[Mapguide_dev] MapGuide Open Source 1.1.0 RC2
Trevor Wekel trevor.wekel at autodesk.com
Mon Jan 8 11:41:57 EST 2007
Hi Tom,
I would like to put a TCP/IP stream version check in the 1.1.0 release
to help catch versioning issues between the Web Extensions and Server
code bases.  Over time, improvements in the TCP/IP protocol will be
made.  Some of these improvements could break compatibility with older
releases.
Thanks,
Trevor
  _____
[mailto:mapguide_dev-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Sunday, January 07, 2007 9:26 PM
To: mapguide_dev at lists.osgeo.org
Subject: [Mapguide_dev] MapGuide Open Source 1.1.0 RC2
I would like to release MapGuide Open Source 1.1.0 RC2 in a couple of
weeks. This means that approved defect submissions to the 1.1.0 stream
need to be made by next weekend.  If you have a defect fix that you
would like to submit, please send it to this list for review.  If it is
a security related defect fix, please send it to me directly for review.
Thanks
Tom
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070108/e7ad3f70/attachment.html
More information about the Mapguide-internals mailing list
