[mapguide-dev] problems initializing web tier
Traian Stanev traian.stanev at autodesk.com
Mon Apr 24 10:03:58 EDT 2006
Well if you have all debug DLLs, you should be able to turn on unmanaged
debugging for your project and then set up the debugger to break on C++
exceptions and Win32 exceptions. Then run your app and see where it
stops in the debugger -- this will be the place it is crashing -- and
see what exactly it is trying to do.
Traian
-----Original Message-----
From: alucas at srtec.com [mailto:alucas at srtec.com]
Sent: Monday, April 24, 2006 9:59 AM
To: dev at mapguide.osgeo.org
Cc: dev at mapguide.osgeo.org
Subject: RE: [mapguide-dev] problems initializing web tier
Well, I've run the .exe through explorer getting the same error. If I
build my sample applicattion in Debug mode, the exception I get is:
An unhandled exception of type 'System.TypeInitializationException'
occurred in MapGuideDotNetApid.dll
Additional information: The type initializer for 'MapGuideApiPINVOKE'
threw an exception.
Any idea?
> The msjava should not be an issue. I'm all out of ideas, may be
someone
> else will come up with something... By the way, are you running from
> inside the debugger? Did you try running the .exe directly by clicking
> on it from explorer?
> Traian
> Sent: Monday, April 24, 2006 9:44 AM
> Well,
> I set this variables in order to build Web Extensions:
> PROJ_LIB=C:\Documents and Settings\alucas\Mis
> documentos\mapguide-1.0.0\Oem\proj-4.4.9\nad
> GDAL_DATA=c:\Documents and Settings\alucas\Mis
> documentos\mapguide-1.0.0\Oem\gdal-1.3.0\data
> I've depends.exe and have been executed selecting
> MapGuideDotNetApid.dll,
> I'm not an expert using this tool but, the only problem I see is with
> MSJAVA.dll. I attach screenshot of the result.
>> OK that looks fine. It is probably still worth it to check with the
> dll
>> dependecy tool -- available at http://www.dependencywalker.com/
>> Another thing... Can you run "set" form a command line and tell me if
>> the environment variables GDAL_DATA and PROJ_LIB are defined and what
>> their values are?
>> Traian
>> Sent: Monday, April 24, 2006 8:59 AM
>> You're right Traian, but all dll's are builded as debug. I've omitted
>> this
>> detail because I read this in the pdf. Excuse me this mistake.
>> So, all Webtier.sln and Oem.sln have been compiled in debug mode, all
>> dll's have 'd' character at the end:
>> ACEd.dll
>> I've attached a screeenshot.
>>> One thing bothers me here. The exception message says it is
> attempting
>>> to load MapGuideDotNetApid.dll, which is a debug build of the API
dll
>>> (notice the d). The debug dll expects to find other debug dlls like
>>> MgCommond.dll and ACEd.dll. The list you give me has no 'd', which
>> leads
>>> me to believe these are release dlls. You need either all debug or
> all
>>> release builds of the dlls.
>>> Traian
>>> Sent: Monday, April 24, 2006 8:40 AM
>>> Hi Traian,
>>> I was thinking this, for this reason, I was put all dll's generated
>> with
>>> WebTier.sln in the same directory that exe file. So, the directory
>>> contains:
>>> ACE.dll
>>> All Api dll's : MapGuideJavaApi.dll ...
>>> MapguideUnmanagedApi.dll
>>> MgCommon.dll
>>> MgCoordinateSystem.dll
>>> I don't know nothing about dependency tool. I never have used it. I
>> will
>>> search in the net.
>>>> Could it be that it is looking for the dll that contains
>>>> MgInitializeWebTier (or one of its dependencies) and not finding
it?
>>> Do
>>>> you have the dependency tool (depends.exe). Could you run it
against
>>>> MapGuideDotNetApid.dll and see which dlls it depends on and is not
>>>> finding?
>>>> For example, when you add a managed dependency, if that dll has
>>>> unmanaged dependencies (like MgCommond.dll in our case), the
>> unmanaged
>>>> dependencies will not get automatically copied to the .exe
directory
>>> and
>>>> you will need to do it by hand.
>>>> Traian
>>>> Sent: Monday, April 24, 2006 7:18 AM
>>>> Subject: [mapguide-dev] problems initializing web tier
>>>> Hello list,
>>>> When I try to connect to the server in .NET, I get the exception:
>>>> 'An unhandled exception of type
>>> 'OSGeo.MapGuide.MgFileNotFoundException'
>>>> occurred in MapGuideDotNetApid.dll'
>>>> I've added as a reference 'MapGuideDotNetApi.dll' in the project.
>>>> The sample code to establish my conenction is:
>>>> // This is a sample windows form application in C#.
>>>> // I've tried with @"c:\pathtofile\webconfig.ini".
>>>> // Here, the file is in the same directory that .exe
>>>> // I've changed the IP address in the webconfig.ini
>>>> // Here, I get the exception
>>>> MapGuideApi.MgInitializeWebTier("webconfig.ini");
>>>> // I've tried several paths and combinations but
>>>> // always get the same exception.
>>>> MgUserInformation userInfo = new
>>>> MgUserInformation("Administrator","admin");
>>>> MgSiteConnection siteConn = new MgSiteConnection();
>>>> siteConn.Open(userInfo);
>>>> Antonio Lucas
>>>> Software Engineer
>>>> SER&TEC S.L
>>>> Phone: +34 96 395 95 13
>>>> www.srtec.com
>>>> Valencia (Spain)
>>>> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>>>> For additional commands, e-mail: dev-help at mapguide.osgeo.org
>>> Antonio Lucas
>>> Software Engineer
>>> SER&TEC S.L
>>> www.srtec.com
>>> Valencia (Spain)
>> Antonio Lucas
>> Software Engineer
>> SER&TEC S.L
>> www.srtec.com
>> Valencia (Spain)
> Antonio Lucas
> Software Engineer
> SER&TEC S.L
> www.srtec.com
> Valencia (Spain)
Antonio Lucas
Software Engineer
SER&TEC S.L
www.srtec.com
Valencia (Spain)
More information about the Mapguide-internals mailing list
