[mapguide-commits] r8943 - in trunk/Tools/Vagrant: . scripts
svn_mapguide at osgeo.org
Mon May 9 16:59:30 PDT 2016
Author: jng
Date: 2016-05-09 16:59:30 -0700 (Mon, 09 May 2016)
New Revision: 8943
Added:
trunk/Tools/Vagrant/build_target.bat
trunk/Tools/Vagrant/scripts/provision_ubuntu.sh
Vagrant build environment updates:
- Add new build_target.bat that is basically the build.bat split up so that it can be used against any vagrant VM target.
- provision_ubuntu.sh:
- Don't copy MapGuide .tar.xz files to build output (because MapGuide tarballs are not created on Ubuntu)
- sudo run ./dpkgmapguide.sh
Added: trunk/Tools/Vagrant/build_target.bat
--- trunk/Tools/Vagrant/build_target.bat (rev 0)
+++ trunk/Tools/Vagrant/build_target.bat 2016-05-09 23:59:30 UTC (rev 8943)
@@ -0,0 +1,151 @@
+ at echo off
+rem ==================================================
+rem build_target.bat
+rem
+rem Builds MapGuide/FDO in a specific vagrant VM
+rem
+rem Requires the tee and md5sum utilities, which is
+rem part of GNU on Windows
+rem
+rem https://github.com/bmatzelle/gow
+rem
+rem Parameter Handling
+:study_params
+if (%1)==() goto start_build
+if "%1"=="-h" goto help_show
+if "%1"=="-distro" goto get_distro
+if "%1"=="-target" goto get_target
+if "%1"=="-ext" goto get_extension
+if "%1"=="-teardown" goto get_teardown
+goto custom_error
+:next_param
+shift
+shift
+goto study_params
+:get_distro
+SET VM_DISTRO=%2
+goto next_param
+:get_target
+SET VM_TARGET=%2
+IF "%2"=="x86" goto next_param
+IF "%2"=="x64" goto next_param
+SET ERRORMSG=Unrecognised target: %2
+goto custom_error
+:get_extension
+SET BUILD_ARTIFACT_EXTENSION=%2
+IF "%2"=="deb" goto next_param
+IF "%2"=="tar.xz" goto next_param
+SET ERRORMSG=Unrecognised extension: %2
+goto custom_error
+:get_teardown
+SET VM_TEARDOWN=%2
+IF "%2"=="1" goto next_param
+IF "%2"=="0" goto next_param
+SET ERRORMSG=Teardown flag must be 1 or 0. Got: %2
+goto custom_error
+:start_build
+IF "%VM_DISTRO%"=="" goto help_show
+IF "%VM_TARGET%"=="" goto help_show
+IF "%VM_TEARDOWN%"=="" goto help_show
+IF "%BUILD_ARTIFACT_EXTENSION%"=="" goto help_show
+SET BUILD_ARTIFACT_DIR=builds\%VM_DISTRO%_%VM_TARGET%
+SET BUILD_LOG_DIR=%BUILD_ARTIFACT_DIR%\logs
+SET VAGRANTFILE_DIR=%VM_DISTRO%\%VM_TARGET%
+SET BUILD_ARTIFACT_SRC_DIR=%VAGRANTFILE_DIR%\build
+IF NOT EXIST %VAGRANTFILE_DIR% (
+ SET ERRORMSG=No vagrantfile exists at [%VAGRANTFILE_DIR%]
+ goto custom_error
+rem Ensure build artifact dir exists
+IF NOT EXIST builds mkdir builds
+IF NOT EXIST %BUILD_ARTIFACT_DIR% mkdir %BUILD_ARTIFACT_DIR%
+IF NOT EXIST %BUILD_LOG_DIR% mkdir %BUILD_LOG_DIR%
+echo ***************** VM Build Summary *********************
+echo Distro: %VM_DISTRO%
+echo Target: %VM_TARGET%
+echo Teardown?: %VM_TEARDOWN%
+echo Artifact Extension: %BUILD_ARTIFACT_EXTENSION%
+echo Using vagrantfile from: %VAGRANTFILE_DIR%
+echo Build Artifacts will be in: %BUILD_ARTIFACT_DIR%
+echo ********************************************************
