[mapguide-commits] r8771 - in trunk/MgDev/UnitTest/Acceptance/tests: . fusion
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Oct 11 16:02:05 PDT 2015
Author: jng
Date: 2015-10-11 16:02:05 -0700 (Sun, 11 Oct 2015)
New Revision: 8771
Added:
   trunk/MgDev/UnitTest/Acceptance/tests/fusion/
   trunk/MgDev/UnitTest/Acceptance/tests/fusion/appdef.js
   trunk/MgDev/UnitTest/Acceptance/tests/fusion/slate_navigation.js
   trunk/MgDev/UnitTest/Acceptance/tests/settings.js
#2573: Add some basic tests for the fusion slate template
Added: trunk/MgDev/UnitTest/Acceptance/tests/fusion/appdef.js
--- trunk/MgDev/UnitTest/Acceptance/tests/fusion/appdef.js	                        (rev 0)
+++ trunk/MgDev/UnitTest/Acceptance/tests/fusion/appdef.js	2015-10-11 23:02:05 UTC (rev 8771)
@@ -0,0 +1,26 @@
+var cmdCodes = {
+    ZOOM_IN: 1,
+    ZOOM_OUT: 2,
+    ZOOM_RECT: 3
+module.exports = {
+    TB: cmdCodes,
+    getToolbarCommand: function(toolbarRootSelector, cmd) {
+        var className = null;
+        switch (cmd) {
+            case cmdCodes.ZOOM_IN:
+                className = "zoom-in-fixed";
+                break;
+            case cmdCodes.ZOOM_OUT:
+                className = "zoom-out-fixed";
+                break;
+            case cmdCodes.ZOOM_RECT:
+                className = "zoom-in";
+                break;
+            default:
+                throw new Error("Unknown command code: " + cmd);
+        return toolbarRootSelector + " div.jxBarScroller div.jxBarWrapper ul.jxToolbar li.jxToolItem span.jxButtonContainer a.jxButton span.jxButtonContent img." + className;
\ No newline at end of file
Added: trunk/MgDev/UnitTest/Acceptance/tests/fusion/slate_navigation.js
--- trunk/MgDev/UnitTest/Acceptance/tests/fusion/slate_navigation.js	                        (rev 0)
+++ trunk/MgDev/UnitTest/Acceptance/tests/fusion/slate_navigation.js	2015-10-11 23:02:05 UTC (rev 8771)
@@ -0,0 +1,61 @@
+var settings = require("../settings");
+var helper = require("../helper");
+var appDef = require("./appdef");
+module.exports = {
+    tags: ["fusion", "slate", "navigation"],
+    beforeEach: function(browser) {
+        helper.setDefaultBrowserSize(browser);
+    'SLATE_NAV001 - Zoom In': function(client) {
+        var funcName = arguments.callee.name;
+        client.url(settings.getFusionUrl("slate"))
+            .waitForElementVisible("div.olMapViewport", 8000, true)
+            .waitForElementVisible("img.olTileImage", 8000, true)
+            .waitForElementVisible("#Navigator", 2000, true)
+            .waitForElementVisible("#TaskPane_IFRAME", 2000, true)
+            .frame("TaskPane_IFRAME")
+                .waitForElementVisible("h1", 3000, true)
+                .assert.containsText("h1", "Task Pane Help")
+            .frame(null)
+            .moveToElement(appDef.getToolbarCommand("#ToolbarSecondary", appDef.TB.ZOOM_IN), 10, 10)
+            .mouseButtonClick(0)
+            .pause(3000) //Let rendering breathe
+            .saveScreenshot(helper.screenshotName(client, "Fusion - " + funcName + " - 001 - Zoom In clicked"))
+            .end();
+    'SLATE_NAV002 - Zoom Out': function(client) {
+            .frame(null)
+            .moveToElement(appDef.getToolbarCommand("#ToolbarSecondary", appDef.TB.ZOOM_OUT), 10, 10)
+            .saveScreenshot(helper.screenshotName(client, "Fusion - " + funcName + " - 001 - Zoom Out clicked"))
+            .end();
+    'SLATE_NAV003 - Zoom Rect': function(client) {
+            .frame(null)
+            .moveToElement(appDef.getToolbarCommand("#ToolbarSecondary", appDef.TB.ZOOM_RECT), 10, 10)
+            .saveScreenshot(helper.screenshotName(client, "Fusion - " + funcName + " - 001 - Zoom Rect clicked"))
+            .end();
Modified: trunk/MgDev/UnitTest/Acceptance/tests/settings.js
--- trunk/MgDev/UnitTest/Acceptance/tests/settings.js	2015-10-08 06:35:59 UTC (rev 8770)
+++ trunk/MgDev/UnitTest/Acceptance/tests/settings.js	2015-10-11 23:02:05 UTC (rev 8771)
@@ -6,8 +6,16 @@
     getAjaxViewerUrl: function(webLayout) {
         return "http://" + this.host + ":" + this.port + "/" + this.vdir + "/mapviewerajax/?USERNAME=Anonymous&WEBLAYOUT=" + (webLayout || this.defaultWebLayout);
+    getDefaultFlexLayout: function(template) {
+        switch (template) {
+            case "slate":
+                return "Library://Samples/Sheboygan/FlexibleLayouts/Slate.ApplicationDefinition";
+            default:
+                return "";
     getFusionUrl: function(template, layout) {
-        return "http://" + this.host + ":" + this.port + "/" + this.vdir + "/fusion/templates/mapguide/" + template + "/index.html?ApplicationDefinition=" + layout;
+        return "http://" + this.host + ":" + this.port + "/" + this.vdir + "/fusion/templates/mapguide/" + template + "/index.html?ApplicationDefinition=" + (layout || this.getDefaultFlexLayout(template));
 module.exports = settings;
More information about the mapguide-commits mailing list
