType">
+ <xs:annotation>
+ <xs:documentation>Stylization of a predefined shape (ShapeType).</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Shape" type="ShapeType"/>
+ <xs:annotation>
+ <xs:documentation>No fill is drawn if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Edge" type="StrokeType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>No edge is drawn if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="NameStringPairType">
+ <xs:annotation>
+ <xs:documentation>Used by vector layer definition to hold properties that can be displayed to the end user, and the friendly name to display it as.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Name" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the property to expose.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Value" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name to show the end user.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="ShapeType">
+ <xs:annotation>
+ <xs:documentation>SLD supports square, circle, triangle, star, cross, and X.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Square"/>
+ <xs:enumeration value="Circle"/>
+ <xs:enumeration value="Triangle"/>
+ <xs:enumeration value="Star"/>
+ <xs:enumeration value="Cross"/>
+ <xs:enumeration value="X"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="ImageSymbolType">
+ <xs:annotation>
+ <xs:documentation>Symbols that are comprised of a raster.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:element name="Image">
+ <xs:annotation>
+ <xs:documentation>Reference to the image.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:sequence>
+ <xs:element name="ResourceId">
+ <xs:annotation>
+ <xs:documentation>The reference to the resource.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LibraryItemName" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If ResourceId specifies a library, this identifies the name of a library item.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="Content" type="xs:hexBinary">
+ <xs:annotation>
+ <xs:documentation>BinHex data for image.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="FontSymbolType">
+ <xs:annotation>
+ <xs:documentation>Symbols that are specified by a font and character.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>If the font is not installed, the actual font used is application dependent.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Character" type="xs:string"/>
+ <xs:element name="Bold" type="xs:boolean" minOccurs="0"/>
+ <xs:element name="Italic" type="xs:boolean" minOccurs="0"/>
+ <xs:element name="Underlined" type="xs:boolean" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="W2DSymbolType">
+ <xs:annotation>
+ <xs:documentation>A symbol using a W2D stream.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="W2DSymbol">
+ <xs:complexType>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The reference to the symbol library.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LibraryItemName">
+ <xs:annotation>
+ <xs:documentation>The W2D stream in the symbol library.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="FillColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified all polygon fills in the symbol are drawn in this color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified all lines in the symbol are drawn in this color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TextColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified all text in the symbol is drawn in this color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="BlockSymbolType">
+ <xs:annotation>
+ <xs:documentation>A block symbol.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="DrawingName" type="xs:string"/>
+ <xs:element name="BlockName" type="xs:string"/>
+ <xs:element name="BlockColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Static color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="CompositeTypeStyle">
+ <xs:annotation>
+ <xs:documentation>A style specification consisting of composite rules.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="CompositeRule" type="CompositeRule" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>One or more CompositeRules defining the CompositeTypeStyle.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="CompositeRule">
+ <xs:annotation>
+ <xs:documentation>A style rule containing a composite symbolization.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CompositeSymbolization" type="CompositeSymbolization">
+ <xs:annotation>
+ <xs:documentation>The symbolization for the Rule.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="CompositeSymbolization">
+ <xs:annotation>
+ <xs:documentation>Stylization attributes of a point, line, or area feature.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SymbolInstance" type="SymbolInstance" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>The symbol instances used for stylization.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ThemeLabel">
+ <xs:annotation>
+ <xs:documentation>Provides legend labeling information for a theme.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Description" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The legend description for the theme.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CategoryFormat" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The default legend format to use for each category in the theme.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Override">
+ <xs:annotation>
+ <xs:documentation>A parameter override.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SymbolName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the symbol definition containing the parameter being overridden.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ParameterIdentifier" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The identifier of the parameter being overridden.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ParameterValue" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The override value for the parameter.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ThemeLabel" type="ThemeLabel" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>An optional theme label for this override.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ParameterOverrides">
+ <xs:annotation>
+ <xs:documentation>A collection of parameter overrides.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Override" type="Override" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:simpleType name="UsageContextType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed UsageContext values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Unspecified"/>
+ <xs:enumeration value="Point"/>
+ <xs:enumeration value="Line"/>
+ <xs:enumeration value="Area"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="GeometryContextType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed GeometryContext values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="LineString"/>
+ <xs:enumeration value="Polygon"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="SymbolInstance">
