[mapguide-internals] ogr postgis layer problems
Traian Stanev traian.stanev at autodesk.com
Tue Jan 30 23:34:06 EST 2007
Hi Frank,
I am applying the FID filter as an attribute filter, using the following call:
layer->SetAttributeFilter(mbattrsql);
where layer is an OGRLayer. After that in the case of Select I call layer->ResetReading() before reading the resulting features. I basically treat the string representation of the FDO attribute filter (mbattrsql) as a valid OGR filter. I don't know what OGR does underneath, may be it uses ExecuteSQL -- you tell me. I do acknowledge that doing this for attribute filters is extremely hopeful (meaning that the assumption that it works is based on pure belief in miracles :-), but I did do some limited testing and other attribute filters worked well as layer filters in MapGuide.
In general I spent very little time on the filter handling in the OGR provider since I didn't have much time and wasn't sure how useful it would be. I'm willing to fix it up if it turns out to be the problem. In particular, I didn't bother to support queries which are more than a combination of one spatial filter and one attribute filter -- which is about par for most MapGuide operations.
Traian
P.S. the provider Paul is using is compiled with GDAL 1.3.2.
	-----Original Message-----
	From: mapguide-internals-bounces at lists.osgeo.org on behalf of Frank Warmerdam (External)
	Sent: Wed 1/31/2007 12:31 AM
	To: MapGuide Internals Mail List
	Cc:
	Subject: Re: [mapguide-internals] ogr postgis layer problems
	Traian Stanev wrote:
	> What you are describing seems to me to lead to a bug in the OGR provider
	> in the case where a filter is used that is a combination of a spatial
	> filter and FID filter, which is what the selection rendering code uses
	> to get the features that have to draw as selected overlay. Since the
	> selection itself seems to work for you, my guess is that the provider
	> messes something up during such a query that results in a confusion
	> during subsequent queries.
	> My guess could be wrong though... To narrow it down, I can look over the
	> code and check for obvious flaws (I don't have the time to install
	> PostGIS right now), and you can try connecting to an SHP file with the
	> OGR provider to see if selection works for that. Another thing you can
	> try is run the server in interactive mode and check for any console
	> output. The provider (and OGR itself) will sometimes printf stuff to the
	> console.
	Paul,
	I think Traian's approach is good.  See if you can reproduce the problem
	with other providers to isolate whether it is a systematic problem, or
	a driver specific problem.
	Traian - does the OGR provider use ExecuteSQL() at all to get results?
	Setting attributes filters on ExecuteSQL() results often didn't work
	before the 1.4.0 release of GDAL/OGR.  So if the FID filter is being
	applied as an attribute filter and you are using ExecuteSQL() to get
	the resultset this might explain it.
	Best regards,
	and watch the world go round - Rush    | President OSGeo, http://osgeo.org
	mapguide-internals mailing list
	mapguide-internals at lists.osgeo.org
	http://lists.osgeo.org/mailman/listinfo/mapguide-internals
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070130/fd4fb005/attachment-0001.html
More information about the mapguide-internals mailing list
