[mapguide-internals] RFC required for tile caching changes?
Paul Spencer pspencer at dmsolutions.ca
Sun Jan 14 13:58:38 EST 2007
FWIW, Traian's suggestion for naming folders based on a mod of r/c is
essentially the same approach I took with ka-Map (for the same reason
that Chris brought this up) and it seems to work very well.  In ka-
Map, tiles are rendered in blocks of about 2000x2000 pixels (tile
size is configurable but you might get 10 x 10 tiles in a typical
configuration) and they would go in one of these sub-directories.  I
think I figured out that this would be enough directories to decently
cache a pretty large area (say, all of the US) without running into
file system limits for most scales.
It would be interesting to know the limits on:
* files per directory
* directories per directory
* total number of directories
* total number of files
* minimum block(?) size in the file system compared to typical size
of a tile (wasted space per tile).
for various operating systems/file system combinations.  I know we
use ReiserFS because it handles lots of small files better than ext3
for instance.  Knowing some of this might help make the caching
system more tunable in different environments.
Paul
On 13-Jan-07, at 11:09 AM, Traian Stanev wrote:
> Can you also give an example for tiles with negative indices?
> For example if in the current scheme the tile is -33, -64, what
> would be the resulting directory path?
> R-2/C-3/-3_-4
> What about tile -1,-1
> Another suggestion I have -- name the folder part of the path (30 *
> tile index div 30) and then the file part would be (tile index mod
> 30).
> So for tile 33,64 the folder would be:
> Base Layer Group/30/60/3_4.png
> And for tile -33,-64 the folder would be:
> Base Layer Group/-30/-60/-3_-4.png
> For tile 1,1, the folder would be:
> Base Layer Group/0/0/1_1.png
> For tile -1,-1 the folder would be:
> Base Layer Group/-0/-0/-1_-1.png
> It's a little weird around 0, but it allows for arbitrary groupings
> of tiles in folders (they don't have to be 30x30) since the tile
> index can be computed directly from the file path, by adding the
> folder term to the file path term.
> Also, can you tell us what the problem is with having too many
> images in one directory? Is it a file system issue? And how many
> tiles is the limit, i.e. why is 30x30 the preferred grouping and
> not 1000x1000 for example?
> Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org on behalf of Jason
> Birch
> Sent: Fri 1/12/2007 8:57 PM
> To: MapGuide Internals Mail List
> Cc:
> Subject: RE: [mapguide-internals] RFC required for tile caching
> changes?
> Can I forward this to the "tiling" list for comment?
> From: mapguide-internals-bounces at lists.osgeo.org on behalf of Chris
> Claydon
> Sent: Fri 2007-01-12 12:24 PM
> changes?
> A sample tile location would be as follows:
> ……\ Repositories\TileCache\Samples_Sheboygan_Maps_Sheboygan\7\Base
> The R and C indices correspond to rows and columns where each row
> contains 30 tiles vertically and each column contains 30 tiles
> horizontally.
> This indicates that:
> 1)       We’re at zoom level 7
> 2)       We’re in grouped row 2
> 3)       We’re in grouped column 3
> 4)       The tile location within this grouped row/column
> combination is (3,4).
> The R and C indices never take a zero value (to avoid issues with
> negative values around the origin), so this tile corresponds to a
> location of (33, 64) in the old scheme.
> I took a quick look at the Tile Map Service Specification, but it
> doesn’t appear to support the concept of grouping blocks of tiles
> into subfolders in its current form. Can you provide more
> information on whether this is possible?
> Chris.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