+ <xs:annotation>
+ <xs:documentation>An instance of a symbol.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:annotation>
+ <xs:documentation>A library reference to an existing SymbolDefinition, either simple or compound.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SimpleSymbolDefinition" type="SimpleSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>An inlined SimpleSymbolDefinition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CompoundSymbolDefinition" type="CompoundSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>An inlined CompoundSymbolDefinition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ <xs:element name="ParameterOverrides" type="ParameterOverrides">
+ <xs:annotation>
+ <xs:documentation>Specifies all parameter overrides for this symbol instance.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleX" type="xs:string" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The additional amount to scale the symbol horizontally in symbol space. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleY" type="xs:string" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The additional amount to scale the symbol vertically in symbol space. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionOffsetX" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the additional amount to offset the symbol horizontally, in mm in device units, after scaling and rotation have been applied. Applies only to point symbols. Defaults to 0 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="InsertionOffsetY" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the additional amount to offset the symbol vertically, in mm in device units, after scaling and rotation have been applied. Applies only to point symbols. Defaults to 0 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeContext" type="SizeContextType" default="DeviceUnits" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies whether the symbol sizes are with respect to the map or the user's display device. Defaults to device units.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DrawLast" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether the symbol is drawn as part of a final rendering pass (e.g. for labeling). This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CheckExclusionRegion" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether to render this symbol only if its graphical extent does not overlap the exclusion region. If the positioning algorithm generates multiple candidate symbol positions and this setting is True, then only the first non-overlapping candidate is rendered. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AddToExclusionRegion" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether the graphical extent for this symbol instance is added to the exclusion region (if it is rendered). Symbols which check the exclusion region will not draw on top of this symbol. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositioningAlgorithm" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the algorithm used to generate candidate positions for the symbol. If specified this must evaluate to one of: Default, EightSurrounding, or PathLabels. Default means generate one position using the feature geometry (used for normal rendering). EightSurrounding means generate eight candidate labels surrounding the feature geometry (used when labeling point features). PathLabels means generate periodic labels which follow the feature geometry (used when labeling linestring features).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="RenderingPass" type="xs:string" default="0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The optional rendering pass in which this symbol instance draws. If specified this must be greater than or equal to zero. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="UsageContext" type="UsageContextType" default="Unspecified" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies which usage in the symbol should be the active one. Defaults to Unspecified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GeometryContext" type="GeometryContextType" default="Unspecified" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies which geometry type this symbol instance applies to. Defaults to Unspecified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:annotation>
+ <xs:documentation>******************** Grid layer ********************</xs:documentation>
+ </xs:annotation>
+ <xs:complexType name="GridLayerDefinitionType">
+ <xs:annotation>
+ <xs:documentation>A layer for raster or grid data.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="FeatureName" type="xs:string"/>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GridScaleRange" type="GridScaleRangeType" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="ChannelBandType">
+ <xs:annotation>
+ <xs:documentation>Defines how to scale numbers into a color channel.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Band" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Name of the band.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LowBand" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is low value found in band. Band values less than this are snapped to this number.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HighBand" type="xs:double" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is high value found in band. Band values greater than this are snapped to this number.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LowChannel" type="xs:unsignedByte" default="0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is 0. Range is 0:255. LowBand is mapped to this number. LowChannel can be greater than HighChannel.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HighChannel" type="xs:unsignedByte" default="255" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is 255. Range is 0:255.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorBandsType">
+ <xs:annotation>
+ <xs:documentation>Specifies a color using distinct RGB values.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="RedBand" type="ChannelBandType"/>
+ <xs:element name="GreenBand" type="ChannelBandType"/>
+ <xs:element name="BlueBand" type="ChannelBandType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorType">
+ <xs:annotation>
+ <xs:documentation>The color to use for a grid rule.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ExplicitColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>Explicit ARGB color.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Band" type="xs:string"/>
+ <xs:element name="Bands" type="GridColorBandsType"/>
+ </xs:choice>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorRuleType">
+ <xs:annotation>
+ <xs:documentation>Encapsulate a style for a grid source.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>A label for the Rule. Does not apply to GridColorRule.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Color" type="GridColorType"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="HillShadeType">
