[mapguide-commits] r8944 - in trunk/Tools/Vagrant: . ubuntu14/x64 ubuntu14/x86
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 10 04:47:53 PDT 2016
Author: jng
Date: 2016-05-10 04:47:53 -0700 (Tue, 10 May 2016)
New Revision: 8944
Added:
   trunk/Tools/Vagrant/ubuntu14/
   trunk/Tools/Vagrant/ubuntu14/x64/Vagrantfile
   trunk/Tools/Vagrant/ubuntu14/x86/Vagrantfile
Removed:
#2590: Add Ubuuntu 14 vagrantfiles
Deleted: trunk/Tools/Vagrant/ubuntu14/x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile	2016-04-22 13:00:17 UTC (rev 8931)
+++ trunk/Tools/Vagrant/ubuntu14/x64/Vagrantfile	2016-05-10 11:47:53 UTC (rev 8944)
@@ -1,123 +0,0 @@
-# -*- mode: ruby -*-
-# vi: set ft=ruby :
-# Vagrantfile API/syntax version. Don't touch unless you know what you're doing!
-VAGRANTFILE_API_VERSION = "2"
-Vagrant.configure(VAGRANTFILE_API_VERSION) do |config|
-  # All Vagrant configuration is done here. The most common configuration
-  # options are documented and commented below. For a complete reference,
-  # please see the online documentation at vagrantup.com.
-  # Every Vagrant virtual environment requires a box to build off of.
-  config.vm.box = "ubuntu12-amd64"
-  # The url from where the 'config.vm.box' box will be fetched if it
-  # doesn't already exist on the user's system.
-  # config.vm.box_url = "http://domain.com/path/to/above.box"
-  # Create a forwarded port mapping which allows access to a specific port
-  # within the machine from a port on the host machine. In the example below,
-  # accessing "localhost:8080" will access port 80 on the guest machine.
-  # config.vm.network :forwarded_port, guest: 80, host: 8080
-  # Create a private network, which allows host-only access to the machine
-  # using a specific IP.
-  # config.vm.network :private_network, ip: "192.168.33.10"
-  # Create a public network, which generally matched to bridged network.
-  # Bridged networks make the machine appear as another physical device on
-  # your network.
-  # config.vm.network :public_network
-  # If true, then any SSH connections made will enable agent forwarding.
-  # Default value: false
-  # config.ssh.forward_agent = true
-  # Share an additional folder to the guest VM. The first argument is
-  # the path on the host to the actual folder. The second argument is
-  # the path on the guest to mount the folder. And the optional third
-  # argument is a set of non-required options.
-  config.vm.synced_folder "../../sources", "/mapguide_sources"
-  # Provider-specific configuration so you can fine-tune various
-  # backing providers for Vagrant. These expose provider-specific options.
-  # Example for VirtualBox:
-  # config.vm.provider :virtualbox do |vb|
-  #   # Don't boot with headless mode
-  #   vb.gui = true
-  #   # Use VBoxManage to customize the VM. For example to change memory:
-  #   vb.customize ["modifyvm", :id, "--memory", "1024"]
-  # end
-  # View the documentation for the provider you're using for more
-  # information on available options.
-  # Enable provisioning with Puppet stand alone.  Puppet manifests
-  # are contained in a directory path relative to this Vagrantfile.
-  # You will need to create the manifests directory and a manifest in
-  # the file vagrant-mapguide-ubuntu-precise32.pp in the manifests_path directory.
-  # An example Puppet manifest to provision the message of the day:
-  # # group { "puppet":
-  # #   ensure => "present",
-  # # File { owner => 0, group => 0, mode => 0644 }
-  # # file { '/etc/motd':
-  # #   content => "Welcome to your Vagrant-built virtual machine!
-  # #               Managed by Puppet.\n"
-  # config.vm.provision :puppet do |puppet|
-  #   puppet.manifests_path = "manifests"
-  #   puppet.manifest_file  = "site.pp"
-  # end
-  # Enable provisioning with chef solo, specifying a cookbooks path, roles
-  # path, and data_bags path (all relative to this Vagrantfile), and adding
-  # some recipes and/or roles.
