[mapguide-internals] MGOS 2.0 beta 2 candidate
Jason Birch Jason.Birch at nanaimo.ca
Mon Dec 10 16:31:49 EST 2007
Weird.  Maybe setting it through the UI adds a period, or escapes the /
or something.
Are you able to check it out after a failed installer using the MetaEdit
utility?
http://support.microsoft.com/kb/232068
BTW, I'm surprised that it's in there as text/plain.  JSON's official
IANA media type is application/json
http://www.iana.org/assignments/media-types/application/
http://www.ietf.org/rfc/rfc4627.txt
Jason
-----Original Message-----
Subject: Re: [mapguide-internals] MGOS 2.0 beta 2 candidate
I just added the mime type again, exactly as it appeared after the
install, and it works.
I tried the installer twice with the same result.
Kenneth, GEOGRAF A/S skrev:
> I fixed it by deleting the MIME entry from the MapGuide folder
> (.json,text/plain).
> No idea why it is a problem.
> I seem to recal that some fusion stuff did not work without the entry?
More information about the mapguide-internals mailing list
