[mapguide-commits] r9010 - trunk/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jul 27 08:44:43 PDT 2016
Author: jng
Date: 2016-07-27 08:44:43 -0700 (Wed, 27 Jul 2016)
New Revision: 9010
   trunk/MgDev/build_oem.sh
Fix #2594. Based on this GEOS ticket (https://trac.osgeo.org/geos/ticket/469), setting explicit -m32/-m64 flags in CFLAGS/CXXFLAGS/CPPFLAGS/FFLAGS/LDFLAGS before calling the geos configure script.
Running "make check" without these changes reproduces the assertion error.
Running "make check" with this change does not produce the assertion error.
Modified: trunk/MgDev/build_oem.sh
--- trunk/MgDev/build_oem.sh	2016-07-27 14:03:30 UTC (rev 9009)
+++ trunk/MgDev/build_oem.sh	2016-07-27 15:44:43 UTC (rev 9010)
@@ -236,12 +236,20 @@
     # For this version of GEOS, don't run the aclocal/libtoolize/automake/autoconf quartet as we normally do, as it
     # may produce an unusable configure script. Just run autoreconf to regenerate the configure script from configure.in
     autoreconf
+    # Fix for error:
+    # virtual void geos::geom::GeometryComponentFilter::filter_ro(const geos::geom::Geometry*): Assertion `0' failed
+    # Based on this GEOS ticket: https://trac.osgeo.org/geos/ticket/469
+    # The fix to to set the appropriate CFLAGS/CPPFLAGS/CXXFLAGS/LDFLAGS/FFLAGS before calling the configure script
+    # If we upgrade our internal copy of GEOS in the future, this should be reviewed
+    chmod +x configure
     if [ $BUILD_CPU -eq 64 ]; then
-        sh ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
+        CFLAGS="-m64" CPPFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" FFLAGS="-m64" LDFLAGS="-L/usr/lib64" ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
     else
-        sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
+        CFLAGS="-m32" CPPFLAGS="-m32" CXXFLAGS="-m32" LDFLAGS="-m32" FFLAGS="-m32" LDFLAGS="-L/usr/lib" ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
     fi
-    make
     # The check build is disabled as the build will fail with automake version < 2.59
     check_build
     popd
@@ -673,7 +681,7 @@
 pushd Oem
-for lib in linuxapt fusion ace dwfcore dwftk geos bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
+for lib in linuxapt fusion ace dwfcore dwftk bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap geos;
 do
     echo "$lib: Initialization..........................."
     init_"$lib"
More information about the mapguide-commits mailing list