-  # config.vm.provision :chef_solo do |chef|
-  #   chef.cookbooks_path = "../my-recipes/cookbooks"
-  #   chef.roles_path = "../my-recipes/roles"
-  #   chef.data_bags_path = "../my-recipes/data_bags"
-  #   chef.add_recipe "mysql"
-  #   chef.add_role "web"
-  #   # You may also specify custom JSON attributes:
-  #   chef.json = { :mysql_password => "foo" }
-  # end
-  # Enable provisioning with chef server, specifying the chef server URL,
-  # and the path to the validation key (relative to this Vagrantfile).
-  # The Opscode Platform uses HTTPS. Substitute your organization for
-  # ORGNAME in the URL and validation key.
-  # If you have your own Chef Server, use the appropriate URL, which may be
-  # HTTP instead of HTTPS depending on your configuration. Also change the
-  # validation key to validation.pem.
-  # config.vm.provision :chef_client do |chef|
-  #   chef.chef_server_url = "https://api.opscode.com/organizations/ORGNAME"
-  #   chef.validation_key_path = "ORGNAME-validator.pem"
-  # end
-  # If you're using the Opscode platform, your validator client is
-  # ORGNAME-validator, replacing ORGNAME with your organization name.
-  # If you have your own Chef Server, the default validation client name is
-  # chef-validator, unless you changed the configuration.
-  #   chef.validation_client_name = "ORGNAME-validator"
-  config.vm.provision "shell",
-    privileged: false,
-    path: "provision_ubuntu.sh",
-    args: [4, 1, 0, 3, 1, 0, "trunk", "trunk", "amd64", "Test", "ubuntu12"]
-end
Copied: trunk/Tools/Vagrant/ubuntu14/x64/Vagrantfile (from rev 8932, trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile)
--- trunk/Tools/Vagrant/ubuntu14/x64/Vagrantfile	                        (rev 0)
@@ -0,0 +1,123 @@
+# -*- mode: ruby -*-
+# vi: set ft=ruby :
+# Vagrantfile API/syntax version. Don't touch unless you know what you're doing!
+VAGRANTFILE_API_VERSION = "2"
+Vagrant.configure(VAGRANTFILE_API_VERSION) do |config|
+  # All Vagrant configuration is done here. The most common configuration
+  # options are documented and commented below. For a complete reference,
+  # please see the online documentation at vagrantup.com.
+  # Every Vagrant virtual environment requires a box to build off of.
+  config.vm.box = "ubuntu14-amd64"
+  # The url from where the 'config.vm.box' box will be fetched if it
+  # doesn't already exist on the user's system.
+  # config.vm.box_url = "http://domain.com/path/to/above.box"
+  # Create a forwarded port mapping which allows access to a specific port
+  # within the machine from a port on the host machine. In the example below,
+  # accessing "localhost:8080" will access port 80 on the guest machine.
+  # config.vm.network :forwarded_port, guest: 80, host: 8080
+  # Create a private network, which allows host-only access to the machine
+  # using a specific IP.
+  # config.vm.network :private_network, ip: "192.168.33.10"
+  # Create a public network, which generally matched to bridged network.
+  # Bridged networks make the machine appear as another physical device on
+  # your network.
+  # config.vm.network :public_network
+  # If true, then any SSH connections made will enable agent forwarding.
+  # Default value: false
+  # config.ssh.forward_agent = true
+  # Share an additional folder to the guest VM. The first argument is
+  # the path on the host to the actual folder. The second argument is
+  # the path on the guest to mount the folder. And the optional third
+  # argument is a set of non-required options.
+  config.vm.synced_folder "../../sources", "/mapguide_sources"
+  # Provider-specific configuration so you can fine-tune various
+  # backing providers for Vagrant. These expose provider-specific options.
+  # Example for VirtualBox:
+  # config.vm.provider :virtualbox do |vb|
+  #   # Don't boot with headless mode
+  #   vb.gui = true
+  #   # Use VBoxManage to customize the VM. For example to change memory:
+  #   vb.customize ["modifyvm", :id, "--memory", "1024"]
+  # end
+  # View the documentation for the provider you're using for more
+  # information on available options.
