[mapguide-internals] ogr postgis layer problems
Wed Jan 31 01:52:28 EST 2007
Traian Stanev wrote:
> Hi Frank,
> I am applying the FID filter as an attribute filter, using the following
> call:
> layer->SetAttributeFilter(mbattrsql);
> where layer is an OGRLayer. After that in the case of Select I call
> layer->ResetReading() before reading the resulting features. I basically
> treat the string representation of the FDO attribute filter (mbattrsql)
> as a valid OGR filter. I don't know what OGR does underneath, may be it
> uses ExecuteSQL -- you tell me.
Traian,
If you aren't calling it explicitly then it isn't happening and this isn't
the problem.
 > I do acknowledge that doing this for
> attribute filters is extremely hopeful (meaning that the assumption that
> it works is based on pure belief in miracles :-), but I did do some
> limited testing and other attribute filters worked well as layer filters
> in MapGuide.
> In general I spent very little time on the filter handling in the OGR
> provider since I didn't have much time and wasn't sure how useful it
> would be. I'm willing to fix it up if it turns out to be the problem. In
> particular, I didn't bother to support queries which are more than a
> combination of one spatial filter and one attribute filter -- which is
> about par for most MapGuide operations.
I don't see any obvious sign of problems in what you are doing.
> Traian
> P.S. the provider Paul is using is compiled with GDAL 1.3.2.
I'd encourage trying it with GDAL 1.4.0 if that is practical.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the mapguide-internals mailing list