+rem Copy build/provisioning scripts to vagrantfile dir
+xcopy /S /Y /I scripts\* %VAGRANTFILE_DIR%
+:spin_up_vm
+echo [build]: Spin up VM at [%VAGRANTFILE_DIR%]
+pushd %VAGRANTFILE_DIR%
+if exist build rd /S /Q build
+call vagrant up 2>&1 | tee up.log
+echo [build]: vagrant returned %errorlevel%
+if "%errorlevel%"=="1" goto error
+if not exist build\*.%BUILD_ARTIFACT_EXTENSION% goto error
+popd
+goto copy_artifacts
+:copy_artifacts
+echo [build]: Copying artifacts from [%BUILD_ARTIFACT_SRC_DIR%] to [%BUILD_ARTIFACT_DIR%]
+move /Y %BUILD_ARTIFACT_SRC_DIR%\*.sh %BUILD_ARTIFACT_DIR%
+move /Y %BUILD_ARTIFACT_SRC_DIR%\*.%BUILD_ARTIFACT_EXTENSION% %BUILD_ARTIFACT_DIR%
+echo [build]: Copying logs from [%BUILD_ARTIFACT_SRC_DIR%] to [%BUILD_LOG_DIR%]
+move /Y %BUILD_ARTIFACT_SRC_DIR%\*.log %BUILD_LOG_DIR%
+move /Y %BUILD_ARTIFACT_SRC_DIR%\*.xml %BUILD_LOG_DIR%
+echo [build]: Generate MD5 hashes in [%BUILD_ARTIFACT_DIR%]
+pushd %BUILD_ARTIFACT_DIR%
+if exist md5sums.txt del md5sums.txt
+md5sum *.sh > md5sums.txt
+md5sum *.%BUILD_ARTIFACT_EXTENSION% >> md5sums.txt
+popd
+IF "%VM_TEARDOWN%"=="1" goto tear_down_vm
+goto quit
+:tear_down_vm
+echo [build]: Tear down VM at [%VAGRANTFILE_DIR%]
+call vagrant destroy -f
+popd
+goto quit
+:error
+echo [ERROR]: There was an error building the component
+exit /B 1
+:custom_error
+echo [ERROR]: %ERRORMSG%
+SET ERRORMSG=
+:help_show
+echo Usage:
+echo ************************************************************************
+echo build.bat [-h]
+echo [-distro=Distro]
+echo [-target=TargetName]
+echo [-ext=Extension]
+echo [-teardown=Teardown]
+echo Help: -h
+echo Distro: -distro=ubuntu12,
+echo ubuntu14
+echo centos6
+echo TargetName: -target=x86,
+echo x64
+echo Extension: -ext=deb,
+echo tar.xz
+echo Teardown: -teardown=1,
+echo 0
+:quit
\ No newline at end of file
Modified: trunk/Tools/Vagrant/scripts/provision_ubuntu.sh
--- trunk/Tools/Vagrant/scripts/provision_ubuntu.sh 2016-05-09 06:07:55 UTC (rev 8942)
+++ trunk/Tools/Vagrant/scripts/provision_ubuntu.sh 2016-05-09 23:59:30 UTC (rev 8943)
@@ -267,7 +267,7 @@
FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
MG_REV=`svn info $MG_SRC | perl revnum.pl`
BUILD_COMPONENT="MapGuide deb packages"
-./dpkgmapguide.sh $MG_ARCH $MG_REV 2>&1 | tee $MG_HOME/dpkg_mapguide.log
+sudo -E ./dpkgmapguide.sh $MG_ARCH $MG_REV 2>&1 | tee $MG_HOME/dpkg_mapguide.log
check_build
> $MG_HOME/unit_test_status.log
if [ $FDO_UNIT_TEST -eq 1 ];
@@ -355,7 +355,7 @@
echo [provision]: Copy log files to output dir
sudo mv -f $MG_HOME/*.log $MOUNT_DIR/build
echo [provision]: Copy tarballs to output dir
-sudo cp bin/*.tar.xz $MOUNT_DIR/build
+# sudo cp bin/*.tar.xz $MOUNT_DIR/build
sudo cp fdosdk-${FDO_DISTRO}-${MG_ARCH}-${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}_${FDO_REV}.tar.xz $MOUNT_DIR/build
if [ $MAKE_FDO_SDK -eq 1 ]; then
echo [provision]: Copy FDO SDK for Ubuntu builds
More information about the mapguide-commits