+  # Enable provisioning with Puppet stand alone.  Puppet manifests
+  # are contained in a directory path relative to this Vagrantfile.
+  # You will need to create the manifests directory and a manifest in
+  # the file vagrant-mapguide-ubuntu-precise32.pp in the manifests_path directory.
+  # An example Puppet manifest to provision the message of the day:
+  # # group { "puppet":
+  # #   ensure => "present",
+  # # File { owner => 0, group => 0, mode => 0644 }
+  # # file { '/etc/motd':
+  # #   content => "Welcome to your Vagrant-built virtual machine!
+  # #               Managed by Puppet.\n"
+  # config.vm.provision :puppet do |puppet|
+  #   puppet.manifests_path = "manifests"
+  #   puppet.manifest_file  = "site.pp"
+  # end
+  # Enable provisioning with chef solo, specifying a cookbooks path, roles
+  # path, and data_bags path (all relative to this Vagrantfile), and adding
+  # some recipes and/or roles.
+  # config.vm.provision :chef_solo do |chef|
+  #   chef.cookbooks_path = "../my-recipes/cookbooks"
+  #   chef.roles_path = "../my-recipes/roles"
+  #   chef.data_bags_path = "../my-recipes/data_bags"
+  #   chef.add_recipe "mysql"
+  #   chef.add_role "web"
+  #   # You may also specify custom JSON attributes:
+  #   chef.json = { :mysql_password => "foo" }
+  # end
+  # Enable provisioning with chef server, specifying the chef server URL,
+  # and the path to the validation key (relative to this Vagrantfile).
+  # The Opscode Platform uses HTTPS. Substitute your organization for
+  # ORGNAME in the URL and validation key.
+  # If you have your own Chef Server, use the appropriate URL, which may be
+  # HTTP instead of HTTPS depending on your configuration. Also change the
+  # validation key to validation.pem.
+  # config.vm.provision :chef_client do |chef|
+  #   chef.chef_server_url = "https://api.opscode.com/organizations/ORGNAME"
+  #   chef.validation_key_path = "ORGNAME-validator.pem"
+  # end
+  # If you're using the Opscode platform, your validator client is
+  # ORGNAME-validator, replacing ORGNAME with your organization name.
+  # If you have your own Chef Server, the default validation client name is
+  # chef-validator, unless you changed the configuration.
+  #   chef.validation_client_name = "ORGNAME-validator"
+  config.vm.provision "shell",
+    privileged: false,
+    path: "provision_ubuntu.sh",
+    args: [4, 1, 0, 3, 1, 0, "trunk", "trunk", "amd64", "Test", "ubuntu14", 1, 1]
+end
Deleted: trunk/Tools/Vagrant/ubuntu14/x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile	2016-04-22 13:00:17 UTC (rev 8931)
+++ trunk/Tools/Vagrant/ubuntu14/x86/Vagrantfile	2016-05-10 11:47:53 UTC (rev 8944)
@@ -1,123 +0,0 @@
-  config.vm.box = "ubuntu12-i386"
-  # your network.
-  #   vb.gui = true
-  # end
-  # end
-  # end
-  # end
-    args: [4, 1, 0, 3, 1, 0, "trunk", "trunk", "i386", "Test", "ubuntu12"]
-end
Copied: trunk/Tools/Vagrant/ubuntu14/x86/Vagrantfile (from rev 8932, trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile)
--- trunk/Tools/Vagrant/ubuntu14/x86/Vagrantfile	                        (rev 0)
@@ -0,0 +1,123 @@
+  config.vm.box = "ubuntu14-i386"
+  # your network.
+  #   vb.gui = true
+  # end
+  # end
+  # end
+  # end
+    args: [4, 1, 0, 3, 1, 0, "trunk", "trunk", "i386", "Test", "ubuntu14", 1, 1]
+end
More information about the mapguide-commits mailing list
