[mapguide-dev] mg version stamp
Tom Fukushima tom.fukushima at autodesk.com
Thu Oct 26 13:07:45 EDT 2006
Hi Haris,
Are you seeing a 1.0.1 or a I see from the ServerCore.rc file
that the version is set to  I'll see if we can get that updated
to the correct version numbers for any postings we do from now on.  It
should be for this source tarball.
Thanks for pointing this out.
Sent: Wednesday, October 25, 2006 6:13 PM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] mg version stamp
I have successfully build from sources and used MG 1.0.2 on windows XP
But versions of build files are still 1.0.1. Where is version stamped
for this file ( like mgserver.exe) in which make files?
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20061026/755dd5c0/attachment.html
More information about the Mapguide-internals mailing list