+ <xs:annotation>
+ <xs:documentation>Specifies how to shade given a band and a light source.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>Name of the band used for the computation.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Azimuth" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Azimuth of the sun in degrees.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Altitude" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Altitude of the sun in degrees.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleFactor" type="xs:double" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The scale factor applied to the band prior to computing hillshade. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridColorStyleType">
+ <xs:annotation>
+ <xs:documentation>Specifies how to style each pixel.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="HillShade" type="HillShadeType" minOccurs="0"/>
+ <xs:element name="TransparencyColor" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If a pixel color prior to factoring in HillShade is this value then the pixel is transparent.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="BrightnessFactor" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Default is 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ContrastFactor" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ColorRule" type="GridColorRuleType" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridSurfaceStyleType">
+ <xs:annotation>
+ <xs:documentation>Specifies how to calculate pixel elevations.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>Band to use for 3D data.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ZeroValue" type="xs:double" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Determines which input value is mapped to zero elevation. Defaults to 0 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Determines how to scale the inputs into a consistent elevation. Defaults to 1 if not specified.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DefaultColor" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The default color to use if no ColorStyle is defined at a pixel.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="GridScaleRangeType">
+ <xs:annotation>
+ <xs:documentation>The stylization for a specified scale range.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SurfaceStyle" type="GridSurfaceStyleType" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Defines the height field of the grid.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ColorStyle" type="GridColorStyleType" minOccurs="0"/>
+ <xs:element name="RebuildFactor" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>When the user has zoomed in by this amount, a request for more detailed raster data is made.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Copied: branches/2.6/MgDev/Doc/samples/phpsamples/common/PlatformCommon-1.0.0.xsd (from rev 8568, trunk/MgDev/Doc/samples/phpsamples/common/PlatformCommon-1.0.0.xsd)
--- branches/2.6/MgDev/Doc/samples/phpsamples/common/PlatformCommon-1.0.0.xsd (rev 0)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/common/PlatformCommon-1.0.0.xsd 2015-04-02 11:40:10 UTC (rev 8614)
@@ -0,0 +1,11 @@
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="1.0.0">
+ <xs:complexType name="ExtendedDataType">
+ <xs:annotation>
+ <xs:documentation>A type allocating space for future, additional, and validatable data.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:any processContents="lax" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
Copied: branches/2.6/MgDev/Doc/samples/phpsamples/common/SymbolDefinition-1.1.0.xsd (from rev 8568, trunk/MgDev/Doc/samples/phpsamples/common/SymbolDefinition-1.1.0.xsd)
--- branches/2.6/MgDev/Doc/samples/phpsamples/common/SymbolDefinition-1.1.0.xsd (rev 0)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/common/SymbolDefinition-1.1.0.xsd 2015-04-02 11:40:10 UTC (rev 8614)
@@ -0,0 +1,808 @@
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="1.1.0">
+ <xs:element name="SimpleSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>A 2D simple symbol for stylization.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:extension base="SimpleSymbolDefinition">
+ <xs:attribute name="version" type="xs:string" use="required" fixed="1.1.0"/>
+ </xs:extension>
+ </xs:complexType>
+ </xs:element>
+ <xs:element name="CompoundSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>A 2D compound symbol for stylization.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:extension base="CompoundSymbolDefinition">
+ </xs:extension>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="SymbolDefinitionBase">
+ <xs:annotation>
+ <xs:documentation>Base type used with all symbol definitions.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The name of the symbol.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Description" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>An optional description of the symbol.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ResizeBox">
+ <xs:annotation>
+ <xs:documentation>Defines a resize box used with SimpleSymbolDefinitions.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SizeX" type="xs:string" default="1.0">
+ <xs:annotation>
+ <xs:documentation>The initial width of the resize box, in mm. This must be greater than or equal to zero.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeY" type="xs:string" default="1.0">
+ <xs:annotation>
+ <xs:documentation>The initial height of the resize box, in mm. This must be greater than or equal to zero.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositionX" type="xs:string" default="0.0">
+ <xs:annotation>
+ <xs:documentation>The initial x-coordinate of the resize box center, in mm.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositionY" type="xs:string" default="0.0">
+ <xs:annotation>
+ <xs:documentation>The initial y-coordinate of the resize box center, in mm.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GrowControl" type="xs:string" default="'GrowInXYMaintainAspect'">
+ <xs:annotation>
+ <xs:documentation>Specifies how the resize box grows in size. This must evaluate to one of: GrowInX, GrowInY, GrowInXY, or GrowInXYMaintainAspect (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="PointUsage">
+ <xs:annotation>
+ <xs:documentation>Specifies how a symbol is used in the context of point features.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="AngleControl" type="xs:string" default="'FromAngle'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies how the symbol angle is defined. This must evaluate to one of: FromAngle (default) or FromGeometry.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Angle" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the symbol angle, in degrees. If AngleControl evaluates to FromAngle then this specifies the absolute angle of the symbol. If AngleControl evaluates to FromGeometry then this specifies the symbol angle relative to the geometry. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OriginOffsetX" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the horizontal offset to apply to the symbol origin, in mm. This offset is applied before the symbol is scaled and rotated. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OriginOffsetY" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the vertical offset to apply to the symbol origin, in mm. This offset is applied before the symbol is scaled and rotated. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="LineUsage">
