[mapguide-commits] r9340 - in trunk/MgDev: . Web/src/mapviewerjava Web/src/mapviewernet Web/src/mapviewerphp Web/src/viewerfiles
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Mar 3 05:01:30 PST 2018
Author: jng
Date: 2018-03-03 05:01:30 -0800 (Sat, 03 Mar 2018)
New Revision: 9340
   trunk/MgDev/
   trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
   trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx
   trunk/MgDev/Web/src/mapviewerphp/selectwithin.php
   trunk/MgDev/Web/src/viewerfiles/
   trunk/MgDev/Web/src/viewerfiles/selectwithinui.templ
Merged revision(s) 9136-9138 from sandbox/adsk/3.2o.AIMS:
#2764 Select Within returns all features when actually no result should be found
Clear selection if there is no features in the polygon.
Update the JSP code.
Update the PHP code.
Index: trunk/MgDev
--- trunk/MgDev	2018-03-03 12:59:57 UTC (rev 9339)
+++ trunk/MgDev	2018-03-03 13:01:30 UTC (rev 9340)
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -6,7 +6,7 ##
 /sandbox/adsk/2.6l:8727
 /sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
 /sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942,9019-9020
-/sandbox/adsk/3.2o.AIMS:9135
+/sandbox/adsk/3.2o.AIMS:9135-9138
 /sandbox/jng/clean_json:8818-9180
 /sandbox/jng/cmake_v2:9259-9317
 /sandbox/jng/cmdline:9199-9217
Modified: trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
--- trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp	2018-03-03 12:59:57 UTC (rev 9339)
+++ trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp	2018-03-03 13:01:30 UTC (rev 9340)
@@ -52,6 +52,7 @@
         site.Open(cred);
         MgFeatureService featureSrvc = (MgFeatureService)site.CreateService(MgServiceType.FeatureService);
         MgRenderingService renderingSrvc = (MgRenderingService)site.CreateService(MgServiceType.RenderingService);
+        MgResourceService resourceSrvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
         //load the map runtime state
@@ -81,8 +82,16 @@
                     if(resultSel != null)
                         // Return XML
-                        response.addHeader("Content-type", "text/xml");
-                        outStream.write(resultSel.ToXml());
+                        resultSel.Save(resourceSrvc, mapName);
+                        //this needs to be re-opened for some reason
+                        resultSel = new MgSelection(map);
+                        resultSel.Open(resourceSrvc, mapName);
+                        MgReadOnlyLayerCollection resLayers = resultSel.GetLayers();
+                        if (resLayers != null && resLayers.GetCount() >= 0)
+                            response.addHeader("Content-type", "text/xml");
+                            outStream.write(resultSel.ToXml());
Modified: trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx
--- trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx	2018-03-03 12:59:57 UTC (rev 9339)
+++ trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx	2018-03-03 13:01:30 UTC (rev 9340)
@@ -1,5 +1,5 @@
-Copyright (C) 2004-2011 by Autodesk, Inc.
+Copyright (C) 2017 by Autodesk, Inc.
 This library is free software; you can redistribute it and/or
 modify it under the terms of version 2.1 of the GNU Lesser
 General Public License as published by the Free Software Foundation.
@@ -50,6 +50,7 @@
         site.Open(cred);
         MgFeatureService featureSrvc = site.CreateService(MgServiceType.FeatureService) as MgFeatureService;
         MgRenderingService renderingSrvc = site.CreateService(MgServiceType.RenderingService) as MgRenderingService;
+        MgResourceService resourceSrvc = site.CreateService(MgServiceType.ResourceService) as MgResourceService;
@@ -79,8 +80,16 @@
                         // Return XML
-                        Response.AddHeader("Content-type", "text/xml");
-                        Response.Write(resultSel.ToXml());
+                            Response.AddHeader("Content-type", "text/xml");
+                            Response.Write(resultSel.ToXml());
Modified: trunk/MgDev/Web/src/mapviewerphp/selectwithin.php
--- trunk/MgDev/Web/src/mapviewerphp/selectwithin.php	2018-03-03 12:59:57 UTC (rev 9339)
+++ trunk/MgDev/Web/src/mapviewerphp/selectwithin.php	2018-03-03 13:01:30 UTC (rev 9340)
@@ -42,6 +42,7 @@
         $site->Open($cred);
         $featureSrvc = $site->CreateService(MgServiceType::FeatureService);
         $renderingSrvc = $site->CreateService(MgServiceType::RenderingService);
+        $resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
@@ -69,9 +70,17 @@
                     $resultSel = $fi->GetSelection();
                     if($resultSel)
-                        //return XML
-                        header("Content-type: text/xml");
-                        echo $resultSel->ToXml();
+                        // Return XML
+                        $resultSel->Save($resourceSrvc, $mapName);
+                        $resultSel = new MgSelection($map);
+                        $resultSel->Open($resourceSrvc, $mapName);
+                        $resLayers = $resultSel->GetLayers();
+                        if ($resLayers != null && $resLayers->GetCount() >= 0)
+                            header("Content-type: text/xml");
+                            echo $resultSel->ToXml();
Index: trunk/MgDev/Web/src/viewerfiles
--- trunk/MgDev/Web/src/viewerfiles	2018-03-03 12:59:57 UTC (rev 9339)
+++ trunk/MgDev/Web/src/viewerfiles	2018-03-03 13:01:30 UTC (rev 9340)
Property changes on: trunk/MgDev/Web/src/viewerfiles
## -3,6 +3,7 ##
 /branches/3.1/MgDev/Web/src/viewerfiles:9058-9059
 /sandbox/adsk/2.2gp/Web/src/viewerfiles:5392
 /sandbox/adsk/3.0m/Web/src/viewerfiles:8607
+/sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles:9136-9138
 /sandbox/jng/clean_json/Web/src/viewerfiles:8818-9180
 /sandbox/jng/createruntimemap/Web/src/viewerfiles:7486-7555
 /sandbox/jng/v30/Web/src/viewerfiles:8226-8227
\ No newline at end of property
Modified: trunk/MgDev/Web/src/viewerfiles/selectwithinui.templ
--- trunk/MgDev/Web/src/viewerfiles/selectwithinui.templ	2018-03-03 12:59:57 UTC (rev 9339)
+++ trunk/MgDev/Web/src/viewerfiles/selectwithinui.templ	2018-03-03 13:01:30 UTC (rev 9340)
@@ -90,6 +90,8 @@
         reqHandler.send(reqParams);
         if(reqHandler.responseXML)
             GetParent().SetSelectionXML(reqHandler.responseText);
+        else
+            GetParent().GetMapFrame().ClearSelection();
     catch(e) {}
     GetParent().GotoHomePage();
More information about the mapguide-commits mailing list
