[Mapguide_dev] MapGuide Open Source 1.1.0 RC2
Tom Fukushima tom.fukushima at autodesk.com
Mon Jan 8 11:59:52 EST 2007
Hi Trevor,
I would like to get an idea of the risk and size of the change.  Can you
give me the revision numbers for the submissions for this to the trunk?
Thanks
Tom
  _____
Sent: Monday, January 08, 2007 9:42 AM
To: Tom Fukushima; mapguide_dev at lists.osgeo.org
Subject: RE: [Mapguide_dev] MapGuide Open Source 1.1.0 RC2
Hi Tom,
I would like to put a TCP/IP stream version check in the 1.1.0 release
to help catch versioning issues between the Web Extensions and Server
code bases.  Over time, improvements in the TCP/IP protocol will be
made.  Some of these improvements could break compatibility with older
releases.
Thanks,
Trevor
  _____
[mailto:mapguide_dev-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Sunday, January 07, 2007 9:26 PM
To: mapguide_dev at lists.osgeo.org
Subject: [Mapguide_dev] MapGuide Open Source 1.1.0 RC2
I would like to release MapGuide Open Source 1.1.0 RC2 in a couple of
weeks. This means that approved defect submissions to the 1.1.0 stream
need to be made by next weekend.  If you have a defect fix that you
would like to submit, please send it to this list for review.  If it is
a security related defect fix, please send it to me directly for review.
Thanks
Tom
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070108/3d6ec394/attachment.html
More information about the Mapguide-internals mailing list