+ <xs:annotation>
+ <xs:documentation>Specifies how a symbol is used in the context of linear features.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="AngleControl" type="xs:string" default="'FromGeometry'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies how the symbol angle is defined. This must evaluate to one of: FromAngle or FromGeometry (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="UnitsControl" type="xs:string" default="'Absolute'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies whether the distribution parameters are interpreted as absolute values (in mm) or parametric values. This must evaluate to one of: Absolute (default) or Parametric.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VertexControl" type="xs:string" default="'OverlapWrap'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the symbol behavior at vertices. This must evaluate to one of: OverlapNone, OverlapDirect, or OverlapWrap (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Specifies the angle of each repeating symbol, in degrees. If AngleControl evaluates to FromAngle then this specifies the absolute angle of the symbol. If AngleControl evaluates to FromGeometry then this specifies the symbol angle relative to the geometry. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="StartOffset" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies where the symbol distribution begins, relative to the start of the feature. If specified this must be greater than or equal to zero.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="EndOffset" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies where the symbol distribution ends, relative to the end of the feature. If specified this must be greater than or equal to zero.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Repeat" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the separation between repeating symbols. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VertexAngleLimit" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the limiting angle, in degrees, by a which the feature geometry can change before some of the VertexControl options take effect. If specified this must be greater than or equal to zero. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VertexJoin" type="xs:string" default="'Round'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the wrapping behavior at vertices for all graphic elements. Only applies if VertexControl evaluates to OverlapWrap. This must evaluate to one of: None, Bevel, Round (default), or Miter.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VertexMiterLimit" type="xs:string" default="5.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The limit to use when drawing miter vertex joins. A miter vertex join is trimmed if the ratio of the miter length to symbol height is greater than the miter limit. If specified this must be greater than zero. Defaults to 5.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DefaultPath" type="Path" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the default path attributes to use when drawing the symbol. These apply to any centerline that gets drawn where the symbol can't draw, and to path elements that don't specify attributes. The geometry contained in this path is ignored and should be empty.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="AreaUsage">
+ <xs:annotation>
+ <xs:documentation>Specifies how a symbol is used in the context of area features.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OriginControl" type="xs:string" default="'Global'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies how the symbol grid origin is defined. This must evaluate to one of: Global (default), Local, or Centroid.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ClippingControl" type="xs:string" default="'Clip'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies the clipping behavior of the symbol at polygon boundaries. This must evaluate to one of: Clip (default), Inside, or Overlap.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OriginX" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The x-coordinate of the symbol grid origin, in mm. Only applies if OriginControl evaluates to Global or Local. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OriginY" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The y-coordinate of the symbol grid origin, in mm. Only applies if OriginControl evaluates to Global or Local. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="RepeatX" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The horizontal separation between symbols, in mm. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="RepeatY" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The vertical separation between symbols, in mm. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="BufferWidth" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The width, in mm, of the buffer zone relative to the polygon boundary in which the symbol is rendered. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Parameter">
+ <xs:annotation>
+ <xs:documentation>The metadata for a symbol parameter.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Identifier" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The parameter identifier as used in the symbol.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DefaultValue" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The default value of the parameter if no override is defined in the symbol instance. This can be an expression.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DisplayName" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>An optional short description of the parameter. This can be used, for example, to ask the user to specify a parameter value.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>An optional long description of the parameter. This might include a description of useful values for this parameter.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DataType" type="DataType" default="String" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>An optional explicit declaration of data type or data usage context. This is a hint used by the UI when assigning a value to this parameter. Defaults to String.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ParameterDefinition">
+ <xs:annotation>
+ <xs:documentation>A collection of symbol parameters.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Parameter" type="Parameter" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="SimpleSymbol">
+ <xs:annotation>
