[mapguide-commits] r9011 - branches/3.1/MgDev
svn_mapguide at osgeo.org
Wed Jul 27 08:47:15 PDT 2016
Author: jng
Date: 2016-07-27 08:47:14 -0700 (Wed, 27 Jul 2016)
New Revision: 9011
branches/3.1/MgDev/
branches/3.1/MgDev/build_oem.sh
Merged revision(s) 9010 from trunk/MgDev:
Fix #2594. Based on this GEOS ticket (https://trac.osgeo.org/geos/ticket/469), setting explicit -m32/-m64 flags in CFLAGS/CXXFLAGS/CPPFLAGS/FFLAGS/LDFLAGS before calling the geos configure script.
Running "make check" without these changes reproduces the assertion error.
Running "make check" with this change does not produce the assertion error.
Property changes on: branches/3.1/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/branches/3.0/MgDev:8658,8705,8710
/sandbox/VC140:8684-8759
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/php56x:8975-8985
/sandbox/jng/rfc155:8872-8884
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
/trunk/MgDev:8955-8956,8969,8980-8981,8986,8996,9000,9004-9006
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8955-8956,8969,8980-8981,8986,8996,9000,9004-9006,9010
Modified: branches/3.1/MgDev/build_oem.sh
--- branches/3.1/MgDev/build_oem.sh 2016-07-27 15:44:43 UTC (rev 9010)
+++ branches/3.1/MgDev/build_oem.sh 2016-07-27 15:47:14 UTC (rev 9011)
@@ -236,12 +236,20 @@
# For this version of GEOS, don't run the aclocal/libtoolize/automake/autoconf quartet as we normally do, as it
# may produce an unusable configure script. Just run autoreconf to regenerate the configure script from configure.in
autoreconf
+ # Fix for error:
+ # virtual void geos::geom::GeometryComponentFilter::filter_ro(const geos::geom::Geometry*): Assertion `0' failed
+ # Based on this GEOS ticket: https://trac.osgeo.org/geos/ticket/469
+ # The fix to to set the appropriate CFLAGS/CPPFLAGS/CXXFLAGS/LDFLAGS/FFLAGS before calling the configure script
+ # If we upgrade our internal copy of GEOS in the future, this should be reviewed
+ chmod +x configure
if [ $BUILD_CPU -eq 64 ]; then
- sh ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
+ CFLAGS="-m64" CPPFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" FFLAGS="-m64" LDFLAGS="-L/usr/lib64" ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
else
- sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
+ CFLAGS="-m32" CPPFLAGS="-m32" CXXFLAGS="-m32" LDFLAGS="-m32" FFLAGS="-m32" LDFLAGS="-L/usr/lib" ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
fi
- make
# The check build is disabled as the build will fail with automake version < 2.59
check_build
popd
@@ -673,7 +681,7 @@
pushd Oem
-for lib in linuxapt fusion ace dwfcore dwftk geos bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
+for lib in linuxapt fusion ace dwfcore dwftk bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap geos;
do
echo "$lib: Initialization..........................."
init_"$lib"
More information about the mapguide-commits
