[mapguide-commits] r9341 - in trunk/MgDev: . Web/src/viewerfiles
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Mar 3 05:03:09 PST 2018
Author: jng
Date: 2018-03-03 05:03:09 -0800 (Sat, 03 Mar 2018)
New Revision: 9341
   trunk/MgDev/
   trunk/MgDev/Web/src/viewerfiles/
   trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
Merged revision(s) 9139 from sandbox/adsk/3.2o.AIMS:
Currently, zoom selection doesn't work if the select panel is invisible. It is because the selection bounds is calculated only when selection panel is visible. Now remove this limit to make zoom selection work at all time.
Index: trunk/MgDev
--- trunk/MgDev	2018-03-03 13:01:30 UTC (rev 9340)
+++ trunk/MgDev	2018-03-03 13:03:09 UTC (rev 9341)
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -6,7 +6,7 ##
 /sandbox/adsk/2.6l:8727
 /sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
 /sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942,9019-9020
-/sandbox/adsk/3.2o.AIMS:9135-9138
+/sandbox/adsk/3.2o.AIMS:9135-9139
 /sandbox/jng/clean_json:8818-9180
 /sandbox/jng/cmake_v2:9259-9317
 /sandbox/jng/cmdline:9199-9217
Index: trunk/MgDev/Web/src/viewerfiles
--- trunk/MgDev/Web/src/viewerfiles	2018-03-03 13:01:30 UTC (rev 9340)
+++ trunk/MgDev/Web/src/viewerfiles	2018-03-03 13:03:09 UTC (rev 9341)
Property changes on: trunk/MgDev/Web/src/viewerfiles
## -3,7 +3,7 ##
 /branches/3.1/MgDev/Web/src/viewerfiles:9058-9059
 /sandbox/adsk/2.2gp/Web/src/viewerfiles:5392
 /sandbox/adsk/3.0m/Web/src/viewerfiles:8607
-/sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles:9136-9138
+/sandbox/adsk/3.2o.AIMS/Web/src/viewerfiles:9136-9139
 /sandbox/jng/clean_json/Web/src/viewerfiles:8818-9180
 /sandbox/jng/createruntimemap/Web/src/viewerfiles:7486-7555
 /sandbox/jng/v30/Web/src/viewerfiles:8226-8227
\ No newline at end of property
Modified: trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
--- trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ	2018-03-03 13:01:30 UTC (rev 9340)
+++ trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ	2018-03-03 13:03:09 UTC (rev 9341)
@@ -3176,20 +3176,17 @@
     if(which & 2)
-        if (IsPropertyCtrlVisible())
+        if (selection.count > 0)
-            if (selection.count > 0)
-                //Check if we have attributes inline
-                var props = xmlIn.getElementsByTagName("SelectedLayer");
-                var resp = ConvertToSelectedFeatureSet(props, xmlIn, append);
-                ProcessSelectedFeatureSet(resp, append);
-            else
-                ResetPropertyPane();
+            //Check if we have attributes inline
+            var props = xmlIn.getElementsByTagName("SelectedLayer");
+            var resp = ConvertToSelectedFeatureSet(props, xmlIn, append);
+            ProcessSelectedFeatureSet(resp, append);
+        else
+            ResetPropertyPane();
     if(which & 4)
More information about the mapguide-commits mailing list