+ <xs:documentation>Defines a reference to a SimpleSymbolDefinition, either inlined or a library reference.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>A library reference to an existing SimpleSymbolDefinition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ <xs:annotation>
+ <xs:documentation>The optional rendering pass in which this symbol definition draws. If specified this must be greater than or equal to zero. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="SimpleSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>A symbol definition containing a collection of graphic elements and information on how to use these in the context of different feature geometry types.</xs:documentation>
+ </xs:annotation>
+ <xs:extension base="SymbolDefinitionBase">
+ <xs:sequence>
+ <xs:element name="Graphics" type="Graphics">
+ <xs:annotation>
+ <xs:documentation>The collection of graphic elements defining this symbol.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ResizeBox" type="ResizeBox" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The optional box used to resize and reposition select graphic elements. The graphical extent of all elements with ResizeControl set to AddToResizeBox will be added to this box, potentially causing it to grow in size. Any change in size causes all elements with ResizeControl set to AdjustToResizeBox to be proportionally resized and repositioned.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PointUsage" type="PointUsage" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies how the symbol is used in the context of point features.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineUsage" type="LineUsage" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies how the symbol is used in the context of linear features.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="AreaUsage" type="AreaUsage" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies how the symbol is used in the context of area features.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ParameterDefinition" type="ParameterDefinition">
+ <xs:annotation>
+ <xs:documentation>The list of parameters used in this symbol. If a parameter is not listed here this is considered a bug in the symbol definition.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="CompoundSymbolDefinition">
+ <xs:annotation>
+ <xs:documentation>A symbol definition specified using a collection of SimpleSymbolDefinition elements or references.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="SimpleSymbol" type="SimpleSymbol" minOccurs="0" maxOccurs="unbounded"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="Graphics">
+ <xs:annotation>
+ <xs:documentation>A collection of graphic elements.</xs:documentation>
+ </xs:annotation>
+ <xs:element name="Path" type="Path"/>
+ <xs:element name="Image" type="Image"/>
+ <xs:element name="Text" type="Text"/>
+ </xs:choice>
+ </xs:complexType>
+ <xs:complexType name="GraphicBase">
+ <xs:annotation>
+ <xs:documentation>Base type used with all graphic elements.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ResizeControl" type="xs:string" default="'ResizeNone'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies how this graphic element interacts with the resize box. This must evaluate to one of: ResizeNone (default), AddToResizeBox, or AdjustToResizeBox. AddToResizeBox means the element's graphical extent is added to the resize box, but the element is not resized or repositioned if the resize box grows. AdjustToResizeBox means the element is resized and repositioned relative to the resize box, but its extent is not added to the box. ResizeNone means the element does not interact with the resize box.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Path">
+ <xs:annotation>
+ <xs:documentation>A 2D path defining vector geometry to include in the symbol definition.</xs:documentation>
+ </xs:annotation>
+ <xs:complexContent>
+ <xs:extension base="GraphicBase">
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The path geometry. The format is a sequence of segments, each represented by a letter indicating the segment type followed by one or more parameters. Uppercase letters denote absolute values and lowercase letters denote relative values. Segment types can be one of "M" (moveto), "L" (lineto), "H" (horizontal lineto), "V" (vertical lineto), "A" (arcto), or "Z" (close segment).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The ARGB color used to fill the path. If this element is missing or empty then no fill is applied to the path.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The ARGB color used to draw the path outline. If this element is missing or empty then no path outline is drawn.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineWeight" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The weight to use when drawing the path outline, in mm. If specified this must be greater than or equal to zero. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineWeightScalable" type="xs:string" default="true" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether the line weight scales with the symbol. This behavior is independent of the symbol's size context. This must evaluate to True (default) or False.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineCap" type="xs:string" default="'Round'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The cap type to use at the ends of each segment in the path outline. This must evaluate to one of: None, Round (default), Triangle, or Square.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineJoin" type="xs:string" default="'Round'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The join type to use at each vertex in the path outline. This must evaluate to one of: None, Bevel, Round (default), or Miter.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineMiterLimit" type="xs:string" default="5.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The limit to use when drawing miter joins. A miter join is trimmed if the ratio of the miter length to line weight is greater than the miter limit. If specified this must be greater than zero. Defaults to 5.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ <xs:complexType name="ImageReference">
+ <xs:annotation>
+ <xs:documentation>Defines a library reference used with image elements.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ResourceId" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The resource where the image data is stored. For non-inlined symbol definitions this can be an empty string, in which case the resource is assumed to be the parent symbol definition resource. For inlined symbol definitions this must point to a separate resource.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LibraryItemName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the resource data storing the image.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Image">
+ <xs:annotation>
+ <xs:documentation>An image to include in the symbol definition.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:choice>
+ <xs:element name="Content" type="xs:base64Binary">
