[Mapguide_dev] svn commit: r1036 - Add missing ReadNext() check
Walt Welton-Lair walt.welton-lair at autodesk.com
Mon Jan 8 10:49:08 EST 2007
r1036 | waltweltonlair | 2007-01-08 17:40:08 +0100 (Mon, 08 Jan 2007) |
10 lines
The buffer web code was calling ReadNext on an MgSpatialContextReader
without
checking the return value.  It then immediately called
GetCoordinateSystemWkt
on the reader.  This generates an MgIndexOutOfRangeException if there
are no
spatial contexts.  Updated the code to only call GetCoordinateSystemWkt
if
ReadNext returns true.
The fix was made for all three web tier flavors: ASPX, PHP, JSP.
--- mapviewerjava/buffer.jsp    (revision 1035)
+++ mapviewerjava/buffer.jsp    (revision 1036)
@@ -221,17 +221,10 @@
             MgResourceIdentifier featSourceId = new
MgResourceIdentifier(selLayer.GetFeatureSourceId());
             MgSpatialContextReader ctxs =
featureSrvc.GetSpatialContexts(featSourceId, true);
             String srsDefDs = "";
-            if(ctxs != null)
-                ctxs.ReadNext();
+            if(ctxs != null && ctxs.ReadNext())
                 srsDefDs = ctxs.GetCoordinateSystemWkt();
-                if(srsDefDs == null || srsDefDs.length() == 0)
-                    excludedLayers++;
-                    continue;
-            else
+            if(srsDefDs == null || srsDefDs.length() == 0)
                 excludedLayers++;
                 continue;
@@ -505,16 +498,16 @@
 String GetMapSrs(MgMap map)
-    try
+    try
         String srs = map.GetMapSRS();
-        if(!srs.equals(""))
+        if(!srs.equals(""))
             return srs;
     catch(MgException e)
     //No SRS, set to ArbitrayXY meters
     return
"LOCALCS[\"*XY-MT*\",LOCAL_DATUM[\"*X-Y*\",10000],UNIT[\"Meter\",
1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
--- mapviewernet/buffer.aspx    (revision 1035)
+++ mapviewernet/buffer.aspx    (revision 1036)
@@ -202,17 +202,10 @@
-            if (ctxs != null)
-                ctxs.ReadNext();
+            if (ctxs != null && ctxs.ReadNext())
-                if (srsDefDs == null || srsDefDs.Length == 0)
-                    excludedLayers++;
-                    continue;
-            else
+            if (srsDefDs == null || srsDefDs.Length == 0)
                 excludedLayers++;
                 continue;
--- mapviewerphp/buffer.php     (revision 1035)
+++ mapviewerphp/buffer.php     (revision 1036)
@@ -191,17 +191,10 @@
             $featSourceId = new
MgResourceIdentifier($selLayer->GetFeatureSourceId());
             $ctxs = $featureSrvc->GetSpatialContexts($featSourceId,
true);
             $srsDefDs = "";
-            if($ctxs != null)
-                $ctxs->ReadNext();
+            if($ctxs != null && $ctxs->ReadNext())
                 $srsDefDs = $ctxs->GetCoordinateSystemWkt();
-                if($srsDefDs == "")
-                    $excludedLayers ++;
-                    continue;
-            else
+            if($srsDefDs == "")
                 $excludedLayers ++;
                 continue;
@@ -213,7 +206,7 @@
             if($arbitraryDsSrs)
                 $dsSrsUnits = $srsDs->GetUnits();
             // exclude layer if:
             //  the map is non-arbitrary and the layer is arbitrary or
vice-versa
             //     or
@@ -474,9 +467,9 @@
 function GetMapSrs($map)
     $srs = $map->GetMapSRS();
-    if($srs != "")
+    if($srs != "")
         return $srs;
     return
 W       E         @__   __o
   A   T   R   @___    _ \<,_
     L           @_   (*)/ (*)
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070108/95abc826/attachment.html
More information about the Mapguide-internals mailing list
