[mapguide-internals] ogr postgis layer problems
Traian Stanev traian.stanev at autodesk.com
Wed Jan 31 15:33:12 EST 2007
Hi Paul.
I tried it against an SHP file and selection is definitely not working
right. :)
To avoid the disappearing map problem, you can disable connection
pooling for the OGR provider in the serverconfig.ini file. This will
prevent the map from disappearing (since the connection is not reused
after it breaks during selection), but it will not make selection work.
I will see what can be done about fixing this and let you know.
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer (External)
Sent: Tuesday, January 30, 2007 9:18 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] ogr postgis layer problems
Hi all,
I am looking into an issue regarding postgis layers loaded via the OGR
provider for a client.  The postgis layer is functioning normally when
the map loads (it is initially off but it can be toggled on/off no
problem).  It can be queried using the select.  However, when the layer
has had features selected on it, the next action causes the layer to be
turned off and the layer cannot be turned back on without restarting the
service and web browser.
Any ideas what might be going on?  Bug in the OGR provider?  AJAX
Viewer?  Bad data?
Cheers
Paul
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