+ <xs:annotation>
+ <xs:documentation>An embedded PNG image stored using base64 binary.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Reference" type="ImageReference">
+ <xs:annotation>
+ <xs:documentation>A library reference to a PNG image.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:choice>
+ <xs:annotation>
+ <xs:documentation>The width of the image, in mm. This must be greater than zero.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The height of the image, in mm. This must be greater than zero.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="SizeScalable" type="xs:string" default="true" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether the image sizes scale with the symbol. This behavior is independent of the symbol's size context. This must evaluate to True (default) or False.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The angle of the image in symbol space, in degrees. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositionX" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The x-coordinate of the image center in symbol space, in mm. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositionY" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The y-coordinate of the image center in symbol space, in mm. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:complexType name="TextFrame">
+ <xs:annotation>
+ <xs:documentation>Defines a frame used with text elements.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The ARGB color used to draw the text frame border. If this element is missing or empty then no frame border is drawn.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The ARGB color used to fill the text frame. If this element is missing or empty then no fill is drawn.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OffsetX" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The additional horizontal offset of the frame relative to the text box, in mm. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="OffsetY" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The additional vertical offset of the frame relative to the text box, in mm. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Text">
+ <xs:annotation>
+ <xs:documentation>A text string to include in the symbol definition.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="Content" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The string content for the text.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FontName" type="xs:string" default="'Arial'">
+ <xs:annotation>
+ <xs:documentation>The name of the font to use for the text.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Specifies if the text should be drawn using a bold font. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Specifies if the text should be drawn using an italic font. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>Specifies if the text should be underlined. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Overlined" type="xs:string" default="false" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Specifies if the text should be overlined. This must evaluate to True or False (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ObliqueAngle" type="xs:string" default="0.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A numeric value between -85.0 and 85.0 representing the angle in degrees forward (for positive) or backwards (for negative) that the text should be obliqued (a la shear or skew transform). Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TrackSpacing" type="xs:string" default="1.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>A numeric value between 0.75 and 10.0, representing the text "tracking" factor to apply to inter-character spacing, effectively a multiplier of each character's advance width. Values less than 1.0 condense the text, spacing individual characters closer together than normally dictated by the font, whereas values greater than 1.0 expand the text, spacing characters farther apart. The outline of individual characters is not altered by this element, only the spacing between them and adjacent characters. Defaults to 1.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Height" type="xs:string" default="4.0" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The height of the text, in mm. If specified this must be greater than zero. Defaults to 4.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="HeightScalable" type="xs:string" default="true" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>Boolean value which specifies whether the font height scales with the symbol. This behavior is independent of the symbol's size context. This must evaluate to True (default) or False.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The angle of the text in symbol space, in degrees. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The x-coordinate of the text in symbol space, in mm. Horizontal alignment of the text box is relative to this coordinate. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The y-coordinate of the text in symbol space, in mm. Vertical alignment of the text box is relative to this coordinate. Defaults to 0.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The horizontal alignment of the text box relative to its position. This must evaluate to one of: Left, Center (default), or Right.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="VerticalAlignment" type="xs:string" default="'Halfline'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The vertical alignment of the text box relative to its position. This must evaluate to one of: Bottom, Baseline, Halfline (default), Capline, or Top.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Justification" type="xs:string" default="'FromAlignment'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The horizontal justification of individual lines of text in a multi-line text string. This must evaluate to one of: Left, Center, Right, Justified, or FromAlignment (default).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LineSpacing" type="xs:string" default="1.05" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The spacing between individual lines of text in a multi-line text string, as a multiple of the font height. If specified this must be greater than zero. Defaults to 1.05.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="TextColor" type="xs:string" default="ff000000" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The ARGB color used to draw the text. Defaults to black (ff000000).</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="GhostColor" type="xs:string" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The ARGB color used to draw the ghosted text. If this element is missing or empty then no ghosting is drawn.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Frame" type="TextFrame" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>If specified, defines the kind of frame drawn around the text.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Markup" type="xs:string" default="'Plain'" minOccurs="0">
