[mapguide-internals] ogr postgis layer problems
Wed Jan 31 00:31:30 EST 2007
Traian Stanev wrote:
> What you are describing seems to me to lead to a bug in the OGR provider
> in the case where a filter is used that is a combination of a spatial
> filter and FID filter, which is what the selection rendering code uses
> to get the features that have to draw as selected overlay. Since the
> selection itself seems to work for you, my guess is that the provider
> messes something up during such a query that results in a confusion
> during subsequent queries.
> My guess could be wrong though... To narrow it down, I can look over the
> code and check for obvious flaws (I don't have the time to install
> PostGIS right now), and you can try connecting to an SHP file with the
> OGR provider to see if selection works for that. Another thing you can
> try is run the server in interactive mode and check for any console
> output. The provider (and OGR itself) will sometimes printf stuff to the
> console.
Paul,
I think Traian's approach is good.  See if you can reproduce the problem
with other providers to isolate whether it is a systematic problem, or
a driver specific problem.
Traian - does the OGR provider use ExecuteSQL() at all to get results?
Setting attributes filters on ExecuteSQL() results often didn't work
before the 1.4.0 release of GDAL/OGR.  So if the FID filter is being
applied as an attribute filter and you are using ExecuteSQL() to get
the resultset this might explain it.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the mapguide-internals mailing list
