[mapguide-internals] Rfc 21 posted
Kenneth, GEOGRAF A/S ks at geograf.dk
Sat Jun 2 14:35:45 EDT 2007
Yes, they take into account that you can have any number of runtime maps.
The current viewer implementations only create one runtime map, and
always name the map:
"Session:" + sessionId + "//" + mapName + ".Map"
The security system should not allow one session to interfere with
another session (except for administrators).
I belive that the system works like this already.
I have updated the Rfc, so the mapName parameter is now a full
MgResourceIdentifier, rather than just the map name.
This will ensure that it can read/write a runtime map of any name,
including the naming scheme currently used.
Regards, GEOGRAF A/S
Paul Spencer wrote:
> Personally, I would only want it to affect a specific map within a
> specific session. I believe it is possible to have more than one map
> in the session based on the same map definition and I think this
> should only affect the specifically named map. It certainly should not
> affect other users in other sessions.
> Cheers
> Paul
> On 31-May-07, at 7:34 PM, Walt Welton-Lair wrote:
>> Do these new APIs take into account the caller's session? You can have
>> multiple users viewing the same map definition, and therefore there are
>> multiple runtime maps associated with that map definition (each part of
>> a different session).
>> I also can't remember - is it possible to have two runtime maps for the
>> same map definition within a single session?
>> Walt
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
>> Dechant
>> Sent: Friday, June 01, 2007 1:10 AM
>> To: MapGuide Internals Mail List
>> Subject: RE: [mapguide-internals] Rfc 21 posted
>> Here are my comments.
>> In the APIs below there is no need for the "mapName" parameter because
>> everything is already contained in the underlying map resource
>> referenced by the MgResourceIdentifier so the parameter is redundant:
>> void MgMap::UpdateRuntimeMap(MgResourceService* resourceService,
>> MgResourceIdentifier* mapDefinition, CREFSTRING mapName); void
>> MgMap::UpdateMapDefinition(MgResourceService* resourceService,
>> For the other proposed APIs below the "mapName" parameter should be
>> replaced with the MgResourceIdentifier because we do operations with
>> resource IDs:
>> MgByteReader* mapDefinitionAsXml, CREFSTRING mapName);
>> MgByteReader* MgMap::MapDefinitionFromRuntimeMap(MgResourceService*
>> resourceService, CREFSTRING mapName); void
>> MgMap::CreateMap(MgResourceService* resourceService, MgByteReader*
>> Thanks,
>> Bruce
>> Sent: May 29, 2007 2:56 AM
>> Subject: [mapguide-internals] Rfc 21 posted
>> I have posted a Rfc.
>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc21
>> --Regards, Kenneth, GEOGRAF A/S
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