+ <xs:annotation>
+ <xs:documentation>The markup format of the string content. Defaults to 'Plain'.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexType>
+ <xs:simpleType name="GrowControl">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed GrowControl values.</xs:documentation>
+ </xs:annotation>
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="GrowInX"/>
+ <xs:enumeration value="GrowInY"/>
+ <xs:enumeration value="GrowInXY"/>
+ <xs:enumeration value="GrowInXYMaintainAspect"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="AngleControl">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed AngleControl values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="FromAngle"/>
+ <xs:enumeration value="FromGeometry"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="UnitsControl">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed UnitsControl values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Absolute"/>
+ <xs:enumeration value="Parametric"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="VertexControl">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed VertexControl values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="OverlapNone"/>
+ <xs:enumeration value="OverlapDirect"/>
+ <xs:enumeration value="OverlapWrap"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="VertexJoin">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed VertexJoin values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="None"/>
+ <xs:enumeration value="Bevel"/>
+ <xs:enumeration value="Round"/>
+ <xs:enumeration value="Miter"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="OriginControl">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed OriginControl values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Global"/>
+ <xs:enumeration value="Local"/>
+ <xs:enumeration value="Centroid"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="ClippingControl">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed ClippingControl values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Clip"/>
+ <xs:enumeration value="Inside"/>
+ <xs:enumeration value="Overlap"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="ResizeControl">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed ResizeControl values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="ResizeNone"/>
+ <xs:enumeration value="AddToResizeBox"/>
+ <xs:enumeration value="AdjustToResizeBox"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="LineCap">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed LineCap values.</xs:documentation>
+ </xs:annotation>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="LineJoin">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed LineJoin values.</xs:documentation>
+ </xs:annotation>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="HorizontalAlignment">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed HorizontalAlignment values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Left"/>
+ <xs:enumeration value="Center"/>
+ <xs:enumeration value="Right"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="VerticalAlignment">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed VerticalAlignment values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Bottom"/>
+ <xs:enumeration value="Baseline"/>
+ <xs:enumeration value="Halfline"/>
+ <xs:enumeration value="Capline"/>
+ <xs:enumeration value="Top"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="Justification">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed Justification values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="Justified"/>
+ <xs:enumeration value="FromAlignment"/>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="DataType">
+ <xs:annotation>
+ <xs:documentation>Enumerates the allowed DataType values.</xs:documentation>
+ </xs:annotation>
+ <xs:enumeration value="String"/>
+ <xs:enumeration value="Boolean"/>
+ <xs:enumeration value="Integer"/>
+ <xs:enumeration value="Real"/>
+ <xs:enumeration value="Color"/>
+ <xs:enumeration value="Angle"/>
+ <xs:enumeration value="FillColor"/>
+ <xs:enumeration value="LineColor"/>
+ <xs:enumeration value="LineWeight"/>
+ <xs:enumeration value="Content"/>
+ <xs:enumeration value="Markup"/>
+ <xs:enumeration value="FontName"/>
+ <xs:enumeration value="Bold"/>
+ <xs:enumeration value="Italic"/>
+ <xs:enumeration value="Underlined"/>
+ <xs:enumeration value="Overlined"/>
+ <xs:enumeration value="ObliqueAngle"/>
+ <xs:enumeration value="TrackSpacing"/>
+ <xs:enumeration value="FontHeight"/>
+ <xs:enumeration value="HorizontalAlignment"/>
+ <xs:enumeration value="VerticalAlignment"/>
+ <xs:enumeration value="Justification"/>
+ <xs:enumeration value="LineSpacing"/>
+ <xs:enumeration value="TextColor"/>
+ <xs:enumeration value="GhostColor"/>
+ <xs:enumeration value="FrameLineColor"/>
+ <xs:enumeration value="FrameFillColor"/>
+ <xs:enumeration value="StartOffset"/>
+ <xs:enumeration value="EndOffset"/>
+ <xs:enumeration value="RepeatX"/>
+ <xs:enumeration value="RepeatY"/>
+ </xs:restriction>
+ </xs:simpleType>
+</xs:schema>
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/common/common.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/common/common.php 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/common/common.php 2015-04-02 11:40:10 UTC (rev 8614)
@@ -16,45 +16,11 @@
// Define some commonly used directories and files
-// Use the following for Windows installations
-$webExtensionsDirectory = 'C:\Program Files\OSGeo\MapGuide\Web\\';
-$MapGuideServerDirectory = 'C:\Program Files\OSGeo\MapGuide\Server\\';
-$viewerFilesDirectory = $webExtensionsDirectory . 'www\viewerfiles\\';
-$schemaDirectory = $MapGuideServerDirectory . 'Schema\\';
-$webconfigDirectory = $webExtensionsDirectory . 'www\\';
-$webconfigFilePath = $webconfigDirectory . 'webconfig.ini';
-// End of Windows configuration
-// Use the following for Linux installations
-$webExtensionsDirectory = '/usr/local/mapguideopensource/webserverextensions/';
-$MapGuideServerDirectory = '/usr/local/mapguideopensource/server/';
-$viewerFilesDirectory = $webExtensionsDirectory . 'www/viewerfiles/';
-$schemaDirectory = $MapGuideServerDirectory . 'Schema/';
-$webconfigDirectory = $webExtensionsDirectory . 'www/';
-// End of Linux configuration
+$webRootDirectory = dirname(__FILE__)."/../..";
+$viewerFilesDirectory = $webRootDirectory . '/viewerfiles';
+$schemaDirectory = dirname(__FILE__);
+$webconfigFilePath = $webRootDirectory . '/webconfig.ini';
// Include constants like MgServiceType::ResourceService
-require_once($webExtensionsDirectory . 'www/mapviewerphp/constants.php');
+require_once($webRootDirectory . '/mapadmin/constants.php');
\ No newline at end of file
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/index.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/index.php 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/index.php 2015-04-02 11:40:10 UTC (rev 8614)
@@ -69,7 +69,7 @@
// If the docs are located in that directory, this scripts links to them from the task pane.
- $helpDir = $webExtensionsDirectory . 'www/Help/';
+ $helpDir = $webRootDirectory . '/Help/';
$helpUrl = '/mapguide/Help/';
$devGuide = $helpDir . 'DevGuide.pdf';
$apiRef = $helpDir . 'index.htm';
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2015-04-02 11:40:10 UTC (rev 8614)
@@ -62,15 +62,8 @@
// Load the prototype layer definition into
// a PHP DOM object.
- $domDocument =
- DOMDocument::load('RecentlyBuilt.LayerDefinition');
- if ($domDocument == NULL)
- echo "The layer definition
- 'RecentlyBuilt.LayerDefinition' could not be
- found.<BR>\n";
- return;
+ $domDocument = new DOMDocument();
+ $domDocument->load('RecentlyBuilt.LayerDefinition');
// Change the filter
$xpath = new DOMXPath($domDocument);
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php 2015-04-02 11:40:10 UTC (rev 8614)
@@ -25,7 +25,7 @@
// Validate the XML.
$domDocument = new DOMDocument;
$domDocument->loadXML($layerDefinition);
- if (! $domDocument->schemaValidate($schemaDirectory . "LayerDefinition-1.3.0.xsd") ) // $schemaDirectory is defined in common.php
+ if (! $domDocument->schemaValidate($schemaDirectory . "/LayerDefinition-1.3.0.xsd") ) // $schemaDirectory is defined in common.php
echo "ERROR: The new XML document is invalid.<BR>\n.";
return NULL;
Modified: branches/2.6/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- branches/2.6/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2015-04-02 11:40:10 UTC (rev 8614)
@@ -416,7 +416,7 @@
//create the directory to make sure, [SetUserDictionaryDir]
//can succeed
- MgFileUtil::CreateDirectory(userDictionaryDir);
+ MgFileUtil::CreateDirectory(userDictionaryDir, false, true);
pCsCatalog->SetUserDictionaryDir(userDictionaryDir);
STRING setUserDictionaryDir = pCsCatalog->GetUserDictionaryDir();
@@ -470,6 +470,8 @@
bool TestCoordinateSystem::SetDefaultUserDictionaryDir()
+ MG_TRY()
MgCoordinateSystemFactory mgCsFactory;
Ptr<MgCoordinateSystemCatalog> pCsCatalog = mgCsFactory.GetCatalog();
@@ -485,9 +487,18 @@
//can succeed
- MgFileUtil::CreateDirectory(defUserDictionaryDir);
+ if (!MgFileUtil::PathnameExists(defUserDictionaryDir))
+ MgFileUtil::CreateDirectory(defUserDictionaryDir, false, true);
pCsCatalog->SetUserDictionaryDir(defUserDictionaryDir);
+ MG_CATCH(L"TestCoordinateSystem.SetDefaultUserDictionaryDir")
+ if (NULL != mgException.p)
+ STRING errDetails = mgException->GetDetails();
+ ACE_DEBUG((LM_INFO, ACE_TEXT("Exception setting user dictionary dir: %W"), errDetails.c_str()));
+ return false;
return true;
Modified: branches/2.6/MgDev/Web/src/mapviewernet/selectwithin.aspx
--- branches/2.6/MgDev/Web/src/mapviewernet/selectwithin.aspx 2015-04-02 11:36:00 UTC (rev 8613)
+++ branches/2.6/MgDev/Web/src/mapviewernet/selectwithin.aspx 2015-04-02 11:40:10 UTC (rev 8614)
@@ -73,7 +73,7 @@
// Query all the features belonging the the layer list that intersects with the input geometries
- MgFeatureInformation fi = renderingSrvc.QueryFeatures(map, layerNames, inputGeom, MgFeatureSpatialOperations.Intersects, -1);
+ MgFeatureInformation fi = renderingSrvc.QueryFeatures(map, layerNames, inputGeom, MgFeatureSpatialOperations.Intersects, "", -1, 2);
if(fi != null)
MgSelection resultSel = fi.GetSelection();
More information about the mapguide-commits
